[mapguide-commits] r9126 - in trunk/Tools/Maestro: . Maestro
svn_mapguide at osgeo.org
Wed Jan 25 06:44:23 PST 2017
Author: jng
Date: 2017-01-25 06:44:23 -0800 (Wed, 25 Jan 2017)
New Revision: 9126
trunk/Tools/Maestro/Maestro/changelog.txt
trunk/Tools/Maestro/build.bat
Prep for m6 release
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2017-01-25 14:41:18 UTC (rev 9125)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2017-01-25 14:44:23 UTC (rev 9126)
@@ -1,5 +1,5 @@
-Next
+6.0m6
- Fix: MgCooker - InvalidCastException when editing override coordinates for a selected TileSetDefinition
- Fix: API - Infinite recursive call in CreateMapLayer
@@ -10,6 +10,8 @@
- Fix: Dirty state not triggered when editing most properties in a Symbol Definition
- Fix: Editing Fusion widget XML does not trigger dirty state
- Fix: Incorrect total tile counts for tiling runs with custom extents
+ - Fix: mapguide-rest addin generates incorrect representations node in configuration editor
+ - Added validation rules for ODBC configuration documents
- MgCooker now supports a map-viewer-based extent selection mode
- Local Map Previews are now non-modal
- Added DockPanel themes
Modified: trunk/Tools/Maestro/build.bat
--- trunk/Tools/Maestro/build.bat 2017-01-25 14:41:18 UTC (rev 9125)
+++ trunk/Tools/Maestro/build.bat 2017-01-25 14:44:23 UTC (rev 9126)
@@ -2,7 +2,7 @@
SET TYPEACTION=build
SET TYPEBUILD=Release
SET PLATFORM=Any CPU
-SET RELEASE_VERSION=6.0m5
+SET RELEASE_VERSION=6.0m6
SET OLDPATH=%PATH%
SET PATH=%PATH%;%CD%\Thirdparty\NSIS;C:\Windows\Microsoft.NET\Framework\v4.0.30319
SET SLNDIR=%CD%
More information about the mapguide-commits
