[mapguide-commits] r8472 - in trunk/Tools/Maestro/SDK/Samples: . DrawMap DwfInspector HelloAddIn MapViewer QueryFeatureSource SchemaViewer StandaloneWebLayoutEditor
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Dec 27 09:24:11 PST 2014
Author: jng
Date: 2014-12-27 09:24:11 -0800 (Sat, 27 Dec 2014)
New Revision: 8472
   trunk/Tools/Maestro/SDK/Samples/
   trunk/Tools/Maestro/SDK/Samples/DrawMap/DrawMap.csproj
   trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.cs
   trunk/Tools/Maestro/SDK/Samples/DwfInspector/DwfInspector.csproj
   trunk/Tools/Maestro/SDK/Samples/DwfInspector/Form1.cs
   trunk/Tools/Maestro/SDK/Samples/HelloAddIn/HelloAddIn.csproj
   trunk/Tools/Maestro/SDK/Samples/HelloAddIn/SidePanel.cs
   trunk/Tools/Maestro/SDK/Samples/MapViewer/Form1.cs
   trunk/Tools/Maestro/SDK/Samples/MapViewer/MapViewer.csproj
   trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.cs
   trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/QueryFeatureSource.csproj
   trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.cs
   trunk/Tools/Maestro/SDK/Samples/SchemaViewer/SchemaViewer.csproj
   trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Form1.cs
   trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/StandaloneWebLayoutEditor.csproj
Fix SDK code samples in light of #2513
Property changes on: trunk/Tools/Maestro/SDK/Samples
___________________________________________________________________
Modified: svn:ignore
   - Samples.suo
Samples.sln.docstates.suo
   + Samples.suo
*.suo
Modified: trunk/Tools/Maestro/SDK/Samples/DrawMap/DrawMap.csproj
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/DrawMap.csproj	2014-12-27 17:16:54 UTC (rev 8471)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/DrawMap.csproj	2014-12-27 17:24:11 UTC (rev 8472)
@@ -60,14 +60,13 @@
       <SpecificVersion>False</SpecificVersion>
       <HintPath>..\..\bin\Maestro.Login.dll</HintPath>
     </Reference>
-    <Reference Include="OSGeo.MapGuide.ExtendedObjectModels, Version=1.0.0.0, Culture=neutral, processorArchitecture=MSIL">
-      <SpecificVersion>False</SpecificVersion>
-      <HintPath>..\..\bin\OSGeo.MapGuide.ExtendedObjectModels.dll</HintPath>
-    </Reference>
     <Reference Include="OSGeo.MapGuide.MaestroAPI, Version=3.0.0.5728, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
       <HintPath>..\..\bin\OSGeo.MapGuide.MaestroAPI.dll</HintPath>
     </Reference>
+    <Reference Include="OSGeo.MapGuide.ObjectModels">
+      <HintPath>..\..\bin\OSGeo.MapGuide.ObjectModels.dll</HintPath>
+    </Reference>
     <Reference Include="System" />
     <Reference Include="System.Data" />
     <Reference Include="System.Deployment" />
Modified: trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.cs	2014-12-27 17:16:54 UTC (rev 8471)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.cs	2014-12-27 17:24:11 UTC (rev 8472)
@@ -28,7 +28,7 @@
 using OSGeo.MapGuide.MaestroAPI;
 using OSGeo.MapGuide.MaestroAPI.Services;
 using OSGeo.MapGuide.ObjectModels.MapDefinition;
-using OSGeo.MapGuide.ExtendedObjectModels;
+using OSGeo.MapGuide.ObjectModels;
 namespace DrawMap
@@ -43,11 +43,6 @@
         protected override void OnLoad(EventArgs e)
-            //This call is a one-time only call that will instantly register all known resource
-            //version types and validators. This way you never have to manually reference a
-            //ObjectModels assembly of the desired resource type you want to work with
-            ModelSetup.Initialize();
             //Anytime we work with the Maestro API, we require an IServerConnection
             //reference. The Maestro.Login.LoginDialog provides a UI to obtain such a
             //reference.
Modified: trunk/Tools/Maestro/SDK/Samples/DwfInspector/DwfInspector.csproj
--- trunk/Tools/Maestro/SDK/Samples/DwfInspector/DwfInspector.csproj	2014-12-27 17:16:54 UTC (rev 8471)
+++ trunk/Tools/Maestro/SDK/Samples/DwfInspector/DwfInspector.csproj	2014-12-27 17:24:11 UTC (rev 8472)
@@ -60,14 +60,13 @@
     </Reference>
-    </Reference>
     </Reference>
+    </Reference>
Modified: trunk/Tools/Maestro/SDK/Samples/DwfInspector/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/DwfInspector/Form1.cs	2014-12-27 17:16:54 UTC (rev 8471)
+++ trunk/Tools/Maestro/SDK/Samples/DwfInspector/Form1.cs	2014-12-27 17:24:11 UTC (rev 8472)
@@ -30,7 +30,6 @@
 using OSGeo.MapGuide.ObjectModels.DrawingSource;
 namespace DwfInspector
@@ -46,11 +45,6 @@
             //reference.
@@ -131,7 +125,7 @@
             // The DWF file we upload must be the same name as the SourceName property
             // in the DrawingSource and the resource data name that we are uploading as
-            IDrawingSource ds = ObjectFactory.CreateDrawingSource(_conn);
+            IDrawingSource ds = ObjectFactory.CreateDrawingSource();
             ds.SourceName = Path.GetFileName(txtDwfPath.Text);
             string resId = "Session:" + _conn.SessionID + "//InspectedDwf.DrawingSource";
Modified: trunk/Tools/Maestro/SDK/Samples/HelloAddIn/HelloAddIn.csproj
--- trunk/Tools/Maestro/SDK/Samples/HelloAddIn/HelloAddIn.csproj	2014-12-27 17:16:54 UTC (rev 8471)
+++ trunk/Tools/Maestro/SDK/Samples/HelloAddIn/HelloAddIn.csproj	2014-12-27 17:24:11 UTC (rev 8472)
@@ -56,6 +56,9 @@
       <Private>False</Private>
     </Reference>
+    </Reference>
     <Reference Include="System.Core" />
     <Reference Include="System.Xml.Linq" />
Modified: trunk/Tools/Maestro/SDK/Samples/HelloAddIn/SidePanel.cs
--- trunk/Tools/Maestro/SDK/Samples/HelloAddIn/SidePanel.cs	2014-12-27 17:16:54 UTC (rev 8471)
+++ trunk/Tools/Maestro/SDK/Samples/HelloAddIn/SidePanel.cs	2014-12-27 17:24:11 UTC (rev 8472)
@@ -16,6 +16,7 @@
 using OSGeo.MapGuide.MaestroAPI.Exceptions;
 using OSGeo.MapGuide.ObjectModels.Common;
 namespace HelloAddIn
@@ -122,7 +123,7 @@
             worker.ReportProgress(0);
-            var context = new ResourceValidationContext(conn.ResourceService, conn.FeatureService);
+            var context = new ResourceValidationContext(conn);
             var set = new ValidationResultSet();
             int i = 0;
Modified: trunk/Tools/Maestro/SDK/Samples/MapViewer/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/MapViewer/Form1.cs	2014-12-27 17:16:54 UTC (rev 8471)
+++ trunk/Tools/Maestro/SDK/Samples/MapViewer/Form1.cs	2014-12-27 17:24:11 UTC (rev 8472)
@@ -8,9 +8,9 @@
 using System.Windows.Forms;
 using Maestro.Editors.Generic;
 namespace MapViewer
@@ -25,11 +25,6 @@
             //reference.
Modified: trunk/Tools/Maestro/SDK/Samples/MapViewer/MapViewer.csproj
--- trunk/Tools/Maestro/SDK/Samples/MapViewer/MapViewer.csproj	2014-12-27 17:16:54 UTC (rev 8471)
+++ trunk/Tools/Maestro/SDK/Samples/MapViewer/MapViewer.csproj	2014-12-27 17:24:11 UTC (rev 8472)
@@ -44,12 +44,12 @@
     <Reference Include="Maestro.MapViewer">
       <HintPath>..\..\bin\Maestro.MapViewer.dll</HintPath>
     </Reference>
-    <Reference Include="OSGeo.MapGuide.ExtendedObjectModels">
-    </Reference>
     <Reference Include="OSGeo.MapGuide.MaestroAPI">
     </Reference>
+    </Reference>
Modified: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.cs	2014-12-27 17:16:54 UTC (rev 8471)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.cs	2014-12-27 17:24:11 UTC (rev 8472)
@@ -28,7 +28,7 @@
 using OSGeo.MapGuide.MaestroAPI.Feature;
 using OSGeo.MapGuide.MaestroAPI.Schema;
 namespace QueryFeatureSource
@@ -43,11 +43,6 @@
             //reference.
Modified: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/QueryFeatureSource.csproj
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/QueryFeatureSource.csproj	2014-12-27 17:16:54 UTC (rev 8471)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/QueryFeatureSource.csproj	2014-12-27 17:24:11 UTC (rev 8472)
@@ -60,14 +60,13 @@
     </Reference>
-    </Reference>
     </Reference>
+    </Reference>
Modified: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.cs	2014-12-27 17:16:54 UTC (rev 8471)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.cs	2014-12-27 17:24:11 UTC (rev 8472)
@@ -27,7 +27,7 @@
 namespace SchemaViewer
@@ -42,11 +42,6 @@
             //reference.
Modified: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/SchemaViewer.csproj
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/SchemaViewer.csproj	2014-12-27 17:16:54 UTC (rev 8471)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/SchemaViewer.csproj	2014-12-27 17:24:11 UTC (rev 8472)
@@ -60,14 +60,13 @@
     </Reference>
-    </Reference>
     </Reference>
+    </Reference>
Modified: trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Form1.cs	2014-12-27 17:16:54 UTC (rev 8471)
+++ trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Form1.cs	2014-12-27 17:24:11 UTC (rev 8472)
@@ -28,7 +28,7 @@
 using Maestro.Editors;
 using Maestro.Editors.WebLayout;
 namespace StandaloneWebLayoutEditor
@@ -48,11 +48,6 @@
             //reference.
Modified: trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/StandaloneWebLayoutEditor.csproj
--- trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/StandaloneWebLayoutEditor.csproj	2014-12-27 17:16:54 UTC (rev 8471)
+++ trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/StandaloneWebLayoutEditor.csproj	2014-12-27 17:24:11 UTC (rev 8472)
@@ -60,14 +60,13 @@
     </Reference>
-    </Reference>
     <Reference Include="OSGeo.MapGuide.MaestroAPI, Version=3.5.0.5977, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
     </Reference>
+    </Reference>
More information about the mapguide-commits mailing list
