[mapguide-commits] r7482 - sandbox/jng/queryfeatures_v2/Web/src/mapviewerphp
svn_mapguide at osgeo.org
Wed May 8 05:10:42 PDT 2013
Author: jng
Date: 2013-05-08 05:10:41 -0700 (Wed, 08 May 2013)
New Revision: 7482
Removed:
sandbox/jng/queryfeatures_v2/Web/src/mapviewerphp/getselectedfeatures.php
sandbox/jng/queryfeatures_v2/Web/src/mapviewerphp/mapframe.php
So long getselectedfeatures.php. This RFC has eliminated the need for you
Deleted: sandbox/jng/queryfeatures_v2/Web/src/mapviewerphp/getselectedfeatures.php
--- sandbox/jng/queryfeatures_v2/Web/src/mapviewerphp/getselectedfeatures.php 2013-05-08 12:10:26 UTC (rev 7481)
+++ sandbox/jng/queryfeatures_v2/Web/src/mapviewerphp/getselectedfeatures.php 2013-05-08 12:10:41 UTC (rev 7482)
@@ -1,499 +0,0 @@
-<?php
-TODO:
-- Use the property mapping. This will have to be old-fashioned parsing the <PropertyMapping> elements
-of the layer definition. I really wanted to use MgSelection::GetSelectedFeatures(layer, class, true) but realised
-that unless the geometry is mapped, you're not going to see it in the Feature Reader (ie. No zoom point). Right now
-it is returning all properties.
-- I know of a few features in the Sheboygan Dataset that trip up the JSON response. Need to find out of addslashes() fixes this.
-- General cleanup of the code
-//require_once('FirePHPCore/fb.php');
-// Used to model the JSON response.
-class SelectionSet
- private $layers;
- public function __construct()
- $this->layers = array();
- public function AddFeature($feat)
- $layerName = $feat->layerName;
- if(!array_key_exists($layerName, $this->layers))
- $this->layers[$layerName] = array();
- array_push($this->layers[$layerName], $feat);
- public function GetLayers()
- return array_keys($this->layers);
- public function GetFeatures($layerName)
- if(array_key_exists($layerName, $this->layers))
- return $this->layers[$layerName];
- return null;
-class ZoomBox
- public $minx;
- public $miny;
- public $maxx;
- public $maxy;
-// Represents a selected feature property
-class FeatureProperty
- public $name;
- public $value;
-class Feature
- public $layerName;
- public $zoom;
- private $properties;
- public function __construct($layerName)
- $this->layerName = $layerName;
- $this->properties = array();
- public function AddProperty($prop)
- $this->properties[$prop->name] = $prop;
- public function GetProperties()
- return $this->properties;
- include 'common.php';
- include 'constants.php';
- $mapName = "";
- $sessionId = "";
- $locale = "";
- GetRequestParameters();
- if (null == $locale || strlen($locale) == 0)
- $locale = GetDefaultLocale();
- setlocale(LC_ALL, $locale);
- try
- InitializeWebTier();
- $cred = new MgUserInformation($sessionId);
- $cred->SetClientIp(GetClientIp());
- $cred->SetClientAgent(GetClientAgent());
- //connect to the site and get an instance of the resource and feature service
- $site = new MgSiteConnection();
- $site->Open($cred);
- $resourceSrvc = $site->CreateService(MgServiceType::ResourceService);
- //load the map runtime state
- $map = new MgMap($site);
- $map->Open($mapName);
- // Create the selection set
- $selection = new MgSelection($map);
- $selection->Open($resourceSrvc, $mapName);
- $layers = $selection->GetLayers();
- if($layers != null)
- $nLayers = $layers->GetCount();
- $agfRW = new MgAgfReaderWriter();
- $selectionSet = new SelectionSet();
- for ($i = 0; $i < $nLayers; $i++) {
- $lyr = $layers->GetItem($i);
- $layerName = $lyr->GetName();
- //FB::log("Layer Name: " . $lyr->GetName());
- $featResId = new MgResourceIdentifier($lyr->GetFeatureSourceId());
- $class = $lyr->GetFeatureClassName();
- $queryOptions = new MgFeatureQueryOptions();
- $mappings = GetLayerPropertyMappings($resourceSrvc, $lyr);
- //FB::log("Property Mappings for Layer: $layerName");
- foreach($mappings as $name => $value) {
- $queryOptions->AddFeatureProperty($name);
- //FB::log("$name => $value");
- $geomName = $lyr->GetFeatureGeometryName();
- $queryOptions->AddFeatureProperty($geomName);
- $filter = $selection->GenerateFilter($lyr, $class);
- $queryOptions->SetFilter($filter);
- $fr = $lyr->SelectFeatures($queryOptions);
- $clsDef = $fr->GetClassDefinition();
- $props = $clsDef->GetProperties();
- //FB::log("Geometry: $geomName");
- while($fr->ReadNext())
- $feat = new Feature($layerName);
- $zoom = null;
- for ($k = 0; $k < $props->GetCount(); $k++)
- $prop = $props->GetItem($k);
- $propName = $prop->GetName();
- $propType = $fr->GetPropertyType($propName);
- //We only care about mapped properties or geometry properties
- if (array_key_exists($propName, $mappings) || $propType == MgPropertyType::Geometry)
- $value = "";
- if (!$fr->IsNull($propName))
- if(strcmp($propName,$geomName) == 0)
- //We want the centroid so we have a zoom-to point
- $agf = $fr->GetGeometry($propName);
- $geom = $agfRW->Read($agf);
- $env = $geom->Envelope();
- $ll = $env->GetLowerLeftCoordinate();
- $ur = $env->GetUpperRightCoordinate();
- $zoom = new ZoomBox();
- $zoom->minx = $ll->GetX();
- $zoom->miny = $ll->GetY();
- $zoom->maxx = $ur->GetX();
- $zoom->maxy = $ur->GetY();
- $feat->zoom = $zoom;
- //FB::log("zoom: (".$zoom->x.",".$zoom->y.")");
- else
- $value = GetPropertyValueFromFeatureReader($fr, $agfRW, $propType, $propName);
- if (array_key_exists($propName, $mappings))
- $fp = new FeatureProperty();
- $fp->name = $mappings[$propName];
- $fp->value = $value;
- $feat->AddProperty($fp);
- $c = count($feat->GetProperties());
- //FB::log("Selected feature processed ($c)");
- $selectionSet->AddFeature($feat);
- $fr->Close();
- //Now output the selection set
- header("Content-Type: application/json");
- header("X-JSON: true");
- echo GetJson($selectionSet);
- catch(Exception $e)
- echo JsonifyError($e->getMessage(), $e->getTraceAsString());
- catch(MgException $e)
- echo JsonifyError($e->GetDetails(), $e->GetStackTrace());
-function GetJson($selectionSet)
- if($selectionSet == null)
- return "";
- //FB::log("Processing JSON response");
- A sample of the JSON output this method will produce:
- "Layer1" : [
- 'values' { "name" : "name1" , "value" : "value1" },
- 'zoom' : { x: num1, y: num2 }
- "Layer2" : [
- 'values' { "name" : "name2" , "value" : "value2" },
- $layers = $selectionSet->GetLayers();
- $totalLayers = array(); //The data portion of the JSON response
- //FB::log("Layers in selection set: ".count($layers));
- for ($i = 0; $i < count($layers); $i++)
- $layerName = $layers[$i];
- $features = $selectionSet->GetFeatures($layerName);
- //FB::log("Features: ".$features);
- if($features != null)
- //FB::log("Processing layer: $layerName");
- $totalFeaturesOnLayer = array();
- if (count($features) > 0)
- for ($j = 0; $j < count($features); $j++)
- $feat = $features[$j];
- $featureProperties = array();
- $fps = $feat->GetProperties();
- foreach($fps as $fp)
- $name = $fp->name;
- $value = $fp->value;
- //Add JSONified feature property
- array_push($featureProperties, "{\"name\" : \"$name\", \"value\" : \"$value\" }");
- if($feat->zoom != null)
- $minxstr = number_format($feat->zoom->minx, 8, '.','');
- $minystr = number_format($feat->zoom->miny, 8, '.','');
- $maxxstr = number_format($feat->zoom->maxx, 8, '.','');
- $maxystr = number_format($feat->zoom->maxy, 8, '.','');
- array_push($totalFeaturesOnLayer, "{\"values\" : [".join(",", $featureProperties)."], \"zoom\" : { \"minx\": $minxstr, \"miny\": $minystr, \"maxx\": $maxxstr, \"maxy\": $maxystr } }");
- else
- array_push($totalFeaturesOnLayer, "{\"values\" : [".join(",", $featureProperties)."], \"zoom\" : null }");
- //FB::log("Feature processed on layer: $layerName");
- array_push($totalLayers, "\"$layerName\" : [" . join(", ", $totalFeaturesOnLayer) . "]");
- //FB::log("Selected features on layer added to final JSON response");
- //FB::log("Selection layer count: ".count($totalLayers));
- $result = "{" . join(",",$totalLayers) . "}";
- //return json_encode($result);
- return $result;
-function GetPropertyValueFromFeatureReader($fr, $agfRW, $propType, $propName)
- $val = "";
- $tStr = "";
- switch($propType)
- case MgPropertyType::Null:
- $tStr = "Null";
- $val = "";
- break;
- case MgPropertyType::Boolean:
- $tStr = "Boolean";
- $val = sprintf("%s", $fr->GetBoolean($propName));
- break;
- case MgPropertyType::Byte:
- $tStr = "Byte";
- $val = sprintf("%d", $fr->GetByte($propName));
- break;
- case MgPropertyType::DateTime:
- $tStr = "DateTime";
- $val = printDateTime($fr->GetDateTime($propName)); // yyyy-mm-dd is enforced regardless of locale
- break;
- case MgPropertyType::Single:
- $tStr = "Single";
- $val = sprintf("%f", $fr->GetSingle($propName));
- break;
- case MgPropertyType::Double:
- $tStr = "Double";
- $val = sprintf("%f", $fr->GetDouble($propName));
- break;
- case MgPropertyType::Int16:
- $tStr = "Int16";
- $val = sprintf("%d", $fr->GetInt16($propName));
- break;
- case MgPropertyType::Int32:
- $tStr = "Int32";
- $val = sprintf("%d", $fr->GetInt32($propName));
- break;
- case MgPropertyType::Int64:
- $tStr = "Int64";
- $val = sprintf("%d", $fr->GetInt64($propName));
- break;
- case MgPropertyType::String:
- $tStr = "String";
- $val = JsonEscape($fr->GetString($propName)); //String content is arbitrary
- $val = trim(preg_replace('/\s+/',' ',$val));
- break;
- case MgPropertyType::Blob: //NOT PRESENTABLE IN PROPERTY GRID
- $tStr = "BLOB";
- break;
- case MgPropertyType::Clob: //NOT PRESENTABLE IN PROPERTY GRID
- $tStr = "CLOB";
- break;
- case MgPropertyType::Feature: //NOT PRESENTABLE IN PROPERTY GRID
- $tStr = "Feature";
- break;
- case MgPropertyType::Geometry: //NOT PRESENTABLE IN PROPERTY GRID
- $tStr = "Geometry";
- break;
- case MgPropertyType::Raster: //NOT PRESENTABLE IN PROPERTY GRID
- $tStr = "Raster";
- break;
- //FB::log("$propName ($tStr) = $val");
- return $val;
-/* retrieve the property mappings for a layer */
-function GetLayerPropertyMappings($resourceService, $layer) {
- $mappings = array();
- $byteReader = $resourceService->GetResourceContent($layer->GetLayerDefinition());
- $xmldoc = DOMDocument::loadXML(ByteReaderToString($byteReader));
- $mappingNodeList = $xmldoc->getElementsByTagName('PropertyMapping');
- for ($i=0; $i<$mappingNodeList->length; $i++) {
- $mapping = $mappingNodeList->item($i);
- $nameElt = $mapping->getElementsByTagName('Name');
- $name = $nameElt->item(0)->nodeValue;
- $valueElt = $mapping->getElementsByTagName('Value');
- $value = $valueElt->item(0)->nodeValue;
- $mappings[$name] = $value;
- return $mappings;
-function ByteReaderToString($byteReader)
- return $byteReader->ToString();
-function printDateTime($mgDateTime)
- $dayToday = $mgDateTime->GetDay();
- $month = $mgDateTime->GetMonth();
- $year = $mgDateTime->GetYear();
- return $dayToday.".".$month.".".$year;
-function GetParameters($params)
- global $mapName, $sessionId, $locale;
- $mapName = $params['MAPNAME'];
- $sessionId = $params['SESSION'];
- $locale = $params['LOCALE'];
-function JsonEscape($str)
- return str_replace("\\", "\\\\", EscapeForHtml($str));
-function JsonifyError($msg, $st)
- "Error" : {
- "Message" : <exception-message>,
- "StackTrace" : <exception-stack-trace>
- $emsg = JsonEscape($msg);
- $est = JsonEscape($st);
- $json = "{\"Error\":{\"Message\":\"$emsg\",\"StackTrace\":\"$est\"}}";
- return $json;
-function UnescapeMagicQuotes($str)
- if(ini_get("magic_quotes_sybase") == "1")
- return str_replace("''", "'", $str);
- else if(get_magic_quotes_gpc() == "1")
- //Unescape double quotes
- $str = str_replace('\\"', '"', $str);
- //remove additional backslash
- return str_replace("\\", "", $str);
- return $str;
-function GetRequestParameters()
- if($_SERVER['REQUEST_METHOD'] == "POST")
- GetParameters($_POST);
- else
- GetParameters($_GET);
Modified: sandbox/jng/queryfeatures_v2/Web/src/mapviewerphp/mapframe.php
--- sandbox/jng/queryfeatures_v2/Web/src/mapviewerphp/mapframe.php 2013-05-08 12:10:26 UTC (rev 7481)
+++ sandbox/jng/queryfeatures_v2/Web/src/mapviewerphp/mapframe.php 2013-05-08 12:10:41 UTC (rev 7482)
@@ -146,7 +146,6 @@
$vpath . "setselection.php",
$showSlider? "true": "false",
$locale,
- $vpath . "getselectedfeatures.php",
$scaleCreationCode,
$selectionColor,
$mapImgFormat,
More information about the mapguide-commits
