[mapguide-commits] r9222 - sandbox/jng/geoprocessing/Web/src/HttpHandler
svn_mapguide at osgeo.org
Sun Jun 25 03:36:26 PDT 2017
Author: jng
Date: 2017-06-25 03:36:25 -0700 (Sun, 25 Jun 2017)
New Revision: 9222
Added:
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoTessellate.cpp
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoTessellate.h
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeometryInfo.cpp
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeometryInfo.h
Add missing source files from previous commmit
Added: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoTessellate.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoTessellate.cpp (rev 0)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoTessellate.cpp 2017-06-25 10:36:25 UTC (rev 9222)
@@ -0,0 +1,104 @@
+// Copyright (C) 2004-2017 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "HttpHandler.h"
+#include "HttpGeoTessellate.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGeoTessellate)
+MgHttpGeoTessellate::MgHttpGeoTessellate(MgHttpRequest* hRequest)
+ InitializeCommonParameters(hRequest);
+ Ptr<MgHttpRequestParam> params = hRequest->GetRequestParam();
+ m_geomWKT = params->GetParameterValue(MgHttpResourceStrings::reqFeatGeometry);
+ m_format = params->GetParameterValue(MgHttpResourceStrings::reqGeoFormat);
+ m_coordinateSystem = params->GetParameterValue(MgHttpResourceStrings::reqGeoCoordinateSystem);
+ m_transformTo = params->GetParameterValue(MgHttpResourceStrings::reqGeoTransformTo);
+void MgHttpGeoTessellate::Execute(MgHttpResponse & hResponse)
+ Ptr<MgHttpResult> hResult = hResponse.GetResult();
+ MG_HTTP_HANDLER_TRY()
+ // Check common parameters
+ ValidateCommonParameters();
+ if (m_geomWKT.empty())
+ MgStringCollection arguments;
+ arguments.Add(MgHttpResourceStrings::reqFeatGeometry);
+ arguments.Add(MgResources::BlankArgument);
+ throw new MgInvalidArgumentException(L"MgHttpGeoTessellate.Execute",
+ __LINE__, __WFILE__, &arguments, L"MgStringEmpty", NULL);
+ Ptr<MgWktReaderWriter> wktRw = new MgWktReaderWriter();
+ Ptr<MgGeometry> input = wktRw->Read(m_geomWKT);
+ Ptr<MgGeometry> result = input->Tessellate();
+ if (!m_transformTo.empty())
+ Ptr<MgCoordinateSystemFactory> csFactory = new MgCoordinateSystemFactory();
+ Ptr<MgCoordinateSystem> cs = csFactory->CreateFromCode(m_coordinateSystem);
+ Ptr<MgCoordinateSystem> target = csFactory->CreateFromCode(m_transformTo);
+ Ptr<MgCoordinateSystemTransform> xform = csFactory->GetTransform(cs, target);
+ Ptr<MgGeometry> xGeom = (MgGeometry*)result->Transform(xform);
+ result = xGeom;
+ if (m_format == L"WKT")
+ STRING wkt = wktRw->Write(result);
+ Ptr<MgHttpPrimitiveValue> value = new MgHttpPrimitiveValue(wkt);
+ hResult->SetResultObject(value, MgMimeType::Text);
+ else if (m_format == L"GEOJSON")
+ MgGeoJsonWriter gw;
+ STRING geoJson = gw.GeometryToGeoJson(result);
+ std::string mbGeoJson;
+ MgUtil::WideCharToMultiByte(geoJson, mbGeoJson);
+ Ptr<MgByteSource> byteSource = new MgByteSource((BYTE_ARRAY_IN)mbGeoJson.c_str(), (INT32)mbGeoJson.length());
+ byteSource->SetMimeType(MgMimeType::Json);
+ Ptr<MgByteReader> byteReader = byteSource->GetReader();
+ hResult->SetResultObject(byteReader, byteReader->GetMimeType());
+ MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGeoTessellate.Execute")
+void MgHttpGeoTessellate::ValidateOperationVersion()
+ // There are multiple supported versions
+ INT32 version = m_userInfo->GetApiVersion();
+ if (version != MG_API_VERSION(3, 3, 0))
+ throw new MgInvalidOperationVersionException(
+ L"MgHttpGeoTessellate.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+ MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpGeoTessellate.ValidateOperationVersion");
Added: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoTessellate.h
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoTessellate.h (rev 0)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoTessellate.h 2017-06-25 10:36:25 UTC (rev 9222)
@@ -0,0 +1,63 @@
+#ifndef MG_HTTP_GEO_TESSELLATE_H
+#define MG_HTTP_GEO_TESSELLATE_H
+class MgHttpGeoTessellate : public MgHttpRequestResponseHandler
+ HTTP_DECLARE_CREATE_OBJECT()
+public:
+ /// <summary>
+ /// Initializes the common parameters of the request.
+ /// </summary>
+ /// <param name="name">Input
+ /// MgHttpRequest
+ /// This contains all the parameters of the request.
+ /// </param>
+ /// <returns>
+ /// nothing
+ /// </returns>
+ MgHttpGeoTessellate(MgHttpRequest *hRequest);
+ /// <summary>
+ /// Executes the specific request.
+ /// </summary>
+ /// <param name="hResponse">Input
+ /// This contains the response (including MgHttpResult and StatusCode) from the server.
+ /// </param>
+ void Execute(MgHttpResponse& hResponse);
+ /// <summary>
+ /// Returns the classification of this request/response handler
+ /// </summary>
+ /// <returns>
+ /// Classification of handler
+ /// </returns>
+ MgRequestClassification GetRequestClassification() { return MgHttpRequestResponseHandler::mrcViewer; }
+ virtual void ValidateOperationVersion();
+private:
+ STRING m_geomWKT;
+ STRING m_format;
+ STRING m_coordinateSystem;
+ STRING m_transformTo;
+#endif
Added: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeometryInfo.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeometryInfo.cpp (rev 0)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeometryInfo.cpp 2017-06-25 10:36:25 UTC (rev 9222)
@@ -0,0 +1,161 @@
+#include "HttpGeometryInfo.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGeometryInfo)
+MgHttpGeometryInfo::MgHttpGeometryInfo(MgHttpRequest* hRequest)
+void MgHttpGeometryInfo::Execute(MgHttpResponse & hResponse)
+ throw new MgInvalidArgumentException(L"MgHttpGeometryInfo.Execute",
+ //Collect all geometry information
+ double area = input->GetArea();
+ INT32 dim = input->GetDimension();
+ double length = input->GetLength();
+ bool isClosed = input->IsClosed();
+ bool isEmpty = input->IsEmpty();
+ bool isSimple = input->IsSimple();
+ bool isValid = input->IsValid();
+ Ptr<MgEnvelope> env = input->Envelope();
+ Ptr<MgPoint> centroid = input->GetCentroid();
+ Ptr<MgCoordinate> cCentroid = centroid->GetCoordinate();
+ Ptr<MgCoordinate> envLL = env->GetLowerLeftCoordinate();
+ Ptr<MgCoordinate> envUR = env->GetUpperRightCoordinate();
+ std::string mbXml;
+ mbXml = "<?xml version=\"1.0\" encoding=\"utf-8\"?>";
+ mbXml += "<GeometryInfo xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"GeometryInfo-3.3.0.xsd\">";
+ mbXml += "<Area>";
+ std::string sArea;
+ MgUtil::DoubleToString(area, sArea);
+ mbXml += sArea;
+ mbXml += "</Area>";
+ mbXml += "<Dimension>";
+ std::string sDim;
+ MgUtil::Int32ToString(dim, sDim);
+ mbXml += sDim;
+ mbXml += "</Dimension>";
+ mbXml += "<Length>";
+ std::string sLen;
+ MgUtil::DoubleToString(length, sLen);
+ mbXml += sLen;
+ mbXml += "</Length>";
+ mbXml += "<IsClosed>";
+ mbXml += (isClosed ? "true" : "false");
+ mbXml += "</IsClosed>";
+ mbXml += "<IsEmpty>";
+ mbXml += (isEmpty ? "true" : "false");
+ mbXml += "</IsEmpty>";
+ mbXml += "<IsSimple>";
+ mbXml += (isSimple ? "true" : "false");
+ mbXml += "</IsSimple>";
+ mbXml += "<IsValid>";
+ mbXml += (isValid ? "true" : "false");
+ mbXml += "</IsValid>";
+ mbXml += "<Envelope>";
+ mbXml += "<LowerLeft>";
+ mbXml += "<X>";
+ std::string sLLX;
+ MgUtil::DoubleToString(envLL->GetX(), sLLX);
+ mbXml += sLLX;
+ mbXml += "</X>";
+ mbXml += "<Y>";
+ std::string sLLY;
+ MgUtil::DoubleToString(envLL->GetY(), sLLY);
+ mbXml += sLLY;
+ mbXml += "</Y>";
+ mbXml += "</LowerLeft>";
+ mbXml += "<UpperRight>";
+ mbXml += "<X>";
+ std::string sURX;
+ MgUtil::DoubleToString(envUR->GetX(), sURX);
+ mbXml += sURX;
+ mbXml += "</X>";
+ mbXml += "<Y>";
+ std::string sURY;
+ MgUtil::DoubleToString(envUR->GetY(), sURY);
+ mbXml += sURY;
+ mbXml += "</Y>";
+ mbXml += "</UpperRight>";
+ mbXml += "</Envelope>";
+ mbXml += "<Centroid>";
+ mbXml += "<X>";
+ std::string sCentX;
+ MgUtil::DoubleToString(cCentroid->GetX(), sCentX);
+ mbXml += sCentX;
+ mbXml += "</X>";
+ mbXml += "<Y>";
+ std::string sCentY;
+ MgUtil::DoubleToString(cCentroid->GetY(), sCentY);
+ mbXml += sCentY;
+ mbXml += "</Y>";
+ mbXml += "</Centroid>";
+ mbXml += "</GeometryInfo>";
+ Ptr<MgByteSource> bs = new MgByteSource((BYTE_ARRAY_IN)mbXml.c_str(), (INT32)mbXml.length());
+ bs->SetMimeType(MgMimeType::Xml);
+ Ptr<MgByteReader> br = bs->GetReader();
+ //Convert to alternate response format, if necessary
+ ProcessFormatConversion(br);
+ hResult->SetResultObject(br, br->GetMimeType());
+ MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGeometryInfo.Execute")
+void MgHttpGeometryInfo::ValidateOperationVersion()
+ L"MgHttpGeometryInfo.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+ MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpGeometryInfo.ValidateOperationVersion");
Added: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeometryInfo.h
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeometryInfo.h (rev 0)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeometryInfo.h 2017-06-25 10:36:25 UTC (rev 9222)
@@ -0,0 +1,60 @@
+#ifndef MG_HTTP_GEOMETRY_INFO_H
+#define MG_HTTP_GEOMETRY_INFO_H
+class MgHttpGeometryInfo : public MgHttpRequestResponseHandler
+public:
+ /// <summary>
+ /// </summary>
+ /// MgHttpRequest
+ /// </param>
+ /// <returns>
+ /// nothing
+ /// </returns>
+ MgHttpGeometryInfo(MgHttpRequest *hRequest);
+ /// <summary>
+ /// </summary>
+ /// </param>
+ /// <summary>
+ /// </summary>
+ /// <returns>
+ /// </returns>
+private:
+ STRING m_geomWKT;
+#endif
More information about the mapguide-commits
