[mapguide-commits] r8909 - in trunk/Tools/Maestro/SDK: . Samples Samples/DrawMap Samples/DrawMap/Properties Samples/DwfInspector Samples/DwfInspector/Properties Samples/HelloAddIn Samples/MapViewer Samples/MapViewer/Properties Samples/QueryFeatureSource Samples/QueryFeatureSource/Properties Samples/SchemaViewer Samples/SchemaViewer/Properties Samples/StandaloneWebLayoutEditor Samples/StandaloneWebLayoutEditor/Properties SamplesWeb SamplesWeb/SamplesWeb
svn_mapguide at osgeo.org
Thu Apr 7 07:39:48 PDT 2016
Author: jng
Date: 2016-04-07 07:39:48 -0700 (Thu, 07 Apr 2016)
New Revision: 8909
trunk/Tools/Maestro/SDK/Samples/
trunk/Tools/Maestro/SDK/Samples/DrawMap/DrawMap.csproj
trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Resources.Designer.cs
trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Settings.Designer.cs
trunk/Tools/Maestro/SDK/Samples/DrawMap/app.config
trunk/Tools/Maestro/SDK/Samples/DwfInspector/DwfInspector.csproj
trunk/Tools/Maestro/SDK/Samples/DwfInspector/Properties/Resources.Designer.cs
trunk/Tools/Maestro/SDK/Samples/DwfInspector/Properties/Settings.Designer.cs
trunk/Tools/Maestro/SDK/Samples/DwfInspector/app.config
trunk/Tools/Maestro/SDK/Samples/HelloAddIn/HelloAddIn.csproj
trunk/Tools/Maestro/SDK/Samples/MapViewer/MapViewer.csproj
trunk/Tools/Maestro/SDK/Samples/MapViewer/Properties/Resources.Designer.cs
trunk/Tools/Maestro/SDK/Samples/MapViewer/Properties/Settings.Designer.cs
trunk/Tools/Maestro/SDK/Samples/MapViewer/app.config
trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Resources.Designer.cs
trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Settings.Designer.cs
trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/QueryFeatureSource.csproj
trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/app.config
trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Resources.Designer.cs
trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Settings.Designer.cs
trunk/Tools/Maestro/SDK/Samples/SchemaViewer/SchemaViewer.csproj
trunk/Tools/Maestro/SDK/Samples/SchemaViewer/app.config
trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Properties/Resources.Designer.cs
trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Properties/Settings.Designer.cs
trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/StandaloneWebLayoutEditor.csproj
trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/app.config
trunk/Tools/Maestro/SDK/SamplesWeb/
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Web.config
trunk/Tools/Maestro/SDK/sdk_changelog.txt
Update Maestro SDK sample projects to target .net Framework 4.5
Property changes on: trunk/Tools/Maestro/SDK/Samples
___________________________________________________________________
Modified: svn:ignore
- Samples.suo
Samples.sln.docstates.suo
*.suo
+ Samples.suo
*.suo
.vs
Modified: trunk/Tools/Maestro/SDK/Samples/DrawMap/DrawMap.csproj
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/DrawMap.csproj 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/DrawMap.csproj 2016-04-07 14:39:48 UTC (rev 8909)
@@ -10,7 +10,7 @@
<AppDesignerFolder>Properties</AppDesignerFolder>
<RootNamespace>DrawMap</RootNamespace>
<AssemblyName>DrawMap</AssemblyName>
- <TargetFrameworkVersion>v4.0</TargetFrameworkVersion>
+ <TargetFrameworkVersion>v4.5</TargetFrameworkVersion>
<FileAlignment>512</FileAlignment>
<FileUpgradeFlags>
</FileUpgradeFlags>
@@ -42,6 +42,7 @@
<DefineConstants>DEBUG;TRACE</DefineConstants>
<ErrorReport>prompt</ErrorReport>
<WarningLevel>4</WarningLevel>
+ <Prefer32Bit>false</Prefer32Bit>
</PropertyGroup>
<PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' ">
<DebugType>pdbonly</DebugType>
@@ -50,6 +51,7 @@
<DefineConstants>TRACE</DefineConstants>
</PropertyGroup>
<ItemGroup>
<Reference Include="Maestro.Editors, Version=3.0.0.5728, Culture=neutral, processorArchitecture=MSIL">
Modified: trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Resources.Designer.cs 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Resources.Designer.cs 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:4.0.30319.17929
+// Runtime Version:4.0.30319.42000
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
Modified: trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Settings.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Settings.Designer.cs 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Settings.Designer.cs 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,7 +1,7 @@
// <auto-generated>
@@ -12,7 +12,7 @@
[global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
- [global::System.CodeDom.Compiler.GeneratedCodeAttribute("Microsoft.VisualStudio.Editors.SettingsDesigner.SettingsSingleFileGenerator", "10.0.0.0")]
+ [global::System.CodeDom.Compiler.GeneratedCodeAttribute("Microsoft.VisualStudio.Editors.SettingsDesigner.SettingsSingleFileGenerator", "14.0.0.0")]
internal sealed partial class Settings : global::System.Configuration.ApplicationSettingsBase {
private static Settings defaultInstance = ((Settings)(global::System.Configuration.ApplicationSettingsBase.Synchronized(new Settings())));
Modified: trunk/Tools/Maestro/SDK/Samples/DrawMap/app.config
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/app.config 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/app.config 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,3 +1,3 @@
<?xml version="1.0"?>
<configuration>
-<startup><supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.0"/></startup></configuration>
+<startup><supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.5"/></startup></configuration>
Modified: trunk/Tools/Maestro/SDK/Samples/DwfInspector/DwfInspector.csproj
--- trunk/Tools/Maestro/SDK/Samples/DwfInspector/DwfInspector.csproj 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/DwfInspector/DwfInspector.csproj 2016-04-07 14:39:48 UTC (rev 8909)
@@ -10,7 +10,7 @@
<RootNamespace>DwfInspector</RootNamespace>
<AssemblyName>DwfInspector</AssemblyName>
<FileUpgradeFlags>
</FileUpgradeFlags>
@@ -42,6 +42,7 @@
</PropertyGroup>
@@ -50,6 +51,7 @@
</PropertyGroup>
<ItemGroup>
Modified: trunk/Tools/Maestro/SDK/Samples/DwfInspector/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/DwfInspector/Properties/Resources.Designer.cs 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/DwfInspector/Properties/Resources.Designer.cs 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,7 +1,7 @@
// <auto-generated>
Modified: trunk/Tools/Maestro/SDK/Samples/DwfInspector/Properties/Settings.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/DwfInspector/Properties/Settings.Designer.cs 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/DwfInspector/Properties/Settings.Designer.cs 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,7 +1,7 @@
// <auto-generated>
@@ -12,7 +12,7 @@
Modified: trunk/Tools/Maestro/SDK/Samples/DwfInspector/app.config
--- trunk/Tools/Maestro/SDK/Samples/DwfInspector/app.config 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/DwfInspector/app.config 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,3 +1,3 @@
<configuration>
Modified: trunk/Tools/Maestro/SDK/Samples/HelloAddIn/HelloAddIn.csproj
--- trunk/Tools/Maestro/SDK/Samples/HelloAddIn/HelloAddIn.csproj 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/HelloAddIn/HelloAddIn.csproj 2016-04-07 14:39:48 UTC (rev 8909)
@@ -10,7 +10,7 @@
<RootNamespace>HelloAddIn</RootNamespace>
<AssemblyName>HelloAddIn</AssemblyName>
<TargetFrameworkProfile>
</TargetFrameworkProfile>
@@ -23,6 +23,7 @@
</PropertyGroup>
@@ -31,6 +32,7 @@
</PropertyGroup>
<ItemGroup>
<Reference Include="Accessibility">
Modified: trunk/Tools/Maestro/SDK/Samples/MapViewer/MapViewer.csproj
--- trunk/Tools/Maestro/SDK/Samples/MapViewer/MapViewer.csproj 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/MapViewer/MapViewer.csproj 2016-04-07 14:39:48 UTC (rev 8909)
@@ -10,7 +10,7 @@
<RootNamespace>MapViewer</RootNamespace>
<AssemblyName>MapViewer</AssemblyName>
@@ -24,6 +24,7 @@
</PropertyGroup>
<PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|x86' ">
<PlatformTarget>x86</PlatformTarget>
@@ -33,6 +34,7 @@
</PropertyGroup>
<ItemGroup>
<Reference Include="Maestro.Editors">
Modified: trunk/Tools/Maestro/SDK/Samples/MapViewer/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/MapViewer/Properties/Resources.Designer.cs 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/MapViewer/Properties/Resources.Designer.cs 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,7 +1,7 @@
// <auto-generated>
Modified: trunk/Tools/Maestro/SDK/Samples/MapViewer/Properties/Settings.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/MapViewer/Properties/Settings.Designer.cs 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/MapViewer/Properties/Settings.Designer.cs 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,7 +1,7 @@
// <auto-generated>
@@ -12,7 +12,7 @@
Modified: trunk/Tools/Maestro/SDK/Samples/MapViewer/app.config
--- trunk/Tools/Maestro/SDK/Samples/MapViewer/app.config 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/MapViewer/app.config 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,3 +1,3 @@
<configuration>
Modified: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Resources.Designer.cs 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Resources.Designer.cs 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,7 +1,7 @@
// <auto-generated>
Modified: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Settings.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Settings.Designer.cs 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Settings.Designer.cs 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,7 +1,7 @@
// <auto-generated>
@@ -12,7 +12,7 @@
Modified: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/QueryFeatureSource.csproj
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/QueryFeatureSource.csproj 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/QueryFeatureSource.csproj 2016-04-07 14:39:48 UTC (rev 8909)
@@ -10,7 +10,7 @@
<RootNamespace>QueryFeatureSource</RootNamespace>
<AssemblyName>QueryFeatureSource</AssemblyName>
<FileUpgradeFlags>
</FileUpgradeFlags>
@@ -42,6 +42,7 @@
</PropertyGroup>
@@ -50,6 +51,7 @@
</PropertyGroup>
<ItemGroup>
Modified: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/app.config
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/app.config 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/app.config 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,3 +1,3 @@
<configuration>
Modified: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Resources.Designer.cs 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Resources.Designer.cs 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,7 +1,7 @@
// <auto-generated>
Modified: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Settings.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Settings.Designer.cs 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Settings.Designer.cs 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,7 +1,7 @@
// <auto-generated>
@@ -12,7 +12,7 @@
Modified: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/SchemaViewer.csproj
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/SchemaViewer.csproj 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/SchemaViewer.csproj 2016-04-07 14:39:48 UTC (rev 8909)
@@ -10,7 +10,7 @@
<RootNamespace>SchemaViewer</RootNamespace>
<AssemblyName>SchemaViewer</AssemblyName>
<FileUpgradeFlags>
</FileUpgradeFlags>
@@ -42,6 +42,7 @@
</PropertyGroup>
@@ -50,6 +51,7 @@
</PropertyGroup>
<ItemGroup>
Modified: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/app.config
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/app.config 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/app.config 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,3 +1,3 @@
<configuration>
Modified: trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Properties/Resources.Designer.cs 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Properties/Resources.Designer.cs 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,7 +1,7 @@
// <auto-generated>
Modified: trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Properties/Settings.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Properties/Settings.Designer.cs 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Properties/Settings.Designer.cs 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,7 +1,7 @@
// <auto-generated>
@@ -12,7 +12,7 @@
Modified: trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/StandaloneWebLayoutEditor.csproj
--- trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/StandaloneWebLayoutEditor.csproj 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/StandaloneWebLayoutEditor.csproj 2016-04-07 14:39:48 UTC (rev 8909)
@@ -10,7 +10,7 @@
<RootNamespace>StandaloneWebLayoutEditor</RootNamespace>
<AssemblyName>StandaloneWebLayoutEditor</AssemblyName>
<FileUpgradeFlags>
</FileUpgradeFlags>
@@ -42,6 +42,7 @@
</PropertyGroup>
@@ -50,6 +51,7 @@
</PropertyGroup>
<ItemGroup>
<Reference Include="Maestro.Editors, Version=3.5.0.5977, Culture=neutral, processorArchitecture=MSIL">
Modified: trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/app.config
--- trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/app.config 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/app.config 2016-04-07 14:39:48 UTC (rev 8909)
@@ -1,3 +1,3 @@
<configuration>
Property changes on: trunk/Tools/Maestro/SDK/SamplesWeb
- SamplesWeb.suo
*.suo
+ SamplesWeb.suo
*.suo
.vs
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj 2016-04-07 14:39:48 UTC (rev 8909)
@@ -12,7 +12,7 @@
<RootNamespace>SamplesWeb</RootNamespace>
<AssemblyName>SamplesWeb</AssemblyName>
<FileUpgradeFlags>
</FileUpgradeFlags>
<UpgradeBackupLocation>
@@ -24,6 +24,7 @@
<IISExpressAnonymousAuthentication />
<IISExpressWindowsAuthentication />
<IISExpressUseClassicPipelineMode />
+ <UseGlobalApplicationHostFile />
</PropertyGroup>
<PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
<DebugSymbols>true</DebugSymbols>
@@ -33,6 +34,7 @@
</PropertyGroup>
@@ -41,6 +43,7 @@
</PropertyGroup>
<ItemGroup>
<Reference Include="OSGeo.MapGuide.MaestroAPI, Version=3.0.0.5728, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Web.config
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Web.config 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Web.config 2016-04-07 14:39:48 UTC (rev 8909)
@@ -4,6 +4,14 @@
<add key="MapAgentUrl" value="http://localhost/mapguide/mapagent/mapagent.fcgi"/>
</appSettings>
<connectionStrings/>
+ For a description of web.config changes see http://go.microsoft.com/fwlink/?LinkId=235367.
+ The following attributes can be set on the <httpRuntime> tag.
+ <system.Web>
+ <httpRuntime targetFramework="4.5" />
+ </system.Web>
<system.web>
Set compilation debug="true" to insert debugging
@@ -11,7 +19,7 @@
affects performance, set this value to true only
during development.
- <compilation debug="true" targetFramework="4.0"/>
+ <compilation debug="true" targetFramework="4.5"/>
The <authentication> section enables configuration
of the security authentication mode used by
Modified: trunk/Tools/Maestro/SDK/sdk_changelog.txt
--- trunk/Tools/Maestro/SDK/sdk_changelog.txt 2016-04-07 13:59:01 UTC (rev 8908)
+++ trunk/Tools/Maestro/SDK/sdk_changelog.txt 2016-04-07 14:39:48 UTC (rev 8909)
@@ -11,6 +11,7 @@
extension methods that previously relied on this fact now take an IServerConnection parameter to provide context.
- Applications will now generally need to reference OSGeo.MapGuide.ObjectModels in addition to OSGeo.MapGuide.MaestroAPI for most existing code to compile
and work as before.
+ - Need to target .net Framework 4.5 as a minimum (6.0m5 onwards)
5.1
More information about the mapguide-commits
