[mapguide-commits] r7890 - branches/2.5/Installer/scripts
svn_mapguide at osgeo.org
Fri Oct 4 02:39:00 PDT 2013
Author: jng
Date: 2013-10-04 02:39:00 -0700 (Fri, 04 Oct 2013)
New Revision: 7890
Added:
branches/2.5/Installer/scripts/build_fdo.sh
Bring FDO build script from trunk
Copied: branches/2.5/Installer/scripts/build_fdo.sh (from rev 7828, trunk/Installer/scripts/build_fdo.sh)
--- branches/2.5/Installer/scripts/build_fdo.sh (rev 0)
+++ branches/2.5/Installer/scripts/build_fdo.sh 2013-10-04 09:39:00 UTC (rev 7890)
@@ -0,0 +1,187 @@
+#!/bin/bash
+# build_fdo.sh
+# Builds FDO and creates a tarball from the binary output
+# Modify setenvironment.sh to point to the correct Oracle, MySQL and PostgreSQL paths
+# before building
+FDO_BUILD_COMPONENT=
+# FDO version. Make sure this matches your FDO build source
+FDO_VER_MAJOR=3
+FDO_VER_MINOR=8
+FDO_VER_REV=1
+# FDO install directory
+FDO_VER_FULL=${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}
+FDO_INST=/usr/local/fdo-${FDO_VER_FULL}
+check_build()
+ error=$?
+ if [ $error -ne 0 ]; then
+ echo "[error]: ${FDO_BUILD_COMPONENT} - Error build failed ($error)"
+ exit $error
+ fi
+check_fdo_lib()
+ libname=$1-${FDO_VER_FULL}.so
+ libpath=${FDO_INST}/lib/${libname}
+ if [ ! -e ${libpath} ]; then
+ echo "[error]: Error building ${libname}"
+ exit 1
+ fi
+BUILDROOT=`pwd`
+LOCALSVN=1
+PRESERVE_BUILD_ROOT=1
+CMAKE=0
+FDO_SRC=/home/mgbuild/fdo/trunk
+#FDO_SRC=http://svn.osgeo.org/fdo/trunk
+FDO_BUILD_AREA=${BUILDROOT}/fdo_build_area
+modify_sdk_paths()
+ echo "[info]: Updating setenvironment.sh"
+ # Note: Change your paths here if they're different
+ sed -i 's/export FDOMYSQL=$FDOTHIRDPARTY\/mysql\/rhlinux/export FDOMYSQL=\/usr/g' ${FDO_BUILD_AREA}/setenvironment.sh
+ sed -i 's/export FDOPOSTGRESQL=$FDOTHIRDPARTY\/pgsql/export FDOPOSTGRESQL=\/usr/g' ${FDO_BUILD_AREA}/setenvironment.sh
+ echo "export FDOORACLE=/home/mgbuild/fdo_rdbms_thirdparty/oracle/x86/instantclient_11_2/sdk" >> ${FDO_BUILD_AREA}/setenvironment.sh
+# Must have root
+if [[ $EUID -ne 0 ]]; then
+ echo "[error]: You must run this script with superuser privileges"
+ exit 1
+fi
+echo "***********************************************************"
+echo " FDO Source: ${FDO_SRC}"
+echo " FDO Build Area: ${FDO_BUILD_AREA}"
+echo " FDO Install dir: ${FDO_INST}"
+echo " CMake build: ${CMAKE}"
+echo " Export from local SVN checkout: ${LOCALSVN}"
+echo " Re-use previous build area: ${PRESERVE_BUILD_ROOT}"
+start_time=`date +%s`
+REVISION=`svn info ${FDO_SRC} | perl revnum.pl`
+if [ ${CMAKE} -eq 1 ];
+then
+ echo "[error]: CMake build of FDO not supported yet"
+ exit 1
+else
+ echo "[info]: Using automake build"
+ if [ -d ${FDO_BUILD_AREA} ];
+ then
+ if [ ${PRESERVE_BUILD_ROOT} -eq 1 ];
+ then
+ echo "[info]: FDO build area ${FDO_BUILD_AREA} exists. Going straight to build"
+ else
+ echo "[info]: Removing old FDO build area at ${FDO_BUILD_AREA}"
+ rm -rf ${FDO_BUILD_AREA}
+ if [ ${LOCALSVN} -eq 1 ]
+ then
+ svn export ${FDO_SRC} ${FDO_BUILD_AREA}
+ modify_sdk_paths
+ else
+ echo "[info]: Performing fresh SVN export of ${FDO_SRC} (r${REVISION}) to ${FDO_BUILD_AREA}"
+ svn export -q -r ${REVISION} ${FDO_SRC} ${FDO_BUILD_AREA}
+ modify_sdk_paths
+ fi
+ fi
+ else
+ echo "[info]: FDO build area ${FDO_BUILD_AREA} does not exist. Doing svn export"
+ echo "[info]: Exporting svn revision ${REVISION}"
+ then
+ modify_sdk_paths
+ else
+ modify_sdk_paths
+ fi
+ fi
+fi
+echo "[info]: Building FDO (${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}) rev (${REVISION})"
+cd ${FDO_BUILD_AREA}
+source ./setenvironment.sh
+if [ ! -d ${FDO_INST} ];
+then
+ echo "[error]: FDO install directory ${FDO_INST} doesn't exist. setenvironment.sh should've created this directory. Ensure the FDO version number in this script is correct"
+ exit 1;
+fi
+FDO_BUILD_COMPONENT="FDO Thirdparty"
+./build_thirdparty.sh
+check_build
+then
+ FDO_BUILD_COMPONENT="FDO (cmake)"
+ exit 1;
+else
+ #NOTE: We never build ArcSDE provider because we haven't paid the ESRI tax for their ArcSDE SDK
+ for comp in fdocore fdo utilities shp sqlite gdal ogr wfs wms rdbms kingoracle sdf
+ do
+ FDO_BUILD_COMPONENT="$comp (automake)"
+ ./build_linux.sh --w $comp --p ${FDO_INST}
+ check_build
+ done
+fi
+check_fdo_lib libFDO
+check_fdo_lib libExpressionEngine
+check_fdo_lib libSDFProvider
+check_fdo_lib libSHPProvider
+check_fdo_lib libSHPOverrides
+check_fdo_lib libWFSProvider
+check_fdo_lib libWMSProvider
+check_fdo_lib libWMSOverrides
+# ArcSDE provider currently disabled due to missing libraries
+#./buildfdoprovider.sh arcsde
+#check_fdo_lib libArcSDEProvider
+check_fdo_lib libFdoMySQL
+check_fdo_lib libFdoPostgreSQL
+check_fdo_lib libFdoODBC
+check_fdo_lib libSchemaMgr_OV
+check_fdo_lib libGRFPProvider
+check_fdo_lib libGRFPOverrides
+check_fdo_lib libOGRProvider
+check_fdo_lib libKingOracleProvider
+check_fdo_lib libKingOracleOverrides
+check_fdo_lib libSQLiteProvider
+end_time=`date +%s`
+FDO_BUILD_COMPONENT="Remove .la files from ${FDO_INST}"
+# Remove .la files from lib directory
+rm -f ${FDO_INST}/lib/*.la
+check_build
+FDO_BUILD_COMPONENT="Strip so symbols and remove execute flag"
+# Remove unneeded symbols from files in the lib directory
+# and make them non-executable
+for file in `find ${FDO_INST}/lib/lib*.so* -type f -print`
+do
+ strip --strip-unneeded ${file}
+ chmod a-x ${file}
+done
+check_build
+cd $BUILDROOT
+FDO_BUILD_COMPONENT="Make tarball"
+# Create a binary tar ball for FDO
+tar -zcf fdosdk-centos5-${FDO_VER_FULL}_${REVISION}.tar.gz ${FDO_INST}
+check_build
+echo "[info]: FDO build complete!"
+echo Main build execution time: `expr $end_time - $start_time` s
More information about the mapguide-commits
