[mapguide-commits] r8556 - in trunk/Tools/Maestro: . Maestro Maestro/packages Maestro.AddIn.Local Maestro.AddIn.Rest Maestro.AddIn.Rest/Commands Maestro.AddIn.Rest/Model Maestro.AddIn.Rest/Properties Maestro.AddIn.Rest/Resources Maestro.AddIn.Rest/Resources/Images Maestro.AddIn.Rest/UI Maestro.AddIn.Rest/UI/Methods Maestro.AddIn.Rest/UI/Representation Maestro.Editors/Common Maestro.Shared.UI
svn_mapguide at osgeo.org
Wed Mar 4 05:59:24 PST 2015
Author: jng
Date: 2015-03-04 05:59:24 -0800 (Wed, 04 Mar 2015)
New Revision: 8556
Added:
trunk/Tools/Maestro/Maestro.AddIn.Rest/
trunk/Tools/Maestro/Maestro.AddIn.Rest/Commands/
trunk/Tools/Maestro/Maestro.AddIn.Rest/Commands/StartupCommand.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/ExtensionMethods.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/Maestro.AddIn.Rest.csproj
trunk/Tools/Maestro/Maestro.AddIn.Rest/Manifest.addin
trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/
trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/BoxedValue.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/DataConfigurationList.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/DataFileList.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/RestSourceContext.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/Properties/
trunk/Tools/Maestro/Maestro.AddIn.Rest/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/Resources/
trunk/Tools/Maestro/Maestro.AddIn.Rest/Resources/Images/
trunk/Tools/Maestro/Maestro.AddIn.Rest/Resources/Images/blue-document--plus.png
trunk/Tools/Maestro/Maestro.AddIn.Rest/Resources/Images/cross-script.png
trunk/Tools/Maestro/Maestro.AddIn.Rest/Resources/Images/pencil.png
trunk/Tools/Maestro/Maestro.AddIn.Rest/Resources/Images/plus.png
trunk/Tools/Maestro/Maestro.AddIn.Rest/Strings.Designer.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/Strings.resx
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Methods/
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Methods/GetMethodCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Methods/GetMethodCtrl.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Methods/GetMethodCtrl.resx
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/NewRepresentationDialog.Designer.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/NewRepresentationDialog.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/NewRepresentationDialog.resx
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CruddableRepresentationCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CruddableRepresentationCtrl.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CruddableRepresentationCtrl.resx
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CsvRepresentationCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CsvRepresentationCtrl.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CsvRepresentationCtrl.resx
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/IRepresentationCtrl.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/ImageRepresentationCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/ImageRepresentationCtrl.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/ImageRepresentationCtrl.resx
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/PermissionsCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/PermissionsCtrl.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/PermissionsCtrl.resx
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/TemplateRepresentationCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/TemplateRepresentationCtrl.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/TemplateRepresentationCtrl.resx
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestConfigurationEditor.Designer.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestConfigurationEditor.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestConfigurationEditor.resx
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestExplorer.Designer.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestExplorer.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestExplorer.resx
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestLoginDialog.Designer.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestLoginDialog.cs
trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestLoginDialog.resx
trunk/Tools/Maestro/Maestro.AddIn.Rest/packages.config
trunk/Tools/Maestro/Maestro.AddIn.Local/Maestro.AddIn.Local.csproj
trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.cs
trunk/Tools/Maestro/Maestro.Editors/Common/IExpressionEditor.cs
trunk/Tools/Maestro/Maestro.Editors/Common/MonoCompatibleExpressionEditor.cs
trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.cs
trunk/Tools/Maestro/Maestro/Maestro_All.sln
trunk/Tools/Maestro/Maestro/packages/
trunk/Tools/Maestro/Maestro/packages/repositories.config
#2506: First cut of a dedicated addin for working with mapguide-rest. This consists of:
- A new sidebar pane with a tree explorer to list all available configurations
- A configuration editor with shortcuts to add the desired feature/layer source and desired representations
This was made possible with the introduction of data configuration management APIs introduced with mapguide-rest 1.0 RC1, as such this is the minimum required version of mapguide-rest required for this addin to work.
Modified: trunk/Tools/Maestro/Maestro/Maestro_All.sln
--- trunk/Tools/Maestro/Maestro/Maestro_All.sln 2015-03-02 12:19:20 UTC (rev 8555)
+++ trunk/Tools/Maestro/Maestro/Maestro_All.sln 2015-03-04 13:59:24 UTC (rev 8556)
@@ -122,6 +122,8 @@
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.FDO.Expressions", "..\OSGeo.FDO.Expressions\OSGeo.FDO.Expressions.csproj", "{DA2CC031-200B-4F99-A0A9-2E95374BE78F}"
EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Maestro.AddIn.Rest", "..\Maestro.AddIn.Rest\Maestro.AddIn.Rest.csproj", "{2BFC5B13-3179-4FF9-9877-0D6CE9911A74}"
+EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
Debug|Any CPU = Debug|Any CPU
@@ -268,6 +270,10 @@
{DA2CC031-200B-4F99-A0A9-2E95374BE78F}.Debug|Any CPU.Build.0 = Debug|Any CPU
{DA2CC031-200B-4F99-A0A9-2E95374BE78F}.Release|Any CPU.ActiveCfg = Release|Any CPU
{DA2CC031-200B-4F99-A0A9-2E95374BE78F}.Release|Any CPU.Build.0 = Release|Any CPU
+ {2BFC5B13-3179-4FF9-9877-0D6CE9911A74}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {2BFC5B13-3179-4FF9-9877-0D6CE9911A74}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {2BFC5B13-3179-4FF9-9877-0D6CE9911A74}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {2BFC5B13-3179-4FF9-9877-0D6CE9911A74}.Release|Any CPU.Build.0 = Release|Any CPU
EndGlobalSection
GlobalSection(SolutionProperties) = preSolution
HideSolutionNode = FALSE
@@ -306,5 +312,6 @@
{28224492-7383-46BD-AE64-2DA35243175C} = {7507E52A-413B-4E0D-A1FF-7D293E462C1B}
{D32BE7DB-D0C3-4805-A057-18312370C57E} = {7507E52A-413B-4E0D-A1FF-7D293E462C1B}
{DA2CC031-200B-4F99-A0A9-2E95374BE78F} = {0DA73D0B-B89E-464B-AD24-CD370242F641}
+ {2BFC5B13-3179-4FF9-9877-0D6CE9911A74} = {D5A5B73D-6F2D-4199-8F1E-6786CE41B83D}
EndGlobalSection
EndGlobal
Property changes on: trunk/Tools/Maestro/Maestro/packages
___________________________________________________________________
Modified: svn:ignore
- DockPanelSuite.2.9.0.0
fleesharp.0.9.27-pre
IronPython.2.7.4
IronPython.StdLib.2.7.4
NUnit.2.6.3
SharpZipLib.0.86.0
TreeViewAdv.1.7.0.0
mapguide-api-base-x86.2.5.2.7949
mg-desktop-net40-x86.2.5.2.7949
mg-desktop-viewer-net40-x86.2.5.2.7949
RestSharp.105.0.1
Moq.4.2.1409.1722
NUnit.2.6.2
IronPython.2.7.5
IronPython.StdLib.2.7.5
Irony.0.9.0
mapguide-api-base-x86.2.6.0.8316
mg-desktop-viewer-x86.2.6.0.8316
mg-desktop-x86.2.6.0.8316
GeoAPI.1.7.3
NetTopologySuite.1.13.3.2
ProjNET4GeoAPI.1.3.0.4
+ DockPanelSuite.2.9.0.0
IronPython.2.7.4
NUnit.2.6.3
SharpZipLib.0.86.0
TreeViewAdv.1.7.0.0
RestSharp.105.0.1
Moq.4.2.1409.1722
NUnit.2.6.2
IronPython.2.7.5
Irony.0.9.0
GeoAPI.1.7.3
Newtonsoft.Json.6.0.8
Modified: trunk/Tools/Maestro/Maestro/packages/repositories.config
--- trunk/Tools/Maestro/Maestro/packages/repositories.config 2015-03-02 12:19:20 UTC (rev 8555)
+++ trunk/Tools/Maestro/Maestro/packages/repositories.config 2015-03-04 13:59:24 UTC (rev 8556)
@@ -1,6 +1,7 @@
<?xml version="1.0" encoding="utf-8"?>
<repositories>
<repository path="..\..\Maestro.AddIn.Local\packages.config" />
+ <repository path="..\..\Maestro.AddIn.Rest\packages.config" />
<repository path="..\..\Maestro.AddIn.Scripting\packages.config" />
<repository path="..\..\Maestro.AddInManager\packages.config" />
<repository path="..\..\Maestro.Base\packages.config" />
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/Maestro.AddIn.Local.csproj
--- trunk/Tools/Maestro/Maestro.AddIn.Local/Maestro.AddIn.Local.csproj 2015-03-02 12:19:20 UTC (rev 8555)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/Maestro.AddIn.Local.csproj 2015-03-04 13:59:24 UTC (rev 8556)
@@ -143,6 +143,7 @@
<ProjectReference Include="..\Maestro.Shared.UI\Maestro.Shared.UI.csproj">
<Project>{CFD19053-2172-41D3-8460-0FD2123A1E88}</Project>
<Name>Maestro.Shared.UI</Name>
+ <Private>False</Private>
</ProjectReference>
<ProjectReference Include="..\OSGeo.MapGuide.MaestroAPI.Local\OSGeo.MapGuide.MaestroAPI.Local.csproj">
<Project>{3DDF6501-0148-474C-8674-7C7DA49C7F02}</Project>
Property changes on: trunk/Tools/Maestro/Maestro.AddIn.Rest
Added: svn:ignore
+ bin
obj
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/Commands/StartupCommand.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/Commands/StartupCommand.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/Commands/StartupCommand.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,47 @@
+#region Disclaimer / License
+// Copyright (C) 2015, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion Disclaimer / License
+using ICSharpCode.Core;
+using Maestro.AddIn.Rest.UI;
+using Maestro.Base;
+using Maestro.Base.Services;
+using System;
+using System.Collections.Generic;
+using System.Linq;
+using System.Text;
+using System.Threading.Tasks;
+namespace Maestro.AddIn.Rest.Commands
+ public class StartupCommand : AbstractCommand
+ public override void Run()
+ ResourceService.RegisterNeutralStrings(Strings.ResourceManager);
+ Workbench.WorkbenchInitialized += (sender, e) =>
+ var mgr = ServiceRegistry.GetService<ViewContentManager>();
+ mgr.OpenContent<RestExplorer>(Shared.UI.ViewRegion.Right);
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/ExtensionMethods.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/ExtensionMethods.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/ExtensionMethods.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,53 @@
+using RestSharp;
+using System;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+ public static class ExtensionMethods
+ public static void UIThreadInvoke(this Control control, Action action)
+ if (control.InvokeRequired)
+ control.Invoke(action);
+ else
+ action();
+ public static RestRequestAsyncHandle ExecuteGetRequestAsync<T>(this RestClient client, string uriPart, Action<T, Exception> callback) where T : new()
+ var req = new RestRequest(uriPart);
+ return client.ExecuteAsync<T>(req, (resp) =>
+ if (resp.StatusCode != System.Net.HttpStatusCode.OK)
+ throw new Exception(resp.Content);
+ callback(resp.Data, resp.ErrorException);
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/Maestro.AddIn.Rest.csproj
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/Maestro.AddIn.Rest.csproj (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/Maestro.AddIn.Rest.csproj 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,224 @@
+<?xml version="1.0" encoding="utf-8"?>
+<Project ToolsVersion="12.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <Import Project="$(MSBuildExtensionsPath)\$(MSBuildToolsVersion)\Microsoft.Common.props" Condition="Exists('$(MSBuildExtensionsPath)\$(MSBuildToolsVersion)\Microsoft.Common.props')" />
+ <PropertyGroup>
+ <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
+ <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
+ <ProjectGuid>{2BFC5B13-3179-4FF9-9877-0D6CE9911A74}</ProjectGuid>
+ <OutputType>Library</OutputType>
+ <AppDesignerFolder>Properties</AppDesignerFolder>
+ <RootNamespace>Maestro.AddIn.Rest</RootNamespace>
+ <AssemblyName>Maestro.AddIn.Rest</AssemblyName>
+ <TargetFrameworkVersion>v4.5.1</TargetFrameworkVersion>
+ <FileAlignment>512</FileAlignment>
+ <SolutionDir Condition="$(SolutionDir) == '' Or $(SolutionDir) == '*Undefined*'">..\Maestro\</SolutionDir>
+ <RestorePackages>true</RestorePackages>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
+ <DebugSymbols>true</DebugSymbols>
+ <DebugType>full</DebugType>
+ <Optimize>false</Optimize>
+ <OutputPath>..\out\Debug\AddIns\Rest\</OutputPath>
+ <DefineConstants>DEBUG;TRACE</DefineConstants>
+ <ErrorReport>prompt</ErrorReport>
+ <WarningLevel>4</WarningLevel>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' ">
+ <DebugType>pdbonly</DebugType>
+ <Optimize>true</Optimize>
+ <OutputPath>..\out\Release\AddIns\Local\</OutputPath>
+ <DefineConstants>TRACE</DefineConstants>
+ </PropertyGroup>
+ <ItemGroup>
+ <Reference Include="ICSharpCode.TextEditor">
+ <HintPath>..\SDK\bin\ICSharpCode.TextEditor.dll</HintPath>
+ </Reference>
+ <Reference Include="Newtonsoft.Json, Version=6.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed, processorArchitecture=MSIL">
+ <SpecificVersion>False</SpecificVersion>
+ <HintPath>..\Maestro\packages\Newtonsoft.Json.6.0.8\lib\net45\Newtonsoft.Json.dll</HintPath>
+ </Reference>
+ <Reference Include="RestSharp">
+ <HintPath>..\Maestro\packages\RestSharp.105.0.1\lib\net4\RestSharp.dll</HintPath>
+ </Reference>
+ <Reference Include="System" />
+ <Reference Include="System.Core" />
+ <Reference Include="System.Drawing" />
+ <Reference Include="System.Windows.Forms" />
+ <Reference Include="System.Xml.Linq" />
+ <Reference Include="System.Data.DataSetExtensions" />
+ <Reference Include="Microsoft.CSharp" />
+ <Reference Include="System.Data" />
+ <Reference Include="System.Xml" />
+ </ItemGroup>
+ <ItemGroup>
+ <Compile Include="Commands\StartupCommand.cs" />
+ <Compile Include="ExtensionMethods.cs" />
+ <Compile Include="Model\BoxedValue.cs" />
+ <Compile Include="Model\DataConfigurationList.cs" />
+ <Compile Include="Model\DataFileList.cs" />
+ <Compile Include="Model\RestSourceContext.cs" />
+ <Compile Include="Properties\AssemblyInfo.cs" />
+ <Compile Include="Strings.Designer.cs">
+ <AutoGen>True</AutoGen>
+ <DesignTime>True</DesignTime>
+ <DependentUpon>Strings.resx</DependentUpon>
+ </Compile>
+ <Compile Include="UI\Methods\GetMethodCtrl.cs">
+ <SubType>UserControl</SubType>
+ </Compile>
+ <Compile Include="UI\Methods\GetMethodCtrl.Designer.cs">
+ <DependentUpon>GetMethodCtrl.cs</DependentUpon>
+ </Compile>
+ <Compile Include="UI\NewRepresentationDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="UI\NewRepresentationDialog.Designer.cs">
+ <DependentUpon>NewRepresentationDialog.cs</DependentUpon>
+ </Compile>
+ <Compile Include="UI\Representation\CsvRepresentationCtrl.cs">
+ </Compile>
+ <Compile Include="UI\Representation\CsvRepresentationCtrl.Designer.cs">
+ <DependentUpon>CsvRepresentationCtrl.cs</DependentUpon>
+ </Compile>
+ <Compile Include="UI\Representation\ImageRepresentationCtrl.cs">
+ </Compile>
+ <Compile Include="UI\Representation\ImageRepresentationCtrl.Designer.cs">
+ <DependentUpon>ImageRepresentationCtrl.cs</DependentUpon>
+ </Compile>
+ <Compile Include="UI\Representation\IRepresentationCtrl.cs" />
+ <Compile Include="UI\Representation\PermissionsCtrl.cs">
+ </Compile>
+ <Compile Include="UI\Representation\PermissionsCtrl.Designer.cs">
+ <DependentUpon>PermissionsCtrl.cs</DependentUpon>
+ </Compile>
+ <Compile Include="UI\Representation\CruddableRepresentationCtrl.cs">
+ </Compile>
+ <Compile Include="UI\Representation\CruddableRepresentationCtrl.Designer.cs">
+ <DependentUpon>CruddableRepresentationCtrl.cs</DependentUpon>
+ </Compile>
+ <Compile Include="UI\Representation\TemplateRepresentationCtrl.cs">
+ </Compile>
+ <Compile Include="UI\Representation\TemplateRepresentationCtrl.Designer.cs">
+ <DependentUpon>TemplateRepresentationCtrl.cs</DependentUpon>
+ </Compile>
+ <Compile Include="UI\RestConfigurationEditor.cs">
+ </Compile>
+ <Compile Include="UI\RestConfigurationEditor.Designer.cs">
+ <DependentUpon>RestConfigurationEditor.cs</DependentUpon>
+ </Compile>
+ <Compile Include="UI\RestExplorer.cs">
+ </Compile>
+ <Compile Include="UI\RestExplorer.Designer.cs">
+ <DependentUpon>RestExplorer.cs</DependentUpon>
+ </Compile>
+ <Compile Include="UI\RestLoginDialog.cs">
+ </Compile>
+ <Compile Include="UI\RestLoginDialog.Designer.cs">
+ <DependentUpon>RestLoginDialog.cs</DependentUpon>
+ </Compile>
+ </ItemGroup>
+ <ItemGroup>
+ <ProjectReference Include="..\Maestro.Base\Maestro.Base.csproj">
+ <Project>{f1e2f468-5030-4dba-968c-9620284afaa1}</Project>
+ <Name>Maestro.Base</Name>
+ </ProjectReference>
+ <ProjectReference Include="..\Maestro.Editors\Maestro.Editors.csproj">
+ <Project>{5ad2cdba-952e-4148-98a1-31d2e0d540d5}</Project>
+ <Name>Maestro.Editors</Name>
+ <ProjectReference Include="..\Maestro.Shared.UI\Maestro.Shared.UI.csproj">
+ <Project>{cfd19053-2172-41d3-8460-0fd2123a1e88}</Project>
+ <Name>Maestro.Shared.UI</Name>
+ <ProjectReference Include="..\OSGeo.MapGuide.MaestroAPI\OSGeo.MapGuide.MaestroAPI.csproj">
+ <Project>{80fa3158-8b5f-48d1-a393-0378afe48a7e}</Project>
+ <Name>OSGeo.MapGuide.MaestroAPI</Name>
+ <ProjectReference Include="..\OSGeo.MapGuide.ObjectModels\OSGeo.MapGuide.ObjectModels.csproj">
+ <Project>{48c5eb23-45ae-4c4c-8fab-635428ae8ca1}</Project>
+ <Name>OSGeo.MapGuide.ObjectModels</Name>
+ <ProjectReference Include="..\Thirdparty\SharpDevelop\ICSharpCode.Core\ICSharpCode.Core.csproj">
+ <Project>{35cef10f-2d4c-45f2-9dd1-161e0fec583c}</Project>
+ <Name>ICSharpCode.Core</Name>
+ </ItemGroup>
+ <ItemGroup>
+ <Content Include="Manifest.addin">
+ <CopyToOutputDirectory>Always</CopyToOutputDirectory>
+ </Content>
+ <None Include="packages.config" />
+ <None Include="Resources\Images\pencil.png" />
+ <None Include="Resources\Images\blue-document--plus.png" />
+ <None Include="Resources\Images\cross-script.png" />
+ <None Include="Resources\Images\plus.png" />
+ </ItemGroup>
+ <ItemGroup>
+ <EmbeddedResource Include="Strings.resx">
+ <Generator>ResXFileCodeGenerator</Generator>
+ <LastGenOutput>Strings.Designer.cs</LastGenOutput>
+ </EmbeddedResource>
+ <EmbeddedResource Include="UI\Methods\GetMethodCtrl.resx">
+ <EmbeddedResource Include="UI\NewRepresentationDialog.resx">
+ <EmbeddedResource Include="UI\Representation\CsvRepresentationCtrl.resx">
+ <EmbeddedResource Include="UI\Representation\ImageRepresentationCtrl.resx">
+ <EmbeddedResource Include="UI\Representation\PermissionsCtrl.resx">
+ <EmbeddedResource Include="UI\Representation\CruddableRepresentationCtrl.resx">
+ <EmbeddedResource Include="UI\Representation\TemplateRepresentationCtrl.resx">
+ <EmbeddedResource Include="UI\RestConfigurationEditor.resx">
+ <EmbeddedResource Include="UI\RestExplorer.resx">
+ <EmbeddedResource Include="UI\RestLoginDialog.resx">
+ </ItemGroup>
+ <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
+ <Import Project="$(SolutionDir)\.nuget\NuGet.targets" Condition="Exists('$(SolutionDir)\.nuget\NuGet.targets')" />
+ <Target Name="EnsureNuGetPackageBuildImports" BeforeTargets="PrepareForBuild">
+ <PropertyGroup>
+ <ErrorText>This project references NuGet package(s) that are missing on this computer. Enable NuGet Package Restore to download them. For more information, see http://go.microsoft.com/fwlink/?LinkID=322105. The missing file is {0}.</ErrorText>
+ </PropertyGroup>
+ <Error Condition="!Exists('$(SolutionDir)\.nuget\NuGet.targets')" Text="$([System.String]::Format('$(ErrorText)', '$(SolutionDir)\.nuget\NuGet.targets'))" />
+ </Target>
+ <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
+ Other similar extension points exist, see Microsoft.Common.targets.
+ <Target Name="BeforeBuild">
+ </Target>
+ <Target Name="AfterBuild">
+ </Target>
+</Project>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/Manifest.addin
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/Manifest.addin (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/Manifest.addin 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,25 @@
+<AddIn name="Maestro.AddIn.Rest"
+ author="Jackie Ng"
+ url="http://trac.osgeo.org/mapguide/wiki/maestro"
+ description="MapGuide Maestro AddIn to support publishing spatial data to a mapguide-rest instance"
+ addInManagerHidden="preinstalled">
+ <Manifest>
+ <Identity name="Maestro.AddIn.Rest" />
+ </Manifest>
+ <Runtime>
+ <Import assembly=":Maestro.Base" />
+ <Import assembly="Maestro.AddIn.Rest.dll" />
+ </Runtime>
+ <!-- Auto-start commands -->
+ <Path name="/Workspace/Autostart">
+ <Class id="Startup" class="Maestro.AddIn.Rest.Commands.StartupCommand" />
+ </Path>
+ <!-- Singleton view content -->
+ <Path name="/Maestro/Shell/SingleViewContent">
+ <Class id="RestExplorer" class="Maestro.AddIn.Rest.UI.RestExplorer" />
+ </Path>
+</AddIn>
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/BoxedValue.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/BoxedValue.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/BoxedValue.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,44 @@
+using System;
+using System.Linq;
+using System.Text;
+namespace Maestro.AddIn.Rest.Model
+ public class PrimitiveValueResponse
+ public PrimitiveValueResponse() { }
+ public PrimitiveValue PrimitiveValue { get; set; }
+ public PrimitiveValue() { }
+ public string Type { get; set; }
+ public object Value { get; set; }
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/DataConfigurationList.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/DataConfigurationList.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/DataConfigurationList.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,71 @@
+using System;
+using System.Linq;
+using System.Text;
+ public class DataConfigurationResponse
+ public DataConfigurationResponse() { }
+ /// <summary>
+ /// The list of data configurations
+ /// </summary>
+ public DataConfigurationList DataConfigurationList { get; set; }
+ public class DataConfigurationList
+ public DataConfigurationList() { }
+ /// <summary>
+ /// The base endpoint URI for mapguide-rest
+ /// </summary>
+ public string RootUri { get; set; }
+ /// <summary>
+ /// The associated mapagent URL
+ /// </summary>
+ public string MapAgentUrl { get; set; }
+ /// <summary>
+ /// The array of configured published data sources
+ /// </summary>
+ public List<DataConfiguration> Configuration { get; set; }
+ public DataConfiguration() { }
+ /// <summary>
+ /// The relative URI part to read/write the configuration file
+ /// </summary>
+ public string ConfigUriPart { get; set; }
+ /// <summary>
+ /// The relative URI part to access the API documentation for this data configuration
+ /// </summary>
+ public string DocUriPart { get; set; }
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/DataFileList.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/DataFileList.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/DataFileList.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,43 @@
+using System;
+using System.Linq;
+using System.Text;
+ public class DataFileListResponse
+ public DataFileListResponse() { }
+ public DataFileList DataConfigurationFileList { get; set; }
+ public DataFileList() { }
+ public List<string> File { get; set; }
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/RestSourceContext.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/RestSourceContext.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/Model/RestSourceContext.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,103 @@
+using Maestro.Editors.Common;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Schema;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using OSGeo.MapGuide.ObjectModels.FeatureSource;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+using System;
+using System.Linq;
+using System.Text;
+ public class RestSource
+ public string FeatureSource { get; set; }
+ public string ClassName { get; set; }
+ public class RestSourceContext
+ private RestSource _source;
+ private IServerConnection _conn;
+ private ClassDefinition _cls;
+ public RestSourceContext(IServerConnection conn, RestSource source)
+ _conn = conn;
+ _source = source;
+ private ClassDefinition GetClass()
+ if (_cls == null)
+ _cls = _conn.FeatureService.GetClassDefinition(_source.FeatureSource, _source.ClassName);
+ return _cls;
+ internal IList<string> GetPropertyNames()
+ var list = new List<string>();
+ var cls = GetClass();
+ list.AddRange(cls.Properties.Select(p => p.Name));
+ return list;
+ internal string EditExpression(string expr)
+ var editor = FdoExpressionEditorFactory.Create();
+ editor.Initialize(_conn, GetClass(), _source.FeatureSource, ExpressionEditorMode.Expression);
+ if (editor.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ return editor.Expression;
+ return null;
+ internal string PickCoordinateSystemCode()
+ CoordinateSystemPicker picker = new CoordinateSystemPicker(_conn.CoordinateSystemCatalog);
+ if (picker.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ var cs = picker.SelectedCoordSys;
+ return cs.Code;
+ return null;
+ internal IList<string> GetGroups()
+ ISiteService site = (ISiteService)_conn.GetService((int)ServiceType.Site);
+ list.AddRange(site.EnumerateGroups().Group.Select(g => g.Name));
+ return list;
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/Properties/AssemblyInfo.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/Properties/AssemblyInfo.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,36 @@
+using System.Reflection;
+using System.Runtime.CompilerServices;
+using System.Runtime.InteropServices;
+// General Information about an assembly is controlled through the following
+// set of attributes. Change these attribute values to modify the information
+// associated with an assembly.
+[assembly: AssemblyTitle("Maestro.AddIn.Rest")]
+[assembly: AssemblyDescription("")]
+[assembly: AssemblyConfiguration("")]
+[assembly: AssemblyCompany("")]
+[assembly: AssemblyProduct("Maestro.AddIn.Rest")]
+[assembly: AssemblyCopyright("Copyright © 2015")]
+[assembly: AssemblyTrademark("")]
+[assembly: AssemblyCulture("")]
+// Setting ComVisible to false makes the types in this assembly not visible
+// to COM components. If you need to access a type in this assembly from
+// COM, set the ComVisible attribute to true on that type.
+[assembly: ComVisible(false)]
+// The following GUID is for the ID of the typelib if this project is exposed to COM
+[assembly: Guid("e00b3cd6-9d5a-46a2-97da-c0bea22b644a")]
+// Version information for an assembly consists of the following four values:
+// Major Version
+// Minor Version
+// Build Number
+// Revision
+// You can specify all the values or you can default the Build and Revision Numbers
+// by using the '*' as shown below:
+// [assembly: AssemblyVersion("1.0.*")]
+[assembly: AssemblyVersion("1.0.0.0")]
+[assembly: AssemblyFileVersion("1.0.0.0")]
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/Resources/Images/blue-document--plus.png
(Binary files differ)
Property changes on: trunk/Tools/Maestro/Maestro.AddIn.Rest/Resources/Images/blue-document--plus.png
Added: svn:mime-type
+ application/octet-stream
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/Resources/Images/cross-script.png
Property changes on: trunk/Tools/Maestro/Maestro.AddIn.Rest/Resources/Images/cross-script.png
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/Resources/Images/pencil.png
Property changes on: trunk/Tools/Maestro/Maestro.AddIn.Rest/Resources/Images/pencil.png
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/Resources/Images/plus.png
Property changes on: trunk/Tools/Maestro/Maestro.AddIn.Rest/Resources/Images/plus.png
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/Strings.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/Strings.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/Strings.Designer.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,171 @@
+// <auto-generated>
+// This code was generated by a tool.
+// Runtime Version:4.0.30319.34209
+// Changes to this file may cause incorrect behavior and will be lost if
+// the code is regenerated.
+// </auto-generated>
+namespace Maestro.AddIn.Rest {
+ using System;
+ /// <summary>
+ /// A strongly-typed resource class, for looking up localized strings, etc.
+ /// </summary>
+ // This class was auto-generated by the StronglyTypedResourceBuilder
+ // class via a tool like ResGen or Visual Studio.
+ // To add or remove a member, edit your .ResX file then rerun ResGen
+ // with the /str option, or rebuild your VS project.
+ [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "4.0.0.0")]
+ [global::System.Diagnostics.DebuggerNonUserCodeAttribute()]
+ [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
+ internal class Strings {
+ private static global::System.Resources.ResourceManager resourceMan;
+ private static global::System.Globalization.CultureInfo resourceCulture;
+ [global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")]
+ internal Strings() {
+ /// <summary>
+ /// Returns the cached ResourceManager instance used by this class.
+ /// </summary>
+ [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)]
+ internal static global::System.Resources.ResourceManager ResourceManager {
+ get {
+ if (object.ReferenceEquals(resourceMan, null)) {
+ global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("Maestro.AddIn.Rest.Strings", typeof(Strings).Assembly);
+ resourceMan = temp;
+ return resourceMan;
+ /// <summary>
+ /// Overrides the current thread's CurrentUICulture property for all
+ /// resource lookups using this strongly typed resource class.
+ /// </summary>
+ internal static global::System.Globalization.CultureInfo Culture {
+ get {
+ return resourceCulture;
+ set {
+ resourceCulture = value;
+ /// <summary>
+ /// Looks up a localized string similar to Configuration deleted.
+ /// </summary>
+ internal static string ConfigurationDeleted {
+ get {
+ return ResourceManager.GetString("ConfigurationDeleted", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Configuration saved.
+ /// </summary>
+ internal static string ConfigurationSaved {
+ get {
+ return ResourceManager.GetString("ConfigurationSaved", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Delete configuration.
+ /// </summary>
+ internal static string DeleteConfiguration {
+ get {
+ return ResourceManager.GetString("DeleteConfiguration", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Error saving configuration: {0}.
+ /// </summary>
+ internal static string ErrorSavingConfiguration {
+ get {
+ return ResourceManager.GetString("ErrorSavingConfiguration", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to FDO Class.
+ /// </summary>
+ internal static string FdoClass {
+ get {
+ return ResourceManager.GetString("FdoClass", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Configuration has a missing or invalid source configuration.
+ /// </summary>
+ internal static string InvalidSourceConfiguration {
+ get {
+ return ResourceManager.GetString("InvalidSourceConfiguration", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No source specified. Please specify a source from a Feature Source or Layer Definition first.
+ /// </summary>
+ internal static string NoSourceInConfiguration {
+ get {
+ return ResourceManager.GetString("NoSourceInConfiguration", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Not a vector layer: {0}.
+ /// </summary>
+ internal static string NotAVectorLayer {
+ get {
+ return ResourceManager.GetString("NotAVectorLayer", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Delete this configuration?.
+ /// </summary>
+ internal static string PromptDeleteConfiguration {
+ get {
+ return ResourceManager.GetString("PromptDeleteConfiguration", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to REST Explorer.
+ /// </summary>
+ internal static string RestExplorer {
+ get {
+ return ResourceManager.GetString("RestExplorer", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Select class name.
+ /// </summary>
+ internal static string SelectClassName {
+ get {
+ return ResourceManager.GetString("SelectClassName", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Please enter the URI part for this configuration. If the URI part already exists, saving will overwrite the existing configuration.
+ /// </summary>
+ internal static string UriPartRequrired {
+ get {
+ return ResourceManager.GetString("UriPartRequrired", resourceCulture);
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/Strings.resx
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/Strings.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/Strings.resx 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,156 @@
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <data name="RestExplorer" xml:space="preserve">
+ <value>REST Explorer</value>
+ </data>
+ <data name="FdoClass" xml:space="preserve">
+ <value>FDO Class</value>
+ </data>
+ <data name="SelectClassName" xml:space="preserve">
+ <value>Select class name</value>
+ </data>
+ <data name="ErrorSavingConfiguration" xml:space="preserve">
+ <value>Error saving configuration: {0}</value>
+ </data>
+ <data name="ConfigurationSaved" xml:space="preserve">
+ <value>Configuration saved</value>
+ </data>
+ <data name="NoSourceInConfiguration" xml:space="preserve">
+ <value>No source specified. Please specify a source from a Feature Source or Layer Definition first</value>
+ </data>
+ <data name="NotAVectorLayer" xml:space="preserve">
+ <value>Not a vector layer: {0}</value>
+ </data>
+ <data name="InvalidSourceConfiguration" xml:space="preserve">
+ <value>Configuration has a missing or invalid source configuration</value>
+ </data>
+ <data name="PromptDeleteConfiguration" xml:space="preserve">
+ <value>Delete this configuration?</value>
+ </data>
+ <data name="DeleteConfiguration" xml:space="preserve">
+ <value>Delete configuration</value>
+ </data>
+ <data name="ConfigurationDeleted" xml:space="preserve">
+ <value>Configuration deleted</value>
+ </data>
+ <data name="UriPartRequrired" xml:space="preserve">
+ <value>Please enter the URI part for this configuration. If the URI part already exists, saving will overwrite the existing configuration</value>
+ </data>
+</root>
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Methods/GetMethodCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Methods/GetMethodCtrl.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Methods/GetMethodCtrl.Designer.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,185 @@
+namespace Maestro.AddIn.Rest.UI.Methods
+ partial class GetMethodCtrl
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Component Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(GetMethodCtrl));
+ this.chkMaxCount = new System.Windows.Forms.CheckBox();
+ this.chkPageSize = new System.Windows.Forms.CheckBox();
+ this.numPageSize = new System.Windows.Forms.NumericUpDown();
+ this.numMaxCount = new System.Windows.Forms.NumericUpDown();
+ this.chkTransformTo = new System.Windows.Forms.CheckBox();
+ this.txtTransformTo = new System.Windows.Forms.TextBox();
+ this.btnBrowseCs = new System.Windows.Forms.Button();
+ this.chkComputedProperties = new System.Windows.Forms.CheckBox();
+ this.grdComputedProperties = new System.Windows.Forms.DataGridView();
+ this.lstProperties = new System.Windows.Forms.ListBox();
+ this.chkProperties = new System.Windows.Forms.CheckBox();
+ this.panel1 = new System.Windows.Forms.Panel();
+ this.toolStrip1 = new System.Windows.Forms.ToolStrip();
+ this.btnEditExpression = new System.Windows.Forms.ToolStripButton();
+ ((System.ComponentModel.ISupportInitialize)(this.numPageSize)).BeginInit();
+ ((System.ComponentModel.ISupportInitialize)(this.numMaxCount)).BeginInit();
+ ((System.ComponentModel.ISupportInitialize)(this.grdComputedProperties)).BeginInit();
+ this.panel1.SuspendLayout();
+ this.toolStrip1.SuspendLayout();
+ this.SuspendLayout();
+ // chkMaxCount
+ resources.ApplyResources(this.chkMaxCount, "chkMaxCount");
+ this.chkMaxCount.Name = "chkMaxCount";
+ this.chkMaxCount.UseVisualStyleBackColor = true;
+ // chkPageSize
+ resources.ApplyResources(this.chkPageSize, "chkPageSize");
+ this.chkPageSize.Name = "chkPageSize";
+ this.chkPageSize.UseVisualStyleBackColor = true;
+ // numPageSize
+ resources.ApplyResources(this.numPageSize, "numPageSize");
+ this.numPageSize.Name = "numPageSize";
+ // numMaxCount
+ resources.ApplyResources(this.numMaxCount, "numMaxCount");
+ this.numMaxCount.Name = "numMaxCount";
+ // chkTransformTo
+ resources.ApplyResources(this.chkTransformTo, "chkTransformTo");
+ this.chkTransformTo.Name = "chkTransformTo";
+ this.chkTransformTo.UseVisualStyleBackColor = true;
+ // txtTransformTo
+ resources.ApplyResources(this.txtTransformTo, "txtTransformTo");
+ this.txtTransformTo.Name = "txtTransformTo";
+ this.txtTransformTo.ReadOnly = true;
+ // btnBrowseCs
+ resources.ApplyResources(this.btnBrowseCs, "btnBrowseCs");
+ this.btnBrowseCs.Name = "btnBrowseCs";
+ this.btnBrowseCs.UseVisualStyleBackColor = true;
+ this.btnBrowseCs.Click += new System.EventHandler(this.btnBrowseCs_Click);
+ // chkComputedProperties
+ resources.ApplyResources(this.chkComputedProperties, "chkComputedProperties");
+ this.chkComputedProperties.Name = "chkComputedProperties";
+ this.chkComputedProperties.UseVisualStyleBackColor = true;
+ // grdComputedProperties
+ this.grdComputedProperties.ColumnHeadersHeightSizeMode = System.Windows.Forms.DataGridViewColumnHeadersHeightSizeMode.AutoSize;
+ resources.ApplyResources(this.grdComputedProperties, "grdComputedProperties");
+ this.grdComputedProperties.Name = "grdComputedProperties";
+ this.grdComputedProperties.SelectionChanged += new System.EventHandler(this.grdComputedProperties_SelectionChanged);
+ // lstProperties
+ this.lstProperties.FormattingEnabled = true;
+ resources.ApplyResources(this.lstProperties, "lstProperties");
+ this.lstProperties.Name = "lstProperties";
+ this.lstProperties.SelectionMode = System.Windows.Forms.SelectionMode.MultiSimple;
+ // chkProperties
+ resources.ApplyResources(this.chkProperties, "chkProperties");
+ this.chkProperties.Name = "chkProperties";
+ this.chkProperties.UseVisualStyleBackColor = true;
+ // panel1
+ this.panel1.Controls.Add(this.grdComputedProperties);
+ this.panel1.Controls.Add(this.toolStrip1);
+ resources.ApplyResources(this.panel1, "panel1");
+ this.panel1.Name = "panel1";
+ // toolStrip1
+ this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.btnEditExpression});
+ resources.ApplyResources(this.toolStrip1, "toolStrip1");
+ this.toolStrip1.Name = "toolStrip1";
+ // btnEditExpression
+ resources.ApplyResources(this.btnEditExpression, "btnEditExpression");
+ this.btnEditExpression.Name = "btnEditExpression";
+ this.btnEditExpression.Click += new System.EventHandler(this.btnEditExpression_Click);
+ // GetMethodCtrl
+ resources.ApplyResources(this, "$this");
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.Controls.Add(this.panel1);
+ this.Controls.Add(this.lstProperties);
+ this.Controls.Add(this.chkProperties);
+ this.Controls.Add(this.chkComputedProperties);
+ this.Controls.Add(this.btnBrowseCs);
+ this.Controls.Add(this.txtTransformTo);
+ this.Controls.Add(this.chkTransformTo);
+ this.Controls.Add(this.numMaxCount);
+ this.Controls.Add(this.numPageSize);
+ this.Controls.Add(this.chkPageSize);
+ this.Controls.Add(this.chkMaxCount);
+ this.Name = "GetMethodCtrl";
+ ((System.ComponentModel.ISupportInitialize)(this.numPageSize)).EndInit();
+ ((System.ComponentModel.ISupportInitialize)(this.numMaxCount)).EndInit();
+ ((System.ComponentModel.ISupportInitialize)(this.grdComputedProperties)).EndInit();
+ this.panel1.ResumeLayout(false);
+ this.panel1.PerformLayout();
+ this.toolStrip1.ResumeLayout(false);
+ this.toolStrip1.PerformLayout();
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.CheckBox chkMaxCount;
+ private System.Windows.Forms.CheckBox chkPageSize;
+ private System.Windows.Forms.NumericUpDown numPageSize;
+ private System.Windows.Forms.NumericUpDown numMaxCount;
+ private System.Windows.Forms.CheckBox chkTransformTo;
+ private System.Windows.Forms.TextBox txtTransformTo;
+ private System.Windows.Forms.Button btnBrowseCs;
+ private System.Windows.Forms.CheckBox chkComputedProperties;
+ private System.Windows.Forms.DataGridView grdComputedProperties;
+ private System.Windows.Forms.ListBox lstProperties;
+ private System.Windows.Forms.CheckBox chkProperties;
+ private System.Windows.Forms.Panel panel1;
+ private System.Windows.Forms.ToolStrip toolStrip1;
+ private System.Windows.Forms.ToolStripButton btnEditExpression;
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Methods/GetMethodCtrl.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Methods/GetMethodCtrl.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Methods/GetMethodCtrl.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,160 @@
+using System;
+using System.ComponentModel;
+using System.Drawing;
+using System.Data;
+using System.Linq;
+using System.Text;
+using System.Dynamic;
+using Maestro.AddIn.Rest.Model;
+ internal partial class GetMethodCtrl : UserControl
+ class ComputedProperty : INotifyPropertyChanged
+ private string _alias;
+ private string _expression;
+ public ComputedProperty()
+ _alias = "";
+ _expression = "";
+ public string Alias
+ get { return _alias; }
+ set
+ if (value != _alias)
+ _alias = value;
+ var h = this.PropertyChanged;
+ if (h != null)
+ h(this, new PropertyChangedEventArgs("Alias")); //NOXLATE
+ public string Expression
+ get { return _expression; }
+ set
+ if (value != _expression)
+ _expression = value;
+ if (h != null)
+ h(this, new PropertyChangedEventArgs("Expression")); //NOXLATE
+ public event PropertyChangedEventHandler PropertyChanged;
+ private RestSourceContext _context;
+ private BindingList<ComputedProperty> _props;
+ public GetMethodCtrl()
+ InitializeComponent();
+ _props = new BindingList<ComputedProperty>();
+ grdComputedProperties.DataSource = _props;
+ public void Init(RestSourceContext context)
+ _context = context;
+ numMaxCount.Minimum = 0;
+ numMaxCount.Maximum = Int32.MaxValue;
+ numPageSize.Minimum = 0;
+ numPageSize.Maximum = Int32.MaxValue;
+ numMaxCount.Value = 500;
+ numPageSize.Value = 100;
+ lstProperties.DataSource = context.GetPropertyNames();
+ public dynamic WriteOptions()
+ dynamic opts = new ExpandoObject();
+ if (chkPageSize.Checked)
+ opts.PageSize = Convert.ToInt32(numPageSize.Value);
+ if (chkMaxCount.Checked)
+ opts.MaxCount = Convert.ToInt32(numMaxCount.Value);
+ if (chkTransformTo.Checked)
+ opts.TransformTo = txtTransformTo.Text;
+ if (chkProperties.Checked)
+ opts.Properties = new List<string>(lstProperties.SelectedItems.Cast<object>().Select(o => o.ToString()));
+ if (chkComputedProperties.Checked)
+ opts.ComputedProperties = new ExpandoObject();
+ var dict = (IDictionary<string, object>)opts.ComputedProperties;
+ foreach (var prop in _props)
+ dict.Add(prop.Alias, prop.Expression);
+ return opts;
+ private void grdComputedProperties_SelectionChanged(object sender, EventArgs e)
+ btnEditExpression.Enabled = grdComputedProperties.SelectedRows.Count == 1;
+ private void btnEditExpression_Click(object sender, EventArgs e)
+ if (grdComputedProperties.SelectedRows.Count == 1)
+ var prop = grdComputedProperties.SelectedRows[0].DataBoundItem as ComputedProperty;
+ if (prop != null)
+ string expr = _context.EditExpression(prop.Expression);
+ if (expr != null)
+ prop.Expression = expr;
+ private void btnBrowseCs_Click(object sender, EventArgs e)
+ string code = _context.PickCoordinateSystemCode();
+ if (code != null)
+ txtTransformTo.Text = code;
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Methods/GetMethodCtrl.resx
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Methods/GetMethodCtrl.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Methods/GetMethodCtrl.resx 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,480 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="chkMaxCount.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="chkMaxCount.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 26</value>
+ </data>
+ <data name="chkMaxCount.Size" type="System.Drawing.Size, System.Drawing">
+ <value>77, 17</value>
+ </data>
+ <data name="chkMaxCount.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="chkMaxCount.Text" xml:space="preserve">
+ <value>Max Count</value>
+ </data>
+ <data name=">>chkMaxCount.Name" xml:space="preserve">
+ <value>chkMaxCount</value>
+ </data>
+ <data name=">>chkMaxCount.Type" xml:space="preserve">
+ <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>chkMaxCount.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>chkMaxCount.ZOrder" xml:space="preserve">
+ <value>10</value>
+ </data>
+ <data name="chkPageSize.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="chkPageSize.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 3</value>
+ </data>
+ <data name="chkPageSize.Size" type="System.Drawing.Size, System.Drawing">
+ <value>74, 17</value>
+ </data>
+ <data name="chkPageSize.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name="chkPageSize.Text" xml:space="preserve">
+ <value>Page Size</value>
+ </data>
+ <data name=">>chkPageSize.Name" xml:space="preserve">
+ <value>chkPageSize</value>
+ </data>
+ <data name=">>chkPageSize.Type" xml:space="preserve">
+ </data>
+ <data name=">>chkPageSize.Parent" xml:space="preserve">
+ </data>
+ <data name=">>chkPageSize.ZOrder" xml:space="preserve">
+ <value>9</value>
+ </data>
+ <data name="numPageSize.Location" type="System.Drawing.Point, System.Drawing">
+ <value>149, 0</value>
+ </data>
+ <data name="numPageSize.Size" type="System.Drawing.Size, System.Drawing">
+ <value>83, 20</value>
+ </data>
+ <data name="numPageSize.TabIndex" type="System.Int32, mscorlib">
+ <value>9</value>
+ </data>
+ <data name=">>numPageSize.Name" xml:space="preserve">
+ <value>numPageSize</value>
+ </data>
+ <data name=">>numPageSize.Type" xml:space="preserve">
+ <value>System.Windows.Forms.NumericUpDown, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>numPageSize.Parent" xml:space="preserve">
+ </data>
+ <data name=">>numPageSize.ZOrder" xml:space="preserve">
+ <value>8</value>
+ </data>
+ <data name="numMaxCount.Location" type="System.Drawing.Point, System.Drawing">
+ <value>149, 23</value>
+ </data>
+ <data name="numMaxCount.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="numMaxCount.TabIndex" type="System.Int32, mscorlib">
+ <value>10</value>
+ </data>
+ <data name=">>numMaxCount.Name" xml:space="preserve">
+ <value>numMaxCount</value>
+ </data>
+ <data name=">>numMaxCount.Type" xml:space="preserve">
+ </data>
+ <data name=">>numMaxCount.Parent" xml:space="preserve">
+ </data>
+ <data name=">>numMaxCount.ZOrder" xml:space="preserve">
+ <value>7</value>
+ </data>
+ <data name="chkTransformTo.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="chkTransformTo.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 50</value>
+ </data>
+ <data name="chkTransformTo.Size" type="System.Drawing.Size, System.Drawing">
+ <value>133, 17</value>
+ </data>
+ <data name="chkTransformTo.TabIndex" type="System.Int32, mscorlib">
+ <value>11</value>
+ </data>
+ <data name="chkTransformTo.Text" xml:space="preserve">
+ <value>Transform Features To</value>
+ </data>
+ <data name=">>chkTransformTo.Name" xml:space="preserve">
+ <value>chkTransformTo</value>
+ </data>
+ <data name=">>chkTransformTo.Type" xml:space="preserve">
+ </data>
+ <data name=">>chkTransformTo.Parent" xml:space="preserve">
+ </data>
+ <data name=">>chkTransformTo.ZOrder" xml:space="preserve">
+ <value>6</value>
+ </data>
+ <data name="txtTransformTo.Location" type="System.Drawing.Point, System.Drawing">
+ <value>149, 48</value>
+ </data>
+ <data name="txtTransformTo.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="txtTransformTo.TabIndex" type="System.Int32, mscorlib">
+ <value>12</value>
+ </data>
+ <data name=">>txtTransformTo.Name" xml:space="preserve">
+ <value>txtTransformTo</value>
+ </data>
+ <data name=">>txtTransformTo.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>txtTransformTo.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtTransformTo.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name="btnBrowseCs.Location" type="System.Drawing.Point, System.Drawing">
+ <value>238, 46</value>
+ </data>
+ <data name="btnBrowseCs.Size" type="System.Drawing.Size, System.Drawing">
+ <value>27, 23</value>
+ </data>
+ <data name="btnBrowseCs.TabIndex" type="System.Int32, mscorlib">
+ <value>13</value>
+ </data>
+ <data name="btnBrowseCs.Text" xml:space="preserve">
+ <value>...</value>
+ </data>
+ <data name=">>btnBrowseCs.Name" xml:space="preserve">
+ <value>btnBrowseCs</value>
+ </data>
+ <data name=">>btnBrowseCs.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnBrowseCs.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnBrowseCs.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="chkComputedProperties.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="chkComputedProperties.Location" type="System.Drawing.Point, System.Drawing">
+ <value>288, 3</value>
+ </data>
+ <data name="chkComputedProperties.Size" type="System.Drawing.Size, System.Drawing">
+ <value>124, 17</value>
+ </data>
+ <data name="chkComputedProperties.TabIndex" type="System.Int32, mscorlib">
+ <value>14</value>
+ </data>
+ <data name="chkComputedProperties.Text" xml:space="preserve">
+ <value>Computed Properties</value>
+ </data>
+ <data name=">>chkComputedProperties.Name" xml:space="preserve">
+ <value>chkComputedProperties</value>
+ </data>
+ <data name=">>chkComputedProperties.Type" xml:space="preserve">
+ </data>
+ <data name=">>chkComputedProperties.Parent" xml:space="preserve">
+ </data>
+ <data name=">>chkComputedProperties.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="grdComputedProperties.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ <value>Fill</value>
+ </data>
+ <data name="grdComputedProperties.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 25</value>
+ </data>
+ <data name="grdComputedProperties.Size" type="System.Drawing.Size, System.Drawing">
+ <value>256, 179</value>
+ </data>
+ <data name="grdComputedProperties.TabIndex" type="System.Int32, mscorlib">
+ <value>15</value>
+ </data>
+ <data name=">>grdComputedProperties.Name" xml:space="preserve">
+ <value>grdComputedProperties</value>
+ </data>
+ <data name=">>grdComputedProperties.Type" xml:space="preserve">
+ <value>System.Windows.Forms.DataGridView, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>grdComputedProperties.Parent" xml:space="preserve">
+ <value>panel1</value>
+ </data>
+ <data name=">>grdComputedProperties.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="lstProperties.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 96</value>
+ </data>
+ <data name="lstProperties.Size" type="System.Drawing.Size, System.Drawing">
+ <value>262, 134</value>
+ </data>
+ <data name="lstProperties.TabIndex" type="System.Int32, mscorlib">
+ <value>17</value>
+ </data>
+ <data name=">>lstProperties.Name" xml:space="preserve">
+ <value>lstProperties</value>
+ </data>
+ <data name=">>lstProperties.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ListBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>lstProperties.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lstProperties.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="chkProperties.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="chkProperties.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 73</value>
+ </data>
+ <data name="chkProperties.Size" type="System.Drawing.Size, System.Drawing">
+ <value>73, 17</value>
+ </data>
+ <data name="chkProperties.TabIndex" type="System.Int32, mscorlib">
+ <value>16</value>
+ </data>
+ <data name="chkProperties.Text" xml:space="preserve">
+ <value>Properties</value>
+ </data>
+ <data name=">>chkProperties.Name" xml:space="preserve">
+ <value>chkProperties</value>
+ </data>
+ <data name=">>chkProperties.Type" xml:space="preserve">
+ </data>
+ <data name=">>chkProperties.Parent" xml:space="preserve">
+ </data>
+ <data name=">>chkProperties.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+ <data name="btnEditExpression.Enabled" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <data name="btnEditExpression.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAACSSURBVDhPYxgFmICRkbERiNfgwI1QZXgBJ1BhDxCvB7J1
+ IEJgoAMVIwqADJkAxFuAbD2IEBjoQmmiABfQgClAvBPI1ocIkQYMgJr3A/EMIJsLIkQ8MAJqPArEc4Fs
+ ZM1GUBovMAFqPAPEi4FsZM1gcSgbJ+AEYlBIP8SBNwAxXu+ADBAGYikcWBSISQ6PQQ0YGADEYBhjFBYm
+ UAAAAABJRU5ErkJggg==
+</value>
+ </data>
+ <data name="btnEditExpression.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ <value>Magenta</value>
+ </data>
+ <data name="btnEditExpression.Size" type="System.Drawing.Size, System.Drawing">
+ <value>105, 22</value>
+ </data>
+ <data name="btnEditExpression.Text" xml:space="preserve">
+ <value>Edit Expression</value>
+ </data>
+ <data name="toolStrip1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 0</value>
+ </data>
+ <data name="toolStrip1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>256, 25</value>
+ </data>
+ <data name="toolStrip1.TabIndex" type="System.Int32, mscorlib">
+ <value>16</value>
+ </data>
+ <data name="toolStrip1.Text" xml:space="preserve">
+ <value>toolStrip1</value>
+ </data>
+ <data name=">>toolStrip1.Name" xml:space="preserve">
+ </data>
+ <data name=">>toolStrip1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>toolStrip1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>toolStrip1.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="panel1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>288, 26</value>
+ </data>
+ <data name="panel1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>256, 204</value>
+ </data>
+ <data name="panel1.TabIndex" type="System.Int32, mscorlib">
+ <value>18</value>
+ </data>
+ <data name=">>panel1.Name" xml:space="preserve">
+ </data>
+ <data name=">>panel1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>panel1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>panel1.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ </metadata>
+ <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
+ <value>6, 13</value>
+ </data>
+ <data name="$this.Size" type="System.Drawing.Size, System.Drawing">
+ <value>547, 236</value>
+ </data>
+ <data name=">>btnEditExpression.Name" xml:space="preserve">
+ <value>btnEditExpression</value>
+ </data>
+ <data name=">>btnEditExpression.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>GetMethodCtrl</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.UserControl, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/NewRepresentationDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/NewRepresentationDialog.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/NewRepresentationDialog.Designer.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,92 @@
+ partial class NewRepresentationDialog
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// </summary>
+ this.btnSave = new System.Windows.Forms.Button();
+ this.btnCancel = new System.Windows.Forms.Button();
+ this.panelSettings = new System.Windows.Forms.Panel();
+ // btnSave
+ this.btnSave.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnSave.Location = new System.Drawing.Point(439, 507);
+ this.btnSave.Name = "btnSave";
+ this.btnSave.Size = new System.Drawing.Size(75, 23);
+ this.btnSave.TabIndex = 1;
+ this.btnSave.Text = "Save";
+ this.btnSave.UseVisualStyleBackColor = true;
+ this.btnSave.Click += new System.EventHandler(this.btnSave_Click);
+ // btnCancel
+ this.btnCancel.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ this.btnCancel.Location = new System.Drawing.Point(520, 507);
+ this.btnCancel.Name = "btnCancel";
+ this.btnCancel.Size = new System.Drawing.Size(75, 23);
+ this.btnCancel.TabIndex = 2;
+ this.btnCancel.Text = "Cancel";
+ this.btnCancel.UseVisualStyleBackColor = true;
+ this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+ // panelSettings
+ this.panelSettings.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
+ | System.Windows.Forms.AnchorStyles.Left)
+ | System.Windows.Forms.AnchorStyles.Right)));
+ this.panelSettings.Location = new System.Drawing.Point(13, 13);
+ this.panelSettings.Name = "panelSettings";
+ this.panelSettings.Size = new System.Drawing.Size(582, 488);
+ this.panelSettings.TabIndex = 3;
+ // NewRepresentationDialog
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.CancelButton = this.btnCancel;
+ this.ClientSize = new System.Drawing.Size(607, 542);
+ this.ControlBox = false;
+ this.Controls.Add(this.panelSettings);
+ this.Controls.Add(this.btnCancel);
+ this.Controls.Add(this.btnSave);
+ this.Name = "NewRepresentationDialog";
+ this.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent;
+ this.Text = "New Representation";
+ #endregion
+ private System.Windows.Forms.Button btnSave;
+ private System.Windows.Forms.Button btnCancel;
+ private System.Windows.Forms.Panel panelSettings;
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/NewRepresentationDialog.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/NewRepresentationDialog.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/NewRepresentationDialog.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,99 @@
+using Maestro.AddIn.Rest.UI.Representation;
+using System;
+using System.Data;
+using System.Linq;
+using System.Text;
+ public partial class NewRepresentationDialog : Form
+ private NewRepresentationDialog()
+ private string _rep;
+ private IRepresentationCtrl _ctrl;
+ private dynamic _config;
+ public NewRepresentationDialog(string rep, dynamic config, RestSourceContext context)
+ : this()
+ _config = config;
+ _rep = rep;
+ switch(rep)
+ case "xml":
+ case "geojson":
+ _ctrl = new CruddableRepresentationCtrl(rep, context);
+ break;
+ case "csv":
+ _ctrl = new CsvRepresentationCtrl(context);
+ break;
+ case "image":
+ _ctrl = new ImageRepresentationCtrl(context);
+ break;
+ case "template":
+ _ctrl = new TemplateRepresentationCtrl(context);
+ break;
+ if (_ctrl != null)
+ _ctrl.Dock = DockStyle.Fill;
+ panelSettings.Controls.Add((Control)_ctrl);
+ private void btnCancel_Click(object sender, EventArgs e)
+ this.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ private void btnSave_Click(object sender, EventArgs e)
+ dynamic repr = null;
+ if (!((IDictionary<string, object>)_config).ContainsKey("Representations"))
+ _config.Representation = new ExpandoObject();
+ repr = _config.Representation;
+ dynamic conf = _ctrl.GetOptions();
+ ((IDictionary<string, object>)repr)[_rep] = conf;
+ this.DialogResult = System.Windows.Forms.DialogResult.OK;
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/NewRepresentationDialog.resx
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/NewRepresentationDialog.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/NewRepresentationDialog.resx 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,120 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+</root>
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CruddableRepresentationCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CruddableRepresentationCtrl.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CruddableRepresentationCtrl.Designer.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,245 @@
+namespace Maestro.AddIn.Rest.UI.Representation
+ partial class CruddableRepresentationCtrl
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(CruddableRepresentationCtrl));
+ this.chkGet = new System.Windows.Forms.CheckBox();
+ this.chkPost = new System.Windows.Forms.CheckBox();
+ this.chkPut = new System.Windows.Forms.CheckBox();
+ this.chkDelete = new System.Windows.Forms.CheckBox();
+ this.label1 = new System.Windows.Forms.Label();
+ this.tabs = new System.Windows.Forms.TabControl();
+ this.TAB_GET = new System.Windows.Forms.TabPage();
+ this.grpGetPerms = new System.Windows.Forms.GroupBox();
+ this.getPermsCtrl = new Maestro.AddIn.Rest.UI.Representation.PermissionsCtrl();
+ this.groupBox1 = new System.Windows.Forms.GroupBox();
+ this.getMethodCtrl1 = new Maestro.AddIn.Rest.UI.Methods.GetMethodCtrl();
+ this.TAB_POST = new System.Windows.Forms.TabPage();
+ this.grpPostPerms = new System.Windows.Forms.GroupBox();
+ this.postPermsCtrl = new Maestro.AddIn.Rest.UI.Representation.PermissionsCtrl();
+ this.TAB_PUT = new System.Windows.Forms.TabPage();
+ this.grpPutPerms = new System.Windows.Forms.GroupBox();
+ this.putPermsCtrl = new Maestro.AddIn.Rest.UI.Representation.PermissionsCtrl();
+ this.TAB_DELETE = new System.Windows.Forms.TabPage();
+ this.grpDeletePerms = new System.Windows.Forms.GroupBox();
+ this.deletePermsCtrl = new Maestro.AddIn.Rest.UI.Representation.PermissionsCtrl();
+ this.tabs.SuspendLayout();
+ this.TAB_GET.SuspendLayout();
+ this.grpGetPerms.SuspendLayout();
+ this.groupBox1.SuspendLayout();
+ this.TAB_POST.SuspendLayout();
+ this.grpPostPerms.SuspendLayout();
+ this.TAB_PUT.SuspendLayout();
+ this.grpPutPerms.SuspendLayout();
+ this.TAB_DELETE.SuspendLayout();
+ this.grpDeletePerms.SuspendLayout();
+ // chkGet
+ resources.ApplyResources(this.chkGet, "chkGet");
+ this.chkGet.Name = "chkGet";
+ this.chkGet.UseVisualStyleBackColor = true;
+ this.chkGet.CheckedChanged += new System.EventHandler(this.chkGet_CheckedChanged);
+ // chkPost
+ resources.ApplyResources(this.chkPost, "chkPost");
+ this.chkPost.Name = "chkPost";
+ this.chkPost.UseVisualStyleBackColor = true;
+ this.chkPost.CheckedChanged += new System.EventHandler(this.chkPost_CheckedChanged);
+ // chkPut
+ resources.ApplyResources(this.chkPut, "chkPut");
+ this.chkPut.Name = "chkPut";
+ this.chkPut.UseVisualStyleBackColor = true;
+ this.chkPut.CheckedChanged += new System.EventHandler(this.chkPut_CheckedChanged);
+ // chkDelete
+ resources.ApplyResources(this.chkDelete, "chkDelete");
+ this.chkDelete.Name = "chkDelete";
+ this.chkDelete.UseVisualStyleBackColor = true;
+ this.chkDelete.CheckedChanged += new System.EventHandler(this.chkDelete_CheckedChanged);
+ // label1
+ resources.ApplyResources(this.label1, "label1");
+ this.label1.Name = "label1";
+ // tabs
+ resources.ApplyResources(this.tabs, "tabs");
+ this.tabs.Controls.Add(this.TAB_GET);
+ this.tabs.Controls.Add(this.TAB_POST);
+ this.tabs.Controls.Add(this.TAB_PUT);
+ this.tabs.Controls.Add(this.TAB_DELETE);
+ this.tabs.Name = "tabs";
+ this.tabs.SelectedIndex = 0;
+ // TAB_GET
+ this.TAB_GET.Controls.Add(this.grpGetPerms);
+ this.TAB_GET.Controls.Add(this.groupBox1);
+ resources.ApplyResources(this.TAB_GET, "TAB_GET");
+ this.TAB_GET.Name = "TAB_GET";
+ this.TAB_GET.UseVisualStyleBackColor = true;
+ // grpGetPerms
+ this.grpGetPerms.Controls.Add(this.getPermsCtrl);
+ resources.ApplyResources(this.grpGetPerms, "grpGetPerms");
+ this.grpGetPerms.Name = "grpGetPerms";
+ this.grpGetPerms.TabStop = false;
+ // getPermsCtrl
+ resources.ApplyResources(this.getPermsCtrl, "getPermsCtrl");
+ this.getPermsCtrl.Name = "getPermsCtrl";
+ // groupBox1
+ this.groupBox1.Controls.Add(this.getMethodCtrl1);
+ resources.ApplyResources(this.groupBox1, "groupBox1");
+ this.groupBox1.Name = "groupBox1";
+ this.groupBox1.TabStop = false;
+ // getMethodCtrl1
+ resources.ApplyResources(this.getMethodCtrl1, "getMethodCtrl1");
+ this.getMethodCtrl1.Name = "getMethodCtrl1";
+ // TAB_POST
+ this.TAB_POST.Controls.Add(this.grpPostPerms);
+ resources.ApplyResources(this.TAB_POST, "TAB_POST");
+ this.TAB_POST.Name = "TAB_POST";
+ this.TAB_POST.UseVisualStyleBackColor = true;
+ // grpPostPerms
+ this.grpPostPerms.Controls.Add(this.postPermsCtrl);
+ resources.ApplyResources(this.grpPostPerms, "grpPostPerms");
+ this.grpPostPerms.Name = "grpPostPerms";
+ this.grpPostPerms.TabStop = false;
+ // postPermsCtrl
+ resources.ApplyResources(this.postPermsCtrl, "postPermsCtrl");
+ this.postPermsCtrl.Name = "postPermsCtrl";
+ // TAB_PUT
+ this.TAB_PUT.Controls.Add(this.grpPutPerms);
+ resources.ApplyResources(this.TAB_PUT, "TAB_PUT");
+ this.TAB_PUT.Name = "TAB_PUT";
+ this.TAB_PUT.UseVisualStyleBackColor = true;
+ // grpPutPerms
+ this.grpPutPerms.Controls.Add(this.putPermsCtrl);
+ resources.ApplyResources(this.grpPutPerms, "grpPutPerms");
+ this.grpPutPerms.Name = "grpPutPerms";
+ this.grpPutPerms.TabStop = false;
+ // putPermsCtrl
+ resources.ApplyResources(this.putPermsCtrl, "putPermsCtrl");
+ this.putPermsCtrl.Name = "putPermsCtrl";
+ // TAB_DELETE
+ this.TAB_DELETE.Controls.Add(this.grpDeletePerms);
+ resources.ApplyResources(this.TAB_DELETE, "TAB_DELETE");
+ this.TAB_DELETE.Name = "TAB_DELETE";
+ this.TAB_DELETE.UseVisualStyleBackColor = true;
+ // grpDeletePerms
+ this.grpDeletePerms.Controls.Add(this.deletePermsCtrl);
+ resources.ApplyResources(this.grpDeletePerms, "grpDeletePerms");
+ this.grpDeletePerms.Name = "grpDeletePerms";
+ this.grpDeletePerms.TabStop = false;
+ // deletePermsCtrl
+ resources.ApplyResources(this.deletePermsCtrl, "deletePermsCtrl");
+ this.deletePermsCtrl.Name = "deletePermsCtrl";
+ // CruddableRepresentationCtrl
+ this.Controls.Add(this.tabs);
+ this.Controls.Add(this.label1);
+ this.Controls.Add(this.chkDelete);
+ this.Controls.Add(this.chkPut);
+ this.Controls.Add(this.chkPost);
+ this.Controls.Add(this.chkGet);
+ this.Name = "CruddableRepresentationCtrl";
+ this.tabs.ResumeLayout(false);
+ this.TAB_GET.ResumeLayout(false);
+ this.grpGetPerms.ResumeLayout(false);
+ this.groupBox1.ResumeLayout(false);
+ this.TAB_POST.ResumeLayout(false);
+ this.grpPostPerms.ResumeLayout(false);
+ this.TAB_PUT.ResumeLayout(false);
+ this.grpPutPerms.ResumeLayout(false);
+ this.TAB_DELETE.ResumeLayout(false);
+ this.grpDeletePerms.ResumeLayout(false);
+ #endregion
+ private System.Windows.Forms.CheckBox chkGet;
+ private System.Windows.Forms.CheckBox chkPost;
+ private System.Windows.Forms.CheckBox chkPut;
+ private System.Windows.Forms.CheckBox chkDelete;
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.TabControl tabs;
+ private System.Windows.Forms.TabPage TAB_GET;
+ private Methods.GetMethodCtrl getMethodCtrl1;
+ private System.Windows.Forms.TabPage TAB_POST;
+ private System.Windows.Forms.TabPage TAB_PUT;
+ private System.Windows.Forms.TabPage TAB_DELETE;
+ private System.Windows.Forms.GroupBox grpGetPerms;
+ private System.Windows.Forms.GroupBox groupBox1;
+ private PermissionsCtrl getPermsCtrl;
+ private System.Windows.Forms.GroupBox grpPostPerms;
+ private PermissionsCtrl postPermsCtrl;
+ private System.Windows.Forms.GroupBox grpPutPerms;
+ private PermissionsCtrl putPermsCtrl;
+ private System.Windows.Forms.GroupBox grpDeletePerms;
+ private PermissionsCtrl deletePermsCtrl;
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CruddableRepresentationCtrl.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CruddableRepresentationCtrl.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CruddableRepresentationCtrl.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,130 @@
+#region Disclaimer / License
+// Copyright (C) 2015, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion Disclaimer / License
+using System;
+using System.Collections.Generic;
+using System.Data;
+using System.Linq;
+using System.Text;
+using System.Threading.Tasks;
+using System.Windows.Forms;
+ internal partial class CruddableRepresentationCtrl : UserControl, IRepresentationCtrl
+ private string _type;
+ public CruddableRepresentationCtrl(string type, RestSourceContext context)
+ getMethodCtrl1.Init(context);
+ getPermsCtrl.Init(context);
+ postPermsCtrl.Init(context);
+ putPermsCtrl.Init(context);
+ deletePermsCtrl.Init(context);
+ this.CheckStates();
+ switch(type.ToLower())
+ case "xml":
+ _type = "FeatureSetXml";
+ break;
+ case "geojson":
+ _type = "FeatureSetGeoJson";
+ break;
+ public dynamic GetOptions()
+ opts.Adapter = _type;
+ opts.Methods = new ExpandoObject();
+ if (chkGet.Checked)
+ var getOpts = getMethodCtrl1.WriteOptions();
+ getPermsCtrl.UpdateConfiguration(getOpts);
+ opts.Methods.GET = getOpts;
+ if (chkPost.Checked)
+ var postOpts = new ExpandoObject();
+ postPermsCtrl.UpdateConfiguration(postOpts);
+ opts.Methods.POST = postOpts;
+ if (chkPut.Checked)
+ var putOpts = new ExpandoObject();
+ putPermsCtrl.UpdateConfiguration(putOpts);
+ opts.Methods.PUT = putOpts;
+ if (chkDelete.Checked)
+ var deleteOpts = new ExpandoObject();
+ deletePermsCtrl.UpdateConfiguration(deleteOpts);
+ opts.Methods.DELETE = deleteOpts;
+ return opts;
+ private void CheckStates()
+ tabs.TabPages.Clear();
+ tabs.TabPages.Add(TAB_GET);
+ tabs.TabPages.Add(TAB_POST);
+ tabs.TabPages.Add(TAB_PUT);
+ tabs.TabPages.Add(TAB_DELETE);
+ private void chkGet_CheckedChanged(object sender, EventArgs e)
+ private void chkPost_CheckedChanged(object sender, EventArgs e)
+ private void chkPut_CheckedChanged(object sender, EventArgs e)
+ private void chkDelete_CheckedChanged(object sender, EventArgs e)
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CruddableRepresentationCtrl.resx
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CruddableRepresentationCtrl.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CruddableRepresentationCtrl.resx 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,819 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <data name="chkGet.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="chkGet.Location" type="System.Drawing.Point, System.Drawing">
+ <value>104, 9</value>
+ </data>
+ <data name="chkGet.Size" type="System.Drawing.Size, System.Drawing">
+ <value>48, 17</value>
+ </data>
+ <data name="chkGet.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="chkGet.Text" xml:space="preserve">
+ <value>GET</value>
+ </data>
+ <data name=">>chkGet.Name" xml:space="preserve">
+ <value>chkGet</value>
+ </data>
+ <data name=">>chkGet.Type" xml:space="preserve">
+ </data>
+ <data name=">>chkGet.Parent" xml:space="preserve">
+ </data>
+ <data name=">>chkGet.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name="chkPost.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="chkPost.Location" type="System.Drawing.Point, System.Drawing">
+ <value>158, 9</value>
+ </data>
+ <data name="chkPost.Size" type="System.Drawing.Size, System.Drawing">
+ <value>55, 17</value>
+ </data>
+ <data name="chkPost.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="chkPost.Text" xml:space="preserve">
+ <value>POST</value>
+ </data>
+ <data name=">>chkPost.Name" xml:space="preserve">
+ <value>chkPost</value>
+ </data>
+ <data name=">>chkPost.Type" xml:space="preserve">
+ </data>
+ <data name=">>chkPost.Parent" xml:space="preserve">
+ </data>
+ <data name=">>chkPost.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="chkPut.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="chkPut.Location" type="System.Drawing.Point, System.Drawing">
+ <value>219, 9</value>
+ </data>
+ <data name="chkPut.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="chkPut.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="chkPut.Text" xml:space="preserve">
+ <value>PUT</value>
+ </data>
+ <data name=">>chkPut.Name" xml:space="preserve">
+ <value>chkPut</value>
+ </data>
+ <data name=">>chkPut.Type" xml:space="preserve">
+ </data>
+ <data name=">>chkPut.Parent" xml:space="preserve">
+ </data>
+ <data name=">>chkPut.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="chkDelete.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="chkDelete.Location" type="System.Drawing.Point, System.Drawing">
+ <value>273, 9</value>
+ </data>
+ <data name="chkDelete.Size" type="System.Drawing.Size, System.Drawing">
+ <value>68, 17</value>
+ </data>
+ <data name="chkDelete.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="chkDelete.Text" xml:space="preserve">
+ <value>DELETE</value>
+ </data>
+ <data name=">>chkDelete.Name" xml:space="preserve">
+ <value>chkDelete</value>
+ </data>
+ <data name=">>chkDelete.Type" xml:space="preserve">
+ </data>
+ <data name=">>chkDelete.Parent" xml:space="preserve">
+ </data>
+ <data name=">>chkDelete.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="label1.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 10</value>
+ </data>
+ <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>84, 13</value>
+ </data>
+ <data name="label1.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name="label1.Text" xml:space="preserve">
+ <value>Enable Methods</value>
+ </data>
+ <data name=">>label1.Name" xml:space="preserve">
+ <value>label1</value>
+ </data>
+ <data name=">>label1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>label1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label1.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="tabs.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Bottom, Left, Right</value>
+ </data>
+ <data name=">>TAB_GET.Name" xml:space="preserve">
+ <value>TAB_GET</value>
+ </data>
+ <data name=">>TAB_GET.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TabPage, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>TAB_GET.Parent" xml:space="preserve">
+ <value>tabs</value>
+ </data>
+ <data name=">>TAB_GET.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>TAB_POST.Name" xml:space="preserve">
+ <value>TAB_POST</value>
+ </data>
+ <data name=">>TAB_POST.Type" xml:space="preserve">
+ </data>
+ <data name=">>TAB_POST.Parent" xml:space="preserve">
+ </data>
+ <data name=">>TAB_POST.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name=">>TAB_PUT.Name" xml:space="preserve">
+ <value>TAB_PUT</value>
+ </data>
+ <data name=">>TAB_PUT.Type" xml:space="preserve">
+ </data>
+ <data name=">>TAB_PUT.Parent" xml:space="preserve">
+ </data>
+ <data name=">>TAB_PUT.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name=">>TAB_DELETE.Name" xml:space="preserve">
+ <value>TAB_DELETE</value>
+ </data>
+ <data name=">>TAB_DELETE.Type" xml:space="preserve">
+ </data>
+ <data name=">>TAB_DELETE.Parent" xml:space="preserve">
+ </data>
+ <data name=">>TAB_DELETE.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="tabs.Location" type="System.Drawing.Point, System.Drawing">
+ <value>6, 35</value>
+ </data>
+ <data name="tabs.Size" type="System.Drawing.Size, System.Drawing">
+ <value>603, 485</value>
+ </data>
+ <data name="tabs.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name=">>tabs.Name" xml:space="preserve">
+ </data>
+ <data name=">>tabs.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TabControl, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>tabs.Parent" xml:space="preserve">
+ </data>
+ <data name=">>tabs.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>grpGetPerms.Name" xml:space="preserve">
+ <value>grpGetPerms</value>
+ </data>
+ <data name=">>grpGetPerms.Type" xml:space="preserve">
+ <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>grpGetPerms.Parent" xml:space="preserve">
+ </data>
+ <data name=">>grpGetPerms.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>groupBox1.Name" xml:space="preserve">
+ <value>groupBox1</value>
+ </data>
+ <data name=">>groupBox1.Type" xml:space="preserve">
+ </data>
+ <data name=">>groupBox1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>groupBox1.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="TAB_GET.Location" type="System.Drawing.Point, System.Drawing">
+ <value>4, 22</value>
+ </data>
+ <data name="TAB_GET.Padding" type="System.Windows.Forms.Padding, System.Windows.Forms">
+ <value>3, 3, 3, 3</value>
+ </data>
+ <data name="TAB_GET.Size" type="System.Drawing.Size, System.Drawing">
+ <value>595, 459</value>
+ </data>
+ <data name="TAB_GET.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="TAB_GET.Text" xml:space="preserve">
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
+ <data name=">>getPermsCtrl.Name" xml:space="preserve">
+ <value>getPermsCtrl</value>
+ </data>
+ <data name=">>getPermsCtrl.Type" xml:space="preserve">
+ <value>Maestro.AddIn.Rest.UI.Representation.PermissionsCtrl, Maestro.AddIn.Rest, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null</value>
+ </data>
+ <data name=">>getPermsCtrl.Parent" xml:space="preserve">
+ </data>
+ <data name=">>getPermsCtrl.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="grpGetPerms.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="grpGetPerms.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 268</value>
+ </data>
+ <data name="grpGetPerms.Size" type="System.Drawing.Size, System.Drawing">
+ <value>589, 188</value>
+ </data>
+ <data name="grpGetPerms.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="grpGetPerms.Text" xml:space="preserve">
+ <value>Permissions</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
+ <data name="getPermsCtrl.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="getPermsCtrl.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 16</value>
+ </data>
+ <data name="getPermsCtrl.Size" type="System.Drawing.Size, System.Drawing">
+ <value>583, 169</value>
+ </data>
+ <data name="getPermsCtrl.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
+ <data name=">>getMethodCtrl1.Name" xml:space="preserve">
+ <value>getMethodCtrl1</value>
+ </data>
+ <data name=">>getMethodCtrl1.Type" xml:space="preserve">
+ <value>Maestro.AddIn.Rest.UI.Methods.GetMethodCtrl, Maestro.AddIn.Rest, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null</value>
+ </data>
+ <data name=">>getMethodCtrl1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>getMethodCtrl1.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="groupBox1.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ <value>Top</value>
+ </data>
+ <data name="groupBox1.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="groupBox1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>589, 265</value>
+ </data>
+ <data name="groupBox1.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="groupBox1.Text" xml:space="preserve">
+ <value>Settings</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>1</value>
+ </data>
+ <data name="getMethodCtrl1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>6, 19</value>
+ </data>
+ <data name="getMethodCtrl1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>578, 262</value>
+ </data>
+ <data name="getMethodCtrl1.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
+ <data name=">>grpPostPerms.Name" xml:space="preserve">
+ <value>grpPostPerms</value>
+ </data>
+ <data name=">>grpPostPerms.Type" xml:space="preserve">
+ </data>
+ <data name=">>grpPostPerms.Parent" xml:space="preserve">
+ </data>
+ <data name=">>grpPostPerms.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="TAB_POST.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="TAB_POST.Padding" type="System.Windows.Forms.Padding, System.Windows.Forms">
+ </data>
+ <data name="TAB_POST.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="TAB_POST.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="TAB_POST.Text" xml:space="preserve">
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>1</value>
+ </data>
+ <data name=">>postPermsCtrl.Name" xml:space="preserve">
+ <value>postPermsCtrl</value>
+ </data>
+ <data name=">>postPermsCtrl.Type" xml:space="preserve">
+ </data>
+ <data name=">>postPermsCtrl.Parent" xml:space="preserve">
+ </data>
+ <data name=">>postPermsCtrl.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="grpPostPerms.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="grpPostPerms.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="grpPostPerms.Size" type="System.Drawing.Size, System.Drawing">
+ <value>589, 453</value>
+ </data>
+ <data name="grpPostPerms.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="grpPostPerms.Text" xml:space="preserve">
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
+ <data name="postPermsCtrl.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="postPermsCtrl.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="postPermsCtrl.Size" type="System.Drawing.Size, System.Drawing">
+ <value>583, 434</value>
+ </data>
+ <data name="postPermsCtrl.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
+ <data name=">>grpPutPerms.Name" xml:space="preserve">
+ <value>grpPutPerms</value>
+ </data>
+ <data name=">>grpPutPerms.Type" xml:space="preserve">
+ </data>
+ <data name=">>grpPutPerms.Parent" xml:space="preserve">
+ </data>
+ <data name=">>grpPutPerms.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="TAB_PUT.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="TAB_PUT.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="TAB_PUT.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="TAB_PUT.Text" xml:space="preserve">
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>2</value>
+ </data>
+ <data name=">>putPermsCtrl.Name" xml:space="preserve">
+ <value>putPermsCtrl</value>
+ </data>
+ <data name=">>putPermsCtrl.Type" xml:space="preserve">
+ </data>
+ <data name=">>putPermsCtrl.Parent" xml:space="preserve">
+ </data>
+ <data name=">>putPermsCtrl.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="grpPutPerms.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="grpPutPerms.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="grpPutPerms.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="grpPutPerms.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="grpPutPerms.Text" xml:space="preserve">
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
+ <data name="putPermsCtrl.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="putPermsCtrl.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="putPermsCtrl.Size" type="System.Drawing.Size, System.Drawing">
+ <value>589, 440</value>
+ </data>
+ <data name="putPermsCtrl.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
+ <data name=">>grpDeletePerms.Name" xml:space="preserve">
+ <value>grpDeletePerms</value>
+ </data>
+ <data name=">>grpDeletePerms.Type" xml:space="preserve">
+ </data>
+ <data name=">>grpDeletePerms.Parent" xml:space="preserve">
+ </data>
+ <data name=">>grpDeletePerms.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="TAB_DELETE.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="TAB_DELETE.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="TAB_DELETE.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="TAB_DELETE.Text" xml:space="preserve">
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>3</value>
+ </data>
+ <data name=">>deletePermsCtrl.Name" xml:space="preserve">
+ <value>deletePermsCtrl</value>
+ </data>
+ <data name=">>deletePermsCtrl.Type" xml:space="preserve">
+ </data>
+ <data name=">>deletePermsCtrl.Parent" xml:space="preserve">
+ </data>
+ <data name=">>deletePermsCtrl.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="grpDeletePerms.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="grpDeletePerms.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="grpDeletePerms.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="grpDeletePerms.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="grpDeletePerms.Text" xml:space="preserve">
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
+ <data name="deletePermsCtrl.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="deletePermsCtrl.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="deletePermsCtrl.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="deletePermsCtrl.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
+ </metadata>
+ </data>
+ <value>612, 523</value>
+ </data>
+ <value>CruddableRepresentationCtrl</value>
+ </data>
+ </data>
+</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CsvRepresentationCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CsvRepresentationCtrl.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CsvRepresentationCtrl.Designer.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,62 @@
+ partial class CsvRepresentationCtrl
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(CsvRepresentationCtrl));
+ this.permissionsCtrl1 = new Maestro.AddIn.Rest.UI.Representation.PermissionsCtrl();
+ // getMethodCtrl1
+ // permissionsCtrl1
+ resources.ApplyResources(this.permissionsCtrl1, "permissionsCtrl1");
+ this.permissionsCtrl1.Name = "permissionsCtrl1";
+ // CsvRepresentationCtrl
+ this.Controls.Add(this.permissionsCtrl1);
+ this.Controls.Add(this.getMethodCtrl1);
+ this.Name = "CsvRepresentationCtrl";
+ #endregion
+ private PermissionsCtrl permissionsCtrl1;
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CsvRepresentationCtrl.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CsvRepresentationCtrl.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CsvRepresentationCtrl.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,57 @@
+using System;
+using System.Data;
+using System.Linq;
+using System.Text;
+ internal partial class CsvRepresentationCtrl : UserControl, IRepresentationCtrl
+ public CsvRepresentationCtrl(RestSourceContext context)
+ permissionsCtrl1.Init(context);
+ opts.Adapter = "FeatureSetCsv"; //NOXLATE
+ dynamic getOpts = getMethodCtrl1.WriteOptions();
+ permissionsCtrl1.UpdateConfiguration(getOpts);
+ return opts;
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CsvRepresentationCtrl.resx
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CsvRepresentationCtrl.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/CsvRepresentationCtrl.resx 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,183 @@
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <data name="getMethodCtrl1.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>1</value>
+ </data>
+ <data name="permissionsCtrl1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 236</value>
+ </data>
+ <data name="permissionsCtrl1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>304, 153</value>
+ </data>
+ <data name="permissionsCtrl1.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>permissionsCtrl1.Name" xml:space="preserve">
+ <value>permissionsCtrl1</value>
+ </data>
+ <data name=">>permissionsCtrl1.Type" xml:space="preserve">
+ </data>
+ <data name=">>permissionsCtrl1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>permissionsCtrl1.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ </metadata>
+ </data>
+ <value>550, 393</value>
+ </data>
+ <value>CsvRepresentationCtrl</value>
+ </data>
+ </data>
+</root>
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/IRepresentationCtrl.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/IRepresentationCtrl.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/IRepresentationCtrl.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,37 @@
+using System;
+using System.Linq;
+using System.Text;
+ internal interface IRepresentationCtrl
+ dynamic GetOptions();
+ DockStyle Dock { get; set; }
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/ImageRepresentationCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/ImageRepresentationCtrl.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/ImageRepresentationCtrl.Designer.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,62 @@
+ partial class ImageRepresentationCtrl
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Component Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(ImageRepresentationCtrl));
+ this.SuspendLayout();
+ // getMethodCtrl1
+ // ImageRepresentationCtrl
+ resources.ApplyResources(this, "$this");
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.Name = "ImageRepresentationCtrl";
+ this.ResumeLayout(false);
+ #endregion
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/ImageRepresentationCtrl.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/ImageRepresentationCtrl.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/ImageRepresentationCtrl.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,58 @@
+using System;
+using System.ComponentModel;
+using System.Drawing;
+using System.Data;
+using System.Linq;
+using System.Text;
+using System.Dynamic;
+using Maestro.AddIn.Rest.Model;
+ internal partial class ImageRepresentationCtrl : UserControl, IRepresentationCtrl
+ public ImageRepresentationCtrl(RestSourceContext context)
+ opts.Adapter = "MapImage"; //NOXLATE
+ return opts;
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/ImageRepresentationCtrl.resx
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/ImageRepresentationCtrl.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/ImageRepresentationCtrl.resx 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,179 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ </data>
+ <value>306, 153</value>
+ </data>
+ <value>3</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
+ </data>
+ </data>
+ <value>2</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>1</value>
+ </data>
+ </metadata>
+ </data>
+ <value>554, 393</value>
+ </data>
+ <value>ImageRepresentationCtrl</value>
+ </data>
+ </data>
+</root>
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/PermissionsCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/PermissionsCtrl.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/PermissionsCtrl.Designer.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,92 @@
+ partial class PermissionsCtrl
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(PermissionsCtrl));
+ this.chkAllowRoles = new System.Windows.Forms.CheckBox();
+ this.lstAllowGroups = new System.Windows.Forms.ListBox();
+ this.chkAllowGroups = new System.Windows.Forms.CheckBox();
+ this.chkAllowAnonymous = new System.Windows.Forms.CheckBox();
+ this.txtRoles = new System.Windows.Forms.TextBox();
+ // chkAllowRoles
+ resources.ApplyResources(this.chkAllowRoles, "chkAllowRoles");
+ this.chkAllowRoles.Name = "chkAllowRoles";
+ this.chkAllowRoles.UseVisualStyleBackColor = true;
+ // lstAllowGroups
+ resources.ApplyResources(this.lstAllowGroups, "lstAllowGroups");
+ this.lstAllowGroups.FormattingEnabled = true;
+ this.lstAllowGroups.Name = "lstAllowGroups";
+ this.lstAllowGroups.SelectionMode = System.Windows.Forms.SelectionMode.MultiSimple;
+ // chkAllowGroups
+ resources.ApplyResources(this.chkAllowGroups, "chkAllowGroups");
+ this.chkAllowGroups.Name = "chkAllowGroups";
+ this.chkAllowGroups.UseVisualStyleBackColor = true;
+ // chkAllowAnonymous
+ resources.ApplyResources(this.chkAllowAnonymous, "chkAllowAnonymous");
+ this.chkAllowAnonymous.Name = "chkAllowAnonymous";
+ this.chkAllowAnonymous.UseVisualStyleBackColor = true;
+ // txtRoles
+ resources.ApplyResources(this.txtRoles, "txtRoles");
+ this.txtRoles.Name = "txtRoles";
+ // PermissionsCtrl
+ this.Controls.Add(this.txtRoles);
+ this.Controls.Add(this.chkAllowRoles);
+ this.Controls.Add(this.lstAllowGroups);
+ this.Controls.Add(this.chkAllowGroups);
+ this.Controls.Add(this.chkAllowAnonymous);
+ this.Name = "PermissionsCtrl";
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.CheckBox chkAllowRoles;
+ private System.Windows.Forms.ListBox lstAllowGroups;
+ private System.Windows.Forms.CheckBox chkAllowGroups;
+ private System.Windows.Forms.CheckBox chkAllowAnonymous;
+ private System.Windows.Forms.TextBox txtRoles;
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/PermissionsCtrl.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/PermissionsCtrl.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/PermissionsCtrl.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,59 @@
+using System;
+using System.Data;
+using System.Linq;
+using System.Text;
+ internal partial class PermissionsCtrl : UserControl
+ public PermissionsCtrl()
+ InitializeComponent();
+ public void Init(RestSourceContext context)
+ lstAllowGroups.DataSource = context.GetGroups();
+ public void UpdateConfiguration(dynamic methodConfig)
+ if (chkAllowAnonymous.Checked)
+ methodConfig.AllowAnonymous = true;
+ if (chkAllowGroups.Checked)
+ methodConfig.AllowGroups = new List<string>(lstAllowGroups.SelectedItems.Cast<object>().Select(o => o.ToString()));
+ if (chkAllowRoles.Checked)
+ methodConfig.AllowRoles = new List<string>(txtRoles.Lines);
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/PermissionsCtrl.resx
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/PermissionsCtrl.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/PermissionsCtrl.resx 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,270 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="chkAllowRoles.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="chkAllowRoles.Location" type="System.Drawing.Point, System.Drawing">
+ <value>129, 30</value>
+ </data>
+ <data name="chkAllowRoles.Size" type="System.Drawing.Size, System.Drawing">
+ <value>172, 17</value>
+ </data>
+ <data name="chkAllowRoles.TabIndex" type="System.Int32, mscorlib">
+ <value>12</value>
+ </data>
+ <data name="chkAllowRoles.Text" xml:space="preserve">
+ <value>Allow Roles (enter one per line)</value>
+ </data>
+ <data name=">>chkAllowRoles.Name" xml:space="preserve">
+ <value>chkAllowRoles</value>
+ </data>
+ <data name=">>chkAllowRoles.Type" xml:space="preserve">
+ <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>chkAllowRoles.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>chkAllowRoles.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="lstAllowGroups.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Bottom, Left</value>
+ </data>
+ <data name="lstAllowGroups.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 53</value>
+ </data>
+ <data name="lstAllowGroups.Size" type="System.Drawing.Size, System.Drawing">
+ <value>120, 95</value>
+ </data>
+ <data name="lstAllowGroups.TabIndex" type="System.Int32, mscorlib">
+ <value>11</value>
+ </data>
+ <data name=">>lstAllowGroups.Name" xml:space="preserve">
+ <value>lstAllowGroups</value>
+ </data>
+ <data name=">>lstAllowGroups.Type" xml:space="preserve">
+ </data>
+ <data name=">>lstAllowGroups.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lstAllowGroups.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="chkAllowGroups.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="chkAllowGroups.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 30</value>
+ </data>
+ <data name="chkAllowGroups.Size" type="System.Drawing.Size, System.Drawing">
+ <value>88, 17</value>
+ </data>
+ <data name="chkAllowGroups.TabIndex" type="System.Int32, mscorlib">
+ <value>10</value>
+ </data>
+ <data name="chkAllowGroups.Text" xml:space="preserve">
+ <value>Allow Groups</value>
+ </data>
+ <data name=">>chkAllowGroups.Name" xml:space="preserve">
+ <value>chkAllowGroups</value>
+ </data>
+ <data name=">>chkAllowGroups.Type" xml:space="preserve">
+ </data>
+ <data name=">>chkAllowGroups.Parent" xml:space="preserve">
+ </data>
+ <data name=">>chkAllowGroups.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="chkAllowAnonymous.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="chkAllowAnonymous.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 6</value>
+ </data>
+ <data name="chkAllowAnonymous.Size" type="System.Drawing.Size, System.Drawing">
+ <value>109, 17</value>
+ </data>
+ <data name="chkAllowAnonymous.TabIndex" type="System.Int32, mscorlib">
+ <value>9</value>
+ </data>
+ <data name="chkAllowAnonymous.Text" xml:space="preserve">
+ <value>Allow Anonymous</value>
+ </data>
+ <data name=">>chkAllowAnonymous.Name" xml:space="preserve">
+ <value>chkAllowAnonymous</value>
+ </data>
+ <data name=">>chkAllowAnonymous.Type" xml:space="preserve">
+ </data>
+ <data name=">>chkAllowAnonymous.Parent" xml:space="preserve">
+ </data>
+ <data name=">>chkAllowAnonymous.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="txtRoles.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="txtRoles.Location" type="System.Drawing.Point, System.Drawing">
+ <value>129, 53</value>
+ </data>
+ <data name="txtRoles.Multiline" type="System.Boolean, mscorlib">
+ </data>
+ <data name="txtRoles.Size" type="System.Drawing.Size, System.Drawing">
+ <value>171, 94</value>
+ </data>
+ <data name="txtRoles.TabIndex" type="System.Int32, mscorlib">
+ <value>13</value>
+ </data>
+ <data name=">>txtRoles.Name" xml:space="preserve">
+ <value>txtRoles</value>
+ </data>
+ <data name=">>txtRoles.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>txtRoles.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtRoles.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ </metadata>
+ </data>
+ <value>303, 153</value>
+ </data>
+ <value>PermissionsCtrl</value>
+ </data>
+ </data>
+</root>
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/TemplateRepresentationCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/TemplateRepresentationCtrl.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/TemplateRepresentationCtrl.Designer.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,62 @@
+ partial class TemplateRepresentationCtrl
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(TemplateRepresentationCtrl));
+ // getMethodCtrl1
+ // TemplateRepresentationCtrl
+ this.Name = "TemplateRepresentationCtrl";
+ #endregion
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/TemplateRepresentationCtrl.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/TemplateRepresentationCtrl.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/TemplateRepresentationCtrl.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,58 @@
+using System;
+using System.Data;
+using System.Linq;
+using System.Text;
+ internal partial class TemplateRepresentationCtrl : UserControl, IRepresentationCtrl
+ public TemplateRepresentationCtrl(RestSourceContext context)
+ dynamic opts = new ExpandoObject();
+ opts.Adapter = "Template"; //NOXLATE
+ return opts;
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/TemplateRepresentationCtrl.resx
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/TemplateRepresentationCtrl.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/Representation/TemplateRepresentationCtrl.resx 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,179 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ </data>
+ </data>
+ <value>5</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
+ <value>3, 3</value>
+ </data>
+ </data>
+ <value>4</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>1</value>
+ </data>
+ </metadata>
+ </data>
+ <value>551, 394</value>
+ </data>
+ <value>TemplateRepresentationCtrl</value>
+ </data>
+ </data>
+</root>
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestConfigurationEditor.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestConfigurationEditor.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestConfigurationEditor.Designer.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,257 @@
+ partial class RestConfigurationEditor
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(RestConfigurationEditor));
+ this.txtJson = new ICSharpCode.TextEditor.TextEditorControl();
+ this.txtUriPart = new System.Windows.Forms.TextBox();
+ this.toolStrip1 = new System.Windows.Forms.ToolStrip();
+ this.toolStripButton1 = new System.Windows.Forms.ToolStripDropDownButton();
+ this.featureSourceToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.layerDefinitionToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripButton2 = new System.Windows.Forms.ToolStripDropDownButton();
+ this.xMLToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.geoJSONToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.cSVToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.imageToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.templateToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.label2 = new System.Windows.Forms.Label();
+ this.label3 = new System.Windows.Forms.Label();
+ this.toolStrip1.SuspendLayout();
+ // txtJson
+ this.txtJson.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
+ this.txtJson.IsReadOnly = false;
+ this.txtJson.Location = new System.Drawing.Point(13, 63);
+ this.txtJson.Name = "txtJson";
+ this.txtJson.ShowSpaces = true;
+ this.txtJson.ShowTabs = true;
+ this.txtJson.Size = new System.Drawing.Size(695, 410);
+ this.txtJson.TabIndex = 0;
+ // btnSave
+ this.btnSave.Location = new System.Drawing.Point(552, 490);
+ // btnCancel
+ this.btnCancel.Location = new System.Drawing.Point(633, 490);
+ // label1
+ this.label1.AutoSize = true;
+ this.label1.Location = new System.Drawing.Point(14, 40);
+ this.label1.Size = new System.Drawing.Size(48, 13);
+ this.label1.TabIndex = 3;
+ this.label1.Text = "URI Part";
+ // txtUriPart
+ this.txtUriPart.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtUriPart.Location = new System.Drawing.Point(137, 37);
+ this.txtUriPart.Name = "txtUriPart";
+ this.txtUriPart.Size = new System.Drawing.Size(289, 20);
+ this.txtUriPart.TabIndex = 4;
+ // toolStrip1
+ this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.toolStripButton1,
+ this.toolStripButton2});
+ this.toolStrip1.Location = new System.Drawing.Point(0, 0);
+ this.toolStrip1.Name = "toolStrip1";
+ this.toolStrip1.Size = new System.Drawing.Size(720, 25);
+ this.toolStrip1.TabIndex = 5;
+ this.toolStrip1.Text = "toolStrip1";
+ // toolStripButton1
+ this.toolStripButton1.DropDownItems.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.featureSourceToolStripMenuItem,
+ this.layerDefinitionToolStripMenuItem});
+ this.toolStripButton1.Image = ((System.Drawing.Image)(resources.GetObject("toolStripButton1.Image")));
+ this.toolStripButton1.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton1.Name = "toolStripButton1";
+ this.toolStripButton1.Size = new System.Drawing.Size(91, 22);
+ this.toolStripButton1.Text = "Set Source";
+ // featureSourceToolStripMenuItem
+ this.featureSourceToolStripMenuItem.Image = ((System.Drawing.Image)(resources.GetObject("featureSourceToolStripMenuItem.Image")));
+ this.featureSourceToolStripMenuItem.Name = "featureSourceToolStripMenuItem";
+ this.featureSourceToolStripMenuItem.Size = new System.Drawing.Size(157, 22);
+ this.featureSourceToolStripMenuItem.Text = "Feature Source";
+ this.featureSourceToolStripMenuItem.Click += new System.EventHandler(this.featureSourceToolStripMenuItem_Click);
+ // layerDefinitionToolStripMenuItem
+ this.layerDefinitionToolStripMenuItem.Image = ((System.Drawing.Image)(resources.GetObject("layerDefinitionToolStripMenuItem.Image")));
+ this.layerDefinitionToolStripMenuItem.Name = "layerDefinitionToolStripMenuItem";
+ this.layerDefinitionToolStripMenuItem.Size = new System.Drawing.Size(157, 22);
+ this.layerDefinitionToolStripMenuItem.Text = "Layer Definition";
+ this.layerDefinitionToolStripMenuItem.Click += new System.EventHandler(this.layerDefinitionToolStripMenuItem_Click);
+ // toolStripButton2
+ this.toolStripButton2.DropDownItems.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.xMLToolStripMenuItem,
+ this.geoJSONToolStripMenuItem,
+ this.cSVToolStripMenuItem,
+ this.imageToolStripMenuItem,
+ this.templateToolStripMenuItem});
+ this.toolStripButton2.Image = ((System.Drawing.Image)(resources.GetObject("toolStripButton2.Image")));
+ this.toolStripButton2.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton2.Name = "toolStripButton2";
+ this.toolStripButton2.Size = new System.Drawing.Size(140, 22);
+ this.toolStripButton2.Text = "Add Representation";
+ // xMLToolStripMenuItem
+ this.xMLToolStripMenuItem.Name = "xMLToolStripMenuItem";
+ this.xMLToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.xMLToolStripMenuItem.Text = "XML";
+ this.xMLToolStripMenuItem.Click += new System.EventHandler(this.xmlToolStripMenuItem_Click);
+ // geoJSONToolStripMenuItem
+ this.geoJSONToolStripMenuItem.Name = "geoJSONToolStripMenuItem";
+ this.geoJSONToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.geoJSONToolStripMenuItem.Text = "GeoJSON";
+ this.geoJSONToolStripMenuItem.Click += new System.EventHandler(this.geoJSONToolStripMenuItem_Click);
+ // cSVToolStripMenuItem
+ this.cSVToolStripMenuItem.Name = "cSVToolStripMenuItem";
+ this.cSVToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.cSVToolStripMenuItem.Text = "CSV";
+ this.cSVToolStripMenuItem.Click += new System.EventHandler(this.csvToolStripMenuItem_Click);
+ // imageToolStripMenuItem
+ this.imageToolStripMenuItem.Name = "imageToolStripMenuItem";
+ this.imageToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.imageToolStripMenuItem.Text = "Image";
+ this.imageToolStripMenuItem.Click += new System.EventHandler(this.imageToolStripMenuItem_Click);
+ // templateToolStripMenuItem
+ this.templateToolStripMenuItem.Name = "templateToolStripMenuItem";
+ this.templateToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.templateToolStripMenuItem.Text = "Template";
+ this.templateToolStripMenuItem.Click += new System.EventHandler(this.templateToolStripMenuItem_Click);
+ // label2
+ this.label2.AutoSize = true;
+ this.label2.Location = new System.Drawing.Point(96, 40);
+ this.label2.Name = "label2";
+ this.label2.Size = new System.Drawing.Size(38, 13);
+ this.label2.TabIndex = 6;
+ this.label2.Text = "/data/";
+ // label3
+ this.label3.AutoSize = true;
+ this.label3.Location = new System.Drawing.Point(432, 40);
+ this.label3.Name = "label3";
+ this.label3.Size = new System.Drawing.Size(41, 13);
+ this.label3.TabIndex = 7;
+ this.label3.Text = "/config";
+ // RestConfigurationEditor
+ this.AcceptButton = this.btnSave;
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.CancelButton = this.btnCancel;
+ this.ClientSize = new System.Drawing.Size(720, 525);
+ this.Controls.Add(this.label3);
+ this.Controls.Add(this.label2);
+ this.Controls.Add(this.toolStrip1);
+ this.Controls.Add(this.txtUriPart);
+ this.Controls.Add(this.btnCancel);
+ this.Controls.Add(this.btnSave);
+ this.Controls.Add(this.txtJson);
+ this.Icon = ((System.Drawing.Icon)(resources.GetObject("$this.Icon")));
+ this.Name = "RestConfigurationEditor";
+ this.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent;
+ this.Text = "REST Configuration";
+ this.toolStrip1.ResumeLayout(false);
+ this.toolStrip1.PerformLayout();
+ #endregion
+ private ICSharpCode.TextEditor.TextEditorControl txtJson;
+ private System.Windows.Forms.Button btnSave;
+ private System.Windows.Forms.Button btnCancel;
+ private System.Windows.Forms.TextBox txtUriPart;
+ private System.Windows.Forms.ToolStrip toolStrip1;
+ private System.Windows.Forms.ToolStripDropDownButton toolStripButton1;
+ private System.Windows.Forms.ToolStripMenuItem featureSourceToolStripMenuItem;
+ private System.Windows.Forms.ToolStripMenuItem layerDefinitionToolStripMenuItem;
+ private System.Windows.Forms.ToolStripDropDownButton toolStripButton2;
+ private System.Windows.Forms.ToolStripMenuItem xMLToolStripMenuItem;
+ private System.Windows.Forms.ToolStripMenuItem geoJSONToolStripMenuItem;
+ private System.Windows.Forms.ToolStripMenuItem cSVToolStripMenuItem;
+ private System.Windows.Forms.ToolStripMenuItem imageToolStripMenuItem;
+ private System.Windows.Forms.ToolStripMenuItem templateToolStripMenuItem;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.Label label3;
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestConfigurationEditor.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestConfigurationEditor.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestConfigurationEditor.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,269 @@
+using Maestro.Editors.Common;
+using Maestro.Editors.Generic;
+using Newtonsoft.Json;
+using Newtonsoft.Json.Converters;
+using Newtonsoft.Json.Linq;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.ObjectModels;
+using OSGeo.MapGuide.ObjectModels.FeatureSource;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+using RestSharp;
+using System;
+using System.Data;
+using System.Linq;
+using System.Text;
+namespace Maestro.AddIn.Rest.UI
+ public partial class RestConfigurationEditor : Form
+ private RestConfigurationEditor()
+ txtJson.EnableFolding = true;
+ txtJson.SetHighlighting("JavaScript"); //Close enough
+ private IRestClient _client;
+ private IServerConnection _conn;
+ public RestConfigurationEditor(IServerConnection conn, IRestClient client, string json, string uriPart, bool isNew)
+ : this()
+ _conn = conn;
+ _client = client;
+ if (!isNew)
+ var dataLen = "data/".Length;
+ var configLen = "/config".Length;
+ txtUriPart.Text = uriPart.Substring(uriPart.IndexOf("data/") + dataLen, uriPart.Length - dataLen - configLen);
+ txtUriPart.ReadOnly = !isNew;
+ txtJson.Text = json;
+ public bool IsNew
+ get { return !txtUriPart.ReadOnly; }
+ public string GetUriPart()
+ return "data/" + txtUriPart.Text + "/config";
+ public string GetJson()
+ string json = txtJson.Text;
+ return json;
+ private void btnCancel_Click(object sender, EventArgs e)
+ this.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ private void btnSave_Click(object sender, EventArgs e)
+ if (!txtUriPart.ReadOnly && string.IsNullOrEmpty(txtUriPart.Text))
+ MessageBox.Show(Maestro.AddIn.Rest.Strings.UriPartRequrired);
+ txtUriPart.Focus();
+ return;
+ var req = new RestRequest(this.GetUriPart(), Method.POST);
+ req.AddFile("data", Encoding.UTF8.GetBytes(this.GetJson()), "restcfg.json");
+ var resp = _client.Execute(req);
+ if (resp.StatusCode != System.Net.HttpStatusCode.OK)
+ MessageBox.Show(string.Format(Maestro.AddIn.Rest.Strings.ErrorSavingConfiguration, resp.Content));
+ else
+ MessageBox.Show(Maestro.AddIn.Rest.Strings.ConfigurationSaved);
+ this.DialogResult = System.Windows.Forms.DialogResult.OK;
+ private void featureSourceToolStripMenuItem_Click(object sender, EventArgs e)
+ using (var picker = new ResourcePicker(_conn, ResourceTypes.FeatureSource.ToString(), ResourcePickerMode.OpenResource))
+ if (picker.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ dynamic conf = GetConfigurationObject();
+ dynamic source = new ExpandoObject();
+ source.Type = "MapGuide"; //NOXLATE
+ source.FeatureSource = picker.ResourceID;
+ string[] classNames = _conn.FeatureService.GetClassNames(picker.ResourceID, null);
+ string className = GenericItemSelectionDialog.SelectItem(Maestro.AddIn.Rest.Strings.FdoClass, Maestro.AddIn.Rest.Strings.SelectClassName, classNames);
+ if (className != null)
+ source.FeatureClass = className;
+ conf.Source = source;
+ txtJson.Text = JsonConvert.SerializeObject(conf, Formatting.Indented);
+ private void layerDefinitionToolStripMenuItem_Click(object sender, EventArgs e)
+ using (var picker = new ResourcePicker(_conn, ResourceTypes.LayerDefinition.ToString(), ResourcePickerMode.OpenResource))
+ source.LayerDefinition = picker.ResourceID;
+ private dynamic GetConfigurationObject()
+ var converter = new ExpandoObjectConverter();
+ dynamic conf = JsonConvert.DeserializeObject<ExpandoObject>(txtJson.Text, converter);
+ return conf;
+ private RestSourceContext GetSourceContext(dynamic conf)
+ var source = conf.Source as IDictionary<string, object>;
+ if (source.ContainsKey("LayerDefinition"))
+ string resId = conf.Source.LayerDefinition;
+ ILayerDefinition ldf = (ILayerDefinition)_conn.ResourceService.GetResource(resId);
+ IVectorLayerDefinition vl = ldf.SubLayer as IVectorLayerDefinition;
+ if (vl == null)
+ throw new InvalidOperationException(string.Format(Maestro.AddIn.Rest.Strings.NotAVectorLayer, resId));
+ return new RestSourceContext(_conn, new RestSource()
+ FeatureSource = vl.ResourceId,
+ ClassName = vl.FeatureName
+ else if (source.ContainsKey("FeatureSource"))
+ string resId = conf.Source.FeatureSource;
+ FeatureSource = resId,
+ ClassName = conf.Source.FeatureClass
+ throw new InvalidOperationException(Maestro.AddIn.Rest.Strings.InvalidSourceConfiguration);
+ private void xmlToolStripMenuItem_Click(object sender, EventArgs e)
+ var conf = GetConfigurationObject();
+ if (!((IDictionary<string, object>)conf).ContainsKey("Source"))
+ MessageBox.Show(Maestro.AddIn.Rest.Strings.NoSourceInConfiguration);
+ return;
+ var ctx = GetSourceContext(conf);
+ if (new NewRepresentationDialog("xml", conf, ctx).ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ private void geoJSONToolStripMenuItem_Click(object sender, EventArgs e)
+ return;
+ if (new NewRepresentationDialog("geojson", conf, ctx).ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ private void csvToolStripMenuItem_Click(object sender, EventArgs e)
+ return;
+ if (new NewRepresentationDialog("csv", conf, ctx).ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ private void imageToolStripMenuItem_Click(object sender, EventArgs e)
+ return;
+ if (new NewRepresentationDialog("image", conf, ctx).ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ private void templateToolStripMenuItem_Click(object sender, EventArgs e)
+ return;
+ if (new NewRepresentationDialog("template", conf, ctx).ShowDialog() == System.Windows.Forms.DialogResult.OK)
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestConfigurationEditor.resx
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestConfigurationEditor.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestConfigurationEditor.resx 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,688 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+ <data name="toolStripButton1.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAHBSURBVDhPjc9NS2JhFAdwi4koKyoKHLxGhKDpFTOC5lKS
+ dsF8yVxcJbiYimYhKTODRRtdRrgMBuZL9AFat2thBL0QBUFE21YDA0Gd/kclIiXvH35ceJ5zznOPTmty
+ udxkqVT6XalULI0j7QmHw/ZEIrF7c3NPyWRyp3HcNn6oCoKw7vV6y9XqNTmdzj1JksT69dfZhNNisUj8
+ PT4+I5PJ9MdqtU7zZbt1HAaD4aJQKFA2m6V8Ps9DzvR6fYEvtaxTlmX5KZPJUDQapXg8Tul0moecG43G
+ DS3rHCqK8j8SiRBeo1AoRMFgkHw+Hw+5/LxOq5zg5ZdAIEB4jWw2kQRhjCyWSbLbHTzkGuv8rJc2Jwy3
+ /OuSNIcmkcxm2ztRdGGgk4fc1qo/ZQXuUqkUzc97yOWSaGrqx7uZmbkarmnUNuWemxcXfeR2L2HIEsny
+ Mnk8/tfZ2YXniQnLv76+/gfU/aqXN+cAHlU1TX5/jBRljV97hCs4gn1wQcuoQLFYjJueVHWj9gUF2uZj
+ M/sLz7AKmvKxeQtGYBgGYQD6QQ890A1d8A06oQN0u8DN22AHK5hhHAT4DqMwBDysF3gQhug63wCbhbW0
+ /QkwqgAAAABJRU5ErkJggg==
+</value>
+ </data>
+ <data name="toolStripButton2.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAIRSURBVDhPjZJNSJRRFIa/pdHORa2FZiEILYKQaFWQLhIk
+ LVy4cGM11BAjwwjOyECbtjER2QgDgobUmE7+hJS/48AgSC5qQBHEYExkqJz//9fzftzxFk7SC2dxP973
+ +c499xhV3RscbLvr8dw/qzo9nkvKflqdLteDdKmEX/k8DjMZxFIpfE8msZdImBVcXQU9d9xui4r8rfaB
+ gYfJQgFxCf44OsJuPI6tgwN829/H11gMY3NzoOirCWlzOq0pAfxMp2tCXoyOnpSlpcWtYlq3HY5HmWIR
+ v6X9f0HYCa9Dr4pp3bLbH2dlBols9kwIAfSqmNZNm82WE8DWzg7WIhFEt7dPIF+iUcyvrCC0uWkOll4V
+ 07phtT4plMv4MDODrHTxPhhEcHYWU3J+NzlpfhsLBMzXoVfFtK739tqLAgiFw3g9PIzlUAgBCfI6n+Tv
+ 3qEhfFxcxKGA6FUxrWs9PX2lSgV5uUZOhpmRF3kzPn5qJtwTelVM62p3t6MsAHZRhfhHRpDK5RDZ2MDb
+ iQmE19eREDC9KqZ1pavLWZFFKQmgCpmansYrnw8vpX3OwOf3g8tGr4ppXe7o6OemVaSLPyHs5PPSEp57
+ vZhfWEBazvSqmJaltdVFAFULwpnwOlw2elXM1DmpCxebm5+qvClehzPhYAniE3NP8nKmlxmVNeqlmuoa
+ GvrONzY++5+ilxnDMOqPAY/4PMei9SzEAAAAAElFTkSuQmCC
+</value>
+ </data>
+ <data name="featureSourceToolStripMenuItem.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACnElEQVQ4T5XRa0hTYRzH8WfV
+ i4ZvglJ8EQbdKBLfTIQVyRiBubG5mqtYVwi0zQrLXihpFwwchGKKuYu5JW6h4qW5zc1LOi/zsuNUZGo3
+ dYpzqIESZZDw65yBicvCXnzhPIfDh/P8/0Qmk4UmokvZRsx35A9ALBanLCwsYHJyEl6vFxQ1DKu1G3b7
+ AHp6xul3fszNfYdIJFJKJJKtAb/fD4/Hg9bWVlgsNujKqmGoMKPR0o2+/veY9i3/L1AFfUUDzNZO9A6M
+ Ycr3ZQPg8YShAEehUDRqtVqo1WqoVCpkZmYiOzs7+FxaWoqMjIwmGogLAhERcaFAyAyGYGlywuLoQodr
+ EEPej5ieW9z4A0JObEK2uoJWb4Kusgq1Njs63RQ++GY3A0z/AjR6I7TGN6hpsqLD3Y+Jmam/AzeSTm9r
+ BgKBIE4oFAaBQSapVJrKZJDvdYy8UsKtVcJTlw+3y4lGRxvqmx1w9DrRN+bBhP8zeDxeKp/PJyQ9vQgS
+ yX2sra3BbDYDn6qC/RyvxGxzHppVySjPvQm1oRhGey1aqHaMzowhJiYmLUuwn5DExDRwuVcQCARgMpmw
+ 6tFhpafod98oDSZqs1D/OBHGlw9grs6HrUCOQhHb1XZjl5LExl5AdHRScG0ajQZf+0owXJ4GZ8FltKhk
+ GDHcweK75/hBw6/vngRVdgvLNMycG+Q7dSQhQQEOR4b5+XlERkY+fSENH+0vubrke/sIlCYFtlwJ9Le5
+ 0KbGoj1fjllzzmpX3llvneJQh/7cjov0EI+sMIWFheWx2ex7p6LItYfxpKbw/L5RV+GlpYAtF+sx5+Lk
+ 8KFnfFbJmYMsrvgYi9kCiaI7ThdNd5juKB2Hhq4z0BMeodbLiSfV8QcIs/w9dLsJIaxfLDsc751acxMA
+ AAAASUVORK5CYII=
+</value>
+ </data>
+ <data name="layerDefinitionToolStripMenuItem.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABuklEQVQ4T6XS6SsEcRzH8e8z
+ yTMkUUpJjuT6D/wDPFFSruQWyfXIXyBHrqWUnKXGHuy6Voq19rAe2Ad23W1mrbGzWLdH6/cZZJU0svVq
+ Zn77fc/VUCAQ+BfKbtdDHJPLFMqEWTREWW2rkGc58i1d+V9tgv/F+hvMYBYNWspsXYEi4fZlx+V91MuB
+ WTRoKaNlGYo9N8+mM+FhRQ7MokFL6c1LUOr2PRmPPfeLcmAWDVpKa9JBGbs1g4O/0wbbc90qjU5xQm+/
+ HNLuXvSqrHwnmI98M2jQUmrjApSfCo8bdpdfA7unNxyLRuYsfDdnPu+SmL4YHN4pNGgppWEeKg499+ss
+ VG7ueydVVncfZ+J7ObOkR9ri+H2tx+AQZ9CgpaR6NVTt83dra3ZhnF11YM78TX8QaY2dYBYNWkqsVUKN
+ 7eRap7Tww4ziA/aDjz/XFAanl0ODlhKqOagzHohqtdU9+ok9huSn/S2nqEaDluIrZqGBvVmdxuYek+x8
+ bH/C/sMsGrQUEp1MsSWTldMbJ8vsE13cPhC1v8EMZtGgxS88LC03JyJ/sCmyYLRDDsyiQYsThDJRTMwf
+ sYZC3wAh5nPvZl53vQAAAABJRU5ErkJggg==
+</value>
+ </data>
+ <data name="$this.Icon" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ AAABAAwAMDAQAAEABABoBgAAxgAAACAgEAABAAQA6AIAAC4HAAAYGBAAAQAEAOgBAAAWCgAAEBAQAAEA
+ BAAoAQAA/gsAADAwAAABAAgAqA4AACYNAAAgIAAAAQAIAKgIAADOGwAAGBgAAAEACADIBgAAdiQAABAQ
+ AAABAAgAaAUAAD4rAAAwMAAAAQAgAKglAACmMAAAICAAAAEAIACoEAAATlYAABgYAAABACAAiAkAAPZm
+ AAAQEAAAAQAgAGgEAAB+cAAAKAAAADAAAABgAAAAAQAEAAAAAACABAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAIAAAIAAAACAgACAAAAAgACAAICAAACAgIAAwMDAAAAA/wAA/wAAAP//AP8AAAD/AP8A//8AAP//
+ /wAAAAAAAAAAAAAAAIeHAAAAAAAAAAAAAAAAAAAAAAAAAAd8RsTEfEdwAAAAAAAAAAAAAAAAAAAAhGxH
+ d4iIx2xMdwAAAAAAAAAAAAAAAACEx3iPiIjo+PiHxHcAAAAAAAAAAAAAAAbHd2iOjufn7oiIh8xwAAAA
+ AAAAAAAACEV4ZiZo7Oznzm7uiIfEgAAAAAAAAAAAfGiOI2Nmjo6O6Ox+zoiERwAAAAAAAAAHx4iHYnpy
+ 6Ofs7O7n5+6PxlAAAAAAAAB8aI7oanpyZ+jo6OjO7sjoh8cAAAAAAAfHiI6Ocno3pn6Ofn7ozu7IZ3yA
+ AAAAAAbPjo6I4nOnJyaO5+fu6M7uZnZAAAAAAHyIjo5+hienp6Zo5+fsjujoYmhlAAAAB0BgYERAUCBj
+ pzNo6MZCQEBAACBEcAAABAAAAAAAAAACenpmjgAAAAAAAAAAYAAAgAEBAQEhAhAANjYyhgAQEAECEBAQ
+ WAAAYzMzMzMzMzMzY6em6HMzMzMzMzMzdAAAwzMzMzMzMzMzNqZ4jhMzMzMzMzMzPAAHczkzOTOTOTOT
+ Yojo6HMzkzkzkzM5d3AMb4gzMzMzNzNqIAAABo6HJzMzM5M2dsAHz445M5M2JqemAAAABI6GejMzkzN6
+ d0AGf4gzMzMyYmJgMzMzM0jmNjMTMzM2KEAMiOgzMzk3iI8DEzkzMxaGpyMzMzN6Z8CGiI45MzM4iIYT
+ MzMzkzCGJyOTOTM3KGh8iIgzOTM4iOEzOTMzMzNIYjMzMzNqZ8eMiOczMzMX6BMzMzOTM5M2hiMzkzOG
+ aHeGj3YzM5M2djMzM5czMzMxaCEzMzfo+McMjiIzkzMyITM5MziHOTMzNmMzOTN2aEAGgmIzMzM1MzMz
+ M4iIMzMzMSOTMzMmKEAMdiczM5MwMzkzmI6Ogzk5MxMzMzNyZ8AHx6czkzMzOTMzjoiI5zMzMzM5M5N6
+ dnAIZ2MzMzOTMzMzj46OiHMzOTMzMzM2jHAAyCYzM5MzMzk2Zojo6OOTMzOTMzNidgAAdnIzkzMzkzNj
+ Jo6I6IdzMzMzkzMnxwAAhzOTMzMzMzN6Z+jo6O5zOTOTMzkzdwAAAxMzMzkzOXpyaIiOjo6HMzMzMzMz
+ EAAAAzMzOTM5MmImjo546M7sczkzOTOTcAAAAHdzMzd3hiYo6IZijo6Od3d3d4d3AAAAAAR3ZqaOiCam
+ jnpyZ+jn7u7u6IZAAAAAAAjHYnJo56Y2b2Knpifo7OzoiMdwAAAAAAB2hiemaCYmfnZ6c2Yn6OjohscA
+ AAAAAAAHyGJiKGJo6Go2Onpmjs6Ix3AAAAAAAAAAfIiGaGfo6Cenpzc26I+MfAAAAAAAAAAACGyGqI6I
+ 52pzanqmeI5HcAAAAAAAAAAAAAZ3iI/iYnOnp6ciflxwAAAAAAAAAAAAAAB8bIh2JqYmImZ4fHcAAAAA
+ AAAAAAAAAAAAhsZ4d3eHh4fGyAAAAAAAAAAAAAAAAAAAAAjGxsZsbGyAAAAAAAAAAAAAAAAAAAAAAAAA
+ CIiIgAAAAAAAAAAAAAD///w///8AAP//gAH//wAA//wAAD//AAD/8AAAD/8AAP/gAAAH/wAA/4AAAAH/
+ AAD/AAAAAP8AAP4AAAAAfwAA/AAAAAA/AAD4AAAAAB8AAPgAAAAAHwAA8AAAAAAPAADgAAAAAAcAAOAA
+ AAAABwAAwAAAAAADAADAAAAAAAMAAMAAAAAAAwAAgAAAAAABAACAAAAAAAEAAIAAAAAAAQAAgAAAAAAB
+ AACAAAAAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAAAABAACAAAAAAAEAAIAA
+ AAAAAQAAgAAAAAABAACAAAAAAAEAAMAAAAAAAwAAwAAAAAADAADAAAAAAAMAAOAAAAAABwAA4AAAAAAH
+ AADwAAAAAA8AAPgAAAAAHwAA+AAAAAAfAAD8AAAAAD8AAP4AAAAAfwAA/wAAAAD/AAD/gAAAAf8AAP/g
+ AAAH/wAA//AAAA//AAD//AAAP/8AAP//gAH//wAA///4H///AAAoAAAAIAAAAEAAAAABAAQAAAAAAAAC
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAgAAAAICAAIAAAACAAIAAgIAAAICAgADAwMAAAAD/AAD/
+ AAAA//8A/wAAAP8A/wD//wAA////AAAAAAAAAAB3dwAAAAAAAAAAAAAAAHRlyMfHRwAAAAAAAAAAAHx4
+ j46IiIx8AAAAAAAAAIR3Zo7n7u6Ih0gAAAAAAAfIhicn7n7O7OiMcAAAAAB8iOenpo5+js7uiMcAAAAI
+ yI6OJzYo5+fo7OZ2gAAABojo6Gp6dn6Ofs6GZ8AAAFBAQAQAJ6No5EAkACAHAAAAIAIQAQJ6Z2AAEAAQ
+ BAAHMzMzMzMzY2dzMzMzMzNwDDM5MzMzNyjo4zMzMzM3UAeIMzkzc3IAAHiHM5M5N2CM+DMzNiYgMzNO
+ diMzM3J4d44zMziIIzMTNeNjMzN6yH6IOTN4hjOTMzN2MzkzJnd4hzMzN3MzMzMxN2MzM4eMfIYzOTYz
+ Ezh5MzNjMzNud4hiMzMwMzN4hzMzEzEzcngGYzMzMzk3iOhzMzMzM3bAB2czkzkzN4iOgzkzE5MncAdy
+ MzMzM3JuiOczMzMzZ3AAMzM5MzNqiOjoczkzMzcAADOTMzNyd+jo7oYzM5MzAAAHcnOHYmiGZ47IaHeH
+ UAAACMcmeGam46Zn7u7ujIAAAAB+cmaKZ4ZzpyjsiMcAAAAAB3fihn6Cp6cuiIyAAAAAAACMdo6OY2N6
+ dofIAAAAAAAAAHaIYiamJnfHAAAAAAAAAAAAfIeHeHdnAAAAAAAAAAAAAAAIyMjgAAAAAAAA//w////A
+ A///AAD//AAAP/gAAB/wAAAP4AAAB+AAAAfAAAADwAAAA4AAAAGAAAABgAAAAQAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAIAAAAGAAAABgAAAAcAAAAPAAAAD4AAAB+AAAAfwAAAP+AAAH/wAAD//AAD//8AD///4
+ H/8oAAAAGAAAADAAAAABAAQAAAAAACABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAgAAAAICAAIAA
+ AACAAIAAgIAAAICAgADAwMAAAAD/AAD/AAAA//8A/wAAAP8A/wD//wAA////AAAAAAAAd8cAAAAAAAAA
+ AAd3iIiMcAAAAAAAB2Zo7O5ohnAAAAAAaIZ2fo7uyIwAAAAHh+MnbufO7oZwAAB36OdqN36OjOZ3AABA
+ QAADan5AAAAEAAcTExMwemgDMzExYAczMzMzJ44zEzMzcIeDMzY2AAGOMzM3aHjjEzdyMzNnYzEzZ8iD
+ M3hzMzMXYzM2d3jjM3czM5MzYzM4jHdjkzIzGIMzcxM2Z4ZzMxMziOczMTM3eAdjMzOTeI5zMzMycAcz
+ M5M2boiHM5M3cAgzEzNqiO7nMzMxAAB3N4dmhneOd+h3AAAGYmemhqZn7njAAAAAd24243o26IwAAAAA
+ B3iOenNqjHAAAAAAAAaGdmdncAAAAAAAAAAId36AAAAAAP/D/wD+AH8A+AAfAPAADwDgAAcAwAADAMAA
+ AwCAAAEAgAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAAAQCAAAEAgAADAMAAAwDgAAcA8AAPAPgA
+ HwD+AH8A/4H/ACgAAAAQAAAAIAAAAAEABAAAAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAAACA
+ AAAAgIAAgAAAAIAAgACAgAAAgICAAMDAwAAAAP8AAP8AAAD//wD/AAAA/wD/AP//AAD///8AAAAAd3cA
+ AAAAAHaOjowAAAB4Z25+yIcAAI6GNujuZgAAQAAndgBAUAMzMzZ3MzMweDM3IydzM3d4M3gzM2MzJ34z
+ czNTdjOHhpMxOIMzk2cGMzN+hzMzYAMzM2joczMwAHOGdn7n5wAAhmZ2o2h4AAAAeONnZwAAAAAAd3gA
+ AAD8PwAA8A8AAMADAADAAwAAgAEAAIABAAAAAAAAAAAAAAAAAAAAAAAAgAEAAIABAADAAwAAwAMAAPAP
+ AAD8PwAAKAAAADAAAABgAAAAAQAIAAAAAAAACQAAAAAAAAAAAAAAAQAAAAEAAAAAAAATDwgACxsFABgS
+ BwAADhMAARYdACUOCgA2FQ4AKhUUADwQEAAMIwsAGD8GABkkEQARMhUANigIAD8wDgAnIxQANioXAAAd
+ JwAMJy0AAiw6ADYvIQAuOCwANTMvACAwMQBFHhUAQT42ABpQGgAkWQIAI0sQACx0DAA1dwYAK3kYAD5+
+ HwATUC4AJF8kADhcLAAebDsAJX44AGxTGwBCfA4AUkQjAFpXOQABOUgAAkFPAAFDVgASSlYAGndJABdy
+ WQA2Zl4AKn1VAAFVcAA9WGwAEm5hABBzZQAEYXkAGmF5AAlzfQA/YHcAUk1OAHxRUwBRcEMAemZWAExV
+ YwBlYmEAnCwqAJ8wKwCMLzEAnjAwAKQ3KwCjOjYArEEsALJKLAC3US8ArEY3ALJMNQC4VTcAiG83AKtK
+ RQCrUUkAtVdHAK9UUwCyW1kAkXxAAK1kTQC7ZVQAn312ALhmYwC/cGUAu3l3AMVyVwDEeGkAwnx5ADeI
+ BgA3jRMAOJIXADWNKQA4myYAKogzADWYPgA5ozcAQ4sLAEmOEgBViRgATZIYAFaUGQBnmR8AW5ooAFeL
+ OQBmmyUAcZ8qAGiaNwB0oS0AZ6A1AHmmOgAbg18AIYZMADWeQQAkjVQAKptbADmsRwAuoFgAG4ZmAC6D
+ awAklWUAd5NTAHalSgBWgn8AfZ9hAHaZdwCIqTkA/LkeAMyfOADcoygA26k6AOerJgDssS0A/rwnAOKs
+ MwDvuj0A/78wAP7BNwCZnksAmZpWAK+OQgCzkkkAvJ9eAImsRACXsEgAiKhcALi3RQCtrV8AoLlcALK7
+ WQCtmnsAt5pzAIKlZgCapW0AmbhhAJuwfACjoWoAqLFpAKugdwDJoEEA3KxEAN+xTADEt1kA2rFWAOm5
+ TgDnulcAyoVrAMqIdQDQjnoAw5J2ANCQfQDBtmgA1L1tAOi/ZAC6wmgAvMVzAMvDXgD+xkYA/MpXAP/Q
+ XgDHxGcA2sVpANnNdgDpxWkA+8xjAP3QaQDnyXsA8ct3AOzRcwD91HYAAmiIAAd2iAAAbpMAB3GRABp5
+ kwAle4gARWyCAGR6iAAvgpMAR4aBAG6VigB5o5YAup2FAI6nhACYqYUAjKyaALihhwCttYUAurCFAKq4
+ lwC/v58AyImGAMqUiQDUmYgAzZSSANOckwDLo4YAz6yfANillwDfsqMA47+zAKnGgQC9xJ8AxMeMAN3H
+ jADFyZUA2suTAM3UlgDc15MA59OFAPzYhgDv3JsA+9uTAP3hnADLwqQA1sOkANnYpQDWzrQA7d6sAOfG
+ uADs1roA+N+yANfgtQD946cA/ui5ANrSyQDu08MA89zGAPvpxQD56dMA/vHVAP///wAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAA2tfX2gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFxOQkJC
+ QkJERERBRE5ZAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANdOQkJCSlJc19ra11tSREFEQUbX
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADXR0ZQW976/vz39+3t7ff8/vTXT0RERNcAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAE5HT62VaOfsu6mlpIaGpKSoscHt/PNXREFGAAAAAAAAAAAAAAAAAAAAAAAAAADX
+ R0JY02VeXiiOp6SKiIiIiIeFhYWkqer481FBRNcAAAAAAAAAAAAAAAAAAAAAAFhHRdv+nl1jY2Afgry1
+ jY2MjIyJiYiHhYWp6vzXREFXAAAAAAAAAAAAAAAAAAAAVUVL8/jqlx5jeHhkXZS3tY2NjY2MjImDiYeH
+ irz34EZEUQAAAAAAAAAAAAAAAABYR07797+nsF1keHh4ZGWZt7W1jY2NjIyJiYODh4eo9/FXRFcAAAAA
+ AAAAAAAAANdHS/v3u6m2wW5eeHh4eGRdlMG1tY2NjY2MiYmDg4OHu2aVUkFcAAAAAAAAAAAAAEdK8/i7
+ sba2vbpdeHh4eHhkXW7AtrW1jY2MjImJg4ODqGddnU9EAAAAAAAAAAAAUEfe+L+xtry8vexlZHh4eHh4
+ eF5wwbW1jY2NjYyJiYODtmVeXZpGRgAAAAAAAABWBwYXFRERERERERUCCg0jeHh4eHhduLe1oycPDg4O
+ Dg4OEQICAgwICVkAAAAAAAAZAAAAAAAAAAAAAAAAAAAADXh4eHhhasGjAwAAAAAAAAAAAAAAAAAAAEMA
+ AAAAANgZEhISEhISEhISEhISEgUACnV4eHh4XbqQAAQFEhISEhISEhISEhISBUPXAAAAAEvExMTExMTE
+ xMTExMTExMTCMHh4eGRfXbKxMcTExMTExMTExMTExMTExDRGAAAAAEjExMTExMTExMTExMTExMTExXhk
+ ZWWUsuqwxcTFxMTExMTExMTExMTExDpEAAAAq0jExMTExMTExMTExMTExMTFfGQfoeS+u7G7gcXExMTE
+ xMTExMTExMTExMhEWQAAUEj54p/FxMTExMTCMnR3d3l4dQsAAQAAAQGRvLGvnyZ2NsXExMTExMN8YpxO
+ RgAASEz+7b7FxMTExMQ4IWF4eGRkHAAEBAQEBAQQp7e9gl94JcLExMTExMN4ZHFXRAAASFv+7L7FxMTE
+ xMQ3Hl1dXV0fAS3ExMTExMQrKbbqXmR4JcLExMTExMN4ZF3XRAAASK786r7FxMTExMQ3bOPw8PQaK8TE
+ xMTExMTEFE3pXWR4JcTFxMTExMN4eF2tRADZSN746unFxMTExMQ31vj49T4UxMTExMTExMTEwhOSgl94
+ JcLExMTExMN4eF3SRNeuSN/46unFxMTExMTC7vj4mhPCxMTExMTExMTExDcWr2VfJcLExMTExMNfX13S
+ RlyuSN/495XFxMTExMTCleXuGDfExMTExMTExMTExMQzKrlqI8LExMTExMeWgnDdQlzZSN78k17ExMTE
+ xMU3Hm87M8TExMTExMrKxMTExMTEM1OyG8LExMTExMe2wfjeQtcASN7hXV3ExMTExMQ3IB0zxMTExMTE
+ yubjxsXExMTExC6OIzfExMTExMpqamveQgAASdldXV3ExMTExMQ3JSvExMTExMTG5ezq08bExMTExMQi
+ G8LExMTExDldX12tRAAASatlYXXExMTExMQ3K8TExMTExMXV7Orq6s/ExMTExMTCK8LExMTExDlkYWtY
+ RAAATFpvYXjExMTExMTExMTExMTExNHs7Orqwb/MxMTExMTEwsTExMTExMN4X5VPSgAAqlCPXXnFxMTE
+ xMTExMTExMTEe/L37OrqwcG8y8TExMTExMTExMTExMN4XaJKWAAAAEytXWTExMTExMTExMTExMQ2XWVy
+ 6+rBwcG9ucfExMTExMTExMTExDlfaK1CAAAAAExUJCLFxMTExMTExMTExDl1ZGFds+rBwby8t6bCxcTE
+ xMTExMTExDkbPU9GAAAAAK04xMTExMTExMTExMTExXl4ZF2T7MHBvby3traPwsTExMTExMTExMTExD9Z
+ AAAAAADExMTExMTExMTExMTEdnh4X3LswcHBwby2trW1fcTExMTExMTExMTExDQAAAAAAADGxMTExMTE
+ xMTExMQlZF1dXenBwemTmcG3tbW1izHExMTExMTExMTExMwAAAAAAAAAPkB/L3p6ejLNgdBoXWVllOrB
+ 6WhfXbC3t7W1jYZ9fYB9gICBzck7PAAAAAAAAAAAAElbcl54ZGbqweqZZmVdaerqlF54YWWUu7e1jIyM
+ iYmDibXq+kpHAAAAAAAAAAAAAKtJqm9deF1xuOxyXWFfXXHqaV94eGRfZYK5toyDiYOMter7T0dcAAAA
+ AAAAAAAAAABaTKtvXWRdXWqyXWRhZYLqgl14eHh4ZF9dpo2JjIy16vtVR1UAAAAAAAAAAAAAAAAAWkyq
+ cl1dXV3pal1dmb3Ba2F4eHh4eHhfcLWMjbf3+lBFUAAAAAAAAAAAAAAAAAAAAFpMW9T2aF3pcG24vbe5
+ XXh4eHh4eHhkZbS3wfjfS0dVAAAAAAAAAAAAAAAAAAAAAACqSUzZcl3o7cHBwcFuX3h4eHh4eHh4X4L4
+ +6pHR1sAAAAAAAAAAAAAAAAAAAAAAAAAAExMWtz9+PiYZWhdeHh4eHh4ZGFlZZXeS0dKAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAACsSUlMqvOTXV1dXV9dX2VdZnKdrVVLR1sAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAKpMSUxarZuboaCgoZubq1pMS0urAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFtMSUlM
+ TExMTExJSEtYAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADerKurrNkAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAD///w///8AAP//gAH//wAA//wAAD//AAD/8AAAD/8AAP/gAAAH/wAA/4AAAAH/
+ AAAH/wAA//AAAA//AAD//AAAP/8AAP//gAH//wAA///4H///AAAoAAAAIAAAAEAAAAABAAgAAAAAAAAE
+ AAAAAAAAAAAAAAABAAAAAQAAAAAAAAoIBAAcCwkACRcGABIXBQAAExkAJBsJACQcEwAkIR0AAiYtABkv
+ LgAeMjYAXyIkABxJCwApYw0ANW0SABpPIQANTj4AIGQkACp9NABYRBcARUgxAGpGPwB6YiwAB05VAB9X
+ XgAee0cADWNZAANXawAAV3QALF52ABZmYAADYXgAHm97AAhxegAmbnEASU5FAHlFRQBWe18Af3RLAJws
+ LACfMzIAojUtAKc7LgCpPi8Aozk3AKxCLQCySS4ArEQzAKZBPgCqRDkAr0s7ALJMNAC6VzcAh0hIAINb
+ TgCnRkUAqUZDAKtJQwC4XUkAr1ZWALJbWQCUdE0AvWRNALdhVwC2Yl8AuGVeAKFwXACwdV8AhH9uALZk
+ YgC6amUAumxrAL9wZQC/f2MAtXdrAL5xawCyf2wAvXJwAMFpTADBbFUAw3NYAMBxZADGemQAxHpsAMl+
+ aADCenYAwXt5ADeGAAA3iQYAPIgFADSECAA7gw8AN4oMADuLCwA2jhIAPI4SADiTGAA4miYAKIY0AC+R
+ NQA2mDAANZY/ADabOAA5oC8AOqc+AEWMDABEjBMASIkWAEaRFQBUkxoAV44iAFiXIgBCjDYAYJAiAGad
+ KAB/misAZZ02AHGWOQB5pDUAJIRAADKFQQAql1UAMJ9RADqrRwAuoFkAMaRUACaWYABimkQAfpNAAHSd
+ QQB6mEcAZ4VqAIalNQD7uB4A3KUuAN+sOwDtriMA4KcqAOOqLADxsSEA/rskAP6+LADjqzEA7LQyAP/A
+ MwD/wToAiJlHAImWVwCZnFwApp9HALGQRwCrjF4ArZtWAIyvVQCKtFwAnLZUAKaiTwCmtEkAsrdKAKW3
+ VAC4u1IAs7xZALq6XACaj2EAt4diAJa2ZwCup2YAuK5jAKayYAC/tm4A3K1CAMi7RgDes1UA6rpMAOm9
+ WQDKgGgAy4d0AMOxYADlvGYAxsFZAP7EQgD/x0gA/chLAOzIVwD8ylcAycNhANzGaADJyHMA1sd1AO3A
+ YAD+zmIA/dFrAO3MegD2z3YA6NF4APzUeQACZ4cABXOJABZ2jQAAbpMABHCSAC1rhgA8eYUAPHeQADKB
+ igBSj4wARY2WAGWalQB3oJAAioiKAImpkwClsoQAtreDAMuOigDOkIQA0paFANSZhQDUnI4Ay5GSANKc
+ kwDIqY8A1qGRANmmlgDfsJkA2rymAMnPkQDlyoIA8c+CAOvSgwDz1IIA/taDAPXVigD+2owA69mWAPTX
+ kwD62pIA+dyZANvLpQDnwawA6MSpAOzJqwDk3KkA6siwAPLXtwD23bMA9t67AO/hpwD74qYA/eSsAP7m
+ sgD75roA/ei4AOHbxAD+68EA////AAAAAAAAAAAAAAAAAAAAV0hIVwAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAEwqKjpCTExBOSgoSAAAAAAAAAAAAAAAAAAAAAAAAEAyRN32+evk5Oj49d89KDwAAAAAAAAAAAAA
+ AAAAANwrTINgb7Krj4+Li4eIr+zwPSjbAAAAAAAAAAAAAABULN77XGZna6G1kpGRjo2Jiq7t2ihIAAAA
+ AAAAAAAAVDDv7LNyfHx8bru1kpKRjo6NjI/C4ThIAAAAAAAAANww7+ivuaJhfHxpbbS5kpKRjo2NhpCF
+ lDHbAAAAAAAALt/svr+/5mF8fHx8YaG5tZKRjo2NjXRdpCkAAAAAABYCCAcGBwYHAwMQfHx8bcCrFAYG
+ BgYGBAMDAjYAAAAABwUFBQUFBQUFBQFjfHxonxcBBQUFBQUFBQUFDAAAAFPIyMjIyMjIyMjIxXtpYmGf
+ p8XIyMjIyMjIyMgeRgAAL8jIyMjIyMjIyMjGe2yp48Oqx8jIyMjIyMjIyMopAAAv/dXJyMjIIWN9fnwN
+ AAEAAZe+vXF6IMjIyMl+gDgA2j/+5MnIyMgbYWFhDgkcHB0cCq26YXwcyMjIxnxtRtaxsPrkycjIyB/i
+ 8u4LxcjIyMjFFaNiaSDIyMjJfGFLTlOx+eTJyMjIy/v1JCDIyMjIyMggJ3BlHMjIycZiYU1GU7H7m8jI
+ yMgjpkUdyMjIyMjIyMgcmXIcyMjJx6ycV0exsaZeycjIyBsPHMjIyMjT0cjIyMgZkxzIyMnHhZxXTN6w
+ XmHJyMjIHBjIyMjI0OzozsjIyMgRHMjIycZhbUTbAE9ufMjIyMjFycjIyM/r7ObBzcjIyMXFyMjJxnx1
+ MwAANYFnyMjIyMjIyMgipurpxMS7x8jIyMjIyMnGYpQsAABTPhLIyMjIyMjIyWRhcOnEwL+oyMjIyMjI
+ yckOQ0IAAADFyMjIyMnJych6fGG8xMS/ubmUyMjIyMjJyMgeAAAAAMnIyMjIycnIGmhhnMTkosK5t7Um
+ yMjIyMnJyMwAAAAAADeEeH951NVwXlrD53NhhcC3kpCdnZad1NIlAAAAAAAA2U92aGGg6HdhYYW9YXxi
+ bZ64kY2NjsDxNNcAAAAAAAAAsFF2YV1tnGFhnsNefHx8aG23jpHA8TNEAAAAAAAAAAAAsE+Vm168bp+/
+ n2J8fHx8Yp+57OA0UwAAAAAAAAAAAAAA2TWld/fpu7RufHx8fHxoc/VULtcAAAAAAAAAAAAAAAAAAE81
+ sfF1WV1iYmFhcJOYND8AAAAAAAAAAAAAAAAAAAAAAABTNU+lpZmYpaVPNVIAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAANmwUVGw2gAAAAAAAAAAAAAAAAD//D///8AD//8AAP/8AAA/+AAAH/AAAA/gAAAH4AAAB8AA
+ AAPAAAADgAAAAYAAAAGAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAAYAAAAGAAAABwAAAA8AA
+ AAPgAAAH4AAAB/AAAA/4AAAf/AAAP/8AAP//wAP///gf/ygAAAAYAAAAMAAAAAEACAAAAAAAQAIAAAAA
+ AAAAAAAAAAEAAAABAAAAAAAABg8DAAQMDAAXCAYAGQkJAAkQBAAHFggAGxQEABASCAAaFQoAGxgUADs1
+ HgANNT0ACD07ABpNIAAiQCUAVEEWAHRpPAAARV0ACVJWABBeUgATZ08AD2BSABJhXwAaZF8AHnFdAB16
+ WwAicEwALmVdAC92WgAIVW0AF1poAANYcgAAXXoAD2liAAxqbAAHbXkAD3x8AHBMVgB3WlcAWVpgAKM9
+ PQCvSjwAsE08AI5OUgCZV1MAp0VFAKlIRwCsTksAs1hPALleSwCvVFMAr1ZWALJaVwCyW1kAs11ZALVf
+ XACYYV4AlWpbAJF7UAC9YEIAs3hPAK5mVQC3YFUAu2VTALBrVwC2YFgAtWBdALR1VQC6bGkAoHNkALxx
+ bwC+c3AAwGlKAMJuVADDcFcAwnBYAMZ6ZgDJfGQAyH9rADSGCAA5kRUAOZQaADWMJQAzjysAN5cnADqX
+ IAA4mSMANpgsADmfLgAxjD4ALpI7ADSaNgA3nj0AOaEyADegOAA5pTsAOqg/AECLCgBBhxAATpMWAEaX
+ HwBLlh4ATJUfAFSWHQBEmCIASpkiAFGbJABcmiMAZ54pAGWbNQBumD0AdZI5AHKRPQB4kT0AZqAsAH2k
+ LwBmoDUAKpFGAC+YRQAxmkEAOqtEADOjTgA5rEgAfotFAHiTRABshFsAU4t/AICpPAC8pz8A1a45AO+x
+ JADxsiIA/rshAPu6KAD+vigA/78tAOauMgDirDQA4a04APi+OAD+wDEA/sE1AP/COgD+wjwAjodCAI+I
+ RgCMhk8Ajo5MAJKATgCUjUsAjJNKAIyTUgCwgVUAgKNCAIGtTgCSrkQAmK9DAI+wVQCNsFgAoqZKALyn
+ QACrtkoAtbZCAKK2UgC3vFUAiYJsAJeZYACSnm4Ao6NnAKSzYgCnu2UAuLlkALy0aAC3t3oAtbl8ANWx
+ SADhsEQA5rZMAMqAagDKiXwAzIx+AMu3YADEvWgA1rxpALvAYADNwFAA18RZAP7FRADyx04A/slOAOLF
+ VADkx1kA78RbAPfKVwD/zFIA9MVbAM7FZQDXy3UA7sNgAOvDZADpx28A/s5jAPXPaAD6z20A8813APDK
+ eADyzn4A/tRyAPrUewAAY4MAD22FAAFtjwALe4UAA3KMAA10jQASdY4AAG6TAARwkwAMdJMALHmAACJ7
+ jAB9n4MAaJKQAJ6OhwCPrJcApLOMALm6gwCyu5MAiK67AMuQjgDRmoUA1JqJANafkQDYoI0A26aPANyp
+ jwDfrI0Aw7aJAN2rkADkuJQA5ryWAOO3nADlu58A6L6YAM7KhwDPxo0A7NOBAPLThAD91oEA89SIAPvZ
+ jgDsyqwA/uOhAP3kuAD///8AAAAAAAAAAAAAAEhDOEcAAAAAAAAAAAAAAAAAAAAAADFDte/w8O+1MC8A
+ AAAAAAAAAAAAAAA/QXFuuLGLiouyz/A4MwAAAAAAAAAAACvq9VNdZ7+PjoiIg4rN5ykAAAAAAAAAK/LP
+ yGV7YWzAvI+IiIWEx6cuAAAAAABA6s/Hypxhe3tpu7yPjYiFjWOTMwAAAAADCgkHCQgGDnthc8cQBwcH
+ BwEFBAAAACcSEhISEhISDXt7UrYMEhISEhISEiwAACjZ2dnZ2dnZ1Viat8nd2dnZ2dnZ2SYA6ef22dnZ
+ GXd6VAYCAgvBrFsj2dnZd5XmT/P42dnZG5ufD9LZ2SERnWEi2dnWYXxFTPz429nZ3/6mIdnZ2dkglFYi
+ 2dnWXn04S/ye2dnZHage2dnb29nZH6AW2dnYuu41s6lQ2dnZFRPZ2dvk4tnZ2RwU2dnXZJhF6pFf2dnZ
+ IdnZ2eH7+d7Z2dkh2dnWXpXmAD1V2dnZ2dnZGqv70cx/2dnZ2dnWUj8AADoX2dnZ2dklYGf30MrH3NnZ
+ 2dnZGC0AAOXZ2dnZ2SRfUcbRxcq+sNPZ2dnZ2QAAAABGfnZa46piaPmAVqLCj4Khoa3gOQAAAAAASXFX
+ baRSUbloYV5ro4iIw/QrAAAAAAAAAEmXdZxsostpe3t7ar3Q7ysAAAAAAAAAAABLma79pXRhe3thUq5N
+ MgAAAAAAAAAAAAAAADxOlnFvb3KSRDIAAAAAAAAAAAAAAAAAAAAA6E5LS03oAAAAAAAAAAAA/8P/AP4A
+ fwD4AB8A8AAPAOAABwDAAAMAwAADAIAAAQCAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAABAIAA
+ AQCAAAMAwAADAOAABwDwAA8A+AAfAP4AfwD/gf8AKAAAABAAAAAgAAAAAQAIAAAAAAAAAQAAAAAAAAAA
+ AAAAAQAAAAEAAAAAAAAEFQ8ABRQQAA0WEAASFxAAERgVABEZGAAuHx4AAis4AAQsOABEIiQAH10nACFe
+ IQBsViIAHX1UACN5RQA8eE0AP31QAARdbwAEX3MAB1p0ABFdcAAZfWAANWxsACNldwB+e0AAp2pPAKx6
+ SwC4ZV4Au35dALVuZgC6amcAu29qAL1wbwC/dHAAvnV0AMh8ZgDIfmkAwHh0AD2VIgA4miUAP5okADSa
+ NgAykzkAOqAxADmjNABRlR0ARZkoAFqCOgBDnT0AYoA6AHSXOgBAoDIAS6EwAFShMABfpDIAWKA3AGKh
+ LwB2pDQAfqo+ACCHVgA4okEAOqlBADqsRgA6rUgAGoZrAECTTQBvgkwAdJZBAHeQZABgjnoAgYw/AIyq
+ MgCDrD4Akaw/ALurLgDTrjcA8rQmAP67IgD+vi0A/8E2APbAPgD/wjsAg45JAKePSgCKrkAAhalKAJ60
+ SwCerlQAobJDAKS0SQC5t0QArrZXALGRewCWtmEAqqxwALy9eADStEkA7r1OAOu+WgDrv14AyoFqAMqC
+ bgDKh3QAzIt0AMmHfADPjHgAz5V2ANeefwDcp3cA3qV5AO3FTwD2xUkA/spSAM/IcwDpymUA6ctoAPLH
+ aQDrxHEA7dJ7AP7TdAACb44AFWqKABtsigADcY4AAG6SAARukAAAb5QAAnGRAAxzkAARdpQAHnuSACN+
+ kwCGpYwAxYOEAMyMggDTloIA2qKCAMC1kQDNwoQA1MmSAOTHggDqw5UA9tuZAOLUogAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAP///wAAAAAAAAAiHx8hAAAAAAAAAAAAABpTjWRkdm0cAAAAAAAAh2xYPTlwUE9NYmuG
+ AAAAAIl1cyw/N29ST05LGQAAAAcGBQUBC0BVDQQEAwIKAAB9fX19fUE3XEZ9fX19egBmkH19DyoMCAhU
+ VhZ9gDEiJY+Af4WKFH19FTMOfYAoHmZefX0RGH2Eg30XEX2BWiBqJ319FICCjIuBfRR9gC8mADB9gH+A
+ QnJ4X319fX0yAAB9fX9/PDZ3dHFFfX19ewAAAEMrYC46VzVbUUxhXQAAAACIRy47WUlAP0hxbmkAAAAA
+ AAAbjkooLDREJQAAAAAAAAAAAABqHR1nAAAAAAAA/D8AAPAPAADAAwAAwAMAAIABAACAAQAAAAAAAAAA
+ AAAAAAAAAAAAAIABAACAAQAAwAMAAMADAADwDwAA/D8AACgAAAAwAAAAYAAAAAEAIAAAAAAAgCUAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAChMSsCoDErHKAwK0ifLytqny8rgZ4uK4yeLiuMnS0qgZ0t
+ KmqdLCpInCwqHJwrKgIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACiNCsIojMqT6EyKp+hMiveoDEq/aAxKv6gMCv/ny8q/p4v
+ Kv6eLiv/ni4q/p0tKv6dLCr/nCwp/ZwrKd6cKyqfmyopT5sqKggAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApDYrHaM2K42jNCvoozQr/qIzKv6hMiv/pjw1/rVf
+ Wf7Cenb/youG/s6Tjv7Nk47/yYqG/sB4dv6zW1n/ojc1/pwsKf6cKyr/nCsp/pwqKuibKimNmykpHQAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKU4KxGlNyuQpDYr96Y7MP+wUkn/wHZv/9Sh
+ mv/t0cP//vHV///twv//6LD//eOk//3gnf/84Jz//eKh//7nrf//7L///vDS/+zQwf/OlJD/q0xK/5ws
+ Kv+cKir/myoq95sqKpCbKioRAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApjkrUKY4K+WmOi7+slRK/sGM
+ fP6LoVz/TpMc/s3Ulv742pT/7sdu/uW6Wf7fsUz/2qtE/tioP/7Ypz7/2qk//t6uRf7ktk//7MJg/vbR
+ ef7+4pz//ezF/ubGuf+5aGf+nCwr/psqKv+aKSnlmikpUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKc6KwSnOiyRpjkr/aY5
+ LP+8amD+rLSD/kSNEP43iwv/NYkW/kJ8Dv6Znkv/2rBX/t6qOv7krDH/6a8v/uyxLv7tsSz/6q4p/uWq
+ J/7fpSb/2qIo/tqkLv7frD3/7L9X/vvXgf/+6rj+58i7/q9UU/+bKin+mikp/ZspKpGaKCkEAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAqDwsEag7
+ LLmoOyz/qT4v/9ObkP/979T/mbhh/zWFD/81lT7/NZQ9/zWNKf82gAT/iqc5/+3Oaf//xUL//8E4///B
+ Nv//wDP//78w//+/Lf//vir//Lsn//KzJP/nqiL/3aMm/92nMv/rvFD/+9iD//3rxP/Nk4//nS8u/5sq
+ Kv+bKSq5mykqEQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AACpPSwRqT0ryKg8K/6vSjv/5sS3/v/quf/21Ib+ra1f/jJ3Bv43n0L/OqpH/jqtSP45ozX/N4sJ/p6y
+ R/7/zl3//sRB/v7CPP7/wjn//sE2/v7AM/7/vy///r4s/v69KP7/vSX/+7ki/u6vIf/hpiX+4aw2/vLH
+ YP/+5aj+47+z/qU+Pv+bKyv+mykqyJsqKxEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAKo+KwSqPiy8qT0r/rBOPv7v1sb//uWr/vDJc//itVb+175u/jmEAv46qT//Oq1I/jqt
+ SP47rkn/OZwp/kGKCP60u1b//tFm/v7GRv7/wz///sI8/v7BOP7/wTX//sAx/v6/Lf7/vin//r0l/v+8
+ Iv/8uSD+7a4g/uKpK//su07+/eOi/tbOtP+0YmH+nS4u/psqKrybKioEAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAKs/LJarPyz/sU08/+/Xx//+46f/7cVu/+S2Vf/0wlT//tV4/26f
+ K/83jg//O61I/zuuSf87rkn/Oq1I/zmgMP84iAT/mLBG//zUcv//ylD//8VC///DPv//wjr//8E2///A
+ Mv//vy7//74p//+9Jf//vCH//7sf//e2H//mqyf/6cJr/0uOEf+HpFv/slxb/5wsLP+bKiqWAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAq0ArVatAK/2tRDH/6Me5/v7mrv7ux3L/6Lta/vnI
+ Wv/+zFv+/tBm/t7Pev43hwL/OqtE/jqtSP47rkn/Oq1I/jqtSP46pTr/N4oI/mydKP7s0XP//spR/v7G
+ RP7/xED//sI7/v7BN/7/wDL//r8u/v++Kf/+vCX+/rsh/v+7Hf/8uR7+67tN/lWJGP83hgH+mqVt/qtN
+ TP+bKir9mysrVQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACINCIVrEEs56xBLP/Xo5b//+u9//PO
+ fP/rvl///Mtf///OYf//zmP//9Bn//zbjv8+iQb/OqY6/zuuSf87rkn/O65J/zuuSf87rkn/OqpD/zeP
+ Ef9zoS3//tR0///IS///x0X//8RB///CPP//wTf//8Ay//+/Lf//vSj//7wk//+7IP//ux7/+8xW/0GB
+ CP82jR3/PYoI/6+be/+jPDz/mikp54YkJBUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABeJBiXNhUO/iUO
+ Cv41My//Ni8h/jIpFv40KhT/NiwV/jYsFf82LBb+Ni0Z/jMuH/4MHQD/DCML/hEyFf4gXyj/NqFD/jqt
+ SP47rkn/Oq1I/jqpQf43iQX/xcNl/v7OXv7+x0v/zJ84/mxTG/4/MA7/NikL/jYoCv82KAn+NigI/jYo
+ B/82KAb+NisS/g4dAf8LHwr+Cx0C/hkkEf8qFRT+PBAQ/ockJJcAAAAAAAAAAAAAAAAAAAAAAAAAAIEz
+ IyJBGRD5AAAA/gAAAP4AAAD/AAAA/gAAAP4AAAD/AAAA/gAAAP8AAAD+AAAA/gAAAP4AAAD/AAAA/gAA
+ AP4AAAD/ETMV/jinRv47rkn/Oq1I/jqtSP45miX/Ypoi/v3We/7JoEH/GBIH/gAAAP4AAAD/AAAA/gAA
+ AP8AAAD+AAAA/gAAAP8AAAD+AAAA/gAAAP8AAAD+AAAA/gAAAP8AAAD+AAAA/pEnJ/mQKCgiAAAAAAAA
+ AAAAAAAAAAAAAKFDLpU/IRv/ABoi/gAeKP4AHij/AB4o/gAeKP4AHij/AB4o/gAeKP8AHij+AB4o/gAe
+ KP4AHij/AB0n/gAWHf4ABQb/CBkK/jejRP47rkn/Oq1I/jqtSP46qkH/N4cC/tXLcv6vjkL/BgUC/gAH
+ Cv4AGCD/AB0n/gAeKP8AHij+AB4o/gAeKP8AHij+AB4o/gAeKP8AHij+AB4o/gAeKP8AHSf+ABYd/owv
+ Mf+YLCyVAAAAAAAAAAAAAAAArEYuD69GLfAFa47/AG6T/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+U/wBvlP8Ab5T/AG6T/wBtkv8AZIT/F3JZ/zmrSf87rkn/OqxG/zmiNP84lBn/N4cC/77C
+ Zv/pw2P/MGFe/wBniv8AbpL/AG6T/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8AbpP/AG2S/z1WbP+bKyrwmysqEAAAAAAAAAAAsEYsXLBGLP4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBu
+ k/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/B3eJ/jepTf44mSL/N4kF/kWN
+ Df6Mrkn/vcNs/vvYhv7RvWz/DnSQ/gBuk/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBv
+ lP8AbpP+AG6T/gBvlP8AbpP+AG6T/j9gd/+cLCv+nCsqXAAAAAAAAAAAsEcsqrBHLP4Eb5L/AG+U/gBu
+ k/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBuk/4Ab5T/AG6T/gBvk/4Ec47/IZNp/jij
+ P/4yeQD/qLFp/t3HjP7kxH7/5MBv/ui/ZP7wyGb/c5l8/glykf4Ab5P/AG6T/gBvlP8AbpP+AG6T/gBv
+ lP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/kVsgv+hNjT+nCwqqgAAAACxSC0FsUgt6bFH
+ Lf/a0sn/vcSf/5+ug/8GcZL/AG+U/wBvlP8Ab5T/AG+U/wBvlP8HaYj/K3tT/yGGTP8nmGL/KZtf/y6g
+ WP82qU7/OKE2/xg/Bv8DBgD/CQgG/wkIBf8JCAT/CQgE/xMPCP+zkkn//c1i/+fDYP/Btmn/m7B8/yV+
+ OP8ijFj/Em5h/wBpi/8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wZ2i/8omF//Kogz/4KlZv+oRUL/nCwq6Zws
+ KgWxSC0osUgs/rlZQP7+9N///N2X/ubKfP4JcpH/AG6T/gBuk/4Ab5T/AG6T/gBvlP8JY33+Pn4f/jiX
+ H/46rUf/OqtD/jqnPv44mSX/JFkC/gIJBf4ADxP/AA8U/gAPFP4ADxT/AA8U/gAOE/4nIxT/27JW/v7N
+ Xf7/03H/h6o8/jiQE/86rUj+H24//gBlhv8AbpP+AG6T/gBvlP8AbpP+AG6T/gl5h/86rEn+OJsp/mOg
+ N/+2Y2D+nSwq/pwsKiiySS1Wskks/sd6Zv7+8ND/+9qP/ufLfP4JcpH/AG6T/gBuk/4Ab5T/AG6T/gBv
+ lP8DYHb+LHQM/jeJBv43iAP/N4cB/jaGAP47dg7/ChQJ/gBEWv4AbJD/AGyQ/gBskP4AbJD/AGyQ/gBr
+ jv4AOUz/UkQj/vLEXf721oH/QosI/jmjNf86rUj+H24//gBlhv8AbpP+AG6T/gBvlP8AbpP+AG6T/gl5
+ h/86rUn+OaM3/j6KCP/Fh4P+ni8s/p0tKlazSi15s0ot/9KUgv/+7MT//NmK/+jMff8JcpL/AG+U/wBv
+ lP8Ab5T/AG+U/wBvlP8DYHb/V4s5/8DMjP/W16L/3dqo/+vatv9BPjb/ADdJ/wBskP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+U/wBvlP8Aao3/Ay47/4hvN//u04D/OYcC/zqkOP86rUj/H24//wBlhv8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+U/wl5iP86rUn/OqpD/zeGAf/Alof/oDEv/50tKnmzSi2Qs0os/tmkk/7+6r3//dmJ/ujM
+ fv4JcpL/AG6T/gBuk/4Ab5T/AG6T/gBvlP8IYnz+v7+f/v3kt/7+5Lb/+N+y/ndrVf4CKzn/AGqO/gBu
+ k/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5P/AGWH/g8qLv68n17/i6tA/jiQE/86rUj+H24//gBl
+ hv8AbpP+AG6T/gBvlP8AbpP+AG6T/gl5h/86rUn+Oq1H/jeIA/+6nYX+oDQx/p4tKpCzSy2cs0ss/t2t
+ nf7+6bn//dqL/ujRjv4JcpP/AG6T/gBuk/4Ab5T/AG6T/gBvlP8NZYD+y8Kk/v3mvP7947f/q5l7/gol
+ Lf4AZYf/AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBggP4uOCz/wrZn/kOM
+ Cv84lRv+H208/gBlhv8AbpP+AG6T/gBvlP8AbpP+AG6T/ghzff83jA3+OJUd/jeHAv+4oYf+oTUx/p4u
+ K5u0TC2dtEst/92unf/+6rz/+uGh/4yvXP8EcI//AG+U/wBvlP8Ab5T/AG+U/wBvlP8NZYH/fZ9h/8TP
+ lP/Ww6T/IDAx/wBffv8AbpP/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8AVXH/Wlc5/9rHb/9ZlRr/HV4i/wBlhv8Ab5T/AG+U/wBvlP8Ab5T/AG+U/yB7if+4t0X/iak2/2uh
+ M//PrJ//oDMu/54uK520TC2StEwt/tqmlf787sv/ha1K/jKEDP4Cb43/AG6T/gBuk/4Ab5T/AG6T/gBv
+ lP8FYXn+LXUN/meaN/5HTkn/AFZz/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG+T/jiHk/4rgJL/AG6T/gBu
+ k/4Ab5T/AG6T/gBuk/4AbpP/A01k/pF8QP/CwV/+H1oa/gBlhv8AbpP+AG6T/gBvlP8AbpP+AG6T/ih9
+ h//3y1X++9Vy/v7ptv/UoJv+nzAr/p4vKpK1TS18tU0u/tiikv6pxoH/N4YA/jKEDP4Cb43/AG6T/gBu
+ k/4Ab5T/AG6T/gBvlP8DYHf+K3kY/iNLEP4CTGT/AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5P/LIGU/trL
+ k/7Jw43/HHqS/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG2R/hJKVv+cmlD+KV8h/gBlhv8AbpP+AG6T/gBv
+ lP8AbpP+AG6T/id+jf9nmR/+Ypoh/luZI//Snpr+oDIs/p8vKn21TS1btk8w/9Scif84hgH/N4gE/zKF
+ D/8Cb47/AG+U/wBvlP8Ab5T/AG+U/wBvlP8DYnr/HWIz/wFDU/8AbpL/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8YeZT/xsSW//7akf/92Ir/r7aI/w50kv8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBrj/8LRz7/GE4c/wBl
+ hv8Ab5T/AG+U/wBvlP8Ab5T/AG+U/w10f/82hwT/OJAS/zmHA//JjYj/oTIs/6AwK1u1Ti4utk8v/s+J
+ dP48iQb/OZwp/jWjRv4CcJD/AG6T/gBuk/4Ab5T/AG6T/gBvlP8AXHn+AkFP/gBskP4Ab5T/AG6T/gBu
+ k/4Ab5T/AG6T/gtzk/6quJf//NqU/v3Zjv7+14f//NWA/o6nhP4EcJL/AG6T/gBuk/4Ab5T/AG6T/gBv
+ lP8AZ4r+AztD/gBlh/8AbpP+AG6T/gBvlP8AbpP+AG6T/ghzfv85ozf+OZ4s/lycLv+7bGf+oTIr/qAx
+ Ky62Ti4Itk8u7cNuU/5snDv/OJkj/jWoT/4CcJD/AG6T/gBuk/4Ab5T/AG6T/gBvlP8Aa4/+AGyQ/gBu
+ k/4Ab5T/AG6T/gBuk/4Ab5T/BXGU/oysmv772pb//dqQ/v3Yiv7+14T//dV9/vfQdv5rloH/AW6T/gBu
+ k/4Ab5T/AG6T/gBvlP8AbpP+AGqN/gBtkf8AbpP+AG6T/gBvlP8AbpP+AG6T/gl5h/86rUn+OJMX/oSp
+ W/+uTkf+oTIr7aEyKwgAAAAAtk8us71fQf+Wm1n/N4wM/zWoTv8CcJD/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8AbpL/LoNr/+3erP/94af//tuR//7Xhv/+1oD//tR5//7S
+ cv/vy23/R4aB/wBuk/8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wl5
+ h/86q0X/N4cD/6ugd/+nPjb/ojMrswAAAAAAAAAAtk8uZrhTM/7BkXD/OogE/jWfP/4CcJD/AG6T/gBu
+ k/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBuk/4Ab5T/AG6T/gBuk/4Qc2X/NYUK/j6JB/5zpDj/79yb/v3X
+ hf7+1Hv//dN1/v3Rbv7+z2f/3cBl/iZ3g/4AbpP/AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBv
+ lP8AbpP+AG6T/ghzff83jA7+S5IZ/sOEe/+jNi3+ojQrZgAAAAAAAAAAtlAvFrZQLvWtZE3/OFws/xNN
+ LP8AbY//AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wp1gP8znUD/OZwp/zmf
+ Lf83hgH/vMVz//7XhP/+03b//tJw//7Qav//zmP//81c/8KwXv8Pbof/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wZpgv8YSRr/UXBD/6tRSf+iNCv1ojUrFgAAAAAAAAAAAAAAAKtS
+ NKUaYXn/AGyQ/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBuk/4Ab5T/BG+H/i+e
+ Vf46rUn/Oqg//jeIBf6HrUf/99yW/v3UeP7+0nD//tBr/v7PZf7/zV7//stY/v7KUv6bm1r/BWyM/gBv
+ lP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AGqN/kxVY/+dOC+lAAAAAAAA
+ AAAAAAAAAAAAAGZcWTAAb5T/AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBu
+ k/4Baof/J45R/jqsRv46rEX/N48R/n+oP/793ZT//dR5/v3UeP7+1n7//tR1/v7OYv7/zFn//spT/v7J
+ Tf76xUf/a4FZ/gFsj/8AbpP+AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/j1Z
+ bP1yR0owAAAAAAAAAAAAAAAAAAAAAAAAAAABbpLxAG6T/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+U/wFskP8cbjj/OaM3/zeKCP83iAT/O4gE/+PUiv/+1Hf//tV6/+fUhv+KrEP/sLxe//7V
+ eP//y1X//8lO///ISf//xUP/77o9/z1rX/8AbZL/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG6T/yhgebUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3ZHMsdllO8GViYf5Wgn//GndJ/huD
+ YP4cimz/G4Nf/ip/WP95oI7+eZuA/pKlh/5Njxf/N4oI/keODv45hwL/kLBM/v3aiP7+0nD/6NSE/k6R
+ FP44kRT/OIcD/s/IbP7/0Gb//spS/v7GRP7/wz7//sI5/tqqNP9+j1f+eZFc/nmRWv95kFj+eZBZ/nmS
+ X/95mXP+eaae/mR6iP9dTFT+dEdJ8EhWZSkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApVM3abhT
+ MP7Hel//eZ1F/jeMC/46qkL/OaI0/keNDf/12Yz+/tN0/v7Xgf6zwGj/R40O/j2JBf43jg//VpQa/v3b
+ jv7/1n3/k7BJ/jiPEv46rUj/OJgh/kaNDP6cskj/4sxs/v7NWv7/xkT//sE2/v+/MP/+viv+/r0m/v+8
+ Iv/+vCH+/r4p/v/IRf/+3In+7tK//qtENv+mOSv+mT0zaQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAt1EvArhRLq26VjT/x4Vp/2aZNP83jQ3/OqlA/zeOD/9pnSn/x8Zt//vckP9woC//N4gF/zme
+ LP84lRz/O4gD/2ecJ//83ZH/WJUb/ziUGv86rEb/Oq1I/zmfLf84kBP/Q4sJ/4+rPP/Vxl7//8tS//+/
+ Lf//vSf//7wj//+8I///vyv//8hG///agv/14Mj/slNF/6g7LP+nOiytpjksAgAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAALhSLw+4US7Nu1k4/smLb/5omjb/N4wL/jmgMP83jQz+N4cC/mCZ
+ If68w2n/OIcD/jmiNP45mST/QosJ/oysQP7+2of/g6g6/jeHAv46qUH/Oq1I/jqtSP46rUj/OaI0/jiS
+ Fv45iAP/x79U/v/DOP/+vSX+/r0n/v/BMf/+y07+/tyJ/vbhyP+3XE7+qDwr/qg7LM2nOisPAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC4UjAYuFEu1rtZN/7KhWv/eZ5G/jeG
+ AP87iAX+N4YA/j+KB/7o1IP/YJkh/jeNDf43iAT/srxZ/v7Sa/7+1Xb/X5gf/jmcKf47rkn/Oq1I/jqt
+ SP47rkn/Oq1I/jqtSP44mCH/eqIr/v/LT//+vy7+/sU8/v/QXv/+4pz+79TA/rVWRv+pPSv+qT0r1qg8
+ LBgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAuFIwGLhR
+ Ls66VjT/x3le/7qwhf/X4LX/UZMZ/zeGAP/j1IT/daMy/2mdJ//EwmH//NNv///LVf/XyWn/OIcC/zqp
+ Qf87rkn/O65J/zuuSf87rkn/O65J/zuuSf86pDb/OogE/8vEXf//z13//9h6///rvP/fsqP/r0k2/6s/
+ LP+qPizOqT0sGAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAALhSLw+4US6tuFIv/rtZOf/NmoD+dJ9D/jqIBP7c15P//t6S/v7Zgf7+1nn/+dR2/v3V
+ dv5xnyr/OJQb/jqtSP47rkn/Oq1I/jqtSP47rkn/Oq1I/jqtSP46rUf/OJMY/n6pP//+6rn+89zG/sZ8
+ bP+sQSv+q0Ar/qs/LK2qPisPAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC4US4Ct1EubbdQLvO6WDf+xnRa/sujhv7149L//u3E/v7m
+ rP6guVz/RYwM/lGRFP43igj/OqpC/jqtSP47rkn/Oq1I/jqtSP46qkL/OaM1/jiZIv43jAv/P4oK/oqr
+ Xv/VnZD+sUo1/q1CLP+sQSzzrEArbatALAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALhRLyS4US6vt1Au/bhT
+ Mv+5VDP/y4Fp/+jFtv9/q1X/PIkG/zeGAP83iQX/N40O/ziPEf84jxH/N40N/zeKB/83hgH/QowO/26g
+ QP+ho2r/xpN8/71mUv+xSzT/rkMt/a1DLK+sQiwkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAt1AuMbZPLau3Ty74tk8t/rlXOP7FcVf/0I96/rqWcP6zn3P/qKFs/qGhaP6hoWj/qKFt/rSf
+ dP6+l3b/zYp4/r9pU/63Vj7/sUox/rBFLfivRS2rrkUuMQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC2Ty4dtk8ucrZPLr+2Ti70tlAw/rdTNP64VDb/uVc5/rlY
+ O/64Vzv/t1U5/rZRNf60TjP/skou/rFILfSxSC2/sEcucrBHLh0AAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC2Ty8Ntk8vO7VO
+ Lmi1TS6LtU0uobRMLay0TC2ss0stobNLLYuzSi1oskouO7FJLg0AAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD//8AD//8AAP/+
+ AAB//wAA//gAAB//AAD/4AAAB/8AAP/AAAAD/wAA/wAAAAD/AAD+AAAAAH8AAPwAAAAAPwAA+AAAAAAf
+ AAD4AAAAAB8AAPAAAAAADwAA4AAAAAAHAADgAAAAAAcAAMAAAAAAAwAAwAAAAAADAACAAAAAAAEAAIAA
+ AAAAAQAAgAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAAAAAAAEAAIAA
+ AAAAAQAAgAAAAAABAADAAAAAAAMAAMAAAAAAAwAA4AAAAAAHAADgAAAAAAcAAPAAAAAADwAA8AAAAAAP
+ AAD4AAAAAB8AAPwAAAAAPwAA/gAAAAB/AAD/AAAAAP8AAP+AAAAB/wAA/+AAAAf/AAD/+AAAH/8AAP/+
+ AAB//wAA///AA///AAAoAAAAIAAAAEAAAAABACAAAAAAAIAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAChMisOoDErSqAwK36fLyugni8rsZ4u
+ KrGdLSqgnSwqfpwrKkqcKyoOAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKQ2KwGjNStLojQrsKIzK/mhMyv/rEpE/7hk
+ X/++cWz/vXBs/7ZiX/+pRkP/nSwq/5wrKvmbKiqwmyoqS5sqKgEAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAClOCs3pTgsyqpEOf+wdV//yKmP//be
+ u//85Kz/9deR//HQg//xz4L/9NWN//vipv/23LX/2KaX/7NdWv+bKir/myoqypsqKjcAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACnOiwCpzosgKY5LPy/c2n/ephH/zyO
+ E/9XjiL/w7Fg/9urQv/hqzT/5aww/+WsLf/iqSz/3KUu/9+sO//rv1r/+duT/+jEqf+yWlj/myoq/Jsp
+ KoCbKSoCAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAqTwsB6g8LK2pPi//1qGR//rn
+ u/87gw//NZY//zeZOP9EjBP/ubtQ///FQ///wTj//8A0//+/L//+viv/+Lgm/+2uI//gpyr/6rpM//re
+ mv/Smo7/nC0t/5spKq2bKSoHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKo+LAKqPiyvrEQ0/+fB
+ rP/42JH/5bxm/2CQIv86qkT/O65J/zqrQ/9Qkxb/3cdg///HSP//wz3//8E4///AMv//vy3//70n//67
+ Iv/xsSH/5Kww//bPdv/avKb/p0ZF/5sqKq+bKSoCAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAq0AshKxC
+ L//nwq3/9tWL/+i7Wf/6yVv/tbxY/ziXH/87rkn/O65J/zqnPf9FkhX/xMBZ///LVf//xEH//8I7///A
+ NP//vy7//70n//+8If/7uB7/6rEw/4ShN/+Fl1L/pT8//5sqKoQAAAAAAAAAAAAAAAAAAAAAAAAAAJs7
+ JzqsQSz82qeV//nbmP/twGD//cxf///OYf/41n//O5AT/zuuSf87rkn/O65J/zqrRP84khb/uLxV///K
+ UP//xUP//8I8///ANP//vy3//70m//+7IP/+vij/f5or/zeJDf+aj2H/nzIy/JEnJzsAAAAAAAAAAAAA
+ AACDMyEBRxsSzhoKB/8kIR3/IhwQ/yMcDf8kHQ7/JB0P/yIfE/8IFAH/Ch8N/xpPIf84pkX/O65J/zqs
+ Rf9Kkxf/99Ft/96vQv9YRBf/KB4J/yQbB/8kGwX/JBoF/yQbBf8SFwX/BxQF/w4WB/8eDAz/ax0dzpAn
+ JwEAAAAAAAAAAJ9CLVAqGRb/ABQa/wAUGv8AFBr/ABQa/wAUGv8AFBr/ABQa/wAUGv8AEBX/AAMD/yp9
+ NP87rkn/O65J/zmbKP+tuVP/emIs/wADBP8AERf/ABQa/wAUGv8AFBr/ABQa/wAUGv8AFBr/ABQa/wAS
+ Gf9fIiT/mCsrUAAAAAAAAAAArkYuugJtkf8AbpP/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBu
+ k/8BZYH/MJ9S/zqoP/85myf/PY8S/6i4Vv+up2b/AWWG/wBuk/8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG6T/ylfev+bKyq6AAAAALBHLROwRy37Am+T/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+T/wd2iv8wn1D/SIkW/6ayYP/lyoL/7shx/7+2bv8Udo//AG+T/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+U/wBvlP8Ab5P/LWuG/54wL/ucKyoTsUgtU7JJLv/h28T/vbyG/wVwkv8Ab5T/AG+U/wBv
+ lP8eb3v/KIY0/y6gWf8xpFT/OKVA/xxJC/8DBAH/BgUD/wYFA/8KCAT/sZBH//PJX//RwXP/Qow2/yiS
+ VP8DYXj/AG+U/wBvlP8Ab5T/BHSN/y6dUv9imkT/pkE+/5wsKlOySS2HvmVN//7rwf/tz3//BnGS/wBv
+ lP8Ab5T/AG+U/w5iWP83jAz/OJMZ/zeQEv8vZgv/AiYt/wBSbf8AU27/AFNu/wBRbP8ZLy7/3rNV/8nD
+ Yf84lh7/N6NF/wRdbv8Ab5T/AG+U/wBvlP8GdYz/OqxJ/0GRGP+2ZGH/nSwqh7NKLanJfmj//uay/+/P
+ fv8GcZL/AG+U/wBvlP8Ab5T/FmZg/8nPkf/k3Kn/28ul/x4yNv8AZon/AG+U/wBvlP8Ab5T/AG+U/wBj
+ hP9FSDH/urpc/ziXH/83o0X/BF1u/wBvlP8Ab5T/AG+U/wZ1jP86rUn/OJIW/7V3a/+dLSqqs0stu86L
+ dv/+5az/79KH/wZxk/8Ab5T/AG+U/wBvlP88eYX//eW6//fesv9JTkX/AGCA/wBvlP8Ab5T/AG+U/wBv
+ lP8Ab5T/AG+U/wBZd/9/dEv/Xpkh/zaYMP8EXW7/AG+U/wBvlP8Ab5T/BnOH/ziZJP83jxH/sn9s/54u
+ K7u0TC28z4x3//3ouP+Mr1X/Am+Q/wBvlP8Ab5T/AG+U/yZucf+TtWL/hH9u/wBWcv8AbpP/AG+U/wBv
+ lP8CcJP/AW+T/wBvlP8Ab5T/AG+U/wdSaf+tm1b/XJEf/wRba/8Ab5T/AG+U/wBvlP8Xd4z/yLtG/6C4
+ Vv/Bgnr/ni8rvLRNLavNhnD/nb1v/zSECP8Bb4//AG+U/wBvlP8Ab5T/DWRb/zVtEv8IUGf/AG6T/wBv
+ lP8Ab5T/AW+U/4mpk/93oJD/AG+T/wBvlP8Ab5T/AG6T/x9XXv+MmkL/BFlo/wBvlP8Ab5T/AG+U/xp5
+ jv+NqDL/mrZU/8J6dv+fLyustU0uisqAaf83iQb/NI0X/wFvkP8Ab5T/AG+U/wBvlP8JXmP/B05V/wBu
+ k/8Ab5T/AG+U/wBvk/9lmpX/+tmS//fViP9Sj4z/AG+U/wBvlP8Ab5T/AG2R/w1OPv8DWGr/AG+U/wBv
+ lP8Ab5T/B3KF/ziTGf8+jA3/umpl/6AxK4q2Ti5YwWhN/1GTIf83qUv/AXCR/wBvlP8Ab5T/AG+U/wBi
+ g/8AbZH/AG+U/wBvlP8AbpP/RY2W//TXlv/+2Y3//taD/+3Nev8ygYr/AG6T/wBvlP8Ab5T/AGuO/wBk
+ hf8Ab5T/AG+U/wBvlP8GdIr/OqpD/2OcNv+rSUL/oTIrWLZPLhi6Vzj9fpNA/zaeOP8BcJH/AG+U/wBv
+ lP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/whxev+Ssmb/69mW//7Yif/+1X3//tJz/9rBbf8WdYz/AG+U/wBv
+ lP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wZ0if84mib/i5VV/6Q5Mf2hMysYAAAAALZQL8GUdE3/IGQk/wBu
+ kf8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8EcYv/L5E1/ziWHv9Xlh7//tuP//7Tdv/+0Wz//s5i/7iu
+ Y/8Hbo7/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/BG2H/yRgD/+hcFz/ozUrwQAAAAAAAAAAn1M6Wwto
+ hv8AbpP/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AW2O/ymXW/86rEb/PpEU/8bHdP/+1Xz//tFv//7P
+ Zf//zFz//spS/4uWXv8AbZH/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG6T/y9dc/+YOTJbAAAAAAAA
+ AABGYmsDAG6T+QBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBukv8ee0f/OZsn/ziQE/+etlX//tV6//TV
+ gf+yvFv/9NFz///LVP//yEv/+8NC/1Z7X/8AbpP/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/H2N/3WZL
+ UgMAAAAAAAAAAAAAAABYXmBMg1tO/meFav8khED/JpZg/zKFQf+lsof/sLOB/1eWIP9Ciwr/PYkG/+fS
+ gP/+1n3/Zp0o/ziWHv+Cpzb//dJt///ITP//wjz/7rc0/6ifSf+mn0j/pp9G/6aiT/+msoL/ioiK/3lF
+ Rf5gTlZKAAAAAAAAAAAAAAAAAAAAAAAAAAC3US+UwmtN/3CVOP85nCj/OJQb/6i4Vf/114T/daM0/zqT
+ GP84kBP/fqY3/9vNd/83jxH/Oq1H/zmbJ/9DkBL/pbNE/+zIV///wTP//70n//+8I///vy3//9Fj/+zJ
+ q/+rQjP/pjoslAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALhRLge4Ui+6wnFS/3OXO/84lBr/N4kG/0mO
+ D/+gtVH/OJYe/zqQE/+jtEz/6NF4/zmLCv86rEX/O65J/zqsRv85nSv/TJIV//rIS///vSf//8I2///U
+ bv/syqv/r0s7/6g8LLqnOiwHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALhRLgu4Ui+7wWpM/5mc
+ XP+KtFz/PIgE/8zJcv9Ukxf/qrZN///PYP+xuE7/OZwo/zuuSf87rkn/O65J/zuuSf84mCL/s7dG///M
+ VP//35P/37CZ/65GNP+qPiy7qTwsCwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALhR
+ Lge4US6UuVUz/rqLZf90nUH/7+Gn///cjP/dy23/ycJa/1GUGP86q0T/O65J/zuuSf87rkn/Oq1H/zmg
+ L/9fmib/8te3/8Z6aP+sQSz+q0AslKo+LAcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAC3US5KuFEv271dPv/OiHD/6siw/2ifN/83hgD/N48Q/ziZI/84mSP/OJYe/ziQ
+ E/9Ulyb/hZhM/7OGY/+zTjj/rUMs26xBLEoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC3UC4Et08uXrZPLsi4UjL+wmtQ/7+BYf+0iWH/q41e/6yM
+ Xv+0iGL/v39j/71kTf+0Tzb+sEYtyK9FLV6uQy0EAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALZPLh62Ty5gtU4uk7VN
+ LrW0TC3GtEstxrNKLbWySi2TsUktYLFILR4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAP/gB///AAD//gAAf/gAAB/wAAAP4AAAB+AAAAfAAAADgAAAAYAAAAGAAAABAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAAAAGAAAABgAAAAcAAAAPgAAAH4AAAB/AA
+ AA/4AAAf/gAAf/8AAP//4Af/KAAAABgAAAAwAAAAAQAgAAAAAABgCQAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACHKyMCoTIqO6AxK36fMCusny8rwp4uKsKdLSqsnCwpfpwr
+ KjuFJCQCAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkzEmBKQ2
+ K2mnPjTctmBY/syMfv/dq5D/5LiV/+S4lP7cqY//yol8/qxOS/+cKyrcmyopaY4mJgQAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAClOSslpjkrzLBrV/5ykT3+ZZs1/ta8af7hsET+4q04/uKs
+ NP7hrTj+5rZM/vHOff7mvJb+s11Z/psqKcyaKSklAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKk8
+ LDqqPy/t2KGM/s7Kh/81jCX/N549/kyVH//ixVT//8I7//7BNf7/vy7/+7oo/u+xJP/mrjL/8813/tOa
+ hv+dLy/tmykqOgAAAAAAAAAAAAAAAAAAAAAAAAAAqj8rJ6xCMO7jt5z/8Mp4/uvDZP9Glx//Oq1I/jqp
+ Qf9anCX/5MdZ//7FQ/7/wjn//sAx/v++Kf/+uyL/8bIi/u7DYP+XmWD/oTg47psqKicAAAAAAAAAAAAA
+ AACGMyIFrEErztumj/7zzn/+98dd/v7OY/6Ur0T+OqtE/jqtSP46q0X+RZgh/tfEWf7+xkX+/sI8/v7A
+ Mv7+vin+/rsg/vi+OP5BhxD+jIZP/p0vL86LJSUFAAAAAAAAAABjJhltFwgG/hsYFP8ZFAr/GxYK/hsW
+ C/8QEgj/BxUI/hpNIP86rEj/OqxH/2agLP7xw1n/VEEW/h0WBv8bFAT/GxQD/hsVBv8GDwP/CRAE/hkJ
+ Cf+NJiZsAAAAAJQ8JwNlRUHhAEVc/gBGXv8ARl7/AEZe/gBGXv8ARl7/AERa/gg9O/85qkj/OqpD/ziT
+ F/7Lt2D/DTU9/gBEW/8ARl7/AEZe/gBGXv8ARl7/AEZe/gBEWv9/NzzhkCcnBLBHLEFZWmD+AG+T/gBu
+ k/4AbpP+AG6T/gBuk/4AbpP+AG6T/gt7hf42mCz+gKNC/sS9aP7px2/+InuM/gBvk/4AbpP+AG6T/gBu
+ k/4AbpP+AG6T/gBuk/5wTFb+nCsqQbFILYXQmoX/z8aN/gRwk/8Ab5T/AG6T/h5xXf8vmEX/M6NO/jOP
+ K/8HFwj/BAwN/wQMDP47NR7/78Rd/ri5ZP8ukjv/DGps/gBvlP8Ab5T/A3OO/jGaQf+Re1D/nCwqhbJJ
+ LbPlu5//8tOE/gRwk/8Ab5T/AG6T/iJwTP+BrU7/jbBY/iJAJf8AY4P/AG2S/wBtkv4AX3//dGk8/piv
+ Q/86qD//D2li/gBvlP8Ab5T/BHSN/jqqQ/9+i0X/ni4ss7NLLcrsyar/89SI/gRwk/8Ab5T/AG6T/miS
+ kP/95Lj/iYJs/gBaeP8Ab5T/AG+U/wBuk/4Ab5T/A1hy/o6OTP87lyD/D2li/gBvlP8Ab5T/BHKL/jmf
+ Lv94k0T/nzEuyrRMLcvsy67+j7BV/gFvkf4AbpP+AG6T/i92Wv6Snm7+CFVt/gBuk/4AbpP+DnWT/gpz
+ k/4AbpP+AG6T/hdaaP6ipkr+D2BS/gBuk/4AbpP+EnWO/s3AUP7Dton+nzAsy7VNLrWjo2f/NIYI/gFv
+ kP8Ab5T/AG6T/hNnT/8JUlb/AG6T/gBvlP8GcZT/sruT/6SzjP4DcJP/AG6T/gBuk/8uZV3/EF5S/gBv
+ lP8Ab5T/DXSN/k6TFv+Mk1L/oDErtbZOLoiOh0L+N6A4/gFvkv4AbpP+AG6T/gBdev4AbpP+AG6T/gFv
+ lP6PrJf+/dmP/v3Wgv59n4P+AG6T/gBuk/4AbZH+AF56/gBuk/4AbpP+BHKL/jmgMf6SgE7+oTIriLZP
+ LkazeE//N5cn/gFvkv8Ab5T/AG6T/gBvlP8Ab5T/AG6T/h16W/+nu2X/+tmO//3Uev76z23/U4t//gBu
+ k/8Ab5T/AG6T/gBvlP8Ab5T/BHKL/jyUHP+uZlX/oTMrRqRJKwWKWkrmEmFf/gBukv8Ab5T/AG6T/gBv
+ lP8Ab5T/D3x8/jikPP9Llh7/7NOB//7ScP7+z2T/78RZ/ix5gP8Ab5T/AG6T/gBvlP8Ab5T/AW2P/hpk
+ X/+ORUHmnTIqBQAAAAAhaICIAG6T/gBuk/4AbpP+AG6T/gBuk/4HbXn+NJo2/jmTGP7Xy3X++NR8/s7F
+ Zf7+zmL+/slO/tWxSP4PbYX+AG6T/gBuk/4AbpP+AG6T/gBuk/5HVmZ4AAAAAAAAAAA4YnALjlhG1WyE
+ W/8qkUb/MYw+/rm6g/+ks2L/QIsK/laWHv/+14H/gKk8/zmXIP6stkr/98pX/v/DPP/Vrjn/vKdA/ryn
+ P/+8tGj/no6H/oRCP9VPU2AKAAAAAAAAAAAAAAAAuFEuL71hQfJ0kzn/OJkj/meeKf+itlL/OJQa/juQ
+ E/+7wGD/UpYc/zqsRv45ojT/UZsk/rW2Qv//vyz//r4o/v/MUv/ovpj/q0Ey8qc6LC8AAAAAAAAAAAAA
+ AAAAAAAAAAAAALhRL0G+YUHyjJNK/magNf6QrkT+Xpki/qq2S/71z2j+Q5kj/jqtSP46rUj+Oq1I/kqZ
+ Iv7yx07+/tZ0/t+sjf6tRDLyqTwrQQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC4US4vuFMx17CB
+ Vf+1uXz//uOh/re8Vf99pC//OqY7/zqtSP46rUf/OqY6/jqWHf+3t3r/xnll/qxBLNerPywvAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAsk4sCbdQLne3UTDoyXth/pSNS/93kTr/bpg9/26Y
+ Pf54kT3/j4hG/rR1Vf+zTzjorkMtd6pBKwkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAACtSysHtk8uTLZPL4+2UTK8t1I00rZRM9K0TTG8skkuj7BHLUyqRCsHAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAP4AfwD4AB8A8AAPAOAABwDAAAMAgAABAIAAAQAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAABAIAAAQDAAAMA4AAHAPAADwD4AB8A/gB/ACgA
+ AAAQAAAAIAAAAAEAIAAAAAAAQAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAcSUeE58y
+ Km2jNzGxrU1I06xLSNOgMjCxmiopbm8eHhMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApDgrbaJi
+ RfGDjkn/5MeC/+u/Xv/rvlr/68Rx/9ynd/+0XVXxmikpbQAAAAAAAAAAAAAAAAAAAAAAAAAAqj8umNee
+ f/+erlT/OKJB/2KhL//2xUn//8E2//29LP/ytCb/7r1O/8+Vdv+eMDGYAAAAAAAAAAAAAAAApT4qb9qi
+ gv/yx2n/6cpl/zqgMf86rEb/X6Qy/+3FT///wjv//78u//67Iv+7qy7/fntA/5krK28AAAAAbSsdFCMU
+ EvIRGRj/ERgU/xEZFv8EFQ//H10n/zqtSP+KrkD/bFYi/xMXEP8SFxD/DRYQ/wUUEP86FxnydCAgFK1F
+ LHIBbpP/AG+U/wBvlP8Ab5T/AG6T/xqGa/9YoDf/rrZX/2COev8AbpP/AG+U/wBvlP8Ab5T/FWqK/5ws
+ K3K1UDW24tSi/wJvk/8Ab5T/I3lF/zSaNv8hXiH/Ais4/wQsOP+nj0r/halK/xl9YP8Ab5T/AnKQ/0Od
+ Pf+lPz22v2dO2Pbbmf8DcJP/AG+U/4aljP/AtZH/B1p0/wBvlP8Ab5T/EV1w/3SXOv8dfVT/AG+U/wNx
+ jv84miX/qFRL2MFrUNmWtmH/AW+R/wBvlP8/fVD/I2V3/wBuk/8jfpP/HnuS/wBvlP81bGz/PHhN/wBv
+ lP8Mc5D/pLRJ/7BWUdm9YUS4PZUi/wBvkv8Ab5T/BF9z/wBuk/8RdpT/1MmS/83ChP8Mc5H/AG6T/wRd
+ b/8Ab5T/A3GO/0WZKP+pRT+4tlEwdVqCOv8Ab5L/AG+U/wBvlP8Bb5H/QJNN/8/Ic//+03T/qqxw/wFu
+ kv8Ab5T/AG+U/wJvjv9igDr/ojUsdWhCNRcDbZD9AG+U/wBvlP8AbpP/IIdW/1ShMP/t0nv/6cto//7K
+ U/93kGT/AG6T/wBvlP8Ab5T/E2eG9nQyLhcAAAAAj1dEd2+CTP8ykzn/vL14/1KWHf92pDT/nrRL/0uh
+ MP+5t0T/9sA+/9OuN//StEn/sZF7/4dCPXcAAAAAAAAAAGYtGQG6WTiggYw//1GVHf9+qj7/obJD/4Os
+ Pv86rUj/OqlB/4yqMv//y1H/3qV5/6pAL6BnJBsBAAAAAAAAAAAAAAAAaC4aAbhSL3epdkX26sOV/5Gs
+ P/8/miT/OaM0/0CgMv90lkH/xnhh9qxALHdpJhsBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkT8kGLdQ
+ L3m7YkO8smxG3rFrRt64XUO8sUkveZA4JRgAAAAAAAAAAAAAAAAAAAAA8A8AAOAHAADAAwAAgAEAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAEAAIABAADAAwAA8A8AAA==
+</value>
+ </data>
+</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestExplorer.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestExplorer.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestExplorer.Designer.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,158 @@
+ partial class RestExplorer
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Component Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.components = new System.ComponentModel.Container();
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(RestExplorer));
+ this.toolStrip1 = new System.Windows.Forms.ToolStrip();
+ this.btnConnect = new System.Windows.Forms.ToolStripButton();
+ this.btnRefresh = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator2 = new System.Windows.Forms.ToolStripSeparator();
+ this.btnNew = new System.Windows.Forms.ToolStripButton();
+ this.btnAddFile = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator1 = new System.Windows.Forms.ToolStripSeparator();
+ this.btnEdit = new System.Windows.Forms.ToolStripButton();
+ this.btnDelete = new System.Windows.Forms.ToolStripButton();
+ this.trvRestExplorer = new System.Windows.Forms.TreeView();
+ this.imgIcons = new System.Windows.Forms.ImageList(this.components);
+ this.toolStrip1.SuspendLayout();
+ this.SuspendLayout();
+ // toolStrip1
+ this.btnConnect,
+ this.btnRefresh,
+ this.toolStripSeparator2,
+ this.btnNew,
+ this.btnAddFile,
+ this.toolStripSeparator1,
+ this.btnEdit,
+ this.btnDelete});
+ resources.ApplyResources(this.toolStrip1, "toolStrip1");
+ // btnConnect
+ this.btnConnect.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ resources.ApplyResources(this.btnConnect, "btnConnect");
+ this.btnConnect.Name = "btnConnect";
+ this.btnConnect.Click += new System.EventHandler(this.btnConnect_Click);
+ // btnRefresh
+ this.btnRefresh.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ resources.ApplyResources(this.btnRefresh, "btnRefresh");
+ this.btnRefresh.Name = "btnRefresh";
+ this.btnRefresh.Click += new System.EventHandler(this.btnRefresh_Click);
+ // toolStripSeparator2
+ this.toolStripSeparator2.Name = "toolStripSeparator2";
+ resources.ApplyResources(this.toolStripSeparator2, "toolStripSeparator2");
+ // btnNew
+ this.btnNew.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ resources.ApplyResources(this.btnNew, "btnNew");
+ this.btnNew.Name = "btnNew";
+ this.btnNew.Click += new System.EventHandler(this.btnNew_Click);
+ // btnAddFile
+ this.btnAddFile.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ resources.ApplyResources(this.btnAddFile, "btnAddFile");
+ this.btnAddFile.Name = "btnAddFile";
+ this.btnAddFile.Click += new System.EventHandler(this.btnAddFile_Click);
+ // toolStripSeparator1
+ this.toolStripSeparator1.Name = "toolStripSeparator1";
+ resources.ApplyResources(this.toolStripSeparator1, "toolStripSeparator1");
+ // btnEdit
+ this.btnEdit.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ resources.ApplyResources(this.btnEdit, "btnEdit");
+ this.btnEdit.Name = "btnEdit";
+ this.btnEdit.Click += new System.EventHandler(this.btnEdit_Click);
+ // btnDelete
+ this.btnDelete.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ resources.ApplyResources(this.btnDelete, "btnDelete");
+ this.btnDelete.Name = "btnDelete";
+ this.btnDelete.Click += new System.EventHandler(this.btnDelete_Click);
+ // trvRestExplorer
+ resources.ApplyResources(this.trvRestExplorer, "trvRestExplorer");
+ this.trvRestExplorer.ImageList = this.imgIcons;
+ this.trvRestExplorer.Name = "trvRestExplorer";
+ this.trvRestExplorer.AfterExpand += new System.Windows.Forms.TreeViewEventHandler(this.trvRestExplorer_AfterExpand);
+ this.trvRestExplorer.AfterSelect += new System.Windows.Forms.TreeViewEventHandler(this.trvRestExplorer_AfterSelect);
+ // imgIcons
+ this.imgIcons.ImageStream = ((System.Windows.Forms.ImageListStreamer)(resources.GetObject("imgIcons.ImageStream")));
+ this.imgIcons.TransparentColor = System.Drawing.Color.Transparent;
+ this.imgIcons.Images.SetKeyName(0, "folder-horizontal.png");
+ this.imgIcons.Images.SetKeyName(1, "document-share.png");
+ this.imgIcons.Images.SetKeyName(2, "document-sub.png");
+ this.imgIcons.Images.SetKeyName(3, "server.png");
+ // RestExplorer
+ resources.ApplyResources(this, "$this");
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.Controls.Add(this.trvRestExplorer);
+ this.Name = "RestExplorer";
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.TreeView trvRestExplorer;
+ private System.Windows.Forms.ToolStripButton btnNew;
+ private System.Windows.Forms.ToolStripButton btnEdit;
+ private System.Windows.Forms.ToolStripButton btnAddFile;
+ private System.Windows.Forms.ToolStripSeparator toolStripSeparator1;
+ private System.Windows.Forms.ToolStripButton btnDelete;
+ private System.Windows.Forms.ImageList imgIcons;
+ private System.Windows.Forms.ToolStripButton btnConnect;
+ private System.Windows.Forms.ToolStripSeparator toolStripSeparator2;
+ private System.Windows.Forms.ToolStripButton btnRefresh;
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestExplorer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestExplorer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestExplorer.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,241 @@
+#region Disclaimer / License
+// Copyright (C) 2015, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion Disclaimer / License
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Drawing;
+using System.Data;
+using System.Linq;
+using System.Text;
+using System.Threading.Tasks;
+using System.Windows.Forms;
+using Maestro.Shared.UI;
+using RestSharp;
+using Maestro.AddIn.Rest.Model;
+using Maestro.Base.Services;
+ internal partial class RestExplorer : SingletonViewContent
+ private RestClient _client;
+ public RestExplorer()
+ InitializeComponent();
+ this.Title = this.Description = Maestro.AddIn.Rest.Strings.RestExplorer;
+ public override ViewRegion DefaultRegion
+ get
+ return ViewRegion.Right;
+ public override bool AllowUserClose
+ get
+ return false;
+ private bool IsConnected
+ get { return _client != null; }
+ private void btnConnect_Click(object sender, EventArgs e)
+ var diag = new RestLoginDialog();
+ if (diag.ShowDialog() == DialogResult.OK)
+ _client = diag.GetClient();
+ DoRefresh();
+ private void DoRefresh()
+ _client.ExecuteGetRequestAsync<DataConfigurationResponse>("data/configs.json", (resp, ex) =>
+ this.UIThreadInvoke(() =>
+ if (ex != null)
+ ErrorDialog.Show(ex);
+ return;
+ var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ foreach (var name in connMgr.GetConnectionNames())
+ var conn = connMgr.GetConnection(name);
+ var param = conn.CloneParameters;
+ if (resp.DataConfigurationList.MapAgentUrl.IndexOf(param["Url"] ?? Guid.NewGuid().ToString()) >= 0)
+ _conn = conn;
+ break;
+ if (_conn == null)
+ //Ask if the user wants to add this connection to the Site Explorer
+ PopulateTree(resp);
+ btnRefresh.Enabled = true;
+ btnNew.Enabled = true;
+ const int IDX_FOLDER = 0;
+ const int IDX_CONFIG = 1;
+ const int IDX_FILE = 2;
+ const int IDX_SERVER = 3;
+ private void PopulateTree(DataConfigurationResponse resp)
+ var list = resp.DataConfigurationList;
+ try
+ trvRestExplorer.BeginUpdate();
+ trvRestExplorer.Nodes.Clear();
+ var root = trvRestExplorer.Nodes.Add(list.RootUri);
+ root.ImageIndex = root.SelectedImageIndex = IDX_SERVER;
+ foreach (var conf in list.Configuration)
+ string name = conf.ConfigUriPart;
+ if (name.EndsWith("/config"))
+ name = name.Substring(0, name.Length - "/config".Length);
+ var node = root.Nodes.Add(name);
+ node.Tag = conf;
+ node.ImageIndex = node.SelectedImageIndex = IDX_CONFIG;
+ node.Nodes.Add("dummy"); //HACK: To show the "+" beside the node
+ root.Expand();
+ finally
+ trvRestExplorer.EndUpdate();
+ private void trvRestExplorer_AfterSelect(object sender, TreeViewEventArgs e)
+ var conf = e.Node.Tag as DataConfiguration;
+ btnDelete.Enabled = btnEdit.Enabled = false;
+ if (conf != null)
+ btnDelete.Enabled = btnEdit.Enabled = btnAddFile.Enabled = true;
+ private void LoadConfig(string json, string uriPart, bool isNew)
+ new RestConfigurationEditor(_conn, _client, json, uriPart, isNew).ShowDialog();
+ private void trvRestExplorer_AfterExpand(object sender, TreeViewEventArgs e)
+ if (conf != null && e.Node.Nodes[0].Text == "dummy")
+ e.Node.Nodes.Clear();
+ var req = new RestRequest(conf.ConfigUriPart.Replace("/config", "/files.json"));
+ _client.ExecuteAsync<DataFileListResponse>(req, (resp) =>
+ var list = resp.Data.DataConfigurationFileList;
+ foreach (var file in list.File)
+ var n = e.Node.Nodes.Add(file);
+ n.ImageIndex = n.SelectedImageIndex = IDX_FILE;
+ private void btnEdit_Click(object sender, EventArgs e)
+ var conf = trvRestExplorer.SelectedNode.Tag as DataConfiguration;
+ if (conf != null)
+ var req = new RestRequest(conf.ConfigUriPart);
+ _client.ExecuteAsync(req, (resp) =>
+ var json = resp.Content;
+ LoadConfig(json, conf.ConfigUriPart, false);
+ private void btnDelete_Click(object sender, EventArgs e)
+ if (conf != null)
+ if (MessageBox.Show(Maestro.AddIn.Rest.Strings.PromptDeleteConfiguration, Maestro.AddIn.Rest.Strings.DeleteConfiguration, MessageBoxButtons.YesNo) == DialogResult.Yes)
+ var req = new RestRequest(conf.ConfigUriPart, Method.POST);
+ req.AddHeader("X-HTTP-METHOD-OVERRIDE", "DELETE");
+ if (resp.StatusCode == System.Net.HttpStatusCode.OK)
+ MessageBox.Show(Maestro.AddIn.Rest.Strings.ConfigurationDeleted);
+ this.DoRefresh();
+ else
+ MessageBox.Show(resp.Content);
+ private void btnAddFile_Click(object sender, EventArgs e)
+ private void btnNew_Click(object sender, EventArgs e)
+ LoadConfig("{}", "", true);
+ private void btnRefresh_Click(object sender, EventArgs e)
+ this.DoRefresh();
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestExplorer.resx
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestExplorer.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestExplorer.resx 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,469 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="btnConnect.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAIZSURBVDhPjc/fa1JhGAfwN40gdD9cBpbHiCXo9AxnDNZh
+ k3SC80emphKIqfhjISkRJiNwBEEX0rqIohgsgq676k/YXaAyqMbYoFgwdlF4FcQG29P3VRubRfMLH845
+ 7/s+z3se1mvy+fxIpVK5V61WDZ2l3uP3+82JRGJufX2TkslkubN8bNxQFwQh63A45uv1NbJYLI8lSRLb
+ 2//PbWiUSiXiz+XlFdLpdC+MRuNlvnncOKMajeZTsVikXC5HhUKBN1lRKBRFvtnLOPNOp7OZyWQoEolQ
+ PB6ndDrNm3zUarWzvYzzLhgM/goEAoTbyOfzkdfrJZfLxZt87h7nX/kQCoX2PB4P4TYymUQShAtkMIyQ
+ 2TzKm6xhnLvto3/HDxv81yVpEkUi6fWmA6JoRUMLb7LROt2V6/AllUrR1JSdrFaJxsauHBgfnyT1g0vE
+ nqh2WLn/fbvkaDZ58fS0i2y2GTSZIafzGtnt7v2Jiau7w8P6n/LqmZ1ss0zsrbrWqTmSZ7AVi6XJ7Y5S
+ OHyL/+oWrLLsqR9sYWCbvRxYjX6fJfZaVWtZGlrkhTwxoGg0youasRgO4QlhYOz5YM2xfYO68XW+fbiY
+ ewW7cBPaedq3yBaUNU78ZqM/76115HDxHVDDEAxCP/SBAk6zh8rG+a9mYo+UdXzL4ASwOeDF98EMRtDD
+ RRDgHJwFFQvK37CcrMFC8iV8n2SMyX4DHirmsEIqF9MAAAAASUVORK5CYII=
+</value>
+ </data>
+ <data name="btnConnect.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ <value>Magenta</value>
+ </data>
+ <data name="btnConnect.Size" type="System.Drawing.Size, System.Drawing">
+ <value>23, 22</value>
+ </data>
+ <data name="btnConnect.Text" xml:space="preserve">
+ <value>Connect</value>
+ </data>
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="btnRefresh.Enabled" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <data name="btnRefresh.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAKUSURBVDhPrVJrSJNRGD4WalrgyglqolEZZT9WKuRdUdCo
+ FkVWYtY0BXFbhAk2xB+1EiwsXGYXNPG6DXVbho28TSOLgkMDMSX6yPJzOMlLy9ZMXG9711c2i371wMP3
+ nOfy4xw+8t8RU/shMLFuSppUN6VMuGemSNToYcbV/o7Ymglhcv2kMb/bwsqHFqyVzDdQOHjJofN7LCxm
+ 2OHqroiqfi9MrTcNKRg7lBkXQU6/uhC9qrd2SG0wDWGXm/3A7qrRwNhqxnhtdBFKn8zD2a4524EGlom8
+ /poiUaNXOjgPijdLEHeLMeKGmxMiKB+WZrSa2OK+GSi4b7YJrgzTXVeHM7mYoEZP3GG2yQyzIOqYZHHD
+ xYSEXaAqqd5sFWtNkHDjFRMmf/lr/BPoJVaNMBKdCc71T1txw0WEhJY8pdLOSchRvwPUnP0HMMtrG4fi
+ gRnXXnCh4fEpDWs5qhyzoOZsJ4IKe+8GF/ZmoQ4pMtATreMg6ZoC1M4CIkCir0itZYxpzeMjOy8O9viL
+ 9fu4CDPqpFh/U1D2nNmvYiFdNWb1L3i4fAXfXJ1wm/yFck+zqTO6fuwBP1dbzs/WhGPGz9PRk4aPgN+9
+ HdMQozZDeAVlN+Rqlx/RR6Tjrc9pl21vm6sMVc9VhjVNKDae75f5iFoj1mWpaFznJ0jr/gxb1bOAmpej
+ 6fc9rXT9Kz0zWzZ7Z7eJ/DTWM8hAjVUSorMleR9vpIJHC8Bv/wLxfQuAZ69jjZe52QrElwR4ZjQme8gG
+ D3rdZtPXaBcT3Q/X0sgBO4T2LDmZ/MwO6LkfqnE+7O9Y6+Am4u0TQYKiE8iOIymrt6QkucUUKVcJ79CV
+ dIsqanL0Q5xLDh4O8hwMcBDv9y9ix48QwvsOWgZuf9T4HhoAAAAASUVORK5CYII=
+</value>
+ </data>
+ <data name="btnRefresh.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ </data>
+ <data name="btnRefresh.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnRefresh.Text" xml:space="preserve">
+ <value>Refresh</value>
+ </data>
+ <data name="toolStripSeparator2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>6, 25</value>
+ </data>
+ <data name="btnNew.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="btnNew.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAFVSURBVDhPtY67L8NRGIaPSzpI0R+tVNuEFBGqiaYTdYlL
+ xK3ULUFE1CYmdpvF0MUgOlhI3WMh5roHR8Igqc3IX/H6vpMTQ7VNfoMneZI373fe5Ij/49ARF8cOqeRs
+ mgO7jH6vYuFrBZx1a4KEXU5/LoHlrFsT7Bpy7GMRkVQUnHVrgh1DDrzNov91Bpx1m4W4LS626VGaPc+T
+ 6HocR6ab2vyyZZPh93n0yinwqPtpQg1br4fQcjWIjvtRtN+NoO02jNDNsMq80Wtis1TyVzsfIkoe8LDx
+ PITqo4DSnWiCa88HT8IP70kQvNFrIlYcFzGrTNdz5ofr1IdMN7XJyYZVOi8bUHFRD866NcG6VdqTdShP
+ 1oKzbk2wViTLXmpgSC8469YEyxZppLxgOes2J4Wkm2wmg6Ivb1/M5UslZ+6ECJBVpIX8Qz5ZQjpJVxYr
+ SRtZQBJC/ADGtKxvV2OcbwAAAABJRU5ErkJggg==
+</value>
+ </data>
+ <data name="btnNew.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ </data>
+ <data name="btnNew.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnNew.Text" xml:space="preserve">
+ <value>New Configuration</value>
+ </data>
+ <data name="btnAddFile.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="btnAddFile.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAIGSURBVDhPfZHfS1NhGMffG6WooHYhFXQRpGy4i+7d3rO6
+ 6Soko/8gKmsgZZlocxcSFORNXbjCFMoKssAsldYoEqOoo6mJlpvIhmub+3WcZ7op8e08461DnHa+8Nx9
+ Px/e93nYn3BP4LizI3DWbCTvu0OibozU4W9cVLYwm9jAdCyPyWUVcmQNcjhXmidjIVCHX/NXC+TfSB6/
+ ey65gQ9LWbwPphGYW8HIVBwvJ35iSI7i3sgMousA9RzeNzUC06OZm+ZTBXwMZ/8rud4/9ndczf0PBaaH
+ e15fmk8X8CmilJXQS+g71BWYHt4+2vI9U8Dn5VVTSUmgdQWmh7cPt/3IFPElmjOV0GKpKzA9vO2VdyFb
+ xEQsZyqh61BXYHp464vOBaWIyfiaqYROTF2B6ZFaB28ElU1MrahlJfVv3agdPQpL97GvAtMjXX3eFVzd
+ xHRSLSuxDrpwOnMFFb01cYHpcbYM3A5pgplU3iBp8F+A9ZkE6wDHqeQZVPiqE+z+Hpn1WO4KXNvB5afd
+ odwWvqXzBontsRNHYg2GYXd2ywJnzHXx0YNFTTCbWTdITg6dh63PAVtvHewRJypvHkyxWztl1rWr9ILt
+ 2lRJTT3DYfUXSEIvoe/QTmixdB06sd1Xh/1Ltdjm3acQI1hm0cZ++ERzH2/0jZvNXrcjsePcAbWyvmqc
+ GMaY5Tfuoj+zr538AAAAAABJRU5ErkJggg==
+</value>
+ </data>
+ <data name="btnAddFile.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ </data>
+ <data name="btnAddFile.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnAddFile.Text" xml:space="preserve">
+ <value>Add Files to Configuration</value>
+ </data>
+ <data name="toolStripSeparator1.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnEdit.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="btnEdit.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAHASURBVDhPYyAVPGRg0H7AyDj3EgODPVSIeBAUFCS/R1R0
+ 7v+Ojv9HGRl3bmJgcIZKEQYhISEqAQEBmd++ffv/IyPj/6eYmP8rGBg2QqXxg82zGRymNIssBmk+c+bM
+ /7t37/5vZmXdOo+BwQiqBDcAaV49lXH7/3cd/3evMgZrFhcXbzZkY9OEKsENkDX/ed38/97ZsP89lRwb
+ uLi49KFKcANkzT+e1/1/cD7q/5rJTAfWz2AmHHDImr88rvj/+FLs/yU9TIdWTGJ2gSrBDZA1v79X+P/J
+ 5YT/s1uZDi/qYHaFKsENkDW/vpUJ1jyphuno9EYSNT+7mgzUHP+/s5jx+IRKBsKaF9cwqC/vZVwG0vzo
+ Yuz/hxei/9dnM55oK2BwgyrBDVbVM7BNL2TI+fjkwPszu13+3z8X8b8yifFUbQaDO1QJftCfzWC5e3HS
+ gU/PDv2/cW7B1/xwxsNlCURqBoGqWMZWkObFE0MvJvswzrLXZwgACosCsTAQCwIxPxDzAjEXEHMAMRsQ
+ swAxMxAzAjHD/2QvxlnWegzJfJwMpkC+LhBrAbEaECsCsSwQSwKxCBALADE3EIMMYmVgYGACAJ+b08TC
+ IH0dAAAAAElFTkSuQmCC
+</value>
+ </data>
+ <data name="btnEdit.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ </data>
+ <data name="btnEdit.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnEdit.Text" xml:space="preserve">
+ <value>Edit this item</value>
+ </data>
+ <data name="btnDelete.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="btnDelete.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAHOSURBVDhPzZJNSJNxHMe/ztgzNnpqtsctTeqm4sFMBK/z
+ spDwJt4KNJIcemnpTSEycsVguOlBTS3zpUO+MCwivXhSBiPfTnqIMQKJLnrJt8fvf/tRjGQduvSBD//f
+ //f2sD/D/8MMcHsKiCungX5JZzEJVLCvm869Ax5IOsNrDh4HAuae33+6WlOTUncppXkD9E1ZrYkJYOkt
+ UG8CeVLKMMaNIxxSw3vNzWayoeFw1jC2h4DqaV0fXS4r230FxIaB6zLyJwNsjgJBnvE1r/dHwuc7+VBa
+ mvxUWZmMAPPUI625eclFIS6JVVXtL5SXHw7abJtS+ju9gEHnJoqKvsU8np8hTVsfcbm+Bi2WdWnJTTcQ
+ HjeM1HJJyUlQ0zZ5b6HvI3b7Ds9FaTufANAaZWPc7TbHdT3VBTyWkgrCz/Pzt9jzTFLZtPF1O/i7vxjG
+ 0YrDccA49hBwSjlNO/CEfqReSf3mPt9u1G5P7RYUmJ0WywaHq6WUBf89T2lfD3BBUhnuqa87naezVut3
+ xi8kfS6sP/IBt+Sa5tpN4G4TlzQCn91AHXM3aCG9RC/Sy9SgxcVAbQVwh/EvdOqiV0U1qAYc1EY1OdVd
+ 9aq3uUL/FeAMspd+/GJVT0sAAAAASUVORK5CYII=
+</value>
+ </data>
+ <data name="btnDelete.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ </data>
+ <data name="btnDelete.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnDelete.Text" xml:space="preserve">
+ <value>Delete this item</value>
+ </data>
+ <data name="toolStrip1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 0</value>
+ </data>
+ <data name="toolStrip1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>281, 25</value>
+ </data>
+ <data name="toolStrip1.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="toolStrip1.Text" xml:space="preserve">
+ <value>toolStrip1</value>
+ </data>
+ <data name=">>toolStrip1.Name" xml:space="preserve">
+ </data>
+ <data name=">>toolStrip1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>toolStrip1.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>toolStrip1.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="trvRestExplorer.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ <value>Fill</value>
+ </data>
+ <data name="trvRestExplorer.ImageIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <metadata name="imgIcons.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>122, 17</value>
+ </metadata>
+ <data name="imgIcons.ImageStream" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>
+ AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj00LjAuMC4w
+ LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
+ ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAAK
+ CwAAAk1TRnQBSQFMAgEBBAEAAVABAAFQAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
+ AwABQAMAASADAAEBAQABCAYAAQgYAAGAAgABgAMAAoABAAGAAwABgAEAAYABAAKAAgADwAEAAcAB3AHA
+ AQAB8AHKAaYBAAEzBQABMwEAATMBAAEzAQACMwIAAxYBAAMcAQADIgEAAykBAANVAQADTQEAA0IBAAM5
+ AQABgAF8Af8BAAJQAf8BAAGTAQAB1gEAAf8B7AHMAQABxgHWAe8BAAHWAucBAAGQAakBrQIAAf8BMwMA
+ AWYDAAGZAwABzAIAATMDAAIzAgABMwFmAgABMwGZAgABMwHMAgABMwH/AgABZgMAAWYBMwIAAmYCAAFm
+ AZkCAAFmAcwCAAFmAf8CAAGZAwABmQEzAgABmQFmAgACmQIAAZkBzAIAAZkB/wIAAcwDAAHMATMCAAHM
+ AWYCAAHMAZkCAALMAgABzAH/AgAB/wFmAgAB/wGZAgAB/wHMAQABMwH/AgAB/wEAATMBAAEzAQABZgEA
+ ATMBAAGZAQABMwEAAcwBAAEzAQAB/wEAAf8BMwIAAzMBAAIzAWYBAAIzAZkBAAIzAcwBAAIzAf8BAAEz
+ AWYCAAEzAWYBMwEAATMCZgEAATMBZgGZAQABMwFmAcwBAAEzAWYB/wEAATMBmQIAATMBmQEzAQABMwGZ
+ AWYBAAEzApkBAAEzAZkBzAEAATMBmQH/AQABMwHMAgABMwHMATMBAAEzAcwBZgEAATMBzAGZAQABMwLM
+ AQABMwHMAf8BAAEzAf8BMwEAATMB/wFmAQABMwH/AZkBAAEzAf8BzAEAATMC/wEAAWYDAAFmAQABMwEA
+ AWYBAAFmAQABZgEAAZkBAAFmAQABzAEAAWYBAAH/AQABZgEzAgABZgIzAQABZgEzAWYBAAFmATMBmQEA
+ AWYBMwHMAQABZgEzAf8BAAJmAgACZgEzAQADZgEAAmYBmQEAAmYBzAEAAWYBmQIAAWYBmQEzAQABZgGZ
+ AWYBAAFmApkBAAFmAZkBzAEAAWYBmQH/AQABZgHMAgABZgHMATMBAAFmAcwBmQEAAWYCzAEAAWYBzAH/
+ AQABZgH/AgABZgH/ATMBAAFmAf8BmQEAAWYB/wHMAQABzAEAAf8BAAH/AQABzAEAApkCAAGZATMBmQEA
+ AZkBAAGZAQABmQEAAcwBAAGZAwABmQIzAQABmQEAAWYBAAGZATMBzAEAAZkBAAH/AQABmQFmAgABmQFm
+ ATMBAAGZATMBZgEAAZkBZgGZAQABmQFmAcwBAAGZATMB/wEAApkBMwEAApkBZgEAA5kBAAKZAcwBAAKZ
+ Af8BAAGZAcwCAAGZAcwBMwEAAWYBzAFmAQABmQHMAZkBAAGZAswBAAGZAcwB/wEAAZkB/wIAAZkB/wEz
+ AQABmQHMAWYBAAGZAf8BmQEAAZkB/wHMAQABmQL/AQABzAMAAZkBAAEzAQABzAEAAWYBAAHMAQABmQEA
+ AcwBAAHMAQABmQEzAgABzAIzAQABzAEzAWYBAAHMATMBmQEAAcwBMwHMAQABzAEzAf8BAAHMAWYCAAHM
+ AWYBMwEAAZkCZgEAAcwBZgGZAQABzAFmAcwBAAGZAWYB/wEAAcwBmQIAAcwBmQEzAQABzAGZAWYBAAHM
+ ApkBAAHMAZkBzAEAAcwBmQH/AQACzAIAAswBMwEAAswBZgEAAswBmQEAA8wBAALMAf8BAAHMAf8CAAHM
+ Af8BMwEAAZkB/wFmAQABzAH/AZkBAAHMAf8BzAEAAcwC/wEAAcwBAAEzAQAB/wEAAWYBAAH/AQABmQEA
+ AcwBMwIAAf8CMwEAAf8BMwFmAQAB/wEzAZkBAAH/ATMBzAEAAf8BMwH/AQAB/wFmAgAB/wFmATMBAAHM
+ AmYBAAH/AWYBmQEAAf8BZgHMAQABzAFmAf8BAAH/AZkCAAH/AZkBMwEAAf8BmQFmAQAB/wKZAQAB/wGZ
+ AcwBAAH/AZkB/wEAAf8BzAIAAf8BzAEzAQAB/wHMAWYBAAH/AcwBmQEAAf8CzAEAAf8BzAH/AQAC/wEz
+ AQABzAH/AWYBAAL/AZkBAAL/AcwBAAJmAf8BAAFmAf8BZgEAAWYC/wEAAf8CZgEAAf8BZgH/AQAC/wFm
+ AQABIQEAAaUBAANfAQADdwEAA4YBAAOWAQADywEAA7IBAAPXAQAD3QEAA+MBAAPqAQAD8QEAA/gBAAHw
+ AfsB/wEAAaQCoAEAA4ADAAH/AgAB/wMAAv8BAAH/AwAB/wEAAf8BAAL/AgAD//8A/wD/AP8AFQAF9AHz
+ AfABHANuARwB8gT/AfQBvAoHAbwB9AH/AQAO/wEAEP8CEQHvAQcB8AEcAXMBdAOaAnQBmQHzAQAC/wEH
+ Cv8BBwL/AQAB/wG8CuwBvAH/AQABmQ50AZkCZgHyAQcBcwF0AXkCdAJLAXQBmQJ0ARsCAAG8Af8B9wbt
+ AfcB/wG8BAAB9AH3COwB9wH0AgABdA6aAXQBZgEVAfEBkgGaBHQCmgFLAXQCmgGZAgABvAH/AfcG/wH3
+ Af8BvAUAAfcGbQFVAW0B9wMAAZkBmgx6AZoBmQESAWYB8wH3BZoBmQF0AZkBBwF0AZMBGgIAAbwB/wH3
+ A/8D9AH3Af8BvAUAAewIEgHsAwABmQ6aAZkBrgHqAf8B7wSaAXQBmQHzAf8B9AH/AbwDAAG8Af8B7wL/
+ AvQB8wH0Ae8B/wG8BQAKBwMAAZkOmgGZAuoC8QN0AZkB9AL/AvQB/wG8AwABvAH/Ae8B/wL0AvMB9AHv
+ Af8BvAUAAQcBvAUHAfABvAEHAwABmQ6aAZkEAAG8Bf8D9AH/AbwDAAG8Af8B7wH/AfQC8wHxAfQB7wH0
+ AbwFAAK8BQcBkgK8AwABmQ6aAZkEAAG8BP8E9AH/AbwDAAHwAf8BBwH/AvME9wH0AfAFAAG8CPABvAMA
+ AZkOmgGZBAABvAP/BvQBvAMAAfAB/wEHAfQB8wHxAe8B/wEHAfAB9AHwBQABvAHvBgcB7wG8AwABGgGg
+ BpoHoAEaBAAB8AL/BfQB8wH0AfADAAHwAf8BvAH/AvQBBwG8AfAB8QH0AfAFAAHwAfEGvAHxAfADAAEa
+ AaAFmgGgAZkGeQEaBAAB8AH/BfQB8wHxAfQB8AMAAfAB/wW8AfAC8QH0AfAFAAHwAfIG8QHyAfADAAEa
+ BqACmgagARoEAAHwAf8E9AHzA/cBvAMAAfAB/wP0AvMB8QP3AbwFAAHwCAcB8AMAARsHGgL/AfQB8wLa
+ ARoBGwQAAfAB/wP0AfMB8QHvAf8B8AH0AwAB8AH/AvQC8wLxAe8B/wHwAfQFAAHwAfIG8QHyAfAKAAH0
+ BhoB9AUAAfAD/wP0AQcB8AH0BAAB8QL/BfQBBwHxAfQGAAHwAfMG8gHzAfAXAAHzB/IB9AUAAfMI8gH0
+ BwAB8gjxAfIDAAFCAU0BPgcAAT4DAAEoAwABQAMAASADAAEBAQABAQYAAQEWAAP/gQAC/wQAAYABAQMA
+ AQECAAGAAQEEAAHAAQMBwAEDBAABwAEDAeABBwQAAcABAwHgAQcDAAEBAcABAwHgAQcDAAEBAcABAwHg
+ AQcCAAHwAQEBwAEDAeABBwIAAfABAQHAAQMB4AEHAgAB8AEBAcABAwHgAQcCAAHwAQEBwAEDAeABBwIA
+ AfABAQHAAQMB4AEHAgAB8AEBAcABAwHgAQcCAAHwAQEBwAEDAeABBwH+AQEB8AEDAcABBwHgAQcC/wHw
+ AQcBwAEPAeABBws=
+</value>
+ </data>
+ <data name="trvRestExplorer.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 25</value>
+ </data>
+ <data name="trvRestExplorer.SelectedImageIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="trvRestExplorer.Size" type="System.Drawing.Size, System.Drawing">
+ <value>281, 466</value>
+ </data>
+ <data name="trvRestExplorer.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>trvRestExplorer.Name" xml:space="preserve">
+ <value>trvRestExplorer</value>
+ </data>
+ <data name=">>trvRestExplorer.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TreeView, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>trvRestExplorer.Parent" xml:space="preserve">
+ </data>
+ <data name=">>trvRestExplorer.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <value>True</value>
+ </metadata>
+ <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
+ <value>6, 13</value>
+ </data>
+ <data name="$this.Size" type="System.Drawing.Size, System.Drawing">
+ <value>281, 491</value>
+ </data>
+ <data name=">>btnConnect.Name" xml:space="preserve">
+ <value>btnConnect</value>
+ </data>
+ <data name=">>btnConnect.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnRefresh.Name" xml:space="preserve">
+ <value>btnRefresh</value>
+ </data>
+ <data name=">>btnRefresh.Type" xml:space="preserve">
+ </data>
+ <data name=">>toolStripSeparator2.Name" xml:space="preserve">
+ <value>toolStripSeparator2</value>
+ </data>
+ <data name=">>toolStripSeparator2.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripSeparator, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnNew.Name" xml:space="preserve">
+ <value>btnNew</value>
+ </data>
+ <data name=">>btnNew.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnAddFile.Name" xml:space="preserve">
+ <value>btnAddFile</value>
+ </data>
+ <data name=">>btnAddFile.Type" xml:space="preserve">
+ </data>
+ <data name=">>toolStripSeparator1.Name" xml:space="preserve">
+ <value>toolStripSeparator1</value>
+ </data>
+ <data name=">>toolStripSeparator1.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnEdit.Name" xml:space="preserve">
+ <value>btnEdit</value>
+ </data>
+ <data name=">>btnEdit.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnDelete.Name" xml:space="preserve">
+ <value>btnDelete</value>
+ </data>
+ <data name=">>btnDelete.Type" xml:space="preserve">
+ </data>
+ <data name=">>imgIcons.Name" xml:space="preserve">
+ <value>imgIcons</value>
+ </data>
+ <data name=">>imgIcons.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ImageList, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>RestExplorer</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>Maestro.Shared.UI.SingletonViewContent, Maestro.Shared.UI, Version=6.0.0.0, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
+ </data>
+</root>
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestLoginDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestLoginDialog.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestLoginDialog.Designer.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,119 @@
+namespace Maestro.AddIn.Rest.UI
+ partial class RestLoginDialog
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// </summary>
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(RestLoginDialog));
+ this.label1 = new System.Windows.Forms.Label();
+ this.txtUrl = new System.Windows.Forms.TextBox();
+ this.txtUsername = new System.Windows.Forms.TextBox();
+ this.label2 = new System.Windows.Forms.Label();
+ this.txtPassword = new System.Windows.Forms.TextBox();
+ this.label3 = new System.Windows.Forms.Label();
+ this.btnLogin = new System.Windows.Forms.Button();
+ this.btnCancel = new System.Windows.Forms.Button();
+ // label1
+ resources.ApplyResources(this.label1, "label1");
+ this.label1.Name = "label1";
+ // txtUrl
+ resources.ApplyResources(this.txtUrl, "txtUrl");
+ this.txtUrl.Name = "txtUrl";
+ // txtUsername
+ resources.ApplyResources(this.txtUsername, "txtUsername");
+ this.txtUsername.Name = "txtUsername";
+ // label2
+ resources.ApplyResources(this.label2, "label2");
+ this.label2.Name = "label2";
+ // txtPassword
+ resources.ApplyResources(this.txtPassword, "txtPassword");
+ this.txtPassword.Name = "txtPassword";
+ // label3
+ resources.ApplyResources(this.label3, "label3");
+ this.label3.Name = "label3";
+ // btnLogin
+ resources.ApplyResources(this.btnLogin, "btnLogin");
+ this.btnLogin.Name = "btnLogin";
+ this.btnLogin.UseVisualStyleBackColor = true;
+ this.btnLogin.Click += new System.EventHandler(this.btnLogin_Click);
+ // btnCancel
+ resources.ApplyResources(this.btnCancel, "btnCancel");
+ this.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ this.btnCancel.Name = "btnCancel";
+ this.btnCancel.UseVisualStyleBackColor = true;
+ this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+ // RestLoginDialog
+ this.AcceptButton = this.btnLogin;
+ this.CancelButton = this.btnCancel;
+ this.ControlBox = false;
+ this.Controls.Add(this.btnCancel);
+ this.Controls.Add(this.btnLogin);
+ this.Controls.Add(this.txtPassword);
+ this.Controls.Add(this.label3);
+ this.Controls.Add(this.txtUsername);
+ this.Controls.Add(this.label2);
+ this.Controls.Add(this.txtUrl);
+ this.Controls.Add(this.label1);
+ this.Name = "RestLoginDialog";
+ #endregion
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.TextBox txtUrl;
+ private System.Windows.Forms.TextBox txtUsername;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.TextBox txtPassword;
+ private System.Windows.Forms.Label label3;
+ private System.Windows.Forms.Button btnLogin;
+ private System.Windows.Forms.Button btnCancel;
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestLoginDialog.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestLoginDialog.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestLoginDialog.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,67 @@
+using RestSharp;
+using System;
+using System.Data;
+using System.Linq;
+using System.Text;
+ public partial class RestLoginDialog : Form
+ public RestLoginDialog()
+ public RestClient GetClient()
+ return _client;
+ private void btnCancel_Click(object sender, EventArgs e)
+ this.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ private void btnLogin_Click(object sender, EventArgs e)
+ _client = new RestClient(txtUrl.Text);
+ _client.Authenticator = new HttpBasicAuthenticator(txtUsername.Text, txtPassword.Text);
+ //To test the credentials, create a session
+ var req = new RestRequest("session", Method.POST);
+ var session = _client.Execute<PrimitiveValueResponse>(req);
+ this.DialogResult = System.Windows.Forms.DialogResult.OK;
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestLoginDialog.resx
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestLoginDialog.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestLoginDialog.resx 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,363 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <data name="label1.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>13, 13</value>
+ </data>
+ <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>98, 13</value>
+ </data>
+ <data name="label1.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="label1.Text" xml:space="preserve">
+ <value>mapguide-rest URL</value>
+ </data>
+ <data name=">>label1.Name" xml:space="preserve">
+ <value>label1</value>
+ </data>
+ <data name=">>label1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>label1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label1.ZOrder" xml:space="preserve">
+ <value>7</value>
+ </data>
+ <data name="txtUrl.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ <data name="txtUrl.Location" type="System.Drawing.Point, System.Drawing">
+ <value>16, 29</value>
+ </data>
+ <data name="txtUrl.Size" type="System.Drawing.Size, System.Drawing">
+ <value>361, 20</value>
+ </data>
+ <data name="txtUrl.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name="txtUrl.Text" xml:space="preserve">
+ <value>http://localhost/mapguide/rest/v1</value>
+ </data>
+ <data name=">>txtUrl.Name" xml:space="preserve">
+ <value>txtUrl</value>
+ </data>
+ <data name=">>txtUrl.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>txtUrl.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtUrl.ZOrder" xml:space="preserve">
+ <value>6</value>
+ </data>
+ <data name="txtUsername.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="txtUsername.Location" type="System.Drawing.Point, System.Drawing">
+ <value>16, 74</value>
+ </data>
+ <data name="txtUsername.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="txtUsername.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name=">>txtUsername.Name" xml:space="preserve">
+ <value>txtUsername</value>
+ </data>
+ <data name=">>txtUsername.Type" xml:space="preserve">
+ </data>
+ <data name=">>txtUsername.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtUsername.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="label2.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label2.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ <value>NoControl</value>
+ </data>
+ <data name="label2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>13, 58</value>
+ </data>
+ <data name="label2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>55, 13</value>
+ </data>
+ <data name="label2.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="label2.Text" xml:space="preserve">
+ <value>Username</value>
+ </data>
+ <data name=">>label2.Name" xml:space="preserve">
+ <value>label2</value>
+ </data>
+ <data name=">>label2.Type" xml:space="preserve">
+ </data>
+ <data name=">>label2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label2.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name="txtPassword.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="txtPassword.Location" type="System.Drawing.Point, System.Drawing">
+ <value>16, 116</value>
+ </data>
+ <data name="txtPassword.PasswordChar" type="System.Char, mscorlib" xml:space="preserve">
+ <value>*</value>
+ </data>
+ <data name="txtPassword.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="txtPassword.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>txtPassword.Name" xml:space="preserve">
+ <value>txtPassword</value>
+ </data>
+ <data name=">>txtPassword.Type" xml:space="preserve">
+ </data>
+ <data name=">>txtPassword.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtPassword.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="label3.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label3.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="label3.Location" type="System.Drawing.Point, System.Drawing">
+ <value>13, 100</value>
+ </data>
+ <data name="label3.Size" type="System.Drawing.Size, System.Drawing">
+ <value>53, 13</value>
+ </data>
+ <data name="label3.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name="label3.Text" xml:space="preserve">
+ <value>Password</value>
+ </data>
+ <data name=">>label3.Name" xml:space="preserve">
+ <value>label3</value>
+ </data>
+ <data name=">>label3.Type" xml:space="preserve">
+ </data>
+ <data name=">>label3.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label3.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="btnLogin.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom, Right</value>
+ </data>
+ <data name="btnLogin.Location" type="System.Drawing.Point, System.Drawing">
+ <value>221, 153</value>
+ </data>
+ <data name="btnLogin.Size" type="System.Drawing.Size, System.Drawing">
+ <value>75, 23</value>
+ </data>
+ <data name="btnLogin.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="btnLogin.Text" xml:space="preserve">
+ <value>Login</value>
+ </data>
+ <data name=">>btnLogin.Name" xml:space="preserve">
+ <value>btnLogin</value>
+ </data>
+ <data name=">>btnLogin.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnLogin.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnLogin.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="btnCancel.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="btnCancel.Location" type="System.Drawing.Point, System.Drawing">
+ <value>302, 154</value>
+ </data>
+ <data name="btnCancel.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnCancel.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="btnCancel.Text" xml:space="preserve">
+ <value>Cancel</value>
+ </data>
+ <data name=">>btnCancel.Name" xml:space="preserve">
+ <value>btnCancel</value>
+ </data>
+ <data name=">>btnCancel.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnCancel.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnCancel.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ </metadata>
+ </data>
+ <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+ <value>399, 189</value>
+ </data>
+ <data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
+ <value>CenterParent</value>
+ </data>
+ <data name="$this.Text" xml:space="preserve">
+ </data>
+ <value>RestLoginDialog</value>
+ </data>
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
Added: trunk/Tools/Maestro/Maestro.AddIn.Rest/packages.config
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/packages.config (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/packages.config 2015-03-04 13:59:24 UTC (rev 8556)
@@ -0,0 +1,5 @@
+<packages>
+ <package id="Newtonsoft.Json" version="6.0.8" targetFramework="net451" />
+ <package id="RestSharp" version="105.0.1" targetFramework="net451" />
+</packages>
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.cs 2015-03-02 12:19:20 UTC (rev 8555)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -35,6 +35,8 @@
using System.Linq;
using System.Text;
+using OSGeo.MapGuide.ObjectModels.FeatureSource;
+using OSGeo.MapGuide.MaestroAPI.Services;
namespace Maestro.Editors.Common
@@ -44,6 +46,7 @@
public partial class ExpressionEditor : Form, IExpressionEditor, ITextInserter, IExpressionErrorSource
private ClassDefinition _cls;
+ private IFeatureService _featSvc;
private IEditorService _edSvc;
private string m_featureSource = null;
private IFdoProviderCapabilities _caps;
@@ -84,6 +87,17 @@
private ExpressionEditorMode _mode;
+ public void Initialize(IServerConnection conn, ClassDefinition cls, string featureSourceId, ExpressionEditorMode mode)
+ IFeatureSource fs = (IFeatureSource)conn.ResourceService.GetResource(featureSourceId);
+ IFdoProviderCapabilities caps = conn.FeatureService.GetProviderCapabilities(fs.Provider);
+ //This is normally set by the Editor Service, but we don't have that so do it here
+ _featSvc = conn.FeatureService;
+ this.Initialize(null, caps, cls, featureSourceId, mode, false);
/// <summary>
/// Initializes the dialog.
/// </summary>
@@ -100,6 +114,15 @@
_mode = mode;
_cls = cls;
_edSvc = edSvc;
+ if (_edSvc != null)
+ _featSvc = _edSvc.CurrentConnection.FeatureService;
+ insertThemeExpressionToolStripMenuItem.Enabled = true;
+ else
+ insertThemeExpressionToolStripMenuItem.Enabled = false;
m_featureSource = featureSourceId;
_caps = caps;
@@ -331,7 +354,7 @@
ColumnValue.Tag = null;
try
- using (var rdr = _edSvc.CurrentConnection.FeatureService.AggregateQueryFeatureSource(m_featureSource, _cls.QualifiedName, filter, new System.Collections.Specialized.NameValueCollection() {
+ using (var rdr = _featSvc.AggregateQueryFeatureSource(m_featureSource, _cls.QualifiedName, filter, new System.Collections.Specialized.NameValueCollection() {
{ "UNIQ_VALS", expr } //NOXLATE
@@ -376,7 +399,7 @@
try
retry = false;
- using (var rd = _edSvc.CurrentConnection.FeatureService.QueryFeatureSource(m_featureSource, _cls.QualifiedName, filter, new string[] { ColumnName.Text }))
+ using (var rd = _featSvc.QueryFeatureSource(m_featureSource, _cls.QualifiedName, filter, new string[] { ColumnName.Text }))
while (rd.ReadNext())
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/IExpressionEditor.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/IExpressionEditor.cs 2015-03-02 12:19:20 UTC (rev 8555)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/IExpressionEditor.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -44,7 +44,7 @@
/// <summary>
/// The expression editor interface
/// </summary>
- internal interface IExpressionEditor
+ public interface IExpressionEditor
/// <summary>
/// Initializes the expression editor
@@ -67,6 +67,8 @@
/// </summary>
/// <returns></returns>
System.Windows.Forms.DialogResult ShowDialog();
+ void Initialize(IServerConnection conn, ClassDefinition classDefinition, string featureSourceId, ExpressionEditorMode mode);
/// <summary>
@@ -82,7 +84,7 @@
void InsertText(string text);
- internal static class FdoExpressionEditorFactory
+ public static class FdoExpressionEditorFactory
public static IExpressionEditor Create()
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/MonoCompatibleExpressionEditor.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/MonoCompatibleExpressionEditor.cs 2015-03-02 12:19:20 UTC (rev 8555)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/MonoCompatibleExpressionEditor.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -34,6 +34,8 @@
@@ -82,6 +84,7 @@
@@ -107,6 +110,17 @@
/// <summary>
/// </summary>
@@ -124,6 +138,15 @@
_mode = mode;
_cls = cls;
_edSvc = edSvc;
+ else
insertThemeExpressionToolStripMenuItem.Enabled = attachStylizationFunctions;
@@ -835,7 +858,7 @@
try
@@ -886,7 +909,7 @@
try
retry = false;
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.cs 2015-03-02 12:19:20 UTC (rev 8555)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.cs 2015-03-04 13:59:24 UTC (rev 8556)
@@ -71,7 +71,7 @@
contentPanel.Dock = DockStyle.Fill;
contentPanel.DockLeftPortion = 250;
contentPanel.DockBottomPortion = 150;
- contentPanel.DockRightPortion = 200;
+ contentPanel.DockRightPortion = 250;
menu = _workbenchInitializer.GetMainMenu(this);
More information about the mapguide-commits
