[mapguide-commits] r8181 - in sandbox/jng/tiling: Common/MapGuideCommon/Resources Server/src/Services/Tile Server/src/UnitTesting
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Jun 2 23:14:44 PDT 2014
Author: jng
Date: 2014-06-02 23:14:44 -0700 (Mon, 02 Jun 2014)
New Revision: 8181
   sandbox/jng/tiling/Common/MapGuideCommon/Resources/mapguide_en.res
   sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.cpp
   sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.cpp
   sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.h
Implement GetTileProviders
Modified: sandbox/jng/tiling/Common/MapGuideCommon/Resources/mapguide_en.res
--- sandbox/jng/tiling/Common/MapGuideCommon/Resources/mapguide_en.res	2014-06-02 22:33:06 UTC (rev 8180)
+++ sandbox/jng/tiling/Common/MapGuideCommon/Resources/mapguide_en.res	2014-06-03 06:14:44 UTC (rev 8181)
@@ -426,6 +426,9 @@
 # T I L E  S E R V I C E
 [TileService]
+MgTileProvider_Default_DisplayName                     = Default Tile Provider
+MgTileProvider_Default_Description                     = Default tile access provided by MapGuide. Supports MapGuide-managed tile path or user-defined path
+MgTileProvider_Default_Property_TilePath_LocalizedName = Tile Path
 # S T Y L I Z A T I O N
Modified: sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.cpp
--- sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.cpp	2014-06-02 22:33:06 UTC (rev 8180)
+++ sandbox/jng/tiling/Server/src/Services/Tile/ServerTileService.cpp	2014-06-03 06:14:44 UTC (rev 8181)
@@ -163,6 +163,55 @@
     Ptr<MgByteReader> ret;
     MG_TRY()
+    //This response is obviously pre-canned right now. If we do want to FDO-ize tile provider support
+    //we obviously should revisit this.
+    std::string xml = "<?xml version=\"1.0\" encoding=\"utf-8\"?>\n";
+    xml += "<TileProviderList>\n";
+    xml += "\t<TileProvider>\n";
+    xml += "\t\t<Name>";
+    std::string mbName;
+    STRING wName = TILE_PROVIDER_DEFAULT;
+    MgUtil::WideCharToMultiByte(wName, mbName);
+    xml += mbName;
+    xml += "</Name>\n";
+    xml += "\t\t<DisplayName>";
+    std::string mbDisplayName;
+    STRING wDisplayName = MgUtil::GetResourceMessage(MgResources::TileService, L"MgTileProvider_Default_DisplayName");
+    xml += mbDisplayName;
+    xml += "</DisplayName>\n";
+    xml += "\t\t<Description>";
+    std::string mbDescription;
+    STRING wDescription = MgUtil::GetResourceMessage(MgResources::TileService, L"MgTileProvider_Default_Description");
+    xml += mbDescription;
+    xml += "</Description>\n";
+    xml += "\t\t<ConnectionProperties>\n";
+    xml += "\t\t\t<ConnectionProperty Enumerable=\"false\" Protected=\"false\" Required=\"true\">\n";
+    xml += "\t\t\t\t<Name>";
+    std::string mbTilePath;
+    STRING wTilePath = TILE_PROVIDER_DEFAULT_PARAM_TILEPATH;
+    MgUtil::WideCharToMultiByte(wTilePath, mbTilePath);
+    xml += mbTilePath;
+    xml += "\t\t\t\t<LocalizedName>";
+    std::string mbLocName;
+    STRING wLocName = MgUtil::GetResourceMessage(MgResources::TileService, L"MgTileProvider_Default_Property_TilePath_LocalizedName");
+    MgUtil::WideCharToMultiByte(wLocName, mbLocName);
+    xml += "</LocalizedName>\n";
+    xml += "\t\t\t\t<DefaultValue>";
+    std::string mbDefaultTag;
+    MgUtil::WideCharToMultiByte(MgResourceTag::TileCachePath, mbDefaultTag);
+    xml += mbDefaultTag;
+    xml += "</DefaultValue>\n";
+    xml += "\t\t\t</ConnectionProperty>\n";
+    xml += "\t\t</ConnectionProperties>\n";
+    xml += "\t</TileProvider>\n";
+    xml += "</TileProviderList>";
+    Ptr<MgByteSource> source = new MgByteSource((BYTE_ARRAY_IN)xml.c_str(), (INT32)xml.length());
+    ret = source->GetReader();
     MG_CATCH_AND_THROW(L"MgServerTileService.GetTileProviders")
     return ret.Detach();
Modified: sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.cpp
--- sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.cpp	2014-06-02 22:33:06 UTC (rev 8180)
+++ sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.cpp	2014-06-03 06:14:44 UTC (rev 8181)
@@ -1227,6 +1227,26 @@
+void TestTileService::TestCase_GetTileProviders()
+    try
+        Ptr<MgByteReader> content = m_svcTile->GetTileProviders();
+        Ptr<MgByteSink> sink = new MgByteSink(content);
+        sink->ToFile(L"../UnitTestFiles/GetTileProviders_Result.xml");
+    catch (MgException* e)
+        STRING message = e->GetDetails(TEST_LOCALE);
+        SAFE_RELEASE(e);
+        CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+    catch (...)
+        throw;
 /// Helpers
Modified: sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.h
--- sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.h	2014-06-02 22:33:06 UTC (rev 8180)
+++ sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.h	2014-06-03 06:14:44 UTC (rev 8181)
@@ -25,15 +25,16 @@
     CPPUNIT_TEST_SUITE(TestTileService);
     CPPUNIT_TEST(TestStart); // This must be the very first unit test
+    CPPUNIT_TEST(TestCase_GetTileProviders);
+    CPPUNIT_TEST(TestCase_MgMap_Inline);
+    CPPUNIT_TEST(TestCase_MgMap_Linked);
+    CPPUNIT_TEST(TestCase_MgMapFromTileSet);
     CPPUNIT_TEST(TestCase_GetTile);
     CPPUNIT_TEST(TestCase_SetTile);
     CPPUNIT_TEST(TestCase_GetSetTile);
     CPPUNIT_TEST(TestCase_ClearCache);
     CPPUNIT_TEST(TestCase_GetTileLinked);
     CPPUNIT_TEST(TestCase_ClearCacheLinked);
-    CPPUNIT_TEST(TestCase_MgMap_Inline);
-    CPPUNIT_TEST(TestCase_MgMap_Linked);
-    CPPUNIT_TEST(TestCase_MgMapFromTileSet);
     CPPUNIT_TEST(TestEnd); // This must be the very last unit test
     CPPUNIT_TEST_SUITE_END();
@@ -47,6 +48,7 @@
     void TestStart();
     void TestEnd();
+    void TestCase_GetTileProviders();
     void TestCase_MgMap_Inline();
     void TestCase_MgMap_Linked();
     void TestCase_MgMapFromTileSet();
More information about the mapguide-commits mailing list
