[mapguide-commits] r8161 - in trunk/MgDev/Common: Foundation/Data Geometry/CoordinateSystem MapGuideCommon/Services PlatformBase/Services
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon May 26 07:19:31 PDT 2014
Author: jng
Date: 2014-05-26 07:19:31 -0700 (Mon, 26 May 2014)
New Revision: 8161
   trunk/MgDev/Common/Foundation/Data/FeaturePropertyType.h
   trunk/MgDev/Common/Foundation/Data/MimeType.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemErrorCode.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h
   trunk/MgDev/Common/MapGuideCommon/Services/ImageFormats.h
   trunk/MgDev/Common/MapGuideCommon/Services/MappingDefs.h
   trunk/MgDev/Common/MapGuideCommon/Services/UnitType.h
   trunk/MgDev/Common/PlatformBase/Services/BaseServiceDefs.h
   trunk/MgDev/Common/PlatformBase/Services/FeatureCommandType.h
   trunk/MgDev/Common/PlatformBase/Services/FeatureGeometricType.h
   trunk/MgDev/Common/PlatformBase/Services/FeatureService.h
   trunk/MgDev/Common/PlatformBase/Services/ObjectPropertyType.h
   trunk/MgDev/Common/PlatformBase/Services/RasterTypes.h
   trunk/MgDev/Common/PlatformBase/Services/ReaderType.h
   trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h
   trunk/MgDev/Common/PlatformBase/Services/SpatialContextExtentType.h
API documentation updates
 - Fill in more missing commentary
 - #2452: Fix improperly formatted API documentation for certain constant classes
Modified: trunk/MgDev/Common/Foundation/Data/FeaturePropertyType.h
--- trunk/MgDev/Common/Foundation/Data/FeaturePropertyType.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/Foundation/Data/FeaturePropertyType.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -59,6 +59,7 @@
     static const int AssociationProperty    =  103;
+    /// \brief
     /// Type name for a raster property definition. See
     /// MgRasterPropertyDefinition.
     static const int RasterProperty         =  104;
Modified: trunk/MgDev/Common/Foundation/Data/MimeType.h
--- trunk/MgDev/Common/Foundation/Data/MimeType.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/Foundation/Data/MimeType.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -32,42 +32,55 @@
     /// The "value(xxx)" comments are used by SWIG to build constants.php.  Do not alter them.
     /// \endif
+    /// \brief
     /// application/agf
     static const STRING Agf;      ///\if INTERNAL value("application/agf") \endif
+    /// \brief
     /// application/octet-stream
     static const STRING Binary;   ///\if INTERNAL value("application/octet-stream") \endif
+    /// \brief
     /// model/vnd.dwf
     static const STRING Dwf;      ///\if INTERNAL value("model/vnd.dwf") \endif
+    /// \brief
     /// image/gif
     static const STRING Gif;      ///\if INTERNAL value("image/gif") \endif
+    /// \brief
     /// image/jpeg
     static const STRING Jpeg;     ///\if INTERNAL value("image/jpeg") \endif
+    /// \brief
     /// image/png
     static const STRING Png;      ///\if INTERNAL value("image/png") \endif
+    /// \brief
     /// text/plain
     static const STRING Text;     ///\if INTERNAL value("text/plain") \endif
+    /// \brief
     /// image/tiff
     static const STRING Tiff;     ///\if INTERNAL value("image/tiff") \endif
+    /// \brief
     /// text/xml
     static const STRING Xml;      ///\if INTERNAL value("text/xml") \endif
+    /// \brief
     /// application/json
     static const STRING Json;      ///\if INTERNAL value("application/json") \endif
+    /// \brief
     /// text/html
     static const STRING Html;     ///\if INTERNAL value("text/html") \endif
+    /// \brief
     /// application/vnd.google-earth.kml+xml
     static const STRING Kml;      ///\if INTERNAL value("application/vnd.google-earth.kml+xml") \endif
+    /// \brief
     /// application/vnd.google-earth.kmz
     static const STRING Kmz;      ///\if INTERNAL value("application/vnd.google-earth.kmz") \endif
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemErrorCode.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemErrorCode.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemErrorCode.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -317,32 +317,32 @@
     /// \brief
+    /// The operation succeeded
     static const INT32 Ok                   = 1000;
     /// \brief
+    /// The operation ran out of memory
     static const INT32 OutOfMemory          = 1001;
     /// \brief
+    /// An initialization operation failed
     static const INT32 InitializationFailed = 1002;
     /// \brief
+    /// A conversion operation failed
     static const INT32 ConversionFailed     = 1003;
     /// \brief
+    /// An argument supplied to an operation was null
     static const INT32 NullArgument         = 1004;
     /// \brief
+    /// An argument supplied to an operation was invalid
     static const INT32 InvalidArgument      = 1005;
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -24,6 +24,7 @@
 /// \brief
+/// Defines the type of a geodetic transformation method
 class MG_GEOMETRY_API MgCoordinateSystemGeodeticTransformationMethod
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -23,7 +23,7 @@
-/// <summary>
+/// \brief
 /// An enumeration of the supported values for the <c>m_Orientation</c> member
 /// of several objects related to grids and graticules. <p>
 /// This value is used to qualify objects which are of the "iso" type.  I.e. a
@@ -34,25 +34,24 @@
 /// points which share a common <b>easting</b> value, and the "m_Value" element
 /// of that object will be an <b>easting</b> value.  Note that in this example,
 /// the line is typically a vertical line.
-/// </summary>
 class MG_GEOMETRY_API MgCoordinateSystemGridOrientation
 PUBLISHED_API:
-    /// \brief Not specified yet, initialize to this value.
+    /// \brief
+    /// Not specified yet, initialize to this value.
     static const INT8 None = 0;
-    /// \brief The object represents a constant easting value.
+    /// \brief
+    /// The object represents a constant easting value.
     static const INT8 EastWest = 1;         // generally indicates a vertical grid line
-    /// \brief The object represents a constant northing value.
+    /// \brief
+    /// The object represents a constant northing value.
     static const INT8 NorthSouth = 2;       // generally indicates a horizontal grid line
-    /// \brief Indicates the failure of an algorithm or other problem.
+    /// \brief
+    /// Indicates the failure of an algorithm or other problem.
     static const INT8 Unknown = 3;          // indicates a failure of an algorithm
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -23,7 +23,7 @@
-/// <summary>
+/// \brief
 /// An enumeration of the various types of specialized grids/graticules
 /// currently supported.  A specialized grid is one for which specific
 /// standards exist to which the results of this feature are compliant with.
@@ -33,7 +33,6 @@
 /// with similar features and is currently entirely arbitrary.  Using a
 /// numeric literal instead of thes names of the defined constants is a sure
 /// way to write code that will get broken in the future.
-/// </summary>
 class MG_GEOMETRY_API MgCoordinateSystemGridSpecializationType
 PUBLISHED_API:
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ImageFormats.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ImageFormats.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ImageFormats.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -30,21 +30,27 @@
     /// \internal
+    /// \brief
     /// Gif format
     static const STRING Gif;    /// \if INTERNAL value("GIF") \endif
+    /// \brief
     /// Jpeg format
     static const STRING Jpeg;   /// \if INTERNAL value("JPG") \endif
+    /// \brief
     /// Png format
     static const STRING Png;    /// \if INTERNAL value("PNG") \endif
+    /// \brief
     /// Png format
     static const STRING Png8;   /// \if INTERNAL value("PNG8") \endif
+    /// \brief
     /// Tiff format
     static const STRING Tiff;   /// \if INTERNAL value("TIF") \endif
+    /// \brief
     /// Raw format
     static const STRING Raw;    /// \if INTERNAL value("RAW") \endif
Modified: trunk/MgDev/Common/MapGuideCommon/Services/MappingDefs.h
--- trunk/MgDev/Common/MapGuideCommon/Services/MappingDefs.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/MapGuideCommon/Services/MappingDefs.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -37,9 +37,11 @@
     /// \endif
+    /// \brief
     /// Page units are in inches.
     static const STRING Inches;           ///\if INTERNAL value("in") \endif
+    /// \brief
     /// Page units are in millimeters.
     static const STRING Millimeters;      ///\if INTERNAL value("mm") \endif
Modified: trunk/MgDev/Common/MapGuideCommon/Services/UnitType.h
--- trunk/MgDev/Common/MapGuideCommon/Services/UnitType.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/MapGuideCommon/Services/UnitType.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -29,9 +29,11 @@
     /// \endif
+    /// \brief
     /// US English.
     static const STRING USEnglish;  ///\if INTERNAL value("US-English") \endif
+    /// \brief
     /// Metric.
     static const STRING Metric;     ///\if INTERNAL value("Metric") \endif
Modified: trunk/MgDev/Common/PlatformBase/Services/BaseServiceDefs.h
--- trunk/MgDev/Common/PlatformBase/Services/BaseServiceDefs.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/PlatformBase/Services/BaseServiceDefs.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -29,39 +29,47 @@
 PUBLISHED_API:
+    /// \brief
     /// Resource Service
     static const INT16 ResourceService      = 0;
+    /// \brief
     /// DWF Drawing Service
     static const INT16 DrawingService       = 1;
+    /// \brief
     /// FDO Feature Service
     static const INT16 FeatureService       = 2;
+    /// \brief
     /// Mapping Service
     static const INT16 MappingService       = 3;
+    /// \brief
     /// Rendering Service
     static const INT16 RenderingService     = 4;
+    /// \brief
     /// Tile Service
     static const INT16 TileService          = 5;
+    /// \brief
     /// Kml Service
     static const INT16 KmlService           = 6;
+    /// \brief
     /// Profiling Service
     static const INT16 ProfilingService     = 10;
Modified: trunk/MgDev/Common/PlatformBase/Services/FeatureCommandType.h
--- trunk/MgDev/Common/PlatformBase/Services/FeatureCommandType.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/PlatformBase/Services/FeatureCommandType.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -31,18 +31,23 @@
 PUBLISHED_API:
+    /// \brief
     /// Specifies the type of an MgInsertFeatures object.
     static const int InsertFeatures = 0;
+    /// \brief
     /// Specifies the type of an MgUpdateFeatures object.
     static const int UpdateFeatures = 1;
+    /// \brief
     /// Specifies the type of an MgDeleteFeatures object.
     static const int DeleteFeatures = 2;
+    /// \brief
     /// Specifies the type of an MgLockFeatures object.
     static const int LockFeatures = 3;
+    /// \brief
     /// Specifies the type of an MgUnlockFeatures object.
     static const int UnlockFeatures = 4;
 INTERNAL_API:
Modified: trunk/MgDev/Common/PlatformBase/Services/FeatureGeometricType.h
--- trunk/MgDev/Common/PlatformBase/Services/FeatureGeometricType.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/PlatformBase/Services/FeatureGeometricType.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -35,21 +35,25 @@
 PUBLISHED_API:
+    /// \brief
     /// Represents zero-dimensional geometric primitives, such as
     /// MgPoint.
     static const int Point      =  1;
+    /// \brief
     /// Represents one-dimensional geometric primitives, such as
     /// MgLineString and MgCurveString.
     static const int Curve      =  2;
+    /// \brief
     /// Represents two-dimensional geometric primitives, such as
     /// MgPolygon and MgCurvePolygon.
     static const int Surface    =  4;
+    /// \brief
     /// Represents three-dimensional geometric primitives, such as
     /// Cubes.
     static const int Solid      =  8;
Modified: trunk/MgDev/Common/PlatformBase/Services/FeatureService.h
--- trunk/MgDev/Common/PlatformBase/Services/FeatureService.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/PlatformBase/Services/FeatureService.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -1891,6 +1891,7 @@
     static const INT32 m_cls_id = PlatformBase_FeatureService_FeatureService;
+///\cond INTERNAL
 #define MG_CHECK_FEATURE_SET_COUNT(pointer, methodname)                       \
 if (0 == pointer->GetCount())                                                 \
@@ -1904,6 +1905,7 @@
     throw new MgInvalidPropertyTypeException(methodname,                      \
         __LINE__, __WFILE__, NULL, L"", NULL);                                \
+///\endcond
Modified: trunk/MgDev/Common/PlatformBase/Services/ObjectPropertyType.h
--- trunk/MgDev/Common/PlatformBase/Services/ObjectPropertyType.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/PlatformBase/Services/ObjectPropertyType.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -24,8 +24,8 @@
 /// \brief
-/// Defines the type of an MgObjectPropertionDefinition object
-/// property, that is, whether the property ccontains a single
+/// Defines the type of an \link MgObjectPropertionDefinition \endlink object
+/// property, that is, whether the property contains a single
 /// feature class object, or an unordered or ordered collection
 /// of them.
@@ -33,21 +33,23 @@
 PUBLISHED_API:
+    /// \brief
     /// Signifies that the object property contains a single feature
     /// class object.
     static const int Value = 0;
+    /// \brief
     /// Signifies that the object property contains more than one
     /// feature class object. The collection of objects is in no
     /// particular order relative to the identity property defined
-    /// for the collection. See
-    /// MgObjectPropertyDefinition::GetIdentityProperty.
+    /// for the collection. See \link MgObjectPropertyDefinition::GetIdentityProperty \endlink
     static const int Collection = 1;
+    /// \brief
     /// feature class object in ascending or descending order
     /// relative to the identity property defined for the collection.
-    /// See MgObjectPropertyDefinition::GetIdentityProperty.
+    /// See \link MgObjectPropertyDefinition::GetIdentityProperty \endlink
     static const int OrderedCollection = 2;
 INTERNAL_API:
Modified: trunk/MgDev/Common/PlatformBase/Services/RasterTypes.h
--- trunk/MgDev/Common/PlatformBase/Services/RasterTypes.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/PlatformBase/Services/RasterTypes.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -32,27 +32,34 @@
     // These correspond to FDO RasterDataModelType definitions
+    /// \brief
     /// Data is organized in an unknown or provider specific manner.
     static const INT32 Unknown;     /// value(0)
+    /// \brief
     /// Data is rectangular grid, floating point data model.
     static const INT32 Data;        /// value(1)
+    /// \brief
     /// Data is one bit (black/white - bitonal) pixels.
     static const INT32 Bitonal;     /// value(2)
+    /// \brief
     /// Data is monochrome (black->gray->white) pixels.
     /// It is necessary to know the BitsPerPixel value to interpret the data.
     static const INT32 Gray;        /// value(3)
+    /// \brief
     /// Data is red/green/blue (in that order) pixels.
     static const INT32 RGB;         /// value(4)
+    /// \brief
     /// Data is red/green/blue/alpha (in that order) pixels; RGB with transparency.
     static const INT32 RGBA;        /// value(5)
+    /// \brief
     /// Data is monochrome but backed by a pallette (value->pallette->colour) pixels.
     static const INT32 Palette;     /// value(6)
Modified: trunk/MgDev/Common/PlatformBase/Services/ReaderType.h
--- trunk/MgDev/Common/PlatformBase/Services/ReaderType.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/PlatformBase/Services/ReaderType.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -36,12 +36,15 @@
 PUBLISHED_API:
+    /// \brief
     /// Signifies that the object is of type MgFeatureReader.
     static const int FeatureReader = 0;
+    /// \brief
     /// Signifies that the object is of type MgDataReader.
     static const int DataReader = 1;
+    /// \brief
     /// Signifies that the object is of type MgSqlDataReader.
     static const int SqlDataReader = 2;
 INTERNAL_API:
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h
--- trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -52,10 +52,12 @@
     /// \endif
+    /// \brief
     /// The repository is the \link library library \endlink.
     static const STRING Library;      ///\if INTERNAL value("Library") \endif
+    /// \brief
     /// The repository is a \link session_repository session repository \endlink,
     /// used to store temporary data.
     /// \note1
@@ -492,12 +494,15 @@
     /// \endif
+    /// \brief
     /// No Access permission.
     static const STRING NoAccess;       ///\if INTERNAL value("n") \endif
+    /// \brief
     /// Read-Only permission.
     static const STRING ReadOnly;       ///\if INTERNAL value("r") \endif
+    /// \brief
     /// Read/Write permission.
     static const STRING ReadWrite;      ///\if INTERNAL value("r,w") \endif
@@ -549,12 +554,15 @@
     /// \endif
+    /// \brief
     /// Return folders only
     static const STRING Folders;     ///\if INTERNAL value("Folders") \endif
+    /// \brief
     /// Return files only
     static const STRING Files;       ///\if INTERNAL value("Files") \endif
+    /// \brief
     /// Return both files and folders
     static const STRING Both;        ///\if INTERNAL value("Both") \endif
Modified: trunk/MgDev/Common/PlatformBase/Services/SpatialContextExtentType.h
--- trunk/MgDev/Common/PlatformBase/Services/SpatialContextExtentType.h	2014-05-26 14:17:09 UTC (rev 8160)
+++ trunk/MgDev/Common/PlatformBase/Services/SpatialContextExtentType.h	2014-05-26 14:19:31 UTC (rev 8161)
@@ -29,9 +29,11 @@
 class MgSpatialContextExtentType
 PUBLISHED_API:
+    /// \brief
     /// The spatial extent of the context is static and must be specified
     /// when the context is created.
     static const int scStatic = 0;
+    /// \brief
     /// The spatial extent of the context is dynamic and changes as data is
     /// added and removed from the context.
     static const int scDynamic = 1;
More information about the mapguide-commits mailing list
