[mapguide-commits] r8912 - sandbox/adsk/3.1n/Common/MapGuideCommon/Controller
svn_mapguide at osgeo.org
Mon Apr 11 00:03:02 PDT 2016
Author: hubu
Date: 2016-04-11 00:03:02 -0700 (Mon, 11 Apr 2016)
New Revision: 8912
sandbox/adsk/3.1n/Common/MapGuideCommon/Controller/HtmlController.cpp
Fix the issue that DateTime value cannot be displayed in selection panel.
Modified: sandbox/adsk/3.1n/Common/MapGuideCommon/Controller/HtmlController.cpp
--- sandbox/adsk/3.1n/Common/MapGuideCommon/Controller/HtmlController.cpp 2016-04-10 04:30:40 UTC (rev 8911)
+++ sandbox/adsk/3.1n/Common/MapGuideCommon/Controller/HtmlController.cpp 2016-04-11 07:03:02 UTC (rev 8912)
@@ -612,7 +612,7 @@
//ToXmlString() won't work with dates before Jan 1, 1970, so use yyyy-mm-dd hh:mm:ss
STRING dateStr;
STRING str;
- if (dt->IsDate())
+ if (dt->GetYear() != -1)
MgUtil::Int32ToString(dt->GetYear(), str);
dateStr += str;
@@ -625,9 +625,9 @@
MgUtil::PadLeft(str, 2, L'0');
dateStr += str;
- if (dt->IsTime())
+ if (dt->GetHour() != -1)
- if (dt->IsDate())
dateStr += L" ";
More information about the mapguide-commits
