[mapguide-commits] r8515 - trunk/MgDev/Oem/SWIGEx/Lib/csharp
svn_mapguide at osgeo.org
Fri Jan 23 05:08:44 PST 2015
Author: jng
Date: 2015-01-23 05:08:44 -0800 (Fri, 23 Jan 2015)
New Revision: 8515
trunk/MgDev/Oem/SWIGEx/Lib/csharp/csharphead.swg
Update SWIG C# boilerplate to use generic Dictionary instead of Hashtable for .net proxy type resolution.
Also add some #ifdefs for .net Core compilation support.
Modified: trunk/MgDev/Oem/SWIGEx/Lib/csharp/csharphead.swg
--- trunk/MgDev/Oem/SWIGEx/Lib/csharp/csharphead.swg 2015-01-21 15:46:16 UTC (rev 8514)
+++ trunk/MgDev/Oem/SWIGEx/Lib/csharp/csharphead.swg 2015-01-23 13:08:44 UTC (rev 8515)
@@ -57,19 +57,22 @@
parameters[1] = true;
Type type = Type.GetType(className);
+ //NOTE: For .net Core, this will be one monolithic assembly (due to lack of AppDomain class) so no
+ //need to probe type information from other loaded assemblies, it should all be there and populated
+ //by the SWIG-generated code
+ #if !ASPNETCORE50
if(type == null)
- // Find the specified class in the pre-defined assemblies
- System.Reflection.Assembly[] assemblies = System.AppDomain.CurrentDomain.GetAssemblies();
- foreach (System.Reflection.Assembly assem in assemblies)
- System.Reflection.AssemblyName assemblyName = new System.Reflection.AssemblyName(assem.FullName);
- String dllName = assemblyNameMap[assemblyName.Name] as String;
- if (!String.IsNullOrEmpty(dllName))
+ // Find the specified class in the pre-defined assemblies
+ System.Reflection.Assembly[] assemblies = System.AppDomain.CurrentDomain.GetAssemblies();
+ foreach (System.Reflection.Assembly assem in assemblies)
+ System.Reflection.AssemblyName assemblyName = new System.Reflection.AssemblyName(assem.FullName);
+ if (assemblyNameMap.ContainsKey(assemblyName.Name))
type = assem.GetType(className, false);
if (type != null)
- break;
+ break;
@@ -80,6 +83,7 @@
break;
+ #endif
if (type == null)
exception = new Exception("Exception (" + className + ") was thrown. No .net type could be found for this exception type");
else
@@ -97,15 +101,19 @@
static SWIGExceptionHelper() {
SWIGRegisterCustomExceptionCallbacks_$module(customExceptionDelegate);
- assemblyNameMap = new Hashtable();
+ assemblyNameMap = new System.Collections.Generic.Dictionary<string, string>();
+ #if ASPNETCORE50
+ assemblyNameMap["OSGeo.MapGuide"] = "OSGeo.MapGuide";
+ #else
assemblyNameMap["OSGeo.MapGuide.Foundation"] = "OSGeo.MapGuide.Foundation";
assemblyNameMap["OSGeo.MapGuide.Geometry"] = "OSGeo.MapGuide.Geometry";
assemblyNameMap["OSGeo.MapGuide.PlatformBase"] = "OSGeo.MapGuide.PlatformBase";
assemblyNameMap["OSGeo.MapGuide.MapGuideCommon"] = "OSGeo.MapGuide.MapGuideCommon";
assemblyNameMap["OSGeo.MapGuide.Web"] = "OSGeo.MapGuide.Web";
assemblyNameMap["Autodesk.Map.PlatformEx"] = "Autodesk.Map.PlatformEx";
+ #endif
- protected static Hashtable assemblyNameMap;
+ protected static System.Collections.Generic.Dictionary<string, string> assemblyNameMap;
static SWIGExceptionHelper exceptionHelper = new SWIGExceptionHelper();
@@ -154,37 +162,50 @@
%pragma(csharp) imclasscode=%{
static $modulePINVOKE()
- classMap = new Hashtable();
- classNameMap = new Hashtable();
+ classMap = new System.Collections.Generic.Dictionary<int, Type>();
+ classNameMap = new System.Collections.Generic.Dictionary<int, string>();
+ #if ASPNETCORE50
+ #else
+ #endif
$initMap
static public object createObject(int id, IntPtr nameSpaceNamePtr, IntPtr classNamePtr, IntPtr cPtr, bool ownMemory)
- Type type = classMap[id] as Type;
- if(type == null)
+ Type type = null;
+ if (classMap.ContainsKey(id))
+ type = classMap[id];
+ #if !ASPNETCORE50
+ if (type == null)
- String className = classNameMap[id] as String;
- if (String.IsNullOrEmpty(className))
+ String className = null;
+ if (!classNameMap.ContainsKey(id))
// Marshall strings in nameSpaceNamePtr and classNamePtr from unmanaged char * to managed strings
String nameSpaceName = System.Runtime.InteropServices.Marshal.PtrToStringAnsi(nameSpaceNamePtr);
className = nameSpaceName + "." + System.Runtime.InteropServices.Marshal.PtrToStringAnsi(classNamePtr);
+ else
+ className = classNameMap[id];
if (type != null)
@@ -210,14 +231,14 @@
if (type == null)
- return null;
+ return null;
+ #endif
object[] args = new object[2] { cPtr, ownMemory };
return Activator.CreateInstance(type, args);
- protected static Hashtable classMap;
- protected static Hashtable classNameMap;
+ protected static System.Collections.Generic.Dictionary<int, Type> classMap;
+ protected static System.Collections.Generic.Dictionary<int, string> classNameMap;
%insert(runtime) %{
More information about the mapguide-commits
