[mapguide-commits] r8481 - in trunk/Tools/Maestro: Maestro.Base/UI MaestroAPITests OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/Mapping OSGeo.MapGuide.MaestroAPI/Serialization OSGeo.MapGuide.MaestroAPI.Http OSGeo.MapGuide.ObjectModels
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Dec 29 02:11:17 PST 2014
Author: jng
Date: 2014-12-29 02:11:17 -0800 (Mon, 29 Dec 2014)
New Revision: 8481
   trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.cs
   trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Serialization/MgBinarySerializer.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/ResourceIdentifier.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/ResourceTypes.cs
#2514: Update RuntimeMap to support MGOS 3.0 MgMap state.
 - Rename ResourceTypes.RuntimeMap to ResourceTypes.Map, this avoids the need for special-case processing when converting resource ids to strings when dealing with Runtime Map resources.
 - Update RuntimeMap serialization logic to handle the new information in MGOS 3.0 (tile set ids)
 - Update MgBinarySerializer to properly handle the case of null resource IDs.
Modified: trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.cs	2014-12-29 08:03:30 UTC (rev 8480)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.cs	2014-12-29 10:11:17 UTC (rev 8481)
@@ -109,7 +109,7 @@
                 //AIMS 2012 demands this checks out. Can't flub it anymore
                 m.ResourceID = "Session:" + m_connection.SessionID + "//non-existing.MapDefinition"; //NOXLATE
                 var mpsvc = (IMappingService)m_connection.GetService((int)ServiceType.Mapping);
-                var rid = new ResourceIdentifier(Guid.NewGuid().ToString(), ResourceTypes.RuntimeMap, m_connection.SessionID);
+                var rid = new ResourceIdentifier(Guid.NewGuid().ToString(), ResourceTypes.Map, m_connection.SessionID);
                 m_tempmap = mpsvc.CreateMap(m);
Modified: trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs	2014-12-29 08:03:30 UTC (rev 8480)
+++ trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs	2014-12-29 10:11:17 UTC (rev 8481)
@@ -1043,7 +1043,7 @@
             ResourceIdentifier rtmX = new ResourceIdentifier(mapdefinition);
             string rtmDef = "Library://UnitTests/Cache/" + rtmX.Fullpath.Replace(":", "_").Replace("/", "_");
             string mapName = rtmX.Name;
-            ResourceIdentifier mapid = new ResourceIdentifier(mapName, ResourceTypes.RuntimeMap, conn.SessionID);
+            ResourceIdentifier mapid = new ResourceIdentifier(mapName, ResourceTypes.Map, conn.SessionID);
             IMapDefinition mdef = (IMapDefinition)conn.ResourceService.GetResource(mapdefinition);
             RuntimeMap rtm = mapSvc.CreateMap(mdef); // Create new runtime map
             Assert.IsFalse(rtm.IsDirty);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs	2014-12-29 08:03:30 UTC (rev 8480)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs	2014-12-29 10:11:17 UTC (rev 8481)
@@ -485,6 +485,17 @@
         /// <summary>
+        /// Gets or sets the tile set definition resource id. Only applicable
+        /// if the Map Definition used to create this map contains a reference
+        /// to a tile set
+        /// </summary>
+        public virtual string TileSetDefinition
+            get;
+            internal set;
+        /// <summary>
         /// Gets or sets the map definition resource id
         /// </summary>
         /// <value>The map definition resource id.</value>
@@ -649,7 +660,7 @@
         /// <value>The type of the resource.</value>
         public ResourceTypes ResourceType
-            get { return ResourceTypes.RuntimeMap; }
+            get { return ResourceTypes.Map; }
         /// <summary>
@@ -736,6 +747,10 @@
                     s.Write(this.WatermarkUsage);
+                if (s.SiteVersion >= new Version(3, 0))
+                    s.WriteResourceIdentifier(this.TileSetDefinition);
                 s.Write((int)0);
             else
@@ -951,6 +966,10 @@
                     this.WatermarkUsage = d.ReadInt32();
+                if (d.SiteVersion >= new Version(3, 0))
+                    this.TileSetDefinition = d.ReadResourceIdentifier();
                 int mapLayerCount = d.ReadInt32();
                 if (mapLayerCount != 0)
                     throw new Exception(Strings.ErrorShouldHaveNoLayerDataInMap);
@@ -1242,13 +1261,16 @@
         private void Save(string resourceID)
+            Check.ArgumentNotNull(resourceID, "resourceID");
+            Check.ArgumentNotEmpty(resourceID, "resourceID");
+            Check.ThatPreconditionIsMet(resourceID.EndsWith(".Map"), "resourceID.EndsWith(\".Map\")");
             var map = this;
             string selectionID = resourceID.Substring(0, resourceID.LastIndexOf(".")) + ".Selection"; //NOXLATE
             this.ResourceService.SetResourceXmlData(resourceID, new System.IO.MemoryStream(System.Text.Encoding.UTF8.GetBytes(RUNTIMEMAP_XML)));
             this.ResourceService.SetResourceXmlData(selectionID, new System.IO.MemoryStream(System.Text.Encoding.UTF8.GetBytes(RUNTIMEMAP_SELECTION_XML)));
-            ResourceIdentifier.Validate(resourceID, ResourceTypes.RuntimeMap);
+            ResourceIdentifier.Validate(resourceID, ResourceTypes.Map);
             if (!resourceID.StartsWith("Session:" + this.SessionId + "//") || !resourceID.EndsWith(".Map")) //NOXLATE
                 throw new Exception(Strings.ErrorRuntimeMapNotInSessionRepo);
@@ -1304,7 +1326,7 @@
         private void SaveSelectionXml(string resourceID)
             System.IO.MemoryStream ms = new System.IO.MemoryStream();
             MgBinarySerializer serializer = new MgBinarySerializer(ms, this.SiteVersion);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs	2014-12-29 08:03:30 UTC (rev 8480)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs	2014-12-29 10:11:17 UTC (rev 8481)
@@ -2205,7 +2205,7 @@
         /// <returns></returns>
         public RuntimeMap CreateMap(IMapDefinition mdf, bool suppressErrors)
-            var rid = new ResourceIdentifier(ResourceIdentifier.GetName(mdf.ResourceID), ResourceTypes.RuntimeMap, this.SessionID);
+            var rid = new ResourceIdentifier(ResourceIdentifier.GetName(mdf.ResourceID), ResourceTypes.Map, this.SessionID);
             return CreateMap(rid.ToString(), mdf, suppressErrors);
@@ -2231,7 +2231,7 @@
         public RuntimeMap CreateMap(IMapDefinition mdf, double metersPerUnit, bool suppressErrors)
             return CreateMap(rid.ToString(), mdf, metersPerUnit, suppressErrors);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Serialization/MgBinarySerializer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Serialization/MgBinarySerializer.cs	2014-12-29 08:03:30 UTC (rev 8480)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Serialization/MgBinarySerializer.cs	2014-12-29 10:11:17 UTC (rev 8481)
@@ -113,14 +113,22 @@
         /// <param name="resourceID">The resource ID.</param>
         public void WriteResourceIdentifier(string resourceID)
-            if (m_siteVersion <= SiteVersions.GetVersion(KnownSiteVersions.MapGuideEP1_1))
-                WriteClassId(12003);
+            if (resourceID == null)
+                //For null objects, we write a class ID of 0
+                WriteClassId(0);
             else
-                WriteClassId(11500);
-            if (m_siteVersion >= SiteVersions.GetVersion(KnownSiteVersions.MapGuideOS1_2))
-                WriteStringInternal(resourceID);
-            else
-                Write(resourceID);
+                if (m_siteVersion <= SiteVersions.GetVersion(KnownSiteVersions.MapGuideEP1_1))
+                    WriteClassId(12003);
+                else
+                    WriteClassId(11500);
+                if (m_siteVersion >= SiteVersions.GetVersion(KnownSiteVersions.MapGuideOS1_2))
+                    WriteStringInternal(resourceID);
+                else
+                    Write(resourceID);
         /// <summary>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs	2014-12-29 08:03:30 UTC (rev 8480)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs	2014-12-29 10:11:17 UTC (rev 8481)
@@ -1061,7 +1061,7 @@
         public override System.IO.Stream RenderRuntimeMap(Mapping.RuntimeMap map, double x, double y, double scale, int width, int height, int dpi, string format, bool clip)
             var resourceId = map.ResourceID;
-            ResourceIdentifier.Validate(resourceId, ResourceTypes.RuntimeMap);
+            ResourceIdentifier.Validate(resourceId, ResourceTypes.Map);
             string mapname = resourceId.Substring(resourceId.IndexOf("//") + 2);
             mapname = mapname.Substring(0, mapname.LastIndexOf("."));
 #if DEBUG
@@ -1093,7 +1093,7 @@
         public override System.IO.Stream RenderRuntimeMap(Mapping.RuntimeMap map, double x1, double y1, double x2, double y2, int width, int height, int dpi, string format, bool clip)
 #if DEBUG
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/ResourceIdentifier.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/ResourceIdentifier.cs	2014-12-29 08:03:30 UTC (rev 8480)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/ResourceIdentifier.cs	2014-12-29 10:11:17 UTC (rev 8481)
@@ -418,7 +418,7 @@
             var ext = GetExtension(identifier);
             if (ext == "Map") //NOXLATE
-                return ResourceTypes.RuntimeMap;
+                return ResourceTypes.Map;
             else
                 return (ResourceTypes)Enum.Parse(typeof(ResourceTypes), ext);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/ResourceTypes.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/ResourceTypes.cs	2014-12-29 08:03:30 UTC (rev 8480)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/ResourceTypes.cs	2014-12-29 10:11:17 UTC (rev 8481)
@@ -55,7 +55,7 @@
         /// <summary>
         /// Runtime Map
         /// </summary>
-        RuntimeMap,
+        Map,
         /// <summary>
         /// Folder
More information about the mapguide-commits mailing list
