[mapguide-commits] r8565 - in trunk/Tools/Maestro: Maestro.Base/Editor Maestro.Editors/Generic OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.ObjectModels/IO
svn_mapguide at osgeo.org
Tue Mar 10 05:37:21 PDT 2015
Author: jng
Date: 2015-03-10 05:37:20 -0700 (Tue, 10 Mar 2015)
New Revision: 8565
Removed:
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utf8XmlWriter.cs
trunk/Tools/Maestro/Maestro.Base/Editor/FsEditorOptionPanel.cs
trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/IO/Utf8XmlWriter.cs
- Remove duplicate Utf8XmlWriter class. The OSGeo.MapGuide.ObjectModels one is the "winner"
- Ensure that an XML prolog with utf-8 encoding is written when formatting an XML document in the generic XML editor
- Only validate well-formedness if validating a configuration document via the generic XML editor
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/FsEditorOptionPanel.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/FsEditorOptionPanel.cs 2015-03-09 01:18:31 UTC (rev 8564)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/FsEditorOptionPanel.cs 2015-03-10 12:37:20 UTC (rev 8565)
@@ -114,6 +114,7 @@
var content = _fs.GetConfigurationContent(_edsvc.CurrentConnection);
var dlg = new XmlEditorDialog(_edsvc);
+ dlg.OnlyValidateWellFormedness = true;
dlg.XmlContent = content;
if (dlg.ShowDialog() == DialogResult.OK)
Modified: trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.cs 2015-03-09 01:18:31 UTC (rev 8564)
+++ trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.cs 2015-03-10 12:37:20 UTC (rev 8565)
@@ -24,6 +24,7 @@
using ICSharpCode.TextEditor.Document;
using OSGeo.MapGuide.MaestroAPI;
using OSGeo.MapGuide.ObjectModels;
+using OSGeo.MapGuide.ObjectModels.IO;
using System;
using System.Collections.Generic;
using System.Drawing;
@@ -305,12 +306,25 @@
return;
System.Xml.XmlDocument doc = new System.Xml.XmlDocument();
- doc.LoadXml(txtXmlContent.Text);
- System.Text.StringBuilder sb = new System.Text.StringBuilder();
- System.Xml.XmlWriter xw = System.Xml.XmlTextWriter.Create(sb, new System.Xml.XmlWriterSettings() { Indent = true });
- doc.WriteTo(xw);
- xw.Flush();
- txtXmlContent.Text = sb.ToString();
+ using (var ms = new MemoryStream(System.Text.Encoding.UTF8.GetBytes(txtXmlContent.Text)))
+ using (var ms2 = Utility.RemoveUTF8BOM(ms))
+ doc.Load(ms2);
+ using (var ms = new MemoryStream())
+ using (var uw = new Utf8XmlWriter(ms))
+ uw.WriteStartDocument();
+ doc.WriteTo(uw);
+ uw.Flush();
+ txtXmlContent.Text = System.Text.Encoding.UTF8.GetString(ms.GetBuffer());
/// <summary>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2015-03-09 01:18:31 UTC (rev 8564)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2015-03-10 12:37:20 UTC (rev 8565)
@@ -239,7 +239,6 @@
</Compile>
<Compile Include="Tile\BatchSettings.cs" />
<Compile Include="Tile\RenderThread.cs" />
- <Compile Include="Utf8XmlWriter.cs" />
<Compile Include="Utility.cs" />
<Compile Include="WeakEventHandler.cs" />
<Compile Include="XmlValidator.cs" />
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2015-03-09 01:18:31 UTC (rev 8564)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2015-03-10 12:37:20 UTC (rev 8565)
@@ -33,6 +33,7 @@
using OSGeo.MapGuide.ObjectModels.Capabilities;
using OSGeo.MapGuide.ObjectModels.Common;
using OSGeo.MapGuide.ObjectModels.LayerDefinition;
using OSGeo.MapGuide.ObjectModels.LoadProcedure;
using OSGeo.MapGuide.ObjectModels.MapDefinition;
@@ -42,7 +43,6 @@
using System.Collections.Specialized;
using System.IO;
using System.Text;
using ObjCommon = OSGeo.MapGuide.ObjectModels.Common;
namespace OSGeo.MapGuide.MaestroAPI
Deleted: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utf8XmlWriter.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utf8XmlWriter.cs 2015-03-09 01:18:31 UTC (rev 8564)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utf8XmlWriter.cs 2015-03-10 12:37:20 UTC (rev 8565)
@@ -1,88 +0,0 @@
-#region Disclaimer / License
-// Copyright (C) 2009, Kenneth Skovhede
-// http://www.hexad.dk, opensource at hexad.dk
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of the GNU Lesser General Public
-// License as published by the Free Software Foundation; either
-// version 2.1 of the License, or (at your option) any later version.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
-#endregion Disclaimer / License
-namespace OSGeo.MapGuide.MaestroAPI
- /// <summary>
- /// Overrides the default XmlWriter, to ensure that the Xml is Utf8 and with whitespaces, as the MapGuide server requires Utf8
- /// </summary>
- public class Utf8XmlWriter : System.Xml.XmlTextWriter
- /// <summary>
- /// Initializes a new instance of the <see cref="Utf8XmlWriter"/> class.
- /// </summary>
- /// <param name="s">The s.</param>
- public Utf8XmlWriter(System.IO.Stream s)
- //This creation of the UTF8 encoder removes the BOM
- //Which is required because MapGuide has trouble reading files with a BOM.
- : base(s, new System.Text.UTF8Encoding(false, true))
- Initialize();
- private void Initialize()
- //The MapGuide Studio parser is broken, it can't read Xml without whitespace :)
- base.Formatting = System.Xml.Formatting.Indented;
- base.Indentation = 2;
- base.IndentChar = ' ';
- /// <summary>
- /// </summary>
- /// <param name="w">The TextWriter to write to. It is assumed that the TextWriter is already set to the correct encoding.</param>
- public Utf8XmlWriter(System.IO.TextWriter w)
- : base(w)
- Initialize();
- /// <summary>
- /// Writes the XML declaration with the version "1.0".
- /// </summary>
- /// <exception cref="T:System.InvalidOperationException">
- /// This is not the first write method called after the constructor.
- /// </exception>
- public override void WriteStartDocument()
- Utf8WriteHeader();
- /// <summary>
- /// Writes the XML declaration with the version "1.0" and the standalone attribute.
- /// </summary>
- /// <param name="standalone">If true, it writes "standalone=yes"; if false, it writes "standalone=no".</param>
- /// </exception>
- public override void WriteStartDocument(bool standalone)
- private void Utf8WriteHeader()
- base.WriteRaw("<?xml version=\"1.0\" encoding=\"utf-8\"?>"); //NOXLATE
\ No newline at end of file
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/IO/Utf8XmlWriter.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/IO/Utf8XmlWriter.cs 2015-03-09 01:18:31 UTC (rev 8564)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/IO/Utf8XmlWriter.cs 2015-03-10 12:37:20 UTC (rev 8565)
@@ -30,7 +30,7 @@
/// <summary>
/// </summary>
- internal class Utf8XmlWriter : System.Xml.XmlTextWriter
+ public class Utf8XmlWriter : System.Xml.XmlTextWriter
/// <summary>
More information about the mapguide-commits
