[mapguide-commits] r9125 - in trunk/Tools/Maestro: OSGeo.MapGuide.MaestroAPI/Tile OSGeo.MapGuide.MaestroAPI.Tests
svn_mapguide at osgeo.org
Wed Jan 25 06:41:18 PST 2017
Author: jng
Date: 2017-01-25 06:41:18 -0800 (Wed, 25 Jan 2017)
New Revision: 9125
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Tests/TileTests.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Tile/BatchSettings.cs
Fix the row/col offset calculations when override extents are involved
Fixes #2745
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Tile/BatchSettings.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Tile/BatchSettings.cs 2017-01-25 14:01:47 UTC (rev 9124)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Tile/BatchSettings.cs 2017-01-25 14:41:18 UTC (rev 9125)
@@ -687,28 +687,28 @@
// Also have in mind that you can also request tiles beyond the map extent (for example tile (-1, -1), however, there is probably no point to cache them unless you have valid data outside your initial map extents.
//The tile extent in meters
- double tileWidth = ((INCH_TO_METER / m_parent.Config.DPI * m_parent.Config.TileWidth) * (scale));
- double tileHeight = ((INCH_TO_METER / m_parent.Config.DPI * m_parent.Config.TileHeight) * (scale));
+ double tileMapWidth = ((INCH_TO_METER / m_parent.Config.DPI * m_parent.Config.TileWidth) * (scale));
+ double tileMapHeight = ((INCH_TO_METER / m_parent.Config.DPI * m_parent.Config.TileHeight) * (scale));
//Using this algorithm, yields a negative number of columns/rows, if the max scale is larger than the max extent of the map.
- rows = Math.Max(1, (int)Math.Ceiling((height_in_meters / tileHeight)));
- cols = Math.Max(1, (int)Math.Ceiling((width_in_meters / tileWidth)));
+ rows = Math.Max(1, (int)Math.Ceiling((height_in_meters / tileMapHeight)));
+ cols = Math.Max(1, (int)Math.Ceiling((width_in_meters / tileMapWidth)));
if (m_maxExtent != null)
//The extent is overridden, so we need to adjust the start offsets
//and re-compute row/col span against the overridden extents
- double offsetX = m_maxExtent.MinX - m_tileSetExtents.MinX;
- double offsetY = m_tileSetExtents.MaxY - m_maxExtent.MaxY;
- rowTileOffset = (int)Math.Floor(offsetY / tileHeight);
- colTileOffset = (int)Math.Floor(offsetX / tileWidth);
+ double offsetMapX = Math.Abs(m_parent.Config.MetersPerUnit * (m_maxExtent.MinX - m_tileSetExtents.MinX));
+ double offsetMapY = Math.Abs(m_parent.Config.MetersPerUnit * (m_tileSetExtents.MaxY - m_maxExtent.MaxY));
+ rowTileOffset = (int)Math.Floor(offsetMapY / tileMapHeight);
+ colTileOffset = (int)Math.Floor(offsetMapX / tileMapWidth);
//Re-compute rows/cols against override extent
width_in_meters = Math.Abs(m_parent.Config.MetersPerUnit * (m_maxExtent.MaxX - m_maxExtent.MinX));
height_in_meters = Math.Abs(m_parent.Config.MetersPerUnit * (m_maxExtent.MaxY - m_maxExtent.MinY));
m_dimensions[i] = new long[] { rows, cols, rowTileOffset, colTileOffset };
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Tests/TileTests.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Tests/TileTests.cs 2017-01-25 14:01:47 UTC (rev 9124)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Tests/TileTests.cs 2017-01-25 14:41:18 UTC (rev 9125)
@@ -98,7 +98,7 @@
Assert.AreEqual(127472, tileConf.TotalTiles);
- customExtents = ObjectFactory.CreateEnvelope(-87.73, 43.71, -87.71, 43.75);
+ customExtents = ObjectFactory.CreateEnvelope(-87.7278601614039, 43.7443959276596, -87.7135994943579, 43.7592852552018);
tileConf.SetScalesAndExtend(Enumerable.Range(0, 10).ToArray(), customExtents);
//I don't know the exact number here, but it should be less than the original and
More information about the mapguide-commits
