[mapguide-commits] r8162 - in trunk/MgDev/UnitTest/WebTier/DotNet: . TestMapGuideApi
svn_mapguide at osgeo.org
Mon May 26 09:24:25 PDT 2014
Author: jng
Date: 2014-05-26 09:24:24 -0700 (Mon, 26 May 2014)
New Revision: 8162
trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTestExecutorCollection.cs
trunk/MgDev/UnitTest/WebTier/DotNet/prebuild.bat
DotNet test runner updates:
- Fix prebuild.bat for x64 configuration
- Normalize line endings on string results on comparisons to guard against incorrect line endings in expected test results entered in the SQLite GUI
Modified: trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTestExecutorCollection.cs
--- trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTestExecutorCollection.cs 2014-05-26 14:19:31 UTC (rev 8161)
+++ trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTestExecutorCollection.cs 2014-05-26 16:24:24 UTC (rev 8162)
@@ -412,7 +412,11 @@
if (strExpectedResult != null && strResultData != null)
- bEqual = strResultData.Equals(strExpectedResult, StringComparison.InvariantCultureIgnoreCase);
+ //Normalize line endings on LF before comparsion (in case the SQLite GUI recorded CRLFs)
+ string normStrResultData = strResultData.Replace("\r\n", "\n");
+ string normStrExpectedResult = strExpectedResult.Replace("\r\n", "\n");
+ bEqual = normStrResultData.Equals(normStrExpectedResult, StringComparison.InvariantCultureIgnoreCase);
else if (bExpected != null && bActual != null)
Modified: trunk/MgDev/UnitTest/WebTier/DotNet/prebuild.bat
--- trunk/MgDev/UnitTest/WebTier/DotNet/prebuild.bat 2014-05-26 14:19:31 UTC (rev 8161)
+++ trunk/MgDev/UnitTest/WebTier/DotNet/prebuild.bat 2014-05-26 16:24:24 UTC (rev 8162)
@@ -22,7 +22,7 @@
goto done
:copy
-if "%PLAT%"=="x64" (
+if %PLAT%=="x64" (
echo Copying x64 binaries from %SLN_DIR%..\..\..\Web\bin\%CFG%64
copy /Y %SLN_DIR%..\..\..\Web\bin\%CFG%64\*.* "%SLN_DIR%Libs\"
echo Copying x64 SqliteDotNet.dll
More information about the mapguide-commits
