[mapguide-commits] r8244 - trunk/Tools/Maestro/Maestro
svn_mapguide at osgeo.org
Wed Jun 18 12:10:58 PDT 2014
Author: jng
Date: 2014-06-18 12:10:58 -0700 (Wed, 18 Jun 2014)
New Revision: 8244
trunk/Tools/Maestro/Maestro/changelog.txt
changelog.txt update
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2014-06-18 09:39:48 UTC (rev 8243)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2014-06-18 19:10:58 UTC (rev 8244)
@@ -1,4 +1,16 @@
- - MgCooker changes
+ - Drag/Drop now properly handles cases where multiple handlers could handle a given file drop
+ - Future-proofing
+ - Maestro can now work with unknown resource types
+ - Map Definitions, Web Layouts and Application Definitions of unknown schema versions can be previewed
+ - Files of unknown extensions will be loaded as XML content when drag/dropped in the Site Explorer
+ - Fusion editor changes
+ - Map Group editor re-designed to better reflect its logical structure in the Map Definition
+ - New Generic XML editor option allowing for custom layer types to be added
+6.0a2
+ - MgCooker changes
- Removed non-official tile generation method
- Removed username/password/native connection options in UI. Replaced with provider/connection string
- Added support for adding default point/line/area composite styles in Layer Definition Editor
More information about the mapguide-commits
