[mapguide-commits] r8473 - in trunk/Tools/Maestro/SDK/SamplesWeb: . SamplesWeb SamplesWeb/Tasks
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Dec 27 09:29:38 PST 2014
Author: jng
Date: 2014-12-27 09:29:38 -0800 (Sat, 27 Dec 2014)
New Revision: 8473
   trunk/Tools/Maestro/SDK/SamplesWeb/
   trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Default.aspx.cs
   trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Global.asax.cs
   trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj
   trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddThemedDistrictsLayer.aspx.cs
   trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.cs
Fix SDK code samples in light of #2513
Property changes on: trunk/Tools/Maestro/SDK/SamplesWeb
___________________________________________________________________
Modified: svn:ignore
   - SamplesWeb.suo
   + SamplesWeb.suo
*.suo
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Default.aspx.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Default.aspx.cs	2014-12-27 17:24:11 UTC (rev 8472)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Default.aspx.cs	2014-12-27 17:29:38 UTC (rev 8473)
@@ -60,7 +60,8 @@
                 //the latest supported one on the mapguide server we've connected to. For example
                 //connecting to MGOS 2.2 will create a version 1.1.0 WebLayout. All the known
                 //resource versions have been registered on startup (see Global.asax.cs)
-                IWebLayout wl = ObjectFactory.CreateWebLayout(conn, mdfId);
+                Version ver = conn.Capabilities.GetMaxSupportedResourceVersion(ResourceTypes.WebLayout.ToString());
+                IWebLayout wl = ObjectFactory.CreateWebLayout(ver, mdfId);
                 //What is IWebLayout2? It is an extension of IWebLayout that supports the ping server property.
                 //This is the interface equivalent of WebLayout 1.1.0 schema. Most schema revisions in MapGuide
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Global.asax.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Global.asax.cs	2014-12-27 17:24:11 UTC (rev 8472)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Global.asax.cs	2014-12-27 17:29:38 UTC (rev 8473)
@@ -30,7 +30,6 @@
 using OSGeo.MapGuide.MaestroAPI.Resource.Validation;
 using OSGeo.MapGuide.MaestroAPI;
 using OSGeo.MapGuide.MaestroAPI.Resource;
-using OSGeo.MapGuide.ExtendedObjectModels;
 namespace SamplesWeb
@@ -39,16 +38,7 @@
         protected void Application_Start(object sender, EventArgs e)
-            //By default the ObjectFactory, ResourceTypeRegistry and ResourceValidatorSet only
-            //support v1.0.0 of all resource types. To support additional types we need to inject
-            //this information as part of the consuming application's init/startup process
-            //This is our application's entry point, so we do this here.
-            //The ModelSetup utility class can auto-magically do this for us
-            //This is only necessary if you want to create resources newer than version 1.0.0
-            ModelSetup.Initialize();
         protected void Session_Start(object sender, EventArgs e)
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj	2014-12-27 17:24:11 UTC (rev 8472)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj	2014-12-27 17:29:38 UTC (rev 8473)
@@ -20,6 +20,10 @@
     <OldToolsVersion>3.5</OldToolsVersion>
     <TargetFrameworkProfile />
     <UseIISExpress>false</UseIISExpress>
+    <IISExpressSSLPort />
+    <IISExpressAnonymousAuthentication />
+    <IISExpressWindowsAuthentication />
+    <IISExpressUseClassicPipelineMode />
   </PropertyGroup>
   <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
     <DebugSymbols>true</DebugSymbols>
@@ -39,13 +43,13 @@
     <WarningLevel>4</WarningLevel>
   </PropertyGroup>
   <ItemGroup>
-    <Reference Include="OSGeo.MapGuide.ExtendedObjectModels">
-      <HintPath>..\..\bin\OSGeo.MapGuide.ExtendedObjectModels.dll</HintPath>
-    </Reference>
     <Reference Include="OSGeo.MapGuide.MaestroAPI, Version=3.0.0.5728, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
       <SpecificVersion>False</SpecificVersion>
       <HintPath>..\..\bin\OSGeo.MapGuide.MaestroAPI.dll</HintPath>
     </Reference>
+    <Reference Include="OSGeo.MapGuide.ObjectModels">
+      <HintPath>..\..\bin\OSGeo.MapGuide.ObjectModels.dll</HintPath>
+    </Reference>
     <Reference Include="System" />
     <Reference Include="System.Data" />
     <Reference Include="System.Data.DataSetExtensions" />
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddThemedDistrictsLayer.aspx.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddThemedDistrictsLayer.aspx.cs	2014-12-27 17:24:11 UTC (rev 8472)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddThemedDistrictsLayer.aspx.cs	2014-12-27 17:29:38 UTC (rev 8473)
@@ -103,8 +103,10 @@
         private void CreateDistrictsLayer(IServerConnection conn, string resId, string layerId)
-            //We use the ObjectFactory class to create our layer
-            ILayerDefinition ldf = ObjectFactory.CreateDefaultLayer(conn, LayerType.Vector);
+            //We use the Utility class to create our layer. You can also use ObjectFactory, but
+            //that requires explicitly specifying the resource version. Using Utility will pick
+            //the latest supported version
+            ILayerDefinition ldf = Utility.CreateDefaultLayer(conn, LayerType.Vector);
             IVectorLayerDefinition vldf = (IVectorLayerDefinition)ldf.SubLayer;
             //Set feature source
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.cs	2014-12-27 17:24:11 UTC (rev 8472)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.cs	2014-12-27 17:29:38 UTC (rev 8473)
@@ -115,8 +115,10 @@
         private static void CreateTracksLayer(IServerConnection conn, string resId, string layerId)
More information about the mapguide-commits mailing list
