[mapguide-commits] r8911 - in branches/2.6/vagrant: . centos/src_update centos/x64 centos/x86 scripts ubuntu/x64 ubuntu/x86
svn_mapguide at osgeo.org
Sat Apr 9 21:30:40 PDT 2016
Author: jng
Date: 2016-04-09 21:30:40 -0700 (Sat, 09 Apr 2016)
New Revision: 8911
Added:
branches/2.6/vagrant/scripts/provision_centos.sh
branches/2.6/vagrant/scripts/provision_ubuntu.sh
branches/2.6/vagrant/scripts/svn_update.sh
branches/2.6/vagrant/README.txt
branches/2.6/vagrant/build.bat
branches/2.6/vagrant/centos/src_update/Vagrantfile
branches/2.6/vagrant/centos/x64/Vagrantfile
branches/2.6/vagrant/centos/x86/Vagrantfile
branches/2.6/vagrant/scripts/build.sh
branches/2.6/vagrant/scripts/build_fdo.sh
branches/2.6/vagrant/scripts/dpkgfdocore.sh
branches/2.6/vagrant/scripts/dpkgfdoprovider.sh
branches/2.6/vagrant/scripts/dpkgmapguide.sh
branches/2.6/vagrant/scripts/mapguidecommon_excludes.txt
branches/2.6/vagrant/scripts/mginstallcentos.sh
branches/2.6/vagrant/scripts/mginstallubuntu.sh
branches/2.6/vagrant/scripts/mguninstallcentos.sh
branches/2.6/vagrant/scripts/platformbase_excludes.txt
branches/2.6/vagrant/ubuntu/x64/Vagrantfile
branches/2.6/vagrant/ubuntu/x86/Vagrantfile
branches/2.6/vagrant/verify.bat
Bring across the vagrant build environment from 3.0 to the 2.6 branch
Property changes on: branches/2.6/vagrant
___________________________________________________________________
Added: svn:ignore
+ builds
Modified: branches/2.6/vagrant/README.txt
--- branches/2.6/vagrant/README.txt 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/README.txt 2016-04-10 04:30:40 UTC (rev 8911)
@@ -66,3 +66,14 @@
If a given build does not produce the expected build artifacts, always check the build logs for any errors.
+Release Versioning
+When doing branched releases, the following files have to be modified and their respective MapGuide and FDO versions and branch names updated to match:
+ - centos\x64\Vagrantfile
+ - centos\x86\Vagrantfile
+ - ubuntu\x64\Vagrantfile
+ - ubuntu\x86\Vagrantfile
+ - scripts\mapguidecommon_excludes.txt
+ - scripts\platformbase_excludes.txt
Modified: branches/2.6/vagrant/build.bat
--- branches/2.6/vagrant/build.bat 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/build.bat 2016-04-10 04:30:40 UTC (rev 8911)
@@ -11,13 +11,13 @@
IF "%MG_SVN_UPDATE_SOURCES%"=="" SET MG_SVN_UPDATE_SOURCES=1
IF "%BUILD_UBUNTU_32%"=="" SET BUILD_UBUNTU_32=1
-IF "%BUILD_UBUNTU_64%"=="" SET BUILD_UBUNTU_64=0
+IF "%BUILD_UBUNTU_64%"=="" SET BUILD_UBUNTU_64=1
IF "%BUILD_CENTOS_32%"=="" SET BUILD_CENTOS_32=1
-IF "%BUILD_CENTOS_64%"=="" SET BUILD_CENTOS_64=0
+IF "%BUILD_CENTOS_64%"=="" SET BUILD_CENTOS_64=1
IF "%TEARDOWN_UBUNTU_32%"=="" SET TEARDOWN_UBUNTU_32=1
-IF "%TEARDOWN_UBUNTU_64%"=="" SET TEARDOWN_UBUNTU_64=0
+IF "%TEARDOWN_UBUNTU_64%"=="" SET TEARDOWN_UBUNTU_64=1
IF "%TEARDOWN_CENTOS_32%"=="" SET TEARDOWN_CENTOS_32=1
-IF "%TEARDOWN_CENTOS_64%"=="" SET TEARDOWN_CENTOS_64=0
+IF "%TEARDOWN_CENTOS_64%"=="" SET TEARDOWN_CENTOS_64=1
SET ROOT=%CD%
SET COMPONENT=
echo **************** Build Summary *********************
@@ -29,6 +29,7 @@
echo ****************************************************
:prepare
echo [build]: Prepare scripts for provisioning
+copy /Y scripts\svn_update.sh %ROOT%\centos\src_update
if %BUILD_CENTOS_32% == 1 xcopy /S /Y /I scripts\* %ROOT%\centos\x86
if %BUILD_UBUNTU_32% == 1 xcopy /S /Y /I scripts\* %ROOT%\ubuntu\x86
if %BUILD_CENTOS_64% == 1 xcopy /S /Y /I scripts\* %ROOT%\centos\x64
Modified: branches/2.6/vagrant/centos/src_update/Vagrantfile
--- branches/2.6/vagrant/centos/src_update/Vagrantfile 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/centos/src_update/Vagrantfile 2016-04-10 04:30:40 UTC (rev 8911)
@@ -116,87 +116,8 @@
# chef.validation_client_name = "ORGNAME-validator"
- $script = <<SCRIPT
-BUILD_COMPONENT=
-check_build()
- error=$?
- if [ $error -ne 0 ]; then
- echo "[error]: ${BUILD_COMPONENT} - Error build failed ($error)"
- exit $error
- fi
-cd ~
-echo [provision]: Home directory is `pwd`
-echo [provision]: Checking directories
-HAVE_FDO=0
-HAVE_FDO_LIBS=0
-HAVE_MAPGUIDE=0
-MG_UNIT_TEST=1
-FDO_UNIT_TEST=1
-MAKE_FDO_SDK=0
-FDO_SRC_ROOT=~/fdo/branches
-FDO_VER_MM=3.9
-FDO_VER_FULL=${FDO_VER_MM}.1
-MG_VER_MM=2.6
-MG_VER_FULL=${MG_VER_MM}.1
-FDO_SRC_DIR=3.9
-FDO_SRC=$FDO_SRC_ROOT/$FDO_SRC_DIR
-MG_SRC_ROOT=~/mapguide/branches/2.6
-MG_SRC=$MG_SRC_ROOT/MgDev
-FDO_TARBALL=fdo-checkout-3.9.tar.gz
-MG_TARBALL=mapguide-checkout-2.6.tar.gz
-FDO_INST_PATH=/usr/local/fdo-${FDO_VER_FULL}
-MG_INST_PATH=/usr/local/mapguideopensource-${MG_VER_FULL}
-if [ -d $FDO_SRC ];
-then
- HAVE_FDO=1
-fi
-if [ -d $MG_SRC ];
-then
- HAVE_MAPGUIDE=1
-fi
-if [ $HAVE_FDO -eq 0 ];
-then
- echo [provision]: Extracting FDO working copy
- mkdir -p $FDO_SRC_ROOT
- tar -zxf /mapguide_sources/$FDO_TARBALL -C $FDO_SRC_ROOT
-fi
-if [ $HAVE_MAPGUIDE -eq 0 ];
-then
- echo [provision]: Extracting MapGuide working copy
- mkdir -p $MG_SRC_ROOT
- tar -zxf /mapguide_sources/$MG_TARBALL -C $MG_SRC_ROOT
-fi
-echo [provision]: svn update FDO
-BUILD_COMPONENT="svn update FDO"
-svn update $FDO_SRC
-check_build
-echo [provision]: svn update MapGuide
-BUILD_COMPONENT="svn update MapGuide"
-svn update $MG_SRC
-check_build
-if [ ! -d /mapguide_sources/updated ]; then
- sudo mkdir -p /mapguide_sources/updated
- cd $MG_SRC_ROOT
- echo [provision]: Updating mapguide source tarball
- tar -zcf $MG_TARBALL MgDev
- sudo mv $MG_TARBALL /mapguide_sources/updated
- cd $FDO_SRC_ROOT
- echo [provision]: Updating fdo source tarball
- tar -zcf $FDO_TARBALL $FDO_SRC_DIR
- sudo mv $FDO_TARBALL /mapguide_sources/updated
-else
- echo [provision]: Updated tarballs already exist. Doing nothing
-fi
-echo [provision]: Build complete
-echo [info]: MapGuide working copy
-svn info $MG_SRC
-echo [info]: FDO working copy
-svn info $FDO_SRC
-SCRIPT
config.vm.provision "shell",
privileged: false,
- inline: $script
+ path: "svn_update.sh",
+ args: ["3.9", "2.6"]
end
Modified: branches/2.6/vagrant/centos/x64/Vagrantfile
--- branches/2.6/vagrant/centos/x64/Vagrantfile 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/centos/x64/Vagrantfile 2016-04-10 04:30:40 UTC (rev 8911)
@@ -116,230 +116,8 @@
-BUILD_COMPONENT=
-check_build()
- error=$?
- exit $error
- fi
-check_test()
- error=$?
- echo "[warning]: ${BUILD_COMPONENT} - Unit Tests failed ($error)"
- echo "[warning]: ${BUILD_COMPONENT} - Unit Tests failed ($error)" >> ~/unit_test_status.log
- fi
-if hash scons 2>/dev/null; then
- echo [provision]: We have scons
-else
- echo [provision]: We do not have scons. Installing it
- sudo rpm -Uvh /mapguide_sources/scons-2.3.0-1.noarch.rpm
- check_build
-fi
-cd ~
-HAVE_FDO=0
-HAVE_FDO_LIBS=0
-HAVE_MAPGUIDE=0
-MG_UNIT_TEST=0
-FDO_UNIT_TEST=0
-MAKE_FDO_SDK=0
-SCRIPT_ROOT=~/scripts
-FDO_VER_MM=3.9
-FDO_VER_FULL=${FDO_VER_MM}.0
-MG_VER_MM=2.6
-FDO_SRC_DIR=3.9
-FDO_LIB_SRC=~/fdo_rdbms_thirdparty
-then
- HAVE_FDO=1
-fi
-if [ -d $FDO_LIB_SRC ];
-then
- HAVE_FDO_LIBS=1
-fi
-if [ -d $MG_SRC ];
-then
- HAVE_MAPGUIDE=1
-fi
-if [ -f /usr/include/asm/atomic.h ];
-then
- echo [provision]: atomic.h exists. Doing nothing
-else
- echo [provision]: Copy atomic.h
- sudo mkdir -p /usr/include/asm
- sudo cp /mapguide_sources/atomic.h /usr/include/asm
-fi
-echo [provision]: Clean line endings
-sudo dos2unix /vagrant/*.sh
-sudo dos2unix /vagrant/*.pl
-sudo dos2unix /vagrant/*.txt
-echo [provision]: Copying shell scripts
-mkdir -p $SCRIPT_ROOT
-cp -f /vagrant/*.sh $SCRIPT_ROOT
-cp -f /vagrant/*.pl $SCRIPT_ROOT
-cp -f /vagrant/*.txt $SCRIPT_ROOT
-echo [provision]: Flip Ubuntu switch
-cd $SCRIPT_ROOT
-sed -i 's/UBUNTU=1/UBUNTU=0/g' build.sh
-sed -i 's/UBUNTU=1/UBUNTU=0/g' build_fdo.sh
-sed -i 's/FDO_PLATFORM=32/FDO_PLATFORM=64/g' build_fdo.sh
-sed -i 's/FDO_CPU=x86/FDO_CPU=x64/g' build_fdo.sh
-sed -i 's/FDO_BUILD_CPU=i386/FDO_BUILD_CPU=amd64/g' build_fdo.sh
-sed -i 's/LIB_DIRNAME=lib/LIB_DIRNAME=lib64/g' build_fdo.sh
-if [ $HAVE_FDO_LIBS -eq 0 ];
-then
- echo [provision]: Extracting FDO thirdparty libs
- tar -zxf /mapguide_sources/fdo_rdbms_thirdparty.tar.gz -C ~
-fi
-then
-fi
-then
-fi
-if [ -d /mapguide_sources/patches/fdo ];
-then
- echo [provision]: Applying FDO source patches
- cp -R /mapguide_sources/patches/fdo/* $FDO_SRC
-fi
-if [ -d /mapguide_sources/patches/mapguide ];
-then
- echo [provision]: Applying MapGuide source patches
- cp -R /mapguide_sources/patches/mapguide/* $MG_SRC
-fi
-echo [provision]: Making sure swig is executable
-chmod +x $MG_SRC/Oem/SWIGEx/Linux/swig
-cd ~/scripts
-BUILD_COMPONENT="FDO"
-sudo -E ./build_fdo.sh 2>&1 | tee ~/fdo_build.log
-check_build
-BUILD_COMPONENT="MapGuide"
-sudo -E ./build.sh 2>&1 | tee ~/mapguide_build.log
-check_build
-FDO_REV=`svn info $FDO_SRC | perl revnum.pl`
-MG_REV=`svn info $MG_SRC | perl revnum.pl`
-> ~/unit_test_status.log
-if [ $FDO_UNIT_TEST -eq 1 ];
-then
- echo [provision]: Unit test FDO
- BUILD_COMPONENT="Unit Test FDO Core"
- cd $SCRIPT_ROOT/fdo_build_area/Fdo/UnitTest
- sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_core_unit_test.log
- check_test
- BUILD_COMPONENT="Unit Test SHP Provider"
- cd $SCRIPT_ROOT/fdo_build_area/Providers/SHP/Src/UnitTest
- sudo rm providers.xml
- sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_shp_unit_test.log
- check_test
- BUILD_COMPONENT="Unit Test SDF Provider"
- cd $SCRIPT_ROOT/fdo_build_area/Providers/SDF/Src/UnitTest
- sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_sdf_unit_test.log
- check_test
- BUILD_COMPONENT="Unit Test SQLite Provider"
- cd $SCRIPT_ROOT/fdo_build_area/Providers/SQLite/Src/UnitTest
- sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_sqlite_unit_test.log
- check_test
- BUILD_COMPONENT="Unit Test GDAL Provider"
- cd $SCRIPT_ROOT/fdo_build_area/Providers/GDAL/Src/UnitTest
- sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_gdal_unit_test.log
- check_test
- BUILD_COMPONENT="Unit Test OGR Provider"
- cd $SCRIPT_ROOT/fdo_build_area/Providers/OGR/Src/UnitTest
- sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_ogr_unit_test.log
- check_test
- BUILD_COMPONENT="Unit Test WMS Provider"
- cd $SCRIPT_ROOT/fdo_build_area/Providers/WMS/Src/UnitTest
- sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_wms_unit_test.log
- check_test
-fi
-if [ $MG_UNIT_TEST -eq 1 ];
-then
- echo [provision]: Unit test MapGuide
- BUILD_COMPONENT="Unit Test MapGuide Server"
- # HACK: Tile and Resource Service tests are known to freeze our VMs when driven by vagrant (why? who knows?
- # All we know is that those tests involve threads)
- # So test everything *but* the above services. If required, this can be tested under a manually controlled
- # VM
- # build the individual targets that would comprise "make check" sans execution of unittest.sh
- cd $SCRIPT_ROOT/mgdev/Server/src/UnitTesting
- sudo make libMgUnitTesting.la
- cd $SCRIPT_ROOT/mgdev/Server/src/Core
- sudo make unittest.sh
- # Run the test suites individually except for TileService/ResourceService for reasons already stated
- for comp in CoordinateSystem FeatureService Geometry KmlService LogManager MappingService MdfModel Misc Performance RenderingService ServerAdminService ServerManager ServiceManager SiteManager SiteService ProfilingService TransformMesh
- do
- sudo -E ./mgserver test $comp UnitTestResults_${comp}.xml 2>&1 | tee ~/mapguide_${comp}_unit_test.log
- check_test
- if [ -f UnitTestResults_${comp}.xml ]; then
- sudo mv UnitTestResults_${comp}.xml ~/UnitTestResults_${comp}.xml
- fi
- done
- sudo -E ./run_tests.sh --prefix ${MG_INST_PATH} --with-php --with-java --logpath ~
-fi
-cd $SCRIPT_ROOT
-echo [provision]: Make output dir
-sudo mkdir -p /vagrant/build
-echo [provision]: Copy log files to output dir
-sudo mv -f ~/*.log /vagrant/build
-echo [provision]: Copy tarballs to output dir
-sudo cp bin/*.tar.xz /vagrant/build
-sudo cp fdosdk-centos6-amd64-${FDO_VER_FULL}_${FDO_REV}.tar.xz /vagrant/build
-if [ $MAKE_FDO_SDK -eq 1 ]; then
- echo [provision]: Copy FDO SDK for Ubuntu builds
- # Copy SDK also to sources, so Ubuntu can pick it up
- sudo rm -f /mapguide_sources/fdosdk*.tar.xz
- sudo cp fdosdk-centos6-amd64-${FDO_VER_FULL}_${FDO_REV}.tar.xz /mapguide_sources
- # Record file name so Ubuntu knows what tarball to extract from
- sudo echo fdosdk-centos6-amd64-${FDO_VER_FULL}_${FDO_REV}.tar.xz > /mapguide_sources/fdosdk_filename
- sudo echo ${FDO_REV} > /mapguide_sources/fdosdk_rev
- # Export filelist to Ubuntu can deb package this SDK if needed
- sudo cp -R $SCRIPT_ROOT/fdo_build_area/install/filelist /mapguide_sources
-fi
-echo [provision]: Copy unit test logs to output dir
-sudo mv ~/unit_test_status.log /vagrant/build/unit_test_status.log
-sudo mv ~/fdo_*_unit_test.log /vagrant/build
-sudo mv ~/UnitTestResults_*.xml /vagrant/build
-echo [provision]: Copy install/uninstall scripts to output dir
-sudo cp /vagrant/mginstallcentos.sh /vagrant/build/mginstallcentos.sh
-sudo cp /vagrant/mguninstallcentos.sh /vagrant/build/mguninstallcentos.sh
-sudo sed -i 's/URL_PART="centos"/URL_PART="centos_x64"/g' /vagrant/build/mginstallcentos.sh
-sudo sed -i 's/FDOVER_REV=0/FDOVER_REV='"$FDO_REV"'/g' /vagrant/build/mginstallcentos.sh
-sudo sed -i 's/MGVER_REV=0/MGVER_REV='"$MG_REV"'/g' /vagrant/build/mginstallcentos.sh
-sudo sed -i 's/FDO_ARCH=i386/FDO_ARCH=amd64/g' /vagrant/build/mginstallcentos.sh
-sudo sed -i 's/MG_ARCH=i386/MG_ARCH=amd64/g' /vagrant/build/mginstallcentos.sh
-SCRIPT
privileged: false,
- inline: $script
+ path: "provision_centos.sh",
+ args: [3, 9, 0, 2, 6, 2, "3.9", "2.6", "amd64", "Final", "centos6"]
end
Modified: branches/2.6/vagrant/centos/x86/Vagrantfile
--- branches/2.6/vagrant/centos/x86/Vagrantfile 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/centos/x86/Vagrantfile 2016-04-10 04:30:40 UTC (rev 8911)
-BUILD_COMPONENT=
-check_build()
- error=$?
- exit $error
- fi
-check_test()
- error=$?
- fi
-else
- check_build
-fi
-cd ~
-HAVE_FDO=0
-HAVE_FDO_LIBS=0
-HAVE_MAPGUIDE=0
-MG_UNIT_TEST=0
-FDO_UNIT_TEST=0
-MAKE_FDO_SDK=0
-FDO_VER_MM=3.9
-MG_VER_MM=2.6
-FDO_SRC_DIR=3.9
-then
- HAVE_FDO=1
-fi
-then
- HAVE_FDO_LIBS=1
-fi
-if [ -d $MG_SRC ];
-then
- HAVE_MAPGUIDE=1
-fi
-then
-else
-fi
-#echo [provision]: Checking all tools and libs are in place
-#yum install -y gcc-* gd-* automake bison byacc flex doxygen expat expat-devel libtool libjpeg-devel libpng libpng-devel libxml2 libxml2-devel openssl curl curl-devel libxslt libxslt-devel subversion java-1.7.0-openjdk java-1.7.0-openjdk-devel ant dos2unix openssh-server openldap-devel alsa-lib-devel pcre-devel unixODBC-devel libcom_err-devel krb5-devel openssl-devel mysql-devel postgresql-devel unixODBC
-cd $SCRIPT_ROOT
-sed -i 's/FDO_PLATFORM=64/FDO_PLATFORM=32/g' build_fdo.sh
-sed -i 's/FDO_CPU=x64/FDO_CPU=x86/g' build_fdo.sh
-sed -i 's/FDO_BUILD_CPU=amd64/FDO_BUILD_CPU=i386/g' build_fdo.sh
-sed -i 's/LIB_DIRNAME=lib64/LIB_DIRNAME=lib/g' build_fdo.sh
-then
-fi
-then
-fi
-then
-fi
-then
-fi
-then
-fi
-cd ~/scripts
-check_build
-check_build
-then
- check_test
- check_test
- check_test
- check_test
- check_test
- check_test
- check_test
-fi
-then
- # VM
- do
- check_test
- fi
- done
-fi
-cd $SCRIPT_ROOT
-sudo cp fdosdk-centos6-i386-${FDO_VER_FULL}_${FDO_REV}.tar.xz /vagrant/build
- sudo cp fdosdk-centos6-i386-${FDO_VER_FULL}_${FDO_REV}.tar.zx /mapguide_sources
- sudo echo fdosdk-centos6-i386-${FDO_VER_FULL}_${FDO_REV}.tar.xz > /mapguide_sources/fdosdk_filename
-fi
-sudo sed -i 's/URL_PART="centos"/URL_PART="centos_x86"/g' /vagrant/build/mginstallcentos.sh
-SCRIPT
privileged: false,
- inline: $script
+ args: [3, 9, 0, 2, 6, 2, "3.9", "2.6", "i386", "Final", "centos6"]
end
Modified: branches/2.6/vagrant/scripts/build.sh
--- branches/2.6/vagrant/scripts/build.sh 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/scripts/build.sh 2016-04-10 04:30:40 UTC (rev 8911)
@@ -1,13 +1,28 @@
#!/bin/bash
# Global vars for this script. Modify as necessary
-APIVERSION=2.6
-BUILDNUM=${APIVERSION}.1
+MG_VER_MAJOR=${MG_VER_MAJOR:-3}
+MG_VER_MINOR=${MG_VER_MINOR:-0}
+MG_VER_REV=${MG_VER_REV:-1}
+FDO_VER_MAJOR=${FDO_VER_MAJOR:-4}
+FDO_VER_MINOR=${FDO_VER_MINOR:-0}
+FDO_VER_REV=${FDO_VER_REV:-0}
+MG_DISTRO=${MG_DISTRO:-centos6}
+FDO_INST=/usr/local/fdo-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}
+APIVERSION=${MG_VER_MAJOR}.${MG_VER_MINOR}
+BUILDNUM=${APIVERSION}.${MG_VER_REV}
BUILDROOT=`pwd`
-MGCPUPLATFORM=i386
+MGCPUPLATFORM=${MG_ARCH:-i386}
MGDEBUG=0
-INSTALLROOT=/usr/local/mapguideopensource-${BUILDNUM}
-#INSTALLROOT=/usr/local/mapguideopensource-trunk
+INSTALLROOT=
+if [ -z "${MG_INST_PATH}" ]; then
+ INSTALLROOT=/usr/local/mapguideopensource-${BUILDNUM}
+else
+ INSTALLROOT=${MG_INST_PATH}
+fi
LOCKFILEDIR=/var/lock/mgserver
MGSOURCE=${BUILDROOT}/mgdev
VERFILE=${MGSOURCE}/Common/ProductVersion.h
@@ -17,29 +32,35 @@
SVNROOT=/home/vagrant
#SVNROOT="svn://svn.bld.mgproto.net"
#SVNROOT="http://svn.osgeo.org"
-SVNRELPATH=/mapguide/branches/2.6/MgDev
+SVNRELPATH=/mapguide/branches/${MG_VER_MAJOR}.${MG_VER_MINOR}/MgDev
+if [ "${MG_BRANCH}" = "trunk" ]; then
+ SVNRELPATH=/mapguide/trunk/MgDev
+fi
MY_MAKE_OPTS="-j 2"
-UBUNTU=0
+UBUNTU=${UBUNTU:-0}
PRESERVE_BUILD_ROOT=1
echo "******************************************************************"
+echo " MapGuide Version is: ${BUILDNUM}"
echo " MapGuide will be installed to: ${INSTALLROOT}"
-echo " SVN Source is: ${SVNROOT}${SVNRELPATH}"
-echo " Make Options: ${MY_MAKE_OPTS}"
-echo " Is Ubuntu?: ${UBUNTU}"
-echo " Debug Build?: ${MGDEBUG}"
-echo " Preserving the build dir?: ${PRESERVE_BUILD_ROOT}"
-echo " JAVA_HOME: ${JAVA_HOME}"
+echo " SVN Source is: ${SVNROOT}${SVNRELPATH}"
+echo " Make Options: ${MY_MAKE_OPTS}"
+echo " Is Ubuntu?: ${UBUNTU}"
+echo " Debug Build?: ${MGDEBUG}"
+echo " Preserving the build dir?: ${PRESERVE_BUILD_ROOT}"
+echo " JAVA_HOME: ${JAVA_HOME}"
+echo " Using FDO headers from: ${FDO_INST}/include"
+echo " Using FDO libs from: ${FDO_INST}/lib"
# Need JAVA_HOME for JavaApi
if [ ! -d ${JAVA_HOME} ];
then
-echo "ERROR: Environment variable JAVA_HOME not set. Please set this enviroment variable first"
-exit
+ echo "ERROR: Environment variable JAVA_HOME not set. Please set this enviroment variable first"
+ exit 1
fi
-check_build()
+mg_check_build()
error=$?
@@ -134,26 +155,29 @@
pushd ${MGSOURCE}/Oem/LinuxApt
BUILD_COMPONENT="LinuxApt"
./build_apt.sh --prefix ${INSTALLROOT} --with-tomcat
-check_build
+mg_check_build
popd
-echo "Building Oem"
BUILD_COMPONENT="Oem"
-if [ $(uname -m) = "x86_64" ]; then
+if [ "${MG_ARCH}" = "amd64" ] || [ $(uname -m) = "x86_64" ]; then
if [ ${MGDEBUG} -eq 1 ]; then
+ echo "Building Oem (64-bit, debug)"
./build_oem.sh --prefix ${INSTALLROOT} --build 64 --config debug
- check_build
+ mg_check_build
else
+ echo "Building Oem (64-bit, release)"
- check_build
+ mg_check_build
fi
else
+ echo "Building Oem (32-bit, debug)"
./build_oem.sh --prefix ${INSTALLROOT} --config debug
- check_build
+ mg_check_build
else
+ echo "Building Oem (32-bit, release)"
- check_build
+ mg_check_build
fi
fi
@@ -163,7 +187,7 @@
BUILD_COMPONENT="Fusion"
ant prepare
ant compress
-check_build
+mg_check_build
popd
echo "Building MapGuide"
@@ -172,31 +196,33 @@
libtoolize --force
automake --add-missing --copy
autoconf
MGCPUPLATFORM=amd64
- ./configure --disable-optimized --enable-silent-rules --enable-64bit --prefix=${INSTALLROOT}
+ ./configure --disable-optimized --enable-silent-rules --enable-64bit --prefix=${INSTALLROOT} --with-fdo-include=${FDO_INST}/include --with-fdo-lib=${FDO_INST}/lib
else
- ./configure --enable-optimized --enable-silent-rules --enable-64bit --prefix=${INSTALLROOT}
+ ./configure --enable-optimized --enable-silent-rules --enable-64bit --prefix=${INSTALLROOT} --with-fdo-include=${FDO_INST}/include --with-fdo-lib=${FDO_INST}/lib
fi
else
MGCPUPLATFORM=i386
- ./configure --disable-optimized --enable-silent-rules --prefix=${INSTALLROOT}
+ ./configure --disable-optimized --enable-silent-rules --prefix=${INSTALLROOT} --with-fdo-include=${FDO_INST}/include --with-fdo-lib=${FDO_INST}/lib
else
- ./configure --enable-optimized --enable-silent-rules --prefix=${INSTALLROOT}
+ ./configure --enable-optimized --enable-silent-rules --prefix=${INSTALLROOT} --with-fdo-include=${FDO_INST}/include --with-fdo-lib=${FDO_INST}/lib
fi
fi
make $MY_MAKE_OPTS
-check_build
+mg_check_build
BUILD_COMPONENT="MapGuide Install"
make install
-check_build
+mg_check_build
end_time=`date +%s`
echo "Preparing binaries for packaging"
# Strip the heavy CS-Map dictionary data files. The geoid stuff is not used and the NSRS ones can be packaged separately
+echo "Removing unused CS-Map dictionary files"
pushd ${INSTALLROOT}/share/gis/coordsys
rm -rf WW15MGH.GRD
popd
@@ -238,7 +264,7 @@
mkdir -p bin
fi
- tar -Jcf bin/mapguideopensource-${BUILDNUM}.${REVISION}.${MGCPUPLATFORM}.tar.xz ${INSTALLROOT} ${LOCKFILEDIR}
+ tar -Jcf bin/mapguideopensource-${MG_DISTRO}-${BUILDNUM}.${REVISION}.${MGCPUPLATFORM}.tar.xz ${INSTALLROOT} ${LOCKFILEDIR}
fi
echo "Build complete!"
-echo Main build execution: `expr $end_time - $start_time` s
+echo MapGuide main build execution: `expr $end_time - $start_time` s
Modified: branches/2.6/vagrant/scripts/build_fdo.sh
--- branches/2.6/vagrant/scripts/build_fdo.sh 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/scripts/build_fdo.sh 2016-04-10 04:30:40 UTC (rev 8911)
@@ -12,29 +12,58 @@
FDO_BUILD_COMPONENT=
# FDO version. Make sure this matches your FDO build source
-FDO_VER_MAJOR=3
-FDO_VER_MINOR=9
-FDO_VER_REV=0
+FDO_DISTRO=${FDO_DISTRO:-centos6}
+# FDO install directory
+FDO_VER_FULL=${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}
+# Ubuntu distro switch
+if [ -z "${FDO_INST_PATH}" ]; then
+ FDO_INST=/usr/local/fdo-${FDO_VER_FULL}
+else
+ FDO_INST=${FDO_INST_PATH}
+fi
# Extra flags to pass to FDO build scripts
-FDO_BUILD_FLAGS=
+FDO_BUILD_CONF=
if [ $FDO_DEBUG -eq 1 ]; then
- FDO_BUILD_FLAGS="--config debug"
+ FDO_BUILD_CONF=debug
else
- FDO_BUILD_FLAGS="--config release"
+ FDO_BUILD_CONF=release
fi
-UBUNTU=0
-FDO_CPU=x86
-FDO_PLATFORM=32
-FDO_BUILD_CPU=i386
-LIB_DIRNAME=lib
+FDO_CPU=
+FDO_BUILD_CPU=
+FDO_LIB_DIRNAME=
+FDO_PLATFORM=
+if [ "${ARCH}" = "amd64" ] || [ $(uname -m) = "x86_64" ]; then
+ FDO_CPU=x64
+ FDO_BUILD_CPU=amd64
+ FDO_LIB_DIRNAME=lib64
+ FDO_PLATFORM=64
+else
+ FDO_CPU=x86
+ FDO_BUILD_CPU=i386
+ FDO_PLATFORM=32
+fi
-# FDO install directory
-FDO_VER_FULL=${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}
-FDO_INST=/usr/local/fdo-${FDO_VER_FULL}
+echo "******************************************************************"
+echo "FDO version: ${FDO_VER_FULL}"
+echo "FDO Platform: ${FDO_PLATFORM}"
+echo "CPU: ${FDO_CPU}"
+echo "Arch: ${FDO_BUILD_CPU}"
+echo "Lib Dir: ${FDO_LIB_DIRNAME}"
+echo "FDO will be installed to: ${FDO_INST}"
-check_build()
+check_fdo_build()
error=$?
@@ -105,6 +134,9 @@
MY_HOME_DIR=/home/vagrant
FDO_SRC=${MY_HOME_DIR}/fdo/branches/${FDO_VER_MAJOR}.${FDO_VER_MINOR}
+if [ "${FDO_BRANCH}" = "trunk" ]; then
+ FDO_SRC=${MY_HOME_DIR}/fdo/trunk
+fi
#FDO_SRC=http://svn.osgeo.org/fdo/trunk
FDO_BUILD_AREA=${BUILDROOT}/fdo_build_area
FDO_FILELIST=${FDO_BUILD_AREA}/install/filelist
@@ -133,14 +165,14 @@
echo "[info]: PostgreSQL include path already symlinked"
fi
# PostgreSQL lib path
- if [ ! -d ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/$LIB_DIRNAME ];
+ if [ ! -d ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/$FDO_LIB_DIRNAME ];
then
if [ ${FDO_PLATFORM} -eq 32 ];
then
- ln -s /usr/lib ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/$LIB_DIRNAME
+ ln -s /usr/lib ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/$FDO_LIB_DIRNAME
echo "[info]: Symlinked PostgreSQL lib path (x86)"
else
echo "[info]: Symlinked PostgreSQL lib path (x64)"
fi
else
@@ -156,14 +188,14 @@
echo "[info]: MySQL include path already symlinked"
fi
# MySQL lib path
- if [ ! -d ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/$LIB_DIRNAME ];
+ if [ ! -d ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/$FDO_LIB_DIRNAME ];
then
then
- ln -s /usr/lib/i386-linux-gnu ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/$LIB_DIRNAME
+ ln -s /usr/lib/i386-linux-gnu ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/$FDO_LIB_DIRNAME
echo "[info]: Symlinked MySQL lib path (x86)"
else
- ln -s /usr/lib/x86_64-linux-gnu ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/$LIB_DIRNAME
+ ln -s /usr/lib/x86_64-linux-gnu ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/$FDO_LIB_DIRNAME
echo "[info]: Symlinked MySQL lib path (x64)"
fi
else
@@ -289,7 +321,7 @@
echo "the GDAL SDK files to $FDOTHIRDPARTY/gdal. "
echo "If this value remains unchanged, the FDO build process will"
echo "build the version of GDAL located in Thirdparty/gdal and will "
- echo "install the resulting libraries in /usr/local/fdo-3.9.0. The FDO build"
+ echo "install the resulting libraries in $FDO_INST. The FDO build"
echo "process will then use that location when building the GDAL and"
echo "WMS providers. If you wish to build the FDO GDAL or WMS Providers"
echo "using a previously installed version of GDAL, modify the setenvironment.sh "
@@ -333,8 +365,8 @@
# parameter no installation directory is created, ie.:
# $ source ./setenvironment.sh --noinstall
if test ! $# -eq 1; then
- mkdir -p "/usr/local/fdo-${FDO_VER_FULL}/lib"
- export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/fdo-${FDO_VER_FULL}/lib:$SDEHOME/lib
+ mkdir -p "$FDO_INST/lib"
+ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$FDO_INST/lib:$SDEHOME/lib
fi
export XERCESCROOT=$FDOTHIRDPARTY/apache/xerces
@@ -383,20 +415,20 @@
fi
echo "******* Environment variable summary *********"
- echo "FDO: $FDO"
- echo "FDOUTILITIES: $FDOUTILITIES"
- echo "FDOTHIRDPARTY: $FDOTHIRDPARTY"
- echo "SDEHOME: $SDEHOME"
- echo "FDOGDAL: $FDOGDAL"
- echo "FDOODBC: $FDOODBC"
- echo "PYTHON_LIB_PATH: $PYTHON_LIB_PATH"
+ echo "FDO: $FDO"
+ echo "FDOUTILITIES: $FDOUTILITIES"
+ echo "FDOTHIRDPARTY: $FDOTHIRDPARTY"
+ echo "SDEHOME: $SDEHOME"
+ echo "FDOGDAL: $FDOGDAL"
+ echo "FDOODBC: $FDOODBC"
+ echo "PYTHON_LIB_PATH: $PYTHON_LIB_PATH"
echo "PYTHON_INCLUDE_PATH: $PYTHON_INCLUDE_PATH"
- echo "XERCESCROOT: $XERCESCROOT"
- echo "XALANCROOT: $XALANCROOT"
- echo "NLSDIR: $NLSDIR"
- echo "FDOORACLE: $FDOORACLE"
- echo "FDOMYSQL: $FDOMYSQL"
- echo "FDOPOSTGRESQL: $FDOPOSTGRESQL"
+ echo "XERCESCROOT: $XERCESCROOT"
+ echo "XALANCROOT: $XALANCROOT"
+ echo "NLSDIR: $NLSDIR"
+ echo "FDOORACLE: $FDOORACLE"
+ echo "FDOMYSQL: $FDOMYSQL"
+ echo "FDOPOSTGRESQL: $FDOPOSTGRESQL"
echo "**********************************************"
echo ""
@@ -408,15 +440,16 @@
fi
echo "***********************************************************"
-echo " FDO Source: ${FDO_SRC}"
-echo " FDO Build Area: ${FDO_BUILD_AREA}"
-echo " FDO Install dir: ${FDO_INST}"
-echo " FDO CPU Target: ${FDO_BUILD_CPU}"
-echo " CMake build: ${CMAKE}"
-echo " Debug build: ${FDO_DEBUG}"
+echo " FDO Source: ${FDO_SRC}"
+echo " FDO Build Area: ${FDO_BUILD_AREA}"
+echo " FDO Install dir: ${FDO_INST}"
+echo " FDO CPU Target: ${FDO_BUILD_CPU}"
+echo " FDO build config: ${FDO_BUILD_CONF}"
+echo " CMake build: ${CMAKE}"
+echo " Debug build: ${FDO_DEBUG}"
echo " Export from local SVN checkout: ${LOCALSVN}"
-echo " Re-use previous build area: ${PRESERVE_BUILD_ROOT}"
+echo " Re-use previous build area: ${PRESERVE_BUILD_ROOT}"
start_time=`date +%s`
REVISION=`svn info ${FDO_SRC} | perl revnum.pl`
@@ -473,8 +506,8 @@
cd ${FDO_BUILD_AREA}
FDO_BUILD_COMPONENT="FDO Thirdparty"
-./build_thirdparty.sh -b ${FDO_PLATFORM} ${FDO_BUILD_FLAGS}
-check_build
+./build_thirdparty.sh -b ${FDO_PLATFORM} --c ${FDO_BUILD_CONF} --p ${FDO_INST}
+check_fdo_build
if [ ${CMAKE} -eq 1 ];
then
@@ -486,17 +519,17 @@
for comp in fdocore fdo utilities
do
FDO_BUILD_COMPONENT="$comp (automake)"
- ./build_linux.sh --w $comp --p ${FDO_INST} --b ${FDO_PLATFORM} ${FDO_BUILD_FLAGS}
+ ./build_linux.sh --w $comp --p ${FDO_INST} --b ${FDO_PLATFORM} --c ${FDO_BUILD_CONF}
update_fdocore_file_list
- check_build
+ check_fdo_build
done
for comp in shp sqlite gdal ogr wfs wms rdbms kingoracle sdf
do
save_current_file_list
update_provider_file_list $comp
- check_build
+ check_fdo_build
done
fi
check_fdo_lib libFDO
@@ -528,7 +561,7 @@
FDO_BUILD_COMPONENT="Remove .la files from ${FDO_INST}"
# Remove .la files from lib directory
rm -f ${FDO_INST}/lib/*.la
- check_build
+ check_fdo_build
FDO_BUILD_COMPONENT="Strip so symbols and remove execute flag"
# Remove unneeded symbols from files in the lib directory
@@ -538,13 +571,13 @@
strip --strip-unneeded ${file}
chmod a-x ${file}
done
- check_build
+ check_fdo_build
FDO_BUILD_COMPONENT="Make tarball"
# Create a binary tar ball for FDO
cd ${FDO_INST}
- tar -Jcf ${BUILDROOT}/fdosdk-centos6-${FDO_BUILD_CPU}-${FDO_VER_FULL}_${REVISION}.tar.xz *
- check_build
+ tar -Jcf ${BUILDROOT}/fdosdk-${FDO_DISTRO}-${FDO_BUILD_CPU}-${FDO_VER_FULL}_${REVISION}.tar.xz *
+ check_fdo_build
if [ ${UBUNTU} -eq 1 ];
then
@@ -557,4 +590,4 @@
fi
echo "[info]: FDO build complete!"
-echo Main build execution time: `expr $end_time - $start_time` s
+echo FDO main build execution time: `expr $end_time - $start_time` s
Modified: branches/2.6/vagrant/scripts/dpkgfdocore.sh
--- branches/2.6/vagrant/scripts/dpkgfdocore.sh 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/scripts/dpkgfdocore.sh 2016-04-10 04:30:40 UTC (rev 8911)
@@ -11,8 +11,13 @@
# control - control file generated from dpkg-gencontrol
# symbols - symbols file generated from dpkg-gensymbols
BUILDROOT=`pwd`
-FDOBUILD=3.9.0
+FDOBUILD=${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}
FDO=usr/local/fdo-${FDOBUILD}
ROOT=${BUILDROOT}/debian/fdocore
TREE=${BUILDROOT}/debian
Modified: branches/2.6/vagrant/scripts/dpkgfdoprovider.sh
--- branches/2.6/vagrant/scripts/dpkgfdoprovider.sh 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/scripts/dpkgfdoprovider.sh 2016-04-10 04:30:40 UTC (rev 8911)
@@ -12,13 +12,16 @@
# Read and validate command line parameters
-ARCH="$1"
+FDO_ARCH="$1"
BUILDNUM="$2"
PROVIDER="$3"
-if test -z ${ARCH}; then
+if test -z ${FDO_ARCH}; then
echo Usage: dpkgfdoprovider.sh [i386/amd64] svnChangeNum provider
exit -1
fi
@@ -27,7 +30,7 @@
exit -1
fi
-case $ARCH in
+case $FDO_ARCH in
i386)
echo Setting architecture to i386.
@@ -62,7 +65,7 @@
BUILDROOT=`pwd`
-FDOBUILD=3.9.0
ROOT=${BUILDROOT}/debian/fdo${PROVIDER}
CPROOT=${ROOT}/${FDO}
@@ -138,5 +141,5 @@
# And move resulting debian package and lintian results to build directory
dpkg-deb -Zlzma --build ${ROOT}
lintian -i debian/fdo${PROVIDER}.deb > tmp/fdo${PROVIDER}.lintian
-mv debian/fdo${PROVIDER}.deb bin/fdo-${PROVIDER}_${FDOBUILD}-${BUILDNUM}_${ARCH}.deb
+mv debian/fdo${PROVIDER}.deb bin/fdo-${PROVIDER}_${FDOBUILD}-${BUILDNUM}_${FDO_ARCH}.deb
popd
Modified: branches/2.6/vagrant/scripts/dpkgmapguide.sh
--- branches/2.6/vagrant/scripts/dpkgmapguide.sh 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/scripts/dpkgmapguide.sh 2016-04-10 04:30:40 UTC (rev 8911)
@@ -6,51 +6,59 @@
# changelog - generated changelog file
# substvars - subst params created by dpkg-shlibdeps
# mapguideplatformbase/ - packaging directory for common MapGuide components
-# usr/local/mapguideopensource-3.0.0/ - copied tree for common components
+# usr/local/mapguideopensource-x.y.z/ - copied tree for common components
# DEBIAN/
# mapguidecommon/ - packaging directory for common MapGuide components
# DEBIAN/
# mapguidecoordsys/ - packaging directory for CS-Map coordinate system dictionaries
# DEBIAN/
# mapguidecoordsyslite/ - packaging directory for CS-Map coordinate system dictionaries
# DEBIAN/
# mapguideserver/ - packaging directory for MapGuide Server
-# usr/local/mapguideopensource-3.0.0/ - copied tree for Server
+# usr/local/mapguideopensource-x.y.z/ - copied tree for Server
# DEBIAN/
# mapguidewebextensions/ - packaging directory for Web Extensions
-# usr/local/mapguideopensource-3.0.0/ - copied tree for Web Extensions
+# usr/local/mapguideopensource-x.y.z/ - copied tree for Web Extensions
# DEBIAN/
# mapguidehttpd/ - packaging directory for Apache Bundle
-# usr/local/mapguideopensource-3.0.0/ - copied tree for Apache bundle
+# usr/local/mapguideopensource-x.y.z/ - copied tree for Apache bundle
# DEBIAN/
BUILDROOT=`pwd`
-MGBUILD=2.6.1
-FDOBUILD=3.9.1
+MGBUILD=${MG_VER_MAJOR}.${MG_VER_MINOR}.${MG_VER_REV}
MGINST=usr/local/mapguideopensource-${MGBUILD}
CPROOT=${ROOT}/${MGINST}
Modified: branches/2.6/vagrant/scripts/mapguidecommon_excludes.txt
--- branches/2.6/vagrant/scripts/mapguidecommon_excludes.txt 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/scripts/mapguidecommon_excludes.txt 2016-04-10 04:30:40 UTC (rev 8911)
@@ -3,25 +3,25 @@
libdwfcore-1.1.1.so
libdwfemap-1.0.0.so
libdwftk-7.1.1.so
-libMgFoundation-2.6.1.so
+libMgFoundation-2.6.2.so
libMgFoundation.so
-libMgGeometry-2.6.1.so
+libMgGeometry-2.6.2.so
libMgGeometry.so
-libMgGwsCommon-2.6.1.so
+libMgGwsCommon-2.6.2.so
libMgGwsCommon.so
-libMgGwsQueryEngine-2.6.1.so
+libMgGwsQueryEngine-2.6.2.so
libMgGwsQueryEngine.so
-libMgGwsResource-2.6.1.so
+libMgGwsResource-2.6.2.so
libMgGwsResource.so
-libMgMdfModel-2.6.1.so
+libMgMdfModel-2.6.2.so
libMgMdfModel.so
-libMgMdfParser-2.6.1.so
+libMgMdfParser-2.6.2.so
libMgMdfParser.so
-libMgPlatformBase-2.6.1.so
+libMgPlatformBase-2.6.2.so
libMgPlatformBase.so
-libMgRenderers-2.6.1.so
+libMgRenderers-2.6.2.so
libMgRenderers.so
-libMgStylization-2.6.1.so
+libMgStylization-2.6.2.so
libMgStylization.so
libxerces-c-3.1.so
libxerces-c.so
Modified: branches/2.6/vagrant/scripts/mginstallcentos.sh
--- branches/2.6/vagrant/scripts/mginstallcentos.sh 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/scripts/mginstallcentos.sh 2016-04-10 04:30:40 UTC (rev 8911)
@@ -1,22 +1,31 @@
#!/bin/bash
-URL_ROOT="http://download.osgeo.org/mapguide/releases/2.6.1/Final"
-URL_PART="centos"
-URL="$URL_ROOT/$URL_PART"
-#URL="http://192.168.0.4/downloads"
-FDOVER_MAJOR_MINOR=3.9
-FDOVER_POINT=1
+URL_HOST="http://download.osgeo.org"
+URL_RELPATH="/mapguide/releases"
+FDOVER_MAJOR=0
+FDOVER_MINOR=0
+FDOVER_MAJOR_MINOR=${FDOVER_MAJOR}.${FDOVER_MINOR}
+FDOVER_POINT=0
FDOVER_REV=0
FDO_ARCH=i386
FDOVER_MAJOR_MINOR_REV=${FDOVER_MAJOR_MINOR}.${FDOVER_POINT}
FDOVER=${FDOVER_MAJOR_MINOR_REV}_${FDOVER_REV}
-MGVER_MAJOR_MINOR=2.6
-MGVER_POINT=1
+MGVER_MAJOR=0
+MGVER_MINOR=0
+MGVER_MAJOR_MINOR=${MGVER_MAJOR}.${MGVER_MINOR}
+MGVER_POINT=0
MGVER_REV=0
MG_ARCH=i386
MGVER_MAJOR_MINOR_REV=${MGVER_MAJOR_MINOR}.${MGVER_POINT}
MGVER=${MGVER_MAJOR_MINOR_REV}.${MGVER_REV}
+MGRELEASELABEL="ReleaseLabel"
FDO_TARBALL=fdosdk-centos6-${FDO_ARCH}-${FDOVER}.tar.xz
-MG_TARBALL=mapguideopensource-${MGVER}.${MG_ARCH}.tar.xz
+MG_TARBALL=mapguideopensource-centos6-${MGVER}.${MG_ARCH}.tar.xz
+URL_ROOT="${URL_HOST}/${URL_RELPATH}/${MGVER_MAJOR_MINOR_REV}/${MGRELEASELABEL}"
+URL_PART="centos"
+URL="$URL_ROOT/$URL_PART"
MG_URL=${URL}/${MG_TARBALL}
FDO_URL=${URL}/${FDO_TARBALL}
Modified: branches/2.6/vagrant/scripts/mginstallubuntu.sh
--- branches/2.6/vagrant/scripts/mginstallubuntu.sh 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/scripts/mginstallubuntu.sh 2016-04-10 04:30:40 UTC (rev 8911)
@@ -1,21 +1,30 @@
#!/bin/bash
TEMPDIR=/tmp/build_mapguide
-URL_PART="ubuntu12"
-#URL="http://192.168.0.5/downloads/ubuntu12"
-FDOVER_MAJOR_MINOR_REV=${FDOVER_MAJOR_MINOR}.1
+FDOVER_MAJOR=0
+FDOVER_MINOR=0
+FDOVER_POINT=0
+FDOVER_MAJOR_MINOR_REV=${FDOVER_MAJOR_MINOR}.${FDOVER_POINT}
FDOBUILD=0
FDOARCH=i386
FDOVER=${FDOVER_MAJOR_MINOR_REV}-${FDOBUILD}_${FDOARCH}
-MGVER_MAJOR_MINOR_REV=${MGVER_MAJOR_MINOR}.1
+MGVER_MAJOR=0
+MGVER_MINOR=0
+MGVER_POINT=0
+MGVER_MAJOR_MINOR_REV=${MGVER_MAJOR_MINOR}.${MGVER_POINT}
MGBUILD=0
MGARCH=i386
MGVER=${MGVER_MAJOR_MINOR_REV}-${MGBUILD}_${MGARCH}
INSTALLER_TITLE="MapGuide Open Source Ubuntu installer"
+URL_PART="ubuntu"
DEFAULT_SERVER_IP="127.0.0.1"
DEFAULT_ADMIN_PORT=2810
Modified: branches/2.6/vagrant/scripts/mguninstallcentos.sh
--- branches/2.6/vagrant/scripts/mguninstallcentos.sh 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/scripts/mguninstallcentos.sh 2016-04-10 04:30:40 UTC (rev 8911)
@@ -1,9 +1,13 @@
#!/bin/bash
-FDOVER_POINT=1
+FDOVER_MAJOR=0
+FDOVER_MINOR=0
+FDOVER_POINT=0
-MGVER_POINT=1
+MGVER_MAJOR=0
+MGVER_MINOR=0
+MGVER_POINT=0
FDOINST=/usr/local/fdo-${FDOVER_MAJOR_MINOR_REV}
Modified: branches/2.6/vagrant/scripts/platformbase_excludes.txt
--- branches/2.6/vagrant/scripts/platformbase_excludes.txt 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/scripts/platformbase_excludes.txt 2016-04-10 04:30:40 UTC (rev 8911)
@@ -6,7 +6,7 @@
libdbxml-2.5.so
libdbxml.so
liblib_json.so
-libMgMapGuideCommon-2.6.1.so
+libMgMapGuideCommon-2.6.2.so
libMgMapGuideCommon.so
libxqilla.so
libxqilla.so.5
Added: branches/2.6/vagrant/scripts/provision_centos.sh
--- branches/2.6/vagrant/scripts/provision_centos.sh (rev 0)
+++ branches/2.6/vagrant/scripts/provision_centos.sh 2016-04-10 04:30:40 UTC (rev 8911)
@@ -0,0 +1,347 @@
+#!/bin/bash
+# provision_centos.sh
+# Entry point provisioning shell script
+# Expected environment (set up by vagrant)
+# - Calling vagrantfile is for a CentOS 6.x box
+# - Vagrant folder (path of the Vagrantfile) mounted as: /vagrant
+# - Source folder mounted as: /mapguide_sources
+# - Contains tarballs for MapGuide/FDO
+# Required arguments (to be passed in by the Vagrantfile):
+# $1 - FDO major version
+# $2 - FDO minor version
+# $3 - FDO patch version
+# $4 - MG major version
+# $5 - MG minor version
+# $6 - MG patch version
+# $7 - FDO branch name (trunk|major.minor)
+# $8 - MG branch name (trunk|major.minor)
+# $9 - architecture (i386|amd64)
+# $10 - release label (eg. Beta1, RC1, Final)
+# $11 - distro label (eg. centos6, ubuntu12) - Optional
+PROVISION_START_TIME=`date +%s`
+echo "*****************************************************"
+echo " Arg check"
+echo " 1 - ${1}"
+echo " 2 - ${2}"
+echo " 3 - ${3}"
+echo " 4 - ${4}"
+echo " 5 - ${5}"
+echo " 6 - ${6}"
+echo " 7 - ${7}"
+echo " 8 - ${8}"
+echo " 9 - ${9}"
+echo " 10 - ${10}"
+echo " 11 - ${11}"
+# FDO version
+FDO_VER_MAJOR=${1}
+FDO_VER_MINOR=${2}
+FDO_VER_REV=${3}
+# MG version
+MG_VER_MAJOR=${4}
+MG_VER_MINOR=${5}
+MG_VER_REV=${6}
+FDO_BRANCH=${7}
+MG_BRANCH=${8}
+MG_ARCH=${9}
+MG_RELEASE_LABEL=${10}
+DISTRO=${11:-centos6}
+FDO_DISTRO=${DISTRO}
+MG_DISTRO=${DISTRO}
+UBUNTU=0
+FDO_PLATFORM=
+if [ "${MG_ARCH}" = "amd64" ]; then
+ FDO_PLATFORM=64
+elif [ "${MG_ARCH}" = "i386" ]; then
+ FDO_PLATFORM=32
+else
+ echo "[error]: Unknown ARCH (${MG_ARCH})"
+ exit 1
+fi
+# Export vars for sub-shells
+export FDO_VER_MAJOR
+export FDO_VER_MINOR
+export FDO_VER_REV
+export MG_VER_MAJOR
+export MG_VER_MINOR
+export MG_VER_REV
+export FDO_BRANCH
+export MG_BRANCH
+export MG_ARCH
+export UBUNTU
+export FDO_DISTRO
+export MG_DISTRO
+BUILD_COMPONENT=
+check_build()
+ error=$?
+ if [ $error -ne 0 ]; then
+ echo "[error]: ${BUILD_COMPONENT} - Error build failed ($error)"
+ exit $error
+ fi
+check_test()
+ error=$?
+ echo "[warning]: ${BUILD_COMPONENT} - Unit Tests failed ($error)"
+ echo "[warning]: ${BUILD_COMPONENT} - Unit Tests failed ($error)" >> ~/unit_test_status.log
+ fi
+if hash scons 2>/dev/null; then
+ echo [provision]: We have scons
+else
+ echo [provision]: We do not have scons. Installing it
+ sudo rpm -Uvh /mapguide_sources/scons-2.3.0-1.noarch.rpm
+ check_build
+fi
+cd ~
+HAVE_FDO=0
+HAVE_FDO_LIBS=0
+HAVE_MAPGUIDE=0
+MG_UNIT_TEST=0
+FDO_UNIT_TEST=0
+MAKE_FDO_SDK=0
+SCRIPT_ROOT=~/scripts
+FDO_SRC_ROOT=~/fdo/branches
+FDO_SRC_DIR=${FDO_BRANCH}
+FDO_SRC=$FDO_SRC_ROOT/$FDO_SRC_DIR
+ FDO_SRC_ROOT=~/fdo
+ FDO_SRC=$FDO_SRC_ROOT/$FDO_SRC_DIR
+fi
+FDO_LIB_SRC=~/fdo_rdbms_thirdparty
+MG_SRC_ROOT=~/mapguide/branches/${MG_BRANCH}
+ MG_SRC_ROOT=~/mapguide/trunk
+fi
+MG_SRC=$MG_SRC_ROOT/MgDev
+FDO_TARBALL=fdo-checkout-${FDO_BRANCH}.tar.gz
+MG_TARBALL=mapguide-checkout-${MG_BRANCH}.tar.gz
+FDO_INST_PATH=/usr/local/fdo-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}
+MG_INST_PATH=/usr/local/mapguideopensource-${MG_VER_MAJOR}.${MG_VER_MINOR}.${MG_VER_REV}
+echo "********************************************************************************"
+echo Home directory is `pwd`
+echo "FDO version: ${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}"
+echo "FDO branch: ${FDO_BRANCH}"
+echo "MG version: ${MG_VER_MAJOR}.${MG_VER_MINOR}.${MG_VER_REV}"
+echo "MG branch: ${MG_BRANCH}"
+echo "Build target: ${MG_DISTRO} - ${MG_ARCH}"
+echo "Release Label: ${MG_RELEASE_LABEL}"
+echo "FDO Distro label: ${FDO_DISTRO}"
+echo "Checking directories"
+if [ -d $FDO_SRC ];
+then
+ HAVE_FDO=1
+fi
+if [ -d $FDO_LIB_SRC ];
+then
+ HAVE_FDO_LIBS=1
+fi
+if [ -d $MG_SRC ];
+then
+ HAVE_MAPGUIDE=1
+fi
+if [ -f /usr/include/asm/atomic.h ];
+then
+ echo [provision]: atomic.h exists. Doing nothing
+else
+ echo [provision]: Copy atomic.h
+ sudo mkdir -p /usr/include/asm
+ sudo cp /mapguide_sources/atomic.h /usr/include/asm
+fi
+echo [provision]: Clean line endings
+sudo dos2unix /vagrant/*.sh
+sudo dos2unix /vagrant/*.pl
+sudo dos2unix /vagrant/*.txt
+echo [provision]: Copying shell scripts
+mkdir -p $SCRIPT_ROOT
+cp -f /vagrant/*.sh $SCRIPT_ROOT
+cp -f /vagrant/*.pl $SCRIPT_ROOT
+cp -f /vagrant/*.txt $SCRIPT_ROOT
+cd $SCRIPT_ROOT
+if [ $HAVE_FDO_LIBS -eq 0 ];
+then
+ echo [provision]: Extracting FDO thirdparty libs
+ tar -zxf /mapguide_sources/fdo_rdbms_thirdparty.tar.gz -C ~
+fi
+if [ $HAVE_FDO -eq 0 ];
+then
+ echo [provision]: Extracting FDO working copy
+ mkdir -p $FDO_SRC_ROOT
+ tar -zxf /mapguide_sources/$FDO_TARBALL -C $FDO_SRC_ROOT
+fi
+if [ $HAVE_MAPGUIDE -eq 0 ];
+then
+ echo [provision]: Extracting MapGuide working copy
+ mkdir -p $MG_SRC_ROOT
+ tar -zxf /mapguide_sources/$MG_TARBALL -C $MG_SRC_ROOT
+fi
+if [ -d /mapguide_sources/patches/fdo ];
+then
+ echo [provision]: Applying FDO source patches
+ cp -R /mapguide_sources/patches/fdo/* $FDO_SRC
+fi
+if [ -d /mapguide_sources/patches/mapguide ];
+then
+ echo [provision]: Applying MapGuide source patches
+ cp -R /mapguide_sources/patches/mapguide/* $MG_SRC
+fi
+echo [provision]: Making sure swig is executable
+chmod +x $MG_SRC/Oem/SWIGEx/Linux/swig
+cd ~/scripts
+BUILD_COMPONENT="FDO"
+sudo -E ./build_fdo.sh 2>&1 | tee ~/fdo_build.log
+check_build
+BUILD_COMPONENT="MapGuide"
+sudo -E ./build.sh 2>&1 | tee ~/mapguide_build.log
+check_build
+FDO_REV=`svn info $FDO_SRC | perl revnum.pl`
+MG_REV=`svn info $MG_SRC | perl revnum.pl`
+> ~/unit_test_status.log
+if [ $FDO_UNIT_TEST -eq 1 ];
+then
+ echo [provision]: Unit test FDO
+ BUILD_COMPONENT="Unit Test FDO Core"
+ cd $SCRIPT_ROOT/fdo_build_area/Fdo/UnitTest
+ sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_core_unit_test.log
+ check_test
+ BUILD_COMPONENT="Unit Test SHP Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/SHP/Src/UnitTest
+ sudo rm providers.xml
+ sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_shp_unit_test.log
+ check_test
+ BUILD_COMPONENT="Unit Test SDF Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/SDF/Src/UnitTest
+ sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_sdf_unit_test.log
+ check_test
+ BUILD_COMPONENT="Unit Test SQLite Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/SQLite/Src/UnitTest
+ sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_sqlite_unit_test.log
+ check_test
+ BUILD_COMPONENT="Unit Test GDAL Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/GDAL/Src/UnitTest
+ sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_gdal_unit_test.log
+ check_test
+ BUILD_COMPONENT="Unit Test OGR Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/OGR/Src/UnitTest
+ sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_ogr_unit_test.log
+ check_test
+ BUILD_COMPONENT="Unit Test WMS Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/WMS/Src/UnitTest
+ sudo -E NLSPATH=${FDO_INST_PATH}/nls/%N ./UnitTest 2>&1 | tee ~/fdo_wms_unit_test.log
+ check_test
+fi
+if [ $MG_UNIT_TEST -eq 1 ];
+then
+ echo [provision]: Unit test MapGuide
+ BUILD_COMPONENT="Unit Test MapGuide Server"
+ # HACK: Tile and Resource Service tests are known to freeze our VMs when driven by vagrant (why? who knows?
+ # All we know is that those tests involve threads)
+ # So test everything *but* the above services. If required, this can be tested under a manually controlled
+ # VM
+ # build the individual targets that would comprise "make check" sans execution of unittest.sh
+ cd $SCRIPT_ROOT/mgdev/Server/src/UnitTesting
+ sudo make libMgUnitTesting.la
+ cd $SCRIPT_ROOT/mgdev/Server/src/Core
+ sudo make unittest.sh
+ # Run the test suites individually except for TileService/ResourceService for reasons already stated
+ for comp in CoordinateSystem FeatureService Geometry KmlService LogManager MappingService MdfModel Misc Performance RenderingService ServerAdminService ServerManager ServiceManager SiteManager SiteService ProfilingService TransformMesh
+ do
+ sudo -E ./mgserver test $comp UnitTestResults_${comp}.xml 2>&1 | tee ~/mapguide_${comp}_unit_test.log
+ check_test
+ if [ -f UnitTestResults_${comp}.xml ]; then
+ sudo mv UnitTestResults_${comp}.xml ~/UnitTestResults_${comp}.xml
+ fi
+ done
+ sudo -E ./run_tests.sh --prefix ${MG_INST_PATH} --with-php --with-java --logpath ~
+fi
+cd $SCRIPT_ROOT
+echo [provision]: Make output dir
+sudo mkdir -p /vagrant/build
+echo [provision]: Copy log files to output dir
+sudo mv -f ~/*.log /vagrant/build
+echo [provision]: Copy tarballs to output dir
+sudo cp bin/*.tar.xz /vagrant/build
+sudo cp fdosdk-${FDO_DISTRO}-${MG_ARCH}-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}_${FDO_REV}.tar.xz /vagrant/build
+if [ $MAKE_FDO_SDK -eq 1 ]; then
+ echo [provision]: Copy FDO SDK for Ubuntu builds
+ # Copy SDK also to sources, so Ubuntu can pick it up
+ sudo rm -f /mapguide_sources/fdosdk*.tar.xz
+ sudo cp fdosdk-${FDO_DISTRO}-${MG_ARCH}-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}_${FDO_REV}.tar.xz /mapguide_sources
+ # Record file name so Ubuntu knows what tarball to extract from
+ sudo echo fdosdk-${FDO_DISTRO}-${MG_ARCH}-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}_${FDO_REV}.tar.xz > /mapguide_sources/fdosdk_filename
+ sudo echo ${FDO_REV} > /mapguide_sources/fdosdk_rev
+ # Export filelist to Ubuntu can deb package this SDK if needed
+ sudo cp -R $SCRIPT_ROOT/fdo_build_area/install/filelist /mapguide_sources
+fi
+echo [provision]: Copy unit test logs to output dir
+if [ -f "~/unit_test_status.log" ]; then
+ sudo mv ~/unit_test_status.log /vagrant/build/unit_test_status.log
+fi
+if ls ~/fdo_*_unit_test.log 1> /dev/null 2>&1; then
+ sudo mv ~/fdo_*_unit_test.log /vagrant/build
+else
+ echo [provision]: No FDO unit test result files found. If FDO_UNIT_TEST is 0 [value is ${FDO_UNIT_TEST}], this can be safely ignored
+fi
+if ls ~/UnitTestResults_*.xml 1> /dev/null 2>&1; then
+ sudo mv ~/UnitTestResults_*.xml /vagrant/build
+else
+ echo [provision]: No MapGuide unit test result files found. If MG_UNIT_TEST is 0 [value is ${MG_UNIT_TEST}], this can be safely ignored
+fi
+echo [provision]: Copy install/uninstall scripts to output dir
+DISTNAME=${MG_DISTRO}_x86
+ DISTNAME=${MG_DISTRO}_x64
+fi
+echo [provision]: Stamping install script
+sudo cp /vagrant/mginstallcentos.sh /vagrant/build/mginstallcentos.sh
+sudo cp /vagrant/mguninstallcentos.sh /vagrant/build/mguninstallcentos.sh
+sudo sed -i 's/URL_PART="centos"/URL_PART='"$DISTNAME"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/MGRELEASELABEL="ReleaseLabel"/MGRELEASELABEL='"$MG_RELEASE_LABEL"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/FDO_ARCH=i386/FDO_ARCH='"$MG_ARCH"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/MG_ARCH=i386/MG_ARCH='"$MG_ARCH"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/FDOVER_REV=0/FDOVER_REV='"$FDO_REV"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/MGVER_REV=0/MGVER_REV='"$MG_REV"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/FDOVER_MAJOR=0/FDOVER_MAJOR='"$FDO_VER_MAJOR"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/FDOVER_MINOR=0/FDOVER_MINOR='"$FDO_VER_MINOR"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/FDOVER_POINT=0/FDOVER_POINT='"$FDO_VER_REV"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/MGVER_MAJOR=0/MGVER_MAJOR='"$MG_VER_MAJOR"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/MGVER_MINOR=0/MGVER_MINOR='"$MG_VER_MINOR"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/MGVER_POINT=0/MGVER_POINT='"$MG_VER_REV"'/g' /vagrant/build/mginstallcentos.sh
+echo [provision]: Stamping variables to uninstall script
+sudo sed -i 's/FDOVER_MAJOR=0/FDOVER_MAJOR='"$FDO_VER_MAJOR"'/g' /vagrant/build/mguninstallcentos.sh
+sudo sed -i 's/FDOVER_MINOR=0/FDOVER_MINOR='"$FDO_VER_MINOR"'/g' /vagrant/build/mguninstallcentos.sh
+sudo sed -i 's/FDOVER_POINT=0/FDOVER_POINT='"$FDO_VER_REV"'/g' /vagrant/build/mguninstallcentos.sh
+sudo sed -i 's/MGVER_MAJOR=0/MGVER_MAJOR='"$MG_VER_MAJOR"'/g' /vagrant/build/mguninstallcentos.sh
+sudo sed -i 's/MGVER_MINOR=0/MGVER_MINOR='"$MG_VER_MINOR"'/g' /vagrant/build/mguninstallcentos.sh
+sudo sed -i 's/MGVER_POINT=0/MGVER_POINT='"$MG_VER_REV"'/g' /vagrant/build/mguninstallcentos.sh
+PROVISION_END_TIME=`date +%s`
+echo [provision]: Build complete
+echo [provision]: Overall build duration: `expr $PROVISION_END_TIME - $PROVISION_START_TIME` s
\ No newline at end of file
Added: branches/2.6/vagrant/scripts/provision_ubuntu.sh
--- branches/2.6/vagrant/scripts/provision_ubuntu.sh (rev 0)
+++ branches/2.6/vagrant/scripts/provision_ubuntu.sh 2016-04-10 04:30:40 UTC (rev 8911)
@@ -0,0 +1,346 @@
+#!/bin/bash
+# provision_ubuntu.sh
+# - Calling vagrantfile is for a Ubuntu 12.04.x LTS box
+echo " Arg check"
+echo " 1 - ${1}"
+echo " 2 - ${2}"
+echo " 3 - ${3}"
+echo " 4 - ${4}"
+echo " 5 - ${5}"
+echo " 6 - ${6}"
+echo " 7 - ${7}"
+echo " 8 - ${8}"
+echo " 9 - ${9}"
+echo " 10 - ${10}"
+echo " 11 - ${11}"
+# FDO version
+FDO_VER_MAJOR=${1}
+FDO_VER_MINOR=${2}
+FDO_VER_REV=${3}
+# MG version
+MG_VER_MAJOR=${4}
+MG_VER_MINOR=${5}
+MG_VER_REV=${6}
+FDO_BRANCH=${7}
+MG_BRANCH=${8}
+MG_ARCH=${9}
+DISTRO=${11:-ubuntu12}
+UBUNTU=1
+FDO_PLATFORM=
+ FDO_PLATFORM=64
+ FDO_PLATFORM=32
+else
+ exit 1
+fi
+export FDO_VER_REV
+export MG_VER_REV
+export FDO_BRANCH
+export MG_BRANCH
+export MG_ARCH
+export UBUNTU
+export FDO_DISTRO
+export MG_DISTRO
+BUILD_COMPONENT=
+check_build()
+ error=$?
+ exit $error
+ fi
+check_test()
+ error=$?
+ fi
+else
+ check_build
+fi
+cd ~
+HAVE_FDO=0
+HAVE_FDO_LIBS=0
+HAVE_MAPGUIDE=0
+MG_UNIT_TEST=0
+FDO_UNIT_TEST=0
+MAKE_FDO_SDK=0
+fi
+fi
+then
+ HAVE_FDO=1
+fi
+then
+ HAVE_FDO_LIBS=1
+fi
+if [ -d $MG_SRC ];
+then
+ HAVE_MAPGUIDE=1
+fi
+then
+else
+fi
+cd $SCRIPT_ROOT
+then
+fi
+then
+fi
+then
+fi
+then
+fi
+then
+fi
+cd ~/scripts
+check_build
+check_build
+BUILD_COMPONENT="MapGuide deb packages"
+./dpkgmapguide.sh $MG_ARCH $MG_REV 2>&1 | tee ~/dpkg_mapguide.log
+check_build
+then
+ check_test
+ check_test
+ check_test
+ check_test
+ check_test
+ check_test
+ check_test
+fi
+then
+ # VM
+ do
+ check_test
+ fi
+ done
+fi
+cd $SCRIPT_ROOT
+fi
+echo [provision]: Copy FDO deb packages
+sudo cp fdo_build_area/install/bin/*.deb /vagrant/build
+echo [provision]: Copy MapGuide deb packages
+sudo cp bin/*.deb /vagrant/build
+fi
+else
+fi
+else
+fi
+fi
+sudo cp /vagrant/mginstallubuntu.sh /vagrant/build/mginstallubuntu.sh
+sudo cp /vagrant/mguninstallubuntu.sh /vagrant/build/mguninstallubuntu.sh
+sudo sed -i 's/URL_PART="ubuntu12"/URL_PART='"$DISTNAME"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/MGRELEASELABEL="ReleaseLabel"/MGRELEASELABEL='"$MG_RELEASE_LABEL"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/FDOARCH=i386/FDOARCH='"$MG_ARCH"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/MGARCH=i386/MGARCH='"$MG_ARCH"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/FDOBUILD=0/FDOBUILD='"$FDO_REV"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/MGBUILD=0/MGBUILD='"$MG_REV"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/FDOVER_MAJOR=0/FDOVER_MAJOR='"$FDO_VER_MAJOR"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/FDOVER_MINOR=0/FDOVER_MINOR='"$FDO_VER_MINOR"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/FDOVER_POINT=0/FDOVER_POINT='"$FDO_VER_REV"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/MGVER_MAJOR=0/MGVER_MAJOR='"$MG_VER_MAJOR"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/MGVER_MINOR=0/MGVER_MINOR='"$MG_VER_MINOR"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/MGVER_POINT=0/MGVER_POINT='"$MG_VER_REV"'/g' /vagrant/build/mginstallubuntu.sh
Added: branches/2.6/vagrant/scripts/svn_update.sh
--- branches/2.6/vagrant/scripts/svn_update.sh (rev 0)
+++ branches/2.6/vagrant/scripts/svn_update.sh 2016-04-10 04:30:40 UTC (rev 8911)
@@ -0,0 +1,96 @@
+#!/bin/bash
+# svn_update.sh
+# $1 - FDO branch name (trunk|major.minor)
+# $2 - MG branch name (trunk|major.minor)
+echo " Arg check"
+echo " 1 - ${1}"
+echo " 2 - ${2}"
+FDO_BRANCH=${1}
+MG_BRANCH=${2}
+BUILD_COMPONENT=
+check_build()
+ error=$?
+ exit $error
+ fi
+cd ~
+echo [provision]: Home directory is `pwd`
+echo [provision]: Checking directories
+HAVE_FDO=0
+HAVE_MAPGUIDE=0
+FDO_SRC_ROOT=~/fdo
+fi
+then
+ HAVE_FDO=1
+fi
+if [ -d $MG_SRC ];
+then
+ HAVE_MAPGUIDE=1
+fi
+then
+fi
+then
+fi
+echo [provision]: svn update FDO
+BUILD_COMPONENT="svn update FDO"
+svn update $FDO_SRC
+check_build
+echo [provision]: svn update MapGuide
+BUILD_COMPONENT="svn update MapGuide"
+svn update $MG_SRC
+check_build
+if [ ! -d /mapguide_sources/updated ]; then
+ sudo mkdir -p /mapguide_sources/updated
+ cd $MG_SRC_ROOT
+ echo [provision]: Updating mapguide source tarball
+ tar -zcf $MG_TARBALL MgDev
+ sudo mv $MG_TARBALL /mapguide_sources/updated
+ cd $FDO_SRC_ROOT
+ echo [provision]: Updating fdo source tarball
+ tar -zcf $FDO_TARBALL $FDO_SRC_DIR
+ sudo mv $FDO_TARBALL /mapguide_sources/updated
+else
+ echo [provision]: Updated tarballs already exist. Doing nothing
+fi
Modified: branches/2.6/vagrant/ubuntu/x64/Vagrantfile
--- branches/2.6/vagrant/ubuntu/x64/Vagrantfile 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/ubuntu/x64/Vagrantfile 2016-04-10 04:30:40 UTC (rev 8911)
@@ -116,262 +116,8 @@
-BUILD_COMPONENT=
-check_build()
- error=$?
- exit $error
- fi
-check_test()
- error=$?
- fi
-cd ~
-HAVE_FDO=0
-HAVE_FDO_LIBS=0
-HAVE_MAPGUIDE=0
-MG_UNIT_TEST=0
-FDO_UNIT_TEST=0
-FDO_VER_MM=3.9
-MG_VER_MM=2.6
-FDO_SRC_DIR=3.9
-HAVE_FDO_SDK=0
-FDO_SDK_PKG_PATH=~/fdosdk
-FDO_SDK_TARBALL=
-then
- HAVE_FDO=1
-fi
-then
- HAVE_FDO_LIBS=1
-fi
-if [ -d $MG_SRC ];
-then
- HAVE_MAPGUIDE=1
-fi
-if [ -f /mapguide_sources/fdosdk_filename ] && [ -f /mapguide_sources/fdosdk_rev ] && [ -d /mapguide_sources/filelist ];
-then
- FDO_SDK_TARBALL=`cat /mapguide_sources/fdosdk_filename`
- FDO_REV=`cat /mapguide_sources/fdosdk_rev`
- if [ -f /mapguide_sources/$FDO_SDK_TARBALL ];
- then
- sudo mkdir -p ${FDO_INST}
- sudo tar -zxf /mapguide_sources/$FDO_SDK_TARBALL -C ${FDO_INST}
- HAVE_FDO_SDK=1
- FDO_UNIT_TEST=0
- echo [provision]: Using FDO SDK. Not building from source. Not running FDO unit tests.
- fi
-else
- echo [provision]: FDO SDK not found. Building FDO from source.
-fi
-then
-else
-fi
-if [ $HAVE_FDO_SDK -eq 1 ];
-then
- echo [provision]: Prepare package build area for FDO SDK
- mkdir -p $FDO_SDK_PKG_PATH
- cp -R /mapguide_sources/filelist $FDO_SDK_PKG_PATH
- cp -f /vagrant/dpkgfdo.sh $FDO_SDK_PKG_PATH
- cp -f /vagrant/dpkgfdocore.sh $FDO_SDK_PKG_PATH
- cp -f /vagrant/dpkgfdoprovider.sh $FDO_SDK_PKG_PATH
- cp -f /vagrant/revnum.pl $FDO_SDK_PKG_PATH
-fi
-cd $SCRIPT_ROOT
-sed -i 's/UBUNTU=0/UBUNTU=1/g' build.sh
-sed -i 's/UBUNTU=0/UBUNTU=1/g' build_fdo.sh
-if [ $HAVE_FDO_SDK -eq 0 ];
-then
- if [ $HAVE_FDO_LIBS -eq 0 ];
- then
- fi
- if [ $HAVE_FDO -eq 0 ];
- then
- fi
-fi
-then
-fi
-then
- if [ -d /mapguide_sources/patches/fdo ];
- then
- fi
-else
- echo [provision]: Using FDO SDK. No source patches to apply
-fi
-then
-fi
-cd ~/scripts
-then
- BUILD_COMPONENT="FDO"
- sudo -E ./build_fdo.sh 2>&1 | tee ~/fdo_build.log
- check_build
- FDO_REV=`svn info $FDO_SRC | perl revnum.pl`
-else
- echo [provision]: Re-packaging FDO SDK r$FDO_REV as debs
- FDO_FILELIST=$FDO_SDK_PKG_PATH/filelist
- pushd $FDO_SDK_PKG_PATH
- ./dpkgfdo.sh amd64 $FDO_REV 2>&1 | tee ~/dpkg_fdo.log
- popd
-fi
-check_build
-BUILD_COMPONENT="MapGuide deb packages"
-./dpkgmapguide.sh amd64 $MG_REV 2>&1 | tee ~/dpkg_mapguide.log
-check_build
-then
- check_test
- check_test
- check_test
- check_test
- check_test
- check_test
- check_test
-fi
-then
- # VM
- # Run the test suites individually except for TileService for reasons already stated
- do
- check_test
- fi
- done
-fi
-cd $SCRIPT_ROOT
-then
- sudo cp fdo_build_area/install/bin/*.deb /vagrant/build
- sudo cp ~/fdo_*_unit_test.log /vagrant/build
-else
- sudo cp $FDO_SDK_PKG_PATH/bin/*.deb /vagrant/build
-fi
-sudo cp bin/*.deb /vagrant/build
-sudo cp ~/UnitTestResults_*.xml /vagrant/build
-sudo cp /vagrant/mginstallubuntu.sh /vagrant/build/mginstallubuntu.sh
-sudo cp /vagrant/mguninstallubuntu.sh /vagrant/build/mguninstallubuntu.sh
-sudo sed -i 's/URL_PART="ubuntu12"/URL_PART="ubuntu_x64"/g' /vagrant/build/mginstallubuntu.sh
-sudo sed -i 's/FDOBUILD=0/FDOBUILD='"$FDO_REV"'/g' /vagrant/build/mginstallubuntu.sh
-sudo sed -i 's/MGBUILD=0/MGBUILD='"$MG_REV"'/g' /vagrant/build/mginstallubuntu.sh
-sudo sed -i 's/FDOARCH=i386/FDOARCH=amd64/g' /vagrant/build/mginstallubuntu.sh
-sudo sed -i 's/MGARCH=i386/MGARCH=amd64/g' /vagrant/build/mginstallubuntu.sh
-SCRIPT
privileged: false,
- inline: $script
+ path: "provision_ubuntu.sh",
+ args: [3, 9, 0, 2, 6, 2, "3.9", "2.6", "amd64", "Final", "ubuntu12"]
end
Modified: branches/2.6/vagrant/ubuntu/x86/Vagrantfile
--- branches/2.6/vagrant/ubuntu/x86/Vagrantfile 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/ubuntu/x86/Vagrantfile 2016-04-10 04:30:40 UTC (rev 8911)
@@ -116,259 +116,8 @@
-BUILD_COMPONENT=
-check_build()
- error=$?
- exit $error
- fi
-check_test()
- error=$?
- fi
-cd ~
-HAVE_FDO=0
-HAVE_FDO_LIBS=0
-HAVE_MAPGUIDE=0
-MG_UNIT_TEST=0
-FDO_UNIT_TEST=0
-FDO_VER_MM=3.9
-MG_VER_MM=2.6
-FDO_SRC_DIR=3.9
-HAVE_FDO_SDK=0
-FDO_SDK_TARBALL=
-then
- HAVE_FDO=1
-fi
-then
- HAVE_FDO_LIBS=1
-fi
-if [ -d $MG_SRC ];
-then
- HAVE_MAPGUIDE=1
-fi
-then
- then
- HAVE_FDO_SDK=1
- FDO_UNIT_TEST=0
- fi
-else
-fi
-then
-else
-fi
-then
-fi
-cd $SCRIPT_ROOT
-then
- then
- fi
- then
- fi
-fi
-then
-fi
-then
- then
- fi
-else
-fi
-then
-fi
-cd ~/scripts
-then
- check_build
-else
- ./dpkgfdo.sh i386 $FDO_REV 2>&1 | tee ~/dpkg_fdo.log
- popd
-fi
-check_build
-./dpkgmapguide.sh i386 $MG_REV 2>&1 | tee ~/dpkg_mapguide.log
-check_build
-then
- check_test
- check_test
- check_test
- check_test
- check_test
- check_test
- check_test
-fi
-then
- # VM
- do
- check_test
- fi
- done
-fi
-cd $SCRIPT_ROOT
-then
-else
-fi
-sudo sed -i 's/URL_PART="ubuntu12"/URL_PART="ubuntu_x86"/g' /vagrant/build/mginstallubuntu.sh
-SCRIPT
privileged: false,
- inline: $script
+ args: [3, 9, 0, 2, 6, 2, "3.9", "2.6", "i386", "Final", "ubuntu12"]
end
Modified: branches/2.6/vagrant/verify.bat
--- branches/2.6/vagrant/verify.bat 2016-04-09 05:22:43 UTC (rev 8910)
+++ branches/2.6/vagrant/verify.bat 2016-04-10 04:30:40 UTC (rev 8911)
@@ -16,9 +16,9 @@
IF "%DOWNLOAD_HOST%"=="" SET DOWNLOAD_HOST=192.168.0.6
IF "%MG_DIST_DIR%"=="" SET MG_DIST_DIR=builds30
IF "%VERIFY_UBUNTU_32%"=="" SET VERIFY_UBUNTU_32=1
-IF "%VERIFY_UBUNTU_64%"=="" SET VERIFY_UBUNTU_64=0
+IF "%VERIFY_UBUNTU_64%"=="" SET VERIFY_UBUNTU_64=1
IF "%VERIFY_CENTOS_32%"=="" SET VERIFY_CENTOS_32=1
-IF "%VERIFY_CENTOS_64%"=="" SET VERIFY_CENTOS_64=0
+IF "%VERIFY_CENTOS_64%"=="" SET VERIFY_CENTOS_64=1
echo **************** Verify Summary *********************
echo Download Host is: %DOWNLOAD_HOST%
More information about the mapguide-commits
