[mapguide-commits] r9221 - in sandbox/jng/geoprocessing: Common/Schema UnitTest/WebTier/MapAgent/MapAgentForms Web/src/HttpHandler
svn_mapguide at osgeo.org
Sun Jun 25 02:58:13 PDT 2017
Author: jng
Date: 2017-06-25 02:58:13 -0700 (Sun, 25 Jun 2017)
New Revision: 9221
Added:
sandbox/jng/geoprocessing/Common/Schema/GeometryInfo-3.3.0.xsd
sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geometryinfoform.html
sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/tessellateform.html
sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj.filters
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandlerBuild.cpp
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpRequest.cpp
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.cpp
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.h
sandbox/jng/geoprocessing/Web/src/HttpHandler/XmlJsonConvert.cpp
Add the following operations to the mapagent:
- GEO.TESSELLATE
- Returns a tessellated version of the given input geometry (in WKT). This operation is mainly for approximating curve-based geometries and has no effect on non-curve based geometries (it will return the original WKT in such cases). Output can be WKT or GeoJSON with optional transformation.
- GEO.GEOMETRYINFO
- Given an input geometry (in WKT), this operation returns an assortment of information about this geometry, all of which is returned in a response modeled on a new GeometryInfo-3.3.0.xsd schema
Added: sandbox/jng/geoprocessing/Common/Schema/GeometryInfo-3.3.0.xsd
--- sandbox/jng/geoprocessing/Common/Schema/GeometryInfo-3.3.0.xsd (rev 0)
+++ sandbox/jng/geoprocessing/Common/Schema/GeometryInfo-3.3.0.xsd 2017-06-25 09:58:13 UTC (rev 9221)
@@ -0,0 +1,55 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified">
+ <xs:element name="GeometryInfo">
+ <xs:annotation>
+ <xs:documentation>Geometry Information</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:sequence>
+ <xs:element name="Area" type="xs:double" />
+ <xs:element name="Dimension" type="xs:int" />
+ <xs:element name="Length" type="xs:double" />
+ <xs:element name="IsClosed" type="xs:boolean" />
+ <xs:element name="IsEmpty" type="xs:boolean" />
+ <xs:element name="IsSimple" type="xs:boolean" />
+ <xs:element name="IsValid" type="xs:boolean" />
+ <xs:element name="Envelope" type="Envelope" />
+ <xs:element name="Centroid" type="Coordinate" />
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+ <xs:complexType name="Coordinate">
+ <xs:annotation>
+ <xs:documentation>Represents a bounding box</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="X" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>x-coordinate</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Y" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>y-coordinate</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="Envelope">
+ <xs:annotation>
+ <xs:documentation>Represents a bounding box defined in terms of a lower left coordinate and an upper right coordinate</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="LowerLeft" type="Coordinate">
+ <xs:annotation>
+ <xs:documentation>Lower-left coordinate</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="UpperRight" type="Coordinate">
+ <xs:annotation>
+ <xs:documentation>Upper-right coordinate</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+</xs:schema>
Added: sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geometryinfoform.html
--- sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geometryinfoform.html (rev 0)
+++ sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geometryinfoform.html 2017-06-25 09:58:13 UTC (rev 9221)
@@ -0,0 +1,31 @@
+<html>
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+<script type="text/javascript" src="setactiontarget.js" >
+</script>
+</head>
+<body>
+<form name="input" action="" method="get">
+<b>Operation:</b>
+<input type="text" name="OPERATION" value="GEO.GEOMETRYINFO" size="50">
+<p> Version:
+<input type="text" name="VERSION" value="3.3.0" size="10">
+<p> Locale:
+<input type="text" name="LOCALE" value="en" size="10">
+<p> Client Agent:
+<input type="text" name="CLIENTAGENT" value="MapGuide Developer" size="100">
+<p> Geometry (WKT):
+<input type="text" name="GEOMETRY" value="" size="100">
+<p> Output Format:
+<select name="FORMAT">
+ <option value="text/xml">text/xml</option>
+ <option value="application/json">application/json</option>
+</select>
+<p>
+ Clean JSON: <input type="text" name="CLEAN" value="1" ID="TextClean">
+<p>
+<input type="submit" value="Submit" onclick="SetActionTarget()"> <input type="reset">
+</form>
+</body>
+</html>
+<html>
Modified: sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html
--- sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html 2017-06-25 09:21:35 UTC (rev 9220)
+++ sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html 2017-06-25 09:58:13 UTC (rev 9221)
@@ -15,8 +15,12 @@
<LI>
<A href="distanceform.html" target="showform">Distance</A>
<LI>
+ <A href="geometryinfoform.html" target="showform">GeometryInfo</A>
+ <LI>
<A href="simplifyform.html" target="showform">Simplify</A>
<LI>
+ <A href="tessellateform.html" target="showform">Tessellate</A>
+ <LI>
<A href="binaryoperationform.html" target="showform">BinaryOperation</A>
<LI>
<A href="spatialpredicateform.html" target="showform">SpatialPredicate</A>
Added: sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/tessellateform.html
--- sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/tessellateform.html (rev 0)
+++ sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/tessellateform.html 2017-06-25 09:58:13 UTC (rev 9221)
@@ -0,0 +1,33 @@
+<html>
+<head>
+</script>
+</head>
+<body>
+<b>Operation:</b>
+<input type="text" name="OPERATION" value="GEO.TESSELLATE" size="50">
+<p> Version:
+<p> Locale:
+<p> Client Agent:
+<p> Output Format:
+ <option value="WKT">Geometry Well-Known Text</option>
+ <option value="GEOJSON">GeoJSON</option>
+</select>
+<p> Input Coordinate System (CS-Map Code):
+<input type="text" name="COORDINATESYSTEM" value="" size="10">
+<p> Output Coordinate System (CS-Map Code):
+<input type="text" name="TRANSFORMTO" value="" size="10">
+<p>
+</form>
+</body>
+</html>
+<html>
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj 2017-06-25 09:21:35 UTC (rev 9220)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj 2017-06-25 09:58:13 UTC (rev 9221)
@@ -306,6 +306,12 @@
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</ExcludedFromBuild>
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
</ClCompile>
+ <ClCompile Include="HttpGeometryInfo.cpp">
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
+ </ClCompile>
<ClCompile Include="HttpGeoSimplify.cpp">
@@ -318,6 +324,12 @@
</ClCompile>
+ <ClCompile Include="HttpGeoTessellate.cpp">
+ </ClCompile>
<ClCompile Include="HttpGetRepositoryContent.cpp">
@@ -997,8 +1009,10 @@
<ClInclude Include="HttpGeoBuffer.h" />
<ClInclude Include="HttpGeoBinaryOperation.h" />
<ClInclude Include="HttpGeoDistance.h" />
+ <ClInclude Include="HttpGeometryInfo.h" />
<ClInclude Include="HttpGeoSimplify.h" />
<ClInclude Include="HttpGeoSpatialPredicate.h" />
+ <ClInclude Include="HttpGeoTessellate.h" />
<ClInclude Include="HttpGetRepositoryContent.h" />
<ClInclude Include="HttpGetRepositoryHeader.h" />
<ClInclude Include="HttpGetResourceContent.h" />
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj.filters
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj.filters 2017-06-25 09:21:35 UTC (rev 9220)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj.filters 2017-06-25 09:58:13 UTC (rev 9221)
@@ -407,6 +407,12 @@
<ClCompile Include="HttpGeoConvexHull.cpp">
<Filter>GeoProcessing</Filter>
</ClCompile>
+ <Filter>GeoProcessing</Filter>
+ </ClCompile>
+ </ClCompile>
</ItemGroup>
<ItemGroup>
<ClInclude Include="HttpApplyResourcePackage.h">
@@ -796,6 +802,12 @@
<ClInclude Include="HttpGeoConvexHull.h">
</ClInclude>
+ <ClInclude Include="HttpGeometryInfo.h">
+ </ClInclude>
+ <ClInclude Include="HttpGeoTessellate.h">
+ </ClInclude>
</ItemGroup>
<ItemGroup>
<ResourceCompile Include="HttpHandler.rc" />
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandlerBuild.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandlerBuild.cpp 2017-06-25 09:21:35 UTC (rev 9220)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandlerBuild.cpp 2017-06-25 09:58:13 UTC (rev 9221)
@@ -59,8 +59,10 @@
#include "HttpGeoBinaryOperation.cpp"
#include "HttpGeoConvexHull.cpp"
#include "HttpGeoDistance.cpp"
+#include "HttpGeometryInfo.cpp"
#include "HttpGeoSimplify.cpp"
#include "HttpGeoSpatialPredicate.cpp"
+#include "HttpGeoTessellate.cpp"
#include "HttpGetCapabilities.cpp"
#include "HttpGetConnectionPropertyValues.cpp"
#include "HttpGetDefaultTileSizeX.cpp"
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpRequest.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpRequest.cpp 2017-06-25 09:21:35 UTC (rev 9220)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpRequest.cpp 2017-06-25 09:58:13 UTC (rev 9221)
@@ -129,8 +129,10 @@
#include "HttpGeoBinaryOperation.h"
#include "HttpGeoConvexHull.h"
#include "HttpGeoDistance.h"
+#include "HttpGeometryInfo.h"
#include "HttpGeoSimplify.h"
#include "HttpGeoSpatialPredicate.h"
+#include "HttpGeoTessellate.h"
#include <algorithm>
using namespace std;
@@ -443,8 +445,10 @@
httpClassCreators[MgHttpResourceStrings::opGeoBinaryOperation] = MgHttpGeoBinaryOperation::CreateObject;
httpClassCreators[MgHttpResourceStrings::opGeoConvexHull] = MgHttpGeoConvexHull::CreateObject;
httpClassCreators[MgHttpResourceStrings::opGeoDistance] = MgHttpGeoDistance::CreateObject;
+ httpClassCreators[MgHttpResourceStrings::opGeometryInfo] = MgHttpGeometryInfo::CreateObject;
httpClassCreators[MgHttpResourceStrings::opGeoSimplify] = MgHttpGeoSimplify::CreateObject;
httpClassCreators[MgHttpResourceStrings::opGeoSpatialPredicate] = MgHttpGeoSpatialPredicate::CreateObject;
+ httpClassCreators[MgHttpResourceStrings::opGeoTessellate] = MgHttpGeoTessellate::CreateObject;
httpPostHandlerCreators.push_back(MgHttpWfsGetCapabilities::ProcessPostRequest);
httpPostHandlerCreators.push_back(MgHttpWfsDescribeFeatureType::ProcessPostRequest);
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.cpp 2017-06-25 09:21:35 UTC (rev 9220)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.cpp 2017-06-25 09:58:13 UTC (rev 9221)
@@ -368,8 +368,10 @@
const STRING MgHttpResourceStrings::opGeoBuffer = L"GEO.BUFFER";
const STRING MgHttpResourceStrings::opGeoConvexHull = L"GEO.CONVEXHULL";
const STRING MgHttpResourceStrings::opGeoDistance = L"GEO.DISTANCE";
+const STRING MgHttpResourceStrings::opGeometryInfo = L"GEO.GEOMETRYINFO";
const STRING MgHttpResourceStrings::opGeoSimplify = L"GEO.SIMPLIFY";
const STRING MgHttpResourceStrings::opGeoSpatialPredicate = L"GEO.SPATIALPREDICATE";
+const STRING MgHttpResourceStrings::opGeoTessellate = L"GEO.TESSELLATE";
const STRING MgHttpResourceStrings::opGeoBinaryOperation = L"GEO.BINARYOPERATION";
const STRING MgHttpResourceStrings::reqGeoA = L"GEOMETRYA";
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.h
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.h 2017-06-25 09:21:35 UTC (rev 9220)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.h 2017-06-25 09:58:13 UTC (rev 9221)
@@ -372,8 +372,10 @@
static const STRING opGeoBuffer;
static const STRING opGeoConvexHull;
static const STRING opGeoDistance;
+ static const STRING opGeometryInfo;
static const STRING opGeoSimplify;
static const STRING opGeoSpatialPredicate;
+ static const STRING opGeoTessellate;
static const STRING opGeoBinaryOperation;
static const STRING reqGeoA;
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/XmlJsonConvert.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/XmlJsonConvert.cpp 2017-06-25 09:21:35 UTC (rev 9220)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/XmlJsonConvert.cpp 2017-06-25 09:58:13 UTC (rev 9221)
@@ -946,6 +946,20 @@
s_elementPathTypeMap["/ClassDefinition/Properties/Property/DefaultImageYSize"] = XML_DATA_TYPE_NUM_INT;
//UnitOfMeasure-3.3.0.xsd
s_elementPathTypeMap["/UnitOfMeasure/Value"] = XML_DATA_TYPE_NUM_DOUBLE;
+ //GeometryInfo-3.3.0.xsd
+ s_elementPathTypeMap["/GeometryInfo/Area"] = XML_DATA_TYPE_NUM_DOUBLE;
+ s_elementPathTypeMap["/GeometryInfo/Dimension"] = XML_DATA_TYPE_NUM_INT;
+ s_elementPathTypeMap["/GeometryInfo/Length"] = XML_DATA_TYPE_NUM_DOUBLE;
+ s_elementPathTypeMap["/GeometryInfo/IsClosed"] = XML_DATA_TYPE_BOOLEAN;
+ s_elementPathTypeMap["/GeometryInfo/IsEmpty"] = XML_DATA_TYPE_BOOLEAN;
+ s_elementPathTypeMap["/GeometryInfo/IsSimple"] = XML_DATA_TYPE_BOOLEAN;
+ s_elementPathTypeMap["/GeometryInfo/IsValid"] = XML_DATA_TYPE_BOOLEAN;
+ s_elementPathTypeMap["/GeometryInfo/Envelope/LowerLeft/X"] = XML_DATA_TYPE_NUM_DOUBLE;
+ s_elementPathTypeMap["/GeometryInfo/Envelope/LowerLeft/Y"] = XML_DATA_TYPE_NUM_DOUBLE;
+ s_elementPathTypeMap["/GeometryInfo/Envelope/UpperRight/X"] = XML_DATA_TYPE_NUM_DOUBLE;
+ s_elementPathTypeMap["/GeometryInfo/Envelope/UpperRight/Y"] = XML_DATA_TYPE_NUM_DOUBLE;
+ s_elementPathTypeMap["/GeometryInfo/Centroid/X"] = XML_DATA_TYPE_NUM_DOUBLE;
+ s_elementPathTypeMap["/GeometryInfo/Centroid/Y"] = XML_DATA_TYPE_NUM_DOUBLE;
//Miscellaneous MapGuide response types that don't have a formal schema
s_elementPathTypeMap["/SessionTimeout/Value"] = XML_DATA_TYPE_NUM_INT;
s_elementPathTypeMap["/FeatureInformation/SelectedFeatures/SelectedLayer/LayerMetadata/Property/Type"] = XML_DATA_TYPE_NUM_INT;
More information about the mapguide-commits
