[mapguide-commits] r8557 - trunk/Tools/Maestro/Maestro.AddIn.Rest/UI
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Mar 4 06:25:08 PST 2015
Author: jng
Date: 2015-03-04 06:25:07 -0800 (Wed, 04 Mar 2015)
New Revision: 8557
   trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestExplorer.cs
#2506: File adding/deleting support
Modified: trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestExplorer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestExplorer.cs	2015-03-04 13:59:24 UTC (rev 8556)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/UI/RestExplorer.cs	2015-03-04 14:25:07 UTC (rev 8557)
@@ -33,6 +33,7 @@
 using Maestro.AddIn.Rest.Model;
 using OSGeo.MapGuide.MaestroAPI;
 using Maestro.Base.Services;
+using System.IO;
 namespace Maestro.AddIn.Rest.UI
@@ -148,9 +149,12 @@
         private void trvRestExplorer_AfterSelect(object sender, TreeViewEventArgs e)
             var conf = e.Node.Tag as DataConfiguration;
-            btnDelete.Enabled = btnEdit.Enabled = false;
+            var list = e.Node.Tag as DataFileList;
+            btnDelete.Enabled = btnEdit.Enabled = btnAddFile.Enabled = false;
             if (conf != null)
                 btnDelete.Enabled = btnEdit.Enabled = btnAddFile.Enabled = true;
+            else if (list != null)
+                btnDelete.Enabled = true;
         private void LoadConfig(string json, string uriPart, bool isNew)
@@ -173,6 +177,7 @@
                         foreach (var file in list.File)
                             var n = e.Node.Nodes.Add(file);
+                            n.Tag = list;
                             n.ImageIndex = n.SelectedImageIndex = IDX_FILE;
@@ -200,6 +205,7 @@
         private void btnDelete_Click(object sender, EventArgs e)
             var conf = trvRestExplorer.SelectedNode.Tag as DataConfiguration;
+            var list = trvRestExplorer.SelectedNode.Tag as DataFileList;
             if (conf != null)
                 if (MessageBox.Show(Maestro.AddIn.Rest.Strings.PromptDeleteConfiguration, Maestro.AddIn.Rest.Strings.DeleteConfiguration, MessageBoxButtons.YesNo) == DialogResult.Yes)
@@ -221,11 +227,69 @@
+                string file = trvRestExplorer.SelectedNode.Text;
+                //Parent node is the configuration
+                conf = trvRestExplorer.SelectedNode.Parent.Tag as DataConfiguration;
+                if (conf != null)
+                    if (MessageBox.Show("Delete this file?", "Delete file", MessageBoxButtons.YesNo) == DialogResult.Yes)
+                        var req = new RestRequest(conf.ConfigUriPart.Replace("/config", "/file"), Method.POST);
+                        req.AddHeader("X-HTTP-METHOD-OVERRIDE", "DELETE");
+                        req.AddParameter("filename", file);
+                        _client.ExecuteAsync(req, (resp) =>
+                            if (resp.StatusCode == System.Net.HttpStatusCode.OK)
+                                this.UIThreadInvoke(() =>
+                                    MessageBox.Show("File deleted");
+                                    this.DoRefresh();
+                            else
+                                MessageBox.Show(resp.Content);
         private void btnAddFile_Click(object sender, EventArgs e)
+            var conf = trvRestExplorer.SelectedNode.Tag as DataConfiguration;
+            if (list != null)
+            if (conf != null)
+                using (var picker = new OpenFileDialog())
+                    if (picker.ShowDialog() == DialogResult.OK)
+                        req.AddParameter("filename", Path.GetFileName(picker.FileName));
+                        req.AddFile("data", picker.FileName);
+                                    MessageBox.Show("File added");
+                                    this.DoRefresh();
+                            else
         private void btnNew_Click(object sender, EventArgs e)
More information about the mapguide-commits mailing list
