[mapguide-commits] r7481 - sandbox/jng/queryfeatures_v2/Web/src/mapviewernet
svn_mapguide at osgeo.org
Wed May 8 05:10:26 PDT 2013
Author: jng
Date: 2013-05-08 05:10:26 -0700 (Wed, 08 May 2013)
New Revision: 7481
Removed:
sandbox/jng/queryfeatures_v2/Web/src/mapviewernet/getselectedfeatures.aspx
sandbox/jng/queryfeatures_v2/Web/src/mapviewernet/mapframe.aspx
So long getselectedfeatures.aspx. This RFC has eliminated the need for you
Deleted: sandbox/jng/queryfeatures_v2/Web/src/mapviewernet/getselectedfeatures.aspx
--- sandbox/jng/queryfeatures_v2/Web/src/mapviewernet/getselectedfeatures.aspx 2013-05-08 12:10:10 UTC (rev 7480)
+++ sandbox/jng/queryfeatures_v2/Web/src/mapviewernet/getselectedfeatures.aspx 2013-05-08 12:10:26 UTC (rev 7481)
@@ -1,397 +0,0 @@
-<%@ Page Language="C#" %>
-<%@ Import Namespace="System" %>
-<%@ Import Namespace="System.IO" %>
-<%@ Import Namespace="System.Collections.Generic" %>
-<%@ Import Namespace="System.Web" %>
-<%@ Import Namespace="System.Xml" %>
-<%@ Import Namespace="System.Globalization" %>
-<%@ Import Namespace="OSGeo.MapGuide" %>
-<!-- #include File="common.aspx" -->
-<script runat="server">
- class SelectionSet
- private Dictionary<string, List<Feature>> _layers;
- public SelectionSet()
- _layers = new Dictionary<String, List<Feature>>();
- public void AddFeature(Feature feat)
- if (!_layers.ContainsKey(feat.LayerName))
- _layers[feat.LayerName] = new List<Feature>();
- _layers[feat.LayerName].Add(feat);
- public String[] GetLayers()
- return new List<String>(_layers.Keys).ToArray();
- public Feature[] GetFeatures(String layerName)
- if (_layers.ContainsKey(layerName))
- return _layers[layerName].ToArray();
- return null;
- class ZoomBox
- public double MinX;
- public double MinY;
- public double MaxX;
- public double MaxY;
- class FeatureProperty
- public String Name;
- public String Value;
- class Feature
- public String LayerName;
- public ZoomBox Zoom;
- private Dictionary<string, FeatureProperty> _properties;
- public Feature(string layerName)
- this.LayerName = layerName;
- _properties = new Dictionary<string, FeatureProperty>();
- public void AddProperty(FeatureProperty prop)
- _properties[prop.Name] = prop;
- public FeatureProperty[] GetProperties()
- return new List<FeatureProperty>(_properties.Values).ToArray();
- String mapName;
- String sessionId;
- String locale;
- CultureInfo culture;
- System.Text.RegularExpressions.Regex regex;
- static NameValueCollection GetLayerPropertyMappings(MgResourceService resSvc, MgLayerBase layer)
- NameValueCollection mappings = new NameValueCollection();
- MgByteReader content = resSvc.GetResourceContent(layer.GetLayerDefinition());
- XmlDocument doc = new XmlDocument();
- doc.LoadXml(content.ToString());
- XmlNodeList propNodes = doc.SelectNodes("//LayerDefinition/VectorLayerDefinition/PropertyMapping");
- foreach (XmlNode propNode in propNodes)
- String name = propNode["Name"].InnerText;
- String value = propNode["Value"].InnerText;
- mappings[name] = value;
- return mappings;
- String GetPropertyValueFromFeatureReader(MgFeatureReader reader, MgAgfReaderWriter agfRw, int propType, String propName)
- String value = "";
- switch(propType)
- case MgPropertyType.Boolean:
- value = String.Format(culture, "{0}", reader.GetBoolean(propName));
- break;
- case MgPropertyType.Byte:
- value = String.Format(culture, "{0:d}", reader.GetByte(propName));
- break;
- case MgPropertyType.DateTime:
- value = GetDateTimeString(reader.GetDateTime(propName)); // yyyy-mm-dd is enforced regardless of locale
- break;
- case MgPropertyType.Single:
- value = String.Format(culture, "{0:f}", reader.GetSingle(propName));
- break;
- case MgPropertyType.Double:
- value = String.Format(culture, "{0:f}", reader.GetDouble(propName));
- break;
- case MgPropertyType.Int16:
- value = String.Format(culture, "{0:d}", reader.GetInt16(propName));
- break;
- case MgPropertyType.Int32:
- value = String.Format(culture, "{0:d}", reader.GetInt32(propName));
- break;
- case MgPropertyType.Int64:
- value = String.Format(culture, "{0:d}", reader.GetInt64(propName));
- break;
- case MgPropertyType.String:
- value = JsonEscape(reader.GetString(propName)); //String content is arbitrary
- value = regex.Replace(value, " ").Trim();
- break;
- default: //NOT PRESENTABLE IN PROPERTY GRID
- value = "";
- break;
- return value;
- static String GetDateTimeString(MgDateTime value)
- return String.Format("{0}-{1}-{2}", value.Year, value.Month, value.Day);
- void GetParameters(NameValueCollection param)
- mapName = param["MAPNAME"];
- sessionId = param["SESSION"];
- locale = param["LOCALE"];
- void GetRequestParameters()
- if (Request.RequestType == "POST")
- GetParameters(Request.Form);
- else
- GetParameters(Request.QueryString);
- String JsonEscape(String str)
- return EscapeForHtml(str).Replace("\\", "\\\\");
- String JsonifyError(Exception ex)
- return "{\"Error\":{\"Message\":\"" + JsonEscape(ex.Message) + "\",\"StackTrace\":\"" + JsonEscape(ex.StackTrace) + "\"}}";
- static String GetJson(SelectionSet set)
- A sample of the JSON output this method will produce:
- "Layer1" : [
- 'values' { "name" : "name1" , "value" : "value1" },
- 'zoom' : { x: num1, y: num2 }
- "Layer2" : [
- 'values' { "name" : "name2" , "value" : "value2" },
- if (set == null)
- return "";
- StringBuilder sb = new StringBuilder();
- //Begin selection set
- sb.Append("{");
- String[] layers = set.GetLayers();
- for (int i = 0; i < layers.Length; i++)
- //Begin layer
- sb.Append("\"" + layers[i] + "\" : [");
- Feature[] features = set.GetFeatures(layers[i]);
- for (int j = 0; j < features.Length; j++)
- Feature feat = features[j];
- //begin feature
- //begin feature properties
- sb.Append("{\"values\" : [");
- FeatureProperty[] properties = feat.GetProperties();
- for(int k = 0; k < properties.Length; k++)
- FeatureProperty fp = properties[k];
- sb.Append("{\"name\" : \"" + fp.Name + "\", \"value\" : \"" + fp.Value + "\" }");
- if (k != properties.Length - 1)
- sb.Append(",");
- //end feature properties
- //begin zoom
- sb.Append("], \"zoom\" : ");
- if (feat.Zoom == null)
- sb.Append("null");
- else
- sb.Append("{" + String.Format(CultureInfo.InvariantCulture, "\"minx\" : {0}, \"miny\" : {1}, \"maxx\": {2}, \"maxy\": {3}", feat.Zoom.MinX, feat.Zoom.MinY, feat.Zoom.MaxX, feat.Zoom.MaxY) + "}");
- //end zoom
- //end feature
- sb.Append("}");
- if (j != features.Length - 1)
- sb.Append(",");
- //End Layer
- sb.Append("]");
- if (i != layers.Length - 1)
- sb.Append(",");
- //End selection set
- sb.Append("}");
- return sb.ToString();
-</script>
- mapName = "";
- sessionId = "";
- locale = "";
- GetRequestParameters();
- if (String.IsNullOrEmpty(locale))
- locale = GetDefaultLocale();
- culture = CultureInfo.GetCultureInfo(locale);
- regex = new System.Text.RegularExpressions.Regex("\\s+");
- //HACK: The default locale (en) resolves to a neutral culture, .net forbids the use of
- //neutral cultures for formatting purposes, so default to InvariantCulture if the resolved
- //culture is not neutral.
- if (culture.IsNeutralCulture)
- culture = CultureInfo.InvariantCulture; //We need a non-neutral culture
- try
- MgUserInformation cred = new MgUserInformation(sessionId);
- cred.SetClientIp(GetClientIp(Request));
- cred.SetClientAgent(GetClientAgent());
- MgSiteConnection site = new MgSiteConnection();
- site.Open(cred);
- MgResourceService resSvc = (MgResourceService)site.CreateService(MgServiceType.ResourceService);
- MgMap map = new MgMap(site);
- map.Open(mapName);
- MgSelection selection = new MgSelection(map);
- selection.Open(resSvc, mapName);
- MgReadOnlyLayerCollection layers = selection.GetLayers();
- if (layers != null && layers.Count > 0)
- int layerCount = layers.Count;
- MgAgfReaderWriter agfRW = new MgAgfReaderWriter();
- SelectionSet selectionSet = new SelectionSet();
- for (int i = 0; i < layerCount; i++)
- MgLayerBase layer = layers[i];
- String layerName = layer.Name;
- MgResourceIdentifier fsId = new MgResourceIdentifier(layer.GetFeatureSourceId());
- String className = layer.GetFeatureClassName();
- String geomName = layer.GetFeatureGeometryName();
- MgFeatureQueryOptions query = new MgFeatureQueryOptions();
- NameValueCollection mappings = GetLayerPropertyMappings(resSvc, layer);
- foreach (String key in mappings.Keys)
- query.AddFeatureProperty(key);
- query.AddFeatureProperty(geomName);
- String filter = selection.GenerateFilter(layer, className);
- query.SetFilter(filter);
- MgFeatureReader reader = layer.SelectFeatures(query);
- MgClassDefinition clsDef = reader.GetClassDefinition();
- MgPropertyDefinitionCollection props = clsDef.GetProperties();
- while (reader.ReadNext())
- Feature feat = new Feature(layerName);
- ZoomBox zoom = null;
- for (int k = 0; k < props.Count; k++)
- MgPropertyDefinition propDef = props[k];
- String propName = propDef.Name;
- int propType = reader.GetPropertyType(propName);
- if (mappings[propName] != null || propType == MgPropertyType.Geometry)
- if (!reader.IsNull(propName))
- if (propName == geomName)
- MgByteReader agf = reader.GetGeometry(propName);
- MgGeometry geom = agfRW.Read(agf);
- MgEnvelope env = geom.Envelope();
- MgCoordinate ll = env.GetLowerLeftCoordinate();
- MgCoordinate ur = env.GetUpperRightCoordinate();
- zoom = new ZoomBox();
- zoom.MinX = ll.X;
- zoom.MinY = ll.Y;
- zoom.MaxX = ur.X;
- zoom.MaxY = ur.Y;
- feat.Zoom = zoom;
- else
- value = GetPropertyValueFromFeatureReader(reader, agfRW, propType, propName);
- if (mappings[propName] != null)
- FeatureProperty fp = new FeatureProperty();
- fp.Name = mappings[propName];
- fp.Value = value;
- feat.AddProperty(fp);
- selectionSet.AddFeature(feat);
- reader.Close();
- //Now output the selection set
- Response.AddHeader("Content-Type", "application/json");
- Response.AddHeader("X-JSON", "true");
- Response.Write(GetJson(selectionSet));
- catch (MgException ex)
- Response.Write(JsonifyError(ex));
- catch (Exception ex)
Modified: sandbox/jng/queryfeatures_v2/Web/src/mapviewernet/mapframe.aspx
--- sandbox/jng/queryfeatures_v2/Web/src/mapviewernet/mapframe.aspx 2013-05-08 12:10:10 UTC (rev 7480)
+++ sandbox/jng/queryfeatures_v2/Web/src/mapviewernet/mapframe.aspx 2013-05-08 12:10:26 UTC (rev 7481)
@@ -182,7 +182,6 @@
vpath + "setselection.aspx",
showSlider != 0? "true": "false",
locale,
- vpath + "getselectedfeatures.aspx",
scaleCreationCode,
selectionColor,
mapImgFormat,
More information about the mapguide-commits
