[mapguide-commits] r8564 - sandbox/adsk/2.6l/Common/MapGuideCommon/Controller
svn_mapguide at osgeo.org
Sun Mar 8 18:18:31 PDT 2015
Author: hubu
Date: 2015-03-08 18:18:31 -0700 (Sun, 08 Mar 2015)
New Revision: 8564
sandbox/adsk/2.6l/Common/MapGuideCommon/Controller/HtmlController.cpp
Integrate fix for #2547 to sandbox/adsk/2.6l branch.
Modified: sandbox/adsk/2.6l/Common/MapGuideCommon/Controller/HtmlController.cpp
--- sandbox/adsk/2.6l/Common/MapGuideCommon/Controller/HtmlController.cpp 2015-03-09 01:03:18 UTC (rev 8563)
+++ sandbox/adsk/2.6l/Common/MapGuideCommon/Controller/HtmlController.cpp 2015-03-09 01:18:31 UTC (rev 8564)
@@ -473,37 +473,41 @@
MdfModel::NameStringPairCollection* pmappings = vl->GetPropertyMappings();
for (int j=0; j<pmappings->GetCount(); j++)
- STRING pTypeStr;
MdfModel::NameStringPair* m = pmappings->GetAt(j);
propNames->Add(m->GetName());
displayNameMap.insert(std::make_pair(m->GetName(), m->GetValue()));
- INT32 pidx = clsProps->IndexOf(m->GetName());
- if (pidx >= 0)
+ STRING pTypeStr;
+ for (int k = 0; k < clsProps->GetCount(); k++)
+ Ptr<MgPropertyDefinition> propDef = clsProps->GetItem(k);
+ STRING propName = propDef->GetName();
+ DisplayNameMap::iterator it = displayNameMap.find(propName);
+ //Skip properties without display mappings
+ if (it == displayNameMap.end())
+ continue;
+ INT32 pdType = propDef->GetPropertyType();
+ INT32 pType = MgPropertyType::Null;
+ if (pdType == MgFeaturePropertyType::DataProperty)
- Ptr<MgPropertyDefinition> propDef = clsProps->GetItem(pidx);
- INT32 pdType = propDef->GetPropertyType();
- INT32 pType = MgPropertyType::Null;
- if (pdType == MgFeaturePropertyType::DataProperty)
- pType = ((MgDataPropertyDefinition*)propDef.p)->GetDataType();
- else if (pdType == MgFeaturePropertyType::GeometricProperty)
- pType = MgPropertyType::Geometry;
- MgUtil::Int32ToString(pType, pTypeStr);
- xmlOut.append(L"<Property>\n");
- xmlOut.append(L"<Name>");
- xmlOut.append(m->GetName());
- xmlOut.append(L"</Name>\n");
- xmlOut.append(L"<Type>");
- xmlOut.append(pTypeStr);
- xmlOut.append(L"</Type>\n");
- xmlOut.append(L"<DisplayName>");
- xmlOut.append(m->GetValue());
- xmlOut.append(L"</DisplayName>\n");
- xmlOut.append(L"</Property>\n");
+ pType = ((MgDataPropertyDefinition*)propDef.p)->GetDataType();
+ else if (pdType == MgFeaturePropertyType::GeometricProperty)
+ pType = MgPropertyType::Geometry;
+ MgUtil::Int32ToString(pType, pTypeStr);
+ xmlOut.append(L"<Property>\n");
+ xmlOut.append(L"<Name>");
+ xmlOut.append(it->first);
+ xmlOut.append(L"</Name>\n");
+ xmlOut.append(L"<Type>");
+ xmlOut.append(pTypeStr);
+ xmlOut.append(L"</Type>\n");
+ xmlOut.append(L"<DisplayName>");
+ xmlOut.append(it->second);
+ xmlOut.append(L"</DisplayName>\n");
+ xmlOut.append(L"</Property>\n");
More information about the mapguide-commits
