[mapguide-commits] r9214 - trunk/MgDev/UnitTest/TestData/Samples/Sheboygan
svn_mapguide at osgeo.org
Thu Jun 15 08:43:43 PDT 2017
Author: jng
Date: 2017-06-15 08:43:43 -0700 (Thu, 15 Jun 2017)
New Revision: 9214
trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml
Format this package manifest so we can easily diff against the subsequent change to it
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml 2017-06-15 15:31:16 UTC (rev 9213)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml 2017-06-15 15:43:43 UTC (rev 9214)
@@ -1 +1,2379 @@
-<?xml version="1.0" encoding="UTF-8" standalone="no" ?><ResourcePackageManifest xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourcePackageManifest-1.0.0.xsd"><Operations><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/S
heboygan/Layers/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/MapsTiled/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/MapsTiled/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/La
youts/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/_HEA
DER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples
/Sheboygan/Layers/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Bu
ildings.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</Con
tentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><
Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name>
<Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_HEADER.x
ml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>D
ELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESO
URCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value
>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout</Value></Parameter></
Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></O
peration><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_DATA_symbols.dwf</Value><ContentType>model/vnd.dwf</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>5594</Value></Parameter><Parameter><Name>DATANAME</Name><Value>symbols.dwf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parame
ter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><
Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_DATA_symbols.dwf</Value><ContentType>model/vnd.dwf</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>22760</Value></Parameter><Parameter><Name>DATANAME</Name><Value>symbols.dwf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboyga
n/Data/BuildingOutlines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_DATA_BuildingOutlines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>8038400</Value></Parameter><Parameter><Name>DATANAME</Name><Value>BuildingOutlines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Lib
rary://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_DATA_CityLimits.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>City
Limits.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Paramet
ers></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_DATA_HydrographicLines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>768000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>HydrographicLines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples
/Sheboygan/Data/HydrographicPolygons.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_DATA_HydrographicPolygons.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>512000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>HydrographicPolygons.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/D
ata/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_DATA_Islands.s
df</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Islands.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType
></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_DATA_LandUse.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>1996800</Value></Parameter><Parameter><Name>DATANAME</Name><Value>LandUse.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Ver
sion>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_DATA_Parcels.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>11929600</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Parcels.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sh
eboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_DATA_Rail.sdf</Value><ContentType
>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>870400</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Rail.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></P
arameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_DATA_RoadCenterLines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>665600</Value></Parameter><Parameter><Name>DATANAME</Name><Value>RoadCenterLines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Opera
tion><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_DATA_Soils.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>4556800</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Soils.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>
Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_DATA_Trees
.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>6656000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Trees.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_HEADER.xml</Value><ContentTyp
e>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_DATA_VotingDistricts.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>VotingDistricts.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</Value></Parame
ter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</Conte
ntType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Libra
ry://Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Par
ameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganV26.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Vers
ion>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganV26.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Param
eter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Param
eter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition</Value></Parameter></Parameters></Operation><
Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition</Value>
</Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLa
youts/Maroon.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_HEADER.xml</Value><ContentT
ype>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameter
s><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</N
ame><Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan
/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced
/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sh
eboygan/Layers_Advanced/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/S
heboygan/Layers_Advanced/Soils.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition
_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Rail.SymbolDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Rail.SymbolDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURC
E</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Trees.SymbolDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Trees.SymbolDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0
</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Paramet
er><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name>
<Value>Library://Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOUR
CEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Paramete
rs><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Va
lue>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/Sheboyga
n.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/M
apsTiled/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation></Operations></ResourcePackageManifest>
\ No newline at end of file
+<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
+<ResourcePackageManifest
+ xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourcePackageManifest-1.0.0.xsd">
+ <Operations>
+ <Operation>
+ <Name>SETRESOURCE</Name>
+ <Version>1.0.0</Version>
+ <Parameters>
+ <Parameter>
+ <Name>HEADER</Name>
+ <Value>Library/Samples/Sheboygan/_HEADER.xml</Value>
+ <ContentType>text/xml</ContentType>
+ </Parameter>
+ <Parameter>
+ <Name>RESOURCEID</Name>
+ <Value>Library://Samples/Sheboygan/</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/FlexibleLayouts/_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/FlexibleLayouts/</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers/</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Maps/_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Maps/</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/MapsTiled/_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/MapsTiled/</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layouts/</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Symbols/_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Symbols/</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Data/</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Watermarks/_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Watermarks/</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers_Advanced/</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/TileSets/_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/TileSets/</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Name>DELETERESOURCE</Name>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Name>CONTENT</Name>
+ <Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Name>SETRESOURCEDATA</Name>
+ <Parameters>
+ <Parameter>
+ <Name>DATA</Name>
+ <Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_DATA_symbols.dwf</Value>
+ <ContentType>model/vnd.dwf</ContentType>
+ </Parameter>
+ <Parameter>
+ <Name>DATALENGTH</Name>
+ <Value>5594</Value>
+ </Parameter>
+ <Parameter>
+ <Name>DATANAME</Name>
+ <Value>symbols.dwf</Value>
+ </Parameter>
+ <Parameter>
+ <Name>DATATYPE</Name>
+ <Value>File</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Name>DATA</Name>
+ <Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_DATA_symbols.dwf</Value>
+ </Parameter>
+ <Parameter>
+ <Value>22760</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Name>DATA</Name>
+ <Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_DATA_BuildingOutlines.sdf</Value>
+ <ContentType>application/octet-stream</ContentType>
+ </Parameter>
+ <Parameter>
+ <Value>8038400</Value>
+ </Parameter>
+ <Parameter>
+ <Value>BuildingOutlines.sdf</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Name>DATA</Name>
+ <Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_DATA_CityLimits.sdf</Value>
+ </Parameter>
+ <Parameter>
+ <Value>307200</Value>
+ </Parameter>
+ <Parameter>
+ <Value>CityLimits.sdf</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Name>DATA</Name>
+ <Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_DATA_HydrographicLines.sdf</Value>
+ </Parameter>
+ <Parameter>
+ <Value>768000</Value>
+ </Parameter>
+ <Parameter>
+ <Value>HydrographicLines.sdf</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Name>DATA</Name>
+ <Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_DATA_HydrographicPolygons.sdf</Value>
+ </Parameter>
+ <Parameter>
+ <Value>512000</Value>
+ </Parameter>
+ <Parameter>
+ <Value>HydrographicPolygons.sdf</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Name>DATA</Name>
+ <Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_DATA_Islands.sdf</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ <Value>Islands.sdf</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Name>DATA</Name>
+ <Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_DATA_LandUse.sdf</Value>
+ </Parameter>
+ <Parameter>
+ <Value>1996800</Value>
+ </Parameter>
+ <Parameter>
+ <Value>LandUse.sdf</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Name>DATA</Name>
+ <Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_DATA_Parcels.sdf</Value>
+ </Parameter>
+ <Parameter>
+ <Value>11929600</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Parcels.sdf</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Name>DATA</Name>
+ <Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_DATA_Rail.sdf</Value>
+ </Parameter>
+ <Parameter>
+ <Value>870400</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Rail.sdf</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Name>DATA</Name>
+ <Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_DATA_RoadCenterLines.sdf</Value>
+ </Parameter>
+ <Parameter>
+ <Value>665600</Value>
+ </Parameter>
+ <Parameter>
+ <Value>RoadCenterLines.sdf</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Name>DATA</Name>
+ <Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_DATA_Soils.sdf</Value>
+ </Parameter>
+ <Parameter>
+ <Value>4556800</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Soils.sdf</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Name>DATA</Name>
+ <Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_DATA_Trees.sdf</Value>
+ </Parameter>
+ <Parameter>
+ <Value>6656000</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Trees.sdf</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Name>DATA</Name>
+ <Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_DATA_VotingDistricts.sdf</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ <Value>VotingDistricts.sdf</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layouts/SheboyganV26.WebLayout</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers/Trees.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers/Soils.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Symbols/Rail.SymbolDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Symbols/Trees.SymbolDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Parameters>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_CONTENT.xml</Value>
+ </Parameter>
+ <Parameter>
+ <Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ </Operations>
+</ResourcePackageManifest>
More information about the mapguide-commits
