[mapguide-commits] r9119 - in trunk/Tools/Maestro: Maestro.Base/Commands Maestro.Editors Maestro.Editors/Preview Maestro.LiveMapEditor
svn_mapguide at osgeo.org
Fri Jan 20 03:15:58 PST 2017
Author: jng
Date: 2017-01-20 03:15:58 -0800 (Fri, 20 Jan 2017)
New Revision: 9119
Added:
trunk/Tools/Maestro/Maestro.Editors/Preview/MapPreviewViewContent.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Preview/MapPreviewViewContent.cs
trunk/Tools/Maestro/Maestro.Editors/Preview/MapPreviewViewContent.resx
trunk/Tools/Maestro/Maestro.Base/Commands/StartupCommand.cs
trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
trunk/Tools/Maestro/Maestro.Editors/Preview/LocalMapPreviewer.cs
trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Strings.resx
trunk/Tools/Maestro/Maestro.LiveMapEditor/Program.cs
Make local map previews non-modal
Fixes #2758
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/StartupCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/StartupCommand.cs 2017-01-11 15:11:06 UTC (rev 9118)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/StartupCommand.cs 2017-01-20 11:15:58 UTC (rev 9119)
@@ -43,11 +43,12 @@
PreviewSettings.UseLocalPreview = PropertyService.Get(ConfigProperties.UseLocalPreview, ConfigProperties.DefaultUseLocalPreview);
var urlLauncher = ServiceRegistry.GetService<UrlLauncherService>();
- ResourcePreviewerFactory.RegisterPreviewer("Maestro.Http", new LocalMapPreviewer(new DefaultResourcePreviewer(urlLauncher), urlLauncher)); //NOXLATE
- ResourcePreviewerFactory.RegisterPreviewer("Maestro.Rest", new LocalMapPreviewer(new DefaultResourcePreviewer(urlLauncher), urlLauncher)); //NOXLATE
+ var vcMgr = ServiceRegistry.GetService<ViewContentManager>();
+ ResourcePreviewerFactory.RegisterPreviewer("Maestro.Http", new LocalMapPreviewer(new DefaultResourcePreviewer(urlLauncher), urlLauncher, vcMgr)); //NOXLATE
+ ResourcePreviewerFactory.RegisterPreviewer("Maestro.Rest", new LocalMapPreviewer(new DefaultResourcePreviewer(urlLauncher), urlLauncher, vcMgr)); //NOXLATE
//A stub previewer does nothing, but will use local map previews for applicable resources if the configuration
//property is set
- ResourcePreviewerFactory.RegisterPreviewer("Maestro.LocalNative", new LocalMapPreviewer(new StubPreviewer(), urlLauncher)); //NOXLATE
+ ResourcePreviewerFactory.RegisterPreviewer("Maestro.LocalNative", new LocalMapPreviewer(new StubPreviewer(), urlLauncher, vcMgr)); //NOXLATE
ServiceRegistry.GetService<NewItemTemplateService>().InitUserTemplates();
var wb = Workbench.Instance;
@@ -57,14 +58,12 @@
wb.FormClosing += new System.Windows.Forms.FormClosingEventHandler(OnWorkbenchClosing);
wb.Text = "MapGuide Maestro"; //NOXLATE
- var mgr = ServiceRegistry.GetService<ViewContentManager>();
if (Props.Get(ConfigProperties.ShowMessages, true))
- mgr.OpenContent<MessageViewer>(ViewRegion.Bottom);
+ vcMgr.OpenContent<MessageViewer>(ViewRegion.Bottom);
if (Props.Get(ConfigProperties.ShowOutboundRequests, true))
- mgr.OpenContent<OutboundRequestViewer>(ViewRegion.Bottom);
+ vcMgr.OpenContent<OutboundRequestViewer>(ViewRegion.Bottom);
LoginCommand.RunInternal(true);
Modified: trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
--- trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2017-01-11 15:11:06 UTC (rev 9118)
+++ trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2017-01-20 11:15:58 UTC (rev 9119)
@@ -1066,6 +1066,12 @@
<Compile Include="Preview\MapPreviewDialog.Designer.cs">
<DependentUpon>MapPreviewDialog.cs</DependentUpon>
</Compile>
+ <Compile Include="Preview\MapPreviewViewContent.cs">
+ <SubType>UserControl</SubType>
+ </Compile>
+ <Compile Include="Preview\MapPreviewViewContent.Designer.cs">
+ <DependentUpon>MapPreviewViewContent.cs</DependentUpon>
+ </Compile>
<Compile Include="Preview\PreviewSettings.cs" />
<Compile Include="Preview\ResourcePreviewEngine.cs" />
<Compile Include="Preview\ResourcePreviewFactory.cs" />
@@ -1875,6 +1881,9 @@
<EmbeddedResource Include="Preview\MapPreviewDialog.resx">
</EmbeddedResource>
+ <EmbeddedResource Include="Preview\MapPreviewViewContent.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="PrintLayout\LogoDialog.resx">
<DependentUpon>LogoDialog.cs</DependentUpon>
</EmbeddedResource>
Modified: trunk/Tools/Maestro/Maestro.Editors/Preview/LocalMapPreviewer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Preview/LocalMapPreviewer.cs 2017-01-11 15:11:06 UTC (rev 9118)
+++ trunk/Tools/Maestro/Maestro.Editors/Preview/LocalMapPreviewer.cs 2017-01-20 11:15:58 UTC (rev 9119)
@@ -37,18 +37,21 @@
/// </summary>
public class LocalMapPreviewer : IResourcePreviewer
- private readonly IResourcePreviewer _inner;
- private readonly IUrlLauncherService _launcher;
+ readonly IResourcePreviewer _inner;
+ readonly IUrlLauncherService _launcher;
+ readonly IViewContentManager _viewManager;
/// <summary>
/// Initializes a new instance of the LocalMapPreviewer class
/// </summary>
/// <param name="inner">The inner resource previewer</param>
/// <param name="launcher">The URL launcher service</param>
- public LocalMapPreviewer(IResourcePreviewer inner, IUrlLauncherService launcher)
+ /// <param name="viewManager">The view content manager</param>
+ public LocalMapPreviewer(IResourcePreviewer inner, IUrlLauncherService launcher, IViewContentManager viewManager)
_inner = inner;
_launcher = launcher;
+ _viewManager = viewManager;
/// <summary>
@@ -164,8 +167,15 @@
if (obj != null)
var rtMap = (RuntimeMap)obj;
- var diag = new MapPreviewDialog(rtMap, _launcher, (edSvc.IsNew) ? null : edSvc.ResourceID);
- diag.Show(null);
+ if (_viewManager != null)
+ _viewManager.OpenContent(ViewRegion.Document, () => new MapPreviewViewContent(rtMap, _launcher, (edSvc.IsNew) ? null : edSvc.ResourceID));
+ else
+ var diag = new MapPreviewDialog(rtMap, _launcher, (edSvc.IsNew) ? null : edSvc.ResourceID);
+ diag.Show(null);
else //Fallback, shouldn't happen
Added: trunk/Tools/Maestro/Maestro.Editors/Preview/MapPreviewViewContent.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Preview/MapPreviewViewContent.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Preview/MapPreviewViewContent.Designer.cs 2017-01-20 11:15:58 UTC (rev 9119)
@@ -0,0 +1,372 @@
+namespace Maestro.Editors.Preview
+ partial class MapPreviewViewContent
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Component Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.defaultToolbar = new Maestro.MapViewer.DefaultToolbar();
+ this.statusStrip = new System.Windows.Forms.StatusStrip();
+ this.lblCoordinates = new System.Windows.Forms.ToolStripStatusLabel();
+ this.lblSelected = new System.Windows.Forms.ToolStripStatusLabel();
+ this.lblScale = new System.Windows.Forms.ToolStripStatusLabel();
+ this.legend = new Maestro.MapViewer.Legend();
+ this.rightPanel = new System.Windows.Forms.Panel();
+ this.mapViewer = new Maestro.MapViewer.MapViewer();
+ this.mapStatusTracker = new Maestro.MapViewer.MapStatusTracker();
+ this.grpOtherTools = new System.Windows.Forms.GroupBox();
+ this.btnGetMapKml = new System.Windows.Forms.Button();
+ this.lnkZoomToScale = new System.Windows.Forms.LinkLabel();
+ this.numZoomToScale = new System.Windows.Forms.NumericUpDown();
+ this.label5 = new System.Windows.Forms.Label();
+ this.groupBox1 = new System.Windows.Forms.GroupBox();
+ this.txtCoordinateSystem = new System.Windows.Forms.TextBox();
+ this.label6 = new System.Windows.Forms.Label();
+ this.txtMaxY = new System.Windows.Forms.TextBox();
+ this.label4 = new System.Windows.Forms.Label();
+ this.txtMaxX = new System.Windows.Forms.TextBox();
+ this.label3 = new System.Windows.Forms.Label();
+ this.txtMinY = new System.Windows.Forms.TextBox();
+ this.label2 = new System.Windows.Forms.Label();
+ this.txtMinX = new System.Windows.Forms.TextBox();
+ this.label1 = new System.Windows.Forms.Label();
+ this.statusStrip.SuspendLayout();
+ this.rightPanel.SuspendLayout();
+ this.grpOtherTools.SuspendLayout();
+ ((System.ComponentModel.ISupportInitialize)(this.numZoomToScale)).BeginInit();
+ this.groupBox1.SuspendLayout();
+ this.SuspendLayout();
+ // defaultToolbar
+ this.defaultToolbar.Location = new System.Drawing.Point(0, 0);
+ this.defaultToolbar.Name = "defaultToolbar";
+ this.defaultToolbar.Size = new System.Drawing.Size(821, 25);
+ this.defaultToolbar.TabIndex = 0;
+ this.defaultToolbar.Text = "defaultToolbar1";
+ this.defaultToolbar.Viewer = this.mapViewer;
+ // statusStrip
+ this.statusStrip.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.lblCoordinates,
+ this.lblSelected,
+ this.lblScale});
+ this.statusStrip.Location = new System.Drawing.Point(0, 525);
+ this.statusStrip.Name = "statusStrip";
+ this.statusStrip.Size = new System.Drawing.Size(821, 22);
+ this.statusStrip.TabIndex = 4;
+ this.statusStrip.Text = "statusStrip1";
+ // lblCoordinates
+ this.lblCoordinates.Name = "lblCoordinates";
+ this.lblCoordinates.Size = new System.Drawing.Size(0, 17);
+ // lblSelected
+ this.lblSelected.Name = "lblSelected";
+ this.lblSelected.Size = new System.Drawing.Size(775, 17);
+ this.lblSelected.Spring = true;
+ // lblScale
+ this.lblScale.Name = "lblScale";
+ this.lblScale.Size = new System.Drawing.Size(0, 17);
+ // legend
+ this.legend.Dock = System.Windows.Forms.DockStyle.Left;
+ this.legend.GroupContextMenu = null;
+ this.legend.LayerContextMenu = null;
+ this.legend.Location = new System.Drawing.Point(0, 25);
+ this.legend.Name = "legend";
+ this.legend.SelectOnRightClick = false;
+ this.legend.ShowAllLayersAndGroups = false;
+ this.legend.ShowTooltips = true;
+ this.legend.Size = new System.Drawing.Size(210, 500);
+ this.legend.TabIndex = 5;
+ this.legend.ThemeCompressionLimit = 25;
+ this.legend.Viewer = this.mapViewer;
+ // rightPanel
+ this.rightPanel.Controls.Add(this.grpOtherTools);
+ this.rightPanel.Controls.Add(this.groupBox1);
+ this.rightPanel.Dock = System.Windows.Forms.DockStyle.Right;
+ this.rightPanel.Location = new System.Drawing.Point(593, 25);
+ this.rightPanel.Name = "rightPanel";
+ this.rightPanel.Size = new System.Drawing.Size(228, 500);
+ this.rightPanel.TabIndex = 6;
+ // mapViewer
+ this.mapViewer.Cursor = System.Windows.Forms.Cursors.Default;
+ this.mapViewer.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.mapViewer.Location = new System.Drawing.Point(210, 25);
+ this.mapViewer.MaxScale = 1000000000;
+ this.mapViewer.MinScale = 10;
+ this.mapViewer.MouseWheelDelayRenderInterval = 800;
+ this.mapViewer.Name = "mapViewer";
+ this.mapViewer.PointPixelBuffer = 2;
+ this.mapViewer.SelectionColor = System.Drawing.Color.Blue;
+ this.mapViewer.Size = new System.Drawing.Size(383, 500);
+ this.mapViewer.TabIndex = 7;
+ this.mapViewer.Text = "mapViewer1";
+ this.mapViewer.TooltipDelayInterval = 1000;
+ this.mapViewer.ZoomInFactor = 0.5D;
+ this.mapViewer.ZoomOutFactor = 2D;
+ this.mapViewer.MapScaleChanged += new System.EventHandler(this.mapViewer_MapScaleChanged);
+ this.mapViewer.PropertyChanged += new System.ComponentModel.PropertyChangedEventHandler(this.mapViewer_PropertyChanged);
+ // mapStatusTracker
+ this.mapStatusTracker.CoordinatesLabel = this.lblCoordinates;
+ this.mapStatusTracker.ScaleLabel = this.lblScale;
+ this.mapStatusTracker.SelectedLabel = this.lblSelected;
+ this.mapStatusTracker.Viewer = this.mapViewer;
+ // grpOtherTools
+ this.grpOtherTools.Controls.Add(this.btnGetMapKml);
+ this.grpOtherTools.Controls.Add(this.lnkZoomToScale);
+ this.grpOtherTools.Controls.Add(this.numZoomToScale);
+ this.grpOtherTools.Controls.Add(this.label5);
+ this.grpOtherTools.Dock = System.Windows.Forms.DockStyle.Bottom;
+ this.grpOtherTools.Location = new System.Drawing.Point(0, 385);
+ this.grpOtherTools.Name = "grpOtherTools";
+ this.grpOtherTools.Size = new System.Drawing.Size(228, 115);
+ this.grpOtherTools.TabIndex = 9;
+ this.grpOtherTools.TabStop = false;
+ this.grpOtherTools.Text = "Other Tools";
+ // btnGetMapKml
+ this.btnGetMapKml.Location = new System.Drawing.Point(10, 74);
+ this.btnGetMapKml.Name = "btnGetMapKml";
+ this.btnGetMapKml.Size = new System.Drawing.Size(94, 23);
+ this.btnGetMapKml.TabIndex = 4;
+ this.btnGetMapKml.Text = "Get Map KML";
+ this.btnGetMapKml.UseVisualStyleBackColor = true;
+ this.btnGetMapKml.Click += new System.EventHandler(this.btnGetMapKml_Click);
+ // lnkZoomToScale
+ this.lnkZoomToScale.AutoSize = true;
+ this.lnkZoomToScale.Location = new System.Drawing.Point(93, 32);
+ this.lnkZoomToScale.Name = "lnkZoomToScale";
+ this.lnkZoomToScale.Size = new System.Drawing.Size(40, 13);
+ this.lnkZoomToScale.TabIndex = 3;
+ this.lnkZoomToScale.TabStop = true;
+ this.lnkZoomToScale.Text = "(Zoom)";
+ this.lnkZoomToScale.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkZoomToScale_LinkClicked);
+ // numZoomToScale
+ this.numZoomToScale.Location = new System.Drawing.Point(10, 48);
+ this.numZoomToScale.Name = "numZoomToScale";
+ this.numZoomToScale.Size = new System.Drawing.Size(135, 20);
+ this.numZoomToScale.TabIndex = 2;
+ // label5
+ this.label5.AutoSize = true;
+ this.label5.Location = new System.Drawing.Point(7, 32);
+ this.label5.Name = "label5";
+ this.label5.Size = new System.Drawing.Size(80, 13);
+ this.label5.TabIndex = 1;
+ this.label5.Text = "Zoom To Scale";
+ // groupBox1
+ this.groupBox1.Controls.Add(this.txtCoordinateSystem);
+ this.groupBox1.Controls.Add(this.label6);
+ this.groupBox1.Controls.Add(this.txtMaxY);
+ this.groupBox1.Controls.Add(this.label4);
+ this.groupBox1.Controls.Add(this.txtMaxX);
+ this.groupBox1.Controls.Add(this.label3);
+ this.groupBox1.Controls.Add(this.txtMinY);
+ this.groupBox1.Controls.Add(this.label2);
+ this.groupBox1.Controls.Add(this.txtMinX);
+ this.groupBox1.Controls.Add(this.label1);
+ this.groupBox1.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.groupBox1.Location = new System.Drawing.Point(0, 0);
+ this.groupBox1.Name = "groupBox1";
+ this.groupBox1.Size = new System.Drawing.Size(228, 500);
+ this.groupBox1.TabIndex = 8;
+ this.groupBox1.TabStop = false;
+ this.groupBox1.Text = "Current Extents";
+ // txtCoordinateSystem
+ this.txtCoordinateSystem.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ | System.Windows.Forms.AnchorStyles.Right)));
+ this.txtCoordinateSystem.Location = new System.Drawing.Point(10, 207);
+ this.txtCoordinateSystem.Multiline = true;
+ this.txtCoordinateSystem.Name = "txtCoordinateSystem";
+ this.txtCoordinateSystem.ReadOnly = true;
+ this.txtCoordinateSystem.ScrollBars = System.Windows.Forms.ScrollBars.Vertical;
+ this.txtCoordinateSystem.Size = new System.Drawing.Size(198, 123);
+ this.txtCoordinateSystem.TabIndex = 9;
+ // label6
+ this.label6.AutoSize = true;
+ this.label6.Location = new System.Drawing.Point(7, 190);
+ this.label6.Name = "label6";
+ this.label6.Size = new System.Drawing.Size(95, 13);
+ this.label6.TabIndex = 8;
+ this.label6.Text = "Coordinate System";
+ // txtMaxY
+ this.txtMaxY.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtMaxY.Location = new System.Drawing.Point(10, 167);
+ this.txtMaxY.Name = "txtMaxY";
+ this.txtMaxY.ReadOnly = true;
+ this.txtMaxY.Size = new System.Drawing.Size(198, 20);
+ this.txtMaxY.TabIndex = 7;
+ // label4
+ this.label4.AutoSize = true;
+ this.label4.Location = new System.Drawing.Point(7, 150);
+ this.label4.Name = "label4";
+ this.label4.Size = new System.Drawing.Size(37, 13);
+ this.label4.TabIndex = 6;
+ this.label4.Text = "Max Y";
+ // txtMaxX
+ this.txtMaxX.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtMaxX.Location = new System.Drawing.Point(10, 129);
+ this.txtMaxX.Name = "txtMaxX";
+ this.txtMaxX.ReadOnly = true;
+ this.txtMaxX.Size = new System.Drawing.Size(198, 20);
+ this.txtMaxX.TabIndex = 5;
+ // label3
+ this.label3.AutoSize = true;
+ this.label3.Location = new System.Drawing.Point(7, 112);
+ this.label3.Name = "label3";
+ this.label3.Size = new System.Drawing.Size(37, 13);
+ this.label3.TabIndex = 4;
+ this.label3.Text = "Max X";
+ // txtMinY
+ this.txtMinY.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtMinY.Location = new System.Drawing.Point(10, 89);
+ this.txtMinY.Name = "txtMinY";
+ this.txtMinY.ReadOnly = true;
+ this.txtMinY.Size = new System.Drawing.Size(198, 20);
+ this.txtMinY.TabIndex = 3;
+ // label2
+ this.label2.AutoSize = true;
+ this.label2.Location = new System.Drawing.Point(7, 72);
+ this.label2.Name = "label2";
+ this.label2.Size = new System.Drawing.Size(34, 13);
+ this.label2.TabIndex = 2;
+ this.label2.Text = "Min Y";
+ // txtMinX
+ this.txtMinX.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtMinX.Location = new System.Drawing.Point(10, 49);
+ this.txtMinX.Name = "txtMinX";
+ this.txtMinX.ReadOnly = true;
+ this.txtMinX.Size = new System.Drawing.Size(198, 20);
+ this.txtMinX.TabIndex = 1;
+ // label1
+ this.label1.AutoSize = true;
+ this.label1.Location = new System.Drawing.Point(7, 32);
+ this.label1.Name = "label1";
+ this.label1.Size = new System.Drawing.Size(34, 13);
+ this.label1.TabIndex = 0;
+ this.label1.Text = "Min X";
+ // MapPreviewViewContent
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.Controls.Add(this.mapViewer);
+ this.Controls.Add(this.rightPanel);
+ this.Controls.Add(this.legend);
+ this.Controls.Add(this.statusStrip);
+ this.Controls.Add(this.defaultToolbar);
+ this.Name = "MapPreviewViewContent";
+ this.Size = new System.Drawing.Size(821, 547);
+ this.statusStrip.ResumeLayout(false);
+ this.statusStrip.PerformLayout();
+ this.rightPanel.ResumeLayout(false);
+ this.grpOtherTools.ResumeLayout(false);
+ this.grpOtherTools.PerformLayout();
+ ((System.ComponentModel.ISupportInitialize)(this.numZoomToScale)).EndInit();
+ this.groupBox1.ResumeLayout(false);
+ this.groupBox1.PerformLayout();
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private MapViewer.DefaultToolbar defaultToolbar;
+ private System.Windows.Forms.StatusStrip statusStrip;
+ private System.Windows.Forms.ToolStripStatusLabel lblCoordinates;
+ private System.Windows.Forms.ToolStripStatusLabel lblSelected;
+ private System.Windows.Forms.ToolStripStatusLabel lblScale;
+ private System.Windows.Forms.Panel rightPanel;
+ private MapViewer.MapViewer mapViewer;
+ private MapViewer.Legend legend;
+ private MapViewer.MapStatusTracker mapStatusTracker;
+ private System.Windows.Forms.GroupBox grpOtherTools;
+ private System.Windows.Forms.Button btnGetMapKml;
+ private System.Windows.Forms.LinkLabel lnkZoomToScale;
+ private System.Windows.Forms.NumericUpDown numZoomToScale;
+ private System.Windows.Forms.Label label5;
+ private System.Windows.Forms.GroupBox groupBox1;
+ private System.Windows.Forms.TextBox txtCoordinateSystem;
+ private System.Windows.Forms.Label label6;
+ private System.Windows.Forms.TextBox txtMaxY;
+ private System.Windows.Forms.Label label4;
+ private System.Windows.Forms.TextBox txtMaxX;
+ private System.Windows.Forms.Label label3;
+ private System.Windows.Forms.TextBox txtMinY;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.TextBox txtMinX;
+ private System.Windows.Forms.Label label1;
Added: trunk/Tools/Maestro/Maestro.Editors/Preview/MapPreviewViewContent.cs
--- trunk/Tools/Maestro/Maestro.Editors/Preview/MapPreviewViewContent.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Preview/MapPreviewViewContent.cs 2017-01-20 11:15:58 UTC (rev 9119)
@@ -0,0 +1,115 @@
+#region Disclaimer / License
+// Copyright (C) 2017, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion Disclaimer / License
+using Maestro.Shared.UI;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Mapping;
+using System;
+using System.ComponentModel;
+using System.Globalization;
+using System.Linq;
+using System.Windows.Forms;
+ public partial class MapPreviewViewContent : ViewContentBase
+ private readonly RuntimeMap _map;
+ private readonly IUrlLauncherService _launcher;
+ private readonly IServerConnection _conn;
+ private readonly string _resourceId;
+ public MapPreviewViewContent(RuntimeMap map, IUrlLauncherService urlLauncher, string resourceId)
+ InitializeComponent();
+ _map = map;
+ _resourceId = resourceId;
+ txtCoordinateSystem.Text = map.CoordinateSystem;
+ numZoomToScale.Minimum = 1;
+ numZoomToScale.Maximum = Int32.MaxValue;
+ _launcher = urlLauncher;
+ _conn = map.CurrentConnection;
+ btnGetMapKml.Enabled = (_conn.ProviderName.ToUpper() == "MAESTRO.HTTP"); //NOXLATE
+ protected override void OnLoad(EventArgs e)
+ base.OnLoad(e);
+ if (!string.IsNullOrEmpty(_resourceId))
+ this.Title = $"{Strings.ResourcePreviewTitle} - {_resourceId}"; //NOXLATE
+ this.Description = _resourceId;
+ if (_map.Layers.Count == 1) //Single-layer preview
+ var maxScale = _map.Layers.Max(x => x.ScaleRanges.Max(y => y.MaxScale));
+ var initScale = Math.Floor(maxScale - 0.5);
+ var env = _map.MapExtent;
+ double mcsW = env.MaxX - env.MinX;
+ double mcsH = env.MaxY - env.MinY;
+ var bboxScale = Maestro.MapViewer.MapViewer.CalculateScale(_map, mcsW, mcsH, mapViewer.Width, mapViewer.Height);
+ double desiredScale = Math.Min(initScale, bboxScale);
+ mapViewer.LoadMap(_map, desiredScale);
+ else
+ mapViewer.LoadMap(_map);
+ private void mapViewer_MapScaleChanged(object sender, EventArgs e)
+ numZoomToScale.Value = Convert.ToDecimal(mapViewer.GetMap().ViewScale);
+ private void lnkZoomToScale_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)
+ mapViewer.ZoomToScale(Convert.ToDouble(numZoomToScale.Value));
+ private void mapViewer_PropertyChanged(object sender, PropertyChangedEventArgs e)
+ if (e.PropertyName == nameof(mapViewer.IsBusy))
+ grpOtherTools.Enabled = !mapViewer.IsBusy;
+ if (!mapViewer.IsBusy)
+ double minx, miny, maxx, maxy;
+ mapViewer.GetViewExtent(out minx, out miny, out maxx, out maxy);
+ txtMinX.Text = minx.ToString(CultureInfo.InvariantCulture);
+ txtMinY.Text = miny.ToString(CultureInfo.InvariantCulture);
+ txtMaxX.Text = maxx.ToString(CultureInfo.InvariantCulture);
+ txtMaxY.Text = maxy.ToString(CultureInfo.InvariantCulture);
+ private void btnGetMapKml_Click(object sender, EventArgs e)
+ var mapagent = _conn.GetCustomProperty("BaseUrl").ToString(); //NOXLATE
+ mapagent += "mapagent/mapagent.fcgi?SESSION=" + _conn.SessionID + "&VERSION=1.0.0&OPERATION=GETMAPKML&DPI=96&MAPDEFINITION=" + _map.MapDefinition + "&FORMAT=KML&CLIENTAGENT=Maestro Local Map Previewer"; //NOXLATE
+ _launcher.OpenUrl(mapagent);
+ public override ViewRegion DefaultRegion => ViewRegion.Document;
Added: trunk/Tools/Maestro/Maestro.Editors/Preview/MapPreviewViewContent.resx
--- trunk/Tools/Maestro/Maestro.Editors/Preview/MapPreviewViewContent.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Preview/MapPreviewViewContent.resx 2017-01-20 11:15:58 UTC (rev 9119)
@@ -0,0 +1,129 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <metadata name="defaultToolbar.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+ <metadata name="statusStrip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>148, 17</value>
+ </metadata>
+ <metadata name="mapStatusTracker.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>257, 17</value>
+ </metadata>
+</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs 2017-01-11 15:11:06 UTC (rev 9118)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs 2017-01-20 11:15:58 UTC (rev 9119)
@@ -1,17 +1,17 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:4.0.30319.34209
+// Runtime Version:4.0.30319.42000
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
// </auto-generated>
-namespace Maestro.Editors
+namespace Maestro.Editors {
+ using System;
/// <summary>
/// A strongly-typed resource class, for looking up localized strings, etc.
/// </summary>
@@ -2558,6 +2558,15 @@
/// <summary>
+ /// Looks up a localized string similar to Resource Preview.
+ /// </summary>
+ internal static string ResourcePreviewTitle {
+ get {
+ return ResourceManager.GetString("ResourcePreviewTitle", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Saved tile set to: {0}.
/// </summary>
internal static string SavedTileSet {
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.resx
--- trunk/Tools/Maestro/Maestro.Editors/Strings.resx 2017-01-11 15:11:06 UTC (rev 9118)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.resx 2017-01-20 11:15:58 UTC (rev 9119)
@@ -1721,4 +1721,7 @@
<data name="MgCookerIncompatibleTileSet" xml:space="preserve">
<value>MgCooker only works with Tile Sets using the 'Default' tile provider</value>
</data>
+ <data name="ResourcePreviewTitle" xml:space="preserve">
+ <value>Resource Preview</value>
+ </data>
</root>
Modified: trunk/Tools/Maestro/Maestro.LiveMapEditor/Program.cs
--- trunk/Tools/Maestro/Maestro.LiveMapEditor/Program.cs 2017-01-11 15:11:06 UTC (rev 9118)
+++ trunk/Tools/Maestro/Maestro.LiveMapEditor/Program.cs 2017-01-20 11:15:58 UTC (rev 9119)
@@ -50,10 +50,10 @@
//Register previewers
var urlLauncher = new OurUrlLauncher();
+ ResourcePreviewerFactory.RegisterPreviewer("Maestro.Http", new LocalMapPreviewer(new DefaultResourcePreviewer(urlLauncher), urlLauncher, null)); //NOXLATE
//property is set
+ ResourcePreviewerFactory.RegisterPreviewer("Maestro.LocalNative", new LocalMapPreviewer(new StubPreviewer(), urlLauncher, null)); //NOXLATE
//Can't use this code, it requires a call to MgdPlatform.Initialize which we can't call indirectly :(
More information about the mapguide-commits
