[mapguide-commits] r7889 - in branches/maestro-5.0.x: Maestro Maestro.Editors Maestro.Editors/LayerDefinition/Vector/Scales Maestro.Editors/SymbolDefinition OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org
Wed Oct 2 06:01:50 PDT 2013
Author: jng
Date: 2013-10-02 06:01:50 -0700 (Wed, 02 Oct 2013)
New Revision: 7889
Added:
branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancePropertiesDialog.Designer.cs
branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancePropertiesDialog.cs
branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancePropertiesDialog.resx
branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.Designer.cs
branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.cs
branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.resx
branches/maestro-5.0.x/Maestro.Editors/Maestro.Editors.csproj
branches/maestro-5.0.x/Maestro.Editors/SymbolDefinition/SymbolField.cs
branches/maestro-5.0.x/Maestro/changelog.txt
branches/maestro-5.0.x/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs
#2353: Merge to 5.0.x
Modified: branches/maestro-5.0.x/Maestro/changelog.txt
--- branches/maestro-5.0.x/Maestro/changelog.txt 2013-10-02 11:41:46 UTC (rev 7888)
+++ branches/maestro-5.0.x/Maestro/changelog.txt 2013-10-02 13:01:50 UTC (rev 7889)
@@ -1,5 +1,6 @@
5.0.1
+ - Added missing support for editing symbol instance properties
- Add support in Generic XML editor to re-read XML content from source resource
- Fix: Create Package with custom restore path skips some Load Procedure elements
- Fix: Cannot preview watermarks in Local Map Preview mode
Copied: branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancePropertiesDialog.Designer.cs (from rev 7870, trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancePropertiesDialog.Designer.cs)
--- branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancePropertiesDialog.Designer.cs (rev 0)
+++ branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancePropertiesDialog.Designer.cs 2013-10-02 13:01:50 UTC (rev 7889)
@@ -0,0 +1,322 @@
+namespace Maestro.Editors.LayerDefinition.Vector.Scales
+ partial class SymbolInstancePropertiesDialog
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(SymbolInstancePropertiesDialog));
+ this.groupBox1 = new System.Windows.Forms.GroupBox();
+ this.lblInsertOffsetY = new System.Windows.Forms.Label();
+ this.symInsertOffsetY = new Maestro.Editors.SymbolDefinition.SymbolField();
+ this.lblInsertOffsetX = new System.Windows.Forms.Label();
+ this.symInsertOffsetX = new Maestro.Editors.SymbolDefinition.SymbolField();
+ this.lblScaleY = new System.Windows.Forms.Label();
+ this.symScaleY = new Maestro.Editors.SymbolDefinition.SymbolField();
+ this.lblScaleX = new System.Windows.Forms.Label();
+ this.symScaleX = new Maestro.Editors.SymbolDefinition.SymbolField();
+ this.groupBox2 = new System.Windows.Forms.GroupBox();
+ this.lblPositioningAlgorithm = new System.Windows.Forms.Label();
+ this.symPositioningAlgorithm = new Maestro.Editors.SymbolDefinition.SymbolField();
+ this.lblAddToExclusionRegion = new System.Windows.Forms.Label();
+ this.symAddToExclusionRegion = new Maestro.Editors.SymbolDefinition.SymbolField();
+ this.lblCheckExclusionRegion = new System.Windows.Forms.Label();
+ this.symCheckExclusionRegion = new Maestro.Editors.SymbolDefinition.SymbolField();
+ this.groupBox3 = new System.Windows.Forms.GroupBox();
+ this.symGeometryContext = new Maestro.Editors.SymbolDefinition.SymbolField();
+ this.lblGeometryContext = new System.Windows.Forms.Label();
+ this.symUsageContext = new Maestro.Editors.SymbolDefinition.SymbolField();
+ this.lblUsageContext = new System.Windows.Forms.Label();
+ this.symRenderingPass = new Maestro.Editors.SymbolDefinition.SymbolField();
+ this.lblDrawLast = new System.Windows.Forms.Label();
+ this.symDrawLast = new Maestro.Editors.SymbolDefinition.SymbolField();
+ this.lblSizeContext = new System.Windows.Forms.Label();
+ this.symSizeContext = new Maestro.Editors.SymbolDefinition.SymbolField();
+ this.lblRenderingPass = new System.Windows.Forms.Label();
+ this.btnClose = new System.Windows.Forms.Button();
+ this.groupBox1.SuspendLayout();
+ this.groupBox2.SuspendLayout();
+ this.groupBox3.SuspendLayout();
+ this.SuspendLayout();
+ // groupBox1
+ resources.ApplyResources(this.groupBox1, "groupBox1");
+ this.groupBox1.Controls.Add(this.lblInsertOffsetY);
+ this.groupBox1.Controls.Add(this.symInsertOffsetY);
+ this.groupBox1.Controls.Add(this.lblInsertOffsetX);
+ this.groupBox1.Controls.Add(this.symInsertOffsetX);
+ this.groupBox1.Controls.Add(this.lblScaleY);
+ this.groupBox1.Controls.Add(this.symScaleY);
+ this.groupBox1.Controls.Add(this.lblScaleX);
+ this.groupBox1.Controls.Add(this.symScaleX);
+ this.groupBox1.Name = "groupBox1";
+ this.groupBox1.TabStop = false;
+ // lblInsertOffsetY
+ resources.ApplyResources(this.lblInsertOffsetY, "lblInsertOffsetY");
+ this.lblInsertOffsetY.Name = "lblInsertOffsetY";
+ // symInsertOffsetY
+ resources.ApplyResources(this.symInsertOffsetY, "symInsertOffsetY");
+ this.symInsertOffsetY.Name = "symInsertOffsetY";
+ this.symInsertOffsetY.SupportedEnhancedDataTypes = null;
+ this.symInsertOffsetY.RequestBrowse += new Maestro.Editors.SymbolDefinition.SymbolField.BrowseEventHandler(this.OnRequestBrowse);
+ this.symInsertOffsetY.ContentChanged += new System.EventHandler(this.OnContentChanged);
+ // lblInsertOffsetX
+ resources.ApplyResources(this.lblInsertOffsetX, "lblInsertOffsetX");
+ this.lblInsertOffsetX.Name = "lblInsertOffsetX";
+ // symInsertOffsetX
+ resources.ApplyResources(this.symInsertOffsetX, "symInsertOffsetX");
+ this.symInsertOffsetX.Name = "symInsertOffsetX";
+ this.symInsertOffsetX.SupportedEnhancedDataTypes = null;
+ this.symInsertOffsetX.RequestBrowse += new Maestro.Editors.SymbolDefinition.SymbolField.BrowseEventHandler(this.OnRequestBrowse);
+ this.symInsertOffsetX.ContentChanged += new System.EventHandler(this.OnContentChanged);
+ // lblScaleY
+ resources.ApplyResources(this.lblScaleY, "lblScaleY");
+ this.lblScaleY.Name = "lblScaleY";
+ // symScaleY
+ resources.ApplyResources(this.symScaleY, "symScaleY");
+ this.symScaleY.Name = "symScaleY";
+ this.symScaleY.SupportedEnhancedDataTypes = null;
+ this.symScaleY.RequestBrowse += new Maestro.Editors.SymbolDefinition.SymbolField.BrowseEventHandler(this.OnRequestBrowse);
+ this.symScaleY.ContentChanged += new System.EventHandler(this.OnContentChanged);
+ // lblScaleX
+ resources.ApplyResources(this.lblScaleX, "lblScaleX");
+ this.lblScaleX.Name = "lblScaleX";
+ // symScaleX
+ resources.ApplyResources(this.symScaleX, "symScaleX");
+ this.symScaleX.Name = "symScaleX";
+ this.symScaleX.SupportedEnhancedDataTypes = null;
+ this.symScaleX.RequestBrowse += new Maestro.Editors.SymbolDefinition.SymbolField.BrowseEventHandler(this.OnRequestBrowse);
+ this.symScaleX.ContentChanged += new System.EventHandler(this.OnContentChanged);
+ // groupBox2
+ resources.ApplyResources(this.groupBox2, "groupBox2");
+ this.groupBox2.Controls.Add(this.lblPositioningAlgorithm);
+ this.groupBox2.Controls.Add(this.symPositioningAlgorithm);
+ this.groupBox2.Controls.Add(this.lblAddToExclusionRegion);
+ this.groupBox2.Controls.Add(this.symAddToExclusionRegion);
+ this.groupBox2.Controls.Add(this.lblCheckExclusionRegion);
+ this.groupBox2.Controls.Add(this.symCheckExclusionRegion);
+ this.groupBox2.Name = "groupBox2";
+ this.groupBox2.TabStop = false;
+ // lblPositioningAlgorithm
+ resources.ApplyResources(this.lblPositioningAlgorithm, "lblPositioningAlgorithm");
+ this.lblPositioningAlgorithm.Name = "lblPositioningAlgorithm";
+ // symPositioningAlgorithm
+ resources.ApplyResources(this.symPositioningAlgorithm, "symPositioningAlgorithm");
+ this.symPositioningAlgorithm.Name = "symPositioningAlgorithm";
+ this.symPositioningAlgorithm.SupportedEnhancedDataTypes = null;
+ this.symPositioningAlgorithm.RequestBrowse += new Maestro.Editors.SymbolDefinition.SymbolField.BrowseEventHandler(this.OnRequestBrowse);
+ this.symPositioningAlgorithm.ContentChanged += new System.EventHandler(this.OnContentChanged);
+ // lblAddToExclusionRegion
+ resources.ApplyResources(this.lblAddToExclusionRegion, "lblAddToExclusionRegion");
+ this.lblAddToExclusionRegion.Name = "lblAddToExclusionRegion";
+ // symAddToExclusionRegion
+ resources.ApplyResources(this.symAddToExclusionRegion, "symAddToExclusionRegion");
+ this.symAddToExclusionRegion.Name = "symAddToExclusionRegion";
+ this.symAddToExclusionRegion.SupportedEnhancedDataTypes = null;
+ this.symAddToExclusionRegion.RequestBrowse += new Maestro.Editors.SymbolDefinition.SymbolField.BrowseEventHandler(this.OnRequestBrowse);
+ this.symAddToExclusionRegion.ContentChanged += new System.EventHandler(this.OnContentChanged);
+ // lblCheckExclusionRegion
+ resources.ApplyResources(this.lblCheckExclusionRegion, "lblCheckExclusionRegion");
+ this.lblCheckExclusionRegion.Name = "lblCheckExclusionRegion";
+ // symCheckExclusionRegion
+ resources.ApplyResources(this.symCheckExclusionRegion, "symCheckExclusionRegion");
+ this.symCheckExclusionRegion.Name = "symCheckExclusionRegion";
+ this.symCheckExclusionRegion.SupportedEnhancedDataTypes = null;
+ this.symCheckExclusionRegion.RequestBrowse += new Maestro.Editors.SymbolDefinition.SymbolField.BrowseEventHandler(this.OnRequestBrowse);
+ this.symCheckExclusionRegion.ContentChanged += new System.EventHandler(this.OnContentChanged);
+ // groupBox3
+ resources.ApplyResources(this.groupBox3, "groupBox3");
+ this.groupBox3.Controls.Add(this.symGeometryContext);
+ this.groupBox3.Controls.Add(this.lblGeometryContext);
+ this.groupBox3.Controls.Add(this.symUsageContext);
+ this.groupBox3.Controls.Add(this.lblUsageContext);
+ this.groupBox3.Controls.Add(this.symRenderingPass);
+ this.groupBox3.Controls.Add(this.lblDrawLast);
+ this.groupBox3.Controls.Add(this.symDrawLast);
+ this.groupBox3.Controls.Add(this.lblSizeContext);
+ this.groupBox3.Controls.Add(this.symSizeContext);
+ this.groupBox3.Controls.Add(this.lblRenderingPass);
+ this.groupBox3.Name = "groupBox3";
+ this.groupBox3.TabStop = false;
+ // symGeometryContext
+ resources.ApplyResources(this.symGeometryContext, "symGeometryContext");
+ this.symGeometryContext.Name = "symGeometryContext";
+ this.symGeometryContext.SupportedEnhancedDataTypes = null;
+ this.symGeometryContext.RequestBrowse += new Maestro.Editors.SymbolDefinition.SymbolField.BrowseEventHandler(this.OnRequestBrowse);
+ this.symGeometryContext.ContentChanged += new System.EventHandler(this.OnContentChanged);
+ // lblGeometryContext
+ resources.ApplyResources(this.lblGeometryContext, "lblGeometryContext");
+ this.lblGeometryContext.Name = "lblGeometryContext";
+ // symUsageContext
+ resources.ApplyResources(this.symUsageContext, "symUsageContext");
+ this.symUsageContext.Name = "symUsageContext";
+ this.symUsageContext.SupportedEnhancedDataTypes = null;
+ this.symUsageContext.RequestBrowse += new Maestro.Editors.SymbolDefinition.SymbolField.BrowseEventHandler(this.OnRequestBrowse);
+ this.symUsageContext.ContentChanged += new System.EventHandler(this.OnContentChanged);
+ // lblUsageContext
+ resources.ApplyResources(this.lblUsageContext, "lblUsageContext");
+ this.lblUsageContext.Name = "lblUsageContext";
+ // symRenderingPass
+ resources.ApplyResources(this.symRenderingPass, "symRenderingPass");
+ this.symRenderingPass.Name = "symRenderingPass";
+ this.symRenderingPass.SupportedEnhancedDataTypes = null;
+ this.symRenderingPass.RequestBrowse += new Maestro.Editors.SymbolDefinition.SymbolField.BrowseEventHandler(this.OnRequestBrowse);
+ this.symRenderingPass.ContentChanged += new System.EventHandler(this.OnContentChanged);
+ // lblDrawLast
+ resources.ApplyResources(this.lblDrawLast, "lblDrawLast");
+ this.lblDrawLast.Name = "lblDrawLast";
+ // symDrawLast
+ resources.ApplyResources(this.symDrawLast, "symDrawLast");
+ this.symDrawLast.Name = "symDrawLast";
+ this.symDrawLast.SupportedEnhancedDataTypes = null;
+ this.symDrawLast.RequestBrowse += new Maestro.Editors.SymbolDefinition.SymbolField.BrowseEventHandler(this.OnRequestBrowse);
+ this.symDrawLast.ContentChanged += new System.EventHandler(this.OnContentChanged);
+ // lblSizeContext
+ resources.ApplyResources(this.lblSizeContext, "lblSizeContext");
+ this.lblSizeContext.Name = "lblSizeContext";
+ // symSizeContext
+ resources.ApplyResources(this.symSizeContext, "symSizeContext");
+ this.symSizeContext.Name = "symSizeContext";
+ this.symSizeContext.SupportedEnhancedDataTypes = null;
+ this.symSizeContext.RequestBrowse += new Maestro.Editors.SymbolDefinition.SymbolField.BrowseEventHandler(this.OnRequestBrowse);
+ this.symSizeContext.ContentChanged += new System.EventHandler(this.OnContentChanged);
+ // lblRenderingPass
+ resources.ApplyResources(this.lblRenderingPass, "lblRenderingPass");
+ this.lblRenderingPass.Name = "lblRenderingPass";
+ // btnClose
+ resources.ApplyResources(this.btnClose, "btnClose");
+ this.btnClose.Name = "btnClose";
+ this.btnClose.UseVisualStyleBackColor = true;
+ this.btnClose.Click += new System.EventHandler(this.btnClose_Click);
+ // SymbolInstancePropertiesDialog
+ resources.ApplyResources(this, "$this");
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.ControlBox = false;
+ this.Controls.Add(this.btnClose);
+ this.Controls.Add(this.groupBox3);
+ this.Controls.Add(this.groupBox2);
+ this.Controls.Add(this.groupBox1);
+ this.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog;
+ this.Name = "SymbolInstancePropertiesDialog";
+ this.groupBox1.ResumeLayout(false);
+ this.groupBox1.PerformLayout();
+ this.groupBox2.ResumeLayout(false);
+ this.groupBox2.PerformLayout();
+ this.groupBox3.ResumeLayout(false);
+ this.groupBox3.PerformLayout();
+ this.ResumeLayout(false);
+ #endregion
+ private SymbolDefinition.SymbolField symScaleX;
+ private System.Windows.Forms.GroupBox groupBox1;
+ private System.Windows.Forms.Label lblInsertOffsetY;
+ private SymbolDefinition.SymbolField symInsertOffsetY;
+ private System.Windows.Forms.Label lblInsertOffsetX;
+ private SymbolDefinition.SymbolField symInsertOffsetX;
+ private System.Windows.Forms.Label lblScaleY;
+ private SymbolDefinition.SymbolField symScaleY;
+ private System.Windows.Forms.Label lblScaleX;
+ private System.Windows.Forms.GroupBox groupBox2;
+ private System.Windows.Forms.Label lblPositioningAlgorithm;
+ private SymbolDefinition.SymbolField symPositioningAlgorithm;
+ private System.Windows.Forms.Label lblAddToExclusionRegion;
+ private SymbolDefinition.SymbolField symAddToExclusionRegion;
+ private System.Windows.Forms.Label lblCheckExclusionRegion;
+ private SymbolDefinition.SymbolField symCheckExclusionRegion;
+ private System.Windows.Forms.GroupBox groupBox3;
+ private SymbolDefinition.SymbolField symGeometryContext;
+ private System.Windows.Forms.Label lblGeometryContext;
+ private SymbolDefinition.SymbolField symUsageContext;
+ private System.Windows.Forms.Label lblUsageContext;
+ private SymbolDefinition.SymbolField symRenderingPass;
+ private System.Windows.Forms.Label lblDrawLast;
+ private SymbolDefinition.SymbolField symDrawLast;
+ private System.Windows.Forms.Label lblSizeContext;
+ private SymbolDefinition.SymbolField symSizeContext;
+ private System.Windows.Forms.Label lblRenderingPass;
+ private System.Windows.Forms.Button btnClose;
\ No newline at end of file
Copied: branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancePropertiesDialog.cs (from rev 7870, trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancePropertiesDialog.cs)
--- branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancePropertiesDialog.cs (rev 0)
+++ branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancePropertiesDialog.cs 2013-10-02 13:01:50 UTC (rev 7889)
@@ -0,0 +1,121 @@
+#region Disclaimer / License
+// Copyright (C) 2013, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using Maestro.Editors.SymbolDefinition;
+using OSGeo.MapGuide.MaestroAPI.Schema;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+using OSGeo.MapGuide.ObjectModels.SymbolDefinition;
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+ public partial class SymbolInstancePropertiesDialog : Form
+ private SymbolInstancePropertiesDialog()
+ InitializeComponent();
+ private IEditorService _edSvc;
+ private ClassDefinition _cls;
+ private string _featureSourceId;
+ private string _providerName;
+ public SymbolInstancePropertiesDialog(ISymbolInstance inst, IEditorService edSvc, ClassDefinition cls, string featureSourceId, string providerName)
+ : this()
+ _edSvc = edSvc;
+ _cls = cls;
+ _featureSourceId = featureSourceId;
+ _providerName = providerName;
+ symAddToExclusionRegion.SetBooleanMode();
+ symAddToExclusionRegion.Bind(inst, "AddToExclusionRegion");
+ symCheckExclusionRegion.SetBooleanMode();
+ symCheckExclusionRegion.Bind(inst, "CheckExclusionRegion");
+ symDrawLast.SetBooleanMode();
+ symDrawLast.Bind(inst, "DrawLast");
+ symSizeContext.SetEnumMode<SizeContextType>();
+ symSizeContext.Bind(inst, "SizeContext");
+ symInsertOffsetX.Bind(inst, "InsertionOffsetX");
+ symInsertOffsetY.Bind(inst, "InsertionOffsetY");
+ symPositioningAlgorithm.Items = new string[]
+ "'Default'",
+ "'EightSurrounding'",
+ "'PathLabels'"
+ symPositioningAlgorithm.Bind(inst, "PositioningAlgorithm");
+ symScaleX.Bind(inst, "ScaleX");
+ symScaleY.Bind(inst, "ScaleY");
+ var inst2 = inst as ISymbolInstance2;
+ if (inst2 != null)
+ symGeometryContext.SetEnumMode<GeometryContextType>();
+ symUsageContext.SetEnumMode<UsageContextType>();
+ symRenderingPass.Bind(inst2, "RenderingPass");
+ symGeometryContext.Bind(inst2, "GeometryContext");
+ symUsageContext.Bind(inst2, "UsageContext");
+ else
+ symRenderingPass.Visible =
+ symGeometryContext.Visible =
+ symUsageContext.Visible =
+ lblRenderingPass.Visible =
+ lblGeometryContext.Visible =
+ lblUsageContext.Visible = false;
+ private void btnClose_Click(object sender, EventArgs e)
+ this.DialogResult = System.Windows.Forms.DialogResult.OK;
+ private void OnRequestBrowse(SymbolDefinition.SymbolField sender)
+ string expr = _edSvc.EditExpression(sender.Content, _cls, _providerName, _featureSourceId, true);
+ if (expr != null)
+ sender.Content = expr;
+ private void OnContentChanged(object sender, EventArgs e)
+ this.HasChanged = true;
+ public bool HasChanged { get; private set; }
Copied: branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancePropertiesDialog.resx (from rev 7870, trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancePropertiesDialog.resx)
--- branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancePropertiesDialog.resx (rev 0)
+++ branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancePropertiesDialog.resx 2013-10-02 13:01:50 UTC (rev 7889)
@@ -0,0 +1,864 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="groupBox1.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="lblInsertOffsetY.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <data name="lblInsertOffsetY.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ <value>NoControl</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="lblInsertOffsetY.Location" type="System.Drawing.Point, System.Drawing">
+ <value>229, 59</value>
+ </data>
+ <data name="lblInsertOffsetY.Size" type="System.Drawing.Size, System.Drawing">
+ <value>88, 13</value>
+ </data>
+ <data name="lblInsertOffsetY.TabIndex" type="System.Int32, mscorlib">
+ <value>7</value>
+ </data>
+ <data name="lblInsertOffsetY.Text" xml:space="preserve">
+ <value>Insertion Offset Y</value>
+ </data>
+ <data name=">>lblInsertOffsetY.Name" xml:space="preserve">
+ <value>lblInsertOffsetY</value>
+ </data>
+ <data name=">>lblInsertOffsetY.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>lblInsertOffsetY.Parent" xml:space="preserve">
+ <value>groupBox1</value>
+ </data>
+ <data name=">>lblInsertOffsetY.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="symInsertOffsetY.Location" type="System.Drawing.Point, System.Drawing">
+ <value>326, 56</value>
+ </data>
+ <data name="symInsertOffsetY.Size" type="System.Drawing.Size, System.Drawing">
+ <value>115, 21</value>
+ </data>
+ <data name="symInsertOffsetY.TabIndex" type="System.Int32, mscorlib">
+ <value>6</value>
+ </data>
+ <data name=">>symInsertOffsetY.Name" xml:space="preserve">
+ <value>symInsertOffsetY</value>
+ </data>
+ <data name=">>symInsertOffsetY.Type" xml:space="preserve">
+ <value>Maestro.Editors.SymbolDefinition.SymbolField, Maestro.Editors, Version=5.0.0.6640, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
+ </data>
+ <data name=">>symInsertOffsetY.Parent" xml:space="preserve">
+ </data>
+ <data name=">>symInsertOffsetY.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="lblInsertOffsetX.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="lblInsertOffsetX.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="lblInsertOffsetX.Location" type="System.Drawing.Point, System.Drawing">
+ <value>229, 32</value>
+ </data>
+ <data name="lblInsertOffsetX.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="lblInsertOffsetX.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name="lblInsertOffsetX.Text" xml:space="preserve">
+ <value>Insertion Offset X</value>
+ </data>
+ <data name=">>lblInsertOffsetX.Name" xml:space="preserve">
+ <value>lblInsertOffsetX</value>
+ </data>
+ <data name=">>lblInsertOffsetX.Type" xml:space="preserve">
+ </data>
+ <data name=">>lblInsertOffsetX.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lblInsertOffsetX.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="symInsertOffsetX.Location" type="System.Drawing.Point, System.Drawing">
+ <value>326, 29</value>
+ </data>
+ <data name="symInsertOffsetX.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="symInsertOffsetX.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name=">>symInsertOffsetX.Name" xml:space="preserve">
+ <value>symInsertOffsetX</value>
+ </data>
+ <data name=">>symInsertOffsetX.Type" xml:space="preserve">
+ </data>
+ <data name=">>symInsertOffsetX.Parent" xml:space="preserve">
+ </data>
+ <data name=">>symInsertOffsetX.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="lblScaleY.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="lblScaleY.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="lblScaleY.Location" type="System.Drawing.Point, System.Drawing">
+ <value>15, 59</value>
+ </data>
+ <data name="lblScaleY.Size" type="System.Drawing.Size, System.Drawing">
+ <value>44, 13</value>
+ </data>
+ <data name="lblScaleY.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="lblScaleY.Text" xml:space="preserve">
+ <value>Scale Y</value>
+ </data>
+ <data name=">>lblScaleY.Name" xml:space="preserve">
+ <value>lblScaleY</value>
+ </data>
+ <data name=">>lblScaleY.Type" xml:space="preserve">
+ </data>
+ <data name=">>lblScaleY.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lblScaleY.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="symScaleY.Location" type="System.Drawing.Point, System.Drawing">
+ <value>103, 56</value>
+ </data>
+ <data name="symScaleY.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="symScaleY.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name=">>symScaleY.Name" xml:space="preserve">
+ <value>symScaleY</value>
+ </data>
+ <data name=">>symScaleY.Type" xml:space="preserve">
+ </data>
+ <data name=">>symScaleY.Parent" xml:space="preserve">
+ </data>
+ <data name=">>symScaleY.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name="lblScaleX.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="lblScaleX.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="lblScaleX.Location" type="System.Drawing.Point, System.Drawing">
+ <value>15, 32</value>
+ </data>
+ <data name="lblScaleX.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="lblScaleX.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="lblScaleX.Text" xml:space="preserve">
+ <value>Scale X</value>
+ </data>
+ <data name=">>lblScaleX.Name" xml:space="preserve">
+ <value>lblScaleX</value>
+ </data>
+ <data name=">>lblScaleX.Type" xml:space="preserve">
+ </data>
+ <data name=">>lblScaleX.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lblScaleX.ZOrder" xml:space="preserve">
+ <value>6</value>
+ </data>
+ <data name="symScaleX.Location" type="System.Drawing.Point, System.Drawing">
+ <value>103, 29</value>
+ </data>
+ <data name="symScaleX.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="symScaleX.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name=">>symScaleX.Name" xml:space="preserve">
+ <value>symScaleX</value>
+ </data>
+ <data name=">>symScaleX.Type" xml:space="preserve">
+ </data>
+ <data name=">>symScaleX.Parent" xml:space="preserve">
+ </data>
+ <data name=">>symScaleX.ZOrder" xml:space="preserve">
+ <value>7</value>
+ </data>
+ <data name="groupBox1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>13, 13</value>
+ </data>
+ <data name="groupBox1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>468, 96</value>
+ </data>
+ <data name="groupBox1.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="groupBox1.Text" xml:space="preserve">
+ <value>Scaling/Insertion</value>
+ </data>
+ <data name=">>groupBox1.Name" xml:space="preserve">
+ </data>
+ <data name=">>groupBox1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>groupBox1.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>groupBox1.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="groupBox2.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="lblPositioningAlgorithm.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="lblPositioningAlgorithm.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="lblPositioningAlgorithm.Location" type="System.Drawing.Point, System.Drawing">
+ <value>15, 79</value>
+ </data>
+ <data name="lblPositioningAlgorithm.Size" type="System.Drawing.Size, System.Drawing">
+ <value>104, 13</value>
+ </data>
+ <data name="lblPositioningAlgorithm.TabIndex" type="System.Int32, mscorlib">
+ <value>7</value>
+ </data>
+ <data name="lblPositioningAlgorithm.Text" xml:space="preserve">
+ <value>Positioning Algorithm</value>
+ </data>
+ <data name=">>lblPositioningAlgorithm.Name" xml:space="preserve">
+ <value>lblPositioningAlgorithm</value>
+ </data>
+ <data name=">>lblPositioningAlgorithm.Type" xml:space="preserve">
+ </data>
+ <data name=">>lblPositioningAlgorithm.Parent" xml:space="preserve">
+ <value>groupBox2</value>
+ </data>
+ <data name=">>lblPositioningAlgorithm.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="symPositioningAlgorithm.Location" type="System.Drawing.Point, System.Drawing">
+ <value>155, 76</value>
+ </data>
+ <data name="symPositioningAlgorithm.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="symPositioningAlgorithm.TabIndex" type="System.Int32, mscorlib">
+ <value>6</value>
+ </data>
+ <data name=">>symPositioningAlgorithm.Name" xml:space="preserve">
+ <value>symPositioningAlgorithm</value>
+ </data>
+ <data name=">>symPositioningAlgorithm.Type" xml:space="preserve">
+ </data>
+ <data name=">>symPositioningAlgorithm.Parent" xml:space="preserve">
+ </data>
+ <data name=">>symPositioningAlgorithm.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="lblAddToExclusionRegion.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="lblAddToExclusionRegion.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="lblAddToExclusionRegion.Location" type="System.Drawing.Point, System.Drawing">
+ <value>15, 52</value>
+ </data>
+ <data name="lblAddToExclusionRegion.Size" type="System.Drawing.Size, System.Drawing">
+ <value>123, 13</value>
+ </data>
+ <data name="lblAddToExclusionRegion.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name="lblAddToExclusionRegion.Text" xml:space="preserve">
+ <value>Add to Exclusion Region</value>
+ </data>
+ <data name=">>lblAddToExclusionRegion.Name" xml:space="preserve">
+ <value>lblAddToExclusionRegion</value>
+ </data>
+ <data name=">>lblAddToExclusionRegion.Type" xml:space="preserve">
+ </data>
+ <data name=">>lblAddToExclusionRegion.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lblAddToExclusionRegion.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="symAddToExclusionRegion.Location" type="System.Drawing.Point, System.Drawing">
+ <value>155, 49</value>
+ </data>
+ <data name="symAddToExclusionRegion.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="symAddToExclusionRegion.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name=">>symAddToExclusionRegion.Name" xml:space="preserve">
+ <value>symAddToExclusionRegion</value>
+ </data>
+ <data name=">>symAddToExclusionRegion.Type" xml:space="preserve">
+ </data>
+ <data name=">>symAddToExclusionRegion.Parent" xml:space="preserve">
+ </data>
+ <data name=">>symAddToExclusionRegion.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="lblCheckExclusionRegion.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="lblCheckExclusionRegion.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="lblCheckExclusionRegion.Location" type="System.Drawing.Point, System.Drawing">
+ <value>15, 25</value>
+ </data>
+ <data name="lblCheckExclusionRegion.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="lblCheckExclusionRegion.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="lblCheckExclusionRegion.Text" xml:space="preserve">
+ <value>Check Exclusion Region</value>
+ </data>
+ <data name=">>lblCheckExclusionRegion.Name" xml:space="preserve">
+ <value>lblCheckExclusionRegion</value>
+ </data>
+ <data name=">>lblCheckExclusionRegion.Type" xml:space="preserve">
+ </data>
+ <data name=">>lblCheckExclusionRegion.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lblCheckExclusionRegion.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="symCheckExclusionRegion.Location" type="System.Drawing.Point, System.Drawing">
+ <value>155, 22</value>
+ </data>
+ <data name="symCheckExclusionRegion.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="symCheckExclusionRegion.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name=">>symCheckExclusionRegion.Name" xml:space="preserve">
+ <value>symCheckExclusionRegion</value>
+ </data>
+ <data name=">>symCheckExclusionRegion.Type" xml:space="preserve">
+ </data>
+ <data name=">>symCheckExclusionRegion.Parent" xml:space="preserve">
+ </data>
+ <data name=">>symCheckExclusionRegion.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name="groupBox2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>13, 116</value>
+ </data>
+ <data name="groupBox2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>468, 112</value>
+ </data>
+ <data name="groupBox2.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="groupBox2.Text" xml:space="preserve">
+ <value>Label Placement</value>
+ </data>
+ <data name=">>groupBox2.Name" xml:space="preserve">
+ </data>
+ <data name=">>groupBox2.Type" xml:space="preserve">
+ </data>
+ <data name=">>groupBox2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>groupBox2.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="groupBox3.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="symGeometryContext.Location" type="System.Drawing.Point, System.Drawing">
+ <value>326, 73</value>
+ </data>
+ <data name="symGeometryContext.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="symGeometryContext.TabIndex" type="System.Int32, mscorlib">
+ <value>18</value>
+ </data>
+ <data name=">>symGeometryContext.Name" xml:space="preserve">
+ <value>symGeometryContext</value>
+ </data>
+ <data name=">>symGeometryContext.Type" xml:space="preserve">
+ </data>
+ <data name=">>symGeometryContext.Parent" xml:space="preserve">
+ <value>groupBox3</value>
+ </data>
+ <data name=">>symGeometryContext.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="lblGeometryContext.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="lblGeometryContext.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="lblGeometryContext.Location" type="System.Drawing.Point, System.Drawing">
+ <value>229, 76</value>
+ </data>
+ <data name="lblGeometryContext.Size" type="System.Drawing.Size, System.Drawing">
+ <value>91, 13</value>
+ </data>
+ <data name="lblGeometryContext.TabIndex" type="System.Int32, mscorlib">
+ <value>17</value>
+ </data>
+ <data name="lblGeometryContext.Text" xml:space="preserve">
+ <value>Geometry Context</value>
+ </data>
+ <data name=">>lblGeometryContext.Name" xml:space="preserve">
+ <value>lblGeometryContext</value>
+ </data>
+ <data name=">>lblGeometryContext.Type" xml:space="preserve">
+ </data>
+ <data name=">>lblGeometryContext.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lblGeometryContext.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="symUsageContext.Location" type="System.Drawing.Point, System.Drawing">
+ <value>103, 73</value>
+ </data>
+ <data name="symUsageContext.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="symUsageContext.TabIndex" type="System.Int32, mscorlib">
+ <value>16</value>
+ </data>
+ <data name=">>symUsageContext.Name" xml:space="preserve">
+ <value>symUsageContext</value>
+ </data>
+ <data name=">>symUsageContext.Type" xml:space="preserve">
+ </data>
+ <data name=">>symUsageContext.Parent" xml:space="preserve">
+ </data>
+ <data name=">>symUsageContext.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="lblUsageContext.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="lblUsageContext.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="lblUsageContext.Location" type="System.Drawing.Point, System.Drawing">
+ <value>15, 76</value>
+ </data>
+ <data name="lblUsageContext.Size" type="System.Drawing.Size, System.Drawing">
+ <value>77, 13</value>
+ </data>
+ <data name="lblUsageContext.TabIndex" type="System.Int32, mscorlib">
+ <value>15</value>
+ </data>
+ <data name="lblUsageContext.Text" xml:space="preserve">
+ <value>Usage Context</value>
+ </data>
+ <data name=">>lblUsageContext.Name" xml:space="preserve">
+ <value>lblUsageContext</value>
+ </data>
+ <data name=">>lblUsageContext.Type" xml:space="preserve">
+ </data>
+ <data name=">>lblUsageContext.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lblUsageContext.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="symRenderingPass.Location" type="System.Drawing.Point, System.Drawing">
+ <value>103, 46</value>
+ </data>
+ <data name="symRenderingPass.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="symRenderingPass.TabIndex" type="System.Int32, mscorlib">
+ <value>14</value>
+ </data>
+ <data name=">>symRenderingPass.Name" xml:space="preserve">
+ <value>symRenderingPass</value>
+ </data>
+ <data name=">>symRenderingPass.Type" xml:space="preserve">
+ </data>
+ <data name=">>symRenderingPass.Parent" xml:space="preserve">
+ </data>
+ <data name=">>symRenderingPass.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="lblDrawLast.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="lblDrawLast.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="lblDrawLast.Location" type="System.Drawing.Point, System.Drawing">
+ <value>229, 22</value>
+ </data>
+ <data name="lblDrawLast.Size" type="System.Drawing.Size, System.Drawing">
+ <value>55, 13</value>
+ </data>
+ <data name="lblDrawLast.TabIndex" type="System.Int32, mscorlib">
+ <value>13</value>
+ </data>
+ <data name="lblDrawLast.Text" xml:space="preserve">
+ <value>Draw Last</value>
+ </data>
+ <data name=">>lblDrawLast.Name" xml:space="preserve">
+ <value>lblDrawLast</value>
+ </data>
+ <data name=">>lblDrawLast.Type" xml:space="preserve">
+ </data>
+ <data name=">>lblDrawLast.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lblDrawLast.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name="symDrawLast.Location" type="System.Drawing.Point, System.Drawing">
+ <value>326, 19</value>
+ </data>
+ <data name="symDrawLast.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="symDrawLast.TabIndex" type="System.Int32, mscorlib">
+ <value>12</value>
+ </data>
+ <data name=">>symDrawLast.Name" xml:space="preserve">
+ <value>symDrawLast</value>
+ </data>
+ <data name=">>symDrawLast.Type" xml:space="preserve">
+ </data>
+ <data name=">>symDrawLast.Parent" xml:space="preserve">
+ </data>
+ <data name=">>symDrawLast.ZOrder" xml:space="preserve">
+ <value>6</value>
+ </data>
+ <data name="lblSizeContext.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="lblSizeContext.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="lblSizeContext.Location" type="System.Drawing.Point, System.Drawing">
+ <value>15, 22</value>
+ </data>
+ <data name="lblSizeContext.Size" type="System.Drawing.Size, System.Drawing">
+ <value>66, 13</value>
+ </data>
+ <data name="lblSizeContext.TabIndex" type="System.Int32, mscorlib">
+ <value>11</value>
+ </data>
+ <data name="lblSizeContext.Text" xml:space="preserve">
+ <value>Size Context</value>
+ </data>
+ <data name=">>lblSizeContext.Name" xml:space="preserve">
+ <value>lblSizeContext</value>
+ </data>
+ <data name=">>lblSizeContext.Type" xml:space="preserve">
+ </data>
+ <data name=">>lblSizeContext.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lblSizeContext.ZOrder" xml:space="preserve">
+ <value>7</value>
+ </data>
+ <data name="symSizeContext.Location" type="System.Drawing.Point, System.Drawing">
+ <value>103, 19</value>
+ </data>
+ <data name="symSizeContext.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="symSizeContext.TabIndex" type="System.Int32, mscorlib">
+ <value>10</value>
+ </data>
+ <data name=">>symSizeContext.Name" xml:space="preserve">
+ <value>symSizeContext</value>
+ </data>
+ <data name=">>symSizeContext.Type" xml:space="preserve">
+ </data>
+ <data name=">>symSizeContext.Parent" xml:space="preserve">
+ </data>
+ <data name=">>symSizeContext.ZOrder" xml:space="preserve">
+ <value>8</value>
+ </data>
+ <data name="lblRenderingPass.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="lblRenderingPass.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="lblRenderingPass.Location" type="System.Drawing.Point, System.Drawing">
+ <value>15, 49</value>
+ </data>
+ <data name="lblRenderingPass.Size" type="System.Drawing.Size, System.Drawing">
+ <value>82, 13</value>
+ </data>
+ <data name="lblRenderingPass.TabIndex" type="System.Int32, mscorlib">
+ <value>9</value>
+ </data>
+ <data name="lblRenderingPass.Text" xml:space="preserve">
+ <value>Rendering Pass</value>
+ </data>
+ <data name=">>lblRenderingPass.Name" xml:space="preserve">
+ <value>lblRenderingPass</value>
+ </data>
+ <data name=">>lblRenderingPass.Type" xml:space="preserve">
+ </data>
+ <data name=">>lblRenderingPass.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lblRenderingPass.ZOrder" xml:space="preserve">
+ <value>9</value>
+ </data>
+ <data name="groupBox3.Location" type="System.Drawing.Point, System.Drawing">
+ <value>13, 235</value>
+ </data>
+ <data name="groupBox3.Size" type="System.Drawing.Size, System.Drawing">
+ <value>468, 100</value>
+ </data>
+ <data name="groupBox3.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="groupBox3.Text" xml:space="preserve">
+ <value>Miscellaneous</value>
+ </data>
+ <data name=">>groupBox3.Name" xml:space="preserve">
+ </data>
+ <data name=">>groupBox3.Type" xml:space="preserve">
+ </data>
+ <data name=">>groupBox3.Parent" xml:space="preserve">
+ </data>
+ <data name=">>groupBox3.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="btnClose.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="btnClose.Location" type="System.Drawing.Point, System.Drawing">
+ <value>406, 346</value>
+ </data>
+ <data name="btnClose.Size" type="System.Drawing.Size, System.Drawing">
+ <value>75, 23</value>
+ </data>
+ <data name="btnClose.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name="btnClose.Text" xml:space="preserve">
+ <value>Close</value>
+ </data>
+ <data name=">>btnClose.Name" xml:space="preserve">
+ <value>btnClose</value>
+ </data>
+ <data name=">>btnClose.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnClose.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnClose.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ </metadata>
+ <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
+ <value>6, 13</value>
+ </data>
+ <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+ <value>493, 381</value>
+ </data>
+ <data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
+ <value>CenterParent</value>
+ </data>
+ <data name="$this.Text" xml:space="preserve">
+ <value>Symbol Instance Properties</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>SymbolInstancePropertiesDialog</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
Modified: branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.Designer.cs
--- branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.Designer.cs 2013-10-02 11:41:46 UTC (rev 7888)
+++ branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.Designer.cs 2013-10-02 13:01:50 UTC (rev 7889)
@@ -44,6 +44,8 @@
this.symPreview = new System.Windows.Forms.PictureBox();
this.btnRefresh = new System.Windows.Forms.Button();
+ this.btnEditInstanceProperties = new System.Windows.Forms.Button();
+ ((System.ComponentModel.ISupportInitialize)(this.splitContainer1)).BeginInit();
this.splitContainer1.Panel1.SuspendLayout();
this.splitContainer1.SuspendLayout();
@@ -162,16 +164,25 @@
this.btnRefresh.UseVisualStyleBackColor = true;
this.btnRefresh.Click += new System.EventHandler(this.btnRefresh_Click);
+ // btnEditInstanceProperties
+ resources.ApplyResources(this.btnEditInstanceProperties, "btnEditInstanceProperties");
+ this.btnEditInstanceProperties.Name = "btnEditInstanceProperties";
+ this.btnEditInstanceProperties.UseVisualStyleBackColor = true;
+ this.btnEditInstanceProperties.Click += new System.EventHandler(this.btnEditInstanceProperties_Click);
// SymbolInstancesDialog
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
+ this.Controls.Add(this.btnEditInstanceProperties);
this.Controls.Add(this.btnRefresh);
this.Controls.Add(this.splitContainer1);
this.Name = "SymbolInstancesDialog";
this.splitContainer1.Panel1.ResumeLayout(false);
+ ((System.ComponentModel.ISupportInitialize)(this.splitContainer1)).EndInit();
this.splitContainer1.ResumeLayout(false);
@@ -199,5 +210,6 @@
private System.Windows.Forms.PictureBox symPreview;
private System.Windows.Forms.Button btnRefresh;
+ private System.Windows.Forms.Button btnEditInstanceProperties;
Modified: branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.cs
--- branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.cs 2013-10-02 11:41:46 UTC (rev 7888)
+++ branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.cs 2013-10-02 13:01:50 UTC (rev 7889)
@@ -195,12 +195,31 @@
c.Dock = DockStyle.Fill;
splitContainer1.Panel2.Controls.Clear();
splitContainer1.Panel2.Controls.Add(c);
+ btnEditInstanceProperties.Enabled = true;
+ else
+ btnEditInstanceProperties.Enabled = false;
private void btnRefresh_Click(object sender, EventArgs e)
UpdatePreviewImage();
+ private void btnEditInstanceProperties_Click(object sender, EventArgs e)
+ if (lstInstances.SelectedItems.Count == 1)
+ var it = lstInstances.SelectedItems[0];
+ ISymbolInstance symRef = (ISymbolInstance)it.Tag;
+ using (var diag = new SymbolInstancePropertiesDialog(symRef, _edSvc, _cls, _featureSourceId, _provider))
+ diag.ShowDialog();
Modified: branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.resx
--- branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.resx 2013-10-02 11:41:46 UTC (rev 7888)
+++ branches/maestro-5.0.x/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.resx 2013-10-02 13:01:50 UTC (rev 7889)
@@ -145,7 +145,7 @@
</data>
- <value>2</value>
+ <value>3</value>
</data>
<data name="splitContainer1.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Bottom, Left, Right</value>
@@ -164,7 +164,7 @@
AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj00LjAuMC4w
LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAD2
- CAAAAk1TRnQBSQFMAgEBAgEAATgBAAE4AQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
+ CAAAAk1TRnQBSQFMAgEBAgEAAVABAAFQAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
AwABQAMAARADAAEBAQABCAYAAQQYAAGAAgABgAMAAoABAAGAAwABgAEAAYABAAKAAgADwAEAAcAB3AHA
AQAB8AHKAaYBAAEzBQABMwEAATMBAAEzAQACMwIAAxYBAAMcAQADIgEAAykBAANVAQADTQEAA0IBAAM5
AQABgAF8Af8BAAJQAf8BAAGTAQAB1gEAAf8B7AHMAQABxgHWAe8BAAHWAucBAAGQAakBrQIAAf8BMwMA
@@ -407,7 +407,7 @@
</data>
<data name=">>splitContainer1.ZOrder" xml:space="preserve">
- <value>1</value>
+ <value>2</value>
</data>
<data name="btnRefresh.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Bottom, Left</value>
@@ -434,6 +434,33 @@
</data>
<data name=">>btnRefresh.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="btnEditInstanceProperties.Enabled" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <data name="btnEditInstanceProperties.Location" type="System.Drawing.Point, System.Drawing">
+ <value>120, 527</value>
+ </data>
+ <data name="btnEditInstanceProperties.Size" type="System.Drawing.Size, System.Drawing">
+ <value>148, 23</value>
+ </data>
+ <data name="btnEditInstanceProperties.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="btnEditInstanceProperties.Text" xml:space="preserve">
+ <value>Edit Instance Properties</value>
+ </data>
+ <data name=">>btnEditInstanceProperties.Name" xml:space="preserve">
+ <value>btnEditInstanceProperties</value>
+ </data>
+ <data name=">>btnEditInstanceProperties.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnEditInstanceProperties.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnEditInstanceProperties.ZOrder" xml:space="preserve">
<value>0</value>
</data>
Modified: branches/maestro-5.0.x/Maestro.Editors/Maestro.Editors.csproj
--- branches/maestro-5.0.x/Maestro.Editors/Maestro.Editors.csproj 2013-10-02 11:41:46 UTC (rev 7888)
+++ branches/maestro-5.0.x/Maestro.Editors/Maestro.Editors.csproj 2013-10-02 13:01:50 UTC (rev 7889)
@@ -684,6 +684,12 @@
<Compile Include="LayerDefinition\Vector\Scales\SymbolInstanceEditors\ReferenceCtrl.Designer.cs">
<DependentUpon>ReferenceCtrl.cs</DependentUpon>
</Compile>
+ <Compile Include="LayerDefinition\Vector\Scales\SymbolInstancePropertiesDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="LayerDefinition\Vector\Scales\SymbolInstancePropertiesDialog.Designer.cs">
+ <DependentUpon>SymbolInstancePropertiesDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="LayerDefinition\Vector\Scales\SymbolInstancesDialog.cs">
</Compile>
@@ -1531,6 +1537,9 @@
<EmbeddedResource Include="LayerDefinition\Vector\Scales\SymbolInstanceEditors\ReferenceCtrl.resx">
</EmbeddedResource>
+ <EmbeddedResource Include="LayerDefinition\Vector\Scales\SymbolInstancePropertiesDialog.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="LayerDefinition\Vector\Scales\SymbolInstancesDialog.resx">
<DependentUpon>SymbolInstancesDialog.cs</DependentUpon>
</EmbeddedResource>
Modified: branches/maestro-5.0.x/Maestro.Editors/SymbolDefinition/SymbolField.cs
--- branches/maestro-5.0.x/Maestro.Editors/SymbolDefinition/SymbolField.cs 2013-10-02 11:41:46 UTC (rev 7888)
+++ branches/maestro-5.0.x/Maestro.Editors/SymbolDefinition/SymbolField.cs 2013-10-02 13:01:50 UTC (rev 7889)
@@ -141,6 +141,40 @@
+ /// <summary>
+ /// Gets or sets the enum type. Only set this if the underlying symbol property is an enum type
+ /// </summary>
+ [DesignerSerializationVisibility(DesignerSerializationVisibility.Hidden)]
+ public Type EnumType
+ get;
+ private set;
+ /// <summary>
+ /// Sets this field to explicitly take enum values for input
+ /// </summary>
+ /// <typeparam name="TEnum"></typeparam>
+ public void SetEnumMode<TEnum>()
+ this.EnumType = typeof(TEnum);
+ this.Items = GetItems<TEnum>(false);
+ combo.DropDownStyle = ComboBoxStyle.DropDownList;
+ /// <summary>
+ /// Sets this field for boolean input
+ /// </summary>
+ public void SetBooleanMode()
+ this.EnumType = null;
+ this.Items = new string[]
+ true.ToString().ToLower(),
+ false.ToString().ToLower()
private void OnContentChanged()
if (_isBinding)
@@ -156,9 +190,20 @@
_suppressUI = true;
if (string.IsNullOrEmpty(this.Content))
_boundProperty.SetValue(_boundObject, null, null);
else
- _boundProperty.SetValue(_boundObject, this.Content, null);
+ if (this.EnumType != null)
+ _boundProperty.SetValue(_boundObject, Enum.Parse(this.EnumType, this.Content), null);
+ else
+ _boundProperty.SetValue(_boundObject, this.Content, null);
finally
@@ -219,20 +264,41 @@
public DataType2[] SupportedEnhancedDataTypes { get; set; }
/// <summary>
- /// Gets the items.
+ /// Gets the items
/// </summary>
/// <typeparam name="T"></typeparam>
/// <returns></returns>
public static string[] GetItems<T>()
+ return GetItems<T>(true);
+ /// <summary>
+ /// Gets the items.
+ /// </summary>
+ /// <typeparam name="T"></typeparam>
+ /// <returns></returns>
+ public static string[] GetItems<T>(bool quote)
var values = Enum.GetValues(typeof(T));
var items = new string[values.Length];
int i = 0;
- foreach(var val in values)
+ if (quote)
- items[i] = "'" + val + "'";
- i++;
+ foreach (var val in values)
+ items[i] = "'" + val + "'";
+ i++;
+ else
+ items[i] = val + "";
+ i++;
return items;
Modified: branches/maestro-5.0.x/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs
--- branches/maestro-5.0.x/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs 2013-10-02 11:41:46 UTC (rev 7888)
+++ branches/maestro-5.0.x/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs 2013-10-02 13:01:50 UTC (rev 7889)
@@ -1989,7 +1989,7 @@
#if LDF_110
return new Version(1, 0, 0);
-#elif LDF_120 || LDF_230
+#elif LDF_120 || LDF_130 || LDF_230
return new Version(1, 1, 0);
#elif LDF_240
return new Version(2, 4, 0);
@@ -2112,6 +2112,10 @@
partial class SymbolInstance : ISymbolInstance
+#if LDF_100 || LDF_110
+#else
+ , ISymbolInstance2
+#endif
[XmlIgnore]
IParameterOverrideCollection ISymbolInstance.ParameterOverrides
More information about the mapguide-commits
