[mapguide-commits] r9215 - in trunk/MgDev/UnitTest/TestData/Samples/Sheboygan: . Library/Samples/Sheboygan/TileSets
svn_mapguide at osgeo.org
Thu Jun 15 08:48:18 PDT 2017
Author: jng
Date: 2017-06-15 08:48:18 -0700 (Thu, 15 Jun 2017)
New Revision: 9215
Added:
trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_CONTENT.xml
trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_HEADER.xml
trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml
Add example UTFGrid tile set definition
Added: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_CONTENT.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_CONTENT.xml (rev 0)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_CONTENT.xml 2017-06-15 15:48:18 UTC (rev 9215)
@@ -0,0 +1,95 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<TileSetDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="TileSetDefinition-3.0.0.xsd">
+ <TileStoreParameters>
+ <TileProvider>XYZ</TileProvider>
+ <Parameter>
+ <Name>TilePath</Name>
+ <Value>%MG_TILE_CACHE_PATH%</Value>
+ </Parameter>
+ <Parameter>
+ <Name>TileFormat</Name>
+ <Value>UTFGRID</Value>
+ </Parameter>
+ <Parameter>
+ <Name>RenderOnly</Name>
+ <Value>true</Value>
+ </Parameter>
+ </TileStoreParameters>
+ <Extents>
+ <MinX>-87.797866013831964</MinX>
+ <MaxX>-87.664527771869246</MaxX>
+ <MinY>43.6868578621819</MinY>
+ <MaxY>43.8037962206133</MaxY>
+ </Extents>
+ <BaseMapLayerGroup>
+ <Name>Base Layer Group</Name>
+ <Visible>true</Visible>
+ <ShowInLegend>true</ShowInLegend>
+ <ExpandInLegend>true</ExpandInLegend>
+ <LegendLabel>Tiled Layers</LegendLabel>
+ <BaseMapLayer>
+ <Name>Trees</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Trees.LayerDefinition</ResourceId>
+ <Selectable>true</Selectable>
+ <LegendLabel>Trees</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>Roads</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</ResourceId>
+ <Selectable>false</Selectable>
+ <LegendLabel>Roads</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>Districts</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</ResourceId>
+ <LegendLabel>Districts</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>Buildings</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</ResourceId>
+ <LegendLabel>Buildings</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>Parcels</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</ResourceId>
+ <LegendLabel>Parcels</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>Islands</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</ResourceId>
+ <LegendLabel>Islands</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>Hydrography</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</ResourceId>
+ <LegendLabel>Hydrography</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>CityLimits</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</ResourceId>
+ <LegendLabel>CityLimits</LegendLabel>
+ </BaseMapLayer>
+ </BaseMapLayerGroup>
+</TileSetDefinition>
\ No newline at end of file
Added: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_HEADER.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_HEADER.xml (rev 0)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_HEADER.xml 2017-06-15 15:48:18 UTC (rev 9215)
@@ -0,0 +1,6 @@
+<ResourceDocumentHeader xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
+ <Security>
+ <Inherited>true</Inherited>
+ </Security>
+</ResourceDocumentHeader>
Modified: trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml
--- trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml 2017-06-15 15:43:43 UTC (rev 9214)
+++ trunk/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml 2017-06-15 15:48:18 UTC (rev 9215)
@@ -2375,5 +2375,35 @@
</Parameter>
</Parameters>
</Operation>
+ <Operation>
+ <Name>DELETERESOURCE</Name>
+ <Version>1.0.0</Version>
+ <Parameters>
+ <Parameter>
+ <Name>RESOURCEID</Name>
+ <Value>Library://Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition</Value>
+ </Parameter>
+ </Parameters>
+ </Operation>
+ <Operation>
+ <Name>SETRESOURCE</Name>
+ <Parameters>
+ <Parameter>
+ <Name>CONTENT</Name>
+ <Value>Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_CONTENT.xml</Value>
+ <ContentType>text/xml</ContentType>
+ </Parameter>
+ <Parameter>
+ <Name>HEADER</Name>
+ <Value>Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_HEADER.xml</Value>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ </Parameters>
+ </Operation>
</Operations>
</ResourcePackageManifest>
More information about the mapguide-commits
