[mapguide-commits] r8327 - sandbox/jng/dwftk
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Aug 9 21:33:45 PDT 2014
Author: jng
Date: 2014-08-09 21:33:45 -0700 (Sat, 09 Aug 2014)
New Revision: 8327
   sandbox/jng/dwftk/
   sandbox/jng/dwftk/build_oem.sh
Merged revision(s) 8326 from trunk/MgDev:
#2478: Update build_oem.sh to apply extra flags and settings for 64-bit and/or debug modes
Property changes on: sandbox/jng/dwftk
___________________________________________________________________
Modified: svn:mergeinfo
   - /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/2.6/MgDev:8276-8286,8288-8292,8297,8299,8301,8303,8314-8315,8318
/sandbox/jng/convenience_apis:8263
/sandbox/jng/createruntimemap:7486-7555
/sandbox/jng/v30:8212-8227
/sandbox/rfc94:5099-5163
   + /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/trunk/MgDev:8326
Modified: sandbox/jng/dwftk/build_oem.sh
--- sandbox/jng/dwftk/build_oem.sh	2014-08-10 04:24:45 UTC (rev 8326)
+++ sandbox/jng/dwftk/build_oem.sh	2014-08-10 04:33:45 UTC (rev 8327)
@@ -105,6 +105,16 @@
 init_ace()
     LIB_NAME="ACE 5.7"
+    ace_buildbits=32
+    ace_debug=0
+    ace_optimize=1
+    if [ $BUILD_CONFIG = "debug" ]; then
+        ace_debug=1
+        ace_optimize=0
+    fi
+    if [ $BUILD_CPU -eq 64 ]; then
+        ace_buildbits=64
+    fi
 build_ace()
@@ -112,7 +122,7 @@
     pushd ACE/ACE_wrappers
     ACE_PATH="${PWD}"
     pushd ace
-    env ACE_ROOT="${ACE_PATH}" make
+    env ACE_ROOT="${ACE_PATH}" make buildbits=$ace_buildbits debug=$ace_debug optimize=$ace_optimize
     check_build
     popd
     popd
@@ -123,7 +133,7 @@
     ACE_PATH="${PWD}"
     pushd ace
-    env ACE_ROOT="${ACE_PATH}" make clean
+    env ACE_ROOT="${ACE_PATH}" make clean buildbits=$ace_buildbits debug=$ace_debug optimize=$ace_optimize
     check_clean
     popd
     popd
@@ -295,7 +305,11 @@
     chmod +x s_paths
     popd
     pushd dbxml
-    sh ./buildall.sh
+        sh ./buildall.sh --enable-debug
+    else
+        sh ./buildall.sh
+    fi
     check_build
     popd
@@ -412,7 +426,7 @@
     cp scripts/makefile.std makefile
         #Inject -fPIC to CFLAGS for 64-bit
-        sed 's/^CFLAGS=/CFLAGS= -fPIC /g' makefile > makefile64
+        sed 's/^CFLAGS=/CFLAGS= -fPIC -m64/g' makefile > makefile64
         make -fmakefile64
     else
         make
@@ -448,7 +462,7 @@
         sh ./configure --enable-static --disable-shared
         #--with-pic does nothing (probably ancient configure script), so do some sed trickery
         #to inject this flag. Know a better way? Enlighten us :)
-        sed 's/^CFLAGS=/CFLAGS= -fPIC/g' Makefile > Makefile64
+        sed 's/^CFLAGS=/CFLAGS= -fPIC -m64/g' Makefile > Makefile64
         make -fMakefile64
     else
@@ -546,7 +560,7 @@
     pushd agg-2.4
-        make EXTRACXXFLAGS=-fPIC
+        make EXTRACXXFLAGS=-fPIC -m64
     else
         make
     fi
@@ -603,9 +617,7 @@
     mkdir -p .libs
     pushd Source
-        #Need to build CS-Map with -fPIC because linking libraries will be built with -fPIC
-        sed 's/^C_FLG =/C_FLG = -fPIC/g' Library.mak | sed 's/CPP_FLG =/CPP_FLG = -fPIC/g' > Library64.mak
-        make -fLibrary64.mak
+        make -fLibrary.mak PROCESSOR=x64
     else
         make -fLibrary.mak PROCESSOR=x86
     fi
@@ -613,9 +625,7 @@
     popd
     pushd Dictionaries
-        sed 's/^C_FLG =/C_FLG = -fPIC/g' Library.mak | sed 's/CPP_FLG =/CPP_FLG = -fPIC/g' > Compiler64.mak
-        make -fCompiler64.mak
+        make -fCompiler.mak PROCESSOR=x64
     else
         make -fCompiler.mak PROCESSOR=x86
     fi
@@ -629,9 +639,9 @@
     pushd CsMap/Source
-        make clean -fLibrary64.mak
+        make clean -fLibrary.mak PROCESSOR=x64
     else
-        make clean -fLibrary.mak
+        make clean -fLibrary.mak PROCESSOR=x86
     fi
     check_clean
     popd
More information about the mapguide-commits mailing list
