[mapguide-commits] r7577 - trunk/Tools/Maestro/Maestro.MapViewer
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Jun 7 02:07:11 PDT 2013
Author: jng
Date: 2013-06-07 02:07:10 -0700 (Fri, 07 Jun 2013)
New Revision: 7577
   trunk/Tools/Maestro/Maestro.MapViewer/LegendPresenter.cs
#2248: The Maestro MapViewer legend will still infinite loop on a background thread if we have groups not set to display in the legend. This submission handles this particular case.
Modified: trunk/Tools/Maestro/Maestro.MapViewer/LegendPresenter.cs
--- trunk/Tools/Maestro/Maestro.MapViewer/LegendPresenter.cs	2013-06-07 09:04:00 UTC (rev 7576)
+++ trunk/Tools/Maestro/Maestro.MapViewer/LegendPresenter.cs	2013-06-07 09:07:10 UTC (rev 7577)
@@ -530,36 +530,44 @@
                             node.Expand();
-                //Process parented layers
-                while (remainingLayers.Count > 0)
+            //Process parented layers
+            while (remainingLayers.Count > 0)
+                List<RuntimeMapLayer> toRemove = new List<RuntimeMapLayer>();
+                for (int j = remainingLayers.Count - 1; j >= 0; j--)
-                    List<RuntimeMapLayer> toRemove = new List<RuntimeMapLayer>();
-                    for (int j = remainingLayers.Count - 1; j >= 0; j--)
+                    var grpName = remainingLayers[j].Group;
+                    var parentGroup = _map.Groups[grpName];
+                    if (parentGroup != null)
-                        var grpName = remainingLayers[j].Group;
-                        var parentGroup = _map.Groups[grpName];
-                        if (parentGroup != null && nodesById.ContainsKey(parentGroup.ObjectId))
+                        if (nodesById.ContainsKey(parentGroup.ObjectId))
                             var node = CreateLayerNode(remainingLayers[j]);
                             if (node != null)
-                                nodesById[parentGroup.ObjectId].Nodes.Insert(0, node);
+                                nodesById[parentGroup.ObjectId].Nodes.Add(node); //.Insert(0, node);
                                 if (remainingLayers[j].ExpandInLegend)
                                     node.Expand();
                             toRemove.Add(remainingLayers[j]);
-                    //Whittle down this list
-                    if (toRemove.Count > 0)
-                        foreach (var g in toRemove)
+                        else //Group may not even be set to show in legend. Check for this
-                            remainingLayers.Remove(g);
+                            if (!parentGroup.ShowInLegend)
+                                toRemove.Add(remainingLayers[j]);
+                //Whittle down this list
+                if (toRemove.Count > 0)
+                    foreach (var g in toRemove)
+                        remainingLayers.Remove(g);
             //Now expand any relevant groups
More information about the mapguide-commits mailing list
