[mapguide-commits] r8480 - in trunk/Tools/Maestro: MaestroAPITests OSGeo.MapGuide.MaestroAPI.Http
svn_mapguide at osgeo.org
Mon Dec 29 00:03:30 PST 2014
Author: jng
Date: 2014-12-29 00:03:30 -0800 (Mon, 29 Dec 2014)
New Revision: 8480
trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Files.Designer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/OSGeo.MapGuide.MaestroAPI.Http.csproj
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Strings.Designer.cs
Liberate the Maestro HTTP connection provider from System.Web and re-target towards the .net 4.0 client profile.
Modified: trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs 2014-12-29 04:46:11 UTC (rev 8479)
+++ trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs 2014-12-29 08:03:30 UTC (rev 8480)
@@ -1155,6 +1155,7 @@
//Create a 200 layer, 50 group map. This is not part of the benchmark
var mdf = Utility.CreateMapDefinition(_conn, "LargeMap");
+ mdf.ResourceID = "Library://UnitTests/LargeMapTest/LargeMap.MapDefinition";
string root = "Library://UnitTests/LargeMapTest/";
//We have to create 200 unique layer definitions (same content) otherwise only one GetResourceContent
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Files.Designer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Files.Designer.cs 2014-12-29 04:46:11 UTC (rev 8479)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Files.Designer.cs 2014-12-29 08:03:30 UTC (rev 8480)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:4.0.30319.34209
+// Runtime Version:4.0.30319.18444
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/OSGeo.MapGuide.MaestroAPI.Http.csproj
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/OSGeo.MapGuide.MaestroAPI.Http.csproj 2014-12-29 04:46:11 UTC (rev 8479)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/OSGeo.MapGuide.MaestroAPI.Http.csproj 2014-12-29 08:03:30 UTC (rev 8480)
@@ -20,8 +20,7 @@
<UpgradeBackupLocation>
</UpgradeBackupLocation>
<OldToolsVersion>3.5</OldToolsVersion>
- <TargetFrameworkProfile>
- </TargetFrameworkProfile>
+ <TargetFrameworkProfile>Client</TargetFrameworkProfile>
<PublishUrl>publish\</PublishUrl>
<Install>true</Install>
<InstallFrom>Disk</InstallFrom>
@@ -64,9 +63,7 @@
<Private>False</Private>
</Reference>
<Reference Include="System" />
- <Reference Include="System.Data" />
<Reference Include="System.Drawing" />
- <Reference Include="System.Web" />
<Reference Include="System.Xml" />
</ItemGroup>
<ItemGroup>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs 2014-12-29 04:46:11 UTC (rev 8479)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs 2014-12-29 08:03:30 UTC (rev 8480)
@@ -233,9 +233,18 @@
return EncodeParameters(param, true);
+ static string UrlEncode(string name)
+ if (name == null)
+ return string.Empty;
+ return System.Uri.EscapeDataString(name);
private string EncodeParameter(string name, string value)
- return System.Web.HttpUtility.UrlEncode(name) + "=" + System.Web.HttpUtility.UrlEncode(value);
+ if (name == null)
+ return UrlEncode(name) + "=" + UrlEncode(value);
public string GetMapDWF(string id)
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Strings.Designer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Strings.Designer.cs 2014-12-29 04:46:11 UTC (rev 8479)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Strings.Designer.cs 2014-12-29 08:03:30 UTC (rev 8480)
@@ -1,7 +1,7 @@
// <auto-generated>
More information about the mapguide-commits
