[mapguide-commits] r8516 - in trunk/Tools/Vagrant: centos/x64 centos/x86 scripts ubuntu/x64 ubuntu/x86
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sun Jan 25 01:39:02 PST 2015
Author: jng
Date: 2015-01-25 01:39:02 -0800 (Sun, 25 Jan 2015)
New Revision: 8516
   trunk/Tools/Vagrant/centos/x64/Vagrantfile
   trunk/Tools/Vagrant/centos/x86/Vagrantfile
   trunk/Tools/Vagrant/scripts/build_fdo.sh
   trunk/Tools/Vagrant/scripts/mginstallcentos.sh
   trunk/Tools/Vagrant/scripts/mginstallubuntu.sh
   trunk/Tools/Vagrant/scripts/mguninstallcentos.sh
   trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile
   trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile
#2520: Update Vagrant configurations for MGOS 3.0
 - Update FDO version to 4.0.0
 - Remove providers.xml in Unit Test directory before running unit test (it seems to pick up this one instead of the installed one)
 - Run FDO unit tests with NLSPATH set inline
 - Also run web tier tests as part of the FDO/MapGuide test suite execution
Modified: trunk/Tools/Vagrant/centos/x64/Vagrantfile
--- trunk/Tools/Vagrant/centos/x64/Vagrantfile	2015-01-23 13:08:44 UTC (rev 8515)
+++ trunk/Tools/Vagrant/centos/x64/Vagrantfile	2015-01-25 09:39:02 UTC (rev 8516)
@@ -152,7 +152,7 @@
 MAKE_FDO_SDK=0
 SCRIPT_ROOT=~/scripts
 FDO_SRC_ROOT=~/fdo
-FDO_VER_MM=3.9
+FDO_VER_MM=4.0
 FDO_VER_FULL=${FDO_VER_MM}.0
 MG_VER_MM=3.0
 MG_VER_FULL=${MG_VER_MM}.0
@@ -163,7 +163,9 @@
 MG_SRC=$MG_SRC_ROOT/MgDev
 FDO_TARBALL=fdo-checkout.tar.gz
 MG_TARBALL=mapguide-checkout.tar.gz
-if [ -d $FDO_SRC ];
+FDO_INST_PATH=/usr/local/fdo-${FDO_VER_FULL}
+MG_INST_PATH=/usr/local/mapguideopensource-${MG_VER_FULL}
+if [ -d $FDO_SRC ];
 then
     HAVE_FDO=1
 fi
@@ -249,35 +251,40 @@
 > ~/unit_test_status.log
 if [ $FDO_UNIT_TEST -eq 1 ];
 then
-    export NLSPATH=/usr/local/fdo-${FDO_VER_FULL}/nls/%N
     echo [provision]: Unit test FDO
     BUILD_COMPONENT="Unit Test FDO Core"
     cd $SCRIPT_ROOT/fdo_build_area/Fdo/UnitTest
-    sudo -E ./UnitTest 2>&1 | tee ~/fdo_core_unit_test.log
+    sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_core_unit_test.log
     check_test
     BUILD_COMPONENT="Unit Test SHP Provider"
     cd $SCRIPT_ROOT/fdo_build_area/Providers/SHP/Src/UnitTest
-    sudo -E ./UnitTest 2>&1 | tee ~/fdo_shp_unit_test.log
+    sudo rm providers.xml
+    sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_shp_unit_test.log
     check_test
     BUILD_COMPONENT="Unit Test SDF Provider"
     cd $SCRIPT_ROOT/fdo_build_area/Providers/SDF/Src/UnitTest
-    sudo -E ./UnitTest 2>&1 | tee ~/fdo_sdf_unit_test.log
+    sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_sdf_unit_test.log
     check_test
     BUILD_COMPONENT="Unit Test SQLite Provider"
     cd $SCRIPT_ROOT/fdo_build_area/Providers/SQLite/Src/UnitTest
-    sudo -E ./UnitTest 2>&1 | tee ~/fdo_sqlite_unit_test.log
+    sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_sqlite_unit_test.log
     check_test
     BUILD_COMPONENT="Unit Test GDAL Provider"
     cd $SCRIPT_ROOT/fdo_build_area/Providers/GDAL/Src/UnitTest
-    sudo -E ./UnitTest 2>&1 | tee ~/fdo_gdal_unit_test.log
+    sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_gdal_unit_test.log
     check_test
     BUILD_COMPONENT="Unit Test OGR Provider"
     cd $SCRIPT_ROOT/fdo_build_area/Providers/OGR/Src/UnitTest
-    sudo -E ./UnitTest 2>&1 | tee ~/fdo_ogr_unit_test.log
+    sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_ogr_unit_test.log
     check_test
     BUILD_COMPONENT="Unit Test WMS Provider"
     cd $SCRIPT_ROOT/fdo_build_area/Providers/WMS/Src/UnitTest
-    sudo -E ./UnitTest 2>&1 | tee ~/fdo_wms_unit_test.log
+    sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_wms_unit_test.log
     check_test
 fi
 if [ $MG_UNIT_TEST -eq 1 ];
@@ -303,6 +310,8 @@
             sudo mv UnitTestResults_${comp}.xml ~/UnitTestResults_${comp}.xml
         fi
     done
+    cd $SCRIPT_ROOT/mgdev
+    sudo -E ./run_tests.sh --prefix ${MG_INST_PATH} --with-php --with-java --logpath ~
 fi
 cd $SCRIPT_ROOT
 echo [provision]: Make output dir
Modified: trunk/Tools/Vagrant/centos/x86/Vagrantfile
--- trunk/Tools/Vagrant/centos/x86/Vagrantfile	2015-01-23 13:08:44 UTC (rev 8515)
+++ trunk/Tools/Vagrant/centos/x86/Vagrantfile	2015-01-25 09:39:02 UTC (rev 8516)
@@ -152,7 +152,7 @@
 MAKE_FDO_SDK=0
 FDO_SRC_ROOT=~/fdo
-FDO_VER_MM=3.9
+FDO_VER_MM=4.0
 MG_VER_MM=3.0
@@ -163,7 +163,9 @@
 then
     HAVE_FDO=1
 fi
@@ -251,35 +253,40 @@
 then
     check_test
     check_test
     check_test
     check_test
     check_test
     check_test
     check_test
 fi
@@ -305,6 +312,8 @@
         fi
     done
 fi
 cd $SCRIPT_ROOT
Modified: trunk/Tools/Vagrant/scripts/build_fdo.sh
--- trunk/Tools/Vagrant/scripts/build_fdo.sh	2015-01-23 13:08:44 UTC (rev 8515)
+++ trunk/Tools/Vagrant/scripts/build_fdo.sh	2015-01-25 09:39:02 UTC (rev 8516)
@@ -12,8 +12,8 @@
 FDO_BUILD_COMPONENT=
 # FDO version. Make sure this matches your FDO build source
-FDO_VER_MAJOR=3
-FDO_VER_MINOR=9
+FDO_VER_MAJOR=4
+FDO_VER_MINOR=0
 FDO_VER_REV=0
 # Extra flags to pass to FDO build scripts
Modified: trunk/Tools/Vagrant/scripts/mginstallcentos.sh
--- trunk/Tools/Vagrant/scripts/mginstallcentos.sh	2015-01-23 13:08:44 UTC (rev 8515)
+++ trunk/Tools/Vagrant/scripts/mginstallcentos.sh	2015-01-25 09:39:02 UTC (rev 8516)
@@ -1,7 +1,7 @@
 #!/bin/bash
 URL="http://download.osgeo.org/mapguide/releases/3.0.0/Release"
 #URL="http://192.168.0.4/downloads"
-FDOVER_MAJOR_MINOR=3.9
+FDOVER_MAJOR_MINOR=4.0
 FDOVER_POINT=0
 FDOVER_REV=0
 FDO_ARCH=i386
Modified: trunk/Tools/Vagrant/scripts/mginstallubuntu.sh
--- trunk/Tools/Vagrant/scripts/mginstallubuntu.sh	2015-01-23 13:08:44 UTC (rev 8515)
+++ trunk/Tools/Vagrant/scripts/mginstallubuntu.sh	2015-01-25 09:39:02 UTC (rev 8516)
@@ -2,7 +2,7 @@
 TEMPDIR=/tmp/build_mapguide
 URL="http://download.osgeo.org/mapguide/releases/3.0.0/Release/ubuntu12"
 #URL="http://192.168.0.5/downloads/ubuntu12"
 FDOVER_MAJOR_MINOR_REV=${FDOVER_MAJOR_MINOR}.0
 FDOBUILD=0
 FDOARCH=i386
Modified: trunk/Tools/Vagrant/scripts/mguninstallcentos.sh
--- trunk/Tools/Vagrant/scripts/mguninstallcentos.sh	2015-01-23 13:08:44 UTC (rev 8515)
+++ trunk/Tools/Vagrant/scripts/mguninstallcentos.sh	2015-01-25 09:39:02 UTC (rev 8516)
@@ -1,5 +1,5 @@
 #!/bin/bash
 FDOVER_POINT=0
 FDOVER_MAJOR_MINOR_REV=${FDOVER_MAJOR_MINOR}.${FDOVER_POINT}
 MGVER_MAJOR_MINOR=3.0
Modified: trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile	2015-01-23 13:08:44 UTC (rev 8515)
+++ trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile	2015-01-25 09:39:02 UTC (rev 8516)
@@ -144,7 +144,7 @@
 FDO_UNIT_TEST=1
 FDO_SRC_ROOT=~/fdo
-FDO_VER_MM=3.9
+FDO_VER_MM=4.0
 MG_VER_MM=3.0
@@ -155,6 +155,8 @@
 HAVE_FDO_SDK=0
 FDO_SDK_PKG_PATH=~/fdosdk
@@ -302,35 +304,40 @@
 then
     check_test
     check_test
     check_test
     check_test
     check_test
     check_test
     check_test
 fi
@@ -356,6 +363,8 @@
         fi
     done
 fi
 cd $SCRIPT_ROOT
 sudo mkdir -p /vagrant/build
Modified: trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile	2015-01-23 13:08:44 UTC (rev 8515)
+++ trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile	2015-01-25 09:39:02 UTC (rev 8516)
@@ -144,7 +144,7 @@
 FDO_UNIT_TEST=1
 FDO_SRC_ROOT=~/fdo
-FDO_VER_MM=3.9
+FDO_VER_MM=4.0
 MG_VER_MM=3.0
@@ -155,7 +155,8 @@
 HAVE_FDO_SDK=0
 FDO_SDK_TARBALL=
@@ -302,35 +303,40 @@
 then
     check_test
     check_test
     check_test
     check_test
     check_test
     check_test
     check_test
 fi
@@ -356,6 +362,8 @@
         fi
     done
 fi
 cd $SCRIPT_ROOT
More information about the mapguide-commits mailing list
