[mapguide-commits] r8910 - in branches/3.0/vagrant: centos/x64 centos/x86 scripts ubuntu/x64 ubuntu/x86
svn_mapguide at osgeo.org
Fri Apr 8 22:22:44 PDT 2016
Author: jng
Date: 2016-04-08 22:22:43 -0700 (Fri, 08 Apr 2016)
New Revision: 8910
branches/3.0/vagrant/centos/x64/Vagrantfile
branches/3.0/vagrant/centos/x86/Vagrantfile
branches/3.0/vagrant/scripts/build.sh
branches/3.0/vagrant/scripts/build_fdo.sh
branches/3.0/vagrant/scripts/dpkgfdocore.sh
branches/3.0/vagrant/scripts/dpkgfdoprovider.sh
branches/3.0/vagrant/scripts/dpkgmapguide.sh
branches/3.0/vagrant/scripts/mginstallcentos.sh
branches/3.0/vagrant/scripts/mginstallubuntu.sh
branches/3.0/vagrant/scripts/mguninstallcentos.sh
branches/3.0/vagrant/scripts/provision_centos.sh
branches/3.0/vagrant/scripts/provision_ubuntu.sh
branches/3.0/vagrant/ubuntu/x64/Vagrantfile
branches/3.0/vagrant/ubuntu/x86/Vagrantfile
Fix up the vagrant build system for 3.0
- build.sh
- Explicitly set --with-fdo-include and --with-fdo-lib options on MapGuide configure script
- build_fdo.sh
- Explicitly set prefix on build_thirdparty.sh
- Parameterize the distro name for the final SDK tarball
- dpkgfdocore.sh
- Parameterize FDO version number
- dpkgfdoprovider.sh
- Set baseline FDO version number
- dpkgmapguide.sh
- Set baseline MapGuide/FDO version numbers
- mginstallcentos.sh/mginstallubuntu.sh
- Parameterize
- MapGuide version number
- FDO version number
- Release label
- Set parameterized values to baseline settings so that provisioning scripts know what to look for when stamping the file
- mguninstallcentos.sh
- Parameterize MapGuide/FDO version numbers
- provision_centos.sh/provision_ubuntu.sh
- Add release label and distro top-level parameters and export these parameters so that build_fdo.sh and build.sh can access them
- Only copy log/test files to output directory if they exist (which they won't if unit tests are disabled)
- Fix incorrect stamping of install/uninstall script
- Vagrantfiles
- Pass in distro and release label as required by the updated provisioning scripts
Modified: branches/3.0/vagrant/centos/x64/Vagrantfile
--- branches/3.0/vagrant/centos/x64/Vagrantfile 2016-04-07 14:39:48 UTC (rev 8909)
+++ branches/3.0/vagrant/centos/x64/Vagrantfile 2016-04-09 05:22:43 UTC (rev 8910)
@@ -119,5 +119,5 @@
config.vm.provision "shell",
privileged: false,
path: "provision_centos.sh",
- args: [4, 0, 1, 3, 0, 1, "4.0", "3.0", "amd64"]
+ args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "amd64", "Final", "centos6"]
end
Modified: branches/3.0/vagrant/centos/x86/Vagrantfile
--- branches/3.0/vagrant/centos/x86/Vagrantfile 2016-04-07 14:39:48 UTC (rev 8909)
+++ branches/3.0/vagrant/centos/x86/Vagrantfile 2016-04-09 05:22:43 UTC (rev 8910)
@@ -119,5 +119,5 @@
privileged: false,
- args: [4, 0, 1, 3, 0, 1, "4.0", "3.0", "i386"]
+ args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "i386", "Final", "centos6"]
end
Modified: branches/3.0/vagrant/scripts/build.sh
--- branches/3.0/vagrant/scripts/build.sh 2016-04-07 14:39:48 UTC (rev 8909)
+++ branches/3.0/vagrant/scripts/build.sh 2016-04-09 05:22:43 UTC (rev 8910)
@@ -2,9 +2,16 @@
# Global vars for this script. Modify as necessary
MG_VER_MAJOR=${MG_VER_MAJOR:-3}
-MG_VER_MINOR=${MG_VER_MINOR:-1}
-MG_VER_REV=${MG_VER_REV:-0}
+MG_VER_MINOR=${MG_VER_MINOR:-0}
+MG_VER_REV=${MG_VER_REV:-1}
+FDO_VER_MAJOR=${FDO_VER_MAJOR:-4}
+FDO_VER_MINOR=${FDO_VER_MINOR:-0}
+FDO_VER_REV=${FDO_VER_REV:-0}
+MG_DISTRO=${MG_DISTRO:-centos6}
+FDO_INST=/usr/local/fdo-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}
APIVERSION=${MG_VER_MAJOR}.${MG_VER_MINOR}
BUILDNUM=${APIVERSION}.${MG_VER_REV}
BUILDROOT=`pwd`
@@ -42,6 +49,8 @@
echo " Debug Build?: ${MGDEBUG}"
echo " Preserving the build dir?: ${PRESERVE_BUILD_ROOT}"
echo " JAVA_HOME: ${JAVA_HOME}"
+echo " Using FDO headers from: ${FDO_INST}/include"
+echo " Using FDO libs from: ${FDO_INST}/lib"
echo "******************************************************************"
# Need JAVA_HOME for JavaApi
@@ -190,16 +199,16 @@
if [ "${MG_ARCH}" = "amd64" ] || [ $(uname -m) = "x86_64" ]; then
MGCPUPLATFORM=amd64
if [ ${MGDEBUG} -eq 1 ]; then
- ./configure --disable-optimized --enable-silent-rules --enable-64bit --prefix=${INSTALLROOT}
+ ./configure --disable-optimized --enable-silent-rules --enable-64bit --prefix=${INSTALLROOT} --with-fdo-include=${FDO_INST}/include --with-fdo-lib=${FDO_INST}/lib
else
- ./configure --enable-optimized --enable-silent-rules --enable-64bit --prefix=${INSTALLROOT}
+ ./configure --enable-optimized --enable-silent-rules --enable-64bit --prefix=${INSTALLROOT} --with-fdo-include=${FDO_INST}/include --with-fdo-lib=${FDO_INST}/lib
fi
else
MGCPUPLATFORM=i386
- ./configure --disable-optimized --enable-silent-rules --prefix=${INSTALLROOT}
+ ./configure --disable-optimized --enable-silent-rules --prefix=${INSTALLROOT} --with-fdo-include=${FDO_INST}/include --with-fdo-lib=${FDO_INST}/lib
else
- ./configure --enable-optimized --enable-silent-rules --prefix=${INSTALLROOT}
+ ./configure --enable-optimized --enable-silent-rules --prefix=${INSTALLROOT} --with-fdo-include=${FDO_INST}/include --with-fdo-lib=${FDO_INST}/lib
fi
fi
make $MY_MAKE_OPTS
@@ -255,7 +264,7 @@
mkdir -p bin
fi
- tar -Jcf bin/mapguideopensource-${BUILDNUM}.${REVISION}.${MGCPUPLATFORM}.tar.xz ${INSTALLROOT} ${LOCKFILEDIR}
+ tar -Jcf bin/mapguideopensource-${MG_DISTRO}-${BUILDNUM}.${REVISION}.${MGCPUPLATFORM}.tar.xz ${INSTALLROOT} ${LOCKFILEDIR}
fi
echo "Build complete!"
echo MapGuide main build execution: `expr $end_time - $start_time` s
Modified: branches/3.0/vagrant/scripts/build_fdo.sh
--- branches/3.0/vagrant/scripts/build_fdo.sh 2016-04-07 14:39:48 UTC (rev 8909)
+++ branches/3.0/vagrant/scripts/build_fdo.sh 2016-04-09 05:22:43 UTC (rev 8910)
@@ -13,9 +13,11 @@
# FDO version. Make sure this matches your FDO build source
-FDO_VER_MINOR=${FDO_VER_MINOR:-1}
+FDO_DISTRO=${FDO_DISTRO:-centos6}
# FDO install directory
FDO_VER_FULL=${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}
@@ -319,7 +321,7 @@
echo "the GDAL SDK files to $FDOTHIRDPARTY/gdal. "
echo "If this value remains unchanged, the FDO build process will"
echo "build the version of GDAL located in Thirdparty/gdal and will "
- echo "install the resulting libraries in /usr/local/fdo-3.9.0. The FDO build"
+ echo "install the resulting libraries in $FDO_INST. The FDO build"
echo "process will then use that location when building the GDAL and"
echo "WMS providers. If you wish to build the FDO GDAL or WMS Providers"
echo "using a previously installed version of GDAL, modify the setenvironment.sh "
@@ -363,8 +365,8 @@
# parameter no installation directory is created, ie.:
# $ source ./setenvironment.sh --noinstall
if test ! $# -eq 1; then
- mkdir -p "/usr/local/fdo-${FDO_VER_FULL}/lib"
- export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/fdo-${FDO_VER_FULL}/lib:$SDEHOME/lib
+ mkdir -p "$FDO_INST/lib"
+ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$FDO_INST/lib:$SDEHOME/lib
fi
export XERCESCROOT=$FDOTHIRDPARTY/apache/xerces
@@ -504,7 +506,7 @@
cd ${FDO_BUILD_AREA}
FDO_BUILD_COMPONENT="FDO Thirdparty"
-./build_thirdparty.sh -b ${FDO_PLATFORM} --c ${FDO_BUILD_CONF}
+./build_thirdparty.sh -b ${FDO_PLATFORM} --c ${FDO_BUILD_CONF} --p ${FDO_INST}
check_fdo_build
if [ ${CMAKE} -eq 1 ];
@@ -574,7 +576,7 @@
FDO_BUILD_COMPONENT="Make tarball"
# Create a binary tar ball for FDO
cd ${FDO_INST}
- tar -Jcf ${BUILDROOT}/fdosdk-centos6-${FDO_BUILD_CPU}-${FDO_VER_FULL}_${REVISION}.tar.xz *
+ tar -Jcf ${BUILDROOT}/fdosdk-${FDO_DISTRO}-${FDO_BUILD_CPU}-${FDO_VER_FULL}_${REVISION}.tar.xz *
check_fdo_build
if [ ${UBUNTU} -eq 1 ];
Modified: branches/3.0/vagrant/scripts/dpkgfdocore.sh
--- branches/3.0/vagrant/scripts/dpkgfdocore.sh 2016-04-07 14:39:48 UTC (rev 8909)
+++ branches/3.0/vagrant/scripts/dpkgfdocore.sh 2016-04-09 05:22:43 UTC (rev 8910)
@@ -11,8 +11,13 @@
# control - control file generated from dpkg-gencontrol
# symbols - symbols file generated from dpkg-gensymbols
BUILDROOT=`pwd`
-FDOBUILD=3.9.0
+FDOBUILD=${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}
FDO=usr/local/fdo-${FDOBUILD}
ROOT=${BUILDROOT}/debian/fdocore
TREE=${BUILDROOT}/debian
Modified: branches/3.0/vagrant/scripts/dpkgfdoprovider.sh
--- branches/3.0/vagrant/scripts/dpkgfdoprovider.sh 2016-04-07 14:39:48 UTC (rev 8909)
+++ branches/3.0/vagrant/scripts/dpkgfdoprovider.sh 2016-04-09 05:22:43 UTC (rev 8910)
@@ -13,7 +13,7 @@
# Read and validate command line parameters
Modified: branches/3.0/vagrant/scripts/dpkgmapguide.sh
--- branches/3.0/vagrant/scripts/dpkgmapguide.sh 2016-04-07 14:39:48 UTC (rev 8909)
+++ branches/3.0/vagrant/scripts/dpkgmapguide.sh 2016-04-09 05:22:43 UTC (rev 8910)
@@ -49,11 +49,11 @@
BUILDROOT=`pwd`
Modified: branches/3.0/vagrant/scripts/mginstallcentos.sh
--- branches/3.0/vagrant/scripts/mginstallcentos.sh 2016-04-07 14:39:48 UTC (rev 8909)
+++ branches/3.0/vagrant/scripts/mginstallcentos.sh 2016-04-09 05:22:43 UTC (rev 8910)
@@ -1,22 +1,31 @@
#!/bin/bash
-URL_ROOT="http://download.osgeo.org/mapguide/releases/3.0.0/Beta2"
-URL_PART="centos"
-URL="$URL_ROOT/$URL_PART"
-#URL="http://192.168.0.4/downloads"
-FDOVER_MAJOR_MINOR=4.0
+URL_HOST="http://download.osgeo.org"
+URL_RELPATH="/mapguide/releases"
+FDOVER_MAJOR=0
+FDOVER_MINOR=0
+FDOVER_MAJOR_MINOR=${FDOVER_MAJOR}.${FDOVER_MINOR}
FDOVER_POINT=0
FDOVER_REV=0
FDO_ARCH=i386
FDOVER_MAJOR_MINOR_REV=${FDOVER_MAJOR_MINOR}.${FDOVER_POINT}
FDOVER=${FDOVER_MAJOR_MINOR_REV}_${FDOVER_REV}
-MGVER_MAJOR_MINOR=3.0
+MGVER_MAJOR=0
+MGVER_MINOR=0
+MGVER_MAJOR_MINOR=${MGVER_MAJOR}.${MGVER_MINOR}
MGVER_POINT=0
MGVER_REV=0
MG_ARCH=i386
MGVER_MAJOR_MINOR_REV=${MGVER_MAJOR_MINOR}.${MGVER_POINT}
MGVER=${MGVER_MAJOR_MINOR_REV}.${MGVER_REV}
+MGRELEASELABEL="ReleaseLabel"
FDO_TARBALL=fdosdk-centos6-${FDO_ARCH}-${FDOVER}.tar.xz
-MG_TARBALL=mapguideopensource-${MGVER}.${MG_ARCH}.tar.xz
+MG_TARBALL=mapguideopensource-centos6-${MGVER}.${MG_ARCH}.tar.xz
+URL_ROOT="${URL_HOST}/${URL_RELPATH}/${MGVER_MAJOR_MINOR_REV}/${MGRELEASELABEL}"
+URL_PART="centos"
+URL="$URL_ROOT/$URL_PART"
MG_URL=${URL}/${MG_TARBALL}
FDO_URL=${URL}/${FDO_TARBALL}
Modified: branches/3.0/vagrant/scripts/mginstallubuntu.sh
--- branches/3.0/vagrant/scripts/mginstallubuntu.sh 2016-04-07 14:39:48 UTC (rev 8909)
+++ branches/3.0/vagrant/scripts/mginstallubuntu.sh 2016-04-09 05:22:43 UTC (rev 8910)
@@ -1,21 +1,30 @@
#!/bin/bash
TEMPDIR=/tmp/build_mapguide
-URL_PART="ubuntu12"
-#URL="http://192.168.0.5/downloads/ubuntu12"
-FDOVER_MAJOR_MINOR_REV=${FDOVER_MAJOR_MINOR}.0
+FDOVER_MAJOR=0
+FDOVER_MINOR=0
+FDOVER_POINT=0
+FDOVER_MAJOR_MINOR_REV=${FDOVER_MAJOR_MINOR}.${FDOVER_POINT}
FDOBUILD=0
FDOARCH=i386
FDOVER=${FDOVER_MAJOR_MINOR_REV}-${FDOBUILD}_${FDOARCH}
-MGVER_MAJOR_MINOR_REV=${MGVER_MAJOR_MINOR}.0
+MGVER_MAJOR=0
+MGVER_MINOR=0
+MGVER_POINT=0
+MGVER_MAJOR_MINOR_REV=${MGVER_MAJOR_MINOR}.${MGVER_POINT}
MGBUILD=0
MGARCH=i386
MGVER=${MGVER_MAJOR_MINOR_REV}-${MGBUILD}_${MGARCH}
INSTALLER_TITLE="MapGuide Open Source Ubuntu installer"
+URL_PART="ubuntu"
DEFAULT_SERVER_IP="127.0.0.1"
DEFAULT_ADMIN_PORT=2810
Modified: branches/3.0/vagrant/scripts/mguninstallcentos.sh
--- branches/3.0/vagrant/scripts/mguninstallcentos.sh 2016-04-07 14:39:48 UTC (rev 8909)
+++ branches/3.0/vagrant/scripts/mguninstallcentos.sh 2016-04-09 05:22:43 UTC (rev 8910)
@@ -1,8 +1,12 @@
#!/bin/bash
+FDOVER_MAJOR=0
+FDOVER_MINOR=0
FDOVER_POINT=0
+MGVER_MAJOR=0
+MGVER_MINOR=0
MGVER_POINT=0
Modified: branches/3.0/vagrant/scripts/provision_centos.sh
--- branches/3.0/vagrant/scripts/provision_centos.sh 2016-04-07 14:39:48 UTC (rev 8909)
+++ branches/3.0/vagrant/scripts/provision_centos.sh 2016-04-09 05:22:43 UTC (rev 8910)
@@ -6,6 +6,7 @@
# Expected environment (set up by vagrant)
+# - Calling vagrantfile is for a CentOS 6.x box
# - Vagrant folder (path of the Vagrantfile) mounted as: /vagrant
# - Source folder mounted as: /mapguide_sources
# - Contains tarballs for MapGuide/FDO
@@ -21,7 +22,11 @@
# $7 - FDO branch name (trunk|major.minor)
# $8 - MG branch name (trunk|major.minor)
# $9 - architecture (i386|amd64)
+# $10 - release label (eg. Beta1, RC1, Final)
+# $11 - distro label (eg. centos6, ubuntu12) - Optional
+PROVISION_START_TIME=`date +%s`
echo "*****************************************************"
echo " Arg check"
echo " 1 - ${1}"
@@ -33,6 +38,8 @@
echo " 7 - ${7}"
echo " 8 - ${8}"
echo " 9 - ${9}"
+echo " 10 - ${10}"
+echo " 11 - ${11}"
# FDO version
@@ -49,6 +56,10 @@
MG_BRANCH=${8}
MG_ARCH=${9}
+MG_RELEASE_LABEL=${10}
+DISTRO=${11:-centos6}
+FDO_DISTRO=${DISTRO}
+MG_DISTRO=${DISTRO}
UBUNTU=0
FDO_PLATFORM=
@@ -72,6 +83,8 @@
export MG_BRANCH
export MG_ARCH
export UBUNTU
+export FDO_DISTRO
+export MG_DISTRO
BUILD_COMPONENT=
check_build()
@@ -129,7 +142,9 @@
echo "FDO branch: ${FDO_BRANCH}"
echo "MG version: ${MG_VER_MAJOR}.${MG_VER_MINOR}.${MG_VER_REV}"
echo "MG branch: ${MG_BRANCH}"
-echo "Build target: centos - ${MG_ARCH}"
+echo "Build target: ${MG_DISTRO} - ${MG_ARCH}"
+echo "Release Label: ${MG_RELEASE_LABEL}"
+echo "FDO Distro label: ${FDO_DISTRO}"
echo "Checking directories"
echo "********************************************************************************"
@@ -273,30 +288,60 @@
sudo mv -f ~/*.log /vagrant/build
echo [provision]: Copy tarballs to output dir
sudo cp bin/*.tar.xz /vagrant/build
-sudo cp fdosdk-centos6-${MG_ARCH}-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}_${FDO_REV}.tar.xz /vagrant/build
+sudo cp fdosdk-${FDO_DISTRO}-${MG_ARCH}-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}_${FDO_REV}.tar.xz /vagrant/build
if [ $MAKE_FDO_SDK -eq 1 ]; then
echo [provision]: Copy FDO SDK for Ubuntu builds
# Copy SDK also to sources, so Ubuntu can pick it up
sudo rm -f /mapguide_sources/fdosdk*.tar.xz
- sudo cp fdosdk-centos6-${MG_ARCH}-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}_${FDO_REV}.tar.xz /mapguide_sources
+ sudo cp fdosdk-${FDO_DISTRO}-${MG_ARCH}-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}_${FDO_REV}.tar.xz /mapguide_sources
# Record file name so Ubuntu knows what tarball to extract from
- sudo echo fdosdk-centos6-${MG_ARCH}-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}_${FDO_REV}.tar.xz > /mapguide_sources/fdosdk_filename
+ sudo echo fdosdk-${FDO_DISTRO}-${MG_ARCH}-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}_${FDO_REV}.tar.xz > /mapguide_sources/fdosdk_filename
sudo echo ${FDO_REV} > /mapguide_sources/fdosdk_rev
# Export filelist to Ubuntu can deb package this SDK if needed
sudo cp -R $SCRIPT_ROOT/fdo_build_area/install/filelist /mapguide_sources
fi
echo [provision]: Copy unit test logs to output dir
-sudo mv ~/unit_test_status.log /vagrant/build/unit_test_status.log
-sudo mv ~/fdo_*_unit_test.log /vagrant/build
-sudo mv ~/UnitTestResults_*.xml /vagrant/build
+if [ -f "~/unit_test_status.log" ]; then
+ sudo mv ~/unit_test_status.log /vagrant/build/unit_test_status.log
+fi
+if ls ~/fdo_*_unit_test.log 1> /dev/null 2>&1; then
+ sudo mv ~/fdo_*_unit_test.log /vagrant/build
+else
+ echo [provision]: No FDO unit test result files found. If FDO_UNIT_TEST is 0 [value is ${FDO_UNIT_TEST}], this can be safely ignored
+fi
+if ls ~/UnitTestResults_*.xml 1> /dev/null 2>&1; then
+ sudo mv ~/UnitTestResults_*.xml /vagrant/build
+else
+ echo [provision]: No MapGuide unit test result files found. If MG_UNIT_TEST is 0 [value is ${MG_UNIT_TEST}], this can be safely ignored
+fi
echo [provision]: Copy install/uninstall scripts to output dir
-DISTNAME=centos_x86
-if [ "${MG_ARCH}" -eq "amd64" ]; then
- DISTNAME=centos_x64
+DISTNAME=${MG_DISTRO}_x86
+if [ "${MG_ARCH}" = "amd64" ]; then
+ DISTNAME=${MG_DISTRO}_x64
fi
-sudo sed -i 's/URL_PART="centos"/URL_PART='"$DISTNAME"'/g' /vagrant/build/mginstallcentos.sh
+echo [provision]: Stamping install script
sudo cp /vagrant/mginstallcentos.sh /vagrant/build/mginstallcentos.sh
sudo cp /vagrant/mguninstallcentos.sh /vagrant/build/mguninstallcentos.sh
+sudo sed -i 's/URL_PART="centos"/URL_PART='"$DISTNAME"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/MGRELEASELABEL="ReleaseLabel"/MGRELEASELABEL='"$MG_RELEASE_LABEL"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/FDO_ARCH=i386/FDO_ARCH='"$MG_ARCH"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/MG_ARCH=i386/MG_ARCH='"$MG_ARCH"'/g' /vagrant/build/mginstallcentos.sh
sudo sed -i 's/FDOVER_REV=0/FDOVER_REV='"$FDO_REV"'/g' /vagrant/build/mginstallcentos.sh
sudo sed -i 's/MGVER_REV=0/MGVER_REV='"$MG_REV"'/g' /vagrant/build/mginstallcentos.sh
-echo [provision]: Build complete
\ No newline at end of file
+sudo sed -i 's/FDOVER_MAJOR=0/FDOVER_MAJOR='"$FDO_VER_MAJOR"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/FDOVER_MINOR=0/FDOVER_MINOR='"$FDO_VER_MINOR"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/FDOVER_POINT=0/FDOVER_POINT='"$FDO_VER_REV"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/MGVER_MAJOR=0/MGVER_MAJOR='"$MG_VER_MAJOR"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/MGVER_MINOR=0/MGVER_MINOR='"$MG_VER_MINOR"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/MGVER_POINT=0/MGVER_POINT='"$MG_VER_REV"'/g' /vagrant/build/mginstallcentos.sh
+echo [provision]: Stamping variables to uninstall script
+sudo sed -i 's/FDOVER_MAJOR=0/FDOVER_MAJOR='"$FDO_VER_MAJOR"'/g' /vagrant/build/mguninstallcentos.sh
+sudo sed -i 's/FDOVER_MINOR=0/FDOVER_MINOR='"$FDO_VER_MINOR"'/g' /vagrant/build/mguninstallcentos.sh
+sudo sed -i 's/FDOVER_POINT=0/FDOVER_POINT='"$FDO_VER_REV"'/g' /vagrant/build/mguninstallcentos.sh
+sudo sed -i 's/MGVER_MAJOR=0/MGVER_MAJOR='"$MG_VER_MAJOR"'/g' /vagrant/build/mguninstallcentos.sh
+sudo sed -i 's/MGVER_MINOR=0/MGVER_MINOR='"$MG_VER_MINOR"'/g' /vagrant/build/mguninstallcentos.sh
+sudo sed -i 's/MGVER_POINT=0/MGVER_POINT='"$MG_VER_REV"'/g' /vagrant/build/mguninstallcentos.sh
+PROVISION_END_TIME=`date +%s`
+echo [provision]: Build complete
+echo [provision]: Overall build duration: `expr $PROVISION_END_TIME - $PROVISION_START_TIME` s
Modified: branches/3.0/vagrant/scripts/provision_ubuntu.sh
--- branches/3.0/vagrant/scripts/provision_ubuntu.sh 2016-04-07 14:39:48 UTC (rev 8909)
+++ branches/3.0/vagrant/scripts/provision_ubuntu.sh 2016-04-09 05:22:43 UTC (rev 8910)
@@ -1,11 +1,12 @@
#!/bin/bash
-# provision_centos.sh
+# provision_ubuntu.sh
# Entry point provisioning shell script
+# - Calling vagrantfile is for a Ubuntu 12.04.x LTS box
@@ -21,7 +22,11 @@
echo " Arg check"
echo " 1 - ${1}"
@@ -33,6 +38,8 @@
echo " 7 - ${7}"
echo " 8 - ${8}"
echo " 9 - ${9}"
+echo " 10 - ${10}"
+echo " 11 - ${11}"
# FDO version
@@ -49,6 +56,10 @@
MG_BRANCH=${8}
MG_ARCH=${9}
+DISTRO=${11:-ubuntu12}
UBUNTU=1
FDO_PLATFORM=
@@ -72,6 +83,8 @@
export MG_BRANCH
export MG_ARCH
export UBUNTU
+export FDO_DISTRO
+export MG_DISTRO
BUILD_COMPONENT=
check_build()
@@ -129,7 +142,9 @@
@@ -276,14 +291,14 @@
@@ -293,17 +308,39 @@
echo [provision]: Copy MapGuide deb packages
sudo cp bin/*.deb /vagrant/build
+fi
+else
+fi
+else
+fi
-DISTNAME=ubuntu12_x86
- DISTNAME=ubuntu12_x64
fi
-sudo sed -i 's/URL_PART="ubuntu12"/URL_PART='"$DISTNAME"'/g' /vagrant/build/mginstallubuntu.sh
sudo cp /vagrant/mginstallubuntu.sh /vagrant/build/mginstallubuntu.sh
sudo cp /vagrant/mguninstallubuntu.sh /vagrant/build/mguninstallubuntu.sh
-sudo sed -i 's/FDOVER_REV=0/FDOVER_REV='"$FDO_REV"'/g' /vagrant/build/mginstallubuntu.sh
-sudo sed -i 's/MGVER_REV=0/MGVER_REV='"$MG_REV"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/URL_PART="ubuntu12"/URL_PART='"$DISTNAME"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/MGRELEASELABEL="ReleaseLabel"/MGRELEASELABEL='"$MG_RELEASE_LABEL"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/FDOARCH=i386/FDOARCH='"$MG_ARCH"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/MGARCH=i386/MGARCH='"$MG_ARCH"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/FDOBUILD=0/FDOBUILD='"$FDO_REV"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/MGBUILD=0/MGBUILD='"$MG_REV"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/FDOVER_MAJOR=0/FDOVER_MAJOR='"$FDO_VER_MAJOR"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/FDOVER_MINOR=0/FDOVER_MINOR='"$FDO_VER_MINOR"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/FDOVER_POINT=0/FDOVER_POINT='"$FDO_VER_REV"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/MGVER_MAJOR=0/MGVER_MAJOR='"$MG_VER_MAJOR"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/MGVER_MINOR=0/MGVER_MINOR='"$MG_VER_MINOR"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/MGVER_POINT=0/MGVER_POINT='"$MG_VER_REV"'/g' /vagrant/build/mginstallubuntu.sh
Modified: branches/3.0/vagrant/ubuntu/x64/Vagrantfile
--- branches/3.0/vagrant/ubuntu/x64/Vagrantfile 2016-04-07 14:39:48 UTC (rev 8909)
+++ branches/3.0/vagrant/ubuntu/x64/Vagrantfile 2016-04-09 05:22:43 UTC (rev 8910)
@@ -119,5 +119,5 @@
privileged: false,
path: "provision_ubuntu.sh",
+ args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "amd64", "Final", "ubuntu12"]
end
Modified: branches/3.0/vagrant/ubuntu/x86/Vagrantfile
--- branches/3.0/vagrant/ubuntu/x86/Vagrantfile 2016-04-07 14:39:48 UTC (rev 8909)
+++ branches/3.0/vagrant/ubuntu/x86/Vagrantfile 2016-04-09 05:22:43 UTC (rev 8910)
@@ -119,5 +119,5 @@
privileged: false,
+ args: [4, 0, 0, 3, 0, 1, "4.0", "3.0", "i386", "Final", "ubuntu12"]
end
More information about the mapguide-commits
