[mapguide-commits] r8243 - in trunk/Tools/Maestro: Maestro.Editors/Fusion Maestro.Editors/Fusion/MapEditors OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org
Wed Jun 18 02:39:48 PDT 2014
Author: jng
Date: 2014-06-18 02:39:48 -0700 (Wed, 18 Jun 2014)
New Revision: 8243
trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/Fusion/MapEditors/EditorFactory.cs
trunk/Tools/Maestro/Maestro.Editors/Fusion/MapEditors/MapGuideEditor.Designer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinitionInterfaces.cs
#1635: Finish off the Fusion editor loose ends. This implements the move up/down and remove map buttons for the re-vamped map group editor.
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.Designer.cs 2014-06-18 09:02:42 UTC (rev 8242)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.Designer.cs 2014-06-18 09:39:48 UTC (rev 8243)
@@ -104,6 +104,7 @@
resources.ApplyResources(this.btnRemoveMap, "btnRemoveMap");
this.btnRemoveMap.Image = global::Maestro.Editors.Properties.Resources.map__minus;
this.btnRemoveMap.Name = "btnRemoveMap";
+ this.btnRemoveMap.Click += new System.EventHandler(this.btnRemoveMap_Click);
// toolStripSeparator1
@@ -116,6 +117,7 @@
resources.ApplyResources(this.btnMapUp, "btnMapUp");
this.btnMapUp.Image = global::Maestro.Editors.Properties.Resources.arrow_090;
this.btnMapUp.Name = "btnMapUp";
+ this.btnMapUp.Click += new System.EventHandler(this.btnMapUp_Click);
// btnMapDown
@@ -123,6 +125,7 @@
resources.ApplyResources(this.btnMapDown, "btnMapDown");
this.btnMapDown.Image = global::Maestro.Editors.Properties.Resources.arrow_270;
this.btnMapDown.Name = "btnMapDown";
+ this.btnMapDown.Click += new System.EventHandler(this.btnMapDown_Click);
// grpChildMap
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.cs 2014-06-18 09:02:42 UTC (rev 8242)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.cs 2014-06-18 09:39:48 UTC (rev 8243)
@@ -101,15 +101,21 @@
_edSvc.RegisterCustomNotifier(this);
_models = new BindingList<MapModel>();
lstMaps.DataSource = _models;
- foreach (var m in group.Map.Select(x => new MapModel(x)))
- _models.Add(m);
+ UpdateMapList();
txtMapId.Text = _widget.MapId;
LoadMapOptions();
+ private void UpdateMapList()
+ _models.Clear();
+ foreach (var m in _group.Map.Select(x => new MapModel(x)))
+ _models.Add(m);
private void LoadMapOptions()
foreach (var option in EditorFactory.GetAvailableOptions(_group))
@@ -117,9 +123,45 @@
var ed = option;
btnNewMap.DropDown.Items.Add(ed.Name, null, (s, e) =>
+ bool bAddedCommercialLayer = false;
var map = ed.Action();
+ if (map.Type == EditorFactory.Type_Google)
+ _appDef.SetValue("GoogleScript", EditorFactory.GOOGLE_URL);
+ bAddedCommercialLayer = true;
+ else if (map.Type == EditorFactory.Type_Bing)
+ _appDef.SetValue("VirtualEarthScript", EditorFactory.BING_URL);
+ else if (map.Type == EditorFactory.Type_OSM)
+ _appDef.SetValue("OpenStreetMapScript", EditorFactory.OSM_URL);
_group.AddMap(map);
_models.Add(new MapModel(map));
+ if (bAddedCommercialLayer)
+ foreach (var m in _group.Map)
+ if (m.Type == EditorFactory.Type_MapGuide)
+ m.OverlayOptions = m.CreateOverlayOptions(false, true, "EPSG:900913"); //NOXLATE
+ else
+ m.OverlayOptions = null;
@@ -146,11 +188,59 @@
var map = lstMaps.SelectedItem as MapModel;
if (map != null)
+ btnRemoveMap.Enabled = btnMapUp.Enabled = btnMapDown.Enabled = true;
grpChildMap.Controls.Clear();
var control = EditorFactory.GetEditor(_edSvc, _group, map.Map);
control.Dock = DockStyle.Fill;
grpChildMap.Controls.Add(control);
+ else
+ btnRemoveMap.Enabled = btnMapUp.Enabled = btnMapDown.Enabled = false;
+ private void btnRemoveMap_Click(object sender, EventArgs e)
+ var map = lstMaps.SelectedItem as MapModel;
+ if (map != null)
+ _models.Remove(map);
+ _group.RemoveMap(map.Map);
+ private void btnMapUp_Click(object sender, EventArgs e)
+ if (map != null)
+ int idx = _models.IndexOf(map);
+ if (_group.MoveUp(map.Map))
+ idx--;
+ UpdateMapList();
+ if (idx >= 0 && idx < lstMaps.Items.Count - 1)
+ lstMaps.SelectedIndex = idx;
+ private void btnMapDown_Click(object sender, EventArgs e)
+ if (map != null)
+ if (_group.MoveDown(map.Map))
+ idx++;
+ UpdateMapList();
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/MapEditors/EditorFactory.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/MapEditors/EditorFactory.cs 2014-06-18 09:02:42 UTC (rev 8242)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/MapEditors/EditorFactory.cs 2014-06-18 09:39:48 UTC (rev 8243)
@@ -37,19 +37,19 @@
const string BING_AERIAL = "Aerial"; //NOXLATE
const string BING_HYBRID = "Hybrid"; //NOXLATE
- const string Type_Google = "Google"; //NOXLATE
- const string Type_Bing = "VirtualEarth"; //NOXLATE
- const string Type_OSM = "OpenStreetMap"; //NOXLATE
- const string Type_MapGuide = "MapGuide"; //NOXLATE
+ internal const string Type_Google = "Google"; //NOXLATE
+ internal const string Type_Bing = "VirtualEarth"; //NOXLATE
+ internal const string Type_OSM = "OpenStreetMap"; //NOXLATE
+ internal const string Type_MapGuide = "MapGuide"; //NOXLATE
const string Type_Generic = "Generic"; //NOXLATE
const string OSM_MAP_MAPNIK = "Mapnik"; //NOXLATE
const string OSM_MAP_TRANSPORTMAP = "TransportMap"; //NOXLATE
const string OSM_MAP_CYCLEMAP = "CycleMap"; //NOXLATE
- const string OSM_URL = "http://www.openstreetmap.org/openlayers/OpenStreetMap.js"; //NOXLATE
- const string GOOGLE_URL = "http://maps.google.com/maps/api/js?sensor=false"; //NOXLATE
- const string BING_URL = "http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.2"; //NOXLATE
+ internal const string OSM_URL = "http://www.openstreetmap.org/openlayers/OpenStreetMap.js"; //NOXLATE
+ internal const string GOOGLE_URL = "http://maps.google.com/maps/api/js?sensor=false"; //NOXLATE
+ internal const string BING_URL = "http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.2"; //NOXLATE
internal static Control GetEditor(IEditorService edSvc, IMapGroup group, IMap map)
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/MapEditors/MapGuideEditor.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/MapEditors/MapGuideEditor.Designer.cs 2014-06-18 09:02:42 UTC (rev 8242)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/MapEditors/MapGuideEditor.Designer.cs 2014-06-18 09:39:48 UTC (rev 8243)
@@ -50,7 +50,7 @@
this.chkSelectionAsOverlay.AutoSize = true;
this.chkSelectionAsOverlay.ImeMode = System.Windows.Forms.ImeMode.NoControl;
- this.chkSelectionAsOverlay.Location = new System.Drawing.Point(311, 107);
+ this.chkSelectionAsOverlay.Location = new System.Drawing.Point(317, 107);
this.chkSelectionAsOverlay.Name = "chkSelectionAsOverlay";
this.chkSelectionAsOverlay.Size = new System.Drawing.Size(124, 17);
this.chkSelectionAsOverlay.TabIndex = 19;
@@ -218,7 +218,7 @@
this.Controls.Add(this.txtMapDefinition);
this.Controls.Add(this.btnBrowseMdf);
this.Name = "MapGuideEditor";
- this.Size = new System.Drawing.Size(460, 142);
+ this.Size = new System.Drawing.Size(460, 138);
this.groupBox1.ResumeLayout(false);
this.groupBox1.PerformLayout();
this.ResumeLayout(false);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs 2014-06-18 09:02:42 UTC (rev 8242)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs 2014-06-18 09:39:48 UTC (rev 8243)
@@ -697,6 +697,40 @@
partial class MapGroupType : IMapGroup
+ bool IMapGroup.MoveUp(IMap map)
+ var mt = map as MapType;
+ if (mt != null)
+ var idx = this.mapField.IndexOf(mt);
+ if (idx > 0)
+ this.mapField.RemoveAt(idx);
+ idx--;
+ this.mapField.Insert(idx, mt);
+ return true;
+ return false;
+ bool IMapGroup.MoveDown(IMap map)
+ if (mt != null)
+ if (idx < this.mapField.Count - 1)
+ idx++;
+ return true;
+ return false;
IMap IMapGroup.CreateMapGuideEntry(string mapDefinition)
var map = new MapType()
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinitionInterfaces.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinitionInterfaces.cs 2014-06-18 09:02:42 UTC (rev 8242)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinitionInterfaces.cs 2014-06-18 09:39:48 UTC (rev 8243)
@@ -1123,6 +1123,10 @@
IMap CreateCmsMapEntry(string type, bool singleTile, string name, string olType);
IMap CreateGenericEntry();
+ bool MoveUp(IMap map);
+ bool MoveDown(IMap map);
public interface IMap : INotifyPropertyChanged, IExtensibleElement
More information about the mapguide-commits
