[mapguide-commits] r8180 - in sandbox/jng/tiling: Common/MapGuideCommon Common/MapGuideCommon/Exception Common/MapGuideCommon/MapLayer Common/MapGuideCommon/Services Common/MapGuideCommon/System Server/src/PostBuild Server/src/Services/Tile Server/src/UnitTesting UnitTest/TestData/TileService
svn_mapguide at osgeo.org
Mon Jun 2 15:33:06 PDT 2014
Author: jng
Date: 2014-06-02 15:33:06 -0700 (Mon, 02 Jun 2014)
New Revision: 8180
Added:
sandbox/jng/tiling/Common/MapGuideCommon/Exception/UnknownTileProviderException.cpp
sandbox/jng/tiling/Common/MapGuideCommon/Exception/UnknownTileProviderException.h
sandbox/jng/tiling/UnitTest/TestData/TileService/UT_BaseMap.tsd
sandbox/jng/tiling/UnitTest/TestData/TileService/UT_LinkedTileSet.mdf
sandbox/jng/tiling/Common/MapGuideCommon/MapGuideCommon.h
sandbox/jng/tiling/Common/MapGuideCommon/MapGuideCommon.vcxproj
sandbox/jng/tiling/Common/MapGuideCommon/MapGuideCommon.vcxproj.filters
sandbox/jng/tiling/Common/MapGuideCommon/MapGuideCommonBuild.cpp
sandbox/jng/tiling/Common/MapGuideCommon/MapLayer/Map.cpp
sandbox/jng/tiling/Common/MapGuideCommon/MapLayer/Map.h
sandbox/jng/tiling/Common/MapGuideCommon/Services/TileDefs.cpp
sandbox/jng/tiling/Common/MapGuideCommon/Services/TileDefs.h
sandbox/jng/tiling/Common/MapGuideCommon/System/MapGuideCommonClassId.h
sandbox/jng/tiling/Server/src/PostBuild/PostBuild.mak
sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.cpp
sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.h
sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.vcxproj
sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.vcxproj.filters
sandbox/jng/tiling/Server/src/Services/Tile/ServerTileServiceBuild.cpp
sandbox/jng/tiling/Server/src/Services/Tile/TileCacheDefault.cpp
sandbox/jng/tiling/Server/src/Services/Tile/TileCacheDefault.h
sandbox/jng/tiling/Server/src/UnitTesting/TestMdfModel.cpp
sandbox/jng/tiling/Server/src/UnitTesting/TestMdfModel.h
sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.cpp
sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.h
Add first cut of shareable tile sets:
- Add a new implementation of MgTileCache (MgTileCacheDefaultProvider) that inherits from MgTileCacheDefaults and overrides several key methods, to return values that are plugged in by the TileSetDefinition resource.
- Modify MgMap to allow creation from
- A Map Definition
- A Map Definition that links to a Tile Set Definition
- A Tile Set Definition
This is to allow the tile rendering off of Tile Set Definitions to work as they require a MgMap be passed to the RenderTile() method.
- Add new unit tests
- MdfModel test to ensure a TileSetDefinition is properly deserialized
- Tile Service tests to exercise multi-threaded GetTile() calls to a tile set definition and clearing the cache of a tile set definition
- MgMap tests to exercise creation from the new input resource permutations
Added: sandbox/jng/tiling/Common/MapGuideCommon/Exception/UnknownTileProviderException.cpp
--- sandbox/jng/tiling/Common/MapGuideCommon/Exception/UnknownTileProviderException.cpp (rev 0)
+++ sandbox/jng/tiling/Common/MapGuideCommon/Exception/UnknownTileProviderException.cpp 2014-06-02 22:33:06 UTC (rev 8180)
@@ -0,0 +1,40 @@
+// Copyright (C) 2004-2014 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "MapGuideCommon.h"
+IMPLEMENT_EXCEPTION_DEFAULTS(MgUnknownTileProviderException, MgApplicationException)
+/// \brief
+/// Construct a MgUnknownTileProviderException object.
+MgUnknownTileProviderException::MgUnknownTileProviderException(CREFSTRING methodName,
+ INT32 lineNumber, CREFSTRING fileName, MgStringCollection* whatArguments,
+ CREFSTRING whyMessageId, MgStringCollection* whyArguments) throw() :
+ MgApplicationException(methodName, lineNumber, fileName,
+ whatArguments, whyMessageId, whyArguments)
+/// \brief
+/// Destruct the object.
+MgUnknownTileProviderException::~MgUnknownTileProviderException() throw()
Added: sandbox/jng/tiling/Common/MapGuideCommon/Exception/UnknownTileProviderException.h
--- sandbox/jng/tiling/Common/MapGuideCommon/Exception/UnknownTileProviderException.h (rev 0)
+++ sandbox/jng/tiling/Common/MapGuideCommon/Exception/UnknownTileProviderException.h 2014-06-02 22:33:06 UTC (rev 8180)
@@ -0,0 +1,69 @@
+#ifndef MG_UNKNOWN_TILE_PROVIDER_EXCEPTION_H_
+#define MG_UNKNOWN_TILE_PROVIDER_EXCEPTION_H_
+/// \ingroup Exceptions_Module
+/// \brief
+/// Thrown when a tile set definition contains an unknown tile provider
+class MG_MAPGUIDE_API MgUnknownTileProviderException : public MgApplicationException
+ DECLARE_CLASSNAME(MgUnknownTileProviderException)
+EXTERNAL_API:
+ /// \brief
+ /// Construct a MgUnknownTileProviderException object.
+ /// \param methodName
+ /// Name of the method where the exception occurred.
+ /// \param lineNumber
+ /// Line number where the exception occurred.
+ /// \param fileName
+ /// File name where the exception occurred.
+ /// \param whatArguments
+ /// Collection of arguments used to format the message that describes what the exception is.
+ /// \param whyMessageId
+ /// ID of the message that describes why the exception occurs.
+ /// \param whyArguments
+ /// Collection of arguments used to format the message that describes why the exception occurs.
+ MgUnknownTileProviderException(CREFSTRING methodName, INT32 lineNumber,
+ CREFSTRING fileName, MgStringCollection* whatArguments,
+ CREFSTRING whyMessageId, MgStringCollection* whyArguments) throw();
+ /// \brief
+ /// Destructor for a MgUnknownTileProviderException object.
+ virtual ~MgUnknownTileProviderException() throw();
+INTERNAL_API:
+ DECLARE_EXCEPTION_DEFAULTS(MgUnknownTileProviderException)
+CLASS_ID:
+ static const INT32 m_cls_id = MapGuide_Exception_MgUnknownTileProviderException;
+#endif
Modified: sandbox/jng/tiling/Common/MapGuideCommon/MapGuideCommon.h
--- sandbox/jng/tiling/Common/MapGuideCommon/MapGuideCommon.h 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Common/MapGuideCommon/MapGuideCommon.h 2014-06-02 22:33:06 UTC (rev 8180)
@@ -116,6 +116,7 @@
#include "Exception/SessionNotFoundException.h"
#include "Exception/StylizeLayerFailedException.h"
#include "Exception/UnauthorizedAccessException.h"
+#include "Exception/UnknownTileProviderException.h"
#include "Exception/UnsupportedProviderThreadModelException.h"
#include "Exception/UriFormatException.h"
Modified: sandbox/jng/tiling/Common/MapGuideCommon/MapGuideCommon.vcxproj
--- sandbox/jng/tiling/Common/MapGuideCommon/MapGuideCommon.vcxproj 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Common/MapGuideCommon/MapGuideCommon.vcxproj 2014-06-02 22:33:06 UTC (rev 8180)
@@ -198,6 +198,12 @@
</Link>
</ItemDefinitionGroup>
<ItemGroup>
+ <ClCompile Include="Exception\UnknownTileProviderException.cpp">
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
+ </ClCompile>
<ClCompile Include="MapLayer\Layer.cpp">
@@ -939,6 +945,7 @@
</ClCompile>
</ItemGroup>
<ItemGroup>
+ <ClInclude Include="Exception\UnknownTileProviderException.h" />
<ClInclude Include="MapLayer\Layer.h" />
<ClInclude Include="MapLayer\Map.h" />
<ClInclude Include="MapLayer\Selection.h" />
Modified: sandbox/jng/tiling/Common/MapGuideCommon/MapGuideCommon.vcxproj.filters
--- sandbox/jng/tiling/Common/MapGuideCommon/MapGuideCommon.vcxproj.filters 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Common/MapGuideCommon/MapGuideCommon.vcxproj.filters 2014-06-02 22:33:06 UTC (rev 8180)
@@ -394,6 +394,9 @@
<ClCompile Include="Util\TimerUtil.cpp">
<Filter>Util</Filter>
</ClCompile>
+ <Filter>Exception</Filter>
+ </ClCompile>
</ItemGroup>
<ItemGroup>
<ClInclude Include="MapLayer\Layer.h">
@@ -769,6 +772,9 @@
<ClInclude Include="Util\TimerUtil.h">
</ClInclude>
+ <ClInclude Include="Exception\UnknownTileProviderException.h">
+ </ClInclude>
</ItemGroup>
<ItemGroup>
<ResourceCompile Include="MapGuideCommon.rc" />
Modified: sandbox/jng/tiling/Common/MapGuideCommon/MapGuideCommonBuild.cpp
--- sandbox/jng/tiling/Common/MapGuideCommon/MapGuideCommonBuild.cpp 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Common/MapGuideCommon/MapGuideCommonBuild.cpp 2014-06-02 22:33:06 UTC (rev 8180)
@@ -72,6 +72,7 @@
#include "Exception/SessionNotFoundException.cpp"
#include "Exception/StylizeLayerFailedException.cpp"
#include "Exception/UnauthorizedAccessException.cpp"
+#include "Exception/UnknownTileProviderException.cpp"
#include "Exception/UnsupportedProviderThreadModelException.cpp"
#include "Exception/UriFormatException.cpp"
#include "MapLayer/Layer.cpp"
Modified: sandbox/jng/tiling/Common/MapGuideCommon/MapLayer/Map.cpp
--- sandbox/jng/tiling/Common/MapGuideCommon/MapLayer/Map.cpp 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Common/MapGuideCommon/MapLayer/Map.cpp 2014-06-02 22:33:06 UTC (rev 8180)
@@ -111,10 +111,33 @@
// Initializes a new Map object.
// This method is used for Mg Viewers or for offline map production.
-void MgMap::Create(MgResourceService* resourceService, MgResourceIdentifier* mapDefinition, CREFSTRING mapName)
+void MgMap::Create(MgResourceService* resourceService, MgResourceIdentifier* resource, CREFSTRING mapName)
MG_TRY()
+ if (resource->GetResourceType() == MgResourceType::MapDefinition)
+ CreateFromMapDefinition(resourceService, resource, mapName);
+ else if (resource->GetResourceType() == MgResourceType::TileSetDefinition)
+ CreateFromTileSet(resourceService, resource, mapName);
+ else
+ throw new MgInvalidResourceTypeException(L"MgMap.Create", __LINE__, __WFILE__, NULL, L"", NULL);
+ MG_CATCH_AND_THROW(L"MgMap.Create")
+/// Initializes a new MgMap object given a map definition and a name for the map.
+/// This method is used for MapGuide Viewers or for offline map production.
+void MgMap::Create(MgResourceIdentifier* mapDefinition, CREFSTRING mapName)
+ Create(NULL, mapDefinition, mapName);
+void MgMap::CreateFromMapDefinition(MgResourceService* resourceService, MgResourceIdentifier* mapDefinition, CREFSTRING mapName)
+ MG_TRY()
InitializeResourceService(resourceService);
m_trackChangesDisabled = true;
@@ -151,17 +174,6 @@
assert(mdef.get() != NULL);
MgGeometryFactory gf;
- const Box2D& extent = mdef->GetExtents();
- Ptr<MgCoordinate> lowerLeft = gf.CreateCoordinateXY(extent.GetMinX(), extent.GetMinY());
- Ptr<MgCoordinate> upperRight = gf.CreateCoordinateXY(extent.GetMaxX(), extent.GetMaxY());
- m_mapExtent = new MgEnvelope(lowerLeft, upperRight);
- m_dataExtent = new MgEnvelope(lowerLeft, upperRight);
- m_backColor = mdef->GetBackgroundColor();
- Ptr<MgCoordinate> coordCenter = gf.CreateCoordinateXY(extent.GetMinX() + (extent.GetMaxX() - extent.GetMinX()) / 2,
- extent.GetMinY() + (extent.GetMaxY() - extent.GetMinY()) / 2);
- m_center = gf.CreatePoint(coordCenter);
Ptr<MgResourceIdentifier> tileSetDefId;
//If this Map Definition links to a Tile Set Definition, its coordinate system takes precedence
@@ -189,10 +201,47 @@
assert(tdef.get() != NULL);
m_srs = tdef->GetCoordinateSystem();
+ //If tile CS is not the same as map def CS, then the bounds of the map def need to be transformed
+ if (m_srs != mdef->GetCoordinateSystem())
+ Ptr<MgCoordinateSystemFactory> csFactory = new MgCoordinateSystemFactory();
+ Ptr<MgCoordinateSystem> mapCs = csFactory->Create(mdef->GetCoordinateSystem());
+ Ptr<MgCoordinateSystem> tileCs = csFactory->Create(tdef->GetCoordinateSystem());
+ Ptr<MgCoordinateSystemTransform> trans = csFactory->GetTransform(mapCs, tileCs);
+ const Box2D& extent = mdef->GetExtents();
+ Ptr<MgCoordinate> lowerLeft = gf.CreateCoordinateXY(extent.GetMinX(), extent.GetMinY());
+ Ptr<MgCoordinate> upperRight = gf.CreateCoordinateXY(extent.GetMaxX(), extent.GetMaxY());
+ Ptr<MgEnvelope> mapExtent = new MgEnvelope(lowerLeft, upperRight);
+ Ptr<MgEnvelope> dataExtent = new MgEnvelope(lowerLeft, upperRight);
+ m_mapExtent = mapExtent->Transform(trans);
+ m_dataExtent = mapExtent->Transform(trans);
+ Ptr<MgCoordinate> ll = mapExtent->GetLowerLeftCoordinate();
+ Ptr<MgCoordinate> ur = mapExtent->GetUpperRightCoordinate();
+ Ptr<MgCoordinate> coordCenter = gf.CreateCoordinateXY(ll->GetX() + (ur->GetX() - ll->GetX()) / 2,
+ ll->GetY() + (ur->GetY() - ll->GetY()) / 2);
+ m_center = gf.CreatePoint(coordCenter);
else
m_srs = mdef->GetCoordinateSystem();
+ m_mapExtent = new MgEnvelope(lowerLeft, upperRight);
+ m_dataExtent = new MgEnvelope(lowerLeft, upperRight);
+ m_backColor = mdef->GetBackgroundColor();
+ Ptr<MgCoordinate> coordCenter = gf.CreateCoordinateXY(extent.GetMinX() + (extent.GetMaxX() - extent.GetMinX()) / 2,
+ extent.GetMinY() + (extent.GetMaxY() - extent.GetMinY()) / 2);
//Calculate the meter per unit for the given coordinate system
@@ -381,11 +430,16 @@
STRING groupName = baseGroup->GetName();
Ptr<MgLayerGroup> rtGroup;
if (NULL != (MgResourceIdentifier*)tileSetDefId)
rtGroup = new MgLayerGroup(groupName, tileSetDefId);
+ rtGroup->SetLayerGroupType(MgLayerGroupType::BaseMapFromTileSet);
else
rtGroup = new MgLayerGroup(groupName);
+ rtGroup->SetLayerGroupType(MgLayerGroupType::BaseMap);
rtGroup->SetVisible(baseGroup->IsVisible());
- rtGroup->SetLayerGroupType(MgLayerGroupType::BaseMap);
rtGroup->SetDisplayInLegend(baseGroup->IsShowInLegend());
rtGroup->SetExpandInLegend(baseGroup->IsExpandInLegend());
rtGroup->SetLegendLabel(baseGroup->GetLegendLabel());
@@ -482,16 +536,216 @@
// there's nothing to unpack anymore in this case
m_unpackedLayersGroups = true;
- MG_CATCH_AND_THROW(L"MgMap.Create")
+ MG_CATCH_AND_THROW(L"MgMap.CreateFromMapDefinition")
-/// Initializes a new MgMap object given a map definition and a name for the map.
-/// This method is used for MapGuide Viewers or for offline map production.
-void MgMap::Create(MgResourceIdentifier* mapDefinition, CREFSTRING mapName)
+void MgMap::CreateFromTileSet(MgResourceService* resourceService, MgResourceIdentifier* tileSetDefId, CREFSTRING mapName)
- Create(NULL, mapDefinition, mapName);
+ MG_TRY()
+ InitializeResourceService(resourceService);
+ m_trackChangesDisabled = true;
+ m_mapDefinitionId = NULL;
+ m_name = mapName;
+ // reset the colorlist from our layers (std::list dtor clears the list)
+ delete m_colorPalette;
+ m_colorPalette = NULL; // initialize to empty (lazy as its only used for 8bit color)
+ // generate a unique id for this map
+ MgUtil::GenerateUuid(m_objectId);
+ // get the map definition from the resource repository
+ Ptr<MgByteReader> content = m_resourceService->GetResourceContent(tileSetDefId);
+ Ptr<MgByteSink> sink = new MgByteSink(content);
+ Ptr<MgByte> bytes = sink->ToBuffer();
+ // parse the map definition
+ MdfParser::SAX2Parser parser;
+ parser.ParseString((const char*)bytes->Bytes(), bytes->GetLength());
+ if (!parser.GetSucceeded())
+ STRING errorMsg = parser.GetErrorMessage();
+ MgStringCollection arguments;
+ arguments.Add(errorMsg);
+ throw new MgInvalidMapDefinitionException(L"MgMap.Create", __LINE__, __WFILE__, &arguments, L"", NULL);
+ // build the runtime map object from the parsed definition
+ std::auto_ptr<MdfModel::TileSetDefinition> tdef(parser.DetachTileSetDefinition());
+ assert(tdef.get() != NULL);
+ MgGeometryFactory gf;
+ const Box2D& extent = tdef->GetExtents();
+ m_backColor = L"FFFFFFFF";
+ m_srs = tdef->GetCoordinateSystem();
+ //Calculate the meter per unit for the given coordinate system
+ m_metersPerUnit = 1.0; // assume a default value
+ if (m_srs.length() > 0)
+ Ptr<MgCoordinateSystemFactory> coordFactory = new MgCoordinateSystemFactory();
+ Ptr<MgCoordinateSystem> coordSys = coordFactory->Create(m_srs);
+ if (coordSys != NULL)
+ m_metersPerUnit = coordSys->ConvertCoordinateSystemUnitsToMeters(1.0);
+ // clear the collections
+ m_layers->Clear();
+ m_groups->Clear();
+ m_changeLists->Clear();
+ m_finiteDisplayScales.clear();
+ double displayOrder = LAYER_ZORDER_TOP;
+ //Get all the layersand get the contents of them in a single request.
+ Ptr<MgStringCollection> layerIds = new MgStringCollection();
+ BaseMapLayerGroupCollection* baseLayerGroups = tdef->GetBaseMapLayerGroups();
+ if (baseLayerGroups)
+ for(int i = 0; i < baseLayerGroups->GetCount(); i ++)
+ BaseMapLayerGroup* baseGroup = (BaseMapLayerGroup*)baseLayerGroups->GetAt(i);
+ BaseMapLayerCollection* baseLayers = baseGroup->GetLayers();
+ if(baseLayers)
+ for(int j = 0; j < baseLayers->GetCount(); j ++)
+ layerIds->Add(baseLayers->GetAt(j)->GetLayerResourceID());
+ std::map<STRING, STRING> layerContentPair;
+ if (layerIds->GetCount() != 0)
+ Ptr<MgStringCollection> layerContents = m_resourceService->GetResourceContents(layerIds, NULL);
+ for(int i = 0; i < layerIds->GetCount(); i ++)
+ layerContentPair.insert(std::pair<STRING, STRING>(layerIds->GetItem(i), layerContents->GetItem(i)));
+ // BaseMapLayerGroups and BaseMapLayers come at the end
+ BaseMapLayerGroupCollection* baseGroups = tdef->GetBaseMapLayerGroups();
+ if (baseGroups)
+ for(int i = 0; i < baseGroups->GetCount(); i++)
+ BaseMapLayerGroup* baseGroup = (BaseMapLayerGroup*)baseGroups->GetAt(i);
+ //create a runtime group from this group and add it to the group collection
+ STRING groupName = baseGroup->GetName();
+ Ptr<MgLayerGroup> rtGroup;
+ rtGroup = new MgLayerGroup(groupName, tileSetDefId);
+ rtGroup->SetVisible(baseGroup->IsVisible());
+ rtGroup->SetDisplayInLegend(baseGroup->IsShowInLegend());
+ rtGroup->SetExpandInLegend(baseGroup->IsExpandInLegend());
+ rtGroup->SetLegendLabel(baseGroup->GetLegendLabel());
+ // NOTE: base groups do not have a parent group
+ m_groups->Add(rtGroup);
+ // process the base map layers for this group
+ if (baseLayers)
+ for(int j = 0; j < baseLayers->GetCount(); j++, displayOrder += LAYER_ZORDER_INCR)
+ BaseMapLayer* baseLayer = (BaseMapLayer*)baseLayers->GetAt(j);
+ // base layers should always be visible
+ assert(baseLayer->IsVisible());
+ if (baseLayer->IsVisible())
+ //create a runtime layer from this base layer and add it to the layer collection
+ Ptr<MgResourceIdentifier> layerDefId = new MgResourceIdentifier(baseLayer->GetLayerResourceID());
+ Ptr<MgLayerBase> rtLayer = new MgLayer(layerDefId, m_resourceService, true, false);
+ rtLayer->SetLayerResourceContent(layerContentPair[layerDefId->ToString()]);
+ rtLayer->SetName(baseLayer->GetName());
+ rtLayer->SetVisible(true);
+ rtLayer->SetLayerType(MgLayerType::BaseMap);
+ rtLayer->SetDisplayInLegend(baseLayer->IsShowInLegend());
+ rtLayer->SetExpandInLegend(baseLayer->IsExpandInLegend());
+ rtLayer->SetLegendLabel(baseLayer->GetLegendLabel());
+ rtLayer->SetSelectable(baseLayer->IsSelectable());
+ rtLayer->SetDisplayOrder(displayOrder);
+ m_layers->Add(rtLayer);
+ // attach the layer to its group
+ rtLayer->SetGroup(rtGroup);
+ // Now that we've added all the layers (dynamic and base map) to the m_layers collection,
+ // bulk load the identity properties for all layers
+ Ptr<MgSiteConnection> siteConn;
+ if (m_siteConnection.p != NULL)
+ siteConn = SAFE_ADDREF((MgSiteConnection*)m_siteConnection);
+ else
+ Ptr<MgUserInformation> userInfo = m_resourceService->GetUserInfo();
+ siteConn = new MgSiteConnection();
+ siteConn->Open(userInfo);
+ Ptr<MgFeatureService> featureService = dynamic_cast<MgFeatureService*>(siteConn->CreateService(MgServiceType::FeatureService));
+ BulkLoadIdentityProperties(featureService);
+ // build the sorted list of finite display scales
+ SORTEDSCALES sortedScales;
+ DisplayScaleCollection* displayScales = tdef->GetFiniteDisplayScales();
+ if (displayScales)
+ for(int i = 0; i < displayScales->GetCount(); i++)
+ DisplayScale* displayScale = displayScales->GetAt(i);
+ double scale = displayScale->GetValue();
+ // skip non-positive scales
+ if (scale <= 0.0)
+ continue;
+ // skip duplicate scales
+ SORTEDSCALES::iterator iter = sortedScales.find(scale);
+ if (iter != sortedScales.end())
+ continue;
+ // insert the scale (automatically sorted in ascending order)
+ sortedScales.insert(SORTEDSCALES::value_type(scale, scale));
+ // load the sorted scales into the vector
+ for (SORTEDSCALES::iterator sIter = sortedScales.begin(); sIter != sortedScales.end(); ++sIter)
+ m_finiteDisplayScales.push_back(sIter->second);
+ m_trackChangesDisabled = false;
+ // there's nothing to unpack anymore in this case
+ m_unpackedLayersGroups = true;
+ MG_CATCH_AND_THROW(L"MgMap.CreateFromTileSet")
Modified: sandbox/jng/tiling/Common/MapGuideCommon/MapLayer/Map.h
--- sandbox/jng/tiling/Common/MapGuideCommon/MapLayer/Map.h 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Common/MapGuideCommon/MapLayer/Map.h 2014-06-02 22:33:06 UTC (rev 8180)
@@ -664,6 +664,8 @@
static const INT32 m_cls_id = MapGuide_MapLayer_Map;
private:
+ void CreateFromMapDefinition(MgResourceService* resourceService, MgResourceIdentifier* resource, CREFSTRING mapName);
+ void CreateFromTileSet(MgResourceService* resourceService, MgResourceIdentifier* resource, CREFSTRING mapName);
// Version for serialization
static const int m_serializeVersion = (4<<16) + 0;
Modified: sandbox/jng/tiling/Common/MapGuideCommon/Services/TileDefs.cpp
--- sandbox/jng/tiling/Common/MapGuideCommon/Services/TileDefs.cpp 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Common/MapGuideCommon/Services/TileDefs.cpp 2014-06-02 22:33:06 UTC (rev 8180)
@@ -29,3 +29,4 @@
INT32 MgTileParameters::tileHeight = 300; // height for all tiles
const INT32 MgTileParameters::tileDPI = 96; // assumed DPI for all tiles
STRING MgTileParameters::tileFormat = MgImageFormats::Png; // image format for all tiles
+STRING MgTileParameters::tileCachePath = L""; // tile cache root directory
Modified: sandbox/jng/tiling/Common/MapGuideCommon/Services/TileDefs.h
--- sandbox/jng/tiling/Common/MapGuideCommon/Services/TileDefs.h 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Common/MapGuideCommon/Services/TileDefs.h 2014-06-02 22:33:06 UTC (rev 8180)
@@ -43,7 +43,7 @@
/// \cond INTERNAL
/// \brief
-/// Tile parameters.
+/// Default tile parameters.
/// INTERNAL do not document.
class MG_MAPGUIDE_API MgTileParameters
@@ -51,8 +51,9 @@
INTERNAL_API:
static INT32 tileWidth; // width for all tiles
static INT32 tileHeight; // height for all tiles
- static const INT32 tileDPI; // assumed DPI for all tiles
+ static const INT32 tileDPI; // assumed DPI for all tiles
static STRING tileFormat; // image format for all tiles
+ static STRING tileCachePath; // tile cache root path
/// \endcond
Modified: sandbox/jng/tiling/Common/MapGuideCommon/System/MapGuideCommonClassId.h
--- sandbox/jng/tiling/Common/MapGuideCommon/System/MapGuideCommonClassId.h 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Common/MapGuideCommon/System/MapGuideCommonClassId.h 2014-06-02 22:33:06 UTC (rev 8180)
@@ -89,6 +89,7 @@
#define MapGuide_Exception_MgUnsupportedProviderThreadModelException MAPGUIDE_EXCEPTION_ID+53
#define MapGuide_Exception_MgAllProviderConnectionsUsedException MAPGUIDE_EXCEPTION_ID+54
#define MapGuide_Exception_MgRasterTransformationNotSupportedException MAPGUIDE_EXCEPTION_ID+55
+#define MapGuide_Exception_MgUnknownTileProviderException MAPGUIDE_EXCEPTION_ID+56
// MapLayer API
Modified: sandbox/jng/tiling/Server/src/PostBuild/PostBuild.mak
--- sandbox/jng/tiling/Server/src/PostBuild/PostBuild.mak 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Server/src/PostBuild/PostBuild.mak 2014-06-02 22:33:06 UTC (rev 8180)
@@ -164,6 +164,8 @@
..\..\bin\UnitTestFiles\TEST.FeatureSource \
..\..\bin\UnitTestFiles\TEST.sdf \
..\..\bin\UnitTestFiles\UT_BaseMap.mdf \
+ ..\..\bin\UnitTestFiles\UT_BaseMap.tsd \
+ ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf \
..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf \
..\..\bin\UnitTestFiles\UT_Parcels.fs \
..\..\bin\UnitTestFiles\UT_Parcels.ldf \
@@ -433,6 +435,8 @@
@@ -702,6 +706,8 @@
@@ -971,6 +977,8 @@
@@ -1113,6 +1121,8 @@
if EXIST ..\..\bin\UnitTestFiles\TEST.FeatureSource del /F ..\..\bin\UnitTestFiles\TEST.FeatureSource
if EXIST ..\..\bin\UnitTestFiles\TEST.sdf del /F ..\..\bin\UnitTestFiles\TEST.sdf
if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap.mdf del /F ..\..\bin\UnitTestFiles\UT_BaseMap.mdf
+ if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap.tsd del /F ..\..\bin\UnitTestFiles\UT_BaseMap.tsd
+ if EXIST ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf del /F ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf
if EXIST ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf del /F ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf
if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.fs del /F ..\..\bin\UnitTestFiles\UT_Parcels.fs
if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.ldf del /F ..\..\bin\UnitTestFiles\UT_Parcels.ldf
@@ -1250,6 +1260,8 @@
@@ -1387,6 +1399,8 @@
@@ -1522,6 +1536,8 @@
@@ -1784,6 +1800,8 @@
@@ -2046,6 +2064,8 @@
@@ -2308,6 +2328,8 @@
@@ -2570,6 +2592,8 @@
@@ -2705,6 +2729,8 @@
@@ -2835,6 +2861,8 @@
@@ -2965,6 +2993,8 @@
@@ -3093,6 +3123,8 @@
@@ -3228,6 +3260,8 @@
"..\..\..\UnitTestFiles\UT_SingleFTSMultiCTS.ldf" :
"..\..\..\UnitTest\TestData\MappingService\UT_RotatedPointStyles.ldf" :
"..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf" :
+"..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd" :
+"..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" :
"..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" :
"..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs" :
"..\..\..\UnitTest\TestData\TileService\UT_Parcels.ldf" :
@@ -3467,6 +3501,14 @@
if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
if EXIST "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf" ..\..\bin\UnitTestFiles\
+..\..\bin\UnitTestFiles\UT_BaseMap.tsd : "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd"
+ if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
+ if EXIST "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd" ..\..\bin\UnitTestFiles\
+..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf : "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf"
+ if EXIST "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" ..\..\bin\UnitTestFiles\
..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf : "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf"
if EXIST "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" ..\..\bin\UnitTestFiles\
Modified: sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.cpp
--- sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.cpp 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.cpp 2014-06-02 22:33:06 UTC (rev 8180)
@@ -17,9 +17,15 @@
#include "ServerTileService.h"
+#include "TileSetDefinition.h"
+#include "UnmanagedDataManager.h"
+#include "SAX2Parser.h"
IMPLEMENT_CREATE_SERVICE(MgServerTileService)
+#define TILE_PROVIDER_DEFAULT L"Default"
+#define TILE_PROVIDER_DEFAULT_PARAM_TILEPATH L"TilePath"
MgServerTileService::MgServerTileService() : MgTileService()
MgTileCacheDefault::Initialize();
@@ -190,7 +196,49 @@
+ // get service manager
+ MgServiceManager* serviceMan = MgServiceManager::GetInstance();
+ assert(NULL != serviceMan);
+ // Get the service from service manager
+ Ptr<MgResourceService> resourceService = dynamic_cast<MgResourceService*>(
+ serviceMan->RequestService(MgServiceType::ResourceService));
+ assert(NULL != resourceService);
+ if (!resourceService->HasPermission(resource, MgResourcePermission::ReadOnly))
+ MG_LOG_AUTHENTICATION_ENTRY(MgResources::PermissionDenied.c_str());
+ arguments.Add(resource->ToString());
+ throw new MgPermissionDeniedException(L"MgServerTileService.GetTileCache", __LINE__, __WFILE__, &arguments, L"", NULL);
+ Ptr<MgByteReader> content = resourceService->GetResourceContent(resource);
+ std::string xml;
+ sink->ToStringUtf8(xml);
+ // Before parsing, do any substitutions on the content
+ MgUnmanagedDataManager::SubstituteDataPathAliases(xml);
+ // parse the tile set definition
+ parser.ParseString(xml.c_str(), xml.size());
+ throw new MgXmlParserException(L"MgServerTileService.GetTileCache", __LINE__, __WFILE__, &arguments, L"", NULL);
+ MdfModel::TileSetDefinition* tileset = parser.DetachTileSetDefinition();
+ assert(NULL != tileset);
+ cache = GetTileCache(resource, tileset);
MG_CATCH_AND_THROW(L"MgServerTileService.GetTileCache")
@@ -198,6 +246,47 @@
return cache.Detach();
+MgTileCache* MgServerTileService::GetTileCache(MgResourceIdentifier* tileSetId, MdfModel::TileSetDefinition* tileset)
+ Ptr<MgTileCache> cache;
+ MG_TRY()
+ MdfModel::TileStoreParameters* tilesetParams = tileset->GetTileStoreParameters();
+ const MdfModel::MdfString& provider = tilesetParams->GetTileProvider();
+ if (provider == TILE_PROVIDER_DEFAULT)
+ MdfModel::NameStringPairCollection* parameters = tilesetParams->GetParameters();
+ STRING path;
+ for (INT32 i = 0; i < parameters->GetCount(); i++)
+ MdfModel::NameStringPair* pair = parameters->GetAt(i);
+ if (pair->GetName() == TILE_PROVIDER_DEFAULT_PARAM_TILEPATH)
+ path = pair->GetValue();
+ //If we find the cache path substitution tag, replace it with the default path from the configuration
+ if (path == MgResourceTag::TileCachePath)
+ path = MgTileParameters::tileCachePath;
+ cache = new MgTileCacheDefaultProvider(tileSetId, path, tilesetParams->GetTileWidth(), tilesetParams->GetTileHeight(), tilesetParams->GetFormat());
+ else
+ arguments.Add(provider);
+ throw new MgUnknownTileProviderException(L"MgServerTileService.GetTileCache", __LINE__, __WFILE__, &arguments, L"UnknownTileProvider", NULL);
+ MG_CATCH_AND_THROW(L"MgServerTileService.GetTileCache")
+ return cache.Detach();
bool MgServerTileService::IsTileCacheEmpty() const
return false;
Modified: sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.h
--- sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.h 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.h 2014-06-02 22:33:06 UTC (rev 8180)
@@ -21,6 +21,11 @@
#include "ServerTileDllExport.h"
#include "TileCache.h"
+namespace MdfModel
+ class TileSetDefinition;
class MG_SERVER_TILE_API MgServerTileService : public MgTileService
DECLARE_CLASSNAME(MgServerTileService)
@@ -72,6 +77,7 @@
private:
MgTileCache* GetTileCache(MgResourceIdentifier* resource);
+ MgTileCache* GetTileCache(MgResourceIdentifier* tileSetId, MdfModel::TileSetDefinition* tileset);
#endif
Modified: sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.vcxproj
--- sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.vcxproj 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.vcxproj 2014-06-02 22:33:06 UTC (rev 8180)
@@ -94,7 +94,7 @@
<ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
<ClCompile>
<Optimization>Disabled</Optimization>
- <AdditionalIncludeDirectories>..\..\..\..\Common\Foundation;..\..\..\..\Common\Geometry;..\..\..\..\Common\PlatformBase;..\..\..\..\Common\MapGuideCommon;..\..\..\..\Common\MdfModel;..\..\Common;..\..\Common\Base;..\..\Common\Manager;..\Mapping;..\..\..\..\Oem\ACE\ACE_wrappers;..\..\..\..\Oem\FDO\inc;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
+ <AdditionalIncludeDirectories>..\..\..\..\Common\Foundation;..\..\..\..\Common\Geometry;..\..\..\..\Common\PlatformBase;..\..\..\..\Common\MapGuideCommon;..\..\..\..\Common\MdfModel;..\..\..\..\Common\MdfParser;..\..\Common;..\..\Common\Base;..\..\Common\Manager;..\Mapping;..\..\..\..\Oem\ACE\ACE_wrappers;..\..\..\..\Oem\FDO\inc;..\..\..\..\Oem\dbxml\xerces-c-src\src;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
<PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;MG_SERVER_TILE_EXPORTS;%(PreprocessorDefinitions)</PreprocessorDefinitions>
<ExceptionHandling>Async</ExceptionHandling>
<BasicRuntimeChecks>EnableFastChecks</BasicRuntimeChecks>
@@ -104,9 +104,9 @@
<MultiProcessorCompilation>true</MultiProcessorCompilation>
</ClCompile>
<Link>
- <AdditionalDependencies>ACEd.lib;%(AdditionalDependencies)</AdditionalDependencies>
+ <AdditionalDependencies>ACEd.lib;MgMdfModeld.lib;MgMdfParserd.lib;%(AdditionalDependencies)</AdditionalDependencies>
<OutputFile>$(OutDir)MgServerTileServiced.dll</OutputFile>
- <AdditionalLibraryDirectories>..\..\..\..\Oem\ACE\ACE_wrappers\lib\$(Configuration);%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
+ <AdditionalLibraryDirectories>..\..\..\..\Oem\ACE\ACE_wrappers\lib\$(Configuration);..\..\..\..\Common\lib\Debug;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
<GenerateDebugInformation>true</GenerateDebugInformation>
<ProgramDatabaseFile>$(OutDir)MgServerTileServiced.pdb</ProgramDatabaseFile>
<SubSystem>Windows</SubSystem>
@@ -120,7 +120,7 @@
<ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">
<ClCompile>
@@ -130,9 +130,9 @@
</ClCompile>
<Link>
- <AdditionalLibraryDirectories>..\..\..\..\Oem\ACE\ACE_wrappers\lib64\$(Configuration);%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
+ <AdditionalLibraryDirectories>..\..\..\..\Oem\ACE\ACE_wrappers\lib64\$(Configuration);..\..\..\..\Common\lib\Debug64;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
@@ -146,7 +146,7 @@
<ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
<ClCompile>
<Optimization>MaxSpeed</Optimization>
<PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;MG_SERVER_TILE_EXPORTS;%(PreprocessorDefinitions)</PreprocessorDefinitions>
<RuntimeLibrary>MultiThreadedDLL</RuntimeLibrary>
@@ -155,9 +155,9 @@
</ClCompile>
<Link>
- <AdditionalDependencies>ACE.lib;%(AdditionalDependencies)</AdditionalDependencies>
+ <AdditionalDependencies>ACE.lib;MgMdfModel.lib;MgMdfParser.lib;%(AdditionalDependencies)</AdditionalDependencies>
<OutputFile>$(OutDir)MgServerTileService.dll</OutputFile>
+ <AdditionalLibraryDirectories>..\..\..\..\Oem\ACE\ACE_wrappers\lib\$(Configuration);..\..\..\..\Common\lib\Release;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
<ProgramDatabaseFile>$(OutDir)MgServerTileService.pdb</ProgramDatabaseFile>
@@ -173,7 +173,7 @@
<ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'">
<ClCompile>
@@ -182,9 +182,9 @@
</ClCompile>
<Link>
+ <AdditionalLibraryDirectories>..\..\..\..\Oem\ACE\ACE_wrappers\lib64\$(Configuration);..\..\..\..\Common\lib\Release64;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
@@ -234,6 +234,12 @@
</ClCompile>
+ <ClCompile Include="TileCacheDefaultProvider.cpp">
+ </ClCompile>
<ClCompile Include="TileOperation.cpp">
@@ -279,6 +285,7 @@
<ClInclude Include="OpGetTile.h" />
<ClInclude Include="OpSetTile.h" />
<ClInclude Include="TileCacheDefault.h" />
+ <ClInclude Include="TileCacheDefaultProvider.h" />
<ClInclude Include="TileOperation.h" />
<ClInclude Include="TileOperationFactory.h" />
<ClInclude Include="ServerTileDllExport.h" />
Modified: sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.vcxproj.filters
--- sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.vcxproj.filters 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.vcxproj.filters 2014-06-02 22:33:06 UTC (rev 8180)
@@ -33,6 +33,7 @@
<ClCompile Include="TileCache.cpp" />
<ClCompile Include="TileServiceHandler.cpp" />
<ClCompile Include="TileCacheDefault.cpp" />
+ <ClCompile Include="TileCacheDefaultProvider.cpp" />
</ItemGroup>
<ItemGroup>
<ClInclude Include="OpClearCache.h">
@@ -62,6 +63,7 @@
<ClInclude Include="TileCache.h" />
<ClInclude Include="TileServiceHandler.h" />
</ItemGroup>
<ItemGroup>
<ResourceCompile Include="ServerTileService.rc" />
Modified: sandbox/jng/tiling/Server/src/Services/Tile/ServerTileServiceBuild.cpp
--- sandbox/jng/tiling/Server/src/Services/Tile/ServerTileServiceBuild.cpp 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Server/src/Services/Tile/ServerTileServiceBuild.cpp 2014-06-02 22:33:06 UTC (rev 8180)
@@ -25,6 +25,7 @@
#include "OpGetDefaultTileSizeY.cpp"
#include "TileCache.cpp"
#include "TileCacheDefault.cpp"
+#include "TileCacheDefaultProvider.cpp"
#include "TileOperation.cpp"
#include "TileOperationFactory.cpp"
#include "TileServiceHandler.cpp"
Modified: sandbox/jng/tiling/Server/src/Services/Tile/TileCacheDefault.cpp
--- sandbox/jng/tiling/Server/src/Services/Tile/TileCacheDefault.cpp 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Server/src/Services/Tile/TileCacheDefault.cpp 2014-06-02 22:33:06 UTC (rev 8180)
@@ -35,6 +35,12 @@
INT32 MgTileCacheDefault::sm_pollingInterval = 1; // in seconds
INT32 MgTileCacheDefault::sm_mapCacheSize = 10;
+MgTileCacheDefault::MgTileCacheDefault()
+ m_map = NULL;
+ m_resourceId = NULL;
MgTileCacheDefault::MgTileCacheDefault(MgMap* map)
m_map = SAFE_ADDREF(map);
@@ -101,6 +107,8 @@
// create directory if it is not already there
MgFileUtil::CreateDirectory(sm_path, false, true);
+ MgTileParameters::tileCachePath = sm_path;
configuration->GetIntValue(MgConfigProperties::TileServicePropertiesSection,
MgConfigProperties::TileServicePropertyTileColumnsPerFolder,
sm_tileColumnsPerFolder,
@@ -154,17 +162,18 @@
if (m_map != NULL)
ret = GetTileForMap(baseMapLayerGroupName, tileColumn, tileRow, scaleIndex);
else if (m_resourceId != NULL)
- ret = GetTileForMapDefinition(baseMapLayerGroupName, tileColumn, tileRow, scaleIndex);
+ ret = GetTileForResource(m_resourceId, baseMapLayerGroupName, tileColumn, tileRow, scaleIndex);
MG_CATCH_AND_THROW(L"MgTileCacheDefault.GetTile")
return ret.Detach();
-MgByteReader* MgTileCacheDefault::GetTileForMapDefinition(CREFSTRING baseMapLayerGroupName,
- INT32 tileColumn,
- INT32 tileRow,
- INT32 scaleIndex)
+MgByteReader* MgTileCacheDefault::GetTileForResource(MgResourceIdentifier* resource,
+ CREFSTRING baseMapLayerGroupName,
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 scaleIndex)
Ptr<MgByteReader> ret;
FILE* lockFile = NULL;
@@ -172,9 +181,9 @@
MG_TRY()
- if (NULL == (MgResourceIdentifier*)m_resourceId || baseMapLayerGroupName.empty())
+ if (NULL == (MgResourceIdentifier*)resource || baseMapLayerGroupName.empty())
- throw new MgNullArgumentException(L"MgTileCacheDefault.GetTileForMapDefinition",
+ throw new MgNullArgumentException(L"MgTileCacheDefault.GetTileForResource",
@@ -187,15 +196,15 @@
arguments.Add(L"5");
arguments.Add(buffer);
- throw new MgInvalidArgumentException(L"MgTileCacheDefault.GetTileForMapDefinition",
+ throw new MgInvalidArgumentException(L"MgTileCacheDefault.GetTileForResource",
__LINE__, __WFILE__, &arguments, L"MgInvalidScaleIndex", NULL);
// get the service from our helper method
- Ptr<MgResourceService> resourceService = GetResourceServiceForMapDef(m_resourceId,
- L"MgTileCacheDefault.GetTileForMapDefinition");
+ Ptr<MgResourceService> resourceService = GetResourceServiceForMapDef(resource,
+ L"MgTileCacheDefault.GetTileForResource");
// Generate tile and lock pathnames.
- GeneratePathNames(m_resourceId, scaleIndex, baseMapLayerGroupName, tileColumn, tileRow, tilePathname, lockPathname, false);
+ GeneratePathNames(scaleIndex, baseMapLayerGroupName, tileColumn, tileRow, tilePathname, lockPathname, false);
// If there is a dangling lock file, then attempt to remove it.
if (DetectTileLockFile(lockPathname))
@@ -213,7 +222,7 @@
// Attempt use a cached & serialized MgMap object
Ptr<MgMemoryStreamHelper> cachedMap;
- STRING mapString = m_resourceId->ToString();
+ STRING mapString = resource->ToString();
Ptr<MgMap> map;
// Protect the serialized MgMap cache with a mutex. Stream reading is not
@@ -230,7 +239,7 @@
arguments.Add(lockPathname);
- throw new MgFileIoException(L"MgTileCacheDefault.GetTileForMapDefinition",
+ throw new MgFileIoException(L"MgTileCacheDefault.GetTileForResource",
__LINE__, __WFILE__, &arguments, L"MgUnableToLockTileFile", NULL);
@@ -243,7 +252,7 @@
// Create the lock file and close it right away.
- CreateFullPath(m_resourceId, scaleIndex, baseMapLayerGroupName, tileColumn, tileRow);
+ CreateFullPath(scaleIndex, baseMapLayerGroupName, tileColumn, tileRow);
lockFile = ACE_OS::fopen(MG_WCHAR_TO_TCHAR(lockPathname), ACE_TEXT("wb"));
if (NULL == lockFile)
@@ -251,7 +260,7 @@
__LINE__, __WFILE__, &arguments, L"MgUnableToOpenLockFile", NULL);
else
@@ -274,7 +283,7 @@
Ptr<MgUserInformation> userInfo = MgUserInformation::GetCurrentUserInfo();
map = new MgMap(siteConn);
- map->Create(resourceService, m_resourceId, mapString);
+ map->Create(resourceService, resource, mapString);
cachedMap = new MgMemoryStreamHelper();
Ptr<MgStream> stream = new MgStream(cachedMap);
map->Serialize(stream);
@@ -294,7 +303,7 @@
break;
- MG_CATCH(L"MgTileCacheDefault.GetTileForMapDefinition")
+ MG_CATCH(L"MgTileCacheDefault.GetTileForResource")
if (NULL != lockFile)
@@ -335,7 +344,7 @@
// Detect the lock file to see if another thread is creating the tile file.
- GeneratePathNames(m_map, scaleIndex, baseMapLayerGroupName,
@@ -375,7 +384,7 @@
- CreateFullPath(m_map, scaleIndex, baseMapLayerGroupName, tileColumn, tileRow);
@@ -426,7 +435,7 @@
if (svcRendering != NULL)
// generate the tile
- img = svcRendering->RenderTile(map, baseMapLayerGroupName, tileColumn, tileRow);
+ img = svcRendering->RenderTile(map, baseMapLayerGroupName, tileColumn, tileRow, GetDefaultTileSizeX(), GetDefaultTileSizeY(), map->GetDisplayDpi(), GetTileFormat());
// cache the tile
if (!sm_renderOnly)
@@ -475,7 +484,7 @@
tileColumn, tileRow, tilePathname, lockPathname, true);
@@ -520,23 +529,11 @@
void MgTileCacheDefault::Clear()
- if (m_map != NULL)
- STRING basePath = GetBasePath(m_map);
+ STRING basePath = GetBasePath();
- // delete main map directory
- if (!basePath.empty())
- MgFileUtil::DeleteDirectory(basePath, true, false);
- // the resource must be a map definition
- else if (m_resourceId != NULL && m_resourceId->GetResourceType() == MgResourceType::MapDefinition)
- STRING basePath = GetBasePath(m_resourceId);
+ // delete main map directory
+ if (!basePath.empty())
+ MgFileUtil::DeleteDirectory(basePath, true, false);
INT32 MgTileCacheDefault::GetDefaultTileSizeX()
@@ -549,6 +546,11 @@
return MgTileParameters::tileHeight;
+STRING MgTileCacheDefault::GetTileFormat()
+ return MgTileParameters::tileFormat;
// accessor method for resource service
MgResourceService* MgTileCacheDefault::GetResourceServiceForMapDef(MgResourceIdentifier* mapDefinition,
@@ -643,27 +645,16 @@
-void MgTileCacheDefault::GeneratePathNames(MgMap* map, int scaleIndex,
- CREFSTRING group, int tileColumn, int tileRow,
- STRING& tilePathname, STRING& lockPathname, bool createFullPath)
- assert(NULL != map);
- Ptr<MgResourceIdentifier> mapDef = map->GetMapDefinition();
- GeneratePathNames(mapDef, scaleIndex, group, tileColumn, tileRow,
- tilePathname, lockPathname, createFullPath);
/// \brief
/// Generate tile and lock pathnames.
-void MgTileCacheDefault::GeneratePathNames(MgResourceIdentifier* mapDef, int scaleIndex,
+void MgTileCacheDefault::GeneratePathNames(int scaleIndex,
STRING fileName = L"/" + GetTileName(tileRow, tileColumn) + L".";
- STRING basePath = GetBasePath(mapDef);
if (createFullPath)
@@ -679,11 +670,12 @@
// <lockPathname> = <fullPath>/<row>_<column>.lck
tilePathname += fileName;
lockPathname = tilePathname;
- if (MgTileParameters::tileFormat == MgImageFormats::Jpeg)
+ STRING fmt = GetTileFormat();
+ if (fmt == MgImageFormats::Jpeg)
tilePathname += L"jpg";
- else if (MgTileParameters::tileFormat == MgImageFormats::Gif)
+ else if (fmt == MgImageFormats::Gif)
tilePathname += L"gif";
@@ -772,45 +764,42 @@
return fullPath;
-STRING MgTileCacheDefault::CreateFullPath(MgResourceIdentifier* mapDef, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow)
+STRING MgTileCacheDefault::CreateFullPath(int scaleIndex, CREFSTRING group, int tileColumn, int tileRow)
- return CreateFullPath(GetBasePath(mapDef), scaleIndex, group, tileColumn, tileRow);
+ return CreateFullPath(GetBasePath(), scaleIndex, group, tileColumn, tileRow);
-STRING MgTileCacheDefault::CreateFullPath(MgMap* map, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow)
+STRING MgTileCacheDefault::GetBasePath()
- return CreateFullPath(GetBasePath(map), scaleIndex, group, tileColumn, tileRow);
+ Ptr<MgResourceIdentifier> resId;
+ if (NULL != (MgMap*)m_map)
+ resId = m_map->GetMapDefinition();
+ else if (NULL != m_resourceId && m_resourceId->GetResourceType() == MgResourceType::MapDefinition)
+ resId = SAFE_ADDREF((MgResourceIdentifier*)m_resourceId);
+ return GetBasePathFromResourceId(resId);
-// gets the base path to use with the tile cache for the given map
-STRING MgTileCacheDefault::GetBasePath(MgMap* map)
+STRING MgTileCacheDefault::GetBasePathFromResourceId(MgResourceIdentifier* resId)
- return GetBasePath(mapDef);
-// gets the base path to use with the tile cache for the given map definition resource
-STRING MgTileCacheDefault::GetBasePath(MgResourceIdentifier* mapDef)
- assert(mapDef != NULL);
- assert(mapDef->GetResourceType() == MgResourceType::MapDefinition);
STRING mapPath;
- if (mapDef->GetRepositoryType() == MgRepositoryType::Library)
+ if (resId->GetRepositoryType() == MgRepositoryType::Library)
// for maps in the library repository the path+name is unique
- mapPath = mapDef->GetPath();
+ mapPath = resId->GetPath();
mapPath += L"_";
- mapPath += mapDef->GetName();
+ mapPath += resId->GetName();
- else if (mapDef->GetRepositoryType() == MgRepositoryType::Session)
+ else if (resId->GetRepositoryType() == MgRepositoryType::Session)
// for maps in the session repository we use the session + path + map name
- mapPath = mapDef->GetRepositoryName();
+ mapPath = resId->GetRepositoryName();
mapPath += L"_";
- STRING resourcePath = mapDef->GetPath();
+ STRING resourcePath = resId->GetPath();
if (!resourcePath.empty())
@@ -818,7 +807,7 @@
mapPath += L"_";
else
@@ -863,19 +852,11 @@
// gets the full path to use with the tile cache for the given map definition / scale index / group
-STRING MgTileCacheDefault::GetFullPath(MgResourceIdentifier* mapDef, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow)
+STRING MgTileCacheDefault::GetFullPath(int scaleIndex, CREFSTRING group, int tileColumn, int tileRow)
- return GetFullPath(GetBasePath(mapDef), scaleIndex, group, tileColumn, tileRow);
+ return GetFullPath(GetBasePath(), scaleIndex, group, tileColumn, tileRow);
-// gets the full path to use with the tile cache for the given map / scale index / group
-STRING MgTileCacheDefault::GetFullPath(MgMap* map, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow)
- return GetFullPath(mapDef, scaleIndex, group, tileColumn, tileRow);
// Get the folder name corresponding to the specified tile column
STRING MgTileCacheDefault::GetColumnFolder(int tileColumn)
Modified: sandbox/jng/tiling/Server/src/Services/Tile/TileCacheDefault.h
--- sandbox/jng/tiling/Server/src/Services/Tile/TileCacheDefault.h 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Server/src/Services/Tile/TileCacheDefault.h 2014-06-02 22:33:06 UTC (rev 8180)
@@ -19,9 +19,11 @@
+//The default tile cache implementation with default settings based on server configuration
class MG_SERVER_TILE_API MgTileCacheDefault : public MgTileCache
public:
+ MgTileCacheDefault();
MgTileCacheDefault(MgMap* map);
MgTileCacheDefault(MgResourceIdentifier* resource);
virtual ~MgTileCacheDefault();
@@ -45,6 +47,8 @@
virtual INT32 GetDefaultTileSizeY();
+ virtual STRING GetTileFormat();
void ClearMapCache(CREFSTRING mapName);
protected:
@@ -53,12 +57,17 @@
delete this;
+ virtual STRING GetBasePath();
+ virtual STRING GetFullPath(CREFSTRING basePath, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
+ virtual STRING CreateFullPath(CREFSTRING basePath, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
+ MgByteReader* GetTileForResource(MgResourceIdentifier* resource,
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 scaleIndex);
private:
- MgByteReader* GetTileForMapDefinition(CREFSTRING baseMapLayerGroupName,
- INT32 tileColumn,
- INT32 tileRow,
- INT32 scaleIndex);
MgByteReader* GetTileForMap(CREFSTRING baseMapLayerGroupName,
INT32 tileColumn,
INT32 tileRow,
@@ -69,23 +78,15 @@
void Set(MgByteReader* img, CREFSTRING path);
MgByteReader* Get(CREFSTRING path);
- void GeneratePathNames(MgResourceIdentifier* mapDef, int scaleIndex,
+ void GeneratePathNames(int scaleIndex,
STRING& tilePathname, STRING& lockPathname, bool createFullPath);
- void GeneratePathNames(MgMap* map, int scaleIndex,
- STRING& tilePathname, STRING& lockPathname, bool createFullPath);
- STRING GetBasePath(MgResourceIdentifier* mapDef);
- STRING GetBasePath(MgMap* map);
- STRING GetFullPath(CREFSTRING basePath, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
- STRING GetFullPath(MgResourceIdentifier* mapDef, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
- STRING GetFullPath(MgMap* map, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
+ STRING GetBasePathFromResourceId(MgResourceIdentifier* resId);
- STRING CreateFullPath(MgResourceIdentifier* mapDef, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
- STRING CreateFullPath(MgMap* map, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
- STRING CreateFullPath(CREFSTRING basePath, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
+ STRING GetFullPath(int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
+ STRING CreateFullPath(int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
STRING GetScaleIndexFolder(int scaleIndex);
STRING GetRowFolder(int tileRow);
Modified: sandbox/jng/tiling/Server/src/UnitTesting/TestMdfModel.cpp
--- sandbox/jng/tiling/Server/src/UnitTesting/TestMdfModel.cpp 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Server/src/UnitTesting/TestMdfModel.cpp 2014-06-02 22:33:06 UTC (rev 8180)
@@ -82,6 +82,11 @@
Ptr<MgByteSource> mdfsrc4 = new MgByteSource(L"../UnitTestFiles/MdfTestMap.mdf", false);
Ptr<MgByteReader> mdfrdr4 = mdfsrc4->GetReader();
m_svcResource->SetResource(mdfres4, mdfrdr4, NULL);
+ Ptr<MgResourceIdentifier> mdfres5 = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/MdfTestTileSet.TileSetDefinition");
+ Ptr<MgByteSource> mdfsrc5 = new MgByteSource(L"../UnitTestFiles/UT_BaseMap.tsd", false);
+ Ptr<MgByteReader> mdfrdr5 = mdfsrc5->GetReader();
+ m_svcResource->SetResource(mdfres5, mdfrdr5, NULL);
catch (MgException* e)
@@ -114,6 +119,8 @@
m_svcResource->DeleteResource(ldfres3);
Ptr<MgResourceIdentifier> mdfres4 = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/MdfTestMap.MapDefinition");
m_svcResource->DeleteResource(mdfres4);
+ m_svcResource->DeleteResource(mdfres5);
catch(MgFileIoException* e)
@@ -861,3 +868,77 @@
CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+void TestMdfModel::TestCase_TileSetDefinition()
+ try
+ Ptr<MgResourceIdentifier> tsId = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/MdfTestTileSet.TileSetDefinition");
+ Ptr<MgByteReader> content = m_svcResource->GetResourceContent(tsId);
+ CPPUNIT_ASSERT(parser.GetSucceeded());
+ CPPUNIT_ASSERT(NULL != tileset);
+ CPPUNIT_ASSERT(NULL != tilesetParams);
+ CPPUNIT_ASSERT(L"Default" == tilesetParams->GetTileProvider());
+ CPPUNIT_ASSERT(256 == tilesetParams->GetTileWidth());
+ CPPUNIT_ASSERT(256 == tilesetParams->GetTileHeight());
+ CPPUNIT_ASSERT(L"PNG" == tilesetParams->GetFormat());
+ const MdfModel::Box2D& extents = tileset->GetExtents();
+ CPPUNIT_ASSERT_DOUBLES_EQUAL(-87.79786601383196, extents.GetMinX(), 0.00000000000001);
+ CPPUNIT_ASSERT_DOUBLES_EQUAL( 43.686857862181, extents.GetMinY(), 0.000000000001);
+ CPPUNIT_ASSERT_DOUBLES_EQUAL(-87.66452777186925, extents.GetMaxX(), 0.00000000000001);
+ CPPUNIT_ASSERT_DOUBLES_EQUAL( 43.8037962206133, extents.GetMaxY(), 0.0000000000001);
+ MdfModel::DisplayScaleCollection* scales = tileset->GetFiniteDisplayScales();
+ CPPUNIT_ASSERT(10 == scales->GetCount());
+ CPPUNIT_ASSERT(200000 == scales->GetAt(0)->GetValue());
+ CPPUNIT_ASSERT(100000 == scales->GetAt(1)->GetValue());
+ CPPUNIT_ASSERT(50000 == scales->GetAt(2)->GetValue());
+ CPPUNIT_ASSERT(25000 == scales->GetAt(3)->GetValue());
+ CPPUNIT_ASSERT(12500 == scales->GetAt(4)->GetValue());
+ CPPUNIT_ASSERT(6250 == scales->GetAt(5)->GetValue());
+ CPPUNIT_ASSERT(3125 == scales->GetAt(6)->GetValue());
+ CPPUNIT_ASSERT(1562.5 == scales->GetAt(7)->GetValue());
+ CPPUNIT_ASSERT(781.25 == scales->GetAt(8)->GetValue());
+ CPPUNIT_ASSERT(390.625 == scales->GetAt(9)->GetValue());
+ MdfModel::BaseMapLayerGroupCollection* groups = tileset->GetBaseMapLayerGroups();
+ CPPUNIT_ASSERT(1 == groups->GetCount());
+ CPPUNIT_ASSERT(L"BaseLayers" == groups->GetAt(0)->GetName());
+ CPPUNIT_ASSERT(L"Base Layers" == groups->GetAt(0)->GetLegendLabel());
+ CPPUNIT_ASSERT(groups->GetAt(0)->IsShowInLegend());
+ CPPUNIT_ASSERT(groups->GetAt(0)->IsExpandInLegend());
+ MdfModel::BaseMapLayerCollection* layers = groups->GetAt(0)->GetLayers();
+ CPPUNIT_ASSERT(2 == layers->GetCount());
+ CPPUNIT_ASSERT(L"Parcels" == layers->GetAt(0)->GetName());
+ CPPUNIT_ASSERT(L"Parcels" == layers->GetAt(0)->GetLegendLabel());
+ CPPUNIT_ASSERT(L"Library://UnitTests/Layers/Parcels.LayerDefinition" == layers->GetAt(0)->GetLayerResourceID());
+ CPPUNIT_ASSERT(!layers->GetAt(0)->IsExpandInLegend());
+ CPPUNIT_ASSERT(layers->GetAt(0)->IsShowInLegend());
+ CPPUNIT_ASSERT(layers->GetAt(0)->IsSelectable());
+ CPPUNIT_ASSERT(L"VotingDistricts" == layers->GetAt(1)->GetName());
+ CPPUNIT_ASSERT(L"Voting Districts" == layers->GetAt(1)->GetLegendLabel());
+ CPPUNIT_ASSERT(L"Library://UnitTests/Layers/VotingDistricts.LayerDefinition" == layers->GetAt(1)->GetLayerResourceID());
+ CPPUNIT_ASSERT(!layers->GetAt(1)->IsExpandInLegend());
+ CPPUNIT_ASSERT(layers->GetAt(1)->IsShowInLegend());
+ CPPUNIT_ASSERT(layers->GetAt(1)->IsSelectable());
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
Modified: sandbox/jng/tiling/Server/src/UnitTesting/TestMdfModel.h
--- sandbox/jng/tiling/Server/src/UnitTesting/TestMdfModel.h 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Server/src/UnitTesting/TestMdfModel.h 2014-06-02 22:33:06 UTC (rev 8180)
@@ -28,6 +28,8 @@
CPPUNIT_TEST(TestCase_Serialization);
CPPUNIT_TEST(TestCase_Versioning);
+ CPPUNIT_TEST(TestCase_TileSetDefinition);
CPPUNIT_TEST(TestEnd); // This must be the very last unit test
CPPUNIT_TEST_SUITE_END();
@@ -42,6 +44,7 @@
void TestCase_Serialization();
void TestCase_Versioning();
+ void TestCase_TileSetDefinition();
private:
Ptr<MgResourceService> m_svcResource;
Modified: sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.cpp
--- sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.cpp 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.cpp 2014-06-02 22:33:06 UTC (rev 8180)
@@ -118,6 +118,16 @@
Ptr<MgByteReader> mdfrdr1 = mdfsrc1->GetReader();
m_svcResource->SetResource(mapres1, mdfrdr1, NULL);
+ Ptr<MgResourceIdentifier> mapres2 = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSet.MapDefinition");
+ Ptr<MgByteSource> mdfsrc2 = new MgByteSource(L"../UnitTestFiles/UT_LinkedTileSet.mdf", false);
+ Ptr<MgByteReader> mdfrdr2 = mdfsrc2->GetReader();
+ m_svcResource->SetResource(mapres2, mdfrdr2, NULL);
+ Ptr<MgResourceIdentifier> tilesetres1 = new MgResourceIdentifier(L"Library://UnitTests/TileSets/Sheboygan.TileSetDefinition");
+ Ptr<MgByteSource> tsdsrc1 = new MgByteSource(L"../UnitTestFiles/UT_BaseMap.tsd", false);
+ Ptr<MgByteReader> tsdrdr1 = tsdsrc1->GetReader();
+ m_svcResource->SetResource(tilesetres1, tsdrdr1, NULL);
// publish the layer definitions
Ptr<MgResourceIdentifier> ldfres1 = new MgResourceIdentifier(L"Library://UnitTests/Layers/RoadCenterLines.LayerDefinition");
Ptr<MgByteSource> ldfsrc1 = new MgByteSource(L"../UnitTestFiles/UT_RoadCenterLines.ldf", false);
@@ -196,6 +206,12 @@
Ptr<MgResourceIdentifier> mapres1 = new MgResourceIdentifier(L"Library://UnitTests/Maps/BaseMap.MapDefinition");
m_svcResource->DeleteResource(mapres1);
+ m_svcResource->DeleteResource(mapres2);
+ m_svcResource->DeleteResource(tilesetres1);
// delete the layer definitions
m_svcResource->DeleteResource(ldfres1);
@@ -251,6 +267,8 @@
Ptr<MgMap> map;
INT32 tileRow;
INT32 tileCol;
+ INT32 tileScale;
+ STRING tileSetId;
@@ -451,7 +469,198 @@
+// the method which gets executed by the ACE worker thread
+ACE_THR_FUNC_RETURN GetTileLinkedWorker(void* param)
+ // get the data for this thread
+ TileThreadData* threadData = (TileThreadData*)param;
+ INT32 threadId = threadData->threadId;
+ INT32 tileRow = threadData->tileRow;
+ INT32 tileCol = threadData->tileCol;
+ INT32 tileScale = threadData->tileScale;
+ bool saveTile = threadData->saveTile;
+ Ptr<MgResourceIdentifier> tsId = new MgResourceIdentifier(threadData->tileSetId);
+ #ifdef _DEBUG
+ printf("> thread %d started, tile %d,%d\n", threadId, tileRow, tileCol);
+ #endif
+ try
+ // set user info
+ Ptr<MgUserInformation> userInfo = new MgUserInformation(L"Administrator", L"admin");
+ userInfo->SetLocale(TEST_LOCALE);
+ MgUserInformation::SetCurrentUserInfo(userInfo);
+ // get the tile service instance
+ MgServiceManager* serviceManager = MgServiceManager::GetInstance();
+ Ptr<MgTileService> svcTile = dynamic_cast<MgTileService*>(
+ serviceManager->RequestService(MgServiceType::TileService));
+ assert(svcTile != NULL);
+ // get the tile
+ Ptr<MgByteReader> img = svcTile->GetTile(tsId, L"BaseLayers", tileCol, tileRow, tileScale);
+ CHECKNULL((MgByteReader*)img, L"GetTileLinkedWorker");
+ // save the image to a file if necessary
+ if (saveTile)
+ wchar_t imgName[PATH_LEN] = { 0 };
+ swprintf(imgName, PATH_LEN, L"./temp_tiles/tile%d_%d.png", tileRow, tileCol);
+ (MgByteSink(img)).ToFile(imgName);
+ // clear the user info to prevent leaks
+ MgUserInformation::SetCurrentUserInfo(NULL);
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+ #ifdef _DEBUG
+// printf("> thread %d done\n", threadId);
+ #endif
+ threadData->done = true;
+ return 0;
+void TestTileService::TestCase_GetTileLinked()
+ // specify the number of threads to use
+ const INT32 numThreads = MG_TEST_THREADS;
+ TileThreadData threadData[numThreads];
+ // define the range of tiles to get
+ INT32 tileRowMin = 0;
+ INT32 tileRowMax = 12;
+ INT32 tileColMin = 3;
+ INT32 tileColMax = 11;
+ try
+ // need a thread manager
+ ACE_Thread_Manager* manager = ACE_Thread_Manager::instance();
+ // make the runtime map
+ Ptr<MgMap> map = CreateMapLinked();
+ Ptr<MgResourceIdentifier> tsId;
+ Ptr<MgLayerGroupCollection> groups = map->GetLayerGroups();
+ Ptr<MgLayerGroup> group = groups->GetItem(L"BaseLayers");
+ tsId = group->GetTileSetDefinition();
+ // set up the tile indices
+ INT32 numTileRows = tileRowMax - tileRowMin + 1;
+ INT32 numTileCols = tileColMax - tileColMin + 1;
+ INT32 numTiles = numTileRows * numTileCols;
+ INT32* tileRows = new INT32[numTiles];
+ INT32* tileCols = new INT32[numTiles];
+ INT32 nRequest = 0;
+ for (INT32 tileRow = tileRowMin; tileRow <= tileRowMax; ++tileRow)
+ for (INT32 tileCol = tileColMin; tileCol <= tileColMax; ++tileCol)
+ tileRows[nRequest] = tileRow;
+ tileCols[nRequest] = tileCol;
+ nRequest++;
+ // initialize the thread data
+ for (INT32 i=0; i<numThreads; i++)
+ // each thread works with its own instance of the map
+ threadData[i].threadId = i;
+ threadData[i].done = true;
+ threadData[i].saveTile = false;
+ threadData[i].tileRow = 0;
+ threadData[i].tileCol = 0;
+ threadData[i].tileScale = 4;
+ threadData[i].tileSetId = tsId->ToString().c_str();
+ // execute the requests to randomly access the tiles
+ #ifdef _DEBUG
+ printf("\n");
+ #endif
+ nRequest = 0;
+ for (;;)
+ INT32 dc = 0;
+ // check if the thread is available
+ if (threadData[i].done)
+ // if we're not yet done then give the thread a new request
+ if (nRequest < REQUEST_FACTOR*numTiles)
+ // pick a random request to execute...
+ INT32 nTile = Rand(numTiles);
+ // ... but make every REQUEST_FACTOR-th tile non-random to
+ // ensure we get each tile at least once
+ if (nRequest % REQUEST_FACTOR == 0)
+ nTile = nRequest / REQUEST_FACTOR;
+ threadData[i].done = false;
+ threadData[i].saveTile = (nRequest % REQUEST_FACTOR == 0);
+ threadData[i].tileRow = tileRows[nTile];
+ threadData[i].tileCol = tileCols[nTile];
+ // spawn a new thread using a specific group id
+ int thid = manager->spawn(ACE_THR_FUNC(GetTileLinkedWorker), &threadData[i], 0, NULL, NULL, 0, THREAD_GROUP);
+ nRequest++;
+ // keep a tally of all the done threads
+ ++dc;
+ // move on if all threads are done
+ if (dc == numThreads)
+ break;
+ // under Linux we get a deadlock if we don't call this every once in a while
+ if (nRequest % 25 == 0)
+ manager->wait_grp(THREAD_GROUP);
+ else
+ // pause briefly (10ms) before checking again
+ ACE_Time_Value t(0, 10000);
+ ACE_OS::sleep(t);
+ // make sure all threads in the group have completed
+ // done with the tile indices
+ delete [] tileRows;
+ delete [] tileCols;
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
/// SetTile methods
@@ -844,7 +1053,6 @@
/// ClearCache methods
@@ -881,6 +1089,144 @@
+void TestTileService::TestCase_ClearCacheLinked()
+ try
+ // call the API with a NULL argument
+ CPPUNIT_ASSERT_THROW_MG(m_svcTile->ClearCache((MgResourceIdentifier*)NULL), MgNullArgumentException*);
+ Ptr<MgResourceIdentifier> tsId = new MgResourceIdentifier(L"Library://UnitTests/TileSets/Sheboygan.TileSetDefinition");
+ m_svcTile->ClearCache(tsId);
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+void TestTileService::TestCase_MgMap_Inline()
+ try
+ Ptr<MgMap> map = CreateMap();
+ Ptr<MgEnvelope> extents = map->GetMapExtent();
+ Ptr<MgCoordinate> ll = extents->GetLowerLeftCoordinate();
+ Ptr<MgCoordinate> ur = extents->GetUpperRightCoordinate();
+ CPPUNIT_ASSERT_DOUBLES_EQUAL(-87.79786601383196, ll->GetX(), 0.00000000000001);
+ CPPUNIT_ASSERT_DOUBLES_EQUAL( 43.686857862181, ll->GetY(), 0.000000000001);
+ CPPUNIT_ASSERT_DOUBLES_EQUAL(-87.66452777186925, ur->GetX(), 0.00000000000001);
+ CPPUNIT_ASSERT_DOUBLES_EQUAL( 43.8037962206133, ur->GetY(), 0.0000000000001);
+ for (INT32 i = 0; i < groups->GetCount(); i++)
+ Ptr<MgLayerGroup> group = groups->GetItem(i);
+ CPPUNIT_ASSERT(MgLayerGroupType::BaseMap == group->GetLayerGroupType());
+ Ptr<MgResourceIdentifier> tsId = group->GetTileSetDefinition();
+ CPPUNIT_ASSERT(NULL == (MgResourceIdentifier*)tsId);
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+void TestTileService::TestCase_MgMap_Linked()
+ try
+ //Bounds should be that of the tile set
+ CPPUNIT_ASSERT_DOUBLES_EQUAL(-87.797866013831, ll->GetX(), 0.000000000001);
+ CPPUNIT_ASSERT_DOUBLES_EQUAL(-87.664527771869, ur->GetX(), 0.000000000001);
+ CPPUNIT_ASSERT_DOUBLES_EQUAL( 43.803796220613, ur->GetY(), 0.000000000001);
+ CPPUNIT_ASSERT(MgLayerGroupType::BaseMapFromTileSet == group->GetLayerGroupType());
+ CPPUNIT_ASSERT(NULL != (MgResourceIdentifier*)tsId);
+ CPPUNIT_ASSERT(L"Library://UnitTests/TileSets/Sheboygan.TileSetDefinition" == tsId->ToString());
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
+void TestTileService::TestCase_MgMapFromTileSet()
+ try
+ // make a runtime map
+ Ptr<MgResourceIdentifier> tsdres = new MgResourceIdentifier(L"Library://UnitTests/TileSets/Sheboygan.TileSetDefinition");
+ MgMap* map = new MgMap(m_siteConnection);
+ map->Create(tsdres, L"LinkedTileSet");
+ Ptr<MgResourceIdentifier> mdfId = map->GetMapDefinition();
+ CPPUNIT_ASSERT(NULL == (MgResourceIdentifier*)mdfId);
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
/// Helpers
@@ -911,6 +1257,30 @@
+MgMap* TestTileService::CreateMapLinked(CREFSTRING mapName)
+ // set a default name if not supplied
+ STRING name = (mapName.empty())? L"UnitTestBaseMapLinked" : mapName;
+ Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/LinkedTileSet.MapDefinition");
+ map->Create(mdfres, name);
+ // set the view
+ Ptr<MgCoordinate> coordNewCenter = new MgCoordinateXY(-87.723636, 43.715015);
+ Ptr<MgPoint> ptNewCenter = new MgPoint(coordNewCenter);
+ map->SetViewCenter(ptNewCenter);
+ map->SetDisplayDpi(96);
+ map->SetDisplayWidth(1024);
+ map->SetDisplayHeight(1024);
+ // render at a scale of 1:12500
+ map->SetViewScale(12500.0);
+ return map;
// returns a random integer in the range 0 to n-1
INT32 TestTileService::Rand(INT32 n)
Modified: sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.h
--- sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.h 2014-06-02 20:35:11 UTC (rev 8179)
+++ sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.h 2014-06-02 22:33:06 UTC (rev 8180)
@@ -29,6 +29,11 @@
CPPUNIT_TEST(TestCase_SetTile);
CPPUNIT_TEST(TestCase_GetSetTile);
CPPUNIT_TEST(TestCase_ClearCache);
+ CPPUNIT_TEST(TestCase_GetTileLinked);
+ CPPUNIT_TEST(TestCase_ClearCacheLinked);
+ CPPUNIT_TEST(TestCase_MgMap_Inline);
+ CPPUNIT_TEST(TestCase_MgMap_Linked);
+ CPPUNIT_TEST(TestCase_MgMapFromTileSet);
@@ -42,13 +47,19 @@
void TestStart();
void TestEnd();
+ void TestCase_MgMap_Inline();
+ void TestCase_MgMap_Linked();
+ void TestCase_MgMapFromTileSet();
void TestCase_GetTile();
void TestCase_SetTile();
void TestCase_GetSetTile();
void TestCase_ClearCache();
+ void TestCase_GetTileLinked();
+ void TestCase_ClearCacheLinked();
private:
MgMap* CreateMap(CREFSTRING mapName = L"");
+ MgMap* CreateMapLinked(CREFSTRING mapName = L"");
INT32 Rand(INT32 n);
private:
Added: sandbox/jng/tiling/UnitTest/TestData/TileService/UT_BaseMap.tsd
--- sandbox/jng/tiling/UnitTest/TestData/TileService/UT_BaseMap.tsd (rev 0)
+++ sandbox/jng/tiling/UnitTest/TestData/TileService/UT_BaseMap.tsd 2014-06-02 22:33:06 UTC (rev 8180)
@@ -0,0 +1,53 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<TileSetDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="TileSetDefinition-3.0.0.xsd">
+ <TileStoreParameters>
+ <TileProvider>Default</TileProvider>
+ <TileWidth>256</TileWidth>
+ <TileHeight>256</TileHeight>
+ <Format>PNG</Format>
+ <Parameter>
+ <Name>TilePath</Name>
+ <Value>%MG_TILE_CACHE_PATH%</Value>
+ </Parameter>
+ </TileStoreParameters>
+ <CoordinateSystem>GEOGCS["LL84",DATUM["WGS 84",SPHEROID["WGS 84",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["Degrees",0.01745329252]]</CoordinateSystem>
+ <Extents>
+ <MinX>-87.79786601383196</MinX>
+ <MaxX>-87.66452777186925</MaxX>
+ <MinY>43.6868578621819</MinY>
+ <MaxY>43.8037962206133</MaxY>
+ </Extents>
+ <FiniteDisplayScale>200000</FiniteDisplayScale>
+ <FiniteDisplayScale>100000</FiniteDisplayScale>
+ <FiniteDisplayScale>50000</FiniteDisplayScale>
+ <FiniteDisplayScale>25000</FiniteDisplayScale>
+ <FiniteDisplayScale>12500</FiniteDisplayScale>
+ <FiniteDisplayScale>6250</FiniteDisplayScale>
+ <FiniteDisplayScale>3125</FiniteDisplayScale>
+ <FiniteDisplayScale>1562.5</FiniteDisplayScale>
+ <FiniteDisplayScale>781.25</FiniteDisplayScale>
+ <FiniteDisplayScale>390.625</FiniteDisplayScale>
+ <BaseMapLayerGroup>
+ <Name>BaseLayers</Name>
+ <Visible>true</Visible>
+ <ShowInLegend>true</ShowInLegend>
+ <ExpandInLegend>true</ExpandInLegend>
+ <LegendLabel>Base Layers</LegendLabel>
+ <BaseMapLayer>
+ <Name>Parcels</Name>
+ <ResourceId>Library://UnitTests/Layers/Parcels.LayerDefinition</ResourceId>
+ <Selectable>true</Selectable>
+ <LegendLabel>Parcels</LegendLabel>
+ <ExpandInLegend>false</ExpandInLegend>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>VotingDistricts</Name>
+ <ResourceId>Library://UnitTests/Layers/VotingDistricts.LayerDefinition</ResourceId>
+ <LegendLabel>Voting Districts</LegendLabel>
+ </BaseMapLayer>
+ </BaseMapLayerGroup>
+</TileSetDefinition>
Added: sandbox/jng/tiling/UnitTest/TestData/TileService/UT_LinkedTileSet.mdf
--- sandbox/jng/tiling/UnitTest/TestData/TileService/UT_LinkedTileSet.mdf (rev 0)
+++ sandbox/jng/tiling/UnitTest/TestData/TileService/UT_LinkedTileSet.mdf 2014-06-02 22:33:06 UTC (rev 8180)
@@ -0,0 +1,25 @@
+<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="MapDefinition-3.0.0.xsd" version="3.0.0">
+ <Name>Base Map linked to Tile Set</Name>
+ <CoordinateSystem>PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular Visualisation Pseudo Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]</CoordinateSystem>
+ <Extents>
+ <MinX>-9773613.7373958</MinX>
+ <MaxX>-9758770.5921973</MaxX>
+ <MinY>5417109.9090669</MinY>
+ <MaxY>5435129.2308673</MaxY>
+ </Extents>
+ <BackgroundColor>FFF7E1D2</BackgroundColor>
+ <MapLayer>
+ <Name>RoadCenterLines</Name>
+ <ResourceId>Library://UnitTests/Layers/RoadCenterLines.LayerDefinition</ResourceId>
+ <Selectable>false</Selectable>
+ <LegendLabel>Road CenterLines</LegendLabel>
+ <Group></Group>
+ </MapLayer>
+ <TileSetSource>
+ <ResourceId>Library://UnitTests/TileSets/Sheboygan.TileSetDefinition</ResourceId>
+ </TileSetSource>
+</MapDefinition>
More information about the mapguide-commits
