[mapguide-commits] r8482 - in trunk/Tools/Maestro: Generated Maestro MaestroAPITests OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/Schemas OSGeo.MapGuide.MaestroAPI.Http OSGeo.MapGuide.ObjectModels OSGeo.MapGuide.ObjectModels/RuntimeMap OSGeo.MapGuide.ObjectModels/RuntimeMap/v3_0_0 Thirdparty
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Dec 29 05:18:49 PST 2014
Author: jng
Date: 2014-12-29 05:18:49 -0800 (Mon, 29 Dec 2014)
New Revision: 8482
Added:
   trunk/Tools/Maestro/Generated/MapDefinition-3.0.0.designer.cs
   trunk/Tools/Maestro/Generated/RuntimeMap-3.0.0.designer.cs
   trunk/Tools/Maestro/Generated/TileProviderList-3.0.0.designer.cs
   trunk/Tools/Maestro/Generated/TileSetDefinition-3.0.0.designer.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schemas/MapDefinition-3.0.0.xsd
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schemas/RuntimeMap-3.0.0.xsd
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schemas/TileProviderList-3.0.0.xsd
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schemas/TileSetDefinition-3.0.0.xsd
   trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/RuntimeMap/v3_0_0/
   trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/RuntimeMap/v3_0_0/RuntimeMapImpl.cs
Removed:
   trunk/Tools/Maestro/Thirdparty/Xsd2Code/
   trunk/Tools/Maestro/Maestro/Maestro.csproj
   trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj
   trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
   trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/OSGeo.MapGuide.ObjectModels.csproj
   trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/RuntimeMap/RuntimeMapInterfaces.cs
#2515: Add support for the Runtime 3.0.0 schema in MGOS 3.0. Add a new IRuntimeMapInfo2 to model the new changes. Modify the HTTP implementations of ICreateRuntimeMap and IDescribeRuntimeMap to request this particular version of the RuntimeMap schema. Update the runtime map tests to check that the right IRuntimeMapInfo instance is being returned.
Also remove xsd2code from thirdparty
Added: trunk/Tools/Maestro/Generated/MapDefinition-3.0.0.designer.cs
--- trunk/Tools/Maestro/Generated/MapDefinition-3.0.0.designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Generated/MapDefinition-3.0.0.designer.cs	2014-12-29 13:18:49 UTC (rev 8482)
@@ -0,0 +1,11593 @@
+//  <auto-generated>
+//    Generated by Xsd2Code. Version 3.4.0.32989
+//    <NameSpace>OSGeo.MapGuide.ObjectModels.MapDefinition</NameSpace><Collection>BindingList</Collection><codeType>CSharp</codeType><EnableDataBinding>True</EnableDataBinding><EnableLazyLoading>False</EnableLazyLoading><TrackingChangesEnable>False</TrackingChangesEnable><GenTrackingClasses>False</GenTrackingClasses><HidePrivateFieldInIDE>True</HidePrivateFieldInIDE><EnableSummaryComment>True</EnableSummaryComment><VirtualProp>False</VirtualProp><IncludeSerializeMethod>True</IncludeSerializeMethod><UseBaseClass>False</UseBaseClass><GenBaseClass>False</GenBaseClass><GenerateCloneMethod>True</GenerateCloneMethod><GenerateDataContracts>False</GenerateDataContracts><CodeBaseTag>Net20</CodeBaseTag><SerializeMethodName>Serialize</SerializeMethodName><DeserializeMethodName>Deserialize</DeserializeMethodName><SaveToFileMethodName>SaveToFile</SaveToFileMethodName><LoadFromFileMethodName>LoadFromFile</LoadFromFileMethodName><GenerateXMLAttributes>True</GenerateXMLAttributes><OrderXMLA
 ttrib>False</OrderXMLAttrib><EnableEncoding>False</EnableEncoding><AutomaticProperties>False</AutomaticProperties><GenerateShouldSerialize>False</GenerateShouldSerialize><DisableDebug>False</DisableDebug><PropNameSpecified>Default</PropNameSpecified><Encoder>UTF8</Encoder><CustomUsings></CustomUsings><ExcludeIncludedTypes>False</ExcludeIncludedTypes><EnableInitializeFields>False</EnableInitializeFields>
+//  </auto-generated>
+namespace OSGeo.MapGuide.ObjectModels.MapDefinition {
+    using System;
+    using System.Diagnostics;
+    using System.Xml.Serialization;
+    using System.Collections;
+    using System.Xml.Schema;
+    using System.ComponentModel;
+    using System.IO;
+    using System.Text;
+    [System.CodeDom.Compiler.GeneratedCodeAttribute("Xsd2Code", "3.4.0.32990")]
+    [System.SerializableAttribute()]
+    [System.ComponentModel.DesignerCategoryAttribute("code")]
+    [System.Xml.Serialization.XmlTypeAttribute(AnonymousType=true)]
+    [System.Xml.Serialization.XmlRootAttribute("SimpleSymbolDefinition", Namespace="", IsNullable=false)]
+    public partial class SimpleSymbolDefinition1 : SimpleSymbolDefinition, System.ComponentModel.INotifyPropertyChanged {
+        [EditorBrowsable(EditorBrowsableState.Never)]
+        private string versionField;
+        private static System.Xml.Serialization.XmlSerializer serializer;
+        public SimpleSymbolDefinition1() {
+            this.versionField = "2.4.0";
+        [System.Xml.Serialization.XmlAttributeAttribute()]
+        public string version {
+            get {
+                return this.versionField;
+            set {
+                if ((this.versionField != null)) {
+                    if ((versionField.Equals(value) != true)) {
+                        this.versionField = value;
+                        this.OnPropertyChanged("version");
+                else {
+        private static System.Xml.Serialization.XmlSerializer Serializer {
+            get {
+                if ((serializer == null)) {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(SimpleSymbolDefinition1));
+                return serializer;
+        public event System.ComponentModel.PropertyChangedEventHandler PropertyChanged;
+        public virtual void OnPropertyChanged(string propertyName) {
+            System.ComponentModel.PropertyChangedEventHandler handler = this.PropertyChanged;
+            if ((handler != null)) {
+                handler(this, new System.ComponentModel.PropertyChangedEventArgs(propertyName));
+        #region Serialize/Deserialize
+        /// <summary>
+        /// Serializes current SimpleSymbolDefinition1 object into an XML document
+        /// </summary>
+        /// <returns>string XML value</returns>
+        public virtual string Serialize() {
+            System.IO.StreamReader streamReader = null;
+            System.IO.MemoryStream memoryStream = null;
+            try {
+                memoryStream = new System.IO.MemoryStream();
+                Serializer.Serialize(memoryStream, this);
+                memoryStream.Seek(0, System.IO.SeekOrigin.Begin);
+                streamReader = new System.IO.StreamReader(memoryStream);
+                return streamReader.ReadToEnd();
+            finally {
+                if ((streamReader != null)) {
+                    streamReader.Dispose();
+                if ((memoryStream != null)) {
+                    memoryStream.Dispose();
+        /// <summary>
+        /// Deserializes workflow markup into an SimpleSymbolDefinition1 object
+        /// </summary>
+        /// <param name="xml">string workflow markup to deserialize</param>
+        /// <param name="obj">Output SimpleSymbolDefinition1 object</param>
+        /// <param name="exception">output Exception value if deserialize failed</param>
+        /// <returns>true if this XmlSerializer can deserialize the object; otherwise, false</returns>
+        public static bool Deserialize(string xml, out SimpleSymbolDefinition1 obj, out System.Exception exception) {
+            exception = null;
+            obj = default(SimpleSymbolDefinition1);
+            try {
+                obj = Deserialize(xml);
+                return true;
+            catch (System.Exception ex) {
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out SimpleSymbolDefinition1 obj) {
+            System.Exception exception = null;
+            return Deserialize(xml, out obj, out exception);
+        public static SimpleSymbolDefinition1 Deserialize(string xml) {
+            System.IO.StringReader stringReader = null;
+            try {
+                stringReader = new System.IO.StringReader(xml);
+                return ((SimpleSymbolDefinition1)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+                if ((stringReader != null)) {
+                    stringReader.Dispose();
+        /// <summary>
+        /// Serializes current SimpleSymbolDefinition1 object into file
+        /// </summary>
+        /// <param name="fileName">full path of outupt xml file</param>
+        /// <param name="exception">output Exception value if failed</param>
+        /// <returns>true if can serialize and save into file; otherwise, false</returns>
+        public virtual bool SaveToFile(string fileName, out System.Exception exception) {
+            exception = null;
+            try {
+                SaveToFile(fileName);
+                return true;
+            catch (System.Exception e) {
+                exception = e;
+                return false;
+        public virtual void SaveToFile(string fileName) {
+            System.IO.StreamWriter streamWriter = null;
+            try {
+                string xmlString = Serialize();
+                System.IO.FileInfo xmlFile = new System.IO.FileInfo(fileName);
+                streamWriter = xmlFile.CreateText();
+                streamWriter.WriteLine(xmlString);
+                streamWriter.Close();
+            finally {
+                if ((streamWriter != null)) {
+                    streamWriter.Dispose();
+        /// <summary>
+        /// Deserializes xml markup from file into an SimpleSymbolDefinition1 object
+        /// </summary>
+        /// <param name="fileName">string xml file to load and deserialize</param>
+        public static bool LoadFromFile(string fileName, out SimpleSymbolDefinition1 obj, out System.Exception exception) {
+            exception = null;
+            try {
+                obj = LoadFromFile(fileName);
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out SimpleSymbolDefinition1 obj) {
+            return LoadFromFile(fileName, out obj, out exception);
+        public static SimpleSymbolDefinition1 LoadFromFile(string fileName) {
+            System.IO.FileStream file = null;
+            System.IO.StreamReader sr = null;
+            try {
+                file = new System.IO.FileStream(fileName, FileMode.Open, FileAccess.Read);
+                sr = new System.IO.StreamReader(file);
+                string xmlString = sr.ReadToEnd();
+                sr.Close();
+                file.Close();
+                return Deserialize(xmlString);
+            finally {
+                if ((file != null)) {
+                    file.Dispose();
+                if ((sr != null)) {
+                    sr.Dispose();
+        #endregion
+        #region Clone method
+        /// <summary>
+        /// Create a clone of this SimpleSymbolDefinition1 object
+        /// </summary>
+        public virtual SimpleSymbolDefinition1 Clone() {
+            return ((SimpleSymbolDefinition1)(this.MemberwiseClone()));
+        #endregion
+    /// <summary>
+    /// A 2D simple symbol for stylization.
+    /// </summary>
+    public partial class SimpleSymbolDefinition : SymbolDefinitionBase, System.ComponentModel.INotifyPropertyChanged {
+        private BindingList<GraphicBase> graphicsField;
+        private ResizeBox resizeBoxField;
+        private PointUsage pointUsageField;
+        private LineUsage lineUsageField;
+        private AreaUsage areaUsageField;
+        private ParameterDefinition parameterDefinitionField;
+        private ExtendedDataType extendedData1Field;
+        /// <summary>
+        /// The collection of graphic elements defining this symbol.
+        /// </summary>
+        [System.Xml.Serialization.XmlArrayItemAttribute(typeof(Image), IsNullable=false)]
+        [System.Xml.Serialization.XmlArrayItemAttribute(typeof(Path), IsNullable=false)]
+        [System.Xml.Serialization.XmlArrayItemAttribute(typeof(Text), IsNullable=false)]
+        public BindingList<GraphicBase> Graphics {
+            get {
+                return this.graphicsField;
+            set {
+                if ((this.graphicsField != null)) {
+                    if ((graphicsField.Equals(value) != true)) {
+                        this.graphicsField = value;
+                        this.OnPropertyChanged("Graphics");
+                else {
+        /// <summary>
+        /// The optional box used to resize and reposition select graphic elements.  The graphical extent of all elements with ResizeControl set to AddToResizeBox will be added to this box, potentially causing it to grow in size.  Any change in size causes all elements with ResizeControl set to AdjustToResizeBox to be proportionally resized and repositioned.
+        /// </summary>
+        public ResizeBox ResizeBox {
+            get {
+                return this.resizeBoxField;
+            set {
+                if ((this.resizeBoxField != null)) {
+                    if ((resizeBoxField.Equals(value) != true)) {
+                        this.resizeBoxField = value;
+                        this.OnPropertyChanged("ResizeBox");
+                else {
+        /// <summary>
+        /// Specifies how the symbol is used in the context of point features.
+        /// </summary>
+        public PointUsage PointUsage {
+            get {
+                return this.pointUsageField;
+            set {
+                if ((this.pointUsageField != null)) {
+                    if ((pointUsageField.Equals(value) != true)) {
+                        this.pointUsageField = value;
+                        this.OnPropertyChanged("PointUsage");
+                else {
+        /// <summary>
+        /// Specifies how the symbol is used in the context of linear features.
+        /// </summary>
+        public LineUsage LineUsage {
+            get {
+                return this.lineUsageField;
+            set {
+                if ((this.lineUsageField != null)) {
+                    if ((lineUsageField.Equals(value) != true)) {
+                        this.lineUsageField = value;
+                        this.OnPropertyChanged("LineUsage");
+                else {
+        /// <summary>
+        /// Specifies how the symbol is used in the context of area features.
+        /// </summary>
+        public AreaUsage AreaUsage {
+            get {
+                return this.areaUsageField;
+            set {
+                if ((this.areaUsageField != null)) {
+                    if ((areaUsageField.Equals(value) != true)) {
+                        this.areaUsageField = value;
+                        this.OnPropertyChanged("AreaUsage");
+                else {
+        /// <summary>
+        /// The list of parameters used in this symbol.  If a parameter is not listed here this is considered a bug in the symbol definition.
+        /// </summary>
+        public ParameterDefinition ParameterDefinition {
+            get {
+                return this.parameterDefinitionField;
+            set {
+                if ((this.parameterDefinitionField != null)) {
+                    if ((parameterDefinitionField.Equals(value) != true)) {
+                        this.parameterDefinitionField = value;
+                        this.OnPropertyChanged("ParameterDefinition");
+                else {
+        public ExtendedDataType ExtendedData1 {
+            get {
+                return this.extendedData1Field;
+            set {
+                if ((this.extendedData1Field != null)) {
+                    if ((extendedData1Field.Equals(value) != true)) {
+                        this.extendedData1Field = value;
+                        this.OnPropertyChanged("ExtendedData1");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(SimpleSymbolDefinition));
+        /// <summary>
+        /// Serializes current SimpleSymbolDefinition object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an SimpleSymbolDefinition object
+        /// </summary>
+        /// <param name="obj">Output SimpleSymbolDefinition object</param>
+        public static bool Deserialize(string xml, out SimpleSymbolDefinition obj, out System.Exception exception) {
+            exception = null;
+            obj = default(SimpleSymbolDefinition);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out SimpleSymbolDefinition obj) {
+        public static SimpleSymbolDefinition Deserialize(string xml) {
+            try {
+                return ((SimpleSymbolDefinition)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current SimpleSymbolDefinition object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an SimpleSymbolDefinition object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out SimpleSymbolDefinition obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out SimpleSymbolDefinition obj) {
+        public static SimpleSymbolDefinition LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this SimpleSymbolDefinition object
+        /// </summary>
+        public virtual SimpleSymbolDefinition Clone() {
+            return ((SimpleSymbolDefinition)(this.MemberwiseClone()));
+        #endregion
+    public partial class Image : GraphicBase, System.ComponentModel.INotifyPropertyChanged {
+        private object itemField;
+        private string sizeXField;
+        private string sizeYField;
+        private string sizeScalableField;
+        private string angleField;
+        private string positionXField;
+        private string positionYField;
+        public Image() {
+            this.sizeXField = "1.0";
+            this.sizeYField = "1.0";
+            this.sizeScalableField = "true";
+            this.angleField = "0.0";
+            this.positionXField = "0.0";
+            this.positionYField = "0.0";
+        [System.Xml.Serialization.XmlElementAttribute("Content", typeof(byte[]), DataType="base64Binary")]
+        [System.Xml.Serialization.XmlElementAttribute("Reference", typeof(ImageReference))]
+        public object Item {
+            get {
+                return this.itemField;
+            set {
+                if ((this.itemField != null)) {
+                    if ((itemField.Equals(value) != true)) {
+                        this.itemField = value;
+                        this.OnPropertyChanged("Item");
+                else {
+        public string SizeX {
+            get {
+                return this.sizeXField;
+            set {
+                if ((this.sizeXField != null)) {
+                    if ((sizeXField.Equals(value) != true)) {
+                        this.sizeXField = value;
+                        this.OnPropertyChanged("SizeX");
+                else {
+        public string SizeY {
+            get {
+                return this.sizeYField;
+            set {
+                if ((this.sizeYField != null)) {
+                    if ((sizeYField.Equals(value) != true)) {
+                        this.sizeYField = value;
+                        this.OnPropertyChanged("SizeY");
+                else {
+        [System.ComponentModel.DefaultValueAttribute("true")]
+        public string SizeScalable {
+            get {
+                return this.sizeScalableField;
+            set {
+                if ((this.sizeScalableField != null)) {
+                    if ((sizeScalableField.Equals(value) != true)) {
+                        this.sizeScalableField = value;
+                        this.OnPropertyChanged("SizeScalable");
+                else {
+        [System.ComponentModel.DefaultValueAttribute("0.0")]
+        public string Angle {
+            get {
+                return this.angleField;
+            set {
+                if ((this.angleField != null)) {
+                    if ((angleField.Equals(value) != true)) {
+                        this.angleField = value;
+                        this.OnPropertyChanged("Angle");
+                else {
+        public string PositionX {
+            get {
+                return this.positionXField;
+            set {
+                if ((this.positionXField != null)) {
+                    if ((positionXField.Equals(value) != true)) {
+                        this.positionXField = value;
+                        this.OnPropertyChanged("PositionX");
+                else {
+        public string PositionY {
+            get {
+                return this.positionYField;
+            set {
+                if ((this.positionYField != null)) {
+                    if ((positionYField.Equals(value) != true)) {
+                        this.positionYField = value;
+                        this.OnPropertyChanged("PositionY");
+                else {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(Image));
+        /// <summary>
+        /// Serializes current Image object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an Image object
+        /// </summary>
+        /// <param name="obj">Output Image object</param>
+        public static bool Deserialize(string xml, out Image obj, out System.Exception exception) {
+            exception = null;
+            obj = default(Image);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out Image obj) {
+        public static Image Deserialize(string xml) {
+            try {
+                return ((Image)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current Image object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an Image object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out Image obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out Image obj) {
+        public static Image LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this Image object
+        /// </summary>
+        public virtual Image Clone() {
+            return ((Image)(this.MemberwiseClone()));
+        #endregion
+    public partial class ImageReference : System.ComponentModel.INotifyPropertyChanged {
+        private string resourceIdField;
+        private string libraryItemNameField;
+        public string ResourceId {
+            get {
+                return this.resourceIdField;
+            set {
+                if ((this.resourceIdField != null)) {
+                    if ((resourceIdField.Equals(value) != true)) {
+                        this.resourceIdField = value;
+                        this.OnPropertyChanged("ResourceId");
+                else {
+        public string LibraryItemName {
+            get {
+                return this.libraryItemNameField;
+            set {
+                if ((this.libraryItemNameField != null)) {
+                    if ((libraryItemNameField.Equals(value) != true)) {
+                        this.libraryItemNameField = value;
+                        this.OnPropertyChanged("LibraryItemName");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(ImageReference));
+        /// <summary>
+        /// Serializes current ImageReference object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an ImageReference object
+        /// </summary>
+        /// <param name="obj">Output ImageReference object</param>
+        public static bool Deserialize(string xml, out ImageReference obj, out System.Exception exception) {
+            exception = null;
+            obj = default(ImageReference);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out ImageReference obj) {
+        public static ImageReference Deserialize(string xml) {
+            try {
+                return ((ImageReference)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current ImageReference object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an ImageReference object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out ImageReference obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out ImageReference obj) {
+        public static ImageReference LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this ImageReference object
+        /// </summary>
+        public virtual ImageReference Clone() {
+            return ((ImageReference)(this.MemberwiseClone()));
+        #endregion
+    public partial class SimpleSymbol : System.ComponentModel.INotifyPropertyChanged {
+        private string renderingPassField;
+        public SimpleSymbol() {
+            this.renderingPassField = "0";
+        [System.Xml.Serialization.XmlElementAttribute("ResourceId", typeof(string))]
+        [System.Xml.Serialization.XmlElementAttribute("SimpleSymbolDefinition", typeof(SimpleSymbolDefinition))]
+            get {
+            set {
+                else {
+        /// <summary>
+        /// The optional rendering pass in which this symbol definition draws.  If specified this must be greater than or equal to zero.  Defaults to 0.
+        /// </summary>
+        [System.ComponentModel.DefaultValueAttribute("0")]
+        public string RenderingPass {
+            get {
+                return this.renderingPassField;
+            set {
+                if ((this.renderingPassField != null)) {
+                    if ((renderingPassField.Equals(value) != true)) {
+                        this.renderingPassField = value;
+                        this.OnPropertyChanged("RenderingPass");
+                else {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(SimpleSymbol));
+        /// <summary>
+        /// Serializes current SimpleSymbol object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an SimpleSymbol object
+        /// </summary>
+        /// <param name="obj">Output SimpleSymbol object</param>
+        public static bool Deserialize(string xml, out SimpleSymbol obj, out System.Exception exception) {
+            exception = null;
+            obj = default(SimpleSymbol);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out SimpleSymbol obj) {
+        public static SimpleSymbol Deserialize(string xml) {
+            try {
+                return ((SimpleSymbol)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current SimpleSymbol object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an SimpleSymbol object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out SimpleSymbol obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out SimpleSymbol obj) {
+        public static SimpleSymbol LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this SimpleSymbol object
+        /// </summary>
+        public virtual SimpleSymbol Clone() {
+            return ((SimpleSymbol)(this.MemberwiseClone()));
+        #endregion
+    public partial class ExtendedDataType : System.ComponentModel.INotifyPropertyChanged {
+        private BindingList<System.Xml.XmlElement> anyField;
+        [System.Xml.Serialization.XmlAnyElementAttribute()]
+        public BindingList<System.Xml.XmlElement> Any {
+            get {
+                return this.anyField;
+            set {
+                if ((this.anyField != null)) {
+                    if ((anyField.Equals(value) != true)) {
+                        this.anyField = value;
+                        this.OnPropertyChanged("Any");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(ExtendedDataType));
+        /// <summary>
+        /// Serializes current ExtendedDataType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an ExtendedDataType object
+        /// </summary>
+        /// <param name="obj">Output ExtendedDataType object</param>
+        public static bool Deserialize(string xml, out ExtendedDataType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(ExtendedDataType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out ExtendedDataType obj) {
+        public static ExtendedDataType Deserialize(string xml) {
+            try {
+                return ((ExtendedDataType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current ExtendedDataType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an ExtendedDataType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out ExtendedDataType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out ExtendedDataType obj) {
+        public static ExtendedDataType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this ExtendedDataType object
+        /// </summary>
+        public virtual ExtendedDataType Clone() {
+            return ((ExtendedDataType)(this.MemberwiseClone()));
+        #endregion
+    public partial class Parameter : System.ComponentModel.INotifyPropertyChanged {
+        private string identifierField;
+        private string defaultValueField;
+        private string displayNameField;
+        private string descriptionField;
+        private DataType dataTypeField;
+        public Parameter() {
+            this.dataTypeField = DataType.String;
+        /// <summary>
+        /// The parameter identifier as used in the symbol.
+        /// </summary>
+        public string Identifier {
+            get {
+                return this.identifierField;
+            set {
+                if ((this.identifierField != null)) {
+                    if ((identifierField.Equals(value) != true)) {
+                        this.identifierField = value;
+                        this.OnPropertyChanged("Identifier");
+                else {
+        /// <summary>
+        /// The default value of the parameter if no override is defined in the symbol instance.  This can be an expression.
+        /// </summary>
+        public string DefaultValue {
+            get {
+                return this.defaultValueField;
+            set {
+                if ((this.defaultValueField != null)) {
+                    if ((defaultValueField.Equals(value) != true)) {
+                        this.defaultValueField = value;
+                        this.OnPropertyChanged("DefaultValue");
+                else {
+        /// <summary>
+        /// An optional short description of the parameter.  This can be used, for example, to ask the user to specify a parameter value.
+        /// </summary>
+        public string DisplayName {
+            get {
+                return this.displayNameField;
+            set {
+                if ((this.displayNameField != null)) {
+                    if ((displayNameField.Equals(value) != true)) {
+                        this.displayNameField = value;
+                        this.OnPropertyChanged("DisplayName");
+                else {
+        /// <summary>
+        /// An optional long description of the parameter.  This might include a description of useful values for this parameter.
+        /// </summary>
+        public string Description {
+            get {
+                return this.descriptionField;
+            set {
+                if ((this.descriptionField != null)) {
+                    if ((descriptionField.Equals(value) != true)) {
+                        this.descriptionField = value;
+                        this.OnPropertyChanged("Description");
+                else {
+        /// <summary>
+        /// An optional explicit declaration of data type or data usage context.  This is a hint used by the UI when assigning a value to this parameter.  Defaults to String.
+        /// </summary>
+        [System.ComponentModel.DefaultValueAttribute(DataType.String)]
+        public DataType DataType {
+            get {
+                return this.dataTypeField;
+            set {
+                if ((dataTypeField.Equals(value) != true)) {
+                    this.dataTypeField = value;
+                    this.OnPropertyChanged("DataType");
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(Parameter));
+        /// <summary>
+        /// Serializes current Parameter object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an Parameter object
+        /// </summary>
+        /// <param name="obj">Output Parameter object</param>
+        public static bool Deserialize(string xml, out Parameter obj, out System.Exception exception) {
+            exception = null;
+            obj = default(Parameter);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out Parameter obj) {
+        public static Parameter Deserialize(string xml) {
+            try {
+                return ((Parameter)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current Parameter object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an Parameter object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out Parameter obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out Parameter obj) {
+        public static Parameter LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this Parameter object
+        /// </summary>
+        public virtual Parameter Clone() {
+            return ((Parameter)(this.MemberwiseClone()));
+        #endregion
+    public enum DataType {
+        /// <remarks/>
+        String,
+        /// <remarks/>
+        Boolean,
+        /// <remarks/>
+        Integer,
+        /// <remarks/>
+        Real,
+        /// <remarks/>
+        Color,
+        /// <remarks/>
+        Angle,
+        /// <remarks/>
+        FillColor,
+        /// <remarks/>
+        LineColor,
+        /// <remarks/>
+        LineWeight,
+        /// <remarks/>
+        Content,
+        /// <remarks/>
+        Markup,
+        /// <remarks/>
+        FontName,
+        /// <remarks/>
+        Bold,
+        /// <remarks/>
+        Italic,
+        /// <remarks/>
+        Underlined,
+        /// <remarks/>
+        Overlined,
+        /// <remarks/>
+        ObliqueAngle,
+        /// <remarks/>
+        TrackSpacing,
+        /// <remarks/>
+        FontHeight,
+        /// <remarks/>
+        HorizontalAlignment,
+        /// <remarks/>
+        VerticalAlignment,
+        /// <remarks/>
+        Justification,
+        /// <remarks/>
+        LineSpacing,
+        /// <remarks/>
+        TextColor,
+        /// <remarks/>
+        GhostColor,
+        /// <remarks/>
+        FrameLineColor,
+        /// <remarks/>
+        FrameFillColor,
+        /// <remarks/>
+        StartOffset,
+        /// <remarks/>
+        EndOffset,
+        /// <remarks/>
+        RepeatX,
+        /// <remarks/>
+        RepeatY,
+    /// <summary>
+    /// </summary>
+    public partial class ParameterDefinition : System.ComponentModel.INotifyPropertyChanged {
+        private BindingList<Parameter> parameterField;
+        [System.Xml.Serialization.XmlElementAttribute("Parameter")]
+        public BindingList<Parameter> Parameter {
+            get {
+                return this.parameterField;
+            set {
+                if ((this.parameterField != null)) {
+                    if ((parameterField.Equals(value) != true)) {
+                        this.parameterField = value;
+                        this.OnPropertyChanged("Parameter");
+                else {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(ParameterDefinition));
+        /// <summary>
+        /// Serializes current ParameterDefinition object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an ParameterDefinition object
+        /// </summary>
+        /// <param name="obj">Output ParameterDefinition object</param>
+        public static bool Deserialize(string xml, out ParameterDefinition obj, out System.Exception exception) {
+            exception = null;
+            obj = default(ParameterDefinition);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out ParameterDefinition obj) {
+        public static ParameterDefinition Deserialize(string xml) {
+            try {
+                return ((ParameterDefinition)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current ParameterDefinition object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an ParameterDefinition object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out ParameterDefinition obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out ParameterDefinition obj) {
+        public static ParameterDefinition LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this ParameterDefinition object
+        /// </summary>
+        public virtual ParameterDefinition Clone() {
+            return ((ParameterDefinition)(this.MemberwiseClone()));
+        #endregion
+    /// <summary>
+    /// </summary>
+    public partial class AreaUsage : System.ComponentModel.INotifyPropertyChanged {
+        private string angleControlField;
+        private string originControlField;
+        private string clippingControlField;
+        private string originXField;
+        private string originYField;
+        private string repeatXField;
+        private string repeatYField;
+        private string bufferWidthField;
+        public AreaUsage() {
+            this.angleControlField = "\'FromAngle\'";
+            this.originControlField = "\'Global\'";
+            this.clippingControlField = "\'Clip\'";
+            this.originXField = "0.0";
+            this.originYField = "0.0";
+            this.repeatXField = "0.0";
+            this.repeatYField = "0.0";
+            this.bufferWidthField = "0.0";
+        /// <summary>
+        /// Specifies how the symbol angle is defined.  This must evaluate to one of: FromAngle (default) or FromGeometry.
+        /// </summary>
+        [System.ComponentModel.DefaultValueAttribute("\'FromAngle\'")]
+        public string AngleControl {
+            get {
+                return this.angleControlField;
+            set {
+                if ((this.angleControlField != null)) {
+                    if ((angleControlField.Equals(value) != true)) {
+                        this.angleControlField = value;
+                        this.OnPropertyChanged("AngleControl");
+                else {
+        /// <summary>
+        /// Specifies how the symbol grid origin is defined.  This must evaluate to one of: Global (default), Local, or Centroid.
+        /// </summary>
+        [System.ComponentModel.DefaultValueAttribute("\'Global\'")]
+        public string OriginControl {
+            get {
+                return this.originControlField;
+            set {
+                if ((this.originControlField != null)) {
+                    if ((originControlField.Equals(value) != true)) {
+                        this.originControlField = value;
+                        this.OnPropertyChanged("OriginControl");
+                else {
+        /// <summary>
+        /// Specifies the clipping behavior of the symbol at polygon boundaries.  This must evaluate to one of: Clip (default), Inside, or Overlap.
+        /// </summary>
+        [System.ComponentModel.DefaultValueAttribute("\'Clip\'")]
+        public string ClippingControl {
+            get {
+                return this.clippingControlField;
+            set {
+                if ((this.clippingControlField != null)) {
+                    if ((clippingControlField.Equals(value) != true)) {
+                        this.clippingControlField = value;
+                        this.OnPropertyChanged("ClippingControl");
+                else {
+        /// <summary>
+        /// Specifies the angle of each repeating symbol, in degrees.  If AngleControl evaluates to FromAngle then this specifies the absolute angle of the symbol.  If AngleControl evaluates to FromGeometry then this specifies the symbol angle relative to the geometry.  Defaults to 0.
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// The x-coordinate of the symbol grid origin, in mm.  Only applies if OriginControl evaluates to Global or Local.  Defaults to 0.
+        /// </summary>
+        public string OriginX {
+            get {
+                return this.originXField;
+            set {
+                if ((this.originXField != null)) {
+                    if ((originXField.Equals(value) != true)) {
+                        this.originXField = value;
+                        this.OnPropertyChanged("OriginX");
+                else {
+        /// <summary>
+        /// The y-coordinate of the symbol grid origin, in mm.  Only applies if OriginControl evaluates to Global or Local.  Defaults to 0.
+        /// </summary>
+        public string OriginY {
+            get {
+                return this.originYField;
+            set {
+                if ((this.originYField != null)) {
+                    if ((originYField.Equals(value) != true)) {
+                        this.originYField = value;
+                        this.OnPropertyChanged("OriginY");
+                else {
+        /// <summary>
+        /// The horizontal separation between symbols, in mm.  Defaults to 0.
+        /// </summary>
+        public string RepeatX {
+            get {
+                return this.repeatXField;
+            set {
+                if ((this.repeatXField != null)) {
+                    if ((repeatXField.Equals(value) != true)) {
+                        this.repeatXField = value;
+                        this.OnPropertyChanged("RepeatX");
+                else {
+        /// <summary>
+        /// The vertical separation between symbols, in mm.  Defaults to 0.
+        /// </summary>
+        public string RepeatY {
+            get {
+                return this.repeatYField;
+            set {
+                if ((this.repeatYField != null)) {
+                    if ((repeatYField.Equals(value) != true)) {
+                        this.repeatYField = value;
+                        this.OnPropertyChanged("RepeatY");
+                else {
+        /// <summary>
+        /// The width, in mm, of the buffer zone relative to the polygon boundary in which the symbol is rendered.  Defaults to 0.
+        /// </summary>
+        public string BufferWidth {
+            get {
+                return this.bufferWidthField;
+            set {
+                if ((this.bufferWidthField != null)) {
+                    if ((bufferWidthField.Equals(value) != true)) {
+                        this.bufferWidthField = value;
+                        this.OnPropertyChanged("BufferWidth");
+                else {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(AreaUsage));
+        /// <summary>
+        /// Serializes current AreaUsage object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an AreaUsage object
+        /// </summary>
+        /// <param name="obj">Output AreaUsage object</param>
+        public static bool Deserialize(string xml, out AreaUsage obj, out System.Exception exception) {
+            exception = null;
+            obj = default(AreaUsage);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out AreaUsage obj) {
+        public static AreaUsage Deserialize(string xml) {
+            try {
+                return ((AreaUsage)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current AreaUsage object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an AreaUsage object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out AreaUsage obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out AreaUsage obj) {
+        public static AreaUsage LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this AreaUsage object
+        /// </summary>
+        public virtual AreaUsage Clone() {
+            return ((AreaUsage)(this.MemberwiseClone()));
+        #endregion
+    /// <summary>
+    /// </summary>
+    public partial class LineUsage : System.ComponentModel.INotifyPropertyChanged {
+        private string unitsControlField;
+        private string vertexControlField;
+        private string startOffsetField;
+        private string endOffsetField;
+        private string repeatField;
+        private string vertexAngleLimitField;
+        private string vertexJoinField;
+        private string vertexMiterLimitField;
+        private Path defaultPathField;
+        public LineUsage() {
+            this.angleControlField = "\'FromGeometry\'";
+            this.unitsControlField = "\'Absolute\'";
+            this.vertexControlField = "\'OverlapWrap\'";
+            this.repeatField = "0.0";
+            this.vertexAngleLimitField = "0.0";
+            this.vertexJoinField = "\'Round\'";
+            this.vertexMiterLimitField = "5.0";
+        /// <summary>
+        /// Specifies how the symbol angle is defined.  This must evaluate to one of: FromAngle or FromGeometry (default).
+        /// </summary>
+        [System.ComponentModel.DefaultValueAttribute("\'FromGeometry\'")]
+            get {
+            set {
+                else {
+        /// <summary>
+        /// Specifies whether the distribution parameters are interpreted as absolute values (in mm) or parametric values.  This must evaluate to one of: Absolute (default) or Parametric.
+        /// </summary>
+        [System.ComponentModel.DefaultValueAttribute("\'Absolute\'")]
+        public string UnitsControl {
+            get {
+                return this.unitsControlField;
+            set {
+                if ((this.unitsControlField != null)) {
+                    if ((unitsControlField.Equals(value) != true)) {
+                        this.unitsControlField = value;
+                        this.OnPropertyChanged("UnitsControl");
+                else {
+        /// <summary>
+        /// Specifies the symbol behavior at vertices.  This must evaluate to one of: OverlapNone, OverlapDirect, or OverlapWrap (default).
+        /// </summary>
+        [System.ComponentModel.DefaultValueAttribute("\'OverlapWrap\'")]
+        public string VertexControl {
+            get {
+                return this.vertexControlField;
+            set {
+                if ((this.vertexControlField != null)) {
+                    if ((vertexControlField.Equals(value) != true)) {
+                        this.vertexControlField = value;
+                        this.OnPropertyChanged("VertexControl");
+                else {
+        /// <summary>
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// Specifies where the symbol distribution begins, relative to the start of the feature.  If specified this must be greater than or equal to zero.
+        /// </summary>
+        public string StartOffset {
+            get {
+                return this.startOffsetField;
+            set {
+                if ((this.startOffsetField != null)) {
+                    if ((startOffsetField.Equals(value) != true)) {
+                        this.startOffsetField = value;
+                        this.OnPropertyChanged("StartOffset");
+                else {
+        /// <summary>
+        /// Specifies where the symbol distribution ends, relative to the end of the feature.  If specified this must be greater than or equal to zero.
+        /// </summary>
+        public string EndOffset {
+            get {
+                return this.endOffsetField;
+            set {
+                if ((this.endOffsetField != null)) {
+                    if ((endOffsetField.Equals(value) != true)) {
+                        this.endOffsetField = value;
+                        this.OnPropertyChanged("EndOffset");
+                else {
+        /// <summary>
+        /// Specifies the separation between repeating symbols.  Defaults to 0.
+        /// </summary>
+        public string Repeat {
+            get {
+                return this.repeatField;
+            set {
+                if ((this.repeatField != null)) {
+                    if ((repeatField.Equals(value) != true)) {
+                        this.repeatField = value;
+                        this.OnPropertyChanged("Repeat");
+                else {
+        /// <summary>
+        /// Specifies the limiting angle, in degrees, by a which the feature geometry can change before some of the VertexControl options take effect.  If specified this must be greater than or equal to zero.  Defaults to 0.
+        /// </summary>
+        public string VertexAngleLimit {
+            get {
+                return this.vertexAngleLimitField;
+            set {
+                if ((this.vertexAngleLimitField != null)) {
+                    if ((vertexAngleLimitField.Equals(value) != true)) {
+                        this.vertexAngleLimitField = value;
+                        this.OnPropertyChanged("VertexAngleLimit");
+                else {
+        /// <summary>
+        /// Specifies the wrapping behavior at vertices for all graphic elements.  Only applies if VertexControl evaluates to OverlapWrap.  This must evaluate to one of: None, Bevel, Round (default), or Miter.
+        /// </summary>
+        [System.ComponentModel.DefaultValueAttribute("\'Round\'")]
+        public string VertexJoin {
+            get {
+                return this.vertexJoinField;
+            set {
+                if ((this.vertexJoinField != null)) {
+                    if ((vertexJoinField.Equals(value) != true)) {
+                        this.vertexJoinField = value;
+                        this.OnPropertyChanged("VertexJoin");
+                else {
+        /// <summary>
+        /// The limit to use when drawing miter vertex joins.  A miter vertex join is trimmed if the ratio of the miter length to symbol height is greater than the miter limit.  If specified this must be greater than zero.  Defaults to 5.
+        /// </summary>
+        [System.ComponentModel.DefaultValueAttribute("5.0")]
+        public string VertexMiterLimit {
+            get {
+                return this.vertexMiterLimitField;
+            set {
+                if ((this.vertexMiterLimitField != null)) {
+                    if ((vertexMiterLimitField.Equals(value) != true)) {
+                        this.vertexMiterLimitField = value;
+                        this.OnPropertyChanged("VertexMiterLimit");
+                else {
+        /// <summary>
+        /// Specifies the default path attributes to use when drawing the symbol.  These apply to any centerline that gets drawn where the symbol can't draw, and to path elements that don't specify attributes.  The geometry contained in this path is ignored and should be empty.
+        /// </summary>
+        public Path DefaultPath {
+            get {
+                return this.defaultPathField;
+            set {
+                if ((this.defaultPathField != null)) {
+                    if ((defaultPathField.Equals(value) != true)) {
+                        this.defaultPathField = value;
+                        this.OnPropertyChanged("DefaultPath");
+                else {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(LineUsage));
+        /// <summary>
+        /// Serializes current LineUsage object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an LineUsage object
+        /// </summary>
+        /// <param name="obj">Output LineUsage object</param>
+        public static bool Deserialize(string xml, out LineUsage obj, out System.Exception exception) {
+            exception = null;
+            obj = default(LineUsage);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out LineUsage obj) {
+        public static LineUsage Deserialize(string xml) {
+            try {
+                return ((LineUsage)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current LineUsage object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an LineUsage object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out LineUsage obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out LineUsage obj) {
+        public static LineUsage LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this LineUsage object
+        /// </summary>
+        public virtual LineUsage Clone() {
+            return ((LineUsage)(this.MemberwiseClone()));
+        #endregion
+    public partial class Path : GraphicBase, System.ComponentModel.INotifyPropertyChanged {
+        private string geometryField;
+        private string scaleXField;
+        private string scaleYField;
+        private string fillColorField;
+        private string lineColorField;
+        private string lineWeightField;
+        private string lineWeightScalableField;
+        private string lineCapField;
+        private string lineJoinField;
+        private string lineMiterLimitField;
+        public Path() {
+            this.scaleXField = "1.0";
+            this.scaleYField = "1.0";
+            this.lineWeightField = "0.0";
+            this.lineWeightScalableField = "true";
+            this.lineCapField = "\'Round\'";
+            this.lineJoinField = "\'Round\'";
+            this.lineMiterLimitField = "5.0";
+        public string Geometry {
+            get {
+                return this.geometryField;
+            set {
+                if ((this.geometryField != null)) {
+                    if ((geometryField.Equals(value) != true)) {
+                        this.geometryField = value;
+                        this.OnPropertyChanged("Geometry");
+                else {
+        [System.ComponentModel.DefaultValueAttribute("1.0")]
+        public string ScaleX {
+            get {
+                return this.scaleXField;
+            set {
+                if ((this.scaleXField != null)) {
+                    if ((scaleXField.Equals(value) != true)) {
+                        this.scaleXField = value;
+                        this.OnPropertyChanged("ScaleX");
+                else {
+        public string ScaleY {
+            get {
+                return this.scaleYField;
+            set {
+                if ((this.scaleYField != null)) {
+                    if ((scaleYField.Equals(value) != true)) {
+                        this.scaleYField = value;
+                        this.OnPropertyChanged("ScaleY");
+                else {
+        public string FillColor {
+            get {
+                return this.fillColorField;
+            set {
+                if ((this.fillColorField != null)) {
+                    if ((fillColorField.Equals(value) != true)) {
+                        this.fillColorField = value;
+                        this.OnPropertyChanged("FillColor");
+                else {
+        public string LineColor {
+            get {
+                return this.lineColorField;
+            set {
+                if ((this.lineColorField != null)) {
+                    if ((lineColorField.Equals(value) != true)) {
+                        this.lineColorField = value;
+                        this.OnPropertyChanged("LineColor");
+                else {
+        public string LineWeight {
+            get {
+                return this.lineWeightField;
+            set {
+                if ((this.lineWeightField != null)) {
+                    if ((lineWeightField.Equals(value) != true)) {
+                        this.lineWeightField = value;
+                        this.OnPropertyChanged("LineWeight");
+                else {
+        public string LineWeightScalable {
+            get {
+                return this.lineWeightScalableField;
+            set {
+                if ((this.lineWeightScalableField != null)) {
+                    if ((lineWeightScalableField.Equals(value) != true)) {
+                        this.lineWeightScalableField = value;
+                        this.OnPropertyChanged("LineWeightScalable");
+                else {
+        public string LineCap {
+            get {
+                return this.lineCapField;
+            set {
+                if ((this.lineCapField != null)) {
+                    if ((lineCapField.Equals(value) != true)) {
+                        this.lineCapField = value;
+                        this.OnPropertyChanged("LineCap");
+                else {
+        public string LineJoin {
+            get {
+                return this.lineJoinField;
+            set {
+                if ((this.lineJoinField != null)) {
+                    if ((lineJoinField.Equals(value) != true)) {
+                        this.lineJoinField = value;
+                        this.OnPropertyChanged("LineJoin");
+                else {
+        public string LineMiterLimit {
+            get {
+                return this.lineMiterLimitField;
+            set {
+                if ((this.lineMiterLimitField != null)) {
+                    if ((lineMiterLimitField.Equals(value) != true)) {
+                        this.lineMiterLimitField = value;
+                        this.OnPropertyChanged("LineMiterLimit");
+                else {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(Path));
+        /// <summary>
+        /// Serializes current Path object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an Path object
+        /// </summary>
+        /// <param name="obj">Output Path object</param>
+        public static bool Deserialize(string xml, out Path obj, out System.Exception exception) {
+            exception = null;
+            obj = default(Path);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out Path obj) {
+        public static Path Deserialize(string xml) {
+            try {
+                return ((Path)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current Path object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an Path object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out Path obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out Path obj) {
+        public static Path LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this Path object
+        /// </summary>
+        public virtual Path Clone() {
+            return ((Path)(this.MemberwiseClone()));
+        #endregion
+    [System.Xml.Serialization.XmlIncludeAttribute(typeof(Text))]
+    [System.Xml.Serialization.XmlIncludeAttribute(typeof(Image))]
+    [System.Xml.Serialization.XmlIncludeAttribute(typeof(Path))]
+    public partial class GraphicBase : System.ComponentModel.INotifyPropertyChanged {
+        private string resizeControlField;
+        public GraphicBase() {
+            this.resizeControlField = "\'ResizeNone\'";
+        [System.ComponentModel.DefaultValueAttribute("\'ResizeNone\'")]
+        public string ResizeControl {
+            get {
+                return this.resizeControlField;
+            set {
+                if ((this.resizeControlField != null)) {
+                    if ((resizeControlField.Equals(value) != true)) {
+                        this.resizeControlField = value;
+                        this.OnPropertyChanged("ResizeControl");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(GraphicBase));
+        /// <summary>
+        /// Serializes current GraphicBase object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an GraphicBase object
+        /// </summary>
+        /// <param name="obj">Output GraphicBase object</param>
+        public static bool Deserialize(string xml, out GraphicBase obj, out System.Exception exception) {
+            exception = null;
+            obj = default(GraphicBase);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out GraphicBase obj) {
+        public static GraphicBase Deserialize(string xml) {
+            try {
+                return ((GraphicBase)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current GraphicBase object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an GraphicBase object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out GraphicBase obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out GraphicBase obj) {
+        public static GraphicBase LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this GraphicBase object
+        /// </summary>
+        public virtual GraphicBase Clone() {
+            return ((GraphicBase)(this.MemberwiseClone()));
+        #endregion
+    public partial class Text : GraphicBase, System.ComponentModel.INotifyPropertyChanged {
+        private string contentField;
+        private string fontNameField;
+        private string boldField;
+        private string italicField;
+        private string underlinedField;
+        private string overlinedField;
+        private string obliqueAngleField;
+        private string trackSpacingField;
+        private string heightField;
+        private string heightScalableField;
+        private string horizontalAlignmentField;
+        private string verticalAlignmentField;
+        private string justificationField;
+        private string lineSpacingField;
+        private string textColorField;
+        private string ghostColorField;
+        private TextFrame frameField;
+        private string markupField;
+        public Text() {
+            this.fontNameField = "\'Arial\'";
+            this.boldField = "false";
+            this.italicField = "false";
+            this.underlinedField = "false";
+            this.overlinedField = "false";
+            this.obliqueAngleField = "0.0";
+            this.trackSpacingField = "1.0";
+            this.heightField = "4.0";
+            this.heightScalableField = "true";
+            this.horizontalAlignmentField = "\'Center\'";
+            this.verticalAlignmentField = "\'Halfline\'";
+            this.justificationField = "\'FromAlignment\'";
+            this.lineSpacingField = "1.05";
+            this.textColorField = "ff000000";
+            this.markupField = "\'Plain\'";
+        public string Content {
+            get {
+                return this.contentField;
+            set {
+                if ((this.contentField != null)) {
+                    if ((contentField.Equals(value) != true)) {
+                        this.contentField = value;
+                        this.OnPropertyChanged("Content");
+                else {
+        public string FontName {
+            get {
+                return this.fontNameField;
+            set {
+                if ((this.fontNameField != null)) {
+                    if ((fontNameField.Equals(value) != true)) {
+                        this.fontNameField = value;
+                        this.OnPropertyChanged("FontName");
+                else {
+        [System.ComponentModel.DefaultValueAttribute("false")]
+        public string Bold {
+            get {
+                return this.boldField;
+            set {
+                if ((this.boldField != null)) {
+                    if ((boldField.Equals(value) != true)) {
+                        this.boldField = value;
+                        this.OnPropertyChanged("Bold");
+                else {
+        public string Italic {
+            get {
+                return this.italicField;
+            set {
+                if ((this.italicField != null)) {
+                    if ((italicField.Equals(value) != true)) {
+                        this.italicField = value;
+                        this.OnPropertyChanged("Italic");
+                else {
+        public string Underlined {
+            get {
+                return this.underlinedField;
+            set {
+                if ((this.underlinedField != null)) {
+                    if ((underlinedField.Equals(value) != true)) {
+                        this.underlinedField = value;
+                        this.OnPropertyChanged("Underlined");
+                else {
+        public string Overlined {
+            get {
+                return this.overlinedField;
+            set {
+                if ((this.overlinedField != null)) {
+                    if ((overlinedField.Equals(value) != true)) {
+                        this.overlinedField = value;
+                        this.OnPropertyChanged("Overlined");
+                else {
+        public string ObliqueAngle {
+            get {
+                return this.obliqueAngleField;
+            set {
+                if ((this.obliqueAngleField != null)) {
+                    if ((obliqueAngleField.Equals(value) != true)) {
+                        this.obliqueAngleField = value;
+                        this.OnPropertyChanged("ObliqueAngle");
+                else {
+        public string TrackSpacing {
+            get {
+                return this.trackSpacingField;
+            set {
+                if ((this.trackSpacingField != null)) {
+                    if ((trackSpacingField.Equals(value) != true)) {
+                        this.trackSpacingField = value;
+                        this.OnPropertyChanged("TrackSpacing");
+                else {
+        [System.ComponentModel.DefaultValueAttribute("4.0")]
+        public string Height {
+            get {
+                return this.heightField;
+            set {
+                if ((this.heightField != null)) {
+                    if ((heightField.Equals(value) != true)) {
+                        this.heightField = value;
+                        this.OnPropertyChanged("Height");
+                else {
+        public string HeightScalable {
+            get {
+                return this.heightScalableField;
+            set {
+                if ((this.heightScalableField != null)) {
+                    if ((heightScalableField.Equals(value) != true)) {
+                        this.heightScalableField = value;
+                        this.OnPropertyChanged("HeightScalable");
+                else {
+            get {
+            set {
+                else {
+            get {
+            set {
+                else {
+            get {
+            set {
+                else {
+        [System.ComponentModel.DefaultValueAttribute("\'Center\'")]
+        public string HorizontalAlignment {
+            get {
+                return this.horizontalAlignmentField;
+            set {
+                if ((this.horizontalAlignmentField != null)) {
+                    if ((horizontalAlignmentField.Equals(value) != true)) {
+                        this.horizontalAlignmentField = value;
+                        this.OnPropertyChanged("HorizontalAlignment");
+                else {
+        [System.ComponentModel.DefaultValueAttribute("\'Halfline\'")]
+        public string VerticalAlignment {
+            get {
+                return this.verticalAlignmentField;
+            set {
+                if ((this.verticalAlignmentField != null)) {
+                    if ((verticalAlignmentField.Equals(value) != true)) {
+                        this.verticalAlignmentField = value;
+                        this.OnPropertyChanged("VerticalAlignment");
+                else {
+        [System.ComponentModel.DefaultValueAttribute("\'FromAlignment\'")]
+        public string Justification {
+            get {
+                return this.justificationField;
+            set {
+                if ((this.justificationField != null)) {
+                    if ((justificationField.Equals(value) != true)) {
+                        this.justificationField = value;
+                        this.OnPropertyChanged("Justification");
+                else {
+        [System.ComponentModel.DefaultValueAttribute("1.05")]
+        public string LineSpacing {
+            get {
+                return this.lineSpacingField;
+            set {
+                if ((this.lineSpacingField != null)) {
+                    if ((lineSpacingField.Equals(value) != true)) {
+                        this.lineSpacingField = value;
+                        this.OnPropertyChanged("LineSpacing");
+                else {
+        [System.ComponentModel.DefaultValueAttribute("ff000000")]
+        public string TextColor {
+            get {
+                return this.textColorField;
+            set {
+                if ((this.textColorField != null)) {
+                    if ((textColorField.Equals(value) != true)) {
+                        this.textColorField = value;
+                        this.OnPropertyChanged("TextColor");
+                else {
+        public string GhostColor {
+            get {
+                return this.ghostColorField;
+            set {
+                if ((this.ghostColorField != null)) {
+                    if ((ghostColorField.Equals(value) != true)) {
+                        this.ghostColorField = value;
+                        this.OnPropertyChanged("GhostColor");
+                else {
+        public TextFrame Frame {
+            get {
+                return this.frameField;
+            set {
+                if ((this.frameField != null)) {
+                    if ((frameField.Equals(value) != true)) {
+                        this.frameField = value;
+                        this.OnPropertyChanged("Frame");
+                else {
+        [System.ComponentModel.DefaultValueAttribute("\'Plain\'")]
+        public string Markup {
+            get {
+                return this.markupField;
+            set {
+                if ((this.markupField != null)) {
+                    if ((markupField.Equals(value) != true)) {
+                        this.markupField = value;
+                        this.OnPropertyChanged("Markup");
+                else {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(Text));
+        /// <summary>
+        /// Serializes current Text object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an Text object
+        /// </summary>
+        /// <param name="obj">Output Text object</param>
+        public static bool Deserialize(string xml, out Text obj, out System.Exception exception) {
+            exception = null;
+            obj = default(Text);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out Text obj) {
+        public static Text Deserialize(string xml) {
+            try {
+                return ((Text)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current Text object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an Text object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out Text obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out Text obj) {
+        public static Text LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this Text object
+        /// </summary>
+        public virtual Text Clone() {
+            return ((Text)(this.MemberwiseClone()));
+        #endregion
+    public partial class TextFrame : System.ComponentModel.INotifyPropertyChanged {
+        private string offsetXField;
+        private string offsetYField;
+        public TextFrame() {
+            this.offsetXField = "0.0";
+            this.offsetYField = "0.0";
+            get {
+            set {
+                else {
+            get {
+            set {
+                else {
+        public string OffsetX {
+            get {
+                return this.offsetXField;
+            set {
+                if ((this.offsetXField != null)) {
+                    if ((offsetXField.Equals(value) != true)) {
+                        this.offsetXField = value;
+                        this.OnPropertyChanged("OffsetX");
+                else {
+        public string OffsetY {
+            get {
+                return this.offsetYField;
+            set {
+                if ((this.offsetYField != null)) {
+                    if ((offsetYField.Equals(value) != true)) {
+                        this.offsetYField = value;
+                        this.OnPropertyChanged("OffsetY");
+                else {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(TextFrame));
+        /// <summary>
+        /// Serializes current TextFrame object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an TextFrame object
+        /// </summary>
+        /// <param name="obj">Output TextFrame object</param>
+        public static bool Deserialize(string xml, out TextFrame obj, out System.Exception exception) {
+            exception = null;
+            obj = default(TextFrame);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out TextFrame obj) {
+        public static TextFrame Deserialize(string xml) {
+            try {
+                return ((TextFrame)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current TextFrame object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an TextFrame object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out TextFrame obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out TextFrame obj) {
+        public static TextFrame LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this TextFrame object
+        /// </summary>
+        public virtual TextFrame Clone() {
+            return ((TextFrame)(this.MemberwiseClone()));
+        #endregion
+    /// <summary>
+    /// </summary>
+    [System.CodeDom.Compiler.GeneratedCodeAttribute("Xsd2Code", "3.4.0.32990")]
+    [System.SerializableAttribute()]
+    [System.ComponentModel.DesignerCategoryAttribute("code")]
+    public partial class PointUsage : System.ComponentModel.INotifyPropertyChanged {
+        private string originOffsetXField;
+        private string originOffsetYField;
+        public PointUsage() {
+            this.originOffsetXField = "0.0";
+            this.originOffsetYField = "0.0";
+        /// <summary>
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// Specifies the symbol angle, in degrees.  If AngleControl evaluates to FromAngle then this specifies the absolute angle of the symbol.  If AngleControl evaluates to FromGeometry then this specifies the symbol angle relative to the geometry.  Defaults to 0.
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// Specifies the horizontal offset to apply to the symbol origin, in mm.  This offset is applied before the symbol is scaled and rotated.  Defaults to 0.
+        /// </summary>
+        public string OriginOffsetX {
+            get {
+                return this.originOffsetXField;
+            set {
+                if ((this.originOffsetXField != null)) {
+                    if ((originOffsetXField.Equals(value) != true)) {
+                        this.originOffsetXField = value;
+                        this.OnPropertyChanged("OriginOffsetX");
+                else {
+        /// <summary>
+        /// Specifies the vertical offset to apply to the symbol origin, in mm.  This offset is applied before the symbol is scaled and rotated.  Defaults to 0.
+        /// </summary>
+        public string OriginOffsetY {
+            get {
+                return this.originOffsetYField;
+            set {
+                if ((this.originOffsetYField != null)) {
+                    if ((originOffsetYField.Equals(value) != true)) {
+                        this.originOffsetYField = value;
+                        this.OnPropertyChanged("OriginOffsetY");
+                else {
+            get {
+            set {
+                else {
+        private static System.Xml.Serialization.XmlSerializer Serializer {
+            get {
+                if ((serializer == null)) {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(PointUsage));
+                return serializer;
+        public event System.ComponentModel.PropertyChangedEventHandler PropertyChanged;
+        public virtual void OnPropertyChanged(string propertyName) {
+            System.ComponentModel.PropertyChangedEventHandler handler = this.PropertyChanged;
+            if ((handler != null)) {
+                handler(this, new System.ComponentModel.PropertyChangedEventArgs(propertyName));
+        #region Serialize/Deserialize
+        /// <summary>
+        /// Serializes current PointUsage object into an XML document
+        /// </summary>
+        /// <returns>string XML value</returns>
+        public virtual string Serialize() {
+            System.IO.StreamReader streamReader = null;
+            System.IO.MemoryStream memoryStream = null;
+            try {
+                memoryStream = new System.IO.MemoryStream();
+                Serializer.Serialize(memoryStream, this);
+                memoryStream.Seek(0, System.IO.SeekOrigin.Begin);
+                streamReader = new System.IO.StreamReader(memoryStream);
+                return streamReader.ReadToEnd();
+            finally {
+                if ((streamReader != null)) {
+                    streamReader.Dispose();
+                if ((memoryStream != null)) {
+                    memoryStream.Dispose();
+        /// <summary>
+        /// Deserializes workflow markup into an PointUsage object
+        /// </summary>
+        /// <param name="xml">string workflow markup to deserialize</param>
+        /// <param name="obj">Output PointUsage object</param>
+        /// <param name="exception">output Exception value if deserialize failed</param>
+        /// <returns>true if this XmlSerializer can deserialize the object; otherwise, false</returns>
+        public static bool Deserialize(string xml, out PointUsage obj, out System.Exception exception) {
+            exception = null;
+            obj = default(PointUsage);
+            try {
+                obj = Deserialize(xml);
+                return true;
+            catch (System.Exception ex) {
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out PointUsage obj) {
+            System.Exception exception = null;
+            return Deserialize(xml, out obj, out exception);
+        public static PointUsage Deserialize(string xml) {
+            System.IO.StringReader stringReader = null;
+            try {
+                stringReader = new System.IO.StringReader(xml);
+                return ((PointUsage)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+                if ((stringReader != null)) {
+                    stringReader.Dispose();
+        /// <summary>
+        /// Serializes current PointUsage object into file
+        /// </summary>
+        /// <param name="fileName">full path of outupt xml file</param>
+        /// <param name="exception">output Exception value if failed</param>
+        /// <returns>true if can serialize and save into file; otherwise, false</returns>
+        public virtual bool SaveToFile(string fileName, out System.Exception exception) {
+            exception = null;
+            try {
+                SaveToFile(fileName);
+                return true;
+            catch (System.Exception e) {
+                exception = e;
+                return false;
+        public virtual void SaveToFile(string fileName) {
+            System.IO.StreamWriter streamWriter = null;
+            try {
+                string xmlString = Serialize();
+                System.IO.FileInfo xmlFile = new System.IO.FileInfo(fileName);
+                streamWriter = xmlFile.CreateText();
+                streamWriter.WriteLine(xmlString);
+                streamWriter.Close();
+            finally {
+                if ((streamWriter != null)) {
+                    streamWriter.Dispose();
+        /// <summary>
+        /// Deserializes xml markup from file into an PointUsage object
+        /// </summary>
+        /// <param name="fileName">string xml file to load and deserialize</param>
+        public static bool LoadFromFile(string fileName, out PointUsage obj, out System.Exception exception) {
+            exception = null;
+            try {
+                obj = LoadFromFile(fileName);
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out PointUsage obj) {
+            return LoadFromFile(fileName, out obj, out exception);
+        public static PointUsage LoadFromFile(string fileName) {
+            System.IO.FileStream file = null;
+            System.IO.StreamReader sr = null;
+            try {
+                file = new System.IO.FileStream(fileName, FileMode.Open, FileAccess.Read);
+                sr = new System.IO.StreamReader(file);
+                string xmlString = sr.ReadToEnd();
+                sr.Close();
+                file.Close();
+                return Deserialize(xmlString);
+            finally {
+                if ((file != null)) {
+                    file.Dispose();
+                if ((sr != null)) {
+                    sr.Dispose();
+        #endregion
+        #region Clone method
+        /// <summary>
+        /// Create a clone of this PointUsage object
+        /// </summary>
+        public virtual PointUsage Clone() {
+            return ((PointUsage)(this.MemberwiseClone()));
+        #endregion
+    /// <summary>
+    /// </summary>
+    public partial class ResizeBox : System.ComponentModel.INotifyPropertyChanged {
+        [EditorBrowsable(EditorBrowsableState.Never)]
+        private string growControlField;
+        private ExtendedDataType extendedData1Field;
+        private static System.Xml.Serialization.XmlSerializer serializer;
+        public ResizeBox() {
+            this.growControlField = "\'GrowInXYMaintainAspect\'";
+        /// <summary>
+        /// The initial width of the resize box, in mm.  This must be greater than or equal to zero.
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// The initial height of the resize box, in mm.  This must be greater than or equal to zero.
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// The initial x-coordinate of the resize box center, in mm.
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// The initial y-coordinate of the resize box center, in mm.
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// Specifies how the resize box grows in size.  This must evaluate to one of: GrowInX, GrowInY, GrowInXY, or GrowInXYMaintainAspect (default).
+        /// </summary>
+        public string GrowControl {
+            get {
+                return this.growControlField;
+            set {
+                if ((this.growControlField != null)) {
+                    if ((growControlField.Equals(value) != true)) {
+                        this.growControlField = value;
+                        this.OnPropertyChanged("GrowControl");
+                else {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(ResizeBox));
+        /// <summary>
+        /// Serializes current ResizeBox object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an ResizeBox object
+        /// </summary>
+        /// <param name="obj">Output ResizeBox object</param>
+        public static bool Deserialize(string xml, out ResizeBox obj, out System.Exception exception) {
+            exception = null;
+            obj = default(ResizeBox);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out ResizeBox obj) {
+        public static ResizeBox Deserialize(string xml) {
+            try {
+                return ((ResizeBox)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current ResizeBox object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an ResizeBox object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out ResizeBox obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out ResizeBox obj) {
+        public static ResizeBox LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this ResizeBox object
+        /// </summary>
+        public virtual ResizeBox Clone() {
+            return ((ResizeBox)(this.MemberwiseClone()));
+        #endregion
+    [System.Xml.Serialization.XmlIncludeAttribute(typeof(CompoundSymbolDefinition))]
+    [System.Xml.Serialization.XmlIncludeAttribute(typeof(SimpleSymbolDefinition))]
+    public partial class SymbolDefinitionBase : System.ComponentModel.INotifyPropertyChanged {
+        private string nameField;
+        public string Name {
+            get {
+                return this.nameField;
+            set {
+                if ((this.nameField != null)) {
+                    if ((nameField.Equals(value) != true)) {
+                        this.nameField = value;
+                        this.OnPropertyChanged("Name");
+                else {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(SymbolDefinitionBase));
+        /// <summary>
+        /// Serializes current SymbolDefinitionBase object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an SymbolDefinitionBase object
+        /// </summary>
+        /// <param name="obj">Output SymbolDefinitionBase object</param>
+        public static bool Deserialize(string xml, out SymbolDefinitionBase obj, out System.Exception exception) {
+            exception = null;
+            obj = default(SymbolDefinitionBase);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out SymbolDefinitionBase obj) {
+        public static SymbolDefinitionBase Deserialize(string xml) {
+            try {
+                return ((SymbolDefinitionBase)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current SymbolDefinitionBase object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an SymbolDefinitionBase object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out SymbolDefinitionBase obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out SymbolDefinitionBase obj) {
+        public static SymbolDefinitionBase LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this SymbolDefinitionBase object
+        /// </summary>
+        public virtual SymbolDefinitionBase Clone() {
+            return ((SymbolDefinitionBase)(this.MemberwiseClone()));
+        #endregion
+    /// <summary>
+    /// A 2D compound symbol for stylization.
+    /// </summary>
+    public partial class CompoundSymbolDefinition : SymbolDefinitionBase, System.ComponentModel.INotifyPropertyChanged {
+        private BindingList<SimpleSymbol> simpleSymbolField;
+        [System.Xml.Serialization.XmlElementAttribute("SimpleSymbol")]
+        public BindingList<SimpleSymbol> SimpleSymbol {
+            get {
+                return this.simpleSymbolField;
+            set {
+                if ((this.simpleSymbolField != null)) {
+                    if ((simpleSymbolField.Equals(value) != true)) {
+                        this.simpleSymbolField = value;
+                        this.OnPropertyChanged("SimpleSymbol");
+                else {
+        public ExtendedDataType ExtendedData1 {
+            get {
+                return this.extendedData1Field;
+            set {
+                if ((this.extendedData1Field != null)) {
+                    if ((extendedData1Field.Equals(value) != true)) {
+                        this.extendedData1Field = value;
+                        this.OnPropertyChanged("ExtendedData1");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(CompoundSymbolDefinition));
+        /// <summary>
+        /// Serializes current CompoundSymbolDefinition object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an CompoundSymbolDefinition object
+        /// </summary>
+        /// <param name="obj">Output CompoundSymbolDefinition object</param>
+        public static bool Deserialize(string xml, out CompoundSymbolDefinition obj, out System.Exception exception) {
+            exception = null;
+            obj = default(CompoundSymbolDefinition);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out CompoundSymbolDefinition obj) {
+        public static CompoundSymbolDefinition Deserialize(string xml) {
+            try {
+                return ((CompoundSymbolDefinition)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current CompoundSymbolDefinition object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an CompoundSymbolDefinition object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out CompoundSymbolDefinition obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out CompoundSymbolDefinition obj) {
+        public static CompoundSymbolDefinition LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this CompoundSymbolDefinition object
+        /// </summary>
+        public virtual CompoundSymbolDefinition Clone() {
+            return ((CompoundSymbolDefinition)(this.MemberwiseClone()));
+        #endregion
+    [System.Xml.Serialization.XmlTypeAttribute(AnonymousType=true)]
+    [System.Xml.Serialization.XmlRootAttribute("CompoundSymbolDefinition", Namespace="", IsNullable=false)]
+    public partial class CompoundSymbolDefinition1 : CompoundSymbolDefinition, System.ComponentModel.INotifyPropertyChanged {
+        private string versionField;
+        public CompoundSymbolDefinition1() {
+            this.versionField = "2.4.0";
+        [System.Xml.Serialization.XmlAttributeAttribute()]
+        public string version {
+            get {
+                return this.versionField;
+            set {
+                if ((this.versionField != null)) {
+                    if ((versionField.Equals(value) != true)) {
+                        this.versionField = value;
+                        this.OnPropertyChanged("version");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(CompoundSymbolDefinition1));
+        /// <summary>
+        /// Serializes current CompoundSymbolDefinition1 object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an CompoundSymbolDefinition1 object
+        /// </summary>
+        /// <param name="obj">Output CompoundSymbolDefinition1 object</param>
+        public static bool Deserialize(string xml, out CompoundSymbolDefinition1 obj, out System.Exception exception) {
+            exception = null;
+            obj = default(CompoundSymbolDefinition1);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out CompoundSymbolDefinition1 obj) {
+        public static CompoundSymbolDefinition1 Deserialize(string xml) {
+            try {
+                return ((CompoundSymbolDefinition1)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current CompoundSymbolDefinition1 object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an CompoundSymbolDefinition1 object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out CompoundSymbolDefinition1 obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out CompoundSymbolDefinition1 obj) {
+        public static CompoundSymbolDefinition1 LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this CompoundSymbolDefinition1 object
+        /// </summary>
+        public virtual CompoundSymbolDefinition1 Clone() {
+            return ((CompoundSymbolDefinition1)(this.MemberwiseClone()));
+        #endregion
+    /// <summary>
+    /// The specification of a watermark.
+    /// </summary>
+    [System.Xml.Serialization.XmlRootAttribute(Namespace="", IsNullable=false)]
+    public partial class WatermarkDefinition : WatermarkDefinitionType, System.ComponentModel.INotifyPropertyChanged {
+        public WatermarkDefinition() {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(WatermarkDefinition));
+        /// <summary>
+        /// Serializes current WatermarkDefinition object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an WatermarkDefinition object
+        /// </summary>
+        /// <param name="obj">Output WatermarkDefinition object</param>
+        public static bool Deserialize(string xml, out WatermarkDefinition obj, out System.Exception exception) {
+            exception = null;
+            obj = default(WatermarkDefinition);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out WatermarkDefinition obj) {
+        public static WatermarkDefinition Deserialize(string xml) {
+            try {
+                return ((WatermarkDefinition)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current WatermarkDefinition object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an WatermarkDefinition object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out WatermarkDefinition obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out WatermarkDefinition obj) {
+        public static WatermarkDefinition LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this WatermarkDefinition object
+        /// </summary>
+        public virtual WatermarkDefinition Clone() {
+            return ((WatermarkDefinition)(this.MemberwiseClone()));
+        #endregion
+    public partial class WatermarkDefinitionType : System.ComponentModel.INotifyPropertyChanged {
+        private WatermarkDefinitionTypeContent contentField;
+        private WatermarkAppearanceType appearanceField;
+        private WatermarkDefinitionTypePosition positionField;
+        public WatermarkDefinitionTypeContent Content {
+            get {
+            set {
+                else {
+        public WatermarkAppearanceType Appearance {
+            get {
+                return this.appearanceField;
+            set {
+                if ((this.appearanceField != null)) {
+                    if ((appearanceField.Equals(value) != true)) {
+                        this.appearanceField = value;
+                        this.OnPropertyChanged("Appearance");
+                else {
+        public WatermarkDefinitionTypePosition Position {
+            get {
+                return this.positionField;
+            set {
+                if ((this.positionField != null)) {
+                    if ((positionField.Equals(value) != true)) {
+                        this.positionField = value;
+                        this.OnPropertyChanged("Position");
+                else {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(WatermarkDefinitionType));
+        /// <summary>
+        /// Serializes current WatermarkDefinitionType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an WatermarkDefinitionType object
+        /// </summary>
+        /// <param name="obj">Output WatermarkDefinitionType object</param>
+        public static bool Deserialize(string xml, out WatermarkDefinitionType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(WatermarkDefinitionType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out WatermarkDefinitionType obj) {
+        public static WatermarkDefinitionType Deserialize(string xml) {
+            try {
+                return ((WatermarkDefinitionType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current WatermarkDefinitionType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an WatermarkDefinitionType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out WatermarkDefinitionType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out WatermarkDefinitionType obj) {
+        public static WatermarkDefinitionType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this WatermarkDefinitionType object
+        /// </summary>
+        public virtual WatermarkDefinitionType Clone() {
+            return ((WatermarkDefinitionType)(this.MemberwiseClone()));
+        #endregion
+    public partial class WatermarkDefinitionTypeContent : System.ComponentModel.INotifyPropertyChanged {
+        private SymbolDefinitionBase itemField;
+        [System.Xml.Serialization.XmlElementAttribute("CompoundSymbolDefinition", typeof(CompoundSymbolDefinition))]
+        [System.Xml.Serialization.XmlElementAttribute("SimpleSymbolDefinition", typeof(SimpleSymbolDefinition))]
+        public SymbolDefinitionBase Item {
+            get {
+                return this.itemField;
+            set {
+                if ((this.itemField != null)) {
+                    if ((itemField.Equals(value) != true)) {
+                        this.itemField = value;
+                        this.OnPropertyChanged("Item");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(WatermarkDefinitionTypeContent));
+        /// <summary>
+        /// Serializes current WatermarkDefinitionTypeContent object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an WatermarkDefinitionTypeContent object
+        /// </summary>
+        /// <param name="obj">Output WatermarkDefinitionTypeContent object</param>
+        public static bool Deserialize(string xml, out WatermarkDefinitionTypeContent obj, out System.Exception exception) {
+            exception = null;
+            obj = default(WatermarkDefinitionTypeContent);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out WatermarkDefinitionTypeContent obj) {
+        public static WatermarkDefinitionTypeContent Deserialize(string xml) {
+            try {
+                return ((WatermarkDefinitionTypeContent)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current WatermarkDefinitionTypeContent object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an WatermarkDefinitionTypeContent object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out WatermarkDefinitionTypeContent obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out WatermarkDefinitionTypeContent obj) {
+        public static WatermarkDefinitionTypeContent LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this WatermarkDefinitionTypeContent object
+        /// </summary>
+        public virtual WatermarkDefinitionTypeContent Clone() {
+            return ((WatermarkDefinitionTypeContent)(this.MemberwiseClone()));
+        #endregion
+    public partial class WatermarkAppearanceType : System.ComponentModel.INotifyPropertyChanged {
+        private double transparencyField;
+        private double rotationField;
+        public WatermarkAppearanceType() {
+            this.transparencyField = 0;
+            this.rotationField = 0;
+        [System.ComponentModel.DefaultValueAttribute(0)]
+        public double Transparency {
+            get {
+                return this.transparencyField;
+            set {
+                if ((transparencyField.Equals(value) != true)) {
+                    this.transparencyField = value;
+                    this.OnPropertyChanged("Transparency");
+        public double Rotation {
+            get {
+                return this.rotationField;
+            set {
+                if ((rotationField.Equals(value) != true)) {
+                    this.rotationField = value;
+                    this.OnPropertyChanged("Rotation");
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(WatermarkAppearanceType));
+        /// <summary>
+        /// Serializes current WatermarkAppearanceType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an WatermarkAppearanceType object
+        /// </summary>
+        /// <param name="obj">Output WatermarkAppearanceType object</param>
+        public static bool Deserialize(string xml, out WatermarkAppearanceType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(WatermarkAppearanceType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out WatermarkAppearanceType obj) {
+        public static WatermarkAppearanceType Deserialize(string xml) {
+            try {
+                return ((WatermarkAppearanceType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current WatermarkAppearanceType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an WatermarkAppearanceType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out WatermarkAppearanceType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out WatermarkAppearanceType obj) {
+        public static WatermarkAppearanceType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this WatermarkAppearanceType object
+        /// </summary>
+        public virtual WatermarkAppearanceType Clone() {
+            return ((WatermarkAppearanceType)(this.MemberwiseClone()));
+        #endregion
+    public partial class WatermarkDefinitionTypePosition : System.ComponentModel.INotifyPropertyChanged {
+        private PositionType itemField;
+        [System.Xml.Serialization.XmlElementAttribute("TilePosition", typeof(TilePositionType))]
+        [System.Xml.Serialization.XmlElementAttribute("XYPosition", typeof(XYPositionType))]
+        public PositionType Item {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(WatermarkDefinitionTypePosition));
+        /// <summary>
+        /// Serializes current WatermarkDefinitionTypePosition object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an WatermarkDefinitionTypePosition object
+        /// </summary>
+        /// <param name="obj">Output WatermarkDefinitionTypePosition object</param>
+        public static bool Deserialize(string xml, out WatermarkDefinitionTypePosition obj, out System.Exception exception) {
+            exception = null;
+            obj = default(WatermarkDefinitionTypePosition);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out WatermarkDefinitionTypePosition obj) {
+        public static WatermarkDefinitionTypePosition Deserialize(string xml) {
+            try {
+                return ((WatermarkDefinitionTypePosition)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current WatermarkDefinitionTypePosition object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an WatermarkDefinitionTypePosition object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out WatermarkDefinitionTypePosition obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out WatermarkDefinitionTypePosition obj) {
+        public static WatermarkDefinitionTypePosition LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this WatermarkDefinitionTypePosition object
+        /// </summary>
+        public virtual WatermarkDefinitionTypePosition Clone() {
+            return ((WatermarkDefinitionTypePosition)(this.MemberwiseClone()));
+        #endregion
+    public partial class TilePositionType : PositionType, System.ComponentModel.INotifyPropertyChanged {
+        private double tileWidthField;
+        private double tileHeightField;
+        private HorizontalPositionType horizontalPositionField;
+        private VerticalPositionType verticalPositionField;
+        public TilePositionType() {
+            this.tileWidthField = 150;
+            this.tileHeightField = 150;
+        public double TileWidth {
+            get {
+                return this.tileWidthField;
+            set {
+                if ((tileWidthField.Equals(value) != true)) {
+                    this.tileWidthField = value;
+                    this.OnPropertyChanged("TileWidth");
+        public double TileHeight {
+            get {
+                return this.tileHeightField;
+            set {
+                if ((tileHeightField.Equals(value) != true)) {
+                    this.tileHeightField = value;
+                    this.OnPropertyChanged("TileHeight");
+        public HorizontalPositionType HorizontalPosition {
+            get {
+                return this.horizontalPositionField;
+            set {
+                if ((this.horizontalPositionField != null)) {
+                    if ((horizontalPositionField.Equals(value) != true)) {
+                        this.horizontalPositionField = value;
+                        this.OnPropertyChanged("HorizontalPosition");
+                else {
+        public VerticalPositionType VerticalPosition {
+            get {
+                return this.verticalPositionField;
+            set {
+                if ((this.verticalPositionField != null)) {
+                    if ((verticalPositionField.Equals(value) != true)) {
+                        this.verticalPositionField = value;
+                        this.OnPropertyChanged("VerticalPosition");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(TilePositionType));
+        /// <summary>
+        /// Serializes current TilePositionType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an TilePositionType object
+        /// </summary>
+        /// <param name="obj">Output TilePositionType object</param>
+        public static bool Deserialize(string xml, out TilePositionType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(TilePositionType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out TilePositionType obj) {
+        public static TilePositionType Deserialize(string xml) {
+            try {
+                return ((TilePositionType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current TilePositionType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an TilePositionType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out TilePositionType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out TilePositionType obj) {
+        public static TilePositionType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this TilePositionType object
+        /// </summary>
+        public virtual TilePositionType Clone() {
+            return ((TilePositionType)(this.MemberwiseClone()));
+        #endregion
+    public partial class HorizontalPositionType : System.ComponentModel.INotifyPropertyChanged {
+        private double offsetField;
+        private UnitType unitField;
+        private HorizontalAlignmentType alignmentField;
+        public HorizontalPositionType() {
+            this.offsetField = 0;
+            this.unitField = UnitType.Points;
+            this.alignmentField = HorizontalAlignmentType.Center;
+        public double Offset {
+            get {
+                return this.offsetField;
+            set {
+                if ((offsetField.Equals(value) != true)) {
+                    this.offsetField = value;
+                    this.OnPropertyChanged("Offset");
+        public UnitType Unit {
+            get {
+                return this.unitField;
+            set {
+                if ((unitField.Equals(value) != true)) {
+                    this.unitField = value;
+                    this.OnPropertyChanged("Unit");
+        public HorizontalAlignmentType Alignment {
+            get {
+                return this.alignmentField;
+            set {
+                if ((alignmentField.Equals(value) != true)) {
+                    this.alignmentField = value;
+                    this.OnPropertyChanged("Alignment");
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(HorizontalPositionType));
+        /// <summary>
+        /// Serializes current HorizontalPositionType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an HorizontalPositionType object
+        /// </summary>
+        /// <param name="obj">Output HorizontalPositionType object</param>
+        public static bool Deserialize(string xml, out HorizontalPositionType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(HorizontalPositionType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out HorizontalPositionType obj) {
+        public static HorizontalPositionType Deserialize(string xml) {
+            try {
+                return ((HorizontalPositionType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current HorizontalPositionType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an HorizontalPositionType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out HorizontalPositionType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out HorizontalPositionType obj) {
+        public static HorizontalPositionType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this HorizontalPositionType object
+        /// </summary>
+        public virtual HorizontalPositionType Clone() {
+            return ((HorizontalPositionType)(this.MemberwiseClone()));
+        #endregion
+    public enum UnitType {
+        /// <remarks/>
+        Inches,
+        /// <remarks/>
+        Centimeters,
+        /// <remarks/>
+        Millimeters,
+        /// <remarks/>
+        Pixels,
+        /// <remarks/>
+        Points,
+    public enum HorizontalAlignmentType {
+        /// <remarks/>
+        Left,
+        /// <remarks/>
+        Center,
+        /// <remarks/>
+        Right,
+    public partial class VerticalPositionType : System.ComponentModel.INotifyPropertyChanged {
+        private VerticalAlignmentType alignmentField;
+        public VerticalPositionType() {
+            this.alignmentField = VerticalAlignmentType.Center;
+            get {
+            set {
+            get {
+            set {
+        public VerticalAlignmentType Alignment {
+            get {
+            set {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(VerticalPositionType));
+        /// <summary>
+        /// Serializes current VerticalPositionType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an VerticalPositionType object
+        /// </summary>
+        /// <param name="obj">Output VerticalPositionType object</param>
+        public static bool Deserialize(string xml, out VerticalPositionType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(VerticalPositionType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out VerticalPositionType obj) {
+        public static VerticalPositionType Deserialize(string xml) {
+            try {
+                return ((VerticalPositionType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current VerticalPositionType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an VerticalPositionType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out VerticalPositionType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out VerticalPositionType obj) {
+        public static VerticalPositionType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this VerticalPositionType object
+        /// </summary>
+        public virtual VerticalPositionType Clone() {
+            return ((VerticalPositionType)(this.MemberwiseClone()));
+        #endregion
+    public enum VerticalAlignmentType {
+        /// <remarks/>
+        Top,
+        /// <remarks/>
+        Center,
+        /// <remarks/>
+        Bottom,
+    [System.Xml.Serialization.XmlIncludeAttribute(typeof(TilePositionType))]
+    [System.Xml.Serialization.XmlIncludeAttribute(typeof(XYPositionType))]
+    public abstract partial class PositionType : System.ComponentModel.INotifyPropertyChanged {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(PositionType));
+        /// <summary>
+        /// Serializes current PositionType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an PositionType object
+        /// </summary>
+        /// <param name="obj">Output PositionType object</param>
+        public static bool Deserialize(string xml, out PositionType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(PositionType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out PositionType obj) {
+        public static PositionType Deserialize(string xml) {
+            try {
+                return ((PositionType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current PositionType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an PositionType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out PositionType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out PositionType obj) {
+        public static PositionType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this PositionType object
+        /// </summary>
+        public virtual PositionType Clone() {
+            return ((PositionType)(this.MemberwiseClone()));
+        #endregion
+    public partial class XYPositionType : PositionType, System.ComponentModel.INotifyPropertyChanged {
+        private HorizontalPositionType xPositionField;
+        private VerticalPositionType yPositionField;
+        public HorizontalPositionType XPosition {
+            get {
+                return this.xPositionField;
+            set {
+                if ((this.xPositionField != null)) {
+                    if ((xPositionField.Equals(value) != true)) {
+                        this.xPositionField = value;
+                        this.OnPropertyChanged("XPosition");
+                else {
+        public VerticalPositionType YPosition {
+            get {
+                return this.yPositionField;
+            set {
+                if ((this.yPositionField != null)) {
+                    if ((yPositionField.Equals(value) != true)) {
+                        this.yPositionField = value;
+                        this.OnPropertyChanged("YPosition");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(XYPositionType));
+        /// <summary>
+        /// Serializes current XYPositionType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an XYPositionType object
+        /// </summary>
+        /// <param name="obj">Output XYPositionType object</param>
+        public static bool Deserialize(string xml, out XYPositionType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(XYPositionType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out XYPositionType obj) {
+        public static XYPositionType Deserialize(string xml) {
+            try {
+                return ((XYPositionType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current XYPositionType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an XYPositionType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out XYPositionType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out XYPositionType obj) {
+        public static XYPositionType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this XYPositionType object
+        /// </summary>
+        public virtual XYPositionType Clone() {
+            return ((XYPositionType)(this.MemberwiseClone()));
+        #endregion
+    /// <summary>
+    /// A MapDefinition defines the collection of layers, groupings of layers, and base map
+    /// </summary>
+    public partial class MapDefinition : MapDefinitionType, System.ComponentModel.INotifyPropertyChanged {
+        public MapDefinition() {
+            this.versionField = "3.0.0";
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(MapDefinition));
+        /// <summary>
+        /// Serializes current MapDefinition object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an MapDefinition object
+        /// </summary>
+        /// <param name="obj">Output MapDefinition object</param>
+        public static bool Deserialize(string xml, out MapDefinition obj, out System.Exception exception) {
+            exception = null;
+            obj = default(MapDefinition);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out MapDefinition obj) {
+        public static MapDefinition Deserialize(string xml) {
+            try {
+                return ((MapDefinition)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current MapDefinition object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an MapDefinition object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out MapDefinition obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out MapDefinition obj) {
+        public static MapDefinition LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this MapDefinition object
+        /// </summary>
+        public virtual MapDefinition Clone() {
+            return ((MapDefinition)(this.MemberwiseClone()));
+        #endregion
+    [System.Xml.Serialization.XmlRootAttribute(Namespace="", IsNullable=true)]
+    public partial class MapDefinitionType : System.ComponentModel.INotifyPropertyChanged {
+        private string coordinateSystemField;
+        private Box2DType extentsField;
+        private byte[] backgroundColorField;
+        private string metadataField;
+        private BindingList<MapLayerType> mapLayerField;
+        private BindingList<MapLayerGroupType> mapLayerGroupField;
+        private MapDefinitionTypeBaseMapDefinition baseMapDefinitionField;
+        private MapDefinitionTypeTileSetSource tileSetSourceField;
+        private BindingList<WatermarkType> watermarksField;
+            get {
+            set {
+                else {
+        public string CoordinateSystem {
+            get {
+                return this.coordinateSystemField;
+            set {
+                if ((this.coordinateSystemField != null)) {
+                    if ((coordinateSystemField.Equals(value) != true)) {
+                        this.coordinateSystemField = value;
+                        this.OnPropertyChanged("CoordinateSystem");
+                else {
+        public Box2DType Extents {
+            get {
+                return this.extentsField;
+            set {
+                if ((this.extentsField != null)) {
+                    if ((extentsField.Equals(value) != true)) {
+                        this.extentsField = value;
+                        this.OnPropertyChanged("Extents");
+                else {
+        [System.Xml.Serialization.XmlElementAttribute(DataType="hexBinary")]
+        public byte[] BackgroundColor {
+            get {
+                return this.backgroundColorField;
+            set {
+                if ((this.backgroundColorField != null)) {
+                    if ((backgroundColorField.Equals(value) != true)) {
+                        this.backgroundColorField = value;
+                        this.OnPropertyChanged("BackgroundColor");
+                else {
+        public string Metadata {
+            get {
+                return this.metadataField;
+            set {
+                if ((this.metadataField != null)) {
+                    if ((metadataField.Equals(value) != true)) {
+                        this.metadataField = value;
+                        this.OnPropertyChanged("Metadata");
+                else {
+        [System.Xml.Serialization.XmlElementAttribute("MapLayer")]
+        public BindingList<MapLayerType> MapLayer {
+            get {
+                return this.mapLayerField;
+            set {
+                if ((this.mapLayerField != null)) {
+                    if ((mapLayerField.Equals(value) != true)) {
+                        this.mapLayerField = value;
+                        this.OnPropertyChanged("MapLayer");
+                else {
+        [System.Xml.Serialization.XmlElementAttribute("MapLayerGroup")]
+        public BindingList<MapLayerGroupType> MapLayerGroup {
+            get {
+                return this.mapLayerGroupField;
+            set {
+                if ((this.mapLayerGroupField != null)) {
+                    if ((mapLayerGroupField.Equals(value) != true)) {
+                        this.mapLayerGroupField = value;
+                        this.OnPropertyChanged("MapLayerGroup");
+                else {
+        public MapDefinitionTypeBaseMapDefinition BaseMapDefinition {
+            get {
+                return this.baseMapDefinitionField;
+            set {
+                if ((this.baseMapDefinitionField != null)) {
+                    if ((baseMapDefinitionField.Equals(value) != true)) {
+                        this.baseMapDefinitionField = value;
+                        this.OnPropertyChanged("BaseMapDefinition");
+                else {
+        public MapDefinitionTypeTileSetSource TileSetSource {
+            get {
+                return this.tileSetSourceField;
+            set {
+                if ((this.tileSetSourceField != null)) {
+                    if ((tileSetSourceField.Equals(value) != true)) {
+                        this.tileSetSourceField = value;
+                        this.OnPropertyChanged("TileSetSource");
+                else {
+        [System.Xml.Serialization.XmlArrayItemAttribute("Watermark", IsNullable=false)]
+        public BindingList<WatermarkType> Watermarks {
+            get {
+                return this.watermarksField;
+            set {
+                if ((this.watermarksField != null)) {
+                    if ((watermarksField.Equals(value) != true)) {
+                        this.watermarksField = value;
+                        this.OnPropertyChanged("Watermarks");
+                else {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(MapDefinitionType));
+        /// <summary>
+        /// Serializes current MapDefinitionType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an MapDefinitionType object
+        /// </summary>
+        /// <param name="obj">Output MapDefinitionType object</param>
+        public static bool Deserialize(string xml, out MapDefinitionType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(MapDefinitionType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out MapDefinitionType obj) {
+        public static MapDefinitionType Deserialize(string xml) {
+            try {
+                return ((MapDefinitionType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current MapDefinitionType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an MapDefinitionType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out MapDefinitionType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out MapDefinitionType obj) {
+        public static MapDefinitionType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this MapDefinitionType object
+        /// </summary>
+        public virtual MapDefinitionType Clone() {
+            return ((MapDefinitionType)(this.MemberwiseClone()));
+        #endregion
+    public partial class Box2DType : System.ComponentModel.INotifyPropertyChanged {
+        private double minXField;
+        private double maxXField;
+        private double minYField;
+        private double maxYField;
+        public double MinX {
+            get {
+                return this.minXField;
+            set {
+                if ((minXField.Equals(value) != true)) {
+                    this.minXField = value;
+                    this.OnPropertyChanged("MinX");
+        public double MaxX {
+            get {
+                return this.maxXField;
+            set {
+                if ((maxXField.Equals(value) != true)) {
+                    this.maxXField = value;
+                    this.OnPropertyChanged("MaxX");
+        public double MinY {
+            get {
+                return this.minYField;
+            set {
+                if ((minYField.Equals(value) != true)) {
+                    this.minYField = value;
+                    this.OnPropertyChanged("MinY");
+        public double MaxY {
+            get {
+                return this.maxYField;
+            set {
+                if ((maxYField.Equals(value) != true)) {
+                    this.maxYField = value;
+                    this.OnPropertyChanged("MaxY");
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(Box2DType));
+        /// <summary>
+        /// Serializes current Box2DType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an Box2DType object
+        /// </summary>
+        /// <param name="obj">Output Box2DType object</param>
+        public static bool Deserialize(string xml, out Box2DType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(Box2DType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out Box2DType obj) {
+        public static Box2DType Deserialize(string xml) {
+            try {
+                return ((Box2DType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current Box2DType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an Box2DType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out Box2DType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out Box2DType obj) {
+        public static Box2DType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this Box2DType object
+        /// </summary>
+        public virtual Box2DType Clone() {
+            return ((Box2DType)(this.MemberwiseClone()));
+        #endregion
+    public partial class MapLayerType : MapLayerCommonType, System.ComponentModel.INotifyPropertyChanged {
+        private bool visibleField;
+        private string groupField;
+        public bool Visible {
+            get {
+                return this.visibleField;
+            set {
+                if ((visibleField.Equals(value) != true)) {
+                    this.visibleField = value;
+                    this.OnPropertyChanged("Visible");
+        public string Group {
+            get {
+                return this.groupField;
+            set {
+                if ((this.groupField != null)) {
+                    if ((groupField.Equals(value) != true)) {
+                        this.groupField = value;
+                        this.OnPropertyChanged("Group");
+                else {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(MapLayerType));
+        /// <summary>
+        /// Serializes current MapLayerType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an MapLayerType object
+        /// </summary>
+        /// <param name="obj">Output MapLayerType object</param>
+        public static bool Deserialize(string xml, out MapLayerType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(MapLayerType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out MapLayerType obj) {
+        public static MapLayerType Deserialize(string xml) {
+            try {
+                return ((MapLayerType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current MapLayerType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an MapLayerType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out MapLayerType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out MapLayerType obj) {
+        public static MapLayerType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this MapLayerType object
+        /// </summary>
+        public virtual MapLayerType Clone() {
+            return ((MapLayerType)(this.MemberwiseClone()));
+        #endregion
+    [System.Xml.Serialization.XmlIncludeAttribute(typeof(BaseMapLayerType))]
+    [System.Xml.Serialization.XmlIncludeAttribute(typeof(MapLayerType))]
+    public partial class MapLayerCommonType : System.ComponentModel.INotifyPropertyChanged {
+        private string resourceIdField;
+        private bool selectableField;
+        private bool showInLegendField;
+        private string legendLabelField;
+        private bool expandInLegendField;
+            get {
+            set {
+                else {
+        public string ResourceId {
+            get {
+                return this.resourceIdField;
+            set {
+                if ((this.resourceIdField != null)) {
+                    if ((resourceIdField.Equals(value) != true)) {
+                        this.resourceIdField = value;
+                        this.OnPropertyChanged("ResourceId");
+                else {
+        public bool Selectable {
+            get {
+                return this.selectableField;
+            set {
+                if ((selectableField.Equals(value) != true)) {
+                    this.selectableField = value;
+                    this.OnPropertyChanged("Selectable");
+        public bool ShowInLegend {
+            get {
+                return this.showInLegendField;
+            set {
+                if ((showInLegendField.Equals(value) != true)) {
+                    this.showInLegendField = value;
+                    this.OnPropertyChanged("ShowInLegend");
+        public string LegendLabel {
+            get {
+                return this.legendLabelField;
+            set {
+                if ((this.legendLabelField != null)) {
+                    if ((legendLabelField.Equals(value) != true)) {
+                        this.legendLabelField = value;
+                        this.OnPropertyChanged("LegendLabel");
+                else {
+        public bool ExpandInLegend {
+            get {
+                return this.expandInLegendField;
+            set {
+                if ((expandInLegendField.Equals(value) != true)) {
+                    this.expandInLegendField = value;
+                    this.OnPropertyChanged("ExpandInLegend");
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(MapLayerCommonType));
+        /// <summary>
+        /// Serializes current MapLayerCommonType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an MapLayerCommonType object
+        /// </summary>
+        /// <param name="obj">Output MapLayerCommonType object</param>
+        public static bool Deserialize(string xml, out MapLayerCommonType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(MapLayerCommonType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out MapLayerCommonType obj) {
+        public static MapLayerCommonType Deserialize(string xml) {
+            try {
+                return ((MapLayerCommonType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current MapLayerCommonType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an MapLayerCommonType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out MapLayerCommonType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out MapLayerCommonType obj) {
+        public static MapLayerCommonType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this MapLayerCommonType object
+        /// </summary>
+        public virtual MapLayerCommonType Clone() {
+            return ((MapLayerCommonType)(this.MemberwiseClone()));
+        #endregion
+    public partial class BaseMapLayerType : MapLayerCommonType, System.ComponentModel.INotifyPropertyChanged {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(BaseMapLayerType));
+        /// <summary>
+        /// Serializes current BaseMapLayerType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an BaseMapLayerType object
+        /// </summary>
+        /// <param name="obj">Output BaseMapLayerType object</param>
+        public static bool Deserialize(string xml, out BaseMapLayerType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(BaseMapLayerType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out BaseMapLayerType obj) {
+        public static BaseMapLayerType Deserialize(string xml) {
+            try {
+                return ((BaseMapLayerType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current BaseMapLayerType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an BaseMapLayerType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out BaseMapLayerType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out BaseMapLayerType obj) {
+        public static BaseMapLayerType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this BaseMapLayerType object
+        /// </summary>
+        public virtual BaseMapLayerType Clone() {
+            return ((BaseMapLayerType)(this.MemberwiseClone()));
+        #endregion
+    public partial class MapLayerGroupType : MapLayerGroupCommonType, System.ComponentModel.INotifyPropertyChanged {
+            get {
+            set {
+                else {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(MapLayerGroupType));
+        /// <summary>
+        /// Serializes current MapLayerGroupType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an MapLayerGroupType object
+        /// </summary>
+        /// <param name="obj">Output MapLayerGroupType object</param>
+        public static bool Deserialize(string xml, out MapLayerGroupType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(MapLayerGroupType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out MapLayerGroupType obj) {
+        public static MapLayerGroupType Deserialize(string xml) {
+            try {
+                return ((MapLayerGroupType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current MapLayerGroupType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an MapLayerGroupType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out MapLayerGroupType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out MapLayerGroupType obj) {
+        public static MapLayerGroupType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this MapLayerGroupType object
+        /// </summary>
+        public virtual MapLayerGroupType Clone() {
+            return ((MapLayerGroupType)(this.MemberwiseClone()));
+        #endregion
+    [System.Xml.Serialization.XmlIncludeAttribute(typeof(BaseMapLayerGroupType))]
+    [System.Xml.Serialization.XmlIncludeAttribute(typeof(MapLayerGroupType))]
+    [System.CodeDom.Compiler.GeneratedCodeAttribute("Xsd2Code", "3.4.0.32990")]
+    [System.SerializableAttribute()]
+    [System.ComponentModel.DesignerCategoryAttribute("code")]
+    public partial class MapLayerGroupCommonType : System.ComponentModel.INotifyPropertyChanged {
+            get {
+            set {
+                else {
+            get {
+            set {
+            get {
+            set {
+            get {
+            set {
+            get {
+            set {
+                else {
+        private static System.Xml.Serialization.XmlSerializer Serializer {
+            get {
+                if ((serializer == null)) {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(MapLayerGroupCommonType));
+                return serializer;
+        public event System.ComponentModel.PropertyChangedEventHandler PropertyChanged;
+        public virtual void OnPropertyChanged(string propertyName) {
+            System.ComponentModel.PropertyChangedEventHandler handler = this.PropertyChanged;
+            if ((handler != null)) {
+                handler(this, new System.ComponentModel.PropertyChangedEventArgs(propertyName));
+        #region Serialize/Deserialize
+        /// <summary>
+        /// Serializes current MapLayerGroupCommonType object into an XML document
+        /// </summary>
+        /// <returns>string XML value</returns>
+        public virtual string Serialize() {
+            System.IO.StreamReader streamReader = null;
+            System.IO.MemoryStream memoryStream = null;
+            try {
+                memoryStream = new System.IO.MemoryStream();
+                Serializer.Serialize(memoryStream, this);
+                memoryStream.Seek(0, System.IO.SeekOrigin.Begin);
+                streamReader = new System.IO.StreamReader(memoryStream);
+                return streamReader.ReadToEnd();
+            finally {
+                if ((streamReader != null)) {
+                    streamReader.Dispose();
+                if ((memoryStream != null)) {
+                    memoryStream.Dispose();
+        /// <summary>
+        /// Deserializes workflow markup into an MapLayerGroupCommonType object
+        /// </summary>
+        /// <param name="xml">string workflow markup to deserialize</param>
+        /// <param name="obj">Output MapLayerGroupCommonType object</param>
+        /// <param name="exception">output Exception value if deserialize failed</param>
+        /// <returns>true if this XmlSerializer can deserialize the object; otherwise, false</returns>
+        public static bool Deserialize(string xml, out MapLayerGroupCommonType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(MapLayerGroupCommonType);
+            try {
+                obj = Deserialize(xml);
+                return true;
+            catch (System.Exception ex) {
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out MapLayerGroupCommonType obj) {
+            System.Exception exception = null;
+            return Deserialize(xml, out obj, out exception);
+        public static MapLayerGroupCommonType Deserialize(string xml) {
+            System.IO.StringReader stringReader = null;
+            try {
+                stringReader = new System.IO.StringReader(xml);
+                return ((MapLayerGroupCommonType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+                if ((stringReader != null)) {
+                    stringReader.Dispose();
+        /// <summary>
+        /// Serializes current MapLayerGroupCommonType object into file
+        /// </summary>
+        /// <param name="fileName">full path of outupt xml file</param>
+        /// <param name="exception">output Exception value if failed</param>
+        /// <returns>true if can serialize and save into file; otherwise, false</returns>
+        public virtual bool SaveToFile(string fileName, out System.Exception exception) {
+            exception = null;
+            try {
+                SaveToFile(fileName);
+                return true;
+            catch (System.Exception e) {
+                exception = e;
+                return false;
+        public virtual void SaveToFile(string fileName) {
+            System.IO.StreamWriter streamWriter = null;
+            try {
+                string xmlString = Serialize();
+                System.IO.FileInfo xmlFile = new System.IO.FileInfo(fileName);
+                streamWriter = xmlFile.CreateText();
+                streamWriter.WriteLine(xmlString);
+                streamWriter.Close();
+            finally {
+                if ((streamWriter != null)) {
+                    streamWriter.Dispose();
+        /// <summary>
+        /// Deserializes xml markup from file into an MapLayerGroupCommonType object
+        /// </summary>
+        /// <param name="fileName">string xml file to load and deserialize</param>
+        public static bool LoadFromFile(string fileName, out MapLayerGroupCommonType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                obj = LoadFromFile(fileName);
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out MapLayerGroupCommonType obj) {
+            return LoadFromFile(fileName, out obj, out exception);
+        public static MapLayerGroupCommonType LoadFromFile(string fileName) {
+            System.IO.FileStream file = null;
+            System.IO.StreamReader sr = null;
+            try {
+                file = new System.IO.FileStream(fileName, FileMode.Open, FileAccess.Read);
+                sr = new System.IO.StreamReader(file);
+                string xmlString = sr.ReadToEnd();
+                sr.Close();
+                file.Close();
+                return Deserialize(xmlString);
+            finally {
+                if ((file != null)) {
+                    file.Dispose();
+                if ((sr != null)) {
+                    sr.Dispose();
+        #endregion
+        #region Clone method
+        /// <summary>
+        /// Create a clone of this MapLayerGroupCommonType object
+        /// </summary>
+        public virtual MapLayerGroupCommonType Clone() {
+            return ((MapLayerGroupCommonType)(this.MemberwiseClone()));
+        #endregion
+    public partial class BaseMapLayerGroupType : MapLayerGroupCommonType, System.ComponentModel.INotifyPropertyChanged {
+        [EditorBrowsable(EditorBrowsableState.Never)]
+        private BindingList<BaseMapLayerType> baseMapLayerField;
+        private ExtendedDataType extendedData1Field;
+        private static System.Xml.Serialization.XmlSerializer serializer;
+        [System.Xml.Serialization.XmlElementAttribute("BaseMapLayer")]
+        public BindingList<BaseMapLayerType> BaseMapLayer {
+            get {
+                return this.baseMapLayerField;
+            set {
+                if ((this.baseMapLayerField != null)) {
+                    if ((baseMapLayerField.Equals(value) != true)) {
+                        this.baseMapLayerField = value;
+                        this.OnPropertyChanged("BaseMapLayer");
+                else {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(BaseMapLayerGroupType));
+        /// <summary>
+        /// Serializes current BaseMapLayerGroupType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an BaseMapLayerGroupType object
+        /// </summary>
+        /// <param name="obj">Output BaseMapLayerGroupType object</param>
+        public static bool Deserialize(string xml, out BaseMapLayerGroupType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(BaseMapLayerGroupType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out BaseMapLayerGroupType obj) {
+        public static BaseMapLayerGroupType Deserialize(string xml) {
+            try {
+                return ((BaseMapLayerGroupType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current BaseMapLayerGroupType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an BaseMapLayerGroupType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out BaseMapLayerGroupType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out BaseMapLayerGroupType obj) {
+        public static BaseMapLayerGroupType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this BaseMapLayerGroupType object
+        /// </summary>
+        public virtual BaseMapLayerGroupType Clone() {
+            return ((BaseMapLayerGroupType)(this.MemberwiseClone()));
+        #endregion
+    public partial class MapDefinitionTypeBaseMapDefinition : System.ComponentModel.INotifyPropertyChanged {
+        private BindingList<double> finiteDisplayScaleField;
+        private BindingList<BaseMapLayerGroupType> baseMapLayerGroupField;
+        [System.Xml.Serialization.XmlElementAttribute("FiniteDisplayScale")]
+        public BindingList<double> FiniteDisplayScale {
+            get {
+                return this.finiteDisplayScaleField;
+            set {
+                if ((this.finiteDisplayScaleField != null)) {
+                    if ((finiteDisplayScaleField.Equals(value) != true)) {
+                        this.finiteDisplayScaleField = value;
+                        this.OnPropertyChanged("FiniteDisplayScale");
+                else {
+        [System.Xml.Serialization.XmlElementAttribute("BaseMapLayerGroup")]
+        public BindingList<BaseMapLayerGroupType> BaseMapLayerGroup {
+            get {
+                return this.baseMapLayerGroupField;
+            set {
+                if ((this.baseMapLayerGroupField != null)) {
+                    if ((baseMapLayerGroupField.Equals(value) != true)) {
+                        this.baseMapLayerGroupField = value;
+                        this.OnPropertyChanged("BaseMapLayerGroup");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(MapDefinitionTypeBaseMapDefinition));
+        /// <summary>
+        /// Serializes current MapDefinitionTypeBaseMapDefinition object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an MapDefinitionTypeBaseMapDefinition object
+        /// </summary>
+        /// <param name="obj">Output MapDefinitionTypeBaseMapDefinition object</param>
+        public static bool Deserialize(string xml, out MapDefinitionTypeBaseMapDefinition obj, out System.Exception exception) {
+            exception = null;
+            obj = default(MapDefinitionTypeBaseMapDefinition);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out MapDefinitionTypeBaseMapDefinition obj) {
+        public static MapDefinitionTypeBaseMapDefinition Deserialize(string xml) {
+            try {
+                return ((MapDefinitionTypeBaseMapDefinition)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current MapDefinitionTypeBaseMapDefinition object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an MapDefinitionTypeBaseMapDefinition object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out MapDefinitionTypeBaseMapDefinition obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out MapDefinitionTypeBaseMapDefinition obj) {
+        public static MapDefinitionTypeBaseMapDefinition LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this MapDefinitionTypeBaseMapDefinition object
+        /// </summary>
+        public virtual MapDefinitionTypeBaseMapDefinition Clone() {
+            return ((MapDefinitionTypeBaseMapDefinition)(this.MemberwiseClone()));
+        #endregion
+    public partial class MapDefinitionTypeTileSetSource : System.ComponentModel.INotifyPropertyChanged {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(MapDefinitionTypeTileSetSource));
+        /// <summary>
+        /// Serializes current MapDefinitionTypeTileSetSource object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an MapDefinitionTypeTileSetSource object
+        /// </summary>
+        /// <param name="obj">Output MapDefinitionTypeTileSetSource object</param>
+        public static bool Deserialize(string xml, out MapDefinitionTypeTileSetSource obj, out System.Exception exception) {
+            exception = null;
+            obj = default(MapDefinitionTypeTileSetSource);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out MapDefinitionTypeTileSetSource obj) {
+        public static MapDefinitionTypeTileSetSource Deserialize(string xml) {
+            try {
+                return ((MapDefinitionTypeTileSetSource)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current MapDefinitionTypeTileSetSource object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an MapDefinitionTypeTileSetSource object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out MapDefinitionTypeTileSetSource obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out MapDefinitionTypeTileSetSource obj) {
+        public static MapDefinitionTypeTileSetSource LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this MapDefinitionTypeTileSetSource object
+        /// </summary>
+        public virtual MapDefinitionTypeTileSetSource Clone() {
+            return ((MapDefinitionTypeTileSetSource)(this.MemberwiseClone()));
+        #endregion
+    public partial class WatermarkType : System.ComponentModel.INotifyPropertyChanged {
+        private string nameField;
+        private UsageType usageField;
+        private WatermarkAppearanceType appearanceOverrideField;
+        private WatermarkTypePositionOverride positionOverrideField;
+        public WatermarkType() {
+            this.usageField = UsageType.All;
+        public string Name {
+            get {
+                return this.nameField;
+            set {
+                if ((this.nameField != null)) {
+                    if ((nameField.Equals(value) != true)) {
+                        this.nameField = value;
+                        this.OnPropertyChanged("Name");
+                else {
+            get {
+            set {
+                else {
+        [System.ComponentModel.DefaultValueAttribute(UsageType.All)]
+        public UsageType Usage {
+            get {
+                return this.usageField;
+            set {
+                if ((usageField.Equals(value) != true)) {
+                    this.usageField = value;
+                    this.OnPropertyChanged("Usage");
+        public WatermarkAppearanceType AppearanceOverride {
+            get {
+                return this.appearanceOverrideField;
+            set {
+                if ((this.appearanceOverrideField != null)) {
+                    if ((appearanceOverrideField.Equals(value) != true)) {
+                        this.appearanceOverrideField = value;
+                        this.OnPropertyChanged("AppearanceOverride");
+                else {
+        public WatermarkTypePositionOverride PositionOverride {
+            get {
+                return this.positionOverrideField;
+            set {
+                if ((this.positionOverrideField != null)) {
+                    if ((positionOverrideField.Equals(value) != true)) {
+                        this.positionOverrideField = value;
+                        this.OnPropertyChanged("PositionOverride");
+                else {
+        public ExtendedDataType ExtendedData1 {
+            get {
+                return this.extendedData1Field;
+            set {
+                if ((this.extendedData1Field != null)) {
+                    if ((extendedData1Field.Equals(value) != true)) {
+                        this.extendedData1Field = value;
+                        this.OnPropertyChanged("ExtendedData1");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(WatermarkType));
+        /// <summary>
+        /// Serializes current WatermarkType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an WatermarkType object
+        /// </summary>
+        /// <param name="obj">Output WatermarkType object</param>
+        public static bool Deserialize(string xml, out WatermarkType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(WatermarkType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out WatermarkType obj) {
+        public static WatermarkType Deserialize(string xml) {
+            try {
+                return ((WatermarkType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current WatermarkType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an WatermarkType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out WatermarkType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out WatermarkType obj) {
+        public static WatermarkType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this WatermarkType object
+        /// </summary>
+        public virtual WatermarkType Clone() {
+            return ((WatermarkType)(this.MemberwiseClone()));
+        #endregion
+    public enum UsageType {
+        /// <remarks/>
+        WMS,
+        /// <remarks/>
+        Viewer,
+        /// <remarks/>
+        All,
+    [System.Xml.Serialization.XmlTypeAttribute(AnonymousType=true)]
+    public partial class WatermarkTypePositionOverride : System.ComponentModel.INotifyPropertyChanged {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(WatermarkTypePositionOverride));
+        /// <summary>
+        /// Serializes current WatermarkTypePositionOverride object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an WatermarkTypePositionOverride object
+        /// </summary>
+        /// <param name="obj">Output WatermarkTypePositionOverride object</param>
+        public static bool Deserialize(string xml, out WatermarkTypePositionOverride obj, out System.Exception exception) {
+            exception = null;
+            obj = default(WatermarkTypePositionOverride);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out WatermarkTypePositionOverride obj) {
+        public static WatermarkTypePositionOverride Deserialize(string xml) {
+            try {
+                return ((WatermarkTypePositionOverride)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current WatermarkTypePositionOverride object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an WatermarkTypePositionOverride object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out WatermarkTypePositionOverride obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out WatermarkTypePositionOverride obj) {
+        public static WatermarkTypePositionOverride LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this WatermarkTypePositionOverride object
+        /// </summary>
+        public virtual WatermarkTypePositionOverride Clone() {
+            return ((WatermarkTypePositionOverride)(this.MemberwiseClone()));
+        #endregion
Added: trunk/Tools/Maestro/Generated/RuntimeMap-3.0.0.designer.cs
--- trunk/Tools/Maestro/Generated/RuntimeMap-3.0.0.designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Generated/RuntimeMap-3.0.0.designer.cs	2014-12-29 13:18:49 UTC (rev 8482)
@@ -0,0 +1,3214 @@
+#pragma warning disable 1591, 0114, 0108
+//  <auto-generated>
+//    Generated by Xsd2Code. Version 3.3.0.2211
+//    <NameSpace>OSGeo.MapGuide.ObjectModels.RuntimeMap</NameSpace><Collection>BindingList</Collection><codeType>CSharp</codeType><EnableDataBinding>True</EnableDataBinding><EnableLasyLoading>False</EnableLasyLoading><HidePrivateFieldInIDE>True</HidePrivateFieldInIDE><EnableSummaryComment>True</EnableSummaryComment><IncludeSerializeMethod>True</IncludeSerializeMethod><UseBaseClass>False</UseBaseClass><GenerateCloneMethod>True</GenerateCloneMethod><GenerateDataContracts>False</GenerateDataContracts><CodeBaseTag>Net20</CodeBaseTag><SerializeMethodName>Serialize</SerializeMethodName><DeserializeMethodName>Deserialize</DeserializeMethodName><SaveToFileMethodName>SaveToFile</SaveToFileMethodName><LoadFromFileMethodName>LoadFromFile</LoadFromFileMethodName><GenerateXMLAttributes>True</GenerateXMLAttributes><AutomaticProperties>False</AutomaticProperties><DisableDebug>False</DisableDebug><CustomUsings></CustomUsings><ExcludeIncludedTypes>False</ExcludeIncludedTypes><EnableInitializ
 eFields>False</EnableInitializeFields>
+//  </auto-generated>
+namespace OSGeo.MapGuide.ObjectModels.RuntimeMap.v3_0_0 {
+    using System;
+    using System.Diagnostics;
+    using System.Xml.Serialization;
+    using System.Collections;
+    using System.Xml.Schema;
+    using System.ComponentModel;
+    using System.IO;
+    /// <summary>
+    /// Describes information about a Runtime Map, so that client applications can interact with it
+    /// </summary>
+    [System.CodeDom.Compiler.GeneratedCodeAttribute("Xsd2Code", "3.3.0.2272")]
+    [System.Diagnostics.DebuggerStepThroughAttribute()]
+    [System.Xml.Serialization.XmlRootAttribute(Namespace="", IsNullable=false)]
+    public partial class RuntimeMap : System.ComponentModel.INotifyPropertyChanged {
+        private string siteVersionField;
+        private string mapDefinitionField;
+        private string tileSetDefinitionField;
+        private string tileWidthField;
+        private string tileHeightField;
+        private string backgroundColorField;
+        private int displayDpiField;
+        private string iconMimeTypeField;
+        private CoordinateSystemType coordinateSystemField;
+        private Envelope extentsField;
+        private BindingList<RuntimeMapGroup> groupField;
+        private BindingList<RuntimeMapLayer> layerField;
+        /// <summary>
+        /// The MapGuide Site Version
+        /// </summary>
+        public string SiteVersion {
+            get {
+                return this.siteVersionField;
+            set {
+                if ((this.siteVersionField != null)) {
+                    if ((siteVersionField.Equals(value) != true)) {
+                        this.siteVersionField = value;
+                        this.OnPropertyChanged("SiteVersion");
+                else {
+        /// <summary>
+        /// The name of the runtime map. This is the value required for any mapagent operation that require a MAPNAME parameter
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// The resource id of the Map Definition from which this runtime map was created from
+        /// </summary>
+        public string MapDefinition {
+            get {
+                return this.mapDefinitionField;
+            set {
+                if ((this.mapDefinitionField != null)) {
+                    if ((mapDefinitionField.Equals(value) != true)) {
+                        this.mapDefinitionField = value;
+                        this.OnPropertyChanged("MapDefinition");
+                else {
+        /// <summary>
+        /// The resource id of the Tile Set Definition linked by the Map Definition from which this runtime map was created from
+        /// </summary>
+        public string TileSetDefinition
+            get
+                return this.tileSetDefinitionField;
+            set
+                if ((this.tileSetDefinitionField != null))
+                    if ((tileSetDefinitionField.Equals(value) != true))
+                        this.tileSetDefinitionField = value;
+                        this.OnPropertyChanged("TileSetDefinition");
+                else
+        /// <summary>
+        /// The tile width
+        /// </summary>
+        [System.Xml.Serialization.XmlElementAttribute(DataType = "integer")]
+        public string TileWidth
+            get
+            set
+                if ((this.tileWidthField != null))
+                else
+        /// <summary>
+        /// The tile height
+        /// </summary>
+        public string TileHeight
+            get
+            set
+                if ((this.tileHeightField != null))
+                else
+        /// <summary>
+        /// The map's background color in ARGB hex string format
+        /// </summary>
+        public string BackgroundColor {
+            get {
+            set {
+                else {
+        /// <summary>
+        /// The number of dots per inch of the map display
+        /// </summary>
+        public int DisplayDpi {
+            get {
+                return this.displayDpiField;
+            set {
+                if ((displayDpiField.Equals(value) != true))
+                    this.displayDpiField = value;
+                    this.OnPropertyChanged("DisplayDpi");
+        /// <summary>
+        /// The mime type of all inline icons
+        /// </summary>
+        public string IconMimeType {
+            get {
+                return this.iconMimeTypeField;
+            set {
+                if ((this.iconMimeTypeField != null)) {
+                    if ((iconMimeTypeField.Equals(value) != true)) {
+                        this.iconMimeTypeField = value;
+                        this.OnPropertyChanged("IconMimeType");
+                else {
+        public CoordinateSystemType CoordinateSystem {
+            get {
+            set {
+                else {
+        public Envelope Extents {
+            get {
+            set {
+                else {
+        [System.Xml.Serialization.XmlElementAttribute("Group")]
+        public BindingList<RuntimeMapGroup> Group {
+            get {
+            set {
+                else {
+        [System.Xml.Serialization.XmlElementAttribute("Layer")]
+        public BindingList<RuntimeMapLayer> Layer {
+            get {
+                return this.layerField;
+            set {
+                if ((this.layerField != null)) {
+                    if ((layerField.Equals(value) != true)) {
+                        this.layerField = value;
+                        this.OnPropertyChanged("Layer");
+                else {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(RuntimeMap));
+        public virtual void OnPropertyChanged(string info) {
+                handler(this, new System.ComponentModel.PropertyChangedEventArgs(info));
+        /// <summary>
+        /// Serializes current RuntimeMap object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an RuntimeMap object
+        /// </summary>
+        /// <param name="obj">Output RuntimeMap object</param>
+        public static bool Deserialize(string xml, out RuntimeMap obj, out System.Exception exception) {
+            exception = null;
+            obj = default(RuntimeMap);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out RuntimeMap obj) {
+        public static RuntimeMap Deserialize(string xml) {
+            try {
+                return ((RuntimeMap)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current RuntimeMap object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an RuntimeMap object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out RuntimeMap obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out RuntimeMap obj) {
+        public static RuntimeMap LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this RuntimeMap object
+        /// </summary>
+        public virtual RuntimeMap Clone() {
+            return ((RuntimeMap)(this.MemberwiseClone()));
+        #endregion
+    public partial class CoordinateSystemType : System.ComponentModel.INotifyPropertyChanged {
+        private string wktField;
+        private string mentorCodeField;
+        private string epsgCodeField;
+        private double metersPerUnitField;
+        public string Wkt {
+            get {
+                return this.wktField;
+            set {
+                if ((this.wktField != null)) {
+                    if ((wktField.Equals(value) != true)) {
+                        this.wktField = value;
+                        this.OnPropertyChanged("Wkt");
+                else {
+        public string MentorCode {
+            get {
+                return this.mentorCodeField;
+            set {
+                if ((this.mentorCodeField != null)) {
+                    if ((mentorCodeField.Equals(value) != true)) {
+                        this.mentorCodeField = value;
+                        this.OnPropertyChanged("MentorCode");
+                else {
+        public string EpsgCode {
+            get {
+                return this.epsgCodeField;
+            set {
+                if ((this.epsgCodeField != null)) {
+                    if ((epsgCodeField.Equals(value) != true)) {
+                        this.epsgCodeField = value;
+                        this.OnPropertyChanged("EpsgCode");
+                else {
+        public double MetersPerUnit {
+            get {
+                return this.metersPerUnitField;
+            set {
+                if ((metersPerUnitField.Equals(value) != true)) {
+                    this.metersPerUnitField = value;
+                    this.OnPropertyChanged("MetersPerUnit");
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(CoordinateSystemType));
+        /// <summary>
+        /// Serializes current CoordinateSystemType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an CoordinateSystemType object
+        /// </summary>
+        /// <param name="obj">Output CoordinateSystemType object</param>
+        public static bool Deserialize(string xml, out CoordinateSystemType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(CoordinateSystemType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out CoordinateSystemType obj) {
+        public static CoordinateSystemType Deserialize(string xml) {
+            try {
+                return ((CoordinateSystemType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current CoordinateSystemType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an CoordinateSystemType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out CoordinateSystemType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out CoordinateSystemType obj) {
+        public static CoordinateSystemType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this CoordinateSystemType object
+        /// </summary>
+        public virtual CoordinateSystemType Clone() {
+            return ((CoordinateSystemType)(this.MemberwiseClone()));
+        #endregion
+    public partial class RuleInfo : System.ComponentModel.INotifyPropertyChanged {
+        private string filterField;
+        private string iconField;
+            get {
+            set {
+                else {
+        public string Filter {
+            get {
+                return this.filterField;
+            set {
+                if ((this.filterField != null)) {
+                    if ((filterField.Equals(value) != true)) {
+                        this.filterField = value;
+                        this.OnPropertyChanged("Filter");
+                else {
+        public string Icon {
+            get {
+                return this.iconField;
+            set {
+                if ((this.iconField != null)) {
+                    if ((iconField.Equals(value) != true)) {
+                        this.iconField = value;
+                        this.OnPropertyChanged("Icon");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(RuleInfo));
+        /// <summary>
+        /// Serializes current RuleInfo object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an RuleInfo object
+        /// </summary>
+        /// <param name="obj">Output RuleInfo object</param>
+        public static bool Deserialize(string xml, out RuleInfo obj, out System.Exception exception) {
+            exception = null;
+            obj = default(RuleInfo);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out RuleInfo obj) {
+        public static RuleInfo Deserialize(string xml) {
+            try {
+                return ((RuleInfo)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current RuleInfo object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an RuleInfo object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out RuleInfo obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out RuleInfo obj) {
+        public static RuleInfo LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this RuleInfo object
+        /// </summary>
+        public virtual RuleInfo Clone() {
+            return ((RuleInfo)(this.MemberwiseClone()));
+        #endregion
+    public partial class FeatureStyleInfo : System.ComponentModel.INotifyPropertyChanged {
+        private string typeField;
+        private BindingList<RuleInfo> ruleField;
+        [System.Xml.Serialization.XmlElementAttribute(DataType="integer")]
+        public string Type {
+            get {
+                return this.typeField;
+            set {
+                if ((this.typeField != null)) {
+                    if ((typeField.Equals(value) != true)) {
+                        this.typeField = value;
+                        this.OnPropertyChanged("Type");
+                else {
+        [System.Xml.Serialization.XmlElementAttribute("Rule")]
+        public BindingList<RuleInfo> Rule {
+            get {
+                return this.ruleField;
+            set {
+                if ((this.ruleField != null)) {
+                    if ((ruleField.Equals(value) != true)) {
+                        this.ruleField = value;
+                        this.OnPropertyChanged("Rule");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(FeatureStyleInfo));
+        /// <summary>
+        /// Serializes current FeatureStyleInfo object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an FeatureStyleInfo object
+        /// </summary>
+        /// <param name="obj">Output FeatureStyleInfo object</param>
+        public static bool Deserialize(string xml, out FeatureStyleInfo obj, out System.Exception exception) {
+            exception = null;
+            obj = default(FeatureStyleInfo);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out FeatureStyleInfo obj) {
+        public static FeatureStyleInfo Deserialize(string xml) {
+            try {
+                return ((FeatureStyleInfo)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current FeatureStyleInfo object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an FeatureStyleInfo object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out FeatureStyleInfo obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out FeatureStyleInfo obj) {
+        public static FeatureStyleInfo LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this FeatureStyleInfo object
+        /// </summary>
+        public virtual FeatureStyleInfo Clone() {
+            return ((FeatureStyleInfo)(this.MemberwiseClone()));
+        #endregion
+    public partial class ScaleRangeInfo : System.ComponentModel.INotifyPropertyChanged {
+        private double minScaleField;
+        private double maxScaleField;
+        private BindingList<FeatureStyleInfo> featureStyleField;
+        public double MinScale {
+            get {
+                return this.minScaleField;
+            set {
+                if ((minScaleField.Equals(value) != true)) {
+                    this.minScaleField = value;
+                    this.OnPropertyChanged("MinScale");
+        public double MaxScale {
+            get {
+                return this.maxScaleField;
+            set {
+                if ((maxScaleField.Equals(value) != true)) {
+                    this.maxScaleField = value;
+                    this.OnPropertyChanged("MaxScale");
+        [System.Xml.Serialization.XmlElementAttribute("FeatureStyle")]
+        public BindingList<FeatureStyleInfo> FeatureStyle {
+            get {
+                return this.featureStyleField;
+            set {
+                if ((this.featureStyleField != null)) {
+                    if ((featureStyleField.Equals(value) != true)) {
+                        this.featureStyleField = value;
+                        this.OnPropertyChanged("FeatureStyle");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(ScaleRangeInfo));
+        /// <summary>
+        /// Serializes current ScaleRangeInfo object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an ScaleRangeInfo object
+        /// </summary>
+        /// <param name="obj">Output ScaleRangeInfo object</param>
+        public static bool Deserialize(string xml, out ScaleRangeInfo obj, out System.Exception exception) {
+            exception = null;
+            obj = default(ScaleRangeInfo);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out ScaleRangeInfo obj) {
+        public static ScaleRangeInfo Deserialize(string xml) {
+            try {
+                return ((ScaleRangeInfo)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current ScaleRangeInfo object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an ScaleRangeInfo object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out ScaleRangeInfo obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out ScaleRangeInfo obj) {
+        public static ScaleRangeInfo LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this ScaleRangeInfo object
+        /// </summary>
+        public virtual ScaleRangeInfo Clone() {
+            return ((ScaleRangeInfo)(this.MemberwiseClone()));
+        #endregion
+    public partial class FeatureSourceInfo : System.ComponentModel.INotifyPropertyChanged {
+        private string classNameField;
+        private string geometryField;
+            get {
+            set {
+                else {
+        public string ClassName {
+            get {
+                return this.classNameField;
+            set {
+                if ((this.classNameField != null)) {
+                    if ((classNameField.Equals(value) != true)) {
+                        this.classNameField = value;
+                        this.OnPropertyChanged("ClassName");
+                else {
+        public string Geometry {
+            get {
+                return this.geometryField;
+            set {
+                if ((this.geometryField != null)) {
+                    if ((geometryField.Equals(value) != true)) {
+                        this.geometryField = value;
+                        this.OnPropertyChanged("Geometry");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(FeatureSourceInfo));
+        /// <summary>
+        /// Serializes current FeatureSourceInfo object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an FeatureSourceInfo object
+        /// </summary>
+        /// <param name="obj">Output FeatureSourceInfo object</param>
+        public static bool Deserialize(string xml, out FeatureSourceInfo obj, out System.Exception exception) {
+            exception = null;
+            obj = default(FeatureSourceInfo);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out FeatureSourceInfo obj) {
+        public static FeatureSourceInfo Deserialize(string xml) {
+            try {
+                return ((FeatureSourceInfo)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current FeatureSourceInfo object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an FeatureSourceInfo object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out FeatureSourceInfo obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out FeatureSourceInfo obj) {
+        public static FeatureSourceInfo LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this FeatureSourceInfo object
+        /// </summary>
+        public virtual FeatureSourceInfo Clone() {
+            return ((FeatureSourceInfo)(this.MemberwiseClone()));
+        #endregion
+    public partial class RuntimeMapLayer : System.ComponentModel.INotifyPropertyChanged {
+        private string objectIdField;
+        private string parentIdField;
+        private bool displayInLegendField;
+        private bool actuallyVisibleField;
+        private string layerDefinitionField;
+        private FeatureSourceInfo featureSourceField;
+        private BindingList<ScaleRangeInfo> scaleRangeField;
+        /// <summary>
+        /// The name of the layer
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// The type of this layer. Can be tiled or dynamic. Uses the value of MgLayerType
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// The layer's legend label
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// The layer's unique id. Use this value for turning on/off this layer in a GETDYNAMICMAPOVERLAYIMAGE request
+        /// </summary>
+        public string ObjectId {
+            get {
+                return this.objectIdField;
+            set {
+                if ((this.objectIdField != null)) {
+                    if ((objectIdField.Equals(value) != true)) {
+                        this.objectIdField = value;
+                        this.OnPropertyChanged("ObjectId");
+                else {
+        /// <summary>
+        /// The layer's parent group id. Use this value for determining parent-child relationships when building a layer/group hierarchy
+        /// </summary>
+        public string ParentId {
+            get {
+                return this.parentIdField;
+            set {
+                if ((this.parentIdField != null)) {
+                    if ((parentIdField.Equals(value) != true)) {
+                        this.parentIdField = value;
+                        this.OnPropertyChanged("ParentId");
+                else {
+        /// <summary>
+        /// Indicates whether this layer should be displayed in the legend
+        /// </summary>
+        public bool DisplayInLegend {
+            get {
+                return this.displayInLegendField;
+            set {
+                if ((displayInLegendField.Equals(value) != true)) {
+                    this.displayInLegendField = value;
+                    this.OnPropertyChanged("DisplayInLegend");
+        /// <summary>
+        /// Indicates whether this layer should be initially expanded (if layer is themed) in the legend
+        /// </summary>
+            get {
+            set {
+        /// <summary>
+        /// Indicates whether this layer is potentially visible. Note that this may be true even though the layer is not visible. This will occur if the visible flag of one of the groups this layer is organized within is not visible or when the current viewScale property of the map is outside the scale ranges defined for this layer.
+        /// </summary>
+            get {
+            set {
+        /// <summary>
+        /// Indicates the actual visibility of the layer. The visibility depends on the visible property of the group, and the visible property of each group this group is organized within.
+        /// </summary>
+        public bool ActuallyVisible {
+            get {
+                return this.actuallyVisibleField;
+            set {
+                if ((actuallyVisibleField.Equals(value) != true)) {
+                    this.actuallyVisibleField = value;
+                    this.OnPropertyChanged("ActuallyVisible");
+        /// <summary>
+        /// The Layer Definition from which this runtime layer was created from
+        /// </summary>
+        public string LayerDefinition {
+            get {
+                return this.layerDefinitionField;
+            set {
+                if ((this.layerDefinitionField != null)) {
+                    if ((layerDefinitionField.Equals(value) != true)) {
+                        this.layerDefinitionField = value;
+                        this.OnPropertyChanged("LayerDefinition");
+                else {
+        public FeatureSourceInfo FeatureSource {
+            get {
+                return this.featureSourceField;
+            set {
+                if ((this.featureSourceField != null)) {
+                    if ((featureSourceField.Equals(value) != true)) {
+                        this.featureSourceField = value;
+                        this.OnPropertyChanged("FeatureSource");
+                else {
+        [System.Xml.Serialization.XmlElementAttribute("ScaleRange")]
+        public BindingList<ScaleRangeInfo> ScaleRange {
+            get {
+                return this.scaleRangeField;
+            set {
+                if ((this.scaleRangeField != null)) {
+                    if ((scaleRangeField.Equals(value) != true)) {
+                        this.scaleRangeField = value;
+                        this.OnPropertyChanged("ScaleRange");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(RuntimeMapLayer));
+        /// <summary>
+        /// Serializes current RuntimeMapLayer object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an RuntimeMapLayer object
+        /// </summary>
+        /// <param name="obj">Output RuntimeMapLayer object</param>
+        public static bool Deserialize(string xml, out RuntimeMapLayer obj, out System.Exception exception) {
+            exception = null;
+            obj = default(RuntimeMapLayer);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out RuntimeMapLayer obj) {
+        public static RuntimeMapLayer Deserialize(string xml) {
+            try {
+                return ((RuntimeMapLayer)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current RuntimeMapLayer object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an RuntimeMapLayer object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out RuntimeMapLayer obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out RuntimeMapLayer obj) {
+        public static RuntimeMapLayer LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this RuntimeMapLayer object
+        /// </summary>
+        public virtual RuntimeMapLayer Clone() {
+            return ((RuntimeMapLayer)(this.MemberwiseClone()));
+        #endregion
+    [System.Xml.Serialization.XmlRootAttribute(Namespace="", IsNullable=true)]
+    public partial class RuntimeMapGroup : System.ComponentModel.INotifyPropertyChanged {
+        /// <summary>
+        /// The name of the group
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// The type of this group. Can be tiled or dynamic. Uses the value of MgLayerGroupType
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// The group's legend label
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// The group's unique id. Use this value for turning on/off this group in a GETDYNAMICMAPOVERLAYIMAGE request
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// The group's parent group id. Use this value for determining parent-child relationships when building a layer/group hierarchy
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// Indicates whether this group should be displayed in the legend
+        /// </summary>
+            get {
+            set {
+        /// <summary>
+        /// Indicates whether this group should be initially expanded in the legend
+        /// </summary>
+            get {
+            set {
+        /// <summary>
+        /// Indicates whether this group is potentially visible. Note that this may be true even though the group is not visible. This will occur if one of the groups this group is organized within is not visible.
+        /// </summary>
+            get {
+            set {
+        /// <summary>
+        /// Indicates the actual visibility of the group. The visibility depends on the visible property of the group, and the visible property of each group this group is organized within.
+        /// </summary>
+            get {
+            set {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(RuntimeMapGroup));
+        /// <summary>
+        /// Serializes current RuntimeMapGroup object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an RuntimeMapGroup object
+        /// </summary>
+        /// <param name="obj">Output RuntimeMapGroup object</param>
+        public static bool Deserialize(string xml, out RuntimeMapGroup obj, out System.Exception exception) {
+            exception = null;
+            obj = default(RuntimeMapGroup);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out RuntimeMapGroup obj) {
+        public static RuntimeMapGroup Deserialize(string xml) {
+            try {
+                return ((RuntimeMapGroup)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current RuntimeMapGroup object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an RuntimeMapGroup object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out RuntimeMapGroup obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out RuntimeMapGroup obj) {
+        public static RuntimeMapGroup LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this RuntimeMapGroup object
+        /// </summary>
+        public virtual RuntimeMapGroup Clone() {
+            return ((RuntimeMapGroup)(this.MemberwiseClone()));
+        #endregion
+    public partial class Envelope : System.ComponentModel.INotifyPropertyChanged {
+        private EnvelopeLowerLeftCoordinate lowerLeftCoordinateField;
+        private EnvelopeUpperRightCoordinate upperRightCoordinateField;
+        public EnvelopeLowerLeftCoordinate LowerLeftCoordinate {
+            get {
+                return this.lowerLeftCoordinateField;
+            set {
+                if ((this.lowerLeftCoordinateField != null)) {
+                    if ((lowerLeftCoordinateField.Equals(value) != true)) {
+                        this.lowerLeftCoordinateField = value;
+                        this.OnPropertyChanged("LowerLeftCoordinate");
+                else {
+        public EnvelopeUpperRightCoordinate UpperRightCoordinate {
+            get {
+                return this.upperRightCoordinateField;
+            set {
+                if ((this.upperRightCoordinateField != null)) {
+                    if ((upperRightCoordinateField.Equals(value) != true)) {
+                        this.upperRightCoordinateField = value;
+                        this.OnPropertyChanged("UpperRightCoordinate");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(Envelope));
+        /// <summary>
+        /// Serializes current Envelope object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an Envelope object
+        /// </summary>
+        /// <param name="obj">Output Envelope object</param>
+        public static bool Deserialize(string xml, out Envelope obj, out System.Exception exception) {
+            exception = null;
+            obj = default(Envelope);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out Envelope obj) {
+        public static Envelope Deserialize(string xml) {
+            try {
+                return ((Envelope)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current Envelope object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an Envelope object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out Envelope obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out Envelope obj) {
+        public static Envelope LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this Envelope object
+        /// </summary>
+        public virtual Envelope Clone() {
+            return ((Envelope)(this.MemberwiseClone()));
+        #endregion
+    public partial class EnvelopeLowerLeftCoordinate : System.ComponentModel.INotifyPropertyChanged {
+        private double xField;
+        private double yField;
+        [System.Xml.Serialization.XmlElementAttribute(DataType = "double")]
+        public double X {
+            get {
+                return this.xField;
+            set {
+                if ((xField.Equals(value) != true))
+                    this.xField = value;
+                    this.OnPropertyChanged("X");
+        public double Y {
+            get {
+                return this.yField;
+            set {
+                if ((yField.Equals(value) != true))
+                    this.yField = value;
+                    this.OnPropertyChanged("Y");
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(EnvelopeLowerLeftCoordinate));
+        /// <summary>
+        /// Serializes current EnvelopeLowerLeftCoordinate object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an EnvelopeLowerLeftCoordinate object
+        /// </summary>
+        /// <param name="obj">Output EnvelopeLowerLeftCoordinate object</param>
+        public static bool Deserialize(string xml, out EnvelopeLowerLeftCoordinate obj, out System.Exception exception) {
+            exception = null;
+            obj = default(EnvelopeLowerLeftCoordinate);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out EnvelopeLowerLeftCoordinate obj) {
+        public static EnvelopeLowerLeftCoordinate Deserialize(string xml) {
+            try {
+                return ((EnvelopeLowerLeftCoordinate)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current EnvelopeLowerLeftCoordinate object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an EnvelopeLowerLeftCoordinate object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out EnvelopeLowerLeftCoordinate obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out EnvelopeLowerLeftCoordinate obj) {
+        public static EnvelopeLowerLeftCoordinate LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this EnvelopeLowerLeftCoordinate object
+        /// </summary>
+        public virtual EnvelopeLowerLeftCoordinate Clone() {
+            return ((EnvelopeLowerLeftCoordinate)(this.MemberwiseClone()));
+        #endregion
+    public partial class EnvelopeUpperRightCoordinate : System.ComponentModel.INotifyPropertyChanged {
+        public double X {
+            get {
+            set {
+        public double Y {
+            get {
+            set {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(EnvelopeUpperRightCoordinate));
+        /// <summary>
+        /// Serializes current EnvelopeUpperRightCoordinate object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an EnvelopeUpperRightCoordinate object
+        /// </summary>
+        /// <param name="obj">Output EnvelopeUpperRightCoordinate object</param>
+        public static bool Deserialize(string xml, out EnvelopeUpperRightCoordinate obj, out System.Exception exception) {
+            exception = null;
+            obj = default(EnvelopeUpperRightCoordinate);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out EnvelopeUpperRightCoordinate obj) {
+        public static EnvelopeUpperRightCoordinate Deserialize(string xml) {
+            try {
+                return ((EnvelopeUpperRightCoordinate)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current EnvelopeUpperRightCoordinate object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an EnvelopeUpperRightCoordinate object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out EnvelopeUpperRightCoordinate obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out EnvelopeUpperRightCoordinate obj) {
+        public static EnvelopeUpperRightCoordinate LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this EnvelopeUpperRightCoordinate object
+        /// </summary>
+        public virtual EnvelopeUpperRightCoordinate Clone() {
+            return ((EnvelopeUpperRightCoordinate)(this.MemberwiseClone()));
+        #endregion
Added: trunk/Tools/Maestro/Generated/TileProviderList-3.0.0.designer.cs
--- trunk/Tools/Maestro/Generated/TileProviderList-3.0.0.designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Generated/TileProviderList-3.0.0.designer.cs	2014-12-29 13:18:49 UTC (rev 8482)
@@ -0,0 +1,818 @@
+//    Generated by Xsd2Code. Version 3.4.0.32989
+//    <NameSpace>OSGeo.MapGuide.ObjectModels.TileProviderList</NameSpace><Collection>BindingList</Collection><codeType>CSharp</codeType><EnableDataBinding>True</EnableDataBinding><EnableLazyLoading>False</EnableLazyLoading><TrackingChangesEnable>False</TrackingChangesEnable><GenTrackingClasses>False</GenTrackingClasses><HidePrivateFieldInIDE>True</HidePrivateFieldInIDE><EnableSummaryComment>True</EnableSummaryComment><VirtualProp>False</VirtualProp><IncludeSerializeMethod>True</IncludeSerializeMethod><UseBaseClass>False</UseBaseClass><GenBaseClass>False</GenBaseClass><GenerateCloneMethod>True</GenerateCloneMethod><GenerateDataContracts>False</GenerateDataContracts><CodeBaseTag>Net20</CodeBaseTag><SerializeMethodName>Serialize</SerializeMethodName><DeserializeMethodName>Deserialize</DeserializeMethodName><SaveToFileMethodName>SaveToFile</SaveToFileMethodName><LoadFromFileMethodName>LoadFromFile</LoadFromFileMethodName><GenerateXMLAttributes>True</GenerateXMLAttributes><OrderX
 MLAttrib>False</OrderXMLAttrib><EnableEncoding>False</EnableEncoding><AutomaticProperties>False</AutomaticProperties><GenerateShouldSerialize>False</GenerateShouldSerialize><DisableDebug>False</DisableDebug><PropNameSpecified>Default</PropNameSpecified><Encoder>UTF8</Encoder><CustomUsings></CustomUsings><ExcludeIncludedTypes>False</ExcludeIncludedTypes><EnableInitializeFields>False</EnableInitializeFields>
+namespace OSGeo.MapGuide.ObjectModels.TileProviderList {
+    using System;
+    using System.IO;
+    using System.Text;
+    /// <summary>
+    /// Root element that contains a collection of TileProvider elements.
+    /// </summary>
+    public partial class TileProviderList : System.ComponentModel.INotifyPropertyChanged {
+        private BindingList<TileProviderListTileProvider> tileProviderField;
+        /// <summary>
+        /// Describes an installed tile provider.
+        /// </summary>
+        [System.Xml.Serialization.XmlElementAttribute("TileProvider")]
+        public BindingList<TileProviderListTileProvider> TileProvider {
+            get {
+                return this.tileProviderField;
+            set {
+                if ((this.tileProviderField != null)) {
+                    if ((tileProviderField.Equals(value) != true)) {
+                        this.tileProviderField = value;
+                        this.OnPropertyChanged("TileProvider");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(TileProviderList));
+        /// <summary>
+        /// Serializes current TileProviderList object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an TileProviderList object
+        /// </summary>
+        /// <param name="obj">Output TileProviderList object</param>
+        public static bool Deserialize(string xml, out TileProviderList obj, out System.Exception exception) {
+            exception = null;
+            obj = default(TileProviderList);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out TileProviderList obj) {
+        public static TileProviderList Deserialize(string xml) {
+            try {
+                return ((TileProviderList)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current TileProviderList object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an TileProviderList object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out TileProviderList obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out TileProviderList obj) {
+        public static TileProviderList LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this TileProviderList object
+        /// </summary>
+        public virtual TileProviderList Clone() {
+            return ((TileProviderList)(this.MemberwiseClone()));
+        #endregion
+    /// <summary>
+    /// </summary>
+    public partial class TileProviderListTileProvider : System.ComponentModel.INotifyPropertyChanged {
+        private string displayNameField;
+        private string descriptionField;
+        private BindingList<TileProviderListTileProviderConnectionProperty> connectionPropertiesField;
+        /// <summary>
+        /// Unique name of the feature provider. This name should be of the form <Company>.<Provider>.lt;Version>.
+        /// </summary>
+            get {
+            set {
+                else {
+        /// <summary>
+        /// A user friendly display name of the feature provider.
+        /// </summary>
+        public string DisplayName {
+            get {
+                return this.displayNameField;
+            set {
+                if ((this.displayNameField != null)) {
+                    if ((displayNameField.Equals(value) != true)) {
+                        this.displayNameField = value;
+                        this.OnPropertyChanged("DisplayName");
+                else {
+        /// <summary>
+        /// A brief description of the feature provider.
+        /// </summary>
+        public string Description {
+            get {
+                return this.descriptionField;
+            set {
+                if ((this.descriptionField != null)) {
+                    if ((descriptionField.Equals(value) != true)) {
+                        this.descriptionField = value;
+                        this.OnPropertyChanged("Description");
+                else {
+        /// <summary>
+        /// Connection properties for each provider with default values will be listed here.
+        /// </summary>
+        [System.Xml.Serialization.XmlArrayItemAttribute("ConnectionProperty", IsNullable=false)]
+        public BindingList<TileProviderListTileProviderConnectionProperty> ConnectionProperties {
+            get {
+                return this.connectionPropertiesField;
+            set {
+                if ((this.connectionPropertiesField != null)) {
+                    if ((connectionPropertiesField.Equals(value) != true)) {
+                        this.connectionPropertiesField = value;
+                        this.OnPropertyChanged("ConnectionProperties");
+                else {
+        private static System.Xml.Serialization.XmlSerializer Serializer {
+            get {
+                if ((serializer == null)) {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(TileProviderListTileProvider));
+                return serializer;
+        public event System.ComponentModel.PropertyChangedEventHandler PropertyChanged;
+        public virtual void OnPropertyChanged(string propertyName) {
+            System.ComponentModel.PropertyChangedEventHandler handler = this.PropertyChanged;
+            if ((handler != null)) {
+                handler(this, new System.ComponentModel.PropertyChangedEventArgs(propertyName));
+        #region Serialize/Deserialize
+        /// <summary>
+        /// Serializes current TileProviderListTileProvider object into an XML document
+        /// </summary>
+        /// <returns>string XML value</returns>
+        public virtual string Serialize() {
+            System.IO.StreamReader streamReader = null;
+            System.IO.MemoryStream memoryStream = null;
+            try {
+                memoryStream = new System.IO.MemoryStream();
+                Serializer.Serialize(memoryStream, this);
+                memoryStream.Seek(0, System.IO.SeekOrigin.Begin);
+                streamReader = new System.IO.StreamReader(memoryStream);
+                return streamReader.ReadToEnd();
+            finally {
+                if ((streamReader != null)) {
+                    streamReader.Dispose();
+                if ((memoryStream != null)) {
+                    memoryStream.Dispose();
+        /// <summary>
+        /// Deserializes workflow markup into an TileProviderListTileProvider object
+        /// </summary>
+        /// <param name="xml">string workflow markup to deserialize</param>
+        /// <param name="obj">Output TileProviderListTileProvider object</param>
+        /// <param name="exception">output Exception value if deserialize failed</param>
+        /// <returns>true if this XmlSerializer can deserialize the object; otherwise, false</returns>
+        public static bool Deserialize(string xml, out TileProviderListTileProvider obj, out System.Exception exception) {
+            exception = null;
+            obj = default(TileProviderListTileProvider);
+            try {
+                obj = Deserialize(xml);
+                return true;
+            catch (System.Exception ex) {
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out TileProviderListTileProvider obj) {
+            System.Exception exception = null;
+            return Deserialize(xml, out obj, out exception);
+        public static TileProviderListTileProvider Deserialize(string xml) {
+            System.IO.StringReader stringReader = null;
+            try {
+                stringReader = new System.IO.StringReader(xml);
+                return ((TileProviderListTileProvider)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+                if ((stringReader != null)) {
+                    stringReader.Dispose();
+        /// <summary>
+        /// Serializes current TileProviderListTileProvider object into file
+        /// </summary>
+        /// <param name="fileName">full path of outupt xml file</param>
+        /// <param name="exception">output Exception value if failed</param>
+        /// <returns>true if can serialize and save into file; otherwise, false</returns>
+        public virtual bool SaveToFile(string fileName, out System.Exception exception) {
+            exception = null;
+            try {
+                SaveToFile(fileName);
+                return true;
+            catch (System.Exception e) {
+                exception = e;
+                return false;
+        public virtual void SaveToFile(string fileName) {
+            System.IO.StreamWriter streamWriter = null;
+            try {
+                string xmlString = Serialize();
+                System.IO.FileInfo xmlFile = new System.IO.FileInfo(fileName);
+                streamWriter = xmlFile.CreateText();
+                streamWriter.WriteLine(xmlString);
+                streamWriter.Close();
+            finally {
+                if ((streamWriter != null)) {
+                    streamWriter.Dispose();
+        /// <summary>
+        /// Deserializes xml markup from file into an TileProviderListTileProvider object
+        /// </summary>
+        /// <param name="fileName">string xml file to load and deserialize</param>
+        public static bool LoadFromFile(string fileName, out TileProviderListTileProvider obj, out System.Exception exception) {
+            exception = null;
+            try {
+                obj = LoadFromFile(fileName);
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out TileProviderListTileProvider obj) {
+            return LoadFromFile(fileName, out obj, out exception);
+        public static TileProviderListTileProvider LoadFromFile(string fileName) {
+            System.IO.FileStream file = null;
+            System.IO.StreamReader sr = null;
+            try {
+                file = new System.IO.FileStream(fileName, FileMode.Open, FileAccess.Read);
+                sr = new System.IO.StreamReader(file);
+                string xmlString = sr.ReadToEnd();
+                sr.Close();
+                file.Close();
+                return Deserialize(xmlString);
+            finally {
+                if ((file != null)) {
+                    file.Dispose();
+                if ((sr != null)) {
+                    sr.Dispose();
+        #endregion
+        #region Clone method
+        /// <summary>
+        /// Create a clone of this TileProviderListTileProvider object
+        /// </summary>
+        public virtual TileProviderListTileProvider Clone() {
+            return ((TileProviderListTileProvider)(this.MemberwiseClone()));
+        #endregion
+    [System.CodeDom.Compiler.GeneratedCodeAttribute("Xsd2Code", "3.4.0.32990")]
+    [System.SerializableAttribute()]
+    [System.ComponentModel.DesignerCategoryAttribute("code")]
+    public partial class TileProviderListTileProviderConnectionProperty : System.ComponentModel.INotifyPropertyChanged {
+        [EditorBrowsable(EditorBrowsableState.Never)]
+        private string localizedNameField;
+        private string defaultValueField;
+        private BindingList<string> valueField;
+        private bool requiredField;
+        private bool protectedField;
+        private bool enumerableField;
+        private static System.Xml.Serialization.XmlSerializer serializer;
+            get {
+            set {
+                else {
+        public string LocalizedName {
+            get {
+                return this.localizedNameField;
+            set {
+                if ((this.localizedNameField != null)) {
+                    if ((localizedNameField.Equals(value) != true)) {
+                        this.localizedNameField = value;
+                        this.OnPropertyChanged("LocalizedName");
+                else {
+        public string DefaultValue {
+            get {
+                return this.defaultValueField;
+            set {
+                if ((this.defaultValueField != null)) {
+                    if ((defaultValueField.Equals(value) != true)) {
+                        this.defaultValueField = value;
+                        this.OnPropertyChanged("DefaultValue");
+                else {
+        [System.Xml.Serialization.XmlElementAttribute("Value")]
+        public BindingList<string> Value {
+            get {
+                return this.valueField;
+            set {
+                if ((this.valueField != null)) {
+                    if ((valueField.Equals(value) != true)) {
+                        this.valueField = value;
+                        this.OnPropertyChanged("Value");
+                else {
+        [System.Xml.Serialization.XmlAttributeAttribute()]
+        public bool Required {
+            get {
+                return this.requiredField;
+            set {
+                if ((requiredField.Equals(value) != true)) {
+                    this.requiredField = value;
+                    this.OnPropertyChanged("Required");
+        public bool Protected {
+            get {
+                return this.protectedField;
+            set {
+                if ((protectedField.Equals(value) != true)) {
+                    this.protectedField = value;
+                    this.OnPropertyChanged("Protected");
+        public bool Enumerable {
+            get {
+                return this.enumerableField;
+            set {
+                if ((enumerableField.Equals(value) != true)) {
+                    this.enumerableField = value;
+                    this.OnPropertyChanged("Enumerable");
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(TileProviderListTileProviderConnectionProperty));
+        /// <summary>
+        /// Serializes current TileProviderListTileProviderConnectionProperty object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an TileProviderListTileProviderConnectionProperty object
+        /// </summary>
+        /// <param name="obj">Output TileProviderListTileProviderConnectionProperty object</param>
+        public static bool Deserialize(string xml, out TileProviderListTileProviderConnectionProperty obj, out System.Exception exception) {
+            exception = null;
+            obj = default(TileProviderListTileProviderConnectionProperty);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out TileProviderListTileProviderConnectionProperty obj) {
+        public static TileProviderListTileProviderConnectionProperty Deserialize(string xml) {
+            try {
+                return ((TileProviderListTileProviderConnectionProperty)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current TileProviderListTileProviderConnectionProperty object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an TileProviderListTileProviderConnectionProperty object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out TileProviderListTileProviderConnectionProperty obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out TileProviderListTileProviderConnectionProperty obj) {
+        public static TileProviderListTileProviderConnectionProperty LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this TileProviderListTileProviderConnectionProperty object
+        /// </summary>
+        public virtual TileProviderListTileProviderConnectionProperty Clone() {
+            return ((TileProviderListTileProviderConnectionProperty)(this.MemberwiseClone()));
+        #endregion
Added: trunk/Tools/Maestro/Generated/TileSetDefinition-3.0.0.designer.cs
--- trunk/Tools/Maestro/Generated/TileSetDefinition-3.0.0.designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Generated/TileSetDefinition-3.0.0.designer.cs	2014-12-29 13:18:49 UTC (rev 8482)
@@ -0,0 +1,1939 @@
+//    <NameSpace>OSGeo.MapGuide.ObjectModels.TileSetDefinition</NameSpace><Collection>BindingList</Collection><codeType>CSharp</codeType><EnableDataBinding>True</EnableDataBinding><EnableLazyLoading>False</EnableLazyLoading><TrackingChangesEnable>False</TrackingChangesEnable><GenTrackingClasses>False</GenTrackingClasses><HidePrivateFieldInIDE>True</HidePrivateFieldInIDE><EnableSummaryComment>True</EnableSummaryComment><VirtualProp>False</VirtualProp><IncludeSerializeMethod>True</IncludeSerializeMethod><UseBaseClass>False</UseBaseClass><GenBaseClass>False</GenBaseClass><GenerateCloneMethod>True</GenerateCloneMethod><GenerateDataContracts>False</GenerateDataContracts><CodeBaseTag>Net20</CodeBaseTag><SerializeMethodName>Serialize</SerializeMethodName><DeserializeMethodName>Deserialize</DeserializeMethodName><SaveToFileMethodName>SaveToFile</SaveToFileMethodName><LoadFromFileMethodName>LoadFromFile</LoadFromFileMethodName><GenerateXMLAttributes>True</GenerateXMLAttributes><Order
 XMLAttrib>False</OrderXMLAttrib><EnableEncoding>False</EnableEncoding><AutomaticProperties>False</AutomaticProperties><GenerateShouldSerialize>False</GenerateShouldSerialize><DisableDebug>False</DisableDebug><PropNameSpecified>Default</PropNameSpecified><Encoder>UTF8</Encoder><CustomUsings></CustomUsings><ExcludeIncludedTypes>False</ExcludeIncludedTypes><EnableInitializeFields>False</EnableInitializeFields>
+namespace OSGeo.MapGuide.ObjectModels.TileSetDefinition {
+    using System;
+    using System.IO;
+    /// <summary>
+    /// Defines a tile cache
+    /// </summary>
+    public partial class TileSetDefinition : System.ComponentModel.INotifyPropertyChanged {
+        private TileStoreParametersType tileStoreParametersField;
+        private Box2DType extentsField;
+        private BindingList<BaseMapLayerGroupCommonType> baseMapLayerGroupField;
+        /// <summary>
+        /// Defines the parameters to access and describe the tile cache
+        /// </summary>
+        public TileStoreParametersType TileStoreParameters {
+            get {
+                return this.tileStoreParametersField;
+            set {
+                if ((this.tileStoreParametersField != null)) {
+                    if ((tileStoreParametersField.Equals(value) != true)) {
+                        this.tileStoreParametersField = value;
+                        this.OnPropertyChanged("TileStoreParameters");
+                else {
+        /// <summary>
+        /// A bounding box around the area of the tile cache
+        /// </summary>
+        public Box2DType Extents {
+            get {
+                return this.extentsField;
+            set {
+                if ((this.extentsField != null)) {
+                    if ((extentsField.Equals(value) != true)) {
+                        this.extentsField = value;
+                        this.OnPropertyChanged("Extents");
+                else {
+        /// <summary>
+        /// A group of layers that is used to compose a tiled layer in the HTML viewer
+        /// </summary>
+        [System.Xml.Serialization.XmlElementAttribute("BaseMapLayerGroup")]
+        public BindingList<BaseMapLayerGroupCommonType> BaseMapLayerGroup {
+            get {
+                return this.baseMapLayerGroupField;
+            set {
+                if ((this.baseMapLayerGroupField != null)) {
+                    if ((baseMapLayerGroupField.Equals(value) != true)) {
+                        this.baseMapLayerGroupField = value;
+                        this.OnPropertyChanged("BaseMapLayerGroup");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(TileSetDefinition));
+        /// <summary>
+        /// Serializes current TileSetDefinition object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an TileSetDefinition object
+        /// </summary>
+        /// <param name="obj">Output TileSetDefinition object</param>
+        public static bool Deserialize(string xml, out TileSetDefinition obj, out System.Exception exception) {
+            exception = null;
+            obj = default(TileSetDefinition);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out TileSetDefinition obj) {
+        public static TileSetDefinition Deserialize(string xml) {
+            try {
+                return ((TileSetDefinition)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current TileSetDefinition object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an TileSetDefinition object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out TileSetDefinition obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out TileSetDefinition obj) {
+        public static TileSetDefinition LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this TileSetDefinition object
+        /// </summary>
+        public virtual TileSetDefinition Clone() {
+            return ((TileSetDefinition)(this.MemberwiseClone()));
+        #endregion
+    public partial class TileStoreParametersType : System.ComponentModel.INotifyPropertyChanged {
+        private string tileProviderField;
+        private BindingList<NameValuePairType> parameterField;
+        public string TileProvider {
+            get {
+            set {
+                else {
+        [System.Xml.Serialization.XmlElementAttribute("Parameter")]
+        public BindingList<NameValuePairType> Parameter {
+            get {
+                return this.parameterField;
+            set {
+                if ((this.parameterField != null)) {
+                    if ((parameterField.Equals(value) != true)) {
+                        this.parameterField = value;
+                        this.OnPropertyChanged("Parameter");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(TileStoreParametersType));
+        /// <summary>
+        /// Serializes current TileStoreParametersType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an TileStoreParametersType object
+        /// </summary>
+        /// <param name="obj">Output TileStoreParametersType object</param>
+        public static bool Deserialize(string xml, out TileStoreParametersType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(TileStoreParametersType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out TileStoreParametersType obj) {
+        public static TileStoreParametersType Deserialize(string xml) {
+            try {
+                return ((TileStoreParametersType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current TileStoreParametersType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an TileStoreParametersType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out TileStoreParametersType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out TileStoreParametersType obj) {
+        public static TileStoreParametersType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this TileStoreParametersType object
+        /// </summary>
+        public virtual TileStoreParametersType Clone() {
+            return ((TileStoreParametersType)(this.MemberwiseClone()));
+        #endregion
+    public partial class NameValuePairType : System.ComponentModel.INotifyPropertyChanged {
+        private string nameField;
+        private string valueField;
+        private ExtendedDataType extendedData1Field;
+        public string Name {
+            get {
+                return this.nameField;
+            set {
+                if ((this.nameField != null)) {
+                    if ((nameField.Equals(value) != true)) {
+                        this.nameField = value;
+                        this.OnPropertyChanged("Name");
+                else {
+        public string Value {
+            get {
+            set {
+                else {
+        public ExtendedDataType ExtendedData1 {
+            get {
+                return this.extendedData1Field;
+            set {
+                if ((this.extendedData1Field != null)) {
+                    if ((extendedData1Field.Equals(value) != true)) {
+                        this.extendedData1Field = value;
+                        this.OnPropertyChanged("ExtendedData1");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(NameValuePairType));
+        /// <summary>
+        /// Serializes current NameValuePairType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an NameValuePairType object
+        /// </summary>
+        /// <param name="obj">Output NameValuePairType object</param>
+        public static bool Deserialize(string xml, out NameValuePairType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(NameValuePairType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out NameValuePairType obj) {
+        public static NameValuePairType Deserialize(string xml) {
+            try {
+                return ((NameValuePairType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current NameValuePairType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an NameValuePairType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out NameValuePairType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out NameValuePairType obj) {
+        public static NameValuePairType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this NameValuePairType object
+        /// </summary>
+        public virtual NameValuePairType Clone() {
+            return ((NameValuePairType)(this.MemberwiseClone()));
+        #endregion
+    public partial class ExtendedDataType : System.ComponentModel.INotifyPropertyChanged {
+        private BindingList<System.Xml.XmlElement> anyField;
+        [System.Xml.Serialization.XmlAnyElementAttribute()]
+        public BindingList<System.Xml.XmlElement> Any {
+            get {
+                return this.anyField;
+            set {
+                if ((this.anyField != null)) {
+                    if ((anyField.Equals(value) != true)) {
+                        this.anyField = value;
+                        this.OnPropertyChanged("Any");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(ExtendedDataType));
+        /// <summary>
+        /// Serializes current ExtendedDataType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an ExtendedDataType object
+        /// </summary>
+        /// <param name="obj">Output ExtendedDataType object</param>
+        public static bool Deserialize(string xml, out ExtendedDataType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(ExtendedDataType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out ExtendedDataType obj) {
+        public static ExtendedDataType Deserialize(string xml) {
+            try {
+                return ((ExtendedDataType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current ExtendedDataType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an ExtendedDataType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out ExtendedDataType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out ExtendedDataType obj) {
+        public static ExtendedDataType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this ExtendedDataType object
+        /// </summary>
+        public virtual ExtendedDataType Clone() {
+            return ((ExtendedDataType)(this.MemberwiseClone()));
+        #endregion
+    public partial class BaseMapLayerType : System.ComponentModel.INotifyPropertyChanged {
+        private string resourceIdField;
+        private bool selectableField;
+        private bool showInLegendField;
+        private string legendLabelField;
+        private bool expandInLegendField;
+            get {
+            set {
+                else {
+        public string ResourceId {
+            get {
+                return this.resourceIdField;
+            set {
+                if ((this.resourceIdField != null)) {
+                    if ((resourceIdField.Equals(value) != true)) {
+                        this.resourceIdField = value;
+                        this.OnPropertyChanged("ResourceId");
+                else {
+        public bool Selectable {
+            get {
+                return this.selectableField;
+            set {
+                if ((selectableField.Equals(value) != true)) {
+                    this.selectableField = value;
+                    this.OnPropertyChanged("Selectable");
+        public bool ShowInLegend {
+            get {
+                return this.showInLegendField;
+            set {
+                if ((showInLegendField.Equals(value) != true)) {
+                    this.showInLegendField = value;
+                    this.OnPropertyChanged("ShowInLegend");
+        public string LegendLabel {
+            get {
+                return this.legendLabelField;
+            set {
+                if ((this.legendLabelField != null)) {
+                    if ((legendLabelField.Equals(value) != true)) {
+                        this.legendLabelField = value;
+                        this.OnPropertyChanged("LegendLabel");
+                else {
+        public bool ExpandInLegend {
+            get {
+                return this.expandInLegendField;
+            set {
+                if ((expandInLegendField.Equals(value) != true)) {
+                    this.expandInLegendField = value;
+                    this.OnPropertyChanged("ExpandInLegend");
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(BaseMapLayerType));
+        /// <summary>
+        /// Serializes current BaseMapLayerType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an BaseMapLayerType object
+        /// </summary>
+        /// <param name="obj">Output BaseMapLayerType object</param>
+        public static bool Deserialize(string xml, out BaseMapLayerType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(BaseMapLayerType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out BaseMapLayerType obj) {
+        public static BaseMapLayerType Deserialize(string xml) {
+            try {
+                return ((BaseMapLayerType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current BaseMapLayerType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an BaseMapLayerType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out BaseMapLayerType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out BaseMapLayerType obj) {
+        public static BaseMapLayerType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this BaseMapLayerType object
+        /// </summary>
+        public virtual BaseMapLayerType Clone() {
+            return ((BaseMapLayerType)(this.MemberwiseClone()));
+        #endregion
+    [System.Xml.Serialization.XmlIncludeAttribute(typeof(BaseMapLayerGroupCommonType))]
+    public partial class MapLayerGroupCommonType : System.ComponentModel.INotifyPropertyChanged {
+        private bool visibleField;
+            get {
+            set {
+                else {
+        public bool Visible {
+            get {
+                return this.visibleField;
+            set {
+                if ((visibleField.Equals(value) != true)) {
+                    this.visibleField = value;
+                    this.OnPropertyChanged("Visible");
+            get {
+            set {
+            get {
+            set {
+            get {
+            set {
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(MapLayerGroupCommonType));
+        /// <summary>
+        /// Serializes current MapLayerGroupCommonType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an MapLayerGroupCommonType object
+        /// </summary>
+        /// <param name="obj">Output MapLayerGroupCommonType object</param>
+        public static bool Deserialize(string xml, out MapLayerGroupCommonType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(MapLayerGroupCommonType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out MapLayerGroupCommonType obj) {
+        public static MapLayerGroupCommonType Deserialize(string xml) {
+            try {
+                return ((MapLayerGroupCommonType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current MapLayerGroupCommonType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an MapLayerGroupCommonType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out MapLayerGroupCommonType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out MapLayerGroupCommonType obj) {
+        public static MapLayerGroupCommonType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this MapLayerGroupCommonType object
+        /// </summary>
+        public virtual MapLayerGroupCommonType Clone() {
+            return ((MapLayerGroupCommonType)(this.MemberwiseClone()));
+        #endregion
+    public partial class BaseMapLayerGroupCommonType : MapLayerGroupCommonType, System.ComponentModel.INotifyPropertyChanged {
+        private BindingList<BaseMapLayerType> baseMapLayerField;
+        [System.Xml.Serialization.XmlElementAttribute("BaseMapLayer")]
+        public BindingList<BaseMapLayerType> BaseMapLayer {
+            get {
+                return this.baseMapLayerField;
+            set {
+                if ((this.baseMapLayerField != null)) {
+                    if ((baseMapLayerField.Equals(value) != true)) {
+                        this.baseMapLayerField = value;
+                        this.OnPropertyChanged("BaseMapLayer");
+                else {
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(BaseMapLayerGroupCommonType));
+        /// <summary>
+        /// Serializes current BaseMapLayerGroupCommonType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an BaseMapLayerGroupCommonType object
+        /// </summary>
+        /// <param name="obj">Output BaseMapLayerGroupCommonType object</param>
+        public static bool Deserialize(string xml, out BaseMapLayerGroupCommonType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(BaseMapLayerGroupCommonType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out BaseMapLayerGroupCommonType obj) {
+        public static BaseMapLayerGroupCommonType Deserialize(string xml) {
+            try {
+                return ((BaseMapLayerGroupCommonType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current BaseMapLayerGroupCommonType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an BaseMapLayerGroupCommonType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out BaseMapLayerGroupCommonType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out BaseMapLayerGroupCommonType obj) {
+        public static BaseMapLayerGroupCommonType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this BaseMapLayerGroupCommonType object
+        /// </summary>
+        public virtual BaseMapLayerGroupCommonType Clone() {
+            return ((BaseMapLayerGroupCommonType)(this.MemberwiseClone()));
+        #endregion
+    public partial class Box2DType : System.ComponentModel.INotifyPropertyChanged {
+        private double minXField;
+        private double maxXField;
+        private double minYField;
+        private double maxYField;
+        public double MinX {
+            get {
+                return this.minXField;
+            set {
+                if ((minXField.Equals(value) != true)) {
+                    this.minXField = value;
+                    this.OnPropertyChanged("MinX");
+        public double MaxX {
+            get {
+                return this.maxXField;
+            set {
+                if ((maxXField.Equals(value) != true)) {
+                    this.maxXField = value;
+                    this.OnPropertyChanged("MaxX");
+        public double MinY {
+            get {
+                return this.minYField;
+            set {
+                if ((minYField.Equals(value) != true)) {
+                    this.minYField = value;
+                    this.OnPropertyChanged("MinY");
+        public double MaxY {
+            get {
+                return this.maxYField;
+            set {
+                if ((maxYField.Equals(value) != true)) {
+                    this.maxYField = value;
+                    this.OnPropertyChanged("MaxY");
+            get {
+                    serializer = new System.Xml.Serialization.XmlSerializer(typeof(Box2DType));
+        /// <summary>
+        /// Serializes current Box2DType object into an XML document
+        /// </summary>
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes workflow markup into an Box2DType object
+        /// </summary>
+        /// <param name="obj">Output Box2DType object</param>
+        public static bool Deserialize(string xml, out Box2DType obj, out System.Exception exception) {
+            exception = null;
+            obj = default(Box2DType);
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool Deserialize(string xml, out Box2DType obj) {
+        public static Box2DType Deserialize(string xml) {
+            try {
+                return ((Box2DType)(Serializer.Deserialize(System.Xml.XmlReader.Create(stringReader))));
+            finally {
+        /// <summary>
+        /// Serializes current Box2DType object into file
+        /// </summary>
+            exception = null;
+            try {
+                return true;
+                exception = e;
+                return false;
+            try {
+            finally {
+        /// <summary>
+        /// Deserializes xml markup from file into an Box2DType object
+        /// </summary>
+        public static bool LoadFromFile(string fileName, out Box2DType obj, out System.Exception exception) {
+            exception = null;
+            try {
+                return true;
+                exception = ex;
+                return false;
+        public static bool LoadFromFile(string fileName, out Box2DType obj) {
+        public static Box2DType LoadFromFile(string fileName) {
+            try {
+                sr.Close();
+                file.Close();
+            finally {
+                    file.Dispose();
+                    sr.Dispose();
+        #endregion
+        /// <summary>
+        /// Create a clone of this Box2DType object
+        /// </summary>
+        public virtual Box2DType Clone() {
+            return ((Box2DType)(this.MemberwiseClone()));
+        #endregion
Modified: trunk/Tools/Maestro/Maestro/Maestro.csproj
--- trunk/Tools/Maestro/Maestro/Maestro.csproj	2014-12-29 10:11:17 UTC (rev 8481)
+++ trunk/Tools/Maestro/Maestro/Maestro.csproj	2014-12-29 13:18:49 UTC (rev 8482)
@@ -263,6 +263,11 @@
       <Link>Schemas\MapDefinition-2.4.0.xsd</Link>
       <CopyToOutputDirectory>Always</CopyToOutputDirectory>
     </None>
+    <None Include="..\OSGeo.MapGuide.MaestroAPI\Schemas\MapDefinition-3.0.0.xsd">
+      <Link>Schemas\MapDefinition-3.0.0.xsd</Link>
+      <SubType>Designer</SubType>
+      <CopyToOutputDirectory>Always</CopyToOutputDirectory>
+    </None>
     <None Include="..\OSGeo.MapGuide.MaestroAPI\Schemas\PlatformCommon-1.0.0.xsd">
       <Link>Schemas\PlatformCommon-1.0.0.xsd</Link>
@@ -319,6 +324,11 @@
       <Link>Schemas\RuntimeMap-2.6.0.xsd</Link>
     </None>
+    <None Include="..\OSGeo.MapGuide.MaestroAPI\Schemas\RuntimeMap-3.0.0.xsd">
+      <Link>Schemas\RuntimeMap-3.0.0.xsd</Link>
+    </None>
     <None Include="..\OSGeo.MapGuide.MaestroAPI\Schemas\SelectAggregate-1.0.0.xsd">
       <Link>Schemas\SelectAggregate-1.0.0.xsd</Link>
@@ -375,6 +385,16 @@
       <Link>Schemas\SymbolLibrary-1.0.0.xsd</Link>
     </None>
+    <None Include="..\OSGeo.MapGuide.MaestroAPI\Schemas\TileProviderList-3.0.0.xsd">
+      <Link>Schemas\TileProviderList-3.0.0.xsd</Link>
+    </None>
+    <None Include="..\OSGeo.MapGuide.MaestroAPI\Schemas\TileSetDefinition-3.0.0.xsd">
+      <Link>Schemas\TileSetDefinition-3.0.0.xsd</Link>
+    </None>
     <None Include="..\OSGeo.MapGuide.MaestroAPI\Schemas\Types-1.0.0.xsd">
       <Link>Schemas\Types-1.0.0.xsd</Link>
@@ -407,6 +427,11 @@
       <Link>Schemas\WebLayout-1.1.0.xsd</Link>
     </None>
+    <None Include="..\OSGeo.MapGuide.MaestroAPI\Schemas\WebLayout-2.4.0.xsd">
+      <Link>Schemas\WebLayout-2.4.0.xsd</Link>
+    </None>
     <None Include="..\OSGeo.MapGuide.MaestroAPI\Schemas\WebLayout-2.6.0.xsd">
       <Link>Schemas\WebLayout-2.6.0.xsd</Link>
Modified: trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj
--- trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj	2014-12-29 10:11:17 UTC (rev 8481)
+++ trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj	2014-12-29 13:18:49 UTC (rev 8482)
@@ -23,6 +23,8 @@
     <OldToolsVersion>3.5</OldToolsVersion>
     <TargetFrameworkProfile>
     </TargetFrameworkProfile>
+    <SolutionDir Condition="$(SolutionDir) == '' Or $(SolutionDir) == '*Undefined*'">..\Maestro\</SolutionDir>
+    <RestorePackages>true</RestorePackages>
     <PublishUrl>publish\</PublishUrl>
     <Install>true</Install>
     <InstallFrom>Disk</InstallFrom>
@@ -37,8 +39,6 @@
     <ApplicationVersion>1.0.0.%2a</ApplicationVersion>
     <UseApplicationTrust>false</UseApplicationTrust>
     <BootstrapperEnabled>true</BootstrapperEnabled>
-    <SolutionDir Condition="$(SolutionDir) == '' Or $(SolutionDir) == '*Undefined*'">..\Maestro\</SolutionDir>
-    <RestorePackages>true</RestorePackages>
   </PropertyGroup>
   <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
     <DebugSymbols>true</DebugSymbols>
@@ -259,6 +259,9 @@
     <None Include="TestData\Symbology\UT_SymbologyRoads.fs">
     </None>
+    <None Include="TestData\TileService\UT_BaseMap.tsd">
+    </None>
     <None Include="TestData\TileService\UT_Parcels.fs">
     </None>
@@ -268,6 +271,9 @@
     <None Include="TestData\TileService\UT_VotingDistricts.fs">
     </None>
+    <None Include="TestData\TileService\UT_XYZ.tsd">
+    </None>
     <None Include="TestData\Unicode\Sample_World_Unicode.FeatureSource">
     </None>
@@ -502,6 +508,9 @@
     <Content Include="TestData\TileService\UT_BaseMap.mdf">
     </Content>
+    <Content Include="TestData\TileService\UT_LinkedTileSet.mdf">
+    </Content>
     <Content Include="TestData\TileService\UT_Parcels.ldf">
     </Content>
Modified: trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs	2014-12-29 10:11:17 UTC (rev 8481)
+++ trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs	2014-12-29 13:18:49 UTC (rev 8482)
@@ -117,6 +117,22 @@
             resSvc.SetResourceXmlData("Library://UnitTests/Data/SpaceShip.DrawingSource", File.OpenRead("TestData/DrawingService/SpaceShipDrawingSource.xml"));
             resSvc.SetResourceData("Library://UnitTests/Data/SpaceShip.DrawingSource", "SpaceShip.dwf", ResourceDataType.File, File.OpenRead("TestData/DrawingService/SpaceShip.dwf"));
+            if (_conn.SiteVersion >= new Version(3, 0))
+                resSvc.SetResourceXmlData("Library://UnitTests/Data/RoadCenterLines.FeatureSource", File.OpenRead("TestData/TileService/UT_RoadCenterLines.fs"));
+                resSvc.SetResourceData("Library://UnitTests/Data/RoadCenterLines.FeatureSource", "RoadCenterLines.sdf", ResourceDataType.File, File.OpenRead("TestData/TileService/UT_RoadCenterLines.sdf"));
+                resSvc.SetResourceXmlData("Library://UnitTests/Layers/RoadCenterLines.LayerDefinition", File.OpenRead("TestData/TileService/UT_RoadCenterLines.ldf"));
+                resSvc.SetResourceXmlData("Library://UnitTests/Data/VotingDistricts.FeatureSource", File.OpenRead("TestData/TileService/UT_VotingDistricts.fs"));
+                resSvc.SetResourceData("Library://UnitTests/Data/VotingDistricts.FeatureSource", "VotingDistricts.sdf", ResourceDataType.File, File.OpenRead("TestData/TileService/UT_VotingDistricts.sdf"));
+                resSvc.SetResourceXmlData("Library://UnitTests/Layers/VotingDistricts.LayerDefinition", File.OpenRead("TestData/TileService/UT_VotingDistricts.ldf"));
+                resSvc.SetResourceXmlData("Library://UnitTests/TileSets/Sheboygan.TileSetDefinition", File.OpenRead("TestData/TileService/UT_BaseMap.tsd"));
+                resSvc.SetResourceXmlData("Library://UnitTests/Maps/SheboyganLinked.MapDefinition", File.OpenRead("TestData/TileService/UT_LinkedTileSet.mdf"));
         [TestFixtureTearDown]
@@ -1341,6 +1357,11 @@
             create.MapDefinition = "Library://UnitTests/Maps/Sheboygan.MapDefinition";
             MapModel.IRuntimeMapInfo rtInfo = create.Execute();
+                Assert.IsInstanceOf<MapModel.IRuntimeMapInfo2>(rtInfo);
             Assert.NotNull(rtInfo.CoordinateSystem);
             Assert.IsNullOrEmpty(rtInfo.IconMimeType);
             Assert.NotNull(rtInfo.Extents);
@@ -1354,6 +1375,10 @@
             create.MapDefinition = "Library://UnitTests/Maps/SheboyganTiled.MapDefinition";
@@ -1370,6 +1395,10 @@
             create.RequestedFeatures = (int)(RuntimeMapRequestedFeatures.LayersAndGroups);
@@ -1389,6 +1418,10 @@
             create.RequestedFeatures = (int)(RuntimeMapRequestedFeatures.LayersAndGroups | RuntimeMapRequestedFeatures.Icons);
             Assert.IsNotNullOrEmpty(rtInfo.IconMimeType);
@@ -1423,6 +1456,10 @@
             create.RequestedFeatures = (int)(RuntimeMapRequestedFeatures.LayersAndGroups | RuntimeMapRequestedFeatures.Icons | RuntimeMapRequestedFeatures.FeatureSourceInformation);
@@ -1453,6 +1490,20 @@
             Assert.NotNull(rtInfo.Groups);
             Assert.True(rtInfo.Groups.Count == 0);
+                create = (ICreateRuntimeMap)_conn.CreateCommand((int)CommandType.CreateRuntimeMap);
+                create.MapDefinition = "Library://UnitTests/Maps/SheboyganLinked.MapDefinition";
+                create.RequestedFeatures = (int)(RuntimeMapRequestedFeatures.LayersAndGroups | RuntimeMapRequestedFeatures.Icons | RuntimeMapRequestedFeatures.FeatureSourceInformation);
+                rtInfo = create.Execute();
+                MapModel.IRuntimeMapInfo2 rtInfo2 = (MapModel.IRuntimeMapInfo2)rtInfo;
+                Assert.AreEqual("Library://UnitTests/TileSets/Sheboygan.TileSetDefinition", rtInfo2.TileSetDefinition);
+                Assert.True(rtInfo2.TileWidth.HasValue);
+                Assert.True(rtInfo2.TileHeight.HasValue);
         [Test]
@@ -1472,10 +1523,17 @@
             MapModel.IRuntimeMapInfo map = create.Execute();
+                Assert.IsInstanceOf<MapModel.IRuntimeMapInfo2>(map);
             IDescribeRuntimeMap describe = (IDescribeRuntimeMap)_conn.CreateCommand((int)CommandType.DescribeRuntimeMap);
             describe.Name = map.Name;
             MapModel.IRuntimeMapInfo rtInfo = describe.Execute();
@@ -1489,10 +1547,17 @@
@@ -1508,11 +1573,18 @@
             describe.RequestedFeatures = (int)(RuntimeMapRequestedFeatures.LayersAndGroups);
@@ -1531,11 +1603,18 @@
             describe.RequestedFeatures = (int)(RuntimeMapRequestedFeatures.LayersAndGroups | RuntimeMapRequestedFeatures.Icons);
@@ -1569,11 +1648,18 @@
             describe.RequestedFeatures = (int)(RuntimeMapRequestedFeatures.LayersAndGroups | RuntimeMapRequestedFeatures.Icons | RuntimeMapRequestedFeatures.FeatureSourceInformation);
@@ -1604,6 +1690,30 @@
+                describe = (IDescribeRuntimeMap)_conn.CreateCommand((int)CommandType.DescribeRuntimeMap);
+                describe.Name = rtInfo.Name;
+                describe.RequestedFeatures = (int)(RuntimeMapRequestedFeatures.LayersAndGroups | RuntimeMapRequestedFeatures.Icons | RuntimeMapRequestedFeatures.FeatureSourceInformation);
+                rtInfo = describe.Execute();
+                rtInfo2 = (MapModel.IRuntimeMapInfo2)rtInfo;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj	2014-12-29 10:11:17 UTC (rev 8481)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj	2014-12-29 13:18:49 UTC (rev 8482)
@@ -44,7 +44,7 @@
     <DebugType>full</DebugType>
     <Optimize>false</Optimize>
     <OutputPath>..\SDK\bin\</OutputPath>
-    <DefineConstants>TRACE;DEBUG;LDF_100, WL_100, MDF_100, SYM_100, LP_100</DefineConstants>
+    <DefineConstants>TRACE;DEBUG</DefineConstants>
     <ErrorReport>prompt</ErrorReport>
     <WarningLevel>4</WarningLevel>
   </PropertyGroup>
@@ -300,6 +300,9 @@
     </None>
     <None Include="Schemas\MapDefinition-2.3.0.xsd" />
     <None Include="Schemas\MapDefinition-2.4.0.xsd" />
+    <None Include="Schemas\MapDefinition-3.0.0.xsd">
+    </None>
     <None Include="Schemas\PlatformCommon-1.0.0.xsd">
     </None>
     <None Include="Schemas\PrintLayout-1.0.0.xsd">
@@ -326,6 +329,9 @@
     <None Include="Schemas\Role-1.0.0.xsd">
     </None>
     <None Include="Schemas\RuntimeMap-2.6.0.xsd" />
+    <None Include="Schemas\RuntimeMap-3.0.0.xsd">
+    </None>
     <None Include="Schemas\SelectAggregate-1.0.0.xsd">
     </None>
     <None Include="Schemas\Server-1.0.0.xsd">
@@ -353,6 +359,12 @@
     <None Include="Schemas\SymbolDefinition-2.4.0.xsd" />
     <None Include="Schemas\SymbolLibrary-1.0.0.xsd">
     </None>
+    <None Include="Schemas\TileProviderList-3.0.0.xsd">
+    </None>
+    <None Include="Schemas\TileSetDefinition-3.0.0.xsd">
+    </None>
     <None Include="Schemas\Types-1.0.0.xsd">
     </None>
     <None Include="Schemas\UnmanagedDataList-1.0.0.xsd">
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schemas/MapDefinition-3.0.0.xsd
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schemas/MapDefinition-3.0.0.xsd	                        (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schemas/MapDefinition-3.0.0.xsd	2014-12-29 13:18:49 UTC (rev 8482)
@@ -0,0 +1,261 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified" version="3.0.0">
+  <xs:include schemaLocation="WatermarkDefinition-2.4.0.xsd"/>
+  <xs:complexType name="Box2DType">
+    <xs:annotation>
+      <xs:documentation>Box2D encapsulates the the coordinates of a box in 2-D space</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+      <xs:element name="MinX" type="xs:double">
+        <xs:annotation>
+          <xs:documentation>Minimum x-coordinate</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="MaxX" type="xs:double">
+        <xs:annotation>
+          <xs:documentation>Maximum x-coordinate</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="MinY" type="xs:double">
+        <xs:annotation>
+          <xs:documentation>Minimum y-coordinate</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="MaxY" type="xs:double">
+        <xs:annotation>
+          <xs:documentation>Maximum y-coordinate</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="MapLayerCommonType">
+    <xs:annotation>
+      <xs:documentation>MapLayerCommonType is a common superclass of MapLayerType and BaseMapLayerType.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+      <xs:element name="Name" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>Name of the MapLayer</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="ResourceId" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>ResourceId of the MapLayer</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="Selectable" type="xs:boolean">
+        <xs:annotation>
+          <xs:documentation>Whether or not the Layer can be selected</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="ShowInLegend" type="xs:boolean">
+        <xs:annotation>
+          <xs:documentation>Whether or not the Layer should be shown in the legend</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="LegendLabel" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>Label to be shown for the Layer in the legend</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="ExpandInLegend" type="xs:boolean">
+        <xs:annotation>
+          <xs:documentation>Whether or not the Layer should be expanded in the legend.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="MapLayerType">
+    <xs:annotation>
+      <xs:documentation>MapLayerType encapsulates the properties of a map layer, including its group and options about how it should be displayed.</xs:documentation>
+    </xs:annotation>
+    <xs:complexContent>
+      <xs:extension base="MapLayerCommonType">
+        <xs:sequence>
+          <xs:element name="Visible" type="xs:boolean">
+            <xs:annotation>
+              <xs:documentation>Whether this layer's visiblity should be visible or not when it first comes into range</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="Group" type="xs:string">
+            <xs:annotation>
+              <xs:documentation>Group of which the MapLayer is a member of</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="ExtendedData1" type="ExtendedDataType" minOccurs="0"/>
+        </xs:sequence>
+      </xs:extension>
+    </xs:complexContent>
+  </xs:complexType>
+  <xs:complexType name="BaseMapLayerType">
+    <xs:annotation>
+      <xs:documentation>BaseMapLayerType encapsulates the properties of a BaseMapLayer.</xs:documentation>
+    </xs:annotation>
+        <xs:sequence>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="MapLayerGroupCommonType">
+    <xs:annotation>
+      <xs:documentation>MapLayerGroupCommonType is a common superclass of MapLayerGroupType and BaseMapLayerGroupType.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+        <xs:annotation>
+          <xs:documentation>The name of this LayerGroup</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>Whether this group's visiblity should be visible or not when it first comes into range</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>Whether or not the LayerGroup should be shown in the legend</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>Whether or not the LayerGroup should be initially expanded in the legend</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>Label to be shown for the LayerGroup in the legend</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="MapLayerGroupType">
+    <xs:annotation>
+      <xs:documentation>MapLayerGroupType encapsulates the properties of a MapLayerGroup.  Its extension to MapLayerGroupCommonType is that the MapLayerGroup itself can also be in a MapLayerGroup.</xs:documentation>
+    </xs:annotation>
+      <xs:extension base="MapLayerGroupCommonType">
+        <xs:sequence>
+            <xs:annotation>
+              <xs:documentation>The group that contains the MapLayerGroup</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="BaseMapLayerGroupType">
+    <xs:annotation>
+      <xs:documentation>BaseMapLayerGroupType encapsulates the properties of a BaseMapLayerGroup.  It extends MapLayerGroupCommonType by holding the layers in the group.  The base map layer groups defines what layers are used to render a tile set in the HTML viewer.</xs:documentation>
+    </xs:annotation>
+        <xs:sequence>
+          <xs:element name="BaseMapLayer" type="BaseMapLayerType" minOccurs="0" maxOccurs="unbounded">
+            <xs:annotation>
+              <xs:documentation>The layers that are part of this group. The order of the layers represents the draw order, layers first is the list are drawn over top of layers later in the list.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="MapDefinitionType">
+    <xs:annotation>
+      <xs:documentation>MapDefinitionType encapsulates a MapDefinition, which houses a collection of MapLayers and their groups.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+        <xs:annotation>
+          <xs:documentation>The name of the MapDefinition</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="CoordinateSystem" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The coordinate system as WKT used by the MapDefinition</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="Extents" type="Box2DType">
+        <xs:annotation>
+          <xs:documentation>A bounding box around the area of the MapDefinition</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="BackgroundColor" type="xs:hexBinary">
+        <xs:annotation>
+          <xs:documentation>The background color to be used with the MapDefinition</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="Metadata" type="xs:string" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Metadata regarding the MapDefinition</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="MapLayer" type="MapLayerType" minOccurs="0" maxOccurs="unbounded">
+        <xs:annotation>
+          <xs:documentation>Zero or more MapLayers that make up the MapDefinition. The order of the layers represents the draw order, layers first is the list are drawn over top of layers later in the list.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="MapLayerGroup" type="MapLayerGroupType" minOccurs="0" maxOccurs="unbounded">
+        <xs:annotation>
+          <xs:documentation>Zero or more MapLayerGroups that make up the MapDefinition</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="BaseMapDefinition" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>The base map.</xs:documentation>
+        </xs:annotation>
+        <xs:complexType>
+          <xs:sequence>
+            <xs:element name="FiniteDisplayScale" type="xs:double" maxOccurs="unbounded">
+              <xs:annotation>
+                <xs:documentation>The display scales that the base map layers will have tiles available. Applies to the HTML viewer.</xs:documentation>
+              </xs:annotation>
+            </xs:element>
+            <xs:element name="BaseMapLayerGroup" type="BaseMapLayerGroupType" minOccurs="0" maxOccurs="unbounded">
+              <xs:annotation>
+                <xs:documentation>A group of layers that is used to compose a tiled layer in the HTML viewer</xs:documentation>
+              </xs:annotation>
+            </xs:element>
+          </xs:sequence>
+        </xs:complexType>
+      </xs:element>
+      <xs:element name="TileSetSource" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>A reference to the tile set source to use</xs:documentation>
+        </xs:annotation>
+        <xs:complexType>
+          <xs:sequence>
+              <xs:annotation>
+                <xs:documentation>ResourceId of the TileSetDefinition</xs:documentation>
+              </xs:annotation>
+            </xs:element>
+          </xs:sequence>
+        </xs:complexType>
+      </xs:element>
+      <xs:element name="Watermarks" type="WatermarkInstanceCollectionType" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>The collection of watermarks used in the map.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:element name="MapDefinition">
+    <xs:annotation>
+      <xs:documentation>A MapDefinition defines the collection of layers, groupings of layers, and base map</xs:documentation>
+    </xs:annotation>
+    <xs:complexType>
+        <xs:extension base="MapDefinitionType">
+          <xs:attribute name="version" type="xs:string" use="required" fixed="3.0.0"/>
+        </xs:extension>
+    </xs:complexType>
+  </xs:element>
+</xs:schema>
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schemas/RuntimeMap-3.0.0.xsd
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schemas/RuntimeMap-3.0.0.xsd	                        (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schemas/RuntimeMap-3.0.0.xsd	2014-12-29 13:18:49 UTC (rev 8482)
@@ -0,0 +1,309 @@
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified">
+  <xs:element name="RuntimeMap">
+    <xs:annotation>
+      <xs:documentation>Describes information about a Runtime Map, so that client applications can interact with it</xs:documentation>
+    </xs:annotation>
+    <xs:complexType>
+      <xs:sequence>
+        <xs:element name="SiteVersion" type="xs:string">
+          <xs:annotation>
+            <xs:documentation>The MapGuide Site Version</xs:documentation>
+          </xs:annotation>
+        </xs:element>
+          <xs:annotation>
+            <xs:documentation>The name of the runtime map. This is the value required for any mapagent operation that require a MAPNAME parameter</xs:documentation>
+          </xs:annotation>
+        </xs:element>
+        <xs:element name="MapDefinition" type="xs:string">
+          <xs:annotation>
+            <xs:documentation>The resource id of the Map Definition from which this runtime map was created from</xs:documentation>
+          </xs:annotation>
+        </xs:element>
+        <xs:element name="TileSetDefinition" type="xs:string" minOccurs="0">
+          <xs:annotation>
+            <xs:documentation>The resource id of the Tile Set Definition that this Map Definition is linked from. If this Map Definition does not link to a tile set, this element is omitted</xs:documentation>
+          </xs:annotation>
+        </xs:element>
+        <xs:element name="TileWidth" type="xs:string" minOccurs="0">
+          <xs:annotation>
+            <xs:documentation>The tile width as defined by the settings in the Tile Set Definition. If this Map Definition does not link to a tile set, this element is omitted</xs:documentation>
+          </xs:annotation>
+        </xs:element>
+        <xs:element name="TileHeight" type="xs:string" minOccurs="0">
+          <xs:annotation>
+            <xs:documentation>The tile height as defined by the settings in the Tile Set Definition. If this Map Definition does not link to a tile set, this element is omitted</xs:documentation>
+          </xs:annotation>
+        </xs:element>
+        <xs:element name="BackgroundColor" type="xs:string">
+          <xs:annotation>
+            <xs:documentation>The map's background color in ARGB hex string format</xs:documentation>
+          </xs:annotation>
+        </xs:element>
+        <xs:element name="DisplayDpi" type="xs:integer">
+          <xs:annotation>
+            <xs:documentation>The number of dots per inch of the map display</xs:documentation>
+          </xs:annotation>
+        </xs:element>
+        <xs:element name="IconMimeType" type="xs:string" minOccurs="0">
+          <xs:annotation>
+            <xs:documentation>The mime type of all inline icons</xs:documentation>
+          </xs:annotation>
+        </xs:element>
+        <xs:element name="CoordinateSystem" type="CoordinateSystemType" />
+        <xs:element name="Extents" type="Envelope" />
+        <xs:element name="Group" type="RuntimeMapGroup" minOccurs="0" maxOccurs="unbounded" />
+        <xs:element name="Layer" type="RuntimeMapLayer" minOccurs="0" maxOccurs="unbounded" />
+        <xs:element name="FiniteDisplayScale" type="xs:double" minOccurs="0" maxOccurs="unbounded" />
+      </xs:sequence>
+    </xs:complexType>
+  </xs:element>
+  <xs:complexType name="CoordinateSystemType">
+    <xs:annotation>
+      <xs:documentation>Describes the coordinate system of the runtime map</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+      <xs:element name="Wkt" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The WKT string of the coordinate system</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="MentorCode" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The CS-Map code of the coordinate system</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="EpsgCode" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The EPSG code of the coordinate system</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="MetersPerUnit" type="xs:double">
+        <xs:annotation>
+          <xs:documentation>The meters-per-unit value of the coordinate system</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="RuntimeMapGroup">
+    <xs:annotation>
+      <xs:documentation>Describes a group of Runtime Map Layers</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+        <xs:annotation>
+          <xs:documentation>The name of the group</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="Type" type="xs:integer">
+        <xs:annotation>
+          <xs:documentation>The type of this group. Can be tiled or dynamic. Uses the value of MgLayerGroupType</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>The group's legend label</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="ObjectId" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The group's unique id. Use this value for turning on/off this group in a GETDYNAMICMAPOVERLAYIMAGE request</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="ParentId" type="xs:string" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>The group's parent group id. Use this value for determining parent-child relationships when building a layer/group hierarchy</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="DisplayInLegend" type="xs:boolean">
+        <xs:annotation>
+          <xs:documentation>Indicates whether this group should be displayed in the legend</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>Indicates whether this group should be initially expanded in the legend</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>Indicates whether this group is potentially visible. Note that this may be true even though the group is not visible. This will occur if one of the groups this group is organized within is not visible.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="ActuallyVisible" type="xs:boolean">
+        <xs:annotation>
+          <xs:documentation>Indicates the actual visibility of the group. The visibility depends on the visible property of the group, and the visible property of each group this group is organized within.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="RuntimeMapLayer">
+    <xs:annotation>
+      <xs:documentation>Describes a runtime instance of a Layer Definition</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+        <xs:annotation>
+          <xs:documentation>The name of the layer</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>The type of this layer. Can be tiled or dynamic. Uses the value of MgLayerType</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>The layer's legend label</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>The layer's unique id. Use this value for turning on/off this layer in a GETDYNAMICMAPOVERLAYIMAGE request</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>The layer's parent group id. Use this value for determining parent-child relationships when building a layer/group hierarchy</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>Indicates whether this layer should be displayed in the legend</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>Indicates whether this layer should be initially expanded (if layer is themed) in the legend</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>Indicates whether this layer is potentially visible. Note that this may be true even though the layer is not visible. This will occur if the visible flag of one of the groups this layer is organized within is not visible or when the current viewScale property of the map is outside the scale ranges defined for this layer.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>Indicates the actual visibility of the layer. The visibility depends on the visible property of the group, and the visible property of each group this group is organized within.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="LayerDefinition" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The Layer Definition from which this runtime layer was created from</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="FeatureSource" type="FeatureSourceInfo" minOccurs="0" />
+      <xs:element name="ScaleRange" type="ScaleRangeInfo" minOccurs="0" maxOccurs="unbounded" />
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="FeatureSourceInfo">
+    <xs:annotation>
+      <xs:documentation>Describe the Feature Source information for a runtime layer</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+        <xs:annotation>
+          <xs:documentation>The Feature Source resource id</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="ClassName" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The qualified FDO class name</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="Geometry" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The name of the default Geometry property</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="ScaleRangeInfo">
+    <xs:annotation>
+      <xs:documentation>Describes a scale range of the runtime layer</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+      <xs:element name="MinScale" type="xs:double">
+        <xs:annotation>
+          <xs:documentation>The minimum scale of this scale range</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="MaxScale" type="xs:double">
+        <xs:annotation>
+          <xs:documentation>The maximum scale of this scale range</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="FeatureStyle" type="FeatureStyleInfo" minOccurs="0" maxOccurs="unbounded">
+        <xs:annotation>
+          <xs:documentation>The feature style for a given geometry type.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="FeatureStyleInfo">
+    <xs:annotation>
+      <xs:documentation>Defines the style rules for a given geometry type</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+        <xs:annotation>
+          <xs:documentation>The geometry type that this rule is applicable to (1=point, 2=line, 3=area, 4=composite)</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="Rule" type="RuleInfo" minOccurs="0" maxOccurs="unbounded" />
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="RuleInfo">
+    <xs:annotation>
+      <xs:documentation>Describes a stylization rule in a layer's scale range</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+        <xs:annotation>
+          <xs:documentation>The legend label for this rule</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="Filter" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The FDO filter that features must match in order for them to be stylized using this particular rule</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="Icon" type="xs:string" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Defines the icon for this rule. The icon's image content is in base64 format</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="Envelope">
+    <xs:annotation>
+      <xs:documentation>Specifies an envelope (a rectangle) using two corner points.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+      <xs:element name="LowerLeftCoordinate">
+        <xs:annotation>
+          <xs:documentation>Specifies the lower left corner of the envelope.</xs:documentation>
+        </xs:annotation>
+        <xs:complexType>
+          <xs:sequence>
+            <xs:element name="X" type="xs:string"/>
+            <xs:element name="Y" type="xs:string"/>
+          </xs:sequence>
+        </xs:complexType>
+      </xs:element>
+      <xs:element name="UpperRightCoordinate">
+        <xs:annotation>
+          <xs:documentation>Specifies the upper right corner of the envelope.</xs:documentation>
+        </xs:annotation>
+        <xs:complexType>
+          <xs:sequence>
+          </xs:sequence>
+        </xs:complexType>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+</xs:schema>
\ No newline at end of file
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schemas/TileProviderList-3.0.0.xsd
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schemas/TileProviderList-3.0.0.xsd	                        (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schemas/TileProviderList-3.0.0.xsd	2014-12-29 13:18:49 UTC (rev 8482)
@@ -0,0 +1,74 @@
+  <xs:element name="TileProviderList" type="TileProviderList">
+    <xs:annotation>
+      <xs:documentation>Root element that contains a collection of TileProvider elements.</xs:documentation>
+    </xs:annotation>
+  </xs:element>
+  <xs:complexType name="TileProviderList">
+    <xs:sequence>
+      <xs:element name="TileProvider" minOccurs="0" maxOccurs="unbounded">
+        <xs:annotation>
+          <xs:documentation>Describes an installed tile provider.</xs:documentation>
+        </xs:annotation>
+        <xs:complexType>
+          <xs:sequence>
+              <xs:annotation>
+                <xs:documentation>Unique name of the feature provider. This name should be of the form <Company>.<Provider>.lt;Version>.</xs:documentation>
+              </xs:annotation>
+            </xs:element>
+            <xs:element name="DisplayName" type="xs:string">
+              <xs:annotation>
+                <xs:documentation>A user friendly display name of the feature provider.</xs:documentation>
+              </xs:annotation>
+            </xs:element>
+            <xs:element name="Description" type="xs:string">
+              <xs:annotation>
+                <xs:documentation>A brief description of the feature provider.</xs:documentation>
+              </xs:annotation>
+            </xs:element>
+            <xs:element name="ConnectionProperties">
+              <xs:annotation>
+                <xs:documentation>Connection properties for each provider with default values will be listed here.</xs:documentation>
+              </xs:annotation>
+              <xs:complexType>
+                <xs:sequence minOccurs="0" maxOccurs="unbounded">
+                  <xs:element name="ConnectionProperty" minOccurs="0" maxOccurs="unbounded">
+                    <xs:complexType>
+                      <xs:sequence>
+                          <xs:annotation>
+                            <xs:documentation>Name of the property retrieved from Fdo Provider</xs:documentation>
+                          </xs:annotation>
+                        </xs:element>
+                        <xs:element name="LocalizedName" type="xs:string" minOccurs="0">
+                          <xs:annotation>
+                            <xs:documentation>Properties can have localized names for displaying them in UI. Provider will inform us what that string should be.</xs:documentation>
+                          </xs:annotation>
+                        </xs:element>
+                        <xs:element name="DefaultValue" type="xs:string" minOccurs="0">
+                          <xs:annotation>
+                            <xs:documentation>This is a default value. This will be one of the values listed in  Value element</xs:documentation>
+                          </xs:annotation>
+                        </xs:element>
+                        <xs:element name="Value" type="xs:string" minOccurs="0" maxOccurs="unbounded">
+                          <xs:annotation>
+                            <xs:documentation>A property can have more than one alternative values to choose from. All possible values will be listed here.</xs:documentation>
+                          </xs:annotation>
+                        </xs:element>
+                      </xs:sequence>
+                      <xs:attribute name="Required" type="xs:boolean" use="required"/>
+                      <xs:attribute name="Protected" type="xs:boolean" use="required"/>
+                      <xs:attribute name="Enumerable" type="xs:boolean" use="required"/>
+                    </xs:complexType>
+                  </xs:element>
+                </xs:sequence>
+              </xs:complexType>
+            </xs:element>
+          </xs:sequence>
+        </xs:complexType>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+</xs:schema>
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schemas/TileSetDefinition-3.0.0.xsd
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schemas/TileSetDefinition-3.0.0.xsd	                        (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schemas/TileSetDefinition-3.0.0.xsd	2014-12-29 13:18:49 UTC (rev 8482)
@@ -0,0 +1,175 @@
+  <xs:include schemaLocation="PlatformCommon-1.0.0.xsd"/>
+  <xs:element name="TileSetDefinition">
+    <xs:annotation>
+      <xs:documentation>Defines a tile cache</xs:documentation>
+    </xs:annotation>
+    <xs:complexType>
+      <xs:sequence>
+        <xs:element name="TileStoreParameters" type="TileStoreParametersType">
+           <xs:annotation>
+            <xs:documentation>Defines the parameters to access and describe the tile cache</xs:documentation>
+          </xs:annotation>
+        </xs:element>
+          <xs:annotation>
+            <xs:documentation>A bounding box around the area of the tile cache</xs:documentation>
+          </xs:annotation>
+        </xs:element>
+        <xs:element name="BaseMapLayerGroup" type="BaseMapLayerGroupCommonType" minOccurs="1" maxOccurs="unbounded">
+          <xs:annotation>
+          </xs:annotation>
+        </xs:element>
+      </xs:sequence>
+    </xs:complexType>
+  </xs:element>
+  <xs:complexType name="TileStoreParametersType">
+    <xs:annotation>
+      <xs:documentation>TileStoreParameters defines the parameters of this tile cache.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+      <xs:element name="TileProvider" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The tile image provider</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="Parameter" type="NameValuePairType" minOccurs="0" maxOccurs="unbounded">
+        <xs:annotation>
+          <xs:documentation>Collection of name value pairs for connecting to the tile image provider</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="NameValuePairType">
+    <xs:annotation>
+      <xs:documentation>A type describing name and value pairs</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+        <xs:annotation>
+          <xs:documentation>Text for the name of parameter</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="Value" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>Text for value of parameter</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+    <xs:annotation>
+    </xs:annotation>
+    <xs:sequence>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+    <xs:annotation>
+    </xs:annotation>
+    <xs:sequence>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+    <xs:annotation>
+      <xs:documentation>MapLayerGroupCommonType is a common subclass of MapLayerGroupCommonType and BaseMapLayerGroupCommonType</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="BaseMapLayerGroupCommonType">
+    <xs:annotation>
+      <xs:documentation>BaseMapLayerGroupCommonType encapsulates the properties of a BaseMapLayerGroup. It extends MapLayerGroupCommonType by holding the layers in the group.  The base map layer groups defines what layers are used to render a tile set in the HTML viewer.</xs:documentation>
+    </xs:annotation>
+        <xs:sequence>
+            <xs:annotation>
+            </xs:annotation>
+          </xs:element>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+</xs:schema>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs	2014-12-29 10:11:17 UTC (rev 8481)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs	2014-12-29 13:18:49 UTC (rev 8482)
@@ -1984,22 +1984,42 @@
         internal IRuntimeMapInfo DescribeRuntimeMap(string mapName, int requestedFeatures, int iconsPerScaleRange, string iconFormat, int iconWidth, int iconHeight)
-            var req = m_reqBuilder.DescribeRuntimeMap(mapName, requestedFeatures, iconsPerScaleRange, iconFormat, iconWidth, iconHeight);
-            using (var s = this.OpenRead(req))
+            if (m_siteVersion >= new Version(3, 0))
-                var info = this.DeserializeObject<OSGeo.MapGuide.ObjectModels.RuntimeMap.v2_6_0.RuntimeMap>(s);
-                return info;
+                var req = m_reqBuilder.DescribeRuntimeMap(mapName, requestedFeatures, iconsPerScaleRange, iconFormat, iconWidth, iconHeight, "3.0.0");
+                using (var s = this.OpenRead(req))
+                    return this.DeserializeObject<OSGeo.MapGuide.ObjectModels.RuntimeMap.v3_0_0.RuntimeMap>(s);
+            else
+                var req = m_reqBuilder.DescribeRuntimeMap(mapName, requestedFeatures, iconsPerScaleRange, iconFormat, iconWidth, iconHeight);
+                    return this.DeserializeObject<OSGeo.MapGuide.ObjectModels.RuntimeMap.v2_6_0.RuntimeMap>(s);
         internal IRuntimeMapInfo CreateRuntimeMap(string mapDefinition, string targetMapName, int requestedFeatures, int iconsPerScaleRange, string iconFormat, int iconWidth, int iconHeight)
-            var req = m_reqBuilder.CreateRuntimeMap(mapDefinition, targetMapName, requestedFeatures, iconsPerScaleRange, iconFormat, iconWidth, iconHeight);
-                return info;
+                var req = m_reqBuilder.CreateRuntimeMap(mapDefinition, targetMapName, requestedFeatures, iconsPerScaleRange, iconFormat, iconWidth, iconHeight, "3.0.0");
+            else
+                var req = m_reqBuilder.CreateRuntimeMap(mapDefinition, targetMapName, requestedFeatures, iconsPerScaleRange, iconFormat, iconWidth, iconHeight);
         public override Resource.Preview.IResourcePreviewUrlGenerator GetPreviewUrlGenerator()
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs	2014-12-29 10:11:17 UTC (rev 8481)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs	2014-12-29 13:18:49 UTC (rev 8482)
@@ -1753,11 +1753,11 @@
             return m_hosturi + "?" + EncodeParameters(param);
-        internal string DescribeRuntimeMap(string mapName, int requestedFeatures, int iconsPerScaleRange, string iconFormat, int iconWidth, int iconHeight)
+        internal string DescribeRuntimeMap(string mapName, int requestedFeatures, int iconsPerScaleRange, string iconFormat, int iconWidth, int iconHeight, string targetVersion = "2.6.0")
             NameValueCollection param = new NameValueCollection();
             param.Add("OPERATION", "DESCRIBERUNTIMEMAP");
-            param.Add("VERSION", "2.6.0");
+            param.Add("VERSION", targetVersion);
             param.Add("SESSION", m_sessionID);
             param.Add("MAPNAME", mapName);
             param.Add("REQUESTEDFEATURES", requestedFeatures.ToString());
@@ -1769,11 +1769,11 @@
-        internal string CreateRuntimeMap(string mapDefinition, string targetMapName, int requestedFeatures, int iconsPerScaleRange, string iconFormat, int iconWidth, int iconHeight)
+        internal string CreateRuntimeMap(string mapDefinition, string targetMapName, int requestedFeatures, int iconsPerScaleRange, string iconFormat, int iconWidth, int iconHeight, string targetVersion = "2.6.0")
             param.Add("OPERATION", "CREATERUNTIMEMAP");
             param.Add("MAPDEFINITION", mapDefinition);
             param.Add("TARGETMAPNAME", targetMapName);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/OSGeo.MapGuide.ObjectModels.csproj
--- trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/OSGeo.MapGuide.ObjectModels.csproj	2014-12-29 10:11:17 UTC (rev 8481)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/OSGeo.MapGuide.ObjectModels.csproj	2014-12-29 13:18:49 UTC (rev 8482)
@@ -140,6 +140,9 @@
     <Compile Include="..\Generated\RuntimeMap-2.6.0.designer.cs">
       <Link>RuntimeMap\v2_6_0\RuntimeMap-2.6.0.designer.cs</Link>
     </Compile>
+    <Compile Include="..\Generated\RuntimeMap-3.0.0.designer.cs">
+      <Link>RuntimeMap\v3_0_0\RuntimeMap-3.0.0.designer.cs</Link>
+    </Compile>
     <Compile Include="..\Generated\SiteInformation-1.0.0.designer.cs">
       <Link>Common\SiteInformation-1.0.0.designer.cs</Link>
     </Compile>
@@ -259,6 +262,7 @@
     <Compile Include="ResourceTypes.cs" />
     <Compile Include="RuntimeMap\RuntimeMapInterfaces.cs" />
     <Compile Include="RuntimeMap\v2_6_0\RuntimeMapImpl.cs" />
+    <Compile Include="RuntimeMap\v3_0_0\RuntimeMapImpl.cs" />
     <Compile Include="Strings.Designer.cs">
       <AutoGen>True</AutoGen>
       <DesignTime>True</DesignTime>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/RuntimeMap/RuntimeMapInterfaces.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/RuntimeMap/RuntimeMapInterfaces.cs	2014-12-29 10:11:17 UTC (rev 8481)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/RuntimeMap/RuntimeMapInterfaces.cs	2014-12-29 13:18:49 UTC (rev 8482)
@@ -104,6 +104,18 @@
     /// <summary>
+    /// Describes the structure of a Runtime Map. Based on RuntimeMap v3.0.0 schema
+    /// </summary>
+    public interface IRuntimeMapInfo2 : IRuntimeMapInfo
+        string TileSetDefinition { get; set; }
+        int? TileWidth { get; set; }
+        int? TileHeight { get; set; }
+    /// <summary>
     /// Represents coordinate system information for a Runtime Map
     /// </summary>
     public interface ICoordinateSystemInfo
Added: trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/RuntimeMap/v3_0_0/RuntimeMapImpl.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/RuntimeMap/v3_0_0/RuntimeMapImpl.cs	                        (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/RuntimeMap/v3_0_0/RuntimeMapImpl.cs	2014-12-29 13:18:49 UTC (rev 8482)
@@ -0,0 +1,397 @@
+#region Disclaimer / License
+// Copyright (C) 2014, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion Disclaimer / License
+using OSGeo.MapGuide.ObjectModels.Common;
+using System;
+using System.Collections.Generic;
+using System.Globalization;
+using System.Linq;
+using System.Text;
+namespace OSGeo.MapGuide.ObjectModels.RuntimeMap.v3_0_0
+    partial class RuntimeMap : IRuntimeMapInfo2
+        string IRuntimeMapInfo.SiteVersion
+            get { return this.SiteVersion; }
+        string IRuntimeMapInfo.Name
+            get { return this.Name; }
+        string IRuntimeMapInfo.MapDefinition
+            get { return this.MapDefinition; }
+        string IRuntimeMapInfo.BackgroundColor
+            get { return this.BackgroundColor; }
+        int IRuntimeMapInfo.DisplayDpi
+            get
+                return this.DisplayDpi;
+        string IRuntimeMapInfo.IconMimeType
+            get { return this.IconMimeType; }
+        ICoordinateSystemInfo IRuntimeMapInfo.CoordinateSystem
+            get { return this.CoordinateSystem; }
+        IEnvelope IRuntimeMapInfo.Extents
+            get
+                return ObjectFactory.CreateEnvelope(this.Extents.LowerLeftCoordinate.X,
+                                                    this.Extents.LowerLeftCoordinate.Y,
+                                                    this.Extents.UpperRightCoordinate.X,
+                                                    this.Extents.UpperRightCoordinate.Y);
+        private ReadOnlyLayerCollection _roLayers;
+        IRuntimeLayerInfoCollection IRuntimeMapInfo.Layers
+            get
+                if (this.Layer == null)
+                    return null;
+                if (_roLayers == null)
+                    _roLayers = new ReadOnlyLayerCollection(this.Layer);
+                return _roLayers;
+        private ReadOnlyGroupCollection _roGroups;
+        IRuntimeLayerGroupInfoCollection IRuntimeMapInfo.Groups
+            get
+                if (this.Group == null)
+                    return null;
+                if (_roGroups == null)
+                    _roGroups = new ReadOnlyGroupCollection(this.Group);
+                return _roGroups;
+        double[] IRuntimeMapInfo.FiniteDisplayScales
+            get
+                return this.FiniteDisplayScale.ToArray();
+        int? IRuntimeMapInfo2.TileWidth
+            get
+                int value;
+                if (int.TryParse(this.TileWidth, out value))
+                    return value;
+                return null;
+            set
+                if (value.HasValue)
+                    this.TileWidth = value.Value.ToString(CultureInfo.InvariantCulture);
+                else
+                    this.TileWidth = null;
+        int? IRuntimeMapInfo2.TileHeight
+            get
+                int value;
+                if (int.TryParse(this.TileHeight, out value))
+                    return value;
+                return null;
+            set
+                    this.TileHeight = value.Value.ToString(CultureInfo.InvariantCulture);
+                else
+                    this.TileHeight = null;
+    //I love C# generics!
+    internal abstract class ReadOnlyCollectionWrapper<TInterface, TImpl>
+        : IReadOnlyCollection<TInterface>
+        where TImpl : TInterface
+        private IList<TImpl> _list;
+        protected ReadOnlyCollectionWrapper(IList<TImpl> list)
+            _list = list;
+        public int Count
+            get { return _list.Count; }
+        public TInterface this[int index]
+            get { return _list[index]; }
+        private class Enumerator : IEnumerator<TInterface>
+            private IList<TImpl> _innerList;
+            private int _pos;
+            public Enumerator(IList<TImpl> list)
+                _pos = -1;
+                _innerList = list;
+            public TInterface Current
+                get { return _innerList[_pos]; }
+            public void Dispose()
+            object System.Collections.IEnumerator.Current
+            public bool MoveNext()
+                _pos++;
+                return _pos <= _innerList.Count - 1;
+            public void Reset()
+                _pos = -1;
+        public IEnumerator<TInterface> GetEnumerator()
+            return new Enumerator(_list);
+        System.Collections.IEnumerator System.Collections.IEnumerable.GetEnumerator()
+            return _list.GetEnumerator();
+    partial class RuntimeMapLayer : IRuntimeLayerInfo
+        int IRuntimeLayerInfo.LayerType
+            get { return Convert.ToInt32(this.Type); }
+        IFeatureSourceInfo IRuntimeLayerInfo.FeatureSource
+            get { return this.FeatureSource; }
+        private ScaleRangeCollection _roScales;
+        IScaleRangeInfoCollection IRuntimeLayerInfo.ScaleRanges
+            get
+                if (this.ScaleRange == null)
+                    return null;
+                if (_roScales == null)
+                    _roScales = new ScaleRangeCollection(this.ScaleRange);
+                return _roScales;
+        string IRuntimeMapLegendElement.ObjectID
+            get { return this.ObjectId; }
+        string IRuntimeMapLegendElement.ParentID
+            get { return this.ParentId; }
+    partial class FeatureSourceInfo : IFeatureSourceInfo
+        string IFeatureSourceInfo.ResourceID
+            get { return this.ResourceId; }
+    partial class RuntimeMapGroup : IRuntimeLayerGroupInfo
+        int IRuntimeLayerGroupInfo.GroupType
+    internal class ReadOnlyLayerCollection : ReadOnlyCollectionWrapper<IRuntimeLayerInfo, RuntimeMapLayer>,
+        public ReadOnlyLayerCollection(IList<RuntimeMapLayer> list)
+            : base(list)
+    internal class ReadOnlyGroupCollection : ReadOnlyCollectionWrapper<IRuntimeLayerGroupInfo, RuntimeMapGroup>,
+        public ReadOnlyGroupCollection(IList<RuntimeMapGroup> list)
+            : base(list)
+    internal class ScaleRangeCollection : ReadOnlyCollectionWrapper<IScaleRangeInfo, ScaleRangeInfo>,
+        public ScaleRangeCollection(IList<ScaleRangeInfo> list)
+            : base(list)
+    internal class FeatureStyleCollection : ReadOnlyCollectionWrapper<IFeatureStyleInfo, FeatureStyleInfo>,
+                                            IFeatureStyleInfoCollection
+        public FeatureStyleCollection(IList<FeatureStyleInfo> list)
+            : base(list)
+    internal class RuleInfoCollection : ReadOnlyCollectionWrapper<IRuleInfo, RuleInfo>,
+                                        IRuleInfoCollection
+        public RuleInfoCollection(IList<RuleInfo> list)
+            : base(list)
+    partial class ScaleRangeInfo : IScaleRangeInfo
+        private FeatureStyleCollection _roStyles;
+        IFeatureStyleInfoCollection IScaleRangeInfo.FeatureStyle
+            get
+                if (this.FeatureStyle == null)
+                    return null;
+                if (_roStyles == null)
+                    _roStyles = new FeatureStyleCollection(this.FeatureStyle);
+                return _roStyles;
+    partial class FeatureStyleInfo : IFeatureStyleInfo
+        int IFeatureStyleInfo.Type
+        private RuleInfoCollection _roRules;
+        /// <summary>
+        /// Gets the rules in this feature style
+        /// </summary>
+        public IRuleInfoCollection Rules
+            get
+                if (this.Rule == null)
+                    return null;
+                if (_roRules == null)
+                    _roRules = new RuleInfoCollection(this.Rule);
+                return _roRules;
+    partial class RuleInfo : IRuleInfo
+        string IRuleInfo.IconBase64
+            get { return this.Icon; }
+    partial class CoordinateSystemType : ICoordinateSystemInfo
More information about the mapguide-commits mailing list
