[mapguide-commits] r8326 - trunk/MgDev
svn_mapguide at osgeo.org
Sat Aug 9 21:24:45 PDT 2014
Author: jng
Date: 2014-08-09 21:24:45 -0700 (Sat, 09 Aug 2014)
New Revision: 8326
trunk/MgDev/build_oem.sh
#2478: Update build_oem.sh to apply extra flags and settings for 64-bit and/or debug modes
Modified: trunk/MgDev/build_oem.sh
--- trunk/MgDev/build_oem.sh 2014-08-09 13:35:33 UTC (rev 8325)
+++ trunk/MgDev/build_oem.sh 2014-08-10 04:24:45 UTC (rev 8326)
@@ -105,6 +105,16 @@
init_ace()
LIB_NAME="ACE 5.7"
+ ace_buildbits=32
+ ace_debug=0
+ ace_optimize=1
+ if [ $BUILD_CONFIG = "debug" ]; then
+ ace_debug=1
+ ace_optimize=0
+ fi
+ if [ $BUILD_CPU -eq 64 ]; then
+ ace_buildbits=64
+ fi
build_ace()
@@ -112,7 +122,7 @@
pushd ACE/ACE_wrappers
ACE_PATH="${PWD}"
pushd ace
- env ACE_ROOT="${ACE_PATH}" make
+ env ACE_ROOT="${ACE_PATH}" make buildbits=$ace_buildbits debug=$ace_debug optimize=$ace_optimize
check_build
popd
popd
@@ -123,7 +133,7 @@
ACE_PATH="${PWD}"
pushd ace
- env ACE_ROOT="${ACE_PATH}" make clean
+ env ACE_ROOT="${ACE_PATH}" make clean buildbits=$ace_buildbits debug=$ace_debug optimize=$ace_optimize
check_clean
popd
popd
@@ -295,7 +305,11 @@
chmod +x s_paths
popd
pushd dbxml
- sh ./buildall.sh
+ sh ./buildall.sh --enable-debug
+ else
+ sh ./buildall.sh
+ fi
check_build
popd
@@ -412,7 +426,7 @@
cp scripts/makefile.std makefile
#Inject -fPIC to CFLAGS for 64-bit
- sed 's/^CFLAGS=/CFLAGS= -fPIC /g' makefile > makefile64
+ sed 's/^CFLAGS=/CFLAGS= -fPIC -m64/g' makefile > makefile64
make -fmakefile64
else
make
@@ -448,7 +462,7 @@
sh ./configure --enable-static --disable-shared
#--with-pic does nothing (probably ancient configure script), so do some sed trickery
#to inject this flag. Know a better way? Enlighten us :)
- sed 's/^CFLAGS=/CFLAGS= -fPIC/g' Makefile > Makefile64
+ sed 's/^CFLAGS=/CFLAGS= -fPIC -m64/g' Makefile > Makefile64
make -fMakefile64
else
@@ -546,7 +560,7 @@
pushd agg-2.4
- make EXTRACXXFLAGS=-fPIC
+ make EXTRACXXFLAGS=-fPIC -m64
else
make
fi
@@ -603,9 +617,7 @@
mkdir -p .libs
pushd Source
- #Need to build CS-Map with -fPIC because linking libraries will be built with -fPIC
- sed 's/^C_FLG =/C_FLG = -fPIC/g' Library.mak | sed 's/CPP_FLG =/CPP_FLG = -fPIC/g' > Library64.mak
- make -fLibrary64.mak
+ make -fLibrary.mak PROCESSOR=x64
else
make -fLibrary.mak PROCESSOR=x86
fi
@@ -613,9 +625,7 @@
popd
pushd Dictionaries
- sed 's/^C_FLG =/C_FLG = -fPIC/g' Library.mak | sed 's/CPP_FLG =/CPP_FLG = -fPIC/g' > Compiler64.mak
- make -fCompiler64.mak
+ make -fCompiler.mak PROCESSOR=x64
else
make -fCompiler.mak PROCESSOR=x86
fi
@@ -629,9 +639,9 @@
pushd CsMap/Source
- make clean -fLibrary64.mak
+ make clean -fLibrary.mak PROCESSOR=x64
else
- make clean -fLibrary.mak
+ make clean -fLibrary.mak PROCESSOR=x86
fi
check_clean
popd
More information about the mapguide-commits
