[mapguide-commits] r9216 - in trunk/MgDev/Common: Geometry MapGuideCommon/MapLayer
svn_mapguide at osgeo.org
Thu Jun 15 09:02:13 PDT 2017
Author: jng
Date: 2017-06-15 09:02:13 -0700 (Thu, 15 Jun 2017)
New Revision: 9216
trunk/MgDev/Common/Geometry/GeometrySimplificationAlgorithmType.h
trunk/MgDev/Common/Geometry/GeometrySimplifier.h
trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h
Tidy up doxygen docs for newly introduced APIs
Modified: trunk/MgDev/Common/Geometry/GeometrySimplificationAlgorithmType.h
--- trunk/MgDev/Common/Geometry/GeometrySimplificationAlgorithmType.h 2017-06-15 15:48:18 UTC (rev 9215)
+++ trunk/MgDev/Common/Geometry/GeometrySimplificationAlgorithmType.h 2017-06-15 16:02:13 UTC (rev 9216)
@@ -1,5 +1,5 @@
-// Copyright (C) 2004-2011 by Autodesk, Inc.
+// Copyright (C) 2004-2015 by Autodesk, Inc.
// This library is free software; you can redistribute it and/or
// modify it under the terms of version 2.1 of the GNU Lesser
@@ -18,7 +18,10 @@
#ifndef _MGGEOMETRYSIMPLIFICATIONALGORITHMTYPE_H_
#define _MGGEOMETRYSIMPLIFICATIONALGORITHMTYPE_H_
-/// \cond INTERNAL
+/// \defgroup MgGeometrySimplificationAlgorithmType MgGeometrySimplificationAlgorithmType
+/// \ingroup Geometry_Module_classes
/// \brief
/// MgGeometrySimplificationAlgorithmType defines constants indicating
@@ -40,6 +43,6 @@
static const INT32 TopologyPreserving = 1;
-/// \endcond
#endif //_MGGEOMETRYSIMPLIFICATIONALGORITHMTYPE_H_
\ No newline at end of file
Modified: trunk/MgDev/Common/Geometry/GeometrySimplifier.h
--- trunk/MgDev/Common/Geometry/GeometrySimplifier.h 2017-06-15 15:48:18 UTC (rev 9215)
+++ trunk/MgDev/Common/Geometry/GeometrySimplifier.h 2017-06-15 16:02:13 UTC (rev 9216)
@@ -18,7 +18,7 @@
#ifndef _MGGEOMETRYSIMPLIFIER_H_
#define _MGGEOMETRYSIMPLIFIER_H_
-/// \defgroup MgAgfReaderWriter MgAgfReaderWriter
+/// \defgroup MgGeometrySimplifier MgGeometrySimplifier
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2017-06-15 15:48:18 UTC (rev 9215)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2017-06-15 16:02:13 UTC (rev 9216)
@@ -1,5 +1,5 @@
+// Copyright (C) 2004-2017 by Autodesk, Inc.
@@ -354,7 +354,7 @@
/// \brief
/// Initializes a new MgMap object given a map definition or tile set
- /// definition and a name for the map with initial display parameters set.
+ /// definition and a name for the map with initial display parameters set.
/// This method is used for MapGuide Viewers or for offline map production.
/// \remarks
@@ -392,6 +392,8 @@
/// \param dpi
/// The display DPI to initially set for the map
+ /// \since 3.3
/// \return
/// Returns nothing.
@@ -481,9 +483,9 @@
/// \brief
- /// Returns the resource id of the Tile Set Definition that created
- /// this map, or the Tile Set Definition linked from the Map Definition
- /// used to created this map. If it was created from a Map Definition and
+ /// Returns the resource id of the Tile Set Definition that created
+ /// this map, or the Tile Set Definition linked from the Map Definition
+ /// used to created this map. If it was created from a Map Definition and
/// that does not link to a Tile Set Definition, then NULL is returned.
/// <!-- Syntax in .Net, Java, and PHP -->
More information about the mapguide-commits
