[mapguide-commits] r9118 -	trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition
    svn_mapguide at osgeo.org
    Wed Jan 11 07:11:06 PST 2017
Author: jng
Date: 2017-01-11 07:11:06 -0800 (Wed, 11 Jan 2017)
New Revision: 9118
   trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/AdvancedSettingsCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/ParametersCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/SymbolGraphicsCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/SymbolParameterDialog.cs
   trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/UsageContextsCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/UsageContextsCtrl.resx
Flag dirty state in more parts of the Symbol Definition editor
Fixes #2472
Modified: trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/AdvancedSettingsCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/AdvancedSettingsCtrl.cs	2017-01-11 14:46:51 UTC (rev 9117)
+++ trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/AdvancedSettingsCtrl.cs	2017-01-11 15:11:06 UTC (rev 9118)
@@ -81,6 +81,7 @@
                 _sym.ResizeBox = _rbox;
             else
                 _sym.ResizeBox = null;
+            _edSvc.MarkDirty();
         private void OnContentChanged(object sender, EventArgs e) => OnResourceChanged();
Modified: trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/ParametersCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/ParametersCtrl.cs	2017-01-11 14:46:51 UTC (rev 9117)
+++ trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/ParametersCtrl.cs	2017-01-11 15:11:06 UTC (rev 9118)
@@ -39,11 +39,13 @@
             grdParameters.DataSource = _params;
+        private IEditorService _edSvc;
         private BindingList<IParameter> _params;
         private ISimpleSymbolDefinition _sym;
         public override void Bind(IEditorService service)
+            _edSvc = service;
             _params.Clear();
             _sym = (ISimpleSymbolDefinition)service.GetEditedResource();
             foreach (var p in _sym.ParameterDefinition.Parameter)
@@ -57,7 +59,7 @@
             var p = _sym.CreateParameter();
             _params.Add(p);
             _sym.ParameterDefinition.AddParameter(p);
-            var diag = new SymbolParameterDialog(_sym.ResourceVersion, p);
+            var diag = new SymbolParameterDialog(_sym.ResourceVersion, p, _edSvc);
             diag.ShowDialog();
@@ -66,7 +68,7 @@
             if (grdParameters.SelectedRows.Count == 1)
                 var p = (IParameter)grdParameters.SelectedRows[0].DataBoundItem;
                 diag.ShowDialog();
@@ -78,6 +80,7 @@
                 _params.Remove(p);
                 _sym.ParameterDefinition.RemoveParameter(p);
Modified: trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/SymbolGraphicsCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/SymbolGraphicsCtrl.cs	2017-01-11 14:46:51 UTC (rev 9117)
+++ trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/SymbolGraphicsCtrl.cs	2017-01-11 15:11:06 UTC (rev 9118)
@@ -86,6 +86,7 @@
             var text = _sym.CreateTextGraphics();
             AddGraphicsItem(text);
             _sym.AddGraphics(text);
+            this.OnResourceChanged();
             new TextDialog(this, _sym, text).ShowDialog();
@@ -94,6 +95,7 @@
             var path = _sym.CreatePathGraphics();
             AddGraphicsItem(path);
             _sym.AddGraphics(path);
             new PathDialog(this, _sym, path).ShowDialog();
@@ -102,6 +104,7 @@
             var img = _sym.CreateImageGraphics();
             AddGraphicsItem(img);
             _sym.AddGraphics(img);
             new ImageDialog(this, _conn, _sym, img).ShowDialog();
@@ -144,6 +147,7 @@
                 var g = (IGraphicBase)li.Tag;
                 lstGraphics.Items.Remove(li);
                 _sym.RemoveGraphics(g);
Modified: trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/SymbolParameterDialog.cs
--- trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/SymbolParameterDialog.cs	2017-01-11 14:46:51 UTC (rev 9117)
+++ trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/SymbolParameterDialog.cs	2017-01-11 15:11:06 UTC (rev 9118)
@@ -28,12 +28,14 @@
     internal partial class SymbolParameterDialog : Form
+        private readonly IEditorService _edSvc;
         private readonly IParameter _p;
         private bool _init = false;
-        public SymbolParameterDialog(Version ver, IParameter p)
+        public SymbolParameterDialog(Version ver, IParameter p, IEditorService edSvc)
             InitializeComponent();
+            _edSvc = edSvc;
             _p = p;
             _init = true;
             try
@@ -68,30 +70,35 @@
             if (_init) return;
             _p.Identifier = txtIdentifier.Text;
         private void txtDisplayName_TextChanged(object sender, EventArgs e)
             if (_init) return;
             _p.DisplayName = txtDisplayName.Text;
         private void txtDescription_TextChanged(object sender, EventArgs e)
             if (_init) return;
             _p.Description = txtDescription.Text;
         private void txtDefaultValue_TextChanged(object sender, EventArgs e)
             if (_init) return;
             _p.DefaultValue = txtDefaultValue.Text;
         private void cmbDataType_SelectedIndexChanged(object sender, EventArgs e)
             if (_init) return;
             _p.DataType = cmbDataType.SelectedItem.ToString();
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/UsageContextsCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/UsageContextsCtrl.cs	2017-01-11 14:46:51 UTC (rev 9117)
+++ trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/UsageContextsCtrl.cs	2017-01-11 15:11:06 UTC (rev 9118)
@@ -137,6 +137,7 @@
                 return;
             _sym.PointUsage = (chkPoint.Checked) ? _pu : null;
         private void chkLine_CheckedChanged(object sender, EventArgs e)
@@ -146,6 +147,7 @@
                 return;
             _sym.LineUsage = (chkLine.Checked) ? _lu : null;
         private void chkArea_CheckedChanged(object sender, EventArgs e)
@@ -155,6 +157,7 @@
                 return;
             _sym.AreaUsage = (chkArea.Checked) ? _au : null;
         private void OnRequestBrowse(SymbolField sender) => ParameterSelector.ShowParameterSelector(_sym.ParameterDefinition.Parameter, sender);
Modified: trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/UsageContextsCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/UsageContextsCtrl.resx	2017-01-11 14:46:51 UTC (rev 9117)
+++ trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/UsageContextsCtrl.resx	2017-01-11 15:11:06 UTC (rev 9118)
@@ -112,23 +112,23 @@
     <value>2.0</value>
   </resheader>
   <resheader name="reader">
-    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
   <resheader name="writer">
-    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
-  <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+  <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
   <data name="symAreaRepeatY.Location" type="System.Drawing.Point, System.Drawing">
     <value>338, 98</value>
   </data>
   <data name="symAreaRepeatY.Size" type="System.Drawing.Size, System.Drawing">
     <value>115, 21</value>
   </data>
-  <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
   <data name="symAreaRepeatY.TabIndex" type="System.Int32, mscorlib">
     <value>51</value>
   </data>
-  <metadata name="toolTip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+  <metadata name="toolTip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
     <value>17, 17</value>
   </metadata>
   <data name="symAreaRepeatY.ToolTip" xml:space="preserve">
@@ -138,7 +138,7 @@
     <value>symAreaRepeatY</value>
   </data>
   <data name=">>symAreaRepeatY.Type" xml:space="preserve">
-    <value>Maestro.Editors.SymbolDefinition.SymbolField, Maestro.Editors, Version=3.1.0.5859, Culture=neutral, PublicKeyToken=null</value>
+    <value>Maestro.Editors.SymbolDefinition.SymbolField, Maestro.Editors, Version=6.0.0.0, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
   </data>
   <data name=">>symAreaRepeatY.Parent" xml:space="preserve">
     <value>grpArea</value>
@@ -162,7 +162,7 @@
     <value>symAreaOriginY</value>
   </data>
   <data name=">>symAreaOriginY.Type" xml:space="preserve">
   </data>
   <data name=">>symAreaOriginY.Parent" xml:space="preserve">
@@ -186,7 +186,7 @@
     <value>symAreaAngle</value>
   </data>
   <data name=">>symAreaAngle.Type" xml:space="preserve">
   </data>
   <data name=">>symAreaAngle.Parent" xml:space="preserve">
@@ -210,7 +210,7 @@
     <value>symAreaOriginControl</value>
   </data>
   <data name=">>symAreaOriginControl.Type" xml:space="preserve">
   </data>
   <data name=">>symAreaOriginControl.Parent" xml:space="preserve">
@@ -234,7 +234,7 @@
     <value>symAreaBufferWidth</value>
   </data>
   <data name=">>symAreaBufferWidth.Type" xml:space="preserve">
   </data>
   <data name=">>symAreaBufferWidth.Parent" xml:space="preserve">
@@ -258,7 +258,7 @@
     <value>symAreaRepeatX</value>
   </data>
   <data name=">>symAreaRepeatX.Type" xml:space="preserve">
   </data>
   <data name=">>symAreaRepeatX.Parent" xml:space="preserve">
@@ -282,7 +282,7 @@
     <value>symAreaOriginX</value>
   </data>
   <data name=">>symAreaOriginX.Type" xml:space="preserve">
   </data>
   <data name=">>symAreaOriginX.Parent" xml:space="preserve">
@@ -306,7 +306,7 @@
     <value>symAreaClippingControl</value>
   </data>
   <data name=">>symAreaClippingControl.Type" xml:space="preserve">
   </data>
   <data name=">>symAreaClippingControl.Parent" xml:space="preserve">
@@ -330,7 +330,7 @@
     <value>symAreaAngleControl</value>
   </data>
   <data name=">>symAreaAngleControl.Type" xml:space="preserve">
   </data>
   <data name=">>symAreaAngleControl.Parent" xml:space="preserve">
@@ -341,7 +341,7 @@
   <data name="label1.AutoSize" type="System.Boolean, mscorlib">
     <value>True</value>
   </data>
-  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
   <data name="label1.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
     <value>NoControl</value>
   </data>
@@ -361,7 +361,7 @@
     <value>label1</value>
   </data>
   <data name=">>label1.Type" xml:space="preserve">
-    <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>label1.Parent" xml:space="preserve">
@@ -391,7 +391,7 @@
     <value>label3</value>
   </data>
   <data name=">>label3.Type" xml:space="preserve">
   </data>
   <data name=">>label3.Parent" xml:space="preserve">
@@ -421,7 +421,7 @@
     <value>label4</value>
   </data>
   <data name=">>label4.Type" xml:space="preserve">
   </data>
   <data name=">>label4.Parent" xml:space="preserve">
@@ -451,7 +451,7 @@
     <value>label5</value>
   </data>
   <data name=">>label5.Type" xml:space="preserve">
   </data>
   <data name=">>label5.Parent" xml:space="preserve">
@@ -481,7 +481,7 @@
     <value>label21</value>
   </data>
   <data name=">>label21.Type" xml:space="preserve">
   </data>
   <data name=">>label21.Parent" xml:space="preserve">
@@ -511,7 +511,7 @@
     <value>label22</value>
   </data>
   <data name=">>label22.Type" xml:space="preserve">
   </data>
   <data name=">>label22.Parent" xml:space="preserve">
@@ -541,7 +541,7 @@
     <value>label23</value>
   </data>
   <data name=">>label23.Type" xml:space="preserve">
   </data>
   <data name=">>label23.Parent" xml:space="preserve">
@@ -571,7 +571,7 @@
     <value>label24</value>
   </data>
   <data name=">>label24.Type" xml:space="preserve">
   </data>
   <data name=">>label24.Parent" xml:space="preserve">
@@ -601,7 +601,7 @@
     <value>label25</value>
   </data>
   <data name=">>label25.Type" xml:space="preserve">
   </data>
   <data name=">>label25.Parent" xml:space="preserve">
@@ -622,7 +622,7 @@
   </data>
   <data name=">>grpArea.Type" xml:space="preserve">
-    <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>grpArea.Parent" xml:space="preserve">
     <value>contentPanel</value>
@@ -646,7 +646,7 @@
     <value>symLineVertexMiterLimit</value>
   </data>
   <data name=">>symLineVertexMiterLimit.Type" xml:space="preserve">
   </data>
   <data name=">>symLineVertexMiterLimit.Parent" xml:space="preserve">
     <value>grpLine</value>
@@ -670,7 +670,7 @@
     <value>symLineVertexAngleLimit</value>
   </data>
   <data name=">>symLineVertexAngleLimit.Type" xml:space="preserve">
   </data>
   <data name=">>symLineVertexAngleLimit.Parent" xml:space="preserve">
@@ -694,7 +694,7 @@
     <value>symLineEndOffset</value>
   </data>
   <data name=">>symLineEndOffset.Type" xml:space="preserve">
   </data>
   <data name=">>symLineEndOffset.Parent" xml:space="preserve">
@@ -718,7 +718,7 @@
     <value>symLineAngle</value>
   </data>
   <data name=">>symLineAngle.Type" xml:space="preserve">
   </data>
   <data name=">>symLineAngle.Parent" xml:space="preserve">
@@ -742,7 +742,7 @@
     <value>symLineUnitsControl</value>
   </data>
   <data name=">>symLineUnitsControl.Type" xml:space="preserve">
   </data>
   <data name=">>symLineUnitsControl.Parent" xml:space="preserve">
@@ -766,7 +766,7 @@
     <value>symLineVertexJoin</value>
   </data>
   <data name=">>symLineVertexJoin.Type" xml:space="preserve">
   </data>
   <data name=">>symLineVertexJoin.Parent" xml:space="preserve">
@@ -790,7 +790,7 @@
     <value>symLineRepeat</value>
   </data>
   <data name=">>symLineRepeat.Type" xml:space="preserve">
   </data>
   <data name=">>symLineRepeat.Parent" xml:space="preserve">
@@ -814,7 +814,7 @@
     <value>symLineStartOffset</value>
   </data>
   <data name=">>symLineStartOffset.Type" xml:space="preserve">
   </data>
   <data name=">>symLineStartOffset.Parent" xml:space="preserve">
@@ -838,7 +838,7 @@
     <value>symLineVertexControl</value>
   </data>
   <data name=">>symLineVertexControl.Type" xml:space="preserve">
   </data>
   <data name=">>symLineVertexControl.Parent" xml:space="preserve">
@@ -862,7 +862,7 @@
     <value>symLineAngleControl</value>
   </data>
   <data name=">>symLineAngleControl.Type" xml:space="preserve">
   </data>
   <data name=">>symLineAngleControl.Parent" xml:space="preserve">
@@ -889,7 +889,7 @@
     <value>button2</value>
   </data>
   <data name=">>button2.Type" xml:space="preserve">
-    <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>button2.Parent" xml:space="preserve">
@@ -916,7 +916,7 @@
     <value>button1</value>
   </data>
   <data name=">>button1.Type" xml:space="preserve">
   </data>
   <data name=">>button1.Parent" xml:space="preserve">
@@ -940,7 +940,7 @@
     <value>textBox16</value>
   </data>
   <data name=">>textBox16.Type" xml:space="preserve">
-    <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>textBox16.Parent" xml:space="preserve">
@@ -970,7 +970,7 @@
     <value>label20</value>
   </data>
   <data name=">>label20.Type" xml:space="preserve">
   </data>
   <data name=">>label20.Parent" xml:space="preserve">
@@ -1000,7 +1000,7 @@
     <value>label19</value>
   </data>
   <data name=">>label19.Type" xml:space="preserve">
   </data>
   <data name=">>label19.Parent" xml:space="preserve">
@@ -1030,7 +1030,7 @@
     <value>label18</value>
   </data>
   <data name=">>label18.Type" xml:space="preserve">
   </data>
   <data name=">>label18.Parent" xml:space="preserve">
@@ -1060,7 +1060,7 @@
     <value>label17</value>
   </data>
   <data name=">>label17.Type" xml:space="preserve">
   </data>
   <data name=">>label17.Parent" xml:space="preserve">
@@ -1090,7 +1090,7 @@
     <value>label16</value>
   </data>
   <data name=">>label16.Type" xml:space="preserve">
   </data>
   <data name=">>label16.Parent" xml:space="preserve">
@@ -1120,7 +1120,7 @@
     <value>label14</value>
   </data>
   <data name=">>label14.Type" xml:space="preserve">
   </data>
   <data name=">>label14.Parent" xml:space="preserve">
@@ -1150,7 +1150,7 @@
     <value>label13</value>
   </data>
   <data name=">>label13.Type" xml:space="preserve">
   </data>
   <data name=">>label13.Parent" xml:space="preserve">
@@ -1180,7 +1180,7 @@
     <value>label15</value>
   </data>
   <data name=">>label15.Type" xml:space="preserve">
   </data>
   <data name=">>label15.Parent" xml:space="preserve">
@@ -1210,7 +1210,7 @@
     <value>label12</value>
   </data>
   <data name=">>label12.Type" xml:space="preserve">
   </data>
   <data name=">>label12.Parent" xml:space="preserve">
@@ -1240,7 +1240,7 @@
     <value>label11</value>
   </data>
   <data name=">>label11.Type" xml:space="preserve">
   </data>
   <data name=">>label11.Parent" xml:space="preserve">
@@ -1270,7 +1270,7 @@
     <value>label10</value>
   </data>
   <data name=">>label10.Type" xml:space="preserve">
   </data>
   <data name=">>label10.Parent" xml:space="preserve">
@@ -1291,7 +1291,7 @@
   </data>
   <data name=">>grpLine.Type" xml:space="preserve">
   </data>
   <data name=">>grpLine.Parent" xml:space="preserve">
@@ -1315,7 +1315,7 @@
     <value>symPointOriginOffsetY</value>
   </data>
   <data name=">>symPointOriginOffsetY.Type" xml:space="preserve">
   </data>
   <data name=">>symPointOriginOffsetY.Parent" xml:space="preserve">
     <value>grpPoint</value>
@@ -1339,7 +1339,7 @@
     <value>symPointAngle</value>
   </data>
   <data name=">>symPointAngle.Type" xml:space="preserve">
   </data>
   <data name=">>symPointAngle.Parent" xml:space="preserve">
@@ -1363,7 +1363,7 @@
     <value>symPointOriginOffsetX</value>
   </data>
   <data name=">>symPointOriginOffsetX.Type" xml:space="preserve">
   </data>
   <data name=">>symPointOriginOffsetX.Parent" xml:space="preserve">
@@ -1387,7 +1387,7 @@
     <value>symPointAngleControl</value>
   </data>
   <data name=">>symPointAngleControl.Type" xml:space="preserve">
   </data>
   <data name=">>symPointAngleControl.Parent" xml:space="preserve">
@@ -1417,7 +1417,7 @@
     <value>label9</value>
   </data>
   <data name=">>label9.Type" xml:space="preserve">
   </data>
   <data name=">>label9.Parent" xml:space="preserve">
@@ -1447,7 +1447,7 @@
     <value>label8</value>
   </data>
   <data name=">>label8.Type" xml:space="preserve">
   </data>
   <data name=">>label8.Parent" xml:space="preserve">
@@ -1477,7 +1477,7 @@
     <value>label7</value>
   </data>
   <data name=">>label7.Type" xml:space="preserve">
   </data>
   <data name=">>label7.Parent" xml:space="preserve">
@@ -1507,7 +1507,7 @@
     <value>label6</value>
   </data>
   <data name=">>label6.Type" xml:space="preserve">
   </data>
   <data name=">>label6.Parent" xml:space="preserve">
@@ -1528,7 +1528,7 @@
   </data>
   <data name=">>grpPoint.Type" xml:space="preserve">
   </data>
   <data name=">>grpPoint.Parent" xml:space="preserve">
@@ -1561,7 +1561,7 @@
     <value>chkArea</value>
   </data>
   <data name=">>chkArea.Type" xml:space="preserve">
-    <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>chkArea.Parent" xml:space="preserve">
@@ -1595,7 +1595,7 @@
     <value>chkLine</value>
   </data>
   <data name=">>chkLine.Type" xml:space="preserve">
   </data>
   <data name=">>chkLine.Parent" xml:space="preserve">
@@ -1628,7 +1628,7 @@
     <value>chkPoint</value>
   </data>
   <data name=">>chkPoint.Type" xml:space="preserve">
   </data>
   <data name=">>chkPoint.Parent" xml:space="preserve">
@@ -1643,7 +1643,7 @@
   </data>
   <data name=">>contentPanel.Type" xml:space="preserve">
-    <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>contentPanel.Parent" xml:space="preserve">
     <value>$this</value>
@@ -1651,9 +1651,12 @@
   <data name=">>contentPanel.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
-  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
     <value>True</value>
   </metadata>
+  <data name="$this.HeaderText" xml:space="preserve">
+    <value>Symbol Usage</value>
+  </data>
   <data name="$this.Size" type="System.Drawing.Size, System.Drawing">
     <value>560, 568</value>
   </data>
@@ -1661,12 +1664,12 @@
     <value>toolTip</value>
   </data>
   <data name=">>toolTip.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ToolTip, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.ToolTip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>$this.Name" xml:space="preserve">
     <value>UsageContextsCtrl</value>
   </data>
   <data name=">>$this.Type" xml:space="preserve">
-    <value>Maestro.Editors.Common.EditorBindableCollapsiblePanel, Maestro.Editors, Version=3.1.0.5859, Culture=neutral, PublicKeyToken=null</value>
+    <value>Maestro.Editors.Common.EditorBindableCollapsiblePanel, Maestro.Editors, Version=6.0.0.0, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
   </data>
 </root>
More information about the mapguide-commits
