[mapguide-commits] r9223 - in sandbox/jng/geoprocessing: UnitTest/WebTier/MapAgent/MapAgentForms Web/src/HttpHandler
svn_mapguide at osgeo.org
Sun Jun 25 03:38:15 PDT 2017
Author: jng
Date: 2017-06-25 03:38:15 -0700 (Sun, 25 Jun 2017)
New Revision: 9223
Added:
sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/boundaryform.html
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBoundary.cpp
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBoundary.h
sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj.filters
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandlerBuild.cpp
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpRequest.cpp
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.cpp
sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.h
Add the following operations to the mapagent:
- GEO.BOUNDARY
- Returns a geometry that represents the boundary of the given input geometry (in WKT). This is a straight pass-through to MgGeometry::Boundary()
With this commit, the mapagent has the same API surface as the MgGeometry API
Added: sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/boundaryform.html
--- sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/boundaryform.html (rev 0)
+++ sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/boundaryform.html 2017-06-25 10:38:15 UTC (rev 9223)
@@ -0,0 +1,33 @@
+<html>
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+<script type="text/javascript" src="setactiontarget.js" >
+</script>
+</head>
+<body>
+<form name="input" action="" method="get">
+<b>Operation:</b>
+<input type="text" name="OPERATION" value="GEO.BOUNDARY" size="50">
+<p> Version:
+<input type="text" name="VERSION" value="3.3.0" size="10">
+<p> Locale:
+<input type="text" name="LOCALE" value="en" size="10">
+<p> Client Agent:
+<input type="text" name="CLIENTAGENT" value="MapGuide Developer" size="100">
+<p> Geometry (WKT):
+<input type="text" name="GEOMETRY" value="" size="100">
+<p> Output Format:
+<select name="FORMAT">
+ <option value="WKT">Geometry Well-Known Text</option>
+ <option value="GEOJSON">GeoJSON</option>
+</select>
+<p> Input Coordinate System (CS-Map Code):
+<input type="text" name="COORDINATESYSTEM" value="" size="10">
+<p> Output Coordinate System (CS-Map Code):
+<input type="text" name="TRANSFORMTO" value="" size="10">
+<p>
+<input type="submit" value="Submit" onclick="SetActionTarget()"> <input type="reset">
+</form>
+</body>
+</html>
+<html>
Modified: sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html
--- sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html 2017-06-25 10:36:25 UTC (rev 9222)
+++ sandbox/jng/geoprocessing/UnitTest/WebTier/MapAgent/MapAgentForms/geoprocessingapi.html 2017-06-25 10:38:15 UTC (rev 9223)
@@ -9,6 +9,8 @@
<body>
<UL>
<LI>
+ <A href="boundaryform.html" target="showform">Boundary</A>
+ <LI>
<A href="bufferform.html" target="showform">Buffer</A>
<LI>
<A href="convexhullform.html" target="showform">ConvexHull</A>
Added: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBoundary.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBoundary.cpp (rev 0)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBoundary.cpp 2017-06-25 10:38:15 UTC (rev 9223)
@@ -0,0 +1,104 @@
+// Copyright (C) 2004-2017 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "HttpHandler.h"
+#include "HttpGeoBoundary.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGeoBoundary)
+MgHttpGeoBoundary::MgHttpGeoBoundary(MgHttpRequest* hRequest)
+ InitializeCommonParameters(hRequest);
+ Ptr<MgHttpRequestParam> params = hRequest->GetRequestParam();
+ m_geomWKT = params->GetParameterValue(MgHttpResourceStrings::reqFeatGeometry);
+ m_format = params->GetParameterValue(MgHttpResourceStrings::reqGeoFormat);
+ m_coordinateSystem = params->GetParameterValue(MgHttpResourceStrings::reqGeoCoordinateSystem);
+ m_transformTo = params->GetParameterValue(MgHttpResourceStrings::reqGeoTransformTo);
+void MgHttpGeoBoundary::Execute(MgHttpResponse & hResponse)
+ Ptr<MgHttpResult> hResult = hResponse.GetResult();
+ MG_HTTP_HANDLER_TRY()
+ // Check common parameters
+ ValidateCommonParameters();
+ if (m_geomWKT.empty())
+ MgStringCollection arguments;
+ arguments.Add(MgHttpResourceStrings::reqFeatGeometry);
+ arguments.Add(MgResources::BlankArgument);
+ throw new MgInvalidArgumentException(L"MgHttpGeoBoundary.Execute",
+ __LINE__, __WFILE__, &arguments, L"MgStringEmpty", NULL);
+ Ptr<MgWktReaderWriter> wktRw = new MgWktReaderWriter();
+ Ptr<MgGeometry> input = wktRw->Read(m_geomWKT);
+ Ptr<MgGeometry> result = input->ConvexHull();
+ if (!m_transformTo.empty())
+ Ptr<MgCoordinateSystemFactory> csFactory = new MgCoordinateSystemFactory();
+ Ptr<MgCoordinateSystem> cs = csFactory->CreateFromCode(m_coordinateSystem);
+ Ptr<MgCoordinateSystem> target = csFactory->CreateFromCode(m_transformTo);
+ Ptr<MgCoordinateSystemTransform> xform = csFactory->GetTransform(cs, target);
+ Ptr<MgGeometry> xGeom = (MgGeometry*)result->Transform(xform);
+ result = xGeom;
+ if (m_format == L"WKT")
+ STRING wkt = wktRw->Write(result);
+ Ptr<MgHttpPrimitiveValue> value = new MgHttpPrimitiveValue(wkt);
+ hResult->SetResultObject(value, MgMimeType::Text);
+ else if (m_format == L"GEOJSON")
+ MgGeoJsonWriter gw;
+ STRING geoJson = gw.GeometryToGeoJson(result);
+ std::string mbGeoJson;
+ MgUtil::WideCharToMultiByte(geoJson, mbGeoJson);
+ Ptr<MgByteSource> byteSource = new MgByteSource((BYTE_ARRAY_IN)mbGeoJson.c_str(), (INT32)mbGeoJson.length());
+ byteSource->SetMimeType(MgMimeType::Json);
+ Ptr<MgByteReader> byteReader = byteSource->GetReader();
+ hResult->SetResultObject(byteReader, byteReader->GetMimeType());
+ MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGeoBoundary.Execute")
+void MgHttpGeoBoundary::ValidateOperationVersion()
+ // There are multiple supported versions
+ INT32 version = m_userInfo->GetApiVersion();
+ if (version != MG_API_VERSION(3, 3, 0))
+ throw new MgInvalidOperationVersionException(
+ L"MgHttpGeoBoundary.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+ MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpGeoBoundary.ValidateOperationVersion");
Added: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBoundary.h
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBoundary.h (rev 0)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpGeoBoundary.h 2017-06-25 10:38:15 UTC (rev 9223)
@@ -0,0 +1,63 @@
+#ifndef MG_HTTP_GEO_BOUNDARY_H
+#define MG_HTTP_GEO_BOUNDARY_H
+class MgHttpGeoBoundary : public MgHttpRequestResponseHandler
+ HTTP_DECLARE_CREATE_OBJECT()
+public:
+ /// <summary>
+ /// Initializes the common parameters of the request.
+ /// </summary>
+ /// <param name="name">Input
+ /// MgHttpRequest
+ /// This contains all the parameters of the request.
+ /// </param>
+ /// <returns>
+ /// nothing
+ /// </returns>
+ MgHttpGeoBoundary(MgHttpRequest *hRequest);
+ /// <summary>
+ /// Executes the specific request.
+ /// </summary>
+ /// <param name="hResponse">Input
+ /// This contains the response (including MgHttpResult and StatusCode) from the server.
+ /// </param>
+ void Execute(MgHttpResponse& hResponse);
+ /// <summary>
+ /// Returns the classification of this request/response handler
+ /// </summary>
+ /// <returns>
+ /// Classification of handler
+ /// </returns>
+ MgRequestClassification GetRequestClassification() { return MgHttpRequestResponseHandler::mrcViewer; }
+ virtual void ValidateOperationVersion();
+private:
+ STRING m_geomWKT;
+ STRING m_format;
+ STRING m_coordinateSystem;
+ STRING m_transformTo;
+#endif
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj 2017-06-25 10:36:25 UTC (rev 9222)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj 2017-06-25 10:38:15 UTC (rev 9223)
@@ -210,6 +210,12 @@
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
</ClCompile>
+ <ClCompile Include="HttpGeoBoundary.cpp">
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
+ </ClCompile>
<ClCompile Include="HttpGeoConvexHull.cpp">
@@ -993,6 +999,7 @@
<ItemGroup>
<ClInclude Include="HttpApplyResourcePackage.h" />
<ClInclude Include="HttpChangeResourceOwner.h" />
+ <ClInclude Include="HttpGeoBoundary.h" />
<ClInclude Include="HttpGeoConvexHull.h" />
<ClInclude Include="HttpCopyResource.h" />
<ClInclude Include="HttpCreateRepository.h" />
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj.filters
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj.filters 2017-06-25 10:36:25 UTC (rev 9222)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandler.vcxproj.filters 2017-06-25 10:38:15 UTC (rev 9223)
@@ -413,6 +413,9 @@
<ClCompile Include="HttpGeoTessellate.cpp">
<Filter>GeoProcessing</Filter>
</ClCompile>
+ <Filter>GeoProcessing</Filter>
+ </ClCompile>
</ItemGroup>
<ItemGroup>
<ClInclude Include="HttpApplyResourcePackage.h">
@@ -808,6 +811,9 @@
<ClInclude Include="HttpGeoTessellate.h">
</ClInclude>
+ <ClInclude Include="HttpGeoBoundary.h">
+ </ClInclude>
</ItemGroup>
<ItemGroup>
<ResourceCompile Include="HttpHandler.rc" />
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandlerBuild.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandlerBuild.cpp 2017-06-25 10:36:25 UTC (rev 9222)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpHandlerBuild.cpp 2017-06-25 10:38:15 UTC (rev 9223)
@@ -55,6 +55,7 @@
#include "HttpEnumerateApplicationTemplates.cpp"
#include "HttpEnumerateApplicationWidgets.cpp"
#include "HttpEnumerateApplicationContainers.cpp"
+#include "HttpGeoBoundary.cpp"
#include "HttpGeoBuffer.cpp"
#include "HttpGeoBinaryOperation.cpp"
#include "HttpGeoConvexHull.cpp"
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpRequest.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpRequest.cpp 2017-06-25 10:36:25 UTC (rev 9222)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpRequest.cpp 2017-06-25 10:38:15 UTC (rev 9223)
@@ -125,6 +125,7 @@
#include "HttpCsIsValid.h"
// Geo-Processing
#include "HttpGeoBuffer.h"
#include "HttpGeoBinaryOperation.h"
#include "HttpGeoConvexHull.h"
@@ -441,6 +442,7 @@
httpClassCreators[MgHttpResourceStrings::opEnumerateApplicationContainers] = MgHttpEnumerateApplicationContainers::CreateObject;
httpClassCreators[MgHttpResourceStrings::opGetDefaultTileSizeX] = MgHttpGetDefaultTileSizeX::CreateObject;
httpClassCreators[MgHttpResourceStrings::opGetDefaultTileSizeY] = MgHttpGetDefaultTileSizeY::CreateObject;
+ httpClassCreators[MgHttpResourceStrings::opGeoBoundary] = MgHttpGeoBoundary::CreateObject;
httpClassCreators[MgHttpResourceStrings::opGeoBuffer] = MgHttpGeoBuffer::CreateObject;
httpClassCreators[MgHttpResourceStrings::opGeoBinaryOperation] = MgHttpGeoBinaryOperation::CreateObject;
httpClassCreators[MgHttpResourceStrings::opGeoConvexHull] = MgHttpGeoConvexHull::CreateObject;
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.cpp
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.cpp 2017-06-25 10:36:25 UTC (rev 9222)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.cpp 2017-06-25 10:38:15 UTC (rev 9223)
@@ -365,6 +365,7 @@
const STRING MgHttpResourceStrings::opEnumerateApplicationContainers = L"ENUMERATEAPPLICATIONCONTAINERS";
// Geo-Processing Operations
+const STRING MgHttpResourceStrings::opGeoBoundary = L"GEO.BOUNDARY";
const STRING MgHttpResourceStrings::opGeoBuffer = L"GEO.BUFFER";
const STRING MgHttpResourceStrings::opGeoConvexHull = L"GEO.CONVEXHULL";
const STRING MgHttpResourceStrings::opGeoDistance = L"GEO.DISTANCE";
Modified: sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.h
--- sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.h 2017-06-25 10:36:25 UTC (rev 9222)
+++ sandbox/jng/geoprocessing/Web/src/HttpHandler/HttpResourceStrings.h 2017-06-25 10:38:15 UTC (rev 9223)
@@ -369,6 +369,7 @@
static const STRING opEnumerateApplicationContainers;
+ static const STRING opGeoBoundary;
static const STRING opGeoBuffer;
static const STRING opGeoConvexHull;
static const STRING opGeoDistance;
More information about the mapguide-commits
