[mapguide-commits] r9198 - in sandbox/jng/utfgrid/Doc/samples/ol2samples: . assets utfgrid
svn_mapguide at osgeo.org
Fri Jun 2 08:36:29 PDT 2017
Author: jng
Date: 2017-06-02 08:36:27 -0700 (Fri, 02 Jun 2017)
New Revision: 9198
Added:
sandbox/jng/utfgrid/Doc/samples/ol2samples/assets/ol-debug.js
sandbox/jng/utfgrid/Doc/samples/ol2samples/assets/ol.css
sandbox/jng/utfgrid/Doc/samples/ol2samples/assets/ol.js
sandbox/jng/utfgrid/Doc/samples/ol2samples/utfgrid/
sandbox/jng/utfgrid/Doc/samples/ol2samples/utfgrid/index.html
Check in the utfgrid sample application
Added: sandbox/jng/utfgrid/Doc/samples/ol2samples/assets/ol-debug.js
--- sandbox/jng/utfgrid/Doc/samples/ol2samples/assets/ol-debug.js (rev 0)
+++ sandbox/jng/utfgrid/Doc/samples/ol2samples/assets/ol-debug.js 2017-06-02 15:36:27 UTC (rev 9198)
@@ -0,0 +1,92034 @@
+// OpenLayers. See https://openlayers.org/
+// License: https://raw.githubusercontent.com/openlayers/openlayers/master/LICENSE.md
+// Version: v4.1.0
+;(function (root, factory) {
+ if (typeof exports === "object") {
+ module.exports = factory();
+ } else if (typeof define === "function" && define.amd) {
+ define([], factory);
+ } else {
+ root.ol = factory();
+}(this, function () {
+ var OPENLAYERS = {};
+ var goog = this.goog = {};
+this.CLOSURE_NO_DEPS = true;
+// Copyright 2006 The Closure Library Authors. All Rights Reserved.
+// Licensed under the Apache License, Version 2.0 (the "License");
+// you may not use this file except in compliance with the License.
+// You may obtain a copy of the License at
+// http://www.apache.org/licenses/LICENSE-2.0
+// Unless required by applicable law or agreed to in writing, software
+// distributed under the License is distributed on an "AS-IS" BASIS,
+// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+// See the License for the specific language governing permissions and
+// limitations under the License.
+ * @fileoverview Bootstrap for the Google JS Library (Closure).
+ * In uncompiled mode base.js will write out Closure's deps file, unless the
+ * global <code>CLOSURE_NO_DEPS</code> is set to true. This allows projects to
+ * include their own deps file(s) from different locations.
+ * Avoid including base.js more than once. This is strictly discouraged and not
+ * supported. goog.require(...) won't work properly in that case.
+ * @author arv at google.com (Erik Arvidsson)
+ * @provideGoog
+ * @define {boolean} Overridden to true by the compiler when
+ * --process_closure_primitives is specified.
+var COMPILED = false;
+ * Base namespace for the Closure library. Checks to see goog is already
+ * defined in the current scope before assigning to prevent clobbering if
+ * base.js is loaded more than once.
+ * @const
+var goog = goog || {};
+ * Reference to the global context. In most cases this will be 'window'.
+goog.global = this;
+ * A hook for overriding the define values in uncompiled mode.
+ * In uncompiled mode, {@code CLOSURE_UNCOMPILED_DEFINES} may be defined before
+ * loading base.js. If a key is defined in {@code CLOSURE_UNCOMPILED_DEFINES},
+ * {@code goog.define} will use the value instead of the default value. This
+ * allows flags to be overwritten without compilation (this is normally
+ * accomplished with the compiler's "define" flag).
+ * Example:
+ * <pre>
+ * var CLOSURE_UNCOMPILED_DEFINES = {'goog.DEBUG': false};
+ * </pre>
+ * @type {Object<string, (string|number|boolean)>|undefined}
+goog.global.CLOSURE_UNCOMPILED_DEFINES;
+ * A hook for overriding the define values in uncompiled or compiled mode,
+ * like CLOSURE_UNCOMPILED_DEFINES but effective in compiled code. In
+ * uncompiled code CLOSURE_UNCOMPILED_DEFINES takes precedence.
+ * Also unlike CLOSURE_UNCOMPILED_DEFINES the values must be number, boolean or
+ * string literals or the compiler will emit an error.
+ * While any @define value may be set, only those set with goog.define will be
+ * effective for uncompiled code.
+ * Example:
+ * <pre>
+ * var CLOSURE_DEFINES = {'goog.DEBUG': false} ;
+ * </pre>
+goog.global.CLOSURE_DEFINES;
+ * Returns true if the specified value is not undefined.
+ * WARNING: Do not use this to test if an object has a property. Use the in
+ * operator instead.
+ * @param {?} val Variable to test.
+ * @return {boolean} Whether variable is defined.
+goog.isDef = function(val) {
+ // void 0 always evaluates to undefined and hence we do not need to depend on
+ // the definition of the global variable named 'undefined'.
+ return val !== void 0;
+ * Builds an object structure for the provided namespace path, ensuring that
+ * names that already exist are not overwritten. For example:
+ * "a.b.c" -> a = {};a.b={};a.b.c={};
+ * Used by goog.provide and goog.exportSymbol.
+ * @param {string} name name of the object that this file defines.
+ * @param {*=} opt_object the object to expose at the end of the path.
+ * @param {Object=} opt_objectToExportTo The object to add the path to; default
+ * is |goog.global|.
+ * @private
+goog.exportPath_ = function(name, opt_object, opt_objectToExportTo) {
+ var parts = name.split('.');
+ var cur = opt_objectToExportTo || goog.global;
+ // Internet Explorer exhibits strange behavior when throwing errors from
+ // methods externed in this manner. See the testExportSymbolExceptions in
+ // base_test.html for an example.
+ if (!(parts[0] in cur) && cur.execScript) {
+ cur.execScript('var ' + parts[0]);
+ // Certain browsers cannot parse code in the form for((a in b); c;);
+ // This pattern is produced by the JSCompiler when it collapses the
+ // statement above into the conditional loop below. To prevent this from
+ // happening, use a for-loop and reserve the init logic as below.
+ // Parentheses added to eliminate strict JS warning in Firefox.
+ for (var part; parts.length && (part = parts.shift());) {
+ if (!parts.length && goog.isDef(opt_object)) {
+ // last part and we have an object; use it
+ cur[part] = opt_object;
+ } else if (cur[part] && Object.prototype.hasOwnProperty.call(cur, part)) {
+ cur = cur[part];
+ } else {
+ cur = cur[part] = {};
+ * Defines a named value. In uncompiled mode, the value is retrieved from
+ * CLOSURE_DEFINES or CLOSURE_UNCOMPILED_DEFINES if the object is defined and
+ * has the property specified, and otherwise used the defined defaultValue.
+ * When compiled the default can be overridden using the compiler
+ * options or the value set in the CLOSURE_DEFINES object.
+ * @param {string} name The distinguished name to provide.
+ * @param {string|number|boolean} defaultValue
+goog.define = function(name, defaultValue) {
+ var value = defaultValue;
+ if (!COMPILED) {
+ if (goog.global.CLOSURE_UNCOMPILED_DEFINES &&
+ Object.prototype.hasOwnProperty.call(
+ goog.global.CLOSURE_UNCOMPILED_DEFINES, name)) {
+ value = goog.global.CLOSURE_UNCOMPILED_DEFINES[name];
+ } else if (
+ goog.global.CLOSURE_DEFINES &&
+ goog.global.CLOSURE_DEFINES, name)) {
+ value = goog.global.CLOSURE_DEFINES[name];
+ goog.exportPath_(name, value);
+ * @define {boolean} DEBUG is provided as a convenience so that debugging code
+ * that should not be included in a production js_binary can be easily stripped
+ * by specifying --define goog.DEBUG=false to the JSCompiler. For example, most
+ * toString() methods should be declared inside an "if (goog.DEBUG)" conditional
+ * because they are generally used for debugging purposes and it is difficult
+ * for the JSCompiler to statically determine whether they are used.
+goog.define('goog.DEBUG', true);
+ * @define {string} LOCALE defines the locale being used for compilation. It is
+ * used to select locale specific data to be compiled in js binary. BUILD rule
+ * can specify this value by "--define goog.LOCALE=<locale_name>" as JSCompiler
+ * option.
+ * Take into account that the locale code format is important. You should use
+ * the canonical Unicode format with hyphen as a delimiter. Language must be
+ * lowercase, Language Script - Capitalized, Region - UPPERCASE.
+ * There are few examples: pt-BR, en, en-US, sr-Latin-BO, zh-Hans-CN.
+ * See more info about locale codes here:
+ * http://www.unicode.org/reports/tr35/#Unicode_Language_and_Locale_Identifiers
+ * For language codes you should use values defined by ISO 693-1. See it here
+ * http://www.w3.org/WAI/ER/IG/ert/iso639.htm. There is only one exception from
+ * this rule: the Hebrew language. For legacy reasons the old code (iw) should
+ * be used instead of the new code (he), see http://wiki/Main/IIISynonyms.
+goog.define('goog.LOCALE', 'en'); // default to en
+ * @define {boolean} Whether this code is running on trusted sites.
+ * On untrusted sites, several native functions can be defined or overridden by
+ * external libraries like Prototype, Datejs, and JQuery and setting this flag
+ * to false forces closure to use its own implementations when possible.
+ * If your JavaScript can be loaded by a third party site and you are wary about
+ * relying on non-standard implementations, specify
+ * "--define goog.TRUSTED_SITE=false" to the JSCompiler.
+goog.define('goog.TRUSTED_SITE', true);
+ * @define {boolean} Whether a project is expected to be running in strict mode.
+ * This define can be used to trigger alternate implementations compatible with
+ * running in EcmaScript Strict mode or warn about unavailable functionality.
+ * @see https://goo.gl/PudQ4y
+goog.define('goog.STRICT_MODE_COMPATIBLE', false);
+ * @define {boolean} Whether code that calls {@link goog.setTestOnly} should
+ * be disallowed in the compilation unit.
+goog.define('goog.DISALLOW_TEST_ONLY_CODE', COMPILED && !goog.DEBUG);
+ * @define {boolean} Whether to use a Chrome app CSP-compliant method for
+ * loading scripts via goog.require. @see appendScriptSrcNode_.
+goog.define('goog.ENABLE_CHROME_APP_SAFE_SCRIPT_LOADING', false);
+ * Defines a namespace in Closure.
+ * A namespace may only be defined once in a codebase. It may be defined using
+ * goog.provide() or goog.module().
+ * The presence of one or more goog.provide() calls in a file indicates
+ * that the file defines the given objects/namespaces.
+ * Provided symbols must not be null or undefined.
+ * In addition, goog.provide() creates the object stubs for a namespace
+ * (for example, goog.provide("goog.foo.bar") will create the object
+ * goog.foo.bar if it does not already exist).
+ * Build tools also scan for provide/require/module statements
+ * to discern dependencies, build dependency files (see deps.js), etc.
+ * @see goog.require
+ * @see goog.module
+ * @param {string} name Namespace provided by this file in the form
+ * "goog.package.part".
+goog.provide = function(name) {
+ if (goog.isInModuleLoader_()) {
+ throw Error('goog.provide can not be used within a goog.module.');
+ if (!COMPILED) {
+ // Ensure that the same namespace isn't provided twice.
+ // A goog.module/goog.provide maps a goog.require to a specific file
+ if (goog.isProvided_(name)) {
+ throw Error('Namespace "' + name + '" already declared.');
+ goog.constructNamespace_(name);
+ * @param {Object=} opt_obj The object to embed in the namespace.
+ * @private
+goog.constructNamespace_ = function(name, opt_obj) {
+ if (!COMPILED) {
+ delete goog.implicitNamespaces_[name];
+ var namespace = name;
+ while ((namespace = namespace.substring(0, namespace.lastIndexOf('.')))) {
+ if (goog.getObjectByName(namespace)) {
+ break;
+ goog.implicitNamespaces_[namespace] = true;
+ goog.exportPath_(name, opt_obj);
+ * Module identifier validation regexp.
+ * Note: This is a conservative check, it is very possible to be more lenient,
+ * the primary exclusion here is "/" and "\" and a leading ".", these
+ * restrictions are intended to leave the door open for using goog.require
+ * with relative file paths rather than module identifiers.
+ * @private
+goog.VALID_MODULE_RE_ = /^[a-zA-Z_$][a-zA-Z0-9._$]*$/;
+ * Defines a module in Closure.
+ * Marks that this file must be loaded as a module and claims the namespace.
+ * goog.module() has three requirements:
+ * - goog.module may not be used in the same file as goog.provide.
+ * - goog.module must be the first statement in the file.
+ * - only one goog.module is allowed per file.
+ * When a goog.module annotated file is loaded, it is enclosed in
+ * a strict function closure. This means that:
+ * - any variables declared in a goog.module file are private to the file
+ * (not global), though the compiler is expected to inline the module.
+ * - The code must obey all the rules of "strict" JavaScript.
+ * - the file will be marked as "use strict"
+ * NOTE: unlike goog.provide, goog.module does not declare any symbols by
+ * itself. If declared symbols are desired, use
+ * goog.module.declareLegacyNamespace().
+ * See the public goog.module proposal: http://goo.gl/Va1hin
+ * "goog.package.part", is expected but not required.
+ * @return {void}
+goog.module = function(name) {
+ if (!goog.isString(name) || !name ||
+ name.search(goog.VALID_MODULE_RE_) == -1) {
+ throw Error('Invalid module identifier');
+ if (!goog.isInModuleLoader_()) {
+ throw Error(
+ 'Module ' + name + ' has been loaded incorrectly. Note, ' +
+ 'modules cannot be loaded as normal scripts. They require some kind of ' +
+ 'pre-processing step. You\'re likely trying to load a module via a ' +
+ 'script tag or as a part of a concatenated bundle without rewriting the ' +
+ 'module. For more info see: ' +
+ 'https://github.com/google/closure-library/wiki/goog.module:-an-ES6-module-like-alternative-to-goog.provide.');
+ if (goog.moduleLoaderState_.moduleName) {
+ throw Error('goog.module may only be called once per module.');
+ // Store the module name for the loader.
+ goog.moduleLoaderState_.moduleName = name;
+ if (!COMPILED) {
+ * @param {string} name The module identifier.
+ * @return {?} The module exports for an already loaded module or null.
+ * Note: This is not an alternative to goog.require, it does not
+ * indicate a hard dependency, instead it is used to indicate
+ * an optional dependency or to access the exports of a module
+ * that has already been loaded.
+ * @suppress {missingProvide}
+goog.module.get = function(name) {
+ return goog.module.getInternal_(name);
+ * @private
+goog.module.getInternal_ = function(name) {
+ if (!COMPILED) {
+ if (name in goog.loadedModules_) {
+ return goog.loadedModules_[name];
+ } else if (!goog.implicitNamespaces_[name]) {
+ var ns = goog.getObjectByName(name);
+ return ns != null ? ns : null;
+ return null;
+ * @private {?{moduleName: (string|undefined), declareLegacyNamespace:boolean}}
+goog.moduleLoaderState_ = null;
+ * @private
+ * @return {boolean} Whether a goog.module is currently being initialized.
+goog.isInModuleLoader_ = function() {
+ return goog.moduleLoaderState_ != null;
+ * Provide the module's exports as a globally accessible object under the
+ * module's declared name. This is intended to ease migration to goog.module
+ * for files that have existing usages.
+goog.module.declareLegacyNamespace = function() {
+ if (!COMPILED && !goog.isInModuleLoader_()) {
+ throw new Error(
+ 'goog.module.declareLegacyNamespace must be called from ' +
+ 'within a goog.module');
+ if (!COMPILED && !goog.moduleLoaderState_.moduleName) {
+ throw Error(
+ 'goog.module must be called prior to ' +
+ 'goog.module.declareLegacyNamespace.');
+ goog.moduleLoaderState_.declareLegacyNamespace = true;
+ * Marks that the current file should only be used for testing, and never for
+ * live code in production.
+ * In the case of unit tests, the message may optionally be an exact namespace
+ * for the test (e.g. 'goog.stringTest'). The linter will then ignore the extra
+ * provide (if not explicitly defined in the code).
+ * @param {string=} opt_message Optional message to add to the error that's
+ * raised when used in production code.
+goog.setTestOnly = function(opt_message) {
+ if (goog.DISALLOW_TEST_ONLY_CODE) {
+ opt_message = opt_message || '';
+ throw Error(
+ 'Importing test-only code into non-debug environment' +
+ (opt_message ? ': ' + opt_message : '.'));
+ * Forward declares a symbol. This is an indication to the compiler that the
+ * symbol may be used in the source yet is not required and may not be provided
+ * in compilation.
+ * The most common usage of forward declaration is code that takes a type as a
+ * function parameter but does not need to require it. By forward declaring
+ * instead of requiring, no hard dependency is made, and (if not required
+ * elsewhere) the namespace may never be required and thus, not be pulled
+ * into the JavaScript binary. If it is required elsewhere, it will be type
+ * checked as normal.
+ * Before using goog.forwardDeclare, please read the documentation at
+ * https://github.com/google/closure-compiler/wiki/Bad-Type-Annotation to
+ * understand the options and tradeoffs when working with forward declarations.
+ * @param {string} name The namespace to forward declare in the form of
+goog.forwardDeclare = function(name) {};
+ * Forward declare type information. Used to assign types to goog.global
+ * referenced object that would otherwise result in unknown type references
+ * and thus block property disambiguation.
+goog.forwardDeclare('Document');
+goog.forwardDeclare('HTMLScriptElement');
+goog.forwardDeclare('XMLHttpRequest');
+if (!COMPILED) {
+ * Check if the given name has been goog.provided. This will return false for
+ * names that are available only as implicit namespaces.
+ * @param {string} name name of the object to look for.
+ * @return {boolean} Whether the name has been provided.
+ * @private
+ goog.isProvided_ = function(name) {
+ return (name in goog.loadedModules_) ||
+ (!goog.implicitNamespaces_[name] &&
+ goog.isDefAndNotNull(goog.getObjectByName(name)));
+ * Namespaces implicitly defined by goog.provide. For example,
+ * goog.provide('goog.events.Event') implicitly declares that 'goog' and
+ * 'goog.events' must be namespaces.
+ * @type {!Object<string, (boolean|undefined)>}
+ * @private
+ goog.implicitNamespaces_ = {'goog.module': true};
+ // NOTE: We add goog.module as an implicit namespace as goog.module is defined
+ // here and because the existing module package has not been moved yet out of
+ // the goog.module namespace. This satisifies both the debug loader and
+ // ahead-of-time dependency management.
+ * Returns an object based on its fully qualified external name. The object
+ * is not found if null or undefined. If you are using a compilation pass that
+ * renames property names beware that using this function will not find renamed
+ * properties.
+ * @param {string} name The fully qualified name.
+ * @param {Object=} opt_obj The object within which to look; default is
+ * |goog.global|.
+ * @return {?} The value (object or primitive) or, if not found, null.
+goog.getObjectByName = function(name, opt_obj) {
+ var cur = opt_obj || goog.global;
+ for (var part; part = parts.shift();) {
+ if (goog.isDefAndNotNull(cur[part])) {
+ cur = cur[part];
+ } else {
+ return null;
+ return cur;
+ * Globalizes a whole namespace, such as goog or goog.lang.
+ * @param {!Object} obj The namespace to globalize.
+ * @param {Object=} opt_global The object to add the properties to.
+ * @deprecated Properties may be explicitly exported to the global scope, but
+ * this should no longer be done in bulk.
+goog.globalize = function(obj, opt_global) {
+ var global = opt_global || goog.global;
+ for (var x in obj) {
+ global[x] = obj[x];
+ * Adds a dependency from a file to the files it requires.
+ * @param {string} relPath The path to the js file.
+ * @param {!Array<string>} provides An array of strings with
+ * the names of the objects this file provides.
+ * @param {!Array<string>} requires An array of strings with
+ * the names of the objects this file requires.
+ * @param {boolean|!Object<string>=} opt_loadFlags Parameters indicating
+ * how the file must be loaded. The boolean 'true' is equivalent
+ * to {'module': 'goog'} for backwards-compatibility. Valid properties
+ * and values include {'module': 'goog'} and {'lang': 'es6'}.
+goog.addDependency = function(relPath, provides, requires, opt_loadFlags) {
+ if (goog.DEPENDENCIES_ENABLED) {
+ var provide, require;
+ var path = relPath.replace(/\\/g, '/');
+ var deps = goog.dependencies_;
+ if (!opt_loadFlags || typeof opt_loadFlags === 'boolean') {
+ opt_loadFlags = opt_loadFlags ? {'module': 'goog'} : {};
+ for (var i = 0; provide = provides[i]; i++) {
+ deps.nameToPath[provide] = path;
+ deps.loadFlags[path] = opt_loadFlags;
+ for (var j = 0; require = requires[j]; j++) {
+ if (!(path in deps.requires)) {
+ deps.requires[path] = {};
+ deps.requires[path][require] = true;
+// NOTE(nnaze): The debug DOM loader was included in base.js as an original way
+// to do "debug-mode" development. The dependency system can sometimes be
+// confusing, as can the debug DOM loader's asynchronous nature.
+// With the DOM loader, a call to goog.require() is not blocking -- the script
+// will not load until some point after the current script. If a namespace is
+// needed at runtime, it needs to be defined in a previous script, or loaded via
+// require() with its registered dependencies.
+// User-defined namespaces may need their own deps file. For a reference on
+// creating a deps file, see:
+// Externally: https://developers.google.com/closure/library/docs/depswriter
+// Because of legacy clients, the DOM loader can't be easily removed from
+// base.js. Work is being done to make it disableable or replaceable for
+// different environments (DOM-less JavaScript interpreters like Rhino or V8,
+// for example). See bootstrap/ for more information.
+ * @define {boolean} Whether to enable the debug loader.
+ * If enabled, a call to goog.require() will attempt to load the namespace by
+ * appending a script tag to the DOM (if the namespace has been registered).
+ * If disabled, goog.require() will simply assert that the namespace has been
+ * provided (and depend on the fact that some outside tool correctly ordered
+ * the script).
+goog.define('goog.ENABLE_DEBUG_LOADER', true);
+ * @param {string} msg
+ * @private
+goog.logToConsole_ = function(msg) {
+ if (goog.global.console) {
+ goog.global.console['error'](msg);
+ * Implements a system for the dynamic resolution of dependencies that works in
+ * parallel with the BUILD system. Note that all calls to goog.require will be
+ * stripped by the JSCompiler when the --process_closure_primitives option is
+ * used.
+ * @see goog.provide
+ * @param {string} name Namespace to include (as was given in goog.provide()) in
+ * the form "goog.package.part".
+ * @return {?} If called within a goog.module file, the associated namespace or
+ * module otherwise null.
+goog.require = function(name) {
+ // If the object already exists we do not need do do anything.
+ if (!COMPILED) {
+ if (goog.ENABLE_DEBUG_LOADER && goog.IS_OLD_IE_) {
+ goog.maybeProcessDeferredDep_(name);
+ } else if (goog.ENABLE_DEBUG_LOADER) {
+ var path = goog.getPathFromDeps_(name);
+ if (path) {
+ goog.writeScripts_(path);
+ } else {
+ var errorMessage = 'goog.require could not find: ' + name;
+ goog.logToConsole_(errorMessage);
+ throw Error(errorMessage);
+ return null;
+ * Path for included scripts.
+ * @type {string}
+goog.basePath = '';
+ * A hook for overriding the base path.
+ * @type {string|undefined}
+goog.global.CLOSURE_BASE_PATH;
+ * Whether to write out Closure's deps file. By default, the deps are written.
+ * @type {boolean|undefined}
+goog.global.CLOSURE_NO_DEPS;
+ * A function to import a single script. This is meant to be overridden when
+ * Closure is being run in non-HTML contexts, such as web workers. It's defined
+ * in the global scope so that it can be set before base.js is loaded, which
+ * allows deps.js to be imported properly.
+ * The function is passed the script source, which is a relative URI. It should
+ * return true if the script was imported, false otherwise.
+ * @type {(function(string): boolean)|undefined}
+goog.global.CLOSURE_IMPORT_SCRIPT;
+ * Null function used for default values of callbacks, etc.
+ * @return {void} Nothing.
+goog.nullFunction = function() {};
+ * When defining a class Foo with an abstract method bar(), you can do:
+ * Foo.prototype.bar = goog.abstractMethod
+ * Now if a subclass of Foo fails to override bar(), an error will be thrown
+ * when bar() is invoked.
+ * Note: This does not take the name of the function to override as an argument
+ * because that would make it more difficult to obfuscate our JavaScript code.
+ * @type {!Function}
+ * @throws {Error} when invoked to indicate the method should be overridden.
+goog.abstractMethod = function() {
+ throw Error('unimplemented abstract method');
+ * Adds a {@code getInstance} static method that always returns the same
+ * instance object.
+ * @param {!Function} ctor The constructor for the class to add the static
+ * method to.
+goog.addSingletonGetter = function(ctor) {
+ // instance_ is immediately set to prevent issues with sealed constructors
+ // such as are encountered when a constructor is returned as the export object
+ // of a goog.module in unoptimized code.
+ ctor.instance_ = undefined;
+ ctor.getInstance = function() {
+ if (ctor.instance_) {
+ return ctor.instance_;
+ if (goog.DEBUG) {
+ // NOTE: JSCompiler can't optimize away Array#push.
+ goog.instantiatedSingletons_[goog.instantiatedSingletons_.length] = ctor;
+ return ctor.instance_ = new ctor;
+ * All singleton classes that have been instantiated, for testing. Don't read
+ * it directly, use the {@code goog.testing.singleton} module. The compiler
+ * removes this variable if unused.
+ * @type {!Array<!Function>}
+ * @private
+goog.instantiatedSingletons_ = [];
+ * @define {boolean} Whether to load goog.modules using {@code eval} when using
+ * the debug loader. This provides a better debugging experience as the
+ * source is unmodified and can be edited using Chrome Workspaces or similar.
+ * However in some environments the use of {@code eval} is banned
+ * so we provide an alternative.
+goog.define('goog.LOAD_MODULE_USING_EVAL', true);
+ * @define {boolean} Whether the exports of goog.modules should be sealed when
+ * possible.
+goog.define('goog.SEAL_MODULE_EXPORTS', goog.DEBUG);
+ * The registry of initialized modules:
+ * the module identifier to module exports map.
+ * @private @const {!Object<string, ?>}
+goog.loadedModules_ = {};
+ * True if goog.dependencies_ is available.
+ * @const {boolean}
+goog.DEPENDENCIES_ENABLED = !COMPILED && goog.ENABLE_DEBUG_LOADER;
+ * @define {string} How to decide whether to transpile. Valid values
+ * are 'always', 'never', and 'detect'. The default ('detect') is to
+ * use feature detection to determine which language levels need
+ * transpilation.
+// NOTE(user): we could expand this to accept a language level to bypass
+// detection: e.g. goog.TRANSPILE == 'es5' would transpile ES6 files but
+// would leave ES3 and ES5 files alone.
+goog.define('goog.TRANSPILE', 'detect');
+ * @define {string} Path to the transpiler. Executing the script at this
+ * path (relative to base.js) should define a function $jscomp.transpile.
+goog.define('goog.TRANSPILER', 'transpile.js');
+if (goog.DEPENDENCIES_ENABLED) {
+ * This object is used to keep track of dependencies and other data that is
+ * used for loading scripts.
+ * @private
+ * @type {{
+ * loadFlags: !Object<string, !Object<string, string>>,
+ * nameToPath: !Object<string, string>,
+ * requires: !Object<string, !Object<string, boolean>>,
+ * visited: !Object<string, boolean>,
+ * written: !Object<string, boolean>,
+ * deferred: !Object<string, string>
+ goog.dependencies_ = {
+ loadFlags: {}, // 1 to 1
+ nameToPath: {}, // 1 to 1
+ requires: {}, // 1 to many
+ // Used when resolving dependencies to prevent us from visiting file twice.
+ visited: {},
+ written: {}, // Used to keep track of script files we have written.
+ deferred: {} // Used to track deferred module evaluations in old IEs
+ * Tries to detect whether is in the context of an HTML document.
+ * @return {boolean} True if it looks like HTML document.
+ * @private
+ goog.inHtmlDocument_ = function() {
+ /** @type {Document} */
+ var doc = goog.global.document;
+ return doc != null && 'write' in doc; // XULDocument misses write.
+ * Tries to detect the base path of base.js script that bootstraps Closure.
+ * @private
+ goog.findBasePath_ = function() {
+ if (goog.isDef(goog.global.CLOSURE_BASE_PATH)) {
+ goog.basePath = goog.global.CLOSURE_BASE_PATH;
+ return;
+ } else if (!goog.inHtmlDocument_()) {
+ return;
+ var scripts = doc.getElementsByTagName('SCRIPT');
+ // Search backwards since the current script is in almost all cases the one
+ // that has base.js.
+ for (var i = scripts.length - 1; i >= 0; --i) {
+ var script = /** @type {!HTMLScriptElement} */ (scripts[i]);
+ var src = script.src;
+ var qmark = src.lastIndexOf('?');
+ var l = qmark == -1 ? src.length : qmark;
+ if (src.substr(l - 7, 7) == 'base.js') {
+ goog.basePath = src.substr(0, l - 7);
+ return;
+ * Imports a script if, and only if, that script hasn't already been imported.
+ * (Must be called at execution time)
+ * @param {string} src Script source.
+ * @param {string=} opt_sourceText The optionally source text to evaluate
+ * @private
+ goog.importScript_ = function(src, opt_sourceText) {
+ var importScript =
+ goog.global.CLOSURE_IMPORT_SCRIPT || goog.writeScriptTag_;
+ if (importScript(src, opt_sourceText)) {
+ goog.dependencies_.written[src] = true;
+ * Whether the browser is IE9 or earlier, which needs special handling
+ * for deferred modules.
+ * @const @private {boolean}
+ goog.IS_OLD_IE_ =
+ !!(!goog.global.atob && goog.global.document && goog.global.document.all);
+ * Given a URL initiate retrieval and execution of a script that needs
+ * pre-processing.
+ * @param {string} src Script source URL.
+ * @param {boolean} isModule Whether this is a goog.module.
+ * @param {boolean} needsTranspile Whether this source needs transpilation.
+ * @private
+ goog.importProcessedScript_ = function(src, isModule, needsTranspile) {
+ // In an attempt to keep browsers from timing out loading scripts using
+ // synchronous XHRs, put each load in its own script block.
+ var bootstrap = 'goog.retrieveAndExec_("' + src + '", ' + isModule + ', ' +
+ needsTranspile + ');';
+ goog.importScript_('', bootstrap);
+ /** @private {!Array<string>} */
+ goog.queuedModules_ = [];
+ * Return an appropriate module text. Suitable to insert into
+ * a script tag (that is unescaped).
+ * @param {string} srcUrl
+ * @param {string} scriptText
+ * @return {string}
+ * @private
+ goog.wrapModule_ = function(srcUrl, scriptText) {
+ if (!goog.LOAD_MODULE_USING_EVAL || !goog.isDef(goog.global.JSON)) {
+ return '' +
+ 'goog.loadModule(function(exports) {' +
+ '"use strict";' + scriptText +
+ '\n' + // terminate any trailing single line comment.
+ ';return exports' +
+ '\n//# sourceURL=' + srcUrl + '\n';
+ } else {
+ return '' +
+ 'goog.loadModule(' +
+ goog.global.JSON.stringify(
+ scriptText + '\n//# sourceURL=' + srcUrl + '\n') +
+ // On IE9 and earlier, it is necessary to handle
+ // deferred module loads. In later browsers, the
+ // code to be evaluated is simply inserted as a script
+ // block in the correct order. To eval deferred
+ // code at the right time, we piggy back on goog.require to call
+ // goog.maybeProcessDeferredDep_.
+ // The goog.requires are used both to bootstrap
+ // the loading process (when no deps are available) and
+ // declare that they should be available.
+ // Here we eval the sources, if all the deps are available
+ // either already eval'd or goog.require'd. This will
+ // be the case when all the dependencies have already
+ // been loaded, and the dependent module is loaded.
+ // But this alone isn't sufficient because it is also
+ // necessary to handle the case where there is no root
+ // that is not deferred. For that there we register for an event
+ // and trigger goog.loadQueuedModules_ handle any remaining deferred
+ // evaluations.
+ * Handle any remaining deferred goog.module evals.
+ * @private
+ goog.loadQueuedModules_ = function() {
+ var count = goog.queuedModules_.length;
+ if (count > 0) {
+ var queue = goog.queuedModules_;
+ for (var i = 0; i < count; i++) {
+ var path = queue[i];
+ goog.maybeProcessDeferredPath_(path);
+ * Eval the named module if its dependencies are
+ * available.
+ * @param {string} name The module to load.
+ * @private
+ goog.maybeProcessDeferredDep_ = function(name) {
+ if (goog.isDeferredModule_(name) && goog.allDepsAreAvailable_(name)) {
+ goog.maybeProcessDeferredPath_(goog.basePath + path);
+ * @param {string} name The module to check.
+ * @return {boolean} Whether the name represents a
+ * module whose evaluation has been deferred.
+ * @private
+ goog.isDeferredModule_ = function(name) {
+ var loadFlags = path && goog.dependencies_.loadFlags[path] || {};
+ var languageLevel = loadFlags['lang'] || 'es3';
+ if (path && (loadFlags['module'] == 'goog' ||
+ goog.needsTranspile_(languageLevel))) {
+ var abspath = goog.basePath + path;
+ return (abspath) in goog.dependencies_.deferred;
+ return false;
+ * module whose declared dependencies have all been loaded
+ * (eval'd or a deferred module load)
+ * @private
+ goog.allDepsAreAvailable_ = function(name) {
+ if (path && (path in goog.dependencies_.requires)) {
+ for (var requireName in goog.dependencies_.requires[path]) {
+ if (!goog.isProvided_(requireName) &&
+ !goog.isDeferredModule_(requireName)) {
+ return false;
+ return true;
+ * @param {string} abspath
+ * @private
+ goog.maybeProcessDeferredPath_ = function(abspath) {
+ if (abspath in goog.dependencies_.deferred) {
+ var src = goog.dependencies_.deferred[abspath];
+ delete goog.dependencies_.deferred[abspath];
+ goog.globalEval(src);
+ * Load a goog.module from the provided URL. This is not a general purpose
+ * code loader and does not support late loading code, that is it should only
+ * be used during page load. This method exists to support unit tests and
+ * "debug" loaders that would otherwise have inserted script tags. Under the
+ * hood this needs to use a synchronous XHR and is not recommeneded for
+ * production code.
+ * The module's goog.requires must have already been satisified; an exception
+ * will be thrown if this is not the case. This assumption is that no
+ * "deps.js" file exists, so there is no way to discover and locate the
+ * module-to-be-loaded's dependencies and no attempt is made to do so.
+ * There should only be one attempt to load a module. If
+ * "goog.loadModuleFromUrl" is called for an already loaded module, an
+ * exception will be throw.
+ * @param {string} url The URL from which to attempt to load the goog.module.
+ goog.loadModuleFromUrl = function(url) {
+ // Because this executes synchronously, we don't need to do any additional
+ // bookkeeping. When "goog.loadModule" the namespace will be marked as
+ // having been provided which is sufficient.
+ goog.retrieveAndExec_(url, true, false);
+ * Writes a new script pointing to {@code src} directly into the DOM.
+ * NOTE: This method is not CSP-compliant. @see goog.appendScriptSrcNode_ for
+ * the fallback mechanism.
+ * @param {string} src The script URL.
+ * @private
+ goog.writeScriptSrcNode_ = function(src) {
+ goog.global.document.write(
+ '<script type="text/javascript" src="' + src + '"></' +
+ 'script>');
+ * Appends a new script node to the DOM using a CSP-compliant mechanism. This
+ * method exists as a fallback for document.write (which is not allowed in a
+ * strict CSP context, e.g., Chrome apps).
+ * NOTE: This method is not analogous to using document.write to insert a
+ * <script> tag; specifically, the user agent will execute a script added by
+ * document.write immediately after the current script block finishes
+ * executing, whereas the DOM-appended script node will not be executed until
+ * the entire document is parsed and executed. That is to say, this script is
+ * added to the end of the script execution queue.
+ * The page must not attempt to call goog.required entities until after the
+ * document has loaded, e.g., in or after the window.onload callback.
+ * @private
+ goog.appendScriptSrcNode_ = function(src) {
+ var scriptEl =
+ /** @type {HTMLScriptElement} */ (doc.createElement('script'));
+ scriptEl.type = 'text/javascript';
+ scriptEl.src = src;
+ scriptEl.defer = false;
+ scriptEl.async = false;
+ doc.head.appendChild(scriptEl);
+ * The default implementation of the import function. Writes a script tag to
+ * import the script.
+ * @param {string} src The script url.
+ * @return {boolean} True if the script was imported, false otherwise.
+ * @private
+ goog.writeScriptTag_ = function(src, opt_sourceText) {
+ if (goog.inHtmlDocument_()) {
+ /** @type {!HTMLDocument} */
+ // If the user tries to require a new symbol after document load,
+ // something has gone terribly wrong. Doing a document.write would
+ // wipe out the page. This does not apply to the CSP-compliant method
+ // of writing script tags.
+ if (!goog.ENABLE_CHROME_APP_SAFE_SCRIPT_LOADING &&
+ doc.readyState == 'complete') {
+ // Certain test frameworks load base.js multiple times, which tries
+ // to write deps.js each time. If that happens, just fail silently.
+ // These frameworks wipe the page between each load of base.js, so this
+ // is OK.
+ var isDeps = /\bdeps.js$/.test(src);
+ if (isDeps) {
+ return false;
+ } else {
+ throw Error('Cannot write "' + src + '" after document load');
+ if (opt_sourceText === undefined) {
+ if (!goog.IS_OLD_IE_) {
+ if (goog.ENABLE_CHROME_APP_SAFE_SCRIPT_LOADING) {
+ goog.appendScriptSrcNode_(src);
+ } else {
+ goog.writeScriptSrcNode_(src);
+ } else {
+ var state = ' onreadystatechange=\'goog.onScriptLoad_(this, ' +
+ ++goog.lastNonModuleScriptIndex_ + ')\' ';
+ doc.write(
+ '<script type="text/javascript" src="' + src + '"' + state +
+ 'script>');
+ } else {
+ doc.write(
+ '<script type="text/javascript">' +
+ goog.protectScriptTag_(opt_sourceText) + '</' +
+ 'script>');
+ return true;
+ } else {
+ return false;
+ * Rewrites closing script tags in input to avoid ending an enclosing script
+ * tag.
+ * @param {string} str
+ * @private
+ goog.protectScriptTag_ = function(str) {
+ return str.replace(/<\/(SCRIPT)/ig, '\\x3c\\$1');
+ * Determines whether the given language needs to be transpiled.
+ * @param {string} lang
+ * @private
+ goog.needsTranspile_ = function(lang) {
+ if (goog.TRANSPILE == 'always') {
+ return true;
+ } else if (goog.TRANSPILE == 'never') {
+ return false;
+ } else if (!goog.requiresTranspilation_) {
+ goog.requiresTranspilation_ = goog.createRequiresTranspilation_();
+ if (lang in goog.requiresTranspilation_) {
+ return goog.requiresTranspilation_[lang];
+ } else {
+ throw new Error('Unknown language mode: ' + lang);
+ /** @private {?Object<string, boolean>} */
+ goog.requiresTranspilation_ = null;
+ /** @private {number} */
+ goog.lastNonModuleScriptIndex_ = 0;
+ * A readystatechange handler for legacy IE
+ * @param {!HTMLScriptElement} script
+ * @param {number} scriptIndex
+ * @private
+ goog.onScriptLoad_ = function(script, scriptIndex) {
+ // for now load the modules when we reach the last script,
+ // later allow more inter-mingling.
+ if (script.readyState == 'complete' &&
+ goog.lastNonModuleScriptIndex_ == scriptIndex) {
+ goog.loadQueuedModules_();
+ return true;
+ * Resolves dependencies based on the dependencies added using addDependency
+ * and calls importScript_ in the correct order.
+ * @param {string} pathToLoad The path from which to start discovering
+ * dependencies.
+ * @private
+ goog.writeScripts_ = function(pathToLoad) {
+ /** @type {!Array<string>} The scripts we need to write this time. */
+ var scripts = [];
+ var seenScript = {};
+ /** @param {string} path */
+ function visitNode(path) {
+ if (path in deps.written) {
+ return;
+ // We have already visited this one. We can get here if we have cyclic
+ // dependencies.
+ if (path in deps.visited) {
+ return;
+ deps.visited[path] = true;
+ if (path in deps.requires) {
+ for (var requireName in deps.requires[path]) {
+ // If the required name is defined, we assume that it was already
+ // bootstrapped by other means.
+ if (!goog.isProvided_(requireName)) {
+ if (requireName in deps.nameToPath) {
+ visitNode(deps.nameToPath[requireName]);
+ } else {
+ throw Error('Undefined nameToPath for ' + requireName);
+ if (!(path in seenScript)) {
+ seenScript[path] = true;
+ scripts.push(path);
+ visitNode(pathToLoad);
+ // record that we are going to load all these scripts.
+ for (var i = 0; i < scripts.length; i++) {
+ var path = scripts[i];
+ goog.dependencies_.written[path] = true;
+ // If a module is loaded synchronously then we need to
+ // clear the current inModuleLoader value, and restore it when we are
+ // done loading the current "requires".
+ var moduleState = goog.moduleLoaderState_;
+ goog.moduleLoaderState_ = null;
+ if (path) {
+ var loadFlags = deps.loadFlags[path] || {};
+ var needsTranspile = goog.needsTranspile_(languageLevel);
+ if (loadFlags['module'] == 'goog' || needsTranspile) {
+ goog.importProcessedScript_(
+ goog.basePath + path, loadFlags['module'] == 'goog',
+ needsTranspile);
+ } else {
+ goog.importScript_(goog.basePath + path);
+ } else {
+ goog.moduleLoaderState_ = moduleState;
+ throw Error('Undefined script input');
+ // restore the current "module loading state"
+ * Looks at the dependency rules and tries to determine the script file that
+ * fulfills a particular rule.
+ * @param {string} rule In the form goog.namespace.Class or project.script.
+ * @return {?string} Url corresponding to the rule, or null.
+ * @private
+ goog.getPathFromDeps_ = function(rule) {
+ if (rule in goog.dependencies_.nameToPath) {
+ return goog.dependencies_.nameToPath[rule];
+ } else {
+ return null;
+ goog.findBasePath_();
+ // Allow projects to manage the deps files themselves.
+ if (!goog.global.CLOSURE_NO_DEPS) {
+ goog.importScript_(goog.basePath + 'deps.js');
+ * @package {?boolean}
+ * Visible for testing.
+goog.hasBadLetScoping = null;
+ * @package Visible for testing.
+goog.useSafari10Workaround = function() {
+ if (goog.hasBadLetScoping == null) {
+ var hasBadLetScoping;
+ try {
+ hasBadLetScoping = !eval(
+ '"use strict";' +
+ 'let x = 1; function f() { return typeof x; };' +
+ 'f() == "number";');
+ } catch (e) {
+ // Assume that ES6 syntax isn't supported.
+ hasBadLetScoping = false;
+ goog.hasBadLetScoping = hasBadLetScoping;
+ return goog.hasBadLetScoping;
+ * @param {string} moduleDef
+goog.workaroundSafari10EvalBug = function(moduleDef) {
+ return '(function(){' + moduleDef +
+ '\n' + // Terminate any trailing single line comment.
+ ';' + // Terminate any trailing expression.
+ '})();\n';
+ * @param {function(?):?|string} moduleDef The module definition.
+goog.loadModule = function(moduleDef) {
+ // NOTE: we allow function definitions to be either in the from
+ // of a string to eval (which keeps the original source intact) or
+ // in a eval forbidden environment (CSP) we allow a function definition
+ // which in its body must call {@code goog.module}, and return the exports
+ // of the module.
+ var previousState = goog.moduleLoaderState_;
+ try {
+ goog.moduleLoaderState_ = {
+ moduleName: undefined,
+ declareLegacyNamespace: false
+ var exports;
+ if (goog.isFunction(moduleDef)) {
+ exports = moduleDef.call(undefined, {});
+ } else if (goog.isString(moduleDef)) {
+ if (goog.useSafari10Workaround()) {
+ moduleDef = goog.workaroundSafari10EvalBug(moduleDef);
+ exports = goog.loadModuleFromSource_.call(undefined, moduleDef);
+ } else {
+ throw Error('Invalid module definition');
+ var moduleName = goog.moduleLoaderState_.moduleName;
+ if (!goog.isString(moduleName) || !moduleName) {
+ throw Error('Invalid module name \"' + moduleName + '\"');
+ // Don't seal legacy namespaces as they may be uses as a parent of
+ // another namespace
+ if (goog.moduleLoaderState_.declareLegacyNamespace) {
+ goog.constructNamespace_(moduleName, exports);
+ } else if (
+ goog.SEAL_MODULE_EXPORTS && Object.seal && typeof exports == 'object' &&
+ exports != null) {
+ Object.seal(exports);
+ goog.loadedModules_[moduleName] = exports;
+ } finally {
+ goog.moduleLoaderState_ = previousState;
+ * @private @const {function(string):?}
+ * The new type inference warns because this function has no formal
+ * parameters, but its jsdoc says that it takes one argument.
+ * (The argument is used via arguments[0], but NTI does not detect this.)
+ * @suppress {newCheckTypes}
+goog.loadModuleFromSource_ = function() {
+ // NOTE: we avoid declaring parameters or local variables here to avoid
+ // masking globals or leaking values into the module definition.
+ 'use strict';
+ var exports = {};
+ eval(arguments[0]);
+ return exports;
+ * Normalize a file path by removing redundant ".." and extraneous "." file
+ * path components.
+ * @private
+goog.normalizePath_ = function(path) {
+ var components = path.split('/');
+ var i = 0;
+ while (i < components.length) {
+ if (components[i] == '.') {
+ components.splice(i, 1);
+ } else if (
+ i && components[i] == '..' && components[i - 1] &&
+ components[i - 1] != '..') {
+ components.splice(--i, 2);
+ } else {
+ i++;
+ return components.join('/');
+ * Loads file by synchronous XHR. Should not be used in production environments.
+ * @param {string} src Source URL.
+ * @return {?string} File contents, or null if load failed.
+ * @private
+goog.loadFileSync_ = function(src) {
+ if (goog.global.CLOSURE_LOAD_FILE_SYNC) {
+ return goog.global.CLOSURE_LOAD_FILE_SYNC(src);
+ } else {
+ try {
+ /** @type {XMLHttpRequest} */
+ var xhr = new goog.global['XMLHttpRequest']();
+ xhr.open('get', src, false);
+ xhr.send();
+ // NOTE: Successful http: requests have a status of 200, but successful
+ // file: requests may have a status of zero. Any other status, or a
+ // thrown exception (particularly in case of file: requests) indicates
+ // some sort of error, which we treat as a missing or unavailable file.
+ return xhr.status == 0 || xhr.status == 200 ? xhr.responseText : null;
+ } catch (err) {
+ // No need to rethrow or log, since errors should show up on their own.
+ return null;
+ * Retrieve and execute a script that needs some sort of wrapping.
+ * @param {boolean} isModule Whether to load as a module.
+ * @param {boolean} needsTranspile Whether to transpile down to ES3.
+ * @private
+goog.retrieveAndExec_ = function(src, isModule, needsTranspile) {
+ if (!COMPILED) {
+ // The full but non-canonicalized URL for later use.
+ var originalPath = src;
+ // Canonicalize the path, removing any /./ or /../ since Chrome's debugging
+ // console doesn't auto-canonicalize XHR loads as it does <script> srcs.
+ src = goog.normalizePath_(src);
+ var scriptText = goog.loadFileSync_(src);
+ if (scriptText == null) {
+ throw new Error('Load of "' + src + '" failed');
+ if (needsTranspile) {
+ scriptText = goog.transpile_.call(goog.global, scriptText, src);
+ if (isModule) {
+ scriptText = goog.wrapModule_(src, scriptText);
+ } else {
+ scriptText += '\n//# sourceURL=' + src;
+ var isOldIE = goog.IS_OLD_IE_;
+ if (isOldIE) {
+ goog.dependencies_.deferred[originalPath] = scriptText;
+ goog.queuedModules_.push(originalPath);
+ } else {
+ importScript(src, scriptText);
+ * Lazily retrieves the transpiler and applies it to the source.
+ * @param {string} code JS code.
+ * @param {string} path Path to the code.
+ * @return {string} The transpiled code.
+ * @private
+goog.transpile_ = function(code, path) {
+ var jscomp = goog.global['$jscomp'];
+ if (!jscomp) {
+ goog.global['$jscomp'] = jscomp = {};
+ var transpile = jscomp.transpile;
+ if (!transpile) {
+ var transpilerPath = goog.basePath + goog.TRANSPILER;
+ var transpilerCode = goog.loadFileSync_(transpilerPath);
+ if (transpilerCode) {
+ // This must be executed synchronously, since by the time we know we
+ // need it, we're about to load and write the ES6 code synchronously,
+ // so a normal script-tag load will be too slow.
+ eval(transpilerCode + '\n//# sourceURL=' + transpilerPath);
+ // Even though the transpiler is optional, if $gwtExport is found, it's
+ // a sign the transpiler was loaded and the $jscomp.transpile *should*
+ // be there.
+ if (goog.global['$gwtExport'] && goog.global['$gwtExport']['$jscomp'] &&
+ !goog.global['$gwtExport']['$jscomp']['transpile']) {
+ throw new Error(
+ 'The transpiler did not properly export the "transpile" ' +
+ 'method. $gwtExport: ' + JSON.stringify(goog.global['$gwtExport']));
+ // transpile.js only exports a single $jscomp function, transpile. We
+ // grab just that and add it to the existing definition of $jscomp which
+ // contains the polyfills.
+ goog.global['$jscomp'].transpile =
+ goog.global['$gwtExport']['$jscomp']['transpile'];
+ jscomp = goog.global['$jscomp'];
+ transpile = jscomp.transpile;
+ if (!transpile) {
+ // The transpiler is an optional component. If it's not available then
+ // replace it with a pass-through function that simply logs.
+ var suffix = ' requires transpilation but no transpiler was found.';
+ transpile = jscomp.transpile = function(code, path) {
+ // TODO(user): figure out some way to get this error to show up
+ // in test results, noting that the failure may occur in many
+ // different ways, including in loadModule() before the test
+ // runner even comes up.
+ goog.logToConsole_(path + suffix);
+ return code;
+ // Note: any transpilation errors/warnings will be logged to the console.
+ return transpile(code, path);
+// Language Enhancements
+ * This is a "fixed" version of the typeof operator. It differs from the typeof
+ * operator in such a way that null returns 'null' and arrays return 'array'.
+ * @param {?} value The value to get the type of.
+ * @return {string} The name of the type.
+goog.typeOf = function(value) {
+ var s = typeof value;
+ if (s == 'object') {
+ if (value) {
+ // Check these first, so we can avoid calling Object.prototype.toString if
+ // possible.
+ // IE improperly marshals typeof across execution contexts, but a
+ // cross-context object will still return false for "instanceof Object".
+ if (value instanceof Array) {
+ return 'array';
+ } else if (value instanceof Object) {
+ return s;
+ // HACK: In order to use an Object prototype method on the arbitrary
+ // value, the compiler requires the value be cast to type Object,
+ // even though the ECMA spec explicitly allows it.
+ var className = Object.prototype.toString.call(
+ /** @type {!Object} */ (value));
+ // In Firefox 3.6, attempting to access iframe window objects' length
+ // property throws an NS_ERROR_FAILURE, so we need to special-case it
+ // here.
+ if (className == '[object Window]') {
+ return 'object';
+ // We cannot always use constructor == Array or instanceof Array because
+ // different frames have different Array objects. In IE6, if the iframe
+ // where the array was created is destroyed, the array loses its
+ // prototype. Then dereferencing val.splice here throws an exception, so
+ // we can't use goog.isFunction. Calling typeof directly returns 'unknown'
+ // so that will work. In this case, this function will return false and
+ // most array functions will still work because the array is still
+ // array-like (supports length and []) even though it has lost its
+ // prototype.
+ // Mark Miller noticed that Object.prototype.toString
+ // allows access to the unforgeable [[Class]] property.
+ // 15.2.4.2 Object.prototype.toString ( )
+ // When the toString method is called, the following steps are taken:
+ // 1. Get the [[Class]] property of this object.
+ // 2. Compute a string value by concatenating the three strings
+ // "[object ", Result(1), and "]".
+ // 3. Return Result(2).
+ // and this behavior survives the destruction of the execution context.
+ if ((className == '[object Array]' ||
+ // In IE all non value types are wrapped as objects across window
+ // boundaries (not iframe though) so we have to do object detection
+ // for this edge case.
+ typeof value.length == 'number' &&
+ typeof value.splice != 'undefined' &&
+ typeof value.propertyIsEnumerable != 'undefined' &&
+ !value.propertyIsEnumerable('splice')
+ return 'array';
+ // HACK: There is still an array case that fails.
+ // function ArrayImpostor() {}
+ // ArrayImpostor.prototype = [];
+ // var impostor = new ArrayImpostor;
+ // this can be fixed by getting rid of the fast path
+ // (value instanceof Array) and solely relying on
+ // (value && Object.prototype.toString.vall(value) === '[object Array]')
+ // but that would require many more function calls and is not warranted
+ // unless closure code is receiving objects from untrusted sources.
+ // IE in cross-window calls does not correctly marshal the function type
+ // (it appears just as an object) so we cannot use just typeof val ==
+ // 'function'. However, if the object has a call property, it is a
+ // function.
+ if ((className == '[object Function]' ||
+ typeof value.call != 'undefined' &&
+ !value.propertyIsEnumerable('call'))) {
+ return 'function';
+ } else {
+ return 'null';
+ } else if (s == 'function' && typeof value.call == 'undefined') {
+ // In Safari typeof nodeList returns 'function', and on Firefox typeof
+ // behaves similarly for HTML{Applet,Embed,Object}, Elements and RegExps. We
+ // would like to return object for those and we can detect an invalid
+ // function by making sure that the function object has a call method.
+ return 'object';
+ return s;
+ * Returns true if the specified value is null.
+ * @return {boolean} Whether variable is null.
+goog.isNull = function(val) {
+ return val === null;
+ * Returns true if the specified value is defined and not null.
+ * @return {boolean} Whether variable is defined and not null.
+goog.isDefAndNotNull = function(val) {
+ // Note that undefined == null.
+ return val != null;
+ * Returns true if the specified value is an array.
+ * @return {boolean} Whether variable is an array.
+goog.isArray = function(val) {
+ return goog.typeOf(val) == 'array';
+ * Returns true if the object looks like an array. To qualify as array like
+ * the value needs to be either a NodeList or an object with a Number length
+ * property. As a special case, a function value is not array like, because its
+ * length property is fixed to correspond to the number of expected arguments.
+goog.isArrayLike = function(val) {
+ var type = goog.typeOf(val);
+ // We do not use goog.isObject here in order to exclude function values.
+ return type == 'array' || type == 'object' && typeof val.length == 'number';
+ * Returns true if the object looks like a Date. To qualify as Date-like the
+ * value needs to be an object and have a getFullYear() function.
+ * @return {boolean} Whether variable is a like a Date.
+goog.isDateLike = function(val) {
+ return goog.isObject(val) && typeof val.getFullYear == 'function';
+ * Returns true if the specified value is a string.
+ * @return {boolean} Whether variable is a string.
+goog.isString = function(val) {
+ return typeof val == 'string';
+ * Returns true if the specified value is a boolean.
+ * @return {boolean} Whether variable is boolean.
+goog.isBoolean = function(val) {
+ return typeof val == 'boolean';
+ * Returns true if the specified value is a number.
+ * @return {boolean} Whether variable is a number.
+goog.isNumber = function(val) {
+ return typeof val == 'number';
+ * Returns true if the specified value is a function.
+ * @return {boolean} Whether variable is a function.
+goog.isFunction = function(val) {
+ return goog.typeOf(val) == 'function';
+ * Returns true if the specified value is an object. This includes arrays and
+ * functions.
+ * @return {boolean} Whether variable is an object.
+goog.isObject = function(val) {
+ var type = typeof val;
+ return type == 'object' && val != null || type == 'function';
+ // return Object(val) === val also works, but is slower, especially if val is
+ // not an object.
+ * Gets a unique ID for an object. This mutates the object so that further calls
+ * with the same object as a parameter returns the same value. The unique ID is
+ * guaranteed to be unique across the current session amongst objects that are
+ * passed into {@code getUid}. There is no guarantee that the ID is unique or
+ * consistent across sessions. It is unsafe to generate unique ID for function
+ * prototypes.
+ * @param {Object} obj The object to get the unique ID for.
+ * @return {number} The unique ID for the object.
+goog.getUid = function(obj) {
+ // TODO(arv): Make the type stricter, do not accept null.
+ // In Opera window.hasOwnProperty exists but always returns false so we avoid
+ // using it. As a consequence the unique ID generated for BaseClass.prototype
+ // and SubClass.prototype will be the same.
+ return obj[goog.UID_PROPERTY_] ||
+ (obj[goog.UID_PROPERTY_] = ++goog.uidCounter_);
+ * Whether the given object is already assigned a unique ID.
+ * This does not modify the object.
+ * @param {!Object} obj The object to check.
+ * @return {boolean} Whether there is an assigned unique id for the object.
+goog.hasUid = function(obj) {
+ return !!obj[goog.UID_PROPERTY_];
+ * Removes the unique ID from an object. This is useful if the object was
+ * previously mutated using {@code goog.getUid} in which case the mutation is
+ * undone.
+ * @param {Object} obj The object to remove the unique ID field from.
+goog.removeUid = function(obj) {
+ // In IE, DOM nodes are not instances of Object and throw an exception if we
+ // try to delete. Instead we try to use removeAttribute.
+ if (obj !== null && 'removeAttribute' in obj) {
+ obj.removeAttribute(goog.UID_PROPERTY_);
+ /** @preserveTry */
+ try {
+ delete obj[goog.UID_PROPERTY_];
+ } catch (ex) {
+ * Name for unique ID property. Initialized in a way to help avoid collisions
+ * with other closure JavaScript on the same page.
+ * @type {string}
+ * @private
+goog.UID_PROPERTY_ = 'closure_uid_' + ((Math.random() * 1e9) >>> 0);
+ * Counter for UID.
+ * @type {number}
+ * @private
+goog.uidCounter_ = 0;
+ * Adds a hash code field to an object. The hash code is unique for the
+ * given object.
+ * @param {Object} obj The object to get the hash code for.
+ * @return {number} The hash code for the object.
+ * @deprecated Use goog.getUid instead.
+goog.getHashCode = goog.getUid;
+ * Removes the hash code field from an object.
+ * @param {Object} obj The object to remove the field from.
+ * @deprecated Use goog.removeUid instead.
+goog.removeHashCode = goog.removeUid;
+ * Clones a value. The input may be an Object, Array, or basic type. Objects and
+ * arrays will be cloned recursively.
+ * WARNINGS:
+ * <code>goog.cloneObject</code> does not detect reference loops. Objects that
+ * refer to themselves will cause infinite recursion.
+ * <code>goog.cloneObject</code> is unaware of unique identifiers, and copies
+ * UIDs created by <code>getUid</code> into cloned results.
+ * @param {*} obj The value to clone.
+ * @return {*} A clone of the input value.
+ * @deprecated goog.cloneObject is unsafe. Prefer the goog.object methods.
+goog.cloneObject = function(obj) {
+ var type = goog.typeOf(obj);
+ if (type == 'object' || type == 'array') {
+ if (obj.clone) {
+ return obj.clone();
+ var clone = type == 'array' ? [] : {};
+ for (var key in obj) {
+ clone[key] = goog.cloneObject(obj[key]);
+ return clone;
+ return obj;
+ * A native implementation of goog.bind.
+ * @param {Function} fn A function to partially apply.
+ * @param {Object|undefined} selfObj Specifies the object which this should
+ * point to when the function is run.
+ * @param {...*} var_args Additional arguments that are partially applied to the
+ * function.
+ * @return {!Function} A partially-applied form of the function bind() was
+ * invoked as a method of.
+ * @private
+ * @suppress {deprecated} The compiler thinks that Function.prototype.bind is
+ * deprecated because some people have declared a pure-JS version.
+ * Only the pure-JS version is truly deprecated.
+goog.bindNative_ = function(fn, selfObj, var_args) {
+ return /** @type {!Function} */ (fn.call.apply(fn.bind, arguments));
+ * A pure-JS implementation of goog.bind.
+ * function.
+ * @private
+goog.bindJs_ = function(fn, selfObj, var_args) {
+ if (!fn) {
+ throw new Error();
+ if (arguments.length > 2) {
+ var boundArgs = Array.prototype.slice.call(arguments, 2);
+ return function() {
+ // Prepend the bound arguments to the current arguments.
+ var newArgs = Array.prototype.slice.call(arguments);
+ Array.prototype.unshift.apply(newArgs, boundArgs);
+ return fn.apply(selfObj, newArgs);
+ } else {
+ return fn.apply(selfObj, arguments);
+ * Partially applies this function to a particular 'this object' and zero or
+ * more arguments. The result is a new function with some arguments of the first
+ * function pre-filled and the value of this 'pre-specified'.
+ * Remaining arguments specified at call-time are appended to the pre-specified
+ * ones.
+ * Also see: {@link #partial}.
+ * Usage:
+ * <pre>var barMethBound = goog.bind(myFunction, myObj, 'arg1', 'arg2');
+ * barMethBound('arg3', 'arg4');</pre>
+ * @param {?function(this:T, ...)} fn A function to partially apply.
+ * @param {T} selfObj Specifies the object which this should point to when the
+ * function is run.
+ * function.
+ * @return {!Function} A partially-applied form of the function goog.bind() was
+ * @template T
+ * @suppress {deprecated} See above.
+goog.bind = function(fn, selfObj, var_args) {
+ // TODO(nicksantos): narrow the type signature.
+ if (Function.prototype.bind &&
+ // NOTE(nicksantos): Somebody pulled base.js into the default Chrome
+ // extension environment. This means that for Chrome extensions, they get
+ // the implementation of Function.prototype.bind that calls goog.bind
+ // instead of the native one. Even worse, we don't want to introduce a
+ // circular dependency between goog.bind and Function.prototype.bind, so
+ // we have to hack this to make sure it works correctly.
+ Function.prototype.bind.toString().indexOf('native code') != -1) {
+ goog.bind = goog.bindNative_;
+ } else {
+ goog.bind = goog.bindJs_;
+ return goog.bind.apply(null, arguments);
+ * Like goog.bind(), except that a 'this object' is not required. Useful when
+ * the target function is already bound.
+ * Usage:
+ * var g = goog.partial(f, arg1, arg2);
+ * g(arg3, arg4);
+ * @param {...*} var_args Additional arguments that are partially applied to fn.
+ * @return {!Function} A partially-applied form of the function goog.partial()
+ * was invoked as a method of.
+goog.partial = function(fn, var_args) {
+ var args = Array.prototype.slice.call(arguments, 1);
+ // Clone the array (with slice()) and append additional arguments
+ // to the existing arguments.
+ var newArgs = args.slice();
+ newArgs.push.apply(newArgs, arguments);
+ return fn.apply(this, newArgs);
+ * Copies all the members of a source object to a target object. This method
+ * does not work on all browsers for all objects that contain keys such as
+ * toString or hasOwnProperty. Use goog.object.extend for this purpose.
+ * @param {Object} target Target.
+ * @param {Object} source Source.
+goog.mixin = function(target, source) {
+ for (var x in source) {
+ target[x] = source[x];
+ // For IE7 or lower, the for-in-loop does not contain any properties that are
+ // not enumerable on the prototype object (for example, isPrototypeOf from
+ // Object.prototype) but also it will not include 'replace' on objects that
+ // extend String and change 'replace' (not that it is common for anyone to
+ // extend anything except Object).
+ * @return {number} An integer value representing the number of milliseconds
+ * between midnight, January 1, 1970 and the current time.
+goog.now = (goog.TRUSTED_SITE && Date.now) || (function() {
+ // Unary plus operator converts its operand to a number which in
+ // the case of
+ // a date is done by calling getTime().
+ return +new Date();
+ * Evals JavaScript in the global scope. In IE this uses execScript, other
+ * browsers use goog.global.eval. If goog.global.eval does not evaluate in the
+ * global scope (for example, in Safari), appends a script tag instead.
+ * Throws an exception if neither execScript or eval is defined.
+ * @param {string} script JavaScript string.
+goog.globalEval = function(script) {
+ if (goog.global.execScript) {
+ goog.global.execScript(script, 'JavaScript');
+ } else if (goog.global.eval) {
+ // Test to see if eval works
+ if (goog.evalWorksForGlobals_ == null) {
+ goog.global.eval('var _evalTest_ = 1;');
+ if (typeof goog.global['_evalTest_'] != 'undefined') {
+ try {
+ delete goog.global['_evalTest_'];
+ } catch (ignore) {
+ // Microsoft edge fails the deletion above in strict mode.
+ goog.evalWorksForGlobals_ = true;
+ } else {
+ goog.evalWorksForGlobals_ = false;
+ if (goog.evalWorksForGlobals_) {
+ goog.global.eval(script);
+ } else {
+ var scriptElt =
+ /** @type {!HTMLScriptElement} */ (doc.createElement('SCRIPT'));
+ scriptElt.type = 'text/javascript';
+ scriptElt.defer = false;
+ // Note(user): can't use .innerHTML since "t('<test>')" will fail and
+ // .text doesn't work in Safari 2. Therefore we append a text node.
+ scriptElt.appendChild(doc.createTextNode(script));
+ doc.body.appendChild(scriptElt);
+ doc.body.removeChild(scriptElt);
+ } else {
+ throw Error('goog.globalEval not available');
+ * Indicates whether or not we can call 'eval' directly to eval code in the
+ * global scope. Set to a Boolean by the first call to goog.globalEval (which
+ * empirically tests whether eval works for globals). @see goog.globalEval
+ * @type {?boolean}
+ * @private
+goog.evalWorksForGlobals_ = null;
+ * Optional map of CSS class names to obfuscated names used with
+ * goog.getCssName().
+ * @private {!Object<string, string>|undefined}
+ * @see goog.setCssNameMapping
+goog.cssNameMapping_;
+ * Optional obfuscation style for CSS class names. Should be set to either
+ * 'BY_WHOLE' or 'BY_PART' if defined.
+ * @private
+goog.cssNameMappingStyle_;
+ * Handles strings that are intended to be used as CSS class names.
+ * This function works in tandem with @see goog.setCssNameMapping.
+ * Without any mapping set, the arguments are simple joined with a hyphen and
+ * passed through unaltered.
+ * When there is a mapping, there are two possible styles in which these
+ * mappings are used. In the BY_PART style, each part (i.e. in between hyphens)
+ * of the passed in css name is rewritten according to the map. In the BY_WHOLE
+ * style, the full css name is looked up in the map directly. If a rewrite is
+ * not specified by the map, the compiler will output a warning.
+ * When the mapping is passed to the compiler, it will replace calls to
+ * goog.getCssName with the strings from the mapping, e.g.
+ * var x = goog.getCssName('foo');
+ * var y = goog.getCssName(this.baseClass, 'active');
+ * becomes:
+ * var x = 'foo';
+ * var y = this.baseClass + '-active';
+ * If one argument is passed it will be processed, if two are passed only the
+ * modifier will be processed, as it is assumed the first argument was generated
+ * as a result of calling goog.getCssName.
+ * @param {string} className The class name.
+ * @param {string=} opt_modifier A modifier to be appended to the class name.
+ * @return {string} The class name or the concatenation of the class name and
+ * the modifier.
+goog.getCssName = function(className, opt_modifier) {
+ // String() is used for compatibility with compiled soy where the passed
+ // className can be non-string objects.
+ if (String(className).charAt(0) == '.') {
+ throw new Error(
+ 'className passed in goog.getCssName must not start with ".".' +
+ ' You passed: ' + className);
+ var getMapping = function(cssName) {
+ return goog.cssNameMapping_[cssName] || cssName;
+ var renameByParts = function(cssName) {
+ // Remap all the parts individually.
+ var parts = cssName.split('-');
+ var mapped = [];
+ for (var i = 0; i < parts.length; i++) {
+ mapped.push(getMapping(parts[i]));
+ return mapped.join('-');
+ var rename;
+ if (goog.cssNameMapping_) {
+ rename =
+ goog.cssNameMappingStyle_ == 'BY_WHOLE' ? getMapping : renameByParts;
+ } else {
+ rename = function(a) {
+ return a;
+ var result =
+ opt_modifier ? className + '-' + rename(opt_modifier) : rename(className);
+ // The special CLOSURE_CSS_NAME_MAP_FN allows users to specify further
+ // processing of the class name.
+ if (goog.global.CLOSURE_CSS_NAME_MAP_FN) {
+ return goog.global.CLOSURE_CSS_NAME_MAP_FN(result);
+ return result;
+ * Sets the map to check when returning a value from goog.getCssName(). Example:
+ * <pre>
+ * goog.setCssNameMapping({
+ * "goog": "a",
+ * "disabled": "b",
+ * var x = goog.getCssName('goog');
+ * // The following evaluates to: "a a-b".
+ * goog.getCssName('goog') + ' ' + goog.getCssName(x, 'disabled')
+ * </pre>
+ * When declared as a map of string literals to string literals, the JSCompiler
+ * will replace all calls to goog.getCssName() using the supplied map if the
+ * --process_closure_primitives flag is set.
+ * @param {!Object} mapping A map of strings to strings where keys are possible
+ * arguments to goog.getCssName() and values are the corresponding values
+ * that should be returned.
+ * @param {string=} opt_style The style of css name mapping. There are two valid
+ * options: 'BY_PART', and 'BY_WHOLE'.
+ * @see goog.getCssName for a description.
+goog.setCssNameMapping = function(mapping, opt_style) {
+ goog.cssNameMapping_ = mapping;
+ goog.cssNameMappingStyle_ = opt_style;
+ * To use CSS renaming in compiled mode, one of the input files should have a
+ * call to goog.setCssNameMapping() with an object literal that the JSCompiler
+ * can extract and use to replace all calls to goog.getCssName(). In uncompiled
+ * mode, JavaScript code should be loaded before this base.js file that declares
+ * a global variable, CLOSURE_CSS_NAME_MAPPING, which is used below. This is
+ * to ensure that the mapping is loaded before any calls to goog.getCssName()
+ * are made in uncompiled mode.
+ * A hook for overriding the CSS name mapping.
+ * @type {!Object<string, string>|undefined}
+goog.global.CLOSURE_CSS_NAME_MAPPING;
+if (!COMPILED && goog.global.CLOSURE_CSS_NAME_MAPPING) {
+ // This does not call goog.setCssNameMapping() because the JSCompiler
+ // requires that goog.setCssNameMapping() be called with an object literal.
+ goog.cssNameMapping_ = goog.global.CLOSURE_CSS_NAME_MAPPING;
+ * Gets a localized message.
+ * This function is a compiler primitive. If you give the compiler a localized
+ * message bundle, it will replace the string at compile-time with a localized
+ * version, and expand goog.getMsg call to a concatenated string.
+ * Messages must be initialized in the form:
+ * <code>
+ * var MSG_NAME = goog.getMsg('Hello {$placeholder}', {'placeholder': 'world'});
+ * </code>
+ * This function produces a string which should be treated as plain text. Use
+ * {@link goog.html.SafeHtmlFormatter} in conjunction with goog.getMsg to
+ * produce SafeHtml.
+ * @param {string} str Translatable string, places holders in the form {$foo}.
+ * @param {Object<string, string>=} opt_values Maps place holder name to value.
+ * @return {string} message with placeholders filled.
+goog.getMsg = function(str, opt_values) {
+ if (opt_values) {
+ str = str.replace(/\{\$([^}]+)}/g, function(match, key) {
+ return (opt_values != null && key in opt_values) ? opt_values[key] :
+ match;
+ return str;
+ * Gets a localized message. If the message does not have a translation, gives a
+ * fallback message.
+ * This is useful when introducing a new message that has not yet been
+ * translated into all languages.
+ * This function is a compiler primitive. Must be used in the form:
+ * <code>var x = goog.getMsgWithFallback(MSG_A, MSG_B);</code>
+ * where MSG_A and MSG_B were initialized with goog.getMsg.
+ * @param {string} a The preferred message.
+ * @param {string} b The fallback message.
+ * @return {string} The best translated message.
+goog.getMsgWithFallback = function(a, b) {
+ return a;
+ * Exposes an unobfuscated global namespace path for the given object.
+ * Note that fields of the exported object *will* be obfuscated, unless they are
+ * exported in turn via this function or goog.exportProperty.
+ * Also handy for making public items that are defined in anonymous closures.
+ * ex. goog.exportSymbol('public.path.Foo', Foo);
+ * ex. goog.exportSymbol('public.path.Foo.staticFunction', Foo.staticFunction);
+ * public.path.Foo.staticFunction();
+ * ex. goog.exportSymbol('public.path.Foo.prototype.myMethod',
+ * Foo.prototype.myMethod);
+ * new public.path.Foo().myMethod();
+ * @param {string} publicPath Unobfuscated name to export.
+ * @param {*} object Object the name should point to.
+ * @param {Object=} opt_objectToExportTo The object to add the path to; default
+ * is goog.global.
+goog.exportSymbol = function(publicPath, object, opt_objectToExportTo) {
+ goog.exportPath_(publicPath, object, opt_objectToExportTo);
+ * Exports a property unobfuscated into the object's namespace.
+ * ex. goog.exportProperty(Foo, 'staticFunction', Foo.staticFunction);
+ * ex. goog.exportProperty(Foo.prototype, 'myMethod', Foo.prototype.myMethod);
+ * @param {Object} object Object whose static property is being exported.
+ * @param {string} publicName Unobfuscated name to export.
+ * @param {*} symbol Object the name should point to.
+goog.exportProperty = function(object, publicName, symbol) {
+ object[publicName] = symbol;
+ * Inherit the prototype methods from one constructor into another.
+ * Usage:
+ * <pre>
+ * function ParentClass(a, b) { }
+ * ParentClass.prototype.foo = function(a) { };
+ * function ChildClass(a, b, c) {
+ * ChildClass.base(this, 'constructor', a, b);
+ * goog.inherits(ChildClass, ParentClass);
+ * var child = new ChildClass('a', 'b', 'see');
+ * child.foo(); // This works.
+ * </pre>
+ * @param {!Function} childCtor Child class.
+ * @param {!Function} parentCtor Parent class.
+goog.inherits = function(childCtor, parentCtor) {
+ /** @constructor */
+ function tempCtor() {}
+ tempCtor.prototype = parentCtor.prototype;
+ childCtor.superClass_ = parentCtor.prototype;
+ childCtor.prototype = new tempCtor();
+ /** @override */
+ childCtor.prototype.constructor = childCtor;
+ * Calls superclass constructor/method.
+ * This function is only available if you use goog.inherits to
+ * express inheritance relationships between classes.
+ * NOTE: This is a replacement for goog.base and for superClass_
+ * property defined in childCtor.
+ * @param {!Object} me Should always be "this".
+ * @param {string} methodName The method name to call. Calling
+ * superclass constructor can be done with the special string
+ * 'constructor'.
+ * @param {...*} var_args The arguments to pass to superclass
+ * method/constructor.
+ * @return {*} The return value of the superclass method/constructor.
+ childCtor.base = function(me, methodName, var_args) {
+ // Copying using loop to avoid deop due to passing arguments object to
+ // function. This is faster in many JS engines as of late 2014.
+ var args = new Array(arguments.length - 2);
+ for (var i = 2; i < arguments.length; i++) {
+ args[i - 2] = arguments[i];
+ return parentCtor.prototype[methodName].apply(me, args);
+ * Call up to the superclass.
+ * If this is called from a constructor, then this calls the superclass
+ * constructor with arguments 1-N.
+ * If this is called from a prototype method, then you must pass the name of the
+ * method as the second argument to this function. If you do not, you will get a
+ * runtime error. This calls the superclass' method with arguments 2-N.
+ * This function only works if you use goog.inherits to express inheritance
+ * relationships between your classes.
+ * This function is a compiler primitive. At compile-time, the compiler will do
+ * macro expansion to remove a lot of the extra overhead that this function
+ * introduces. The compiler will also enforce a lot of the assumptions that this
+ * function makes, and treat it as a compiler error if you break them.
+ * @param {*=} opt_methodName The method name if calling a super method.
+ * @param {...*} var_args The rest of the arguments.
+ * @return {*} The return value of the superclass method.
+ * @suppress {es5Strict} This method can not be used in strict mode, but
+ * all Closure Library consumers must depend on this file.
+goog.base = function(me, opt_methodName, var_args) {
+ var caller = arguments.callee.caller;
+ if (goog.STRICT_MODE_COMPATIBLE || (goog.DEBUG && !caller)) {
+ throw Error(
+ 'arguments.caller not defined. goog.base() cannot be used ' +
+ 'with strict mode code. See ' +
+ 'http://www.ecma-international.org/ecma-262/5.1/#sec-C');
+ if (caller.superClass_) {
+ var ctorArgs = new Array(arguments.length - 1);
+ for (var i = 1; i < arguments.length; i++) {
+ ctorArgs[i - 1] = arguments[i];
+ // This is a constructor. Call the superclass constructor.
+ return caller.superClass_.constructor.apply(me, ctorArgs);
+ var foundCaller = false;
+ for (var ctor = me.constructor; ctor;
+ ctor = ctor.superClass_ && ctor.superClass_.constructor) {
+ if (ctor.prototype[opt_methodName] === caller) {
+ foundCaller = true;
+ } else if (foundCaller) {
+ return ctor.prototype[opt_methodName].apply(me, args);
+ // If we did not find the caller in the prototype chain, then one of two
+ // things happened:
+ // 1) The caller is an instance method.
+ // 2) This method was not called by the right caller.
+ if (me[opt_methodName] === caller) {
+ return me.constructor.prototype[opt_methodName].apply(me, args);
+ } else {
+ throw Error(
+ 'goog.base called from a method of one name ' +
+ 'to a method of a different name');
+ * Allow for aliasing within scope functions. This function exists for
+ * uncompiled code - in compiled code the calls will be inlined and the aliases
+ * applied. In uncompiled code the function is simply run since the aliases as
+ * written are valid JavaScript.
+ * @param {function()} fn Function to call. This function can contain aliases
+ * to namespaces (e.g. "var dom = goog.dom") or classes
+ * (e.g. "var Timer = goog.Timer").
+goog.scope = function(fn) {
+ if (goog.isInModuleLoader_()) {
+ throw Error('goog.scope is not supported within a goog.module.');
+ fn.call(goog.global);
+ * To support uncompiled, strict mode bundles that use eval to divide source
+ * like so:
+ * eval('someSource;//# sourceUrl sourcefile.js');
+ * We need to export the globally defined symbols "goog" and "COMPILED".
+ * Exporting "goog" breaks the compiler optimizations, so we required that
+ * be defined externally.
+ * NOTE: We don't use goog.exportSymbol here because we don't want to trigger
+ * extern generation when that compiler option is enabled.
+if (!COMPILED) {
+ goog.global['COMPILED'] = COMPILED;
+// goog.defineClass implementation
+ * Creates a restricted form of a Closure "class":
+ * - from the compiler's perspective, the instance returned from the
+ * constructor is sealed (no new properties may be added). This enables
+ * better checks.
+ * - the compiler will rewrite this definition to a form that is optimal
+ * for type checking and optimization (initially this will be a more
+ * traditional form).
+ * @param {Function} superClass The superclass, Object or null.
+ * @param {goog.defineClass.ClassDescriptor} def
+ * An object literal describing
+ * the class. It may have the following properties:
+ * "constructor": the constructor function
+ * "statics": an object literal containing methods to add to the constructor
+ * as "static" methods or a function that will receive the constructor
+ * function as its only parameter to which static properties can
+ * be added.
+ * all other properties are added to the prototype.
+ * @return {!Function} The class constructor.
+goog.defineClass = function(superClass, def) {
+ // TODO(johnlenz): consider making the superClass an optional parameter.
+ var constructor = def.constructor;
+ var statics = def.statics;
+ // Wrap the constructor prior to setting up the prototype and static methods.
+ if (!constructor || constructor == Object.prototype.constructor) {
+ constructor = function() {
+ throw Error('cannot instantiate an interface (no constructor defined).');
+ var cls = goog.defineClass.createSealingConstructor_(constructor, superClass);
+ if (superClass) {
+ goog.inherits(cls, superClass);
+ // Remove all the properties that should not be copied to the prototype.
+ delete def.constructor;
+ delete def.statics;
+ goog.defineClass.applyProperties_(cls.prototype, def);
+ if (statics != null) {
+ if (statics instanceof Function) {
+ statics(cls);
+ } else {
+ goog.defineClass.applyProperties_(cls, statics);
+ return cls;
+ * @typedef {{
+ * constructor: (!Function|undefined),
+ * statics: (Object|undefined|function(Function):void)
+goog.defineClass.ClassDescriptor;
+ * @define {boolean} Whether the instances returned by goog.defineClass should
+ * be sealed when possible.
+ * When sealing is disabled the constructor function will not be wrapped by
+ * goog.defineClass, making it incompatible with ES6 class methods.
+goog.define('goog.defineClass.SEAL_CLASS_INSTANCES', goog.DEBUG);
+ * If goog.defineClass.SEAL_CLASS_INSTANCES is enabled and Object.seal is
+ * defined, this function will wrap the constructor in a function that seals the
+ * results of the provided constructor function.
+ * @param {!Function} ctr The constructor whose results maybe be sealed.
+ * @param {Function} superClass The superclass constructor.
+ * @return {!Function} The replacement constructor.
+ * @private
+goog.defineClass.createSealingConstructor_ = function(ctr, superClass) {
+ if (!goog.defineClass.SEAL_CLASS_INSTANCES) {
+ // Do now wrap the constructor when sealing is disabled. Angular code
+ // depends on this for injection to work properly.
+ return ctr;
+ // Compute whether the constructor is sealable at definition time, rather
+ // than when the instance is being constructed.
+ var superclassSealable = !goog.defineClass.isUnsealable_(superClass);
+ * @this {Object}
+ * @return {?}
+ var wrappedCtr = function() {
+ // Don't seal an instance of a subclass when it calls the constructor of
+ // its super class as there is most likely still setup to do.
+ var instance = ctr.apply(this, arguments) || this;
+ instance[goog.UID_PROPERTY_] = instance[goog.UID_PROPERTY_];
+ if (this.constructor === wrappedCtr && superclassSealable &&
+ Object.seal instanceof Function) {
+ Object.seal(instance);
+ return instance;
+ return wrappedCtr;
+ * @param {Function} ctr The constructor to test.
+ * @return {boolean} Whether the constructor has been tagged as unsealable
+ * using goog.tagUnsealableClass.
+ * @private
+goog.defineClass.isUnsealable_ = function(ctr) {
+ return ctr && ctr.prototype &&
+ ctr.prototype[goog.UNSEALABLE_CONSTRUCTOR_PROPERTY_];
+// TODO(johnlenz): share these values with the goog.object
+ * The names of the fields that are defined on Object.prototype.
+ * @type {!Array<string>}
+ * @private
+ * @const
+goog.defineClass.OBJECT_PROTOTYPE_FIELDS_ = [
+ 'constructor', 'hasOwnProperty', 'isPrototypeOf', 'propertyIsEnumerable',
+ 'toLocaleString', 'toString', 'valueOf'
+// TODO(johnlenz): share this function with the goog.object
+ * @param {!Object} target The object to add properties to.
+ * @param {!Object} source The object to copy properties from.
+ * @private
+goog.defineClass.applyProperties_ = function(target, source) {
+ // TODO(johnlenz): update this to support ES5 getters/setters
+ var key;
+ for (key in source) {
+ if (Object.prototype.hasOwnProperty.call(source, key)) {
+ target[key] = source[key];
+ // For IE the for-in-loop does not contain any properties that are not
+ // enumerable on the prototype object (for example isPrototypeOf from
+ // Object.prototype) and it will also not include 'replace' on objects that
+ for (var i = 0; i < goog.defineClass.OBJECT_PROTOTYPE_FIELDS_.length; i++) {
+ key = goog.defineClass.OBJECT_PROTOTYPE_FIELDS_[i];
+ * Sealing classes breaks the older idiom of assigning properties on the
+ * prototype rather than in the constructor. As such, goog.defineClass
+ * must not seal subclasses of these old-style classes until they are fixed.
+ * Until then, this marks a class as "broken", instructing defineClass
+ * not to seal subclasses.
+ * @param {!Function} ctr The legacy constructor to tag as unsealable.
+goog.tagUnsealableClass = function(ctr) {
+ if (!COMPILED && goog.defineClass.SEAL_CLASS_INSTANCES) {
+ ctr.prototype[goog.UNSEALABLE_CONSTRUCTOR_PROPERTY_] = true;
+ * Name for unsealable tag property.
+ * @const @private {string}
+goog.UNSEALABLE_CONSTRUCTOR_PROPERTY_ = 'goog_defineClass_legacy_unsealable';
+ * Returns a newly created map from language mode string to a boolean
+ * indicating whether transpilation should be done for that mode.
+ * Guaranteed invariant:
+ * For any two modes, l1 and l2 where l2 is a newer mode than l1,
+ * `map[l1] == true` implies that `map[l2] == true`.
+ * @private
+ * @return {!Object<string, boolean>}
+goog.createRequiresTranspilation_ = function() {
+ var /** !Object<string, boolean> */ requiresTranspilation = {'es3': false};
+ var transpilationRequiredForAllLaterModes = false;
+ * Adds an entry to requiresTranspliation for the given language mode.
+ * IMPORTANT: Calls must be made in order from oldest to newest language
+ * mode.
+ * @param {string} modeName
+ * @param {function(): boolean} isSupported Returns true if the JS engine
+ * supports the given mode.
+ function addNewerLanguageTranspilationCheck(modeName, isSupported) {
+ if (transpilationRequiredForAllLaterModes) {
+ requiresTranspilation[modeName] = true;
+ } else if (isSupported()) {
+ requiresTranspilation[modeName] = false;
+ } else {
+ transpilationRequiredForAllLaterModes = true;
+ * Does the given code evaluate without syntax errors and return a truthy
+ * result?
+ function /** boolean */ evalCheck(/** string */ code) {
+ try {
+ return !!eval(code);
+ } catch (ignored) {
+ return false;
+ // Identify ES3-only browsers by their incorrect treatment of commas.
+ addNewerLanguageTranspilationCheck('es5', function() {
+ return evalCheck('[1,].length==1');
+ addNewerLanguageTranspilationCheck('es6', function() {
+ // Test es6: [FF50 (?), Edge 14 (?), Chrome 50]
+ // (a) default params (specifically shadowing locals),
+ // (b) destructuring, (c) block-scoped functions,
+ // (d) for-of (const), (e) new.target/Reflect.construct
+ var es6fullTest =
+ 'class X{constructor(){if(new.target!=String)throw 1;this.x=42}}' +
+ 'let q=Reflect.construct(X,[],String);if(q.x!=42||!(q instanceof ' +
+ 'String))throw 1;for(const a of[2,3]){if(a==2)continue;function ' +
+ 'f(z={a}){let a=0;return z.a}{function f(){return 0;}}return f()' +
+ '==3}';
+ return evalCheck('(()=>{"use strict";' + es6fullTest + '})()');
+ // TODO(joeltine): Remove es6-impl references for b/31340605.
+ // Consider es6-impl (widely-implemented es6 features) to be supported
+ // whenever es6 is supported. Technically es6-impl is a lower level of
+ // support than es6, but we don't have tests specifically for it.
+ addNewerLanguageTranspilationCheck('es6-impl', function() {
+ return true;
+ // ** and **= are the only new features in 'es7'
+ addNewerLanguageTranspilationCheck('es7', function() {
+ return evalCheck('2 ** 2 == 4');
+ // async functions are the only new features in 'es8'
+ addNewerLanguageTranspilationCheck('es8', function() {
+ return evalCheck('async () => 1, true');
+ return requiresTranspilation;
+goog.provide('ol.array');
+ * Performs a binary search on the provided sorted list and returns the index of the item if found. If it can't be found it'll return -1.
+ * https://github.com/darkskyapp/binary-search
+ * @param {Array.<*>} haystack Items to search through.
+ * @param {*} needle The item to look for.
+ * @param {Function=} opt_comparator Comparator function.
+ * @return {number} The index of the item if found, -1 if not.
+ol.array.binarySearch = function(haystack, needle, opt_comparator) {
+ var mid, cmp;
+ var comparator = opt_comparator || ol.array.numberSafeCompareFunction;
+ var low = 0;
+ var high = haystack.length;
+ var found = false;
+ while (low < high) {
+ /* Note that "(low + high) >>> 1" may overflow, and results in a typecast
+ * to double (which gives the wrong results). */
+ mid = low + (high - low >> 1);
+ cmp = +comparator(haystack[mid], needle);
+ if (cmp < 0.0) { /* Too low. */
+ low = mid + 1;
+ } else { /* Key found or too high */
+ high = mid;
+ found = !cmp;
+ /* Key not found. */
+ return found ? low : ~low;
+ * Compare function for array sort that is safe for numbers.
+ * @param {*} a The first object to be compared.
+ * @param {*} b The second object to be compared.
+ * @return {number} A negative number, zero, or a positive number as the first
+ * argument is less than, equal to, or greater than the second.
+ol.array.numberSafeCompareFunction = function(a, b) {
+ return a > b ? 1 : a < b ? -1 : 0;
+ * Whether the array contains the given object.
+ * @param {Array.<*>} arr The array to test for the presence of the element.
+ * @param {*} obj The object for which to test.
+ * @return {boolean} The object is in the array.
+ol.array.includes = function(arr, obj) {
+ return arr.indexOf(obj) >= 0;
+ * @param {Array.<number>} arr Array.
+ * @param {number} target Target.
+ * @param {number} direction 0 means return the nearest, > 0
+ * means return the largest nearest, < 0 means return the
+ * smallest nearest.
+ * @return {number} Index.
+ol.array.linearFindNearest = function(arr, target, direction) {
+ var n = arr.length;
+ if (arr[0] <= target) {
+ return 0;
+ } else if (target <= arr[n - 1]) {
+ return n - 1;
+ } else {
+ var i;
+ if (direction > 0) {
+ for (i = 1; i < n; ++i) {
+ if (arr[i] < target) {
+ return i - 1;
+ } else if (direction < 0) {
+ if (arr[i] <= target) {
+ return i;
+ } else {
+ if (arr[i] == target) {
+ return i;
+ } else if (arr[i] < target) {
+ if (arr[i - 1] - target < target - arr[i]) {
+ return i - 1;
+ } else {
+ return i;
+ return n - 1;
+ * @param {Array.<*>} arr Array.
+ * @param {number} begin Begin index.
+ * @param {number} end End index.
+ol.array.reverseSubArray = function(arr, begin, end) {
+ while (begin < end) {
+ var tmp = arr[begin];
+ arr[begin] = arr[end];
+ arr[end] = tmp;
+ ++begin;
+ --end;
+ * @param {Array.<VALUE>} arr The array to modify.
+ * @param {Array.<VALUE>|VALUE} data The elements or arrays of elements
+ * to add to arr.
+ * @template VALUE
+ol.array.extend = function(arr, data) {
+ var i;
+ var extension = Array.isArray(data) ? data : [data];
+ var length = extension.length;
+ for (i = 0; i < length; i++) {
+ arr[arr.length] = extension[i];
+ * @param {VALUE} obj The element to remove.
+ * @template VALUE
+ * @return {boolean} If the element was removed.
+ol.array.remove = function(arr, obj) {
+ var i = arr.indexOf(obj);
+ var found = i > -1;
+ if (found) {
+ arr.splice(i, 1);
+ return found;
+ * @param {Array.<VALUE>} arr The array to search in.
+ * @param {function(VALUE, number, ?) : boolean} func The function to compare.
+ * @template VALUE
+ * @return {VALUE} The element found.
+ol.array.find = function(arr, func) {
+ var length = arr.length >>> 0;
+ var value;
+ for (var i = 0; i < length; i++) {
+ value = arr[i];
+ if (func(value, i, arr)) {
+ return value;
+ return null;
+ * @param {Array|Uint8ClampedArray} arr1 The first array to compare.
+ * @param {Array|Uint8ClampedArray} arr2 The second array to compare.
+ * @return {boolean} Whether the two arrays are equal.
+ol.array.equals = function(arr1, arr2) {
+ var len1 = arr1.length;
+ if (len1 !== arr2.length) {
+ return false;
+ for (var i = 0; i < len1; i++) {
+ if (arr1[i] !== arr2[i]) {
+ return false;
+ return true;
+ * @param {Array.<*>} arr The array to sort (modifies original).
+ * @param {Function} compareFnc Comparison function.
+ol.array.stableSort = function(arr, compareFnc) {
+ var length = arr.length;
+ var tmp = Array(arr.length);
+ var i;
+ tmp[i] = {index: i, value: arr[i]};
+ tmp.sort(function(a, b) {
+ return compareFnc(a.value, b.value) || a.index - b.index;
+ for (i = 0; i < arr.length; i++) {
+ arr[i] = tmp[i].value;
+ * @param {Array.<*>} arr The array to search in.
+ * @param {Function} func Comparison function.
+ * @return {number} Return index.
+ol.array.findIndex = function(arr, func) {
+ var index;
+ var found = !arr.every(function(el, idx) {
+ index = idx;
+ return !func(el, idx, arr);
+ return found ? index : -1;
+ * @param {Array.<*>} arr The array to test.
+ * @param {Function=} opt_func Comparison function.
+ * @param {boolean=} opt_strict Strictly sorted (default false).
+ * @return {boolean} Return index.
+ol.array.isSorted = function(arr, opt_func, opt_strict) {
+ var compare = opt_func || ol.array.numberSafeCompareFunction;
+ return arr.every(function(currentVal, index) {
+ if (index === 0) {
+ return true;
+ var res = compare(arr[index - 1], currentVal);
+ return !(res > 0 || opt_strict && res === 0);
+goog.provide('ol');
+ * Constants defined with the define tag cannot be changed in application
+ * code, but can be set at compile time.
+ * Some reduce the size of the build in advanced compile mode.
+ * @define {boolean} Assume touch. Default is `false`.
+ol.ASSUME_TOUCH = false;
+ * TODO: rename this to something having to do with tile grids
+ * see https://github.com/openlayers/openlayers/issues/2076
+ * @define {number} Default maximum zoom for default tile grids.
+ol.DEFAULT_MAX_ZOOM = 42;
+ * @define {number} Default min zoom level for the map view. Default is `0`.
+ol.DEFAULT_MIN_ZOOM = 0;
+ * @define {number} Default maximum allowed threshold (in pixels) for
+ * reprojection triangulation. Default is `0.5`.
+ol.DEFAULT_RASTER_REPROJECTION_ERROR_THRESHOLD = 0.5;
+ * @define {number} Default tile size.
+ol.DEFAULT_TILE_SIZE = 256;
+ * @define {string} Default WMS version.
+ol.DEFAULT_WMS_VERSION = '1.3.0';
+ * @define {boolean} Enable the Canvas renderer. Default is `true`. Setting
+ * this to false at compile time in advanced mode removes all code
+ * supporting the Canvas renderer from the build.
+ol.ENABLE_CANVAS = true;
+ * @define {boolean} Enable integration with the Proj4js library. Default is
+ * `true`.
+ol.ENABLE_PROJ4JS = true;
+ * @define {boolean} Enable automatic reprojection of raster sources. Default is
+ * `true`.
+ol.ENABLE_RASTER_REPROJECTION = true;
+ * @define {boolean} Enable the WebGL renderer. Default is `true`. Setting
+ * supporting the WebGL renderer from the build.
+ol.ENABLE_WEBGL = true;
+ * @define {boolean} Include debuggable shader sources. Default is `true`.
+ * This should be set to `false` for production builds (if `ol.ENABLE_WEBGL`
+ * is `true`).
+ol.DEBUG_WEBGL = true;
+ * @define {number} The size in pixels of the first atlas image. Default is
+ * `256`.
+ol.INITIAL_ATLAS_SIZE = 256;
+ * @define {number} The maximum size in pixels of atlas images. Default is
+ * `-1`, meaning it is not used (and `ol.WEBGL_MAX_TEXTURE_SIZE` is
+ * used instead).
+ol.MAX_ATLAS_SIZE = -1;
+ * @define {number} Maximum mouse wheel delta.
+ol.MOUSEWHEELZOOM_MAXDELTA = 1;
+ * @define {number} Maximum width and/or height extent ratio that determines
+ * when the overview map should be zoomed out.
+ol.OVERVIEWMAP_MAX_RATIO = 0.75;
+ * @define {number} Minimum width and/or height extent ratio that determines
+ * when the overview map should be zoomed in.
+ol.OVERVIEWMAP_MIN_RATIO = 0.1;
+ * @define {number} Maximum number of source tiles for raster reprojection of
+ * a single tile.
+ * If too many source tiles are determined to be loaded to create a single
+ * reprojected tile the browser can become unresponsive or even crash.
+ * This can happen if the developer defines projections improperly and/or
+ * with unlimited extents.
+ * If too many tiles are required, no tiles are loaded and
+ * `ol.TileState.ERROR` state is set. Default is `100`.
+ol.RASTER_REPROJECTION_MAX_SOURCE_TILES = 100;
+ * @define {number} Maximum number of subdivision steps during raster
+ * reprojection triangulation. Prevents high memory usage and large
+ * number of proj4 calls (for certain transformations and areas).
+ * At most `2*(2^this)` triangles are created for each triangulated
+ * extent (tile/image). Default is `10`.
+ol.RASTER_REPROJECTION_MAX_SUBDIVISION = 10;
+ * @define {number} Maximum allowed size of triangle relative to world width.
+ * When transforming corners of world extent between certain projections,
+ * the resulting triangulation seems to have zero error and no subdivision
+ * is performed.
+ * If the triangle width is more than this (relative to world width; 0-1),
+ * subdivison is forced (up to `ol.RASTER_REPROJECTION_MAX_SUBDIVISION`).
+ * Default is `0.25`.
+ol.RASTER_REPROJECTION_MAX_TRIANGLE_WIDTH = 0.25;
+ * @define {number} Tolerance for geometry simplification in device pixels.
+ol.SIMPLIFY_TOLERANCE = 0.5;
+ * @define {number} Texture cache high water mark.
+ol.WEBGL_TEXTURE_CACHE_HIGH_WATER_MARK = 1024;
+ * @define {string} OpenLayers version.
+ol.VERSION = '';
+ * The maximum supported WebGL texture size in pixels. If WebGL is not
+ * supported, the value is set to `undefined`.
+ * @const
+ * @type {number|undefined}
+ol.WEBGL_MAX_TEXTURE_SIZE; // value is set in `ol.has`
+ * List of supported WebGL extensions.
+ * @const
+ * @type {Array.<string>}
+ol.WEBGL_EXTENSIONS; // value is set in `ol.has`
+ * Usage:
+ * // Call parent constructor
+ * ParentClass.call(this, a, b);
+ * ol.inherits(ChildClass, ParentClass);
+ * @param {!Function} childCtor Child constructor.
+ * @param {!Function} parentCtor Parent constructor.
+ * @function
+ * @api
+ol.inherits = function(childCtor, parentCtor) {
+ childCtor.prototype = Object.create(parentCtor.prototype);
+ * A reusable function, used e.g. as a default for callbacks.
+ * @return {undefined} Nothing.
+ol.nullFunction = function() {};
+ * with the same object as a parameter returns the same value. Unique IDs are generated
+ * as a strictly increasing sequence. Adapted from goog.getUid.
+ol.getUid = function(obj) {
+ return obj.ol_uid ||
+ (obj.ol_uid = ++ol.uidCounter_);
+ * Counter for getUid.
+ * @type {number}
+ * @private
+ol.uidCounter_ = 0;
+goog.provide('ol.AssertionError');
+goog.require('ol');
+ * Error object thrown when an assertion failed. This is an ECMA-262 Error,
+ * extended with a `code` property.
+ * @see {@link https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Error}
+ * @constructor
+ * @extends {Error}
+ * @implements {oli.AssertionError}
+ * @param {number} code Error code.
+ol.AssertionError = function(code) {
+ var path = ol.VERSION ? ol.VERSION.split('-')[0] : 'latest';
+ * @type {string}
+ this.message = 'Assertion failed. See https://openlayers.org/en/' + path +
+ '/doc/errors/#' + code + ' for details.';
+ * Error code. The meaning of the code can be found on
+ * {@link https://openlayers.org/en/latest/doc/errors/} (replace `latest` with
+ * the version found in the OpenLayers script's header comment if a version
+ * other than the latest is used).
+ * @type {number}
+ * @api
+ this.code = code;
+ this.name = 'AssertionError';
+ol.inherits(ol.AssertionError, Error);
+goog.provide('ol.asserts');
+goog.require('ol.AssertionError');
+ * @param {*} assertion Assertion we expected to be truthy.
+ * @param {number} errorCode Error code.
+ol.asserts.assert = function(assertion, errorCode) {
+ if (!assertion) {
+ throw new ol.AssertionError(errorCode);
+goog.provide('ol.TileRange');
+ * A representation of a contiguous block of tiles. A tile range is specified
+ * by its min/max tile coordinates and is inclusive of coordinates.
+ * @constructor
+ * @param {number} minX Minimum X.
+ * @param {number} maxX Maximum X.
+ * @param {number} minY Minimum Y.
+ * @param {number} maxY Maximum Y.
+ * @struct
+ol.TileRange = function(minX, maxX, minY, maxY) {
+ * @type {number}
+ this.minX = minX;
+ * @type {number}
+ this.maxX = maxX;
+ * @type {number}
+ this.minY = minY;
+ * @type {number}
+ this.maxY = maxY;
+ * @param {ol.TileRange|undefined} tileRange TileRange.
+ * @return {ol.TileRange} Tile range.
+ol.TileRange.createOrUpdate = function(minX, maxX, minY, maxY, tileRange) {
+ if (tileRange !== undefined) {
+ tileRange.minX = minX;
+ tileRange.maxX = maxX;
+ tileRange.minY = minY;
+ tileRange.maxY = maxY;
+ return tileRange;
+ } else {
+ return new ol.TileRange(minX, maxX, minY, maxY);
+ * @param {ol.TileCoord} tileCoord Tile coordinate.
+ * @return {boolean} Contains tile coordinate.
+ol.TileRange.prototype.contains = function(tileCoord) {
+ return this.containsXY(tileCoord[1], tileCoord[2]);
+ * @param {ol.TileRange} tileRange Tile range.
+ * @return {boolean} Contains.
+ol.TileRange.prototype.containsTileRange = function(tileRange) {
+ return this.minX <= tileRange.minX && tileRange.maxX <= this.maxX &&
+ this.minY <= tileRange.minY && tileRange.maxY <= this.maxY;
+ * @param {number} x Tile coordinate x.
+ * @param {number} y Tile coordinate y.
+ * @return {boolean} Contains coordinate.
+ol.TileRange.prototype.containsXY = function(x, y) {
+ return this.minX <= x && x <= this.maxX && this.minY <= y && y <= this.maxY;
+ * @return {boolean} Equals.
+ol.TileRange.prototype.equals = function(tileRange) {
+ return this.minX == tileRange.minX && this.minY == tileRange.minY &&
+ this.maxX == tileRange.maxX && this.maxY == tileRange.maxY;
+ol.TileRange.prototype.extend = function(tileRange) {
+ if (tileRange.minX < this.minX) {
+ this.minX = tileRange.minX;
+ if (tileRange.maxX > this.maxX) {
+ this.maxX = tileRange.maxX;
+ if (tileRange.minY < this.minY) {
+ this.minY = tileRange.minY;
+ if (tileRange.maxY > this.maxY) {
+ this.maxY = tileRange.maxY;
+ * @return {number} Height.
+ol.TileRange.prototype.getHeight = function() {
+ return this.maxY - this.minY + 1;
+ * @return {ol.Size} Size.
+ol.TileRange.prototype.getSize = function() {
+ return [this.getWidth(), this.getHeight()];
+ * @return {number} Width.
+ol.TileRange.prototype.getWidth = function() {
+ return this.maxX - this.minX + 1;
+ * @return {boolean} Intersects.
+ol.TileRange.prototype.intersects = function(tileRange) {
+ return this.minX <= tileRange.maxX &&
+ this.maxX >= tileRange.minX &&
+ this.minY <= tileRange.maxY &&
+ this.maxY >= tileRange.minY;
+goog.provide('ol.math');
+goog.require('ol.asserts');
+ * Takes a number and clamps it to within the provided bounds.
+ * @param {number} value The input number.
+ * @param {number} min The minimum value to return.
+ * @param {number} max The maximum value to return.
+ * @return {number} The input number if it is within bounds, or the nearest
+ * number within the bounds.
+ol.math.clamp = function(value, min, max) {
+ return Math.min(Math.max(value, min), max);
+ * Return the hyperbolic cosine of a given number. The method will use the
+ * native `Math.cosh` function if it is available, otherwise the hyperbolic
+ * cosine will be calculated via the reference implementation of the Mozilla
+ * developer network.
+ * @param {number} x X.
+ * @return {number} Hyperbolic cosine of x.
+ol.math.cosh = (function() {
+ // Wrapped in a iife, to save the overhead of checking for the native
+ // implementation on every invocation.
+ var cosh;
+ if ('cosh' in Math) {
+ // The environment supports the native Math.cosh function, use it…
+ cosh = Math.cosh;
+ } else {
+ // … else, use the reference implementation of MDN:
+ cosh = function(x) {
+ var y = Math.exp(x);
+ return (y + 1 / y) / 2;
+ return cosh;
+ * @return {number} The smallest power of two greater than or equal to x.
+ol.math.roundUpToPowerOfTwo = function(x) {
+ ol.asserts.assert(0 < x, 29); // `x` must be greater than `0`
+ return Math.pow(2, Math.ceil(Math.log(x) / Math.LN2));
+ * Returns the square of the closest distance between the point (x, y) and the
+ * line segment (x1, y1) to (x2, y2).
+ * @param {number} y Y.
+ * @param {number} x1 X1.
+ * @param {number} y1 Y1.
+ * @param {number} x2 X2.
+ * @param {number} y2 Y2.
+ * @return {number} Squared distance.
+ol.math.squaredSegmentDistance = function(x, y, x1, y1, x2, y2) {
+ var dx = x2 - x1;
+ var dy = y2 - y1;
+ if (dx !== 0 || dy !== 0) {
+ var t = ((x - x1) * dx + (y - y1) * dy) / (dx * dx + dy * dy);
+ if (t > 1) {
+ x1 = x2;
+ y1 = y2;
+ } else if (t > 0) {
+ x1 += dx * t;
+ y1 += dy * t;
+ return ol.math.squaredDistance(x, y, x1, y1);
+ * Returns the square of the distance between the points (x1, y1) and (x2, y2).
+ol.math.squaredDistance = function(x1, y1, x2, y2) {
+ var dx = x2 - x1;
+ var dy = y2 - y1;
+ return dx * dx + dy * dy;
+ * Solves system of linear equations using Gaussian elimination method.
+ * @param {Array.<Array.<number>>} mat Augmented matrix (n x n + 1 column)
+ * in row-major order.
+ * @return {Array.<number>} The resulting vector.
+ol.math.solveLinearSystem = function(mat) {
+ var n = mat.length;
+ for (var i = 0; i < n; i++) {
+ // Find max in the i-th column (ignoring i - 1 first rows)
+ var maxRow = i;
+ var maxEl = Math.abs(mat[i][i]);
+ for (var r = i + 1; r < n; r++) {
+ var absValue = Math.abs(mat[r][i]);
+ if (absValue > maxEl) {
+ maxEl = absValue;
+ maxRow = r;
+ if (maxEl === 0) {
+ return null; // matrix is singular
+ // Swap max row with i-th (current) row
+ var tmp = mat[maxRow];
+ mat[maxRow] = mat[i];
+ mat[i] = tmp;
+ // Subtract the i-th row to make all the remaining rows 0 in the i-th column
+ for (var j = i + 1; j < n; j++) {
+ var coef = -mat[j][i] / mat[i][i];
+ for (var k = i; k < n + 1; k++) {
+ if (i == k) {
+ mat[j][k] = 0;
+ } else {
+ mat[j][k] += coef * mat[i][k];
+ // Solve Ax=b for upper triangular matrix A (mat)
+ var x = new Array(n);
+ for (var l = n - 1; l >= 0; l--) {
+ x[l] = mat[l][n] / mat[l][l];
+ for (var m = l - 1; m >= 0; m--) {
+ mat[m][n] -= mat[m][l] * x[l];
+ return x;
+ * Converts radians to to degrees.
+ * @param {number} angleInRadians Angle in radians.
+ * @return {number} Angle in degrees.
+ol.math.toDegrees = function(angleInRadians) {
+ return angleInRadians * 180 / Math.PI;
+ * Converts degrees to radians.
+ * @param {number} angleInDegrees Angle in degrees.
+ * @return {number} Angle in radians.
+ol.math.toRadians = function(angleInDegrees) {
+ return angleInDegrees * Math.PI / 180;
+ * Returns the modulo of a / b, depending on the sign of b.
+ * @param {number} a Dividend.
+ * @param {number} b Divisor.
+ * @return {number} Modulo.
+ol.math.modulo = function(a, b) {
+ var r = a % b;
+ return r * b < 0 ? r + b : r;
+ * Calculates the linearly interpolated value of x between a and b.
+ * @param {number} a Number
+ * @param {number} b Number
+ * @param {number} x Value to be interpolated.
+ * @return {number} Interpolated value.
+ol.math.lerp = function(a, b, x) {
+ return a + x * (b - a);
+goog.provide('ol.size');
+ * Returns a buffered size.
+ * @param {ol.Size} size Size.
+ * @param {number} buffer Buffer.
+ * @param {ol.Size=} opt_size Optional reusable size array.
+ * @return {ol.Size} The buffered size.
+ol.size.buffer = function(size, buffer, opt_size) {
+ if (opt_size === undefined) {
+ opt_size = [0, 0];
+ opt_size[0] = size[0] + 2 * buffer;
+ opt_size[1] = size[1] + 2 * buffer;
+ return opt_size;
+ * Determines if a size has a positive area.
+ * @param {ol.Size} size The size to test.
+ * @return {boolean} The size has a positive area.
+ol.size.hasArea = function(size) {
+ return size[0] > 0 && size[1] > 0;
+ * Returns a size scaled by a ratio. The result will be an array of integers.
+ * @param {number} ratio Ratio.
+ * @return {ol.Size} The scaled size.
+ol.size.scale = function(size, ratio, opt_size) {
+ opt_size[0] = (size[0] * ratio + 0.5) | 0;
+ opt_size[1] = (size[1] * ratio + 0.5) | 0;
+ return opt_size;
+ * Returns an `ol.Size` array for the passed in number (meaning: square) or
+ * `ol.Size` array.
+ * (meaning: non-square),
+ * @param {number|ol.Size} size Width and height.
+ * @api
+ol.size.toSize = function(size, opt_size) {
+ if (Array.isArray(size)) {
+ return size;
+ } else {
+ opt_size = [size, size];
+ } else {
+ opt_size[0] = opt_size[1] = /** @type {number} */ (size);
+ return opt_size;
+goog.provide('ol.extent.Corner');
+ * Extent corner.
+ * @enum {string}
+ol.extent.Corner = {
+ BOTTOM_LEFT: 'bottom-left',
+ BOTTOM_RIGHT: 'bottom-right',
+ TOP_LEFT: 'top-left',
+ TOP_RIGHT: 'top-right'
+goog.provide('ol.extent.Relationship');
+ * Relationship to an extent.
+ * @enum {number}
+ol.extent.Relationship = {
+ UNKNOWN: 0,
+ INTERSECTING: 1,
+ ABOVE: 2,
+ RIGHT: 4,
+ BELOW: 8,
+ LEFT: 16
+goog.provide('ol.extent');
+goog.require('ol.extent.Corner');
+goog.require('ol.extent.Relationship');
+ * Build an extent that includes all given coordinates.
+ * @param {Array.<ol.Coordinate>} coordinates Coordinates.
+ * @return {ol.Extent} Bounding extent.
+ * @api
+ol.extent.boundingExtent = function(coordinates) {
+ var extent = ol.extent.createEmpty();
+ for (var i = 0, ii = coordinates.length; i < ii; ++i) {
+ ol.extent.extendCoordinate(extent, coordinates[i]);
+ return extent;
+ * @param {Array.<number>} xs Xs.
+ * @param {Array.<number>} ys Ys.
+ * @param {ol.Extent=} opt_extent Destination extent.
+ * @private
+ * @return {ol.Extent} Extent.
+ol.extent.boundingExtentXYs_ = function(xs, ys, opt_extent) {
+ var minX = Math.min.apply(null, xs);
+ var minY = Math.min.apply(null, ys);
+ var maxX = Math.max.apply(null, xs);
+ var maxY = Math.max.apply(null, ys);
+ return ol.extent.createOrUpdate(minX, minY, maxX, maxY, opt_extent);
+ * Return extent increased by the provided value.
+ * @param {ol.Extent} extent Extent.
+ * @param {number} value The amount by which the extent should be buffered.
+ * @param {ol.Extent=} opt_extent Extent.
+ * @api
+ol.extent.buffer = function(extent, value, opt_extent) {
+ if (opt_extent) {
+ opt_extent[0] = extent[0] - value;
+ opt_extent[1] = extent[1] - value;
+ opt_extent[2] = extent[2] + value;
+ opt_extent[3] = extent[3] + value;
+ return opt_extent;
+ } else {
+ return [
+ extent[0] - value,
+ extent[1] - value,
+ extent[2] + value,
+ extent[3] + value
+ * Creates a clone of an extent.
+ * @param {ol.Extent} extent Extent to clone.
+ * @return {ol.Extent} The clone.
+ol.extent.clone = function(extent, opt_extent) {
+ if (opt_extent) {
+ opt_extent[0] = extent[0];
+ opt_extent[1] = extent[1];
+ opt_extent[2] = extent[2];
+ opt_extent[3] = extent[3];
+ } else {
+ return extent.slice();
+ * @return {number} Closest squared distance.
+ol.extent.closestSquaredDistanceXY = function(extent, x, y) {
+ var dx, dy;
+ if (x < extent[0]) {
+ dx = extent[0] - x;
+ } else if (extent[2] < x) {
+ dx = x - extent[2];
+ } else {
+ dx = 0;
+ if (y < extent[1]) {
+ dy = extent[1] - y;
+ } else if (extent[3] < y) {
+ dy = y - extent[3];
+ } else {
+ dy = 0;
+ * Check if the passed coordinate is contained or on the edge of the extent.
+ * @param {ol.Coordinate} coordinate Coordinate.
+ * @return {boolean} The coordinate is contained in the extent.
+ * @api
+ol.extent.containsCoordinate = function(extent, coordinate) {
+ return ol.extent.containsXY(extent, coordinate[0], coordinate[1]);
+ * Check if one extent contains another.
+ * An extent is deemed contained if it lies completely within the other extent,
+ * including if they share one or more edges.
+ * @param {ol.Extent} extent1 Extent 1.
+ * @param {ol.Extent} extent2 Extent 2.
+ * @return {boolean} The second extent is contained by or on the edge of the
+ * first.
+ * @api
+ol.extent.containsExtent = function(extent1, extent2) {
+ return extent1[0] <= extent2[0] && extent2[2] <= extent1[2] &&
+ extent1[1] <= extent2[1] && extent2[3] <= extent1[3];
+ * @param {number} x X coordinate.
+ * @param {number} y Y coordinate.
+ * @return {boolean} The x, y values are contained in the extent.
+ * @api
+ol.extent.containsXY = function(extent, x, y) {
+ return extent[0] <= x && x <= extent[2] && extent[1] <= y && y <= extent[3];
+ * Get the relationship between a coordinate and extent.
+ * @param {ol.Extent} extent The extent.
+ * @param {ol.Coordinate} coordinate The coordinate.
+ * @return {number} The relationship (bitwise compare with
+ * ol.extent.Relationship).
+ol.extent.coordinateRelationship = function(extent, coordinate) {
+ var minX = extent[0];
+ var minY = extent[1];
+ var maxX = extent[2];
+ var maxY = extent[3];
+ var x = coordinate[0];
+ var y = coordinate[1];
+ var relationship = ol.extent.Relationship.UNKNOWN;
+ if (x < minX) {
+ relationship = relationship | ol.extent.Relationship.LEFT;
+ } else if (x > maxX) {
+ relationship = relationship | ol.extent.Relationship.RIGHT;
+ if (y < minY) {
+ relationship = relationship | ol.extent.Relationship.BELOW;
+ } else if (y > maxY) {
+ relationship = relationship | ol.extent.Relationship.ABOVE;
+ if (relationship === ol.extent.Relationship.UNKNOWN) {
+ relationship = ol.extent.Relationship.INTERSECTING;
+ return relationship;
+ * Create an empty extent.
+ * @return {ol.Extent} Empty extent.
+ * @api
+ol.extent.createEmpty = function() {
+ return [Infinity, Infinity, -Infinity, -Infinity];
+ * Create a new extent or update the provided extent.
+ol.extent.createOrUpdate = function(minX, minY, maxX, maxY, opt_extent) {
+ if (opt_extent) {
+ opt_extent[0] = minX;
+ opt_extent[1] = minY;
+ opt_extent[2] = maxX;
+ opt_extent[3] = maxY;
+ } else {
+ return [minX, minY, maxX, maxY];
+ * Create a new empty extent or make the provided one empty.
+ol.extent.createOrUpdateEmpty = function(opt_extent) {
+ Infinity, Infinity, -Infinity, -Infinity, opt_extent);
+ol.extent.createOrUpdateFromCoordinate = function(coordinate, opt_extent) {
+ return ol.extent.createOrUpdate(x, y, x, y, opt_extent);
+ol.extent.createOrUpdateFromCoordinates = function(coordinates, opt_extent) {
+ var extent = ol.extent.createOrUpdateEmpty(opt_extent);
+ return ol.extent.extendCoordinates(extent, coordinates);
+ * @param {Array.<number>} flatCoordinates Flat coordinates.
+ * @param {number} offset Offset.
+ * @param {number} end End.
+ * @param {number} stride Stride.
+ol.extent.createOrUpdateFromFlatCoordinates = function(flatCoordinates, offset, end, stride, opt_extent) {
+ return ol.extent.extendFlatCoordinates(
+ extent, flatCoordinates, offset, end, stride);
+ * @param {Array.<Array.<ol.Coordinate>>} rings Rings.
+ol.extent.createOrUpdateFromRings = function(rings, opt_extent) {
+ return ol.extent.extendRings(extent, rings);
+ * Determine if two extents are equivalent.
+ * @return {boolean} The two extents are equivalent.
+ * @api
+ol.extent.equals = function(extent1, extent2) {
+ return extent1[0] == extent2[0] && extent1[2] == extent2[2] &&
+ extent1[1] == extent2[1] && extent1[3] == extent2[3];
+ * Modify an extent to include another extent.
+ * @param {ol.Extent} extent1 The extent to be modified.
+ * @param {ol.Extent} extent2 The extent that will be included in the first.
+ * @return {ol.Extent} A reference to the first (extended) extent.
+ * @api
+ol.extent.extend = function(extent1, extent2) {
+ if (extent2[0] < extent1[0]) {
+ extent1[0] = extent2[0];
+ if (extent2[2] > extent1[2]) {
+ extent1[2] = extent2[2];
+ if (extent2[1] < extent1[1]) {
+ extent1[1] = extent2[1];
+ if (extent2[3] > extent1[3]) {
+ extent1[3] = extent2[3];
+ return extent1;
+ol.extent.extendCoordinate = function(extent, coordinate) {
+ if (coordinate[0] < extent[0]) {
+ extent[0] = coordinate[0];
+ if (coordinate[0] > extent[2]) {
+ extent[2] = coordinate[0];
+ if (coordinate[1] < extent[1]) {
+ extent[1] = coordinate[1];
+ if (coordinate[1] > extent[3]) {
+ extent[3] = coordinate[1];
+ol.extent.extendCoordinates = function(extent, coordinates) {
+ var i, ii;
+ for (i = 0, ii = coordinates.length; i < ii; ++i) {
+ return extent;
+ol.extent.extendFlatCoordinates = function(extent, flatCoordinates, offset, end, stride) {
+ for (; offset < end; offset += stride) {
+ ol.extent.extendXY(
+ extent, flatCoordinates[offset], flatCoordinates[offset + 1]);
+ return extent;
+ol.extent.extendRings = function(extent, rings) {
+ var i, ii;
+ for (i = 0, ii = rings.length; i < ii; ++i) {
+ ol.extent.extendCoordinates(extent, rings[i]);
+ return extent;
+ol.extent.extendXY = function(extent, x, y) {
+ extent[0] = Math.min(extent[0], x);
+ extent[1] = Math.min(extent[1], y);
+ extent[2] = Math.max(extent[2], x);
+ extent[3] = Math.max(extent[3], y);
+ * This function calls `callback` for each corner of the extent. If the
+ * callback returns a truthy value the function returns that value
+ * immediately. Otherwise the function returns `false`.
+ * @param {function(this:T, ol.Coordinate): S} callback Callback.
+ * @param {T=} opt_this Value to use as `this` when executing `callback`.
+ * @return {S|boolean} Value.
+ * @template S, T
+ol.extent.forEachCorner = function(extent, callback, opt_this) {
+ var val;
+ val = callback.call(opt_this, ol.extent.getBottomLeft(extent));
+ if (val) {
+ return val;
+ val = callback.call(opt_this, ol.extent.getBottomRight(extent));
+ if (val) {
+ return val;
+ val = callback.call(opt_this, ol.extent.getTopRight(extent));
+ if (val) {
+ return val;
+ val = callback.call(opt_this, ol.extent.getTopLeft(extent));
+ if (val) {
+ return val;
+ return false;
+ * @return {number} Area.
+ol.extent.getArea = function(extent) {
+ var area = 0;
+ if (!ol.extent.isEmpty(extent)) {
+ area = ol.extent.getWidth(extent) * ol.extent.getHeight(extent);
+ return area;
+ * Get the bottom left coordinate of an extent.
+ * @return {ol.Coordinate} Bottom left coordinate.
+ * @api
+ol.extent.getBottomLeft = function(extent) {
+ return [extent[0], extent[1]];
+ * Get the bottom right coordinate of an extent.
+ * @return {ol.Coordinate} Bottom right coordinate.
+ * @api
+ol.extent.getBottomRight = function(extent) {
+ return [extent[2], extent[1]];
+ * Get the center coordinate of an extent.
+ * @return {ol.Coordinate} Center.
+ * @api
+ol.extent.getCenter = function(extent) {
+ return [(extent[0] + extent[2]) / 2, (extent[1] + extent[3]) / 2];
+ * Get a corner coordinate of an extent.
+ * @param {ol.extent.Corner} corner Corner.
+ * @return {ol.Coordinate} Corner coordinate.
+ol.extent.getCorner = function(extent, corner) {
+ var coordinate;
+ if (corner === ol.extent.Corner.BOTTOM_LEFT) {
+ coordinate = ol.extent.getBottomLeft(extent);
+ } else if (corner === ol.extent.Corner.BOTTOM_RIGHT) {
+ coordinate = ol.extent.getBottomRight(extent);
+ } else if (corner === ol.extent.Corner.TOP_LEFT) {
+ coordinate = ol.extent.getTopLeft(extent);
+ } else if (corner === ol.extent.Corner.TOP_RIGHT) {
+ coordinate = ol.extent.getTopRight(extent);
+ } else {
+ ol.asserts.assert(false, 13); // Invalid corner
+ return /** @type {!ol.Coordinate} */ (coordinate);
+ * @return {number} Enlarged area.
+ol.extent.getEnlargedArea = function(extent1, extent2) {
+ var minX = Math.min(extent1[0], extent2[0]);
+ var minY = Math.min(extent1[1], extent2[1]);
+ var maxX = Math.max(extent1[2], extent2[2]);
+ var maxY = Math.max(extent1[3], extent2[3]);
+ return (maxX - minX) * (maxY - minY);
+ * @param {ol.Coordinate} center Center.
+ * @param {number} resolution Resolution.
+ * @param {number} rotation Rotation.
+ol.extent.getForViewAndSize = function(center, resolution, rotation, size, opt_extent) {
+ var dx = resolution * size[0] / 2;
+ var dy = resolution * size[1] / 2;
+ var cosRotation = Math.cos(rotation);
+ var sinRotation = Math.sin(rotation);
+ var xCos = dx * cosRotation;
+ var xSin = dx * sinRotation;
+ var yCos = dy * cosRotation;
+ var ySin = dy * sinRotation;
+ var x = center[0];
+ var y = center[1];
+ var x0 = x - xCos + ySin;
+ var x1 = x - xCos - ySin;
+ var x2 = x + xCos - ySin;
+ var x3 = x + xCos + ySin;
+ var y0 = y - xSin - yCos;
+ var y1 = y - xSin + yCos;
+ var y2 = y + xSin + yCos;
+ var y3 = y + xSin - yCos;
+ Math.min(x0, x1, x2, x3), Math.min(y0, y1, y2, y3),
+ Math.max(x0, x1, x2, x3), Math.max(y0, y1, y2, y3),
+ opt_extent);
+ * Get the height of an extent.
+ * @api
+ol.extent.getHeight = function(extent) {
+ return extent[3] - extent[1];
+ * @return {number} Intersection area.
+ol.extent.getIntersectionArea = function(extent1, extent2) {
+ var intersection = ol.extent.getIntersection(extent1, extent2);
+ return ol.extent.getArea(intersection);
+ * Get the intersection of two extents.
+ * @param {ol.Extent=} opt_extent Optional extent to populate with intersection.
+ * @return {ol.Extent} Intersecting extent.
+ * @api
+ol.extent.getIntersection = function(extent1, extent2, opt_extent) {
+ var intersection = opt_extent ? opt_extent : ol.extent.createEmpty();
+ if (ol.extent.intersects(extent1, extent2)) {
+ if (extent1[0] > extent2[0]) {
+ intersection[0] = extent1[0];
+ } else {
+ intersection[0] = extent2[0];
+ if (extent1[1] > extent2[1]) {
+ intersection[1] = extent1[1];
+ } else {
+ intersection[1] = extent2[1];
+ if (extent1[2] < extent2[2]) {
+ intersection[2] = extent1[2];
+ } else {
+ intersection[2] = extent2[2];
+ if (extent1[3] < extent2[3]) {
+ intersection[3] = extent1[3];
+ } else {
+ intersection[3] = extent2[3];
+ return intersection;
+ * @return {number} Margin.
+ol.extent.getMargin = function(extent) {
+ return ol.extent.getWidth(extent) + ol.extent.getHeight(extent);
+ * Get the size (width, height) of an extent.
+ * @return {ol.Size} The extent size.
+ * @api
+ol.extent.getSize = function(extent) {
+ return [extent[2] - extent[0], extent[3] - extent[1]];
+ * Get the top left coordinate of an extent.
+ * @return {ol.Coordinate} Top left coordinate.
+ * @api
+ol.extent.getTopLeft = function(extent) {
+ return [extent[0], extent[3]];
+ * Get the top right coordinate of an extent.
+ * @return {ol.Coordinate} Top right coordinate.
+ * @api
+ol.extent.getTopRight = function(extent) {
+ return [extent[2], extent[3]];
+ * Get the width of an extent.
+ * @api
+ol.extent.getWidth = function(extent) {
+ return extent[2] - extent[0];
+ * Determine if one extent intersects another.
+ * @param {ol.Extent} extent2 Extent.
+ * @return {boolean} The two extents intersect.
+ * @api
+ol.extent.intersects = function(extent1, extent2) {
+ return extent1[0] <= extent2[2] &&
+ extent1[2] >= extent2[0] &&
+ extent1[1] <= extent2[3] &&
+ extent1[3] >= extent2[1];
+ * Determine if an extent is empty.
+ * @return {boolean} Is empty.
+ * @api
+ol.extent.isEmpty = function(extent) {
+ return extent[2] < extent[0] || extent[3] < extent[1];
+ol.extent.returnOrUpdate = function(extent, opt_extent) {
+ if (opt_extent) {
+ } else {
+ return extent;
+ * @param {number} value Value.
+ol.extent.scaleFromCenter = function(extent, value) {
+ var deltaX = ((extent[2] - extent[0]) / 2) * (value - 1);
+ var deltaY = ((extent[3] - extent[1]) / 2) * (value - 1);
+ extent[0] -= deltaX;
+ extent[2] += deltaX;
+ extent[1] -= deltaY;
+ extent[3] += deltaY;
+ * Determine if the segment between two coordinates intersects (crosses,
+ * touches, or is contained by) the provided extent.
+ * @param {ol.Coordinate} start Segment start coordinate.
+ * @param {ol.Coordinate} end Segment end coordinate.
+ * @return {boolean} The segment intersects the extent.
+ol.extent.intersectsSegment = function(extent, start, end) {
+ var intersects = false;
+ var startRel = ol.extent.coordinateRelationship(extent, start);
+ var endRel = ol.extent.coordinateRelationship(extent, end);
+ if (startRel === ol.extent.Relationship.INTERSECTING ||
+ endRel === ol.extent.Relationship.INTERSECTING) {
+ intersects = true;
+ } else {
+ var startX = start[0];
+ var startY = start[1];
+ var endX = end[0];
+ var endY = end[1];
+ var slope = (endY - startY) / (endX - startX);
+ var x, y;
+ if (!!(endRel & ol.extent.Relationship.ABOVE) &&
+ !(startRel & ol.extent.Relationship.ABOVE)) {
+ // potentially intersects top
+ x = endX - ((endY - maxY) / slope);
+ intersects = x >= minX && x <= maxX;
+ if (!intersects && !!(endRel & ol.extent.Relationship.RIGHT) &&
+ !(startRel & ol.extent.Relationship.RIGHT)) {
+ // potentially intersects right
+ y = endY - ((endX - maxX) * slope);
+ intersects = y >= minY && y <= maxY;
+ if (!intersects && !!(endRel & ol.extent.Relationship.BELOW) &&
+ !(startRel & ol.extent.Relationship.BELOW)) {
+ // potentially intersects bottom
+ x = endX - ((endY - minY) / slope);
+ if (!intersects && !!(endRel & ol.extent.Relationship.LEFT) &&
+ !(startRel & ol.extent.Relationship.LEFT)) {
+ // potentially intersects left
+ y = endY - ((endX - minX) * slope);
+ return intersects;
+ * Apply a transform function to the extent.
+ * @param {ol.TransformFunction} transformFn Transform function. Called with
+ * [minX, minY, maxX, maxY] extent coordinates.
+ * @api
+ol.extent.applyTransform = function(extent, transformFn, opt_extent) {
+ var coordinates = [
+ extent[0], extent[1],
+ extent[0], extent[3],
+ extent[2], extent[1],
+ extent[2], extent[3]
+ transformFn(coordinates, coordinates, 2);
+ var xs = [coordinates[0], coordinates[2], coordinates[4], coordinates[6]];
+ var ys = [coordinates[1], coordinates[3], coordinates[5], coordinates[7]];
+ return ol.extent.boundingExtentXYs_(xs, ys, opt_extent);
+goog.provide('ol.obj');
+ * Polyfill for Object.assign(). Assigns enumerable and own properties from
+ * one or more source objects to a target object.
+ * @see https://developer.mozilla.org/en/docs/Web/JavaScript/Reference/Global_Objects/Object/assign
+ * @param {!Object} target The target object.
+ * @param {...Object} var_sources The source object(s).
+ * @return {!Object} The modified target object.
+ol.obj.assign = (typeof Object.assign === 'function') ? Object.assign : function(target, var_sources) {
+ if (target === undefined || target === null) {
+ throw new TypeError('Cannot convert undefined or null to object');
+ var output = Object(target);
+ for (var i = 1, ii = arguments.length; i < ii; ++i) {
+ var source = arguments[i];
+ if (source !== undefined && source !== null) {
+ for (var key in source) {
+ if (source.hasOwnProperty(key)) {
+ output[key] = source[key];
+ return output;
+ * Removes all properties from an object.
+ * @param {Object} object The object to clear.
+ol.obj.clear = function(object) {
+ for (var property in object) {
+ delete object[property];
+ * Get an array of property values from an object.
+ * @param {Object<K,V>} object The object from which to get the values.
+ * @return {!Array<V>} The property values.
+ * @template K,V
+ol.obj.getValues = function(object) {
+ var values = [];
+ values.push(object[property]);
+ return values;
+ * Determine if an object has any properties.
+ * @param {Object} object The object to check.
+ * @return {boolean} The object is empty.
+ol.obj.isEmpty = function(object) {
+ var property;
+ for (property in object) {
+ return false;
+ return !property;
+ * @license
+ * Latitude/longitude spherical geodesy formulae taken from
+ * http://www.movable-type.co.uk/scripts/latlong.html
+ * Licensed under CC-BY-3.0.
+goog.provide('ol.Sphere');
+goog.require('ol.math');
+ * @classdesc
+ * Class to create objects that can be used with {@link
+ * ol.geom.Polygon.circular}.
+ * For example to create a sphere whose radius is equal to the semi-major
+ * axis of the WGS84 ellipsoid:
+ * ```js
+ * var wgs84Sphere= new ol.Sphere(6378137);
+ * @constructor
+ * @param {number} radius Radius.
+ * @api
+ol.Sphere = function(radius) {
+ * @type {number}
+ this.radius = radius;
+ * Returns the geodesic area for a list of coordinates.
+ * [Reference](https://trs-new.jpl.nasa.gov/handle/2014/40409)
+ * Robert. G. Chamberlain and William H. Duquette, "Some Algorithms for
+ * Polygons on a Sphere", JPL Publication 07-03, Jet Propulsion
+ * Laboratory, Pasadena, CA, June 2007
+ * @param {Array.<ol.Coordinate>} coordinates List of coordinates of a linear
+ * ring. If the ring is oriented clockwise, the area will be positive,
+ * otherwise it will be negative.
+ * @api
+ol.Sphere.prototype.geodesicArea = function(coordinates) {
+ var area = 0, len = coordinates.length;
+ var x1 = coordinates[len - 1][0];
+ var y1 = coordinates[len - 1][1];
+ for (var i = 0; i < len; i++) {
+ var x2 = coordinates[i][0], y2 = coordinates[i][1];
+ area += ol.math.toRadians(x2 - x1) *
+ (2 + Math.sin(ol.math.toRadians(y1)) +
+ Math.sin(ol.math.toRadians(y2)));
+ x1 = x2;
+ y1 = y2;
+ return area * this.radius * this.radius / 2.0;
+ * Returns the distance from c1 to c2 using the haversine formula.
+ * @param {ol.Coordinate} c1 Coordinate 1.
+ * @param {ol.Coordinate} c2 Coordinate 2.
+ * @return {number} Haversine distance.
+ * @api
+ol.Sphere.prototype.haversineDistance = function(c1, c2) {
+ var lat1 = ol.math.toRadians(c1[1]);
+ var lat2 = ol.math.toRadians(c2[1]);
+ var deltaLatBy2 = (lat2 - lat1) / 2;
+ var deltaLonBy2 = ol.math.toRadians(c2[0] - c1[0]) / 2;
+ var a = Math.sin(deltaLatBy2) * Math.sin(deltaLatBy2) +
+ Math.sin(deltaLonBy2) * Math.sin(deltaLonBy2) *
+ Math.cos(lat1) * Math.cos(lat2);
+ return 2 * this.radius * Math.atan2(Math.sqrt(a), Math.sqrt(1 - a));
+ * Returns the coordinate at the given distance and bearing from `c1`.
+ * @param {ol.Coordinate} c1 The origin point (`[lon, lat]` in degrees).
+ * @param {number} distance The great-circle distance between the origin
+ * point and the target point.
+ * @param {number} bearing The bearing (in radians).
+ * @return {ol.Coordinate} The target point.
+ol.Sphere.prototype.offset = function(c1, distance, bearing) {
+ var lon1 = ol.math.toRadians(c1[0]);
+ var dByR = distance / this.radius;
+ var lat = Math.asin(
+ Math.sin(lat1) * Math.cos(dByR) +
+ Math.cos(lat1) * Math.sin(dByR) * Math.cos(bearing));
+ var lon = lon1 + Math.atan2(
+ Math.sin(bearing) * Math.sin(dByR) * Math.cos(lat1),
+ Math.cos(dByR) - Math.sin(lat1) * Math.sin(lat));
+ return [ol.math.toDegrees(lon), ol.math.toDegrees(lat)];
+goog.provide('ol.sphere.NORMAL');
+goog.require('ol.Sphere');
+ * The normal sphere.
+ * @const
+ * @type {ol.Sphere}
+ol.sphere.NORMAL = new ol.Sphere(6370997);
+goog.provide('ol.proj.Units');
+goog.require('ol.sphere.NORMAL');
+ * Projection units: `'degrees'`, `'ft'`, `'m'`, `'pixels'`, `'tile-pixels'` or
+ * `'us-ft'`.
+ * @enum {string}
+ol.proj.Units = {
+ DEGREES: 'degrees',
+ FEET: 'ft',
+ METERS: 'm',
+ PIXELS: 'pixels',
+ TILE_PIXELS: 'tile-pixels',
+ USFEET: 'us-ft'
+ * Meters per unit lookup table.
+ * @const
+ * @type {Object.<ol.proj.Units, number>}
+ * @api
+ol.proj.Units.METERS_PER_UNIT = {};
+ol.proj.Units.METERS_PER_UNIT[ol.proj.Units.DEGREES] =
+ 2 * Math.PI * ol.sphere.NORMAL.radius / 360;
+ol.proj.Units.METERS_PER_UNIT[ol.proj.Units.FEET] = 0.3048;
+ol.proj.Units.METERS_PER_UNIT[ol.proj.Units.METERS] = 1;
+ol.proj.Units.METERS_PER_UNIT[ol.proj.Units.USFEET] = 1200 / 3937;
+goog.provide('ol.proj.proj4');
+ * @private
+ * @type {Proj4}
+ol.proj.proj4.cache_ = null;
+ * Store the proj4 function.
+ * @param {Proj4} proj4 The proj4 function.
+ol.proj.proj4.set = function(proj4) {
+ ol.proj.proj4.cache_ = proj4;
+ * Get proj4.
+ * @return {Proj4} The proj4 function set above or available globally.
+ol.proj.proj4.get = function() {
+ return ol.proj.proj4.cache_ || window['proj4'];
+goog.provide('ol.proj.Projection');
+goog.require('ol.proj.Units');
+goog.require('ol.proj.proj4');
+ * @classdesc
+ * Projection definition class. One of these is created for each projection
+ * supported in the application and stored in the {@link ol.proj} namespace.
+ * You can use these in applications, but this is not required, as API params
+ * and options use {@link ol.ProjectionLike} which means the simple string
+ * code will suffice.
+ * You can use {@link ol.proj.get} to retrieve the object for a particular
+ * projection.
+ * The library includes definitions for `EPSG:4326` and `EPSG:3857`, together
+ * with the following aliases:
+ * * `EPSG:4326`: CRS:84, urn:ogc:def:crs:EPSG:6.6:4326,
+ * urn:ogc:def:crs:OGC:1.3:CRS84, urn:ogc:def:crs:OGC:2:84,
+ * http://www.opengis.net/gml/srs/epsg.xml#4326,
+ * urn:x-ogc:def:crs:EPSG:4326
+ * * `EPSG:3857`: EPSG:102100, EPSG:102113, EPSG:900913,
+ * urn:ogc:def:crs:EPSG:6.18:3:3857,
+ * http://www.opengis.net/gml/srs/epsg.xml#3857
+ * If you use proj4js, aliases can be added using `proj4.defs()`; see
+ * [documentation](https://github.com/proj4js/proj4js). To set an alternative
+ * namespace for proj4, use {@link ol.proj.setProj4}.
+ * @constructor
+ * @param {olx.ProjectionOptions} options Projection options.
+ * @struct
+ * @api
+ol.proj.Projection = function(options) {
+ * @private
+ * @type {string}
+ this.code_ = options.code;
+ * @private
+ * @type {ol.proj.Units}
+ this.units_ = /** @type {ol.proj.Units} */ (options.units);
+ * @private
+ * @type {ol.Extent}
+ this.extent_ = options.extent !== undefined ? options.extent : null;
+ * @private
+ this.worldExtent_ = options.worldExtent !== undefined ?
+ options.worldExtent : null;
+ * @private
+ * @type {string}
+ this.axisOrientation_ = options.axisOrientation !== undefined ?
+ options.axisOrientation : 'enu';
+ * @private
+ * @type {boolean}
+ this.global_ = options.global !== undefined ? options.global : false;
+ * @private
+ * @type {boolean}
+ this.canWrapX_ = !!(this.global_ && this.extent_);
+ * @private
+ * @type {function(number, ol.Coordinate):number|undefined}
+ this.getPointResolutionFunc_ = options.getPointResolution;
+ * @private
+ * @type {ol.tilegrid.TileGrid}
+ this.defaultTileGrid_ = null;
+ * @private
+ this.metersPerUnit_ = options.metersPerUnit;
+ var code = options.code;
+ if (ol.ENABLE_PROJ4JS) {
+ var proj4js = ol.proj.proj4.get();
+ if (typeof proj4js == 'function') {
+ var def = proj4js.defs(code);
+ if (def !== undefined) {
+ if (def.axis !== undefined && options.axisOrientation === undefined) {
+ this.axisOrientation_ = def.axis;
+ if (options.metersPerUnit === undefined) {
+ this.metersPerUnit_ = def.to_meter;
+ if (options.units === undefined) {
+ this.units_ = def.units;
+ * @return {boolean} The projection is suitable for wrapping the x-axis
+ol.proj.Projection.prototype.canWrapX = function() {
+ return this.canWrapX_;
+ * Get the code for this projection, e.g. 'EPSG:4326'.
+ * @return {string} Code.
+ * @api
+ol.proj.Projection.prototype.getCode = function() {
+ return this.code_;
+ * Get the validity extent for this projection.
+ * @api
+ol.proj.Projection.prototype.getExtent = function() {
+ return this.extent_;
+ * Get the units of this projection.
+ * @return {ol.proj.Units} Units.
+ * @api
+ol.proj.Projection.prototype.getUnits = function() {
+ return this.units_;
+ * Get the amount of meters per unit of this projection. If the projection is
+ * not configured with `metersPerUnit` or a units identifier, the return is
+ * `undefined`.
+ * @return {number|undefined} Meters.
+ * @api
+ol.proj.Projection.prototype.getMetersPerUnit = function() {
+ return this.metersPerUnit_ || ol.proj.Units.METERS_PER_UNIT[this.units_];
+ * Get the world extent for this projection.
+ * @api
+ol.proj.Projection.prototype.getWorldExtent = function() {
+ return this.worldExtent_;
+ * Get the axis orientation of this projection.
+ * Example values are:
+ * enu - the default easting, northing, elevation.
+ * neu - northing, easting, up - useful for "lat/long" geographic coordinates,
+ * or south orientated transverse mercator.
+ * wnu - westing, northing, up - some planetary coordinate systems have
+ * "west positive" coordinate systems
+ * @return {string} Axis orientation.
+ol.proj.Projection.prototype.getAxisOrientation = function() {
+ return this.axisOrientation_;
+ * Is this projection a global projection which spans the whole world?
+ * @return {boolean} Whether the projection is global.
+ * @api
+ol.proj.Projection.prototype.isGlobal = function() {
+ return this.global_;
+* Set if the projection is a global projection which spans the whole world
+* @param {boolean} global Whether the projection is global.
+* @api
+ol.proj.Projection.prototype.setGlobal = function(global) {
+ this.global_ = global;
+ this.canWrapX_ = !!(global && this.extent_);
+ * @return {ol.tilegrid.TileGrid} The default tile grid.
+ol.proj.Projection.prototype.getDefaultTileGrid = function() {
+ return this.defaultTileGrid_;
+ * @param {ol.tilegrid.TileGrid} tileGrid The default tile grid.
+ol.proj.Projection.prototype.setDefaultTileGrid = function(tileGrid) {
+ this.defaultTileGrid_ = tileGrid;
+ * Set the validity extent for this projection.
+ * @api
+ol.proj.Projection.prototype.setExtent = function(extent) {
+ this.extent_ = extent;
+ this.canWrapX_ = !!(this.global_ && extent);
+ * Set the world extent for this projection.
+ * @param {ol.Extent} worldExtent World extent
+ * [minlon, minlat, maxlon, maxlat].
+ * @api
+ol.proj.Projection.prototype.setWorldExtent = function(worldExtent) {
+ this.worldExtent_ = worldExtent;
+ * Set the getPointResolution function for this projection.
+ * @param {function(number, ol.Coordinate):number} func Function
+ * @api
+ol.proj.Projection.prototype.setGetPointResolution = function(func) {
+ this.getPointResolutionFunc_ = func;
+ * Get the custom point resolution function for this projection (if set).
+ * @return {function(number, ol.Coordinate):number|undefined} The custom point
+ * resolution function (if set).
+ol.proj.Projection.prototype.getPointResolutionFunc = function() {
+ return this.getPointResolutionFunc_;
+goog.provide('ol.proj.EPSG3857');
+goog.require('ol.proj.Projection');
+ * @classdesc
+ * Projection object for web/spherical Mercator (EPSG:3857).
+ * @constructor
+ * @extends {ol.proj.Projection}
+ * @param {string} code Code.
+ * @private
+ol.proj.EPSG3857.Projection_ = function(code) {
+ ol.proj.Projection.call(this, {
+ code: code,
+ units: ol.proj.Units.METERS,
+ extent: ol.proj.EPSG3857.EXTENT,
+ global: true,
+ worldExtent: ol.proj.EPSG3857.WORLD_EXTENT,
+ getPointResolution: function(resolution, point) {
+ return resolution / ol.math.cosh(point[1] / ol.proj.EPSG3857.RADIUS);
+ol.inherits(ol.proj.EPSG3857.Projection_, ol.proj.Projection);
+ * @const
+ * @type {number}
+ol.proj.EPSG3857.RADIUS = 6378137;
+ * @const
+ * @type {number}
+ol.proj.EPSG3857.HALF_SIZE = Math.PI * ol.proj.EPSG3857.RADIUS;
+ * @const
+ol.proj.EPSG3857.EXTENT = [
+ -ol.proj.EPSG3857.HALF_SIZE, -ol.proj.EPSG3857.HALF_SIZE,
+ ol.proj.EPSG3857.HALF_SIZE, ol.proj.EPSG3857.HALF_SIZE
+ * @const
+ol.proj.EPSG3857.WORLD_EXTENT = [-180, -85, 180, 85];
+ * Lists several projection codes with the same meaning as EPSG:3857.
+ol.proj.EPSG3857.CODES = [
+ 'EPSG:3857',
+ 'EPSG:102100',
+ 'EPSG:102113',
+ 'EPSG:900913',
+ 'urn:ogc:def:crs:EPSG:6.18:3:3857',
+ 'urn:ogc:def:crs:EPSG::3857',
+ 'http://www.opengis.net/gml/srs/epsg.xml#3857'
+ * Projections equal to EPSG:3857.
+ * @const
+ * @type {Array.<ol.proj.Projection>}
+ol.proj.EPSG3857.PROJECTIONS = ol.proj.EPSG3857.CODES.map(function(code) {
+ return new ol.proj.EPSG3857.Projection_(code);
+ * Transformation from EPSG:4326 to EPSG:3857.
+ * @param {Array.<number>} input Input array of coordinate values.
+ * @param {Array.<number>=} opt_output Output array of coordinate values.
+ * @param {number=} opt_dimension Dimension (default is `2`).
+ * @return {Array.<number>} Output array of coordinate values.
+ol.proj.EPSG3857.fromEPSG4326 = function(input, opt_output, opt_dimension) {
+ var length = input.length,
+ dimension = opt_dimension > 1 ? opt_dimension : 2,
+ output = opt_output;
+ if (output === undefined) {
+ if (dimension > 2) {
+ // preserve values beyond second dimension
+ output = input.slice();
+ } else {
+ output = new Array(length);
+ var halfSize = ol.proj.EPSG3857.HALF_SIZE;
+ for (var i = 0; i < length; i += dimension) {
+ output[i] = halfSize * input[i] / 180;
+ var y = ol.proj.EPSG3857.RADIUS *
+ Math.log(Math.tan(Math.PI * (input[i + 1] + 90) / 360));
+ if (y > halfSize) {
+ y = halfSize;
+ } else if (y < -halfSize) {
+ y = -halfSize;
+ output[i + 1] = y;
+ return output;
+ * Transformation from EPSG:3857 to EPSG:4326.
+ol.proj.EPSG3857.toEPSG4326 = function(input, opt_output, opt_dimension) {
+ } else {
+ output[i] = 180 * input[i] / ol.proj.EPSG3857.HALF_SIZE;
+ output[i + 1] = 360 * Math.atan(
+ Math.exp(input[i + 1] / ol.proj.EPSG3857.RADIUS)) / Math.PI - 90;
+ return output;
+goog.provide('ol.sphere.WGS84');
+ * A sphere with radius equal to the semi-major axis of the WGS84 ellipsoid.
+ * @const
+ol.sphere.WGS84 = new ol.Sphere(6378137);
+goog.provide('ol.proj.EPSG4326');
+goog.require('ol.sphere.WGS84');
+ * @classdesc
+ * Projection object for WGS84 geographic coordinates (EPSG:4326).
+ * Note that OpenLayers does not strictly comply with the EPSG definition.
+ * The EPSG registry defines 4326 as a CRS for Latitude,Longitude (y,x).
+ * OpenLayers treats EPSG:4326 as a pseudo-projection, with x,y coordinates.
+ * @constructor
+ * @param {string=} opt_axisOrientation Axis orientation.
+ * @private
+ol.proj.EPSG4326.Projection_ = function(code, opt_axisOrientation) {
+ code: code,
+ units: ol.proj.Units.DEGREES,
+ extent: ol.proj.EPSG4326.EXTENT,
+ axisOrientation: opt_axisOrientation,
+ global: true,
+ metersPerUnit: ol.proj.EPSG4326.METERS_PER_UNIT,
+ worldExtent: ol.proj.EPSG4326.EXTENT
+ol.inherits(ol.proj.EPSG4326.Projection_, ol.proj.Projection);
+ * Extent of the EPSG:4326 projection which is the whole world.
+ * @const
+ol.proj.EPSG4326.EXTENT = [-180, -90, 180, 90];
+ * @const
+ * @type {number}
+ol.proj.EPSG4326.METERS_PER_UNIT = Math.PI * ol.sphere.WGS84.radius / 180;
+ * Projections equal to EPSG:4326.
+ * @const
+ol.proj.EPSG4326.PROJECTIONS = [
+ new ol.proj.EPSG4326.Projection_('CRS:84'),
+ new ol.proj.EPSG4326.Projection_('EPSG:4326', 'neu'),
+ new ol.proj.EPSG4326.Projection_('urn:ogc:def:crs:EPSG::4326', 'neu'),
+ new ol.proj.EPSG4326.Projection_('urn:ogc:def:crs:EPSG:6.6:4326', 'neu'),
+ new ol.proj.EPSG4326.Projection_('urn:ogc:def:crs:OGC:1.3:CRS84'),
+ new ol.proj.EPSG4326.Projection_('urn:ogc:def:crs:OGC:2:84'),
+ new ol.proj.EPSG4326.Projection_('http://www.opengis.net/gml/srs/epsg.xml#4326', 'neu'),
+ new ol.proj.EPSG4326.Projection_('urn:x-ogc:def:crs:EPSG:4326', 'neu')
+goog.provide('ol.proj.projections');
+ * @private
+ * @type {Object.<string, ol.proj.Projection>}
+ol.proj.projections.cache_ = {};
+ * Clear the projections cache.
+ol.proj.projections.clear = function() {
+ ol.proj.projections.cache_ = {};
+ * Get a cached projection by code.
+ * @param {string} code The code for the projection.
+ * @return {ol.proj.Projection} The projection (if cached).
+ol.proj.projections.get = function(code) {
+ var projections = ol.proj.projections.cache_;
+ return projections[code] || null;
+ * Add a projection to the cache.
+ * @param {string} code The projection code.
+ * @param {ol.proj.Projection} projection The projection to cache.
+ol.proj.projections.add = function(code, projection) {
+ projections[code] = projection;
+goog.provide('ol.proj.transforms');
+goog.require('ol.obj');
+ * @private
+ * @type {Object.<string, Object.<string, ol.TransformFunction>>}
+ol.proj.transforms.cache_ = {};
+ * Clear the transform cache.
+ol.proj.transforms.clear = function() {
+ ol.proj.transforms.cache_ = {};
+ * Registers a conversion function to convert coordinates from the source
+ * projection to the destination projection.
+ * @param {ol.proj.Projection} source Source.
+ * @param {ol.proj.Projection} destination Destination.
+ * @param {ol.TransformFunction} transformFn Transform.
+ol.proj.transforms.add = function(source, destination, transformFn) {
+ var sourceCode = source.getCode();
+ var destinationCode = destination.getCode();
+ var transforms = ol.proj.transforms.cache_;
+ if (!(sourceCode in transforms)) {
+ transforms[sourceCode] = {};
+ transforms[sourceCode][destinationCode] = transformFn;
+ * Unregisters the conversion function to convert coordinates from the source
+ * projection to the destination projection. This method is used to clean up
+ * cached transforms during testing.
+ * @param {ol.proj.Projection} source Source projection.
+ * @param {ol.proj.Projection} destination Destination projection.
+ * @return {ol.TransformFunction} transformFn The unregistered transform.
+ol.proj.transforms.remove = function(source, destination) {
+ var transform = transforms[sourceCode][destinationCode];
+ delete transforms[sourceCode][destinationCode];
+ if (ol.obj.isEmpty(transforms[sourceCode])) {
+ delete transforms[sourceCode];
+ return transform;
+ * Get a transform given a source code and a destination code.
+ * @param {string} sourceCode The code for the source projection.
+ * @param {string} destinationCode The code for the destination projection.
+ * @return {ol.TransformFunction|undefined} The transform function (if found).
+ol.proj.transforms.get = function(sourceCode, destinationCode) {
+ var transform;
+ if (sourceCode in transforms && destinationCode in transforms[sourceCode]) {
+ transform = transforms[sourceCode][destinationCode];
+ return transform;
+goog.provide('ol.proj');
+goog.require('ol.extent');
+goog.require('ol.proj.EPSG3857');
+goog.require('ol.proj.EPSG4326');
+goog.require('ol.proj.projections');
+goog.require('ol.proj.transforms');
+ * @const
+ * @api
+ol.proj.METERS_PER_UNIT = ol.proj.Units.METERS_PER_UNIT;
+if (ol.ENABLE_PROJ4JS) {
+ * Register proj4. If not explicitly registered, it will be assumed that
+ * proj4js will be loaded in the global namespace. For example in a
+ * browserify ES6 environment you could use:
+ * import ol from 'openlayers';
+ * import proj4 from 'proj4';
+ * ol.proj.setProj4(proj4);
+ * @param {Proj4} proj4 Proj4.
+ * @api
+ ol.proj.setProj4 = function(proj4) {
+ ol.proj.proj4.set(proj4);
+ * Get the resolution of the point in degrees or distance units.
+ * For projections with degrees as the unit this will simply return the
+ * provided resolution. For other projections the point resolution is
+ * estimated by transforming the 'point' pixel to EPSG:4326,
+ * measuring its width and height on the normal sphere,
+ * and taking the average of the width and height.
+ * @param {ol.proj.Projection} projection The projection.
+ * @param {number} resolution Nominal resolution in projection units.
+ * @param {ol.Coordinate} point Point to find adjusted resolution at.
+ * @return {number} Point resolution at point in projection units.
+ * @api
+ol.proj.getPointResolution = function(projection, resolution, point) {
+ var pointResolution;
+ var getter = projection.getPointResolutionFunc();
+ if (getter) {
+ pointResolution = getter(resolution, point);
+ } else {
+ var units = projection.getUnits();
+ if (units == ol.proj.Units.DEGREES) {
+ pointResolution = resolution;
+ } else {
+ // Estimate point resolution by transforming the center pixel to EPSG:4326,
+ // measuring its width and height on the normal sphere, and taking the
+ // average of the width and height.
+ var toEPSG4326 = ol.proj.getTransformFromProjections(projection, ol.proj.get('EPSG:4326'));
+ var vertices = [
+ point[0] - resolution / 2, point[1],
+ point[0] + resolution / 2, point[1],
+ point[0], point[1] - resolution / 2,
+ point[0], point[1] + resolution / 2
+ vertices = toEPSG4326(vertices, vertices, 2);
+ var width = ol.sphere.NORMAL.haversineDistance(
+ vertices.slice(0, 2), vertices.slice(2, 4));
+ var height = ol.sphere.NORMAL.haversineDistance(
+ vertices.slice(4, 6), vertices.slice(6, 8));
+ pointResolution = (width + height) / 2;
+ var metersPerUnit = projection.getMetersPerUnit();
+ if (metersPerUnit !== undefined) {
+ pointResolution /= metersPerUnit;
+ return pointResolution;
+ * Registers transformation functions that don't alter coordinates. Those allow
+ * to transform between projections with equal meaning.
+ * @param {Array.<ol.proj.Projection>} projections Projections.
+ * @api
+ol.proj.addEquivalentProjections = function(projections) {
+ ol.proj.addProjections(projections);
+ projections.forEach(function(source) {
+ projections.forEach(function(destination) {
+ if (source !== destination) {
+ ol.proj.transforms.add(source, destination, ol.proj.cloneTransform);
+ * Registers transformation functions to convert coordinates in any projection
+ * in projection1 to any projection in projection2.
+ * @param {Array.<ol.proj.Projection>} projections1 Projections with equal
+ * meaning.
+ * @param {Array.<ol.proj.Projection>} projections2 Projections with equal
+ * meaning.
+ * @param {ol.TransformFunction} forwardTransform Transformation from any
+ * projection in projection1 to any projection in projection2.
+ * @param {ol.TransformFunction} inverseTransform Transform from any projection
+ * in projection2 to any projection in projection1..
+ol.proj.addEquivalentTransforms = function(projections1, projections2, forwardTransform, inverseTransform) {
+ projections1.forEach(function(projection1) {
+ projections2.forEach(function(projection2) {
+ ol.proj.transforms.add(projection1, projection2, forwardTransform);
+ ol.proj.transforms.add(projection2, projection1, inverseTransform);
+ * Add a Projection object to the list of supported projections that can be
+ * looked up by their code.
+ * @param {ol.proj.Projection} projection Projection instance.
+ * @api
+ol.proj.addProjection = function(projection) {
+ ol.proj.projections.add(projection.getCode(), projection);
+ ol.proj.transforms.add(projection, projection, ol.proj.cloneTransform);
+ol.proj.addProjections = function(projections) {
+ var addedProjections = [];
+ projections.forEach(function(projection) {
+ addedProjections.push(ol.proj.addProjection(projection));
+ * Clear all cached projections and transforms.
+ol.proj.clearAllProjections = function() {
+ ol.proj.projections.clear();
+ ol.proj.transforms.clear();
+ * @param {ol.proj.Projection|string|undefined} projection Projection.
+ * @param {string} defaultCode Default code.
+ * @return {ol.proj.Projection} Projection.
+ol.proj.createProjection = function(projection, defaultCode) {
+ if (!projection) {
+ return ol.proj.get(defaultCode);
+ } else if (typeof projection === 'string') {
+ return ol.proj.get(projection);
+ } else {
+ return /** @type {ol.proj.Projection} */ (projection);
+ * Registers coordinate transform functions to convert coordinates between the
+ * source projection and the destination projection.
+ * The forward and inverse functions convert coordinate pairs; this function
+ * converts these into the functions used internally which also handle
+ * extents and coordinate arrays.
+ * @param {ol.ProjectionLike} source Source projection.
+ * @param {ol.ProjectionLike} destination Destination projection.
+ * @param {function(ol.Coordinate): ol.Coordinate} forward The forward transform
+ * function (that is, from the source projection to the destination
+ * projection) that takes a {@link ol.Coordinate} as argument and returns
+ * the transformed {@link ol.Coordinate}.
+ * @param {function(ol.Coordinate): ol.Coordinate} inverse The inverse transform
+ * function (that is, from the destination projection to the source
+ * @api
+ol.proj.addCoordinateTransforms = function(source, destination, forward, inverse) {
+ var sourceProj = ol.proj.get(source);
+ var destProj = ol.proj.get(destination);
+ ol.proj.transforms.add(sourceProj, destProj,
+ ol.proj.createTransformFromCoordinateTransform(forward));
+ ol.proj.transforms.add(destProj, sourceProj,
+ ol.proj.createTransformFromCoordinateTransform(inverse));
+ * Creates a {@link ol.TransformFunction} from a simple 2D coordinate transform
+ * function.
+ * @param {function(ol.Coordinate): ol.Coordinate} transform Coordinate
+ * transform.
+ * @return {ol.TransformFunction} Transform function.
+ol.proj.createTransformFromCoordinateTransform = function(transform) {
+ return (
+ * @param {Array.<number>} input Input.
+ * @param {Array.<number>=} opt_output Output.
+ * @param {number=} opt_dimension Dimension.
+ * @return {Array.<number>} Output.
+ function(input, opt_output, opt_dimension) {
+ var length = input.length;
+ var dimension = opt_dimension !== undefined ? opt_dimension : 2;
+ var output = opt_output !== undefined ? opt_output : new Array(length);
+ var point, i, j;
+ for (i = 0; i < length; i += dimension) {
+ point = transform([input[i], input[i + 1]]);
+ output[i] = point[0];
+ output[i + 1] = point[1];
+ for (j = dimension - 1; j >= 2; --j) {
+ output[i + j] = input[i + j];
+ return output;
+ * Transforms a coordinate from longitude/latitude to a different projection.
+ * @param {ol.Coordinate} coordinate Coordinate as longitude and latitude, i.e.
+ * an array with longitude as 1st and latitude as 2nd element.
+ * @param {ol.ProjectionLike=} opt_projection Target projection. The
+ * default is Web Mercator, i.e. 'EPSG:3857'.
+ * @return {ol.Coordinate} Coordinate projected to the target projection.
+ * @api
+ol.proj.fromLonLat = function(coordinate, opt_projection) {
+ return ol.proj.transform(coordinate, 'EPSG:4326',
+ opt_projection !== undefined ? opt_projection : 'EPSG:3857');
+ * Transforms a coordinate to longitude/latitude.
+ * @param {ol.Coordinate} coordinate Projected coordinate.
+ * @param {ol.ProjectionLike=} opt_projection Projection of the coordinate.
+ * The default is Web Mercator, i.e. 'EPSG:3857'.
+ * @return {ol.Coordinate} Coordinate as longitude and latitude, i.e. an array
+ * with longitude as 1st and latitude as 2nd element.
+ * @api
+ol.proj.toLonLat = function(coordinate, opt_projection) {
+ opt_projection !== undefined ? opt_projection : 'EPSG:3857', 'EPSG:4326');
+ * Fetches a Projection object for the code specified.
+ * @param {ol.ProjectionLike} projectionLike Either a code string which is
+ * a combination of authority and identifier such as "EPSG:4326", or an
+ * existing projection object, or undefined.
+ * @return {ol.proj.Projection} Projection object, or null if not in list.
+ * @api
+ol.proj.get = function(projectionLike) {
+ var projection = null;
+ if (projectionLike instanceof ol.proj.Projection) {
+ projection = projectionLike;
+ } else if (typeof projectionLike === 'string') {
+ var code = projectionLike;
+ projection = ol.proj.projections.get(code);
+ if (!projection && typeof proj4js == 'function' &&
+ proj4js.defs(code) !== undefined) {
+ projection = new ol.proj.Projection({code: code});
+ ol.proj.addProjection(projection);
+ return projection;
+ * Checks if two projections are the same, that is every coordinate in one
+ * projection does represent the same geographic point as the same coordinate in
+ * the other projection.
+ * @param {ol.proj.Projection} projection1 Projection 1.
+ * @param {ol.proj.Projection} projection2 Projection 2.
+ * @return {boolean} Equivalent.
+ * @api
+ol.proj.equivalent = function(projection1, projection2) {
+ if (projection1 === projection2) {
+ return true;
+ var equalUnits = projection1.getUnits() === projection2.getUnits();
+ if (projection1.getCode() === projection2.getCode()) {
+ return equalUnits;
+ } else {
+ var transformFn = ol.proj.getTransformFromProjections(
+ projection1, projection2);
+ return transformFn === ol.proj.cloneTransform && equalUnits;
+ * Given the projection-like objects, searches for a transformation
+ * function to convert a coordinates array from the source projection to the
+ * destination projection.
+ * @param {ol.ProjectionLike} source Source.
+ * @param {ol.ProjectionLike} destination Destination.
+ * @api
+ol.proj.getTransform = function(source, destination) {
+ var sourceProjection = ol.proj.get(source);
+ var destinationProjection = ol.proj.get(destination);
+ return ol.proj.getTransformFromProjections(
+ sourceProjection, destinationProjection);
+ * Searches in the list of transform functions for the function for converting
+ * coordinates from the source projection to the destination projection.
+ * @param {ol.proj.Projection} sourceProjection Source Projection object.
+ * @param {ol.proj.Projection} destinationProjection Destination Projection
+ * object.
+ol.proj.getTransformFromProjections = function(sourceProjection, destinationProjection) {
+ var sourceCode = sourceProjection.getCode();
+ var destinationCode = destinationProjection.getCode();
+ var transform = ol.proj.transforms.get(sourceCode, destinationCode);
+ if (ol.ENABLE_PROJ4JS && !transform) {
+ var sourceDef = proj4js.defs(sourceCode);
+ var destinationDef = proj4js.defs(destinationCode);
+ if (sourceDef !== undefined && destinationDef !== undefined) {
+ if (sourceDef === destinationDef) {
+ ol.proj.addEquivalentProjections([destinationProjection, sourceProjection]);
+ } else {
+ var proj4Transform = proj4js(destinationCode, sourceCode);
+ ol.proj.addCoordinateTransforms(destinationProjection, sourceProjection,
+ proj4Transform.forward, proj4Transform.inverse);
+ transform = ol.proj.transforms.get(sourceCode, destinationCode);
+ if (!transform) {
+ transform = ol.proj.identityTransform;
+ return transform;
+ * @param {Array.<number>} input Input coordinate array.
+ * @return {Array.<number>} Input coordinate array (same array as input).
+ol.proj.identityTransform = function(input, opt_output, opt_dimension) {
+ if (opt_output !== undefined && input !== opt_output) {
+ for (var i = 0, ii = input.length; i < ii; ++i) {
+ opt_output[i] = input[i];
+ input = opt_output;
+ return input;
+ * @return {Array.<number>} Output coordinate array (new array, same coordinate
+ * values).
+ol.proj.cloneTransform = function(input, opt_output, opt_dimension) {
+ var output;
+ if (opt_output !== undefined) {
+ } else {
+ return output;
+ * Transforms a coordinate from source projection to destination projection.
+ * This returns a new coordinate (and does not modify the original).
+ * See {@link ol.proj.transformExtent} for extent transformation.
+ * See the transform method of {@link ol.geom.Geometry} and its subclasses for
+ * geometry transforms.
+ * @param {ol.ProjectionLike} source Source projection-like.
+ * @param {ol.ProjectionLike} destination Destination projection-like.
+ * @return {ol.Coordinate} Coordinate.
+ * @api
+ol.proj.transform = function(coordinate, source, destination) {
+ var transformFn = ol.proj.getTransform(source, destination);
+ return transformFn(coordinate, undefined, coordinate.length);
+ * Transforms an extent from source projection to destination projection. This
+ * returns a new extent (and does not modify the original).
+ * @param {ol.Extent} extent The extent to transform.
+ * @return {ol.Extent} The transformed extent.
+ * @api
+ol.proj.transformExtent = function(extent, source, destination) {
+ return ol.extent.applyTransform(extent, transformFn);
+ * Transforms the given point to the destination projection.
+ * @param {ol.Coordinate} point Point.
+ * @param {ol.proj.Projection} sourceProjection Source projection.
+ * @param {ol.proj.Projection} destinationProjection Destination projection.
+ * @return {ol.Coordinate} Point.
+ol.proj.transformWithProjections = function(point, sourceProjection, destinationProjection) {
+ return transformFn(point);
+ * Add transforms to and from EPSG:4326 and EPSG:3857. This function is called
+ * by when this module is executed and should only need to be called again after
+ * `ol.proj.clearAllProjections()` is called (e.g. in tests).
+ol.proj.addCommon = function() {
+ // Add transformations that don't alter coordinates to convert within set of
+ // projections with equal meaning.
+ ol.proj.addEquivalentProjections(ol.proj.EPSG3857.PROJECTIONS);
+ ol.proj.addEquivalentProjections(ol.proj.EPSG4326.PROJECTIONS);
+ // Add transformations to convert EPSG:4326 like coordinates to EPSG:3857 like
+ // coordinates and back.
+ ol.proj.addEquivalentTransforms(
+ ol.proj.EPSG4326.PROJECTIONS,
+ ol.proj.EPSG3857.PROJECTIONS,
+ ol.proj.EPSG3857.fromEPSG4326,
+ ol.proj.EPSG3857.toEPSG4326);
+ol.proj.addCommon();
+goog.provide('ol.tilecoord');
+ * @param {number} z Z.
+ * @param {ol.TileCoord=} opt_tileCoord Tile coordinate.
+ * @return {ol.TileCoord} Tile coordinate.
+ol.tilecoord.createOrUpdate = function(z, x, y, opt_tileCoord) {
+ if (opt_tileCoord !== undefined) {
+ opt_tileCoord[0] = z;
+ opt_tileCoord[1] = x;
+ opt_tileCoord[2] = y;
+ return opt_tileCoord;
+ } else {
+ return [z, x, y];
+ * @return {string} Key.
+ol.tilecoord.getKeyZXY = function(z, x, y) {
+ return z + '/' + x + '/' + y;
+ * @param {ol.TileCoord} tileCoord Tile coord.
+ * @return {number} Hash.
+ol.tilecoord.hash = function(tileCoord) {
+ return (tileCoord[1] << tileCoord[0]) + tileCoord[2];
+ * @return {string} Quad key.
+ol.tilecoord.quadKey = function(tileCoord) {
+ var z = tileCoord[0];
+ var digits = new Array(z);
+ var mask = 1 << (z - 1);
+ var i, charCode;
+ for (i = 0; i < z; ++i) {
+ // 48 is charCode for 0 - '0'.charCodeAt(0)
+ charCode = 48;
+ if (tileCoord[1] & mask) {
+ charCode += 1;
+ if (tileCoord[2] & mask) {
+ charCode += 2;
+ digits[i] = String.fromCharCode(charCode);
+ mask >>= 1;
+ return digits.join('');
+ * @param {ol.TileCoord} tileCoord Tile coordinate.
+ * @param {!ol.tilegrid.TileGrid} tileGrid Tile grid.
+ * @return {boolean} Tile coordinate is within extent and zoom level range.
+ol.tilecoord.withinExtentAndZ = function(tileCoord, tileGrid) {
+ var x = tileCoord[1];
+ var y = tileCoord[2];
+ if (tileGrid.getMinZoom() > z || z > tileGrid.getMaxZoom()) {
+ return false;
+ var extent = tileGrid.getExtent();
+ var tileRange;
+ if (!extent) {
+ tileRange = tileGrid.getFullTileRange(z);
+ } else {
+ tileRange = tileGrid.getTileRangeForExtentAndZ(extent, z);
+ if (!tileRange) {
+ return true;
+ } else {
+ return tileRange.containsXY(x, y);
+goog.provide('ol.tilegrid.TileGrid');
+goog.require('ol');
+goog.require('ol.TileRange');
+goog.require('ol.array');
+goog.require('ol.size');
+goog.require('ol.tilecoord');
+ * @classdesc
+ * Base class for setting the grid pattern for sources accessing tiled-image
+ * servers.
+ * @constructor
+ * @param {olx.tilegrid.TileGridOptions} options Tile grid options.
+ * @struct
+ * @api
+ol.tilegrid.TileGrid = function(options) {
+ * @protected
+ * @type {number}
+ this.minZoom = options.minZoom !== undefined ? options.minZoom : 0;
+ * @private
+ * @type {!Array.<number>}
+ this.resolutions_ = options.resolutions;
+ ol.asserts.assert(ol.array.isSorted(this.resolutions_, function(a, b) {
+ return b - a;
+ }, true), 17); // `resolutions` must be sorted in descending order
+ * @protected
+ * @type {number}
+ this.maxZoom = this.resolutions_.length - 1;
+ * @private
+ * @type {ol.Coordinate}
+ this.origin_ = options.origin !== undefined ? options.origin : null;
+ * @private
+ * @type {Array.<ol.Coordinate>}
+ this.origins_ = null;
+ if (options.origins !== undefined) {
+ this.origins_ = options.origins;
+ ol.asserts.assert(this.origins_.length == this.resolutions_.length,
+ 20); // Number of `origins` and `resolutions` must be equal
+ var extent = options.extent;
+ if (extent !== undefined &&
+ !this.origin_ && !this.origins_) {
+ this.origin_ = ol.extent.getTopLeft(extent);
+ (!this.origin_ && this.origins_) || (this.origin_ && !this.origins_),
+ 18); // Either `origin` or `origins` must be configured, never both
+ * @private
+ * @type {Array.<number|ol.Size>}
+ this.tileSizes_ = null;
+ if (options.tileSizes !== undefined) {
+ this.tileSizes_ = options.tileSizes;
+ ol.asserts.assert(this.tileSizes_.length == this.resolutions_.length,
+ 19); // Number of `tileSizes` and `resolutions` must be equal
+ * @private
+ * @type {number|ol.Size}
+ this.tileSize_ = options.tileSize !== undefined ?
+ options.tileSize :
+ !this.tileSizes_ ? ol.DEFAULT_TILE_SIZE : null;
+ (!this.tileSize_ && this.tileSizes_) ||
+ (this.tileSize_ && !this.tileSizes_),
+ 22); // Either `tileSize` or `tileSizes` must be configured, never both
+ * @private
+ this.extent_ = extent !== undefined ? extent : null;
+ * @private
+ * @type {Array.<ol.TileRange>}
+ this.fullTileRanges_ = null;
+ * @private
+ * @type {ol.Size}
+ this.tmpSize_ = [0, 0];
+ if (options.sizes !== undefined) {
+ this.fullTileRanges_ = options.sizes.map(function(size, z) {
+ var tileRange = new ol.TileRange(
+ Math.min(0, size[0]), Math.max(size[0] - 1, -1),
+ Math.min(0, size[1]), Math.max(size[1] - 1, -1));
+ return tileRange;
+ }, this);
+ } else if (extent) {
+ this.calculateTileRanges_(extent);
+ * @private
+ * @type {ol.TileCoord}
+ol.tilegrid.TileGrid.tmpTileCoord_ = [0, 0, 0];
+ * Call a function with each tile coordinate for a given extent and zoom level.
+ * @param {number} zoom Zoom level.
+ * @param {function(ol.TileCoord)} callback Function called with each tile coordinate.
+ * @api
+ol.tilegrid.TileGrid.prototype.forEachTileCoord = function(extent, zoom, callback) {
+ var tileRange = this.getTileRangeForExtentAndZ(extent, zoom);
+ for (var i = tileRange.minX, ii = tileRange.maxX; i <= ii; ++i) {
+ for (var j = tileRange.minY, jj = tileRange.maxY; j <= jj; ++j) {
+ callback([zoom, i, j]);
+ * @param {function(this: T, number, ol.TileRange): boolean} callback Callback.
+ * @param {T=} opt_this The object to use as `this` in `callback`.
+ * @param {ol.TileRange=} opt_tileRange Temporary ol.TileRange object.
+ * @param {ol.Extent=} opt_extent Temporary ol.Extent object.
+ * @return {boolean} Callback succeeded.
+ * @template T
+ol.tilegrid.TileGrid.prototype.forEachTileCoordParentTileRange = function(tileCoord, callback, opt_this, opt_tileRange, opt_extent) {
+ var tileCoordExtent = this.getTileCoordExtent(tileCoord, opt_extent);
+ var z = tileCoord[0] - 1;
+ while (z >= this.minZoom) {
+ if (callback.call(opt_this, z,
+ this.getTileRangeForExtentAndZ(tileCoordExtent, z, opt_tileRange))) {
+ return true;
+ --z;
+ return false;
+ * Get the extent for this tile grid, if it was configured.
+ol.tilegrid.TileGrid.prototype.getExtent = function() {
+ * Get the maximum zoom level for the grid.
+ * @return {number} Max zoom.
+ * @api
+ol.tilegrid.TileGrid.prototype.getMaxZoom = function() {
+ return this.maxZoom;
+ * Get the minimum zoom level for the grid.
+ * @return {number} Min zoom.
+ * @api
+ol.tilegrid.TileGrid.prototype.getMinZoom = function() {
+ return this.minZoom;
+ * Get the origin for the grid at the given zoom level.
+ * @return {ol.Coordinate} Origin.
+ * @api
+ol.tilegrid.TileGrid.prototype.getOrigin = function(z) {
+ if (this.origin_) {
+ return this.origin_;
+ } else {
+ return this.origins_[z];
+ * Get the resolution for the given zoom level.
+ * @return {number} Resolution.
+ * @api
+ol.tilegrid.TileGrid.prototype.getResolution = function(z) {
+ return this.resolutions_[z];
+ * Get the list of resolutions for the tile grid.
+ * @return {Array.<number>} Resolutions.
+ * @api
+ol.tilegrid.TileGrid.prototype.getResolutions = function() {
+ return this.resolutions_;
+ * @return {ol.TileRange} Tile range.
+ol.tilegrid.TileGrid.prototype.getTileCoordChildTileRange = function(tileCoord, opt_tileRange, opt_extent) {
+ if (tileCoord[0] < this.maxZoom) {
+ return this.getTileRangeForExtentAndZ(
+ tileCoordExtent, tileCoord[0] + 1, opt_tileRange);
+ } else {
+ return null;
+ * @param {ol.TileRange} tileRange Tile range.
+ol.tilegrid.TileGrid.prototype.getTileRangeExtent = function(z, tileRange, opt_extent) {
+ var origin = this.getOrigin(z);
+ var resolution = this.getResolution(z);
+ var tileSize = ol.size.toSize(this.getTileSize(z), this.tmpSize_);
+ var minX = origin[0] + tileRange.minX * tileSize[0] * resolution;
+ var maxX = origin[0] + (tileRange.maxX + 1) * tileSize[0] * resolution;
+ var minY = origin[1] + tileRange.minY * tileSize[1] * resolution;
+ var maxY = origin[1] + (tileRange.maxY + 1) * tileSize[1] * resolution;
+ * @param {ol.TileRange=} opt_tileRange Temporary tile range object.
+ol.tilegrid.TileGrid.prototype.getTileRangeForExtentAndResolution = function(extent, resolution, opt_tileRange) {
+ var tileCoord = ol.tilegrid.TileGrid.tmpTileCoord_;
+ this.getTileCoordForXYAndResolution_(
+ extent[0], extent[1], resolution, false, tileCoord);
+ var minX = tileCoord[1];
+ var minY = tileCoord[2];
+ extent[2], extent[3], resolution, true, tileCoord);
+ return ol.TileRange.createOrUpdate(
+ minX, tileCoord[1], minY, tileCoord[2], opt_tileRange);
+ol.tilegrid.TileGrid.prototype.getTileRangeForExtentAndZ = function(extent, z, opt_tileRange) {
+ return this.getTileRangeForExtentAndResolution(
+ extent, resolution, opt_tileRange);
+ * @return {ol.Coordinate} Tile center.
+ol.tilegrid.TileGrid.prototype.getTileCoordCenter = function(tileCoord) {
+ var origin = this.getOrigin(tileCoord[0]);
+ var resolution = this.getResolution(tileCoord[0]);
+ var tileSize = ol.size.toSize(this.getTileSize(tileCoord[0]), this.tmpSize_);
+ return [
+ origin[0] + (tileCoord[1] + 0.5) * tileSize[0] * resolution,
+ origin[1] + (tileCoord[2] + 0.5) * tileSize[1] * resolution
+ * Get the extent of a tile coordinate.
+ * @param {ol.Extent=} opt_extent Temporary extent object.
+ * @api
+ol.tilegrid.TileGrid.prototype.getTileCoordExtent = function(tileCoord, opt_extent) {
+ var minX = origin[0] + tileCoord[1] * tileSize[0] * resolution;
+ var minY = origin[1] + tileCoord[2] * tileSize[1] * resolution;
+ var maxX = minX + tileSize[0] * resolution;
+ var maxY = minY + tileSize[1] * resolution;
+ * Get the tile coordinate for the given map coordinate and resolution. This
+ * method considers that coordinates that intersect tile boundaries should be
+ * assigned the higher tile coordinate.
+ * @param {ol.TileCoord=} opt_tileCoord Destination ol.TileCoord object.
+ * @api
+ol.tilegrid.TileGrid.prototype.getTileCoordForCoordAndResolution = function(coordinate, resolution, opt_tileCoord) {
+ return this.getTileCoordForXYAndResolution_(
+ coordinate[0], coordinate[1], resolution, false, opt_tileCoord);
+ * @param {number} x X.
+ * @param {number} y Y.
+ * @param {boolean} reverseIntersectionPolicy Instead of letting edge
+ * intersections go to the higher tile coordinate, let edge intersections
+ * go to the lower tile coordinate.
+ * @param {ol.TileCoord=} opt_tileCoord Temporary ol.TileCoord object.
+ * @private
+ol.tilegrid.TileGrid.prototype.getTileCoordForXYAndResolution_ = function(
+ x, y, resolution, reverseIntersectionPolicy, opt_tileCoord) {
+ var z = this.getZForResolution(resolution);
+ var scale = resolution / this.getResolution(z);
+ var adjustX = reverseIntersectionPolicy ? 0.5 : 0;
+ var adjustY = reverseIntersectionPolicy ? 0 : 0.5;
+ var xFromOrigin = Math.floor((x - origin[0]) / resolution + adjustX);
+ var yFromOrigin = Math.floor((y - origin[1]) / resolution + adjustY);
+ var tileCoordX = scale * xFromOrigin / tileSize[0];
+ var tileCoordY = scale * yFromOrigin / tileSize[1];
+ if (reverseIntersectionPolicy) {
+ tileCoordX = Math.ceil(tileCoordX) - 1;
+ tileCoordY = Math.ceil(tileCoordY) - 1;
+ } else {
+ tileCoordX = Math.floor(tileCoordX);
+ tileCoordY = Math.floor(tileCoordY);
+ return ol.tilecoord.createOrUpdate(z, tileCoordX, tileCoordY, opt_tileCoord);
+ * Get a tile coordinate given a map coordinate and zoom level.
+ * @param {number} z Zoom level.
+ * @api
+ol.tilegrid.TileGrid.prototype.getTileCoordForCoordAndZ = function(coordinate, z, opt_tileCoord) {
+ * @return {number} Tile resolution.
+ol.tilegrid.TileGrid.prototype.getTileCoordResolution = function(tileCoord) {
+ return this.resolutions_[tileCoord[0]];
+ * Get the tile size for a zoom level. The type of the return value matches the
+ * `tileSize` or `tileSizes` that the tile grid was configured with. To always
+ * get an `ol.Size`, run the result through `ol.size.toSize()`.
+ * @return {number|ol.Size} Tile size.
+ * @api
+ol.tilegrid.TileGrid.prototype.getTileSize = function(z) {
+ if (this.tileSize_) {
+ return this.tileSize_;
+ } else {
+ return this.tileSizes_[z];
+ * @return {ol.TileRange} Extent tile range for the specified zoom level.
+ol.tilegrid.TileGrid.prototype.getFullTileRange = function(z) {
+ if (!this.fullTileRanges_) {
+ return null;
+ } else {
+ return this.fullTileRanges_[z];
+ * @param {number=} opt_direction If 0, the nearest resolution will be used.
+ * If 1, the nearest lower resolution will be used. If -1, the nearest
+ * higher resolution will be used. Default is 0.
+ * @return {number} Z.
+ * @api
+ol.tilegrid.TileGrid.prototype.getZForResolution = function(
+ resolution, opt_direction) {
+ var z = ol.array.linearFindNearest(this.resolutions_, resolution,
+ opt_direction || 0);
+ return ol.math.clamp(z, this.minZoom, this.maxZoom);
+ * @param {!ol.Extent} extent Extent for this tile grid.
+ * @private
+ol.tilegrid.TileGrid.prototype.calculateTileRanges_ = function(extent) {
+ var length = this.resolutions_.length;
+ var fullTileRanges = new Array(length);
+ for (var z = this.minZoom; z < length; ++z) {
+ fullTileRanges[z] = this.getTileRangeForExtentAndZ(extent, z);
+ this.fullTileRanges_ = fullTileRanges;
+goog.provide('ol.tilegrid');
+goog.require('ol.extent.Corner');
+goog.require('ol.proj');
+goog.require('ol.tilegrid.TileGrid');
+ * @param {ol.proj.Projection} projection Projection.
+ * @return {!ol.tilegrid.TileGrid} Default tile grid for the passed projection.
+ol.tilegrid.getForProjection = function(projection) {
+ var tileGrid = projection.getDefaultTileGrid();
+ if (!tileGrid) {
+ tileGrid = ol.tilegrid.createForProjection(projection);
+ projection.setDefaultTileGrid(tileGrid);
+ return tileGrid;
+ * @param {ol.tilegrid.TileGrid} tileGrid Tile grid.
+ol.tilegrid.wrapX = function(tileGrid, tileCoord, projection) {
+ var center = tileGrid.getTileCoordCenter(tileCoord);
+ var projectionExtent = ol.tilegrid.extentFromProjection(projection);
+ if (!ol.extent.containsCoordinate(projectionExtent, center)) {
+ var worldWidth = ol.extent.getWidth(projectionExtent);
+ var worldsAway = Math.ceil((projectionExtent[0] - center[0]) / worldWidth);
+ center[0] += worldWidth * worldsAway;
+ return tileGrid.getTileCoordForCoordAndZ(center, z);
+ } else {
+ return tileCoord;
+ * @param {ol.Extent} extent Extent.
+ * @param {number=} opt_maxZoom Maximum zoom level (default is
+ * ol.DEFAULT_MAX_ZOOM).
+ * @param {number|ol.Size=} opt_tileSize Tile size (default uses
+ * ol.DEFAULT_TILE_SIZE).
+ * @param {ol.extent.Corner=} opt_corner Extent corner (default is
+ * ol.extent.Corner.TOP_LEFT).
+ * @return {!ol.tilegrid.TileGrid} TileGrid instance.
+ol.tilegrid.createForExtent = function(extent, opt_maxZoom, opt_tileSize, opt_corner) {
+ var corner = opt_corner !== undefined ?
+ opt_corner : ol.extent.Corner.TOP_LEFT;
+ var resolutions = ol.tilegrid.resolutionsFromExtent(
+ extent, opt_maxZoom, opt_tileSize);
+ return new ol.tilegrid.TileGrid({
+ extent: extent,
+ origin: ol.extent.getCorner(extent, corner),
+ resolutions: resolutions,
+ tileSize: opt_tileSize
+ * Creates a tile grid with a standard XYZ tiling scheme.
+ * @param {olx.tilegrid.XYZOptions=} opt_options Tile grid options.
+ * @return {ol.tilegrid.TileGrid} Tile grid instance.
+ * @api
+ol.tilegrid.createXYZ = function(opt_options) {
+ var options = /** @type {olx.tilegrid.TileGridOptions} */ ({});
+ ol.obj.assign(options, opt_options !== undefined ?
+ opt_options : /** @type {olx.tilegrid.XYZOptions} */ ({}));
+ if (options.extent === undefined) {
+ options.extent = ol.proj.get('EPSG:3857').getExtent();
+ options.resolutions = ol.tilegrid.resolutionsFromExtent(
+ options.extent, options.maxZoom, options.tileSize);
+ delete options.maxZoom;
+ return new ol.tilegrid.TileGrid(options);
+ * Create a resolutions array from an extent. A zoom factor of 2 is assumed.
+ * @return {!Array.<number>} Resolutions array.
+ol.tilegrid.resolutionsFromExtent = function(extent, opt_maxZoom, opt_tileSize) {
+ var maxZoom = opt_maxZoom !== undefined ?
+ opt_maxZoom : ol.DEFAULT_MAX_ZOOM;
+ var height = ol.extent.getHeight(extent);
+ var width = ol.extent.getWidth(extent);
+ var tileSize = ol.size.toSize(opt_tileSize !== undefined ?
+ opt_tileSize : ol.DEFAULT_TILE_SIZE);
+ var maxResolution = Math.max(
+ width / tileSize[0], height / tileSize[1]);
+ var length = maxZoom + 1;
+ var resolutions = new Array(length);
+ for (var z = 0; z < length; ++z) {
+ resolutions[z] = maxResolution / Math.pow(2, z);
+ return resolutions;
+ * @param {ol.ProjectionLike} projection Projection.
+ * @param {ol.Size=} opt_tileSize Tile size (default uses ol.DEFAULT_TILE_SIZE).
+ * ol.extent.Corner.BOTTOM_LEFT).
+ol.tilegrid.createForProjection = function(projection, opt_maxZoom, opt_tileSize, opt_corner) {
+ var extent = ol.tilegrid.extentFromProjection(projection);
+ return ol.tilegrid.createForExtent(
+ extent, opt_maxZoom, opt_tileSize, opt_corner);
+ * Generate a tile grid extent from a projection. If the projection has an
+ * extent, it is used. If not, a global extent is assumed.
+ * @return {ol.Extent} Extent.
+ol.tilegrid.extentFromProjection = function(projection) {
+ projection = ol.proj.get(projection);
+ var extent = projection.getExtent();
+ if (!extent) {
+ var half = 180 * ol.proj.METERS_PER_UNIT[ol.proj.Units.DEGREES] /
+ projection.getMetersPerUnit();
+ extent = ol.extent.createOrUpdate(-half, -half, half, half);
+ return extent;
+goog.provide('ol.Attribution');
+goog.require('ol.tilegrid');
+ * @classdesc
+ * An attribution for a layer source.
+ * Example:
+ * source: new ol.source.OSM({
+ * attributions: [
+ * new ol.Attribution({
+ * html: 'All maps © ' +
+ * '<a href="https://www.opencyclemap.org/">OpenCycleMap</a>'
+ * ol.source.OSM.ATTRIBUTION
+ * @constructor
+ * @param {olx.AttributionOptions} options Attribution options.
+ * @struct
+ * @api
+ol.Attribution = function(options) {
+ * @private
+ * @type {string}
+ this.html_ = options.html;
+ * @private
+ * @type {Object.<string, Array.<ol.TileRange>>}
+ this.tileRanges_ = options.tileRanges ? options.tileRanges : null;
+ * Get the attribution markup.
+ * @return {string} The attribution HTML.
+ * @api
+ol.Attribution.prototype.getHTML = function() {
+ return this.html_;
+ * @param {Object.<string, ol.TileRange>} tileRanges Tile ranges.
+ * @param {!ol.proj.Projection} projection Projection.
+ * @return {boolean} Intersects any tile range.
+ol.Attribution.prototype.intersectsAnyTileRange = function(tileRanges, tileGrid, projection) {
+ if (!this.tileRanges_) {
+ return true;
+ var i, ii, tileRange, zKey;
+ for (zKey in tileRanges) {
+ if (!(zKey in this.tileRanges_)) {
+ continue;
+ tileRange = tileRanges[zKey];
+ var testTileRange;
+ for (i = 0, ii = this.tileRanges_[zKey].length; i < ii; ++i) {
+ testTileRange = this.tileRanges_[zKey][i];
+ if (testTileRange.intersects(tileRange)) {
+ return true;
+ var extentTileRange = tileGrid.getTileRangeForExtentAndZ(
+ ol.tilegrid.extentFromProjection(projection), parseInt(zKey, 10));
+ var width = extentTileRange.getWidth();
+ if (tileRange.minX < extentTileRange.minX ||
+ tileRange.maxX > extentTileRange.maxX) {
+ if (testTileRange.intersects(new ol.TileRange(
+ ol.math.modulo(tileRange.minX, width),
+ ol.math.modulo(tileRange.maxX, width),
+ tileRange.minY, tileRange.maxY))) {
+ return true;
+ if (tileRange.getWidth() > width &&
+ testTileRange.intersects(extentTileRange)) {
+ return true;
+ return false;
+goog.provide('ol.CenterConstraint');
+ * @return {ol.CenterConstraintType} The constraint.
+ol.CenterConstraint.createExtent = function(extent) {
+ return (
+ * @param {ol.Coordinate|undefined} center Center.
+ * @return {ol.Coordinate|undefined} Center.
+ function(center) {
+ if (center) {
+ return [
+ ol.math.clamp(center[0], extent[0], extent[2]),
+ ol.math.clamp(center[1], extent[1], extent[3])
+ } else {
+ return undefined;
+ol.CenterConstraint.none = function(center) {
+ return center;
+goog.provide('ol.CollectionEventType');
+ * @enum {string}
+ol.CollectionEventType = {
+ * Triggered when an item is added to the collection.
+ * @event ol.Collection.Event#add
+ * @api
+ ADD: 'add',
+ * Triggered when an item is removed from the collection.
+ * @event ol.Collection.Event#remove
+ * @api
+ REMOVE: 'remove'
+goog.provide('ol.ObjectEventType');
+ * @enum {string}
+ol.ObjectEventType = {
+ * Triggered when a property is changed.
+ * @event ol.Object.Event#propertychange
+ * @api
+ PROPERTYCHANGE: 'propertychange'
+goog.provide('ol.events');
+ * @param {ol.EventsKey} listenerObj Listener object.
+ * @return {ol.EventsListenerFunctionType} Bound listener.
+ol.events.bindListener_ = function(listenerObj) {
+ var boundListener = function(evt) {
+ var listener = listenerObj.listener;
+ var bindTo = listenerObj.bindTo || listenerObj.target;
+ if (listenerObj.callOnce) {
+ ol.events.unlistenByKey(listenerObj);
+ return listener.call(bindTo, evt);
+ listenerObj.boundListener = boundListener;
+ return boundListener;
+ * Finds the matching {@link ol.EventsKey} in the given listener
+ * array.
+ * @param {!Array<!ol.EventsKey>} listeners Array of listeners.
+ * @param {!Function} listener The listener function.
+ * @param {Object=} opt_this The `this` value inside the listener.
+ * @param {boolean=} opt_setDeleteIndex Set the deleteIndex on the matching
+ * listener, for {@link ol.events.unlistenByKey}.
+ * @return {ol.EventsKey|undefined} The matching listener object.
+ * @private
+ol.events.findListener_ = function(listeners, listener, opt_this,
+ opt_setDeleteIndex) {
+ var listenerObj;
+ for (var i = 0, ii = listeners.length; i < ii; ++i) {
+ listenerObj = listeners[i];
+ if (listenerObj.listener === listener &&
+ listenerObj.bindTo === opt_this) {
+ if (opt_setDeleteIndex) {
+ listenerObj.deleteIndex = i;
+ return listenerObj;
+ return undefined;
+ * @param {ol.EventTargetLike} target Target.
+ * @param {string} type Type.
+ * @return {Array.<ol.EventsKey>|undefined} Listeners.
+ol.events.getListeners = function(target, type) {
+ var listenerMap = target.ol_lm;
+ return listenerMap ? listenerMap[type] : undefined;
+ * Get the lookup of listeners. If one does not exist on the target, it is
+ * created.
+ * @return {!Object.<string, Array.<ol.EventsKey>>} Map of
+ * listeners by event type.
+ * @private
+ol.events.getListenerMap_ = function(target) {
+ if (!listenerMap) {
+ listenerMap = target.ol_lm = {};
+ return listenerMap;
+ * Clean up all listener objects of the given type. All properties on the
+ * listener objects will be removed, and if no listeners remain in the listener
+ * map, it will be removed from the target.
+ * @private
+ol.events.removeListeners_ = function(target, type) {
+ var listeners = ol.events.getListeners(target, type);
+ if (listeners) {
+ target.removeEventListener(type, listeners[i].boundListener);
+ ol.obj.clear(listeners[i]);
+ listeners.length = 0;
+ if (listenerMap) {
+ delete listenerMap[type];
+ if (Object.keys(listenerMap).length === 0) {
+ delete target.ol_lm;
+ * Registers an event listener on an event target. Inspired by
+ * {@link https://google.github.io/closure-library/api/source/closure/goog/events/events.js.src.html}
+ * This function efficiently binds a `listener` to a `this` object, and returns
+ * a key for use with {@link ol.events.unlistenByKey}.
+ * @param {ol.EventTargetLike} target Event target.
+ * @param {string} type Event type.
+ * @param {ol.EventsListenerFunctionType} listener Listener.
+ * @param {Object=} opt_this Object referenced by the `this` keyword in the
+ * listener. Default is the `target`.
+ * @param {boolean=} opt_once If true, add the listener as one-off listener.
+ * @return {ol.EventsKey} Unique key for the listener.
+ol.events.listen = function(target, type, listener, opt_this, opt_once) {
+ var listenerMap = ol.events.getListenerMap_(target);
+ var listeners = listenerMap[type];
+ if (!listeners) {
+ listeners = listenerMap[type] = [];
+ var listenerObj = ol.events.findListener_(listeners, listener, opt_this,
+ false);
+ if (listenerObj) {
+ if (!opt_once) {
+ // Turn one-off listener into a permanent one.
+ listenerObj.callOnce = false;
+ } else {
+ listenerObj = /** @type {ol.EventsKey} */ ({
+ bindTo: opt_this,
+ callOnce: !!opt_once,
+ listener: listener,
+ target: target,
+ type: type
+ target.addEventListener(type, ol.events.bindListener_(listenerObj));
+ listeners.push(listenerObj);
+ * Registers a one-off event listener on an event target. Inspired by
+ * This function efficiently binds a `listener` as self-unregistering listener
+ * to a `this` object, and returns a key for use with
+ * {@link ol.events.unlistenByKey} in case the listener needs to be unregistered
+ * before it is called.
+ * When {@link ol.events.listen} is called with the same arguments after this
+ * function, the self-unregistering listener will be turned into a permanent
+ * listener.
+ * @return {ol.EventsKey} Key for unlistenByKey.
+ol.events.listenOnce = function(target, type, listener, opt_this) {
+ return ol.events.listen(target, type, listener, opt_this, true);
+ * Unregisters an event listener on an event target. Inspired by
+ * To return a listener, this function needs to be called with the exact same
+ * arguments that were used for a previous {@link ol.events.listen} call.
+ol.events.unlisten = function(target, type, listener, opt_this) {
+ if (listeners) {
+ true);
+ * Unregisters event listeners on an event target. Inspired by
+ * The argument passed to this function is the key returned from
+ * {@link ol.events.listen} or {@link ol.events.listenOnce}.
+ * @param {ol.EventsKey} key The key.
+ol.events.unlistenByKey = function(key) {
+ if (key && key.target) {
+ key.target.removeEventListener(key.type, key.boundListener);
+ var listeners = ol.events.getListeners(key.target, key.type);
+ if (listeners) {
+ var i = 'deleteIndex' in key ? key.deleteIndex : listeners.indexOf(key);
+ if (i !== -1) {
+ listeners.splice(i, 1);
+ if (listeners.length === 0) {
+ ol.events.removeListeners_(key.target, key.type);
+ ol.obj.clear(key);
+ * Unregisters all event listeners on an event target. Inspired by
+ol.events.unlistenAll = function(target) {
+ for (var type in listenerMap) {
+ ol.events.removeListeners_(target, type);
+goog.provide('ol.Disposable');
+ * Objects that need to clean up after themselves.
+ * @constructor
+ol.Disposable = function() {};
+ * The object has already been disposed.
+ * @type {boolean}
+ * @private
+ol.Disposable.prototype.disposed_ = false;
+ * Clean up.
+ol.Disposable.prototype.dispose = function() {
+ if (!this.disposed_) {
+ this.disposed_ = true;
+ this.disposeInternal();
+ * Extension point for disposable objects.
+ * @protected
+ol.Disposable.prototype.disposeInternal = ol.nullFunction;
+goog.provide('ol.events.Event');
+ * @classdesc
+ * Stripped down implementation of the W3C DOM Level 2 Event interface.
+ * @see {@link https://www.w3.org/TR/DOM-Level-2-Events/events.html#Events-interface}
+ * This implementation only provides `type` and `target` properties, and
+ * `stopPropagation` and `preventDefault` methods. It is meant as base class
+ * for higher level events defined in the library, and works with
+ * {@link ol.events.EventTarget}.
+ * @constructor
+ * @implements {oli.events.Event}
+ol.events.Event = function(type) {
+ * @type {boolean}
+ this.propagationStopped;
+ * The event type.
+ * @type {string}
+ * @api
+ this.type = type;
+ * The event target.
+ * @type {Object}
+ * @api
+ this.target = null;
+ * Stop event propagation.
+ * @function
+ * @override
+ * @api
+ol.events.Event.prototype.preventDefault =
+ * @function
+ * @override
+ * @api
+ol.events.Event.prototype.stopPropagation = function() {
+ this.propagationStopped = true;
+ * @param {Event|ol.events.Event} evt Event
+ol.events.Event.stopPropagation = function(evt) {
+ evt.stopPropagation();
+ol.events.Event.preventDefault = function(evt) {
+ evt.preventDefault();
+goog.provide('ol.events.EventTarget');
+goog.require('ol.Disposable');
+goog.require('ol.events');
+goog.require('ol.events.Event');
+ * @classdesc
+ * A simplified implementation of the W3C DOM Level 2 EventTarget interface.
+ * @see {@link https://www.w3.org/TR/2000/REC-DOM-Level-2-Events-20001113/events.html#Events-EventTarget}
+ * There are two important simplifications compared to the specification:
+ * 1. The handling of `useCapture` in `addEventListener` and
+ * `removeEventListener`. There is no real capture model.
+ * 2. The handling of `stopPropagation` and `preventDefault` on `dispatchEvent`.
+ * There is no event target hierarchy. When a listener calls
+ * `stopPropagation` or `preventDefault` on an event object, it means that no
+ * more listeners after this one will be called. Same as when the listener
+ * returns false.
+ * @constructor
+ * @extends {ol.Disposable}
+ol.events.EventTarget = function() {
+ ol.Disposable.call(this);
+ * @private
+ * @type {!Object.<string, number>}
+ this.pendingRemovals_ = {};
+ * @private
+ this.dispatching_ = {};
+ * @private
+ * @type {!Object.<string, Array.<ol.EventsListenerFunctionType>>}
+ this.listeners_ = {};
+ol.inherits(ol.events.EventTarget, ol.Disposable);
+ol.events.EventTarget.prototype.addEventListener = function(type, listener) {
+ var listeners = this.listeners_[type];
+ if (!listeners) {
+ listeners = this.listeners_[type] = [];
+ if (listeners.indexOf(listener) === -1) {
+ listeners.push(listener);
+ * @param {{type: string,
+ * target: (EventTarget|ol.events.EventTarget|undefined)}|ol.events.Event|
+ * string} event Event or event type.
+ * @return {boolean|undefined} `false` if anyone called preventDefault on the
+ * event object or if any of the listeners returned false.
+ol.events.EventTarget.prototype.dispatchEvent = function(event) {
+ var evt = typeof event === 'string' ? new ol.events.Event(event) : event;
+ var type = evt.type;
+ evt.target = this;
+ var propagate;
+ if (listeners) {
+ if (!(type in this.dispatching_)) {
+ this.dispatching_[type] = 0;
+ this.pendingRemovals_[type] = 0;
+ ++this.dispatching_[type];
+ if (listeners[i].call(this, evt) === false || evt.propagationStopped) {
+ propagate = false;
+ break;
+ --this.dispatching_[type];
+ if (this.dispatching_[type] === 0) {
+ var pendingRemovals = this.pendingRemovals_[type];
+ delete this.pendingRemovals_[type];
+ while (pendingRemovals--) {
+ this.removeEventListener(type, ol.nullFunction);
+ delete this.dispatching_[type];
+ return propagate;
+ * @inheritDoc
+ol.events.EventTarget.prototype.disposeInternal = function() {
+ ol.events.unlistenAll(this);
+ * Get the listeners for a specified event type. Listeners are returned in the
+ * order that they will be called in.
+ * @return {Array.<ol.EventsListenerFunctionType>} Listeners.
+ol.events.EventTarget.prototype.getListeners = function(type) {
+ return this.listeners_[type];
+ * @param {string=} opt_type Type. If not provided,
+ * `true` will be returned if this EventTarget has any listeners.
+ * @return {boolean} Has listeners.
+ol.events.EventTarget.prototype.hasListener = function(opt_type) {
+ return opt_type ?
+ opt_type in this.listeners_ :
+ Object.keys(this.listeners_).length > 0;
+ol.events.EventTarget.prototype.removeEventListener = function(type, listener) {
+ if (listeners) {
+ var index = listeners.indexOf(listener);
+ if (type in this.pendingRemovals_) {
+ // make listener a no-op, and remove later in #dispatchEvent()
+ listeners[index] = ol.nullFunction;
+ ++this.pendingRemovals_[type];
+ } else {
+ listeners.splice(index, 1);
+ delete this.listeners_[type];
+goog.provide('ol.events.EventType');
+ * @enum {string}
+ * @const
+ol.events.EventType = {
+ * Generic change event. Triggered when the revision counter is increased.
+ * @event ol.events.Event#change
+ * @api
+ CHANGE: 'change',
+ CLICK: 'click',
+ DBLCLICK: 'dblclick',
+ DRAGENTER: 'dragenter',
+ DRAGOVER: 'dragover',
+ DROP: 'drop',
+ ERROR: 'error',
+ KEYDOWN: 'keydown',
+ KEYPRESS: 'keypress',
+ LOAD: 'load',
+ MOUSEDOWN: 'mousedown',
+ MOUSEMOVE: 'mousemove',
+ MOUSEOUT: 'mouseout',
+ MOUSEUP: 'mouseup',
+ MOUSEWHEEL: 'mousewheel',
+ MSPOINTERDOWN: 'MSPointerDown',
+ RESIZE: 'resize',
+ TOUCHSTART: 'touchstart',
+ TOUCHMOVE: 'touchmove',
+ TOUCHEND: 'touchend',
+ WHEEL: 'wheel'
+goog.provide('ol.Observable');
+goog.require('ol.events.EventTarget');
+goog.require('ol.events.EventType');
+ * @classdesc
+ * Abstract base class; normally only used for creating subclasses and not
+ * instantiated in apps.
+ * An event target providing convenient methods for listener registration
+ * and unregistration. A generic `change` event is always available through
+ * {@link ol.Observable#changed}.
+ * @constructor
+ * @extends {ol.events.EventTarget}
+ * @fires ol.events.Event
+ * @struct
+ * @api
+ol.Observable = function() {
+ ol.events.EventTarget.call(this);
+ * @private
+ * @type {number}
+ this.revision_ = 0;
+ol.inherits(ol.Observable, ol.events.EventTarget);
+ * Removes an event listener using the key returned by `on()` or `once()`.
+ * @param {ol.EventsKey|Array.<ol.EventsKey>} key The key returned by `on()`
+ * or `once()` (or an array of keys).
+ * @api
+ol.Observable.unByKey = function(key) {
+ if (Array.isArray(key)) {
+ for (var i = 0, ii = key.length; i < ii; ++i) {
+ ol.events.unlistenByKey(key[i]);
+ } else {
+ ol.events.unlistenByKey(/** @type {ol.EventsKey} */ (key));
+ * Increases the revision counter and dispatches a 'change' event.
+ * @api
+ol.Observable.prototype.changed = function() {
+ ++this.revision_;
+ this.dispatchEvent(ol.events.EventType.CHANGE);
+ * Dispatches an event and calls all listeners listening for events
+ * of this type. The event parameter can either be a string or an
+ * Object with a `type` property.
+ * string} event Event object.
+ * @function
+ * @api
+ol.Observable.prototype.dispatchEvent;
+ * Get the version number for this object. Each time the object is modified,
+ * its version number will be incremented.
+ * @return {number} Revision.
+ * @api
+ol.Observable.prototype.getRevision = function() {
+ return this.revision_;
+ * Listen for a certain type of event.
+ * @param {string|Array.<string>} type The event type or array of event types.
+ * @param {function(?): ?} listener The listener function.
+ * @param {Object=} opt_this The object to use as `this` in `listener`.
+ * @return {ol.EventsKey|Array.<ol.EventsKey>} Unique key for the listener. If
+ * called with an array of event types as the first argument, the return
+ * will be an array of keys.
+ * @api
+ol.Observable.prototype.on = function(type, listener, opt_this) {
+ if (Array.isArray(type)) {
+ var len = type.length;
+ var keys = new Array(len);
+ for (var i = 0; i < len; ++i) {
+ keys[i] = ol.events.listen(this, type[i], listener, opt_this);
+ return keys;
+ } else {
+ this, /** @type {string} */ (type), listener, opt_this);
+ * Listen once for a certain type of event.
+ * @api
+ol.Observable.prototype.once = function(type, listener, opt_this) {
+ keys[i] = ol.events.listenOnce(this, type[i], listener, opt_this);
+ return keys;
+ } else {
+ return ol.events.listenOnce(
+ * Unlisten for a certain type of event.
+ * @param {Object=} opt_this The object which was used as `this` by the
+ * `listener`.
+ * @api
+ol.Observable.prototype.un = function(type, listener, opt_this) {
+ for (var i = 0, ii = type.length; i < ii; ++i) {
+ ol.events.unlisten(this, type[i], listener, opt_this);
+ return;
+ } else {
+ ol.events.unlisten(this, /** @type {string} */ (type), listener, opt_this);
+goog.provide('ol.Object');
+goog.require('ol.ObjectEventType');
+goog.require('ol.Observable');
+ * @classdesc
+ * Most non-trivial classes inherit from this.
+ * This extends {@link ol.Observable} with observable properties, where each
+ * property is observable as well as the object as a whole.
+ * Classes that inherit from this have pre-defined properties, to which you can
+ * add your owns. The pre-defined properties are listed in this documentation as
+ * 'Observable Properties', and have their own accessors; for example,
+ * {@link ol.Map} has a `target` property, accessed with `getTarget()` and
+ * changed with `setTarget()`. Not all properties are however settable. There
+ * are also general-purpose accessors `get()` and `set()`. For example,
+ * `get('target')` is equivalent to `getTarget()`.
+ * The `set` accessors trigger a change event, and you can monitor this by
+ * registering a listener. For example, {@link ol.View} has a `center`
+ * property, so `view.on('change:center', function(evt) {...});` would call the
+ * function whenever the value of the center property changes. Within the
+ * function, `evt.target` would be the view, so `evt.target.getCenter()` would
+ * return the new center.
+ * You can add your own observable properties with
+ * `object.set('prop', 'value')`, and retrieve that with `object.get('prop')`.
+ * You can listen for changes on that property value with
+ * `object.on('change:prop', listener)`. You can get a list of all
+ * properties with {@link ol.Object#getProperties object.getProperties()}.
+ * Note that the observable properties are separate from standard JS properties.
+ * You can, for example, give your map object a title with
+ * `map.title='New title'` and with `map.set('title', 'Another title')`. The
+ * first will be a `hasOwnProperty`; the second will appear in
+ * `getProperties()`. Only the second is observable.
+ * Properties can be deleted by using the unset method. E.g.
+ * object.unset('foo').
+ * @constructor
+ * @extends {ol.Observable}
+ * @param {Object.<string, *>=} opt_values An object with key-value pairs.
+ * @fires ol.Object.Event
+ * @api
+ol.Object = function(opt_values) {
+ ol.Observable.call(this);
+ // Call ol.getUid to ensure that the order of objects' ids is the same as
+ // the order in which they were created. This also helps to ensure that
+ // object properties are always added in the same order, which helps many
+ // JavaScript engines generate faster code.
+ ol.getUid(this);
+ * @private
+ * @type {!Object.<string, *>}
+ this.values_ = {};
+ if (opt_values !== undefined) {
+ this.setProperties(opt_values);
+ol.inherits(ol.Object, ol.Observable);
+ * @private
+ * @type {Object.<string, string>}
+ol.Object.changeEventTypeCache_ = {};
+ * @param {string} key Key name.
+ * @return {string} Change name.
+ol.Object.getChangeEventType = function(key) {
+ return ol.Object.changeEventTypeCache_.hasOwnProperty(key) ?
+ ol.Object.changeEventTypeCache_[key] :
+ (ol.Object.changeEventTypeCache_[key] = 'change:' + key);
+ * Gets a value.
+ * @return {*} Value.
+ * @api
+ol.Object.prototype.get = function(key) {
+ var value;
+ if (this.values_.hasOwnProperty(key)) {
+ value = this.values_[key];
+ return value;
+ * Get a list of object property names.
+ * @return {Array.<string>} List of property names.
+ * @api
+ol.Object.prototype.getKeys = function() {
+ return Object.keys(this.values_);
+ * Get an object of all property names and values.
+ * @return {Object.<string, *>} Object.
+ * @api
+ol.Object.prototype.getProperties = function() {
+ return ol.obj.assign({}, this.values_);
+ * @param {*} oldValue Old value.
+ol.Object.prototype.notify = function(key, oldValue) {
+ var eventType;
+ eventType = ol.Object.getChangeEventType(key);
+ this.dispatchEvent(new ol.Object.Event(eventType, key, oldValue));
+ eventType = ol.ObjectEventType.PROPERTYCHANGE;
+ * Sets a value.
+ * @param {*} value Value.
+ * @param {boolean=} opt_silent Update without triggering an event.
+ * @api
+ol.Object.prototype.set = function(key, value, opt_silent) {
+ if (opt_silent) {
+ this.values_[key] = value;
+ } else {
+ var oldValue = this.values_[key];
+ if (oldValue !== value) {
+ this.notify(key, oldValue);
+ * Sets a collection of key-value pairs. Note that this changes any existing
+ * properties and adds new ones (it does not remove any existing properties).
+ * @param {Object.<string, *>} values Values.
+ * @api
+ol.Object.prototype.setProperties = function(values, opt_silent) {
+ var key;
+ for (key in values) {
+ this.set(key, values[key], opt_silent);
+ * Unsets a property.
+ * @param {boolean=} opt_silent Unset without triggering an event.
+ * @api
+ol.Object.prototype.unset = function(key, opt_silent) {
+ if (key in this.values_) {
+ delete this.values_[key];
+ if (!opt_silent) {
+ * @classdesc
+ * Events emitted by {@link ol.Object} instances are instances of this type.
+ * @param {string} type The event type.
+ * @param {string} key The property name.
+ * @param {*} oldValue The old value for `key`.
+ * @extends {ol.events.Event}
+ * @implements {oli.Object.Event}
+ * @constructor
+ol.Object.Event = function(type, key, oldValue) {
+ ol.events.Event.call(this, type);
+ * The name of the property whose value is changing.
+ * @type {string}
+ * @api
+ this.key = key;
+ * The old value. To get the new value use `e.target.get(e.key)` where
+ * `e` is the event object.
+ * @type {*}
+ * @api
+ this.oldValue = oldValue;
+ol.inherits(ol.Object.Event, ol.events.Event);
+ * An implementation of Google Maps' MVCArray.
+ * @see https://developers.google.com/maps/documentation/javascript/reference
+goog.provide('ol.Collection');
+goog.require('ol.AssertionError');
+goog.require('ol.CollectionEventType');
+goog.require('ol.Object');
+ * @classdesc
+ * An expanded version of standard JS Array, adding convenience methods for
+ * manipulation. Add and remove changes to the Collection trigger a Collection
+ * event. Note that this does not cover changes to the objects _within_ the
+ * Collection; they trigger events on the appropriate object, not on the
+ * Collection as a whole.
+ * @constructor
+ * @extends {ol.Object}
+ * @fires ol.Collection.Event
+ * @param {!Array.<T>=} opt_array Array.
+ * @param {olx.CollectionOptions=} opt_options Collection options.
+ * @template T
+ * @api
+ol.Collection = function(opt_array, opt_options) {
+ ol.Object.call(this);
+ var options = opt_options || {};
+ * @private
+ * @type {boolean}
+ this.unique_ = !!options.unique;
+ * @private
+ * @type {!Array.<T>}
+ this.array_ = opt_array ? opt_array : [];
+ if (this.unique_) {
+ for (var i = 0, ii = this.array_.length; i < ii; ++i) {
+ this.assertUnique_(this.array_[i], i);
+ this.updateLength_();
+ol.inherits(ol.Collection, ol.Object);
+ * Remove all elements from the collection.
+ * @api
+ol.Collection.prototype.clear = function() {
+ while (this.getLength() > 0) {
+ this.pop();
+ * Add elements to the collection. This pushes each item in the provided array
+ * to the end of the collection.
+ * @param {!Array.<T>} arr Array.
+ * @return {ol.Collection.<T>} This collection.
+ * @api
+ol.Collection.prototype.extend = function(arr) {
+ var i, ii;
+ for (i = 0, ii = arr.length; i < ii; ++i) {
+ this.push(arr[i]);
+ return this;
+ * Iterate over each element, calling the provided callback.
+ * @param {function(this: S, T, number, Array.<T>): *} f The function to call
+ * for every element. This function takes 3 arguments (the element, the
+ * index and the array). The return value is ignored.
+ * @param {S=} opt_this The object to use as `this` in `f`.
+ * @template S
+ * @api
+ol.Collection.prototype.forEach = function(f, opt_this) {
+ this.array_.forEach(f, opt_this);
+ * Get a reference to the underlying Array object. Warning: if the array
+ * is mutated, no events will be dispatched by the collection, and the
+ * collection's "length" property won't be in sync with the actual length
+ * of the array.
+ * @return {!Array.<T>} Array.
+ * @api
+ol.Collection.prototype.getArray = function() {
+ return this.array_;
+ * Get the element at the provided index.
+ * @param {number} index Index.
+ * @return {T} Element.
+ * @api
+ol.Collection.prototype.item = function(index) {
+ return this.array_[index];
+ * Get the length of this collection.
+ * @return {number} The length of the array.
+ * @observable
+ * @api
+ol.Collection.prototype.getLength = function() {
+ return /** @type {number} */ (this.get(ol.Collection.Property_.LENGTH));
+ * Insert an element at the provided index.
+ * @param {T} elem Element.
+ * @api
+ol.Collection.prototype.insertAt = function(index, elem) {
+ this.assertUnique_(elem);
+ this.array_.splice(index, 0, elem);
+ new ol.Collection.Event(ol.CollectionEventType.ADD, elem));
+ * Remove the last element of the collection and return it.
+ * Return `undefined` if the collection is empty.
+ * @return {T|undefined} Element.
+ * @api
+ol.Collection.prototype.pop = function() {
+ return this.removeAt(this.getLength() - 1);
+ * Insert the provided element at the end of the collection.
+ * @return {number} New length of the collection.
+ * @api
+ol.Collection.prototype.push = function(elem) {
+ var n = this.getLength();
+ this.insertAt(n, elem);
+ return this.getLength();
+ * Remove the first occurrence of an element from the collection.
+ * @return {T|undefined} The removed element or undefined if none found.
+ * @api
+ol.Collection.prototype.remove = function(elem) {
+ var arr = this.array_;
+ var i, ii;
+ if (arr[i] === elem) {
+ return this.removeAt(i);
+ return undefined;
+ * Remove the element at the provided index and return it.
+ * Return `undefined` if the collection does not contain this index.
+ * @return {T|undefined} Value.
+ * @api
+ol.Collection.prototype.removeAt = function(index) {
+ var prev = this.array_[index];
+ this.array_.splice(index, 1);
+ new ol.Collection.Event(ol.CollectionEventType.REMOVE, prev));
+ return prev;
+ * Set the element at the provided index.
+ * @api
+ol.Collection.prototype.setAt = function(index, elem) {
+ if (index < n) {
+ this.assertUnique_(elem, index);
+ this.array_[index] = elem;
+ } else {
+ var j;
+ for (j = n; j < index; ++j) {
+ this.insertAt(j, undefined);
+ this.insertAt(index, elem);
+ * @private
+ol.Collection.prototype.updateLength_ = function() {
+ this.set(ol.Collection.Property_.LENGTH, this.array_.length);
+ * @private
+ * @param {number=} opt_except Optional index to ignore.
+ol.Collection.prototype.assertUnique_ = function(elem, opt_except) {
+ if (this.array_[i] === elem && i !== opt_except) {
+ throw new ol.AssertionError(58);
+ * @enum {string}
+ * @private
+ol.Collection.Property_ = {
+ LENGTH: 'length'
+ * @classdesc
+ * Events emitted by {@link ol.Collection} instances are instances of this
+ * type.
+ * @constructor
+ * @implements {oli.Collection.Event}
+ * @param {ol.CollectionEventType} type Type.
+ * @param {*=} opt_element Element.
+ol.Collection.Event = function(type, opt_element) {
+ * The element that is added to or removed from the collection.
+ * @type {*}
+ * @api
+ this.element = opt_element;
+ol.inherits(ol.Collection.Event, ol.events.Event);
+goog.provide('ol.color');
+goog.require('ol.asserts');
+goog.require('ol.math');
+ * This RegExp matches # followed by 3 or 6 hex digits.
+ * @const
+ * @type {RegExp}
+ * @private
+ol.color.HEX_COLOR_RE_ = /^#(?:[0-9a-f]{3}){1,2}$/i;
+ * Regular expression for matching potential named color style strings.
+ * @const
+ * @type {RegExp}
+ * @private
+ol.color.NAMED_COLOR_RE_ = /^([a-z]*)$/i;
+ * Return the color as an array. This function maintains a cache of calculated
+ * arrays which means the result should not be modified.
+ * @param {ol.Color|string} color Color.
+ * @return {ol.Color} Color.
+ * @api
+ol.color.asArray = function(color) {
+ if (Array.isArray(color)) {
+ return color;
+ } else {
+ return ol.color.fromString(/** @type {string} */ (color));
+ * Return the color as an rgba string.
+ * @return {string} Rgba string.
+ * @api
+ol.color.asString = function(color) {
+ if (typeof color === 'string') {
+ return color;
+ } else {
+ return ol.color.toString(color);
+ * Return named color as an rgba string.
+ * @param {string} color Named color.
+ * @return {string} Rgb string.
+ol.color.fromNamed = function(color) {
+ var el = document.createElement('div');
+ el.style.color = color;
+ document.body.appendChild(el);
+ var rgb = getComputedStyle(el).color;
+ document.body.removeChild(el);
+ return rgb;
+ * @param {string} s String.
+ol.color.fromString = (
+ function() {
+ // We maintain a small cache of parsed strings. To provide cheap LRU-like
+ // semantics, whenever the cache grows too large we simply delete an
+ // arbitrary 25% of the entries.
+ * @const
+ * @type {number}
+ var MAX_CACHE_SIZE = 1024;
+ * @type {Object.<string, ol.Color>}
+ var cache = {};
+ * @type {number}
+ var cacheSize = 0;
+ return (
+ function(s) {
+ var color;
+ if (cache.hasOwnProperty(s)) {
+ color = cache[s];
+ } else {
+ if (cacheSize >= MAX_CACHE_SIZE) {
+ var i = 0;
+ var key;
+ for (key in cache) {
+ if ((i++ & 3) === 0) {
+ delete cache[key];
+ --cacheSize;
+ color = ol.color.fromStringInternal_(s);
+ cache[s] = color;
+ ++cacheSize;
+ return color;
+ * @private
+ol.color.fromStringInternal_ = function(s) {
+ var r, g, b, a, color, parts;
+ if (ol.color.NAMED_COLOR_RE_.exec(s)) {
+ s = ol.color.fromNamed(s);
+ if (ol.color.HEX_COLOR_RE_.exec(s)) { // hex
+ var n = s.length - 1; // number of hex digits
+ ol.asserts.assert(n == 3 || n == 6, 54); // Hex color should have 3 or 6 digits
+ var d = n == 3 ? 1 : 2; // number of digits per channel
+ r = parseInt(s.substr(1 + 0 * d, d), 16);
+ g = parseInt(s.substr(1 + 1 * d, d), 16);
+ b = parseInt(s.substr(1 + 2 * d, d), 16);
+ if (d == 1) {
+ r = (r << 4) + r;
+ g = (g << 4) + g;
+ b = (b << 4) + b;
+ a = 1;
+ color = [r, g, b, a];
+ } else if (s.indexOf('rgba(') == 0) { // rgba()
+ parts = s.slice(5, -1).split(',').map(Number);
+ color = ol.color.normalize(parts);
+ } else if (s.indexOf('rgb(') == 0) { // rgb()
+ parts = s.slice(4, -1).split(',').map(Number);
+ parts.push(1);
+ } else {
+ ol.asserts.assert(false, 14); // Invalid color
+ return /** @type {ol.Color} */ (color);
+ * @param {ol.Color} color Color.
+ * @param {ol.Color=} opt_color Color.
+ * @return {ol.Color} Clamped color.
+ol.color.normalize = function(color, opt_color) {
+ var result = opt_color || [];
+ result[0] = ol.math.clamp((color[0] + 0.5) | 0, 0, 255);
+ result[1] = ol.math.clamp((color[1] + 0.5) | 0, 0, 255);
+ result[2] = ol.math.clamp((color[2] + 0.5) | 0, 0, 255);
+ result[3] = ol.math.clamp(color[3], 0, 1);
+ return result;
+ * @return {string} String.
+ol.color.toString = function(color) {
+ var r = color[0];
+ if (r != (r | 0)) {
+ r = (r + 0.5) | 0;
+ var g = color[1];
+ if (g != (g | 0)) {
+ g = (g + 0.5) | 0;
+ var b = color[2];
+ if (b != (b | 0)) {
+ b = (b + 0.5) | 0;
+ var a = color[3] === undefined ? 1 : color[3];
+ return 'rgba(' + r + ',' + g + ',' + b + ',' + a + ')';
+goog.provide('ol.colorlike');
+goog.require('ol.color');
+ * @param {ol.Color|ol.ColorLike} color Color.
+ * @return {ol.ColorLike} The color as an ol.ColorLike
+ * @api
+ol.colorlike.asColorLike = function(color) {
+ if (ol.colorlike.isColorLike(color)) {
+ return /** @type {string|CanvasPattern|CanvasGradient} */ (color);
+ } else {
+ return ol.color.asString(/** @type {ol.Color} */ (color));
+ * @param {?} color The value that is potentially an ol.ColorLike
+ * @return {boolean} Whether the color is an ol.ColorLike
+ol.colorlike.isColorLike = function(color) {
+ return (
+ typeof color === 'string' ||
+ color instanceof CanvasPattern ||
+ color instanceof CanvasGradient
+goog.provide('ol.Constraints');
+ * @constructor
+ * @param {ol.CenterConstraintType} centerConstraint Center constraint.
+ * @param {ol.ResolutionConstraintType} resolutionConstraint
+ * Resolution constraint.
+ * @param {ol.RotationConstraintType} rotationConstraint
+ * Rotation constraint.
+ol.Constraints = function(centerConstraint, resolutionConstraint, rotationConstraint) {
+ * @type {ol.CenterConstraintType}
+ this.center = centerConstraint;
+ * @type {ol.ResolutionConstraintType}
+ this.resolution = resolutionConstraint;
+ * @type {ol.RotationConstraintType}
+ this.rotation = rotationConstraint;
+goog.provide('ol.dom');
+ * Create an html canvas element and returns its 2d context.
+ * @param {number=} opt_width Canvas width.
+ * @param {number=} opt_height Canvas height.
+ * @return {CanvasRenderingContext2D} The context.
+ol.dom.createCanvasContext2D = function(opt_width, opt_height) {
+ var canvas = document.createElement('CANVAS');
+ if (opt_width) {
+ canvas.width = opt_width;
+ if (opt_height) {
+ canvas.height = opt_height;
+ return canvas.getContext('2d');
+ * Get the current computed width for the given element including margin,
+ * padding and border.
+ * Equivalent to jQuery's `$(el).outerWidth(true)`.
+ * @param {!Element} element Element.
+ * @return {number} The width.
+ol.dom.outerWidth = function(element) {
+ var width = element.offsetWidth;
+ var style = getComputedStyle(element);
+ width += parseInt(style.marginLeft, 10) + parseInt(style.marginRight, 10);
+ return width;
+ * Get the current computed height for the given element including margin,
+ * Equivalent to jQuery's `$(el).outerHeight(true)`.
+ * @return {number} The height.
+ol.dom.outerHeight = function(element) {
+ var height = element.offsetHeight;
+ height += parseInt(style.marginTop, 10) + parseInt(style.marginBottom, 10);
+ return height;
+ * @param {Node} newNode Node to replace old node
+ * @param {Node} oldNode The node to be replaced
+ol.dom.replaceNode = function(newNode, oldNode) {
+ var parent = oldNode.parentNode;
+ if (parent) {
+ parent.replaceChild(newNode, oldNode);
+ * @param {Node} node The node to remove.
+ * @returns {Node} The node that was removed or null.
+ol.dom.removeNode = function(node) {
+ return node && node.parentNode ? node.parentNode.removeChild(node) : null;
+ * @param {Node} node The node to remove the children from.
+ol.dom.removeChildren = function(node) {
+ while (node.lastChild) {
+ node.removeChild(node.lastChild);
+goog.provide('ol.MapEventType');
+ * @enum {string}
+ol.MapEventType = {
+ * Triggered after a map frame is rendered.
+ * @event ol.MapEvent#postrender
+ * @api
+ POSTRENDER: 'postrender',
+ * Triggered after the map is moved.
+ * @event ol.MapEvent#moveend
+ * @api
+ MOVEEND: 'moveend'
+goog.provide('ol.control.Control');
+goog.require('ol.MapEventType');
+goog.require('ol.dom');
+ * @classdesc
+ * A control is a visible widget with a DOM element in a fixed position on the
+ * screen. They can involve user input (buttons), or be informational only;
+ * the position is determined using CSS. By default these are placed in the
+ * container with CSS class name `ol-overlaycontainer-stopevent`, but can use
+ * any outside DOM element.
+ * This is the base class for controls. You can use it for simple custom
+ * controls by creating the element with listeners, creating an instance:
+ * ```js
+ * var myControl = new ol.control.Control({element: myElement});
+ * and then adding this to the map.
+ * The main advantage of having this as a control rather than a simple separate
+ * DOM element is that preventing propagation is handled for you. Controls
+ * will also be `ol.Object`s in a `ol.Collection`, so you can use their
+ * methods.
+ * You can also extend this base for your own control class. See
+ * examples/custom-controls for an example of how to do this.
+ * @constructor
+ * @implements {oli.control.Control}
+ * @param {olx.control.ControlOptions} options Control options.
+ * @api
+ol.control.Control = function(options) {
+ * @protected
+ * @type {Element}
+ this.element = options.element ? options.element : null;
+ * @private
+ * @type {Element}
+ this.target_ = null;
+ * @private
+ * @type {ol.Map}
+ this.map_ = null;
+ * @protected
+ * @type {!Array.<ol.EventsKey>}
+ this.listenerKeys = [];
+ * @type {function(ol.MapEvent)}
+ this.render = options.render ? options.render : ol.nullFunction;
+ if (options.target) {
+ this.setTarget(options.target);
+ol.inherits(ol.control.Control, ol.Object);
+ * @inheritDoc
+ol.control.Control.prototype.disposeInternal = function() {
+ ol.dom.removeNode(this.element);
+ ol.Object.prototype.disposeInternal.call(this);
+ * Get the map associated with this control.
+ * @return {ol.Map} Map.
+ * @api
+ol.control.Control.prototype.getMap = function() {
+ return this.map_;
+ * Remove the control from its current map and attach it to the new map.
+ * Subclasses may set up event handlers to get notified about changes to
+ * the map here.
+ * @param {ol.Map} map Map.
+ * @override
+ * @api
+ol.control.Control.prototype.setMap = function(map) {
+ if (this.map_) {
+ for (var i = 0, ii = this.listenerKeys.length; i < ii; ++i) {
+ ol.events.unlistenByKey(this.listenerKeys[i]);
+ this.listenerKeys.length = 0;
+ this.map_ = map;
+ if (this.map_) {
+ var target = this.target_ ?
+ this.target_ : map.getOverlayContainerStopEvent();
+ target.appendChild(this.element);
+ if (this.render !== ol.nullFunction) {
+ this.listenerKeys.push(ol.events.listen(map,
+ ol.MapEventType.POSTRENDER, this.render, this));
+ map.render();
+ * This function is used to set a target element for the control. It has no
+ * effect if it is called after the control has been added to the map (i.e.
+ * after `setMap` is called on the control). If no `target` is set in the
+ * options passed to the control constructor and if `setTarget` is not called
+ * then the control is added to the map's overlay container.
+ * @param {Element|string} target Target.
+ * @api
+ol.control.Control.prototype.setTarget = function(target) {
+ this.target_ = typeof target === 'string' ?
+ document.getElementById(target) :
+ target;
+goog.provide('ol.css');
+ * The CSS class for hidden feature.
+ * @const
+ * @type {string}
+ol.css.CLASS_HIDDEN = 'ol-hidden';
+ * The CSS class that we'll give the DOM elements to have them unselectable.
+ * @const
+ * @type {string}
+ol.css.CLASS_UNSELECTABLE = 'ol-unselectable';
+ * The CSS class for unsupported feature.
+ * @const
+ * @type {string}
+ol.css.CLASS_UNSUPPORTED = 'ol-unsupported';
+ * The CSS class for controls.
+ * @const
+ * @type {string}
+ol.css.CLASS_CONTROL = 'ol-control';
+// FIXME handle date line wrap
+goog.provide('ol.control.Attribution');
+goog.require('ol.control.Control');
+goog.require('ol.css');
+goog.require('ol.obj');
+ * @classdesc
+ * Control to show all the attributions associated with the layer sources
+ * in the map. This control is one of the default controls included in maps.
+ * By default it will show in the bottom right portion of the map, but this can
+ * be changed by using a css selector for `.ol-attribution`.
+ * @constructor
+ * @extends {ol.control.Control}
+ * @param {olx.control.AttributionOptions=} opt_options Attribution options.
+ * @api
+ol.control.Attribution = function(opt_options) {
+ var options = opt_options ? opt_options : {};
+ * @private
+ * @type {Element}
+ this.ulElement_ = document.createElement('UL');
+ * @private
+ * @type {Element}
+ this.logoLi_ = document.createElement('LI');
+ this.ulElement_.appendChild(this.logoLi_);
+ this.logoLi_.style.display = 'none';
+ * @private
+ * @type {boolean}
+ this.collapsed_ = options.collapsed !== undefined ? options.collapsed : true;
+ * @private
+ * @type {boolean}
+ this.collapsible_ = options.collapsible !== undefined ?
+ options.collapsible : true;
+ if (!this.collapsible_) {
+ this.collapsed_ = false;
+ var className = options.className !== undefined ? options.className : 'ol-attribution';
+ var tipLabel = options.tipLabel !== undefined ? options.tipLabel : 'Attributions';
+ var collapseLabel = options.collapseLabel !== undefined ? options.collapseLabel : '\u00BB';
+ if (typeof collapseLabel === 'string') {
+ * @private
+ * @type {Node}
+ this.collapseLabel_ = document.createElement('span');
+ this.collapseLabel_.textContent = collapseLabel;
+ } else {
+ this.collapseLabel_ = collapseLabel;
+ var label = options.label !== undefined ? options.label : 'i';
+ if (typeof label === 'string') {
+ * @private
+ * @type {Node}
+ this.label_ = document.createElement('span');
+ this.label_.textContent = label;
+ } else {
+ this.label_ = label;
+ var activeLabel = (this.collapsible_ && !this.collapsed_) ?
+ this.collapseLabel_ : this.label_;
+ var button = document.createElement('button');
+ button.setAttribute('type', 'button');
+ button.title = tipLabel;
+ button.appendChild(activeLabel);
+ ol.events.listen(button, ol.events.EventType.CLICK, this.handleClick_, this);
+ var cssClasses = className + ' ' + ol.css.CLASS_UNSELECTABLE + ' ' +
+ ol.css.CLASS_CONTROL +
+ (this.collapsed_ && this.collapsible_ ? ' ol-collapsed' : '') +
+ (this.collapsible_ ? '' : ' ol-uncollapsible');
+ var element = document.createElement('div');
+ element.className = cssClasses;
+ element.appendChild(this.ulElement_);
+ element.appendChild(button);
+ var render = options.render ? options.render : ol.control.Attribution.render;
+ ol.control.Control.call(this, {
+ element: element,
+ render: render,
+ target: options.target
+ * @private
+ * @type {boolean}
+ this.renderedVisible_ = true;
+ * @private
+ * @type {Object.<string, Element>}
+ this.attributionElements_ = {};
+ * @private
+ * @type {Object.<string, boolean>}
+ this.attributionElementRenderedVisible_ = {};
+ * @private
+ this.logoElements_ = {};
+ol.inherits(ol.control.Attribution, ol.control.Control);
+ * @param {?olx.FrameState} frameState Frame state.
+ * @return {Array.<Object.<string, ol.Attribution>>} Attributions.
+ol.control.Attribution.prototype.getSourceAttributions = function(frameState) {
+ var i, ii, j, jj, tileRanges, source, sourceAttribution,
+ sourceAttributionKey, sourceAttributions, sourceKey;
+ var intersectsTileRange;
+ var layerStatesArray = frameState.layerStatesArray;
+ /** @type {Object.<string, ol.Attribution>} */
+ var attributions = ol.obj.assign({}, frameState.attributions);
+ var hiddenAttributions = {};
+ var uniqueAttributions = {};
+ var projection = /** @type {!ol.proj.Projection} */ (frameState.viewState.projection);
+ for (i = 0, ii = layerStatesArray.length; i < ii; i++) {
+ source = layerStatesArray[i].layer.getSource();
+ if (!source) {
+ continue;
+ sourceKey = ol.getUid(source).toString();
+ sourceAttributions = source.getAttributions();
+ if (!sourceAttributions) {
+ continue;
+ for (j = 0, jj = sourceAttributions.length; j < jj; j++) {
+ sourceAttribution = sourceAttributions[j];
+ sourceAttributionKey = ol.getUid(sourceAttribution).toString();
+ if (sourceAttributionKey in attributions) {
+ continue;
+ tileRanges = frameState.usedTiles[sourceKey];
+ if (tileRanges) {
+ var tileGrid = /** @type {ol.source.Tile} */ (source).getTileGridForProjection(projection);
+ intersectsTileRange = sourceAttribution.intersectsAnyTileRange(
+ tileRanges, tileGrid, projection);
+ } else {
+ intersectsTileRange = false;
+ if (intersectsTileRange) {
+ if (sourceAttributionKey in hiddenAttributions) {
+ delete hiddenAttributions[sourceAttributionKey];
+ var html = sourceAttribution.getHTML();
+ if (!(html in uniqueAttributions)) {
+ uniqueAttributions[html] = true;
+ attributions[sourceAttributionKey] = sourceAttribution;
+ } else {
+ hiddenAttributions[sourceAttributionKey] = sourceAttribution;
+ return [attributions, hiddenAttributions];
+ * Update the attribution element.
+ * @param {ol.MapEvent} mapEvent Map event.
+ * @this {ol.control.Attribution}
+ * @api
+ol.control.Attribution.render = function(mapEvent) {
+ this.updateElement_(mapEvent.frameState);
+ * @private
+ol.control.Attribution.prototype.updateElement_ = function(frameState) {
+ if (!frameState) {
+ if (this.renderedVisible_) {
+ this.element.style.display = 'none';
+ this.renderedVisible_ = false;
+ return;
+ var attributions = this.getSourceAttributions(frameState);
+ var visibleAttributions = attributions[0];
+ var hiddenAttributions = attributions[1];
+ var attributionElement, attributionKey;
+ for (attributionKey in this.attributionElements_) {
+ if (attributionKey in visibleAttributions) {
+ if (!this.attributionElementRenderedVisible_[attributionKey]) {
+ this.attributionElements_[attributionKey].style.display = '';
+ this.attributionElementRenderedVisible_[attributionKey] = true;
+ delete visibleAttributions[attributionKey];
+ } else if (attributionKey in hiddenAttributions) {
+ if (this.attributionElementRenderedVisible_[attributionKey]) {
+ this.attributionElements_[attributionKey].style.display = 'none';
+ delete this.attributionElementRenderedVisible_[attributionKey];
+ delete hiddenAttributions[attributionKey];
+ } else {
+ ol.dom.removeNode(this.attributionElements_[attributionKey]);
+ delete this.attributionElements_[attributionKey];
+ for (attributionKey in visibleAttributions) {
+ attributionElement = document.createElement('LI');
+ attributionElement.innerHTML =
+ visibleAttributions[attributionKey].getHTML();
+ this.ulElement_.appendChild(attributionElement);
+ this.attributionElements_[attributionKey] = attributionElement;
+ for (attributionKey in hiddenAttributions) {
+ hiddenAttributions[attributionKey].getHTML();
+ attributionElement.style.display = 'none';
+ var renderVisible =
+ !ol.obj.isEmpty(this.attributionElementRenderedVisible_) ||
+ !ol.obj.isEmpty(frameState.logos);
+ if (this.renderedVisible_ != renderVisible) {
+ this.element.style.display = renderVisible ? '' : 'none';
+ this.renderedVisible_ = renderVisible;
+ if (renderVisible &&
+ ol.obj.isEmpty(this.attributionElementRenderedVisible_)) {
+ this.element.classList.add('ol-logo-only');
+ } else {
+ this.element.classList.remove('ol-logo-only');
+ this.insertLogos_(frameState);
+ * @private
+ol.control.Attribution.prototype.insertLogos_ = function(frameState) {
+ var logo;
+ var logos = frameState.logos;
+ var logoElements = this.logoElements_;
+ for (logo in logoElements) {
+ if (!(logo in logos)) {
+ ol.dom.removeNode(logoElements[logo]);
+ delete logoElements[logo];
+ var image, logoElement, logoKey;
+ for (logoKey in logos) {
+ var logoValue = logos[logoKey];
+ if (logoValue instanceof HTMLElement) {
+ this.logoLi_.appendChild(logoValue);
+ logoElements[logoKey] = logoValue;
+ if (!(logoKey in logoElements)) {
+ image = new Image();
+ image.src = logoKey;
+ if (logoValue === '') {
+ logoElement = image;
+ } else {
+ logoElement = document.createElement('a');
+ logoElement.href = logoValue;
+ logoElement.appendChild(image);
+ this.logoLi_.appendChild(logoElement);
+ logoElements[logoKey] = logoElement;
+ this.logoLi_.style.display = !ol.obj.isEmpty(logos) ? '' : 'none';
+ * @param {Event} event The event to handle
+ * @private
+ol.control.Attribution.prototype.handleClick_ = function(event) {
+ event.preventDefault();
+ this.handleToggle_();
+ * @private
+ol.control.Attribution.prototype.handleToggle_ = function() {
+ this.element.classList.toggle('ol-collapsed');
+ if (this.collapsed_) {
+ ol.dom.replaceNode(this.collapseLabel_, this.label_);
+ } else {
+ ol.dom.replaceNode(this.label_, this.collapseLabel_);
+ this.collapsed_ = !this.collapsed_;
+ * Return `true` if the attribution is collapsible, `false` otherwise.
+ * @return {boolean} True if the widget is collapsible.
+ * @api
+ol.control.Attribution.prototype.getCollapsible = function() {
+ return this.collapsible_;
+ * Set whether the attribution should be collapsible.
+ * @param {boolean} collapsible True if the widget is collapsible.
+ * @api
+ol.control.Attribution.prototype.setCollapsible = function(collapsible) {
+ if (this.collapsible_ === collapsible) {
+ return;
+ this.collapsible_ = collapsible;
+ this.element.classList.toggle('ol-uncollapsible');
+ if (!collapsible && this.collapsed_) {
+ * Collapse or expand the attribution according to the passed parameter. Will
+ * not do anything if the attribution isn't collapsible or if the current
+ * collapsed state is already the one requested.
+ * @param {boolean} collapsed True if the widget is collapsed.
+ * @api
+ol.control.Attribution.prototype.setCollapsed = function(collapsed) {
+ if (!this.collapsible_ || this.collapsed_ === collapsed) {
+ return;
+ * Return `true` when the attribution is currently collapsed or `false`
+ * otherwise.
+ * @return {boolean} True if the widget is collapsed.
+ * @api
+ol.control.Attribution.prototype.getCollapsed = function() {
+ return this.collapsed_;
+goog.provide('ol.easing');
+ * Start slow and speed up.
+ * @param {number} t Input between 0 and 1.
+ * @return {number} Output between 0 and 1.
+ * @api
+ol.easing.easeIn = function(t) {
+ return Math.pow(t, 3);
+ * Start fast and slow down.
+ * @api
+ol.easing.easeOut = function(t) {
+ return 1 - ol.easing.easeIn(1 - t);
+ * Start slow, speed up, and then slow down again.
+ * @api
+ol.easing.inAndOut = function(t) {
+ return 3 * t * t - 2 * t * t * t;
+ * Maintain a constant speed over time.
+ * @api
+ol.easing.linear = function(t) {
+ return t;
+ * Start slow, speed up, and at the very end slow down again. This has the
+ * same general behavior as {@link ol.easing.inAndOut}, but the final slowdown
+ * is delayed.
+ * @api
+ol.easing.upAndDown = function(t) {
+ if (t < 0.5) {
+ return ol.easing.inAndOut(2 * t);
+ } else {
+ return 1 - ol.easing.inAndOut(2 * (t - 0.5));
+goog.provide('ol.control.Rotate');
+goog.require('ol');
+goog.require('ol.easing');
+ * @classdesc
+ * A button control to reset rotation to 0.
+ * To style this control use css selector `.ol-rotate`. A `.ol-hidden` css
+ * selector is added to the button when the rotation is 0.
+ * @constructor
+ * @param {olx.control.RotateOptions=} opt_options Rotate options.
+ * @api
+ol.control.Rotate = function(opt_options) {
+ var className = options.className !== undefined ? options.className : 'ol-rotate';
+ var label = options.label !== undefined ? options.label : '\u21E7';
+ * @type {Element}
+ * @private
+ this.label_ = null;
+ this.label_.className = 'ol-compass';
+ } else {
+ this.label_.classList.add('ol-compass');
+ var tipLabel = options.tipLabel ? options.tipLabel : 'Reset rotation';
+ button.className = className + '-reset';
+ button.appendChild(this.label_);
+ ol.control.Rotate.prototype.handleClick_, this);
+ ol.css.CLASS_CONTROL;
+ var render = options.render ? options.render : ol.control.Rotate.render;
+ this.callResetNorth_ = options.resetNorth ? options.resetNorth : undefined;
+ element: element,
+ render: render,
+ * @type {number}
+ * @private
+ this.duration_ = options.duration !== undefined ? options.duration : 250;
+ * @type {boolean}
+ * @private
+ this.autoHide_ = options.autoHide !== undefined ? options.autoHide : true;
+ * @private
+ * @type {number|undefined}
+ this.rotation_ = undefined;
+ if (this.autoHide_) {
+ this.element.classList.add(ol.css.CLASS_HIDDEN);
+ol.inherits(ol.control.Rotate, ol.control.Control);
+ * @private
+ol.control.Rotate.prototype.handleClick_ = function(event) {
+ if (this.callResetNorth_ !== undefined) {
+ this.callResetNorth_();
+ } else {
+ this.resetNorth_();
+ * @private
+ol.control.Rotate.prototype.resetNorth_ = function() {
+ var map = this.getMap();
+ var view = map.getView();
+ if (!view) {
+ // the map does not have a view, so we can't act
+ // upon it
+ return;
+ if (view.getRotation() !== undefined) {
+ if (this.duration_ > 0) {
+ view.animate({
+ rotation: 0,
+ duration: this.duration_,
+ easing: ol.easing.easeOut
+ } else {
+ view.setRotation(0);
+ * Update the rotate control element.
+ * @this {ol.control.Rotate}
+ * @api
+ol.control.Rotate.render = function(mapEvent) {
+ var frameState = mapEvent.frameState;
+ return;
+ var rotation = frameState.viewState.rotation;
+ if (rotation != this.rotation_) {
+ var transform = 'rotate(' + rotation + 'rad)';
+ var contains = this.element.classList.contains(ol.css.CLASS_HIDDEN);
+ if (!contains && rotation === 0) {
+ } else if (contains && rotation !== 0) {
+ this.element.classList.remove(ol.css.CLASS_HIDDEN);
+ this.label_.style.msTransform = transform;
+ this.label_.style.webkitTransform = transform;
+ this.label_.style.transform = transform;
+ this.rotation_ = rotation;
+goog.provide('ol.control.Zoom');
+ * @classdesc
+ * A control with 2 buttons, one for zoom in and one for zoom out.
+ * This control is one of the default controls of a map. To style this control
+ * use css selectors `.ol-zoom-in` and `.ol-zoom-out`.
+ * @constructor
+ * @param {olx.control.ZoomOptions=} opt_options Zoom options.
+ * @api
+ol.control.Zoom = function(opt_options) {
+ var className = options.className !== undefined ? options.className : 'ol-zoom';
+ var delta = options.delta !== undefined ? options.delta : 1;
+ var zoomInLabel = options.zoomInLabel !== undefined ? options.zoomInLabel : '+';
+ var zoomOutLabel = options.zoomOutLabel !== undefined ? options.zoomOutLabel : '\u2212';
+ var zoomInTipLabel = options.zoomInTipLabel !== undefined ?
+ options.zoomInTipLabel : 'Zoom in';
+ var zoomOutTipLabel = options.zoomOutTipLabel !== undefined ?
+ options.zoomOutTipLabel : 'Zoom out';
+ var inElement = document.createElement('button');
+ inElement.className = className + '-in';
+ inElement.setAttribute('type', 'button');
+ inElement.title = zoomInTipLabel;
+ inElement.appendChild(
+ typeof zoomInLabel === 'string' ? document.createTextNode(zoomInLabel) : zoomInLabel
+ ol.events.listen(inElement, ol.events.EventType.CLICK,
+ ol.control.Zoom.prototype.handleClick_.bind(this, delta));
+ var outElement = document.createElement('button');
+ outElement.className = className + '-out';
+ outElement.setAttribute('type', 'button');
+ outElement.title = zoomOutTipLabel;
+ outElement.appendChild(
+ typeof zoomOutLabel === 'string' ? document.createTextNode(zoomOutLabel) : zoomOutLabel
+ ol.events.listen(outElement, ol.events.EventType.CLICK,
+ ol.control.Zoom.prototype.handleClick_.bind(this, -delta));
+ element.appendChild(inElement);
+ element.appendChild(outElement);
+ element: element,
+ * @type {number}
+ * @private
+ol.inherits(ol.control.Zoom, ol.control.Control);
+ * @param {number} delta Zoom delta.
+ * @private
+ol.control.Zoom.prototype.handleClick_ = function(delta, event) {
+ this.zoomByDelta_(delta);
+ * @private
+ol.control.Zoom.prototype.zoomByDelta_ = function(delta) {
+ if (!view) {
+ // upon it
+ return;
+ var currentResolution = view.getResolution();
+ if (currentResolution) {
+ var newResolution = view.constrainResolution(currentResolution, delta);
+ if (view.getAnimating()) {
+ view.cancelAnimations();
+ view.animate({
+ resolution: newResolution,
+ } else {
+ view.setResolution(newResolution);
+goog.provide('ol.control');
+goog.require('ol.Collection');
+goog.require('ol.control.Attribution');
+goog.require('ol.control.Rotate');
+goog.require('ol.control.Zoom');
+ * Set of controls included in maps by default. Unless configured otherwise,
+ * this returns a collection containing an instance of each of the following
+ * controls:
+ * * {@link ol.control.Zoom}
+ * * {@link ol.control.Rotate}
+ * * {@link ol.control.Attribution}
+ * @param {olx.control.DefaultsOptions=} opt_options Defaults options.
+ * @return {ol.Collection.<ol.control.Control>} Controls.
+ * @api
+ol.control.defaults = function(opt_options) {
+ var controls = new ol.Collection();
+ var zoomControl = options.zoom !== undefined ? options.zoom : true;
+ if (zoomControl) {
+ controls.push(new ol.control.Zoom(options.zoomOptions));
+ var rotateControl = options.rotate !== undefined ? options.rotate : true;
+ if (rotateControl) {
+ controls.push(new ol.control.Rotate(options.rotateOptions));
+ var attributionControl = options.attribution !== undefined ?
+ options.attribution : true;
+ if (attributionControl) {
+ controls.push(new ol.control.Attribution(options.attributionOptions));
+ return controls;
+goog.provide('ol.control.FullScreen');
+ * @classdesc
+ * Provides a button that when clicked fills up the full screen with the map.
+ * The full screen source element is by default the element containing the map viewport unless
+ * overriden by providing the `source` option. In which case, the dom
+ * element introduced using this parameter will be displayed in full screen.
+ * When in full screen mode, a close button is shown to exit full screen mode.
+ * The [Fullscreen API](http://www.w3.org/TR/fullscreen/) is used to
+ * toggle the map in full screen mode.
+ * @constructor
+ * @param {olx.control.FullScreenOptions=} opt_options Options.
+ * @api
+ol.control.FullScreen = function(opt_options) {
+ * @private
+ * @type {string}
+ this.cssClassName_ = options.className !== undefined ? options.className :
+ 'ol-full-screen';
+ var label = options.label !== undefined ? options.label : '\u2922';
+ * @private
+ * @type {Node}
+ this.labelNode_ = typeof label === 'string' ?
+ document.createTextNode(label) : label;
+ var labelActive = options.labelActive !== undefined ? options.labelActive : '\u00d7';
+ * @private
+ * @type {Node}
+ this.labelActiveNode_ = typeof labelActive === 'string' ?
+ document.createTextNode(labelActive) : labelActive;
+ var tipLabel = options.tipLabel ? options.tipLabel : 'Toggle full-screen';
+ button.className = this.cssClassName_ + '-' + ol.control.FullScreen.isFullScreen();
+ button.appendChild(this.labelNode_);
+ this.handleClick_, this);
+ var cssClasses = this.cssClassName_ + ' ' + ol.css.CLASS_UNSELECTABLE +
+ ' ' + ol.css.CLASS_CONTROL + ' ' +
+ (!ol.control.FullScreen.isFullScreenSupported() ? ol.css.CLASS_UNSUPPORTED : '');
+ element: element,
+ * @private
+ * @type {boolean}
+ this.keys_ = options.keys !== undefined ? options.keys : false;
+ * @private
+ * @type {Element|string|undefined}
+ this.source_ = options.source;
+ol.inherits(ol.control.FullScreen, ol.control.Control);
+ * @private
+ol.control.FullScreen.prototype.handleClick_ = function(event) {
+ this.handleFullScreen_();
+ * @private
+ol.control.FullScreen.prototype.handleFullScreen_ = function() {
+ if (!ol.control.FullScreen.isFullScreenSupported()) {
+ return;
+ if (!map) {
+ return;
+ if (ol.control.FullScreen.isFullScreen()) {
+ ol.control.FullScreen.exitFullScreen();
+ } else {
+ var element;
+ if (this.source_) {
+ element = typeof this.source_ === 'string' ?
+ document.getElementById(this.source_) :
+ this.source_;
+ } else {
+ element = map.getTargetElement();
+ if (this.keys_) {
+ ol.control.FullScreen.requestFullScreenWithKeys(element);
+ } else {
+ ol.control.FullScreen.requestFullScreen(element);
+ * @private
+ol.control.FullScreen.prototype.handleFullScreenChange_ = function() {
+ var button = this.element.firstElementChild;
+ button.className = this.cssClassName_ + '-true';
+ ol.dom.replaceNode(this.labelActiveNode_, this.labelNode_);
+ } else {
+ button.className = this.cssClassName_ + '-false';
+ ol.dom.replaceNode(this.labelNode_, this.labelActiveNode_);
+ if (map) {
+ map.updateSize();
+ * @inheritDoc
+ * @api
+ol.control.FullScreen.prototype.setMap = function(map) {
+ ol.control.Control.prototype.setMap.call(this, map);
+ if (map) {
+ this.listenerKeys.push(ol.events.listen(document,
+ ol.control.FullScreen.getChangeType_(),
+ this.handleFullScreenChange_, this)
+ * @return {boolean} Fullscreen is supported by the current platform.
+ol.control.FullScreen.isFullScreenSupported = function() {
+ var body = document.body;
+ return !!(
+ body.webkitRequestFullscreen ||
+ (body.mozRequestFullScreen && document.mozFullScreenEnabled) ||
+ (body.msRequestFullscreen && document.msFullscreenEnabled) ||
+ (body.requestFullscreen && document.fullscreenEnabled)
+ * @return {boolean} Element is currently in fullscreen.
+ol.control.FullScreen.isFullScreen = function() {
+ return !!(
+ document.webkitIsFullScreen || document.mozFullScreen ||
+ document.msFullscreenElement || document.fullscreenElement
+ * Request to fullscreen an element.
+ * @param {Node} element Element to request fullscreen
+ol.control.FullScreen.requestFullScreen = function(element) {
+ if (element.requestFullscreen) {
+ element.requestFullscreen();
+ } else if (element.msRequestFullscreen) {
+ element.msRequestFullscreen();
+ } else if (element.mozRequestFullScreen) {
+ element.mozRequestFullScreen();
+ } else if (element.webkitRequestFullscreen) {
+ element.webkitRequestFullscreen();
+ * Request to fullscreen an element with keyboard input.
+ol.control.FullScreen.requestFullScreenWithKeys = function(element) {
+ if (element.mozRequestFullScreenWithKeys) {
+ element.mozRequestFullScreenWithKeys();
+ element.webkitRequestFullscreen(Element.ALLOW_KEYBOARD_INPUT);
+ } else {
+ * Exit fullscreen.
+ol.control.FullScreen.exitFullScreen = function() {
+ if (document.exitFullscreen) {
+ document.exitFullscreen();
+ } else if (document.msExitFullscreen) {
+ document.msExitFullscreen();
+ } else if (document.mozCancelFullScreen) {
+ document.mozCancelFullScreen();
+ } else if (document.webkitExitFullscreen) {
+ document.webkitExitFullscreen();
+ * @return {string} Change type.
+ * @private
+ol.control.FullScreen.getChangeType_ = (function() {
+ var changeType;
+ return function() {
+ if (!changeType) {
+ if (body.webkitRequestFullscreen) {
+ changeType = 'webkitfullscreenchange';
+ } else if (body.mozRequestFullScreen) {
+ changeType = 'mozfullscreenchange';
+ } else if (body.msRequestFullscreen) {
+ changeType = 'MSFullscreenChange';
+ } else if (body.requestFullscreen) {
+ changeType = 'fullscreenchange';
+ return changeType;
+// FIXME should listen on appropriate pane, once it is defined
+goog.provide('ol.control.MousePosition');
+goog.require('ol.proj');
+ * @classdesc
+ * A control to show the 2D coordinates of the mouse cursor. By default, these
+ * are in the view projection, but can be in any supported projection.
+ * By default the control is shown in the top right corner of the map, but this
+ * can be changed by using the css selector `.ol-mouse-position`.
+ * @constructor
+ * @param {olx.control.MousePositionOptions=} opt_options Mouse position
+ * options.
+ * @api
+ol.control.MousePosition = function(opt_options) {
+ var element = document.createElement('DIV');
+ element.className = options.className !== undefined ? options.className : 'ol-mouse-position';
+ options.render : ol.control.MousePosition.render;
+ element: element,
+ render: render,
+ ol.events.listen(this,
+ ol.Object.getChangeEventType(ol.control.MousePosition.Property_.PROJECTION),
+ this.handleProjectionChanged_, this);
+ if (options.coordinateFormat) {
+ this.setCoordinateFormat(options.coordinateFormat);
+ if (options.projection) {
+ this.setProjection(ol.proj.get(options.projection));
+ * @private
+ * @type {string}
+ this.undefinedHTML_ = options.undefinedHTML !== undefined ? options.undefinedHTML : '';
+ * @private
+ * @type {string}
+ this.renderedHTML_ = element.innerHTML;
+ * @private
+ * @type {ol.proj.Projection}
+ this.mapProjection_ = null;
+ * @private
+ * @type {?ol.TransformFunction}
+ this.transform_ = null;
+ * @private
+ * @type {ol.Pixel}
+ this.lastMouseMovePixel_ = null;
+ol.inherits(ol.control.MousePosition, ol.control.Control);
+ * Update the mouseposition element.
+ * @this {ol.control.MousePosition}
+ * @api
+ol.control.MousePosition.render = function(mapEvent) {
+ } else {
+ if (this.mapProjection_ != frameState.viewState.projection) {
+ this.mapProjection_ = frameState.viewState.projection;
+ this.updateHTML_(this.lastMouseMovePixel_);
+ * @private
+ol.control.MousePosition.prototype.handleProjectionChanged_ = function() {
+ * Return the coordinate format type used to render the current position or
+ * undefined.
+ * @return {ol.CoordinateFormatType|undefined} The format to render the current
+ * position in.
+ * @observable
+ * @api
+ol.control.MousePosition.prototype.getCoordinateFormat = function() {
+ return /** @type {ol.CoordinateFormatType|undefined} */ (
+ this.get(ol.control.MousePosition.Property_.COORDINATE_FORMAT));
+ * Return the projection that is used to report the mouse position.
+ * @return {ol.proj.Projection|undefined} The projection to report mouse
+ * position in.
+ * @observable
+ * @api
+ol.control.MousePosition.prototype.getProjection = function() {
+ return /** @type {ol.proj.Projection|undefined} */ (
+ this.get(ol.control.MousePosition.Property_.PROJECTION));
+ * @param {Event} event Browser event.
+ * @protected
+ol.control.MousePosition.prototype.handleMouseMove = function(event) {
+ this.lastMouseMovePixel_ = map.getEventPixel(event);
+ * @protected
+ol.control.MousePosition.prototype.handleMouseOut = function(event) {
+ this.updateHTML_(null);
+ * @inheritDoc
+ * @api
+ol.control.MousePosition.prototype.setMap = function(map) {
+ if (map) {
+ var viewport = map.getViewport();
+ ol.events.listen(viewport, ol.events.EventType.MOUSEMOVE,
+ this.handleMouseMove, this),
+ ol.events.listen(viewport, ol.events.EventType.MOUSEOUT,
+ this.handleMouseOut, this)
+ * Set the coordinate format type used to render the current position.
+ * @param {ol.CoordinateFormatType} format The format to render the current
+ * position in.
+ * @observable
+ * @api
+ol.control.MousePosition.prototype.setCoordinateFormat = function(format) {
+ this.set(ol.control.MousePosition.Property_.COORDINATE_FORMAT, format);
+ * Set the projection that is used to report the mouse position.
+ * @param {ol.proj.Projection} projection The projection to report mouse
+ * position in.
+ * @observable
+ * @api
+ol.control.MousePosition.prototype.setProjection = function(projection) {
+ this.set(ol.control.MousePosition.Property_.PROJECTION, projection);
+ * @param {?ol.Pixel} pixel Pixel.
+ * @private
+ol.control.MousePosition.prototype.updateHTML_ = function(pixel) {
+ var html = this.undefinedHTML_;
+ if (pixel && this.mapProjection_) {
+ if (!this.transform_) {
+ var projection = this.getProjection();
+ if (projection) {
+ this.transform_ = ol.proj.getTransformFromProjections(
+ this.mapProjection_, projection);
+ } else {
+ this.transform_ = ol.proj.identityTransform;
+ var coordinate = map.getCoordinateFromPixel(pixel);
+ if (coordinate) {
+ this.transform_(coordinate, coordinate);
+ var coordinateFormat = this.getCoordinateFormat();
+ if (coordinateFormat) {
+ html = coordinateFormat(coordinate);
+ } else {
+ html = coordinate.toString();
+ if (!this.renderedHTML_ || html != this.renderedHTML_) {
+ this.element.innerHTML = html;
+ this.renderedHTML_ = html;
+ * @enum {string}
+ * @private
+ol.control.MousePosition.Property_ = {
+ PROJECTION: 'projection',
+ COORDINATE_FORMAT: 'coordinateFormat'
+goog.provide('ol.MapEvent');
+ * @classdesc
+ * Events emitted as map events are instances of this type.
+ * See {@link ol.Map} for which events trigger a map event.
+ * @constructor
+ * @implements {oli.MapEvent}
+ * @param {string} type Event type.
+ * @param {?olx.FrameState=} opt_frameState Frame state.
+ol.MapEvent = function(type, map, opt_frameState) {
+ * The map where the event occurred.
+ * @type {ol.Map}
+ * @api
+ this.map = map;
+ * The frame state at the time of the event.
+ * @type {?olx.FrameState}
+ * @api
+ this.frameState = opt_frameState !== undefined ? opt_frameState : null;
+ol.inherits(ol.MapEvent, ol.events.Event);
+goog.provide('ol.MapBrowserEvent');
+goog.require('ol.MapEvent');
+ * @classdesc
+ * Events emitted as map browser events are instances of this type.
+ * See {@link ol.Map} for which events trigger a map browser event.
+ * @constructor
+ * @extends {ol.MapEvent}
+ * @implements {oli.MapBrowserEvent}
+ * @param {Event} browserEvent Browser event.
+ * @param {boolean=} opt_dragging Is the map currently being dragged?
+ol.MapBrowserEvent = function(type, map, browserEvent, opt_dragging,
+ opt_frameState) {
+ ol.MapEvent.call(this, type, map, opt_frameState);
+ * The original browser event.
+ * @const
+ * @type {Event}
+ * @api
+ this.originalEvent = browserEvent;
+ * The map pixel relative to the viewport corresponding to the original browser event.
+ * @api
+ this.pixel = map.getEventPixel(browserEvent);
+ * The coordinate in view projection corresponding to the original browser event.
+ * @type {ol.Coordinate}
+ * @api
+ this.coordinate = map.getCoordinateFromPixel(this.pixel);
+ * Indicates if the map is currently being dragged. Only set for
+ * `POINTERDRAG` and `POINTERMOVE` events. Default is `false`.
+ * @type {boolean}
+ * @api
+ this.dragging = opt_dragging !== undefined ? opt_dragging : false;
+ol.inherits(ol.MapBrowserEvent, ol.MapEvent);
+ * Prevents the default browser action.
+ * @see https://developer.mozilla.org/en-US/docs/Web/API/event.preventDefault
+ * @override
+ * @api
+ol.MapBrowserEvent.prototype.preventDefault = function() {
+ ol.MapEvent.prototype.preventDefault.call(this);
+ this.originalEvent.preventDefault();
+ * Prevents further propagation of the current event.
+ * @see https://developer.mozilla.org/en-US/docs/Web/API/event.stopPropagation
+ * @override
+ * @api
+ol.MapBrowserEvent.prototype.stopPropagation = function() {
+ ol.MapEvent.prototype.stopPropagation.call(this);
+ this.originalEvent.stopPropagation();
+goog.provide('ol.MapBrowserEventType');
+ * Constants for event names.
+ * @enum {string}
+ol.MapBrowserEventType = {
+ * A true single click with no dragging and no double click. Note that this
+ * event is delayed by 250 ms to ensure that it is not a double click.
+ * @event ol.MapBrowserEvent#singleclick
+ * @api
+ SINGLECLICK: 'singleclick',
+ * A click with no dragging. A double click will fire two of this.
+ * @event ol.MapBrowserEvent#click
+ * @api
+ CLICK: ol.events.EventType.CLICK,
+ * A true double click, with no dragging.
+ * @event ol.MapBrowserEvent#dblclick
+ * @api
+ DBLCLICK: ol.events.EventType.DBLCLICK,
+ * Triggered when a pointer is dragged.
+ * @event ol.MapBrowserEvent#pointerdrag
+ * @api
+ POINTERDRAG: 'pointerdrag',
+ * Triggered when a pointer is moved. Note that on touch devices this is
+ * triggered when the map is panned, so is not the same as mousemove.
+ * @event ol.MapBrowserEvent#pointermove
+ * @api
+ POINTERMOVE: 'pointermove',
+ POINTERDOWN: 'pointerdown',
+ POINTERUP: 'pointerup',
+ POINTEROVER: 'pointerover',
+ POINTEROUT: 'pointerout',
+ POINTERENTER: 'pointerenter',
+ POINTERLEAVE: 'pointerleave',
+ POINTERCANCEL: 'pointercancel'
+goog.provide('ol.MapBrowserPointerEvent');
+goog.require('ol.MapBrowserEvent');
+ * @constructor
+ * @extends {ol.MapBrowserEvent}
+ * @param {ol.pointer.PointerEvent} pointerEvent Pointer event.
+ol.MapBrowserPointerEvent = function(type, map, pointerEvent, opt_dragging,
+ opt_frameState) {
+ ol.MapBrowserEvent.call(this, type, map, pointerEvent.originalEvent, opt_dragging,
+ opt_frameState);
+ * @const
+ * @type {ol.pointer.PointerEvent}
+ this.pointerEvent = pointerEvent;
+ol.inherits(ol.MapBrowserPointerEvent, ol.MapBrowserEvent);
+goog.provide('ol.pointer.EventType');
+ * @enum {string}
+ol.pointer.EventType = {
+goog.provide('ol.webgl');
+if (ol.ENABLE_WEBGL) {
+ /** Constants taken from goog.webgl
+ * @const
+ * @type {number}
+ ol.webgl.ONE = 1;
+ * @const
+ * @type {number}
+ ol.webgl.SRC_ALPHA = 0x0302;
+ * @const
+ * @type {number}
+ ol.webgl.COLOR_ATTACHMENT0 = 0x8CE0;
+ * @const
+ * @type {number}
+ ol.webgl.COLOR_BUFFER_BIT = 0x00004000;
+ * @const
+ * @type {number}
+ ol.webgl.TRIANGLES = 0x0004;
+ * @const
+ * @type {number}
+ ol.webgl.TRIANGLE_STRIP = 0x0005;
+ * @const
+ * @type {number}
+ ol.webgl.ONE_MINUS_SRC_ALPHA = 0x0303;
+ * @const
+ * @type {number}
+ ol.webgl.ARRAY_BUFFER = 0x8892;
+ * @const
+ * @type {number}
+ ol.webgl.ELEMENT_ARRAY_BUFFER = 0x8893;
+ * @const
+ * @type {number}
+ ol.webgl.STREAM_DRAW = 0x88E0;
+ * @const
+ * @type {number}
+ ol.webgl.STATIC_DRAW = 0x88E4;
+ * @const
+ * @type {number}
+ ol.webgl.DYNAMIC_DRAW = 0x88E8;
+ * @const
+ * @type {number}
+ ol.webgl.CULL_FACE = 0x0B44;
+ * @const
+ * @type {number}
+ ol.webgl.BLEND = 0x0BE2;
+ * @const
+ * @type {number}
+ ol.webgl.STENCIL_TEST = 0x0B90;
+ * @const
+ * @type {number}
+ ol.webgl.DEPTH_TEST = 0x0B71;
+ * @const
+ * @type {number}
+ ol.webgl.SCISSOR_TEST = 0x0C11;
+ * @const
+ * @type {number}
+ ol.webgl.UNSIGNED_BYTE = 0x1401;
+ * @const
+ * @type {number}
+ ol.webgl.UNSIGNED_SHORT = 0x1403;
+ * @const
+ * @type {number}
+ ol.webgl.UNSIGNED_INT = 0x1405;
+ * @const
+ * @type {number}
+ ol.webgl.FLOAT = 0x1406;
+ * @const
+ * @type {number}
+ ol.webgl.RGBA = 0x1908;
+ * @const
+ * @type {number}
+ ol.webgl.FRAGMENT_SHADER = 0x8B30;
+ * @const
+ * @type {number}
+ ol.webgl.VERTEX_SHADER = 0x8B31;
+ * @const
+ * @type {number}
+ ol.webgl.LINK_STATUS = 0x8B82;
+ * @const
+ * @type {number}
+ ol.webgl.LINEAR = 0x2601;
+ * @const
+ * @type {number}
+ ol.webgl.TEXTURE_MAG_FILTER = 0x2800;
+ * @const
+ * @type {number}
+ ol.webgl.TEXTURE_MIN_FILTER = 0x2801;
+ * @const
+ * @type {number}
+ ol.webgl.TEXTURE_WRAP_S = 0x2802;
+ * @const
+ * @type {number}
+ ol.webgl.TEXTURE_WRAP_T = 0x2803;
+ * @const
+ * @type {number}
+ ol.webgl.TEXTURE_2D = 0x0DE1;
+ * @const
+ * @type {number}
+ ol.webgl.TEXTURE0 = 0x84C0;
+ * @const
+ * @type {number}
+ ol.webgl.CLAMP_TO_EDGE = 0x812F;
+ * @const
+ * @type {number}
+ ol.webgl.COMPILE_STATUS = 0x8B81;
+ * @const
+ * @type {number}
+ ol.webgl.FRAMEBUFFER = 0x8D40;
+ /** end of goog.webgl constants
+ * @const
+ * @private
+ * @type {Array.<string>}
+ ol.webgl.CONTEXT_IDS_ = [
+ 'experimental-webgl',
+ 'webgl',
+ 'webkit-3d',
+ 'moz-webgl'
+ * @param {HTMLCanvasElement} canvas Canvas.
+ * @param {Object=} opt_attributes Attributes.
+ * @return {WebGLRenderingContext} WebGL rendering context.
+ ol.webgl.getContext = function(canvas, opt_attributes) {
+ var context, i, ii = ol.webgl.CONTEXT_IDS_.length;
+ for (i = 0; i < ii; ++i) {
+ try {
+ context = canvas.getContext(ol.webgl.CONTEXT_IDS_[i], opt_attributes);
+ if (context) {
+ return /** @type {!WebGLRenderingContext} */ (context);
+ } catch (e) {
+ // pass
+ return null;
+goog.provide('ol.has');
+goog.require('ol.webgl');
+var ua = typeof navigator !== 'undefined' ?
+ navigator.userAgent.toLowerCase() : '';
+ * User agent string says we are dealing with Firefox as browser.
+ * @type {boolean}
+ol.has.FIREFOX = ua.indexOf('firefox') !== -1;
+ * User agent string says we are dealing with Safari as browser.
+ * @type {boolean}
+ol.has.SAFARI = ua.indexOf('safari') !== -1 && ua.indexOf('chrom') == -1;
+ * User agent string says we are dealing with a WebKit engine.
+ * @type {boolean}
+ol.has.WEBKIT = ua.indexOf('webkit') !== -1 && ua.indexOf('edge') == -1;
+ * User agent string says we are dealing with a Mac as platform.
+ * @type {boolean}
+ol.has.MAC = ua.indexOf('macintosh') !== -1;
+ * The ratio between physical pixels and device-independent pixels
+ * (dips) on the device (`window.devicePixelRatio`).
+ * @const
+ * @type {number}
+ * @api
+ol.has.DEVICE_PIXEL_RATIO = window.devicePixelRatio || 1;
+ * True if the browser's Canvas implementation implements {get,set}LineDash.
+ * @type {boolean}
+ol.has.CANVAS_LINE_DASH = false;
+ * True if both the library and browser support Canvas. Always `false`
+ * if `ol.ENABLE_CANVAS` is set to `false` at compile time.
+ * @const
+ * @type {boolean}
+ * @api
+ol.has.CANVAS = ol.ENABLE_CANVAS && (
+ * @return {boolean} Canvas supported.
+ function() {
+ if (!('HTMLCanvasElement' in window)) {
+ return false;
+ try {
+ var context = document.createElement('CANVAS').getContext('2d');
+ if (!context) {
+ return false;
+ } else {
+ if (context.setLineDash !== undefined) {
+ ol.has.CANVAS_LINE_DASH = true;
+ return true;
+ } catch (e) {
+ return false;
+ * Indicates if DeviceOrientation is supported in the user's browser.
+ * @const
+ * @type {boolean}
+ * @api
+ol.has.DEVICE_ORIENTATION = 'DeviceOrientationEvent' in window;
+ * Is HTML5 geolocation supported in the current browser?
+ * @const
+ * @type {boolean}
+ * @api
+ol.has.GEOLOCATION = 'geolocation' in navigator;
+ * True if browser supports touch events.
+ * @const
+ * @type {boolean}
+ * @api
+ol.has.TOUCH = ol.ASSUME_TOUCH || 'ontouchstart' in window;
+ * True if browser supports pointer events.
+ * @const
+ * @type {boolean}
+ol.has.POINTER = 'PointerEvent' in window;
+ * True if browser supports ms pointer events (IE 10).
+ * @const
+ * @type {boolean}
+ol.has.MSPOINTER = !!(navigator.msPointerEnabled);
+ * True if both OpenLayers and browser support WebGL. Always `false`
+ * if `ol.ENABLE_WEBGL` is set to `false` at compile time.
+ * @const
+ * @type {boolean}
+ * @api
+ol.has.WEBGL;
+(function() {
+ if (ol.ENABLE_WEBGL) {
+ var hasWebGL = false;
+ var textureSize;
+ var /** @type {Array.<string>} */ extensions = [];
+ if ('WebGLRenderingContext' in window) {
+ try {
+ var canvas = /** @type {HTMLCanvasElement} */
+ (document.createElement('CANVAS'));
+ var gl = ol.webgl.getContext(canvas, {
+ failIfMajorPerformanceCaveat: true
+ if (gl) {
+ hasWebGL = true;
+ textureSize = /** @type {number} */
+ (gl.getParameter(gl.MAX_TEXTURE_SIZE));
+ extensions = gl.getSupportedExtensions();
+ } catch (e) {
+ // pass
+ ol.has.WEBGL = hasWebGL;
+ ol.WEBGL_EXTENSIONS = extensions;
+ ol.WEBGL_MAX_TEXTURE_SIZE = textureSize;
+goog.provide('ol.pointer.EventSource');
+ * @param {ol.pointer.PointerEventHandler} dispatcher Event handler.
+ * @param {!Object.<string, function(Event)>} mapping Event
+ * mapping.
+ * @constructor
+ol.pointer.EventSource = function(dispatcher, mapping) {
+ * @type {ol.pointer.PointerEventHandler}
+ this.dispatcher = dispatcher;
+ * @private
+ * @const
+ * @type {!Object.<string, function(Event)>}
+ this.mapping_ = mapping;
+ * List of events supported by this source.
+ * @return {Array.<string>} Event names
+ol.pointer.EventSource.prototype.getEvents = function() {
+ return Object.keys(this.mapping_);
+ * Returns a mapping between the supported event types and
+ * the handlers that should handle an event.
+ * @return {Object.<string, function(Event)>}
+ * Event/Handler mapping
+ol.pointer.EventSource.prototype.getMapping = function() {
+ return this.mapping_;
+ * Returns the handler that should handle a given event type.
+ * @param {string} eventType The event type.
+ * @return {function(Event)} Handler
+ol.pointer.EventSource.prototype.getHandlerForEvent = function(eventType) {
+ return this.mapping_[eventType];
+// Based on https://github.com/Polymer/PointerEvents
+// Copyright (c) 2013 The Polymer Authors. All rights reserved.
+// Redistribution and use in source and binary forms, with or without
+// modification, are permitted provided that the following conditions are
+// met:
+// * Redistributions of source code must retain the above copyright
+// notice, this list of conditions and the following disclaimer.
+// * Redistributions in binary form must reproduce the above
+// copyright notice, this list of conditions and the following disclaimer
+// in the documentation and/or other materials provided with the
+// distribution.
+// * Neither the name of Google Inc. nor the names of its
+// contributors may be used to endorse or promote products derived from
+// this software without specific prior written permission.
+// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
+// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
+// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+goog.provide('ol.pointer.MouseSource');
+goog.require('ol.pointer.EventSource');
+ * @constructor
+ * @extends {ol.pointer.EventSource}
+ol.pointer.MouseSource = function(dispatcher) {
+ var mapping = {
+ 'mousedown': this.mousedown,
+ 'mousemove': this.mousemove,
+ 'mouseup': this.mouseup,
+ 'mouseover': this.mouseover,
+ 'mouseout': this.mouseout
+ ol.pointer.EventSource.call(this, dispatcher, mapping);
+ * @const
+ * @type {!Object.<string, Event|Object>}
+ this.pointerMap = dispatcher.pointerMap;
+ * @const
+ * @type {Array.<ol.Pixel>}
+ this.lastTouches = [];
+ol.inherits(ol.pointer.MouseSource, ol.pointer.EventSource);
+ * @const
+ * @type {number}
+ol.pointer.MouseSource.POINTER_ID = 1;
+ * @const
+ * @type {string}
+ol.pointer.MouseSource.POINTER_TYPE = 'mouse';
+ * Radius around touchend that swallows mouse events.
+ * @const
+ * @type {number}
+ol.pointer.MouseSource.DEDUP_DIST = 25;
+ * Detect if a mouse event was simulated from a touch by
+ * checking if previously there was a touch event at the
+ * same position.
+ * FIXME - Known problem with the native Android browser on
+ * Samsung GT-I9100 (Android 4.1.2):
+ * In case the page is scrolled, this function does not work
+ * correctly when a canvas is used (WebGL or canvas renderer).
+ * Mouse listeners on canvas elements (for this browser), create
+ * two mouse events: One 'good' and one 'bad' one (on other browsers or
+ * when a div is used, there is only one event). For the 'bad' one,
+ * clientX/clientY and also pageX/pageY are wrong when the page
+ * is scrolled. Because of that, this function can not detect if
+ * the events were simulated from a touch event. As result, a
+ * pointer event at a wrong position is dispatched, which confuses
+ * the map interactions.
+ * It is unclear, how one can get the correct position for the event
+ * or detect that the positions are invalid.
+ * @private
+ * @param {Event} inEvent The in event.
+ * @return {boolean} True, if the event was generated by a touch.
+ol.pointer.MouseSource.prototype.isEventSimulatedFromTouch_ = function(inEvent) {
+ var lts = this.lastTouches;
+ var x = inEvent.clientX, y = inEvent.clientY;
+ for (var i = 0, l = lts.length, t; i < l && (t = lts[i]); i++) {
+ // simulated mouse events will be swallowed near a primary touchend
+ var dx = Math.abs(x - t[0]), dy = Math.abs(y - t[1]);
+ if (dx <= ol.pointer.MouseSource.DEDUP_DIST &&
+ dy <= ol.pointer.MouseSource.DEDUP_DIST) {
+ return true;
+ return false;
+ * Creates a copy of the original event that will be used
+ * for the fake pointer event.
+ * @return {Object} The copied event.
+ol.pointer.MouseSource.prepareEvent = function(inEvent, dispatcher) {
+ var e = dispatcher.cloneEvent(inEvent, inEvent);
+ // forward mouse preventDefault
+ var pd = e.preventDefault;
+ e.preventDefault = function() {
+ inEvent.preventDefault();
+ pd();
+ e.pointerId = ol.pointer.MouseSource.POINTER_ID;
+ e.isPrimary = true;
+ e.pointerType = ol.pointer.MouseSource.POINTER_TYPE;
+ return e;
+ * Handler for `mousedown`.
+ol.pointer.MouseSource.prototype.mousedown = function(inEvent) {
+ if (!this.isEventSimulatedFromTouch_(inEvent)) {
+ // TODO(dfreedman) workaround for some elements not sending mouseup
+ // http://crbug/149091
+ if (ol.pointer.MouseSource.POINTER_ID.toString() in this.pointerMap) {
+ this.cancel(inEvent);
+ var e = ol.pointer.MouseSource.prepareEvent(inEvent, this.dispatcher);
+ this.pointerMap[ol.pointer.MouseSource.POINTER_ID.toString()] = inEvent;
+ this.dispatcher.down(e, inEvent);
+ * Handler for `mousemove`.
+ol.pointer.MouseSource.prototype.mousemove = function(inEvent) {
+ this.dispatcher.move(e, inEvent);
+ * Handler for `mouseup`.
+ol.pointer.MouseSource.prototype.mouseup = function(inEvent) {
+ var p = this.pointerMap[ol.pointer.MouseSource.POINTER_ID.toString()];
+ if (p && p.button === inEvent.button) {
+ this.dispatcher.up(e, inEvent);
+ this.cleanupMouse();
+ * Handler for `mouseover`.
+ol.pointer.MouseSource.prototype.mouseover = function(inEvent) {
+ this.dispatcher.enterOver(e, inEvent);
+ * Handler for `mouseout`.
+ol.pointer.MouseSource.prototype.mouseout = function(inEvent) {
+ this.dispatcher.leaveOut(e, inEvent);
+ * Dispatches a `pointercancel` event.
+ol.pointer.MouseSource.prototype.cancel = function(inEvent) {
+ this.dispatcher.cancel(e, inEvent);
+ * Remove the mouse from the list of active pointers.
+ol.pointer.MouseSource.prototype.cleanupMouse = function() {
+ delete this.pointerMap[ol.pointer.MouseSource.POINTER_ID.toString()];
+// met:
+// distribution.
+goog.provide('ol.pointer.MsSource');
+ * @constructor
+ol.pointer.MsSource = function(dispatcher) {
+ var mapping = {
+ 'MSPointerDown': this.msPointerDown,
+ 'MSPointerMove': this.msPointerMove,
+ 'MSPointerUp': this.msPointerUp,
+ 'MSPointerOut': this.msPointerOut,
+ 'MSPointerOver': this.msPointerOver,
+ 'MSPointerCancel': this.msPointerCancel,
+ 'MSGotPointerCapture': this.msGotPointerCapture,
+ 'MSLostPointerCapture': this.msLostPointerCapture
+ * @const
+ * @const
+ this.POINTER_TYPES = [
+ 'unavailable',
+ 'touch',
+ 'pen',
+ 'mouse'
+ol.inherits(ol.pointer.MsSource, ol.pointer.EventSource);
+ * @private
+ol.pointer.MsSource.prototype.prepareEvent_ = function(inEvent) {
+ var e = inEvent;
+ if (typeof inEvent.pointerType === 'number') {
+ e = this.dispatcher.cloneEvent(inEvent, inEvent);
+ e.pointerType = this.POINTER_TYPES[inEvent.pointerType];
+ return e;
+ * Remove this pointer from the list of active pointers.
+ * @param {number} pointerId Pointer identifier.
+ol.pointer.MsSource.prototype.cleanup = function(pointerId) {
+ delete this.pointerMap[pointerId.toString()];
+ * Handler for `msPointerDown`.
+ol.pointer.MsSource.prototype.msPointerDown = function(inEvent) {
+ this.pointerMap[inEvent.pointerId.toString()] = inEvent;
+ var e = this.prepareEvent_(inEvent);
+ * Handler for `msPointerMove`.
+ol.pointer.MsSource.prototype.msPointerMove = function(inEvent) {
+ * Handler for `msPointerUp`.
+ol.pointer.MsSource.prototype.msPointerUp = function(inEvent) {
+ this.cleanup(inEvent.pointerId);
+ * Handler for `msPointerOut`.
+ol.pointer.MsSource.prototype.msPointerOut = function(inEvent) {
+ * Handler for `msPointerOver`.
+ol.pointer.MsSource.prototype.msPointerOver = function(inEvent) {
+ * Handler for `msPointerCancel`.
+ol.pointer.MsSource.prototype.msPointerCancel = function(inEvent) {
+ * Handler for `msLostPointerCapture`.
+ol.pointer.MsSource.prototype.msLostPointerCapture = function(inEvent) {
+ var e = this.dispatcher.makeEvent('lostpointercapture',
+ inEvent, inEvent);
+ this.dispatcher.dispatchEvent(e);
+ * Handler for `msGotPointerCapture`.
+ol.pointer.MsSource.prototype.msGotPointerCapture = function(inEvent) {
+ var e = this.dispatcher.makeEvent('gotpointercapture',
+// met:
+// distribution.
+goog.provide('ol.pointer.NativeSource');
+ * @constructor
+ol.pointer.NativeSource = function(dispatcher) {
+ var mapping = {
+ 'pointerdown': this.pointerDown,
+ 'pointermove': this.pointerMove,
+ 'pointerup': this.pointerUp,
+ 'pointerout': this.pointerOut,
+ 'pointerover': this.pointerOver,
+ 'pointercancel': this.pointerCancel,
+ 'gotpointercapture': this.gotPointerCapture,
+ 'lostpointercapture': this.lostPointerCapture
+ol.inherits(ol.pointer.NativeSource, ol.pointer.EventSource);
+ * Handler for `pointerdown`.
+ol.pointer.NativeSource.prototype.pointerDown = function(inEvent) {
+ this.dispatcher.fireNativeEvent(inEvent);
+ * Handler for `pointermove`.
+ol.pointer.NativeSource.prototype.pointerMove = function(inEvent) {
+ * Handler for `pointerup`.
+ol.pointer.NativeSource.prototype.pointerUp = function(inEvent) {
+ * Handler for `pointerout`.
+ol.pointer.NativeSource.prototype.pointerOut = function(inEvent) {
+ * Handler for `pointerover`.
+ol.pointer.NativeSource.prototype.pointerOver = function(inEvent) {
+ * Handler for `pointercancel`.
+ol.pointer.NativeSource.prototype.pointerCancel = function(inEvent) {
+ * Handler for `lostpointercapture`.
+ol.pointer.NativeSource.prototype.lostPointerCapture = function(inEvent) {
+ * Handler for `gotpointercapture`.
+ol.pointer.NativeSource.prototype.gotPointerCapture = function(inEvent) {
+// met:
+// distribution.
+goog.provide('ol.pointer.PointerEvent');
+goog.require('ol.events.Event');
+ * A class for pointer events.
+ * This class is used as an abstraction for mouse events,
+ * touch events and even native pointer events.
+ * @constructor
+ * @extends {ol.events.Event}
+ * @param {string} type The type of the event to create.
+ * @param {Event} originalEvent The event.
+ * @param {Object.<string, ?>=} opt_eventDict An optional dictionary of
+ * initial event properties.
+ol.pointer.PointerEvent = function(type, originalEvent, opt_eventDict) {
+ ol.events.Event.call(this, type);
+ * @const
+ * @type {Event}
+ this.originalEvent = originalEvent;
+ var eventDict = opt_eventDict ? opt_eventDict : {};
+ * @type {number}
+ this.buttons = this.getButtons_(eventDict);
+ * @type {number}
+ this.pressure = this.getPressure_(eventDict, this.buttons);
+ // MouseEvent related properties
+ * @type {boolean}
+ this.bubbles = 'bubbles' in eventDict ? eventDict['bubbles'] : false;
+ * @type {boolean}
+ this.cancelable = 'cancelable' in eventDict ? eventDict['cancelable'] : false;
+ * @type {Object}
+ this.view = 'view' in eventDict ? eventDict['view'] : null;
+ * @type {number}
+ this.detail = 'detail' in eventDict ? eventDict['detail'] : null;
+ * @type {number}
+ this.screenX = 'screenX' in eventDict ? eventDict['screenX'] : 0;
+ * @type {number}
+ this.screenY = 'screenY' in eventDict ? eventDict['screenY'] : 0;
+ * @type {number}
+ this.clientX = 'clientX' in eventDict ? eventDict['clientX'] : 0;
+ * @type {number}
+ this.clientY = 'clientY' in eventDict ? eventDict['clientY'] : 0;
+ * @type {boolean}
+ this.ctrlKey = 'ctrlKey' in eventDict ? eventDict['ctrlKey'] : false;
+ * @type {boolean}
+ this.altKey = 'altKey' in eventDict ? eventDict['altKey'] : false;
+ * @type {boolean}
+ this.shiftKey = 'shiftKey' in eventDict ? eventDict['shiftKey'] : false;
+ * @type {boolean}
+ this.metaKey = 'metaKey' in eventDict ? eventDict['metaKey'] : false;
+ * @type {number}
+ this.button = 'button' in eventDict ? eventDict['button'] : 0;
+ * @type {Node}
+ this.relatedTarget = 'relatedTarget' in eventDict ?
+ eventDict['relatedTarget'] : null;
+ // PointerEvent related properties
+ * @const
+ * @type {number}
+ this.pointerId = 'pointerId' in eventDict ? eventDict['pointerId'] : 0;
+ * @type {number}
+ this.width = 'width' in eventDict ? eventDict['width'] : 0;
+ * @type {number}
+ this.height = 'height' in eventDict ? eventDict['height'] : 0;
+ * @type {number}
+ this.tiltX = 'tiltX' in eventDict ? eventDict['tiltX'] : 0;
+ * @type {number}
+ this.tiltY = 'tiltY' in eventDict ? eventDict['tiltY'] : 0;
+ * @type {string}
+ this.pointerType = 'pointerType' in eventDict ? eventDict['pointerType'] : '';
+ * @type {number}
+ this.hwTimestamp = 'hwTimestamp' in eventDict ? eventDict['hwTimestamp'] : 0;
+ * @type {boolean}
+ this.isPrimary = 'isPrimary' in eventDict ? eventDict['isPrimary'] : false;
+ // keep the semantics of preventDefault
+ if (originalEvent.preventDefault) {
+ this.preventDefault = function() {
+ originalEvent.preventDefault();
+ol.inherits(ol.pointer.PointerEvent, ol.events.Event);
+ * @private
+ * @param {Object.<string, ?>} eventDict The event dictionary.
+ * @return {number} Button indicator.
+ol.pointer.PointerEvent.prototype.getButtons_ = function(eventDict) {
+ // According to the w3c spec,
+ // http://www.w3.org/TR/DOM-Level-3-Events/#events-MouseEvent-button
+ // MouseEvent.button == 0 can mean either no mouse button depressed, or the
+ // left mouse button depressed.
+ // As of now, the only way to distinguish between the two states of
+ // MouseEvent.button is by using the deprecated MouseEvent.which property, as
+ // this maps mouse buttons to positive integers > 0, and uses 0 to mean that
+ // no mouse button is held.
+ // MouseEvent.which is derived from MouseEvent.button at MouseEvent creation,
+ // but initMouseEvent does not expose an argument with which to set
+ // MouseEvent.which. Calling initMouseEvent with a buttonArg of 0 will set
+ // MouseEvent.button == 0 and MouseEvent.which == 1, breaking the expectations
+ // of app developers.
+ // The only way to propagate the correct state of MouseEvent.which and
+ // MouseEvent.button to a new MouseEvent.button == 0 and MouseEvent.which == 0
+ // is to call initMouseEvent with a buttonArg value of -1.
+ // This is fixed with DOM Level 4's use of buttons
+ var buttons;
+ if (eventDict.buttons || ol.pointer.PointerEvent.HAS_BUTTONS) {
+ buttons = eventDict.buttons;
+ } else {
+ switch (eventDict.which) {
+ case 1: buttons = 1; break;
+ case 2: buttons = 4; break;
+ case 3: buttons = 2; break;
+ default: buttons = 0;
+ return buttons;
+ * @private
+ * @param {number} buttons Button indicator.
+ * @return {number} The pressure.
+ol.pointer.PointerEvent.prototype.getPressure_ = function(eventDict, buttons) {
+ // Spec requires that pointers without pressure specified use 0.5 for down
+ // state and 0 for up state.
+ var pressure = 0;
+ if (eventDict.pressure) {
+ pressure = eventDict.pressure;
+ } else {
+ pressure = buttons ? 0.5 : 0;
+ return pressure;
+ * Is the `buttons` property supported?
+ * @type {boolean}
+ol.pointer.PointerEvent.HAS_BUTTONS = false;
+ * Checks if the `buttons` property is supported.
+(function() {
+ try {
+ var ev = new MouseEvent('click', {buttons: 1});
+ ol.pointer.PointerEvent.HAS_BUTTONS = ev.buttons === 1;
+ } catch (e) {
+ // pass
+// met:
+// distribution.
+goog.provide('ol.pointer.TouchSource');
+goog.require('ol.array');
+goog.require('ol.pointer.MouseSource');
+ * @constructor
+ * @param {ol.pointer.PointerEventHandler} dispatcher The event handler.
+ * @param {ol.pointer.MouseSource} mouseSource Mouse source.
+ol.pointer.TouchSource = function(dispatcher, mouseSource) {
+ var mapping = {
+ 'touchstart': this.touchstart,
+ 'touchmove': this.touchmove,
+ 'touchend': this.touchend,
+ 'touchcancel': this.touchcancel
+ * @const
+ * @const
+ * @type {ol.pointer.MouseSource}
+ this.mouseSource = mouseSource;
+ * @private
+ this.firstTouchId_ = undefined;
+ * @private
+ * @type {number}
+ this.clickCount_ = 0;
+ * @private
+ this.resetId_ = undefined;
+ol.inherits(ol.pointer.TouchSource, ol.pointer.EventSource);
+ * Mouse event timeout: This should be long enough to
+ * ignore compat mouse events made by touch.
+ * @const
+ * @type {number}
+ol.pointer.TouchSource.DEDUP_TIMEOUT = 2500;
+ * @const
+ * @type {number}
+ol.pointer.TouchSource.CLICK_COUNT_TIMEOUT = 200;
+ * @const
+ * @type {string}
+ol.pointer.TouchSource.POINTER_TYPE = 'touch';
+ * @private
+ * @param {Touch} inTouch The in touch.
+ * @return {boolean} True, if this is the primary touch.
+ol.pointer.TouchSource.prototype.isPrimaryTouch_ = function(inTouch) {
+ return this.firstTouchId_ === inTouch.identifier;
+ * Set primary touch if there are no pointers, or the only pointer is the mouse.
+ * @private
+ol.pointer.TouchSource.prototype.setPrimaryTouch_ = function(inTouch) {
+ var count = Object.keys(this.pointerMap).length;
+ if (count === 0 || (count === 1 &&
+ ol.pointer.MouseSource.POINTER_ID.toString() in this.pointerMap)) {
+ this.firstTouchId_ = inTouch.identifier;
+ this.cancelResetClickCount_();
+ * @private
+ * @param {Object} inPointer The in pointer object.
+ol.pointer.TouchSource.prototype.removePrimaryPointer_ = function(inPointer) {
+ if (inPointer.isPrimary) {
+ this.resetClickCount_();
+ * @private
+ol.pointer.TouchSource.prototype.resetClickCount_ = function() {
+ this.resetId_ = setTimeout(
+ this.resetClickCountHandler_.bind(this),
+ ol.pointer.TouchSource.CLICK_COUNT_TIMEOUT);
+ * @private
+ol.pointer.TouchSource.prototype.resetClickCountHandler_ = function() {
+ * @private
+ol.pointer.TouchSource.prototype.cancelResetClickCount_ = function() {
+ if (this.resetId_ !== undefined) {
+ clearTimeout(this.resetId_);
+ * @private
+ * @param {Touch} inTouch Touch event
+ * @return {Object} A pointer object.
+ol.pointer.TouchSource.prototype.touchToPointer_ = function(browserEvent, inTouch) {
+ var e = this.dispatcher.cloneEvent(browserEvent, inTouch);
+ // Spec specifies that pointerId 1 is reserved for Mouse.
+ // Touch identifiers can start at 0.
+ // Add 2 to the touch identifier for compatibility.
+ e.pointerId = inTouch.identifier + 2;
+ // TODO: check if this is necessary?
+ //e.target = findTarget(e);
+ e.bubbles = true;
+ e.cancelable = true;
+ e.detail = this.clickCount_;
+ e.button = 0;
+ e.buttons = 1;
+ e.width = inTouch.webkitRadiusX || inTouch.radiusX || 0;
+ e.height = inTouch.webkitRadiusY || inTouch.radiusY || 0;
+ e.pressure = inTouch.webkitForce || inTouch.force || 0.5;
+ e.isPrimary = this.isPrimaryTouch_(inTouch);
+ e.pointerType = ol.pointer.TouchSource.POINTER_TYPE;
+ // make sure that the properties that are different for
+ // each `Touch` object are not copied from the BrowserEvent object
+ e.clientX = inTouch.clientX;
+ e.clientY = inTouch.clientY;
+ e.screenX = inTouch.screenX;
+ e.screenY = inTouch.screenY;
+ return e;
+ * @private
+ * @param {Event} inEvent Touch event
+ * @param {function(Event, Object)} inFunction In function.
+ol.pointer.TouchSource.prototype.processTouches_ = function(inEvent, inFunction) {
+ var touches = Array.prototype.slice.call(
+ inEvent.changedTouches);
+ var count = touches.length;
+ function preventDefault() {
+ var i, pointer;
+ for (i = 0; i < count; ++i) {
+ pointer = this.touchToPointer_(inEvent, touches[i]);
+ // forward touch preventDefaults
+ pointer.preventDefault = preventDefault;
+ inFunction.call(this, inEvent, pointer);
+ * @private
+ * @param {TouchList} touchList The touch list.
+ * @param {number} searchId Search identifier.
+ * @return {boolean} True, if the `Touch` with the given id is in the list.
+ol.pointer.TouchSource.prototype.findTouch_ = function(touchList, searchId) {
+ var l = touchList.length;
+ var touch;
+ for (var i = 0; i < l; i++) {
+ touch = touchList[i];
+ if (touch.identifier === searchId) {
+ return true;
+ return false;
+ * In some instances, a touchstart can happen without a touchend. This
+ * leaves the pointermap in a broken state.
+ * Therefore, on every touchstart, we remove the touches that did not fire a
+ * touchend event.
+ * To keep state globally consistent, we fire a pointercancel for
+ * this "abandoned" touch
+ * @private
+ol.pointer.TouchSource.prototype.vacuumTouches_ = function(inEvent) {
+ var touchList = inEvent.touches;
+ // pointerMap.getCount() should be < touchList.length here,
+ // as the touchstart has not been processed yet.
+ var keys = Object.keys(this.pointerMap);
+ var count = keys.length;
+ if (count >= touchList.length) {
+ var d = [];
+ var i, key, value;
+ key = keys[i];
+ value = this.pointerMap[key];
+ // Never remove pointerId == 1, which is mouse.
+ // Touch identifiers are 2 smaller than their pointerId, which is the
+ // index in pointermap.
+ if (key != ol.pointer.MouseSource.POINTER_ID &&
+ !this.findTouch_(touchList, key - 2)) {
+ d.push(value.out);
+ for (i = 0; i < d.length; ++i) {
+ this.cancelOut_(inEvent, d[i]);
+ * Handler for `touchstart`, triggers `pointerover`,
+ * `pointerenter` and `pointerdown` events.
+ol.pointer.TouchSource.prototype.touchstart = function(inEvent) {
+ this.vacuumTouches_(inEvent);
+ this.setPrimaryTouch_(inEvent.changedTouches[0]);
+ this.dedupSynthMouse_(inEvent);
+ this.clickCount_++;
+ this.processTouches_(inEvent, this.overDown_);
+ * @private
+ * @param {Event} browserEvent The event.
+ol.pointer.TouchSource.prototype.overDown_ = function(browserEvent, inPointer) {
+ this.pointerMap[inPointer.pointerId] = {
+ target: inPointer.target,
+ out: inPointer,
+ outTarget: inPointer.target
+ this.dispatcher.over(inPointer, browserEvent);
+ this.dispatcher.enter(inPointer, browserEvent);
+ this.dispatcher.down(inPointer, browserEvent);
+ * Handler for `touchmove`.
+ol.pointer.TouchSource.prototype.touchmove = function(inEvent) {
+ this.processTouches_(inEvent, this.moveOverOut_);
+ * @private
+ * @param {Object} inPointer The in pointer.
+ol.pointer.TouchSource.prototype.moveOverOut_ = function(browserEvent, inPointer) {
+ var event = inPointer;
+ var pointer = this.pointerMap[event.pointerId];
+ // a finger drifted off the screen, ignore it
+ if (!pointer) {
+ return;
+ var outEvent = pointer.out;
+ var outTarget = pointer.outTarget;
+ this.dispatcher.move(event, browserEvent);
+ if (outEvent && outTarget !== event.target) {
+ outEvent.relatedTarget = event.target;
+ event.relatedTarget = outTarget;
+ // recover from retargeting by shadow
+ outEvent.target = outTarget;
+ if (event.target) {
+ this.dispatcher.leaveOut(outEvent, browserEvent);
+ this.dispatcher.enterOver(event, browserEvent);
+ } else {
+ // clean up case when finger leaves the screen
+ event.target = outTarget;
+ event.relatedTarget = null;
+ this.cancelOut_(browserEvent, event);
+ pointer.out = event;
+ pointer.outTarget = event.target;
+ * Handler for `touchend`, triggers `pointerup`,
+ * `pointerout` and `pointerleave` events.
+ * @param {Event} inEvent The event.
+ol.pointer.TouchSource.prototype.touchend = function(inEvent) {
+ this.processTouches_(inEvent, this.upOut_);
+ * @private
+ * @param {Event} browserEvent An event.
+ * @param {Object} inPointer The inPointer object.
+ol.pointer.TouchSource.prototype.upOut_ = function(browserEvent, inPointer) {
+ this.dispatcher.up(inPointer, browserEvent);
+ this.dispatcher.out(inPointer, browserEvent);
+ this.dispatcher.leave(inPointer, browserEvent);
+ this.cleanUpPointer_(inPointer);
+ * Handler for `touchcancel`, triggers `pointercancel`,
+ol.pointer.TouchSource.prototype.touchcancel = function(inEvent) {
+ this.processTouches_(inEvent, this.cancelOut_);
+ * @private
+ol.pointer.TouchSource.prototype.cancelOut_ = function(browserEvent, inPointer) {
+ this.dispatcher.cancel(inPointer, browserEvent);
+ * @private
+ol.pointer.TouchSource.prototype.cleanUpPointer_ = function(inPointer) {
+ delete this.pointerMap[inPointer.pointerId];
+ this.removePrimaryPointer_(inPointer);
+ * Prevent synth mouse events from creating pointer events.
+ * @private
+ol.pointer.TouchSource.prototype.dedupSynthMouse_ = function(inEvent) {
+ var lts = this.mouseSource.lastTouches;
+ var t = inEvent.changedTouches[0];
+ // only the primary finger will synth mouse events
+ if (this.isPrimaryTouch_(t)) {
+ // remember x/y of last touch
+ var lt = [t.clientX, t.clientY];
+ lts.push(lt);
+ setTimeout(function() {
+ // remove touch after timeout
+ ol.array.remove(lts, lt);
+ }, ol.pointer.TouchSource.DEDUP_TIMEOUT);
+// met:
+// distribution.
+goog.provide('ol.pointer.PointerEventHandler');
+goog.require('ol.events');
+goog.require('ol.events.EventTarget');
+goog.require('ol.has');
+goog.require('ol.pointer.EventType');
+goog.require('ol.pointer.MsSource');
+goog.require('ol.pointer.NativeSource');
+goog.require('ol.pointer.PointerEvent');
+goog.require('ol.pointer.TouchSource');
+ * @constructor
+ * @extends {ol.events.EventTarget}
+ * @param {Element|HTMLDocument} element Viewport element.
+ol.pointer.PointerEventHandler = function(element) {
+ ol.events.EventTarget.call(this);
+ * @const
+ * @private
+ * @type {Element|HTMLDocument}
+ this.element_ = element;
+ * @const
+ this.pointerMap = {};
+ * @type {Object.<string, function(Event)>}
+ * @private
+ this.eventMap_ = {};
+ * @type {Array.<ol.pointer.EventSource>}
+ * @private
+ this.eventSourceList_ = [];
+ this.registerSources();
+ol.inherits(ol.pointer.PointerEventHandler, ol.events.EventTarget);
+ * Set up the event sources (mouse, touch and native pointers)
+ * that generate pointer events.
+ol.pointer.PointerEventHandler.prototype.registerSources = function() {
+ if (ol.has.POINTER) {
+ this.registerSource('native', new ol.pointer.NativeSource(this));
+ } else if (ol.has.MSPOINTER) {
+ this.registerSource('ms', new ol.pointer.MsSource(this));
+ } else {
+ var mouseSource = new ol.pointer.MouseSource(this);
+ this.registerSource('mouse', mouseSource);
+ if (ol.has.TOUCH) {
+ this.registerSource('touch',
+ new ol.pointer.TouchSource(this, mouseSource));
+ // register events on the viewport element
+ this.register_();
+ * Add a new event source that will generate pointer events.
+ * @param {string} name A name for the event source
+ * @param {ol.pointer.EventSource} source The source event.
+ol.pointer.PointerEventHandler.prototype.registerSource = function(name, source) {
+ var s = source;
+ var newEvents = s.getEvents();
+ if (newEvents) {
+ newEvents.forEach(function(e) {
+ var handler = s.getHandlerForEvent(e);
+ if (handler) {
+ this.eventMap_[e] = handler.bind(s);
+ }, this);
+ this.eventSourceList_.push(s);
+ * Set up the events for all registered event sources.
+ * @private
+ol.pointer.PointerEventHandler.prototype.register_ = function() {
+ var l = this.eventSourceList_.length;
+ var eventSource;
+ eventSource = this.eventSourceList_[i];
+ this.addEvents_(eventSource.getEvents());
+ * Remove all registered events.
+ * @private
+ol.pointer.PointerEventHandler.prototype.unregister_ = function() {
+ var eventSource;
+ this.removeEvents_(eventSource.getEvents());
+ * Calls the right handler for a new event.
+ * @private
+ * @param {Event} inEvent Browser event.
+ol.pointer.PointerEventHandler.prototype.eventHandler_ = function(inEvent) {
+ var type = inEvent.type;
+ var handler = this.eventMap_[type];
+ if (handler) {
+ handler(inEvent);
+ * Setup listeners for the given events.
+ * @private
+ * @param {Array.<string>} events List of events.
+ol.pointer.PointerEventHandler.prototype.addEvents_ = function(events) {
+ events.forEach(function(eventName) {
+ ol.events.listen(this.element_, eventName, this.eventHandler_, this);
+ }, this);
+ * Unregister listeners for the given events.
+ * @private
+ol.pointer.PointerEventHandler.prototype.removeEvents_ = function(events) {
+ events.forEach(function(e) {
+ ol.events.unlisten(this.element_, e, this.eventHandler_, this);
+ }, this);
+ * Returns a snapshot of inEvent, with writable properties.
+ * @param {Event|Touch} inEvent An event that contains
+ * properties to copy.
+ * @return {Object} An object containing shallow copies of
+ * `inEvent`'s properties.
+ol.pointer.PointerEventHandler.prototype.cloneEvent = function(event, inEvent) {
+ var eventCopy = {}, p;
+ for (var i = 0, ii = ol.pointer.PointerEventHandler.CLONE_PROPS.length; i < ii; i++) {
+ p = ol.pointer.PointerEventHandler.CLONE_PROPS[i][0];
+ eventCopy[p] = event[p] || inEvent[p] || ol.pointer.PointerEventHandler.CLONE_PROPS[i][1];
+ return eventCopy;
+// EVENTS
+ * Triggers a 'pointerdown' event.
+ * @param {Object} data Pointer event data.
+ * @param {Event} event The event.
+ol.pointer.PointerEventHandler.prototype.down = function(data, event) {
+ this.fireEvent(ol.pointer.EventType.POINTERDOWN, data, event);
+ * Triggers a 'pointermove' event.
+ol.pointer.PointerEventHandler.prototype.move = function(data, event) {
+ this.fireEvent(ol.pointer.EventType.POINTERMOVE, data, event);
+ * Triggers a 'pointerup' event.
+ol.pointer.PointerEventHandler.prototype.up = function(data, event) {
+ this.fireEvent(ol.pointer.EventType.POINTERUP, data, event);
+ * Triggers a 'pointerenter' event.
+ol.pointer.PointerEventHandler.prototype.enter = function(data, event) {
+ data.bubbles = false;
+ this.fireEvent(ol.pointer.EventType.POINTERENTER, data, event);
+ * Triggers a 'pointerleave' event.
+ol.pointer.PointerEventHandler.prototype.leave = function(data, event) {
+ this.fireEvent(ol.pointer.EventType.POINTERLEAVE, data, event);
+ * Triggers a 'pointerover' event.
+ol.pointer.PointerEventHandler.prototype.over = function(data, event) {
+ data.bubbles = true;
+ this.fireEvent(ol.pointer.EventType.POINTEROVER, data, event);
+ * Triggers a 'pointerout' event.
+ol.pointer.PointerEventHandler.prototype.out = function(data, event) {
+ this.fireEvent(ol.pointer.EventType.POINTEROUT, data, event);
+ * Triggers a 'pointercancel' event.
+ol.pointer.PointerEventHandler.prototype.cancel = function(data, event) {
+ this.fireEvent(ol.pointer.EventType.POINTERCANCEL, data, event);
+ * Triggers a combination of 'pointerout' and 'pointerleave' events.
+ol.pointer.PointerEventHandler.prototype.leaveOut = function(data, event) {
+ this.out(data, event);
+ if (!this.contains_(data.target, data.relatedTarget)) {
+ this.leave(data, event);
+ * Triggers a combination of 'pointerover' and 'pointerevents' events.
+ol.pointer.PointerEventHandler.prototype.enterOver = function(data, event) {
+ this.over(data, event);
+ this.enter(data, event);
+ * @private
+ * @param {Element} container The container element.
+ * @param {Element} contained The contained element.
+ * @return {boolean} Returns true if the container element
+ * contains the other element.
+ol.pointer.PointerEventHandler.prototype.contains_ = function(container, contained) {
+ if (!container || !contained) {
+ return false;
+ return container.contains(contained);
+// EVENT CREATION AND TRACKING
+ * Creates a new Event of type `inType`, based on the information in
+ * `data`.
+ * @param {string} inType A string representing the type of event to create.
+ * @return {ol.pointer.PointerEvent} A PointerEvent of type `inType`.
+ol.pointer.PointerEventHandler.prototype.makeEvent = function(inType, data, event) {
+ return new ol.pointer.PointerEvent(inType, event, data);
+ * Make and dispatch an event in one call.
+ * @param {string} inType A string representing the type of event.
+ol.pointer.PointerEventHandler.prototype.fireEvent = function(inType, data, event) {
+ var e = this.makeEvent(inType, data, event);
+ this.dispatchEvent(e);
+ * Creates a pointer event from a native pointer event
+ * and dispatches this event.
+ * @param {Event} event A platform event with a target.
+ol.pointer.PointerEventHandler.prototype.fireNativeEvent = function(event) {
+ var e = this.makeEvent(event.type, event, event);
+ * Wrap a native mouse event into a pointer event.
+ * This proxy method is required for the legacy IE support.
+ * @param {string} eventType The pointer event type.
+ * @return {ol.pointer.PointerEvent} The wrapped event.
+ol.pointer.PointerEventHandler.prototype.wrapMouseEvent = function(eventType, event) {
+ var pointerEvent = this.makeEvent(
+ eventType, ol.pointer.MouseSource.prepareEvent(event, this), event);
+ return pointerEvent;
+ * @inheritDoc
+ol.pointer.PointerEventHandler.prototype.disposeInternal = function() {
+ this.unregister_();
+ ol.events.EventTarget.prototype.disposeInternal.call(this);
+ * Properties to copy when cloning an event, with default values.
+ * @type {Array.<Array>}
+ol.pointer.PointerEventHandler.CLONE_PROPS = [
+ // MouseEvent
+ ['bubbles', false],
+ ['cancelable', false],
+ ['view', null],
+ ['detail', null],
+ ['screenX', 0],
+ ['screenY', 0],
+ ['clientX', 0],
+ ['clientY', 0],
+ ['ctrlKey', false],
+ ['altKey', false],
+ ['shiftKey', false],
+ ['metaKey', false],
+ ['button', 0],
+ ['relatedTarget', null],
+ // DOM Level 3
+ ['buttons', 0],
+ // PointerEvent
+ ['pointerId', 0],
+ ['width', 0],
+ ['height', 0],
+ ['pressure', 0],
+ ['tiltX', 0],
+ ['tiltY', 0],
+ ['pointerType', ''],
+ ['hwTimestamp', 0],
+ ['isPrimary', false],
+ // event instance
+ ['type', ''],
+ ['target', null],
+ ['currentTarget', null],
+ ['which', 0]
+goog.provide('ol.MapBrowserEventHandler');
+goog.require('ol');
+goog.require('ol.MapBrowserEventType');
+goog.require('ol.MapBrowserPointerEvent');
+goog.require('ol.pointer.PointerEventHandler');
+ * @param {ol.Map} map The map with the viewport to listen to events on.
+ * @constructor
+ol.MapBrowserEventHandler = function(map) {
+ * This is the element that we will listen to the real events on.
+ * @type {ol.Map}
+ * @private
+ this.map_ = map;
+ * @type {number}
+ * @private
+ this.clickTimeoutId_ = 0;
+ * @type {boolean}
+ * @private
+ this.dragging_ = false;
+ * @type {!Array.<ol.EventsKey>}
+ * @private
+ this.dragListenerKeys_ = [];
+ * The most recent "down" type event (or null if none have occurred).
+ * Set on pointerdown.
+ * @private
+ this.down_ = null;
+ var element = this.map_.getViewport();
+ * @type {number}
+ * @private
+ this.activePointers_ = 0;
+ * @type {!Object.<number, boolean>}
+ * @private
+ this.trackedTouches_ = {};
+ * Event handler which generates pointer events for
+ * the viewport element.
+ * @private
+ this.pointerEventHandler_ = new ol.pointer.PointerEventHandler(element);
+ * the document (used when dragging).
+ * @private
+ this.documentPointerEventHandler_ = null;
+ * @type {?ol.EventsKey}
+ * @private
+ this.pointerdownListenerKey_ = ol.events.listen(this.pointerEventHandler_,
+ ol.pointer.EventType.POINTERDOWN,
+ this.handlePointerDown_, this);
+ * @private
+ this.relayedListenerKey_ = ol.events.listen(this.pointerEventHandler_,
+ ol.pointer.EventType.POINTERMOVE,
+ this.relayEvent_, this);
+ol.inherits(ol.MapBrowserEventHandler, ol.events.EventTarget);
+ * @private
+ol.MapBrowserEventHandler.prototype.emulateClick_ = function(pointerEvent) {
+ var newEvent = new ol.MapBrowserPointerEvent(
+ ol.MapBrowserEventType.CLICK, this.map_, pointerEvent);
+ this.dispatchEvent(newEvent);
+ if (this.clickTimeoutId_ !== 0) {
+ // double-click
+ clearTimeout(this.clickTimeoutId_);
+ newEvent = new ol.MapBrowserPointerEvent(
+ ol.MapBrowserEventType.DBLCLICK, this.map_, pointerEvent);
+ } else {
+ // click
+ this.clickTimeoutId_ = setTimeout(function() {
+ ol.MapBrowserEventType.SINGLECLICK, this.map_, pointerEvent);
+ }.bind(this), 250);
+ * Keeps track on how many pointers are currently active.
+ * @private
+ol.MapBrowserEventHandler.prototype.updateActivePointers_ = function(pointerEvent) {
+ var event = pointerEvent;
+ if (event.type == ol.MapBrowserEventType.POINTERUP ||
+ event.type == ol.MapBrowserEventType.POINTERCANCEL) {
+ delete this.trackedTouches_[event.pointerId];
+ } else if (event.type == ol.MapBrowserEventType.POINTERDOWN) {
+ this.trackedTouches_[event.pointerId] = true;
+ this.activePointers_ = Object.keys(this.trackedTouches_).length;
+ * @private
+ol.MapBrowserEventHandler.prototype.handlePointerUp_ = function(pointerEvent) {
+ this.updateActivePointers_(pointerEvent);
+ ol.MapBrowserEventType.POINTERUP, this.map_, pointerEvent);
+ // We emulate click events on left mouse button click, touch contact, and pen
+ // contact. isMouseActionButton returns true in these cases (evt.button is set
+ // to 0).
+ // See http://www.w3.org/TR/pointerevents/#button-states
+ if (!this.dragging_ && this.isMouseActionButton_(pointerEvent)) {
+ this.emulateClick_(this.down_);
+ if (this.activePointers_ === 0) {
+ this.dragListenerKeys_.forEach(ol.events.unlistenByKey);
+ this.dragListenerKeys_.length = 0;
+ this.documentPointerEventHandler_.dispose();
+ * @return {boolean} If the left mouse button was pressed.
+ * @private
+ol.MapBrowserEventHandler.prototype.isMouseActionButton_ = function(pointerEvent) {
+ return pointerEvent.button === 0;
+ * @private
+ol.MapBrowserEventHandler.prototype.handlePointerDown_ = function(pointerEvent) {
+ ol.MapBrowserEventType.POINTERDOWN, this.map_, pointerEvent);
+ this.down_ = pointerEvent;
+ if (this.dragListenerKeys_.length === 0) {
+ /* Set up a pointer event handler on the `document`,
+ * which is required when the pointer is moved outside
+ * the viewport when dragging.
+ new ol.pointer.PointerEventHandler(document);
+ this.dragListenerKeys_.push(
+ ol.events.listen(this.documentPointerEventHandler_,
+ ol.MapBrowserEventType.POINTERMOVE,
+ this.handlePointerMove_, this),
+ this.handlePointerUp_, this),
+ /* Note that the listener for `pointercancel is set up on
+ * `pointerEventHandler_` and not `documentPointerEventHandler_` like
+ * the `pointerup` and `pointermove` listeners.
+ * The reason for this is the following: `TouchSource.vacuumTouches_()`
+ * issues `pointercancel` events, when there was no `touchend` for a
+ * `touchstart`. Now, let's say a first `touchstart` is registered on
+ * `pointerEventHandler_`. The `documentPointerEventHandler_` is set up.
+ * But `documentPointerEventHandler_` doesn't know about the first
+ * `touchstart`. If there is no `touchend` for the `touchstart`, we can
+ * only receive a `touchcancel` from `pointerEventHandler_`, because it is
+ * only registered there.
+ ol.events.listen(this.pointerEventHandler_,
+ ol.MapBrowserEventType.POINTERCANCEL,
+ * @private
+ol.MapBrowserEventHandler.prototype.handlePointerMove_ = function(pointerEvent) {
+ // Fix IE10 on windows Surface : When you tap the tablet, it triggers
+ // multiple pointermove events between pointerdown and pointerup with
+ // the exact same coordinates of the pointerdown event. To avoid a
+ // 'false' touchmove event to be dispatched , we test if the pointer
+ // effectively moved.
+ if (this.isMoving_(pointerEvent)) {
+ this.dragging_ = true;
+ ol.MapBrowserEventType.POINTERDRAG, this.map_, pointerEvent,
+ this.dragging_);
+ // Some native android browser triggers mousemove events during small period
+ // of time. See: https://code.google.com/p/android/issues/detail?id=5491 or
+ // https://code.google.com/p/android/issues/detail?id=19827
+ // ex: Galaxy Tab P3110 + Android 4.1.1
+ pointerEvent.preventDefault();
+ * Wrap and relay a pointer event. Note that this requires that the type
+ * string for the MapBrowserPointerEvent matches the PointerEvent type.
+ * @private
+ol.MapBrowserEventHandler.prototype.relayEvent_ = function(pointerEvent) {
+ var dragging = !!(this.down_ && this.isMoving_(pointerEvent));
+ this.dispatchEvent(new ol.MapBrowserPointerEvent(
+ pointerEvent.type, this.map_, pointerEvent, dragging));
+ * @return {boolean} Is moving.
+ * @private
+ol.MapBrowserEventHandler.prototype.isMoving_ = function(pointerEvent) {
+ return pointerEvent.clientX != this.down_.clientX ||
+ pointerEvent.clientY != this.down_.clientY;
+ * @inheritDoc
+ol.MapBrowserEventHandler.prototype.disposeInternal = function() {
+ if (this.relayedListenerKey_) {
+ ol.events.unlistenByKey(this.relayedListenerKey_);
+ this.relayedListenerKey_ = null;
+ if (this.pointerdownListenerKey_) {
+ ol.events.unlistenByKey(this.pointerdownListenerKey_);
+ this.pointerdownListenerKey_ = null;
+ if (this.documentPointerEventHandler_) {
+ if (this.pointerEventHandler_) {
+ this.pointerEventHandler_.dispose();
+ this.pointerEventHandler_ = null;
+goog.provide('ol.MapProperty');
+ * @enum {string}
+ol.MapProperty = {
+ LAYERGROUP: 'layergroup',
+ SIZE: 'size',
+ TARGET: 'target',
+ VIEW: 'view'
+goog.provide('ol.TileState');
+ * @enum {number}
+ol.TileState = {
+ IDLE: 0,
+ LOADING: 1,
+ LOADED: 2,
+ ERROR: 3,
+ EMPTY: 4,
+ ABORT: 5
+goog.provide('ol.structs.PriorityQueue');
+goog.require('ol.asserts');
+goog.require('ol.obj');
+ * Priority queue.
+ * The implementation is inspired from the Closure Library's Heap class and
+ * Python's heapq module.
+ * @see http://closure-library.googlecode.com/svn/docs/closure_goog_structs_heap.js.source.html
+ * @see http://hg.python.org/cpython/file/2.7/Lib/heapq.py
+ * @constructor
+ * @param {function(T): number} priorityFunction Priority function.
+ * @param {function(T): string} keyFunction Key function.
+ * @struct
+ * @template T
+ol.structs.PriorityQueue = function(priorityFunction, keyFunction) {
+ * @type {function(T): number}
+ * @private
+ this.priorityFunction_ = priorityFunction;
+ * @type {function(T): string}
+ * @private
+ this.keyFunction_ = keyFunction;
+ * @type {Array.<T>}
+ * @private
+ this.elements_ = [];
+ * @type {Array.<number>}
+ * @private
+ this.priorities_ = [];
+ * @type {Object.<string, boolean>}
+ * @private
+ this.queuedElements_ = {};
+ * @const
+ * @type {number}
+ol.structs.PriorityQueue.DROP = Infinity;
+ * FIXME empty description for jsdoc
+ol.structs.PriorityQueue.prototype.clear = function() {
+ this.elements_.length = 0;
+ this.priorities_.length = 0;
+ ol.obj.clear(this.queuedElements_);
+ * Remove and return the highest-priority element. O(log N).
+ * @return {T} Element.
+ol.structs.PriorityQueue.prototype.dequeue = function() {
+ var elements = this.elements_;
+ var priorities = this.priorities_;
+ var element = elements[0];
+ if (elements.length == 1) {
+ elements.length = 0;
+ priorities.length = 0;
+ } else {
+ elements[0] = elements.pop();
+ priorities[0] = priorities.pop();
+ this.siftUp_(0);
+ var elementKey = this.keyFunction_(element);
+ delete this.queuedElements_[elementKey];
+ return element;
+ * Enqueue an element. O(log N).
+ * @param {T} element Element.
+ * @return {boolean} The element was added to the queue.
+ol.structs.PriorityQueue.prototype.enqueue = function(element) {
+ ol.asserts.assert(!(this.keyFunction_(element) in this.queuedElements_),
+ 31); // Tried to enqueue an `element` that was already added to the queue
+ var priority = this.priorityFunction_(element);
+ if (priority != ol.structs.PriorityQueue.DROP) {
+ this.elements_.push(element);
+ this.priorities_.push(priority);
+ this.queuedElements_[this.keyFunction_(element)] = true;
+ this.siftDown_(0, this.elements_.length - 1);
+ return true;
+ return false;
+ * @return {number} Count.
+ol.structs.PriorityQueue.prototype.getCount = function() {
+ return this.elements_.length;
+ * Gets the index of the left child of the node at the given index.
+ * @param {number} index The index of the node to get the left child for.
+ * @return {number} The index of the left child.
+ * @private
+ol.structs.PriorityQueue.prototype.getLeftChildIndex_ = function(index) {
+ return index * 2 + 1;
+ * Gets the index of the right child of the node at the given index.
+ * @param {number} index The index of the node to get the right child for.
+ * @return {number} The index of the right child.
+ * @private
+ol.structs.PriorityQueue.prototype.getRightChildIndex_ = function(index) {
+ return index * 2 + 2;
+ * Gets the index of the parent of the node at the given index.
+ * @param {number} index The index of the node to get the parent for.
+ * @return {number} The index of the parent.
+ * @private
+ol.structs.PriorityQueue.prototype.getParentIndex_ = function(index) {
+ return (index - 1) >> 1;
+ * Make this a heap. O(N).
+ * @private
+ol.structs.PriorityQueue.prototype.heapify_ = function() {
+ var i;
+ for (i = (this.elements_.length >> 1) - 1; i >= 0; i--) {
+ this.siftUp_(i);
+ * @return {boolean} Is empty.
+ol.structs.PriorityQueue.prototype.isEmpty = function() {
+ return this.elements_.length === 0;
+ * @param {string} key Key.
+ * @return {boolean} Is key queued.
+ol.structs.PriorityQueue.prototype.isKeyQueued = function(key) {
+ return key in this.queuedElements_;
+ * @return {boolean} Is queued.
+ol.structs.PriorityQueue.prototype.isQueued = function(element) {
+ return this.isKeyQueued(this.keyFunction_(element));
+ * @param {number} index The index of the node to move down.
+ * @private
+ol.structs.PriorityQueue.prototype.siftUp_ = function(index) {
+ var count = elements.length;
+ var element = elements[index];
+ var priority = priorities[index];
+ var startIndex = index;
+ while (index < (count >> 1)) {
+ var lIndex = this.getLeftChildIndex_(index);
+ var rIndex = this.getRightChildIndex_(index);
+ var smallerChildIndex = rIndex < count &&
+ priorities[rIndex] < priorities[lIndex] ?
+ rIndex : lIndex;
+ elements[index] = elements[smallerChildIndex];
+ priorities[index] = priorities[smallerChildIndex];
+ index = smallerChildIndex;
+ elements[index] = element;
+ priorities[index] = priority;
+ this.siftDown_(startIndex, index);
+ * @param {number} startIndex The index of the root.
+ * @param {number} index The index of the node to move up.
+ * @private
+ol.structs.PriorityQueue.prototype.siftDown_ = function(startIndex, index) {
+ while (index > startIndex) {
+ var parentIndex = this.getParentIndex_(index);
+ if (priorities[parentIndex] > priority) {
+ elements[index] = elements[parentIndex];
+ priorities[index] = priorities[parentIndex];
+ index = parentIndex;
+ } else {
+ break;
+ol.structs.PriorityQueue.prototype.reprioritize = function() {
+ var priorityFunction = this.priorityFunction_;
+ var index = 0;
+ var n = elements.length;
+ var element, i, priority;
+ for (i = 0; i < n; ++i) {
+ element = elements[i];
+ priority = priorityFunction(element);
+ if (priority == ol.structs.PriorityQueue.DROP) {
+ delete this.queuedElements_[this.keyFunction_(element)];
+ } else {
+ elements[index++] = element;
+ elements.length = index;
+ priorities.length = index;
+ this.heapify_();
+goog.provide('ol.TileQueue');
+goog.require('ol.TileState');
+goog.require('ol.events.EventType');
+goog.require('ol.structs.PriorityQueue');
+ * @constructor
+ * @extends {ol.structs.PriorityQueue.<Array>}
+ * @param {ol.TilePriorityFunction} tilePriorityFunction
+ * Tile priority function.
+ * @param {function(): ?} tileChangeCallback
+ * Function called on each tile change event.
+ * @struct
+ol.TileQueue = function(tilePriorityFunction, tileChangeCallback) {
+ ol.structs.PriorityQueue.call(
+ this,
+ * @param {Array} element Element.
+ * @return {number} Priority.
+ function(element) {
+ return tilePriorityFunction.apply(null, element);
+ * @return {string} Key.
+ return /** @type {ol.Tile} */ (element[0]).getKey();
+ * @private
+ * @type {function(): ?}
+ this.tileChangeCallback_ = tileChangeCallback;
+ * @private
+ * @type {number}
+ this.tilesLoading_ = 0;
+ * @private
+ * @type {!Object.<string,boolean>}
+ this.tilesLoadingKeys_ = {};
+ol.inherits(ol.TileQueue, ol.structs.PriorityQueue);
+ * @inheritDoc
+ol.TileQueue.prototype.enqueue = function(element) {
+ var added = ol.structs.PriorityQueue.prototype.enqueue.call(this, element);
+ if (added) {
+ var tile = element[0];
+ ol.events.listen(tile, ol.events.EventType.CHANGE,
+ this.handleTileChange, this);
+ return added;
+ * @return {number} Number of tiles loading.
+ol.TileQueue.prototype.getTilesLoading = function() {
+ return this.tilesLoading_;
+ * @param {ol.events.Event} event Event.
+ * @protected
+ol.TileQueue.prototype.handleTileChange = function(event) {
+ var tile = /** @type {ol.Tile} */ (event.target);
+ var state = tile.getState();
+ if (state === ol.TileState.LOADED || state === ol.TileState.ERROR ||
+ state === ol.TileState.EMPTY || state === ol.TileState.ABORT) {
+ ol.events.unlisten(tile, ol.events.EventType.CHANGE,
+ var tileKey = tile.getKey();
+ if (tileKey in this.tilesLoadingKeys_) {
+ delete this.tilesLoadingKeys_[tileKey];
+ --this.tilesLoading_;
+ this.tileChangeCallback_();
+ * @param {number} maxTotalLoading Maximum number tiles to load simultaneously.
+ * @param {number} maxNewLoads Maximum number of new tiles to load.
+ol.TileQueue.prototype.loadMoreTiles = function(maxTotalLoading, maxNewLoads) {
+ var newLoads = 0;
+ var tile, tileKey;
+ while (this.tilesLoading_ < maxTotalLoading && newLoads < maxNewLoads &&
+ this.getCount() > 0) {
+ tile = /** @type {ol.Tile} */ (this.dequeue()[0]);
+ tileKey = tile.getKey();
+ if (tile.getState() === ol.TileState.IDLE && !(tileKey in this.tilesLoadingKeys_)) {
+ this.tilesLoadingKeys_[tileKey] = true;
+ ++this.tilesLoading_;
+ ++newLoads;
+ tile.load();
+goog.provide('ol.ResolutionConstraint');
+goog.require('ol.math');
+ * @param {Array.<number>} resolutions Resolutions.
+ * @return {ol.ResolutionConstraintType} Zoom function.
+ol.ResolutionConstraint.createSnapToResolutions = function(resolutions) {
+ return (
+ * @param {number|undefined} resolution Resolution.
+ * @param {number} delta Delta.
+ * @param {number} direction Direction.
+ * @return {number|undefined} Resolution.
+ function(resolution, delta, direction) {
+ if (resolution !== undefined) {
+ var z =
+ ol.array.linearFindNearest(resolutions, resolution, direction);
+ z = ol.math.clamp(z + delta, 0, resolutions.length - 1);
+ var index = Math.floor(z);
+ if (z != index && index < resolutions.length - 1) {
+ var power = resolutions[index] / resolutions[index + 1];
+ return resolutions[index] / Math.pow(power, z - index);
+ } else {
+ return resolutions[index];
+ } else {
+ return undefined;
+ * @param {number} power Power.
+ * @param {number} maxResolution Maximum resolution.
+ * @param {number=} opt_maxLevel Maximum level.
+ol.ResolutionConstraint.createSnapToPower = function(power, maxResolution, opt_maxLevel) {
+ return (
+ var offset = -direction / 2 + 0.5;
+ var oldLevel = Math.floor(
+ Math.log(maxResolution / resolution) / Math.log(power) + offset);
+ var newLevel = Math.max(oldLevel + delta, 0);
+ if (opt_maxLevel !== undefined) {
+ newLevel = Math.min(newLevel, opt_maxLevel);
+ return maxResolution / Math.pow(power, newLevel);
+ } else {
+ return undefined;
+goog.provide('ol.RotationConstraint');
+ * @param {number|undefined} rotation Rotation.
+ * @return {number|undefined} Rotation.
+ol.RotationConstraint.disable = function(rotation, delta) {
+ if (rotation !== undefined) {
+ return 0;
+ } else {
+ return undefined;
+ol.RotationConstraint.none = function(rotation, delta) {
+ return rotation + delta;
+ } else {
+ return undefined;
+ * @param {number} n N.
+ * @return {ol.RotationConstraintType} Rotation constraint.
+ol.RotationConstraint.createSnapToN = function(n) {
+ var theta = 2 * Math.PI / n;
+ return (
+ function(rotation, delta) {
+ rotation = Math.floor((rotation + delta) / theta + 0.5) * theta;
+ return rotation;
+ } else {
+ return undefined;
+ * @param {number=} opt_tolerance Tolerance.
+ol.RotationConstraint.createSnapToZero = function(opt_tolerance) {
+ var tolerance = opt_tolerance || ol.math.toRadians(5);
+ return (
+ if (Math.abs(rotation + delta) <= tolerance) {
+ return 0;
+ } else {
+ } else {
+ return undefined;
+goog.provide('ol.ViewHint');
+ * @enum {number}
+ol.ViewHint = {
+ ANIMATING: 0,
+ INTERACTING: 1
+goog.provide('ol.ViewProperty');
+ * @enum {string}
+ol.ViewProperty = {
+ CENTER: 'center',
+ RESOLUTION: 'resolution',
+ ROTATION: 'rotation'
+goog.provide('ol.string');
+ * @param {number} number Number to be formatted
+ * @param {number} width The desired width
+ * @param {number=} opt_precision Precision of the output string (i.e. number of decimal places)
+ * @returns {string} Formatted string
+ol.string.padNumber = function(number, width, opt_precision) {
+ var numberString = opt_precision !== undefined ? number.toFixed(opt_precision) : '' + number;
+ var decimal = numberString.indexOf('.');
+ decimal = decimal === -1 ? numberString.length : decimal;
+ return decimal > width ? numberString : new Array(1 + width - decimal).join('0') + numberString;
+ * Adapted from https://github.com/omichelsen/compare-versions/blob/master/index.js
+ * @param {string|number} v1 First version
+ * @param {string|number} v2 Second version
+ * @returns {number} Value
+ol.string.compareVersions = function(v1, v2) {
+ var s1 = ('' + v1).split('.');
+ var s2 = ('' + v2).split('.');
+ for (var i = 0; i < Math.max(s1.length, s2.length); i++) {
+ var n1 = parseInt(s1[i] || '0', 10);
+ var n2 = parseInt(s2[i] || '0', 10);
+ if (n1 > n2) {
+ return 1;
+ if (n2 > n1) {
+ return -1;
+ return 0;
+goog.provide('ol.coordinate');
+goog.require('ol.string');
+ * Add `delta` to `coordinate`. `coordinate` is modified in place and returned
+ * by the function.
+ * Example:
+ * var coord = [7.85, 47.983333];
+ * ol.coordinate.add(coord, [-2, 4]);
+ * // coord is now [5.85, 51.983333]
+ * @param {ol.Coordinate} coordinate Coordinate.
+ * @param {ol.Coordinate} delta Delta.
+ * @return {ol.Coordinate} The input coordinate adjusted by the given delta.
+ * @api
+ol.coordinate.add = function(coordinate, delta) {
+ coordinate[0] += delta[0];
+ coordinate[1] += delta[1];
+ return coordinate;
+ * Calculates the point closest to the passed coordinate on the passed segment.
+ * This is the foot of the perpendicular of the coordinate to the segment when
+ * the foot is on the segment, or the closest segment coordinate when the foot
+ * is outside the segment.
+ * @param {ol.Coordinate} coordinate The coordinate.
+ * @param {Array.<ol.Coordinate>} segment The two coordinates of the segment.
+ * @return {ol.Coordinate} The foot of the perpendicular of the coordinate to
+ * the segment.
+ol.coordinate.closestOnSegment = function(coordinate, segment) {
+ var x0 = coordinate[0];
+ var y0 = coordinate[1];
+ var start = segment[0];
+ var end = segment[1];
+ var x1 = start[0];
+ var y1 = start[1];
+ var x2 = end[0];
+ var y2 = end[1];
+ var dx = x2 - x1;
+ var dy = y2 - y1;
+ var along = (dx === 0 && dy === 0) ? 0 :
+ ((dx * (x0 - x1)) + (dy * (y0 - y1))) / ((dx * dx + dy * dy) || 0);
+ var x, y;
+ if (along <= 0) {
+ x = x1;
+ y = y1;
+ } else if (along >= 1) {
+ x = x2;
+ y = y2;
+ } else {
+ x = x1 + along * dx;
+ y = y1 + along * dy;
+ return [x, y];
+ * Returns a {@link ol.CoordinateFormatType} function that can be used to format
+ * a {ol.Coordinate} to a string.
+ * Example without specifying the fractional digits:
+ * var stringifyFunc = ol.coordinate.createStringXY();
+ * var out = stringifyFunc(coord);
+ * // out is now '8, 48'
+ * Example with explicitly specifying 2 fractional digits:
+ * var stringifyFunc = ol.coordinate.createStringXY(2);
+ * // out is now '7.85, 47.98'
+ * @param {number=} opt_fractionDigits The number of digits to include
+ * after the decimal point. Default is `0`.
+ * @return {ol.CoordinateFormatType} Coordinate format.
+ * @api
+ol.coordinate.createStringXY = function(opt_fractionDigits) {
+ return (
+ * @param {ol.Coordinate|undefined} coordinate Coordinate.
+ * @return {string} String XY.
+ function(coordinate) {
+ return ol.coordinate.toStringXY(coordinate, opt_fractionDigits);
+ * @private
+ * @param {number} degrees Degrees.
+ * @param {string} hemispheres Hemispheres.
+ * @return {string} String.
+ol.coordinate.degreesToStringHDMS_ = function(degrees, hemispheres, opt_fractionDigits) {
+ var normalizedDegrees = ol.math.modulo(degrees + 180, 360) - 180;
+ var x = Math.abs(3600 * normalizedDegrees);
+ var dflPrecision = opt_fractionDigits || 0;
+ var precision = Math.pow(10, dflPrecision);
+ var deg = Math.floor(x / 3600);
+ var min = Math.floor((x - deg * 3600) / 60);
+ var sec = x - (deg * 3600) - (min * 60);
+ sec = Math.ceil(sec * precision) / precision;
+ if (sec >= 60) {
+ sec = 0;
+ min += 1;
+ if (min >= 60) {
+ min = 0;
+ deg += 1;
+ return deg + '\u00b0 ' + ol.string.padNumber(min, 2) + '\u2032 ' +
+ ol.string.padNumber(sec, 2, dflPrecision) + '\u2033 ' +
+ hemispheres.charAt(normalizedDegrees < 0 ? 1 : 0);
+ * Transforms the given {@link ol.Coordinate} to a string using the given string
+ * template. The strings `{x}` and `{y}` in the template will be replaced with
+ * the first and second coordinate values respectively.
+ * var template = 'Coordinate is ({x}|{y}).';
+ * var out = ol.coordinate.format(coord, template);
+ * // out is now 'Coordinate is (8|48).'
+ * Example explicitly specifying the fractional digits:
+ * var out = ol.coordinate.format(coord, template, 2);
+ * // out is now 'Coordinate is (7.85|47.98).'
+ * @param {string} template A template string with `{x}` and `{y}` placeholders
+ * that will be replaced by first and second coordinate values.
+ * @return {string} Formatted coordinate.
+ * @api
+ol.coordinate.format = function(coordinate, template, opt_fractionDigits) {
+ if (coordinate) {
+ return template
+ .replace('{x}', coordinate[0].toFixed(opt_fractionDigits))
+ .replace('{y}', coordinate[1].toFixed(opt_fractionDigits));
+ } else {
+ return '';
+ * @param {ol.Coordinate} coordinate1 First coordinate.
+ * @param {ol.Coordinate} coordinate2 Second coordinate.
+ * @return {boolean} Whether the passed coordinates are equal.
+ol.coordinate.equals = function(coordinate1, coordinate2) {
+ var equals = true;
+ for (var i = coordinate1.length - 1; i >= 0; --i) {
+ if (coordinate1[i] != coordinate2[i]) {
+ equals = false;
+ break;
+ return equals;
+ * Rotate `coordinate` by `angle`. `coordinate` is modified in place and
+ * returned by the function.
+ * Example:
+ * var rotateRadians = Math.PI / 2; // 90 degrees
+ * ol.coordinate.rotate(coord, rotateRadians);
+ * // coord is now [-47.983333, 7.85]
+ * @param {number} angle Angle in radian.
+ * @return {ol.Coordinate} Coordinate.
+ * @api
+ol.coordinate.rotate = function(coordinate, angle) {
+ var cosAngle = Math.cos(angle);
+ var sinAngle = Math.sin(angle);
+ var x = coordinate[0] * cosAngle - coordinate[1] * sinAngle;
+ var y = coordinate[1] * cosAngle + coordinate[0] * sinAngle;
+ coordinate[0] = x;
+ coordinate[1] = y;
+ * Scale `coordinate` by `scale`. `coordinate` is modified in place and returned
+ * Example:
+ * var scale = 1.2;
+ * ol.coordinate.scale(coord, scale);
+ * // coord is now [9.42, 57.5799996]
+ * @param {number} scale Scale factor.
+ol.coordinate.scale = function(coordinate, scale) {
+ coordinate[0] *= scale;
+ coordinate[1] *= scale;
+ * Subtract `delta` to `coordinate`. `coordinate` is modified in place and
+ol.coordinate.sub = function(coordinate, delta) {
+ coordinate[0] -= delta[0];
+ coordinate[1] -= delta[1];
+ * @param {ol.Coordinate} coord1 First coordinate.
+ * @param {ol.Coordinate} coord2 Second coordinate.
+ * @return {number} Squared distance between coord1 and coord2.
+ol.coordinate.squaredDistance = function(coord1, coord2) {
+ var dx = coord1[0] - coord2[0];
+ var dy = coord1[1] - coord2[1];
+ return dx * dx + dy * dy;
+ * @return {number} Distance between coord1 and coord2.
+ol.coordinate.distance = function(coord1, coord2) {
+ return Math.sqrt(ol.coordinate.squaredDistance(coord1, coord2));
+ * Calculate the squared distance from a coordinate to a line segment.
+ * @param {ol.Coordinate} coordinate Coordinate of the point.
+ * @param {Array.<ol.Coordinate>} segment Line segment (2 coordinates).
+ * @return {number} Squared distance from the point to the line segment.
+ol.coordinate.squaredDistanceToSegment = function(coordinate, segment) {
+ return ol.coordinate.squaredDistance(coordinate,
+ ol.coordinate.closestOnSegment(coordinate, segment));
+ * Format a geographic coordinate with the hemisphere, degrees, minutes, and
+ * seconds.
+ * Example without specifying fractional digits:
+ * var out = ol.coordinate.toStringHDMS(coord);
+ * // out is now '47° 58′ 60″ N 7° 50′ 60″ E'
+ * Example explicitly specifying 1 fractional digit:
+ * var out = ol.coordinate.toStringHDMS(coord, 1);
+ * // out is now '47° 58′ 60.0″ N 7° 50′ 60.0″ E'
+ * @return {string} Hemisphere, degrees, minutes and seconds.
+ * @api
+ol.coordinate.toStringHDMS = function(coordinate, opt_fractionDigits) {
+ if (coordinate) {
+ return ol.coordinate.degreesToStringHDMS_(coordinate[1], 'NS', opt_fractionDigits) + ' ' +
+ ol.coordinate.degreesToStringHDMS_(coordinate[0], 'EW', opt_fractionDigits);
+ } else {
+ return '';
+ * Format a coordinate as a comma delimited string.
+ * var out = ol.coordinate.toStringXY(coord);
+ * var out = ol.coordinate.toStringXY(coord, 1);
+ * // out is now '7.8, 48.0'
+ * @return {string} XY.
+ * @api
+ol.coordinate.toStringXY = function(coordinate, opt_fractionDigits) {
+ return ol.coordinate.format(coordinate, '{x}, {y}', opt_fractionDigits);
+goog.provide('ol.geom.GeometryType');
+ * The geometry type. One of `'Point'`, `'LineString'`, `'LinearRing'`,
+ * `'Polygon'`, `'MultiPoint'`, `'MultiLineString'`, `'MultiPolygon'`,
+ * `'GeometryCollection'`, `'Circle'`.
+ * @enum {string}
+ol.geom.GeometryType = {
+ POINT: 'Point',
+ LINE_STRING: 'LineString',
+ LINEAR_RING: 'LinearRing',
+ POLYGON: 'Polygon',
+ MULTI_POINT: 'MultiPoint',
+ MULTI_LINE_STRING: 'MultiLineString',
+ MULTI_POLYGON: 'MultiPolygon',
+ GEOMETRY_COLLECTION: 'GeometryCollection',
+ CIRCLE: 'Circle'
+goog.provide('ol.geom.GeometryLayout');
+ * The coordinate layout for geometries, indicating whether a 3rd or 4th z ('Z')
+ * or measure ('M') coordinate is available. Supported values are `'XY'`,
+ * `'XYZ'`, `'XYM'`, `'XYZM'`.
+ * @enum {string}
+ol.geom.GeometryLayout = {
+ XY: 'XY',
+ XYZ: 'XYZ',
+ XYM: 'XYM',
+ XYZM: 'XYZM'
+goog.provide('ol.functions');
+ * Always returns true.
+ * @returns {boolean} true.
+ol.functions.TRUE = function() {
+ return true;
+ * Always returns false.
+ * @returns {boolean} false.
+ol.functions.FALSE = function() {
+ return false;
+goog.provide('ol.geom.Geometry');
+goog.require('ol.Object');
+goog.require('ol.extent');
+goog.require('ol.functions');
+goog.require('ol.proj');
+ * @classdesc
+ * Abstract base class; normally only used for creating subclasses and not
+ * instantiated in apps.
+ * Base class for vector geometries.
+ * To get notified of changes to the geometry, register a listener for the
+ * generic `change` event on your geometry instance.
+ * @constructor
+ * @abstract
+ * @extends {ol.Object}
+ * @api
+ol.geom.Geometry = function() {
+ ol.Object.call(this);
+ * @private
+ * @type {ol.Extent}
+ this.extent_ = ol.extent.createEmpty();
+ * @private
+ * @type {number}
+ this.extentRevision_ = -1;
+ * @protected
+ * @type {Object.<string, ol.geom.Geometry>}
+ this.simplifiedGeometryCache = {};
+ * @protected
+ * @type {number}
+ this.simplifiedGeometryMaxMinSquaredTolerance = 0;
+ * @protected
+ * @type {number}
+ this.simplifiedGeometryRevision = 0;
+ol.inherits(ol.geom.Geometry, ol.Object);
+ * Make a complete copy of the geometry.
+ * @abstract
+ * @return {!ol.geom.Geometry} Clone.
+ol.geom.Geometry.prototype.clone = function() {};
+ * @abstract
+ * @param {number} x X.
+ * @param {number} y Y.
+ * @param {ol.Coordinate} closestPoint Closest point.
+ * @param {number} minSquaredDistance Minimum squared distance.
+ * @return {number} Minimum squared distance.
+ol.geom.Geometry.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {};
+ * Return the closest point of the geometry to the passed point as
+ * {@link ol.Coordinate coordinate}.
+ * @param {ol.Coordinate} point Point.
+ * @param {ol.Coordinate=} opt_closestPoint Closest point.
+ * @return {ol.Coordinate} Closest point.
+ * @api
+ol.geom.Geometry.prototype.getClosestPoint = function(point, opt_closestPoint) {
+ var closestPoint = opt_closestPoint ? opt_closestPoint : [NaN, NaN];
+ this.closestPointXY(point[0], point[1], closestPoint, Infinity);
+ return closestPoint;
+ * Returns true if this geometry includes the specified coordinate. If the
+ * coordinate is on the boundary of the geometry, returns false.
+ * @return {boolean} Contains coordinate.
+ * @api
+ol.geom.Geometry.prototype.intersectsCoordinate = function(coordinate) {
+ return this.containsXY(coordinate[0], coordinate[1]);
+ * @abstract
+ * @param {ol.Extent} extent Extent.
+ * @protected
+ * @return {ol.Extent} extent Extent.
+ol.geom.Geometry.prototype.computeExtent = function(extent) {};
+ * @return {boolean} Contains (x, y).
+ol.geom.Geometry.prototype.containsXY = ol.functions.FALSE;
+ * Get the extent of the geometry.
+ * @param {ol.Extent=} opt_extent Extent.
+ * @api
+ol.geom.Geometry.prototype.getExtent = function(opt_extent) {
+ if (this.extentRevision_ != this.getRevision()) {
+ this.extent_ = this.computeExtent(this.extent_);
+ this.extentRevision_ = this.getRevision();
+ return ol.extent.returnOrUpdate(this.extent_, opt_extent);
+ * Rotate the geometry around a given coordinate. This modifies the geometry
+ * coordinates in place.
+ * @abstract
+ * @param {number} angle Rotation angle in radians.
+ * @param {ol.Coordinate} anchor The rotation center.
+ * @api
+ol.geom.Geometry.prototype.rotate = function(angle, anchor) {};
+ * Scale the geometry (with an optional origin). This modifies the geometry
+ * @abstract
+ * @param {number} sx The scaling factor in the x-direction.
+ * @param {number=} opt_sy The scaling factor in the y-direction (defaults to
+ * sx).
+ * @param {ol.Coordinate=} opt_anchor The scale origin (defaults to the center
+ * of the geometry extent).
+ * @api
+ol.geom.Geometry.prototype.scale = function(sx, opt_sy, opt_anchor) {};
+ * Create a simplified version of this geometry. For linestrings, this uses
+ * the the {@link
+ * https://en.wikipedia.org/wiki/Ramer-Douglas-Peucker_algorithm
+ * Douglas Peucker} algorithm. For polygons, a quantization-based
+ * simplification is used to preserve topology.
+ * @function
+ * @param {number} tolerance The tolerance distance for simplification.
+ * @return {ol.geom.Geometry} A new, simplified version of the original
+ * geometry.
+ * @api
+ol.geom.Geometry.prototype.simplify = function(tolerance) {
+ return this.getSimplifiedGeometry(tolerance * tolerance);
+ * Create a simplified version of this geometry using the Douglas Peucker
+ * algorithm.
+ * @see https://en.wikipedia.org/wiki/Ramer-Douglas-Peucker_algorithm
+ * @abstract
+ * @param {number} squaredTolerance Squared tolerance.
+ * @return {ol.geom.Geometry} Simplified geometry.
+ol.geom.Geometry.prototype.getSimplifiedGeometry = function(squaredTolerance) {};
+ * Get the type of this geometry.
+ * @abstract
+ * @return {ol.geom.GeometryType} Geometry type.
+ol.geom.Geometry.prototype.getType = function() {};
+ * Apply a transform function to each coordinate of the geometry.
+ * The geometry is modified in place.
+ * If you do not want the geometry modified in place, first `clone()` it and
+ * then use this function on the clone.
+ * @abstract
+ * @param {ol.TransformFunction} transformFn Transform.
+ol.geom.Geometry.prototype.applyTransform = function(transformFn) {};
+ * Test if the geometry and the passed extent intersect.
+ * @abstract
+ * @return {boolean} `true` if the geometry and the extent intersect.
+ol.geom.Geometry.prototype.intersectsExtent = function(extent) {};
+ * Translate the geometry. This modifies the geometry coordinates in place. If
+ * instead you want a new geometry, first `clone()` this geometry.
+ * @abstract
+ * @param {number} deltaX Delta X.
+ * @param {number} deltaY Delta Y.
+ol.geom.Geometry.prototype.translate = function(deltaX, deltaY) {};
+ * Transform each coordinate of the geometry from one coordinate reference
+ * system to another. The geometry is modified in place.
+ * For example, a line will be transformed to a line and a circle to a circle.
+ * @param {ol.ProjectionLike} source The current projection. Can be a
+ * string identifier or a {@link ol.proj.Projection} object.
+ * @param {ol.ProjectionLike} destination The desired projection. Can be a
+ * @return {ol.geom.Geometry} This geometry. Note that original geometry is
+ * modified in place.
+ * @api
+ol.geom.Geometry.prototype.transform = function(source, destination) {
+ this.applyTransform(ol.proj.getTransform(source, destination));
+ return this;
+goog.provide('ol.geom.flat.transform');
+ * @param {Array.<number>} flatCoordinates Flat coordinates.
+ * @param {number} offset Offset.
+ * @param {number} end End.
+ * @param {number} stride Stride.
+ * @param {ol.Transform} transform Transform.
+ * @param {Array.<number>=} opt_dest Destination.
+ * @return {Array.<number>} Transformed coordinates.
+ol.geom.flat.transform.transform2D = function(flatCoordinates, offset, end, stride, transform, opt_dest) {
+ var dest = opt_dest ? opt_dest : [];
+ var i = 0;
+ var j;
+ for (j = offset; j < end; j += stride) {
+ var x = flatCoordinates[j];
+ var y = flatCoordinates[j + 1];
+ dest[i++] = transform[0] * x + transform[2] * y + transform[4];
+ dest[i++] = transform[1] * x + transform[3] * y + transform[5];
+ if (opt_dest && dest.length != i) {
+ dest.length = i;
+ return dest;
+ * @param {number} angle Angle.
+ * @param {Array.<number>} anchor Rotation anchor point.
+ol.geom.flat.transform.rotate = function(flatCoordinates, offset, end, stride, angle, anchor, opt_dest) {
+ var cos = Math.cos(angle);
+ var sin = Math.sin(angle);
+ var anchorX = anchor[0];
+ var anchorY = anchor[1];
+ var i = 0;
+ for (var j = offset; j < end; j += stride) {
+ var deltaX = flatCoordinates[j] - anchorX;
+ var deltaY = flatCoordinates[j + 1] - anchorY;
+ dest[i++] = anchorX + deltaX * cos - deltaY * sin;
+ dest[i++] = anchorY + deltaX * sin + deltaY * cos;
+ for (var k = j + 2; k < j + stride; ++k) {
+ dest[i++] = flatCoordinates[k];
+ dest.length = i;
+ return dest;
+ * Scale the coordinates.
+ * @param {number} sx Scale factor in the x-direction.
+ * @param {number} sy Scale factor in the y-direction.
+ * @param {Array.<number>} anchor Scale anchor point.
+ol.geom.flat.transform.scale = function(flatCoordinates, offset, end, stride, sx, sy, anchor, opt_dest) {
+ var i = 0;
+ dest[i++] = anchorX + sx * deltaX;
+ dest[i++] = anchorY + sy * deltaY;
+ dest.length = i;
+ return dest;
+ol.geom.flat.transform.translate = function(flatCoordinates, offset, end, stride, deltaX, deltaY, opt_dest) {
+ var i = 0;
+ var j, k;
+ dest[i++] = flatCoordinates[j] + deltaX;
+ dest[i++] = flatCoordinates[j + 1] + deltaY;
+ for (k = j + 2; k < j + stride; ++k) {
+ dest.length = i;
+ return dest;
+goog.provide('ol.geom.SimpleGeometry');
+goog.require('ol.geom.Geometry');
+goog.require('ol.geom.GeometryLayout');
+goog.require('ol.geom.flat.transform');
+ * @classdesc
+ * Abstract base class; only used for creating subclasses; do not instantiate
+ * in apps, as cannot be rendered.
+ * @constructor
+ * @abstract
+ * @extends {ol.geom.Geometry}
+ * @api
+ol.geom.SimpleGeometry = function() {
+ ol.geom.Geometry.call(this);
+ * @protected
+ * @type {ol.geom.GeometryLayout}
+ this.layout = ol.geom.GeometryLayout.XY;
+ * @protected
+ * @type {number}
+ this.stride = 2;
+ * @protected
+ this.flatCoordinates = null;
+ol.inherits(ol.geom.SimpleGeometry, ol.geom.Geometry);
+ * @private
+ * @return {ol.geom.GeometryLayout} layout Layout.
+ol.geom.SimpleGeometry.getLayoutForStride_ = function(stride) {
+ var layout;
+ if (stride == 2) {
+ layout = ol.geom.GeometryLayout.XY;
+ } else if (stride == 3) {
+ layout = ol.geom.GeometryLayout.XYZ;
+ } else if (stride == 4) {
+ layout = ol.geom.GeometryLayout.XYZM;
+ return /** @type {ol.geom.GeometryLayout} */ (layout);
+ * @param {ol.geom.GeometryLayout} layout Layout.
+ * @return {number} Stride.
+ol.geom.SimpleGeometry.getStrideForLayout = function(layout) {
+ var stride;
+ if (layout == ol.geom.GeometryLayout.XY) {
+ stride = 2;
+ } else if (layout == ol.geom.GeometryLayout.XYZ || layout == ol.geom.GeometryLayout.XYM) {
+ stride = 3;
+ } else if (layout == ol.geom.GeometryLayout.XYZM) {
+ stride = 4;
+ return /** @type {number} */ (stride);
+ * @inheritDoc
+ol.geom.SimpleGeometry.prototype.containsXY = ol.functions.FALSE;
+ * @inheritDoc
+ol.geom.SimpleGeometry.prototype.computeExtent = function(extent) {
+ return ol.extent.createOrUpdateFromFlatCoordinates(
+ this.flatCoordinates, 0, this.flatCoordinates.length, this.stride,
+ extent);
+ * @abstract
+ * @return {Array} Coordinates.
+ol.geom.SimpleGeometry.prototype.getCoordinates = function() {};
+ * Return the first coordinate of the geometry.
+ * @return {ol.Coordinate} First coordinate.
+ * @api
+ol.geom.SimpleGeometry.prototype.getFirstCoordinate = function() {
+ return this.flatCoordinates.slice(0, this.stride);
+ * @return {Array.<number>} Flat coordinates.
+ol.geom.SimpleGeometry.prototype.getFlatCoordinates = function() {
+ return this.flatCoordinates;
+ * Return the last coordinate of the geometry.
+ * @return {ol.Coordinate} Last point.
+ * @api
+ol.geom.SimpleGeometry.prototype.getLastCoordinate = function() {
+ return this.flatCoordinates.slice(this.flatCoordinates.length - this.stride);
+ * Return the {@link ol.geom.GeometryLayout layout} of the geometry.
+ * @return {ol.geom.GeometryLayout} Layout.
+ * @api
+ol.geom.SimpleGeometry.prototype.getLayout = function() {
+ return this.layout;
+ * @inheritDoc
+ol.geom.SimpleGeometry.prototype.getSimplifiedGeometry = function(squaredTolerance) {
+ if (this.simplifiedGeometryRevision != this.getRevision()) {
+ ol.obj.clear(this.simplifiedGeometryCache);
+ this.simplifiedGeometryRevision = this.getRevision();
+ // If squaredTolerance is negative or if we know that simplification will not
+ // have any effect then just return this.
+ if (squaredTolerance < 0 ||
+ (this.simplifiedGeometryMaxMinSquaredTolerance !== 0 &&
+ squaredTolerance <= this.simplifiedGeometryMaxMinSquaredTolerance)) {
+ return this;
+ var key = squaredTolerance.toString();
+ if (this.simplifiedGeometryCache.hasOwnProperty(key)) {
+ return this.simplifiedGeometryCache[key];
+ } else {
+ var simplifiedGeometry =
+ this.getSimplifiedGeometryInternal(squaredTolerance);
+ var simplifiedFlatCoordinates = simplifiedGeometry.getFlatCoordinates();
+ if (simplifiedFlatCoordinates.length < this.flatCoordinates.length) {
+ this.simplifiedGeometryCache[key] = simplifiedGeometry;
+ return simplifiedGeometry;
+ } else {
+ // Simplification did not actually remove any coordinates. We now know
+ // that any calls to getSimplifiedGeometry with a squaredTolerance less
+ // than or equal to the current squaredTolerance will also not have any
+ // effect. This allows us to short circuit simplification (saving CPU
+ // cycles) and prevents the cache of simplified geometries from filling
+ // up with useless identical copies of this geometry (saving memory).
+ this.simplifiedGeometryMaxMinSquaredTolerance = squaredTolerance;
+ return this;
+ * @return {ol.geom.SimpleGeometry} Simplified geometry.
+ * @protected
+ol.geom.SimpleGeometry.prototype.getSimplifiedGeometryInternal = function(squaredTolerance) {
+ return this;
+ol.geom.SimpleGeometry.prototype.getStride = function() {
+ return this.stride;
+ * @protected
+ol.geom.SimpleGeometry.prototype.setFlatCoordinatesInternal = function(layout, flatCoordinates) {
+ this.stride = ol.geom.SimpleGeometry.getStrideForLayout(layout);
+ this.layout = layout;
+ this.flatCoordinates = flatCoordinates;
+ * @abstract
+ * @param {Array} coordinates Coordinates.
+ * @param {ol.geom.GeometryLayout=} opt_layout Layout.
+ol.geom.SimpleGeometry.prototype.setCoordinates = function(coordinates, opt_layout) {};
+ * @param {ol.geom.GeometryLayout|undefined} layout Layout.
+ * @param {number} nesting Nesting.
+ * @protected
+ol.geom.SimpleGeometry.prototype.setLayout = function(layout, coordinates, nesting) {
+ /** @type {number} */
+ var stride;
+ if (layout) {
+ stride = ol.geom.SimpleGeometry.getStrideForLayout(layout);
+ } else {
+ var i;
+ for (i = 0; i < nesting; ++i) {
+ if (coordinates.length === 0) {
+ this.stride = 2;
+ return;
+ } else {
+ coordinates = /** @type {Array} */ (coordinates[0]);
+ stride = coordinates.length;
+ layout = ol.geom.SimpleGeometry.getLayoutForStride_(stride);
+ this.stride = stride;
+ * @inheritDoc
+ * @api
+ol.geom.SimpleGeometry.prototype.applyTransform = function(transformFn) {
+ if (this.flatCoordinates) {
+ transformFn(this.flatCoordinates, this.flatCoordinates, this.stride);
+ this.changed();
+ * @inheritDoc
+ * @api
+ol.geom.SimpleGeometry.prototype.rotate = function(angle, anchor) {
+ var flatCoordinates = this.getFlatCoordinates();
+ if (flatCoordinates) {
+ var stride = this.getStride();
+ ol.geom.flat.transform.rotate(
+ flatCoordinates, 0, flatCoordinates.length,
+ stride, angle, anchor, flatCoordinates);
+ this.changed();
+ * @inheritDoc
+ * @api
+ol.geom.SimpleGeometry.prototype.scale = function(sx, opt_sy, opt_anchor) {
+ var sy = opt_sy;
+ if (sy === undefined) {
+ sy = sx;
+ var anchor = opt_anchor;
+ if (!anchor) {
+ anchor = ol.extent.getCenter(this.getExtent());
+ ol.geom.flat.transform.scale(
+ stride, sx, sy, anchor, flatCoordinates);
+ this.changed();
+ * @inheritDoc
+ * @api
+ol.geom.SimpleGeometry.prototype.translate = function(deltaX, deltaY) {
+ ol.geom.flat.transform.translate(
+ flatCoordinates, 0, flatCoordinates.length, stride,
+ deltaX, deltaY, flatCoordinates);
+ this.changed();
+ * @param {ol.geom.SimpleGeometry} simpleGeometry Simple geometry.
+ * @return {Array.<number>} Transformed flat coordinates.
+ol.geom.SimpleGeometry.transform2D = function(simpleGeometry, transform, opt_dest) {
+ var flatCoordinates = simpleGeometry.getFlatCoordinates();
+ if (!flatCoordinates) {
+ return null;
+ } else {
+ var stride = simpleGeometry.getStride();
+ return ol.geom.flat.transform.transform2D(
+ transform, opt_dest);
+goog.provide('ol.geom.flat.area');
+ * @return {number} Area.
+ol.geom.flat.area.linearRing = function(flatCoordinates, offset, end, stride) {
+ var twiceArea = 0;
+ var x1 = flatCoordinates[end - stride];
+ var y1 = flatCoordinates[end - stride + 1];
+ for (; offset < end; offset += stride) {
+ var x2 = flatCoordinates[offset];
+ var y2 = flatCoordinates[offset + 1];
+ twiceArea += y1 * x2 - x1 * y2;
+ x1 = x2;
+ y1 = y2;
+ return twiceArea / 2;
+ * @param {Array.<number>} ends Ends.
+ol.geom.flat.area.linearRings = function(flatCoordinates, offset, ends, stride) {
+ var area = 0;
+ var i, ii;
+ for (i = 0, ii = ends.length; i < ii; ++i) {
+ var end = ends[i];
+ area += ol.geom.flat.area.linearRing(flatCoordinates, offset, end, stride);
+ offset = end;
+ return area;
+ * @param {Array.<Array.<number>>} endss Endss.
+ol.geom.flat.area.linearRingss = function(flatCoordinates, offset, endss, stride) {
+ var area = 0;
+ var i, ii;
+ for (i = 0, ii = endss.length; i < ii; ++i) {
+ var ends = endss[i];
+ area +=
+ ol.geom.flat.area.linearRings(flatCoordinates, offset, ends, stride);
+ offset = ends[ends.length - 1];
+ return area;
+goog.provide('ol.geom.flat.closest');
+ * Returns the point on the 2D line segment flatCoordinates[offset1] to
+ * flatCoordinates[offset2] that is closest to the point (x, y). Extra
+ * dimensions are linearly interpolated.
+ * @param {number} offset1 Offset 1.
+ * @param {number} offset2 Offset 2.
+ * @param {Array.<number>} closestPoint Closest point.
+ol.geom.flat.closest.point = function(flatCoordinates, offset1, offset2, stride, x, y, closestPoint) {
+ var x1 = flatCoordinates[offset1];
+ var y1 = flatCoordinates[offset1 + 1];
+ var dx = flatCoordinates[offset2] - x1;
+ var dy = flatCoordinates[offset2 + 1] - y1;
+ var i, offset;
+ if (dx === 0 && dy === 0) {
+ offset = offset1;
+ } else {
+ var t = ((x - x1) * dx + (y - y1) * dy) / (dx * dx + dy * dy);
+ if (t > 1) {
+ offset = offset2;
+ } else if (t > 0) {
+ for (i = 0; i < stride; ++i) {
+ closestPoint[i] = ol.math.lerp(flatCoordinates[offset1 + i],
+ flatCoordinates[offset2 + i], t);
+ closestPoint.length = stride;
+ return;
+ } else {
+ offset = offset1;
+ closestPoint[i] = flatCoordinates[offset + i];
+ * Return the squared of the largest distance between any pair of consecutive
+ * coordinates.
+ * @param {number} maxSquaredDelta Max squared delta.
+ * @return {number} Max squared delta.
+ol.geom.flat.closest.getMaxSquaredDelta = function(flatCoordinates, offset, end, stride, maxSquaredDelta) {
+ var x1 = flatCoordinates[offset];
+ var y1 = flatCoordinates[offset + 1];
+ for (offset += stride; offset < end; offset += stride) {
+ var squaredDelta = ol.math.squaredDistance(x1, y1, x2, y2);
+ if (squaredDelta > maxSquaredDelta) {
+ maxSquaredDelta = squaredDelta;
+ x1 = x2;
+ y1 = y2;
+ return maxSquaredDelta;
+ol.geom.flat.closest.getsMaxSquaredDelta = function(flatCoordinates, offset, ends, stride, maxSquaredDelta) {
+ var i, ii;
+ maxSquaredDelta = ol.geom.flat.closest.getMaxSquaredDelta(
+ flatCoordinates, offset, end, stride, maxSquaredDelta);
+ offset = end;
+ol.geom.flat.closest.getssMaxSquaredDelta = function(flatCoordinates, offset, endss, stride, maxSquaredDelta) {
+ var i, ii;
+ maxSquaredDelta = ol.geom.flat.closest.getsMaxSquaredDelta(
+ flatCoordinates, offset, ends, stride, maxSquaredDelta);
+ * @param {number} maxDelta Max delta.
+ * @param {boolean} isRing Is ring.
+ * @param {Array.<number>=} opt_tmpPoint Temporary point object.
+ol.geom.flat.closest.getClosestPoint = function(flatCoordinates, offset, end,
+ stride, maxDelta, isRing, x, y, closestPoint, minSquaredDistance,
+ opt_tmpPoint) {
+ if (offset == end) {
+ return minSquaredDistance;
+ var i, squaredDistance;
+ if (maxDelta === 0) {
+ // All points are identical, so just test the first point.
+ squaredDistance = ol.math.squaredDistance(
+ x, y, flatCoordinates[offset], flatCoordinates[offset + 1]);
+ if (squaredDistance < minSquaredDistance) {
+ return squaredDistance;
+ } else {
+ var tmpPoint = opt_tmpPoint ? opt_tmpPoint : [NaN, NaN];
+ var index = offset + stride;
+ while (index < end) {
+ ol.geom.flat.closest.point(
+ flatCoordinates, index - stride, index, stride, x, y, tmpPoint);
+ squaredDistance = ol.math.squaredDistance(x, y, tmpPoint[0], tmpPoint[1]);
+ minSquaredDistance = squaredDistance;
+ closestPoint[i] = tmpPoint[i];
+ index += stride;
+ } else {
+ // Skip ahead multiple points, because we know that all the skipped
+ // points cannot be any closer than the closest point we have found so
+ // far. We know this because we know how close the current point is, how
+ // close the closest point we have found so far is, and the maximum
+ // distance between consecutive points. For example, if we're currently
+ // at distance 10, the best we've found so far is 3, and that the maximum
+ // distance between consecutive points is 2, then we'll need to skip at
+ // least (10 - 3) / 2 == 3 (rounded down) points to have any chance of
+ // finding a closer point. We use Math.max(..., 1) to ensure that we
+ // always advance at least one point, to avoid an infinite loop.
+ index += stride * Math.max(
+ ((Math.sqrt(squaredDistance) -
+ Math.sqrt(minSquaredDistance)) / maxDelta) | 0, 1);
+ if (isRing) {
+ // Check the closing segment.
+ flatCoordinates, end - stride, offset, stride, x, y, tmpPoint);
+ol.geom.flat.closest.getsClosestPoint = function(flatCoordinates, offset, ends,
+ opt_tmpPoint) {
+ var i, ii;
+ minSquaredDistance = ol.geom.flat.closest.getClosestPoint(
+ maxDelta, isRing, x, y, closestPoint, minSquaredDistance, tmpPoint);
+ offset = end;
+ol.geom.flat.closest.getssClosestPoint = function(flatCoordinates, offset,
+ endss, stride, maxDelta, isRing, x, y, closestPoint, minSquaredDistance,
+ opt_tmpPoint) {
+ var i, ii;
+ minSquaredDistance = ol.geom.flat.closest.getsClosestPoint(
+goog.provide('ol.geom.flat.deflate');
+ * @return {number} offset Offset.
+ol.geom.flat.deflate.coordinate = function(flatCoordinates, offset, coordinate, stride) {
+ var i, ii;
+ for (i = 0, ii = coordinate.length; i < ii; ++i) {
+ flatCoordinates[offset++] = coordinate[i];
+ return offset;
+ * @param {Array.<ol.Coordinate>} coordinates Coordinates.
+ol.geom.flat.deflate.coordinates = function(flatCoordinates, offset, coordinates, stride) {
+ var i, ii;
+ for (i = 0, ii = coordinates.length; i < ii; ++i) {
+ var coordinate = coordinates[i];
+ var j;
+ for (j = 0; j < stride; ++j) {
+ flatCoordinates[offset++] = coordinate[j];
+ return offset;
+ * @param {Array.<Array.<ol.Coordinate>>} coordinatess Coordinatess.
+ * @param {Array.<number>=} opt_ends Ends.
+ * @return {Array.<number>} Ends.
+ol.geom.flat.deflate.coordinatess = function(flatCoordinates, offset, coordinatess, stride, opt_ends) {
+ var ends = opt_ends ? opt_ends : [];
+ var i = 0;
+ var j, jj;
+ for (j = 0, jj = coordinatess.length; j < jj; ++j) {
+ var end = ol.geom.flat.deflate.coordinates(
+ flatCoordinates, offset, coordinatess[j], stride);
+ ends[i++] = end;
+ offset = end;
+ ends.length = i;
+ return ends;
+ * @param {Array.<Array.<Array.<ol.Coordinate>>>} coordinatesss Coordinatesss.
+ * @param {Array.<Array.<number>>=} opt_endss Endss.
+ * @return {Array.<Array.<number>>} Endss.
+ol.geom.flat.deflate.coordinatesss = function(flatCoordinates, offset, coordinatesss, stride, opt_endss) {
+ var endss = opt_endss ? opt_endss : [];
+ var i = 0;
+ var j, jj;
+ for (j = 0, jj = coordinatesss.length; j < jj; ++j) {
+ var ends = ol.geom.flat.deflate.coordinatess(
+ flatCoordinates, offset, coordinatesss[j], stride, endss[i]);
+ endss[i++] = ends;
+ endss.length = i;
+ return endss;
+goog.provide('ol.geom.flat.inflate');
+ * @param {Array.<ol.Coordinate>=} opt_coordinates Coordinates.
+ * @return {Array.<ol.Coordinate>} Coordinates.
+ol.geom.flat.inflate.coordinates = function(flatCoordinates, offset, end, stride, opt_coordinates) {
+ var coordinates = opt_coordinates !== undefined ? opt_coordinates : [];
+ var i = 0;
+ var j;
+ coordinates[i++] = flatCoordinates.slice(j, j + stride);
+ coordinates.length = i;
+ return coordinates;
+ * @param {Array.<Array.<ol.Coordinate>>=} opt_coordinatess Coordinatess.
+ * @return {Array.<Array.<ol.Coordinate>>} Coordinatess.
+ol.geom.flat.inflate.coordinatess = function(flatCoordinates, offset, ends, stride, opt_coordinatess) {
+ var coordinatess = opt_coordinatess !== undefined ? opt_coordinatess : [];
+ var i = 0;
+ var j, jj;
+ for (j = 0, jj = ends.length; j < jj; ++j) {
+ var end = ends[j];
+ coordinatess[i++] = ol.geom.flat.inflate.coordinates(
+ flatCoordinates, offset, end, stride, coordinatess[i]);
+ offset = end;
+ coordinatess.length = i;
+ return coordinatess;
+ * @param {Array.<Array.<Array.<ol.Coordinate>>>=} opt_coordinatesss
+ * Coordinatesss.
+ * @return {Array.<Array.<Array.<ol.Coordinate>>>} Coordinatesss.
+ol.geom.flat.inflate.coordinatesss = function(flatCoordinates, offset, endss, stride, opt_coordinatesss) {
+ var coordinatesss = opt_coordinatesss !== undefined ? opt_coordinatesss : [];
+ var i = 0;
+ var j, jj;
+ for (j = 0, jj = endss.length; j < jj; ++j) {
+ var ends = endss[j];
+ coordinatesss[i++] = ol.geom.flat.inflate.coordinatess(
+ flatCoordinates, offset, ends, stride, coordinatesss[i]);
+ coordinatesss.length = i;
+ return coordinatesss;
+// Based on simplify-js https://github.com/mourner/simplify-js
+// Copyright (c) 2012, Vladimir Agafonkin
+// All rights reserved.
+// Redistribution and use in source and binary forms, with or without
+// modification, are permitted provided that the following conditions are met:
+// 1. Redistributions of source code must retain the above copyright notice,
+// this list of conditions and the following disclaimer.
+// 2. Redistributions in binary form must reproduce the above copyright
+// notice, this list of conditions and the following disclaimer in the
+// documentation and/or other materials provided with the distribution.
+// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+// AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+// IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+// ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+// LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+// CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+// SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+// INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+// CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+// ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+// POSSIBILITY OF SUCH DAMAGE.
+goog.provide('ol.geom.flat.simplify');
+ * @param {boolean} highQuality Highest quality.
+ * @param {Array.<number>=} opt_simplifiedFlatCoordinates Simplified flat
+ * coordinates.
+ * @return {Array.<number>} Simplified line string.
+ol.geom.flat.simplify.lineString = function(flatCoordinates, offset, end,
+ stride, squaredTolerance, highQuality, opt_simplifiedFlatCoordinates) {
+ var simplifiedFlatCoordinates = opt_simplifiedFlatCoordinates !== undefined ?
+ opt_simplifiedFlatCoordinates : [];
+ if (!highQuality) {
+ end = ol.geom.flat.simplify.radialDistance(flatCoordinates, offset, end,
+ simplifiedFlatCoordinates, 0);
+ flatCoordinates = simplifiedFlatCoordinates;
+ offset = 0;
+ stride = 2;
+ simplifiedFlatCoordinates.length = ol.geom.flat.simplify.douglasPeucker(
+ flatCoordinates, offset, end, stride, squaredTolerance,
+ return simplifiedFlatCoordinates;
+ * @param {Array.<number>} simplifiedFlatCoordinates Simplified flat
+ * coordinates.
+ * @param {number} simplifiedOffset Simplified offset.
+ * @return {number} Simplified offset.
+ol.geom.flat.simplify.douglasPeucker = function(flatCoordinates, offset, end,
+ stride, squaredTolerance, simplifiedFlatCoordinates, simplifiedOffset) {
+ var n = (end - offset) / stride;
+ if (n < 3) {
+ simplifiedFlatCoordinates[simplifiedOffset++] =
+ flatCoordinates[offset];
+ flatCoordinates[offset + 1];
+ return simplifiedOffset;
+ /** @type {Array.<number>} */
+ var markers = new Array(n);
+ markers[0] = 1;
+ markers[n - 1] = 1;
+ var stack = [offset, end - stride];
+ var index = 0;
+ var i;
+ while (stack.length > 0) {
+ var last = stack.pop();
+ var first = stack.pop();
+ var maxSquaredDistance = 0;
+ var x1 = flatCoordinates[first];
+ var y1 = flatCoordinates[first + 1];
+ var x2 = flatCoordinates[last];
+ var y2 = flatCoordinates[last + 1];
+ for (i = first + stride; i < last; i += stride) {
+ var x = flatCoordinates[i];
+ var y = flatCoordinates[i + 1];
+ var squaredDistance = ol.math.squaredSegmentDistance(
+ x, y, x1, y1, x2, y2);
+ if (squaredDistance > maxSquaredDistance) {
+ index = i;
+ maxSquaredDistance = squaredDistance;
+ if (maxSquaredDistance > squaredTolerance) {
+ markers[(index - offset) / stride] = 1;
+ if (first + stride < index) {
+ stack.push(first, index);
+ if (index + stride < last) {
+ stack.push(index, last);
+ if (markers[i]) {
+ flatCoordinates[offset + i * stride];
+ flatCoordinates[offset + i * stride + 1];
+ * coordinates.
+ * @param {Array.<number>} simplifiedEnds Simplified ends.
+ol.geom.flat.simplify.douglasPeuckers = function(flatCoordinates, offset,
+ ends, stride, squaredTolerance, simplifiedFlatCoordinates,
+ simplifiedOffset, simplifiedEnds) {
+ var i, ii;
+ simplifiedOffset = ol.geom.flat.simplify.douglasPeucker(
+ simplifiedFlatCoordinates, simplifiedOffset);
+ simplifiedEnds.push(simplifiedOffset);
+ offset = end;
+ * coordinates.
+ * @param {Array.<Array.<number>>} simplifiedEndss Simplified endss.
+ol.geom.flat.simplify.douglasPeuckerss = function(
+ flatCoordinates, offset, endss, stride, squaredTolerance,
+ simplifiedFlatCoordinates, simplifiedOffset, simplifiedEndss) {
+ var i, ii;
+ var simplifiedEnds = [];
+ simplifiedOffset = ol.geom.flat.simplify.douglasPeuckers(
+ flatCoordinates, offset, ends, stride, squaredTolerance,
+ simplifiedFlatCoordinates, simplifiedOffset, simplifiedEnds);
+ simplifiedEndss.push(simplifiedEnds);
+ * coordinates.
+ol.geom.flat.simplify.radialDistance = function(flatCoordinates, offset, end,
+ if (end <= offset + stride) {
+ // zero or one point, no simplification possible, so copy and return
+ simplifiedFlatCoordinates[simplifiedOffset++] = flatCoordinates[offset];
+ // copy first point
+ simplifiedFlatCoordinates[simplifiedOffset++] = x1;
+ simplifiedFlatCoordinates[simplifiedOffset++] = y1;
+ var x2 = x1;
+ var y2 = y1;
+ x2 = flatCoordinates[offset];
+ y2 = flatCoordinates[offset + 1];
+ if (ol.math.squaredDistance(x1, y1, x2, y2) > squaredTolerance) {
+ // copy point at offset
+ simplifiedFlatCoordinates[simplifiedOffset++] = x2;
+ simplifiedFlatCoordinates[simplifiedOffset++] = y2;
+ x1 = x2;
+ y1 = y2;
+ if (x2 != x1 || y2 != y1) {
+ // copy last point
+ * @param {number} value Value.
+ * @param {number} tolerance Tolerance.
+ * @return {number} Rounded value.
+ol.geom.flat.simplify.snap = function(value, tolerance) {
+ return tolerance * Math.round(value / tolerance);
+ * Simplifies a line string using an algorithm designed by Tim Schaub.
+ * Coordinates are snapped to the nearest value in a virtual grid and
+ * consecutive duplicate coordinates are discarded. This effectively preserves
+ * topology as the simplification of any subsection of a line string is
+ * independent of the rest of the line string. This means that, for examples,
+ * the common edge between two polygons will be simplified to the same line
+ * string independently in both polygons. This implementation uses a single
+ * pass over the coordinates and eliminates intermediate collinear points.
+ * coordinates.
+ol.geom.flat.simplify.quantize = function(flatCoordinates, offset, end, stride,
+ tolerance, simplifiedFlatCoordinates, simplifiedOffset) {
+ // do nothing if the line is empty
+ // snap the first coordinate (P1)
+ var x1 = ol.geom.flat.simplify.snap(flatCoordinates[offset], tolerance);
+ var y1 = ol.geom.flat.simplify.snap(flatCoordinates[offset + 1], tolerance);
+ offset += stride;
+ // add the first coordinate to the output
+ // find the next coordinate that does not snap to the same value as the first
+ // coordinate (P2)
+ var x2, y2;
+ do {
+ x2 = ol.geom.flat.simplify.snap(flatCoordinates[offset], tolerance);
+ y2 = ol.geom.flat.simplify.snap(flatCoordinates[offset + 1], tolerance);
+ offset += stride;
+ // all coordinates snap to the same value, the line collapses to a point
+ // push the last snapped value anyway to ensure that the output contains
+ // at least two points
+ // FIXME should we really return at least two points anyway?
+ } while (x2 == x1 && y2 == y1);
+ while (offset < end) {
+ var x3, y3;
+ // snap the next coordinate (P3)
+ x3 = ol.geom.flat.simplify.snap(flatCoordinates[offset], tolerance);
+ y3 = ol.geom.flat.simplify.snap(flatCoordinates[offset + 1], tolerance);
+ offset += stride;
+ // skip P3 if it is equal to P2
+ if (x3 == x2 && y3 == y2) {
+ continue;
+ // calculate the delta between P1 and P2
+ var dx1 = x2 - x1;
+ var dy1 = y2 - y1;
+ // calculate the delta between P3 and P1
+ var dx2 = x3 - x1;
+ var dy2 = y3 - y1;
+ // if P1, P2, and P3 are colinear and P3 is further from P1 than P2 is from
+ // P1 in the same direction then P2 is on the straight line between P1 and
+ // P3
+ if ((dx1 * dy2 == dy1 * dx2) &&
+ ((dx1 < 0 && dx2 < dx1) || dx1 == dx2 || (dx1 > 0 && dx2 > dx1)) &&
+ ((dy1 < 0 && dy2 < dy1) || dy1 == dy2 || (dy1 > 0 && dy2 > dy1))) {
+ // discard P2 and set P2 = P3
+ x2 = x3;
+ y2 = y3;
+ continue;
+ // either P1, P2, and P3 are not colinear, or they are colinear but P3 is
+ // between P3 and P1 or on the opposite half of the line to P2. add P2,
+ // and continue with P1 = P2 and P2 = P3
+ x1 = x2;
+ y1 = y2;
+ x2 = x3;
+ y2 = y3;
+ // add the last point (P2)
+ * coordinates.
+ol.geom.flat.simplify.quantizes = function(
+ tolerance,
+ simplifiedFlatCoordinates, simplifiedOffset, simplifiedEnds) {
+ var i, ii;
+ simplifiedOffset = ol.geom.flat.simplify.quantize(
+ tolerance,
+ offset = end;
+ * coordinates.
+ol.geom.flat.simplify.quantizess = function(
+ tolerance,
+ var i, ii;
+ simplifiedOffset = ol.geom.flat.simplify.quantizes(
+ tolerance,
+goog.provide('ol.geom.LinearRing');
+goog.require('ol');
+goog.require('ol.geom.GeometryType');
+goog.require('ol.geom.SimpleGeometry');
+goog.require('ol.geom.flat.area');
+goog.require('ol.geom.flat.closest');
+goog.require('ol.geom.flat.deflate');
+goog.require('ol.geom.flat.inflate');
+goog.require('ol.geom.flat.simplify');
+ * @classdesc
+ * Linear ring geometry. Only used as part of polygon; cannot be rendered
+ * on its own.
+ * @constructor
+ * @extends {ol.geom.SimpleGeometry}
+ * @api
+ol.geom.LinearRing = function(coordinates, opt_layout) {
+ ol.geom.SimpleGeometry.call(this);
+ * @private
+ * @type {number}
+ this.maxDelta_ = -1;
+ * @private
+ * @type {number}
+ this.maxDeltaRevision_ = -1;
+ this.setCoordinates(coordinates, opt_layout);
+ol.inherits(ol.geom.LinearRing, ol.geom.SimpleGeometry);
+ * @return {!ol.geom.LinearRing} Clone.
+ * @override
+ * @api
+ol.geom.LinearRing.prototype.clone = function() {
+ var linearRing = new ol.geom.LinearRing(null);
+ linearRing.setFlatCoordinates(this.layout, this.flatCoordinates.slice());
+ return linearRing;
+ * @inheritDoc
+ol.geom.LinearRing.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
+ if (minSquaredDistance <
+ ol.extent.closestSquaredDistanceXY(this.getExtent(), x, y)) {
+ if (this.maxDeltaRevision_ != this.getRevision()) {
+ this.maxDelta_ = Math.sqrt(ol.geom.flat.closest.getMaxSquaredDelta(
+ this.flatCoordinates, 0, this.flatCoordinates.length, this.stride, 0));
+ this.maxDeltaRevision_ = this.getRevision();
+ return ol.geom.flat.closest.getClosestPoint(
+ this.maxDelta_, true, x, y, closestPoint, minSquaredDistance);
+ * Return the area of the linear ring on projected plane.
+ * @return {number} Area (on projected plane).
+ * @api
+ol.geom.LinearRing.prototype.getArea = function() {
+ return ol.geom.flat.area.linearRing(
+ this.flatCoordinates, 0, this.flatCoordinates.length, this.stride);
+ * Return the coordinates of the linear ring.
+ * @override
+ * @api
+ol.geom.LinearRing.prototype.getCoordinates = function() {
+ return ol.geom.flat.inflate.coordinates(
+ * @inheritDoc
+ol.geom.LinearRing.prototype.getSimplifiedGeometryInternal = function(squaredTolerance) {
+ var simplifiedFlatCoordinates = [];
+ squaredTolerance, simplifiedFlatCoordinates, 0);
+ var simplifiedLinearRing = new ol.geom.LinearRing(null);
+ simplifiedLinearRing.setFlatCoordinates(
+ ol.geom.GeometryLayout.XY, simplifiedFlatCoordinates);
+ return simplifiedLinearRing;
+ * @inheritDoc
+ * @api
+ol.geom.LinearRing.prototype.getType = function() {
+ return ol.geom.GeometryType.LINEAR_RING;
+ * @inheritDoc
+ol.geom.LinearRing.prototype.intersectsExtent = function(extent) {};
+ * Set the coordinates of the linear ring.
+ * @override
+ * @api
+ol.geom.LinearRing.prototype.setCoordinates = function(coordinates, opt_layout) {
+ if (!coordinates) {
+ this.setFlatCoordinates(ol.geom.GeometryLayout.XY, null);
+ } else {
+ this.setLayout(opt_layout, coordinates, 1);
+ if (!this.flatCoordinates) {
+ this.flatCoordinates = [];
+ this.flatCoordinates.length = ol.geom.flat.deflate.coordinates(
+ this.flatCoordinates, 0, coordinates, this.stride);
+ this.changed();
+ol.geom.LinearRing.prototype.setFlatCoordinates = function(layout, flatCoordinates) {
+ this.setFlatCoordinatesInternal(layout, flatCoordinates);
+ this.changed();
+goog.provide('ol.geom.Point');
+ * @classdesc
+ * Point geometry.
+ * @constructor
+ * @param {ol.Coordinate} coordinates Coordinates.
+ * @api
+ol.geom.Point = function(coordinates, opt_layout) {
+ol.inherits(ol.geom.Point, ol.geom.SimpleGeometry);
+ * @return {!ol.geom.Point} Clone.
+ * @override
+ * @api
+ol.geom.Point.prototype.clone = function() {
+ var point = new ol.geom.Point(null);
+ point.setFlatCoordinates(this.layout, this.flatCoordinates.slice());
+ return point;
+ * @inheritDoc
+ol.geom.Point.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
+ var flatCoordinates = this.flatCoordinates;
+ var squaredDistance = ol.math.squaredDistance(
+ x, y, flatCoordinates[0], flatCoordinates[1]);
+ var stride = this.stride;
+ var i;
+ closestPoint[i] = flatCoordinates[i];
+ } else {
+ * Return the coordinate of the point.
+ * @return {ol.Coordinate} Coordinates.
+ * @override
+ * @api
+ol.geom.Point.prototype.getCoordinates = function() {
+ return !this.flatCoordinates ? [] : this.flatCoordinates.slice();
+ * @inheritDoc
+ol.geom.Point.prototype.computeExtent = function(extent) {
+ return ol.extent.createOrUpdateFromCoordinate(this.flatCoordinates, extent);
+ * @inheritDoc
+ * @api
+ol.geom.Point.prototype.getType = function() {
+ return ol.geom.GeometryType.POINT;
+ * @inheritDoc
+ * @api
+ol.geom.Point.prototype.intersectsExtent = function(extent) {
+ return ol.extent.containsXY(extent,
+ this.flatCoordinates[0], this.flatCoordinates[1]);
+ * @inheritDoc
+ * @api
+ol.geom.Point.prototype.setCoordinates = function(coordinates, opt_layout) {
+ } else {
+ this.setLayout(opt_layout, coordinates, 0);
+ this.flatCoordinates.length = ol.geom.flat.deflate.coordinate(
+ this.changed();
+ol.geom.Point.prototype.setFlatCoordinates = function(layout, flatCoordinates) {
+ this.changed();
+goog.provide('ol.geom.flat.contains');
+ * @return {boolean} Contains extent.
+ol.geom.flat.contains.linearRingContainsExtent = function(flatCoordinates, offset, end, stride, extent) {
+ var outside = ol.extent.forEachCorner(extent,
+ return !ol.geom.flat.contains.linearRingContainsXY(flatCoordinates,
+ offset, end, stride, coordinate[0], coordinate[1]);
+ return !outside;
+ol.geom.flat.contains.linearRingContainsXY = function(flatCoordinates, offset, end, stride, x, y) {
+ // http://geomalgorithms.com/a03-_inclusion.html
+ // Copyright 2000 softSurfer, 2012 Dan Sunday
+ // This code may be freely used and modified for any purpose
+ // providing that this copyright notice is included with it.
+ // SoftSurfer makes no warranty for this code, and cannot be held
+ // liable for any real or imagined damage resulting from its use.
+ // Users of this code must verify correctness for their application.
+ var wn = 0;
+ if (y1 <= y) {
+ if (y2 > y && ((x2 - x1) * (y - y1)) - ((x - x1) * (y2 - y1)) > 0) {
+ wn++;
+ } else if (y2 <= y && ((x2 - x1) * (y - y1)) - ((x - x1) * (y2 - y1)) < 0) {
+ wn--;
+ x1 = x2;
+ y1 = y2;
+ return wn !== 0;
+ol.geom.flat.contains.linearRingsContainsXY = function(flatCoordinates, offset, ends, stride, x, y) {
+ if (ends.length === 0) {
+ return false;
+ if (!ol.geom.flat.contains.linearRingContainsXY(
+ flatCoordinates, offset, ends[0], stride, x, y)) {
+ return false;
+ var i, ii;
+ for (i = 1, ii = ends.length; i < ii; ++i) {
+ if (ol.geom.flat.contains.linearRingContainsXY(
+ flatCoordinates, ends[i - 1], ends[i], stride, x, y)) {
+ return false;
+ return true;
+ol.geom.flat.contains.linearRingssContainsXY = function(flatCoordinates, offset, endss, stride, x, y) {
+ if (endss.length === 0) {
+ return false;
+ var i, ii;
+ if (ol.geom.flat.contains.linearRingsContainsXY(
+ flatCoordinates, offset, ends, stride, x, y)) {
+ return true;
+ return false;
+goog.provide('ol.geom.flat.interiorpoint');
+goog.require('ol.array');
+goog.require('ol.geom.flat.contains');
+ * Calculates a point that is likely to lie in the interior of the linear rings.
+ * Inspired by JTS's com.vividsolutions.jts.geom.Geometry#getInteriorPoint.
+ * @param {Array.<number>} flatCenters Flat centers.
+ * @param {number} flatCentersOffset Flat center offset.
+ * @return {Array.<number>} Destination.
+ol.geom.flat.interiorpoint.linearRings = function(flatCoordinates, offset,
+ ends, stride, flatCenters, flatCentersOffset, opt_dest) {
+ var i, ii, x, x1, x2, y1, y2;
+ var y = flatCenters[flatCentersOffset + 1];
+ var intersections = [];
+ // Calculate intersections with the horizontal line
+ var end = ends[0];
+ x1 = flatCoordinates[end - stride];
+ y1 = flatCoordinates[end - stride + 1];
+ for (i = offset; i < end; i += stride) {
+ x2 = flatCoordinates[i];
+ y2 = flatCoordinates[i + 1];
+ if ((y <= y1 && y2 <= y) || (y1 <= y && y <= y2)) {
+ x = (y - y1) / (y2 - y1) * (x2 - x1) + x1;
+ intersections.push(x);
+ x1 = x2;
+ y1 = y2;
+ // Find the longest segment of the horizontal line that has its center point
+ // inside the linear ring.
+ var pointX = NaN;
+ var maxSegmentLength = -Infinity;
+ intersections.sort(ol.array.numberSafeCompareFunction);
+ x1 = intersections[0];
+ for (i = 1, ii = intersections.length; i < ii; ++i) {
+ x2 = intersections[i];
+ var segmentLength = Math.abs(x2 - x1);
+ if (segmentLength > maxSegmentLength) {
+ x = (x1 + x2) / 2;
+ pointX = x;
+ maxSegmentLength = segmentLength;
+ x1 = x2;
+ if (isNaN(pointX)) {
+ // There is no horizontal line that has its center point inside the linear
+ // ring. Use the center of the the linear ring's extent.
+ pointX = flatCenters[flatCentersOffset];
+ if (opt_dest) {
+ opt_dest.push(pointX, y);
+ return opt_dest;
+ } else {
+ return [pointX, y];
+ * @return {Array.<number>} Interior points.
+ol.geom.flat.interiorpoint.linearRingss = function(flatCoordinates, offset, endss, stride, flatCenters) {
+ var interiorPoints = [];
+ var i, ii;
+ interiorPoints = ol.geom.flat.interiorpoint.linearRings(flatCoordinates,
+ offset, ends, stride, flatCenters, 2 * i, interiorPoints);
+ return interiorPoints;
+goog.provide('ol.geom.flat.segments');
+ * This function calls `callback` for each segment of the flat coordinates
+ * array. If the callback returns a truthy value the function returns that
+ * value immediately. Otherwise the function returns `false`.
+ * @param {function(this: S, ol.Coordinate, ol.Coordinate): T} callback Function
+ * called for each segment.
+ * @param {S=} opt_this The object to be used as the value of 'this'
+ * within callback.
+ * @return {T|boolean} Value.
+ * @template T,S
+ol.geom.flat.segments.forEach = function(flatCoordinates, offset, end, stride, callback, opt_this) {
+ var point1 = [flatCoordinates[offset], flatCoordinates[offset + 1]];
+ var point2 = [];
+ var ret;
+ for (; (offset + stride) < end; offset += stride) {
+ point2[0] = flatCoordinates[offset + stride];
+ point2[1] = flatCoordinates[offset + stride + 1];
+ ret = callback.call(opt_this, point1, point2);
+ if (ret) {
+ return ret;
+ point1[0] = point2[0];
+ point1[1] = point2[1];
+ return false;
+goog.provide('ol.geom.flat.intersectsextent');
+goog.require('ol.geom.flat.segments');
+ * @return {boolean} True if the geometry and the extent intersect.
+ol.geom.flat.intersectsextent.lineString = function(flatCoordinates, offset, end, stride, extent) {
+ var coordinatesExtent = ol.extent.extendFlatCoordinates(
+ ol.extent.createEmpty(), flatCoordinates, offset, end, stride);
+ if (!ol.extent.intersects(extent, coordinatesExtent)) {
+ return false;
+ if (ol.extent.containsExtent(extent, coordinatesExtent)) {
+ return true;
+ if (coordinatesExtent[0] >= extent[0] &&
+ coordinatesExtent[2] <= extent[2]) {
+ return true;
+ if (coordinatesExtent[1] >= extent[1] &&
+ coordinatesExtent[3] <= extent[3]) {
+ return true;
+ return ol.geom.flat.segments.forEach(flatCoordinates, offset, end, stride,
+ * @param {ol.Coordinate} point1 Start point.
+ * @param {ol.Coordinate} point2 End point.
+ * @return {boolean} `true` if the segment and the extent intersect,
+ * `false` otherwise.
+ function(point1, point2) {
+ return ol.extent.intersectsSegment(extent, point1, point2);
+ol.geom.flat.intersectsextent.lineStrings = function(flatCoordinates, offset, ends, stride, extent) {
+ var i, ii;
+ if (ol.geom.flat.intersectsextent.lineString(
+ flatCoordinates, offset, ends[i], stride, extent)) {
+ return true;
+ offset = ends[i];
+ return false;
+ol.geom.flat.intersectsextent.linearRing = function(flatCoordinates, offset, end, stride, extent) {
+ flatCoordinates, offset, end, stride, extent)) {
+ return true;
+ flatCoordinates, offset, end, stride, extent[0], extent[1])) {
+ return true;
+ flatCoordinates, offset, end, stride, extent[0], extent[3])) {
+ return true;
+ flatCoordinates, offset, end, stride, extent[2], extent[1])) {
+ return true;
+ flatCoordinates, offset, end, stride, extent[2], extent[3])) {
+ return true;
+ return false;
+ol.geom.flat.intersectsextent.linearRings = function(flatCoordinates, offset, ends, stride, extent) {
+ if (!ol.geom.flat.intersectsextent.linearRing(
+ flatCoordinates, offset, ends[0], stride, extent)) {
+ return false;
+ if (ends.length === 1) {
+ return true;
+ var i, ii;
+ if (ol.geom.flat.contains.linearRingContainsExtent(
+ flatCoordinates, ends[i - 1], ends[i], stride, extent)) {
+ return false;
+ return true;
+ol.geom.flat.intersectsextent.linearRingss = function(flatCoordinates, offset, endss, stride, extent) {
+ var i, ii;
+ if (ol.geom.flat.intersectsextent.linearRings(
+ flatCoordinates, offset, ends, stride, extent)) {
+ return true;
+ return false;
+goog.provide('ol.geom.flat.reverse');
+ol.geom.flat.reverse.coordinates = function(flatCoordinates, offset, end, stride) {
+ while (offset < end - stride) {
+ var i;
+ var tmp = flatCoordinates[offset + i];
+ flatCoordinates[offset + i] = flatCoordinates[end - stride + i];
+ flatCoordinates[end - stride + i] = tmp;
+ offset += stride;
+ end -= stride;
+goog.provide('ol.geom.flat.orient');
+goog.require('ol.geom.flat.reverse');
+ * @return {boolean} Is clockwise.
+ol.geom.flat.orient.linearRingIsClockwise = function(flatCoordinates, offset, end, stride) {
+ // http://tinyurl.com/clockwise-method
+ // https://github.com/OSGeo/gdal/blob/trunk/gdal/ogr/ogrlinearring.cpp
+ var edge = 0;
+ edge += (x2 - x1) * (y2 + y1);
+ x1 = x2;
+ y1 = y2;
+ return edge > 0;
+ * Determines if linear rings are oriented. By default, left-hand orientation
+ * is tested (first ring must be clockwise, remaining rings counter-clockwise).
+ * To test for right-hand orientation, use the `opt_right` argument.
+ * @param {Array.<number>} ends Array of end indexes.
+ * @param {boolean=} opt_right Test for right-hand orientation
+ * (counter-clockwise exterior ring and clockwise interior rings).
+ * @return {boolean} Rings are correctly oriented.
+ol.geom.flat.orient.linearRingsAreOriented = function(flatCoordinates, offset, ends, stride, opt_right) {
+ var right = opt_right !== undefined ? opt_right : false;
+ var i, ii;
+ var isClockwise = ol.geom.flat.orient.linearRingIsClockwise(
+ flatCoordinates, offset, end, stride);
+ if (i === 0) {
+ if ((right && isClockwise) || (!right && !isClockwise)) {
+ return false;
+ } else {
+ if ((right && !isClockwise) || (!right && isClockwise)) {
+ return false;
+ offset = end;
+ return true;
+ * @param {Array.<Array.<number>>} endss Array of array of end indexes.
+ol.geom.flat.orient.linearRingssAreOriented = function(flatCoordinates, offset, endss, stride, opt_right) {
+ var i, ii;
+ if (!ol.geom.flat.orient.linearRingsAreOriented(
+ flatCoordinates, offset, endss[i], stride, opt_right)) {
+ return false;
+ return true;
+ * Orient coordinates in a flat array of linear rings. By default, rings
+ * are oriented following the left-hand rule (clockwise for exterior and
+ * counter-clockwise for interior rings). To orient according to the
+ * right-hand rule, use the `opt_right` argument.
+ * @param {boolean=} opt_right Follow the right-hand rule for orientation.
+ * @return {number} End.
+ol.geom.flat.orient.orientLinearRings = function(flatCoordinates, offset, ends, stride, opt_right) {
+ var i, ii;
+ var reverse = i === 0 ?
+ (right && isClockwise) || (!right && !isClockwise) :
+ (right && !isClockwise) || (!right && isClockwise);
+ if (reverse) {
+ ol.geom.flat.reverse.coordinates(flatCoordinates, offset, end, stride);
+ offset = end;
+ return offset;
+ol.geom.flat.orient.orientLinearRingss = function(flatCoordinates, offset, endss, stride, opt_right) {
+ var i, ii;
+ offset = ol.geom.flat.orient.orientLinearRings(
+ flatCoordinates, offset, endss[i], stride, opt_right);
+ return offset;
+goog.provide('ol.geom.Polygon');
+goog.require('ol.geom.LinearRing');
+goog.require('ol.geom.Point');
+goog.require('ol.geom.flat.interiorpoint');
+goog.require('ol.geom.flat.intersectsextent');
+goog.require('ol.geom.flat.orient');
+goog.require('ol.math');
+ * @classdesc
+ * Polygon geometry.
+ * @constructor
+ * @param {Array.<Array.<ol.Coordinate>>} coordinates Array of linear
+ * rings that define the polygon. The first linear ring of the array
+ * defines the outer-boundary or surface of the polygon. Each subsequent
+ * linear ring defines a hole in the surface of the polygon. A linear ring
+ * is an array of vertices' coordinates where the first coordinate and the
+ * last are equivalent.
+ * @api
+ol.geom.Polygon = function(coordinates, opt_layout) {
+ * @type {Array.<number>}
+ * @private
+ this.ends_ = [];
+ * @private
+ * @type {number}
+ this.flatInteriorPointRevision_ = -1;
+ * @private
+ * @type {ol.Coordinate}
+ this.flatInteriorPoint_ = null;
+ * @private
+ * @type {number}
+ * @private
+ * @type {number}
+ * @private
+ * @type {number}
+ this.orientedRevision_ = -1;
+ * @private
+ this.orientedFlatCoordinates_ = null;
+ol.inherits(ol.geom.Polygon, ol.geom.SimpleGeometry);
+ * Append the passed linear ring to this polygon.
+ * @param {ol.geom.LinearRing} linearRing Linear ring.
+ * @api
+ol.geom.Polygon.prototype.appendLinearRing = function(linearRing) {
+ this.flatCoordinates = linearRing.getFlatCoordinates().slice();
+ } else {
+ ol.array.extend(this.flatCoordinates, linearRing.getFlatCoordinates());
+ this.ends_.push(this.flatCoordinates.length);
+ this.changed();
+ * @return {!ol.geom.Polygon} Clone.
+ * @override
+ * @api
+ol.geom.Polygon.prototype.clone = function() {
+ var polygon = new ol.geom.Polygon(null);
+ polygon.setFlatCoordinates(
+ this.layout, this.flatCoordinates.slice(), this.ends_.slice());
+ return polygon;
+ * @inheritDoc
+ol.geom.Polygon.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
+ this.maxDelta_ = Math.sqrt(ol.geom.flat.closest.getsMaxSquaredDelta(
+ this.flatCoordinates, 0, this.ends_, this.stride, 0));
+ return ol.geom.flat.closest.getsClosestPoint(
+ * @inheritDoc
+ol.geom.Polygon.prototype.containsXY = function(x, y) {
+ return ol.geom.flat.contains.linearRingsContainsXY(
+ this.getOrientedFlatCoordinates(), 0, this.ends_, this.stride, x, y);
+ * Return the area of the polygon on projected plane.
+ * @api
+ol.geom.Polygon.prototype.getArea = function() {
+ return ol.geom.flat.area.linearRings(
+ this.getOrientedFlatCoordinates(), 0, this.ends_, this.stride);
+ * Get the coordinate array for this geometry. This array has the structure
+ * of a GeoJSON coordinate array for polygons.
+ * @param {boolean=} opt_right Orient coordinates according to the right-hand
+ * rule (counter-clockwise for exterior and clockwise for interior rings).
+ * If `false`, coordinates will be oriented according to the left-hand rule
+ * (clockwise for exterior and counter-clockwise for interior rings).
+ * By default, coordinate orientation will depend on how the geometry was
+ * constructed.
+ * @return {Array.<Array.<ol.Coordinate>>} Coordinates.
+ * @override
+ * @api
+ol.geom.Polygon.prototype.getCoordinates = function(opt_right) {
+ var flatCoordinates;
+ if (opt_right !== undefined) {
+ flatCoordinates = this.getOrientedFlatCoordinates().slice();
+ ol.geom.flat.orient.orientLinearRings(
+ flatCoordinates, 0, this.ends_, this.stride, opt_right);
+ } else {
+ flatCoordinates = this.flatCoordinates;
+ return ol.geom.flat.inflate.coordinatess(
+ flatCoordinates, 0, this.ends_, this.stride);
+ol.geom.Polygon.prototype.getEnds = function() {
+ return this.ends_;
+ * @return {Array.<number>} Interior point.
+ol.geom.Polygon.prototype.getFlatInteriorPoint = function() {
+ if (this.flatInteriorPointRevision_ != this.getRevision()) {
+ var flatCenter = ol.extent.getCenter(this.getExtent());
+ this.flatInteriorPoint_ = ol.geom.flat.interiorpoint.linearRings(
+ flatCenter, 0);
+ this.flatInteriorPointRevision_ = this.getRevision();
+ return this.flatInteriorPoint_;
+ * Return an interior point of the polygon.
+ * @return {ol.geom.Point} Interior point.
+ * @api
+ol.geom.Polygon.prototype.getInteriorPoint = function() {
+ return new ol.geom.Point(this.getFlatInteriorPoint());
+ * Return the number of rings of the polygon, this includes the exterior
+ * ring and any interior rings.
+ * @return {number} Number of rings.
+ * @api
+ol.geom.Polygon.prototype.getLinearRingCount = function() {
+ return this.ends_.length;
+ * Return the Nth linear ring of the polygon geometry. Return `null` if the
+ * given index is out of range.
+ * The exterior linear ring is available at index `0` and the interior rings
+ * at index `1` and beyond.
+ * @param {number} index Index.
+ * @return {ol.geom.LinearRing} Linear ring.
+ * @api
+ol.geom.Polygon.prototype.getLinearRing = function(index) {
+ if (index < 0 || this.ends_.length <= index) {
+ return null;
+ index === 0 ? 0 : this.ends_[index - 1], this.ends_[index]));
+ * Return the linear rings of the polygon.
+ * @return {Array.<ol.geom.LinearRing>} Linear rings.
+ * @api
+ol.geom.Polygon.prototype.getLinearRings = function() {
+ var layout = this.layout;
+ var ends = this.ends_;
+ var linearRings = [];
+ var offset = 0;
+ var i, ii;
+ linearRing.setFlatCoordinates(layout, flatCoordinates.slice(offset, end));
+ linearRings.push(linearRing);
+ offset = end;
+ return linearRings;
+ * @return {Array.<number>} Oriented flat coordinates.
+ol.geom.Polygon.prototype.getOrientedFlatCoordinates = function() {
+ if (this.orientedRevision_ != this.getRevision()) {
+ if (ol.geom.flat.orient.linearRingsAreOriented(
+ flatCoordinates, 0, this.ends_, this.stride)) {
+ this.orientedFlatCoordinates_ = flatCoordinates;
+ } else {
+ this.orientedFlatCoordinates_ = flatCoordinates.slice();
+ this.orientedFlatCoordinates_.length =
+ this.orientedFlatCoordinates_, 0, this.ends_, this.stride);
+ this.orientedRevision_ = this.getRevision();
+ return this.orientedFlatCoordinates_;
+ * @inheritDoc
+ol.geom.Polygon.prototype.getSimplifiedGeometryInternal = function(squaredTolerance) {
+ simplifiedFlatCoordinates.length = ol.geom.flat.simplify.quantizes(
+ Math.sqrt(squaredTolerance),
+ simplifiedFlatCoordinates, 0, simplifiedEnds);
+ var simplifiedPolygon = new ol.geom.Polygon(null);
+ simplifiedPolygon.setFlatCoordinates(
+ ol.geom.GeometryLayout.XY, simplifiedFlatCoordinates, simplifiedEnds);
+ return simplifiedPolygon;
+ * @inheritDoc
+ * @api
+ol.geom.Polygon.prototype.getType = function() {
+ return ol.geom.GeometryType.POLYGON;
+ * @inheritDoc
+ * @api
+ol.geom.Polygon.prototype.intersectsExtent = function(extent) {
+ return ol.geom.flat.intersectsextent.linearRings(
+ this.getOrientedFlatCoordinates(), 0, this.ends_, this.stride, extent);
+ * Set the coordinates of the polygon.
+ * @param {Array.<Array.<ol.Coordinate>>} coordinates Coordinates.
+ * @override
+ * @api
+ol.geom.Polygon.prototype.setCoordinates = function(coordinates, opt_layout) {
+ this.setFlatCoordinates(ol.geom.GeometryLayout.XY, null, this.ends_);
+ } else {
+ this.setLayout(opt_layout, coordinates, 2);
+ this.flatCoordinates, 0, coordinates, this.stride, this.ends_);
+ this.flatCoordinates.length = ends.length === 0 ? 0 : ends[ends.length - 1];
+ this.changed();
+ol.geom.Polygon.prototype.setFlatCoordinates = function(layout, flatCoordinates, ends) {
+ this.ends_ = ends;
+ this.changed();
+ * Create an approximation of a circle on the surface of a sphere.
+ * @param {ol.Sphere} sphere The sphere.
+ * @param {ol.Coordinate} center Center (`[lon, lat]` in degrees).
+ * @param {number} radius The great-circle distance from the center to
+ * the polygon vertices.
+ * @param {number=} opt_n Optional number of vertices for the resulting
+ * polygon. Default is `32`.
+ * @return {ol.geom.Polygon} The "circular" polygon.
+ * @api
+ol.geom.Polygon.circular = function(sphere, center, radius, opt_n) {
+ var n = opt_n ? opt_n : 32;
+ var flatCoordinates = [];
+ var i;
+ for (i = 0; i < n; ++i) {
+ ol.array.extend(
+ flatCoordinates, sphere.offset(center, radius, 2 * Math.PI * i / n));
+ flatCoordinates.push(flatCoordinates[0], flatCoordinates[1]);
+ ol.geom.GeometryLayout.XY, flatCoordinates, [flatCoordinates.length]);
+ return polygon;
+ * Create a polygon from an extent. The layout used is `XY`.
+ * @param {ol.Extent} extent The extent.
+ * @return {ol.geom.Polygon} The polygon.
+ * @api
+ol.geom.Polygon.fromExtent = function(extent) {
+ var minX = extent[0];
+ var minY = extent[1];
+ var maxX = extent[2];
+ var maxY = extent[3];
+ [minX, minY, minX, maxY, maxX, maxY, maxX, minY, minX, minY];
+ return polygon;
+ * Create a regular polygon from a circle.
+ * @param {ol.geom.Circle} circle Circle geometry.
+ * @param {number=} opt_sides Number of sides of the polygon. Default is 32.
+ * @param {number=} opt_angle Start angle for the first vertex of the polygon in
+ * radians. Default is 0.
+ * @return {ol.geom.Polygon} Polygon geometry.
+ * @api
+ol.geom.Polygon.fromCircle = function(circle, opt_sides, opt_angle) {
+ var sides = opt_sides ? opt_sides : 32;
+ var stride = circle.getStride();
+ var layout = circle.getLayout();
+ var polygon = new ol.geom.Polygon(null, layout);
+ var arrayLength = stride * (sides + 1);
+ var flatCoordinates = new Array(arrayLength);
+ for (var i = 0; i < arrayLength; i++) {
+ flatCoordinates[i] = 0;
+ var ends = [flatCoordinates.length];
+ polygon.setFlatCoordinates(layout, flatCoordinates, ends);
+ ol.geom.Polygon.makeRegular(
+ polygon, circle.getCenter(), circle.getRadius(), opt_angle);
+ return polygon;
+ * Modify the coordinates of a polygon to make it a regular polygon.
+ * @param {ol.geom.Polygon} polygon Polygon geometry.
+ * @param {ol.Coordinate} center Center of the regular polygon.
+ * @param {number} radius Radius of the regular polygon.
+ol.geom.Polygon.makeRegular = function(polygon, center, radius, opt_angle) {
+ var flatCoordinates = polygon.getFlatCoordinates();
+ var layout = polygon.getLayout();
+ var stride = polygon.getStride();
+ var ends = polygon.getEnds();
+ var sides = flatCoordinates.length / stride - 1;
+ var startAngle = opt_angle ? opt_angle : 0;
+ var angle, offset;
+ for (var i = 0; i <= sides; ++i) {
+ offset = i * stride;
+ angle = startAngle + (ol.math.modulo(i, sides) * 2 * Math.PI / sides);
+ flatCoordinates[offset] = center[0] + (radius * Math.cos(angle));
+ flatCoordinates[offset + 1] = center[1] + (radius * Math.sin(angle));
+goog.provide('ol.View');
+goog.require('ol.CenterConstraint');
+goog.require('ol.Constraints');
+goog.require('ol.Object');
+goog.require('ol.ResolutionConstraint');
+goog.require('ol.RotationConstraint');
+goog.require('ol.ViewHint');
+goog.require('ol.ViewProperty');
+goog.require('ol.asserts');
+goog.require('ol.coordinate');
+goog.require('ol.easing');
+goog.require('ol.extent');
+goog.require('ol.geom.Polygon');
+goog.require('ol.obj');
+goog.require('ol.proj');
+goog.require('ol.proj.Units');
+ * @classdesc
+ * An ol.View object represents a simple 2D view of the map.
+ * This is the object to act upon to change the center, resolution,
+ * and rotation of the map.
+ * ### The view states
+ * An `ol.View` is determined by three states: `center`, `resolution`,
+ * and `rotation`. Each state has a corresponding getter and setter, e.g.
+ * `getCenter` and `setCenter` for the `center` state.
+ * An `ol.View` has a `projection`. The projection determines the
+ * coordinate system of the center, and its units determine the units of the
+ * resolution (projection units per pixel). The default projection is
+ * Spherical Mercator (EPSG:3857).
+ * ### The constraints
+ * `setCenter`, `setResolution` and `setRotation` can be used to change the
+ * states of the view. Any value can be passed to the setters. And the value
+ * that is passed to a setter will effectively be the value set in the view,
+ * and returned by the corresponding getter.
+ * But an `ol.View` object also has a *resolution constraint*, a
+ * *rotation constraint* and a *center constraint*.
+ * As said above, no constraints are applied when the setters are used to set
+ * new states for the view. Applying constraints is done explicitly through
+ * the use of the `constrain*` functions (`constrainResolution` and
+ * `constrainRotation` and `constrainCenter`).
+ * The main users of the constraints are the interactions and the
+ * controls. For example, double-clicking on the map changes the view to
+ * the "next" resolution. And releasing the fingers after pinch-zooming
+ * snaps to the closest resolution (with an animation).
+ * The *resolution constraint* snaps to specific resolutions. It is
+ * determined by the following options: `resolutions`, `maxResolution`,
+ * `maxZoom`, and `zoomFactor`. If `resolutions` is set, the other three
+ * options are ignored. See documentation for each option for more
+ * information.
+ * The *rotation constraint* snaps to specific angles. It is determined
+ * by the following options: `enableRotation` and `constrainRotation`.
+ * By default the rotation value is snapped to zero when approaching the
+ * horizontal.
+ * The *center constraint* is determined by the `extent` option. By
+ * default the center is not constrained at all.
+ * @constructor
+ * @extends {ol.Object}
+ * @param {olx.ViewOptions=} opt_options View options.
+ * @api
+ol.View = function(opt_options) {
+ ol.Object.call(this);
+ var options = ol.obj.assign({}, opt_options);
+ * @private
+ this.hints_ = [0, 0];
+ * @private
+ * @type {Array.<Array.<ol.ViewAnimation>>}
+ this.animations_ = [];
+ * @private
+ * @type {number|undefined}
+ this.updateAnimationKey_;
+ this.updateAnimations_ = this.updateAnimations_.bind(this);
+ * @private
+ * @const
+ * @type {ol.proj.Projection}
+ this.projection_ = ol.proj.createProjection(options.projection, 'EPSG:3857');
+ this.applyOptions_(options);
+ol.inherits(ol.View, ol.Object);
+ * Set up the view with the given options.
+ * @param {olx.ViewOptions} options View options.
+ol.View.prototype.applyOptions_ = function(options) {
+ * @type {Object.<string, *>}
+ var properties = {};
+ properties[ol.ViewProperty.CENTER] = options.center !== undefined ?
+ options.center : null;
+ var resolutionConstraintInfo = ol.View.createResolutionConstraint_(
+ options);
+ * @private
+ * @type {number}
+ this.maxResolution_ = resolutionConstraintInfo.maxResolution;
+ * @private
+ * @type {number}
+ this.minResolution_ = resolutionConstraintInfo.minResolution;
+ * @private
+ * @type {number}
+ this.zoomFactor_ = resolutionConstraintInfo.zoomFactor;
+ * @private
+ * @type {Array.<number>|undefined}
+ this.resolutions_ = options.resolutions;
+ * @private
+ * @type {number}
+ this.minZoom_ = resolutionConstraintInfo.minZoom;
+ var centerConstraint = ol.View.createCenterConstraint_(options);
+ var resolutionConstraint = resolutionConstraintInfo.constraint;
+ var rotationConstraint = ol.View.createRotationConstraint_(options);
+ * @private
+ * @type {ol.Constraints}
+ this.constraints_ = new ol.Constraints(
+ centerConstraint, resolutionConstraint, rotationConstraint);
+ if (options.resolution !== undefined) {
+ properties[ol.ViewProperty.RESOLUTION] = options.resolution;
+ } else if (options.zoom !== undefined) {
+ properties[ol.ViewProperty.RESOLUTION] = this.constrainResolution(
+ this.maxResolution_, options.zoom - this.minZoom_);
+ properties[ol.ViewProperty.ROTATION] =
+ options.rotation !== undefined ? options.rotation : 0;
+ this.setProperties(properties);
+ * @private
+ * @type {olx.ViewOptions}
+ this.options_ = options;
+ * Get an updated version of the view options used to construct the view. The
+ * current resolution (or zoom), center, and rotation are applied to any stored
+ * options. The provided options can be uesd to apply new min/max zoom or
+ * resolution limits.
+ * @param {olx.ViewOptions} newOptions New options to be applied.
+ * @return {olx.ViewOptions} New options updated with the current view state.
+ol.View.prototype.getUpdatedOptions_ = function(newOptions) {
+ var options = ol.obj.assign({}, this.options_);
+ // preserve resolution (or zoom)
+ options.resolution = this.getResolution();
+ } else {
+ options.zoom = this.getZoom();
+ // preserve center
+ options.center = this.getCenter();
+ // preserve rotation
+ options.rotation = this.getRotation();
+ return ol.obj.assign({}, options, newOptions);
+ * Animate the view. The view's center, zoom (or resolution), and rotation
+ * can be animated for smooth transitions between view states. For example,
+ * to animate the view to a new zoom level:
+ * view.animate({zoom: view.getZoom() + 1});
+ * By default, the animation lasts one second and uses in-and-out easing. You
+ * can customize this behavior by including `duration` (in milliseconds) and
+ * `easing` options (see {@link ol.easing}).
+ * To chain together multiple animations, call the method with multiple
+ * animation objects. For example, to first zoom and then pan:
+ * view.animate({zoom: 10}, {center: [0, 0]});
+ * If you provide a function as the last argument to the animate method, it
+ * will get called at the end of an animation series. The callback will be
+ * called with `true` if the animation series completed on its own or `false`
+ * if it was cancelled.
+ * Animations are cancelled by user interactions (e.g. dragging the map) or by
+ * calling `view.setCenter()`, `view.setResolution()`, or `view.setRotation()`
+ * (or another method that calls one of these).
+ * @param {...(olx.AnimationOptions|function(boolean))} var_args Animation
+ * options. Multiple animations can be run in series by passing multiple
+ * options objects. To run multiple animations in parallel, call the method
+ * multiple times. An optional callback can be provided as a final
+ * argument. The callback will be called with a boolean indicating whether
+ * the animation completed without being cancelled.
+ * @api
+ol.View.prototype.animate = function(var_args) {
+ var start = Date.now();
+ var center = this.getCenter().slice();
+ var resolution = this.getResolution();
+ var rotation = this.getRotation();
+ var animationCount = arguments.length;
+ var callback;
+ if (animationCount > 1 && typeof arguments[animationCount - 1] === 'function') {
+ callback = arguments[animationCount - 1];
+ --animationCount;
+ var series = [];
+ for (var i = 0; i < animationCount; ++i) {
+ var options = /** @type {olx.AnimationOptions} */ (arguments[i]);
+ var animation = /** @type {ol.ViewAnimation} */ ({
+ start: start,
+ complete: false,
+ anchor: options.anchor,
+ duration: options.duration !== undefined ? options.duration : 1000,
+ easing: options.easing || ol.easing.inAndOut
+ if (options.center) {
+ animation.sourceCenter = center;
+ animation.targetCenter = options.center;
+ center = animation.targetCenter;
+ if (options.zoom !== undefined) {
+ animation.sourceResolution = resolution;
+ animation.targetResolution = this.constrainResolution(
+ this.maxResolution_, options.zoom - this.minZoom_, 0);
+ resolution = animation.targetResolution;
+ } else if (options.resolution) {
+ animation.targetResolution = options.resolution;
+ if (options.rotation !== undefined) {
+ animation.sourceRotation = rotation;
+ animation.targetRotation = options.rotation;
+ rotation = animation.targetRotation;
+ animation.callback = callback;
+ start += animation.duration;
+ series.push(animation);
+ this.animations_.push(series);
+ this.setHint(ol.ViewHint.ANIMATING, 1);
+ this.updateAnimations_();
+ * Determine if the view is being animated.
+ * @return {boolean} The view is being animated.
+ * @api
+ol.View.prototype.getAnimating = function() {
+ return this.getHints()[ol.ViewHint.ANIMATING] > 0;
+ * Cancel any ongoing animations.
+ * @api
+ol.View.prototype.cancelAnimations = function() {
+ this.setHint(ol.ViewHint.ANIMATING, -this.getHints()[ol.ViewHint.ANIMATING]);
+ for (var i = 0, ii = this.animations_.length; i < ii; ++i) {
+ var series = this.animations_[i];
+ if (series[0].callback) {
+ series[0].callback(false);
+ this.animations_.length = 0;
+ * Update all animations.
+ol.View.prototype.updateAnimations_ = function() {
+ if (this.updateAnimationKey_ !== undefined) {
+ cancelAnimationFrame(this.updateAnimationKey_);
+ this.updateAnimationKey_ = undefined;
+ if (!this.getAnimating()) {
+ return;
+ var now = Date.now();
+ var more = false;
+ for (var i = this.animations_.length - 1; i >= 0; --i) {
+ var seriesComplete = true;
+ for (var j = 0, jj = series.length; j < jj; ++j) {
+ var animation = series[j];
+ if (animation.complete) {
+ continue;
+ var elapsed = now - animation.start;
+ var fraction = animation.duration > 0 ? elapsed / animation.duration : 1;
+ if (fraction >= 1) {
+ animation.complete = true;
+ fraction = 1;
+ } else {
+ seriesComplete = false;
+ var progress = animation.easing(fraction);
+ if (animation.sourceCenter) {
+ var x0 = animation.sourceCenter[0];
+ var y0 = animation.sourceCenter[1];
+ var x1 = animation.targetCenter[0];
+ var y1 = animation.targetCenter[1];
+ var x = x0 + progress * (x1 - x0);
+ var y = y0 + progress * (y1 - y0);
+ this.set(ol.ViewProperty.CENTER, [x, y]);
+ if (animation.sourceResolution && animation.targetResolution) {
+ var resolution = progress === 1 ?
+ animation.targetResolution :
+ animation.sourceResolution + progress * (animation.targetResolution - animation.sourceResolution);
+ if (animation.anchor) {
+ this.calculateCenterZoom(resolution, animation.anchor));
+ this.set(ol.ViewProperty.RESOLUTION, resolution);
+ if (animation.sourceRotation !== undefined && animation.targetRotation !== undefined) {
+ var rotation = progress === 1 ?
+ animation.targetRotation :
+ animation.sourceRotation + progress * (animation.targetRotation - animation.sourceRotation);
+ this.calculateCenterRotate(rotation, animation.anchor));
+ this.set(ol.ViewProperty.ROTATION, rotation);
+ more = true;
+ if (!animation.complete) {
+ break;
+ if (seriesComplete) {
+ this.animations_[i] = null;
+ this.setHint(ol.ViewHint.ANIMATING, -1);
+ var callback = series[0].callback;
+ if (callback) {
+ callback(true);
+ // prune completed series
+ this.animations_ = this.animations_.filter(Boolean);
+ if (more && this.updateAnimationKey_ === undefined) {
+ this.updateAnimationKey_ = requestAnimationFrame(this.updateAnimations_);
+ * @param {number} rotation Target rotation.
+ * @param {ol.Coordinate} anchor Rotation anchor.
+ * @return {ol.Coordinate|undefined} Center for rotation and anchor.
+ol.View.prototype.calculateCenterRotate = function(rotation, anchor) {
+ var center;
+ var currentCenter = this.getCenter();
+ if (currentCenter !== undefined) {
+ center = [currentCenter[0] - anchor[0], currentCenter[1] - anchor[1]];
+ ol.coordinate.rotate(center, rotation - this.getRotation());
+ ol.coordinate.add(center, anchor);
+ return center;
+ * @param {number} resolution Target resolution.
+ * @param {ol.Coordinate} anchor Zoom anchor.
+ * @return {ol.Coordinate|undefined} Center for resolution and anchor.
+ol.View.prototype.calculateCenterZoom = function(resolution, anchor) {
+ var center;
+ var currentResolution = this.getResolution();
+ if (currentCenter !== undefined && currentResolution !== undefined) {
+ var x = anchor[0] -
+ resolution * (anchor[0] - currentCenter[0]) / currentResolution;
+ var y = anchor[1] -
+ resolution * (anchor[1] - currentCenter[1]) / currentResolution;
+ center = [x, y];
+ return center;
+ * @private
+ * @return {ol.Size} Viewport size or `[100, 100]` when no viewport is found.
+ol.View.prototype.getSizeFromViewport_ = function() {
+ var size = [100, 100];
+ var selector = '.ol-viewport[data-view="' + ol.getUid(this) + '"]';
+ var element = document.querySelector(selector);
+ if (element) {
+ var metrics = getComputedStyle(element);
+ size[0] = parseInt(metrics.width, 10);
+ size[1] = parseInt(metrics.height, 10);
+ return size;
+ * Get the constrained center of this view.
+ * @param {ol.Coordinate|undefined} center Center.
+ * @return {ol.Coordinate|undefined} Constrained center.
+ * @api
+ol.View.prototype.constrainCenter = function(center) {
+ return this.constraints_.center(center);
+ * Get the constrained resolution of this view.
+ * @param {number|undefined} resolution Resolution.
+ * @param {number=} opt_delta Delta. Default is `0`.
+ * @param {number=} opt_direction Direction. Default is `0`.
+ * @return {number|undefined} Constrained resolution.
+ * @api
+ol.View.prototype.constrainResolution = function(
+ resolution, opt_delta, opt_direction) {
+ var delta = opt_delta || 0;
+ var direction = opt_direction || 0;
+ return this.constraints_.resolution(resolution, delta, direction);
+ * Get the constrained rotation of this view.
+ * @param {number|undefined} rotation Rotation.
+ * @return {number|undefined} Constrained rotation.
+ * @api
+ol.View.prototype.constrainRotation = function(rotation, opt_delta) {
+ return this.constraints_.rotation(rotation, delta);
+ * Get the view center.
+ * @return {ol.Coordinate|undefined} The center of the view.
+ * @observable
+ * @api
+ol.View.prototype.getCenter = function() {
+ return /** @type {ol.Coordinate|undefined} */ (
+ this.get(ol.ViewProperty.CENTER));
+ * @param {Array.<number>=} opt_hints Destination array.
+ * @return {Array.<number>} Hint.
+ol.View.prototype.getHints = function(opt_hints) {
+ if (opt_hints !== undefined) {
+ opt_hints[0] = this.hints_[0];
+ opt_hints[1] = this.hints_[1];
+ return opt_hints;
+ } else {
+ return this.hints_.slice();
+ * Calculate the extent for the current view state and the passed size.
+ * The size is the pixel dimensions of the box into which the calculated extent
+ * should fit. In most cases you want to get the extent of the entire map,
+ * that is `map.getSize()`.
+ * @param {ol.Size=} opt_size Box pixel size. If not provided, the size of the
+ * first map that uses this view will be used.
+ * @return {ol.Extent} Extent.
+ * @api
+ol.View.prototype.calculateExtent = function(opt_size) {
+ var size = opt_size || this.getSizeFromViewport_();
+ var center = /** @type {!ol.Coordinate} */ (this.getCenter());
+ ol.asserts.assert(center, 1); // The view center is not defined
+ var resolution = /** @type {!number} */ (this.getResolution());
+ ol.asserts.assert(resolution !== undefined, 2); // The view resolution is not defined
+ var rotation = /** @type {!number} */ (this.getRotation());
+ ol.asserts.assert(rotation !== undefined, 3); // The view rotation is not defined
+ return ol.extent.getForViewAndSize(center, resolution, rotation, size);
+ * Get the maximum resolution of the view.
+ * @return {number} The maximum resolution of the view.
+ * @api
+ol.View.prototype.getMaxResolution = function() {
+ return this.maxResolution_;
+ * Get the minimum resolution of the view.
+ * @return {number} The minimum resolution of the view.
+ * @api
+ol.View.prototype.getMinResolution = function() {
+ return this.minResolution_;
+ * Get the maximum zoom level for the view.
+ * @return {number} The maximum zoom level.
+ * @api
+ol.View.prototype.getMaxZoom = function() {
+ return /** @type {number} */ (this.getZoomForResolution(this.minResolution_));
+ * Set a new maximum zoom level for the view.
+ * @param {number} zoom The maximum zoom level.
+ * @api
+ol.View.prototype.setMaxZoom = function(zoom) {
+ this.applyOptions_(this.getUpdatedOptions_({maxZoom: zoom}));
+ * Get the minimum zoom level for the view.
+ * @return {number} The minimum zoom level.
+ * @api
+ol.View.prototype.getMinZoom = function() {
+ return /** @type {number} */ (this.getZoomForResolution(this.maxResolution_));
+ * Set a new minimum zoom level for the view.
+ * @param {number} zoom The minimum zoom level.
+ * @api
+ol.View.prototype.setMinZoom = function(zoom) {
+ this.applyOptions_(this.getUpdatedOptions_({minZoom: zoom}));
+ * Get the view projection.
+ * @return {ol.proj.Projection} The projection of the view.
+ * @api
+ol.View.prototype.getProjection = function() {
+ return this.projection_;
+ * Get the view resolution.
+ * @return {number|undefined} The resolution of the view.
+ * @observable
+ * @api
+ol.View.prototype.getResolution = function() {
+ return /** @type {number|undefined} */ (
+ this.get(ol.ViewProperty.RESOLUTION));
+ * Get the resolutions for the view. This returns the array of resolutions
+ * passed to the constructor of the {ol.View}, or undefined if none were given.
+ * @return {Array.<number>|undefined} The resolutions of the view.
+ * @api
+ol.View.prototype.getResolutions = function() {
+ return this.resolutions_;
+ * Get the resolution for a provided extent (in map units) and size (in pixels).
+ * @param {ol.Extent} extent Extent.
+ * @param {ol.Size} size Box pixel size.
+ * @return {number} The resolution at which the provided extent will render at
+ * the given size.
+ol.View.prototype.getResolutionForExtent = function(extent, size) {
+ var xResolution = ol.extent.getWidth(extent) / size[0];
+ var yResolution = ol.extent.getHeight(extent) / size[1];
+ return Math.max(xResolution, yResolution);
+ * Return a function that returns a value between 0 and 1 for a
+ * resolution. Exponential scaling is assumed.
+ * @param {number=} opt_power Power.
+ * @return {function(number): number} Resolution for value function.
+ol.View.prototype.getResolutionForValueFunction = function(opt_power) {
+ var power = opt_power || 2;
+ var maxResolution = this.maxResolution_;
+ var minResolution = this.minResolution_;
+ var max = Math.log(maxResolution / minResolution) / Math.log(power);
+ return (
+ * @return {number} Resolution.
+ function(value) {
+ var resolution = maxResolution / Math.pow(power, value * max);
+ return resolution;
+ * Get the view rotation.
+ * @return {number} The rotation of the view in radians.
+ * @observable
+ * @api
+ol.View.prototype.getRotation = function() {
+ return /** @type {number} */ (this.get(ol.ViewProperty.ROTATION));
+ * Return a function that returns a resolution for a value between
+ * 0 and 1. Exponential scaling is assumed.
+ * @return {function(number): number} Value for resolution function.
+ol.View.prototype.getValueForResolutionFunction = function(opt_power) {
+ return (
+ * @param {number} resolution Resolution.
+ * @return {number} Value.
+ function(resolution) {
+ var value =
+ (Math.log(maxResolution / resolution) / Math.log(power)) / max;
+ return value;
+ * @return {olx.ViewState} View state.
+ol.View.prototype.getState = function() {
+ var center = /** @type {ol.Coordinate} */ (this.getCenter());
+ var projection = this.getProjection();
+ var resolution = /** @type {number} */ (this.getResolution());
+ return /** @type {olx.ViewState} */ ({
+ center: center.slice(),
+ projection: projection !== undefined ? projection : null,
+ resolution: resolution,
+ rotation: rotation
+ * Get the current zoom level. Return undefined if the current
+ * resolution is undefined or not within the "resolution constraints".
+ * @return {number|undefined} Zoom.
+ * @api
+ol.View.prototype.getZoom = function() {
+ var zoom;
+ if (resolution !== undefined) {
+ zoom = this.getZoomForResolution(resolution);
+ return zoom;
+ * Get the zoom level for a resolution.
+ * @param {number} resolution The resolution.
+ * @return {number|undefined} The zoom level for the provided resolution.
+ * @api
+ol.View.prototype.getZoomForResolution = function(resolution) {
+ var zoom;
+ if (resolution >= this.minResolution_ && resolution <= this.maxResolution_) {
+ var offset = this.minZoom_ || 0;
+ var max, zoomFactor;
+ if (this.resolutions_) {
+ var nearest = ol.array.linearFindNearest(this.resolutions_, resolution, 1);
+ offset += nearest;
+ if (nearest == this.resolutions_.length - 1) {
+ return offset;
+ max = this.resolutions_[nearest];
+ zoomFactor = max / this.resolutions_[nearest + 1];
+ } else {
+ max = this.maxResolution_;
+ zoomFactor = this.zoomFactor_;
+ zoom = offset + Math.log(max / resolution) / Math.log(zoomFactor);
+ return zoom;
+ * Fit the given geometry or extent based on the given map size and border.
+ * The size is pixel dimensions of the box to fit the extent into.
+ * In most cases you will want to use the map size, that is `map.getSize()`.
+ * Takes care of the map angle.
+ * @param {ol.geom.SimpleGeometry|ol.Extent} geometryOrExtent The geometry or
+ * extent to fit the view to.
+ * @param {olx.view.FitOptions=} opt_options Options.
+ * @api
+ol.View.prototype.fit = function(geometryOrExtent, opt_options) {
+ var options = opt_options || {};
+ var size = options.size;
+ if (!size) {
+ size = this.getSizeFromViewport_();
+ /** @type {ol.geom.SimpleGeometry} */
+ var geometry;
+ if (!(geometryOrExtent instanceof ol.geom.SimpleGeometry)) {
+ ol.asserts.assert(Array.isArray(geometryOrExtent),
+ 24); // Invalid extent or geometry provided as `geometry`
+ ol.asserts.assert(!ol.extent.isEmpty(geometryOrExtent),
+ 25); // Cannot fit empty extent provided as `geometry`
+ geometry = ol.geom.Polygon.fromExtent(geometryOrExtent);
+ } else if (geometryOrExtent.getType() === ol.geom.GeometryType.CIRCLE) {
+ geometryOrExtent = geometryOrExtent.getExtent();
+ geometry.rotate(this.getRotation(), ol.extent.getCenter(geometryOrExtent));
+ } else {
+ geometry = geometryOrExtent;
+ var padding = options.padding !== undefined ? options.padding : [0, 0, 0, 0];
+ var constrainResolution = options.constrainResolution !== undefined ?
+ options.constrainResolution : true;
+ var nearest = options.nearest !== undefined ? options.nearest : false;
+ var minResolution;
+ if (options.minResolution !== undefined) {
+ minResolution = options.minResolution;
+ } else if (options.maxZoom !== undefined) {
+ minResolution = this.constrainResolution(
+ this.maxResolution_, options.maxZoom - this.minZoom_, 0);
+ } else {
+ minResolution = 0;
+ var coords = geometry.getFlatCoordinates();
+ // calculate rotated extent
+ var cosAngle = Math.cos(-rotation);
+ var sinAngle = Math.sin(-rotation);
+ var minRotX = +Infinity;
+ var minRotY = +Infinity;
+ var maxRotX = -Infinity;
+ var maxRotY = -Infinity;
+ var stride = geometry.getStride();
+ for (var i = 0, ii = coords.length; i < ii; i += stride) {
+ var rotX = coords[i] * cosAngle - coords[i + 1] * sinAngle;
+ var rotY = coords[i] * sinAngle + coords[i + 1] * cosAngle;
+ minRotX = Math.min(minRotX, rotX);
+ minRotY = Math.min(minRotY, rotY);
+ maxRotX = Math.max(maxRotX, rotX);
+ maxRotY = Math.max(maxRotY, rotY);
+ // calculate resolution
+ var resolution = this.getResolutionForExtent(
+ [minRotX, minRotY, maxRotX, maxRotY],
+ [size[0] - padding[1] - padding[3], size[1] - padding[0] - padding[2]]);
+ resolution = isNaN(resolution) ? minResolution :
+ Math.max(resolution, minResolution);
+ if (constrainResolution) {
+ var constrainedResolution = this.constrainResolution(resolution, 0, 0);
+ if (!nearest && constrainedResolution < resolution) {
+ constrainedResolution = this.constrainResolution(
+ constrainedResolution, -1, 0);
+ resolution = constrainedResolution;
+ // calculate center
+ sinAngle = -sinAngle; // go back to original rotation
+ var centerRotX = (minRotX + maxRotX) / 2;
+ var centerRotY = (minRotY + maxRotY) / 2;
+ centerRotX += (padding[1] - padding[3]) / 2 * resolution;
+ centerRotY += (padding[0] - padding[2]) / 2 * resolution;
+ var centerX = centerRotX * cosAngle - centerRotY * sinAngle;
+ var centerY = centerRotY * cosAngle + centerRotX * sinAngle;
+ var center = [centerX, centerY];
+ if (options.duration !== undefined) {
+ this.animate({
+ center: center,
+ duration: options.duration,
+ } else {
+ this.setResolution(resolution);
+ this.setCenter(center);
+ * Center on coordinate and view position.
+ * @param {ol.Coordinate} coordinate Coordinate.
+ * @param {ol.Pixel} position Position on the view to center on.
+ * @api
+ol.View.prototype.centerOn = function(coordinate, size, position) {
+ // calculate rotated position
+ var rotX = coordinate[0] * cosAngle - coordinate[1] * sinAngle;
+ var rotY = coordinate[1] * cosAngle + coordinate[0] * sinAngle;
+ rotX += (size[0] / 2 - position[0]) * resolution;
+ rotY += (position[1] - size[1] / 2) * resolution;
+ // go back to original angle
+ var centerX = rotX * cosAngle - rotY * sinAngle;
+ var centerY = rotY * cosAngle + rotX * sinAngle;
+ this.setCenter([centerX, centerY]);
+ * @return {boolean} Is defined.
+ol.View.prototype.isDef = function() {
+ return !!this.getCenter() && this.getResolution() !== undefined;
+ * Rotate the view around a given coordinate.
+ * @param {number} rotation New rotation value for the view.
+ * @param {ol.Coordinate=} opt_anchor The rotation center.
+ * @api
+ol.View.prototype.rotate = function(rotation, opt_anchor) {
+ if (opt_anchor !== undefined) {
+ var center = this.calculateCenterRotate(rotation, opt_anchor);
+ this.setRotation(rotation);
+ * Set the center of the current view.
+ * @param {ol.Coordinate|undefined} center The center of the view.
+ * @observable
+ * @api
+ol.View.prototype.setCenter = function(center) {
+ this.set(ol.ViewProperty.CENTER, center);
+ if (this.getAnimating()) {
+ this.cancelAnimations();
+ * @param {ol.ViewHint} hint Hint.
+ * @param {number} delta Delta.
+ * @return {number} New value.
+ol.View.prototype.setHint = function(hint, delta) {
+ this.hints_[hint] += delta;
+ this.changed();
+ return this.hints_[hint];
+ * Set the resolution for this view.
+ * @param {number|undefined} resolution The resolution of the view.
+ * @observable
+ * @api
+ol.View.prototype.setResolution = function(resolution) {
+ * Set the rotation for this view.
+ * @param {number} rotation The rotation of the view in radians.
+ * @observable
+ * @api
+ol.View.prototype.setRotation = function(rotation) {
+ * Zoom to a specific zoom level.
+ * @param {number} zoom Zoom level.
+ * @api
+ol.View.prototype.setZoom = function(zoom) {
+ var resolution = this.constrainResolution(
+ this.maxResolution_, zoom - this.minZoom_, 0);
+ * @private
+ * @return {ol.CenterConstraintType} The constraint.
+ol.View.createCenterConstraint_ = function(options) {
+ if (options.extent !== undefined) {
+ return ol.CenterConstraint.createExtent(options.extent);
+ } else {
+ return ol.CenterConstraint.none;
+ * @private
+ * @return {{constraint: ol.ResolutionConstraintType, maxResolution: number,
+ * minResolution: number, zoomFactor: number}} The constraint.
+ol.View.createResolutionConstraint_ = function(options) {
+ var resolutionConstraint;
+ var maxResolution;
+ // TODO: move these to be ol constants
+ // see https://github.com/openlayers/openlayers/issues/2076
+ var defaultMaxZoom = 28;
+ var defaultZoomFactor = 2;
+ var minZoom = options.minZoom !== undefined ?
+ options.minZoom : ol.DEFAULT_MIN_ZOOM;
+ var maxZoom = options.maxZoom !== undefined ?
+ options.maxZoom : defaultMaxZoom;
+ var zoomFactor = options.zoomFactor !== undefined ?
+ options.zoomFactor : defaultZoomFactor;
+ if (options.resolutions !== undefined) {
+ var resolutions = options.resolutions;
+ maxResolution = resolutions[0];
+ minResolution = resolutions[resolutions.length - 1];
+ resolutionConstraint = ol.ResolutionConstraint.createSnapToResolutions(
+ resolutions);
+ } else {
+ // calculate the default min and max resolution
+ var projection = ol.proj.createProjection(options.projection, 'EPSG:3857');
+ var extent = projection.getExtent();
+ var size = !extent ?
+ // use an extent that can fit the whole world if need be
+ 360 * ol.proj.METERS_PER_UNIT[ol.proj.Units.DEGREES] /
+ projection.getMetersPerUnit() :
+ Math.max(ol.extent.getWidth(extent), ol.extent.getHeight(extent));
+ var defaultMaxResolution = size / ol.DEFAULT_TILE_SIZE / Math.pow(
+ defaultZoomFactor, ol.DEFAULT_MIN_ZOOM);
+ var defaultMinResolution = defaultMaxResolution / Math.pow(
+ defaultZoomFactor, defaultMaxZoom - ol.DEFAULT_MIN_ZOOM);
+ // user provided maxResolution takes precedence
+ maxResolution = options.maxResolution;
+ if (maxResolution !== undefined) {
+ minZoom = 0;
+ } else {
+ maxResolution = defaultMaxResolution / Math.pow(zoomFactor, minZoom);
+ // user provided minResolution takes precedence
+ if (minResolution === undefined) {
+ if (options.maxZoom !== undefined) {
+ if (options.maxResolution !== undefined) {
+ minResolution = maxResolution / Math.pow(zoomFactor, maxZoom);
+ } else {
+ minResolution = defaultMaxResolution / Math.pow(zoomFactor, maxZoom);
+ } else {
+ minResolution = defaultMinResolution;
+ // given discrete zoom levels, minResolution may be different than provided
+ maxZoom = minZoom + Math.floor(
+ Math.log(maxResolution / minResolution) / Math.log(zoomFactor));
+ minResolution = maxResolution / Math.pow(zoomFactor, maxZoom - minZoom);
+ resolutionConstraint = ol.ResolutionConstraint.createSnapToPower(
+ zoomFactor, maxResolution, maxZoom - minZoom);
+ return {constraint: resolutionConstraint, maxResolution: maxResolution,
+ minResolution: minResolution, minZoom: minZoom, zoomFactor: zoomFactor};
+ * @private
+ * @return {ol.RotationConstraintType} Rotation constraint.
+ol.View.createRotationConstraint_ = function(options) {
+ var enableRotation = options.enableRotation !== undefined ?
+ options.enableRotation : true;
+ if (enableRotation) {
+ var constrainRotation = options.constrainRotation;
+ if (constrainRotation === undefined || constrainRotation === true) {
+ return ol.RotationConstraint.createSnapToZero();
+ } else if (constrainRotation === false) {
+ return ol.RotationConstraint.none;
+ } else if (typeof constrainRotation === 'number') {
+ return ol.RotationConstraint.createSnapToN(constrainRotation);
+ } else {
+ } else {
+ return ol.RotationConstraint.disable;
+goog.provide('ol.Kinetic');
+ * @classdesc
+ * Implementation of inertial deceleration for map movement.
+ * @constructor
+ * @param {number} decay Rate of decay (must be negative).
+ * @param {number} minVelocity Minimum velocity (pixels/millisecond).
+ * @param {number} delay Delay to consider to calculate the kinetic
+ * initial values (milliseconds).
+ * @struct
+ * @api
+ol.Kinetic = function(decay, minVelocity, delay) {
+ * @private
+ * @type {number}
+ this.decay_ = decay;
+ * @private
+ * @type {number}
+ this.minVelocity_ = minVelocity;
+ * @private
+ * @type {number}
+ this.delay_ = delay;
+ * @private
+ this.points_ = [];
+ * @private
+ * @type {number}
+ this.angle_ = 0;
+ * @private
+ * @type {number}
+ this.initialVelocity_ = 0;
+ * FIXME empty description for jsdoc
+ol.Kinetic.prototype.begin = function() {
+ this.points_.length = 0;
+ this.angle_ = 0;
+ * @param {number} x X.
+ * @param {number} y Y.
+ol.Kinetic.prototype.update = function(x, y) {
+ this.points_.push(x, y, Date.now());
+ * @return {boolean} Whether we should do kinetic animation.
+ol.Kinetic.prototype.end = function() {
+ if (this.points_.length < 6) {
+ // at least 2 points are required (i.e. there must be at least 6 elements
+ // in the array)
+ return false;
+ var delay = Date.now() - this.delay_;
+ var lastIndex = this.points_.length - 3;
+ if (this.points_[lastIndex + 2] < delay) {
+ // the last tracked point is too old, which means that the user stopped
+ // panning before releasing the map
+ return false;
+ // get the first point which still falls into the delay time
+ var firstIndex = lastIndex - 3;
+ while (firstIndex > 0 && this.points_[firstIndex + 2] > delay) {
+ firstIndex -= 3;
+ var duration = this.points_[lastIndex + 2] - this.points_[firstIndex + 2];
+ var dx = this.points_[lastIndex] - this.points_[firstIndex];
+ var dy = this.points_[lastIndex + 1] - this.points_[firstIndex + 1];
+ this.angle_ = Math.atan2(dy, dx);
+ this.initialVelocity_ = Math.sqrt(dx * dx + dy * dy) / duration;
+ return this.initialVelocity_ > this.minVelocity_;
+ * @return {number} Total distance travelled (pixels).
+ol.Kinetic.prototype.getDistance = function() {
+ return (this.minVelocity_ - this.initialVelocity_) / this.decay_;
+ * @return {number} Angle of the kinetic panning animation (radians).
+ol.Kinetic.prototype.getAngle = function() {
+ return this.angle_;
+goog.provide('ol.interaction.Property');
+ * @enum {string}
+ol.interaction.Property = {
+ ACTIVE: 'active'
+// FIXME factor out key precondition (shift et. al)
+goog.provide('ol.interaction.Interaction');
+goog.require('ol.interaction.Property');
+ * @classdesc
+ * Abstract base class; normally only used for creating subclasses and not
+ * instantiated in apps.
+ * User actions that change the state of the map. Some are similar to controls,
+ * but are not associated with a DOM element.
+ * For example, {@link ol.interaction.KeyboardZoom} is functionally the same as
+ * {@link ol.control.Zoom}, but triggered by a keyboard event not a button
+ * element event.
+ * Although interactions do not have a DOM element, some of them do render
+ * vectors and so are visible on the screen.
+ * @constructor
+ * @param {olx.interaction.InteractionOptions} options Options.
+ * @api
+ol.interaction.Interaction = function(options) {
+ * @private
+ * @type {ol.Map}
+ this.map_ = null;
+ this.setActive(true);
+ * @type {function(ol.MapBrowserEvent):boolean}
+ this.handleEvent = options.handleEvent;
+ol.inherits(ol.interaction.Interaction, ol.Object);
+ * Return whether the interaction is currently active.
+ * @return {boolean} `true` if the interaction is active, `false` otherwise.
+ * @observable
+ * @api
+ol.interaction.Interaction.prototype.getActive = function() {
+ return /** @type {boolean} */ (
+ this.get(ol.interaction.Property.ACTIVE));
+ * Get the map associated with this interaction.
+ * @return {ol.Map} Map.
+ * @api
+ol.interaction.Interaction.prototype.getMap = function() {
+ return this.map_;
+ * Activate or deactivate the interaction.
+ * @param {boolean} active Active.
+ * @observable
+ * @api
+ol.interaction.Interaction.prototype.setActive = function(active) {
+ this.set(ol.interaction.Property.ACTIVE, active);
+ * Remove the interaction from its current map and attach it to the new map.
+ * Subclasses may set up event handlers to get notified about changes to
+ * the map here.
+ * @param {ol.Map} map Map.
+ol.interaction.Interaction.prototype.setMap = function(map) {
+ this.map_ = map;
+ * @param {ol.View} view View.
+ * @param {ol.Coordinate} delta Delta.
+ * @param {number=} opt_duration Duration.
+ol.interaction.Interaction.pan = function(view, delta, opt_duration) {
+ var currentCenter = view.getCenter();
+ if (currentCenter) {
+ var center = view.constrainCenter(
+ [currentCenter[0] + delta[0], currentCenter[1] + delta[1]]);
+ if (opt_duration) {
+ view.animate({
+ duration: opt_duration,
+ easing: ol.easing.linear,
+ center: center
+ } else {
+ view.setCenter(center);
+ * @param {ol.Coordinate=} opt_anchor Anchor coordinate.
+ol.interaction.Interaction.rotate = function(view, rotation, opt_anchor, opt_duration) {
+ rotation = view.constrainRotation(rotation, 0);
+ ol.interaction.Interaction.rotateWithoutConstraints(
+ view, rotation, opt_anchor, opt_duration);
+ol.interaction.Interaction.rotateWithoutConstraints = function(view, rotation, opt_anchor, opt_duration) {
+ if (rotation !== undefined) {
+ var currentRotation = view.getRotation();
+ if (currentRotation !== undefined && currentCenter && opt_duration > 0) {
+ view.animate({
+ rotation: rotation,
+ anchor: opt_anchor,
+ easing: ol.easing.easeOut
+ } else {
+ view.rotate(rotation, opt_anchor);
+ * @param {number|undefined} resolution Resolution to go to.
+ * @param {number=} opt_direction Zooming direction; > 0 indicates
+ * zooming out, in which case the constraints system will select
+ * the largest nearest resolution; < 0 indicates zooming in, in
+ * which case the constraints system will select the smallest
+ * nearest resolution; == 0 indicates that the zooming direction
+ * is unknown/not relevant, in which case the constraints system
+ * will select the nearest resolution. If not defined 0 is
+ * assumed.
+ol.interaction.Interaction.zoom = function(view, resolution, opt_anchor, opt_duration, opt_direction) {
+ resolution = view.constrainResolution(resolution, 0, opt_direction);
+ ol.interaction.Interaction.zoomWithoutConstraints(
+ view, resolution, opt_anchor, opt_duration);
+ * @param {number} delta Delta from previous zoom level.
+ol.interaction.Interaction.zoomByDelta = function(view, delta, opt_anchor, opt_duration) {
+ var currentResolution = view.getResolution();
+ var resolution = view.constrainResolution(currentResolution, delta, 0);
+ // If we have a constraint on center, we need to change the anchor so that the
+ // new center is within the extent. We first calculate the new center, apply
+ // the constraint to it, and then calculate back the anchor
+ if (opt_anchor && resolution !== undefined && resolution !== currentResolution) {
+ var center = view.calculateCenterZoom(resolution, opt_anchor);
+ center = view.constrainCenter(center);
+ opt_anchor = [
+ (resolution * currentCenter[0] - currentResolution * center[0]) /
+ (resolution - currentResolution),
+ (resolution * currentCenter[1] - currentResolution * center[1]) /
+ol.interaction.Interaction.zoomWithoutConstraints = function(view, resolution, opt_anchor, opt_duration) {
+ if (resolution) {
+ if (currentResolution !== undefined && currentCenter &&
+ resolution !== currentResolution && opt_duration) {
+ view.animate({
+ } else {
+ if (opt_anchor) {
+ view.setResolution(resolution);
+goog.provide('ol.interaction.DoubleClickZoom');
+goog.require('ol');
+goog.require('ol.MapBrowserEventType');
+goog.require('ol.interaction.Interaction');
+ * @classdesc
+ * Allows the user to zoom by double-clicking on the map.
+ * @constructor
+ * @extends {ol.interaction.Interaction}
+ * @param {olx.interaction.DoubleClickZoomOptions=} opt_options Options.
+ * @api
+ol.interaction.DoubleClickZoom = function(opt_options) {
+ var options = opt_options ? opt_options : {};
+ * @private
+ * @type {number}
+ this.delta_ = options.delta ? options.delta : 1;
+ ol.interaction.Interaction.call(this, {
+ handleEvent: ol.interaction.DoubleClickZoom.handleEvent
+ * @private
+ * @type {number}
+ this.duration_ = options.duration !== undefined ? options.duration : 250;
+ol.inherits(ol.interaction.DoubleClickZoom, ol.interaction.Interaction);
+ * Handles the {@link ol.MapBrowserEvent map browser event} (if it was a
+ * doubleclick) and eventually zooms the map.
+ * @param {ol.MapBrowserEvent} mapBrowserEvent Map browser event.
+ * @return {boolean} `false` to stop event propagation.
+ * @this {ol.interaction.DoubleClickZoom}
+ * @api
+ol.interaction.DoubleClickZoom.handleEvent = function(mapBrowserEvent) {
+ var stopEvent = false;
+ var browserEvent = mapBrowserEvent.originalEvent;
+ if (mapBrowserEvent.type == ol.MapBrowserEventType.DBLCLICK) {
+ var map = mapBrowserEvent.map;
+ var anchor = mapBrowserEvent.coordinate;
+ var delta = browserEvent.shiftKey ? -this.delta_ : this.delta_;
+ var view = map.getView();
+ ol.interaction.Interaction.zoomByDelta(
+ view, delta, anchor, this.duration_);
+ mapBrowserEvent.preventDefault();
+ stopEvent = true;
+ return !stopEvent;
+goog.provide('ol.events.condition');
+goog.require('ol.functions');
+goog.require('ol.has');
+ * Return `true` if only the alt-key is pressed, `false` otherwise (e.g. when
+ * additionally the shift-key is pressed).
+ * @return {boolean} True if only the alt key is pressed.
+ * @api
+ol.events.condition.altKeyOnly = function(mapBrowserEvent) {
+ var originalEvent = mapBrowserEvent.originalEvent;
+ return (
+ originalEvent.altKey &&
+ !(originalEvent.metaKey || originalEvent.ctrlKey) &&
+ !originalEvent.shiftKey);
+ * Return `true` if only the alt-key and shift-key is pressed, `false` otherwise
+ * (e.g. when additionally the platform-modifier-key is pressed).
+ * @return {boolean} True if only the alt and shift keys are pressed.
+ * @api
+ol.events.condition.altShiftKeysOnly = function(mapBrowserEvent) {
+ return (
+ originalEvent.shiftKey);
+ * Return always true.
+ * @return {boolean} True.
+ * @function
+ * @api
+ol.events.condition.always = ol.functions.TRUE;
+ * Return `true` if the event is a `click` event, `false` otherwise.
+ * @return {boolean} True if the event is a map `click` event.
+ * @api
+ol.events.condition.click = function(mapBrowserEvent) {
+ return mapBrowserEvent.type == ol.MapBrowserEventType.CLICK;
+ * Return `true` if the event has an "action"-producing mouse button.
+ * By definition, this includes left-click on windows/linux, and left-click
+ * without the ctrl key on Macs.
+ * @return {boolean} The result.
+ol.events.condition.mouseActionButton = function(mapBrowserEvent) {
+ return originalEvent.button == 0 &&
+ !(ol.has.WEBKIT && ol.has.MAC && originalEvent.ctrlKey);
+ * Return always false.
+ * @return {boolean} False.
+ * @function
+ * @api
+ol.events.condition.never = ol.functions.FALSE;
+ * Return `true` if the browser event is a `pointermove` event, `false`
+ * otherwise.
+ * @return {boolean} True if the browser event is a `pointermove` event.
+ * @api
+ol.events.condition.pointerMove = function(mapBrowserEvent) {
+ return mapBrowserEvent.type == 'pointermove';
+ * Return `true` if the event is a map `singleclick` event, `false` otherwise.
+ * @return {boolean} True if the event is a map `singleclick` event.
+ * @api
+ol.events.condition.singleClick = function(mapBrowserEvent) {
+ return mapBrowserEvent.type == ol.MapBrowserEventType.SINGLECLICK;
+ * Return `true` if the event is a map `dblclick` event, `false` otherwise.
+ * @return {boolean} True if the event is a map `dblclick` event.
+ * @api
+ol.events.condition.doubleClick = function(mapBrowserEvent) {
+ return mapBrowserEvent.type == ol.MapBrowserEventType.DBLCLICK;
+ * Return `true` if no modifier key (alt-, shift- or platform-modifier-key) is
+ * pressed.
+ * @return {boolean} True only if there no modifier keys are pressed.
+ * @api
+ol.events.condition.noModifierKeys = function(mapBrowserEvent) {
+ return (
+ !originalEvent.altKey &&
+ * Return `true` if only the platform-modifier-key (the meta-key on Mac,
+ * ctrl-key otherwise) is pressed, `false` otherwise (e.g. when additionally
+ * the shift-key is pressed).
+ * @return {boolean} True if only the platform modifier key is pressed.
+ * @api
+ol.events.condition.platformModifierKeyOnly = function(mapBrowserEvent) {
+ return (
+ (ol.has.MAC ? originalEvent.metaKey : originalEvent.ctrlKey) &&
+ * Return `true` if only the shift-key is pressed, `false` otherwise (e.g. when
+ * additionally the alt-key is pressed).
+ * @return {boolean} True if only the shift key is pressed.
+ * @api
+ol.events.condition.shiftKeyOnly = function(mapBrowserEvent) {
+ return (
+ * Return `true` if the target element is not editable, i.e. not a `<input>`-,
+ * `<select>`- or `<textarea>`-element, `false` otherwise.
+ * @return {boolean} True only if the target element is not editable.
+ * @api
+ol.events.condition.targetNotEditable = function(mapBrowserEvent) {
+ var target = mapBrowserEvent.originalEvent.target;
+ var tagName = target.tagName;
+ return (
+ tagName !== 'INPUT' &&
+ tagName !== 'SELECT' &&
+ tagName !== 'TEXTAREA');
+ * Return `true` if the event originates from a mouse device.
+ * @return {boolean} True if the event originates from a mouse device.
+ * @api
+ol.events.condition.mouseOnly = function(mapBrowserEvent) {
+ ol.asserts.assert(mapBrowserEvent.pointerEvent, 56); // mapBrowserEvent must originate from a pointer event
+ // see http://www.w3.org/TR/pointerevents/#widl-PointerEvent-pointerType
+ return /** @type {ol.MapBrowserEvent} */ (mapBrowserEvent).pointerEvent.pointerType == 'mouse';
+ * Return `true` if the event originates from a primary pointer in
+ * contact with the surface or if the left mouse button is pressed.
+ * @see http://www.w3.org/TR/pointerevents/#button-states
+ * @return {boolean} True if the event originates from a primary pointer.
+ * @api
+ol.events.condition.primaryAction = function(mapBrowserEvent) {
+ var pointerEvent = mapBrowserEvent.pointerEvent;
+ return pointerEvent.isPrimary && pointerEvent.button === 0;
+goog.provide('ol.interaction.Pointer');
+goog.require('ol.MapBrowserPointerEvent');
+ * @classdesc
+ * Base class that calls user-defined functions on `down`, `move` and `up`
+ * events. This class also manages "drag sequences".
+ * When the `handleDownEvent` user function returns `true` a drag sequence is
+ * started. During a drag sequence the `handleDragEvent` user function is
+ * called on `move` events. The drag sequence ends when the `handleUpEvent`
+ * user function is called and returns `false`.
+ * @constructor
+ * @param {olx.interaction.PointerOptions=} opt_options Options.
+ * @api
+ol.interaction.Pointer = function(opt_options) {
+ var handleEvent = options.handleEvent ?
+ options.handleEvent : ol.interaction.Pointer.handleEvent;
+ handleEvent: handleEvent
+ * @type {function(ol.MapBrowserPointerEvent):boolean}
+ * @private
+ this.handleDownEvent_ = options.handleDownEvent ?
+ options.handleDownEvent : ol.interaction.Pointer.handleDownEvent;
+ * @type {function(ol.MapBrowserPointerEvent)}
+ * @private
+ this.handleDragEvent_ = options.handleDragEvent ?
+ options.handleDragEvent : ol.interaction.Pointer.handleDragEvent;
+ * @private
+ this.handleMoveEvent_ = options.handleMoveEvent ?
+ options.handleMoveEvent : ol.interaction.Pointer.handleMoveEvent;
+ * @private
+ this.handleUpEvent_ = options.handleUpEvent ?
+ options.handleUpEvent : ol.interaction.Pointer.handleUpEvent;
+ * @type {boolean}
+ * @protected
+ this.handlingDownUpSequence = false;
+ * @type {Object.<number, ol.pointer.PointerEvent>}
+ * @private
+ this.trackedPointers_ = {};
+ * @type {Array.<ol.pointer.PointerEvent>}
+ * @protected
+ this.targetPointers = [];
+ol.inherits(ol.interaction.Pointer, ol.interaction.Interaction);
+ * @param {Array.<ol.pointer.PointerEvent>} pointerEvents List of events.
+ * @return {ol.Pixel} Centroid pixel.
+ol.interaction.Pointer.centroid = function(pointerEvents) {
+ var length = pointerEvents.length;
+ var clientX = 0;
+ var clientY = 0;
+ for (var i = 0; i < length; i++) {
+ clientX += pointerEvents[i].clientX;
+ clientY += pointerEvents[i].clientY;
+ return [clientX / length, clientY / length];
+ * @param {ol.MapBrowserPointerEvent} mapBrowserEvent Event.
+ * @return {boolean} Whether the event is a pointerdown, pointerdrag
+ * or pointerup event.
+ * @private
+ol.interaction.Pointer.prototype.isPointerDraggingEvent_ = function(mapBrowserEvent) {
+ var type = mapBrowserEvent.type;
+ return (
+ type === ol.MapBrowserEventType.POINTERDOWN ||
+ type === ol.MapBrowserEventType.POINTERDRAG ||
+ type === ol.MapBrowserEventType.POINTERUP);
+ * @private
+ol.interaction.Pointer.prototype.updateTrackedPointers_ = function(mapBrowserEvent) {
+ if (this.isPointerDraggingEvent_(mapBrowserEvent)) {
+ var event = mapBrowserEvent.pointerEvent;
+ if (mapBrowserEvent.type == ol.MapBrowserEventType.POINTERUP) {
+ delete this.trackedPointers_[event.pointerId];
+ } else if (mapBrowserEvent.type ==
+ ol.MapBrowserEventType.POINTERDOWN) {
+ this.trackedPointers_[event.pointerId] = event;
+ } else if (event.pointerId in this.trackedPointers_) {
+ // update only when there was a pointerdown event for this pointer
+ this.targetPointers = ol.obj.getValues(this.trackedPointers_);
+ * @this {ol.interaction.Pointer}
+ol.interaction.Pointer.handleDragEvent = ol.nullFunction;
+ * @return {boolean} Capture dragging.
+ol.interaction.Pointer.handleUpEvent = ol.functions.FALSE;
+ol.interaction.Pointer.handleDownEvent = ol.functions.FALSE;
+ol.interaction.Pointer.handleMoveEvent = ol.nullFunction;
+ * Handles the {@link ol.MapBrowserEvent map browser event} and may call into
+ * other functions, if event sequences like e.g. 'drag' or 'down-up' etc. are
+ * detected.
+ * @api
+ol.interaction.Pointer.handleEvent = function(mapBrowserEvent) {
+ if (!(mapBrowserEvent instanceof ol.MapBrowserPointerEvent)) {
+ return true;
+ this.updateTrackedPointers_(mapBrowserEvent);
+ if (this.handlingDownUpSequence) {
+ if (mapBrowserEvent.type == ol.MapBrowserEventType.POINTERDRAG) {
+ this.handleDragEvent_(mapBrowserEvent);
+ } else if (mapBrowserEvent.type == ol.MapBrowserEventType.POINTERUP) {
+ var handledUp = this.handleUpEvent_(mapBrowserEvent);
+ this.handlingDownUpSequence = handledUp && this.targetPointers.length > 0;
+ } else {
+ if (mapBrowserEvent.type == ol.MapBrowserEventType.POINTERDOWN) {
+ var handled = this.handleDownEvent_(mapBrowserEvent);
+ this.handlingDownUpSequence = handled;
+ stopEvent = this.shouldStopEvent(handled);
+ } else if (mapBrowserEvent.type == ol.MapBrowserEventType.POINTERMOVE) {
+ this.handleMoveEvent_(mapBrowserEvent);
+ * This method is used to determine if "down" events should be propagated to
+ * other interactions or should be stopped.
+ * The method receives the return code of the "handleDownEvent" function.
+ * By default this function is the "identity" function. It's overidden in
+ * child classes.
+ * @param {boolean} handled Was the event handled by the interaction?
+ * @return {boolean} Should the event be stopped?
+ * @protected
+ol.interaction.Pointer.prototype.shouldStopEvent = function(handled) {
+ return handled;
+goog.provide('ol.interaction.DragPan');
+goog.require('ol.events.condition');
+goog.require('ol.interaction.Pointer');
+ * @classdesc
+ * Allows the user to pan the map by dragging the map.
+ * @constructor
+ * @extends {ol.interaction.Pointer}
+ * @param {olx.interaction.DragPanOptions=} opt_options Options.
+ * @api
+ol.interaction.DragPan = function(opt_options) {
+ ol.interaction.Pointer.call(this, {
+ handleDownEvent: ol.interaction.DragPan.handleDownEvent_,
+ handleDragEvent: ol.interaction.DragPan.handleDragEvent_,
+ handleUpEvent: ol.interaction.DragPan.handleUpEvent_
+ * @private
+ * @type {ol.Kinetic|undefined}
+ this.kinetic_ = options.kinetic;
+ * @type {ol.Pixel}
+ this.lastCentroid = null;
+ * @type {number}
+ this.lastPointersCount_;
+ * @private
+ * @type {ol.EventsConditionType}
+ this.condition_ = options.condition ?
+ options.condition : ol.events.condition.noModifierKeys;
+ * @private
+ * @type {boolean}
+ this.noKinetic_ = false;
+ol.inherits(ol.interaction.DragPan, ol.interaction.Pointer);
+ * @this {ol.interaction.DragPan}
+ * @private
+ol.interaction.DragPan.handleDragEvent_ = function(mapBrowserEvent) {
+ var targetPointers = this.targetPointers;
+ var centroid =
+ ol.interaction.Pointer.centroid(targetPointers);
+ if (targetPointers.length == this.lastPointersCount_) {
+ if (this.kinetic_) {
+ this.kinetic_.update(centroid[0], centroid[1]);
+ if (this.lastCentroid) {
+ var deltaX = this.lastCentroid[0] - centroid[0];
+ var deltaY = centroid[1] - this.lastCentroid[1];
+ var viewState = view.getState();
+ var center = [deltaX, deltaY];
+ ol.coordinate.scale(center, viewState.resolution);
+ ol.coordinate.rotate(center, viewState.rotation);
+ ol.coordinate.add(center, viewState.center);
+ } else if (this.kinetic_) {
+ // reset so we don't overestimate the kinetic energy after
+ // after one finger down, tiny drag, second finger down
+ this.kinetic_.begin();
+ this.lastCentroid = centroid;
+ this.lastPointersCount_ = targetPointers.length;
+ * @return {boolean} Stop drag sequence?
+ * @private
+ol.interaction.DragPan.handleUpEvent_ = function(mapBrowserEvent) {
+ if (this.targetPointers.length === 0) {
+ if (!this.noKinetic_ && this.kinetic_ && this.kinetic_.end()) {
+ var distance = this.kinetic_.getDistance();
+ var angle = this.kinetic_.getAngle();
+ var center = /** @type {!ol.Coordinate} */ (view.getCenter());
+ var centerpx = map.getPixelFromCoordinate(center);
+ var dest = map.getCoordinateFromPixel([
+ centerpx[0] - distance * Math.cos(angle),
+ centerpx[1] - distance * Math.sin(angle)
+ view.animate({
+ center: view.constrainCenter(dest),
+ duration: 500,
+ view.setHint(ol.ViewHint.INTERACTING, -1);
+ return false;
+ } else {
+ // after one finger up, tiny drag, second finger up
+ return true;
+ * @return {boolean} Start drag sequence?
+ * @private
+ol.interaction.DragPan.handleDownEvent_ = function(mapBrowserEvent) {
+ if (this.targetPointers.length > 0 && this.condition_(mapBrowserEvent)) {
+ if (!this.handlingDownUpSequence) {
+ view.setHint(ol.ViewHint.INTERACTING, 1);
+ // stop any current animation
+ if (view.getHints()[ol.ViewHint.ANIMATING]) {
+ view.setCenter(mapBrowserEvent.frameState.viewState.center);
+ // No kinetic as soon as more than one pointer on the screen is
+ // detected. This is to prevent nasty pans after pinch.
+ this.noKinetic_ = this.targetPointers.length > 1;
+ return true;
+ } else {
+ return false;
+ * @inheritDoc
+ol.interaction.DragPan.prototype.shouldStopEvent = ol.functions.FALSE;
+goog.provide('ol.interaction.DragRotate');
+ * @classdesc
+ * Allows the user to rotate the map by clicking and dragging on the map,
+ * normally combined with an {@link ol.events.condition} that limits
+ * it to when the alt and shift keys are held down.
+ * This interaction is only supported for mouse devices.
+ * @constructor
+ * @param {olx.interaction.DragRotateOptions=} opt_options Options.
+ * @api
+ol.interaction.DragRotate = function(opt_options) {
+ handleDownEvent: ol.interaction.DragRotate.handleDownEvent_,
+ handleDragEvent: ol.interaction.DragRotate.handleDragEvent_,
+ handleUpEvent: ol.interaction.DragRotate.handleUpEvent_
+ * @private
+ options.condition : ol.events.condition.altShiftKeysOnly;
+ * @private
+ this.lastAngle_ = undefined;
+ * @private
+ * @type {number}
+ol.inherits(ol.interaction.DragRotate, ol.interaction.Pointer);
+ * @this {ol.interaction.DragRotate}
+ * @private
+ol.interaction.DragRotate.handleDragEvent_ = function(mapBrowserEvent) {
+ if (!ol.events.condition.mouseOnly(mapBrowserEvent)) {
+ return;
+ var size = map.getSize();
+ var offset = mapBrowserEvent.pixel;
+ var theta =
+ Math.atan2(size[1] / 2 - offset[1], offset[0] - size[0] / 2);
+ if (this.lastAngle_ !== undefined) {
+ var delta = theta - this.lastAngle_;
+ var rotation = view.getRotation();
+ view, rotation - delta);
+ this.lastAngle_ = theta;
+ * @private
+ol.interaction.DragRotate.handleUpEvent_ = function(mapBrowserEvent) {
+ return true;
+ ol.interaction.Interaction.rotate(view, rotation,
+ undefined, this.duration_);
+ return false;
+ * @private
+ol.interaction.DragRotate.handleDownEvent_ = function(mapBrowserEvent) {
+ return false;
+ if (ol.events.condition.mouseActionButton(mapBrowserEvent) &&
+ this.condition_(mapBrowserEvent)) {
+ map.getView().setHint(ol.ViewHint.INTERACTING, 1);
+ return true;
+ } else {
+ return false;
+ * @inheritDoc
+ol.interaction.DragRotate.prototype.shouldStopEvent = ol.functions.FALSE;
+// FIXME add rotation
+goog.provide('ol.render.Box');
+goog.require('ol.Disposable');
+ * @constructor
+ * @extends {ol.Disposable}
+ * @param {string} className CSS class name.
+ol.render.Box = function(className) {
+ * @type {ol.geom.Polygon}
+ * @private
+ this.geometry_ = null;
+ * @type {HTMLDivElement}
+ * @private
+ this.element_ = /** @type {HTMLDivElement} */ (document.createElement('div'));
+ this.element_.style.position = 'absolute';
+ this.element_.className = 'ol-box ' + className;
+ * @private
+ * @type {ol.Map}
+ this.map_ = null;
+ * @private
+ this.startPixel_ = null;
+ * @private
+ this.endPixel_ = null;
+ol.inherits(ol.render.Box, ol.Disposable);
+ * @inheritDoc
+ol.render.Box.prototype.disposeInternal = function() {
+ this.setMap(null);
+ * @private
+ol.render.Box.prototype.render_ = function() {
+ var startPixel = this.startPixel_;
+ var endPixel = this.endPixel_;
+ var px = 'px';
+ var style = this.element_.style;
+ style.left = Math.min(startPixel[0], endPixel[0]) + px;
+ style.top = Math.min(startPixel[1], endPixel[1]) + px;
+ style.width = Math.abs(endPixel[0] - startPixel[0]) + px;
+ style.height = Math.abs(endPixel[1] - startPixel[1]) + px;
+ol.render.Box.prototype.setMap = function(map) {
+ if (this.map_) {
+ this.map_.getOverlayContainer().removeChild(this.element_);
+ style.left = style.top = style.width = style.height = 'inherit';
+ this.map_ = map;
+ if (this.map_) {
+ this.map_.getOverlayContainer().appendChild(this.element_);
+ * @param {ol.Pixel} startPixel Start pixel.
+ * @param {ol.Pixel} endPixel End pixel.
+ol.render.Box.prototype.setPixels = function(startPixel, endPixel) {
+ this.startPixel_ = startPixel;
+ this.endPixel_ = endPixel;
+ this.createOrUpdateGeometry();
+ this.render_();
+ * Creates or updates the cached geometry.
+ol.render.Box.prototype.createOrUpdateGeometry = function() {
+ var pixels = [
+ startPixel,
+ [startPixel[0], endPixel[1]],
+ endPixel,
+ [endPixel[0], startPixel[1]]
+ var coordinates = pixels.map(this.map_.getCoordinateFromPixel, this.map_);
+ // close the polygon
+ coordinates[4] = coordinates[0].slice();
+ if (!this.geometry_) {
+ this.geometry_ = new ol.geom.Polygon([coordinates]);
+ } else {
+ this.geometry_.setCoordinates([coordinates]);
+ * @return {ol.geom.Polygon} Geometry.
+ol.render.Box.prototype.getGeometry = function() {
+ return this.geometry_;
+// FIXME draw drag box
+goog.provide('ol.interaction.DragBox');
+goog.require('ol.events.Event');
+goog.require('ol.render.Box');
+ * @classdesc
+ * Allows the user to draw a vector box by clicking and dragging on the map,
+ * it to when the shift or other key is held down. This is used, for example,
+ * for zooming to a specific area of the map
+ * (see {@link ol.interaction.DragZoom} and
+ * {@link ol.interaction.DragRotateAndZoom}).
+ * @constructor
+ * @fires ol.interaction.DragBox.Event
+ * @param {olx.interaction.DragBoxOptions=} opt_options Options.
+ * @api
+ol.interaction.DragBox = function(opt_options) {
+ handleDownEvent: ol.interaction.DragBox.handleDownEvent_,
+ handleDragEvent: ol.interaction.DragBox.handleDragEvent_,
+ handleUpEvent: ol.interaction.DragBox.handleUpEvent_
+ * @type {ol.render.Box}
+ * @private
+ this.box_ = new ol.render.Box(options.className || 'ol-dragbox');
+ * @type {number}
+ * @private
+ this.minArea_ = options.minArea !== undefined ? options.minArea : 64;
+ * @private
+ * @private
+ options.condition : ol.events.condition.always;
+ * @private
+ * @type {ol.DragBoxEndConditionType}
+ this.boxEndCondition_ = options.boxEndCondition ?
+ options.boxEndCondition : ol.interaction.DragBox.defaultBoxEndCondition;
+ol.inherits(ol.interaction.DragBox, ol.interaction.Pointer);
+ * The default condition for determining whether the boxend event
+ * should fire.
+ * @param {ol.MapBrowserEvent} mapBrowserEvent The originating MapBrowserEvent
+ * leading to the box end.
+ * @param {ol.Pixel} startPixel The starting pixel of the box.
+ * @param {ol.Pixel} endPixel The end pixel of the box.
+ * @return {boolean} Whether or not the boxend condition should be fired.
+ * @this {ol.interaction.DragBox}
+ol.interaction.DragBox.defaultBoxEndCondition = function(mapBrowserEvent, startPixel, endPixel) {
+ var width = endPixel[0] - startPixel[0];
+ var height = endPixel[1] - startPixel[1];
+ return width * width + height * height >= this.minArea_;
+ * @private
+ol.interaction.DragBox.handleDragEvent_ = function(mapBrowserEvent) {
+ return;
+ this.box_.setPixels(this.startPixel_, mapBrowserEvent.pixel);
+ this.dispatchEvent(new ol.interaction.DragBox.Event(ol.interaction.DragBox.EventType_.BOXDRAG,
+ mapBrowserEvent.coordinate, mapBrowserEvent));
+ * Returns geometry of last drawn box.
+ * @api
+ol.interaction.DragBox.prototype.getGeometry = function() {
+ return this.box_.getGeometry();
+ * To be overriden by child classes.
+ * FIXME: use constructor option instead of relying on overridding.
+ * @protected
+ol.interaction.DragBox.prototype.onBoxEnd = ol.nullFunction;
+ * @private
+ol.interaction.DragBox.handleUpEvent_ = function(mapBrowserEvent) {
+ return true;
+ this.box_.setMap(null);
+ if (this.boxEndCondition_(mapBrowserEvent,
+ this.startPixel_, mapBrowserEvent.pixel)) {
+ this.onBoxEnd(mapBrowserEvent);
+ this.dispatchEvent(new ol.interaction.DragBox.Event(ol.interaction.DragBox.EventType_.BOXEND,
+ return false;
+ * @private
+ol.interaction.DragBox.handleDownEvent_ = function(mapBrowserEvent) {
+ return false;
+ this.startPixel_ = mapBrowserEvent.pixel;
+ this.box_.setMap(mapBrowserEvent.map);
+ this.box_.setPixels(this.startPixel_, this.startPixel_);
+ this.dispatchEvent(new ol.interaction.DragBox.Event(ol.interaction.DragBox.EventType_.BOXSTART,
+ return true;
+ } else {
+ return false;
+ * @enum {string}
+ * @private
+ol.interaction.DragBox.EventType_ = {
+ * Triggered upon drag box start.
+ * @event ol.interaction.DragBox.Event#boxstart
+ * @api
+ BOXSTART: 'boxstart',
+ * Triggered on drag when box is active.
+ * @event ol.interaction.DragBox.Event#boxdrag
+ * @api
+ BOXDRAG: 'boxdrag',
+ * Triggered upon drag box end.
+ * @event ol.interaction.DragBox.Event#boxend
+ * @api
+ BOXEND: 'boxend'
+ * @classdesc
+ * Events emitted by {@link ol.interaction.DragBox} instances are instances of
+ * this type.
+ * @param {string} type The event type.
+ * @param {ol.Coordinate} coordinate The event coordinate.
+ * @param {ol.MapBrowserEvent} mapBrowserEvent Originating event.
+ * @extends {ol.events.Event}
+ * @constructor
+ * @implements {oli.DragBoxEvent}
+ol.interaction.DragBox.Event = function(type, coordinate, mapBrowserEvent) {
+ ol.events.Event.call(this, type);
+ * The coordinate of the drag event.
+ * @const
+ * @type {ol.Coordinate}
+ * @api
+ this.coordinate = coordinate;
+ * @const
+ * @type {ol.MapBrowserEvent}
+ * @api
+ this.mapBrowserEvent = mapBrowserEvent;
+ol.inherits(ol.interaction.DragBox.Event, ol.events.Event);
+goog.provide('ol.interaction.DragZoom');
+goog.require('ol.easing');
+goog.require('ol.extent');
+goog.require('ol.interaction.DragBox');
+ * @classdesc
+ * Allows the user to zoom the map by clicking and dragging on the map,
+ * it to when a key, shift by default, is held down.
+ * To change the style of the box, use CSS and the `.ol-dragzoom` selector, or
+ * your custom one configured with `className`.
+ * @constructor
+ * @extends {ol.interaction.DragBox}
+ * @param {olx.interaction.DragZoomOptions=} opt_options Options.
+ * @api
+ol.interaction.DragZoom = function(opt_options) {
+ var condition = options.condition ?
+ options.condition : ol.events.condition.shiftKeyOnly;
+ * @private
+ * @type {number}
+ this.duration_ = options.duration !== undefined ? options.duration : 200;
+ * @private
+ * @type {boolean}
+ this.out_ = options.out !== undefined ? options.out : false;
+ ol.interaction.DragBox.call(this, {
+ condition: condition,
+ className: options.className || 'ol-dragzoom'
+ol.inherits(ol.interaction.DragZoom, ol.interaction.DragBox);
+ * @inheritDoc
+ol.interaction.DragZoom.prototype.onBoxEnd = function() {
+ var map = this.getMap();
+ var view = /** @type {!ol.View} */ (map.getView());
+ var size = /** @type {!ol.Size} */ (map.getSize());
+ var extent = this.getGeometry().getExtent();
+ if (this.out_) {
+ var mapExtent = view.calculateExtent(size);
+ var boxPixelExtent = ol.extent.createOrUpdateFromCoordinates([
+ map.getPixelFromCoordinate(ol.extent.getBottomLeft(extent)),
+ map.getPixelFromCoordinate(ol.extent.getTopRight(extent))]);
+ var factor = view.getResolutionForExtent(boxPixelExtent, size);
+ ol.extent.scaleFromCenter(mapExtent, 1 / factor);
+ extent = mapExtent;
+ view.getResolutionForExtent(extent, size));
+ var center = ol.extent.getCenter(extent);
+ view.animate({
+ center: center,
+ duration: this.duration_,
+goog.provide('ol.events.KeyCode');
+ * @enum {number}
+ * @const
+ol.events.KeyCode = {
+ LEFT: 37,
+ UP: 38,
+ RIGHT: 39,
+ DOWN: 40
+goog.provide('ol.interaction.KeyboardPan');
+goog.require('ol.coordinate');
+goog.require('ol.events.EventType');
+goog.require('ol.events.KeyCode');
+ * @classdesc
+ * Allows the user to pan the map using keyboard arrows.
+ * Note that, although this interaction is by default included in maps,
+ * the keys can only be used when browser focus is on the element to which
+ * the keyboard events are attached. By default, this is the map div,
+ * though you can change this with the `keyboardEventTarget` in
+ * {@link ol.Map}. `document` never loses focus but, for any other element,
+ * focus will have to be on, and returned to, this element if the keys are to
+ * function.
+ * See also {@link ol.interaction.KeyboardZoom}.
+ * @constructor
+ * @param {olx.interaction.KeyboardPanOptions=} opt_options Options.
+ * @api
+ol.interaction.KeyboardPan = function(opt_options) {
+ handleEvent: ol.interaction.KeyboardPan.handleEvent
+ * @private
+ * @param {ol.MapBrowserEvent} mapBrowserEvent Browser event.
+ * @return {boolean} Combined condition result.
+ this.defaultCondition_ = function(mapBrowserEvent) {
+ return ol.events.condition.noModifierKeys(mapBrowserEvent) &&
+ ol.events.condition.targetNotEditable(mapBrowserEvent);
+ * @private
+ this.condition_ = options.condition !== undefined ?
+ options.condition : this.defaultCondition_;
+ * @private
+ * @type {number}
+ this.duration_ = options.duration !== undefined ? options.duration : 100;
+ * @private
+ * @type {number}
+ this.pixelDelta_ = options.pixelDelta !== undefined ?
+ options.pixelDelta : 128;
+ol.inherits(ol.interaction.KeyboardPan, ol.interaction.Interaction);
+ * Handles the {@link ol.MapBrowserEvent map browser event} if it was a
+ * `KeyEvent`, and decides the direction to pan to (if an arrow key was
+ * pressed).
+ * @this {ol.interaction.KeyboardPan}
+ * @api
+ol.interaction.KeyboardPan.handleEvent = function(mapBrowserEvent) {
+ if (mapBrowserEvent.type == ol.events.EventType.KEYDOWN) {
+ var keyEvent = mapBrowserEvent.originalEvent;
+ var keyCode = keyEvent.keyCode;
+ if (this.condition_(mapBrowserEvent) &&
+ (keyCode == ol.events.KeyCode.DOWN ||
+ keyCode == ol.events.KeyCode.LEFT ||
+ keyCode == ol.events.KeyCode.RIGHT ||
+ keyCode == ol.events.KeyCode.UP)) {
+ var mapUnitsDelta = view.getResolution() * this.pixelDelta_;
+ var deltaX = 0, deltaY = 0;
+ if (keyCode == ol.events.KeyCode.DOWN) {
+ deltaY = -mapUnitsDelta;
+ } else if (keyCode == ol.events.KeyCode.LEFT) {
+ deltaX = -mapUnitsDelta;
+ } else if (keyCode == ol.events.KeyCode.RIGHT) {
+ deltaX = mapUnitsDelta;
+ } else {
+ deltaY = mapUnitsDelta;
+ var delta = [deltaX, deltaY];
+ ol.coordinate.rotate(delta, view.getRotation());
+ ol.interaction.Interaction.pan(view, delta, this.duration_);
+ stopEvent = true;
+goog.provide('ol.interaction.KeyboardZoom');
+ * @classdesc
+ * Allows the user to zoom the map using keyboard + and -.
+ * function.
+ * See also {@link ol.interaction.KeyboardPan}.
+ * @constructor
+ * @param {olx.interaction.KeyboardZoomOptions=} opt_options Options.
+ * @api
+ol.interaction.KeyboardZoom = function(opt_options) {
+ handleEvent: ol.interaction.KeyboardZoom.handleEvent
+ * @private
+ this.condition_ = options.condition ? options.condition :
+ ol.events.condition.targetNotEditable;
+ * @private
+ * @type {number}
+ * @private
+ * @type {number}
+ol.inherits(ol.interaction.KeyboardZoom, ol.interaction.Interaction);
+ * `KeyEvent`, and decides whether to zoom in or out (depending on whether the
+ * key pressed was '+' or '-').
+ * @this {ol.interaction.KeyboardZoom}
+ * @api
+ol.interaction.KeyboardZoom.handleEvent = function(mapBrowserEvent) {
+ if (mapBrowserEvent.type == ol.events.EventType.KEYDOWN ||
+ mapBrowserEvent.type == ol.events.EventType.KEYPRESS) {
+ var charCode = keyEvent.charCode;
+ (charCode == '+'.charCodeAt(0) || charCode == '-'.charCodeAt(0))) {
+ var delta = (charCode == '+'.charCodeAt(0)) ? this.delta_ : -this.delta_;
+ view, delta, undefined, this.duration_);
+ stopEvent = true;
+goog.provide('ol.interaction.MouseWheelZoom');
+goog.require('ol.ViewHint');
+goog.require('ol.math');
+ * @classdesc
+ * Allows the user to zoom the map by scrolling the mouse wheel.
+ * @constructor
+ * @param {olx.interaction.MouseWheelZoomOptions=} opt_options Options.
+ * @api
+ol.interaction.MouseWheelZoom = function(opt_options) {
+ handleEvent: ol.interaction.MouseWheelZoom.handleEvent
+ * @private
+ * @type {number}
+ this.delta_ = 0;
+ * @private
+ * @type {number}
+ * @private
+ * @type {number}
+ this.timeout_ = options.timeout !== undefined ? options.timeout : 80;
+ * @private
+ * @type {boolean}
+ this.useAnchor_ = options.useAnchor !== undefined ? options.useAnchor : true;
+ * @private
+ * @type {boolean}
+ this.constrainResolution_ = options.constrainResolution || false;
+ * @private
+ * @type {?ol.Coordinate}
+ this.lastAnchor_ = null;
+ * @private
+ * @type {number|undefined}
+ this.startTime_ = undefined;
+ * @private
+ this.timeoutId_ = undefined;
+ * @private
+ * @type {ol.interaction.MouseWheelZoom.Mode_|undefined}
+ this.mode_ = undefined;
+ * Trackpad events separated by this delay will be considered separate
+ * interactions.
+ * @type {number}
+ this.trackpadEventGap_ = 400;
+ this.trackpadTimeoutId_ = undefined;
+ * The number of delta values per zoom level
+ * @private
+ * @type {number}
+ this.trackpadDeltaPerZoom_ = 300;
+ * The zoom factor by which scroll zooming is allowed to exceed the limits.
+ * @private
+ * @type {number}
+ this.trackpadZoomBuffer_ = 1.5;
+ol.inherits(ol.interaction.MouseWheelZoom, ol.interaction.Interaction);
+ * mousewheel-event) and eventually zooms the map.
+ * @return {boolean} Allow event propagation.
+ * @this {ol.interaction.MouseWheelZoom}
+ * @api
+ol.interaction.MouseWheelZoom.handleEvent = function(mapBrowserEvent) {
+ if (type !== ol.events.EventType.WHEEL && type !== ol.events.EventType.MOUSEWHEEL) {
+ return true;
+ var wheelEvent = /** @type {WheelEvent} */ (mapBrowserEvent.originalEvent);
+ if (this.useAnchor_) {
+ this.lastAnchor_ = mapBrowserEvent.coordinate;
+ // Delta normalisation inspired by
+ // https://github.com/mapbox/mapbox-gl-js/blob/001c7b9/js/ui/handler/scroll_zoom.js
+ var delta;
+ if (mapBrowserEvent.type == ol.events.EventType.WHEEL) {
+ delta = wheelEvent.deltaY;
+ if (ol.has.FIREFOX &&
+ wheelEvent.deltaMode === WheelEvent.DOM_DELTA_PIXEL) {
+ delta /= ol.has.DEVICE_PIXEL_RATIO;
+ if (wheelEvent.deltaMode === WheelEvent.DOM_DELTA_LINE) {
+ delta *= 40;
+ } else if (mapBrowserEvent.type == ol.events.EventType.MOUSEWHEEL) {
+ delta = -wheelEvent.wheelDeltaY;
+ if (ol.has.SAFARI) {
+ delta /= 3;
+ if (delta === 0) {
+ return false;
+ var now = Date.now();
+ if (this.startTime_ === undefined) {
+ this.startTime_ = now;
+ if (!this.mode_ || now - this.startTime_ > this.trackpadEventGap_) {
+ this.mode_ = Math.abs(delta) < 4 ?
+ ol.interaction.MouseWheelZoom.Mode_.TRACKPAD :
+ ol.interaction.MouseWheelZoom.Mode_.WHEEL;
+ if (this.mode_ === ol.interaction.MouseWheelZoom.Mode_.TRACKPAD) {
+ if (this.trackpadTimeoutId_) {
+ clearTimeout(this.trackpadTimeoutId_);
+ } else {
+ this.trackpadTimeoutId_ = setTimeout(this.decrementInteractingHint_.bind(this), this.trackpadEventGap_);
+ var resolution = view.getResolution() * Math.pow(2, delta / this.trackpadDeltaPerZoom_);
+ var minResolution = view.getMinResolution();
+ var maxResolution = view.getMaxResolution();
+ var rebound = 0;
+ if (resolution < minResolution) {
+ resolution = Math.max(resolution, minResolution / this.trackpadZoomBuffer_);
+ rebound = 1;
+ } else if (resolution > maxResolution) {
+ resolution = Math.min(resolution, maxResolution * this.trackpadZoomBuffer_);
+ rebound = -1;
+ if (this.lastAnchor_) {
+ var center = view.calculateCenterZoom(resolution, this.lastAnchor_);
+ view.setCenter(view.constrainCenter(center));
+ if (rebound === 0 && this.constrainResolution_) {
+ view.animate({
+ resolution: view.constrainResolution(resolution, delta > 0 ? -1 : 1),
+ easing: ol.easing.easeOut,
+ anchor: this.lastAnchor_,
+ if (rebound > 0) {
+ view.animate({
+ resolution: minResolution,
+ duration: 500
+ } else if (rebound < 0) {
+ view.animate({
+ resolution: maxResolution,
+ duration: 500
+ return false;
+ this.delta_ += delta;
+ var timeLeft = Math.max(this.timeout_ - (now - this.startTime_), 0);
+ clearTimeout(this.timeoutId_);
+ this.timeoutId_ = setTimeout(this.handleWheelZoom_.bind(this, map), timeLeft);
+ return false;
+ * @private
+ol.interaction.MouseWheelZoom.prototype.decrementInteractingHint_ = function() {
+ var view = this.getMap().getView();
+ * @private
+ol.interaction.MouseWheelZoom.prototype.handleWheelZoom_ = function(map) {
+ if (view.getAnimating()) {
+ view.cancelAnimations();
+ var maxDelta = ol.MOUSEWHEELZOOM_MAXDELTA;
+ var delta = ol.math.clamp(this.delta_, -maxDelta, maxDelta);
+ ol.interaction.Interaction.zoomByDelta(view, -delta, this.lastAnchor_,
+ this.duration_);
+ this.delta_ = 0;
+ * Enable or disable using the mouse's location as an anchor when zooming
+ * @param {boolean} useAnchor true to zoom to the mouse's location, false
+ * to zoom to the center of the map
+ * @api
+ol.interaction.MouseWheelZoom.prototype.setMouseAnchor = function(useAnchor) {
+ this.useAnchor_ = useAnchor;
+ if (!useAnchor) {
+ * @enum {string}
+ * @private
+ol.interaction.MouseWheelZoom.Mode_ = {
+ TRACKPAD: 'trackpad',
+ WHEEL: 'wheel'
+goog.provide('ol.interaction.PinchRotate');
+ * @classdesc
+ * Allows the user to rotate the map by twisting with two fingers
+ * on a touch screen.
+ * @constructor
+ * @param {olx.interaction.PinchRotateOptions=} opt_options Options.
+ * @api
+ol.interaction.PinchRotate = function(opt_options) {
+ handleDownEvent: ol.interaction.PinchRotate.handleDownEvent_,
+ handleDragEvent: ol.interaction.PinchRotate.handleDragEvent_,
+ handleUpEvent: ol.interaction.PinchRotate.handleUpEvent_
+ * @private
+ this.anchor_ = null;
+ * @private
+ * @private
+ * @type {boolean}
+ this.rotating_ = false;
+ * @private
+ * @type {number}
+ this.rotationDelta_ = 0.0;
+ * @private
+ * @type {number}
+ this.threshold_ = options.threshold !== undefined ? options.threshold : 0.3;
+ * @private
+ * @type {number}
+ol.inherits(ol.interaction.PinchRotate, ol.interaction.Pointer);
+ * @this {ol.interaction.PinchRotate}
+ * @private
+ol.interaction.PinchRotate.handleDragEvent_ = function(mapBrowserEvent) {
+ var rotationDelta = 0.0;
+ var touch0 = this.targetPointers[0];
+ var touch1 = this.targetPointers[1];
+ // angle between touches
+ var angle = Math.atan2(
+ touch1.clientY - touch0.clientY,
+ touch1.clientX - touch0.clientX);
+ var delta = angle - this.lastAngle_;
+ this.rotationDelta_ += delta;
+ if (!this.rotating_ &&
+ Math.abs(this.rotationDelta_) > this.threshold_) {
+ this.rotating_ = true;
+ rotationDelta = delta;
+ this.lastAngle_ = angle;
+ // rotate anchor point.
+ // FIXME: should be the intersection point between the lines:
+ // touch0,touch1 and previousTouch0,previousTouch1
+ var viewportPosition = map.getViewport().getBoundingClientRect();
+ var centroid = ol.interaction.Pointer.centroid(this.targetPointers);
+ centroid[0] -= viewportPosition.left;
+ centroid[1] -= viewportPosition.top;
+ this.anchor_ = map.getCoordinateFromPixel(centroid);
+ // rotate
+ if (this.rotating_) {
+ map.render();
+ ol.interaction.Interaction.rotateWithoutConstraints(view,
+ rotation + rotationDelta, this.anchor_);
+ * @private
+ol.interaction.PinchRotate.handleUpEvent_ = function(mapBrowserEvent) {
+ if (this.targetPointers.length < 2) {
+ view, rotation, this.anchor_, this.duration_);
+ return false;
+ } else {
+ return true;
+ * @private
+ol.interaction.PinchRotate.handleDownEvent_ = function(mapBrowserEvent) {
+ if (this.targetPointers.length >= 2) {
+ return true;
+ } else {
+ return false;
+ * @inheritDoc
+ol.interaction.PinchRotate.prototype.shouldStopEvent = ol.functions.FALSE;
+goog.provide('ol.interaction.PinchZoom');
+ * @classdesc
+ * Allows the user to zoom the map by pinching with two fingers
+ * @constructor
+ * @param {olx.interaction.PinchZoomOptions=} opt_options Options.
+ * @api
+ol.interaction.PinchZoom = function(opt_options) {
+ handleDownEvent: ol.interaction.PinchZoom.handleDownEvent_,
+ handleDragEvent: ol.interaction.PinchZoom.handleDragEvent_,
+ handleUpEvent: ol.interaction.PinchZoom.handleUpEvent_
+ * @private
+ * @type {boolean}
+ * @private
+ * @private
+ * @type {number}
+ this.duration_ = options.duration !== undefined ? options.duration : 400;
+ * @private
+ this.lastDistance_ = undefined;
+ * @private
+ * @type {number}
+ this.lastScaleDelta_ = 1;
+ol.inherits(ol.interaction.PinchZoom, ol.interaction.Pointer);
+ * @this {ol.interaction.PinchZoom}
+ * @private
+ol.interaction.PinchZoom.handleDragEvent_ = function(mapBrowserEvent) {
+ var scaleDelta = 1.0;
+ var dx = touch0.clientX - touch1.clientX;
+ var dy = touch0.clientY - touch1.clientY;
+ // distance between touches
+ var distance = Math.sqrt(dx * dx + dy * dy);
+ if (this.lastDistance_ !== undefined) {
+ scaleDelta = this.lastDistance_ / distance;
+ this.lastDistance_ = distance;
+ var resolution = view.getResolution();
+ var newResolution = resolution * scaleDelta;
+ if (newResolution > maxResolution) {
+ scaleDelta = maxResolution / resolution;
+ newResolution = maxResolution;
+ } else if (newResolution < minResolution) {
+ scaleDelta = minResolution / resolution;
+ newResolution = minResolution;
+ if (scaleDelta != 1.0) {
+ this.lastScaleDelta_ = scaleDelta;
+ // scale anchor point.
+ // scale, bypass the resolution constraint
+ map.render();
+ ol.interaction.Interaction.zoomWithoutConstraints(view, newResolution, this.anchor_);
+ * @private
+ol.interaction.PinchZoom.handleUpEvent_ = function(mapBrowserEvent) {
+ if (this.constrainResolution_ ||
+ resolution < view.getMinResolution() ||
+ resolution > view.getMaxResolution()) {
+ // Zoom to final resolution, with an animation, and provide a
+ // direction not to zoom out/in if user was pinching in/out.
+ // Direction is > 0 if pinching out, and < 0 if pinching in.
+ var direction = this.lastScaleDelta_ - 1;
+ ol.interaction.Interaction.zoom(view, resolution,
+ this.anchor_, this.duration_, direction);
+ return false;
+ } else {
+ return true;
+ * @private
+ol.interaction.PinchZoom.handleDownEvent_ = function(mapBrowserEvent) {
+ return true;
+ } else {
+ return false;
+ * @inheritDoc
+ol.interaction.PinchZoom.prototype.shouldStopEvent = ol.functions.FALSE;
+goog.provide('ol.interaction');
+goog.require('ol.Collection');
+goog.require('ol.Kinetic');
+goog.require('ol.interaction.DoubleClickZoom');
+goog.require('ol.interaction.DragPan');
+goog.require('ol.interaction.DragRotate');
+goog.require('ol.interaction.DragZoom');
+goog.require('ol.interaction.KeyboardPan');
+goog.require('ol.interaction.KeyboardZoom');
+goog.require('ol.interaction.MouseWheelZoom');
+goog.require('ol.interaction.PinchRotate');
+goog.require('ol.interaction.PinchZoom');
+ * Set of interactions included in maps by default. Specific interactions can be
+ * excluded by setting the appropriate option to false in the constructor
+ * options, but the order of the interactions is fixed. If you want to specify
+ * a different order for interactions, you will need to create your own
+ * {@link ol.interaction.Interaction} instances and insert them into a
+ * {@link ol.Collection} in the order you want before creating your
+ * {@link ol.Map} instance. The default set of interactions, in sequence, is:
+ * * {@link ol.interaction.DragRotate}
+ * * {@link ol.interaction.DoubleClickZoom}
+ * * {@link ol.interaction.DragPan}
+ * * {@link ol.interaction.PinchRotate}
+ * * {@link ol.interaction.PinchZoom}
+ * * {@link ol.interaction.KeyboardPan}
+ * * {@link ol.interaction.KeyboardZoom}
+ * * {@link ol.interaction.MouseWheelZoom}
+ * * {@link ol.interaction.DragZoom}
+ * @param {olx.interaction.DefaultsOptions=} opt_options Defaults options.
+ * @return {ol.Collection.<ol.interaction.Interaction>} A collection of
+ * interactions to be used with the ol.Map constructor's interactions option.
+ * @api
+ol.interaction.defaults = function(opt_options) {
+ var interactions = new ol.Collection();
+ var kinetic = new ol.Kinetic(-0.005, 0.05, 100);
+ var altShiftDragRotate = options.altShiftDragRotate !== undefined ?
+ options.altShiftDragRotate : true;
+ if (altShiftDragRotate) {
+ interactions.push(new ol.interaction.DragRotate());
+ var doubleClickZoom = options.doubleClickZoom !== undefined ?
+ options.doubleClickZoom : true;
+ if (doubleClickZoom) {
+ interactions.push(new ol.interaction.DoubleClickZoom({
+ delta: options.zoomDelta,
+ duration: options.zoomDuration
+ var dragPan = options.dragPan !== undefined ? options.dragPan : true;
+ if (dragPan) {
+ interactions.push(new ol.interaction.DragPan({
+ kinetic: kinetic
+ var pinchRotate = options.pinchRotate !== undefined ? options.pinchRotate :
+ true;
+ if (pinchRotate) {
+ interactions.push(new ol.interaction.PinchRotate());
+ var pinchZoom = options.pinchZoom !== undefined ? options.pinchZoom : true;
+ if (pinchZoom) {
+ interactions.push(new ol.interaction.PinchZoom({
+ constrainResolution: options.constrainResolution,
+ var keyboard = options.keyboard !== undefined ? options.keyboard : true;
+ if (keyboard) {
+ interactions.push(new ol.interaction.KeyboardPan());
+ interactions.push(new ol.interaction.KeyboardZoom({
+ var mouseWheelZoom = options.mouseWheelZoom !== undefined ?
+ options.mouseWheelZoom : true;
+ if (mouseWheelZoom) {
+ interactions.push(new ol.interaction.MouseWheelZoom({
+ var shiftDragZoom = options.shiftDragZoom !== undefined ?
+ options.shiftDragZoom : true;
+ if (shiftDragZoom) {
+ interactions.push(new ol.interaction.DragZoom({
+ return interactions;
+goog.provide('ol.layer.Property');
+ * @enum {string}
+ol.layer.Property = {
+ OPACITY: 'opacity',
+ VISIBLE: 'visible',
+ EXTENT: 'extent',
+ Z_INDEX: 'zIndex',
+ MAX_RESOLUTION: 'maxResolution',
+ MIN_RESOLUTION: 'minResolution',
+ SOURCE: 'source'
+goog.provide('ol.layer.Base');
+goog.require('ol.Object');
+goog.require('ol.layer.Property');
+goog.require('ol.obj');
+ * @classdesc
+ * Note that with `ol.layer.Base` and all its subclasses, any property set in
+ * the options is set as a {@link ol.Object} property on the layer object, so
+ * is observable, and has get/set accessors.
+ * @constructor
+ * @abstract
+ * @extends {ol.Object}
+ * @param {olx.layer.BaseOptions} options Layer options.
+ * @api
+ol.layer.Base = function(options) {
+ ol.Object.call(this);
+ * @type {Object.<string, *>}
+ var properties = ol.obj.assign({}, options);
+ properties[ol.layer.Property.OPACITY] =
+ options.opacity !== undefined ? options.opacity : 1;
+ properties[ol.layer.Property.VISIBLE] =
+ options.visible !== undefined ? options.visible : true;
+ properties[ol.layer.Property.Z_INDEX] =
+ options.zIndex !== undefined ? options.zIndex : 0;
+ properties[ol.layer.Property.MAX_RESOLUTION] =
+ options.maxResolution !== undefined ? options.maxResolution : Infinity;
+ properties[ol.layer.Property.MIN_RESOLUTION] =
+ options.minResolution !== undefined ? options.minResolution : 0;
+ this.setProperties(properties);
+ * @type {ol.LayerState}
+ * @private
+ this.state_ = /** @type {ol.LayerState} */ ({
+ layer: /** @type {ol.layer.Layer} */ (this),
+ managed: true
+ol.inherits(ol.layer.Base, ol.Object);
+ * Create a renderer for this layer.
+ * @abstract
+ * @param {ol.renderer.Map} mapRenderer The map renderer.
+ * @return {ol.renderer.Layer} A layer renderer.
+ol.layer.Base.prototype.createRenderer = function(mapRenderer) {};
+ * @return {ol.LayerState} Layer state.
+ol.layer.Base.prototype.getLayerState = function() {
+ this.state_.opacity = ol.math.clamp(this.getOpacity(), 0, 1);
+ this.state_.sourceState = this.getSourceState();
+ this.state_.visible = this.getVisible();
+ this.state_.extent = this.getExtent();
+ this.state_.zIndex = this.getZIndex();
+ this.state_.maxResolution = this.getMaxResolution();
+ this.state_.minResolution = Math.max(this.getMinResolution(), 0);
+ return this.state_;
+ * @abstract
+ * @param {Array.<ol.layer.Layer>=} opt_array Array of layers (to be
+ * modified in place).
+ * @return {Array.<ol.layer.Layer>} Array of layers.
+ol.layer.Base.prototype.getLayersArray = function(opt_array) {};
+ * @abstract
+ * @param {Array.<ol.LayerState>=} opt_states Optional list of layer
+ * states (to be modified in place).
+ * @return {Array.<ol.LayerState>} List of layer states.
+ol.layer.Base.prototype.getLayerStatesArray = function(opt_states) {};
+ * Return the {@link ol.Extent extent} of the layer or `undefined` if it
+ * will be visible regardless of extent.
+ * @return {ol.Extent|undefined} The layer extent.
+ * @observable
+ * @api
+ol.layer.Base.prototype.getExtent = function() {
+ return /** @type {ol.Extent|undefined} */ (
+ this.get(ol.layer.Property.EXTENT));
+ * Return the maximum resolution of the layer.
+ * @return {number} The maximum resolution of the layer.
+ * @observable
+ * @api
+ol.layer.Base.prototype.getMaxResolution = function() {
+ return /** @type {number} */ (
+ this.get(ol.layer.Property.MAX_RESOLUTION));
+ * Return the minimum resolution of the layer.
+ * @return {number} The minimum resolution of the layer.
+ * @observable
+ * @api
+ol.layer.Base.prototype.getMinResolution = function() {
+ this.get(ol.layer.Property.MIN_RESOLUTION));
+ * Return the opacity of the layer (between 0 and 1).
+ * @return {number} The opacity of the layer.
+ * @observable
+ * @api
+ol.layer.Base.prototype.getOpacity = function() {
+ return /** @type {number} */ (this.get(ol.layer.Property.OPACITY));
+ * @abstract
+ * @return {ol.source.State} Source state.
+ol.layer.Base.prototype.getSourceState = function() {};
+ * Return the visibility of the layer (`true` or `false`).
+ * @return {boolean} The visibility of the layer.
+ * @observable
+ * @api
+ol.layer.Base.prototype.getVisible = function() {
+ return /** @type {boolean} */ (this.get(ol.layer.Property.VISIBLE));
+ * Return the Z-index of the layer, which is used to order layers before
+ * rendering. The default Z-index is 0.
+ * @return {number} The Z-index of the layer.
+ * @observable
+ * @api
+ol.layer.Base.prototype.getZIndex = function() {
+ return /** @type {number} */ (this.get(ol.layer.Property.Z_INDEX));
+ * Set the extent at which the layer is visible. If `undefined`, the layer
+ * will be visible at all extents.
+ * @param {ol.Extent|undefined} extent The extent of the layer.
+ * @observable
+ * @api
+ol.layer.Base.prototype.setExtent = function(extent) {
+ this.set(ol.layer.Property.EXTENT, extent);
+ * Set the maximum resolution at which the layer is visible.
+ * @param {number} maxResolution The maximum resolution of the layer.
+ * @observable
+ * @api
+ol.layer.Base.prototype.setMaxResolution = function(maxResolution) {
+ this.set(ol.layer.Property.MAX_RESOLUTION, maxResolution);
+ * Set the minimum resolution at which the layer is visible.
+ * @param {number} minResolution The minimum resolution of the layer.
+ * @observable
+ * @api
+ol.layer.Base.prototype.setMinResolution = function(minResolution) {
+ this.set(ol.layer.Property.MIN_RESOLUTION, minResolution);
+ * Set the opacity of the layer, allowed values range from 0 to 1.
+ * @param {number} opacity The opacity of the layer.
+ * @observable
+ * @api
+ol.layer.Base.prototype.setOpacity = function(opacity) {
+ this.set(ol.layer.Property.OPACITY, opacity);
+ * Set the visibility of the layer (`true` or `false`).
+ * @param {boolean} visible The visibility of the layer.
+ * @observable
+ * @api
+ol.layer.Base.prototype.setVisible = function(visible) {
+ this.set(ol.layer.Property.VISIBLE, visible);
+ * Set Z-index of the layer, which is used to order layers before rendering.
+ * The default Z-index is 0.
+ * @param {number} zindex The z-index of the layer.
+ * @observable
+ * @api
+ol.layer.Base.prototype.setZIndex = function(zindex) {
+ this.set(ol.layer.Property.Z_INDEX, zindex);
+goog.provide('ol.source.State');
+ * State of the source, one of 'undefined', 'loading', 'ready' or 'error'.
+ * @enum {string}
+ol.source.State = {
+ UNDEFINED: 'undefined',
+ LOADING: 'loading',
+ READY: 'ready',
+ ERROR: 'error'
+goog.provide('ol.layer.Group');
+goog.require('ol.CollectionEventType');
+goog.require('ol.ObjectEventType');
+goog.require('ol.asserts');
+goog.require('ol.events');
+goog.require('ol.layer.Base');
+goog.require('ol.source.State');
+ * @classdesc
+ * A {@link ol.Collection} of layers that are handled together.
+ * A generic `change` event is triggered when the group/Collection changes.
+ * @constructor
+ * @extends {ol.layer.Base}
+ * @param {olx.layer.GroupOptions=} opt_options Layer options.
+ * @api
+ol.layer.Group = function(opt_options) {
+ var options = opt_options || {};
+ var baseOptions = /** @type {olx.layer.GroupOptions} */
+ (ol.obj.assign({}, options));
+ delete baseOptions.layers;
+ var layers = options.layers;
+ ol.layer.Base.call(this, baseOptions);
+ * @private
+ * @type {Array.<ol.EventsKey>}
+ this.layersListenerKeys_ = [];
+ * @private
+ * @type {Object.<string, Array.<ol.EventsKey>>}
+ this.listenerKeys_ = {};
+ ol.events.listen(this,
+ ol.Object.getChangeEventType(ol.layer.Group.Property_.LAYERS),
+ this.handleLayersChanged_, this);
+ if (layers) {
+ if (Array.isArray(layers)) {
+ layers = new ol.Collection(layers.slice(), {unique: true});
+ } else {
+ ol.asserts.assert(layers instanceof ol.Collection,
+ 43); // Expected `layers` to be an array or an `ol.Collection`
+ layers = layers;
+ } else {
+ layers = new ol.Collection(undefined, {unique: true});
+ this.setLayers(layers);
+ol.inherits(ol.layer.Group, ol.layer.Base);
+ * @inheritDoc
+ol.layer.Group.prototype.createRenderer = function(mapRenderer) {};
+ * @private
+ol.layer.Group.prototype.handleLayerChange_ = function() {
+ if (this.getVisible()) {
+ this.changed();
+ * @param {ol.events.Event} event Event.
+ * @private
+ol.layer.Group.prototype.handleLayersChanged_ = function(event) {
+ this.layersListenerKeys_.forEach(ol.events.unlistenByKey);
+ this.layersListenerKeys_.length = 0;
+ var layers = this.getLayers();
+ this.layersListenerKeys_.push(
+ ol.events.listen(layers, ol.CollectionEventType.ADD,
+ this.handleLayersAdd_, this),
+ ol.events.listen(layers, ol.CollectionEventType.REMOVE,
+ this.handleLayersRemove_, this));
+ for (var id in this.listenerKeys_) {
+ this.listenerKeys_[id].forEach(ol.events.unlistenByKey);
+ ol.obj.clear(this.listenerKeys_);
+ var layersArray = layers.getArray();
+ var i, ii, layer;
+ for (i = 0, ii = layersArray.length; i < ii; i++) {
+ layer = layersArray[i];
+ this.listenerKeys_[ol.getUid(layer).toString()] = [
+ ol.events.listen(layer, ol.ObjectEventType.PROPERTYCHANGE,
+ this.handleLayerChange_, this),
+ ol.events.listen(layer, ol.events.EventType.CHANGE,
+ this.changed();
+ * @param {ol.Collection.Event} collectionEvent Collection event.
+ * @private
+ol.layer.Group.prototype.handleLayersAdd_ = function(collectionEvent) {
+ var layer = /** @type {ol.layer.Base} */ (collectionEvent.element);
+ var key = ol.getUid(layer).toString();
+ this.listenerKeys_[key] = [
+ this.changed();
+ * @private
+ol.layer.Group.prototype.handleLayersRemove_ = function(collectionEvent) {
+ this.listenerKeys_[key].forEach(ol.events.unlistenByKey);
+ delete this.listenerKeys_[key];
+ this.changed();
+ * Returns the {@link ol.Collection collection} of {@link ol.layer.Layer layers}
+ * in this group.
+ * @return {!ol.Collection.<ol.layer.Base>} Collection of
+ * {@link ol.layer.Base layers} that are part of this group.
+ * @observable
+ * @api
+ol.layer.Group.prototype.getLayers = function() {
+ return /** @type {!ol.Collection.<ol.layer.Base>} */ (this.get(
+ ol.layer.Group.Property_.LAYERS));
+ * Set the {@link ol.Collection collection} of {@link ol.layer.Layer layers}
+ * in this group.
+ * @param {!ol.Collection.<ol.layer.Base>} layers Collection of
+ * @observable
+ * @api
+ol.layer.Group.prototype.setLayers = function(layers) {
+ this.set(ol.layer.Group.Property_.LAYERS, layers);
+ * @inheritDoc
+ol.layer.Group.prototype.getLayersArray = function(opt_array) {
+ var array = opt_array !== undefined ? opt_array : [];
+ this.getLayers().forEach(function(layer) {
+ layer.getLayersArray(array);
+ return array;
+ * @inheritDoc
+ol.layer.Group.prototype.getLayerStatesArray = function(opt_states) {
+ var states = opt_states !== undefined ? opt_states : [];
+ var pos = states.length;
+ layer.getLayerStatesArray(states);
+ var ownLayerState = this.getLayerState();
+ var i, ii, layerState;
+ for (i = pos, ii = states.length; i < ii; i++) {
+ layerState = states[i];
+ layerState.opacity *= ownLayerState.opacity;
+ layerState.visible = layerState.visible && ownLayerState.visible;
+ layerState.maxResolution = Math.min(
+ layerState.maxResolution, ownLayerState.maxResolution);
+ layerState.minResolution = Math.max(
+ layerState.minResolution, ownLayerState.minResolution);
+ if (ownLayerState.extent !== undefined) {
+ if (layerState.extent !== undefined) {
+ layerState.extent = ol.extent.getIntersection(
+ layerState.extent, ownLayerState.extent);
+ } else {
+ layerState.extent = ownLayerState.extent;
+ return states;
+ * @inheritDoc
+ol.layer.Group.prototype.getSourceState = function() {
+ return ol.source.State.READY;
+ * @enum {string}
+ * @private
+ol.layer.Group.Property_ = {
+ LAYERS: 'layers'
+goog.provide('ol.render.EventType');
+ * @enum {string}
+ol.render.EventType = {
+ * @event ol.render.Event#postcompose
+ * @api
+ POSTCOMPOSE: 'postcompose',
+ * @event ol.render.Event#precompose
+ * @api
+ PRECOMPOSE: 'precompose',
+ * @event ol.render.Event#render
+ * @api
+ RENDER: 'render'
+goog.provide('ol.layer.Layer');
+goog.require('ol.render.EventType');
+ * @classdesc
+ * Abstract base class; normally only used for creating subclasses and not
+ * instantiated in apps.
+ * A visual representation of raster or vector map data.
+ * Layers group together those properties that pertain to how the data is to be
+ * displayed, irrespective of the source of that data.
+ * Layers are usually added to a map with {@link ol.Map#addLayer}. Components
+ * like {@link ol.interaction.Select} use unmanaged layers internally. These
+ * unmanaged layers are associated with the map using
+ * {@link ol.layer.Layer#setMap} instead.
+ * A generic `change` event is fired when the state of the source changes.
+ * @constructor
+ * @abstract
+ * @fires ol.render.Event
+ * @param {olx.layer.LayerOptions} options Layer options.
+ * @api
+ol.layer.Layer = function(options) {
+ var baseOptions = ol.obj.assign({}, options);
+ delete baseOptions.source;
+ ol.layer.Base.call(this, /** @type {olx.layer.BaseOptions} */ (baseOptions));
+ * @private
+ * @type {?ol.EventsKey}
+ this.mapPrecomposeKey_ = null;
+ * @private
+ this.mapRenderKey_ = null;
+ * @private
+ this.sourceChangeKey_ = null;
+ if (options.map) {
+ this.setMap(options.map);
+ ol.Object.getChangeEventType(ol.layer.Property.SOURCE),
+ this.handleSourcePropertyChange_, this);
+ var source = options.source ? options.source : null;
+ this.setSource(source);
+ol.inherits(ol.layer.Layer, ol.layer.Base);
+ * Return `true` if the layer is visible, and if the passed resolution is
+ * between the layer's minResolution and maxResolution. The comparison is
+ * inclusive for `minResolution` and exclusive for `maxResolution`.
+ * @param {ol.LayerState} layerState Layer state.
+ * @param {number} resolution Resolution.
+ * @return {boolean} The layer is visible at the given resolution.
+ol.layer.Layer.visibleAtResolution = function(layerState, resolution) {
+ return layerState.visible && resolution >= layerState.minResolution &&
+ resolution < layerState.maxResolution;
+ * @inheritDoc
+ol.layer.Layer.prototype.getLayersArray = function(opt_array) {
+ var array = opt_array ? opt_array : [];
+ array.push(this);
+ return array;
+ * @inheritDoc
+ol.layer.Layer.prototype.getLayerStatesArray = function(opt_states) {
+ var states = opt_states ? opt_states : [];
+ states.push(this.getLayerState());
+ return states;
+ * Get the layer source.
+ * @return {ol.source.Source} The layer source (or `null` if not yet set).
+ * @observable
+ * @api
+ol.layer.Layer.prototype.getSource = function() {
+ var source = this.get(ol.layer.Property.SOURCE);
+ return /** @type {ol.source.Source} */ (source) || null;
+ * @inheritDoc
+ol.layer.Layer.prototype.getSourceState = function() {
+ var source = this.getSource();
+ return !source ? ol.source.State.UNDEFINED : source.getState();
+ * @private
+ol.layer.Layer.prototype.handleSourceChange_ = function() {
+ this.changed();
+ * @private
+ol.layer.Layer.prototype.handleSourcePropertyChange_ = function() {
+ if (this.sourceChangeKey_) {
+ ol.events.unlistenByKey(this.sourceChangeKey_);
+ if (source) {
+ this.sourceChangeKey_ = ol.events.listen(source,
+ ol.events.EventType.CHANGE, this.handleSourceChange_, this);
+ this.changed();
+ * Sets the layer to be rendered on top of other layers on a map. The map will
+ * not manage this layer in its layers collection, and the callback in
+ * {@link ol.Map#forEachLayerAtPixel} will receive `null` as layer. This
+ * is useful for temporary layers. To remove an unmanaged layer from the map,
+ * use `#setMap(null)`.
+ * To add the layer to a map and have it managed by the map, use
+ * {@link ol.Map#addLayer} instead.
+ * @param {ol.Map} map Map.
+ * @api
+ol.layer.Layer.prototype.setMap = function(map) {
+ if (this.mapPrecomposeKey_) {
+ ol.events.unlistenByKey(this.mapPrecomposeKey_);
+ if (!map) {
+ this.changed();
+ if (this.mapRenderKey_) {
+ ol.events.unlistenByKey(this.mapRenderKey_);
+ if (map) {
+ this.mapPrecomposeKey_ = ol.events.listen(
+ map, ol.render.EventType.PRECOMPOSE, function(evt) {
+ var layerState = this.getLayerState();
+ layerState.managed = false;
+ layerState.zIndex = Infinity;
+ evt.frameState.layerStatesArray.push(layerState);
+ evt.frameState.layerStates[ol.getUid(this)] = layerState;
+ }, this);
+ this.mapRenderKey_ = ol.events.listen(
+ this, ol.events.EventType.CHANGE, map.render, map);
+ this.changed();
+ * Set the layer source.
+ * @param {ol.source.Source} source The layer source.
+ * @observable
+ * @api
+ol.layer.Layer.prototype.setSource = function(source) {
+ this.set(ol.layer.Property.SOURCE, source);
+goog.provide('ol.style.IconImageCache');
+goog.require('ol.color');
+ * @constructor
+ol.style.IconImageCache = function() {
+ * @type {Object.<string, ol.style.IconImage>}
+ * @private
+ this.cache_ = {};
+ * @type {number}
+ * @private
+ this.cacheSize_ = 0;
+ * @const
+ * @type {number}
+ * @private
+ this.maxCacheSize_ = 32;
+ * @param {string} src Src.
+ * @param {?string} crossOrigin Cross origin.
+ * @param {ol.Color} color Color.
+ * @return {string} Cache key.
+ol.style.IconImageCache.getKey = function(src, crossOrigin, color) {
+ var colorString = color ? ol.color.asString(color) : 'null';
+ return crossOrigin + ':' + src + ':' + colorString;
+ * FIXME empty description for jsdoc
+ol.style.IconImageCache.prototype.clear = function() {
+ this.cache_ = {};
+ol.style.IconImageCache.prototype.expire = function() {
+ if (this.cacheSize_ > this.maxCacheSize_) {
+ var i = 0;
+ var key, iconImage;
+ for (key in this.cache_) {
+ iconImage = this.cache_[key];
+ if ((i++ & 3) === 0 && !iconImage.hasListener()) {
+ delete this.cache_[key];
+ --this.cacheSize_;
+ * @return {ol.style.IconImage} Icon image.
+ol.style.IconImageCache.prototype.get = function(src, crossOrigin, color) {
+ var key = ol.style.IconImageCache.getKey(src, crossOrigin, color);
+ return key in this.cache_ ? this.cache_[key] : null;
+ * @param {ol.style.IconImage} iconImage Icon image.
+ol.style.IconImageCache.prototype.set = function(src, crossOrigin, color, iconImage) {
+ this.cache_[key] = iconImage;
+ ++this.cacheSize_;
+goog.provide('ol.style');
+goog.require('ol.style.IconImageCache');
+ol.style.iconImageCache = new ol.style.IconImageCache();
+goog.provide('ol.transform');
+ * Collection of affine 2d transformation functions. The functions work on an
+ * array of 6 elements. The element order is compatible with the [SVGMatrix
+ * interface](https://developer.mozilla.org/en-US/docs/Web/API/SVGMatrix) and is
+ * a subset (elements a to f) of a 3x3 martrix:
+ * [ a c e ]
+ * [ b d f ]
+ * [ 0 0 1 ]
+ * @private
+ * @type {ol.Transform}
+ol.transform.tmp_ = new Array(6);
+ * Create an identity transform.
+ * @return {!ol.Transform} Identity transform.
+ol.transform.create = function() {
+ return [1, 0, 0, 1, 0, 0];
+ * Resets the given transform to an identity transform.
+ * @param {!ol.Transform} transform Transform.
+ * @return {!ol.Transform} Transform.
+ol.transform.reset = function(transform) {
+ return ol.transform.set(transform, 1, 0, 0, 1, 0, 0);
+ * Multiply the underlying matrices of two transforms and return the result in
+ * the first transform.
+ * @param {!ol.Transform} transform1 Transform parameters of matrix 1.
+ * @param {!ol.Transform} transform2 Transform parameters of matrix 2.
+ * @return {!ol.Transform} transform1 multiplied with transform2.
+ol.transform.multiply = function(transform1, transform2) {
+ var a1 = transform1[0];
+ var b1 = transform1[1];
+ var c1 = transform1[2];
+ var d1 = transform1[3];
+ var e1 = transform1[4];
+ var f1 = transform1[5];
+ var a2 = transform2[0];
+ var b2 = transform2[1];
+ var c2 = transform2[2];
+ var d2 = transform2[3];
+ var e2 = transform2[4];
+ var f2 = transform2[5];
+ transform1[0] = a1 * a2 + c1 * b2;
+ transform1[1] = b1 * a2 + d1 * b2;
+ transform1[2] = a1 * c2 + c1 * d2;
+ transform1[3] = b1 * c2 + d1 * d2;
+ transform1[4] = a1 * e2 + c1 * f2 + e1;
+ transform1[5] = b1 * e2 + d1 * f2 + f1;
+ return transform1;
+ * Set the transform components a-f on a given transform.
+ * @param {number} a The a component of the transform.
+ * @param {number} b The b component of the transform.
+ * @param {number} c The c component of the transform.
+ * @param {number} d The d component of the transform.
+ * @param {number} e The e component of the transform.
+ * @param {number} f The f component of the transform.
+ * @return {!ol.Transform} Matrix with transform applied.
+ol.transform.set = function(transform, a, b, c, d, e, f) {
+ transform[0] = a;
+ transform[1] = b;
+ transform[2] = c;
+ transform[3] = d;
+ transform[4] = e;
+ transform[5] = f;
+ return transform;
+ * Set transform on one matrix from another matrix.
+ * @param {!ol.Transform} transform1 Matrix to set transform to.
+ * @param {!ol.Transform} transform2 Matrix to set transform from.
+ * @return {!ol.Transform} transform1 with transform from transform2 applied.
+ol.transform.setFromArray = function(transform1, transform2) {
+ transform1[0] = transform2[0];
+ transform1[1] = transform2[1];
+ transform1[2] = transform2[2];
+ transform1[3] = transform2[3];
+ transform1[4] = transform2[4];
+ transform1[5] = transform2[5];
+ * Transforms the given coordinate with the given transform returning the
+ * resulting, transformed coordinate. The coordinate will be modified in-place.
+ * @param {ol.Transform} transform The transformation.
+ * @param {ol.Coordinate|ol.Pixel} coordinate The coordinate to transform.
+ * @return {ol.Coordinate|ol.Pixel} return coordinate so that operations can be
+ * chained together.
+ol.transform.apply = function(transform, coordinate) {
+ var x = coordinate[0], y = coordinate[1];
+ coordinate[0] = transform[0] * x + transform[2] * y + transform[4];
+ coordinate[1] = transform[1] * x + transform[3] * y + transform[5];
+ return coordinate;
+ * Applies rotation to the given transform.
+ * @param {number} angle Angle in radians.
+ * @return {!ol.Transform} The rotated transform.
+ol.transform.rotate = function(transform, angle) {
+ var cos = Math.cos(angle);
+ var sin = Math.sin(angle);
+ return ol.transform.multiply(transform,
+ ol.transform.set(ol.transform.tmp_, cos, sin, -sin, cos, 0, 0));
+ * Applies scale to a given transform.
+ * @param {number} x Scale factor x.
+ * @param {number} y Scale factor y.
+ * @return {!ol.Transform} The scaled transform.
+ol.transform.scale = function(transform, x, y) {
+ ol.transform.set(ol.transform.tmp_, x, 0, 0, y, 0, 0));
+ * Applies translation to the given transform.
+ * @param {number} dx Translation x.
+ * @param {number} dy Translation y.
+ * @return {!ol.Transform} The translated transform.
+ol.transform.translate = function(transform, dx, dy) {
+ ol.transform.set(ol.transform.tmp_, 1, 0, 0, 1, dx, dy));
+ * Creates a composite transform given an initial translation, scale, rotation, and
+ * final translation (in that order only, not commutative).
+ * @param {!ol.Transform} transform The transform (will be modified in place).
+ * @param {number} dx1 Initial translation x.
+ * @param {number} dy1 Initial translation y.
+ * @param {number} sx Scale factor x.
+ * @param {number} sy Scale factor y.
+ * @param {number} angle Rotation (in counter-clockwise radians).
+ * @param {number} dx2 Final translation x.
+ * @param {number} dy2 Final translation y.
+ * @return {!ol.Transform} The composite transform.
+ol.transform.compose = function(transform, dx1, dy1, sx, sy, angle, dx2, dy2) {
+ transform[0] = sx * cos;
+ transform[1] = sy * sin;
+ transform[2] = -sx * sin;
+ transform[3] = sy * cos;
+ transform[4] = dx2 * sx * cos - dy2 * sx * sin + dx1;
+ transform[5] = dx2 * sy * sin + dy2 * sy * cos + dy1;
+ return transform;
+ * Invert the given transform.
+ * @return {!ol.Transform} Inverse of the transform.
+ol.transform.invert = function(transform) {
+ var det = ol.transform.determinant(transform);
+ ol.asserts.assert(det !== 0, 32); // Transformation matrix cannot be inverted
+ var a = transform[0];
+ var b = transform[1];
+ var c = transform[2];
+ var d = transform[3];
+ var e = transform[4];
+ var f = transform[5];
+ transform[0] = d / det;
+ transform[1] = -b / det;
+ transform[2] = -c / det;
+ transform[3] = a / det;
+ transform[4] = (c * f - d * e) / det;
+ transform[5] = -(a * f - b * e) / det;
+ return transform;
+ * Returns the determinant of the given matrix.
+ * @param {!ol.Transform} mat Matrix.
+ * @return {number} Determinant.
+ol.transform.determinant = function(mat) {
+ return mat[0] * mat[3] - mat[1] * mat[2];
+goog.provide('ol.renderer.Map');
+goog.require('ol');
+goog.require('ol.functions');
+goog.require('ol.layer.Layer');
+goog.require('ol.style');
+goog.require('ol.transform');
+ * @constructor
+ * @abstract
+ * @param {Element} container Container.
+ * @struct
+ol.renderer.Map = function(container, map) {
+ ol.Disposable.call(this);
+ * @private
+ * @type {ol.Map}
+ this.map_ = map;
+ * @private
+ * @type {Object.<string, ol.renderer.Layer>}
+ this.layerRenderers_ = {};
+ * @private
+ * @type {Object.<string, ol.EventsKey>}
+ this.layerRendererListeners_ = {};
+ol.inherits(ol.renderer.Map, ol.Disposable);
+ * @param {olx.FrameState} frameState FrameState.
+ * @protected
+ol.renderer.Map.prototype.calculateMatrices2D = function(frameState) {
+ var viewState = frameState.viewState;
+ var coordinateToPixelTransform = frameState.coordinateToPixelTransform;
+ var pixelToCoordinateTransform = frameState.pixelToCoordinateTransform;
+ ol.transform.compose(coordinateToPixelTransform,
+ frameState.size[0] / 2, frameState.size[1] / 2,
+ 1 / viewState.resolution, -1 / viewState.resolution,
+ -viewState.rotation,
+ -viewState.center[0], -viewState.center[1]);
+ ol.transform.invert(
+ ol.transform.setFromArray(pixelToCoordinateTransform, coordinateToPixelTransform));
+ * @inheritDoc
+ol.renderer.Map.prototype.disposeInternal = function() {
+ for (var id in this.layerRenderers_) {
+ this.layerRenderers_[id].dispose();
+ * @param {olx.FrameState} frameState Frame state.
+ * @private
+ol.renderer.Map.expireIconCache_ = function(map, frameState) {
+ var cache = ol.style.iconImageCache;
+ cache.expire();
+ * @param {ol.Coordinate} coordinate Coordinate.
+ * @param {number} hitTolerance Hit tolerance in pixels.
+ * @param {function(this: S, (ol.Feature|ol.render.Feature),
+ * ol.layer.Layer): T} callback Feature callback.
+ * @param {S} thisArg Value to use as `this` when executing `callback`.
+ * @param {function(this: U, ol.layer.Layer): boolean} layerFilter Layer filter
+ * function, only layers which are visible and for which this function
+ * returns `true` will be tested for features. By default, all visible
+ * layers will be tested.
+ * @param {U} thisArg2 Value to use as `this` when executing `layerFilter`.
+ * @return {T|undefined} Callback result.
+ * @template S,T,U
+ol.renderer.Map.prototype.forEachFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, callback, thisArg,
+ layerFilter, thisArg2) {
+ var result;
+ var viewResolution = viewState.resolution;
+ * @param {ol.Feature|ol.render.Feature} feature Feature.
+ * @param {ol.layer.Layer} layer Layer.
+ * @return {?} Callback result.
+ function forEachFeatureAtCoordinate(feature, layer) {
+ var key = ol.getUid(feature).toString();
+ var managed = frameState.layerStates[ol.getUid(layer)].managed;
+ if (!(key in frameState.skippedFeatureUids && !managed)) {
+ return callback.call(thisArg, feature, managed ? layer : null);
+ var projection = viewState.projection;
+ var translatedCoordinate = coordinate;
+ if (projection.canWrapX()) {
+ var projectionExtent = projection.getExtent();
+ var worldWidth = ol.extent.getWidth(projectionExtent);
+ var x = coordinate[0];
+ if (x < projectionExtent[0] || x > projectionExtent[2]) {
+ var worldsAway = Math.ceil((projectionExtent[0] - x) / worldWidth);
+ translatedCoordinate = [x + worldWidth * worldsAway, coordinate[1]];
+ var layerStates = frameState.layerStatesArray;
+ var numLayers = layerStates.length;
+ var i;
+ for (i = numLayers - 1; i >= 0; --i) {
+ var layerState = layerStates[i];
+ var layer = layerState.layer;
+ if (ol.layer.Layer.visibleAtResolution(layerState, viewResolution) &&
+ layerFilter.call(thisArg2, layer)) {
+ var layerRenderer = this.getLayerRenderer(layer);
+ if (layer.getSource()) {
+ result = layerRenderer.forEachFeatureAtCoordinate(
+ layer.getSource().getWrapX() ? translatedCoordinate : coordinate,
+ frameState, hitTolerance, forEachFeatureAtCoordinate, thisArg);
+ if (result) {
+ return result;
+ return undefined;
+ * @abstract
+ * @param {ol.Pixel} pixel Pixel.
+ * @param {function(this: S, ol.layer.Layer, (Uint8ClampedArray|Uint8Array)): T} callback Layer
+ * callback.
+ * @template S,T,U
+ol.renderer.Map.prototype.forEachLayerAtPixel = function(pixel, frameState, callback, thisArg,
+ layerFilter, thisArg2) {};
+ * @param {U} thisArg Value to use as `this` when executing `layerFilter`.
+ * @return {boolean} Is there a feature at the given coordinate?
+ * @template U
+ol.renderer.Map.prototype.hasFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, layerFilter, thisArg) {
+ var hasFeature = this.forEachFeatureAtCoordinate(
+ coordinate, frameState, hitTolerance, ol.functions.TRUE, this, layerFilter, thisArg);
+ return hasFeature !== undefined;
+ * @protected
+ * @return {ol.renderer.Layer} Layer renderer.
+ol.renderer.Map.prototype.getLayerRenderer = function(layer) {
+ var layerKey = ol.getUid(layer).toString();
+ if (layerKey in this.layerRenderers_) {
+ return this.layerRenderers_[layerKey];
+ } else {
+ var layerRenderer = layer.createRenderer(this);
+ this.layerRenderers_[layerKey] = layerRenderer;
+ this.layerRendererListeners_[layerKey] = ol.events.listen(layerRenderer,
+ ol.events.EventType.CHANGE, this.handleLayerRendererChange_, this);
+ return layerRenderer;
+ * @param {string} layerKey Layer key.
+ * @protected
+ol.renderer.Map.prototype.getLayerRendererByKey = function(layerKey) {
+ * @protected
+ * @return {Object.<string, ol.renderer.Layer>} Layer renderers.
+ol.renderer.Map.prototype.getLayerRenderers = function() {
+ return this.layerRenderers_;
+ * @return {ol.Map} Map.
+ol.renderer.Map.prototype.getMap = function() {
+ return this.map_;
+ * @abstract
+ * @return {string} Type
+ol.renderer.Map.prototype.getType = function() {};
+ * Handle changes in a layer renderer.
+ * @private
+ol.renderer.Map.prototype.handleLayerRendererChange_ = function() {
+ this.map_.render();
+ * @private
+ol.renderer.Map.prototype.removeLayerRendererByKey_ = function(layerKey) {
+ var layerRenderer = this.layerRenderers_[layerKey];
+ delete this.layerRenderers_[layerKey];
+ ol.events.unlistenByKey(this.layerRendererListeners_[layerKey]);
+ delete this.layerRendererListeners_[layerKey];
+ * Render.
+ * @param {?olx.FrameState} frameState Frame state.
+ol.renderer.Map.prototype.renderFrame = ol.nullFunction;
+ * @private
+ol.renderer.Map.prototype.removeUnusedLayerRenderers_ = function(map, frameState) {
+ var layerKey;
+ for (layerKey in this.layerRenderers_) {
+ if (!frameState || !(layerKey in frameState.layerStates)) {
+ this.removeLayerRendererByKey_(layerKey).dispose();
+ * @protected
+ol.renderer.Map.prototype.scheduleExpireIconCache = function(frameState) {
+ frameState.postRenderFunctions.push(
+ /** @type {ol.PostRenderFunction} */ (ol.renderer.Map.expireIconCache_)
+ * @param {!olx.FrameState} frameState Frame state.
+ * @protected
+ol.renderer.Map.prototype.scheduleRemoveUnusedLayerRenderers = function(frameState) {
+ var layerKey;
+ if (!(layerKey in frameState.layerStates)) {
+ /** @type {ol.PostRenderFunction} */ (this.removeUnusedLayerRenderers_.bind(this))
+ return;
+ * @param {ol.LayerState} state1 First layer state.
+ * @param {ol.LayerState} state2 Second layer state.
+ * @return {number} The zIndex difference.
+ol.renderer.Map.sortByZIndex = function(state1, state2) {
+ return state1.zIndex - state2.zIndex;
+goog.provide('ol.renderer.Type');
+ * Available renderers: `'canvas'` or `'webgl'`.
+ * @enum {string}
+ol.renderer.Type = {
+ CANVAS: 'canvas',
+ WEBGL: 'webgl'
+goog.provide('ol.render.Event');
+ * @constructor
+ * @implements {oli.render.Event}
+ * @param {ol.render.EventType} type Type.
+ * @param {ol.render.VectorContext=} opt_vectorContext Vector context.
+ * @param {olx.FrameState=} opt_frameState Frame state.
+ * @param {?CanvasRenderingContext2D=} opt_context Context.
+ * @param {?ol.webgl.Context=} opt_glContext WebGL Context.
+ol.render.Event = function(
+ type, opt_vectorContext, opt_frameState, opt_context,
+ opt_glContext) {
+ * For canvas, this is an instance of {@link ol.render.canvas.Immediate}.
+ * @type {ol.render.VectorContext|undefined}
+ * @api
+ this.vectorContext = opt_vectorContext;
+ * An object representing the current render frame state.
+ * @type {olx.FrameState|undefined}
+ * @api
+ this.frameState = opt_frameState;
+ * Canvas context. Only available when a Canvas renderer is used, null
+ * otherwise.
+ * @type {CanvasRenderingContext2D|null|undefined}
+ * @api
+ this.context = opt_context;
+ * WebGL context. Only available when a WebGL renderer is used, null
+ * otherwise.
+ * @type {ol.webgl.Context|null|undefined}
+ * @api
+ this.glContext = opt_glContext;
+ol.inherits(ol.render.Event, ol.events.Event);
+goog.provide('ol.render.canvas');
+ * @const
+ * @type {string}
+ol.render.canvas.defaultFont = '10px sans-serif';
+ * @const
+ * @type {ol.Color}
+ol.render.canvas.defaultFillStyle = [0, 0, 0, 1];
+ * @const
+ * @type {string}
+ol.render.canvas.defaultLineCap = 'round';
+ * @const
+ * @type {Array.<number>}
+ol.render.canvas.defaultLineDash = [];
+ * @const
+ * @type {number}
+ol.render.canvas.defaultLineDashOffset = 0;
+ * @const
+ * @type {string}
+ol.render.canvas.defaultLineJoin = 'round';
+ * @const
+ * @type {number}
+ol.render.canvas.defaultMiterLimit = 10;
+ * @const
+ol.render.canvas.defaultStrokeStyle = [0, 0, 0, 1];
+ * @const
+ * @type {string}
+ol.render.canvas.defaultTextAlign = 'center';
+ * @const
+ * @type {string}
+ol.render.canvas.defaultTextBaseline = 'middle';
+ * @const
+ * @type {number}
+ol.render.canvas.defaultLineWidth = 1;
+ * @param {CanvasRenderingContext2D} context Context.
+ * @param {number} rotation Rotation.
+ * @param {number} offsetX X offset.
+ * @param {number} offsetY Y offset.
+ol.render.canvas.rotateAtOffset = function(context, rotation, offsetX, offsetY) {
+ if (rotation !== 0) {
+ context.translate(offsetX, offsetY);
+ context.rotate(rotation);
+ context.translate(-offsetX, -offsetY);
+goog.provide('ol.render.VectorContext');
+ * Context for drawing geometries. A vector context is available on render
+ * events and does not need to be constructed directly.
+ * @constructor
+ * @abstract
+ * @struct
+ * @api
+ol.render.VectorContext = function() {
+ * Render a geometry.
+ * @param {ol.geom.Geometry} geometry The geometry to render.
+ol.render.VectorContext.prototype.drawGeometry = function(geometry) {};
+ * Set the rendering style.
+ * @param {ol.style.Style} style The rendering style.
+ol.render.VectorContext.prototype.setStyle = function(style) {};
+ * @param {ol.geom.Circle} circleGeometry Circle geometry.
+ * @param {ol.Feature} feature Feature.
+ol.render.VectorContext.prototype.drawCircle = function(circleGeometry, feature) {};
+ * @param {ol.style.Style} style Style.
+ol.render.VectorContext.prototype.drawFeature = function(feature, style) {};
+ * @param {ol.geom.GeometryCollection} geometryCollectionGeometry Geometry
+ * collection.
+ol.render.VectorContext.prototype.drawGeometryCollection = function(geometryCollectionGeometry, feature) {};
+ * @param {ol.geom.LineString|ol.render.Feature} lineStringGeometry Line
+ * string geometry.
+ol.render.VectorContext.prototype.drawLineString = function(lineStringGeometry, feature) {};
+ * @param {ol.geom.MultiLineString|ol.render.Feature} multiLineStringGeometry
+ * MultiLineString geometry.
+ol.render.VectorContext.prototype.drawMultiLineString = function(multiLineStringGeometry, feature) {};
+ * @param {ol.geom.MultiPoint|ol.render.Feature} multiPointGeometry MultiPoint
+ * geometry.
+ol.render.VectorContext.prototype.drawMultiPoint = function(multiPointGeometry, feature) {};
+ * @param {ol.geom.MultiPolygon} multiPolygonGeometry MultiPolygon geometry.
+ol.render.VectorContext.prototype.drawMultiPolygon = function(multiPolygonGeometry, feature) {};
+ * @param {ol.geom.Point|ol.render.Feature} pointGeometry Point geometry.
+ol.render.VectorContext.prototype.drawPoint = function(pointGeometry, feature) {};
+ * @param {ol.geom.Polygon|ol.render.Feature} polygonGeometry Polygon
+ * geometry.
+ol.render.VectorContext.prototype.drawPolygon = function(polygonGeometry, feature) {};
+ * @param {Array.<number>} flatCoordinates Flat coordinates.
+ * @param {number} offset Offset.
+ * @param {number} end End.
+ * @param {number} stride Stride.
+ * @param {ol.geom.Geometry|ol.render.Feature} geometry Geometry.
+ol.render.VectorContext.prototype.drawText = function(flatCoordinates, offset, end, stride, geometry, feature) {};
+ * @param {ol.style.Fill} fillStyle Fill style.
+ * @param {ol.style.Stroke} strokeStyle Stroke style.
+ol.render.VectorContext.prototype.setFillStrokeStyle = function(fillStyle, strokeStyle) {};
+ * @param {ol.style.Image} imageStyle Image style.
+ol.render.VectorContext.prototype.setImageStyle = function(imageStyle) {};
+ * @param {ol.style.Text} textStyle Text style.
+ol.render.VectorContext.prototype.setTextStyle = function(textStyle) {};
+// FIXME test, especially polygons with holes and multipolygons
+// FIXME need to handle large thick features (where pixel size matters)
+// FIXME add offset and end to ol.geom.flat.transform.transform2D?
+goog.provide('ol.render.canvas.Immediate');
+goog.require('ol.array');
+goog.require('ol.colorlike');
+goog.require('ol.geom.GeometryType');
+goog.require('ol.geom.SimpleGeometry');
+goog.require('ol.geom.flat.transform');
+goog.require('ol.has');
+goog.require('ol.render.VectorContext');
+goog.require('ol.render.canvas');
+ * @classdesc
+ * A concrete subclass of {@link ol.render.VectorContext} that implements
+ * direct rendering of features and geometries to an HTML5 Canvas context.
+ * Instances of this class are created internally by the library and
+ * provided to application code as vectorContext member of the
+ * {@link ol.render.Event} object associated with postcompose, precompose and
+ * render events emitted by layers and maps.
+ * @constructor
+ * @extends {ol.render.VectorContext}
+ * @param {number} pixelRatio Pixel ratio.
+ * @param {ol.Extent} extent Extent.
+ * @param {ol.Transform} transform Transform.
+ * @param {number} viewRotation View rotation.
+ * @struct
+ol.render.canvas.Immediate = function(context, pixelRatio, extent, transform, viewRotation) {
+ ol.render.VectorContext.call(this);
+ * @private
+ * @type {CanvasRenderingContext2D}
+ this.context_ = context;
+ * @private
+ * @type {number}
+ this.pixelRatio_ = pixelRatio;
+ * @private
+ * @type {ol.Extent}
+ this.extent_ = extent;
+ * @private
+ this.transform_ = transform;
+ * @private
+ * @type {number}
+ this.viewRotation_ = viewRotation;
+ * @private
+ * @type {?ol.CanvasFillState}
+ this.contextFillState_ = null;
+ * @private
+ * @type {?ol.CanvasStrokeState}
+ this.contextStrokeState_ = null;
+ * @private
+ * @type {?ol.CanvasTextState}
+ this.contextTextState_ = null;
+ * @private
+ this.fillState_ = null;
+ * @private
+ this.strokeState_ = null;
+ * @private
+ * @type {HTMLCanvasElement|HTMLVideoElement|Image}
+ this.image_ = null;
+ * @private
+ * @type {number}
+ this.imageAnchorX_ = 0;
+ * @private
+ * @type {number}
+ this.imageAnchorY_ = 0;
+ * @private
+ * @type {number}
+ this.imageHeight_ = 0;
+ * @private
+ * @type {number}
+ this.imageOpacity_ = 0;
+ * @private
+ * @type {number}
+ this.imageOriginX_ = 0;
+ * @private
+ * @type {number}
+ this.imageOriginY_ = 0;
+ * @private
+ * @type {boolean}
+ this.imageRotateWithView_ = false;
+ * @private
+ * @type {number}
+ this.imageRotation_ = 0;
+ * @private
+ * @type {number}
+ this.imageScale_ = 0;
+ * @private
+ * @type {boolean}
+ this.imageSnapToPixel_ = false;
+ * @private
+ * @type {number}
+ this.imageWidth_ = 0;
+ * @private
+ * @type {string}
+ this.text_ = '';
+ * @private
+ * @type {number}
+ this.textOffsetX_ = 0;
+ * @private
+ * @type {number}
+ this.textOffsetY_ = 0;
+ * @private
+ * @type {boolean}
+ this.textRotateWithView_ = false;
+ * @private
+ * @type {number}
+ this.textRotation_ = 0;
+ * @private
+ * @type {number}
+ this.textScale_ = 0;
+ * @private
+ this.textFillState_ = null;
+ * @private
+ this.textStrokeState_ = null;
+ * @private
+ this.textState_ = null;
+ * @private
+ this.pixelCoordinates_ = [];
+ * @private
+ this.tmpLocalTransform_ = ol.transform.create();
+ol.inherits(ol.render.canvas.Immediate, ol.render.VectorContext);
+ * @private
+ol.render.canvas.Immediate.prototype.drawImages_ = function(flatCoordinates, offset, end, stride) {
+ if (!this.image_) {
+ return;
+ var pixelCoordinates = ol.geom.flat.transform.transform2D(
+ flatCoordinates, offset, end, 2, this.transform_,
+ this.pixelCoordinates_);
+ var context = this.context_;
+ var localTransform = this.tmpLocalTransform_;
+ var alpha = context.globalAlpha;
+ if (this.imageOpacity_ != 1) {
+ context.globalAlpha = alpha * this.imageOpacity_;
+ var rotation = this.imageRotation_;
+ if (this.imageRotateWithView_) {
+ rotation += this.viewRotation_;
+ var i, ii;
+ for (i = 0, ii = pixelCoordinates.length; i < ii; i += 2) {
+ var x = pixelCoordinates[i] - this.imageAnchorX_;
+ var y = pixelCoordinates[i + 1] - this.imageAnchorY_;
+ if (this.imageSnapToPixel_) {
+ x = Math.round(x);
+ y = Math.round(y);
+ if (rotation !== 0 || this.imageScale_ != 1) {
+ var centerX = x + this.imageAnchorX_;
+ var centerY = y + this.imageAnchorY_;
+ ol.transform.compose(localTransform,
+ centerX, centerY,
+ this.imageScale_, this.imageScale_,
+ rotation,
+ -centerX, -centerY);
+ context.setTransform.apply(context, localTransform);
+ context.drawImage(this.image_, this.imageOriginX_, this.imageOriginY_,
+ this.imageWidth_, this.imageHeight_, x, y,
+ this.imageWidth_, this.imageHeight_);
+ context.setTransform(1, 0, 0, 1, 0, 0);
+ context.globalAlpha = alpha;
+ * @private
+ol.render.canvas.Immediate.prototype.drawText_ = function(flatCoordinates, offset, end, stride) {
+ if (!this.textState_ || this.text_ === '') {
+ return;
+ if (this.textFillState_) {
+ this.setContextFillState_(this.textFillState_);
+ if (this.textStrokeState_) {
+ this.setContextStrokeState_(this.textStrokeState_);
+ this.setContextTextState_(this.textState_);
+ flatCoordinates, offset, end, stride, this.transform_,
+ var rotation = this.textRotation_;
+ if (this.textRotateWithView_) {
+ for (; offset < end; offset += stride) {
+ var x = pixelCoordinates[offset] + this.textOffsetX_;
+ var y = pixelCoordinates[offset + 1] + this.textOffsetY_;
+ if (rotation !== 0 || this.textScale_ != 1) {
+ var localTransform = ol.transform.compose(this.tmpLocalTransform_,
+ x, y,
+ this.textScale_, this.textScale_,
+ rotation,
+ -x, -y);
+ context.strokeText(this.text_, x, y);
+ context.fillText(this.text_, x, y);
+ * @param {boolean} close Close.
+ * @private
+ * @return {number} end End.
+ol.render.canvas.Immediate.prototype.moveToLineTo_ = function(flatCoordinates, offset, end, stride, close) {
+ context.moveTo(pixelCoordinates[0], pixelCoordinates[1]);
+ var length = pixelCoordinates.length;
+ if (close) {
+ length -= 2;
+ for (var i = 2; i < length; i += 2) {
+ context.lineTo(pixelCoordinates[i], pixelCoordinates[i + 1]);
+ if (close) {
+ context.closePath();
+ return end;
+ * @param {Array.<number>} ends Ends.
+ * @private
+ * @return {number} End.
+ol.render.canvas.Immediate.prototype.drawRings_ = function(flatCoordinates, offset, ends, stride) {
+ var i, ii;
+ for (i = 0, ii = ends.length; i < ii; ++i) {
+ offset = this.moveToLineTo_(
+ flatCoordinates, offset, ends[i], stride, true);
+ return offset;
+ * Render a circle geometry into the canvas. Rendering is immediate and uses
+ * the current fill and stroke styles.
+ * @param {ol.geom.Circle} geometry Circle geometry.
+ * @override
+ * @api
+ol.render.canvas.Immediate.prototype.drawCircle = function(geometry) {
+ if (!ol.extent.intersects(this.extent_, geometry.getExtent())) {
+ return;
+ if (this.fillState_ || this.strokeState_) {
+ if (this.fillState_) {
+ this.setContextFillState_(this.fillState_);
+ if (this.strokeState_) {
+ this.setContextStrokeState_(this.strokeState_);
+ var pixelCoordinates = ol.geom.SimpleGeometry.transform2D(
+ geometry, this.transform_, this.pixelCoordinates_);
+ var dx = pixelCoordinates[2] - pixelCoordinates[0];
+ var dy = pixelCoordinates[3] - pixelCoordinates[1];
+ var radius = Math.sqrt(dx * dx + dy * dy);
+ context.beginPath();
+ context.arc(
+ pixelCoordinates[0], pixelCoordinates[1], radius, 0, 2 * Math.PI);
+ context.fill();
+ context.stroke();
+ if (this.text_ !== '') {
+ this.drawText_(geometry.getCenter(), 0, 2, 2);
+ * Set the rendering style. Note that since this is an immediate rendering API,
+ * any `zIndex` on the provided style will be ignored.
+ * @override
+ * @api
+ol.render.canvas.Immediate.prototype.setStyle = function(style) {
+ this.setFillStrokeStyle(style.getFill(), style.getStroke());
+ this.setImageStyle(style.getImage());
+ this.setTextStyle(style.getText());
+ * Render a geometry into the canvas. Call
+ * {@link ol.render.canvas.Immediate#setStyle} first to set the rendering style.
+ * @param {ol.geom.Geometry|ol.render.Feature} geometry The geometry to render.
+ * @override
+ * @api
+ol.render.canvas.Immediate.prototype.drawGeometry = function(geometry) {
+ var type = geometry.getType();
+ switch (type) {
+ case ol.geom.GeometryType.POINT:
+ this.drawPoint(/** @type {ol.geom.Point} */ (geometry));
+ break;
+ case ol.geom.GeometryType.LINE_STRING:
+ this.drawLineString(/** @type {ol.geom.LineString} */ (geometry));
+ break;
+ case ol.geom.GeometryType.POLYGON:
+ this.drawPolygon(/** @type {ol.geom.Polygon} */ (geometry));
+ break;
+ case ol.geom.GeometryType.MULTI_POINT:
+ this.drawMultiPoint(/** @type {ol.geom.MultiPoint} */ (geometry));
+ break;
+ case ol.geom.GeometryType.MULTI_LINE_STRING:
+ this.drawMultiLineString(/** @type {ol.geom.MultiLineString} */ (geometry));
+ break;
+ case ol.geom.GeometryType.MULTI_POLYGON:
+ this.drawMultiPolygon(/** @type {ol.geom.MultiPolygon} */ (geometry));
+ break;
+ case ol.geom.GeometryType.GEOMETRY_COLLECTION:
+ this.drawGeometryCollection(/** @type {ol.geom.GeometryCollection} */ (geometry));
+ break;
+ case ol.geom.GeometryType.CIRCLE:
+ this.drawCircle(/** @type {ol.geom.Circle} */ (geometry));
+ break;
+ default:
+ * Render a feature into the canvas. Note that any `zIndex` on the provided
+ * style will be ignored - features are rendered immediately in the order that
+ * this method is called. If you need `zIndex` support, you should be using an
+ * {@link ol.layer.Vector} instead.
+ * @override
+ * @api
+ol.render.canvas.Immediate.prototype.drawFeature = function(feature, style) {
+ var geometry = style.getGeometryFunction()(feature);
+ if (!geometry ||
+ !ol.extent.intersects(this.extent_, geometry.getExtent())) {
+ return;
+ this.setStyle(style);
+ this.drawGeometry(geometry);
+ * Render a GeometryCollection to the canvas. Rendering is immediate and
+ * uses the current styles appropriate for each geometry in the collection.
+ * @param {ol.geom.GeometryCollection} geometry Geometry collection.
+ * @override
+ol.render.canvas.Immediate.prototype.drawGeometryCollection = function(geometry) {
+ var geometries = geometry.getGeometriesArray();
+ var i, ii;
+ for (i = 0, ii = geometries.length; i < ii; ++i) {
+ this.drawGeometry(geometries[i]);
+ * Render a Point geometry into the canvas. Rendering is immediate and uses
+ * the current style.
+ * @param {ol.geom.Point|ol.render.Feature} geometry Point geometry.
+ * @override
+ol.render.canvas.Immediate.prototype.drawPoint = function(geometry) {
+ var flatCoordinates = geometry.getFlatCoordinates();
+ var stride = geometry.getStride();
+ if (this.image_) {
+ this.drawImages_(flatCoordinates, 0, flatCoordinates.length, stride);
+ this.drawText_(flatCoordinates, 0, flatCoordinates.length, stride);
+ * Render a MultiPoint geometry into the canvas. Rendering is immediate and
+ * uses the current style.
+ * @param {ol.geom.MultiPoint|ol.render.Feature} geometry MultiPoint geometry.
+ * @override
+ol.render.canvas.Immediate.prototype.drawMultiPoint = function(geometry) {
+ * Render a LineString into the canvas. Rendering is immediate and uses
+ * @param {ol.geom.LineString|ol.render.Feature} geometry LineString geometry.
+ * @override
+ol.render.canvas.Immediate.prototype.drawLineString = function(geometry) {
+ return;
+ this.moveToLineTo_(flatCoordinates, 0, flatCoordinates.length,
+ geometry.getStride(), false);
+ context.stroke();
+ var flatMidpoint = geometry.getFlatMidpoint();
+ this.drawText_(flatMidpoint, 0, 2, 2);
+ * Render a MultiLineString geometry into the canvas. Rendering is immediate
+ * and uses the current style.
+ * @param {ol.geom.MultiLineString|ol.render.Feature} geometry MultiLineString
+ * geometry.
+ * @override
+ol.render.canvas.Immediate.prototype.drawMultiLineString = function(geometry) {
+ var geometryExtent = geometry.getExtent();
+ if (!ol.extent.intersects(this.extent_, geometryExtent)) {
+ return;
+ var offset = 0;
+ var ends = geometry.getEnds();
+ var i, ii;
+ flatCoordinates, offset, ends[i], stride, false);
+ context.stroke();
+ var flatMidpoints = geometry.getFlatMidpoints();
+ this.drawText_(flatMidpoints, 0, flatMidpoints.length, 2);
+ * Render a Polygon geometry into the canvas. Rendering is immediate and uses
+ * @param {ol.geom.Polygon|ol.render.Feature} geometry Polygon geometry.
+ * @override
+ol.render.canvas.Immediate.prototype.drawPolygon = function(geometry) {
+ return;
+ if (this.strokeState_ || this.fillState_) {
+ this.drawRings_(geometry.getOrientedFlatCoordinates(),
+ 0, geometry.getEnds(), geometry.getStride());
+ context.fill();
+ context.stroke();
+ var flatInteriorPoint = geometry.getFlatInteriorPoint();
+ this.drawText_(flatInteriorPoint, 0, 2, 2);
+ * Render MultiPolygon geometry into the canvas. Rendering is immediate and
+ * @param {ol.geom.MultiPolygon} geometry MultiPolygon geometry.
+ * @override
+ol.render.canvas.Immediate.prototype.drawMultiPolygon = function(geometry) {
+ return;
+ var flatCoordinates = geometry.getOrientedFlatCoordinates();
+ var offset = 0;
+ var endss = geometry.getEndss();
+ var i, ii;
+ for (i = 0, ii = endss.length; i < ii; ++i) {
+ var ends = endss[i];
+ offset = this.drawRings_(flatCoordinates, offset, ends, stride);
+ context.fill();
+ context.stroke();
+ var flatInteriorPoints = geometry.getFlatInteriorPoints();
+ this.drawText_(flatInteriorPoints, 0, flatInteriorPoints.length, 2);
+ * @param {ol.CanvasFillState} fillState Fill state.
+ * @private
+ol.render.canvas.Immediate.prototype.setContextFillState_ = function(fillState) {
+ var contextFillState = this.contextFillState_;
+ if (!contextFillState) {
+ context.fillStyle = fillState.fillStyle;
+ this.contextFillState_ = {
+ fillStyle: fillState.fillStyle
+ } else {
+ if (contextFillState.fillStyle != fillState.fillStyle) {
+ contextFillState.fillStyle = context.fillStyle = fillState.fillStyle;
+ * @param {ol.CanvasStrokeState} strokeState Stroke state.
+ * @private
+ol.render.canvas.Immediate.prototype.setContextStrokeState_ = function(strokeState) {
+ var contextStrokeState = this.contextStrokeState_;
+ if (!contextStrokeState) {
+ context.lineCap = strokeState.lineCap;
+ if (ol.has.CANVAS_LINE_DASH) {
+ context.setLineDash(strokeState.lineDash);
+ context.lineJoin = strokeState.lineJoin;
+ context.lineWidth = strokeState.lineWidth;
+ context.miterLimit = strokeState.miterLimit;
+ context.strokeStyle = strokeState.strokeStyle;
+ this.contextStrokeState_ = {
+ lineCap: strokeState.lineCap,
+ lineDash: strokeState.lineDash,
+ lineJoin: strokeState.lineJoin,
+ lineWidth: strokeState.lineWidth,
+ miterLimit: strokeState.miterLimit,
+ strokeStyle: strokeState.strokeStyle
+ } else {
+ if (contextStrokeState.lineCap != strokeState.lineCap) {
+ contextStrokeState.lineCap = context.lineCap = strokeState.lineCap;
+ if (!ol.array.equals(
+ contextStrokeState.lineDash, strokeState.lineDash)) {
+ context.setLineDash(contextStrokeState.lineDash = strokeState.lineDash);
+ if (contextStrokeState.lineJoin != strokeState.lineJoin) {
+ contextStrokeState.lineJoin = context.lineJoin = strokeState.lineJoin;
+ if (contextStrokeState.lineWidth != strokeState.lineWidth) {
+ contextStrokeState.lineWidth = context.lineWidth = strokeState.lineWidth;
+ if (contextStrokeState.miterLimit != strokeState.miterLimit) {
+ contextStrokeState.miterLimit = context.miterLimit =
+ strokeState.miterLimit;
+ if (contextStrokeState.strokeStyle != strokeState.strokeStyle) {
+ contextStrokeState.strokeStyle = context.strokeStyle =
+ strokeState.strokeStyle;
+ * @param {ol.CanvasTextState} textState Text state.
+ * @private
+ol.render.canvas.Immediate.prototype.setContextTextState_ = function(textState) {
+ var contextTextState = this.contextTextState_;
+ if (!contextTextState) {
+ context.font = textState.font;
+ context.textAlign = textState.textAlign;
+ context.textBaseline = textState.textBaseline;
+ this.contextTextState_ = {
+ font: textState.font,
+ textAlign: textState.textAlign,
+ textBaseline: textState.textBaseline
+ } else {
+ if (contextTextState.font != textState.font) {
+ contextTextState.font = context.font = textState.font;
+ if (contextTextState.textAlign != textState.textAlign) {
+ contextTextState.textAlign = context.textAlign = textState.textAlign;
+ if (contextTextState.textBaseline != textState.textBaseline) {
+ contextTextState.textBaseline = context.textBaseline =
+ textState.textBaseline;
+ * Set the fill and stroke style for subsequent draw operations. To clear
+ * either fill or stroke styles, pass null for the appropriate parameter.
+ * @override
+ol.render.canvas.Immediate.prototype.setFillStrokeStyle = function(fillStyle, strokeStyle) {
+ if (!fillStyle) {
+ } else {
+ var fillStyleColor = fillStyle.getColor();
+ this.fillState_ = {
+ fillStyle: ol.colorlike.asColorLike(fillStyleColor ?
+ fillStyleColor : ol.render.canvas.defaultFillStyle)
+ if (!strokeStyle) {
+ } else {
+ var strokeStyleColor = strokeStyle.getColor();
+ var strokeStyleLineCap = strokeStyle.getLineCap();
+ var strokeStyleLineDash = strokeStyle.getLineDash();
+ var strokeStyleLineDashOffset = strokeStyle.getLineDashOffset();
+ var strokeStyleLineJoin = strokeStyle.getLineJoin();
+ var strokeStyleWidth = strokeStyle.getWidth();
+ var strokeStyleMiterLimit = strokeStyle.getMiterLimit();
+ this.strokeState_ = {
+ lineCap: strokeStyleLineCap !== undefined ?
+ strokeStyleLineCap : ol.render.canvas.defaultLineCap,
+ lineDash: strokeStyleLineDash ?
+ strokeStyleLineDash : ol.render.canvas.defaultLineDash,
+ lineDashOffset: strokeStyleLineDashOffset ?
+ strokeStyleLineDashOffset : ol.render.canvas.defaultLineDashOffset,
+ lineJoin: strokeStyleLineJoin !== undefined ?
+ strokeStyleLineJoin : ol.render.canvas.defaultLineJoin,
+ lineWidth: this.pixelRatio_ * (strokeStyleWidth !== undefined ?
+ strokeStyleWidth : ol.render.canvas.defaultLineWidth),
+ miterLimit: strokeStyleMiterLimit !== undefined ?
+ strokeStyleMiterLimit : ol.render.canvas.defaultMiterLimit,
+ strokeStyle: ol.colorlike.asColorLike(strokeStyleColor ?
+ strokeStyleColor : ol.render.canvas.defaultStrokeStyle)
+ * Set the image style for subsequent draw operations. Pass null to remove
+ * the image style.
+ * @override
+ol.render.canvas.Immediate.prototype.setImageStyle = function(imageStyle) {
+ if (!imageStyle) {
+ } else {
+ var imageAnchor = imageStyle.getAnchor();
+ // FIXME pixel ratio
+ var imageImage = imageStyle.getImage(1);
+ var imageOrigin = imageStyle.getOrigin();
+ var imageSize = imageStyle.getSize();
+ this.imageAnchorX_ = imageAnchor[0];
+ this.imageAnchorY_ = imageAnchor[1];
+ this.imageHeight_ = imageSize[1];
+ this.image_ = imageImage;
+ this.imageOpacity_ = imageStyle.getOpacity();
+ this.imageOriginX_ = imageOrigin[0];
+ this.imageOriginY_ = imageOrigin[1];
+ this.imageRotateWithView_ = imageStyle.getRotateWithView();
+ this.imageRotation_ = imageStyle.getRotation();
+ this.imageScale_ = imageStyle.getScale();
+ this.imageSnapToPixel_ = imageStyle.getSnapToPixel();
+ this.imageWidth_ = imageSize[0];
+ * Set the text style for subsequent draw operations. Pass null to
+ * remove the text style.
+ * @override
+ol.render.canvas.Immediate.prototype.setTextStyle = function(textStyle) {
+ if (!textStyle) {
+ this.text_ = '';
+ } else {
+ var textFillStyle = textStyle.getFill();
+ if (!textFillStyle) {
+ } else {
+ var textFillStyleColor = textFillStyle.getColor();
+ this.textFillState_ = {
+ fillStyle: ol.colorlike.asColorLike(textFillStyleColor ?
+ textFillStyleColor : ol.render.canvas.defaultFillStyle)
+ var textStrokeStyle = textStyle.getStroke();
+ if (!textStrokeStyle) {
+ } else {
+ var textStrokeStyleColor = textStrokeStyle.getColor();
+ var textStrokeStyleLineCap = textStrokeStyle.getLineCap();
+ var textStrokeStyleLineDash = textStrokeStyle.getLineDash();
+ var textStrokeStyleLineDashOffset = textStrokeStyle.getLineDashOffset();
+ var textStrokeStyleLineJoin = textStrokeStyle.getLineJoin();
+ var textStrokeStyleWidth = textStrokeStyle.getWidth();
+ var textStrokeStyleMiterLimit = textStrokeStyle.getMiterLimit();
+ this.textStrokeState_ = {
+ lineCap: textStrokeStyleLineCap !== undefined ?
+ textStrokeStyleLineCap : ol.render.canvas.defaultLineCap,
+ lineDash: textStrokeStyleLineDash ?
+ textStrokeStyleLineDash : ol.render.canvas.defaultLineDash,
+ lineDashOffset: textStrokeStyleLineDashOffset ?
+ textStrokeStyleLineDashOffset : ol.render.canvas.defaultLineDashOffset,
+ lineJoin: textStrokeStyleLineJoin !== undefined ?
+ textStrokeStyleLineJoin : ol.render.canvas.defaultLineJoin,
+ lineWidth: textStrokeStyleWidth !== undefined ?
+ textStrokeStyleWidth : ol.render.canvas.defaultLineWidth,
+ miterLimit: textStrokeStyleMiterLimit !== undefined ?
+ textStrokeStyleMiterLimit : ol.render.canvas.defaultMiterLimit,
+ strokeStyle: ol.colorlike.asColorLike(textStrokeStyleColor ?
+ textStrokeStyleColor : ol.render.canvas.defaultStrokeStyle)
+ var textFont = textStyle.getFont();
+ var textOffsetX = textStyle.getOffsetX();
+ var textOffsetY = textStyle.getOffsetY();
+ var textRotateWithView = textStyle.getRotateWithView();
+ var textRotation = textStyle.getRotation();
+ var textScale = textStyle.getScale();
+ var textText = textStyle.getText();
+ var textTextAlign = textStyle.getTextAlign();
+ var textTextBaseline = textStyle.getTextBaseline();
+ this.textState_ = {
+ font: textFont !== undefined ?
+ textFont : ol.render.canvas.defaultFont,
+ textAlign: textTextAlign !== undefined ?
+ textTextAlign : ol.render.canvas.defaultTextAlign,
+ textBaseline: textTextBaseline !== undefined ?
+ textTextBaseline : ol.render.canvas.defaultTextBaseline
+ this.text_ = textText !== undefined ? textText : '';
+ textOffsetX !== undefined ? (this.pixelRatio_ * textOffsetX) : 0;
+ textOffsetY !== undefined ? (this.pixelRatio_ * textOffsetY) : 0;
+ this.textRotateWithView_ = textRotateWithView !== undefined ? textRotateWithView : false;
+ this.textRotation_ = textRotation !== undefined ? textRotation : 0;
+ this.textScale_ = this.pixelRatio_ * (textScale !== undefined ?
+ textScale : 1);
+// FIXME offset panning
+goog.provide('ol.renderer.canvas.Map');
+goog.require('ol.css');
+goog.require('ol.dom');
+goog.require('ol.render.Event');
+goog.require('ol.render.canvas.Immediate');
+goog.require('ol.renderer.Map');
+goog.require('ol.renderer.Type');
+ * @constructor
+ * @extends {ol.renderer.Map}
+ol.renderer.canvas.Map = function(container, map) {
+ ol.renderer.Map.call(this, container, map);
+ * @private
+ this.context_ = ol.dom.createCanvasContext2D();
+ * @private
+ * @type {HTMLCanvasElement}
+ this.canvas_ = this.context_.canvas;
+ this.canvas_.style.width = '100%';
+ this.canvas_.style.height = '100%';
+ this.canvas_.style.display = 'block';
+ this.canvas_.className = ol.css.CLASS_UNSELECTABLE;
+ container.insertBefore(this.canvas_, container.childNodes[0] || null);
+ * @private
+ * @type {boolean}
+ this.renderedVisible_ = true;
+ * @private
+ this.transform_ = ol.transform.create();
+ol.inherits(ol.renderer.canvas.Map, ol.renderer.Map);
+ * @param {ol.render.EventType} type Event type.
+ * @private
+ol.renderer.canvas.Map.prototype.dispatchComposeEvent_ = function(type, frameState) {
+ var map = this.getMap();
+ if (map.hasListener(type)) {
+ var extent = frameState.extent;
+ var pixelRatio = frameState.pixelRatio;
+ var rotation = viewState.rotation;
+ var transform = this.getTransform(frameState);
+ var vectorContext = new ol.render.canvas.Immediate(context, pixelRatio,
+ extent, transform, rotation);
+ var composeEvent = new ol.render.Event(type, vectorContext,
+ frameState, context, null);
+ map.dispatchEvent(composeEvent);
+ * @protected
+ol.renderer.canvas.Map.prototype.getTransform = function(frameState) {
+ var dx1 = this.canvas_.width / 2;
+ var dy1 = this.canvas_.height / 2;
+ var sx = frameState.pixelRatio / viewState.resolution;
+ var sy = -sx;
+ var angle = -viewState.rotation;
+ var dx2 = -viewState.center[0];
+ var dy2 = -viewState.center[1];
+ return ol.transform.compose(this.transform_, dx1, dy1, sx, sy, angle, dx2, dy2);
+ * @inheritDoc
+ol.renderer.canvas.Map.prototype.getType = function() {
+ return ol.renderer.Type.CANVAS;
+ * @inheritDoc
+ol.renderer.canvas.Map.prototype.renderFrame = function(frameState) {
+ if (!frameState) {
+ if (this.renderedVisible_) {
+ this.canvas_.style.display = 'none';
+ this.renderedVisible_ = false;
+ return;
+ var width = Math.round(frameState.size[0] * pixelRatio);
+ var height = Math.round(frameState.size[1] * pixelRatio);
+ if (this.canvas_.width != width || this.canvas_.height != height) {
+ this.canvas_.width = width;
+ this.canvas_.height = height;
+ } else {
+ context.clearRect(0, 0, width, height);
+ var rotation = frameState.viewState.rotation;
+ this.calculateMatrices2D(frameState);
+ this.dispatchComposeEvent_(ol.render.EventType.PRECOMPOSE, frameState);
+ var layerStatesArray = frameState.layerStatesArray;
+ ol.array.stableSort(layerStatesArray, ol.renderer.Map.sortByZIndex);
+ if (rotation) {
+ context.save();
+ ol.render.canvas.rotateAtOffset(context, rotation, width / 2, height / 2);
+ var viewResolution = frameState.viewState.resolution;
+ var i, ii, layer, layerRenderer, layerState;
+ for (i = 0, ii = layerStatesArray.length; i < ii; ++i) {
+ layerState = layerStatesArray[i];
+ layer = layerState.layer;
+ layerRenderer = /** @type {ol.renderer.canvas.Layer} */ (this.getLayerRenderer(layer));
+ if (!ol.layer.Layer.visibleAtResolution(layerState, viewResolution) ||
+ layerState.sourceState != ol.source.State.READY) {
+ continue;
+ if (layerRenderer.prepareFrame(frameState, layerState)) {
+ layerRenderer.composeFrame(frameState, layerState, context);
+ if (rotation) {
+ context.restore();
+ ol.render.EventType.POSTCOMPOSE, frameState);
+ if (!this.renderedVisible_) {
+ this.canvas_.style.display = '';
+ this.scheduleRemoveUnusedLayerRenderers(frameState);
+ this.scheduleExpireIconCache(frameState);
+ * @inheritDoc
+ol.renderer.canvas.Map.prototype.forEachLayerAtPixel = function(pixel, frameState, callback, thisArg,
+ var result;
+ var coordinate = ol.transform.apply(
+ frameState.pixelToCoordinateTransform, pixel.slice());
+ var i;
+ var layerRenderer = /** @type {ol.renderer.canvas.Layer} */ (this.getLayerRenderer(layer));
+ result = layerRenderer.forEachLayerAtCoordinate(
+ coordinate, frameState, callback, thisArg);
+ if (result) {
+ return result;
+ return undefined;
+goog.provide('ol.render.ReplayType');
+ * @enum {string}
+ol.render.ReplayType = {
+ CIRCLE: 'Circle',
+ IMAGE: 'Image',
+ LINE_STRING: 'LineString',
+ POLYGON: 'Polygon',
+ TEXT: 'Text'
+goog.provide('ol.render.replay');
+goog.require('ol.render.ReplayType');
+ * @const
+ * @type {Array.<ol.render.ReplayType>}
+ol.render.replay.ORDER = [
+ ol.render.ReplayType.POLYGON,
+ ol.render.ReplayType.CIRCLE,
+ ol.render.ReplayType.LINE_STRING,
+ ol.render.ReplayType.IMAGE,
+ ol.render.ReplayType.TEXT
+goog.provide('ol.render.ReplayGroup');
+ * Base class for replay groups.
+ * @constructor
+ * @abstract
+ol.render.ReplayGroup = function() {};
+ * @abstract
+ * @param {number|undefined} zIndex Z index.
+ * @param {ol.render.ReplayType} replayType Replay type.
+ * @return {ol.render.VectorContext} Replay.
+ol.render.ReplayGroup.prototype.getReplay = function(zIndex, replayType) {};
+ * @abstract
+ * @return {boolean} Is empty.
+ol.render.ReplayGroup.prototype.isEmpty = function() {};
+goog.provide('ol.webgl.Shader');
+if (ol.ENABLE_WEBGL) {
+ * @constructor
+ * @abstract
+ * @param {string} source Source.
+ * @struct
+ ol.webgl.Shader = function(source) {
+ * @private
+ * @type {string}
+ this.source_ = source;
+ * @abstract
+ * @return {number} Type.
+ ol.webgl.Shader.prototype.getType = function() {};
+ * @return {string} Source.
+ ol.webgl.Shader.prototype.getSource = function() {
+ return this.source_;
+ * @return {boolean} Is animated?
+ ol.webgl.Shader.prototype.isAnimated = ol.functions.FALSE;
+goog.provide('ol.webgl.Fragment');
+goog.require('ol.webgl');
+goog.require('ol.webgl.Shader');
+ * @constructor
+ * @extends {ol.webgl.Shader}
+ * @struct
+ ol.webgl.Fragment = function(source) {
+ ol.webgl.Shader.call(this, source);
+ ol.inherits(ol.webgl.Fragment, ol.webgl.Shader);
+ * @inheritDoc
+ ol.webgl.Fragment.prototype.getType = function() {
+ return ol.webgl.FRAGMENT_SHADER;
+goog.provide('ol.webgl.Vertex');
+ * @constructor
+ * @struct
+ ol.webgl.Vertex = function(source) {
+ ol.inherits(ol.webgl.Vertex, ol.webgl.Shader);
+ * @inheritDoc
+ ol.webgl.Vertex.prototype.getType = function() {
+ return ol.webgl.VERTEX_SHADER;
+// This file is automatically generated, do not edit
+goog.provide('ol.render.webgl.circlereplay.defaultshader');
+goog.require('ol.webgl.Fragment');
+goog.require('ol.webgl.Vertex');
+ * @constructor
+ * @extends {ol.webgl.Fragment}
+ * @struct
+ ol.render.webgl.circlereplay.defaultshader.Fragment = function() {
+ ol.webgl.Fragment.call(this, ol.render.webgl.circlereplay.defaultshader.Fragment.SOURCE);
+ ol.inherits(ol.render.webgl.circlereplay.defaultshader.Fragment, ol.webgl.Fragment);
+ * @const
+ * @type {string}
+ ol.render.webgl.circlereplay.defaultshader.Fragment.DEBUG_SOURCE = 'precision mediump float;\nvarying vec2 v_center;\nvarying vec2 v_offset;\nvarying float v_halfWidth;\nvarying float v_pixelRatio;\n\n\n\nuniform float u_opacity;\nuniform vec4 u_fillColor;\nuniform vec4 u_strokeColor;\nuniform vec2 u_size;\n\nvoid main(void) {\n vec2 windowCenter = vec2((v_center.x + 1.0) / 2.0 * u_size.x * v_pixelRatio,\n (v_center.y + 1.0) / 2.0 * u_size.y * v_pixelRatio);\n vec2 windowOffset = vec2((v_offset.x + 1.0) / 2.0 * u_size.x * v_pixelRatio,\n (v_offset.y + 1.0) / 2.0 * u_size.y * v_pixelRatio);\n float radius = length(windowCenter - windowOffset);\n float dist = length(windowCenter - gl_FragCoord.xy);\n if (dist > radius + v_halfWidth) {\n if (u_strokeColor.a == 0.0) {\n gl_FragColor = u_fillColor;\n } else {\n gl_FragColor = u_strokeColor;\n }\n gl_FragColor.a = gl_FragColor.a - (dist - (radius + v_halfWidth));\n } else if (u_fillColor.a == 0.0) {
\n // Hooray, no fill, just stroke. We can use real antialiasing.\n gl_FragColor = u_strokeColor;\n if (dist < radius - v_halfWidth) {\n gl_FragColor.a = gl_FragColor.a - (radius - v_halfWidth - dist);\n }\n } else {\n gl_FragColor = u_fillColor;\n float strokeDist = radius - v_halfWidth;\n float antialias = 2.0 * v_pixelRatio;\n if (dist > strokeDist) {\n gl_FragColor = u_strokeColor;\n } else if (dist >= strokeDist - antialias) {\n float step = smoothstep(strokeDist - antialias, strokeDist, dist);\n gl_FragColor = mix(u_fillColor, u_strokeColor, step);\n }\n }\n gl_FragColor.a = gl_FragColor.a * u_opacity;\n if (gl_FragColor.a <= 0.0) {\n discard;\n }\n}\n';
+ * @const
+ * @type {string}
+ ol.render.webgl.circlereplay.defaultshader.Fragment.OPTIMIZED_SOURCE = 'precision mediump float;varying vec2 a;varying vec2 b;varying float c;varying float d;uniform float m;uniform vec4 n;uniform vec4 o;uniform vec2 p;void main(void){vec2 windowCenter=vec2((a.x+1.0)/2.0*p.x*d,(a.y+1.0)/2.0*p.y*d);vec2 windowOffset=vec2((b.x+1.0)/2.0*p.x*d,(b.y+1.0)/2.0*p.y*d);float radius=length(windowCenter-windowOffset);float dist=length(windowCenter-gl_FragCoord.xy);if(dist>radius+c){if(o.a==0.0){gl_FragColor=n;}else{gl_FragColor=o;}gl_FragColor.a=gl_FragColor.a-(dist-(radius+c));}else if(n.a==0.0){gl_FragColor=o;if(dist<radius-c){gl_FragColor.a=gl_FragColor.a-(radius-c-dist);}} else{gl_FragColor=n;float strokeDist=radius-c;float antialias=2.0*d;if(dist>strokeDist){gl_FragColor=o;}else if(dist>=strokeDist-antialias){float step=smoothstep(strokeDist-antialias,strokeDist,dist);gl_FragColor=mix(n,o,step);}} gl_FragColor.a=gl_FragColor.a*m;if(gl_FragColor.a<=0.0){discard;}}';
+ * @const
+ * @type {string}
+ ol.render.webgl.circlereplay.defaultshader.Fragment.SOURCE = ol.DEBUG_WEBGL ?
+ ol.render.webgl.circlereplay.defaultshader.Fragment.DEBUG_SOURCE :
+ ol.render.webgl.circlereplay.defaultshader.Fragment.OPTIMIZED_SOURCE;
+ ol.render.webgl.circlereplay.defaultshader.fragment = new ol.render.webgl.circlereplay.defaultshader.Fragment();
+ * @constructor
+ * @extends {ol.webgl.Vertex}
+ * @struct
+ ol.render.webgl.circlereplay.defaultshader.Vertex = function() {
+ ol.webgl.Vertex.call(this, ol.render.webgl.circlereplay.defaultshader.Vertex.SOURCE);
+ ol.inherits(ol.render.webgl.circlereplay.defaultshader.Vertex, ol.webgl.Vertex);
+ * @const
+ * @type {string}
+ ol.render.webgl.circlereplay.defaultshader.Vertex.DEBUG_SOURCE = 'varying vec2 v_center;\nvarying vec2 v_offset;\nvarying float v_halfWidth;\nvarying float v_pixelRatio;\n\n\nattribute vec2 a_position;\nattribute float a_instruction;\nattribute float a_radius;\n\nuniform mat4 u_projectionMatrix;\nuniform mat4 u_offsetScaleMatrix;\nuniform mat4 u_offsetRotateMatrix;\nuniform float u_lineWidth;\nuniform float u_pixelRatio;\n\nvoid main(void) {\n mat4 offsetMatrix = u_offsetScaleMatrix * u_offsetRotateMatrix;\n v_center = vec4(u_projectionMatrix * vec4(a_position, 0.0, 1.0)).xy;\n v_pixelRatio = u_pixelRatio;\n float lineWidth = u_lineWidth * u_pixelRatio;\n v_halfWidth = lineWidth / 2.0;\n if (lineWidth == 0.0) {\n lineWidth = 2.0 * u_pixelRatio;\n }\n vec2 offset;\n // Radius with anitaliasing (roughly).\n float radius = a_radius + 3.0 * u_pixelRatio;\n // Until we get gl_VertexID in WebGL, we store an instruction.\n if (a_instruction == 0.0) {\n // Offsetting the
edges of the triangle by lineWidth / 2 is necessary, however\n // we should also leave some space for the antialiasing, thus we offset by lineWidth.\n offset = vec2(-1.0, 1.0);\n } else if (a_instruction == 1.0) {\n offset = vec2(-1.0, -1.0);\n } else if (a_instruction == 2.0) {\n offset = vec2(1.0, -1.0);\n } else {\n offset = vec2(1.0, 1.0);\n }\n\n gl_Position = u_projectionMatrix * vec4(a_position + offset * radius, 0.0, 1.0) +\n offsetMatrix * vec4(offset * lineWidth, 0.0, 0.0);\n v_offset = vec4(u_projectionMatrix * vec4(a_position.x + a_radius, a_position.y,\n 0.0, 1.0)).xy;\n\n if (distance(v_center, v_offset) > 20000.0) {\n gl_Position = vec4(v_center, 0.0, 1.0);\n }\n}\n\n\n';
+ * @const
+ * @type {string}
+ ol.render.webgl.circlereplay.defaultshader.Vertex.OPTIMIZED_SOURCE = 'varying vec2 a;varying vec2 b;varying float c;varying float d;attribute vec2 e;attribute float f;attribute float g;uniform mat4 h;uniform mat4 i;uniform mat4 j;uniform float k;uniform float l;void main(void){mat4 offsetMatrix=i*j;a=vec4(h*vec4(e,0.0,1.0)).xy;d=l;float lineWidth=k*l;c=lineWidth/2.0;if(lineWidth==0.0){lineWidth=2.0*l;}vec2 offset;float radius=g+3.0*l;if(f==0.0){offset=vec2(-1.0,1.0);}else if(f==1.0){offset=vec2(-1.0,-1.0);}else if(f==2.0){offset=vec2(1.0,-1.0);}else{offset=vec2(1.0,1.0);}gl_Position=h*vec4(e+offset*radius,0.0,1.0)+offsetMatrix*vec4(offset*lineWidth,0.0,0.0);b=vec4(h*vec4(e.x+g,e.y,0.0,1.0)).xy;if(distance(a,b)>20000.0){gl_Position=vec4(a,0.0,1.0);}}';
+ * @const
+ * @type {string}
+ ol.render.webgl.circlereplay.defaultshader.Vertex.SOURCE = ol.DEBUG_WEBGL ?
+ ol.render.webgl.circlereplay.defaultshader.Vertex.DEBUG_SOURCE :
+ ol.render.webgl.circlereplay.defaultshader.Vertex.OPTIMIZED_SOURCE;
+ ol.render.webgl.circlereplay.defaultshader.vertex = new ol.render.webgl.circlereplay.defaultshader.Vertex();
+ * @constructor
+ * @param {WebGLRenderingContext} gl GL.
+ * @param {WebGLProgram} program Program.
+ * @struct
+ ol.render.webgl.circlereplay.defaultshader.Locations = function(gl, program) {
+ * @type {WebGLUniformLocation}
+ this.u_fillColor = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_fillColor' : 'n');
+ this.u_lineWidth = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_lineWidth' : 'k');
+ this.u_offsetRotateMatrix = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_offsetRotateMatrix' : 'j');
+ this.u_offsetScaleMatrix = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_offsetScaleMatrix' : 'i');
+ this.u_opacity = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_opacity' : 'm');
+ this.u_pixelRatio = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_pixelRatio' : 'l');
+ this.u_projectionMatrix = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_projectionMatrix' : 'h');
+ this.u_size = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_size' : 'p');
+ this.u_strokeColor = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_strokeColor' : 'o');
+ * @type {number}
+ this.a_instruction = gl.getAttribLocation(
+ program, ol.DEBUG_WEBGL ? 'a_instruction' : 'f');
+ * @type {number}
+ this.a_position = gl.getAttribLocation(
+ program, ol.DEBUG_WEBGL ? 'a_position' : 'e');
+ * @type {number}
+ this.a_radius = gl.getAttribLocation(
+ program, ol.DEBUG_WEBGL ? 'a_radius' : 'g');
+goog.provide('ol.vec.Mat4');
+ * @return {Array.<number>} 4x4 matrix representing a 3D identity transform.
+ol.vec.Mat4.create = function() {
+ return [1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1];
+ * @param {Array.<number>} mat4 Flattened 4x4 matrix receiving the result.
+ * @param {ol.Transform} transform Transformation matrix.
+ * @return {Array.<number>} 2D transformation matrix as flattened 4x4 matrix.
+ol.vec.Mat4.fromTransform = function(mat4, transform) {
+ mat4[0] = transform[0];
+ mat4[1] = transform[1];
+ mat4[4] = transform[2];
+ mat4[5] = transform[3];
+ mat4[12] = transform[4];
+ mat4[13] = transform[5];
+ return mat4;
+goog.provide('ol.render.webgl.Replay');
+goog.require('ol.extent');
+goog.require('ol.vec.Mat4');
+ * @constructor
+ * @abstract
+ * @param {number} tolerance Tolerance.
+ * @param {ol.Extent} maxExtent Max extent.
+ * @struct
+ ol.render.webgl.Replay = function(tolerance, maxExtent) {
+ * @protected
+ * @type {number}
+ this.tolerance = tolerance;
+ * @protected
+ * @const
+ this.maxExtent = maxExtent;
+ * The origin of the coordinate system for the point coordinates sent to
+ * the GPU. To eliminate jitter caused by precision problems in the GPU
+ * we use the "Rendering Relative to Eye" technique described in the "3D
+ * Engine Design for Virtual Globes" book.
+ * @protected
+ * @type {ol.Coordinate}
+ this.origin = ol.extent.getCenter(maxExtent);
+ * @private
+ this.projectionMatrix_ = ol.transform.create();
+ * @private
+ this.offsetRotateMatrix_ = ol.transform.create();
+ * @private
+ this.offsetScaleMatrix_ = ol.transform.create();
+ * @private
+ this.tmpMat4_ = ol.vec.Mat4.create();
+ * @protected
+ this.indices = [];
+ * @protected
+ * @type {?ol.webgl.Buffer}
+ this.indicesBuffer = null;
+ * Start index per feature (the index).
+ * @protected
+ this.startIndices = [];
+ * Start index per feature (the feature).
+ * @protected
+ * @type {Array.<ol.Feature|ol.render.Feature>}
+ this.startIndicesFeature = [];
+ * @protected
+ this.vertices = [];
+ * @protected
+ this.verticesBuffer = null;
+ * Optional parameter for PolygonReplay instances.
+ * @protected
+ * @type {ol.render.webgl.LineStringReplay|undefined}
+ this.lineStringReplay = undefined;
+ ol.inherits(ol.render.webgl.Replay, ol.render.VectorContext);
+ * @abstract
+ * @param {ol.webgl.Context} context WebGL context.
+ * @return {function()} Delete resources function.
+ ol.render.webgl.Replay.prototype.getDeleteResourcesFunction = function(context) {};
+ * @abstract
+ * @param {ol.webgl.Context} context Context.
+ ol.render.webgl.Replay.prototype.finish = function(context) {};
+ * @abstract
+ * @protected
+ * @param {WebGLRenderingContext} gl gl.
+ * @param {ol.Size} size Size.
+ * @return {ol.render.webgl.circlereplay.defaultshader.Locations|
+ ol.render.webgl.imagereplay.defaultshader.Locations|
+ ol.render.webgl.linestringreplay.defaultshader.Locations|
+ ol.render.webgl.polygonreplay.defaultshader.Locations} Locations.
+ ol.render.webgl.Replay.prototype.setUpProgram = function(gl, context, size, pixelRatio) {};
+ * @abstract
+ * @protected
+ * @param {ol.render.webgl.circlereplay.defaultshader.Locations|
+ ol.render.webgl.polygonreplay.defaultshader.Locations} locations Locations.
+ ol.render.webgl.Replay.prototype.shutDownProgram = function(gl, locations) {};
+ * @abstract
+ * @protected
+ * @param {Object.<string, boolean>} skippedFeaturesHash Ids of features
+ * to skip.
+ * @param {boolean} hitDetection Hit detection mode.
+ ol.render.webgl.Replay.prototype.drawReplay = function(gl, context, skippedFeaturesHash, hitDetection) {};
+ * @abstract
+ * @protected
+ * to skip.
+ * @param {function((ol.Feature|ol.render.Feature)): T|undefined} featureCallback Feature callback.
+ * @param {ol.Extent=} opt_hitExtent Hit extent: Only features intersecting
+ * this extent are checked.
+ * @template T
+ ol.render.webgl.Replay.prototype.drawHitDetectionReplayOneByOne = function(gl, context, skippedFeaturesHash, featureCallback, opt_hitExtent) {};
+ * @protected
+ * to skip.
+ * @param {boolean} oneByOne Draw features one-by-one for the hit-detecion.
+ * @template T
+ ol.render.webgl.Replay.prototype.drawHitDetectionReplay = function(gl, context, skippedFeaturesHash,
+ featureCallback, oneByOne, opt_hitExtent) {
+ if (!oneByOne) {
+ // draw all hit-detection features in "once" (by texture group)
+ return this.drawHitDetectionReplayAll(gl, context,
+ skippedFeaturesHash, featureCallback);
+ } else {
+ // draw hit-detection features one by one
+ return this.drawHitDetectionReplayOneByOne(gl, context,
+ skippedFeaturesHash, featureCallback, opt_hitExtent);
+ * @protected
+ * to skip.
+ * @template T
+ ol.render.webgl.Replay.prototype.drawHitDetectionReplayAll = function(gl, context, skippedFeaturesHash,
+ featureCallback) {
+ gl.clear(gl.COLOR_BUFFER_BIT | gl.DEPTH_BUFFER_BIT);
+ this.drawReplay(gl, context, skippedFeaturesHash, true);
+ var result = featureCallback(null);
+ if (result) {
+ return result;
+ } else {
+ return undefined;
+ * @param {ol.Coordinate} center Center.
+ * @param {number} resolution Resolution.
+ * @param {number} opacity Global opacity.
+ * to skip.
+ * @template T
+ ol.render.webgl.Replay.prototype.replay = function(context,
+ center, resolution, rotation, size, pixelRatio,
+ opacity, skippedFeaturesHash,
+ var gl = context.getGL();
+ var tmpStencil, tmpStencilFunc, tmpStencilMaskVal, tmpStencilRef, tmpStencilMask,
+ tmpStencilOpFail, tmpStencilOpPass, tmpStencilOpZFail;
+ if (this.lineStringReplay) {
+ tmpStencil = gl.isEnabled(gl.STENCIL_TEST);
+ tmpStencilFunc = gl.getParameter(gl.STENCIL_FUNC);
+ tmpStencilMaskVal = gl.getParameter(gl.STENCIL_VALUE_MASK);
+ tmpStencilRef = gl.getParameter(gl.STENCIL_REF);
+ tmpStencilMask = gl.getParameter(gl.STENCIL_WRITEMASK);
+ tmpStencilOpFail = gl.getParameter(gl.STENCIL_FAIL);
+ tmpStencilOpPass = gl.getParameter(gl.STENCIL_PASS_DEPTH_PASS);
+ tmpStencilOpZFail = gl.getParameter(gl.STENCIL_PASS_DEPTH_FAIL);
+ gl.enable(gl.STENCIL_TEST);
+ gl.clear(gl.STENCIL_BUFFER_BIT);
+ gl.stencilMask(255);
+ gl.stencilFunc(gl.ALWAYS, 1, 255);
+ gl.stencilOp(gl.KEEP, gl.KEEP, gl.REPLACE);
+ this.lineStringReplay.replay(context,
+ featureCallback, oneByOne, opt_hitExtent);
+ gl.stencilMask(0);
+ gl.stencilFunc(gl.NOTEQUAL, 1, 255);
+ context.bindBuffer(ol.webgl.ARRAY_BUFFER, this.verticesBuffer);
+ context.bindBuffer(ol.webgl.ELEMENT_ARRAY_BUFFER, this.indicesBuffer);
+ var locations = this.setUpProgram(gl, context, size, pixelRatio);
+ // set the "uniform" values
+ var projectionMatrix = ol.transform.reset(this.projectionMatrix_);
+ ol.transform.scale(projectionMatrix, 2 / (resolution * size[0]), 2 / (resolution * size[1]));
+ ol.transform.rotate(projectionMatrix, -rotation);
+ ol.transform.translate(projectionMatrix, -(center[0] - this.origin[0]), -(center[1] - this.origin[1]));
+ var offsetScaleMatrix = ol.transform.reset(this.offsetScaleMatrix_);
+ ol.transform.scale(offsetScaleMatrix, 2 / size[0], 2 / size[1]);
+ var offsetRotateMatrix = ol.transform.reset(this.offsetRotateMatrix_);
+ ol.transform.rotate(offsetRotateMatrix, -rotation);
+ gl.uniformMatrix4fv(locations.u_projectionMatrix, false,
+ ol.vec.Mat4.fromTransform(this.tmpMat4_, projectionMatrix));
+ gl.uniformMatrix4fv(locations.u_offsetScaleMatrix, false,
+ ol.vec.Mat4.fromTransform(this.tmpMat4_, offsetScaleMatrix));
+ gl.uniformMatrix4fv(locations.u_offsetRotateMatrix, false,
+ ol.vec.Mat4.fromTransform(this.tmpMat4_, offsetRotateMatrix));
+ gl.uniform1f(locations.u_opacity, opacity);
+ // draw!
+ var result;
+ if (featureCallback === undefined) {
+ this.drawReplay(gl, context, skippedFeaturesHash, false);
+ } else {
+ // draw feature by feature for the hit-detection
+ result = this.drawHitDetectionReplay(gl, context, skippedFeaturesHash,
+ // disable the vertex attrib arrays
+ this.shutDownProgram(gl, locations);
+ if (!tmpStencil) {
+ gl.disable(gl.STENCIL_TEST);
+ gl.stencilFunc(/** @type {number} */ (tmpStencilFunc),
+ /** @type {number} */ (tmpStencilRef), /** @type {number} */ (tmpStencilMaskVal));
+ gl.stencilMask(/** @type {number} */ (tmpStencilMask));
+ gl.stencilOp(/** @type {number} */ (tmpStencilOpFail),
+ /** @type {number} */ (tmpStencilOpZFail), /** @type {number} */ (tmpStencilOpPass));
+ return result;
+ * @protected
+ * @param {number} start Start index.
+ * @param {number} end End index.
+ ol.render.webgl.Replay.prototype.drawElements = function(
+ gl, context, start, end) {
+ var elementType = context.hasOESElementIndexUint ?
+ ol.webgl.UNSIGNED_INT : ol.webgl.UNSIGNED_SHORT;
+ var elementSize = context.hasOESElementIndexUint ? 4 : 2;
+ var numItems = end - start;
+ var offsetInBytes = start * elementSize;
+ gl.drawElements(ol.webgl.TRIANGLES, numItems, elementType, offsetInBytes);
+goog.provide('ol.render.webgl');
+ * @const
+ ol.render.webgl.defaultFillStyle = [0.0, 0.0, 0.0, 1.0];
+ * @const
+ * @type {string}
+ ol.render.webgl.defaultLineCap = 'round';
+ * @const
+ ol.render.webgl.defaultLineDash = [];
+ * @const
+ * @type {number}
+ ol.render.webgl.defaultLineDashOffset = 0;
+ * @const
+ * @type {string}
+ ol.render.webgl.defaultLineJoin = 'round';
+ * @const
+ * @type {number}
+ ol.render.webgl.defaultMiterLimit = 10;
+ * @const
+ ol.render.webgl.defaultStrokeStyle = [0.0, 0.0, 0.0, 1.0];
+ * @const
+ * @type {number}
+ ol.render.webgl.defaultLineWidth = 1;
+ * Calculates the orientation of a triangle based on the determinant method.
+ * @param {number} x1 First X coordinate.
+ * @param {number} y1 First Y coordinate.
+ * @param {number} x2 Second X coordinate.
+ * @param {number} y2 Second Y coordinate.
+ * @param {number} x3 Third X coordinate.
+ * @param {number} y3 Third Y coordinate.
+ * @return {boolean|undefined} Triangle is clockwise.
+ ol.render.webgl.triangleIsCounterClockwise = function(x1, y1, x2, y2, x3, y3) {
+ var area = (x2 - x1) * (y3 - y1) - (x3 - x1) * (y2 - y1);
+ return (area <= ol.render.webgl.EPSILON && area >= -ol.render.webgl.EPSILON) ?
+ undefined : area > 0;
+ * @const
+ * @type {number}
+ ol.render.webgl.EPSILON = Number.EPSILON || 2.220446049250313e-16;
+goog.provide('ol.webgl.Buffer');
+ * @constructor
+ * @param {Array.<number>=} opt_arr Array.
+ * @param {number=} opt_usage Usage.
+ * @struct
+ ol.webgl.Buffer = function(opt_arr, opt_usage) {
+ * @private
+ this.arr_ = opt_arr !== undefined ? opt_arr : [];
+ * @private
+ * @type {number}
+ this.usage_ = opt_usage !== undefined ?
+ opt_usage : ol.webgl.Buffer.Usage_.STATIC_DRAW;
+ * @return {Array.<number>} Array.
+ ol.webgl.Buffer.prototype.getArray = function() {
+ return this.arr_;
+ * @return {number} Usage.
+ ol.webgl.Buffer.prototype.getUsage = function() {
+ return this.usage_;
+ * @enum {number}
+ * @private
+ ol.webgl.Buffer.Usage_ = {
+ STATIC_DRAW: ol.webgl.STATIC_DRAW,
+ STREAM_DRAW: ol.webgl.STREAM_DRAW,
+ DYNAMIC_DRAW: ol.webgl.DYNAMIC_DRAW
+goog.provide('ol.render.webgl.CircleReplay');
+goog.require('ol');
+goog.require('ol.color');
+goog.require('ol.obj');
+goog.require('ol.render.webgl.circlereplay.defaultshader');
+goog.require('ol.render.webgl.Replay');
+goog.require('ol.render.webgl');
+goog.require('ol.webgl.Buffer');
+ * @constructor
+ * @extends {ol.render.webgl.Replay}
+ * @struct
+ ol.render.webgl.CircleReplay = function(tolerance, maxExtent) {
+ ol.render.webgl.Replay.call(this, tolerance, maxExtent);
+ * @private
+ * @type {ol.render.webgl.circlereplay.defaultshader.Locations}
+ this.defaultLocations_ = null;
+ * @private
+ * @type {Array.<Array.<Array.<number>|number>>}
+ this.styles_ = [];
+ * @private
+ this.styleIndices_ = [];
+ * @private
+ * @type {number}
+ this.radius_ = 0;
+ * @private
+ * @type {{fillColor: (Array.<number>|null),
+ * strokeColor: (Array.<number>|null),
+ * lineDash: Array.<number>,
+ * lineDashOffset: (number|undefined),
+ * lineWidth: (number|undefined),
+ * changed: boolean}|null}
+ this.state_ = {
+ fillColor: null,
+ strokeColor: null,
+ lineDash: null,
+ lineDashOffset: undefined,
+ lineWidth: undefined,
+ changed: false
+ ol.inherits(ol.render.webgl.CircleReplay, ol.render.webgl.Replay);
+ * @private
+ ol.render.webgl.CircleReplay.prototype.drawCoordinates_ = function(
+ flatCoordinates, offset, end, stride) {
+ var numVertices = this.vertices.length;
+ var numIndices = this.indices.length;
+ var n = numVertices / 4;
+ var i, ii;
+ for (i = offset, ii = end; i < ii; i += stride) {
+ this.vertices[numVertices++] = flatCoordinates[i];
+ this.vertices[numVertices++] = flatCoordinates[i + 1];
+ this.vertices[numVertices++] = 0;
+ this.vertices[numVertices++] = this.radius_;
+ this.vertices[numVertices++] = 1;
+ this.vertices[numVertices++] = 2;
+ this.vertices[numVertices++] = 3;
+ this.indices[numIndices++] = n;
+ this.indices[numIndices++] = n + 1;
+ this.indices[numIndices++] = n + 2;
+ this.indices[numIndices++] = n + 3;
+ n += 4;
+ * @inheritDoc
+ ol.render.webgl.CircleReplay.prototype.drawCircle = function(circleGeometry, feature) {
+ var radius = circleGeometry.getRadius();
+ var stride = circleGeometry.getStride();
+ if (radius) {
+ this.startIndices.push(this.indices.length);
+ this.startIndicesFeature.push(feature);
+ if (this.state_.changed) {
+ this.styleIndices_.push(this.indices.length);
+ this.state_.changed = false;
+ this.radius_ = radius;
+ var flatCoordinates = circleGeometry.getFlatCoordinates();
+ flatCoordinates = ol.geom.flat.transform.translate(flatCoordinates, 0, 2,
+ stride, -this.origin[0], -this.origin[1]);
+ this.drawCoordinates_(flatCoordinates, 0, 2, stride);
+ } else {
+ this.styles_.pop();
+ if (this.styles_.length) {
+ var lastState = this.styles_[this.styles_.length - 1];
+ this.state_.fillColor = /** @type {Array.<number>} */ (lastState[0]);
+ this.state_.strokeColor = /** @type {Array.<number>} */ (lastState[1]);
+ this.state_.lineWidth = /** @type {number} */ (lastState[2]);
+ * @inheritDoc
+ ol.render.webgl.CircleReplay.prototype.finish = function(context) {
+ // create, bind, and populate the vertices buffer
+ this.verticesBuffer = new ol.webgl.Buffer(this.vertices);
+ // create, bind, and populate the indices buffer
+ this.indicesBuffer = new ol.webgl.Buffer(this.indices);
+ //Clean up, if there is nothing to draw
+ if (this.styleIndices_.length === 0 && this.styles_.length > 0) {
+ this.vertices = null;
+ this.indices = null;
+ * @inheritDoc
+ ol.render.webgl.CircleReplay.prototype.getDeleteResourcesFunction = function(context) {
+ // We only delete our stuff here. The shaders and the program may
+ // be used by other CircleReplay instances (for other layers). And
+ // they will be deleted when disposing of the ol.webgl.Context
+ // object.
+ var verticesBuffer = this.verticesBuffer;
+ var indicesBuffer = this.indicesBuffer;
+ return function() {
+ context.deleteBuffer(verticesBuffer);
+ context.deleteBuffer(indicesBuffer);
+ * @inheritDoc
+ ol.render.webgl.CircleReplay.prototype.setUpProgram = function(gl, context, size, pixelRatio) {
+ // get the program
+ var fragmentShader, vertexShader;
+ fragmentShader = ol.render.webgl.circlereplay.defaultshader.fragment;
+ vertexShader = ol.render.webgl.circlereplay.defaultshader.vertex;
+ var program = context.getProgram(fragmentShader, vertexShader);
+ // get the locations
+ var locations;
+ if (!this.defaultLocations_) {
+ locations =
+ new ol.render.webgl.circlereplay.defaultshader.Locations(gl, program);
+ this.defaultLocations_ = locations;
+ } else {
+ locations = this.defaultLocations_;
+ context.useProgram(program);
+ // enable the vertex attrib arrays
+ gl.enableVertexAttribArray(locations.a_position);
+ gl.vertexAttribPointer(locations.a_position, 2, ol.webgl.FLOAT,
+ false, 16, 0);
+ gl.enableVertexAttribArray(locations.a_instruction);
+ gl.vertexAttribPointer(locations.a_instruction, 1, ol.webgl.FLOAT,
+ false, 16, 8);
+ gl.enableVertexAttribArray(locations.a_radius);
+ gl.vertexAttribPointer(locations.a_radius, 1, ol.webgl.FLOAT,
+ false, 16, 12);
+ // Enable renderer specific uniforms.
+ gl.uniform2fv(locations.u_size, size);
+ gl.uniform1f(locations.u_pixelRatio, pixelRatio);
+ return locations;
+ * @inheritDoc
+ ol.render.webgl.CircleReplay.prototype.shutDownProgram = function(gl, locations) {
+ gl.disableVertexAttribArray(locations.a_position);
+ gl.disableVertexAttribArray(locations.a_instruction);
+ gl.disableVertexAttribArray(locations.a_radius);
+ * @inheritDoc
+ ol.render.webgl.CircleReplay.prototype.drawReplay = function(gl, context, skippedFeaturesHash, hitDetection) {
+ if (!ol.obj.isEmpty(skippedFeaturesHash)) {
+ this.drawReplaySkipping_(gl, context, skippedFeaturesHash);
+ } else {
+ //Draw by style groups to minimize drawElements() calls.
+ var i, start, end, nextStyle;
+ end = this.startIndices[this.startIndices.length - 1];
+ for (i = this.styleIndices_.length - 1; i >= 0; --i) {
+ start = this.styleIndices_[i];
+ nextStyle = this.styles_[i];
+ this.setFillStyle_(gl, /** @type {Array.<number>} */ (nextStyle[0]));
+ this.setStrokeStyle_(gl, /** @type {Array.<number>} */ (nextStyle[1]),
+ /** @type {number} */ (nextStyle[2]));
+ this.drawElements(gl, context, start, end);
+ end = start;
+ * @inheritDoc
+ ol.render.webgl.CircleReplay.prototype.drawHitDetectionReplayOneByOne = function(gl, context, skippedFeaturesHash,
+ featureCallback, opt_hitExtent) {
+ var i, start, end, nextStyle, groupStart, feature, featureUid, featureIndex;
+ featureIndex = this.startIndices.length - 2;
+ end = this.startIndices[featureIndex + 1];
+ groupStart = this.styleIndices_[i];
+ while (featureIndex >= 0 &&
+ this.startIndices[featureIndex] >= groupStart) {
+ start = this.startIndices[featureIndex];
+ feature = this.startIndicesFeature[featureIndex];
+ featureUid = ol.getUid(feature).toString();
+ if (skippedFeaturesHash[featureUid] === undefined &&
+ feature.getGeometry() &&
+ (opt_hitExtent === undefined || ol.extent.intersects(
+ /** @type {Array<number>} */ (opt_hitExtent),
+ feature.getGeometry().getExtent()))) {
+ var result = featureCallback(feature);
+ if (result) {
+ return result;
+ featureIndex--;
+ end = start;
+ return undefined;
+ * @private
+ * @param {Object} skippedFeaturesHash Ids of features to skip.
+ ol.render.webgl.CircleReplay.prototype.drawReplaySkipping_ = function(gl, context, skippedFeaturesHash) {
+ var i, start, end, nextStyle, groupStart, feature, featureUid, featureIndex, featureStart;
+ end = start = this.startIndices[featureIndex + 1];
+ featureStart = this.startIndices[featureIndex];
+ if (skippedFeaturesHash[featureUid]) {
+ if (start !== end) {
+ end = featureStart;
+ featureIndex--;
+ start = featureStart;
+ start = end = groupStart;
+ * @private
+ * @param {Array.<number>} color Color.
+ ol.render.webgl.CircleReplay.prototype.setFillStyle_ = function(gl, color) {
+ gl.uniform4fv(this.defaultLocations_.u_fillColor, color);
+ * @private
+ * @param {number} lineWidth Line width.
+ ol.render.webgl.CircleReplay.prototype.setStrokeStyle_ = function(gl, color, lineWidth) {
+ gl.uniform4fv(this.defaultLocations_.u_strokeColor, color);
+ gl.uniform1f(this.defaultLocations_.u_lineWidth, lineWidth);
+ * @inheritDoc
+ ol.render.webgl.CircleReplay.prototype.setFillStrokeStyle = function(fillStyle, strokeStyle) {
+ var strokeStyleColor, strokeStyleWidth;
+ if (strokeStyle) {
+ this.state_.lineDash = strokeStyleLineDash ?
+ strokeStyleLineDash : ol.render.webgl.defaultLineDash;
+ this.state_.lineDashOffset = strokeStyleLineDashOffset ?
+ strokeStyleLineDashOffset : ol.render.webgl.defaultLineDashOffset;
+ strokeStyleColor = strokeStyle.getColor();
+ if (!(strokeStyleColor instanceof CanvasGradient) &&
+ !(strokeStyleColor instanceof CanvasPattern)) {
+ strokeStyleColor = ol.color.asArray(strokeStyleColor).map(function(c, i) {
+ return i != 3 ? c / 255 : c;
+ }) || ol.render.webgl.defaultStrokeStyle;
+ } else {
+ strokeStyleColor = ol.render.webgl.defaultStrokeStyle;
+ strokeStyleWidth = strokeStyle.getWidth();
+ strokeStyleWidth = strokeStyleWidth !== undefined ?
+ strokeStyleWidth : ol.render.webgl.defaultLineWidth;
+ } else {
+ strokeStyleColor = [0, 0, 0, 0];
+ strokeStyleWidth = 0;
+ var fillStyleColor = fillStyle ? fillStyle.getColor() : [0, 0, 0, 0];
+ if (!(fillStyleColor instanceof CanvasGradient) &&
+ !(fillStyleColor instanceof CanvasPattern)) {
+ fillStyleColor = ol.color.asArray(fillStyleColor).map(function(c, i) {
+ }) || ol.render.webgl.defaultFillStyle;
+ } else {
+ fillStyleColor = ol.render.webgl.defaultFillStyle;
+ if (!this.state_.strokeColor || !ol.array.equals(this.state_.strokeColor, strokeStyleColor) ||
+ !this.state_.fillColor || !ol.array.equals(this.state_.fillColor, fillStyleColor) ||
+ this.state_.lineWidth !== strokeStyleWidth) {
+ this.state_.changed = true;
+ this.state_.fillColor = fillStyleColor;
+ this.state_.strokeColor = strokeStyleColor;
+ this.state_.lineWidth = strokeStyleWidth;
+ this.styles_.push([fillStyleColor, strokeStyleColor, strokeStyleWidth]);
+goog.provide('ol.render.webgl.imagereplay.defaultshader');
+ * @constructor
+ * @struct
+ ol.render.webgl.imagereplay.defaultshader.Fragment = function() {
+ ol.webgl.Fragment.call(this, ol.render.webgl.imagereplay.defaultshader.Fragment.SOURCE);
+ ol.inherits(ol.render.webgl.imagereplay.defaultshader.Fragment, ol.webgl.Fragment);
+ * @const
+ * @type {string}
+ ol.render.webgl.imagereplay.defaultshader.Fragment.DEBUG_SOURCE = 'precision mediump float;\nvarying vec2 v_texCoord;\nvarying float v_opacity;\n\nuniform float u_opacity;\nuniform sampler2D u_image;\n\nvoid main(void) {\n vec4 texColor = texture2D(u_image, v_texCoord);\n gl_FragColor.rgb = texColor.rgb;\n float alpha = texColor.a * v_opacity * u_opacity;\n if (alpha == 0.0) {\n discard;\n }\n gl_FragColor.a = alpha;\n}\n';
+ * @const
+ * @type {string}
+ ol.render.webgl.imagereplay.defaultshader.Fragment.OPTIMIZED_SOURCE = 'precision mediump float;varying vec2 a;varying float b;uniform float k;uniform sampler2D l;void main(void){vec4 texColor=texture2D(l,a);gl_FragColor.rgb=texColor.rgb;float alpha=texColor.a*b*k;if(alpha==0.0){discard;}gl_FragColor.a=alpha;}';
+ * @const
+ * @type {string}
+ ol.render.webgl.imagereplay.defaultshader.Fragment.SOURCE = ol.DEBUG_WEBGL ?
+ ol.render.webgl.imagereplay.defaultshader.Fragment.DEBUG_SOURCE :
+ ol.render.webgl.imagereplay.defaultshader.Fragment.OPTIMIZED_SOURCE;
+ ol.render.webgl.imagereplay.defaultshader.fragment = new ol.render.webgl.imagereplay.defaultshader.Fragment();
+ * @constructor
+ * @struct
+ ol.render.webgl.imagereplay.defaultshader.Vertex = function() {
+ ol.webgl.Vertex.call(this, ol.render.webgl.imagereplay.defaultshader.Vertex.SOURCE);
+ ol.inherits(ol.render.webgl.imagereplay.defaultshader.Vertex, ol.webgl.Vertex);
+ * @const
+ * @type {string}
+ ol.render.webgl.imagereplay.defaultshader.Vertex.DEBUG_SOURCE = 'varying vec2 v_texCoord;\nvarying float v_opacity;\n\nattribute vec2 a_position;\nattribute vec2 a_texCoord;\nattribute vec2 a_offsets;\nattribute float a_opacity;\nattribute float a_rotateWithView;\n\nuniform mat4 u_projectionMatrix;\nuniform mat4 u_offsetScaleMatrix;\nuniform mat4 u_offsetRotateMatrix;\n\nvoid main(void) {\n mat4 offsetMatrix = u_offsetScaleMatrix;\n if (a_rotateWithView == 1.0) {\n offsetMatrix = u_offsetScaleMatrix * u_offsetRotateMatrix;\n }\n vec4 offsets = offsetMatrix * vec4(a_offsets, 0.0, 0.0);\n gl_Position = u_projectionMatrix * vec4(a_position, 0.0, 1.0) + offsets;\n v_texCoord = a_texCoord;\n v_opacity = a_opacity;\n}\n\n\n';
+ * @const
+ * @type {string}
+ ol.render.webgl.imagereplay.defaultshader.Vertex.OPTIMIZED_SOURCE = 'varying vec2 a;varying float b;attribute vec2 c;attribute vec2 d;attribute vec2 e;attribute float f;attribute float g;uniform mat4 h;uniform mat4 i;uniform mat4 j;void main(void){mat4 offsetMatrix=i;if(g==1.0){offsetMatrix=i*j;}vec4 offsets=offsetMatrix*vec4(e,0.0,0.0);gl_Position=h*vec4(c,0.0,1.0)+offsets;a=d;b=f;}';
+ * @const
+ * @type {string}
+ ol.render.webgl.imagereplay.defaultshader.Vertex.SOURCE = ol.DEBUG_WEBGL ?
+ ol.render.webgl.imagereplay.defaultshader.Vertex.DEBUG_SOURCE :
+ ol.render.webgl.imagereplay.defaultshader.Vertex.OPTIMIZED_SOURCE;
+ ol.render.webgl.imagereplay.defaultshader.vertex = new ol.render.webgl.imagereplay.defaultshader.Vertex();
+ * @constructor
+ * @struct
+ ol.render.webgl.imagereplay.defaultshader.Locations = function(gl, program) {
+ this.u_image = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_image' : 'l');
+ program, ol.DEBUG_WEBGL ? 'u_opacity' : 'k');
+ * @type {number}
+ this.a_offsets = gl.getAttribLocation(
+ program, ol.DEBUG_WEBGL ? 'a_offsets' : 'e');
+ * @type {number}
+ this.a_opacity = gl.getAttribLocation(
+ program, ol.DEBUG_WEBGL ? 'a_opacity' : 'f');
+ * @type {number}
+ program, ol.DEBUG_WEBGL ? 'a_position' : 'c');
+ * @type {number}
+ this.a_rotateWithView = gl.getAttribLocation(
+ program, ol.DEBUG_WEBGL ? 'a_rotateWithView' : 'g');
+ * @type {number}
+ this.a_texCoord = gl.getAttribLocation(
+ program, ol.DEBUG_WEBGL ? 'a_texCoord' : 'd');
+goog.provide('ol.webgl.ContextEventType');
+ * @enum {string}
+ol.webgl.ContextEventType = {
+ LOST: 'webglcontextlost',
+ RESTORED: 'webglcontextrestored'
+goog.provide('ol.webgl.Context');
+goog.require('ol.Disposable');
+goog.require('ol.array');
+goog.require('ol.events');
+goog.require('ol.webgl.ContextEventType');
+ * @classdesc
+ * A WebGL context for accessing low-level WebGL capabilities.
+ * @constructor
+ * @extends {ol.Disposable}
+ * @param {HTMLCanvasElement} canvas Canvas.
+ ol.webgl.Context = function(canvas, gl) {
+ * @private
+ this.canvas_ = canvas;
+ * @private
+ * @type {WebGLRenderingContext}
+ this.gl_ = gl;
+ * @private
+ * @type {Object.<string, ol.WebglBufferCacheEntry>}
+ this.bufferCache_ = {};
+ * @private
+ * @type {Object.<string, WebGLShader>}
+ this.shaderCache_ = {};
+ * @private
+ * @type {Object.<string, WebGLProgram>}
+ this.programCache_ = {};
+ * @private
+ * @type {WebGLProgram}
+ this.currentProgram_ = null;
+ * @private
+ * @type {WebGLFramebuffer}
+ this.hitDetectionFramebuffer_ = null;
+ * @private
+ * @type {WebGLTexture}
+ this.hitDetectionTexture_ = null;
+ * @private
+ * @type {WebGLRenderbuffer}
+ this.hitDetectionRenderbuffer_ = null;
+ * @type {boolean}
+ this.hasOESElementIndexUint = ol.array.includes(
+ ol.WEBGL_EXTENSIONS, 'OES_element_index_uint');
+ // use the OES_element_index_uint extension if available
+ if (this.hasOESElementIndexUint) {
+ gl.getExtension('OES_element_index_uint');
+ ol.events.listen(this.canvas_, ol.webgl.ContextEventType.LOST,
+ this.handleWebGLContextLost, this);
+ ol.events.listen(this.canvas_, ol.webgl.ContextEventType.RESTORED,
+ this.handleWebGLContextRestored, this);
+ ol.inherits(ol.webgl.Context, ol.Disposable);
+ * Just bind the buffer if it's in the cache. Otherwise create
+ * the WebGL buffer, bind it, populate it, and add an entry to
+ * the cache.
+ * @param {number} target Target.
+ * @param {ol.webgl.Buffer} buf Buffer.
+ ol.webgl.Context.prototype.bindBuffer = function(target, buf) {
+ var gl = this.getGL();
+ var arr = buf.getArray();
+ var bufferKey = String(ol.getUid(buf));
+ if (bufferKey in this.bufferCache_) {
+ var bufferCacheEntry = this.bufferCache_[bufferKey];
+ gl.bindBuffer(target, bufferCacheEntry.buffer);
+ } else {
+ var buffer = gl.createBuffer();
+ gl.bindBuffer(target, buffer);
+ var /** @type {ArrayBufferView} */ arrayBuffer;
+ if (target == ol.webgl.ARRAY_BUFFER) {
+ arrayBuffer = new Float32Array(arr);
+ } else if (target == ol.webgl.ELEMENT_ARRAY_BUFFER) {
+ arrayBuffer = this.hasOESElementIndexUint ?
+ new Uint32Array(arr) : new Uint16Array(arr);
+ gl.bufferData(target, arrayBuffer, buf.getUsage());
+ this.bufferCache_[bufferKey] = {
+ buf: buf,
+ buffer: buffer
+ ol.webgl.Context.prototype.deleteBuffer = function(buf) {
+ if (!gl.isContextLost()) {
+ gl.deleteBuffer(bufferCacheEntry.buffer);
+ delete this.bufferCache_[bufferKey];
+ * @inheritDoc
+ ol.webgl.Context.prototype.disposeInternal = function() {
+ ol.events.unlistenAll(this.canvas_);
+ var key;
+ for (key in this.bufferCache_) {
+ gl.deleteBuffer(this.bufferCache_[key].buffer);
+ for (key in this.programCache_) {
+ gl.deleteProgram(this.programCache_[key]);
+ for (key in this.shaderCache_) {
+ gl.deleteShader(this.shaderCache_[key]);
+ // delete objects for hit-detection
+ gl.deleteFramebuffer(this.hitDetectionFramebuffer_);
+ gl.deleteRenderbuffer(this.hitDetectionRenderbuffer_);
+ gl.deleteTexture(this.hitDetectionTexture_);
+ * @return {HTMLCanvasElement} Canvas.
+ ol.webgl.Context.prototype.getCanvas = function() {
+ return this.canvas_;
+ * Get the WebGL rendering context
+ * @return {WebGLRenderingContext} The rendering context.
+ * @api
+ ol.webgl.Context.prototype.getGL = function() {
+ return this.gl_;
+ * Get the frame buffer for hit detection.
+ * @return {WebGLFramebuffer} The hit detection frame buffer.
+ ol.webgl.Context.prototype.getHitDetectionFramebuffer = function() {
+ if (!this.hitDetectionFramebuffer_) {
+ this.initHitDetectionFramebuffer_();
+ return this.hitDetectionFramebuffer_;
+ * Get shader from the cache if it's in the cache. Otherwise, create
+ * the WebGL shader, compile it, and add entry to cache.
+ * @param {ol.webgl.Shader} shaderObject Shader object.
+ * @return {WebGLShader} Shader.
+ ol.webgl.Context.prototype.getShader = function(shaderObject) {
+ var shaderKey = String(ol.getUid(shaderObject));
+ if (shaderKey in this.shaderCache_) {
+ return this.shaderCache_[shaderKey];
+ } else {
+ var shader = gl.createShader(shaderObject.getType());
+ gl.shaderSource(shader, shaderObject.getSource());
+ gl.compileShader(shader);
+ this.shaderCache_[shaderKey] = shader;
+ return shader;
+ * Get the program from the cache if it's in the cache. Otherwise create
+ * the WebGL program, attach the shaders to it, and add an entry to the
+ * cache.
+ * @param {ol.webgl.Fragment} fragmentShaderObject Fragment shader.
+ * @param {ol.webgl.Vertex} vertexShaderObject Vertex shader.
+ * @return {WebGLProgram} Program.
+ ol.webgl.Context.prototype.getProgram = function(
+ fragmentShaderObject, vertexShaderObject) {
+ var programKey =
+ ol.getUid(fragmentShaderObject) + '/' + ol.getUid(vertexShaderObject);
+ if (programKey in this.programCache_) {
+ return this.programCache_[programKey];
+ } else {
+ var program = gl.createProgram();
+ gl.attachShader(program, this.getShader(fragmentShaderObject));
+ gl.attachShader(program, this.getShader(vertexShaderObject));
+ gl.linkProgram(program);
+ this.programCache_[programKey] = program;
+ return program;
+ * FIXME empy description for jsdoc
+ ol.webgl.Context.prototype.handleWebGLContextLost = function() {
+ ol.obj.clear(this.bufferCache_);
+ ol.obj.clear(this.shaderCache_);
+ ol.obj.clear(this.programCache_);
+ ol.webgl.Context.prototype.handleWebGLContextRestored = function() {
+ * Creates a 1x1 pixel framebuffer for the hit-detection.
+ * @private
+ ol.webgl.Context.prototype.initHitDetectionFramebuffer_ = function() {
+ var gl = this.gl_;
+ var framebuffer = gl.createFramebuffer();
+ gl.bindFramebuffer(gl.FRAMEBUFFER, framebuffer);
+ var texture = ol.webgl.Context.createEmptyTexture(gl, 1, 1);
+ var renderbuffer = gl.createRenderbuffer();
+ gl.bindRenderbuffer(gl.RENDERBUFFER, renderbuffer);
+ gl.renderbufferStorage(gl.RENDERBUFFER, gl.DEPTH_COMPONENT16, 1, 1);
+ gl.framebufferTexture2D(
+ gl.FRAMEBUFFER, gl.COLOR_ATTACHMENT0, gl.TEXTURE_2D, texture, 0);
+ gl.framebufferRenderbuffer(gl.FRAMEBUFFER, gl.DEPTH_ATTACHMENT,
+ gl.RENDERBUFFER, renderbuffer);
+ gl.bindTexture(gl.TEXTURE_2D, null);
+ gl.bindRenderbuffer(gl.RENDERBUFFER, null);
+ gl.bindFramebuffer(gl.FRAMEBUFFER, null);
+ this.hitDetectionFramebuffer_ = framebuffer;
+ this.hitDetectionTexture_ = texture;
+ this.hitDetectionRenderbuffer_ = renderbuffer;
+ * Use a program. If the program is already in use, this will return `false`.
+ * @return {boolean} Changed.
+ * @api
+ ol.webgl.Context.prototype.useProgram = function(program) {
+ if (program == this.currentProgram_) {
+ return false;
+ } else {
+ gl.useProgram(program);
+ this.currentProgram_ = program;
+ return true;
+ * @param {WebGLRenderingContext} gl WebGL rendering context.
+ * @param {number=} opt_wrapS wrapS.
+ * @param {number=} opt_wrapT wrapT.
+ * @return {WebGLTexture} The texture.
+ * @private
+ ol.webgl.Context.createTexture_ = function(gl, opt_wrapS, opt_wrapT) {
+ var texture = gl.createTexture();
+ gl.bindTexture(gl.TEXTURE_2D, texture);
+ gl.texParameteri(gl.TEXTURE_2D, gl.TEXTURE_MAG_FILTER, gl.LINEAR);
+ gl.texParameteri(gl.TEXTURE_2D, gl.TEXTURE_MIN_FILTER, gl.LINEAR);
+ if (opt_wrapS !== undefined) {
+ gl.texParameteri(
+ ol.webgl.TEXTURE_2D, ol.webgl.TEXTURE_WRAP_S, opt_wrapS);
+ if (opt_wrapT !== undefined) {
+ gl.texParameteri(
+ ol.webgl.TEXTURE_2D, ol.webgl.TEXTURE_WRAP_T, opt_wrapT);
+ return texture;
+ * @param {number} width Width.
+ * @param {number} height Height.
+ ol.webgl.Context.createEmptyTexture = function(
+ gl, width, height, opt_wrapS, opt_wrapT) {
+ var texture = ol.webgl.Context.createTexture_(gl, opt_wrapS, opt_wrapT);
+ gl.texImage2D(
+ gl.TEXTURE_2D, 0, gl.RGBA, width, height, 0, gl.RGBA, gl.UNSIGNED_BYTE,
+ null);
+ return texture;
+ * @param {HTMLCanvasElement|HTMLImageElement|HTMLVideoElement} image Image.
+ ol.webgl.Context.createTexture = function(gl, image, opt_wrapS, opt_wrapT) {
+ gl.texImage2D(
+ gl.TEXTURE_2D, 0, gl.RGBA, gl.RGBA, gl.UNSIGNED_BYTE, image);
+ return texture;
+goog.provide('ol.render.webgl.ImageReplay');
+goog.require('ol.render.webgl.imagereplay.defaultshader');
+goog.require('ol.webgl.Context');
+ * @constructor
+ * @struct
+ ol.render.webgl.ImageReplay = function(tolerance, maxExtent) {
+ * @type {number|undefined}
+ * @private
+ this.anchorX_ = undefined;
+ * @private
+ this.anchorY_ = undefined;
+ * @type {Array.<number>}
+ * @private
+ this.groupIndices_ = [];
+ * @private
+ this.hitDetectionGroupIndices_ = [];
+ * @private
+ this.height_ = undefined;
+ * @type {Array.<HTMLCanvasElement|HTMLImageElement|HTMLVideoElement>}
+ * @private
+ this.images_ = [];
+ * @private
+ this.hitDetectionImages_ = [];
+ * @private
+ this.imageHeight_ = undefined;
+ * @private
+ this.imageWidth_ = undefined;
+ * @private
+ * @type {ol.render.webgl.imagereplay.defaultshader.Locations}
+ * @private
+ this.opacity_ = undefined;
+ * @private
+ this.originX_ = undefined;
+ * @private
+ this.originY_ = undefined;
+ * @private
+ * @type {boolean|undefined}
+ this.rotateWithView_ = undefined;
+ * @private
+ this.rotation_ = undefined;
+ * @private
+ this.scale_ = undefined;
+ * @type {Array.<WebGLTexture>}
+ * @private
+ this.textures_ = [];
+ * @private
+ this.hitDetectionTextures_ = [];
+ * @private
+ this.width_ = undefined;
+ ol.inherits(ol.render.webgl.ImageReplay, ol.render.webgl.Replay);
+ * @inheritDoc
+ ol.render.webgl.ImageReplay.prototype.getDeleteResourcesFunction = function(context) {
+ var textures = this.textures_;
+ var hitDetectionTextures = this.hitDetectionTextures_;
+ var i, ii;
+ for (i = 0, ii = textures.length; i < ii; ++i) {
+ gl.deleteTexture(textures[i]);
+ for (i = 0, ii = hitDetectionTextures.length; i < ii; ++i) {
+ gl.deleteTexture(hitDetectionTextures[i]);
+ * @param {Array.<number>} flatCoordinates Flat coordinates.
+ * @param {number} offset Offset.
+ * @param {number} end End.
+ * @param {number} stride Stride.
+ * @return {number} My end.
+ * @private
+ ol.render.webgl.ImageReplay.prototype.drawCoordinates_ = function(flatCoordinates, offset, end, stride) {
+ var anchorX = /** @type {number} */ (this.anchorX_);
+ var anchorY = /** @type {number} */ (this.anchorY_);
+ var height = /** @type {number} */ (this.height_);
+ var imageHeight = /** @type {number} */ (this.imageHeight_);
+ var imageWidth = /** @type {number} */ (this.imageWidth_);
+ var opacity = /** @type {number} */ (this.opacity_);
+ var originX = /** @type {number} */ (this.originX_);
+ var originY = /** @type {number} */ (this.originY_);
+ var rotateWithView = this.rotateWithView_ ? 1.0 : 0.0;
+ // this.rotation_ is anti-clockwise, but rotation is clockwise
+ var rotation = /** @type {number} */ (-this.rotation_);
+ var scale = /** @type {number} */ (this.scale_);
+ var width = /** @type {number} */ (this.width_);
+ var cos = Math.cos(rotation);
+ var sin = Math.sin(rotation);
+ var i, n, offsetX, offsetY, x, y;
+ for (i = offset; i < end; i += stride) {
+ x = flatCoordinates[i] - this.origin[0];
+ y = flatCoordinates[i + 1] - this.origin[1];
+ // There are 4 vertices per [x, y] point, one for each corner of the
+ // rectangle we're going to draw. We'd use 1 vertex per [x, y] point if
+ // WebGL supported Geometry Shaders (which can emit new vertices), but that
+ // is not currently the case.
+ // And each vertex includes 8 values: the x and y coordinates, the x and
+ // y offsets used to calculate the position of the corner, the u and
+ // v texture coordinates for the corner, the opacity, and whether the
+ // the image should be rotated with the view (rotateWithView).
+ n = numVertices / 8;
+ // bottom-left corner
+ offsetX = -scale * anchorX;
+ offsetY = -scale * (height - anchorY);
+ this.vertices[numVertices++] = x;
+ this.vertices[numVertices++] = y;
+ this.vertices[numVertices++] = offsetX * cos - offsetY * sin;
+ this.vertices[numVertices++] = offsetX * sin + offsetY * cos;
+ this.vertices[numVertices++] = originX / imageWidth;
+ this.vertices[numVertices++] = (originY + height) / imageHeight;
+ this.vertices[numVertices++] = opacity;
+ this.vertices[numVertices++] = rotateWithView;
+ // bottom-right corner
+ offsetX = scale * (width - anchorX);
+ this.vertices[numVertices++] = (originX + width) / imageWidth;
+ // top-right corner
+ offsetY = scale * anchorY;
+ this.vertices[numVertices++] = originY / imageHeight;
+ // top-left corner
+ return numVertices;
+ * @inheritDoc
+ ol.render.webgl.ImageReplay.prototype.drawMultiPoint = function(multiPointGeometry, feature) {
+ var flatCoordinates = multiPointGeometry.getFlatCoordinates();
+ var stride = multiPointGeometry.getStride();
+ flatCoordinates, 0, flatCoordinates.length, stride);
+ * @inheritDoc
+ ol.render.webgl.ImageReplay.prototype.drawPoint = function(pointGeometry, feature) {
+ var flatCoordinates = pointGeometry.getFlatCoordinates();
+ var stride = pointGeometry.getStride();
+ * @inheritDoc
+ ol.render.webgl.ImageReplay.prototype.finish = function(context) {
+ this.groupIndices_.push(this.indices.length);
+ this.hitDetectionGroupIndices_.push(this.indices.length);
+ var indices = this.indices;
+ this.indicesBuffer = new ol.webgl.Buffer(indices);
+ // create textures
+ /** @type {Object.<string, WebGLTexture>} */
+ var texturePerImage = {};
+ this.createTextures_(this.textures_, this.images_, texturePerImage, gl);
+ this.createTextures_(this.hitDetectionTextures_, this.hitDetectionImages_,
+ texturePerImage, gl);
+ this.images_ = null;
+ this.hitDetectionImages_ = null;
+ * @private
+ * @param {Array.<WebGLTexture>} textures Textures.
+ * @param {Array.<HTMLCanvasElement|HTMLImageElement|HTMLVideoElement>} images
+ * Images.
+ * @param {Object.<string, WebGLTexture>} texturePerImage Texture cache.
+ * @param {WebGLRenderingContext} gl Gl.
+ ol.render.webgl.ImageReplay.prototype.createTextures_ = function(textures, images, texturePerImage, gl) {
+ var texture, image, uid, i;
+ var ii = images.length;
+ for (i = 0; i < ii; ++i) {
+ image = images[i];
+ uid = ol.getUid(image).toString();
+ if (uid in texturePerImage) {
+ texture = texturePerImage[uid];
+ } else {
+ texture = ol.webgl.Context.createTexture(
+ gl, image, ol.webgl.CLAMP_TO_EDGE, ol.webgl.CLAMP_TO_EDGE);
+ texturePerImage[uid] = texture;
+ textures[i] = texture;
+ * @inheritDoc
+ ol.render.webgl.ImageReplay.prototype.setUpProgram = function(gl, context, size, pixelRatio) {
+ var fragmentShader = ol.render.webgl.imagereplay.defaultshader.fragment;
+ var vertexShader = ol.render.webgl.imagereplay.defaultshader.vertex;
+ var locations;
+ locations =
+ new ol.render.webgl.imagereplay.defaultshader.Locations(gl, program);
+ } else {
+ // use the program (FIXME: use the return value)
+ false, 32, 0);
+ gl.enableVertexAttribArray(locations.a_offsets);
+ gl.vertexAttribPointer(locations.a_offsets, 2, ol.webgl.FLOAT,
+ false, 32, 8);
+ gl.enableVertexAttribArray(locations.a_texCoord);
+ gl.vertexAttribPointer(locations.a_texCoord, 2, ol.webgl.FLOAT,
+ false, 32, 16);
+ gl.enableVertexAttribArray(locations.a_opacity);
+ gl.vertexAttribPointer(locations.a_opacity, 1, ol.webgl.FLOAT,
+ false, 32, 24);
+ gl.enableVertexAttribArray(locations.a_rotateWithView);
+ gl.vertexAttribPointer(locations.a_rotateWithView, 1, ol.webgl.FLOAT,
+ false, 32, 28);
+ return locations;
+ * @inheritDoc
+ ol.render.webgl.ImageReplay.prototype.shutDownProgram = function(gl, locations) {
+ gl.disableVertexAttribArray(locations.a_offsets);
+ gl.disableVertexAttribArray(locations.a_texCoord);
+ gl.disableVertexAttribArray(locations.a_opacity);
+ gl.disableVertexAttribArray(locations.a_rotateWithView);
+ * @inheritDoc
+ ol.render.webgl.ImageReplay.prototype.drawReplay = function(gl, context, skippedFeaturesHash, hitDetection) {
+ var textures = hitDetection ? this.hitDetectionTextures_ : this.textures_;
+ var groupIndices = hitDetection ? this.hitDetectionGroupIndices_ : this.groupIndices_;
+ gl, context, skippedFeaturesHash, textures, groupIndices);
+ } else {
+ var i, ii, start;
+ for (i = 0, ii = textures.length, start = 0; i < ii; ++i) {
+ gl.bindTexture(ol.webgl.TEXTURE_2D, textures[i]);
+ var end = groupIndices[i];
+ start = end;
+ * Draw the replay while paying attention to skipped features.
+ * This functions creates groups of features that can be drawn to together,
+ * so that the number of `drawElements` calls is minimized.
+ * For example given the following texture groups:
+ * Group 1: A B C
+ * Group 2: D [E] F G
+ * If feature E should be skipped, the following `drawElements` calls will be
+ * made:
+ * drawElements with feature A, B and C
+ * drawElements with feature D
+ * drawElements with feature F and G
+ * @private
+ * to skip.
+ * @param {Array.<number>} groupIndices Texture group indices.
+ ol.render.webgl.ImageReplay.prototype.drawReplaySkipping_ = function(gl, context, skippedFeaturesHash, textures,
+ groupIndices) {
+ var featureIndex = 0;
+ var i, ii;
+ var groupStart = (i > 0) ? groupIndices[i - 1] : 0;
+ var groupEnd = groupIndices[i];
+ var start = groupStart;
+ var end = groupStart;
+ while (featureIndex < this.startIndices.length &&
+ this.startIndices[featureIndex] <= groupEnd) {
+ var feature = this.startIndicesFeature[featureIndex];
+ var featureUid = ol.getUid(feature).toString();
+ if (skippedFeaturesHash[featureUid] !== undefined) {
+ // feature should be skipped
+ // draw the features so far
+ // continue with the next feature
+ start = (featureIndex === this.startIndices.length - 1) ?
+ groupEnd : this.startIndices[featureIndex + 1];
+ end = start;
+ } else {
+ // the feature is not skipped, augment the end index
+ end = (featureIndex === this.startIndices.length - 1) ?
+ featureIndex++;
+ // draw the remaining features (in case there was no skipped feature
+ // in this texture group, all features of a group are drawn together)
+ * @inheritDoc
+ ol.render.webgl.ImageReplay.prototype.drawHitDetectionReplayOneByOne = function(gl, context, skippedFeaturesHash,
+ var i, groupStart, start, end, feature, featureUid;
+ var featureIndex = this.startIndices.length - 1;
+ for (i = this.hitDetectionTextures_.length - 1; i >= 0; --i) {
+ gl.bindTexture(ol.webgl.TEXTURE_2D, this.hitDetectionTextures_[i]);
+ groupStart = (i > 0) ? this.hitDetectionGroupIndices_[i - 1] : 0;
+ end = this.hitDetectionGroupIndices_[i];
+ // draw all features for this texture group
+ if (result) {
+ return result;
+ end = start;
+ featureIndex--;
+ return undefined;
+ * @inheritDoc
+ ol.render.webgl.ImageReplay.prototype.setImageStyle = function(imageStyle) {
+ var anchor = imageStyle.getAnchor();
+ var image = imageStyle.getImage(1);
+ var imageSize = imageStyle.getImageSize();
+ var hitDetectionImage = imageStyle.getHitDetectionImage(1);
+ var opacity = imageStyle.getOpacity();
+ var origin = imageStyle.getOrigin();
+ var rotateWithView = imageStyle.getRotateWithView();
+ var rotation = imageStyle.getRotation();
+ var size = imageStyle.getSize();
+ var scale = imageStyle.getScale();
+ var currentImage;
+ if (this.images_.length === 0) {
+ this.images_.push(image);
+ } else {
+ currentImage = this.images_[this.images_.length - 1];
+ if (ol.getUid(currentImage) != ol.getUid(image)) {
+ if (this.hitDetectionImages_.length === 0) {
+ this.hitDetectionImages_.push(hitDetectionImage);
+ } else {
+ currentImage =
+ this.hitDetectionImages_[this.hitDetectionImages_.length - 1];
+ if (ol.getUid(currentImage) != ol.getUid(hitDetectionImage)) {
+ this.anchorX_ = anchor[0];
+ this.anchorY_ = anchor[1];
+ this.height_ = size[1];
+ this.imageHeight_ = imageSize[1];
+ this.imageWidth_ = imageSize[0];
+ this.opacity_ = opacity;
+ this.originX_ = origin[0];
+ this.originY_ = origin[1];
+ this.rotation_ = rotation;
+ this.rotateWithView_ = rotateWithView;
+ this.scale_ = scale;
+ this.width_ = size[0];
+goog.provide('ol.geom.flat.topology');
+goog.require('ol.geom.flat.area');
+ * Check if the linestring is a boundary.
+ * @return {boolean} The linestring is a boundary.
+ol.geom.flat.topology.lineStringIsClosed = function(flatCoordinates, offset, end, stride) {
+ var lastCoord = end - stride;
+ if (flatCoordinates[offset] === flatCoordinates[lastCoord] &&
+ flatCoordinates[offset + 1] === flatCoordinates[lastCoord + 1] && (end - offset) / stride > 3) {
+ return !!ol.geom.flat.area.linearRing(flatCoordinates, offset, end, stride);
+ return false;
+goog.provide('ol.render.webgl.linestringreplay.defaultshader');
+ * @constructor
+ * @struct
+ ol.render.webgl.linestringreplay.defaultshader.Fragment = function() {
+ ol.webgl.Fragment.call(this, ol.render.webgl.linestringreplay.defaultshader.Fragment.SOURCE);
+ ol.inherits(ol.render.webgl.linestringreplay.defaultshader.Fragment, ol.webgl.Fragment);
+ * @const
+ * @type {string}
+ ol.render.webgl.linestringreplay.defaultshader.Fragment.DEBUG_SOURCE = 'precision mediump float;\nvarying float v_round;\nvarying vec2 v_roundVertex;\nvarying float v_halfWidth;\n\n\n\nuniform float u_opacity;\nuniform vec4 u_color;\nuniform vec2 u_size;\nuniform float u_pixelRatio;\n\nvoid main(void) {\n if (v_round > 0.0) {\n vec2 windowCoords = vec2((v_roundVertex.x + 1.0) / 2.0 * u_size.x * u_pixelRatio,\n (v_roundVertex.y + 1.0) / 2.0 * u_size.y * u_pixelRatio);\n if (length(windowCoords - gl_FragCoord.xy) > v_halfWidth * u_pixelRatio) {\n discard;\n }\n }\n gl_FragColor = u_color;\n float alpha = u_color.a * u_opacity;\n if (alpha == 0.0) {\n discard;\n }\n gl_FragColor.a = alpha;\n}\n';
+ * @const
+ * @type {string}
+ ol.render.webgl.linestringreplay.defaultshader.Fragment.OPTIMIZED_SOURCE = 'precision mediump float;varying float a;varying vec2 b;varying float c;uniform float m;uniform vec4 n;uniform vec2 o;uniform float p;void main(void){if(a>0.0){vec2 windowCoords=vec2((b.x+1.0)/2.0*o.x*p,(b.y+1.0)/2.0*o.y*p);if(length(windowCoords-gl_FragCoord.xy)>c*p){discard;}} gl_FragColor=n;float alpha=n.a*m;if(alpha==0.0){discard;}gl_FragColor.a=alpha;}';
+ * @const
+ * @type {string}
+ ol.render.webgl.linestringreplay.defaultshader.Fragment.SOURCE = ol.DEBUG_WEBGL ?
+ ol.render.webgl.linestringreplay.defaultshader.Fragment.DEBUG_SOURCE :
+ ol.render.webgl.linestringreplay.defaultshader.Fragment.OPTIMIZED_SOURCE;
+ ol.render.webgl.linestringreplay.defaultshader.fragment = new ol.render.webgl.linestringreplay.defaultshader.Fragment();
+ * @constructor
+ * @struct
+ ol.render.webgl.linestringreplay.defaultshader.Vertex = function() {
+ ol.webgl.Vertex.call(this, ol.render.webgl.linestringreplay.defaultshader.Vertex.SOURCE);
+ ol.inherits(ol.render.webgl.linestringreplay.defaultshader.Vertex, ol.webgl.Vertex);
+ * @const
+ * @type {string}
+ ol.render.webgl.linestringreplay.defaultshader.Vertex.DEBUG_SOURCE = 'varying float v_round;\nvarying vec2 v_roundVertex;\nvarying float v_halfWidth;\n\n\nattribute vec2 a_lastPos;\nattribute vec2 a_position;\nattribute vec2 a_nextPos;\nattribute float a_direction;\n\nuniform mat4 u_projectionMatrix;\nuniform mat4 u_offsetScaleMatrix;\nuniform mat4 u_offsetRotateMatrix;\nuniform float u_lineWidth;\nuniform float u_miterLimit;\n\nbool nearlyEquals(in float value, in float ref) {\n float epsilon = 0.000000000001;\n return value >= ref - epsilon && value <= ref + epsilon;\n}\n\nvoid alongNormal(out vec2 offset, in vec2 nextP, in float turnDir, in float direction) {\n vec2 dirVect = nextP - a_position;\n vec2 normal = normalize(vec2(-turnDir * dirVect.y, turnDir * dirVect.x));\n offset = u_lineWidth / 2.0 * normal * direction;\n}\n\nvoid miterUp(out vec2 offset, out float round, in bool isRound, in float direction) {\n float halfWidth = u_lineWidth / 2.0;\n vec2 tangent = norma
lize(normalize(a_nextPos - a_position) + normalize(a_position - a_lastPos));\n vec2 normal = vec2(-tangent.y, tangent.x);\n vec2 dirVect = a_nextPos - a_position;\n vec2 tmpNormal = normalize(vec2(-dirVect.y, dirVect.x));\n float miterLength = abs(halfWidth / dot(normal, tmpNormal));\n offset = normal * direction * miterLength;\n round = 0.0;\n if (isRound) {\n round = 1.0;\n } else if (miterLength > u_miterLimit + u_lineWidth) {\n offset = halfWidth * tmpNormal * direction;\n }\n}\n\nbool miterDown(out vec2 offset, in vec4 projPos, in mat4 offsetMatrix, in float direction) {\n bool degenerate = false;\n vec2 tangent = normalize(normalize(a_nextPos - a_position) + normalize(a_position - a_lastPos));\n vec2 normal = vec2(-tangent.y, tangent.x);\n vec2 dirVect = a_lastPos - a_position;\n vec2 tmpNormal = normalize(vec2(-dirVect.y, dirVect.x));\n vec2 longOffset, shortOffset, longVertex;\n vec4 shortProjVertex;\n float halfWidth = u_lineWidth / 2.0;\n if (length
(a_nextPos - a_position) > length(a_lastPos - a_position)) {\n longOffset = tmpNormal * direction * halfWidth;\n shortOffset = normalize(vec2(dirVect.y, -dirVect.x)) * direction * halfWidth;\n longVertex = a_nextPos;\n shortProjVertex = u_projectionMatrix * vec4(a_lastPos, 0.0, 1.0);\n } else {\n shortOffset = tmpNormal * direction * halfWidth;\n longOffset = normalize(vec2(dirVect.y, -dirVect.x)) * direction * halfWidth;\n longVertex = a_lastPos;\n shortProjVertex = u_projectionMatrix * vec4(a_nextPos, 0.0, 1.0);\n }\n //Intersection algorithm based on theory by Paul Bourke (http://paulbourke.net/geometry/pointlineplane/).\n vec4 p1 = u_projectionMatrix * vec4(longVertex, 0.0, 1.0) + offsetMatrix * vec4(longOffset, 0.0, 0.0);\n vec4 p2 = projPos + offsetMatrix * vec4(longOffset, 0.0, 0.0);\n vec4 p3 = shortProjVertex + offsetMatrix * vec4(-shortOffset, 0.0, 0.0);\n vec4 p4 = shortProjVertex + offsetMatrix * vec4(shortOffset, 0.0, 0.0);\n float denom
= (p4.y - p3.y) * (p2.x - p1.x) - (p4.x - p3.x) * (p2.y - p1.y);\n float firstU = ((p4.x - p3.x) * (p1.y - p3.y) - (p4.y - p3.y) * (p1.x - p3.x)) / denom;\n float secondU = ((p2.x - p1.x) * (p1.y - p3.y) - (p2.y - p1.y) * (p1.x - p3.x)) / denom;\n float epsilon = 0.000000000001;\n if (firstU > epsilon && firstU < 1.0 - epsilon && secondU > epsilon && secondU < 1.0 - epsilon) {\n shortProjVertex.x = p1.x + firstU * (p2.x - p1.x);\n shortProjVertex.y = p1.y + firstU * (p2.y - p1.y);\n offset = shortProjVertex.xy;\n degenerate = true;\n } else {\n float miterLength = abs(halfWidth / dot(normal, tmpNormal));\n offset = normal * direction * miterLength;\n }\n return degenerate;\n}\n\nvoid squareCap(out vec2 offset, out float round, in bool isRound, in vec2 nextP,\n in float turnDir, in float direction) {\n round = 0.0;\n vec2 dirVect = a_position - nextP;\n vec2 firstNormal = normalize(dirVect);\n vec2 secondNormal = vec2(turnDir * firstNormal.y * directio
n, -turnDir * firstNormal.x * direction);\n vec2 hypotenuse = normalize(firstNormal - secondNormal);\n vec2 normal = vec2(turnDir * hypotenuse.y * direction, -turnDir * hypotenuse.x * direction);\n float length = sqrt(v_halfWidth * v_halfWidth * 2.0);\n offset = normal * length;\n if (isRound) {\n round = 1.0;\n }\n}\n\nvoid main(void) {\n bool degenerate = false;\n float direction = float(sign(a_direction));\n mat4 offsetMatrix = u_offsetScaleMatrix * u_offsetRotateMatrix;\n vec2 offset;\n vec4 projPos = u_projectionMatrix * vec4(a_position, 0.0, 1.0);\n bool round = nearlyEquals(mod(a_direction, 2.0), 0.0);\n\n v_round = 0.0;\n v_halfWidth = u_lineWidth / 2.0;\n v_roundVertex = projPos.xy;\n\n if (nearlyEquals(mod(a_direction, 3.0), 0.0) || nearlyEquals(mod(a_direction, 17.0), 0.0)) {\n alongNormal(offset, a_nextPos, 1.0, direction);\n } else if (nearlyEquals(mod(a_direction, 5.0), 0.0) || nearlyEquals(mod(a_direction, 13.0), 0.0)) {\n alongNormal(offset,
a_lastPos, -1.0, direction);\n } else if (nearlyEquals(mod(a_direction, 23.0), 0.0)) {\n miterUp(offset, v_round, round, direction);\n } else if (nearlyEquals(mod(a_direction, 19.0), 0.0)) {\n degenerate = miterDown(offset, projPos, offsetMatrix, direction);\n } else if (nearlyEquals(mod(a_direction, 7.0), 0.0)) {\n squareCap(offset, v_round, round, a_nextPos, 1.0, direction);\n } else if (nearlyEquals(mod(a_direction, 11.0), 0.0)) {\n squareCap(offset, v_round, round, a_lastPos, -1.0, direction);\n }\n if (!degenerate) {\n vec4 offsets = offsetMatrix * vec4(offset, 0.0, 0.0);\n gl_Position = projPos + offsets;\n } else {\n gl_Position = vec4(offset, 0.0, 1.0);\n }\n}\n\n\n';
+ * @const
+ * @type {string}
+ ol.render.webgl.linestringreplay.defaultshader.Vertex.OPTIMIZED_SOURCE = 'varying float a;varying vec2 b;varying float c;attribute vec2 d;attribute vec2 e;attribute vec2 f;attribute float g;uniform mat4 h;uniform mat4 i;uniform mat4 j;uniform float k;uniform float l;bool nearlyEquals(in float value,in float ref){float epsilon=0.000000000001;return value>=ref-epsilon&&value<=ref+epsilon;}void alongNormal(out vec2 offset,in vec2 nextP,in float turnDir,in float direction){vec2 dirVect=nextP-e;vec2 normal=normalize(vec2(-turnDir*dirVect.y,turnDir*dirVect.x));offset=k/2.0*normal*direction;}void miterUp(out vec2 offset,out float round,in bool isRound,in float direction){float halfWidth=k/2.0;vec2 tangent=normalize(normalize(f-e)+normalize(e-d));vec2 normal=vec2(-tangent.y,tangent.x);vec2 dirVect=f-e;vec2 tmpNormal=normalize(vec2(-dirVect.y,dirVect.x));float miterLength=abs(halfWidth/dot(normal,tmpNormal));offset=normal*direction*miterLength;round=0.0;if(isRound){round=1.0;}else if(miter
Length>l+k){offset=halfWidth*tmpNormal*direction;}} bool miterDown(out vec2 offset,in vec4 projPos,in mat4 offsetMatrix,in float direction){bool degenerate=false;vec2 tangent=normalize(normalize(f-e)+normalize(e-d));vec2 normal=vec2(-tangent.y,tangent.x);vec2 dirVect=d-e;vec2 tmpNormal=normalize(vec2(-dirVect.y,dirVect.x));vec2 longOffset,shortOffset,longVertex;vec4 shortProjVertex;float halfWidth=k/2.0;if(length(f-e)>length(d-e)){longOffset=tmpNormal*direction*halfWidth;shortOffset=normalize(vec2(dirVect.y,-dirVect.x))*direction*halfWidth;longVertex=f;shortProjVertex=h*vec4(d,0.0,1.0);}else{shortOffset=tmpNormal*direction*halfWidth;longOffset=normalize(vec2(dirVect.y,-dirVect.x))*direction*halfWidth;longVertex=d;shortProjVertex=h*vec4(f,0.0,1.0);}vec4 p1=h*vec4(longVertex,0.0,1.0)+offsetMatrix*vec4(longOffset,0.0,0.0);vec4 p2=projPos+offsetMatrix*vec4(longOffset,0.0,0.0);vec4 p3=shortProjVertex+offsetMatrix*vec4(-shortOffset,0.0,0.0);vec4 p4=shortProjVertex+offsetMatrix*vec4(shortO
ffset,0.0,0.0);float denom=(p4.y-p3.y)*(p2.x-p1.x)-(p4.x-p3.x)*(p2.y-p1.y);float firstU=((p4.x-p3.x)*(p1.y-p3.y)-(p4.y-p3.y)*(p1.x-p3.x))/denom;float secondU=((p2.x-p1.x)*(p1.y-p3.y)-(p2.y-p1.y)*(p1.x-p3.x))/denom;float epsilon=0.000000000001;if(firstU>epsilon&&firstU<1.0-epsilon&&secondU>epsilon&&secondU<1.0-epsilon){shortProjVertex.x=p1.x+firstU*(p2.x-p1.x);shortProjVertex.y=p1.y+firstU*(p2.y-p1.y);offset=shortProjVertex.xy;degenerate=true;}else{float miterLength=abs(halfWidth/dot(normal,tmpNormal));offset=normal*direction*miterLength;}return degenerate;}void squareCap(out vec2 offset,out float round,in bool isRound,in vec2 nextP,in float turnDir,in float direction){round=0.0;vec2 dirVect=e-nextP;vec2 firstNormal=normalize(dirVect);vec2 secondNormal=vec2(turnDir*firstNormal.y*direction,-turnDir*firstNormal.x*direction);vec2 hypotenuse=normalize(firstNormal-secondNormal);vec2 normal=vec2(turnDir*hypotenuse.y*direction,-turnDir*hypotenuse.x*direction);float length=sqrt(c*c*2.0);offs
et=normal*length;if(isRound){round=1.0;}} void main(void){bool degenerate=false;float direction=float(sign(g));mat4 offsetMatrix=i*j;vec2 offset;vec4 projPos=h*vec4(e,0.0,1.0);bool round=nearlyEquals(mod(g,2.0),0.0);a=0.0;c=k/2.0;b=projPos.xy;if(nearlyEquals(mod(g,3.0),0.0)||nearlyEquals(mod(g,17.0),0.0)){alongNormal(offset,f,1.0,direction);}else if(nearlyEquals(mod(g,5.0),0.0)||nearlyEquals(mod(g,13.0),0.0)){alongNormal(offset,d,-1.0,direction);}else if(nearlyEquals(mod(g,23.0),0.0)){miterUp(offset,a,round,direction);}else if(nearlyEquals(mod(g,19.0),0.0)){degenerate=miterDown(offset,projPos,offsetMatrix,direction);}else if(nearlyEquals(mod(g,7.0),0.0)){squareCap(offset,a,round,f,1.0,direction);}else if(nearlyEquals(mod(g,11.0),0.0)){squareCap(offset,a,round,d,-1.0,direction);}if(!degenerate){vec4 offsets=offsetMatrix*vec4(offset,0.0,0.0);gl_Position=projPos+offsets;}else{gl_Position=vec4(offset,0.0,1.0);}}';
+ * @const
+ * @type {string}
+ ol.render.webgl.linestringreplay.defaultshader.Vertex.SOURCE = ol.DEBUG_WEBGL ?
+ ol.render.webgl.linestringreplay.defaultshader.Vertex.DEBUG_SOURCE :
+ ol.render.webgl.linestringreplay.defaultshader.Vertex.OPTIMIZED_SOURCE;
+ ol.render.webgl.linestringreplay.defaultshader.vertex = new ol.render.webgl.linestringreplay.defaultshader.Vertex();
+ * @constructor
+ * @struct
+ ol.render.webgl.linestringreplay.defaultshader.Locations = function(gl, program) {
+ this.u_color = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_color' : 'n');
+ this.u_miterLimit = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_miterLimit' : 'l');
+ program, ol.DEBUG_WEBGL ? 'u_pixelRatio' : 'p');
+ program, ol.DEBUG_WEBGL ? 'u_size' : 'o');
+ * @type {number}
+ this.a_direction = gl.getAttribLocation(
+ program, ol.DEBUG_WEBGL ? 'a_direction' : 'g');
+ * @type {number}
+ this.a_lastPos = gl.getAttribLocation(
+ program, ol.DEBUG_WEBGL ? 'a_lastPos' : 'd');
+ * @type {number}
+ this.a_nextPos = gl.getAttribLocation(
+ program, ol.DEBUG_WEBGL ? 'a_nextPos' : 'f');
+ * @type {number}
+goog.provide('ol.render.webgl.LineStringReplay');
+goog.require('ol.geom.flat.orient');
+goog.require('ol.geom.flat.transform');
+goog.require('ol.geom.flat.topology');
+goog.require('ol.render.webgl.linestringreplay.defaultshader');
+goog.require('ol.webgl');
+if (ol.ENABLE_WEBGL) {
+ * @constructor
+ * @struct
+ ol.render.webgl.LineStringReplay = function(tolerance, maxExtent) {
+ * @private
+ * @type {ol.render.webgl.linestringreplay.defaultshader.Locations}
+ * @private
+ * @type {Array.<Array.<?>>}
+ * @private
+ * @private
+ * @type {{strokeColor: (Array.<number>|null),
+ * lineCap: (string|undefined),
+ * lineJoin: (string|undefined),
+ * miterLimit: (number|undefined),
+ this.state_ = {
+ lineCap: undefined,
+ lineDash: null,
+ lineJoin: undefined,
+ miterLimit: undefined,
+ changed: false
+ ol.inherits(ol.render.webgl.LineStringReplay, ol.render.webgl.Replay);
+ * Draw one segment.
+ * @private
+ ol.render.webgl.LineStringReplay.prototype.drawCoordinates_ = function(flatCoordinates, offset, end, stride) {
+ var i, ii;
+ //To save a vertex, the direction of a point is a product of the sign (1 or -1), a prime from
+ //ol.render.webgl.LineStringReplay.Instruction_, and a rounding factor (1 or 2). If the product is even,
+ //we round it. If it is odd, we don't.
+ var lineJoin = this.state_.lineJoin === 'bevel' ? 0 :
+ this.state_.lineJoin === 'miter' ? 1 : 2;
+ var lineCap = this.state_.lineCap === 'butt' ? 0 :
+ this.state_.lineCap === 'square' ? 1 : 2;
+ var closed = ol.geom.flat.topology.lineStringIsClosed(flatCoordinates, offset, end, stride);
+ var startCoords, sign, n;
+ var lastIndex = numIndices;
+ var lastSign = 1;
+ //We need the adjacent vertices to define normals in joins. p0 = last, p1 = current, p2 = next.
+ var p0, p1, p2;
+ n = numVertices / 7;
+ p0 = p1;
+ p1 = p2 || [flatCoordinates[i], flatCoordinates[i + 1]];
+ //First vertex.
+ if (i === offset) {
+ p2 = [flatCoordinates[i + stride], flatCoordinates[i + stride + 1]];
+ if (end - offset === stride * 2 && ol.array.equals(p1, p2)) {
+ break;
+ if (closed) {
+ //A closed line! Complete the circle.
+ p0 = [flatCoordinates[end - stride * 2],
+ flatCoordinates[end - stride * 2 + 1]];
+ startCoords = p2;
+ } else {
+ //Add the first two/four vertices.
+ if (lineCap) {
+ numVertices = this.addVertices_([0, 0], p1, p2,
+ lastSign * ol.render.webgl.LineStringReplay.Instruction_.BEGIN_LINE_CAP * lineCap, numVertices);
+ -lastSign * ol.render.webgl.LineStringReplay.Instruction_.BEGIN_LINE_CAP * lineCap, numVertices);
+ lastSign * ol.render.webgl.LineStringReplay.Instruction_.BEGIN_LINE * (lineCap || 1), numVertices);
+ -lastSign * ol.render.webgl.LineStringReplay.Instruction_.BEGIN_LINE * (lineCap || 1), numVertices);
+ lastIndex = numVertices / 7 - 1;
+ continue;
+ } else if (i === end - stride) {
+ //Last vertex.
+ if (closed) {
+ //Same as the first vertex.
+ p2 = startCoords;
+ break;
+ } else {
+ p0 = p0 || [0, 0];
+ numVertices = this.addVertices_(p0, p1, [0, 0],
+ lastSign * ol.render.webgl.LineStringReplay.Instruction_.END_LINE * (lineCap || 1), numVertices);
+ -lastSign * ol.render.webgl.LineStringReplay.Instruction_.END_LINE * (lineCap || 1), numVertices);
+ this.indices[numIndices++] = lastIndex - 1;
+ this.indices[numIndices++] = lastIndex;
+ if (lineCap) {
+ lastSign * ol.render.webgl.LineStringReplay.Instruction_.END_LINE_CAP * lineCap, numVertices);
+ -lastSign * ol.render.webgl.LineStringReplay.Instruction_.END_LINE_CAP * lineCap, numVertices);
+ break;
+ } else {
+ // We group CW and straight lines, thus the not so inituitive CCW checking function.
+ sign = ol.render.webgl.triangleIsCounterClockwise(p0[0], p0[1], p1[0], p1[1], p2[0], p2[1])
+ ? -1 : 1;
+ numVertices = this.addVertices_(p0, p1, p2,
+ sign * ol.render.webgl.LineStringReplay.Instruction_.BEVEL_FIRST * (lineJoin || 1), numVertices);
+ sign * ol.render.webgl.LineStringReplay.Instruction_.BEVEL_SECOND * (lineJoin || 1), numVertices);
+ -sign * ol.render.webgl.LineStringReplay.Instruction_.MITER_BOTTOM * (lineJoin || 1), numVertices);
+ if (i > offset) {
+ this.indices[numIndices++] = lastSign * sign > 0 ? lastIndex : lastIndex - 1;
+ lastIndex = n + 2;
+ lastSign = sign;
+ //Add miter
+ if (lineJoin) {
+ sign * ol.render.webgl.LineStringReplay.Instruction_.MITER_TOP * lineJoin, numVertices);
+ if (closed) {
+ n = n || numVertices / 7;
+ sign = ol.geom.flat.orient.linearRingIsClockwise([p0[0], p0[1], p1[0], p1[1], p2[0], p2[1]], 0, 6, 2)
+ ? 1 : -1;
+ * @param {Array.<number>} p0 Last coordinates.
+ * @param {Array.<number>} p1 Current coordinates.
+ * @param {Array.<number>} p2 Next coordinates.
+ * @param {number} product Sign, instruction, and rounding product.
+ * @param {number} numVertices Vertex counter.
+ * @return {number} Vertex counter.
+ * @private
+ ol.render.webgl.LineStringReplay.prototype.addVertices_ = function(p0, p1, p2, product, numVertices) {
+ this.vertices[numVertices++] = p0[0];
+ this.vertices[numVertices++] = p0[1];
+ this.vertices[numVertices++] = p1[0];
+ this.vertices[numVertices++] = p1[1];
+ this.vertices[numVertices++] = p2[0];
+ this.vertices[numVertices++] = p2[1];
+ this.vertices[numVertices++] = product;
+ * Check if the linestring can be drawn (i. e. valid).
+ * @return {boolean} The linestring can be drawn.
+ * @private
+ ol.render.webgl.LineStringReplay.prototype.isValid_ = function(flatCoordinates, offset, end, stride) {
+ var range = end - offset;
+ if (range < stride * 2) {
+ return false;
+ } else if (range === stride * 2) {
+ var firstP = [flatCoordinates[offset], flatCoordinates[offset + 1]];
+ var lastP = [flatCoordinates[offset + stride], flatCoordinates[offset + stride + 1]];
+ return !ol.array.equals(firstP, lastP);
+ return true;
+ * @inheritDoc
+ ol.render.webgl.LineStringReplay.prototype.drawLineString = function(lineStringGeometry, feature) {
+ var flatCoordinates = lineStringGeometry.getFlatCoordinates();
+ var stride = lineStringGeometry.getStride();
+ if (this.isValid_(flatCoordinates, 0, flatCoordinates.length, stride)) {
+ flatCoordinates = ol.geom.flat.transform.translate(flatCoordinates, 0, flatCoordinates.length,
+ * @inheritDoc
+ ol.render.webgl.LineStringReplay.prototype.drawMultiLineString = function(multiLineStringGeometry, feature) {
+ var indexCount = this.indices.length;
+ var lineStringGeometries = multiLineStringGeometry.getLineStrings();
+ var i, ii;
+ for (i = 0, ii = lineStringGeometries.length; i < ii; ++i) {
+ var flatCoordinates = lineStringGeometries[i].getFlatCoordinates();
+ var stride = lineStringGeometries[i].getStride();
+ if (this.indices.length > indexCount) {
+ this.startIndices.push(indexCount);
+ this.styleIndices_.push(indexCount);
+ * @param {Array.<Array.<number>>} holeFlatCoordinates Hole flat coordinates.
+ ol.render.webgl.LineStringReplay.prototype.drawPolygonCoordinates = function(
+ flatCoordinates, holeFlatCoordinates, stride) {
+ if (!ol.geom.flat.topology.lineStringIsClosed(flatCoordinates, 0,
+ flatCoordinates.length, stride)) {
+ flatCoordinates.push(flatCoordinates[0]);
+ flatCoordinates.push(flatCoordinates[1]);
+ this.drawCoordinates_(flatCoordinates, 0, flatCoordinates.length, stride);
+ if (holeFlatCoordinates.length) {
+ var i, ii;
+ for (i = 0, ii = holeFlatCoordinates.length; i < ii; ++i) {
+ if (!ol.geom.flat.topology.lineStringIsClosed(holeFlatCoordinates[i], 0,
+ holeFlatCoordinates[i].length, stride)) {
+ holeFlatCoordinates[i].push(holeFlatCoordinates[i][0]);
+ holeFlatCoordinates[i].push(holeFlatCoordinates[i][1]);
+ this.drawCoordinates_(holeFlatCoordinates[i], 0,
+ holeFlatCoordinates[i].length, stride);
+ * @param {ol.Feature|ol.render.Feature} feature Feature.
+ * @param {number=} opt_index Index count.
+ ol.render.webgl.LineStringReplay.prototype.setPolygonStyle = function(feature, opt_index) {
+ var index = opt_index === undefined ? this.indices.length : opt_index;
+ this.startIndices.push(index);
+ this.styleIndices_.push(index);
+ * @return {number} Current index.
+ ol.render.webgl.LineStringReplay.prototype.getCurrentIndex = function() {
+ return this.indices.length;
+ * @inheritDoc
+ ol.render.webgl.LineStringReplay.prototype.finish = function(context) {
+ * @inheritDoc
+ ol.render.webgl.LineStringReplay.prototype.getDeleteResourcesFunction = function(context) {
+ * @inheritDoc
+ ol.render.webgl.LineStringReplay.prototype.setUpProgram = function(gl, context, size, pixelRatio) {
+ fragmentShader = ol.render.webgl.linestringreplay.defaultshader.fragment;
+ vertexShader = ol.render.webgl.linestringreplay.defaultshader.vertex;
+ var locations;
+ locations =
+ new ol.render.webgl.linestringreplay.defaultshader.Locations(gl, program);
+ } else {
+ gl.enableVertexAttribArray(locations.a_lastPos);
+ gl.vertexAttribPointer(locations.a_lastPos, 2, ol.webgl.FLOAT,
+ false, 28, 0);
+ false, 28, 8);
+ gl.enableVertexAttribArray(locations.a_nextPos);
+ gl.vertexAttribPointer(locations.a_nextPos, 2, ol.webgl.FLOAT,
+ false, 28, 16);
+ gl.enableVertexAttribArray(locations.a_direction);
+ gl.vertexAttribPointer(locations.a_direction, 1, ol.webgl.FLOAT,
+ false, 28, 24);
+ return locations;
+ * @inheritDoc
+ ol.render.webgl.LineStringReplay.prototype.shutDownProgram = function(gl, locations) {
+ gl.disableVertexAttribArray(locations.a_lastPos);
+ gl.disableVertexAttribArray(locations.a_nextPos);
+ gl.disableVertexAttribArray(locations.a_direction);
+ * @inheritDoc
+ ol.render.webgl.LineStringReplay.prototype.drawReplay = function(gl, context, skippedFeaturesHash, hitDetection) {
+ //Save GL parameters.
+ var tmpDepthFunc = /** @type {number} */ (gl.getParameter(gl.DEPTH_FUNC));
+ var tmpDepthMask = /** @type {boolean} */ (gl.getParameter(gl.DEPTH_WRITEMASK));
+ if (!hitDetection) {
+ gl.enable(gl.DEPTH_TEST);
+ gl.depthMask(true);
+ gl.depthFunc(gl.NOTEQUAL);
+ } else {
+ this.setStrokeStyle_(gl, nextStyle[0], nextStyle[1], nextStyle[2]);
+ gl.clear(gl.DEPTH_BUFFER_BIT);
+ end = start;
+ gl.disable(gl.DEPTH_TEST);
+ //Restore GL parameters.
+ gl.depthMask(tmpDepthMask);
+ gl.depthFunc(tmpDepthFunc);
+ * @private
+ * @param {WebGLRenderingContext} gl gl.
+ * @param {ol.webgl.Context} context Context.
+ ol.render.webgl.LineStringReplay.prototype.drawReplaySkipping_ = function(gl, context, skippedFeaturesHash) {
+ featureIndex--;
+ * @inheritDoc
+ ol.render.webgl.LineStringReplay.prototype.drawHitDetectionReplayOneByOne = function(gl, context, skippedFeaturesHash,
+ gl.clear(gl.COLOR_BUFFER_BIT | gl.DEPTH_BUFFER_BIT);
+ if (result) {
+ return result;
+ featureIndex--;
+ end = start;
+ return undefined;
+ * @private
+ * @param {number} miterLimit Miter limit.
+ ol.render.webgl.LineStringReplay.prototype.setStrokeStyle_ = function(gl, color, lineWidth, miterLimit) {
+ gl.uniform4fv(this.defaultLocations_.u_color, color);
+ gl.uniform1f(this.defaultLocations_.u_miterLimit, miterLimit);
+ * @inheritDoc
+ ol.render.webgl.LineStringReplay.prototype.setFillStrokeStyle = function(fillStyle, strokeStyle) {
+ var strokeStyleLineCap = strokeStyle.getLineCap();
+ this.state_.lineCap = strokeStyleLineCap !== undefined ?
+ strokeStyleLineCap : ol.render.webgl.defaultLineCap;
+ var strokeStyleLineDash = strokeStyle.getLineDash();
+ var strokeStyleLineDashOffset = strokeStyle.getLineDashOffset();
+ var strokeStyleLineJoin = strokeStyle.getLineJoin();
+ this.state_.lineJoin = strokeStyleLineJoin !== undefined ?
+ strokeStyleLineJoin : ol.render.webgl.defaultLineJoin;
+ var strokeStyleColor = strokeStyle.getColor();
+ } else {
+ var strokeStyleWidth = strokeStyle.getWidth();
+ var strokeStyleMiterLimit = strokeStyle.getMiterLimit();
+ strokeStyleMiterLimit = strokeStyleMiterLimit !== undefined ?
+ strokeStyleMiterLimit : ol.render.webgl.defaultMiterLimit;
+ this.state_.lineWidth !== strokeStyleWidth || this.state_.miterLimit !== strokeStyleMiterLimit) {
+ this.state_.miterLimit = strokeStyleMiterLimit;
+ this.styles_.push([strokeStyleColor, strokeStyleWidth, strokeStyleMiterLimit]);
+ * @enum {number}
+ * @private
+ ol.render.webgl.LineStringReplay.Instruction_ = {
+ ROUND: 2,
+ BEGIN_LINE: 3,
+ END_LINE: 5,
+ BEGIN_LINE_CAP: 7,
+ END_LINE_CAP: 11,
+ BEVEL_FIRST: 13,
+ BEVEL_SECOND: 17,
+ MITER_BOTTOM: 19,
+ MITER_TOP: 23
+// This file is automatically generated, do not edit
+goog.provide('ol.render.webgl.polygonreplay.defaultshader');
+goog.require('ol.webgl.Fragment');
+goog.require('ol.webgl.Vertex');
+ * @constructor
+ * @extends {ol.webgl.Fragment}
+ * @struct
+ ol.render.webgl.polygonreplay.defaultshader.Fragment = function() {
+ ol.webgl.Fragment.call(this, ol.render.webgl.polygonreplay.defaultshader.Fragment.SOURCE);
+ ol.inherits(ol.render.webgl.polygonreplay.defaultshader.Fragment, ol.webgl.Fragment);
+ * @const
+ * @type {string}
+ ol.render.webgl.polygonreplay.defaultshader.Fragment.DEBUG_SOURCE = 'precision mediump float;\n\n\n\nuniform vec4 u_color;\nuniform float u_opacity;\n\nvoid main(void) {\n gl_FragColor = u_color;\n float alpha = u_color.a * u_opacity;\n if (alpha == 0.0) {\n discard;\n }\n gl_FragColor.a = alpha;\n}\n';
+ * @const
+ * @type {string}
+ ol.render.webgl.polygonreplay.defaultshader.Fragment.OPTIMIZED_SOURCE = 'precision mediump float;uniform vec4 e;uniform float f;void main(void){gl_FragColor=e;float alpha=e.a*f;if(alpha==0.0){discard;}gl_FragColor.a=alpha;}';
+ * @const
+ * @type {string}
+ ol.render.webgl.polygonreplay.defaultshader.Fragment.SOURCE = ol.DEBUG_WEBGL ?
+ ol.render.webgl.polygonreplay.defaultshader.Fragment.DEBUG_SOURCE :
+ ol.render.webgl.polygonreplay.defaultshader.Fragment.OPTIMIZED_SOURCE;
+ ol.render.webgl.polygonreplay.defaultshader.fragment = new ol.render.webgl.polygonreplay.defaultshader.Fragment();
+ * @constructor
+ * @extends {ol.webgl.Vertex}
+ * @struct
+ ol.render.webgl.polygonreplay.defaultshader.Vertex = function() {
+ ol.webgl.Vertex.call(this, ol.render.webgl.polygonreplay.defaultshader.Vertex.SOURCE);
+ ol.inherits(ol.render.webgl.polygonreplay.defaultshader.Vertex, ol.webgl.Vertex);
+ * @const
+ * @type {string}
+ ol.render.webgl.polygonreplay.defaultshader.Vertex.DEBUG_SOURCE = '\n\nattribute vec2 a_position;\n\nuniform mat4 u_projectionMatrix;\nuniform mat4 u_offsetScaleMatrix;\nuniform mat4 u_offsetRotateMatrix;\n\nvoid main(void) {\n gl_Position = u_projectionMatrix * vec4(a_position, 0.0, 1.0);\n}\n\n\n';
+ * @const
+ * @type {string}
+ ol.render.webgl.polygonreplay.defaultshader.Vertex.OPTIMIZED_SOURCE = 'attribute vec2 a;uniform mat4 b;uniform mat4 c;uniform mat4 d;void main(void){gl_Position=b*vec4(a,0.0,1.0);}';
+ * @const
+ * @type {string}
+ ol.render.webgl.polygonreplay.defaultshader.Vertex.SOURCE = ol.DEBUG_WEBGL ?
+ ol.render.webgl.polygonreplay.defaultshader.Vertex.DEBUG_SOURCE :
+ ol.render.webgl.polygonreplay.defaultshader.Vertex.OPTIMIZED_SOURCE;
+ ol.render.webgl.polygonreplay.defaultshader.vertex = new ol.render.webgl.polygonreplay.defaultshader.Vertex();
+ * @constructor
+ * @param {WebGLRenderingContext} gl GL.
+ * @param {WebGLProgram} program Program.
+ * @struct
+ ol.render.webgl.polygonreplay.defaultshader.Locations = function(gl, program) {
+ * @type {WebGLUniformLocation}
+ program, ol.DEBUG_WEBGL ? 'u_color' : 'e');
+ this.u_offsetRotateMatrix = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_offsetRotateMatrix' : 'd');
+ this.u_offsetScaleMatrix = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_offsetScaleMatrix' : 'c');
+ this.u_opacity = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_opacity' : 'f');
+ this.u_projectionMatrix = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_projectionMatrix' : 'b');
+ * @type {number}
+ this.a_position = gl.getAttribLocation(
+ program, ol.DEBUG_WEBGL ? 'a_position' : 'a');
+goog.provide('ol.style.Stroke');
+goog.require('ol');
+ * @classdesc
+ * Set stroke style for vector features.
+ * Note that the defaults given are the Canvas defaults, which will be used if
+ * option is not defined. The `get` functions return whatever was entered in
+ * the options; they will not return the default.
+ * @constructor
+ * @param {olx.style.StrokeOptions=} opt_options Options.
+ * @api
+ol.style.Stroke = function(opt_options) {
+ var options = opt_options || {};
+ * @private
+ * @type {ol.Color|ol.ColorLike}
+ this.color_ = options.color !== undefined ? options.color : null;
+ * @private
+ * @type {string|undefined}
+ this.lineCap_ = options.lineCap;
+ * @private
+ this.lineDash_ = options.lineDash !== undefined ? options.lineDash : null;
+ * @private
+ this.lineDashOffset_ = options.lineDashOffset;
+ * @private
+ this.lineJoin_ = options.lineJoin;
+ * @private
+ this.miterLimit_ = options.miterLimit;
+ * @private
+ this.width_ = options.width;
+ * @private
+ this.checksum_ = undefined;
+ * Clones the style.
+ * @return {ol.style.Stroke} The cloned style.
+ * @api
+ol.style.Stroke.prototype.clone = function() {
+ var color = this.getColor();
+ return new ol.style.Stroke({
+ color: (color && color.slice) ? color.slice() : color || undefined,
+ lineCap: this.getLineCap(),
+ lineDash: this.getLineDash() ? this.getLineDash().slice() : undefined,
+ lineDashOffset: this.getLineDashOffset(),
+ lineJoin: this.getLineJoin(),
+ miterLimit: this.getMiterLimit(),
+ width: this.getWidth()
+ * Get the stroke color.
+ * @return {ol.Color|ol.ColorLike} Color.
+ * @api
+ol.style.Stroke.prototype.getColor = function() {
+ return this.color_;
+ * Get the line cap type for the stroke.
+ * @return {string|undefined} Line cap.
+ * @api
+ol.style.Stroke.prototype.getLineCap = function() {
+ return this.lineCap_;
+ * Get the line dash style for the stroke.
+ * @return {Array.<number>} Line dash.
+ * @api
+ol.style.Stroke.prototype.getLineDash = function() {
+ return this.lineDash_;
+ * Get the line dash offset for the stroke.
+ * @return {number|undefined} Line dash offset.
+ * @api
+ol.style.Stroke.prototype.getLineDashOffset = function() {
+ return this.lineDashOffset_;
+ * Get the line join type for the stroke.
+ * @return {string|undefined} Line join.
+ * @api
+ol.style.Stroke.prototype.getLineJoin = function() {
+ return this.lineJoin_;
+ * Get the miter limit for the stroke.
+ * @return {number|undefined} Miter limit.
+ * @api
+ol.style.Stroke.prototype.getMiterLimit = function() {
+ return this.miterLimit_;
+ * Get the stroke width.
+ * @return {number|undefined} Width.
+ * @api
+ol.style.Stroke.prototype.getWidth = function() {
+ return this.width_;
+ * Set the color.
+ * @param {ol.Color|ol.ColorLike} color Color.
+ * @api
+ol.style.Stroke.prototype.setColor = function(color) {
+ this.color_ = color;
+ * Set the line cap.
+ * @param {string|undefined} lineCap Line cap.
+ * @api
+ol.style.Stroke.prototype.setLineCap = function(lineCap) {
+ this.lineCap_ = lineCap;
+ * Set the line dash.
+ * Please note that Internet Explorer 10 and lower [do not support][mdn] the
+ * `setLineDash` method on the `CanvasRenderingContext2D` and therefore this
+ * property will have no visual effect in these browsers.
+ * [mdn]: https://developer.mozilla.org/en-US/docs/Web/API/CanvasRenderingContext2D/setLineDash#Browser_compatibility
+ * @param {Array.<number>} lineDash Line dash.
+ * @api
+ol.style.Stroke.prototype.setLineDash = function(lineDash) {
+ this.lineDash_ = lineDash;
+ * Set the line dash offset.
+ * @param {number|undefined} lineDashOffset Line dash offset.
+ * @api
+ol.style.Stroke.prototype.setLineDashOffset = function(lineDashOffset) {
+ this.lineDashOffset_ = lineDashOffset;
+ * Set the line join.
+ * @param {string|undefined} lineJoin Line join.
+ * @api
+ol.style.Stroke.prototype.setLineJoin = function(lineJoin) {
+ this.lineJoin_ = lineJoin;
+ * Set the miter limit.
+ * @param {number|undefined} miterLimit Miter limit.
+ * @api
+ol.style.Stroke.prototype.setMiterLimit = function(miterLimit) {
+ this.miterLimit_ = miterLimit;
+ * Set the width.
+ * @param {number|undefined} width Width.
+ * @api
+ol.style.Stroke.prototype.setWidth = function(width) {
+ this.width_ = width;
+ * @return {string} The checksum.
+ol.style.Stroke.prototype.getChecksum = function() {
+ if (this.checksum_ === undefined) {
+ this.checksum_ = 's';
+ if (this.color_) {
+ if (typeof this.color_ === 'string') {
+ this.checksum_ += this.color_;
+ } else {
+ this.checksum_ += ol.getUid(this.color_).toString();
+ } else {
+ this.checksum_ += '-';
+ this.checksum_ += ',' +
+ (this.lineCap_ !== undefined ?
+ this.lineCap_.toString() : '-') + ',' +
+ (this.lineDash_ ?
+ this.lineDash_.toString() : '-') + ',' +
+ (this.lineDashOffset_ !== undefined ?
+ this.lineDashOffset_ : '-') + ',' +
+ (this.lineJoin_ !== undefined ?
+ this.lineJoin_ : '-') + ',' +
+ (this.miterLimit_ !== undefined ?
+ this.miterLimit_.toString() : '-') + ',' +
+ (this.width_ !== undefined ?
+ this.width_.toString() : '-');
+ return this.checksum_;
+goog.provide('ol.structs.LinkedList');
+ * Creates an empty linked list structure.
+ * @constructor
+ * @struct
+ * @param {boolean=} opt_circular The last item is connected to the first one,
+ * and the first item to the last one. Default is true.
+ol.structs.LinkedList = function(opt_circular) {
+ * @private
+ * @type {ol.LinkedListItem|undefined}
+ this.first_ = undefined;
+ * @private
+ this.last_ = undefined;
+ * @private
+ this.head_ = undefined;
+ * @private
+ * @type {boolean}
+ this.circular_ = opt_circular === undefined ? true : opt_circular;
+ * @private
+ * @type {number}
+ this.length_ = 0;
+ * Inserts an item into the linked list right after the current one.
+ * @param {?} data Item data.
+ol.structs.LinkedList.prototype.insertItem = function(data) {
+ /** @type {ol.LinkedListItem} */
+ var item = {
+ prev: undefined,
+ next: undefined,
+ data: data
+ var head = this.head_;
+ //Initialize the list.
+ if (!head) {
+ this.first_ = item;
+ this.last_ = item;
+ if (this.circular_) {
+ item.next = item;
+ item.prev = item;
+ } else {
+ //Link the new item to the adjacent ones.
+ var next = head.next;
+ item.prev = head;
+ item.next = next;
+ head.next = item;
+ if (next) {
+ next.prev = item;
+ if (head === this.last_) {
+ this.head_ = item;
+ this.length_++;
+ * Removes the current item from the list. Sets the cursor to the next item,
+ * if possible.
+ol.structs.LinkedList.prototype.removeItem = function() {
+ if (head) {
+ var prev = head.prev;
+ if (next) {
+ next.prev = prev;
+ if (prev) {
+ prev.next = next;
+ this.head_ = next || prev;
+ if (this.first_ === this.last_) {
+ } else if (this.first_ === head) {
+ this.first_ = this.head_;
+ } else if (this.last_ === head) {
+ this.last_ = prev ? this.head_.prev : this.head_;
+ this.length_--;
+ * Sets the cursor to the first item, and returns the associated data.
+ * @return {?} Item data.
+ol.structs.LinkedList.prototype.firstItem = function() {
+ this.head_ = this.first_;
+ if (this.head_) {
+ return this.head_.data;
+ return undefined;
+* Sets the cursor to the last item, and returns the associated data.
+* @return {?} Item data.
+ol.structs.LinkedList.prototype.lastItem = function() {
+ this.head_ = this.last_;
+ if (this.head_) {
+ return undefined;
+ * Sets the cursor to the next item, and returns the associated data.
+ol.structs.LinkedList.prototype.nextItem = function() {
+ if (this.head_ && this.head_.next) {
+ this.head_ = this.head_.next;
+ return undefined;
+ * Returns the next item's data without moving the cursor.
+ol.structs.LinkedList.prototype.getNextItem = function() {
+ return this.head_.next.data;
+ return undefined;
+ * Sets the cursor to the previous item, and returns the associated data.
+ol.structs.LinkedList.prototype.prevItem = function() {
+ if (this.head_ && this.head_.prev) {
+ this.head_ = this.head_.prev;
+ return undefined;
+ * Returns the previous item's data without moving the cursor.
+ol.structs.LinkedList.prototype.getPrevItem = function() {
+ return this.head_.prev.data;
+ return undefined;
+ * Returns the current item's data.
+ol.structs.LinkedList.prototype.getCurrItem = function() {
+ if (this.head_) {
+ return undefined;
+ * Sets the first item of the list. This only works for circular lists, and sets
+ * the last item accordingly.
+ol.structs.LinkedList.prototype.setFirstItem = function() {
+ if (this.circular_ && this.head_) {
+ this.last_ = this.head_.prev;
+ * Concatenates two lists.
+ * @param {ol.structs.LinkedList} list List to merge into the current list.
+ol.structs.LinkedList.prototype.concat = function(list) {
+ if (list.head_) {
+ if (this.head_) {
+ var end = this.head_.next;
+ this.head_.next = list.first_;
+ list.first_.prev = this.head_;
+ end.prev = list.last_;
+ list.last_.next = end;
+ this.length_ += list.length_;
+ } else {
+ this.head_ = list.head_;
+ this.first_ = list.first_;
+ this.last_ = list.last_;
+ this.length_ = list.length_;
+ list.head_ = undefined;
+ list.first_ = undefined;
+ list.last_ = undefined;
+ list.length_ = 0;
+ * Returns the current length of the list.
+ * @return {number} Length.
+ol.structs.LinkedList.prototype.getLength = function() {
+ return this.length_;
+goog.provide('ol.ext.rbush');
+/** @typedef {function(*)} */
+ol.ext.rbush;
+(function() {
+var exports = {};
+var module = {exports: exports};
+var define;
+ * @fileoverview
+ * @suppress {accessControls, ambiguousFunctionDecl, checkDebuggerStatement, checkRegExp, checkTypes, checkVars, const, constantProperty, deprecated, duplicate, es5Strict, fileoverviewTags, missingProperties, nonStandardJsDocs, strictModuleDepCheck, suspiciousCode, undefinedNames, undefinedVars, unknownDefines, unusedLocalVariables, uselessCode, visibility}
+(function(f){if(typeof exports==="object"&&typeof module!=="undefined"){module.exports=f()}else if(typeof define==="function"&&define.amd){define([],f)}else{var g;if(typeof window!=="undefined"){g=window}else if(typeof global!=="undefined"){g=global}else if(typeof self!=="undefined"){g=self}else{g=this}g.rbush = f()}})(function(){var define,module,exports;return (function e(t,n,r){function s(o,u){if(!n[o]){if(!t[o]){var a=typeof require=="function"&&require;if(!u&&a)return a(o,!0);if(i)return i(o,!0);var f=new Error("Cannot find module '"+o+"'");throw f.code="MODULE_NOT_FOUND",f}var l=n[o]={exports:{}};t[o][0].call(l.exports,function(e){var n=t[o][1][e];return s(n?n:e)},l,l.exports,e,t,n,r)}return n[o].exports}var i=typeof require=="function"&&require;for(var o=0;o<r.length;o++)s(r[o]);return s})({1:[function(_dereq_,module,exports){
+'use strict';
+module.exports = partialSort;
+// Floyd-Rivest selection algorithm:
+// Rearrange items so that all items in the [left, k] range are smaller than all items in (k, right];
+// The k-th element will have the (k - left + 1)th smallest value in [left, right]
+function partialSort(arr, k, left, right, compare) {
+ left = left || 0;
+ right = right || (arr.length - 1);
+ compare = compare || defaultCompare;
+ while (right > left) {
+ if (right - left > 600) {
+ var n = right - left + 1;
+ var m = k - left + 1;
+ var z = Math.log(n);
+ var s = 0.5 * Math.exp(2 * z / 3);
+ var sd = 0.5 * Math.sqrt(z * s * (n - s) / n) * (m - n / 2 < 0 ? -1 : 1);
+ var newLeft = Math.max(left, Math.floor(k - m * s / n + sd));
+ var newRight = Math.min(right, Math.floor(k + (n - m) * s / n + sd));
+ partialSort(arr, k, newLeft, newRight, compare);
+ var t = arr[k];
+ var i = left;
+ var j = right;
+ swap(arr, left, k);
+ if (compare(arr[right], t) > 0) swap(arr, left, right);
+ while (i < j) {
+ swap(arr, i, j);
+ i++;
+ j--;
+ while (compare(arr[i], t) < 0) i++;
+ while (compare(arr[j], t) > 0) j--;
+ if (compare(arr[left], t) === 0) swap(arr, left, j);
+ else {
+ j++;
+ swap(arr, j, right);
+ if (j <= k) left = j + 1;
+ if (k <= j) right = j - 1;
+function swap(arr, i, j) {
+ var tmp = arr[i];
+ arr[i] = arr[j];
+ arr[j] = tmp;
+function defaultCompare(a, b) {
+ return a < b ? -1 : a > b ? 1 : 0;
+},{}],2:[function(_dereq_,module,exports){
+'use strict';
+module.exports = rbush;
+var quickselect = _dereq_('quickselect');
+function rbush(maxEntries, format) {
+ if (!(this instanceof rbush)) return new rbush(maxEntries, format);
+ // max entries in a node is 9 by default; min node fill is 40% for best performance
+ this._maxEntries = Math.max(4, maxEntries || 9);
+ this._minEntries = Math.max(2, Math.ceil(this._maxEntries * 0.4));
+ if (format) {
+ this._initFormat(format);
+ this.clear();
+rbush.prototype = {
+ all: function () {
+ return this._all(this.data, []);
+ search: function (bbox) {
+ var node = this.data,
+ result = [],
+ toBBox = this.toBBox;
+ if (!intersects(bbox, node)) return result;
+ var nodesToSearch = [],
+ i, len, child, childBBox;
+ while (node) {
+ for (i = 0, len = node.children.length; i < len; i++) {
+ child = node.children[i];
+ childBBox = node.leaf ? toBBox(child) : child;
+ if (intersects(bbox, childBBox)) {
+ if (node.leaf) result.push(child);
+ else if (contains(bbox, childBBox)) this._all(child, result);
+ else nodesToSearch.push(child);
+ node = nodesToSearch.pop();
+ return result;
+ collides: function (bbox) {
+ if (!intersects(bbox, node)) return false;
+ while (node) {
+ if (node.leaf || contains(bbox, childBBox)) return true;
+ nodesToSearch.push(child);
+ return false;
+ load: function (data) {
+ if (!(data && data.length)) return this;
+ if (data.length < this._minEntries) {
+ for (var i = 0, len = data.length; i < len; i++) {
+ this.insert(data[i]);
+ return this;
+ // recursively build the tree with the given data from stratch using OMT algorithm
+ var node = this._build(data.slice(), 0, data.length - 1, 0);
+ if (!this.data.children.length) {
+ // save as is if tree is empty
+ this.data = node;
+ } else if (this.data.height === node.height) {
+ // split root if trees have the same height
+ this._splitRoot(this.data, node);
+ } else {
+ if (this.data.height < node.height) {
+ // swap trees if inserted one is bigger
+ var tmpNode = this.data;
+ this.data = node;
+ node = tmpNode;
+ // insert the small tree into the large tree at appropriate level
+ this._insert(node, this.data.height - node.height - 1, true);
+ return this;
+ insert: function (item) {
+ if (item) this._insert(item, this.data.height - 1);
+ return this;
+ clear: function () {
+ this.data = createNode([]);
+ return this;
+ remove: function (item, equalsFn) {
+ if (!item) return this;
+ bbox = this.toBBox(item),
+ path = [],
+ indexes = [],
+ i, parent, index, goingUp;
+ // depth-first iterative tree traversal
+ while (node || path.length) {
+ if (!node) { // go up
+ node = path.pop();
+ parent = path[path.length - 1];
+ i = indexes.pop();
+ goingUp = true;
+ if (node.leaf) { // check current node
+ index = findItem(item, node.children, equalsFn);
+ if (index !== -1) {
+ // item found, remove the item and condense tree upwards
+ node.children.splice(index, 1);
+ path.push(node);
+ this._condense(path);
+ return this;
+ if (!goingUp && !node.leaf && contains(node, bbox)) { // go down
+ path.push(node);
+ indexes.push(i);
+ i = 0;
+ parent = node;
+ node = node.children[0];
+ } else if (parent) { // go right
+ i++;
+ node = parent.children[i];
+ goingUp = false;
+ } else node = null; // nothing found
+ return this;
+ toBBox: function (item) { return item; },
+ compareMinX: compareNodeMinX,
+ compareMinY: compareNodeMinY,
+ toJSON: function () { return this.data; },
+ fromJSON: function (data) {
+ this.data = data;
+ return this;
+ _all: function (node, result) {
+ var nodesToSearch = [];
+ while (node) {
+ if (node.leaf) result.push.apply(result, node.children);
+ else nodesToSearch.push.apply(nodesToSearch, node.children);
+ return result;
+ _build: function (items, left, right, height) {
+ var N = right - left + 1,
+ M = this._maxEntries,
+ node;
+ if (N <= M) {
+ // reached leaf level; return leaf
+ node = createNode(items.slice(left, right + 1));
+ calcBBox(node, this.toBBox);
+ return node;
+ if (!height) {
+ // target height of the bulk-loaded tree
+ height = Math.ceil(Math.log(N) / Math.log(M));
+ // target number of root entries to maximize storage utilization
+ M = Math.ceil(N / Math.pow(M, height - 1));
+ node = createNode([]);
+ node.leaf = false;
+ node.height = height;
+ // split the items into M mostly square tiles
+ var N2 = Math.ceil(N / M),
+ N1 = N2 * Math.ceil(Math.sqrt(M)),
+ i, j, right2, right3;
+ multiSelect(items, left, right, N1, this.compareMinX);
+ for (i = left; i <= right; i += N1) {
+ right2 = Math.min(i + N1 - 1, right);
+ multiSelect(items, i, right2, N2, this.compareMinY);
+ for (j = i; j <= right2; j += N2) {
+ right3 = Math.min(j + N2 - 1, right2);
+ // pack each entry recursively
+ node.children.push(this._build(items, j, right3, height - 1));
+ return node;
+ _chooseSubtree: function (bbox, node, level, path) {
+ var i, len, child, targetNode, area, enlargement, minArea, minEnlargement;
+ while (true) {
+ path.push(node);
+ if (node.leaf || path.length - 1 === level) break;
+ minArea = minEnlargement = Infinity;
+ area = bboxArea(child);
+ enlargement = enlargedArea(bbox, child) - area;
+ // choose entry with the least area enlargement
+ if (enlargement < minEnlargement) {
+ minEnlargement = enlargement;
+ minArea = area < minArea ? area : minArea;
+ targetNode = child;
+ } else if (enlargement === minEnlargement) {
+ // otherwise choose one with the smallest area
+ if (area < minArea) {
+ minArea = area;
+ node = targetNode || node.children[0];
+ return node;
+ _insert: function (item, level, isNode) {
+ var toBBox = this.toBBox,
+ bbox = isNode ? item : toBBox(item),
+ insertPath = [];
+ // find the best node for accommodating the item, saving all nodes along the path too
+ var node = this._chooseSubtree(bbox, this.data, level, insertPath);
+ // put the item into the node
+ node.children.push(item);
+ extend(node, bbox);
+ // split on node overflow; propagate upwards if necessary
+ while (level >= 0) {
+ if (insertPath[level].children.length > this._maxEntries) {
+ this._split(insertPath, level);
+ level--;
+ } else break;
+ // adjust bboxes along the insertion path
+ this._adjustParentBBoxes(bbox, insertPath, level);
+ // split overflowed node into two
+ _split: function (insertPath, level) {
+ var node = insertPath[level],
+ M = node.children.length,
+ m = this._minEntries;
+ this._chooseSplitAxis(node, m, M);
+ var splitIndex = this._chooseSplitIndex(node, m, M);
+ var newNode = createNode(node.children.splice(splitIndex, node.children.length - splitIndex));
+ newNode.height = node.height;
+ newNode.leaf = node.leaf;
+ calcBBox(newNode, this.toBBox);
+ if (level) insertPath[level - 1].children.push(newNode);
+ else this._splitRoot(node, newNode);
+ _splitRoot: function (node, newNode) {
+ // split root node
+ this.data = createNode([node, newNode]);
+ this.data.height = node.height + 1;
+ this.data.leaf = false;
+ calcBBox(this.data, this.toBBox);
+ _chooseSplitIndex: function (node, m, M) {
+ var i, bbox1, bbox2, overlap, area, minOverlap, minArea, index;
+ minOverlap = minArea = Infinity;
+ for (i = m; i <= M - m; i++) {
+ bbox1 = distBBox(node, 0, i, this.toBBox);
+ bbox2 = distBBox(node, i, M, this.toBBox);
+ overlap = intersectionArea(bbox1, bbox2);
+ area = bboxArea(bbox1) + bboxArea(bbox2);
+ // choose distribution with minimum overlap
+ if (overlap < minOverlap) {
+ minOverlap = overlap;
+ index = i;
+ } else if (overlap === minOverlap) {
+ // otherwise choose distribution with minimum area
+ minArea = area;
+ index = i;
+ return index;
+ // sorts node children by the best axis for split
+ _chooseSplitAxis: function (node, m, M) {
+ var compareMinX = node.leaf ? this.compareMinX : compareNodeMinX,
+ compareMinY = node.leaf ? this.compareMinY : compareNodeMinY,
+ xMargin = this._allDistMargin(node, m, M, compareMinX),
+ yMargin = this._allDistMargin(node, m, M, compareMinY);
+ // if total distributions margin value is minimal for x, sort by minX,
+ // otherwise it's already sorted by minY
+ if (xMargin < yMargin) node.children.sort(compareMinX);
+ // total margin of all possible split distributions where each node is at least m full
+ _allDistMargin: function (node, m, M, compare) {
+ node.children.sort(compare);
+ leftBBox = distBBox(node, 0, m, toBBox),
+ rightBBox = distBBox(node, M - m, M, toBBox),
+ margin = bboxMargin(leftBBox) + bboxMargin(rightBBox),
+ i, child;
+ for (i = m; i < M - m; i++) {
+ extend(leftBBox, node.leaf ? toBBox(child) : child);
+ margin += bboxMargin(leftBBox);
+ for (i = M - m - 1; i >= m; i--) {
+ extend(rightBBox, node.leaf ? toBBox(child) : child);
+ margin += bboxMargin(rightBBox);
+ return margin;
+ _adjustParentBBoxes: function (bbox, path, level) {
+ // adjust bboxes along the given tree path
+ for (var i = level; i >= 0; i--) {
+ extend(path[i], bbox);
+ _condense: function (path) {
+ // go through the path, removing empty nodes and updating bboxes
+ for (var i = path.length - 1, siblings; i >= 0; i--) {
+ if (path[i].children.length === 0) {
+ if (i > 0) {
+ siblings = path[i - 1].children;
+ siblings.splice(siblings.indexOf(path[i]), 1);
+ } else this.clear();
+ } else calcBBox(path[i], this.toBBox);
+ _initFormat: function (format) {
+ // data format (minX, minY, maxX, maxY accessors)
+ // uses eval-type function compilation instead of just accepting a toBBox function
+ // because the algorithms are very sensitive to sorting functions performance,
+ // so they should be dead simple and without inner calls
+ var compareArr = ['return a', ' - b', ';'];
+ this.compareMinX = new Function('a', 'b', compareArr.join(format[0]));
+ this.compareMinY = new Function('a', 'b', compareArr.join(format[1]));
+ this.toBBox = new Function('a',
+ 'return {minX: a' + format[0] +
+ ', minY: a' + format[1] +
+ ', maxX: a' + format[2] +
+ ', maxY: a' + format[3] + '};');
+function findItem(item, items, equalsFn) {
+ if (!equalsFn) return items.indexOf(item);
+ for (var i = 0; i < items.length; i++) {
+ if (equalsFn(item, items[i])) return i;
+ return -1;
+// calculate node's bbox from bboxes of its children
+function calcBBox(node, toBBox) {
+ distBBox(node, 0, node.children.length, toBBox, node);
+// min bounding rectangle of node children from k to p-1
+function distBBox(node, k, p, toBBox, destNode) {
+ if (!destNode) destNode = createNode(null);
+ destNode.minX = Infinity;
+ destNode.minY = Infinity;
+ destNode.maxX = -Infinity;
+ destNode.maxY = -Infinity;
+ for (var i = k, child; i < p; i++) {
+ extend(destNode, node.leaf ? toBBox(child) : child);
+ return destNode;
+function extend(a, b) {
+ a.minX = Math.min(a.minX, b.minX);
+ a.minY = Math.min(a.minY, b.minY);
+ a.maxX = Math.max(a.maxX, b.maxX);
+ a.maxY = Math.max(a.maxY, b.maxY);
+ return a;
+function compareNodeMinX(a, b) { return a.minX - b.minX; }
+function compareNodeMinY(a, b) { return a.minY - b.minY; }
+function bboxArea(a) { return (a.maxX - a.minX) * (a.maxY - a.minY); }
+function bboxMargin(a) { return (a.maxX - a.minX) + (a.maxY - a.minY); }
+function enlargedArea(a, b) {
+ return (Math.max(b.maxX, a.maxX) - Math.min(b.minX, a.minX)) *
+ (Math.max(b.maxY, a.maxY) - Math.min(b.minY, a.minY));
+function intersectionArea(a, b) {
+ var minX = Math.max(a.minX, b.minX),
+ minY = Math.max(a.minY, b.minY),
+ maxX = Math.min(a.maxX, b.maxX),
+ maxY = Math.min(a.maxY, b.maxY);
+ return Math.max(0, maxX - minX) *
+ Math.max(0, maxY - minY);
+function contains(a, b) {
+ return a.minX <= b.minX &&
+ a.minY <= b.minY &&
+ b.maxX <= a.maxX &&
+ b.maxY <= a.maxY;
+function intersects(a, b) {
+ return b.minX <= a.maxX &&
+ b.minY <= a.maxY &&
+ b.maxX >= a.minX &&
+ b.maxY >= a.minY;
+function createNode(children) {
+ return {
+ children: children,
+ height: 1,
+ leaf: true,
+ minX: Infinity,
+ minY: Infinity,
+ maxX: -Infinity,
+ maxY: -Infinity
+// sort an array so that items come in groups of n unsorted items, with groups sorted between each other;
+// combines selection algorithm with binary divide & conquer approach
+function multiSelect(arr, left, right, n, compare) {
+ var stack = [left, right],
+ mid;
+ while (stack.length) {
+ right = stack.pop();
+ left = stack.pop();
+ if (right - left <= n) continue;
+ mid = left + Math.ceil((right - left) / n / 2) * n;
+ quickselect(arr, mid, left, right, compare);
+ stack.push(left, mid, mid, right);
+},{"quickselect":1}]},{},[2])(2)
+ol.ext.rbush = module.exports;
+goog.provide('ol.structs.RBush');
+goog.require('ol.ext.rbush');
+goog.require('ol.extent');
+goog.require('ol.obj');
+ * Wrapper around the RBush by Vladimir Agafonkin.
+ * @constructor
+ * @param {number=} opt_maxEntries Max entries.
+ * @see https://github.com/mourner/rbush
+ * @struct
+ * @template T
+ol.structs.RBush = function(opt_maxEntries) {
+ * @private
+ this.rbush_ = ol.ext.rbush(opt_maxEntries);
+ * A mapping between the objects added to this rbush wrapper
+ * and the objects that are actually added to the internal rbush.
+ * @private
+ * @type {Object.<number, ol.RBushEntry>}
+ this.items_ = {};
+ * Insert a value into the RBush.
+ * @param {ol.Extent} extent Extent.
+ * @param {T} value Value.
+ol.structs.RBush.prototype.insert = function(extent, value) {
+ /** @type {ol.RBushEntry} */
+ var item = {
+ minX: extent[0],
+ minY: extent[1],
+ maxX: extent[2],
+ maxY: extent[3],
+ value: value
+ this.rbush_.insert(item);
+ this.items_[ol.getUid(value)] = item;
+ * Bulk-insert values into the RBush.
+ * @param {Array.<ol.Extent>} extents Extents.
+ * @param {Array.<T>} values Values.
+ol.structs.RBush.prototype.load = function(extents, values) {
+ var items = new Array(values.length);
+ for (var i = 0, l = values.length; i < l; i++) {
+ var extent = extents[i];
+ var value = values[i];
+ var item = {
+ minX: extent[0],
+ minY: extent[1],
+ maxX: extent[2],
+ maxY: extent[3],
+ value: value
+ items[i] = item;
+ this.rbush_.load(items);
+ * Remove a value from the RBush.
+ * @return {boolean} Removed.
+ol.structs.RBush.prototype.remove = function(value) {
+ var uid = ol.getUid(value);
+ // get the object in which the value was wrapped when adding to the
+ // internal rbush. then use that object to do the removal.
+ var item = this.items_[uid];
+ delete this.items_[uid];
+ return this.rbush_.remove(item) !== null;
+ * Update the extent of a value in the RBush.
+ol.structs.RBush.prototype.update = function(extent, value) {
+ var item = this.items_[ol.getUid(value)];
+ var bbox = [item.minX, item.minY, item.maxX, item.maxY];
+ if (!ol.extent.equals(bbox, extent)) {
+ this.remove(value);
+ this.insert(extent, value);
+ * Return all values in the RBush.
+ * @return {Array.<T>} All.
+ol.structs.RBush.prototype.getAll = function() {
+ var items = this.rbush_.all();
+ return items.map(function(item) {
+ return item.value;
+ * Return all values in the given extent.
+ * @return {Array.<T>} All in extent.
+ol.structs.RBush.prototype.getInExtent = function(extent) {
+ var bbox = {
+ minX: extent[0],
+ minY: extent[1],
+ maxX: extent[2],
+ maxY: extent[3]
+ var items = this.rbush_.search(bbox);
+ * Calls a callback function with each value in the tree.
+ * If the callback returns a truthy value, this value is returned without
+ * checking the rest of the tree.
+ * @param {function(this: S, T): *} callback Callback.
+ * @param {S=} opt_this The object to use as `this` in `callback`.
+ * @return {*} Callback return value.
+ * @template S
+ol.structs.RBush.prototype.forEach = function(callback, opt_this) {
+ return this.forEach_(this.getAll(), callback, opt_this);
+ * Calls a callback function with each value in the provided extent.
+ * @template S
+ol.structs.RBush.prototype.forEachInExtent = function(extent, callback, opt_this) {
+ return this.forEach_(this.getInExtent(extent), callback, opt_this);
+ * @private
+ * @template S
+ol.structs.RBush.prototype.forEach_ = function(values, callback, opt_this) {
+ var result;
+ result = callback.call(opt_this, values[i]);
+ if (result) {
+ return result;
+ return result;
+ * @return {boolean} Is empty.
+ol.structs.RBush.prototype.isEmpty = function() {
+ return ol.obj.isEmpty(this.items_);
+ * Remove all values from the RBush.
+ol.structs.RBush.prototype.clear = function() {
+ this.rbush_.clear();
+ this.items_ = {};
+ * @param {ol.Extent=} opt_extent Extent.
+ * @return {!ol.Extent} Extent.
+ol.structs.RBush.prototype.getExtent = function(opt_extent) {
+ // FIXME add getExtent() to rbush
+ var data = this.rbush_.data;
+ return ol.extent.createOrUpdate(data.minX, data.minY, data.maxX, data.maxY, opt_extent);
+goog.provide('ol.render.webgl.PolygonReplay');
+goog.require('ol.array');
+goog.require('ol.color');
+goog.require('ol.geom.flat.contains');
+goog.require('ol.render.webgl.polygonreplay.defaultshader');
+goog.require('ol.render.webgl.LineStringReplay');
+goog.require('ol.render.webgl.Replay');
+goog.require('ol.render.webgl');
+goog.require('ol.style.Stroke');
+goog.require('ol.structs.LinkedList');
+goog.require('ol.structs.RBush');
+goog.require('ol.webgl.Buffer');
+ * @constructor
+ * @extends {ol.render.webgl.Replay}
+ * @param {number} tolerance Tolerance.
+ * @param {ol.Extent} maxExtent Max extent.
+ * @struct
+ ol.render.webgl.PolygonReplay = function(tolerance, maxExtent) {
+ ol.render.webgl.Replay.call(this, tolerance, maxExtent);
+ this.lineStringReplay = new ol.render.webgl.LineStringReplay(
+ tolerance, maxExtent);
+ * @private
+ * @type {ol.render.webgl.polygonreplay.defaultshader.Locations}
+ this.defaultLocations_ = null;
+ * @private
+ * @type {Array.<Array.<number>>}
+ this.styles_ = [];
+ * @private
+ * @type {Array.<number>}
+ this.styleIndices_ = [];
+ * @private
+ * @type {{fillColor: (Array.<number>|null),
+ * changed: boolean}|null}
+ this.state_ = {
+ fillColor: null,
+ changed: false
+ ol.inherits(ol.render.webgl.PolygonReplay, ol.render.webgl.Replay);
+ * Draw one polygon.
+ * @param {Array.<number>} flatCoordinates Flat coordinates.
+ * @param {number} stride Stride.
+ * @private
+ ol.render.webgl.PolygonReplay.prototype.drawCoordinates_ = function(
+ // Triangulate the polygon
+ var outerRing = new ol.structs.LinkedList();
+ var rtree = new ol.structs.RBush();
+ // Initialize the outer ring
+ var maxX = this.processFlatCoordinates_(flatCoordinates, stride, outerRing, rtree, true);
+ // Eliminate holes, if there are any
+ var i, ii;
+ var holeLists = [];
+ var holeList = {
+ list: new ol.structs.LinkedList(),
+ maxX: undefined
+ holeLists.push(holeList);
+ holeList.maxX = this.processFlatCoordinates_(holeFlatCoordinates[i],
+ stride, holeList.list, rtree, false);
+ holeLists.sort(function(a, b) {
+ return b.maxX - a.maxX;
+ for (i = 0; i < holeLists.length; ++i) {
+ this.bridgeHole_(holeLists[i].list, holeLists[i].maxX, outerRing, maxX, rtree);
+ this.classifyPoints_(outerRing, rtree, false);
+ this.triangulate_(outerRing, rtree);
+ * Inserts flat coordinates in a linked list and adds them to the vertex buffer.
+ * @private
+ * @param {ol.structs.LinkedList} list Linked list.
+ * @param {ol.structs.RBush} rtree R-Tree of the polygon.
+ * @param {boolean} clockwise Coordinate order should be clockwise.
+ * @return {number} Maximum X value.
+ ol.render.webgl.PolygonReplay.prototype.processFlatCoordinates_ = function(
+ flatCoordinates, stride, list, rtree, clockwise) {
+ var isClockwise = ol.geom.flat.orient.linearRingIsClockwise(flatCoordinates,
+ 0, flatCoordinates.length, stride);
+ var i, ii, maxX;
+ var n = this.vertices.length / 2;
+ /** @type {ol.WebglPolygonVertex} */
+ var start;
+ var p0;
+ var p1;
+ var extents = [];
+ var segments = [];
+ if (clockwise === isClockwise) {
+ start = this.createPoint_(flatCoordinates[0], flatCoordinates[1], n++);
+ p0 = start;
+ maxX = flatCoordinates[0];
+ for (i = stride, ii = flatCoordinates.length; i < ii; i += stride) {
+ p1 = this.createPoint_(flatCoordinates[i], flatCoordinates[i + 1], n++);
+ segments.push(this.insertItem_(p0, p1, list));
+ extents.push([Math.min(p0.x, p1.x), Math.min(p0.y, p1.y), Math.max(p0.x, p1.x),
+ Math.max(p0.y, p1.y)]);
+ maxX = flatCoordinates[i] > maxX ? flatCoordinates[i] : maxX;
+ p0 = p1;
+ segments.push(this.insertItem_(p1, start, list));
+ } else {
+ var end = flatCoordinates.length - stride;
+ start = this.createPoint_(flatCoordinates[end], flatCoordinates[end + 1], n++);
+ p0 = start;
+ maxX = flatCoordinates[end];
+ for (i = end - stride, ii = 0; i >= ii; i -= stride) {
+ p0 = p1;
+ rtree.load(extents, segments);
+ return maxX;
+ * Classifies the points of a polygon list as convex, reflex. Removes collinear vertices.
+ * @private
+ * @param {ol.structs.LinkedList} list Polygon ring.
+ * @param {boolean} ccw The orientation of the polygon is counter-clockwise.
+ * @return {boolean} There were reclassified points.
+ ol.render.webgl.PolygonReplay.prototype.classifyPoints_ = function(list, rtree, ccw) {
+ var start = list.firstItem();
+ var s0 = start;
+ var s1 = list.nextItem();
+ var pointsReclassified = false;
+ do {
+ var reflex = ccw ? ol.render.webgl.triangleIsCounterClockwise(s1.p1.x,
+ s1.p1.y, s0.p1.x, s0.p1.y, s0.p0.x, s0.p0.y) :
+ ol.render.webgl.triangleIsCounterClockwise(s0.p0.x, s0.p0.y, s0.p1.x,
+ s0.p1.y, s1.p1.x, s1.p1.y);
+ if (reflex === undefined) {
+ this.removeItem_(s0, s1, list, rtree);
+ pointsReclassified = true;
+ if (s1 === start) {
+ start = list.getNextItem();
+ s1 = s0;
+ list.prevItem();
+ } else if (s0.p1.reflex !== reflex) {
+ s0.p1.reflex = reflex;
+ s0 = s1;
+ s1 = list.nextItem();
+ } while (s0 !== start);
+ return pointsReclassified;
+ * @private
+ * @param {ol.structs.LinkedList} hole Linked list of the hole.
+ * @param {number} holeMaxX Maximum X value of the hole.
+ * @param {ol.structs.LinkedList} list Linked list of the polygon.
+ * @param {number} listMaxX Maximum X value of the polygon.
+ ol.render.webgl.PolygonReplay.prototype.bridgeHole_ = function(hole, holeMaxX,
+ list, listMaxX, rtree) {
+ this.classifyPoints_(hole, rtree, true);
+ var seg = hole.firstItem();
+ while (seg.p1.x !== holeMaxX) {
+ seg = hole.nextItem();
+ var p1 = seg.p1;
+ var p2 = {x: listMaxX, y: p1.y, i: -1};
+ var minDist = Infinity;
+ var i, ii, bestPoint;
+ var p5;
+ var intersectingSegments = this.getIntersections_({p0: p1, p1: p2}, rtree, true);
+ for (i = 0, ii = intersectingSegments.length; i < ii; ++i) {
+ var currSeg = intersectingSegments[i];
+ if (currSeg.p0.reflex === undefined) {
+ var intersection = this.calculateIntersection_(p1, p2, currSeg.p0,
+ currSeg.p1, true);
+ var dist = Math.abs(p1.x - intersection[0]);
+ if (dist < minDist) {
+ minDist = dist;
+ p5 = {x: intersection[0], y: intersection[1], i: -1};
+ seg = currSeg;
+ if (minDist === Infinity) {
+ return;
+ bestPoint = seg.p1;
+ if (minDist > 0) {
+ var pointsInTriangle = this.getPointsInTriangle_(p1, p5, seg.p1, rtree);
+ if (pointsInTriangle.length) {
+ var theta = Infinity;
+ for (i = 0, ii = pointsInTriangle.length; i < ii; ++i) {
+ var currPoint = pointsInTriangle[i];
+ var currTheta = Math.atan2(p1.y - currPoint.y, p2.x - currPoint.x);
+ if (currTheta < theta || (currTheta === theta && currPoint.x < bestPoint.x)) {
+ theta = currTheta;
+ bestPoint = currPoint;
+ seg = list.firstItem();
+ while (seg.p1 !== bestPoint) {
+ seg = list.nextItem();
+ //We clone the bridge points as they can have different convexity.
+ var p0Bridge = {x: p1.x, y: p1.y, i: p1.i, reflex: undefined};
+ var p1Bridge = {x: seg.p1.x, y: seg.p1.y, i: seg.p1.i, reflex: undefined};
+ hole.getNextItem().p0 = p0Bridge;
+ this.insertItem_(p1, seg.p1, hole, rtree);
+ this.insertItem_(p1Bridge, p0Bridge, hole, rtree);
+ seg.p1 = p1Bridge;
+ hole.setFirstItem();
+ list.concat(hole);
+ * @private
+ ol.render.webgl.PolygonReplay.prototype.triangulate_ = function(list, rtree) {
+ var ccw = false;
+ var simple = this.isSimple_(list, rtree);
+ // Start clipping ears
+ while (list.getLength() > 3) {
+ if (simple) {
+ if (!this.clipEars_(list, rtree, simple, ccw)) {
+ if (!this.classifyPoints_(list, rtree, ccw)) {
+ // Due to the behavior of OL's PIP algorithm, the ear clipping cannot
+ // introduce touching segments. However, the original data may have some.
+ if (!this.resolveLocalSelfIntersections_(list, rtree, true)) {
+ break;
+ } else {
+ // We ran out of ears, try to reclassify.
+ // We have a bad polygon, try to resolve local self-intersections.
+ if (!this.resolveLocalSelfIntersections_(list, rtree)) {
+ simple = this.isSimple_(list, rtree);
+ if (!simple) {
+ // We have a really bad polygon, try more time consuming methods.
+ this.splitPolygon_(list, rtree);
+ break;
+ } else {
+ ccw = !this.isClockwise_(list);
+ this.classifyPoints_(list, rtree, ccw);
+ if (list.getLength() === 3) {
+ var numIndices = this.indices.length;
+ this.indices[numIndices++] = list.getPrevItem().p0.i;
+ this.indices[numIndices++] = list.getCurrItem().p0.i;
+ this.indices[numIndices++] = list.getNextItem().p0.i;
+ * @private
+ * @param {boolean} simple The polygon is simple.
+ * @param {boolean} ccw Orientation of the polygon is counter-clockwise.
+ * @return {boolean} There were processed ears.
+ ol.render.webgl.PolygonReplay.prototype.clipEars_ = function(list, rtree, simple, ccw) {
+ var s0 = list.getPrevItem();
+ var s1 = start;
+ var s2 = list.nextItem();
+ var s3 = list.getNextItem();
+ var p0, p1, p2;
+ var processedEars = false;
+ do {
+ p0 = s1.p0;
+ p1 = s1.p1;
+ p2 = s2.p1;
+ if (p1.reflex === false) {
+ // We might have a valid ear
+ var diagonalIsInside = ccw ? this.diagonalIsInside_(s3.p1, p2, p1, p0,
+ s0.p0) : this.diagonalIsInside_(s0.p0, p0, p1, p2, s3.p1);
+ if ((simple || this.getIntersections_({p0: p0, p1: p2}, rtree).length === 0) &&
+ diagonalIsInside && this.getPointsInTriangle_(p0, p1, p2, rtree, true).length === 0) {
+ //The diagonal is completely inside the polygon
+ if (simple || p0.reflex === false || p2.reflex === false ||
+ ol.geom.flat.orient.linearRingIsClockwise([s0.p0.x, s0.p0.y, p0.x,
+ p0.y, p1.x, p1.y, p2.x, p2.y, s3.p1.x, s3.p1.y], 0, 10, 2) === !ccw) {
+ //The diagonal is persumably valid, we have an ear
+ this.indices[numIndices++] = p0.i;
+ this.indices[numIndices++] = p1.i;
+ this.indices[numIndices++] = p2.i;
+ this.removeItem_(s1, s2, list, rtree);
+ if (s2 === start) {
+ start = s3;
+ processedEars = true;
+ // Else we have a reflex point.
+ s0 = list.getPrevItem();
+ s1 = list.getCurrItem();
+ s2 = list.nextItem();
+ s3 = list.getNextItem();
+ } while (s1 !== start && list.getLength() > 3);
+ return processedEars;
+ * @private
+ * @param {boolean=} opt_touch Resolve touching segments.
+ * @return {boolean} There were resolved intersections.
+ ol.render.webgl.PolygonReplay.prototype.resolveLocalSelfIntersections_ = function(
+ list, rtree, opt_touch) {
+ list.nextItem();
+ var s0 = start;
+ var resolvedIntersections = false;
+ do {
+ var intersection = this.calculateIntersection_(s0.p0, s0.p1, s1.p0, s1.p1,
+ opt_touch);
+ if (intersection) {
+ var breakCond = false;
+ var numVertices = this.vertices.length;
+ var n = numVertices / 2;
+ var seg = list.prevItem();
+ list.removeItem();
+ rtree.remove(seg);
+ breakCond = (seg === start);
+ var p;
+ if (opt_touch) {
+ if (intersection[0] === s0.p0.x && intersection[1] === s0.p0.y) {
+ list.prevItem();
+ p = s0.p0;
+ s1.p0 = p;
+ rtree.remove(s0);
+ breakCond = breakCond || (s0 === start);
+ } else {
+ p = s1.p1;
+ s0.p1 = p;
+ rtree.remove(s1);
+ breakCond = breakCond || (s1 === start);
+ } else {
+ p = this.createPoint_(intersection[0], intersection[1], n);
+ s0.p1 = p;
+ s1.p0 = p;
+ rtree.update([Math.min(s0.p0.x, s0.p1.x), Math.min(s0.p0.y, s0.p1.y),
+ Math.max(s0.p0.x, s0.p1.x), Math.max(s0.p0.y, s0.p1.y)], s0);
+ rtree.update([Math.min(s1.p0.x, s1.p1.x), Math.min(s1.p0.y, s1.p1.y),
+ Math.max(s1.p0.x, s1.p1.x), Math.max(s1.p0.y, s1.p1.y)], s1);
+ this.indices[numIndices++] = seg.p0.i;
+ this.indices[numIndices++] = seg.p1.i;
+ this.indices[numIndices++] = p.i;
+ resolvedIntersections = true;
+ if (breakCond) {
+ break;
+ return resolvedIntersections;
+ * @private
+ * @return {boolean} The polygon is simple.
+ ol.render.webgl.PolygonReplay.prototype.isSimple_ = function(list, rtree) {
+ var seg = start;
+ do {
+ if (this.getIntersections_(seg, rtree).length) {
+ return false;
+ } while (seg !== start);
+ return true;
+ * @private
+ * @return {boolean} Orientation is clockwise.
+ ol.render.webgl.PolygonReplay.prototype.isClockwise_ = function(list) {
+ var length = list.getLength() * 2;
+ var flatCoordinates = new Array(length);
+ var seg = start;
+ var i = 0;
+ do {
+ flatCoordinates[i++] = seg.p0.x;
+ flatCoordinates[i++] = seg.p0.y;
+ return ol.geom.flat.orient.linearRingIsClockwise(flatCoordinates, 0, length, 2);
+ * @private
+ ol.render.webgl.PolygonReplay.prototype.splitPolygon_ = function(list, rtree) {
+ var s0 = start;
+ do {
+ var intersections = this.getIntersections_(s0, rtree);
+ if (intersections.length) {
+ var s1 = intersections[0];
+ s0.p1, s1.p0, s1.p1);
+ var p = this.createPoint_(intersection[0], intersection[1], n);
+ var newPolygon = new ol.structs.LinkedList();
+ var newRtree = new ol.structs.RBush();
+ this.insertItem_(p, s0.p1, newPolygon, newRtree);
+ s0.p1 = p;
+ rtree.update([Math.min(s0.p0.x, p.x), Math.min(s0.p0.y, p.y),
+ Math.max(s0.p0.x, p.x), Math.max(s0.p0.y, p.y)], s0);
+ var currItem = list.nextItem();
+ while (currItem !== s1) {
+ this.insertItem_(currItem.p0, currItem.p1, newPolygon, newRtree);
+ rtree.remove(currItem);
+ currItem = list.getCurrItem();
+ this.insertItem_(s1.p0, p, newPolygon, newRtree);
+ s1.p0 = p;
+ rtree.update([Math.min(s1.p1.x, p.x), Math.min(s1.p1.y, p.y),
+ Math.max(s1.p1.x, p.x), Math.max(s1.p1.y, p.y)], s1);
+ this.classifyPoints_(list, rtree, false);
+ this.triangulate_(list, rtree);
+ this.classifyPoints_(newPolygon, newRtree, false);
+ this.triangulate_(newPolygon, newRtree);
+ break;
+ s0 = list.nextItem();
+ * @private
+ * @param {number} x X coordinate.
+ * @param {number} y Y coordinate.
+ * @param {number} i Index.
+ * @return {ol.WebglPolygonVertex} List item.
+ ol.render.webgl.PolygonReplay.prototype.createPoint_ = function(x, y, i) {
+ this.vertices[numVertices++] = x;
+ this.vertices[numVertices++] = y;
+ var p = {
+ x: x,
+ y: y,
+ i: i,
+ reflex: undefined
+ return p;
+ * @private
+ * @param {ol.WebglPolygonVertex} p0 First point of segment.
+ * @param {ol.WebglPolygonVertex} p1 Second point of segment.
+ * @param {ol.structs.RBush=} opt_rtree Insert the segment into the R-Tree.
+ * @return {ol.WebglPolygonSegment} segment.
+ ol.render.webgl.PolygonReplay.prototype.insertItem_ = function(p0, p1, list, opt_rtree) {
+ var seg = {
+ p0: p0,
+ p1: p1
+ list.insertItem(seg);
+ if (opt_rtree) {
+ opt_rtree.insert([Math.min(p0.x, p1.x), Math.min(p0.y, p1.y),
+ Math.max(p0.x, p1.x), Math.max(p0.y, p1.y)], seg);
+ return seg;
+ * @private
+ * @param {ol.WebglPolygonSegment} s0 Segment before the remove candidate.
+ * @param {ol.WebglPolygonSegment} s1 Remove candidate segment.
+ ol.render.webgl.PolygonReplay.prototype.removeItem_ = function(s0, s1, list, rtree) {
+ if (list.getCurrItem() === s1) {
+ s0.p1 = s1.p1;
+ rtree.remove(s1);
+ * @private
+ * @param {ol.WebglPolygonVertex} p0 First point.
+ * @param {ol.WebglPolygonVertex} p1 Second point.
+ * @param {ol.WebglPolygonVertex} p2 Third point.
+ * @param {boolean=} opt_reflex Only include reflex points.
+ * @return {Array.<ol.WebglPolygonVertex>} Points in the triangle.
+ ol.render.webgl.PolygonReplay.prototype.getPointsInTriangle_ = function(p0, p1,
+ p2, rtree, opt_reflex) {
+ var i, ii, j, p;
+ var result = [];
+ var segmentsInExtent = rtree.getInExtent([Math.min(p0.x, p1.x, p2.x),
+ Math.min(p0.y, p1.y, p2.y), Math.max(p0.x, p1.x, p2.x), Math.max(p0.y,
+ p1.y, p2.y)]);
+ for (i = 0, ii = segmentsInExtent.length; i < ii; ++i) {
+ for (j in segmentsInExtent[i]) {
+ p = segmentsInExtent[i][j];
+ if (typeof p === 'object' && (!opt_reflex || p.reflex)) {
+ if ((p.x !== p0.x || p.y !== p0.y) && (p.x !== p1.x || p.y !== p1.y) &&
+ (p.x !== p2.x || p.y !== p2.y) && result.indexOf(p) === -1 &&
+ ol.geom.flat.contains.linearRingContainsXY([p0.x, p0.y, p1.x, p1.y,
+ p2.x, p2.y], 0, 6, 2, p.x, p.y)) {
+ result.push(p);
+ return result;
+ * @private
+ * @param {ol.WebglPolygonSegment} segment Segment.
+ * @param {boolean=} opt_touch Touching segments should be considered an intersection.
+ * @return {Array.<ol.WebglPolygonSegment>} Intersecting segments.
+ ol.render.webgl.PolygonReplay.prototype.getIntersections_ = function(segment, rtree, opt_touch) {
+ var p0 = segment.p0;
+ var p1 = segment.p1;
+ var segmentsInExtent = rtree.getInExtent([Math.min(p0.x, p1.x),
+ Math.min(p0.y, p1.y), Math.max(p0.x, p1.x), Math.max(p0.y, p1.y)]);
+ var result = [];
+ var i, ii;
+ var currSeg = segmentsInExtent[i];
+ if (segment !== currSeg && (opt_touch || currSeg.p0 !== p1 || currSeg.p1 !== p0) &&
+ this.calculateIntersection_(p0, p1, currSeg.p0, currSeg.p1, opt_touch)) {
+ result.push(currSeg);
+ return result;
+ * Line intersection algorithm by Paul Bourke.
+ * @see http://paulbourke.net/geometry/pointlineplane/
+ * @private
+ * @param {ol.WebglPolygonVertex} p3 Fourth point.
+ * @return {Array.<number>|undefined} Intersection coordinates.
+ ol.render.webgl.PolygonReplay.prototype.calculateIntersection_ = function(p0,
+ p1, p2, p3, opt_touch) {
+ var denom = (p3.y - p2.y) * (p1.x - p0.x) - (p3.x - p2.x) * (p1.y - p0.y);
+ if (denom !== 0) {
+ var ua = ((p3.x - p2.x) * (p0.y - p2.y) - (p3.y - p2.y) * (p0.x - p2.x)) / denom;
+ var ub = ((p1.x - p0.x) * (p0.y - p2.y) - (p1.y - p0.y) * (p0.x - p2.x)) / denom;
+ if ((!opt_touch && ua > ol.render.webgl.EPSILON && ua < 1 - ol.render.webgl.EPSILON &&
+ ub > ol.render.webgl.EPSILON && ub < 1 - ol.render.webgl.EPSILON) || (opt_touch &&
+ ua >= 0 && ua <= 1 && ub >= 0 && ub <= 1)) {
+ return [p0.x + ua * (p1.x - p0.x), p0.y + ua * (p1.y - p0.y)];
+ return undefined;
+ * @private
+ * @param {ol.WebglPolygonVertex} p0 Point before the start of the diagonal.
+ * @param {ol.WebglPolygonVertex} p1 Start point of the diagonal.
+ * @param {ol.WebglPolygonVertex} p2 Ear candidate.
+ * @param {ol.WebglPolygonVertex} p3 End point of the diagonal.
+ * @param {ol.WebglPolygonVertex} p4 Point after the end of the diagonal.
+ * @return {boolean} Diagonal is inside the polygon.
+ ol.render.webgl.PolygonReplay.prototype.diagonalIsInside_ = function(p0, p1, p2, p3, p4) {
+ if (p1.reflex === undefined || p3.reflex === undefined) {
+ return false;
+ var p1IsLeftOf = (p2.x - p3.x) * (p1.y - p3.y) > (p2.y - p3.y) * (p1.x - p3.x);
+ var p1IsRightOf = (p4.x - p3.x) * (p1.y - p3.y) < (p4.y - p3.y) * (p1.x - p3.x);
+ var p3IsLeftOf = (p0.x - p1.x) * (p3.y - p1.y) > (p0.y - p1.y) * (p3.x - p1.x);
+ var p3IsRightOf = (p2.x - p1.x) * (p3.y - p1.y) < (p2.y - p1.y) * (p3.x - p1.x);
+ var p1InCone = p3.reflex ? p1IsRightOf || p1IsLeftOf : p1IsRightOf && p1IsLeftOf;
+ var p3InCone = p1.reflex ? p3IsRightOf || p3IsLeftOf : p3IsRightOf && p3IsLeftOf;
+ return p1InCone && p3InCone;
+ * @inheritDoc
+ ol.render.webgl.PolygonReplay.prototype.drawMultiPolygon = function(multiPolygonGeometry, feature) {
+ var polygons = multiPolygonGeometry.getPolygons();
+ var stride = multiPolygonGeometry.getStride();
+ var currIndex = this.indices.length;
+ var currLineIndex = this.lineStringReplay.getCurrentIndex();
+ var i, ii, j, jj;
+ for (i = 0, ii = polygons.length; i < ii; ++i) {
+ var linearRings = polygons[i].getLinearRings();
+ if (linearRings.length > 0) {
+ var flatCoordinates = linearRings[0].getFlatCoordinates();
+ stride, -this.origin[0], -this.origin[1]);
+ var holes = [];
+ var holeFlatCoords;
+ for (j = 1, jj = linearRings.length; j < jj; ++j) {
+ holeFlatCoords = linearRings[j].getFlatCoordinates();
+ holeFlatCoords = ol.geom.flat.transform.translate(holeFlatCoords, 0, holeFlatCoords.length,
+ holes.push(holeFlatCoords);
+ this.lineStringReplay.drawPolygonCoordinates(flatCoordinates, holes, stride);
+ this.drawCoordinates_(flatCoordinates, holes, stride);
+ if (this.indices.length > currIndex) {
+ this.startIndices.push(currIndex);
+ this.startIndicesFeature.push(feature);
+ if (this.state_.changed) {
+ this.styleIndices_.push(currIndex);
+ this.state_.changed = false;
+ if (this.lineStringReplay.getCurrentIndex() > currLineIndex) {
+ this.lineStringReplay.setPolygonStyle(feature, currLineIndex);
+ * @inheritDoc
+ ol.render.webgl.PolygonReplay.prototype.drawPolygon = function(polygonGeometry, feature) {
+ var linearRings = polygonGeometry.getLinearRings();
+ var stride = polygonGeometry.getStride();
+ this.startIndices.push(this.indices.length);
+ this.styleIndices_.push(this.indices.length);
+ this.lineStringReplay.setPolygonStyle(feature);
+ var holes = [];
+ var i, ii, holeFlatCoords;
+ for (i = 1, ii = linearRings.length; i < ii; ++i) {
+ holeFlatCoords = linearRings[i].getFlatCoordinates();
+ * @inheritDoc
+ ol.render.webgl.PolygonReplay.prototype.finish = function(context) {
+ // create, bind, and populate the vertices buffer
+ this.verticesBuffer = new ol.webgl.Buffer(this.vertices);
+ // create, bind, and populate the indices buffer
+ this.indicesBuffer = new ol.webgl.Buffer(this.indices);
+ this.lineStringReplay.finish(context);
+ //Clean up, if there is nothing to draw
+ if (this.styleIndices_.length === 0 && this.styles_.length > 0) {
+ this.vertices = null;
+ this.indices = null;
+ * @inheritDoc
+ ol.render.webgl.PolygonReplay.prototype.getDeleteResourcesFunction = function(context) {
+ var verticesBuffer = this.verticesBuffer;
+ var indicesBuffer = this.indicesBuffer;
+ var lineDeleter = this.lineStringReplay.getDeleteResourcesFunction(context);
+ return function() {
+ context.deleteBuffer(verticesBuffer);
+ context.deleteBuffer(indicesBuffer);
+ lineDeleter();
+ * @inheritDoc
+ ol.render.webgl.PolygonReplay.prototype.setUpProgram = function(gl, context, size, pixelRatio) {
+ // get the program
+ var fragmentShader, vertexShader;
+ fragmentShader = ol.render.webgl.polygonreplay.defaultshader.fragment;
+ vertexShader = ol.render.webgl.polygonreplay.defaultshader.vertex;
+ var program = context.getProgram(fragmentShader, vertexShader);
+ // get the locations
+ var locations;
+ if (!this.defaultLocations_) {
+ locations =
+ new ol.render.webgl.polygonreplay.defaultshader.Locations(gl, program);
+ this.defaultLocations_ = locations;
+ } else {
+ locations = this.defaultLocations_;
+ context.useProgram(program);
+ // enable the vertex attrib arrays
+ gl.enableVertexAttribArray(locations.a_position);
+ gl.vertexAttribPointer(locations.a_position, 2, ol.webgl.FLOAT,
+ false, 8, 0);
+ return locations;
+ * @inheritDoc
+ ol.render.webgl.PolygonReplay.prototype.shutDownProgram = function(gl, locations) {
+ gl.disableVertexAttribArray(locations.a_position);
+ * @inheritDoc
+ ol.render.webgl.PolygonReplay.prototype.drawReplay = function(gl, context, skippedFeaturesHash, hitDetection) {
+ if (!ol.obj.isEmpty(skippedFeaturesHash)) {
+ this.drawReplaySkipping_(gl, context, skippedFeaturesHash);
+ } else {
+ //Draw by style groups to minimize drawElements() calls.
+ var i, start, end, nextStyle;
+ end = this.startIndices[this.startIndices.length - 1];
+ for (i = this.styleIndices_.length - 1; i >= 0; --i) {
+ start = this.styleIndices_[i];
+ nextStyle = this.styles_[i];
+ this.setFillStyle_(gl, nextStyle);
+ this.drawElements(gl, context, start, end);
+ end = start;
+ * @inheritDoc
+ ol.render.webgl.PolygonReplay.prototype.drawHitDetectionReplayOneByOne = function(gl, context, skippedFeaturesHash,
+ featureCallback, opt_hitExtent) {
+ var i, start, end, nextStyle, groupStart, feature, featureUid, featureIndex;
+ featureIndex = this.startIndices.length - 2;
+ end = this.startIndices[featureIndex + 1];
+ groupStart = this.styleIndices_[i];
+ while (featureIndex >= 0 &&
+ this.startIndices[featureIndex] >= groupStart) {
+ start = this.startIndices[featureIndex];
+ feature = this.startIndicesFeature[featureIndex];
+ featureUid = ol.getUid(feature).toString();
+ if (skippedFeaturesHash[featureUid] === undefined &&
+ feature.getGeometry() &&
+ (opt_hitExtent === undefined || ol.extent.intersects(
+ /** @type {Array<number>} */ (opt_hitExtent),
+ feature.getGeometry().getExtent()))) {
+ var result = featureCallback(feature);
+ if (result) {
+ return result;
+ featureIndex--;
+ end = start;
+ return undefined;
+ * @private
+ * @param {Object} skippedFeaturesHash Ids of features to skip.
+ ol.render.webgl.PolygonReplay.prototype.drawReplaySkipping_ = function(gl, context, skippedFeaturesHash) {
+ var i, start, end, nextStyle, groupStart, feature, featureUid, featureIndex, featureStart;
+ end = start = this.startIndices[featureIndex + 1];
+ featureStart = this.startIndices[featureIndex];
+ if (skippedFeaturesHash[featureUid]) {
+ if (start !== end) {
+ end = featureStart;
+ featureIndex--;
+ start = featureStart;
+ start = end = groupStart;
+ * @private
+ * @param {Array.<number>} color Color.
+ ol.render.webgl.PolygonReplay.prototype.setFillStyle_ = function(gl, color) {
+ * @inheritDoc
+ ol.render.webgl.PolygonReplay.prototype.setFillStrokeStyle = function(fillStyle, strokeStyle) {
+ var fillStyleColor = fillStyle ? fillStyle.getColor() : [0, 0, 0, 0];
+ if (!(fillStyleColor instanceof CanvasGradient) &&
+ !(fillStyleColor instanceof CanvasPattern)) {
+ fillStyleColor = ol.color.asArray(fillStyleColor).map(function(c, i) {
+ return i != 3 ? c / 255 : c;
+ }) || ol.render.webgl.defaultFillStyle;
+ } else {
+ fillStyleColor = ol.render.webgl.defaultFillStyle;
+ if (!this.state_.fillColor || !ol.array.equals(fillStyleColor, this.state_.fillColor)) {
+ this.state_.fillColor = fillStyleColor;
+ this.state_.changed = true;
+ this.styles_.push(fillStyleColor);
+ //Provide a null stroke style, if no strokeStyle is provided. Required for the draw interaction to work.
+ if (strokeStyle) {
+ this.lineStringReplay.setFillStrokeStyle(null, strokeStyle);
+ } else {
+ var nullStrokeStyle = new ol.style.Stroke({
+ color: [0, 0, 0, 0],
+ lineWidth: 0
+ this.lineStringReplay.setFillStrokeStyle(null, nullStrokeStyle);
+goog.provide('ol.render.webgl.TextReplay');
+if (ol.ENABLE_WEBGL) {
+ * @constructor
+ * @abstract
+ * @struct
+ ol.render.webgl.TextReplay = function(tolerance, maxExtent) {};
+ * @param {ol.style.Text} textStyle Text style.
+ ol.render.webgl.TextReplay.prototype.setTextStyle = function(textStyle) {};
+ * @param {ol.Coordinate} center Center.
+ * @param {number} resolution Resolution.
+ * @param {number} rotation Rotation.
+ * @param {ol.Size} size Size.
+ * @param {number} pixelRatio Pixel ratio.
+ * @param {number} opacity Global opacity.
+ * @param {Object.<string, boolean>} skippedFeaturesHash Ids of features
+ * to skip.
+ * @param {function((ol.Feature|ol.render.Feature)): T|undefined} featureCallback Feature callback.
+ * @param {boolean} oneByOne Draw features one-by-one for the hit-detecion.
+ * @param {ol.Extent=} opt_hitExtent Hit extent: Only features intersecting
+ * this extent are checked.
+ * @return {T|undefined} Callback result.
+ * @template T
+ ol.render.webgl.TextReplay.prototype.replay = function(context,
+ center, resolution, rotation, size, pixelRatio,
+ opacity, skippedFeaturesHash,
+ featureCallback, oneByOne, opt_hitExtent) {
+ return undefined;
+ * @param {number} offset Offset.
+ * @param {number} end End.
+ * @param {ol.geom.Geometry|ol.render.Feature} geometry Geometry.
+ * @param {ol.Feature|ol.render.Feature} feature Feature.
+ ol.render.webgl.TextReplay.prototype.drawText = function(flatCoordinates, offset,
+ end, stride, geometry, feature) {};
+ * @abstract
+ * @param {ol.webgl.Context} context Context.
+ ol.render.webgl.TextReplay.prototype.finish = function(context) {};
+ * @param {ol.webgl.Context} context WebGL context.
+ * @return {function()} Delete resources function.
+ ol.render.webgl.TextReplay.prototype.getDeleteResourcesFunction = function(context) {
+ return ol.nullFunction;
+goog.provide('ol.render.webgl.ReplayGroup');
+goog.require('ol.render.replay');
+goog.require('ol.render.ReplayGroup');
+goog.require('ol.render.webgl.CircleReplay');
+goog.require('ol.render.webgl.ImageReplay');
+goog.require('ol.render.webgl.PolygonReplay');
+goog.require('ol.render.webgl.TextReplay');
+ * @constructor
+ * @extends {ol.render.ReplayGroup}
+ * @param {number=} opt_renderBuffer Render buffer.
+ * @struct
+ ol.render.webgl.ReplayGroup = function(tolerance, maxExtent, opt_renderBuffer) {
+ ol.render.ReplayGroup.call(this);
+ * @type {ol.Extent}
+ * @private
+ this.maxExtent_ = maxExtent;
+ * @type {number}
+ * @private
+ this.tolerance_ = tolerance;
+ * @type {number|undefined}
+ * @private
+ this.renderBuffer_ = opt_renderBuffer;
+ * @private
+ * @type {!Object.<string,
+ * Object.<ol.render.ReplayType, ol.render.webgl.Replay>>}
+ this.replaysByZIndex_ = {};
+ ol.inherits(ol.render.webgl.ReplayGroup, ol.render.ReplayGroup);
+ ol.render.webgl.ReplayGroup.prototype.getDeleteResourcesFunction = function(context) {
+ var functions = [];
+ var zKey;
+ for (zKey in this.replaysByZIndex_) {
+ var replays = this.replaysByZIndex_[zKey];
+ var replayKey;
+ for (replayKey in replays) {
+ functions.push(
+ replays[replayKey].getDeleteResourcesFunction(context));
+ var length = functions.length;
+ var result;
+ for (var i = 0; i < length; i++) {
+ result = functions[i].apply(this, arguments);
+ return result;
+ ol.render.webgl.ReplayGroup.prototype.finish = function(context) {
+ var zKey;
+ var replayKey;
+ replays[replayKey].finish(context);
+ * @inheritDoc
+ ol.render.webgl.ReplayGroup.prototype.getReplay = function(zIndex, replayType) {
+ var zIndexKey = zIndex !== undefined ? zIndex.toString() : '0';
+ var replays = this.replaysByZIndex_[zIndexKey];
+ if (replays === undefined) {
+ replays = {};
+ this.replaysByZIndex_[zIndexKey] = replays;
+ var replay = replays[replayType];
+ if (replay === undefined) {
+ * @type {Function}
+ var Constructor = ol.render.webgl.ReplayGroup.BATCH_CONSTRUCTORS_[replayType];
+ replay = new Constructor(this.tolerance_, this.maxExtent_);
+ replays[replayType] = replay;
+ return replay;
+ * @inheritDoc
+ ol.render.webgl.ReplayGroup.prototype.isEmpty = function() {
+ return ol.obj.isEmpty(this.replaysByZIndex_);
+ * to skip.
+ ol.render.webgl.ReplayGroup.prototype.replay = function(context,
+ opacity, skippedFeaturesHash) {
+ /** @type {Array.<number>} */
+ var zs = Object.keys(this.replaysByZIndex_).map(Number);
+ zs.sort(ol.array.numberSafeCompareFunction);
+ var i, ii, j, jj, replays, replay;
+ for (i = 0, ii = zs.length; i < ii; ++i) {
+ replays = this.replaysByZIndex_[zs[i].toString()];
+ for (j = 0, jj = ol.render.replay.ORDER.length; j < jj; ++j) {
+ replay = replays[ol.render.replay.ORDER[j]];
+ if (replay !== undefined) {
+ replay.replay(context,
+ undefined, false);
+ * @private
+ * to skip.
+ * @template T
+ ol.render.webgl.ReplayGroup.prototype.replayHitDetection_ = function(context,
+ center, resolution, rotation, size, pixelRatio, opacity,
+ skippedFeaturesHash, featureCallback, oneByOne, opt_hitExtent) {
+ zs.sort(function(a, b) {
+ return b - a;
+ var i, ii, j, replays, replay, result;
+ for (j = ol.render.replay.ORDER.length - 1; j >= 0; --j) {
+ result = replay.replay(context,
+ skippedFeaturesHash, featureCallback, oneByOne, opt_hitExtent);
+ if (result) {
+ return result;
+ return undefined;
+ * @param {ol.Coordinate} coordinate Coordinate.
+ * to skip.
+ * @param {function((ol.Feature|ol.render.Feature)): T|undefined} callback Feature callback.
+ * @template T
+ ol.render.webgl.ReplayGroup.prototype.forEachFeatureAtCoordinate = function(
+ coordinate, context, center, resolution, rotation, size, pixelRatio,
+ callback) {
+ var gl = context.getGL();
+ gl.bindFramebuffer(
+ gl.FRAMEBUFFER, context.getHitDetectionFramebuffer());
+ var hitExtent;
+ if (this.renderBuffer_ !== undefined) {
+ // build an extent around the coordinate, so that only features that
+ // intersect this extent are checked
+ hitExtent = ol.extent.buffer(
+ ol.extent.createOrUpdateFromCoordinate(coordinate),
+ resolution * this.renderBuffer_);
+ return this.replayHitDetection_(context,
+ coordinate, resolution, rotation, ol.render.webgl.ReplayGroup.HIT_DETECTION_SIZE_,
+ pixelRatio, opacity, skippedFeaturesHash,
+ * @return {?} Callback result.
+ function(feature) {
+ var imageData = new Uint8Array(4);
+ gl.readPixels(0, 0, 1, 1, gl.RGBA, gl.UNSIGNED_BYTE, imageData);
+ if (imageData[3] > 0) {
+ var result = callback(feature);
+ if (result) {
+ return result;
+ }, true, hitExtent);
+ * to skip.
+ * @return {boolean} Is there a feature at the given coordinate?
+ ol.render.webgl.ReplayGroup.prototype.hasFeatureAtCoordinate = function(
+ var hasFeature = this.replayHitDetection_(context,
+ * @return {boolean} Is there a feature?
+ return imageData[3] > 0;
+ }, false);
+ return hasFeature !== undefined;
+ * @const
+ * @private
+ ol.render.webgl.ReplayGroup.HIT_DETECTION_SIZE_ = [1, 1];
+ * @const
+ * @private
+ * @type {Object.<ol.render.ReplayType,
+ * function(new: ol.render.webgl.Replay, number,
+ * ol.Extent)>}
+ ol.render.webgl.ReplayGroup.BATCH_CONSTRUCTORS_ = {
+ 'Circle': ol.render.webgl.CircleReplay,
+ 'Image': ol.render.webgl.ImageReplay,
+ 'LineString': ol.render.webgl.LineStringReplay,
+ 'Polygon': ol.render.webgl.PolygonReplay,
+ 'Text': ol.render.webgl.TextReplay
+goog.provide('ol.render.webgl.Immediate');
+goog.require('ol');
+goog.require('ol.geom.GeometryType');
+goog.require('ol.render.ReplayType');
+goog.require('ol.render.VectorContext');
+goog.require('ol.render.webgl.ReplayGroup');
+ * @constructor
+ * @extends {ol.render.VectorContext}
+ * @struct
+ ol.render.webgl.Immediate = function(context, center, resolution, rotation, size, extent, pixelRatio) {
+ ol.render.VectorContext.call(this);
+ * @private
+ this.context_ = context;
+ * @private
+ this.center_ = center;
+ * @private
+ this.extent_ = extent;
+ * @private
+ this.pixelRatio_ = pixelRatio;
+ * @private
+ this.size_ = size;
+ * @private
+ this.rotation_ = rotation;
+ * @private
+ this.resolution_ = resolution;
+ * @private
+ * @type {ol.style.Image}
+ this.imageStyle_ = null;
+ * @private
+ * @type {ol.style.Fill}
+ this.fillStyle_ = null;
+ * @private
+ * @type {ol.style.Stroke}
+ this.strokeStyle_ = null;
+ ol.inherits(ol.render.webgl.Immediate, ol.render.VectorContext);
+ * Set the rendering style. Note that since this is an immediate rendering API,
+ * any `zIndex` on the provided style will be ignored.
+ * @param {ol.style.Style} style The rendering style.
+ * @override
+ * @api
+ ol.render.webgl.Immediate.prototype.setStyle = function(style) {
+ this.setFillStrokeStyle(style.getFill(), style.getStroke());
+ this.setImageStyle(style.getImage());
+ * Render a geometry into the canvas. Call
+ * {@link ol.render.webgl.Immediate#setStyle} first to set the rendering style.
+ * @param {ol.geom.Geometry|ol.render.Feature} geometry The geometry to render.
+ * @override
+ * @api
+ ol.render.webgl.Immediate.prototype.drawGeometry = function(geometry) {
+ var type = geometry.getType();
+ switch (type) {
+ case ol.geom.GeometryType.POINT:
+ this.drawPoint(/** @type {ol.geom.Point} */ (geometry), null);
+ break;
+ case ol.geom.GeometryType.LINE_STRING:
+ this.drawLineString(/** @type {ol.geom.LineString} */ (geometry), null);
+ break;
+ case ol.geom.GeometryType.POLYGON:
+ this.drawPolygon(/** @type {ol.geom.Polygon} */ (geometry), null);
+ break;
+ case ol.geom.GeometryType.MULTI_POINT:
+ this.drawMultiPoint(/** @type {ol.geom.MultiPoint} */ (geometry), null);
+ break;
+ case ol.geom.GeometryType.MULTI_LINE_STRING:
+ this.drawMultiLineString(/** @type {ol.geom.MultiLineString} */ (geometry), null);
+ break;
+ case ol.geom.GeometryType.MULTI_POLYGON:
+ this.drawMultiPolygon(/** @type {ol.geom.MultiPolygon} */ (geometry), null);
+ break;
+ case ol.geom.GeometryType.GEOMETRY_COLLECTION:
+ this.drawGeometryCollection(/** @type {ol.geom.GeometryCollection} */ (geometry), null);
+ break;
+ case ol.geom.GeometryType.CIRCLE:
+ this.drawCircle(/** @type {ol.geom.Circle} */ (geometry), null);
+ break;
+ default:
+ // pass
+ * @inheritDoc
+ * @api
+ ol.render.webgl.Immediate.prototype.drawFeature = function(feature, style) {
+ var geometry = style.getGeometryFunction()(feature);
+ if (!geometry ||
+ !ol.extent.intersects(this.extent_, geometry.getExtent())) {
+ return;
+ this.setStyle(style);
+ this.drawGeometry(geometry);
+ * @inheritDoc
+ ol.render.webgl.Immediate.prototype.drawGeometryCollection = function(geometry, data) {
+ var geometries = geometry.getGeometriesArray();
+ var i, ii;
+ for (i = 0, ii = geometries.length; i < ii; ++i) {
+ this.drawGeometry(geometries[i]);
+ * @inheritDoc
+ ol.render.webgl.Immediate.prototype.drawPoint = function(geometry, data) {
+ var context = this.context_;
+ var replayGroup = new ol.render.webgl.ReplayGroup(1, this.extent_);
+ var replay = /** @type {ol.render.webgl.ImageReplay} */ (
+ replayGroup.getReplay(0, ol.render.ReplayType.IMAGE));
+ replay.setImageStyle(this.imageStyle_);
+ replay.drawPoint(geometry, data);
+ replay.finish(context);
+ // default colors
+ var opacity = 1;
+ var skippedFeatures = {};
+ var featureCallback;
+ var oneByOne = false;
+ replay.replay(this.context_, this.center_, this.resolution_, this.rotation_,
+ this.size_, this.pixelRatio_, opacity, skippedFeatures, featureCallback,
+ oneByOne);
+ replay.getDeleteResourcesFunction(context)();
+ * @inheritDoc
+ ol.render.webgl.Immediate.prototype.drawMultiPoint = function(geometry, data) {
+ replay.drawMultiPoint(geometry, data);
+ var opacity = 1;
+ oneByOne);
+ * @inheritDoc
+ ol.render.webgl.Immediate.prototype.drawLineString = function(geometry, data) {
+ var replay = /** @type {ol.render.webgl.LineStringReplay} */ (
+ replayGroup.getReplay(0, ol.render.ReplayType.LINE_STRING));
+ replay.setFillStrokeStyle(null, this.strokeStyle_);
+ replay.drawLineString(geometry, data);
+ var opacity = 1;
+ oneByOne);
+ * @inheritDoc
+ ol.render.webgl.Immediate.prototype.drawMultiLineString = function(geometry, data) {
+ replay.drawMultiLineString(geometry, data);
+ var opacity = 1;
+ oneByOne);
+ * @inheritDoc
+ ol.render.webgl.Immediate.prototype.drawPolygon = function(geometry, data) {
+ var replay = /** @type {ol.render.webgl.PolygonReplay} */ (
+ replayGroup.getReplay(0, ol.render.ReplayType.POLYGON));
+ replay.setFillStrokeStyle(this.fillStyle_, this.strokeStyle_);
+ replay.drawPolygon(geometry, data);
+ var opacity = 1;
+ oneByOne);
+ * @inheritDoc
+ ol.render.webgl.Immediate.prototype.drawMultiPolygon = function(geometry, data) {
+ replay.drawMultiPolygon(geometry, data);
+ var opacity = 1;
+ oneByOne);
+ * @inheritDoc
+ ol.render.webgl.Immediate.prototype.drawCircle = function(geometry, data) {
+ var replay = /** @type {ol.render.webgl.CircleReplay} */ (
+ replayGroup.getReplay(0, ol.render.ReplayType.CIRCLE));
+ replay.drawCircle(geometry, data);
+ var opacity = 1;
+ oneByOne);
+ * @inheritDoc
+ ol.render.webgl.Immediate.prototype.setImageStyle = function(imageStyle) {
+ this.imageStyle_ = imageStyle;
+ * @inheritDoc
+ ol.render.webgl.Immediate.prototype.setFillStrokeStyle = function(fillStyle, strokeStyle) {
+ this.fillStyle_ = fillStyle;
+ this.strokeStyle_ = strokeStyle;
+goog.provide('ol.structs.LRUCache');
+goog.require('ol.asserts');
+ * Implements a Least-Recently-Used cache where the keys do not conflict with
+ * Object's properties (e.g. 'hasOwnProperty' is not allowed as a key). Expiring
+ * items from the cache is the responsibility of the user.
+ * @constructor
+ * @struct
+ * @template T
+ol.structs.LRUCache = function() {
+ * @private
+ * @type {number}
+ this.count_ = 0;
+ * @private
+ * @type {!Object.<string, ol.LRUCacheEntry>}
+ this.entries_ = {};
+ * @private
+ * @type {?ol.LRUCacheEntry}
+ this.oldest_ = null;
+ * @private
+ this.newest_ = null;
+ * FIXME empty description for jsdoc
+ol.structs.LRUCache.prototype.clear = function() {
+ this.count_ = 0;
+ * @param {string} key Key.
+ * @return {boolean} Contains key.
+ol.structs.LRUCache.prototype.containsKey = function(key) {
+ return this.entries_.hasOwnProperty(key);
+ * @param {function(this: S, T, string, ol.structs.LRUCache): ?} f The function
+ * to call for every entry from the oldest to the newer. This function takes
+ * 3 arguments (the entry value, the entry key and the LRUCache object).
+ * The return value is ignored.
+ * @param {S=} opt_this The object to use as `this` in `f`.
+ * @template S
+ol.structs.LRUCache.prototype.forEach = function(f, opt_this) {
+ var entry = this.oldest_;
+ while (entry) {
+ f.call(opt_this, entry.value_, entry.key_, this);
+ entry = entry.newer;
+ * @return {T} Value.
+ol.structs.LRUCache.prototype.get = function(key) {
+ var entry = this.entries_[key];
+ ol.asserts.assert(entry !== undefined,
+ 15); // Tried to get a value for a key that does not exist in the cache
+ if (entry === this.newest_) {
+ return entry.value_;
+ } else if (entry === this.oldest_) {
+ this.oldest_ = /** @type {ol.LRUCacheEntry} */ (this.oldest_.newer);
+ this.oldest_.older = null;
+ } else {
+ entry.newer.older = entry.older;
+ entry.older.newer = entry.newer;
+ entry.newer = null;
+ entry.older = this.newest_;
+ this.newest_.newer = entry;
+ this.newest_ = entry;
+ * @return {number} Count.
+ol.structs.LRUCache.prototype.getCount = function() {
+ return this.count_;
+ * @return {Array.<string>} Keys.
+ol.structs.LRUCache.prototype.getKeys = function() {
+ var keys = new Array(this.count_);
+ var i = 0;
+ var entry;
+ for (entry = this.newest_; entry; entry = entry.older) {
+ keys[i++] = entry.key_;
+ return keys;
+ * @return {Array.<T>} Values.
+ol.structs.LRUCache.prototype.getValues = function() {
+ var values = new Array(this.count_);
+ var i = 0;
+ var entry;
+ values[i++] = entry.value_;
+ return values;
+ * @return {T} Last value.
+ol.structs.LRUCache.prototype.peekLast = function() {
+ return this.oldest_.value_;
+ * @return {string} Last key.
+ol.structs.LRUCache.prototype.peekLastKey = function() {
+ return this.oldest_.key_;
+ * @return {T} value Value.
+ol.structs.LRUCache.prototype.pop = function() {
+ delete this.entries_[entry.key_];
+ if (entry.newer) {
+ entry.newer.older = null;
+ this.oldest_ = /** @type {ol.LRUCacheEntry} */ (entry.newer);
+ if (!this.oldest_) {
+ --this.count_;
+ol.structs.LRUCache.prototype.replace = function(key, value) {
+ this.get(key); // update `newest_`
+ this.entries_[key].value_ = value;
+ol.structs.LRUCache.prototype.set = function(key, value) {
+ ol.asserts.assert(!(key in this.entries_),
+ 16); // Tried to set a value for a key that is used already
+ var entry = /** @type {ol.LRUCacheEntry} */ ({
+ key_: key,
+ newer: null,
+ older: this.newest_,
+ value_: value
+ if (!this.newest_) {
+ this.oldest_ = entry;
+ } else {
+ this.entries_[key] = entry;
+ ++this.count_;
+// FIXME check against gl.getParameter(webgl.MAX_TEXTURE_SIZE)
+goog.provide('ol.renderer.webgl.Map');
+goog.require('ol.css');
+goog.require('ol.dom');
+goog.require('ol.events');
+goog.require('ol.layer.Layer');
+goog.require('ol.render.Event');
+goog.require('ol.render.EventType');
+goog.require('ol.render.webgl.Immediate');
+goog.require('ol.renderer.Map');
+goog.require('ol.renderer.Type');
+goog.require('ol.source.State');
+goog.require('ol.structs.LRUCache');
+goog.require('ol.structs.PriorityQueue');
+goog.require('ol.webgl');
+goog.require('ol.webgl.Context');
+goog.require('ol.webgl.ContextEventType');
+ * @constructor
+ * @extends {ol.renderer.Map}
+ * @param {Element} container Container.
+ * @param {ol.Map} map Map.
+ ol.renderer.webgl.Map = function(container, map) {
+ ol.renderer.Map.call(this, container, map);
+ * @private
+ * @type {HTMLCanvasElement}
+ this.canvas_ = /** @type {HTMLCanvasElement} */
+ (document.createElement('CANVAS'));
+ this.canvas_.style.width = '100%';
+ this.canvas_.style.height = '100%';
+ this.canvas_.style.display = 'block';
+ this.canvas_.className = ol.css.CLASS_UNSELECTABLE;
+ container.insertBefore(this.canvas_, container.childNodes[0] || null);
+ * @private
+ * @type {number}
+ this.clipTileCanvasWidth_ = 0;
+ * @private
+ * @type {number}
+ this.clipTileCanvasHeight_ = 0;
+ * @private
+ * @type {CanvasRenderingContext2D}
+ this.clipTileContext_ = ol.dom.createCanvasContext2D();
+ * @private
+ * @type {boolean}
+ this.renderedVisible_ = true;
+ * @private
+ * @type {WebGLRenderingContext}
+ this.gl_ = ol.webgl.getContext(this.canvas_, {
+ antialias: true,
+ depth: true,
+ failIfMajorPerformanceCaveat: true,
+ preserveDrawingBuffer: false,
+ stencil: true
+ * @private
+ * @type {ol.webgl.Context}
+ this.context_ = new ol.webgl.Context(this.canvas_, this.gl_);
+ ol.events.listen(this.canvas_, ol.webgl.ContextEventType.LOST,
+ this.handleWebGLContextLost, this);
+ ol.events.listen(this.canvas_, ol.webgl.ContextEventType.RESTORED,
+ this.handleWebGLContextRestored, this);
+ * @private
+ * @type {ol.structs.LRUCache.<ol.WebglTextureCacheEntry|null>}
+ this.textureCache_ = new ol.structs.LRUCache();
+ * @private
+ * @type {ol.Coordinate}
+ this.focus_ = null;
+ * @private
+ * @type {ol.structs.PriorityQueue.<Array>}
+ this.tileTextureQueue_ = new ol.structs.PriorityQueue(
+ * @param {Array.<*>} element Element.
+ * @return {number} Priority.
+ * @this {ol.renderer.webgl.Map}
+ (function(element) {
+ var tileCenter = /** @type {ol.Coordinate} */ (element[1]);
+ var tileResolution = /** @type {number} */ (element[2]);
+ var deltaX = tileCenter[0] - this.focus_[0];
+ var deltaY = tileCenter[1] - this.focus_[1];
+ return 65536 * Math.log(tileResolution) +
+ Math.sqrt(deltaX * deltaX + deltaY * deltaY) / tileResolution;
+ }).bind(this),
+ * @return {string} Key.
+ function(element) {
+ return /** @type {ol.Tile} */ (element[0]).getKey();
+ * @param {?olx.FrameState} frameState Frame state.
+ * @return {boolean} false.
+ this.loadNextTileTexture_ =
+ function(map, frameState) {
+ if (!this.tileTextureQueue_.isEmpty()) {
+ this.tileTextureQueue_.reprioritize();
+ var element = this.tileTextureQueue_.dequeue();
+ var tile = /** @type {ol.Tile} */ (element[0]);
+ var tileSize = /** @type {ol.Size} */ (element[3]);
+ var tileGutter = /** @type {number} */ (element[4]);
+ this.bindTileTexture(
+ tile, tileSize, tileGutter, ol.webgl.LINEAR, ol.webgl.LINEAR);
+ return false;
+ }.bind(this);
+ * @private
+ * @type {number}
+ this.textureCacheFrameMarkerCount_ = 0;
+ this.initializeGL_();
+ ol.inherits(ol.renderer.webgl.Map, ol.renderer.Map);
+ * @param {ol.Tile} tile Tile.
+ * @param {ol.Size} tileSize Tile size.
+ * @param {number} tileGutter Tile gutter.
+ * @param {number} magFilter Mag filter.
+ * @param {number} minFilter Min filter.
+ ol.renderer.webgl.Map.prototype.bindTileTexture = function(tile, tileSize, tileGutter, magFilter, minFilter) {
+ var gl = this.getGL();
+ var tileKey = tile.getKey();
+ if (this.textureCache_.containsKey(tileKey)) {
+ var textureCacheEntry = this.textureCache_.get(tileKey);
+ gl.bindTexture(ol.webgl.TEXTURE_2D, textureCacheEntry.texture);
+ if (textureCacheEntry.magFilter != magFilter) {
+ gl.texParameteri(
+ ol.webgl.TEXTURE_2D, ol.webgl.TEXTURE_MAG_FILTER, magFilter);
+ textureCacheEntry.magFilter = magFilter;
+ if (textureCacheEntry.minFilter != minFilter) {
+ gl.texParameteri(
+ ol.webgl.TEXTURE_2D, ol.webgl.TEXTURE_MIN_FILTER, minFilter);
+ textureCacheEntry.minFilter = minFilter;
+ } else {
+ var texture = gl.createTexture();
+ gl.bindTexture(ol.webgl.TEXTURE_2D, texture);
+ if (tileGutter > 0) {
+ var clipTileCanvas = this.clipTileContext_.canvas;
+ var clipTileContext = this.clipTileContext_;
+ if (this.clipTileCanvasWidth_ !== tileSize[0] ||
+ this.clipTileCanvasHeight_ !== tileSize[1]) {
+ clipTileCanvas.width = tileSize[0];
+ clipTileCanvas.height = tileSize[1];
+ this.clipTileCanvasWidth_ = tileSize[0];
+ this.clipTileCanvasHeight_ = tileSize[1];
+ } else {
+ clipTileContext.clearRect(0, 0, tileSize[0], tileSize[1]);
+ clipTileContext.drawImage(tile.getImage(), tileGutter, tileGutter,
+ tileSize[0], tileSize[1], 0, 0, tileSize[0], tileSize[1]);
+ gl.texImage2D(ol.webgl.TEXTURE_2D, 0,
+ ol.webgl.RGBA, ol.webgl.RGBA,
+ ol.webgl.UNSIGNED_BYTE, clipTileCanvas);
+ } else {
+ ol.webgl.UNSIGNED_BYTE, tile.getImage());
+ gl.texParameteri(
+ gl.texParameteri(
+ gl.texParameteri(ol.webgl.TEXTURE_2D, ol.webgl.TEXTURE_WRAP_S,
+ ol.webgl.CLAMP_TO_EDGE);
+ gl.texParameteri(ol.webgl.TEXTURE_2D, ol.webgl.TEXTURE_WRAP_T,
+ this.textureCache_.set(tileKey, {
+ texture: texture,
+ magFilter: magFilter,
+ minFilter: minFilter
+ * @param {ol.render.EventType} type Event type.
+ * @param {olx.FrameState} frameState Frame state.
+ * @private
+ ol.renderer.webgl.Map.prototype.dispatchComposeEvent_ = function(type, frameState) {
+ var map = this.getMap();
+ if (map.hasListener(type)) {
+ var extent = frameState.extent;
+ var size = frameState.size;
+ var viewState = frameState.viewState;
+ var pixelRatio = frameState.pixelRatio;
+ var resolution = viewState.resolution;
+ var center = viewState.center;
+ var rotation = viewState.rotation;
+ var vectorContext = new ol.render.webgl.Immediate(context,
+ center, resolution, rotation, size, extent, pixelRatio);
+ var composeEvent = new ol.render.Event(type, vectorContext,
+ frameState, null, context);
+ map.dispatchEvent(composeEvent);
+ * @inheritDoc
+ ol.renderer.webgl.Map.prototype.disposeInternal = function() {
+ if (!gl.isContextLost()) {
+ this.textureCache_.forEach(
+ * @param {?ol.WebglTextureCacheEntry} textureCacheEntry
+ * Texture cache entry.
+ function(textureCacheEntry) {
+ if (textureCacheEntry) {
+ gl.deleteTexture(textureCacheEntry.texture);
+ this.context_.dispose();
+ ol.renderer.Map.prototype.disposeInternal.call(this);
+ * @private
+ ol.renderer.webgl.Map.prototype.expireCache_ = function(map, frameState) {
+ var textureCacheEntry;
+ while (this.textureCache_.getCount() - this.textureCacheFrameMarkerCount_ >
+ ol.WEBGL_TEXTURE_CACHE_HIGH_WATER_MARK) {
+ textureCacheEntry = this.textureCache_.peekLast();
+ if (!textureCacheEntry) {
+ if (+this.textureCache_.peekLastKey() == frameState.index) {
+ break;
+ } else {
+ --this.textureCacheFrameMarkerCount_;
+ } else {
+ this.textureCache_.pop();
+ * @return {ol.webgl.Context} The context.
+ ol.renderer.webgl.Map.prototype.getContext = function() {
+ return this.context_;
+ * @return {WebGLRenderingContext} GL.
+ ol.renderer.webgl.Map.prototype.getGL = function() {
+ return this.gl_;
+ * @return {ol.structs.PriorityQueue.<Array>} Tile texture queue.
+ ol.renderer.webgl.Map.prototype.getTileTextureQueue = function() {
+ return this.tileTextureQueue_;
+ * @inheritDoc
+ ol.renderer.webgl.Map.prototype.getType = function() {
+ return ol.renderer.Type.WEBGL;
+ * @param {ol.events.Event} event Event.
+ * @protected
+ ol.renderer.webgl.Map.prototype.handleWebGLContextLost = function(event) {
+ event.preventDefault();
+ this.textureCache_.clear();
+ var renderers = this.getLayerRenderers();
+ for (var id in renderers) {
+ var renderer = /** @type {ol.renderer.webgl.Layer} */ (renderers[id]);
+ renderer.handleWebGLContextLost();
+ * @protected
+ ol.renderer.webgl.Map.prototype.handleWebGLContextRestored = function() {
+ this.getMap().render();
+ * @private
+ ol.renderer.webgl.Map.prototype.initializeGL_ = function() {
+ var gl = this.gl_;
+ gl.activeTexture(ol.webgl.TEXTURE0);
+ gl.blendFuncSeparate(
+ ol.webgl.SRC_ALPHA, ol.webgl.ONE_MINUS_SRC_ALPHA,
+ ol.webgl.ONE, ol.webgl.ONE_MINUS_SRC_ALPHA);
+ gl.disable(ol.webgl.CULL_FACE);
+ gl.disable(ol.webgl.DEPTH_TEST);
+ gl.disable(ol.webgl.SCISSOR_TEST);
+ gl.disable(ol.webgl.STENCIL_TEST);
+ * @return {boolean} Is tile texture loaded.
+ ol.renderer.webgl.Map.prototype.isTileTextureLoaded = function(tile) {
+ return this.textureCache_.containsKey(tile.getKey());
+ * @inheritDoc
+ ol.renderer.webgl.Map.prototype.renderFrame = function(frameState) {
+ var context = this.getContext();
+ if (gl.isContextLost()) {
+ return false;
+ if (!frameState) {
+ if (this.renderedVisible_) {
+ this.canvas_.style.display = 'none';
+ this.renderedVisible_ = false;
+ return false;
+ this.focus_ = frameState.focus;
+ this.textureCache_.set((-frameState.index).toString(), null);
+ ++this.textureCacheFrameMarkerCount_;
+ this.dispatchComposeEvent_(ol.render.EventType.PRECOMPOSE, frameState);
+ /** @type {Array.<ol.LayerState>} */
+ var layerStatesToDraw = [];
+ var layerStatesArray = frameState.layerStatesArray;
+ ol.array.stableSort(layerStatesArray, ol.renderer.Map.sortByZIndex);
+ var viewResolution = frameState.viewState.resolution;
+ var i, ii, layerRenderer, layerState;
+ for (i = 0, ii = layerStatesArray.length; i < ii; ++i) {
+ layerState = layerStatesArray[i];
+ if (ol.layer.Layer.visibleAtResolution(layerState, viewResolution) &&
+ layerState.sourceState == ol.source.State.READY) {
+ layerRenderer = /** @type {ol.renderer.webgl.Layer} */ (this.getLayerRenderer(layerState.layer));
+ if (layerRenderer.prepareFrame(frameState, layerState, context)) {
+ layerStatesToDraw.push(layerState);
+ var width = frameState.size[0] * frameState.pixelRatio;
+ var height = frameState.size[1] * frameState.pixelRatio;
+ if (this.canvas_.width != width || this.canvas_.height != height) {
+ this.canvas_.width = width;
+ this.canvas_.height = height;
+ gl.bindFramebuffer(ol.webgl.FRAMEBUFFER, null);
+ gl.clearColor(0, 0, 0, 0);
+ gl.clear(ol.webgl.COLOR_BUFFER_BIT);
+ gl.enable(ol.webgl.BLEND);
+ gl.viewport(0, 0, this.canvas_.width, this.canvas_.height);
+ for (i = 0, ii = layerStatesToDraw.length; i < ii; ++i) {
+ layerState = layerStatesToDraw[i];
+ layerRenderer.composeFrame(frameState, layerState, context);
+ if (!this.renderedVisible_) {
+ this.canvas_.style.display = '';
+ this.calculateMatrices2D(frameState);
+ if (this.textureCache_.getCount() - this.textureCacheFrameMarkerCount_ >
+ frameState.postRenderFunctions.push(
+ /** @type {ol.PostRenderFunction} */ (this.expireCache_.bind(this))
+ frameState.postRenderFunctions.push(this.loadNextTileTexture_);
+ frameState.animate = true;
+ this.dispatchComposeEvent_(ol.render.EventType.POSTCOMPOSE, frameState);
+ this.scheduleRemoveUnusedLayerRenderers(frameState);
+ this.scheduleExpireIconCache(frameState);
+ * @inheritDoc
+ ol.renderer.webgl.Map.prototype.forEachFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, callback, thisArg,
+ layerFilter, thisArg2) {
+ var result;
+ if (this.getGL().isContextLost()) {
+ return false;
+ var layerStates = frameState.layerStatesArray;
+ var numLayers = layerStates.length;
+ var i;
+ for (i = numLayers - 1; i >= 0; --i) {
+ var layerState = layerStates[i];
+ var layer = layerState.layer;
+ if (ol.layer.Layer.visibleAtResolution(layerState, viewState.resolution) &&
+ layerFilter.call(thisArg2, layer)) {
+ var layerRenderer = this.getLayerRenderer(layer);
+ result = layerRenderer.forEachFeatureAtCoordinate(
+ coordinate, frameState, hitTolerance, callback, thisArg);
+ if (result) {
+ return result;
+ return undefined;
+ * @inheritDoc
+ ol.renderer.webgl.Map.prototype.hasFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, layerFilter, thisArg) {
+ var hasFeature = false;
+ return false;
+ var i;
+ layerFilter.call(thisArg, layer)) {
+ hasFeature =
+ layerRenderer.hasFeatureAtCoordinate(coordinate, frameState);
+ if (hasFeature) {
+ return true;
+ return hasFeature;
+ * @inheritDoc
+ ol.renderer.webgl.Map.prototype.forEachLayerAtPixel = function(pixel, frameState, callback, thisArg,
+ return false;
+ var result;
+ var i;
+ var layerRenderer = /** @type {ol.renderer.webgl.Layer} */ (this.getLayerRenderer(layer));
+ result = layerRenderer.forEachLayerAtPixel(
+ pixel, frameState, callback, thisArg);
+ if (result) {
+ return result;
+ return undefined;
+// FIXME recheck layer/map projection compatibility when projection changes
+// FIXME layer renderers should skip when they can't reproject
+// FIXME add tilt and height?
+goog.provide('ol.Map');
+goog.require('ol.Collection');
+goog.require('ol.CollectionEventType');
+goog.require('ol.MapBrowserEvent');
+goog.require('ol.MapBrowserEventHandler');
+goog.require('ol.MapBrowserEventType');
+goog.require('ol.MapEvent');
+goog.require('ol.MapEventType');
+goog.require('ol.MapProperty');
+goog.require('ol.Object');
+goog.require('ol.ObjectEventType');
+goog.require('ol.TileQueue');
+goog.require('ol.View');
+goog.require('ol.ViewHint');
+goog.require('ol.control');
+goog.require('ol.events.Event');
+goog.require('ol.events.EventType');
+goog.require('ol.functions');
+goog.require('ol.has');
+goog.require('ol.interaction');
+goog.require('ol.layer.Group');
+goog.require('ol.renderer.canvas.Map');
+goog.require('ol.renderer.webgl.Map');
+goog.require('ol.size');
+goog.require('ol.transform');
+ * @const
+ * @type {string}
+ol.OL_URL = 'https://openlayers.org/';
+ * @const
+ * @type {string}
+ol.OL_LOGO_URL = 'data:image/png;base64,' +
+ 'iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAMAAABEpIrGAAAAA3NCSVQICAjb4U/gAAAACXBI' +
+ 'WXMAAAHGAAABxgEXwfpGAAAAGXRFWHRTb2Z0d2FyZQB3d3cuaW5rc2NhcGUub3Jnm+48GgAA' +
+ 'AhNQTFRF////AP//AICAgP//AFVVQECA////K1VVSbbbYL/fJ05idsTYJFtbbcjbJllmZszW' +
+ 'WMTOIFhoHlNiZszTa9DdUcHNHlNlV8XRIVdiasrUHlZjIVZjaMnVH1RlIFRkH1RkH1ZlasvY' +
+ 'asvXVsPQH1VkacnVa8vWIVZjIFRjVMPQa8rXIVVkXsXRsNveIFVkIFZlIVVj3eDeh6GmbMvX' +
+ 'H1ZkIFRka8rWbMvXIFVkIFVjIFVkbMvWH1VjbMvWIFVlbcvWIFVla8vVIFVkbMvWbMvVH1Vk' +
+ 'bMvWIFVlbcvWIFVkbcvVbMvWjNPbIFVkU8LPwMzNIFVkbczWIFVkbsvWbMvXIFVkRnB8bcvW' +
+ '2+TkW8XRIFVkIlZlJVloJlpoKlxrLl9tMmJwOWd0Omh1RXF8TneCT3iDUHiDU8LPVMLPVcLP' +
+ 'VcPQVsPPVsPQV8PQWMTQWsTQW8TQXMXSXsXRX4SNX8bSYMfTYcfTYsfTY8jUZcfSZsnUaIqT' +
+ 'acrVasrVa8jTa8rWbI2VbMvWbcvWdJObdcvUdszUd8vVeJaee87Yfc3WgJyjhqGnitDYjaar' +
+ 'ldPZnrK2oNbborW5o9bbo9fbpLa6q9ndrL3ArtndscDDutzfu8fJwN7gwt7gxc/QyuHhy+Hi' +
+ 'zeHi0NfX0+Pj19zb1+Tj2uXk29/e3uLg3+Lh3+bl4uXj4ufl4+fl5Ofl5ufl5ujm5+jmySDn' +
+ 'BAAAAFp0Uk5TAAECAgMEBAYHCA0NDg4UGRogIiMmKSssLzU7PkJJT1JTVFliY2hrdHZ3foSF' +
+ 'hYeJjY2QkpugqbG1tre5w8zQ09XY3uXn6+zx8vT09vf4+Pj5+fr6/P39/f3+gz7SsAAAAVVJ' +
+ 'REFUOMtjYKA7EBDnwCPLrObS1BRiLoJLnte6CQy8FLHLCzs2QUG4FjZ5GbcmBDDjxJBXDWxC' +
+ 'Brb8aM4zbkIDzpLYnAcE9VXlJSWlZRU13koIeW57mGx5XjoMZEUqwxWYQaQbSzLSkYGfKFSe' +
+ '0QMsX5WbjgY0YS4MBplemI4BdGBW+DQ11eZiymfqQuXZIjqwyadPNoSZ4L+0FVM6e+oGI6g8' +
+ 'a9iKNT3o8kVzNkzRg5lgl7p4wyRUL9Yt2jAxVh6mQCogae6GmflI8p0r13VFWTHBQ0rWPW7a' +
+ 'hgWVcPm+9cuLoyy4kCJDzCm6d8PSFoh0zvQNC5OjDJhQopPPJqph1doJBUD5tnkbZiUEqaCn' +
+ 'B3bTqLTFG1bPn71kw4b+GFdpLElKIzRxxgYgWNYc5SCENVHKeUaltHdXx0dZ8uBI1hJ2UUDg' +
+ 'q82CM2MwKeibqAvSO7MCABq0wXEPiqWEAAAAAElFTkSuQmCC';
+ * @type {Array.<ol.renderer.Type>}
+ * @const
+ol.DEFAULT_RENDERER_TYPES = [
+ ol.renderer.Type.CANVAS,
+ ol.renderer.Type.WEBGL
+ * @classdesc
+ * The map is the core component of OpenLayers. For a map to render, a view,
+ * one or more layers, and a target container are needed:
+ * var map = new ol.Map({
+ * view: new ol.View({
+ * center: [0, 0],
+ * zoom: 1
+ * layers: [
+ * new ol.layer.Tile({
+ * source: new ol.source.OSM()
+ * target: 'map'
+ * The above snippet creates a map using a {@link ol.layer.Tile} to display
+ * {@link ol.source.OSM} OSM data and render it to a DOM element with the
+ * id `map`.
+ * The constructor places a viewport container (with CSS class name
+ * `ol-viewport`) in the target element (see `getViewport()`), and then two
+ * further elements within the viewport: one with CSS class name
+ * `ol-overlaycontainer-stopevent` for controls and some overlays, and one with
+ * CSS class name `ol-overlaycontainer` for other overlays (see the `stopEvent`
+ * option of {@link ol.Overlay} for the difference). The map itself is placed in
+ * a further element within the viewport.
+ * Layers are stored as a `ol.Collection` in layerGroups. A top-level group is
+ * provided by the library. This is what is accessed by `getLayerGroup` and
+ * `setLayerGroup`. Layers entered in the options are added to this group, and
+ * `addLayer` and `removeLayer` change the layer collection in the group.
+ * `getLayers` is a convenience function for `getLayerGroup().getLayers()`.
+ * Note that `ol.layer.Group` is a subclass of `ol.layer.Base`, so layers
+ * entered in the options or added with `addLayer` can be groups, which can
+ * contain further groups, and so on.
+ * @constructor
+ * @extends {ol.Object}
+ * @param {olx.MapOptions} options Map options.
+ * @fires ol.MapBrowserEvent
+ * @fires ol.MapEvent
+ * @fires ol.render.Event#postcompose
+ * @fires ol.render.Event#precompose
+ * @api
+ol.Map = function(options) {
+ ol.Object.call(this);
+ var optionsInternal = ol.Map.createOptionsInternal(options);
+ * @type {boolean}
+ * @private
+ this.loadTilesWhileAnimating_ =
+ options.loadTilesWhileAnimating !== undefined ?
+ options.loadTilesWhileAnimating : false;
+ * @type {boolean}
+ * @private
+ this.loadTilesWhileInteracting_ =
+ options.loadTilesWhileInteracting !== undefined ?
+ options.loadTilesWhileInteracting : false;
+ * @private
+ * @type {number}
+ this.pixelRatio_ = options.pixelRatio !== undefined ?
+ options.pixelRatio : ol.has.DEVICE_PIXEL_RATIO;
+ * @private
+ * @type {Object.<string, string>}
+ this.logos_ = optionsInternal.logos;
+ * @private
+ this.animationDelayKey_;
+ * @private
+ this.animationDelay_ = function() {
+ this.animationDelayKey_ = undefined;
+ this.renderFrame_.call(this, Date.now());
+ }.bind(this);
+ * @private
+ * @type {ol.Transform}
+ this.coordinateToPixelTransform_ = ol.transform.create();
+ * @private
+ this.pixelToCoordinateTransform_ = ol.transform.create();
+ * @private
+ * @type {number}
+ this.frameIndex_ = 0;
+ * @private
+ * @type {?olx.FrameState}
+ this.frameState_ = null;
+ * The extent at the previous 'moveend' event.
+ * @private
+ this.previousExtent_ = ol.extent.createEmpty();
+ * @private
+ * @type {?ol.EventsKey}
+ this.viewPropertyListenerKey_ = null;
+ * @private
+ this.viewChangeListenerKey_ = null;
+ * @private
+ * @type {Array.<ol.EventsKey>}
+ this.layerGroupPropertyListenerKeys_ = null;
+ * @private
+ * @type {Element}
+ this.viewport_ = document.createElement('DIV');
+ this.viewport_.className = 'ol-viewport' + (ol.has.TOUCH ? ' ol-touch' : '');
+ this.viewport_.style.position = 'relative';
+ this.viewport_.style.overflow = 'hidden';
+ this.viewport_.style.width = '100%';
+ this.viewport_.style.height = '100%';
+ // prevent page zoom on IE >= 10 browsers
+ this.viewport_.style.msTouchAction = 'none';
+ this.viewport_.style.touchAction = 'none';
+ * @private
+ * @type {!Element}
+ this.overlayContainer_ = document.createElement('DIV');
+ this.overlayContainer_.className = 'ol-overlaycontainer';
+ this.viewport_.appendChild(this.overlayContainer_);
+ * @private
+ this.overlayContainerStopEvent_ = document.createElement('DIV');
+ this.overlayContainerStopEvent_.className = 'ol-overlaycontainer-stopevent';
+ var overlayEvents = [
+ ol.events.EventType.CLICK,
+ ol.events.EventType.DBLCLICK,
+ ol.events.EventType.MOUSEDOWN,
+ ol.events.EventType.TOUCHSTART,
+ ol.events.EventType.MSPOINTERDOWN,
+ ol.MapBrowserEventType.POINTERDOWN,
+ ol.events.EventType.MOUSEWHEEL,
+ ol.events.EventType.WHEEL
+ for (var i = 0, ii = overlayEvents.length; i < ii; ++i) {
+ ol.events.listen(this.overlayContainerStopEvent_, overlayEvents[i],
+ ol.events.Event.stopPropagation);
+ this.viewport_.appendChild(this.overlayContainerStopEvent_);
+ * @private
+ * @type {ol.MapBrowserEventHandler}
+ this.mapBrowserEventHandler_ = new ol.MapBrowserEventHandler(this);
+ for (var key in ol.MapBrowserEventType) {
+ ol.events.listen(this.mapBrowserEventHandler_, ol.MapBrowserEventType[key],
+ this.handleMapBrowserEvent, this);
+ * @private
+ * @type {Element|Document}
+ this.keyboardEventTarget_ = optionsInternal.keyboardEventTarget;
+ * @private
+ this.keyHandlerKeys_ = null;
+ ol.events.listen(this.viewport_, ol.events.EventType.WHEEL,
+ this.handleBrowserEvent, this);
+ ol.events.listen(this.viewport_, ol.events.EventType.MOUSEWHEEL,
+ * @type {ol.Collection.<ol.control.Control>}
+ * @private
+ this.controls_ = optionsInternal.controls;
+ * @type {ol.Collection.<ol.interaction.Interaction>}
+ * @private
+ this.interactions_ = optionsInternal.interactions;
+ * @type {ol.Collection.<ol.Overlay>}
+ * @private
+ this.overlays_ = optionsInternal.overlays;
+ * A lookup of overlays by id.
+ * @private
+ * @type {Object.<string, ol.Overlay>}
+ this.overlayIdIndex_ = {};
+ * @type {ol.renderer.Map}
+ * @private
+ this.renderer_ = new /** @type {Function} */ (optionsInternal.rendererConstructor)(this.viewport_, this);
+ * @type {function(Event)|undefined}
+ * @private
+ this.handleResize_;
+ * @private
+ * @private
+ * @type {Array.<ol.PostRenderFunction>}
+ this.postRenderFunctions_ = [];
+ * @private
+ * @type {ol.TileQueue}
+ this.tileQueue_ = new ol.TileQueue(
+ this.getTilePriority.bind(this),
+ this.handleTileChange_.bind(this));
+ * Uids of features to skip at rendering time.
+ * @type {Object.<string, boolean>}
+ * @private
+ this.skippedFeatureUids_ = {};
+ ol.events.listen(
+ this, ol.Object.getChangeEventType(ol.MapProperty.LAYERGROUP),
+ this.handleLayerGroupChanged_, this);
+ ol.events.listen(this, ol.Object.getChangeEventType(ol.MapProperty.VIEW),
+ this.handleViewChanged_, this);
+ ol.events.listen(this, ol.Object.getChangeEventType(ol.MapProperty.SIZE),
+ this.handleSizeChanged_, this);
+ ol.events.listen(this, ol.Object.getChangeEventType(ol.MapProperty.TARGET),
+ this.handleTargetChanged_, this);
+ // setProperties will trigger the rendering of the map if the map
+ // is "defined" already.
+ this.setProperties(optionsInternal.values);
+ this.controls_.forEach(
+ * @param {ol.control.Control} control Control.
+ * @this {ol.Map}
+ function(control) {
+ control.setMap(this);
+ }, this);
+ ol.events.listen(this.controls_, ol.CollectionEventType.ADD,
+ * @param {ol.Collection.Event} event Collection event.
+ function(event) {
+ event.element.setMap(this);
+ }, this);
+ ol.events.listen(this.controls_, ol.CollectionEventType.REMOVE,
+ function(event) {
+ event.element.setMap(null);
+ }, this);
+ this.interactions_.forEach(
+ * @param {ol.interaction.Interaction} interaction Interaction.
+ * @this {ol.Map}
+ function(interaction) {
+ interaction.setMap(this);
+ }, this);
+ ol.events.listen(this.interactions_, ol.CollectionEventType.ADD,
+ function(event) {
+ }, this);
+ ol.events.listen(this.interactions_, ol.CollectionEventType.REMOVE,
+ function(event) {
+ }, this);
+ this.overlays_.forEach(this.addOverlayInternal_, this);
+ ol.events.listen(this.overlays_, ol.CollectionEventType.ADD,
+ function(event) {
+ this.addOverlayInternal_(/** @type {ol.Overlay} */ (event.element));
+ }, this);
+ ol.events.listen(this.overlays_, ol.CollectionEventType.REMOVE,
+ function(event) {
+ var overlay = /** @type {ol.Overlay} */ (event.element);
+ var id = overlay.getId();
+ if (id !== undefined) {
+ delete this.overlayIdIndex_[id.toString()];
+ }, this);
+ol.inherits(ol.Map, ol.Object);
+ * Add the given control to the map.
+ * @api
+ol.Map.prototype.addControl = function(control) {
+ this.getControls().push(control);
+ * Add the given interaction to the map.
+ * @param {ol.interaction.Interaction} interaction Interaction to add.
+ * @api
+ol.Map.prototype.addInteraction = function(interaction) {
+ this.getInteractions().push(interaction);
+ * Adds the given layer to the top of this map. If you want to add a layer
+ * elsewhere in the stack, use `getLayers()` and the methods available on
+ * {@link ol.Collection}.
+ * @param {ol.layer.Base} layer Layer.
+ * @api
+ol.Map.prototype.addLayer = function(layer) {
+ var layers = this.getLayerGroup().getLayers();
+ layers.push(layer);
+ * Add the given overlay to the map.
+ * @param {ol.Overlay} overlay Overlay.
+ * @api
+ol.Map.prototype.addOverlay = function(overlay) {
+ this.getOverlays().push(overlay);
+ * This deals with map's overlay collection changes.
+ * @private
+ol.Map.prototype.addOverlayInternal_ = function(overlay) {
+ this.overlayIdIndex_[id.toString()] = overlay;
+ overlay.setMap(this);
+ * @inheritDoc
+ol.Map.prototype.disposeInternal = function() {
+ this.mapBrowserEventHandler_.dispose();
+ this.renderer_.dispose();
+ ol.events.unlisten(this.viewport_, ol.events.EventType.WHEEL,
+ ol.events.unlisten(this.viewport_, ol.events.EventType.MOUSEWHEEL,
+ if (this.handleResize_ !== undefined) {
+ window.removeEventListener(ol.events.EventType.RESIZE,
+ this.handleResize_, false);
+ this.handleResize_ = undefined;
+ if (this.animationDelayKey_) {
+ cancelAnimationFrame(this.animationDelayKey_);
+ this.setTarget(null);
+ ol.Object.prototype.disposeInternal.call(this);
+ * Detect features that intersect a pixel on the viewport, and execute a
+ * callback with each intersecting feature. Layers included in the detection can
+ * be configured through `opt_layerFilter`.
+ * @param {ol.Pixel} pixel Pixel.
+ * @param {function(this: S, (ol.Feature|ol.render.Feature),
+ * ol.layer.Layer): T} callback Feature callback. The callback will be
+ * called with two arguments. The first argument is one
+ * {@link ol.Feature feature} or
+ * {@link ol.render.Feature render feature} at the pixel, the second is
+ * the {@link ol.layer.Layer layer} of the feature and will be null for
+ * unmanaged layers. To stop detection, callback functions can return a
+ * truthy value.
+ * @param {olx.AtPixelOptions=} opt_options Optional options.
+ * @return {T|undefined} Callback result, i.e. the return value of last
+ * callback execution, or the first truthy callback return value.
+ * @template S,T
+ * @api
+ol.Map.prototype.forEachFeatureAtPixel = function(pixel, callback, opt_options) {
+ if (!this.frameState_) {
+ return;
+ var coordinate = this.getCoordinateFromPixel(pixel);
+ opt_options = opt_options !== undefined ? opt_options : {};
+ var hitTolerance = opt_options.hitTolerance !== undefined ?
+ opt_options.hitTolerance * this.frameState_.pixelRatio : 0;
+ var layerFilter = opt_options.layerFilter !== undefined ?
+ opt_options.layerFilter : ol.functions.TRUE;
+ return this.renderer_.forEachFeatureAtCoordinate(
+ coordinate, this.frameState_, hitTolerance, callback, null,
+ layerFilter, null);
+ * Detect layers that have a color value at a pixel on the viewport, and
+ * execute a callback with each matching layer. Layers included in the
+ * detection can be configured through `opt_layerFilter`.
+ * @param {function(this: S, ol.layer.Layer, (Uint8ClampedArray|Uint8Array)): T} callback
+ * Layer callback. This callback will recieve two arguments: first is the
+ * {@link ol.layer.Layer layer}, second argument is an array representing
+ * [R, G, B, A] pixel values (0 - 255) and will be `null` for layer types
+ * that do not currently support this argument. To stop detection, callback
+ * functions can return a truthy value.
+ * @param {S=} opt_this Value to use as `this` when executing `callback`.
+ * @param {(function(this: U, ol.layer.Layer): boolean)=} opt_layerFilter Layer
+ * filter function. The filter function will receive one argument, the
+ * {@link ol.layer.Layer layer-candidate} and it should return a boolean
+ * value. Only layers which are visible and for which this function returns
+ * `true` will be tested for features. By default, all visible layers will
+ * be tested.
+ * @param {U=} opt_this2 Value to use as `this` when executing `layerFilter`.
+ * @template S,T,U
+ * @api
+ol.Map.prototype.forEachLayerAtPixel = function(pixel, callback, opt_this, opt_layerFilter, opt_this2) {
+ return;
+ var thisArg = opt_this !== undefined ? opt_this : null;
+ var layerFilter = opt_layerFilter !== undefined ?
+ opt_layerFilter : ol.functions.TRUE;
+ var thisArg2 = opt_this2 !== undefined ? opt_this2 : null;
+ return this.renderer_.forEachLayerAtPixel(
+ pixel, this.frameState_, callback, thisArg,
+ layerFilter, thisArg2);
+ * Detect if features intersect a pixel on the viewport. Layers included in the
+ * @return {boolean} Is there a feature at the given pixel?
+ * @template U
+ * @api
+ol.Map.prototype.hasFeatureAtPixel = function(pixel, opt_options) {
+ return false;
+ return this.renderer_.hasFeatureAtCoordinate(
+ coordinate, this.frameState_, hitTolerance, layerFilter, null);
+ * Returns the coordinate in view projection for a browser event.
+ * @param {Event} event Event.
+ * @return {ol.Coordinate} Coordinate.
+ * @api
+ol.Map.prototype.getEventCoordinate = function(event) {
+ return this.getCoordinateFromPixel(this.getEventPixel(event));
+ * Returns the map pixel position for a browser event relative to the viewport.
+ * @return {ol.Pixel} Pixel.
+ * @api
+ol.Map.prototype.getEventPixel = function(event) {
+ var viewportPosition = this.viewport_.getBoundingClientRect();
+ var eventPosition = event.changedTouches ? event.changedTouches[0] : event;
+ return [
+ eventPosition.clientX - viewportPosition.left,
+ eventPosition.clientY - viewportPosition.top
+ * Get the target in which this map is rendered.
+ * Note that this returns what is entered as an option or in setTarget:
+ * if that was an element, it returns an element; if a string, it returns that.
+ * @return {Element|string|undefined} The Element or id of the Element that the
+ * map is rendered in.
+ * @observable
+ * @api
+ol.Map.prototype.getTarget = function() {
+ return /** @type {Element|string|undefined} */ (
+ this.get(ol.MapProperty.TARGET));
+ * Get the DOM element into which this map is rendered. In contrast to
+ * `getTarget` this method always return an `Element`, or `null` if the
+ * map has no target.
+ * @return {Element} The element that the map is rendered in.
+ * @api
+ol.Map.prototype.getTargetElement = function() {
+ var target = this.getTarget();
+ if (target !== undefined) {
+ return typeof target === 'string' ?
+ document.getElementById(target) :
+ target;
+ } else {
+ return null;
+ * Get the coordinate for a given pixel. This returns a coordinate in the
+ * map view projection.
+ * @param {ol.Pixel} pixel Pixel position in the map viewport.
+ * @return {ol.Coordinate} The coordinate for the pixel position.
+ * @api
+ol.Map.prototype.getCoordinateFromPixel = function(pixel) {
+ var frameState = this.frameState_;
+ return null;
+ } else {
+ return ol.transform.apply(frameState.pixelToCoordinateTransform, pixel.slice());
+ * Get the map controls. Modifying this collection changes the controls
+ * associated with the map.
+ * @return {ol.Collection.<ol.control.Control>} Controls.
+ * @api
+ol.Map.prototype.getControls = function() {
+ return this.controls_;
+ * Get the map overlays. Modifying this collection changes the overlays
+ * @return {ol.Collection.<ol.Overlay>} Overlays.
+ * @api
+ol.Map.prototype.getOverlays = function() {
+ return this.overlays_;
+ * Get an overlay by its identifier (the value returned by overlay.getId()).
+ * Note that the index treats string and numeric identifiers as the same. So
+ * `map.getOverlayById(2)` will return an overlay with id `'2'` or `2`.
+ * @param {string|number} id Overlay identifier.
+ * @return {ol.Overlay} Overlay.
+ * @api
+ol.Map.prototype.getOverlayById = function(id) {
+ var overlay = this.overlayIdIndex_[id.toString()];
+ return overlay !== undefined ? overlay : null;
+ * Get the map interactions. Modifying this collection changes the interactions
+ * Interactions are used for e.g. pan, zoom and rotate.
+ * @return {ol.Collection.<ol.interaction.Interaction>} Interactions.
+ * @api
+ol.Map.prototype.getInteractions = function() {
+ return this.interactions_;
+ * Get the layergroup associated with this map.
+ * @return {ol.layer.Group} A layer group containing the layers in this map.
+ * @observable
+ * @api
+ol.Map.prototype.getLayerGroup = function() {
+ return /** @type {ol.layer.Group} */ (this.get(ol.MapProperty.LAYERGROUP));
+ * Get the collection of layers associated with this map.
+ * @return {!ol.Collection.<ol.layer.Base>} Layers.
+ * @api
+ol.Map.prototype.getLayers = function() {
+ return layers;
+ * Get the pixel for a coordinate. This takes a coordinate in the map view
+ * projection and returns the corresponding pixel.
+ * @param {ol.Coordinate} coordinate A map coordinate.
+ * @return {ol.Pixel} A pixel position in the map viewport.
+ * @api
+ol.Map.prototype.getPixelFromCoordinate = function(coordinate) {
+ return null;
+ } else {
+ return ol.transform.apply(frameState.coordinateToPixelTransform,
+ coordinate.slice(0, 2));
+ * Get the map renderer.
+ * @return {ol.renderer.Map} Renderer
+ol.Map.prototype.getRenderer = function() {
+ return this.renderer_;
+ * Get the size of this map.
+ * @return {ol.Size|undefined} The size in pixels of the map in the DOM.
+ * @observable
+ * @api
+ol.Map.prototype.getSize = function() {
+ return /** @type {ol.Size|undefined} */ (this.get(ol.MapProperty.SIZE));
+ * Get the view associated with this map. A view manages properties such as
+ * center and resolution.
+ * @return {ol.View} The view that controls this map.
+ * @observable
+ * @api
+ol.Map.prototype.getView = function() {
+ return /** @type {ol.View} */ (this.get(ol.MapProperty.VIEW));
+ * Get the element that serves as the map viewport.
+ * @return {Element} Viewport.
+ * @api
+ol.Map.prototype.getViewport = function() {
+ return this.viewport_;
+ * Get the element that serves as the container for overlays. Elements added to
+ * this container will let mousedown and touchstart events through to the map,
+ * so clicks and gestures on an overlay will trigger {@link ol.MapBrowserEvent}
+ * events.
+ * @return {!Element} The map's overlay container.
+ol.Map.prototype.getOverlayContainer = function() {
+ return this.overlayContainer_;
+ * Get the element that serves as a container for overlays that don't allow
+ * event propagation. Elements added to this container won't let mousedown and
+ * touchstart events through to the map, so clicks and gestures on an overlay
+ * don't trigger any {@link ol.MapBrowserEvent}.
+ * @return {!Element} The map's overlay container that stops events.
+ol.Map.prototype.getOverlayContainerStopEvent = function() {
+ return this.overlayContainerStopEvent_;
+ * @param {string} tileSourceKey Tile source key.
+ * @param {ol.Coordinate} tileCenter Tile center.
+ * @param {number} tileResolution Tile resolution.
+ * @return {number} Tile priority.
+ol.Map.prototype.getTilePriority = function(tile, tileSourceKey, tileCenter, tileResolution) {
+ // Filter out tiles at higher zoom levels than the current zoom level, or that
+ // are outside the visible extent.
+ if (!frameState || !(tileSourceKey in frameState.wantedTiles)) {
+ return ol.structs.PriorityQueue.DROP;
+ if (!frameState.wantedTiles[tileSourceKey][tile.getKey()]) {
+ // Prioritize the highest zoom level tiles closest to the focus.
+ // Tiles at higher zoom levels are prioritized using Math.log(tileResolution).
+ // Within a zoom level, tiles are prioritized by the distance in pixels
+ // between the center of the tile and the focus. The factor of 65536 means
+ // that the prioritization should behave as desired for tiles up to
+ // 65536 * Math.log(2) = 45426 pixels from the focus.
+ var deltaX = tileCenter[0] - frameState.focus[0];
+ var deltaY = tileCenter[1] - frameState.focus[1];
+ * @param {Event} browserEvent Browser event.
+ * @param {string=} opt_type Type.
+ol.Map.prototype.handleBrowserEvent = function(browserEvent, opt_type) {
+ var type = opt_type || browserEvent.type;
+ var mapBrowserEvent = new ol.MapBrowserEvent(type, this, browserEvent);
+ this.handleMapBrowserEvent(mapBrowserEvent);
+ * @param {ol.MapBrowserEvent} mapBrowserEvent The event to handle.
+ol.Map.prototype.handleMapBrowserEvent = function(mapBrowserEvent) {
+ // With no view defined, we cannot translate pixels into geographical
+ // coordinates so interactions cannot be used.
+ return;
+ this.focus_ = mapBrowserEvent.coordinate;
+ mapBrowserEvent.frameState = this.frameState_;
+ var interactionsArray = this.getInteractions().getArray();
+ var i;
+ if (this.dispatchEvent(mapBrowserEvent) !== false) {
+ for (i = interactionsArray.length - 1; i >= 0; i--) {
+ var interaction = interactionsArray[i];
+ if (!interaction.getActive()) {
+ continue;
+ var cont = interaction.handleEvent(mapBrowserEvent);
+ if (!cont) {
+ break;
+ * @protected
+ol.Map.prototype.handlePostRender = function() {
+ // Manage the tile queue
+ // Image loads are expensive and a limited resource, so try to use them
+ // efficiently:
+ // * When the view is static we allow a large number of parallel tile loads
+ // to complete the frame as quickly as possible.
+ // * When animating or interacting, image loads can cause janks, so we reduce
+ // the maximum number of loads per frame and limit the number of parallel
+ // tile loads to remain reactive to view changes and to reduce the chance of
+ // loading tiles that will quickly disappear from view.
+ var tileQueue = this.tileQueue_;
+ if (!tileQueue.isEmpty()) {
+ var maxTotalLoading = 16;
+ var maxNewLoads = maxTotalLoading;
+ if (frameState) {
+ var hints = frameState.viewHints;
+ if (hints[ol.ViewHint.ANIMATING]) {
+ maxTotalLoading = this.loadTilesWhileAnimating_ ? 8 : 0;
+ maxNewLoads = 2;
+ if (hints[ol.ViewHint.INTERACTING]) {
+ maxTotalLoading = this.loadTilesWhileInteracting_ ? 8 : 0;
+ maxNewLoads = 2;
+ if (tileQueue.getTilesLoading() < maxTotalLoading) {
+ tileQueue.reprioritize(); // FIXME only call if view has changed
+ tileQueue.loadMoreTiles(maxTotalLoading, maxNewLoads);
+ var postRenderFunctions = this.postRenderFunctions_;
+ var i, ii;
+ for (i = 0, ii = postRenderFunctions.length; i < ii; ++i) {
+ postRenderFunctions[i](this, frameState);
+ postRenderFunctions.length = 0;
+ * @private
+ol.Map.prototype.handleSizeChanged_ = function() {
+ this.render();
+ * @private
+ol.Map.prototype.handleTargetChanged_ = function() {
+ // target may be undefined, null, a string or an Element.
+ // If it's a string we convert it to an Element before proceeding.
+ // If it's not now an Element we remove the viewport from the DOM.
+ // If it's an Element we append the viewport element to it.
+ var targetElement;
+ if (this.getTarget()) {
+ targetElement = this.getTargetElement();
+ if (this.keyHandlerKeys_) {
+ for (var i = 0, ii = this.keyHandlerKeys_.length; i < ii; ++i) {
+ ol.events.unlistenByKey(this.keyHandlerKeys_[i]);
+ if (!targetElement) {
+ ol.dom.removeNode(this.viewport_);
+ } else {
+ targetElement.appendChild(this.viewport_);
+ var keyboardEventTarget = !this.keyboardEventTarget_ ?
+ targetElement : this.keyboardEventTarget_;
+ this.keyHandlerKeys_ = [
+ ol.events.listen(keyboardEventTarget, ol.events.EventType.KEYDOWN,
+ this.handleBrowserEvent, this),
+ ol.events.listen(keyboardEventTarget, ol.events.EventType.KEYPRESS,
+ if (!this.handleResize_) {
+ this.handleResize_ = this.updateSize.bind(this);
+ window.addEventListener(ol.events.EventType.RESIZE,
+ this.updateSize();
+ // updateSize calls setSize, so no need to call this.render
+ // ourselves here.
+ * @private
+ol.Map.prototype.handleTileChange_ = function() {
+ this.render();
+ * @private
+ol.Map.prototype.handleViewPropertyChanged_ = function() {
+ this.render();
+ * @private
+ol.Map.prototype.handleViewChanged_ = function() {
+ if (this.viewPropertyListenerKey_) {
+ ol.events.unlistenByKey(this.viewPropertyListenerKey_);
+ if (this.viewChangeListenerKey_) {
+ ol.events.unlistenByKey(this.viewChangeListenerKey_);
+ var view = this.getView();
+ if (view) {
+ this.viewport_.setAttribute('data-view', ol.getUid(view));
+ this.viewPropertyListenerKey_ = ol.events.listen(
+ view, ol.ObjectEventType.PROPERTYCHANGE,
+ this.handleViewPropertyChanged_, this);
+ this.viewChangeListenerKey_ = ol.events.listen(
+ view, ol.events.EventType.CHANGE,
+ this.render();
+ * @private
+ol.Map.prototype.handleLayerGroupChanged_ = function() {
+ if (this.layerGroupPropertyListenerKeys_) {
+ this.layerGroupPropertyListenerKeys_.forEach(ol.events.unlistenByKey);
+ var layerGroup = this.getLayerGroup();
+ if (layerGroup) {
+ this.layerGroupPropertyListenerKeys_ = [
+ ol.events.listen(
+ layerGroup, ol.ObjectEventType.PROPERTYCHANGE,
+ this.render, this),
+ ol.events.listen(
+ layerGroup, ol.events.EventType.CHANGE,
+ this.render();
+ * @return {boolean} Is rendered.
+ol.Map.prototype.isRendered = function() {
+ return !!this.frameState_;
+ * Requests an immediate render in a synchronous manner.
+ * @api
+ol.Map.prototype.renderSync = function() {
+ this.animationDelay_();
+ * Request a map rendering (at the next animation frame).
+ * @api
+ol.Map.prototype.render = function() {
+ if (this.animationDelayKey_ === undefined) {
+ this.animationDelayKey_ = requestAnimationFrame(
+ this.animationDelay_);
+ * Remove the given control from the map.
+ * @return {ol.control.Control|undefined} The removed control (or undefined
+ * if the control was not found).
+ * @api
+ol.Map.prototype.removeControl = function(control) {
+ return this.getControls().remove(control);
+ * Remove the given interaction from the map.
+ * @param {ol.interaction.Interaction} interaction Interaction to remove.
+ * @return {ol.interaction.Interaction|undefined} The removed interaction (or
+ * undefined if the interaction was not found).
+ * @api
+ol.Map.prototype.removeInteraction = function(interaction) {
+ return this.getInteractions().remove(interaction);
+ * Removes the given layer from the map.
+ * @return {ol.layer.Base|undefined} The removed layer (or undefined if the
+ * layer was not found).
+ * @api
+ol.Map.prototype.removeLayer = function(layer) {
+ return layers.remove(layer);
+ * Remove the given overlay from the map.
+ * @return {ol.Overlay|undefined} The removed overlay (or undefined
+ * if the overlay was not found).
+ * @api
+ol.Map.prototype.removeOverlay = function(overlay) {
+ return this.getOverlays().remove(overlay);
+ * @param {number} time Time.
+ * @private
+ol.Map.prototype.renderFrame_ = function(time) {
+ var i, ii, viewState;
+ var size = this.getSize();
+ var extent = ol.extent.createEmpty();
+ /** @type {?olx.FrameState} */
+ var frameState = null;
+ if (size !== undefined && ol.size.hasArea(size) && view && view.isDef()) {
+ var viewHints = view.getHints(this.frameState_ ? this.frameState_.viewHints : undefined);
+ var layerStatesArray = this.getLayerGroup().getLayerStatesArray();
+ var layerStates = {};
+ layerStates[ol.getUid(layerStatesArray[i].layer)] = layerStatesArray[i];
+ viewState = view.getState();
+ frameState = /** @type {olx.FrameState} */ ({
+ animate: false,
+ attributions: {},
+ coordinateToPixelTransform: this.coordinateToPixelTransform_,
+ extent: extent,
+ focus: !this.focus_ ? viewState.center : this.focus_,
+ index: this.frameIndex_++,
+ layerStates: layerStates,
+ layerStatesArray: layerStatesArray,
+ logos: ol.obj.assign({}, this.logos_),
+ pixelRatio: this.pixelRatio_,
+ pixelToCoordinateTransform: this.pixelToCoordinateTransform_,
+ postRenderFunctions: [],
+ size: size,
+ skippedFeatureUids: this.skippedFeatureUids_,
+ tileQueue: this.tileQueue_,
+ time: time,
+ usedTiles: {},
+ viewState: viewState,
+ viewHints: viewHints,
+ wantedTiles: {}
+ if (frameState) {
+ frameState.extent = ol.extent.getForViewAndSize(viewState.center,
+ viewState.resolution, viewState.rotation, frameState.size, extent);
+ this.frameState_ = frameState;
+ this.renderer_.renderFrame(frameState);
+ if (frameState) {
+ if (frameState.animate) {
+ this.render();
+ Array.prototype.push.apply(
+ this.postRenderFunctions_, frameState.postRenderFunctions);
+ var idle = !frameState.viewHints[ol.ViewHint.ANIMATING] &&
+ !frameState.viewHints[ol.ViewHint.INTERACTING] &&
+ !ol.extent.equals(frameState.extent, this.previousExtent_);
+ if (idle) {
+ this.dispatchEvent(
+ new ol.MapEvent(ol.MapEventType.MOVEEND, this, frameState));
+ ol.extent.clone(frameState.extent, this.previousExtent_);
+ new ol.MapEvent(ol.MapEventType.POSTRENDER, this, frameState));
+ setTimeout(this.handlePostRender.bind(this), 0);
+ * Sets the layergroup of this map.
+ * @param {ol.layer.Group} layerGroup A layer group containing the layers in
+ * this map.
+ * @observable
+ * @api
+ol.Map.prototype.setLayerGroup = function(layerGroup) {
+ this.set(ol.MapProperty.LAYERGROUP, layerGroup);
+ * Set the size of this map.
+ * @param {ol.Size|undefined} size The size in pixels of the map in the DOM.
+ * @observable
+ * @api
+ol.Map.prototype.setSize = function(size) {
+ this.set(ol.MapProperty.SIZE, size);
+ * Set the target element to render this map into.
+ * @param {Element|string|undefined} target The Element or id of the Element
+ * that the map is rendered in.
+ * @observable
+ * @api
+ol.Map.prototype.setTarget = function(target) {
+ this.set(ol.MapProperty.TARGET, target);
+ * Set the view for this map.
+ * @param {ol.View} view The view that controls this map.
+ * @observable
+ * @api
+ol.Map.prototype.setView = function(view) {
+ this.set(ol.MapProperty.VIEW, view);
+ * @param {ol.Feature} feature Feature.
+ol.Map.prototype.skipFeature = function(feature) {
+ var featureUid = ol.getUid(feature).toString();
+ this.skippedFeatureUids_[featureUid] = true;
+ this.render();
+ * Force a recalculation of the map viewport size. This should be called when
+ * third-party code changes the size of the map viewport.
+ * @api
+ol.Map.prototype.updateSize = function() {
+ var targetElement = this.getTargetElement();
+ this.setSize(undefined);
+ } else {
+ var computedStyle = getComputedStyle(targetElement);
+ this.setSize([
+ targetElement.offsetWidth -
+ parseFloat(computedStyle['borderLeftWidth']) -
+ parseFloat(computedStyle['paddingLeft']) -
+ parseFloat(computedStyle['paddingRight']) -
+ parseFloat(computedStyle['borderRightWidth']),
+ targetElement.offsetHeight -
+ parseFloat(computedStyle['borderTopWidth']) -
+ parseFloat(computedStyle['paddingTop']) -
+ parseFloat(computedStyle['paddingBottom']) -
+ parseFloat(computedStyle['borderBottomWidth'])
+ol.Map.prototype.unskipFeature = function(feature) {
+ delete this.skippedFeatureUids_[featureUid];
+ this.render();
+ * @return {ol.MapOptionsInternal} Internal map options.
+ol.Map.createOptionsInternal = function(options) {
+ var keyboardEventTarget = null;
+ if (options.keyboardEventTarget !== undefined) {
+ keyboardEventTarget = typeof options.keyboardEventTarget === 'string' ?
+ document.getElementById(options.keyboardEventTarget) :
+ options.keyboardEventTarget;
+ * @type {Object.<string, *>}
+ var values = {};
+ var logos = {};
+ if (options.logo === undefined ||
+ (typeof options.logo === 'boolean' && options.logo)) {
+ logos[ol.OL_LOGO_URL] = ol.OL_URL;
+ } else {
+ var logo = options.logo;
+ if (typeof logo === 'string') {
+ logos[logo] = '';
+ } else if (logo instanceof HTMLElement) {
+ logos[ol.getUid(logo).toString()] = logo;
+ } else if (logo) {
+ ol.asserts.assert(typeof logo.href == 'string', 44); // `logo.href` should be a string.
+ ol.asserts.assert(typeof logo.src == 'string', 45); // `logo.src` should be a string.
+ logos[logo.src] = logo.href;
+ var layerGroup = (options.layers instanceof ol.layer.Group) ?
+ options.layers : new ol.layer.Group({layers: options.layers});
+ values[ol.MapProperty.LAYERGROUP] = layerGroup;
+ values[ol.MapProperty.TARGET] = options.target;
+ values[ol.MapProperty.VIEW] = options.view !== undefined ?
+ options.view : new ol.View();
+ * @type {function(new: ol.renderer.Map, Element, ol.Map)}
+ var rendererConstructor = ol.renderer.Map;
+ var rendererTypes;
+ if (options.renderer !== undefined) {
+ if (Array.isArray(options.renderer)) {
+ rendererTypes = options.renderer;
+ } else if (typeof options.renderer === 'string') {
+ rendererTypes = [options.renderer];
+ } else {
+ ol.asserts.assert(false, 46); // Incorrect format for `renderer` option
+ if (rendererTypes.indexOf(/** @type {ol.renderer.Type} */ ('dom')) >= 0) {
+ rendererTypes = rendererTypes.concat(ol.DEFAULT_RENDERER_TYPES);
+ } else {
+ rendererTypes = ol.DEFAULT_RENDERER_TYPES;
+ var i, ii;
+ for (i = 0, ii = rendererTypes.length; i < ii; ++i) {
+ /** @type {ol.renderer.Type} */
+ var rendererType = rendererTypes[i];
+ if (ol.ENABLE_CANVAS && rendererType == ol.renderer.Type.CANVAS) {
+ if (ol.has.CANVAS) {
+ rendererConstructor = ol.renderer.canvas.Map;
+ break;
+ } else if (ol.ENABLE_WEBGL && rendererType == ol.renderer.Type.WEBGL) {
+ if (ol.has.WEBGL) {
+ rendererConstructor = ol.renderer.webgl.Map;
+ break;
+ var controls;
+ if (options.controls !== undefined) {
+ if (Array.isArray(options.controls)) {
+ controls = new ol.Collection(options.controls.slice());
+ } else {
+ ol.asserts.assert(options.controls instanceof ol.Collection,
+ 47); // Expected `controls` to be an array or an `ol.Collection`
+ controls = options.controls;
+ } else {
+ controls = ol.control.defaults();
+ var interactions;
+ if (options.interactions !== undefined) {
+ if (Array.isArray(options.interactions)) {
+ interactions = new ol.Collection(options.interactions.slice());
+ } else {
+ ol.asserts.assert(options.interactions instanceof ol.Collection,
+ 48); // Expected `interactions` to be an array or an `ol.Collection`
+ interactions = options.interactions;
+ } else {
+ interactions = ol.interaction.defaults();
+ var overlays;
+ if (options.overlays !== undefined) {
+ if (Array.isArray(options.overlays)) {
+ overlays = new ol.Collection(options.overlays.slice());
+ } else {
+ ol.asserts.assert(options.overlays instanceof ol.Collection,
+ 49); // Expected `overlays` to be an array or an `ol.Collection`
+ overlays = options.overlays;
+ } else {
+ overlays = new ol.Collection();
+ return {
+ controls: controls,
+ interactions: interactions,
+ keyboardEventTarget: keyboardEventTarget,
+ logos: logos,
+ overlays: overlays,
+ rendererConstructor: rendererConstructor,
+ values: values
+goog.provide('ol.OverlayPositioning');
+ * Overlay position: `'bottom-left'`, `'bottom-center'`, `'bottom-right'`,
+ * `'center-left'`, `'center-center'`, `'center-right'`, `'top-left'`,
+ * `'top-center'`, `'top-right'`
+ * @enum {string}
+ol.OverlayPositioning = {
+ BOTTOM_LEFT: 'bottom-left',
+ BOTTOM_CENTER: 'bottom-center',
+ BOTTOM_RIGHT: 'bottom-right',
+ CENTER_LEFT: 'center-left',
+ CENTER_CENTER: 'center-center',
+ CENTER_RIGHT: 'center-right',
+ TOP_LEFT: 'top-left',
+ TOP_CENTER: 'top-center',
+ TOP_RIGHT: 'top-right'
+goog.provide('ol.Overlay');
+goog.require('ol');
+goog.require('ol.OverlayPositioning');
+goog.require('ol.extent');
+ * @classdesc
+ * An element to be displayed over the map and attached to a single map
+ * location. Like {@link ol.control.Control}, Overlays are visible widgets.
+ * Unlike Controls, they are not in a fixed position on the screen, but are tied
+ * to a geographical coordinate, so panning the map will move an Overlay but not
+ * a Control.
+ * Example:
+ * var popup = new ol.Overlay({
+ * element: document.getElementById('popup')
+ * popup.setPosition(coordinate);
+ * map.addOverlay(popup);
+ * @constructor
+ * @param {olx.OverlayOptions} options Overlay options.
+ * @api
+ol.Overlay = function(options) {
+ * @private
+ * @type {number|string|undefined}
+ this.id_ = options.id;
+ * @private
+ * @type {boolean}
+ this.insertFirst_ = options.insertFirst !== undefined ?
+ options.insertFirst : true;
+ * @private
+ * @type {boolean}
+ this.stopEvent_ = options.stopEvent !== undefined ? options.stopEvent : true;
+ * @private
+ * @type {Element}
+ this.element_ = document.createElement('DIV');
+ this.element_.className = 'ol-overlay-container';
+ this.element_.style.position = 'absolute';
+ * @protected
+ * @type {boolean}
+ this.autoPan = options.autoPan !== undefined ? options.autoPan : false;
+ * @private
+ * @type {olx.OverlayPanOptions}
+ this.autoPanAnimation_ = options.autoPanAnimation ||
+ /** @type {olx.OverlayPanOptions} */ ({});
+ * @private
+ * @type {number}
+ this.autoPanMargin_ = options.autoPanMargin !== undefined ?
+ options.autoPanMargin : 20;
+ * @private
+ * @type {{bottom_: string,
+ * left_: string,
+ * right_: string,
+ * top_: string,
+ * visible: boolean}}
+ this.rendered_ = {
+ bottom_: '',
+ left_: '',
+ right_: '',
+ top_: '',
+ visible: true
+ * @private
+ this.mapPostrenderListenerKey_ = null;
+ ol.events.listen(
+ this, ol.Object.getChangeEventType(ol.Overlay.Property_.ELEMENT),
+ this.handleElementChanged, this);
+ ol.events.listen(
+ this, ol.Object.getChangeEventType(ol.Overlay.Property_.MAP),
+ this.handleMapChanged, this);
+ ol.events.listen(
+ this, ol.Object.getChangeEventType(ol.Overlay.Property_.OFFSET),
+ this.handleOffsetChanged, this);
+ ol.events.listen(
+ this, ol.Object.getChangeEventType(ol.Overlay.Property_.POSITION),
+ this.handlePositionChanged, this);
+ ol.events.listen(
+ this, ol.Object.getChangeEventType(ol.Overlay.Property_.POSITIONING),
+ this.handlePositioningChanged, this);
+ if (options.element !== undefined) {
+ this.setElement(options.element);
+ this.setOffset(options.offset !== undefined ? options.offset : [0, 0]);
+ this.setPositioning(options.positioning !== undefined ?
+ /** @type {ol.OverlayPositioning} */ (options.positioning) :
+ ol.OverlayPositioning.TOP_LEFT);
+ if (options.position !== undefined) {
+ this.setPosition(options.position);
+ol.inherits(ol.Overlay, ol.Object);
+ * Get the DOM element of this overlay.
+ * @return {Element|undefined} The Element containing the overlay.
+ * @observable
+ * @api
+ol.Overlay.prototype.getElement = function() {
+ return /** @type {Element|undefined} */ (
+ this.get(ol.Overlay.Property_.ELEMENT));
+ * Get the overlay identifier which is set on constructor.
+ * @return {number|string|undefined} Id.
+ * @api
+ol.Overlay.prototype.getId = function() {
+ return this.id_;
+ * Get the map associated with this overlay.
+ * @return {ol.Map|undefined} The map that the overlay is part of.
+ * @observable
+ * @api
+ol.Overlay.prototype.getMap = function() {
+ return /** @type {ol.Map|undefined} */ (
+ this.get(ol.Overlay.Property_.MAP));
+ * Get the offset of this overlay.
+ * @return {Array.<number>} The offset.
+ * @observable
+ * @api
+ol.Overlay.prototype.getOffset = function() {
+ return /** @type {Array.<number>} */ (
+ this.get(ol.Overlay.Property_.OFFSET));
+ * Get the current position of this overlay.
+ * @return {ol.Coordinate|undefined} The spatial point that the overlay is
+ * anchored at.
+ * @observable
+ * @api
+ol.Overlay.prototype.getPosition = function() {
+ return /** @type {ol.Coordinate|undefined} */ (
+ this.get(ol.Overlay.Property_.POSITION));
+ * Get the current positioning of this overlay.
+ * @return {ol.OverlayPositioning} How the overlay is positioned
+ * relative to its point on the map.
+ * @observable
+ * @api
+ol.Overlay.prototype.getPositioning = function() {
+ return /** @type {ol.OverlayPositioning} */ (
+ this.get(ol.Overlay.Property_.POSITIONING));
+ * @protected
+ol.Overlay.prototype.handleElementChanged = function() {
+ ol.dom.removeChildren(this.element_);
+ var element = this.getElement();
+ if (element) {
+ this.element_.appendChild(element);
+ * @protected
+ol.Overlay.prototype.handleMapChanged = function() {
+ if (this.mapPostrenderListenerKey_) {
+ ol.dom.removeNode(this.element_);
+ ol.events.unlistenByKey(this.mapPostrenderListenerKey_);
+ if (map) {
+ this.mapPostrenderListenerKey_ = ol.events.listen(map,
+ ol.MapEventType.POSTRENDER, this.render, this);
+ this.updatePixelPosition();
+ var container = this.stopEvent_ ?
+ map.getOverlayContainerStopEvent() : map.getOverlayContainer();
+ if (this.insertFirst_) {
+ container.insertBefore(this.element_, container.childNodes[0] || null);
+ } else {
+ container.appendChild(this.element_);
+ * @protected
+ol.Overlay.prototype.render = function() {
+ * @protected
+ol.Overlay.prototype.handleOffsetChanged = function() {
+ * @protected
+ol.Overlay.prototype.handlePositionChanged = function() {
+ if (this.get(ol.Overlay.Property_.POSITION) && this.autoPan) {
+ this.panIntoView_();
+ * @protected
+ol.Overlay.prototype.handlePositioningChanged = function() {
+ * Set the DOM element to be associated with this overlay.
+ * @param {Element|undefined} element The Element containing the overlay.
+ * @observable
+ * @api
+ol.Overlay.prototype.setElement = function(element) {
+ this.set(ol.Overlay.Property_.ELEMENT, element);
+ * Set the map to be associated with this overlay.
+ * @param {ol.Map|undefined} map The map that the overlay is part of.
+ * @observable
+ * @api
+ol.Overlay.prototype.setMap = function(map) {
+ this.set(ol.Overlay.Property_.MAP, map);
+ * Set the offset for this overlay.
+ * @param {Array.<number>} offset Offset.
+ * @observable
+ * @api
+ol.Overlay.prototype.setOffset = function(offset) {
+ this.set(ol.Overlay.Property_.OFFSET, offset);
+ * Set the position for this overlay. If the position is `undefined` the
+ * overlay is hidden.
+ * @param {ol.Coordinate|undefined} position The spatial point that the overlay
+ * is anchored at.
+ * @observable
+ * @api
+ol.Overlay.prototype.setPosition = function(position) {
+ this.set(ol.Overlay.Property_.POSITION, position);
+ * Pan the map so that the overlay is entirely visible in the current viewport
+ * (if necessary).
+ * @private
+ol.Overlay.prototype.panIntoView_ = function() {
+ if (!map || !map.getTargetElement()) {
+ return;
+ var mapRect = this.getRect_(map.getTargetElement(), map.getSize());
+ var element = /** @type {!Element} */ (this.getElement());
+ var overlayRect = this.getRect_(element,
+ [ol.dom.outerWidth(element), ol.dom.outerHeight(element)]);
+ var margin = this.autoPanMargin_;
+ if (!ol.extent.containsExtent(mapRect, overlayRect)) {
+ // the overlay is not completely inside the viewport, so pan the map
+ var offsetLeft = overlayRect[0] - mapRect[0];
+ var offsetRight = mapRect[2] - overlayRect[2];
+ var offsetTop = overlayRect[1] - mapRect[1];
+ var offsetBottom = mapRect[3] - overlayRect[3];
+ var delta = [0, 0];
+ if (offsetLeft < 0) {
+ // move map to the left
+ delta[0] = offsetLeft - margin;
+ } else if (offsetRight < 0) {
+ // move map to the right
+ delta[0] = Math.abs(offsetRight) + margin;
+ if (offsetTop < 0) {
+ // move map up
+ delta[1] = offsetTop - margin;
+ } else if (offsetBottom < 0) {
+ // move map down
+ delta[1] = Math.abs(offsetBottom) + margin;
+ if (delta[0] !== 0 || delta[1] !== 0) {
+ var center = /** @type {ol.Coordinate} */ (map.getView().getCenter());
+ var centerPx = map.getPixelFromCoordinate(center);
+ var newCenterPx = [
+ centerPx[0] + delta[0],
+ centerPx[1] + delta[1]
+ map.getView().animate({
+ center: map.getCoordinateFromPixel(newCenterPx),
+ duration: this.autoPanAnimation_.duration,
+ easing: this.autoPanAnimation_.easing
+ * Get the extent of an element relative to the document
+ * @param {Element|undefined} element The element.
+ * @param {ol.Size|undefined} size The size of the element.
+ * @return {ol.Extent} The extent.
+ * @private
+ol.Overlay.prototype.getRect_ = function(element, size) {
+ var box = element.getBoundingClientRect();
+ var offsetX = box.left + window.pageXOffset;
+ var offsetY = box.top + window.pageYOffset;
+ return [
+ offsetX,
+ offsetY,
+ offsetX + size[0],
+ offsetY + size[1]
+ * Set the positioning for this overlay.
+ * @param {ol.OverlayPositioning} positioning how the overlay is
+ * positioned relative to its point on the map.
+ * @observable
+ * @api
+ol.Overlay.prototype.setPositioning = function(positioning) {
+ this.set(ol.Overlay.Property_.POSITIONING, positioning);
+ * Modify the visibility of the element.
+ * @param {boolean} visible Element visibility.
+ * @protected
+ol.Overlay.prototype.setVisible = function(visible) {
+ if (this.rendered_.visible !== visible) {
+ this.element_.style.display = visible ? '' : 'none';
+ this.rendered_.visible = visible;
+ * Update pixel position.
+ * @protected
+ol.Overlay.prototype.updatePixelPosition = function() {
+ var position = this.getPosition();
+ if (!map || !map.isRendered() || !position) {
+ this.setVisible(false);
+ return;
+ var pixel = map.getPixelFromCoordinate(position);
+ var mapSize = map.getSize();
+ this.updateRenderedPosition(pixel, mapSize);
+ * @param {ol.Pixel} pixel The pixel location.
+ * @param {ol.Size|undefined} mapSize The map size.
+ * @protected
+ol.Overlay.prototype.updateRenderedPosition = function(pixel, mapSize) {
+ var style = this.element_.style;
+ var offset = this.getOffset();
+ var positioning = this.getPositioning();
+ this.setVisible(true);
+ var offsetX = offset[0];
+ var offsetY = offset[1];
+ if (positioning == ol.OverlayPositioning.BOTTOM_RIGHT ||
+ positioning == ol.OverlayPositioning.CENTER_RIGHT ||
+ positioning == ol.OverlayPositioning.TOP_RIGHT) {
+ if (this.rendered_.left_ !== '') {
+ this.rendered_.left_ = style.left = '';
+ var right = Math.round(mapSize[0] - pixel[0] - offsetX) + 'px';
+ if (this.rendered_.right_ != right) {
+ this.rendered_.right_ = style.right = right;
+ } else {
+ if (this.rendered_.right_ !== '') {
+ this.rendered_.right_ = style.right = '';
+ if (positioning == ol.OverlayPositioning.BOTTOM_CENTER ||
+ positioning == ol.OverlayPositioning.CENTER_CENTER ||
+ positioning == ol.OverlayPositioning.TOP_CENTER) {
+ offsetX -= this.element_.offsetWidth / 2;
+ var left = Math.round(pixel[0] + offsetX) + 'px';
+ if (this.rendered_.left_ != left) {
+ this.rendered_.left_ = style.left = left;
+ if (positioning == ol.OverlayPositioning.BOTTOM_LEFT ||
+ positioning == ol.OverlayPositioning.BOTTOM_CENTER ||
+ positioning == ol.OverlayPositioning.BOTTOM_RIGHT) {
+ if (this.rendered_.top_ !== '') {
+ this.rendered_.top_ = style.top = '';
+ var bottom = Math.round(mapSize[1] - pixel[1] - offsetY) + 'px';
+ if (this.rendered_.bottom_ != bottom) {
+ this.rendered_.bottom_ = style.bottom = bottom;
+ } else {
+ if (this.rendered_.bottom_ !== '') {
+ this.rendered_.bottom_ = style.bottom = '';
+ if (positioning == ol.OverlayPositioning.CENTER_LEFT ||
+ positioning == ol.OverlayPositioning.CENTER_RIGHT) {
+ offsetY -= this.element_.offsetHeight / 2;
+ var top = Math.round(pixel[1] + offsetY) + 'px';
+ if (this.rendered_.top_ != top) {
+ this.rendered_.top_ = style.top = top;
+ * @enum {string}
+ * @private
+ol.Overlay.Property_ = {
+ ELEMENT: 'element',
+ MAP: 'map',
+ OFFSET: 'offset',
+ POSITION: 'position',
+ POSITIONING: 'positioning'
+goog.provide('ol.control.OverviewMap');
+goog.require('ol.Map');
+goog.require('ol.Overlay');
+goog.require('ol.ViewProperty');
+goog.require('ol.control.Control');
+goog.require('ol.coordinate');
+goog.require('ol.css');
+goog.require('ol.dom');
+goog.require('ol.events');
+ * Create a new control with a map acting as an overview map for an other
+ * defined map.
+ * @constructor
+ * @extends {ol.control.Control}
+ * @param {olx.control.OverviewMapOptions=} opt_options OverviewMap options.
+ * @api
+ol.control.OverviewMap = function(opt_options) {
+ var options = opt_options ? opt_options : {};
+ * @type {boolean}
+ * @private
+ this.collapsed_ = options.collapsed !== undefined ? options.collapsed : true;
+ * @private
+ * @type {boolean}
+ this.collapsible_ = options.collapsible !== undefined ?
+ options.collapsible : true;
+ if (!this.collapsible_) {
+ this.collapsed_ = false;
+ var className = options.className !== undefined ? options.className : 'ol-overviewmap';
+ var tipLabel = options.tipLabel !== undefined ? options.tipLabel : 'Overview map';
+ var collapseLabel = options.collapseLabel !== undefined ? options.collapseLabel : '\u00AB';
+ if (typeof collapseLabel === 'string') {
+ * @private
+ * @type {Node}
+ this.collapseLabel_ = document.createElement('span');
+ this.collapseLabel_.textContent = collapseLabel;
+ } else {
+ this.collapseLabel_ = collapseLabel;
+ var label = options.label !== undefined ? options.label : '\u00BB';
+ if (typeof label === 'string') {
+ * @private
+ * @type {Node}
+ this.label_ = document.createElement('span');
+ this.label_.textContent = label;
+ } else {
+ this.label_ = label;
+ var activeLabel = (this.collapsible_ && !this.collapsed_) ?
+ this.collapseLabel_ : this.label_;
+ var button = document.createElement('button');
+ button.setAttribute('type', 'button');
+ button.title = tipLabel;
+ button.appendChild(activeLabel);
+ ol.events.listen(button, ol.events.EventType.CLICK,
+ this.handleClick_, this);
+ * @type {Element}
+ * @private
+ this.ovmapDiv_ = document.createElement('DIV');
+ this.ovmapDiv_.className = 'ol-overviewmap-map';
+ * @type {ol.Map}
+ * @private
+ this.ovmap_ = new ol.Map({
+ controls: new ol.Collection(),
+ interactions: new ol.Collection(),
+ view: options.view
+ var ovmap = this.ovmap_;
+ if (options.layers) {
+ options.layers.forEach(
+ * @param {ol.layer.Layer} layer Layer.
+ function(layer) {
+ ovmap.addLayer(layer);
+ }, this);
+ var box = document.createElement('DIV');
+ box.className = 'ol-overviewmap-box';
+ box.style.boxSizing = 'border-box';
+ * @type {ol.Overlay}
+ * @private
+ this.boxOverlay_ = new ol.Overlay({
+ position: [0, 0],
+ positioning: ol.OverlayPositioning.BOTTOM_LEFT,
+ element: box
+ this.ovmap_.addOverlay(this.boxOverlay_);
+ var cssClasses = className + ' ' + ol.css.CLASS_UNSELECTABLE + ' ' +
+ ol.css.CLASS_CONTROL +
+ (this.collapsed_ && this.collapsible_ ? ' ol-collapsed' : '') +
+ (this.collapsible_ ? '' : ' ol-uncollapsible');
+ var element = document.createElement('div');
+ element.className = cssClasses;
+ element.appendChild(this.ovmapDiv_);
+ element.appendChild(button);
+ var render = options.render ? options.render : ol.control.OverviewMap.render;
+ ol.control.Control.call(this, {
+ element: element,
+ render: render,
+ target: options.target
+ /* Interactive map */
+ var scope = this;
+ var overlay = this.boxOverlay_;
+ var overlayBox = this.boxOverlay_.getElement();
+ /* Functions definition */
+ var computeDesiredMousePosition = function(mousePosition) {
+ return {
+ clientX: mousePosition.clientX - (overlayBox.offsetWidth / 2),
+ clientY: mousePosition.clientY + (overlayBox.offsetHeight / 2)
+ var move = function(event) {
+ var coordinates = ovmap.getEventCoordinate(computeDesiredMousePosition(event));
+ overlay.setPosition(coordinates);
+ var endMoving = function(event) {
+ var coordinates = ovmap.getEventCoordinate(event);
+ scope.getMap().getView().setCenter(coordinates);
+ window.removeEventListener('mousemove', move);
+ window.removeEventListener('mouseup', endMoving);
+ /* Binding */
+ overlayBox.addEventListener('mousedown', function() {
+ window.addEventListener('mousemove', move);
+ window.addEventListener('mouseup', endMoving);
+ol.inherits(ol.control.OverviewMap, ol.control.Control);
+ * @inheritDoc
+ * @api
+ol.control.OverviewMap.prototype.setMap = function(map) {
+ var oldMap = this.getMap();
+ if (map === oldMap) {
+ return;
+ if (oldMap) {
+ var oldView = oldMap.getView();
+ if (oldView) {
+ this.unbindView_(oldView);
+ this.ovmap_.setTarget(null);
+ ol.control.Control.prototype.setMap.call(this, map);
+ if (map) {
+ this.ovmap_.setTarget(this.ovmapDiv_);
+ this.listenerKeys.push(ol.events.listen(
+ map, ol.ObjectEventType.PROPERTYCHANGE,
+ this.handleMapPropertyChange_, this));
+ // TODO: to really support map switching, this would need to be reworked
+ if (this.ovmap_.getLayers().getLength() === 0) {
+ this.ovmap_.setLayerGroup(map.getLayerGroup());
+ var view = map.getView();
+ if (view) {
+ this.bindView_(view);
+ if (view.isDef()) {
+ this.ovmap_.updateSize();
+ this.resetExtent_();
+ * Handle map property changes. This only deals with changes to the map's view.
+ * @param {ol.Object.Event} event The propertychange event.
+ * @private
+ol.control.OverviewMap.prototype.handleMapPropertyChange_ = function(event) {
+ if (event.key === ol.MapProperty.VIEW) {
+ var oldView = /** @type {ol.View} */ (event.oldValue);
+ if (oldView) {
+ var newView = this.getMap().getView();
+ this.bindView_(newView);
+ * Register listeners for view property changes.
+ * @param {ol.View} view The view.
+ * @private
+ol.control.OverviewMap.prototype.bindView_ = function(view) {
+ ol.events.listen(view,
+ ol.Object.getChangeEventType(ol.ViewProperty.ROTATION),
+ this.handleRotationChanged_, this);
+ * Unregister listeners for view property changes.
+ * @private
+ol.control.OverviewMap.prototype.unbindView_ = function(view) {
+ ol.events.unlisten(view,
+ * Handle rotation changes to the main map.
+ * TODO: This should rotate the extent rectrangle instead of the
+ * overview map's view.
+ * @private
+ol.control.OverviewMap.prototype.handleRotationChanged_ = function() {
+ this.ovmap_.getView().setRotation(this.getMap().getView().getRotation());
+ * Update the overview map element.
+ * @param {ol.MapEvent} mapEvent Map event.
+ * @this {ol.control.OverviewMap}
+ * @api
+ol.control.OverviewMap.render = function(mapEvent) {
+ this.validateExtent_();
+ this.updateBox_();
+ * Reset the overview map extent if the box size (width or
+ * height) is less than the size of the overview map size times minRatio
+ * or is greater than the size of the overview size times maxRatio.
+ * If the map extent was not reset, the box size can fits in the defined
+ * ratio sizes. This method then checks if is contained inside the overview
+ * map current extent. If not, recenter the overview map to the current
+ * main map center location.
+ * @private
+ol.control.OverviewMap.prototype.validateExtent_ = function() {
+ var map = this.getMap();
+ if (!map.isRendered() || !ovmap.isRendered()) {
+ return;
+ var mapSize = /** @type {ol.Size} */ (map.getSize());
+ var extent = view.calculateExtent(mapSize);
+ var ovmapSize = /** @type {ol.Size} */ (ovmap.getSize());
+ var ovview = ovmap.getView();
+ var ovextent = ovview.calculateExtent(ovmapSize);
+ var topLeftPixel =
+ ovmap.getPixelFromCoordinate(ol.extent.getTopLeft(extent));
+ var bottomRightPixel =
+ ovmap.getPixelFromCoordinate(ol.extent.getBottomRight(extent));
+ var boxWidth = Math.abs(topLeftPixel[0] - bottomRightPixel[0]);
+ var boxHeight = Math.abs(topLeftPixel[1] - bottomRightPixel[1]);
+ var ovmapWidth = ovmapSize[0];
+ var ovmapHeight = ovmapSize[1];
+ if (boxWidth < ovmapWidth * ol.OVERVIEWMAP_MIN_RATIO ||
+ boxHeight < ovmapHeight * ol.OVERVIEWMAP_MIN_RATIO ||
+ boxWidth > ovmapWidth * ol.OVERVIEWMAP_MAX_RATIO ||
+ boxHeight > ovmapHeight * ol.OVERVIEWMAP_MAX_RATIO) {
+ } else if (!ol.extent.containsExtent(ovextent, extent)) {
+ this.recenter_();
+ * Reset the overview map extent to half calculated min and max ratio times
+ * the extent of the main map.
+ * @private
+ol.control.OverviewMap.prototype.resetExtent_ = function() {
+ if (ol.OVERVIEWMAP_MAX_RATIO === 0 || ol.OVERVIEWMAP_MIN_RATIO === 0) {
+ return;
+ // get how many times the current map overview could hold different
+ // box sizes using the min and max ratio, pick the step in the middle used
+ // to calculate the extent from the main map to set it to the overview map,
+ var steps = Math.log(
+ ol.OVERVIEWMAP_MAX_RATIO / ol.OVERVIEWMAP_MIN_RATIO) / Math.LN2;
+ var ratio = 1 / (Math.pow(2, steps / 2) * ol.OVERVIEWMAP_MIN_RATIO);
+ ol.extent.scaleFromCenter(extent, ratio);
+ ovview.fit(extent);
+ * Set the center of the overview map to the map center without changing its
+ * resolution.
+ * @private
+ol.control.OverviewMap.prototype.recenter_ = function() {
+ ovview.setCenter(view.getCenter());
+ * Update the box using the main map extent
+ * @private
+ol.control.OverviewMap.prototype.updateBox_ = function() {
+ return;
+ var rotation = view.getRotation();
+ var box = this.boxOverlay_.getElement();
+ var ovresolution = ovview.getResolution();
+ var bottomLeft = ol.extent.getBottomLeft(extent);
+ var topRight = ol.extent.getTopRight(extent);
+ // set position using bottom left coordinates
+ var rotateBottomLeft = this.calculateCoordinateRotate_(rotation, bottomLeft);
+ overlay.setPosition(rotateBottomLeft);
+ // set box size calculated from map extent size and overview map resolution
+ if (box) {
+ box.style.width = Math.abs((bottomLeft[0] - topRight[0]) / ovresolution) + 'px';
+ box.style.height = Math.abs((topRight[1] - bottomLeft[1]) / ovresolution) + 'px';
+ * @param {number} rotation Target rotation.
+ * @param {ol.Coordinate} coordinate Coordinate.
+ * @return {ol.Coordinate|undefined} Coordinate for rotation and center anchor.
+ * @private
+ol.control.OverviewMap.prototype.calculateCoordinateRotate_ = function(
+ rotation, coordinate) {
+ var coordinateRotate;
+ var currentCenter = view.getCenter();
+ if (currentCenter) {
+ coordinateRotate = [
+ coordinate[0] - currentCenter[0],
+ coordinate[1] - currentCenter[1]
+ ol.coordinate.rotate(coordinateRotate, rotation);
+ ol.coordinate.add(coordinateRotate, currentCenter);
+ return coordinateRotate;
+ * @param {Event} event The event to handle
+ * @private
+ol.control.OverviewMap.prototype.handleClick_ = function(event) {
+ event.preventDefault();
+ this.handleToggle_();
+ * @private
+ol.control.OverviewMap.prototype.handleToggle_ = function() {
+ this.element.classList.toggle('ol-collapsed');
+ if (this.collapsed_) {
+ ol.dom.replaceNode(this.collapseLabel_, this.label_);
+ } else {
+ ol.dom.replaceNode(this.label_, this.collapseLabel_);
+ this.collapsed_ = !this.collapsed_;
+ // manage overview map if it had not been rendered before and control
+ // is expanded
+ if (!this.collapsed_ && !ovmap.isRendered()) {
+ ovmap.updateSize();
+ ol.events.listenOnce(ovmap, ol.MapEventType.POSTRENDER,
+ function(event) {
+ this);
+ * Return `true` if the overview map is collapsible, `false` otherwise.
+ * @return {boolean} True if the widget is collapsible.
+ * @api
+ol.control.OverviewMap.prototype.getCollapsible = function() {
+ return this.collapsible_;
+ * Set whether the overview map should be collapsible.
+ * @param {boolean} collapsible True if the widget is collapsible.
+ * @api
+ol.control.OverviewMap.prototype.setCollapsible = function(collapsible) {
+ if (this.collapsible_ === collapsible) {
+ return;
+ this.collapsible_ = collapsible;
+ this.element.classList.toggle('ol-uncollapsible');
+ if (!collapsible && this.collapsed_) {
+ * Collapse or expand the overview map according to the passed parameter. Will
+ * not do anything if the overview map isn't collapsible or if the current
+ * collapsed state is already the one requested.
+ * @param {boolean} collapsed True if the widget is collapsed.
+ * @api
+ol.control.OverviewMap.prototype.setCollapsed = function(collapsed) {
+ if (!this.collapsible_ || this.collapsed_ === collapsed) {
+ return;
+ * Determine if the overview map is collapsed.
+ * @return {boolean} The overview map is collapsed.
+ * @api
+ol.control.OverviewMap.prototype.getCollapsed = function() {
+ return this.collapsed_;
+ * Return the overview map.
+ * @return {ol.Map} Overview map.
+ * @api
+ol.control.OverviewMap.prototype.getOverviewMap = function() {
+ return this.ovmap_;
+goog.provide('ol.control.ScaleLineUnits');
+ * Units for the scale line. Supported values are `'degrees'`, `'imperial'`,
+ * `'nautical'`, `'metric'`, `'us'`.
+ * @enum {string}
+ol.control.ScaleLineUnits = {
+ DEGREES: 'degrees',
+ IMPERIAL: 'imperial',
+ NAUTICAL: 'nautical',
+ METRIC: 'metric',
+ US: 'us'
+goog.provide('ol.control.ScaleLine');
+goog.require('ol.Object');
+goog.require('ol.asserts');
+goog.require('ol.control.ScaleLineUnits');
+goog.require('ol.proj');
+goog.require('ol.proj.Units');
+ * @classdesc
+ * A control displaying rough y-axis distances, calculated for the center of the
+ * viewport. For conformal projections (e.g. EPSG:3857, the default view
+ * projection in OpenLayers), the scale is valid for all directions.
+ * No scale line will be shown when the y-axis distance of a pixel at the
+ * viewport center cannot be calculated in the view projection.
+ * By default the scale line will show in the bottom left portion of the map,
+ * but this can be changed by using the css selector `.ol-scale-line`.
+ * @constructor
+ * @param {olx.control.ScaleLineOptions=} opt_options Scale line options.
+ * @api
+ol.control.ScaleLine = function(opt_options) {
+ var className = options.className !== undefined ? options.className : 'ol-scale-line';
+ * @private
+ * @type {Element}
+ this.innerElement_ = document.createElement('DIV');
+ this.innerElement_.className = className + '-inner';
+ * @private
+ * @type {Element}
+ this.element_.className = className + ' ' + ol.css.CLASS_UNSELECTABLE;
+ this.element_.appendChild(this.innerElement_);
+ * @private
+ * @type {?olx.ViewState}
+ this.viewState_ = null;
+ * @private
+ * @type {number}
+ this.minWidth_ = options.minWidth !== undefined ? options.minWidth : 64;
+ * @private
+ * @type {boolean}
+ this.renderedVisible_ = false;
+ * @private
+ * @type {number|undefined}
+ this.renderedWidth_ = undefined;
+ * @private
+ * @type {string}
+ this.renderedHTML_ = '';
+ var render = options.render ? options.render : ol.control.ScaleLine.render;
+ element: this.element_,
+ render: render,
+ ol.events.listen(
+ this, ol.Object.getChangeEventType(ol.control.ScaleLine.Property_.UNITS),
+ this.handleUnitsChanged_, this);
+ this.setUnits(/** @type {ol.control.ScaleLineUnits} */ (options.units) ||
+ ol.control.ScaleLineUnits.METRIC);
+ol.inherits(ol.control.ScaleLine, ol.control.Control);
+ * @const
+ * @type {Array.<number>}
+ol.control.ScaleLine.LEADING_DIGITS = [1, 2, 5];
+ * Return the units to use in the scale line.
+ * @return {ol.control.ScaleLineUnits|undefined} The units to use in the scale
+ * line.
+ * @observable
+ * @api
+ol.control.ScaleLine.prototype.getUnits = function() {
+ return /** @type {ol.control.ScaleLineUnits|undefined} */ (
+ this.get(ol.control.ScaleLine.Property_.UNITS));
+ * Update the scale line element.
+ * @this {ol.control.ScaleLine}
+ * @api
+ol.control.ScaleLine.render = function(mapEvent) {
+ var frameState = mapEvent.frameState;
+ if (!frameState) {
+ } else {
+ this.viewState_ = frameState.viewState;
+ this.updateElement_();
+ * @private
+ol.control.ScaleLine.prototype.handleUnitsChanged_ = function() {
+ * Set the units to use in the scale line.
+ * @param {ol.control.ScaleLineUnits} units The units to use in the scale line.
+ * @observable
+ * @api
+ol.control.ScaleLine.prototype.setUnits = function(units) {
+ this.set(ol.control.ScaleLine.Property_.UNITS, units);
+ * @private
+ol.control.ScaleLine.prototype.updateElement_ = function() {
+ var viewState = this.viewState_;
+ if (!viewState) {
+ if (this.renderedVisible_) {
+ this.element_.style.display = 'none';
+ return;
+ var center = viewState.center;
+ var projection = viewState.projection;
+ var metersPerUnit = projection.getMetersPerUnit();
+ var pointResolution =
+ ol.proj.getPointResolution(projection, viewState.resolution, center) *
+ metersPerUnit;
+ var nominalCount = this.minWidth_ * pointResolution;
+ var suffix = '';
+ var units = this.getUnits();
+ if (units == ol.control.ScaleLineUnits.DEGREES) {
+ var metersPerDegree = ol.proj.METERS_PER_UNIT[ol.proj.Units.DEGREES];
+ pointResolution /= metersPerDegree;
+ if (nominalCount < metersPerDegree / 60) {
+ suffix = '\u2033'; // seconds
+ pointResolution *= 3600;
+ } else if (nominalCount < metersPerDegree) {
+ suffix = '\u2032'; // minutes
+ pointResolution *= 60;
+ } else {
+ suffix = '\u00b0'; // degrees
+ } else if (units == ol.control.ScaleLineUnits.IMPERIAL) {
+ if (nominalCount < 0.9144) {
+ suffix = 'in';
+ pointResolution /= 0.0254;
+ } else if (nominalCount < 1609.344) {
+ suffix = 'ft';
+ pointResolution /= 0.3048;
+ } else {
+ suffix = 'mi';
+ pointResolution /= 1609.344;
+ } else if (units == ol.control.ScaleLineUnits.NAUTICAL) {
+ pointResolution /= 1852;
+ suffix = 'nm';
+ } else if (units == ol.control.ScaleLineUnits.METRIC) {
+ if (nominalCount < 0.001) {
+ suffix = 'μm';
+ pointResolution *= 1000000;
+ } else if (nominalCount < 1) {
+ suffix = 'mm';
+ pointResolution *= 1000;
+ } else if (nominalCount < 1000) {
+ suffix = 'm';
+ } else {
+ suffix = 'km';
+ pointResolution /= 1000;
+ } else if (units == ol.control.ScaleLineUnits.US) {
+ suffix = 'in';
+ pointResolution *= 39.37;
+ suffix = 'ft';
+ pointResolution /= 0.30480061;
+ } else {
+ suffix = 'mi';
+ pointResolution /= 1609.3472;
+ } else {
+ ol.asserts.assert(false, 33); // Invalid units
+ var i = 3 * Math.floor(
+ Math.log(this.minWidth_ * pointResolution) / Math.log(10));
+ var count, width;
+ while (true) {
+ count = ol.control.ScaleLine.LEADING_DIGITS[((i % 3) + 3) % 3] *
+ Math.pow(10, Math.floor(i / 3));
+ width = Math.round(count / pointResolution);
+ if (isNaN(width)) {
+ return;
+ } else if (width >= this.minWidth_) {
+ break;
+ ++i;
+ var html = count + ' ' + suffix;
+ if (this.renderedHTML_ != html) {
+ this.innerElement_.innerHTML = html;
+ this.renderedHTML_ = html;
+ if (this.renderedWidth_ != width) {
+ this.innerElement_.style.width = width + 'px';
+ this.renderedWidth_ = width;
+ if (!this.renderedVisible_) {
+ this.element_.style.display = '';
+ this.renderedVisible_ = true;
+ * @enum {string}
+ * @private
+ol.control.ScaleLine.Property_ = {
+ UNITS: 'units'
+// FIXME should possibly show tooltip when dragging?
+goog.provide('ol.control.ZoomSlider');
+goog.require('ol.ViewHint');
+goog.require('ol.easing');
+goog.require('ol.events.Event');
+goog.require('ol.events.EventType');
+goog.require('ol.math');
+goog.require('ol.pointer.EventType');
+goog.require('ol.pointer.PointerEventHandler');
+ * @classdesc
+ * A slider type of control for zooming.
+ * Example:
+ * map.addControl(new ol.control.ZoomSlider());
+ * @constructor
+ * @param {olx.control.ZoomSliderOptions=} opt_options Zoom slider options.
+ * @api
+ol.control.ZoomSlider = function(opt_options) {
+ * Will hold the current resolution of the view.
+ * @private
+ this.currentResolution_ = undefined;
+ * The direction of the slider. Will be determined from actual display of the
+ * container and defaults to ol.control.ZoomSlider.Direction_.VERTICAL.
+ * @type {ol.control.ZoomSlider.Direction_}
+ * @private
+ this.direction_ = ol.control.ZoomSlider.Direction_.VERTICAL;
+ * @type {boolean}
+ * @private
+ this.dragging_;
+ * @type {number}
+ * @private
+ this.heightLimit_ = 0;
+ * @type {number}
+ * @private
+ this.widthLimit_ = 0;
+ * @private
+ this.previousX_;
+ * @private
+ this.previousY_;
+ * The calculated thumb size (border box plus margins). Set when initSlider_
+ * is called.
+ * @type {ol.Size}
+ * @private
+ this.thumbSize_ = null;
+ * Whether the slider is initialized.
+ * @type {boolean}
+ * @private
+ this.sliderInitialized_ = false;
+ * @type {number}
+ * @private
+ this.duration_ = options.duration !== undefined ? options.duration : 200;
+ var className = options.className !== undefined ? options.className : 'ol-zoomslider';
+ var thumbElement = document.createElement('button');
+ thumbElement.setAttribute('type', 'button');
+ thumbElement.className = className + '-thumb ' + ol.css.CLASS_UNSELECTABLE;
+ var containerElement = document.createElement('div');
+ containerElement.className = className + ' ' + ol.css.CLASS_UNSELECTABLE + ' ' + ol.css.CLASS_CONTROL;
+ containerElement.appendChild(thumbElement);
+ * @type {ol.pointer.PointerEventHandler}
+ * @private
+ this.dragger_ = new ol.pointer.PointerEventHandler(containerElement);
+ ol.events.listen(this.dragger_, ol.pointer.EventType.POINTERDOWN,
+ this.handleDraggerStart_, this);
+ ol.events.listen(this.dragger_, ol.pointer.EventType.POINTERMOVE,
+ this.handleDraggerDrag_, this);
+ ol.events.listen(this.dragger_, ol.pointer.EventType.POINTERUP,
+ this.handleDraggerEnd_, this);
+ ol.events.listen(containerElement, ol.events.EventType.CLICK,
+ this.handleContainerClick_, this);
+ ol.events.listen(thumbElement, ol.events.EventType.CLICK,
+ ol.events.Event.stopPropagation);
+ var render = options.render ? options.render : ol.control.ZoomSlider.render;
+ element: containerElement,
+ render: render
+ol.inherits(ol.control.ZoomSlider, ol.control.Control);
+ * @inheritDoc
+ol.control.ZoomSlider.prototype.disposeInternal = function() {
+ this.dragger_.dispose();
+ ol.control.Control.prototype.disposeInternal.call(this);
+ * The enum for available directions.
+ * @enum {number}
+ * @private
+ol.control.ZoomSlider.Direction_ = {
+ VERTICAL: 0,
+ HORIZONTAL: 1
+ * @inheritDoc
+ol.control.ZoomSlider.prototype.setMap = function(map) {
+ if (map) {
+ map.render();
+ * Initializes the slider element. This will determine and set this controls
+ * direction_ and also constrain the dragging of the thumb to always be within
+ * the bounds of the container.
+ * @private
+ol.control.ZoomSlider.prototype.initSlider_ = function() {
+ var container = this.element;
+ var containerSize = {
+ width: container.offsetWidth, height: container.offsetHeight
+ var thumb = container.firstElementChild;
+ var computedStyle = getComputedStyle(thumb);
+ var thumbWidth = thumb.offsetWidth +
+ parseFloat(computedStyle['marginRight']) +
+ parseFloat(computedStyle['marginLeft']);
+ var thumbHeight = thumb.offsetHeight +
+ parseFloat(computedStyle['marginTop']) +
+ parseFloat(computedStyle['marginBottom']);
+ this.thumbSize_ = [thumbWidth, thumbHeight];
+ if (containerSize.width > containerSize.height) {
+ this.direction_ = ol.control.ZoomSlider.Direction_.HORIZONTAL;
+ this.widthLimit_ = containerSize.width - thumbWidth;
+ } else {
+ this.heightLimit_ = containerSize.height - thumbHeight;
+ this.sliderInitialized_ = true;
+ * Update the zoomslider element.
+ * @this {ol.control.ZoomSlider}
+ * @api
+ol.control.ZoomSlider.render = function(mapEvent) {
+ if (!mapEvent.frameState) {
+ return;
+ if (!this.sliderInitialized_) {
+ this.initSlider_();
+ var res = mapEvent.frameState.viewState.resolution;
+ if (res !== this.currentResolution_) {
+ this.currentResolution_ = res;
+ this.setThumbPosition_(res);
+ * @param {Event} event The browser event to handle.
+ * @private
+ol.control.ZoomSlider.prototype.handleContainerClick_ = function(event) {
+ var view = this.getMap().getView();
+ var relativePosition = this.getRelativePosition_(
+ event.offsetX - this.thumbSize_[0] / 2,
+ event.offsetY - this.thumbSize_[1] / 2);
+ var resolution = this.getResolutionForPosition_(relativePosition);
+ view.animate({
+ resolution: view.constrainResolution(resolution),
+ duration: this.duration_,
+ easing: ol.easing.easeOut
+ * Handle dragger start events.
+ * @param {ol.pointer.PointerEvent} event The drag event.
+ * @private
+ol.control.ZoomSlider.prototype.handleDraggerStart_ = function(event) {
+ if (!this.dragging_ && event.originalEvent.target === this.element.firstElementChild) {
+ this.getMap().getView().setHint(ol.ViewHint.INTERACTING, 1);
+ this.previousX_ = event.clientX;
+ this.previousY_ = event.clientY;
+ this.dragging_ = true;
+ * Handle dragger drag events.
+ * @param {ol.pointer.PointerEvent|Event} event The drag event.
+ * @private
+ol.control.ZoomSlider.prototype.handleDraggerDrag_ = function(event) {
+ if (this.dragging_) {
+ var element = this.element.firstElementChild;
+ var deltaX = event.clientX - this.previousX_ + parseInt(element.style.left, 10);
+ var deltaY = event.clientY - this.previousY_ + parseInt(element.style.top, 10);
+ var relativePosition = this.getRelativePosition_(deltaX, deltaY);
+ this.currentResolution_ = this.getResolutionForPosition_(relativePosition);
+ this.getMap().getView().setResolution(this.currentResolution_);
+ this.setThumbPosition_(this.currentResolution_);
+ * Handle dragger end events.
+ * @private
+ol.control.ZoomSlider.prototype.handleDraggerEnd_ = function(event) {
+ view.setHint(ol.ViewHint.INTERACTING, -1);
+ view.animate({
+ resolution: view.constrainResolution(this.currentResolution_),
+ this.dragging_ = false;
+ this.previousX_ = undefined;
+ this.previousY_ = undefined;
+ * Positions the thumb inside its container according to the given resolution.
+ * @param {number} res The res.
+ * @private
+ol.control.ZoomSlider.prototype.setThumbPosition_ = function(res) {
+ var position = this.getPositionForResolution_(res);
+ var thumb = this.element.firstElementChild;
+ if (this.direction_ == ol.control.ZoomSlider.Direction_.HORIZONTAL) {
+ thumb.style.left = this.widthLimit_ * position + 'px';
+ } else {
+ thumb.style.top = this.heightLimit_ * position + 'px';
+ * Calculates the relative position of the thumb given x and y offsets. The
+ * relative position scales from 0 to 1. The x and y offsets are assumed to be
+ * in pixel units within the dragger limits.
+ * @param {number} x Pixel position relative to the left of the slider.
+ * @param {number} y Pixel position relative to the top of the slider.
+ * @return {number} The relative position of the thumb.
+ * @private
+ol.control.ZoomSlider.prototype.getRelativePosition_ = function(x, y) {
+ var amount;
+ if (this.direction_ === ol.control.ZoomSlider.Direction_.HORIZONTAL) {
+ amount = x / this.widthLimit_;
+ } else {
+ amount = y / this.heightLimit_;
+ return ol.math.clamp(amount, 0, 1);
+ * Calculates the corresponding resolution of the thumb given its relative
+ * position (where 0 is the minimum and 1 is the maximum).
+ * @param {number} position The relative position of the thumb.
+ * @return {number} The corresponding resolution.
+ * @private
+ol.control.ZoomSlider.prototype.getResolutionForPosition_ = function(position) {
+ var fn = this.getMap().getView().getResolutionForValueFunction();
+ return fn(1 - position);
+ * Determines the relative position of the slider for the given resolution. A
+ * relative position of 0 corresponds to the minimum view resolution. A
+ * relative position of 1 corresponds to the maximum view resolution.
+ * @param {number} res The resolution.
+ * @return {number} The relative position value (between 0 and 1).
+ * @private
+ol.control.ZoomSlider.prototype.getPositionForResolution_ = function(res) {
+ var fn = this.getMap().getView().getValueForResolutionFunction();
+ return 1 - fn(res);
+goog.provide('ol.control.ZoomToExtent');
+ * @classdesc
+ * A button control which, when pressed, changes the map view to a specific
+ * extent. To style this control use the css selector `.ol-zoom-extent`.
+ * @constructor
+ * @param {olx.control.ZoomToExtentOptions=} opt_options Options.
+ * @api
+ol.control.ZoomToExtent = function(opt_options) {
+ * @type {ol.Extent}
+ * @private
+ this.extent_ = options.extent ? options.extent : null;
+ 'ol-zoom-extent';
+ var label = options.label !== undefined ? options.label : 'E';
+ options.tipLabel : 'Fit to extent';
+ typeof label === 'string' ? document.createTextNode(label) : label
+ element: element,
+ol.inherits(ol.control.ZoomToExtent, ol.control.Control);
+ * @private
+ol.control.ZoomToExtent.prototype.handleClick_ = function(event) {
+ this.handleZoomToExtent_();
+ * @private
+ol.control.ZoomToExtent.prototype.handleZoomToExtent_ = function() {
+ var extent = !this.extent_ ? view.getProjection().getExtent() : this.extent_;
+ view.fit(extent);
+goog.provide('ol.DeviceOrientation');
+goog.require('ol.has');
+ * @classdesc
+ * The ol.DeviceOrientation class provides access to information from
+ * DeviceOrientation events. See the [HTML 5 DeviceOrientation Specification](
+ * http://www.w3.org/TR/orientation-event/) for more details.
+ * Many new computers, and especially mobile phones
+ * and tablets, provide hardware support for device orientation. Web
+ * developers targeting mobile devices will be especially interested in this
+ * class.
+ * Device orientation data are relative to a common starting point. For mobile
+ * devices, the starting point is to lay your phone face up on a table with the
+ * top of the phone pointing north. This represents the zero state. All
+ * angles are then relative to this state. For computers, it is the same except
+ * the screen is open at 90 degrees.
+ * Device orientation is reported as three angles - `alpha`, `beta`, and
+ * `gamma` - relative to the starting position along the three planar axes X, Y
+ * and Z. The X axis runs from the left edge to the right edge through the
+ * middle of the device. Similarly, the Y axis runs from the bottom to the top
+ * of the device through the middle. The Z axis runs from the back to the front
+ * through the middle. In the starting position, the X axis points to the
+ * right, the Y axis points away from you and the Z axis points straight up
+ * from the device lying flat.
+ * The three angles representing the device orientation are relative to the
+ * three axes. `alpha` indicates how much the device has been rotated around the
+ * Z axis, which is commonly interpreted as the compass heading (see note
+ * below). `beta` indicates how much the device has been rotated around the X
+ * axis, or how much it is tilted from front to back. `gamma` indicates how
+ * much the device has been rotated around the Y axis, or how much it is tilted
+ * from left to right.
+ * For most browsers, the `alpha` value returns the compass heading so if the
+ * device points north, it will be 0. With Safari on iOS, the 0 value of
+ * `alpha` is calculated from when device orientation was first requested.
+ * ol.DeviceOrientation provides the `heading` property which normalizes this
+ * behavior across all browsers for you.
+ * It is important to note that the HTML 5 DeviceOrientation specification
+ * indicates that `alpha`, `beta` and `gamma` are in degrees while the
+ * equivalent properties in ol.DeviceOrientation are in radians for consistency
+ * with all other uses of angles throughout OpenLayers.
+ * To get notified of device orientation changes, register a listener for the
+ * generic `change` event on your `ol.DeviceOrientation` instance.
+ * @see {@link http://www.w3.org/TR/orientation-event/}
+ * @constructor
+ * @extends {ol.Object}
+ * @param {olx.DeviceOrientationOptions=} opt_options Options.
+ * @api
+ol.DeviceOrientation = function(opt_options) {
+ ol.Object.call(this);
+ * @private
+ * @type {?ol.EventsKey}
+ this.listenerKey_ = null;
+ ol.events.listen(this,
+ ol.Object.getChangeEventType(ol.DeviceOrientation.Property_.TRACKING),
+ this.handleTrackingChanged_, this);
+ this.setTracking(options.tracking !== undefined ? options.tracking : false);
+ol.inherits(ol.DeviceOrientation, ol.Object);
+ * @inheritDoc
+ol.DeviceOrientation.prototype.disposeInternal = function() {
+ this.setTracking(false);
+ ol.Object.prototype.disposeInternal.call(this);
+ * @private
+ * @param {Event} originalEvent Event.
+ol.DeviceOrientation.prototype.orientationChange_ = function(originalEvent) {
+ var event = /** @type {DeviceOrientationEvent} */ (originalEvent);
+ if (event.alpha !== null) {
+ var alpha = ol.math.toRadians(event.alpha);
+ this.set(ol.DeviceOrientation.Property_.ALPHA, alpha);
+ // event.absolute is undefined in iOS.
+ if (typeof event.absolute === 'boolean' && event.absolute) {
+ this.set(ol.DeviceOrientation.Property_.HEADING, alpha);
+ } else if (typeof event.webkitCompassHeading === 'number' &&
+ event.webkitCompassAccuracy != -1) {
+ var heading = ol.math.toRadians(event.webkitCompassHeading);
+ this.set(ol.DeviceOrientation.Property_.HEADING, heading);
+ if (event.beta !== null) {
+ this.set(ol.DeviceOrientation.Property_.BETA,
+ ol.math.toRadians(event.beta));
+ if (event.gamma !== null) {
+ this.set(ol.DeviceOrientation.Property_.GAMMA,
+ ol.math.toRadians(event.gamma));
+ this.changed();
+ * Rotation around the device z-axis (in radians).
+ * @return {number|undefined} The euler angle in radians of the device from the
+ * standard Z axis.
+ * @observable
+ * @api
+ol.DeviceOrientation.prototype.getAlpha = function() {
+ return /** @type {number|undefined} */ (
+ this.get(ol.DeviceOrientation.Property_.ALPHA));
+ * Rotation around the device x-axis (in radians).
+ * planar X axis.
+ * @observable
+ * @api
+ol.DeviceOrientation.prototype.getBeta = function() {
+ this.get(ol.DeviceOrientation.Property_.BETA));
+ * Rotation around the device y-axis (in radians).
+ * planar Y axis.
+ * @observable
+ * @api
+ol.DeviceOrientation.prototype.getGamma = function() {
+ this.get(ol.DeviceOrientation.Property_.GAMMA));
+ * The heading of the device relative to north (in radians).
+ * @return {number|undefined} The heading of the device relative to north, in
+ * radians, normalizing for different browser behavior.
+ * @observable
+ * @api
+ol.DeviceOrientation.prototype.getHeading = function() {
+ this.get(ol.DeviceOrientation.Property_.HEADING));
+ * Determine if orientation is being tracked.
+ * @return {boolean} Changes in device orientation are being tracked.
+ * @observable
+ * @api
+ol.DeviceOrientation.prototype.getTracking = function() {
+ return /** @type {boolean} */ (
+ this.get(ol.DeviceOrientation.Property_.TRACKING));
+ * @private
+ol.DeviceOrientation.prototype.handleTrackingChanged_ = function() {
+ if (ol.has.DEVICE_ORIENTATION) {
+ var tracking = this.getTracking();
+ if (tracking && !this.listenerKey_) {
+ this.listenerKey_ = ol.events.listen(window, 'deviceorientation',
+ this.orientationChange_, this);
+ } else if (!tracking && this.listenerKey_ !== null) {
+ ol.events.unlistenByKey(this.listenerKey_);
+ * Enable or disable tracking of device orientation events.
+ * @param {boolean} tracking The status of tracking changes to alpha, beta and
+ * gamma. If true, changes are tracked and reported immediately.
+ * @observable
+ * @api
+ol.DeviceOrientation.prototype.setTracking = function(tracking) {
+ this.set(ol.DeviceOrientation.Property_.TRACKING, tracking);
+ * @enum {string}
+ * @private
+ol.DeviceOrientation.Property_ = {
+ ALPHA: 'alpha',
+ BETA: 'beta',
+ GAMMA: 'gamma',
+ HEADING: 'heading',
+ TRACKING: 'tracking'
+goog.provide('ol.ImageState');
+ * @enum {number}
+ol.ImageState = {
+ IDLE: 0,
+ LOADING: 1,
+ LOADED: 2,
+ ERROR: 3
+goog.provide('ol.style.Image');
+ * @classdesc
+ * A base class used for creating subclasses and not instantiated in
+ * apps. Base class for {@link ol.style.Icon}, {@link ol.style.Circle} and
+ * {@link ol.style.RegularShape}.
+ * @constructor
+ * @abstract
+ * @param {ol.StyleImageOptions} options Options.
+ * @api
+ol.style.Image = function(options) {
+ * @private
+ * @type {number}
+ this.opacity_ = options.opacity;
+ * @private
+ * @type {boolean}
+ this.rotateWithView_ = options.rotateWithView;
+ * @private
+ * @type {number}
+ this.rotation_ = options.rotation;
+ * @private
+ * @type {number}
+ this.scale_ = options.scale;
+ * @private
+ * @type {boolean}
+ this.snapToPixel_ = options.snapToPixel;
+ * Get the symbolizer opacity.
+ * @return {number} Opacity.
+ * @api
+ol.style.Image.prototype.getOpacity = function() {
+ return this.opacity_;
+ * Determine whether the symbolizer rotates with the map.
+ * @return {boolean} Rotate with map.
+ * @api
+ol.style.Image.prototype.getRotateWithView = function() {
+ return this.rotateWithView_;
+ * Get the symoblizer rotation.
+ * @return {number} Rotation.
+ * @api
+ol.style.Image.prototype.getRotation = function() {
+ return this.rotation_;
+ * Get the symbolizer scale.
+ * @return {number} Scale.
+ * @api
+ol.style.Image.prototype.getScale = function() {
+ return this.scale_;
+ * Determine whether the symbolizer should be snapped to a pixel.
+ * @return {boolean} The symbolizer should snap to a pixel.
+ * @api
+ol.style.Image.prototype.getSnapToPixel = function() {
+ return this.snapToPixel_;
+ * Get the anchor point in pixels. The anchor determines the center point for the
+ * symbolizer.
+ * @abstract
+ * @return {Array.<number>} Anchor.
+ol.style.Image.prototype.getAnchor = function() {};
+ * Get the image element for the symbolizer.
+ * @abstract
+ * @param {number} pixelRatio Pixel ratio.
+ * @return {HTMLCanvasElement|HTMLVideoElement|Image} Image element.
+ol.style.Image.prototype.getImage = function(pixelRatio) {};
+ * @abstract
+ol.style.Image.prototype.getHitDetectionImage = function(pixelRatio) {};
+ * @abstract
+ * @return {ol.ImageState} Image state.
+ol.style.Image.prototype.getImageState = function() {};
+ * @abstract
+ * @return {ol.Size} Image size.
+ol.style.Image.prototype.getImageSize = function() {};
+ * @abstract
+ * @return {ol.Size} Size of the hit-detection image.
+ol.style.Image.prototype.getHitDetectionImageSize = function() {};
+ * Get the origin of the symbolizer.
+ * @abstract
+ * @return {Array.<number>} Origin.
+ol.style.Image.prototype.getOrigin = function() {};
+ * Get the size of the symbolizer (in pixels).
+ * @abstract
+ * @return {ol.Size} Size.
+ol.style.Image.prototype.getSize = function() {};
+ * Set the opacity.
+ * @param {number} opacity Opacity.
+ * @api
+ol.style.Image.prototype.setOpacity = function(opacity) {
+ this.opacity_ = opacity;
+ * Set whether to rotate the style with the view.
+ * @param {boolean} rotateWithView Rotate with map.
+ol.style.Image.prototype.setRotateWithView = function(rotateWithView) {
+ this.rotateWithView_ = rotateWithView;
+ * Set the rotation.
+ * @param {number} rotation Rotation.
+ * @api
+ol.style.Image.prototype.setRotation = function(rotation) {
+ this.rotation_ = rotation;
+ * Set the scale.
+ * @param {number} scale Scale.
+ * @api
+ol.style.Image.prototype.setScale = function(scale) {
+ this.scale_ = scale;
+ * Set whether to snap the image to the closest pixel.
+ * @param {boolean} snapToPixel Snap to pixel?
+ol.style.Image.prototype.setSnapToPixel = function(snapToPixel) {
+ this.snapToPixel_ = snapToPixel;
+ * @abstract
+ * @param {function(this: T, ol.events.Event)} listener Listener function.
+ * @param {T} thisArg Value to use as `this` when executing `listener`.
+ * @return {ol.EventsKey|undefined} Listener key.
+ * @template T
+ol.style.Image.prototype.listenImageChange = function(listener, thisArg) {};
+ * Load not yet loaded URI.
+ * @abstract
+ol.style.Image.prototype.load = function() {};
+ * @abstract
+ * @template T
+ol.style.Image.prototype.unlistenImageChange = function(listener, thisArg) {};
+goog.provide('ol.style.RegularShape');
+goog.require('ol.colorlike');
+goog.require('ol.ImageState');
+goog.require('ol.render.canvas');
+goog.require('ol.style.Image');
+ * @classdesc
+ * Set regular shape style for vector features. The resulting shape will be
+ * a regular polygon when `radius` is provided, or a star when `radius1` and
+ * `radius2` are provided.
+ * @constructor
+ * @param {olx.style.RegularShapeOptions} options Options.
+ * @extends {ol.style.Image}
+ * @api
+ol.style.RegularShape = function(options) {
+ * @private
+ * @type {Array.<string>}
+ this.checksums_ = null;
+ * @private
+ * @type {HTMLCanvasElement}
+ this.canvas_ = null;
+ * @private
+ this.hitDetectionCanvas_ = null;
+ * @private
+ * @type {ol.style.Fill}
+ this.fill_ = options.fill !== undefined ? options.fill : null;
+ * @private
+ this.origin_ = [0, 0];
+ * @private
+ * @type {number}
+ this.points_ = options.points;
+ * @protected
+ * @type {number}
+ this.radius_ = /** @type {number} */ (options.radius !== undefined ?
+ options.radius : options.radius1);
+ * @private
+ * @type {number}
+ this.radius2_ =
+ options.radius2 !== undefined ? options.radius2 : this.radius_;
+ * @private
+ * @type {number}
+ this.angle_ = options.angle !== undefined ? options.angle : 0;
+ * @private
+ * @type {ol.style.Stroke}
+ this.stroke_ = options.stroke !== undefined ? options.stroke : null;
+ * @private
+ this.anchor_ = null;
+ * @private
+ * @type {ol.Size}
+ this.size_ = null;
+ * @private
+ * @type {ol.Size}
+ this.imageSize_ = null;
+ * @private
+ * @type {ol.Size}
+ this.hitDetectionImageSize_ = null;
+ * @protected
+ * @type {ol.style.AtlasManager|undefined}
+ this.atlasManager_ = options.atlasManager;
+ this.render_(this.atlasManager_);
+ * @type {boolean}
+ var snapToPixel = options.snapToPixel !== undefined ?
+ options.snapToPixel : true;
+ * @type {boolean}
+ var rotateWithView = options.rotateWithView !== undefined ?
+ options.rotateWithView : false;
+ ol.style.Image.call(this, {
+ opacity: 1,
+ rotateWithView: rotateWithView,
+ rotation: options.rotation !== undefined ? options.rotation : 0,
+ scale: 1,
+ snapToPixel: snapToPixel
+ol.inherits(ol.style.RegularShape, ol.style.Image);
+ * Clones the style. If an atlasmanager was provided to the original style it will be used in the cloned style, too.
+ * @return {ol.style.RegularShape} The cloned style.
+ * @api
+ol.style.RegularShape.prototype.clone = function() {
+ var style = new ol.style.RegularShape({
+ fill: this.getFill() ? this.getFill().clone() : undefined,
+ points: this.getRadius2() !== this.getRadius() ? this.getPoints() / 2 : this.getPoints(),
+ radius: this.getRadius(),
+ radius2: this.getRadius2(),
+ angle: this.getAngle(),
+ snapToPixel: this.getSnapToPixel(),
+ stroke: this.getStroke() ? this.getStroke().clone() : undefined,
+ rotation: this.getRotation(),
+ rotateWithView: this.getRotateWithView(),
+ atlasManager: this.atlasManager_
+ style.setOpacity(this.getOpacity());
+ style.setScale(this.getScale());
+ return style;
+ * @inheritDoc
+ * @api
+ol.style.RegularShape.prototype.getAnchor = function() {
+ return this.anchor_;
+ * Get the angle used in generating the shape.
+ * @return {number} Shape's rotation in radians.
+ * @api
+ol.style.RegularShape.prototype.getAngle = function() {
+ return this.angle_;
+ * Get the fill style for the shape.
+ * @return {ol.style.Fill} Fill style.
+ * @api
+ol.style.RegularShape.prototype.getFill = function() {
+ return this.fill_;
+ * @inheritDoc
+ol.style.RegularShape.prototype.getHitDetectionImage = function(pixelRatio) {
+ return this.hitDetectionCanvas_;
+ * @inheritDoc
+ * @api
+ol.style.RegularShape.prototype.getImage = function(pixelRatio) {
+ return this.canvas_;
+ * @inheritDoc
+ol.style.RegularShape.prototype.getImageSize = function() {
+ return this.imageSize_;
+ * @inheritDoc
+ol.style.RegularShape.prototype.getHitDetectionImageSize = function() {
+ return this.hitDetectionImageSize_;
+ * @inheritDoc
+ol.style.RegularShape.prototype.getImageState = function() {
+ return ol.ImageState.LOADED;
+ * @inheritDoc
+ * @api
+ol.style.RegularShape.prototype.getOrigin = function() {
+ return this.origin_;
+ * Get the number of points for generating the shape.
+ * @return {number} Number of points for stars and regular polygons.
+ * @api
+ol.style.RegularShape.prototype.getPoints = function() {
+ return this.points_;
+ * Get the (primary) radius for the shape.
+ * @return {number} Radius.
+ * @api
+ol.style.RegularShape.prototype.getRadius = function() {
+ return this.radius_;
+ * Get the secondary radius for the shape.
+ * @return {number} Radius2.
+ * @api
+ol.style.RegularShape.prototype.getRadius2 = function() {
+ return this.radius2_;
+ * @inheritDoc
+ * @api
+ol.style.RegularShape.prototype.getSize = function() {
+ return this.size_;
+ * Get the stroke style for the shape.
+ * @return {ol.style.Stroke} Stroke style.
+ * @api
+ol.style.RegularShape.prototype.getStroke = function() {
+ return this.stroke_;
+ * @inheritDoc
+ol.style.RegularShape.prototype.listenImageChange = function(listener, thisArg) {};
+ * @inheritDoc
+ol.style.RegularShape.prototype.load = function() {};
+ * @inheritDoc
+ol.style.RegularShape.prototype.unlistenImageChange = function(listener, thisArg) {};
+ * @protected
+ * @param {ol.style.AtlasManager|undefined} atlasManager An atlas manager.
+ol.style.RegularShape.prototype.render_ = function(atlasManager) {
+ var imageSize;
+ var lineCap = '';
+ var lineJoin = '';
+ var miterLimit = 0;
+ var lineDash = null;
+ var strokeStyle;
+ var strokeWidth = 0;
+ if (this.stroke_) {
+ strokeStyle = this.stroke_.getColor();
+ if (strokeStyle === null) {
+ strokeStyle = ol.render.canvas.defaultStrokeStyle;
+ strokeStyle = ol.colorlike.asColorLike(strokeStyle);
+ strokeWidth = this.stroke_.getWidth();
+ if (strokeWidth === undefined) {
+ strokeWidth = ol.render.canvas.defaultLineWidth;
+ lineDash = this.stroke_.getLineDash();
+ if (!ol.has.CANVAS_LINE_DASH) {
+ lineDash = null;
+ lineJoin = this.stroke_.getLineJoin();
+ if (lineJoin === undefined) {
+ lineJoin = ol.render.canvas.defaultLineJoin;
+ lineCap = this.stroke_.getLineCap();
+ if (lineCap === undefined) {
+ lineCap = ol.render.canvas.defaultLineCap;
+ miterLimit = this.stroke_.getMiterLimit();
+ if (miterLimit === undefined) {
+ miterLimit = ol.render.canvas.defaultMiterLimit;
+ var size = 2 * (this.radius_ + strokeWidth) + 1;
+ /** @type {ol.RegularShapeRenderOptions} */
+ var renderOptions = {
+ strokeStyle: strokeStyle,
+ strokeWidth: strokeWidth,
+ size: size,
+ lineCap: lineCap,
+ lineDash: lineDash,
+ lineJoin: lineJoin,
+ miterLimit: miterLimit
+ if (atlasManager === undefined) {
+ // no atlas manager is used, create a new canvas
+ var context = ol.dom.createCanvasContext2D(size, size);
+ this.canvas_ = context.canvas;
+ // canvas.width and height are rounded to the closest integer
+ size = this.canvas_.width;
+ imageSize = size;
+ this.draw_(renderOptions, context, 0, 0);
+ this.createHitDetectionCanvas_(renderOptions);
+ } else {
+ // an atlas manager is used, add the symbol to an atlas
+ size = Math.round(size);
+ var hasCustomHitDetectionImage = !this.fill_;
+ var renderHitDetectionCallback;
+ if (hasCustomHitDetectionImage) {
+ // render the hit-detection image into a separate atlas image
+ renderHitDetectionCallback =
+ this.drawHitDetectionCanvas_.bind(this, renderOptions);
+ var id = this.getChecksum();
+ var info = atlasManager.add(
+ id, size, size, this.draw_.bind(this, renderOptions),
+ renderHitDetectionCallback);
+ this.canvas_ = info.image;
+ this.origin_ = [info.offsetX, info.offsetY];
+ imageSize = info.image.width;
+ this.hitDetectionCanvas_ = info.hitImage;
+ [info.hitImage.width, info.hitImage.height];
+ } else {
+ this.hitDetectionCanvas_ = this.canvas_;
+ this.hitDetectionImageSize_ = [imageSize, imageSize];
+ this.anchor_ = [size / 2, size / 2];
+ this.size_ = [size, size];
+ this.imageSize_ = [imageSize, imageSize];
+ * @private
+ * @param {ol.RegularShapeRenderOptions} renderOptions Render options.
+ * @param {CanvasRenderingContext2D} context The rendering context.
+ * @param {number} x The origin for the symbol (x).
+ * @param {number} y The origin for the symbol (y).
+ol.style.RegularShape.prototype.draw_ = function(renderOptions, context, x, y) {
+ var i, angle0, radiusC;
+ // reset transform
+ context.setTransform(1, 0, 0, 1, 0, 0);
+ // then move to (x, y)
+ context.translate(x, y);
+ context.beginPath();
+ if (this.points_ === Infinity) {
+ context.arc(
+ renderOptions.size / 2, renderOptions.size / 2,
+ this.radius_, 0, 2 * Math.PI, true);
+ } else {
+ if (this.radius2_ !== this.radius_) {
+ this.points_ = 2 * this.points_;
+ for (i = 0; i <= this.points_; i++) {
+ angle0 = i * 2 * Math.PI / this.points_ - Math.PI / 2 + this.angle_;
+ radiusC = i % 2 === 0 ? this.radius_ : this.radius2_;
+ context.lineTo(renderOptions.size / 2 + radiusC * Math.cos(angle0),
+ renderOptions.size / 2 + radiusC * Math.sin(angle0));
+ if (this.fill_) {
+ var color = this.fill_.getColor();
+ if (color === null) {
+ color = ol.render.canvas.defaultFillStyle;
+ context.fillStyle = ol.colorlike.asColorLike(color);
+ context.fill();
+ context.strokeStyle = renderOptions.strokeStyle;
+ context.lineWidth = renderOptions.strokeWidth;
+ if (renderOptions.lineDash) {
+ context.setLineDash(renderOptions.lineDash);
+ context.lineCap = renderOptions.lineCap;
+ context.lineJoin = renderOptions.lineJoin;
+ context.miterLimit = renderOptions.miterLimit;
+ context.stroke();
+ context.closePath();
+ * @private
+ol.style.RegularShape.prototype.createHitDetectionCanvas_ = function(renderOptions) {
+ this.hitDetectionImageSize_ = [renderOptions.size, renderOptions.size];
+ if (this.fill_) {
+ return;
+ // if no fill style is set, create an extra hit-detection image with a
+ // default fill style
+ var context = ol.dom.createCanvasContext2D(renderOptions.size, renderOptions.size);
+ this.hitDetectionCanvas_ = context.canvas;
+ this.drawHitDetectionCanvas_(renderOptions, context, 0, 0);
+ * @private
+ * @param {CanvasRenderingContext2D} context The context.
+ol.style.RegularShape.prototype.drawHitDetectionCanvas_ = function(renderOptions, context, x, y) {
+ context.arc(
+ } else {
+ var i, radiusC, angle0;
+ context.fillStyle = ol.render.canvas.defaultFillStyle;
+ context.fill();
+ context.stroke();
+ * @return {string} The checksum.
+ol.style.RegularShape.prototype.getChecksum = function() {
+ var strokeChecksum = this.stroke_ ?
+ this.stroke_.getChecksum() : '-';
+ var fillChecksum = this.fill_ ?
+ this.fill_.getChecksum() : '-';
+ var recalculate = !this.checksums_ ||
+ (strokeChecksum != this.checksums_[1] ||
+ fillChecksum != this.checksums_[2] ||
+ this.radius_ != this.checksums_[3] ||
+ this.radius2_ != this.checksums_[4] ||
+ this.angle_ != this.checksums_[5] ||
+ this.points_ != this.checksums_[6]);
+ if (recalculate) {
+ var checksum = 'r' + strokeChecksum + fillChecksum +
+ (this.radius_ !== undefined ? this.radius_.toString() : '-') +
+ (this.radius2_ !== undefined ? this.radius2_.toString() : '-') +
+ (this.angle_ !== undefined ? this.angle_.toString() : '-') +
+ (this.points_ !== undefined ? this.points_.toString() : '-');
+ this.checksums_ = [checksum, strokeChecksum, fillChecksum,
+ this.radius_, this.radius2_, this.angle_, this.points_];
+ return this.checksums_[0];
+goog.provide('ol.style.Circle');
+goog.require('ol');
+goog.require('ol.style.RegularShape');
+ * @classdesc
+ * Set circle style for vector features.
+ * @constructor
+ * @param {olx.style.CircleOptions=} opt_options Options.
+ * @extends {ol.style.RegularShape}
+ * @api
+ol.style.Circle = function(opt_options) {
+ var options = opt_options || {};
+ ol.style.RegularShape.call(this, {
+ points: Infinity,
+ fill: options.fill,
+ radius: options.radius,
+ snapToPixel: options.snapToPixel,
+ stroke: options.stroke,
+ atlasManager: options.atlasManager
+ol.inherits(ol.style.Circle, ol.style.RegularShape);
+ * @return {ol.style.Circle} The cloned style.
+ * @override
+ * @api
+ol.style.Circle.prototype.clone = function() {
+ var style = new ol.style.Circle({
+ return style;
+ * Set the circle radius.
+ * @param {number} radius Circle radius.
+ * @api
+ol.style.Circle.prototype.setRadius = function(radius) {
+ this.radius_ = radius;
+goog.provide('ol.style.Fill');
+goog.require('ol.color');
+ * @classdesc
+ * Set fill style for vector features.
+ * @constructor
+ * @param {olx.style.FillOptions=} opt_options Options.
+ * @api
+ol.style.Fill = function(opt_options) {
+ * @private
+ * @type {ol.Color|ol.ColorLike}
+ this.color_ = options.color !== undefined ? options.color : null;
+ * @private
+ * @type {string|undefined}
+ this.checksum_ = undefined;
+ * Clones the style. The color is not cloned if it is an {@link ol.ColorLike}.
+ * @return {ol.style.Fill} The cloned style.
+ * @api
+ol.style.Fill.prototype.clone = function() {
+ var color = this.getColor();
+ return new ol.style.Fill({
+ color: (color && color.slice) ? color.slice() : color || undefined
+ * Get the fill color.
+ * @return {ol.Color|ol.ColorLike} Color.
+ * @api
+ol.style.Fill.prototype.getColor = function() {
+ return this.color_;
+ * Set the color.
+ * @param {ol.Color|ol.ColorLike} color Color.
+ * @api
+ol.style.Fill.prototype.setColor = function(color) {
+ this.color_ = color;
+ol.style.Fill.prototype.getChecksum = function() {
+ if (this.checksum_ === undefined) {
+ if (
+ this.color_ instanceof CanvasPattern ||
+ this.color_ instanceof CanvasGradient
+ this.checksum_ = ol.getUid(this.color_).toString();
+ } else {
+ this.checksum_ = 'f' + (this.color_ ?
+ ol.color.asString(this.color_) : '-');
+ return this.checksum_;
+goog.provide('ol.style.Style');
+goog.require('ol.geom.GeometryType');
+goog.require('ol.style.Circle');
+goog.require('ol.style.Fill');
+goog.require('ol.style.Stroke');
+ * @classdesc
+ * Container for vector feature rendering styles. Any changes made to the style
+ * or its children through `set*()` methods will not take effect until the
+ * feature or layer that uses the style is re-rendered.
+ * @constructor
+ * @struct
+ * @param {olx.style.StyleOptions=} opt_options Style options.
+ * @api
+ol.style.Style = function(opt_options) {
+ * @private
+ * @type {string|ol.geom.Geometry|ol.StyleGeometryFunction}
+ this.geometry_ = null;
+ * @private
+ * @type {!ol.StyleGeometryFunction}
+ this.geometryFunction_ = ol.style.Style.defaultGeometryFunction;
+ if (options.geometry !== undefined) {
+ this.setGeometry(options.geometry);
+ * @private
+ * @private
+ * @type {ol.style.Image}
+ this.image_ = options.image !== undefined ? options.image : null;
+ * @private
+ * @private
+ * @type {ol.style.Text}
+ this.text_ = options.text !== undefined ? options.text : null;
+ * @private
+ this.zIndex_ = options.zIndex;
+ * @return {ol.style.Style} The cloned style.
+ * @api
+ol.style.Style.prototype.clone = function() {
+ var geometry = this.getGeometry();
+ if (geometry && geometry.clone) {
+ geometry = geometry.clone();
+ return new ol.style.Style({
+ geometry: geometry,
+ image: this.getImage() ? this.getImage().clone() : undefined,
+ text: this.getText() ? this.getText().clone() : undefined,
+ zIndex: this.getZIndex()
+ * Get the geometry to be rendered.
+ * @return {string|ol.geom.Geometry|ol.StyleGeometryFunction}
+ * Feature property or geometry or function that returns the geometry that will
+ * be rendered with this style.
+ * @api
+ol.style.Style.prototype.getGeometry = function() {
+ return this.geometry_;
+ * Get the function used to generate a geometry for rendering.
+ * @return {!ol.StyleGeometryFunction} Function that is called with a feature
+ * and returns the geometry to render instead of the feature's geometry.
+ * @api
+ol.style.Style.prototype.getGeometryFunction = function() {
+ return this.geometryFunction_;
+ * Get the fill style.
+ * @api
+ol.style.Style.prototype.getFill = function() {
+ * Set the fill style.
+ * @param {ol.style.Fill} fill Fill style.
+ * @api
+ol.style.Style.prototype.setFill = function(fill) {
+ this.fill_ = fill;
+ * Get the image style.
+ * @return {ol.style.Image} Image style.
+ * @api
+ol.style.Style.prototype.getImage = function() {
+ return this.image_;
+ * Set the image style.
+ * @param {ol.style.Image} image Image style.
+ * @api
+ol.style.Style.prototype.setImage = function(image) {
+ this.image_ = image;
+ * Get the stroke style.
+ * @api
+ol.style.Style.prototype.getStroke = function() {
+ * Set the stroke style.
+ * @param {ol.style.Stroke} stroke Stroke style.
+ * @api
+ol.style.Style.prototype.setStroke = function(stroke) {
+ this.stroke_ = stroke;
+ * Get the text style.
+ * @return {ol.style.Text} Text style.
+ * @api
+ol.style.Style.prototype.getText = function() {
+ return this.text_;
+ * Set the text style.
+ * @param {ol.style.Text} text Text style.
+ * @api
+ol.style.Style.prototype.setText = function(text) {
+ this.text_ = text;
+ * Get the z-index for the style.
+ * @return {number|undefined} ZIndex.
+ * @api
+ol.style.Style.prototype.getZIndex = function() {
+ return this.zIndex_;
+ * Set a geometry that is rendered instead of the feature's geometry.
+ * @param {string|ol.geom.Geometry|ol.StyleGeometryFunction} geometry
+ * Feature property or geometry or function returning a geometry to render
+ * for this style.
+ * @api
+ol.style.Style.prototype.setGeometry = function(geometry) {
+ if (typeof geometry === 'function') {
+ this.geometryFunction_ = geometry;
+ } else if (typeof geometry === 'string') {
+ this.geometryFunction_ = function(feature) {
+ return /** @type {ol.geom.Geometry} */ (feature.get(geometry));
+ } else if (!geometry) {
+ } else if (geometry !== undefined) {
+ this.geometryFunction_ = function() {
+ return /** @type {ol.geom.Geometry} */ (geometry);
+ this.geometry_ = geometry;
+ * Set the z-index.
+ * @param {number|undefined} zIndex ZIndex.
+ * @api
+ol.style.Style.prototype.setZIndex = function(zIndex) {
+ this.zIndex_ = zIndex;
+ * Convert the provided object into a style function. Functions passed through
+ * unchanged. Arrays of ol.style.Style or single style objects wrapped in a
+ * new style function.
+ * @param {ol.StyleFunction|Array.<ol.style.Style>|ol.style.Style} obj
+ * A style function, a single style, or an array of styles.
+ * @return {ol.StyleFunction} A style function.
+ol.style.Style.createFunction = function(obj) {
+ var styleFunction;
+ if (typeof obj === 'function') {
+ styleFunction = obj;
+ } else {
+ * @type {Array.<ol.style.Style>}
+ var styles;
+ if (Array.isArray(obj)) {
+ styles = obj;
+ } else {
+ ol.asserts.assert(obj instanceof ol.style.Style,
+ 41); // Expected an `ol.style.Style` or an array of `ol.style.Style`
+ styles = [obj];
+ styleFunction = function() {
+ return styles;
+ return styleFunction;
+ * @private
+ol.style.Style.default_ = null;
+ * @param {ol.Feature|ol.render.Feature} feature Feature.
+ * @param {number} resolution Resolution.
+ * @return {Array.<ol.style.Style>} Style.
+ol.style.Style.defaultFunction = function(feature, resolution) {
+ // We don't use an immediately-invoked function
+ // and a closure so we don't get an error at script evaluation time in
+ // browsers that do not support Canvas. (ol.style.Circle does
+ // canvas.getContext('2d') at construction time, which will cause an.error
+ // in such browsers.)
+ if (!ol.style.Style.default_) {
+ var fill = new ol.style.Fill({
+ color: 'rgba(255,255,255,0.4)'
+ var stroke = new ol.style.Stroke({
+ color: '#3399CC',
+ width: 1.25
+ ol.style.Style.default_ = [
+ new ol.style.Style({
+ image: new ol.style.Circle({
+ fill: fill,
+ stroke: stroke,
+ radius: 5
+ fill: fill,
+ stroke: stroke
+ return ol.style.Style.default_;
+ * Default styles for editing features.
+ * @return {Object.<ol.geom.GeometryType, Array.<ol.style.Style>>} Styles
+ol.style.Style.createDefaultEditing = function() {
+ /** @type {Object.<ol.geom.GeometryType, Array.<ol.style.Style>>} */
+ var styles = {};
+ var white = [255, 255, 255, 1];
+ var blue = [0, 153, 255, 1];
+ var width = 3;
+ styles[ol.geom.GeometryType.POLYGON] = [
+ fill: new ol.style.Fill({
+ color: [255, 255, 255, 0.5]
+ styles[ol.geom.GeometryType.MULTI_POLYGON] =
+ styles[ol.geom.GeometryType.POLYGON];
+ styles[ol.geom.GeometryType.LINE_STRING] = [
+ stroke: new ol.style.Stroke({
+ color: white,
+ width: width + 2
+ color: blue,
+ width: width
+ styles[ol.geom.GeometryType.MULTI_LINE_STRING] =
+ styles[ol.geom.GeometryType.LINE_STRING];
+ styles[ol.geom.GeometryType.CIRCLE] =
+ styles[ol.geom.GeometryType.POLYGON].concat(
+ styles[ol.geom.GeometryType.POINT] = [
+ radius: width * 2,
+ color: blue
+ color: white,
+ width: width / 2
+ zIndex: Infinity
+ styles[ol.geom.GeometryType.MULTI_POINT] =
+ styles[ol.geom.GeometryType.POINT];
+ styles[ol.geom.GeometryType.GEOMETRY_COLLECTION] =
+ styles[ol.geom.GeometryType.LINE_STRING],
+ return styles;
+ * Function that is called with a feature and returns its default geometry.
+ * @param {ol.Feature|ol.render.Feature} feature Feature to get the geometry
+ * for.
+ * @return {ol.geom.Geometry|ol.render.Feature|undefined} Geometry to render.
+ol.style.Style.defaultGeometryFunction = function(feature) {
+ return feature.getGeometry();
+goog.provide('ol.Feature');
+goog.require('ol.events');
+goog.require('ol.geom.Geometry');
+goog.require('ol.style.Style');
+ * @classdesc
+ * A vector object for geographic features with a geometry and other
+ * attribute properties, similar to the features in vector file formats like
+ * GeoJSON.
+ * Features can be styled individually with `setStyle`; otherwise they use the
+ * style of their vector layer.
+ * Note that attribute properties are set as {@link ol.Object} properties on
+ * the feature object, so they are observable, and have get/set accessors.
+ * Typically, a feature has a single geometry property. You can set the
+ * geometry using the `setGeometry` method and get it with `getGeometry`.
+ * It is possible to store more than one geometry on a feature using attribute
+ * properties. By default, the geometry used for rendering is identified by
+ * the property name `geometry`. If you want to use another geometry property
+ * for rendering, use the `setGeometryName` method to change the attribute
+ * property associated with the geometry for the feature. For example:
+ * ```js
+ * var feature = new ol.Feature({
+ * geometry: new ol.geom.Polygon(polyCoords),
+ * labelPoint: new ol.geom.Point(labelCoords),
+ * name: 'My Polygon'
+ * // get the polygon geometry
+ * var poly = feature.getGeometry();
+ * // Render the feature as a point using the coordinates from labelPoint
+ * feature.setGeometryName('labelPoint');
+ * // get the point geometry
+ * var point = feature.getGeometry();
+ * @constructor
+ * @param {ol.geom.Geometry|Object.<string, *>=} opt_geometryOrProperties
+ * You may pass a Geometry object directly, or an object literal
+ * containing properties. If you pass an object literal, you may
+ * include a Geometry associated with a `geometry` key.
+ * @api
+ol.Feature = function(opt_geometryOrProperties) {
+ * @private
+ * @type {number|string|undefined}
+ this.id_ = undefined;
+ * @type {string}
+ * @private
+ this.geometryName_ = 'geometry';
+ * User provided style.
+ * @private
+ * @type {ol.style.Style|Array.<ol.style.Style>|
+ * ol.FeatureStyleFunction}
+ this.style_ = null;
+ * @private
+ * @type {ol.FeatureStyleFunction|undefined}
+ this.styleFunction_ = undefined;
+ * @private
+ this.geometryChangeKey_ = null;
+ ol.events.listen(
+ this, ol.Object.getChangeEventType(this.geometryName_),
+ this.handleGeometryChanged_, this);
+ if (opt_geometryOrProperties !== undefined) {
+ if (opt_geometryOrProperties instanceof ol.geom.Geometry ||
+ !opt_geometryOrProperties) {
+ var geometry = opt_geometryOrProperties;
+ this.setGeometry(geometry);
+ } else {
+ /** @type {Object.<string, *>} */
+ var properties = opt_geometryOrProperties;
+ this.setProperties(properties);
+ol.inherits(ol.Feature, ol.Object);
+ * Clone this feature. If the original feature has a geometry it
+ * is also cloned. The feature id is not set in the clone.
+ * @return {ol.Feature} The clone.
+ * @api
+ol.Feature.prototype.clone = function() {
+ var clone = new ol.Feature(this.getProperties());
+ clone.setGeometryName(this.getGeometryName());
+ if (geometry) {
+ clone.setGeometry(geometry.clone());
+ var style = this.getStyle();
+ if (style) {
+ clone.setStyle(style);
+ return clone;
+ * Get the feature's default geometry. A feature may have any number of named
+ * geometries. The "default" geometry (the one that is rendered by default) is
+ * set when calling {@link ol.Feature#setGeometry}.
+ * @return {ol.geom.Geometry|undefined} The default geometry for the feature.
+ * @api
+ * @observable
+ol.Feature.prototype.getGeometry = function() {
+ return /** @type {ol.geom.Geometry|undefined} */ (
+ this.get(this.geometryName_));
+ * Get the feature identifier. This is a stable identifier for the feature and
+ * is either set when reading data from a remote source or set explicitly by
+ * calling {@link ol.Feature#setId}.
+ * @return {number|string|undefined} Id.
+ * @api
+ol.Feature.prototype.getId = function() {
+ return this.id_;
+ * Get the name of the feature's default geometry. By default, the default
+ * geometry is named `geometry`.
+ * @return {string} Get the property name associated with the default geometry
+ * for this feature.
+ * @api
+ol.Feature.prototype.getGeometryName = function() {
+ return this.geometryName_;
+ * Get the feature's style. Will return what was provided to the
+ * {@link ol.Feature#setStyle} method.
+ * @return {ol.style.Style|Array.<ol.style.Style>|
+ * ol.FeatureStyleFunction|ol.StyleFunction} The feature style.
+ * @api
+ol.Feature.prototype.getStyle = function() {
+ return this.style_;
+ * Get the feature's style function.
+ * @return {ol.FeatureStyleFunction|undefined} Return a function
+ * representing the current style of this feature.
+ * @api
+ol.Feature.prototype.getStyleFunction = function() {
+ return this.styleFunction_;
+ * @private
+ol.Feature.prototype.handleGeometryChange_ = function() {
+ this.changed();
+ * @private
+ol.Feature.prototype.handleGeometryChanged_ = function() {
+ if (this.geometryChangeKey_) {
+ ol.events.unlistenByKey(this.geometryChangeKey_);
+ if (geometry) {
+ this.geometryChangeKey_ = ol.events.listen(geometry,
+ ol.events.EventType.CHANGE, this.handleGeometryChange_, this);
+ this.changed();
+ * Set the default geometry for the feature. This will update the property
+ * with the name returned by {@link ol.Feature#getGeometryName}.
+ * @param {ol.geom.Geometry|undefined} geometry The new geometry.
+ * @api
+ * @observable
+ol.Feature.prototype.setGeometry = function(geometry) {
+ this.set(this.geometryName_, geometry);
+ * Set the style for the feature. This can be a single style object, an array
+ * of styles, or a function that takes a resolution and returns an array of
+ * styles. If it is `null` the feature has no style (a `null` style).
+ * @param {ol.style.Style|Array.<ol.style.Style>|
+ * ol.FeatureStyleFunction|ol.StyleFunction} style Style for this feature.
+ * @api
+ * @fires ol.events.Event#event:change
+ol.Feature.prototype.setStyle = function(style) {
+ this.style_ = style;
+ this.styleFunction_ = !style ?
+ undefined : ol.Feature.createStyleFunction(style);
+ this.changed();
+ * Set the feature id. The feature id is considered stable and may be used when
+ * requesting features or comparing identifiers returned from a remote source.
+ * The feature id can be used with the {@link ol.source.Vector#getFeatureById}
+ * method.
+ * @param {number|string|undefined} id The feature id.
+ * @api
+ol.Feature.prototype.setId = function(id) {
+ this.id_ = id;
+ this.changed();
+ * Set the property name to be used when getting the feature's default geometry.
+ * When calling {@link ol.Feature#getGeometry}, the value of the property with
+ * this name will be returned.
+ * @param {string} name The property name of the default geometry.
+ * @api
+ol.Feature.prototype.setGeometryName = function(name) {
+ ol.events.unlisten(
+ this.geometryName_ = name;
+ ol.events.listen(
+ this.handleGeometryChanged_();
+ * Convert the provided object into a feature style function. Functions passed
+ * through unchanged. Arrays of ol.style.Style or single style objects wrapped
+ * in a new feature style function.
+ * @param {ol.FeatureStyleFunction|!Array.<ol.style.Style>|!ol.style.Style} obj
+ * A feature style function, a single style, or an array of styles.
+ * @return {ol.FeatureStyleFunction} A style function.
+ol.Feature.createStyleFunction = function(obj) {
+ if (obj.length == 2) {
+ styleFunction = function(resolution) {
+ return /** @type {ol.StyleFunction} */ (obj)(this, resolution);
+ } else {
+ } else {
+ var styles;
+ styles = obj;
+ } else {
+ styles = [obj];
+ return styles;
+goog.provide('ol.format.FormatType');
+ * @enum {string}
+ol.format.FormatType = {
+ ARRAY_BUFFER: 'arraybuffer',
+ JSON: 'json',
+ TEXT: 'text',
+ XML: 'xml'
+goog.provide('ol.xml');
+goog.require('ol.array');
+ * This document should be used when creating nodes for XML serializations. This
+ * document is also used by {@link ol.xml.createElementNS} and
+ * {@link ol.xml.setAttributeNS}
+ * @const
+ * @type {Document}
+ol.xml.DOCUMENT = document.implementation.createDocument('', '', null);
+ * @param {string} namespaceURI Namespace URI.
+ * @param {string} qualifiedName Qualified name.
+ * @return {Node} Node.
+ol.xml.createElementNS = function(namespaceURI, qualifiedName) {
+ return ol.xml.DOCUMENT.createElementNS(namespaceURI, qualifiedName);
+ * Recursively grab all text content of child nodes into a single string.
+ * @param {Node} node Node.
+ * @param {boolean} normalizeWhitespace Normalize whitespace: remove all line
+ * breaks.
+ * @return {string} All text content.
+ * @api
+ol.xml.getAllTextContent = function(node, normalizeWhitespace) {
+ return ol.xml.getAllTextContent_(node, normalizeWhitespace, []).join('');
+ * breaks.
+ * @param {Array.<string>} accumulator Accumulator.
+ * @private
+ * @return {Array.<string>} Accumulator.
+ol.xml.getAllTextContent_ = function(node, normalizeWhitespace, accumulator) {
+ if (node.nodeType == Node.CDATA_SECTION_NODE ||
+ node.nodeType == Node.TEXT_NODE) {
+ if (normalizeWhitespace) {
+ accumulator.push(String(node.nodeValue).replace(/(\r\n|\r|\n)/g, ''));
+ } else {
+ accumulator.push(node.nodeValue);
+ } else {
+ var n;
+ for (n = node.firstChild; n; n = n.nextSibling) {
+ ol.xml.getAllTextContent_(n, normalizeWhitespace, accumulator);
+ return accumulator;
+ * @param {?} value Value.
+ * @return {boolean} Is document.
+ol.xml.isDocument = function(value) {
+ return value instanceof Document;
+ * @return {boolean} Is node.
+ol.xml.isNode = function(value) {
+ return value instanceof Node;
+ * @param {?string} namespaceURI Namespace URI.
+ * @param {string} name Attribute name.
+ * @return {string} Value
+ol.xml.getAttributeNS = function(node, namespaceURI, name) {
+ return node.getAttributeNS(namespaceURI, name) || '';
+ * @param {string|number} value Value.
+ol.xml.setAttributeNS = function(node, namespaceURI, name, value) {
+ node.setAttributeNS(namespaceURI, name, value);
+ * Parse an XML string to an XML Document.
+ * @param {string} xml XML.
+ * @return {Document} Document.
+ * @api
+ol.xml.parse = function(xml) {
+ return new DOMParser().parseFromString(xml, 'application/xml');
+ * Make an array extender function for extending the array at the top of the
+ * object stack.
+ * @param {function(this: T, Node, Array.<*>): (Array.<*>|undefined)}
+ * valueReader Value reader.
+ * @param {T=} opt_this The object to use as `this` in `valueReader`.
+ * @return {ol.XmlParser} Parser.
+ * @template T
+ol.xml.makeArrayExtender = function(valueReader, opt_this) {
+ return (
+ * @param {Array.<*>} objectStack Object stack.
+ function(node, objectStack) {
+ var value = valueReader.call(opt_this, node, objectStack);
+ if (value !== undefined) {
+ var array = /** @type {Array.<*>} */
+ (objectStack[objectStack.length - 1]);
+ ol.array.extend(array, value);
+ * Make an array pusher function for pushing to the array at the top of the
+ * object stack.
+ * @param {function(this: T, Node, Array.<*>): *} valueReader Value reader.
+ * @template T
+ol.xml.makeArrayPusher = function(valueReader, opt_this) {
+ return (
+ var value = valueReader.call(opt_this !== undefined ? opt_this : this,
+ node, objectStack);
+ var array = objectStack[objectStack.length - 1];
+ array.push(value);
+ * Make an object stack replacer function for replacing the object at the
+ * top of the stack.
+ * @template T
+ol.xml.makeReplacer = function(valueReader, opt_this) {
+ return (
+ objectStack[objectStack.length - 1] = value;
+ * Make an object property pusher function for adding a property to the
+ * object at the top of the stack.
+ * @param {string=} opt_property Property.
+ * @template T
+ol.xml.makeObjectPropertyPusher = function(valueReader, opt_property, opt_this) {
+ return (
+ var object = /** @type {Object} */
+ var property = opt_property !== undefined ?
+ opt_property : node.localName;
+ var array;
+ if (property in object) {
+ array = object[property];
+ } else {
+ array = object[property] = [];
+ * Make an object property setter function.
+ * @template T
+ol.xml.makeObjectPropertySetter = function(valueReader, opt_property, opt_this) {
+ return (
+ object[property] = value;
+ * Create a serializer that appends nodes written by its `nodeWriter` to its
+ * designated parent. The parent is the `node` of the
+ * {@link ol.XmlNodeStackItem} at the top of the `objectStack`.
+ * @param {function(this: T, Node, V, Array.<*>)}
+ * nodeWriter Node writer.
+ * @param {T=} opt_this The object to use as `this` in `nodeWriter`.
+ * @return {ol.XmlSerializer} Serializer.
+ * @template T, V
+ol.xml.makeChildAppender = function(nodeWriter, opt_this) {
+ return function(node, value, objectStack) {
+ nodeWriter.call(opt_this !== undefined ? opt_this : this,
+ node, value, objectStack);
+ var parent = objectStack[objectStack.length - 1];
+ var parentNode = parent.node;
+ parentNode.appendChild(node);
+ * Create a serializer that calls the provided `nodeWriter` from
+ * {@link ol.xml.serialize}. This can be used by the parent writer to have the
+ * 'nodeWriter' called with an array of values when the `nodeWriter` was
+ * designed to serialize a single item. An example would be a LineString
+ * geometry writer, which could be reused for writing MultiLineString
+ * geometries.
+ * @template T, V
+ol.xml.makeArraySerializer = function(nodeWriter, opt_this) {
+ var serializersNS, nodeFactory;
+ if (serializersNS === undefined) {
+ serializersNS = {};
+ var serializers = {};
+ serializers[node.localName] = nodeWriter;
+ serializersNS[node.namespaceURI] = serializers;
+ nodeFactory = ol.xml.makeSimpleNodeFactory(node.localName);
+ ol.xml.serialize(serializersNS, nodeFactory, value, objectStack);
+ * Create a node factory which can use the `opt_keys` passed to
+ * {@link ol.xml.serialize} or {@link ol.xml.pushSerializeAndPop} as node names,
+ * or a fixed node name. The namespace of the created nodes can either be fixed,
+ * or the parent namespace will be used.
+ * @param {string=} opt_nodeName Fixed node name which will be used for all
+ * created nodes. If not provided, the 3rd argument to the resulting node
+ * factory needs to be provided and will be the nodeName.
+ * @param {string=} opt_namespaceURI Fixed namespace URI which will be used for
+ * all created nodes. If not provided, the namespace of the parent node will
+ * be used.
+ * @return {function(*, Array.<*>, string=): (Node|undefined)} Node factory.
+ol.xml.makeSimpleNodeFactory = function(opt_nodeName, opt_namespaceURI) {
+ var fixedNodeName = opt_nodeName;
+ return (
+ * @param {*} value Value.
+ * @param {string=} opt_nodeName Node name.
+ function(value, objectStack, opt_nodeName) {
+ var context = objectStack[objectStack.length - 1];
+ var node = context.node;
+ var nodeName = fixedNodeName;
+ if (nodeName === undefined) {
+ nodeName = opt_nodeName;
+ var namespaceURI = opt_namespaceURI;
+ if (opt_namespaceURI === undefined) {
+ namespaceURI = node.namespaceURI;
+ return ol.xml.createElementNS(namespaceURI, /** @type {string} */ (nodeName));
+ * A node factory that creates a node using the parent's `namespaceURI` and the
+ * `nodeName` passed by {@link ol.xml.serialize} or
+ * {@link ol.xml.pushSerializeAndPop} to the node factory.
+ * @const
+ * @type {function(*, Array.<*>, string=): (Node|undefined)}
+ol.xml.OBJECT_PROPERTY_NODE_FACTORY = ol.xml.makeSimpleNodeFactory();
+ * Create an array of `values` to be used with {@link ol.xml.serialize} or
+ * {@link ol.xml.pushSerializeAndPop}, where `orderedKeys` has to be provided as
+ * `opt_key` argument.
+ * @param {Object.<string, V>} object Key-value pairs for the sequence. Keys can
+ * be a subset of the `orderedKeys`.
+ * @param {Array.<string>} orderedKeys Keys in the order of the sequence.
+ * @return {Array.<V>} Values in the order of the sequence. The resulting array
+ * has the same length as the `orderedKeys` array. Values that are not
+ * present in `object` will be `undefined` in the resulting array.
+ * @template V
+ol.xml.makeSequence = function(object, orderedKeys) {
+ var length = orderedKeys.length;
+ var sequence = new Array(length);
+ for (var i = 0; i < length; ++i) {
+ sequence[i] = object[orderedKeys[i]];
+ return sequence;
+ * Create a namespaced structure, using the same values for each namespace.
+ * This can be used as a starting point for versioned parsers, when only a few
+ * values are version specific.
+ * @param {Array.<string>} namespaceURIs Namespace URIs.
+ * @param {T} structure Structure.
+ * @param {Object.<string, T>=} opt_structureNS Namespaced structure to add to.
+ * @return {Object.<string, T>} Namespaced structure.
+ * @template T
+ol.xml.makeStructureNS = function(namespaceURIs, structure, opt_structureNS) {
+ * @type {Object.<string, *>}
+ var structureNS = opt_structureNS !== undefined ? opt_structureNS : {};
+ var i, ii;
+ for (i = 0, ii = namespaceURIs.length; i < ii; ++i) {
+ structureNS[namespaceURIs[i]] = structure;
+ return structureNS;
+ * Parse a node using the parsers and object stack.
+ * @param {Object.<string, Object.<string, ol.XmlParser>>} parsersNS
+ * Parsers by namespace.
+ * @param {*=} opt_this The object to use as `this`.
+ol.xml.parseNode = function(parsersNS, node, objectStack, opt_this) {
+ var n;
+ for (n = node.firstElementChild; n; n = n.nextElementSibling) {
+ var parsers = parsersNS[n.namespaceURI];
+ if (parsers !== undefined) {
+ var parser = parsers[n.localName];
+ if (parser !== undefined) {
+ parser.call(opt_this, n, objectStack);
+ * Push an object on top of the stack, parse and return the popped object.
+ * @param {T} object Object.
+ * @return {T} Object.
+ * @template T
+ol.xml.pushParseAndPop = function(
+ object, parsersNS, node, objectStack, opt_this) {
+ objectStack.push(object);
+ ol.xml.parseNode(parsersNS, node, objectStack, opt_this);
+ return objectStack.pop();
+ * Walk through an array of `values` and call a serializer for each value.
+ * @param {Object.<string, Object.<string, ol.XmlSerializer>>} serializersNS
+ * Namespaced serializers.
+ * @param {function(this: T, *, Array.<*>, (string|undefined)): (Node|undefined)} nodeFactory
+ * Node factory. The `nodeFactory` creates the node whose namespace and name
+ * will be used to choose a node writer from `serializersNS`. This
+ * separation allows us to decide what kind of node to create, depending on
+ * the value we want to serialize. An example for this would be different
+ * geometry writers based on the geometry type.
+ * @param {Array.<*>} values Values to serialize. An example would be an array
+ * of {@link ol.Feature} instances.
+ * @param {Array.<*>} objectStack Node stack.
+ * @param {Array.<string>=} opt_keys Keys of the `values`. Will be passed to the
+ * `nodeFactory`. This is used for serializing object literals where the
+ * node name relates to the property key. The array length of `opt_keys` has
+ * to match the length of `values`. For serializing a sequence, `opt_keys`
+ * determines the order of the sequence.
+ * @param {T=} opt_this The object to use as `this` for the node factory and
+ * serializers.
+ * @template T
+ol.xml.serialize = function(
+ serializersNS, nodeFactory, values, objectStack, opt_keys, opt_this) {
+ var length = (opt_keys !== undefined ? opt_keys : values).length;
+ var value, node;
+ value = values[i];
+ node = nodeFactory.call(opt_this, value, objectStack,
+ opt_keys !== undefined ? opt_keys[i] : undefined);
+ if (node !== undefined) {
+ serializersNS[node.namespaceURI][node.localName]
+ .call(opt_this, node, value, objectStack);
+ * @param {O} object Object.
+ * serializers.
+ * @return {O|undefined} Object.
+ * @template O, T
+ol.xml.pushSerializeAndPop = function(object,
+ ol.xml.serialize(
+ serializersNS, nodeFactory, values, objectStack, opt_keys, opt_this);
+goog.provide('ol.featureloader');
+goog.require('ol.format.FormatType');
+goog.require('ol.xml');
+ * @param {string|ol.FeatureUrlFunction} url Feature URL service.
+ * @param {ol.format.Feature} format Feature format.
+ * @param {function(this:ol.VectorTile, Array.<ol.Feature>, ol.proj.Projection)|function(this:ol.source.Vector, Array.<ol.Feature>)} success
+ * Function called with the loaded features and optionally with the data
+ * projection. Called with the vector tile or source as `this`.
+ * @param {function(this:ol.VectorTile)|function(this:ol.source.Vector)} failure
+ * Function called when loading failed. Called with the vector tile or
+ * source as `this`.
+ * @return {ol.FeatureLoader} The feature loader.
+ol.featureloader.loadFeaturesXhr = function(url, format, success, failure) {
+ return (
+ * @param {ol.Extent} extent Extent.
+ * @param {ol.proj.Projection} projection Projection.
+ * @this {ol.source.Vector|ol.VectorTile}
+ function(extent, resolution, projection) {
+ var xhr = new XMLHttpRequest();
+ xhr.open('GET',
+ typeof url === 'function' ? url(extent, resolution, projection) : url,
+ true);
+ if (format.getType() == ol.format.FormatType.ARRAY_BUFFER) {
+ xhr.responseType = 'arraybuffer';
+ * @param {Event} event Event.
+ * @private
+ xhr.onload = function(event) {
+ // status will be 0 for file:// urls
+ if (!xhr.status || xhr.status >= 200 && xhr.status < 300) {
+ var type = format.getType();
+ /** @type {Document|Node|Object|string|undefined} */
+ var source;
+ if (type == ol.format.FormatType.JSON ||
+ type == ol.format.FormatType.TEXT) {
+ source = xhr.responseText;
+ } else if (type == ol.format.FormatType.XML) {
+ source = xhr.responseXML;
+ if (!source) {
+ source = ol.xml.parse(xhr.responseText);
+ } else if (type == ol.format.FormatType.ARRAY_BUFFER) {
+ source = /** @type {ArrayBuffer} */ (xhr.response);
+ if (source) {
+ success.call(this, format.readFeatures(source,
+ {featureProjection: projection}),
+ format.readProjection(source));
+ } else {
+ failure.call(this);
+ } else {
+ }.bind(this);
+ * @private
+ xhr.onerror = function() {
+ }.bind(this);
+ xhr.send();
+ * Create an XHR feature loader for a `url` and `format`. The feature loader
+ * loads features (with XHR), parses the features, and adds them to the
+ * vector source.
+ * @api
+ol.featureloader.xhr = function(url, format) {
+ return ol.featureloader.loadFeaturesXhr(url, format,
+ * @param {Array.<ol.Feature>} features The loaded features.
+ * @param {ol.proj.Projection} dataProjection Data projection.
+ * @this {ol.source.Vector}
+ function(features, dataProjection) {
+ this.addFeatures(features);
+ }, /* FIXME handle error */ ol.nullFunction);
+goog.provide('ol.format.Feature');
+goog.require('ol.obj');
+goog.require('ol.proj');
+ * @classdesc
+ * Abstract base class; normally only used for creating subclasses and not
+ * instantiated in apps.
+ * Base class for feature formats.
+ * {ol.format.Feature} subclasses provide the ability to decode and encode
+ * {@link ol.Feature} objects from a variety of commonly used geospatial
+ * file formats. See the documentation for each format for more details.
+ * @constructor
+ * @abstract
+ * @api
+ol.format.Feature = function() {
+ * @protected
+ * @type {ol.proj.Projection}
+ this.defaultDataProjection = null;
+ * @protected
+ this.defaultFeatureProjection = null;
+ * Adds the data projection to the read options.
+ * @param {Document|Node|Object|string} source Source.
+ * @param {olx.format.ReadOptions=} opt_options Options.
+ * @return {olx.format.ReadOptions|undefined} Options.
+ * @protected
+ol.format.Feature.prototype.getReadOptions = function(source, opt_options) {
+ var options;
+ if (opt_options) {
+ options = {
+ dataProjection: opt_options.dataProjection ?
+ opt_options.dataProjection : this.readProjection(source),
+ featureProjection: opt_options.featureProjection
+ return this.adaptOptions(options);
+ * Sets the `defaultDataProjection` on the options, if no `dataProjection`
+ * is set.
+ * @param {olx.format.WriteOptions|olx.format.ReadOptions|undefined} options
+ * Options.
+ * @protected
+ * @return {olx.format.WriteOptions|olx.format.ReadOptions|undefined}
+ * Updated options.
+ol.format.Feature.prototype.adaptOptions = function(options) {
+ return ol.obj.assign({
+ dataProjection: this.defaultDataProjection,
+ featureProjection: this.defaultFeatureProjection
+ }, options);
+ * @abstract
+ * @return {ol.format.FormatType} Format.
+ol.format.Feature.prototype.getType = function() {};
+ * Read a single feature from a source.
+ * @abstract
+ * @param {olx.format.ReadOptions=} opt_options Read options.
+ * @return {ol.Feature} Feature.
+ol.format.Feature.prototype.readFeature = function(source, opt_options) {};
+ * Read all features from a source.
+ * @abstract
+ * @param {Document|Node|ArrayBuffer|Object|string} source Source.
+ * @return {Array.<ol.Feature>} Features.
+ol.format.Feature.prototype.readFeatures = function(source, opt_options) {};
+ * Read a single geometry from a source.
+ * @abstract
+ * @return {ol.geom.Geometry} Geometry.
+ol.format.Feature.prototype.readGeometry = function(source, opt_options) {};
+ * Read the projection from a source.
+ * @abstract
+ * @return {ol.proj.Projection} Projection.
+ol.format.Feature.prototype.readProjection = function(source) {};
+ * Encode a feature in this format.
+ * @abstract
+ * @param {ol.Feature} feature Feature.
+ * @param {olx.format.WriteOptions=} opt_options Write options.
+ * @return {string} Result.
+ol.format.Feature.prototype.writeFeature = function(feature, opt_options) {};
+ * Encode an array of features in this format.
+ * @abstract
+ * @param {Array.<ol.Feature>} features Features.
+ol.format.Feature.prototype.writeFeatures = function(features, opt_options) {};
+ * Write a single geometry in this format.
+ * @abstract
+ * @param {ol.geom.Geometry} geometry Geometry.
+ol.format.Feature.prototype.writeGeometry = function(geometry, opt_options) {};
+ * @param {ol.geom.Geometry|ol.Extent} geometry Geometry.
+ * @param {boolean} write Set to true for writing, false for reading.
+ * @param {(olx.format.WriteOptions|olx.format.ReadOptions)=} opt_options
+ * Options.
+ * @return {ol.geom.Geometry|ol.Extent} Transformed geometry.
+ * @protected
+ol.format.Feature.transformWithOptions = function(
+ geometry, write, opt_options) {
+ var featureProjection = opt_options ?
+ ol.proj.get(opt_options.featureProjection) : null;
+ var dataProjection = opt_options ?
+ ol.proj.get(opt_options.dataProjection) : null;
+ * @type {ol.geom.Geometry|ol.Extent}
+ var transformed;
+ if (featureProjection && dataProjection &&
+ !ol.proj.equivalent(featureProjection, dataProjection)) {
+ if (geometry instanceof ol.geom.Geometry) {
+ transformed = (write ? geometry.clone() : geometry).transform(
+ write ? featureProjection : dataProjection,
+ write ? dataProjection : featureProjection);
+ } else {
+ // FIXME this is necessary because ol.format.GML treats extents
+ // as geometries
+ transformed = ol.proj.transformExtent(
+ write ? geometry.slice() : geometry,
+ } else {
+ transformed = geometry;
+ if (write && opt_options && opt_options.decimals) {
+ var power = Math.pow(10, opt_options.decimals);
+ // if decimals option on write, round each coordinate appropriately
+ * @param {Array.<number>} coordinates Coordinates.
+ * @return {Array.<number>} Transformed coordinates.
+ var transform = function(coordinates) {
+ for (var i = 0, ii = coordinates.length; i < ii; ++i) {
+ coordinates[i] = Math.round(coordinates[i] * power) / power;
+ return coordinates;
+ if (Array.isArray(transformed)) {
+ transform(transformed);
+ } else {
+ transformed.applyTransform(transform);
+ return transformed;
+goog.provide('ol.format.JSONFeature');
+goog.require('ol.format.Feature');
+ * @classdesc
+ * Base class for JSON feature formats.
+ * @constructor
+ * @abstract
+ * @extends {ol.format.Feature}
+ol.format.JSONFeature = function() {
+ ol.format.Feature.call(this);
+ol.inherits(ol.format.JSONFeature, ol.format.Feature);
+ * @private
+ * @return {Object} Object.
+ol.format.JSONFeature.prototype.getObject_ = function(source) {
+ if (typeof source === 'string') {
+ var object = JSON.parse(source);
+ return object ? /** @type {Object} */ (object) : null;
+ } else if (source !== null) {
+ return source;
+ } else {
+ return null;
+ * @inheritDoc
+ol.format.JSONFeature.prototype.getType = function() {
+ return ol.format.FormatType.JSON;
+ * @inheritDoc
+ol.format.JSONFeature.prototype.readFeature = function(source, opt_options) {
+ return this.readFeatureFromObject(
+ this.getObject_(source), this.getReadOptions(source, opt_options));
+ * @inheritDoc
+ol.format.JSONFeature.prototype.readFeatures = function(source, opt_options) {
+ return this.readFeaturesFromObject(
+ * @abstract
+ * @param {Object} object Object.
+ * @protected
+ol.format.JSONFeature.prototype.readFeatureFromObject = function(object, opt_options) {};
+ * @abstract
+ * @protected
+ol.format.JSONFeature.prototype.readFeaturesFromObject = function(object, opt_options) {};
+ * @inheritDoc
+ol.format.JSONFeature.prototype.readGeometry = function(source, opt_options) {
+ return this.readGeometryFromObject(
+ * @abstract
+ * @protected
+ol.format.JSONFeature.prototype.readGeometryFromObject = function(object, opt_options) {};
+ * @inheritDoc
+ol.format.JSONFeature.prototype.readProjection = function(source) {
+ return this.readProjectionFromObject(this.getObject_(source));
+ * @abstract
+ * @protected
+ol.format.JSONFeature.prototype.readProjectionFromObject = function(object) {};
+ * @inheritDoc
+ol.format.JSONFeature.prototype.writeFeature = function(feature, opt_options) {
+ return JSON.stringify(this.writeFeatureObject(feature, opt_options));
+ * @abstract
+ol.format.JSONFeature.prototype.writeFeatureObject = function(feature, opt_options) {};
+ * @inheritDoc
+ol.format.JSONFeature.prototype.writeFeatures = function(features, opt_options) {
+ return JSON.stringify(this.writeFeaturesObject(features, opt_options));
+ * @abstract
+ol.format.JSONFeature.prototype.writeFeaturesObject = function(features, opt_options) {};
+ * @inheritDoc
+ol.format.JSONFeature.prototype.writeGeometry = function(geometry, opt_options) {
+ return JSON.stringify(this.writeGeometryObject(geometry, opt_options));
+ * @abstract
+ol.format.JSONFeature.prototype.writeGeometryObject = function(geometry, opt_options) {};
+goog.provide('ol.geom.flat.interpolate');
+goog.require('ol.math');
+ * @param {Array.<number>} flatCoordinates Flat coordinates.
+ * @param {number} offset Offset.
+ * @param {number} end End.
+ * @param {number} stride Stride.
+ * @param {number} fraction Fraction.
+ * @param {Array.<number>=} opt_dest Destination.
+ * @return {Array.<number>} Destination.
+ol.geom.flat.interpolate.lineString = function(flatCoordinates, offset, end, stride, fraction, opt_dest) {
+ var pointX = NaN;
+ var pointY = NaN;
+ var n = (end - offset) / stride;
+ if (n === 1) {
+ pointX = flatCoordinates[offset];
+ pointY = flatCoordinates[offset + 1];
+ } else if (n == 2) {
+ pointX = (1 - fraction) * flatCoordinates[offset] +
+ fraction * flatCoordinates[offset + stride];
+ pointY = (1 - fraction) * flatCoordinates[offset + 1] +
+ fraction * flatCoordinates[offset + stride + 1];
+ } else if (n !== 0) {
+ var x1 = flatCoordinates[offset];
+ var y1 = flatCoordinates[offset + 1];
+ var length = 0;
+ var cumulativeLengths = [0];
+ var i;
+ for (i = offset + stride; i < end; i += stride) {
+ var x2 = flatCoordinates[i];
+ var y2 = flatCoordinates[i + 1];
+ length += Math.sqrt((x2 - x1) * (x2 - x1) + (y2 - y1) * (y2 - y1));
+ cumulativeLengths.push(length);
+ x1 = x2;
+ y1 = y2;
+ var target = fraction * length;
+ var index = ol.array.binarySearch(cumulativeLengths, target);
+ if (index < 0) {
+ var t = (target - cumulativeLengths[-index - 2]) /
+ (cumulativeLengths[-index - 1] - cumulativeLengths[-index - 2]);
+ var o = offset + (-index - 2) * stride;
+ pointX = ol.math.lerp(
+ flatCoordinates[o], flatCoordinates[o + stride], t);
+ pointY = ol.math.lerp(
+ flatCoordinates[o + 1], flatCoordinates[o + stride + 1], t);
+ } else {
+ pointX = flatCoordinates[offset + index * stride];
+ pointY = flatCoordinates[offset + index * stride + 1];
+ if (opt_dest) {
+ opt_dest[0] = pointX;
+ opt_dest[1] = pointY;
+ return opt_dest;
+ } else {
+ return [pointX, pointY];
+ * @param {number} m M.
+ * @param {boolean} extrapolate Extrapolate.
+ * @return {ol.Coordinate} Coordinate.
+ol.geom.flat.interpolate.lineStringCoordinateAtM = function(flatCoordinates, offset, end, stride, m, extrapolate) {
+ if (end == offset) {
+ return null;
+ var coordinate;
+ if (m < flatCoordinates[offset + stride - 1]) {
+ if (extrapolate) {
+ coordinate = flatCoordinates.slice(offset, offset + stride);
+ coordinate[stride - 1] = m;
+ return coordinate;
+ } else {
+ return null;
+ } else if (flatCoordinates[end - 1] < m) {
+ coordinate = flatCoordinates.slice(end - stride, end);
+ } else {
+ return null;
+ // FIXME use O(1) search
+ if (m == flatCoordinates[offset + stride - 1]) {
+ return flatCoordinates.slice(offset, offset + stride);
+ var lo = offset / stride;
+ var hi = end / stride;
+ while (lo < hi) {
+ var mid = (lo + hi) >> 1;
+ if (m < flatCoordinates[(mid + 1) * stride - 1]) {
+ hi = mid;
+ } else {
+ lo = mid + 1;
+ var m0 = flatCoordinates[lo * stride - 1];
+ if (m == m0) {
+ return flatCoordinates.slice((lo - 1) * stride, (lo - 1) * stride + stride);
+ var m1 = flatCoordinates[(lo + 1) * stride - 1];
+ var t = (m - m0) / (m1 - m0);
+ coordinate = [];
+ var i;
+ for (i = 0; i < stride - 1; ++i) {
+ coordinate.push(ol.math.lerp(flatCoordinates[(lo - 1) * stride + i],
+ flatCoordinates[lo * stride + i], t));
+ coordinate.push(m);
+ * @param {Array.<number>} ends Ends.
+ * @param {boolean} interpolate Interpolate.
+ol.geom.flat.interpolate.lineStringsCoordinateAtM = function(
+ flatCoordinates, offset, ends, stride, m, extrapolate, interpolate) {
+ if (interpolate) {
+ return ol.geom.flat.interpolate.lineStringCoordinateAtM(
+ flatCoordinates, offset, ends[ends.length - 1], stride, m, extrapolate);
+ var coordinate;
+ if (m < flatCoordinates[stride - 1]) {
+ coordinate = flatCoordinates.slice(0, stride);
+ } else {
+ return null;
+ if (flatCoordinates[flatCoordinates.length - 1] < m) {
+ coordinate = flatCoordinates.slice(flatCoordinates.length - stride);
+ } else {
+ return null;
+ var i, ii;
+ for (i = 0, ii = ends.length; i < ii; ++i) {
+ var end = ends[i];
+ if (offset == end) {
+ continue;
+ return null;
+ } else if (m <= flatCoordinates[end - 1]) {
+ flatCoordinates, offset, end, stride, m, false);
+ offset = end;
+ return null;
+goog.provide('ol.geom.flat.length');
+ * @return {number} Length.
+ol.geom.flat.length.lineString = function(flatCoordinates, offset, end, stride) {
+ var length = 0;
+ var i;
+ x1 = x2;
+ y1 = y2;
+ return length;
+ * @return {number} Perimeter.
+ol.geom.flat.length.linearRing = function(flatCoordinates, offset, end, stride) {
+ var perimeter =
+ ol.geom.flat.length.lineString(flatCoordinates, offset, end, stride);
+ var dx = flatCoordinates[end - stride] - flatCoordinates[offset];
+ var dy = flatCoordinates[end - stride + 1] - flatCoordinates[offset + 1];
+ perimeter += Math.sqrt(dx * dx + dy * dy);
+ return perimeter;
+goog.provide('ol.geom.LineString');
+goog.require('ol.extent');
+goog.require('ol.geom.GeometryLayout');
+goog.require('ol.geom.SimpleGeometry');
+goog.require('ol.geom.flat.closest');
+goog.require('ol.geom.flat.deflate');
+goog.require('ol.geom.flat.inflate');
+goog.require('ol.geom.flat.interpolate');
+goog.require('ol.geom.flat.intersectsextent');
+goog.require('ol.geom.flat.length');
+goog.require('ol.geom.flat.segments');
+goog.require('ol.geom.flat.simplify');
+ * @classdesc
+ * Linestring geometry.
+ * @constructor
+ * @extends {ol.geom.SimpleGeometry}
+ * @param {Array.<ol.Coordinate>} coordinates Coordinates.
+ * @param {ol.geom.GeometryLayout=} opt_layout Layout.
+ * @api
+ol.geom.LineString = function(coordinates, opt_layout) {
+ ol.geom.SimpleGeometry.call(this);
+ * @private
+ * @type {ol.Coordinate}
+ this.flatMidpoint_ = null;
+ * @private
+ * @type {number}
+ this.flatMidpointRevision_ = -1;
+ * @private
+ * @type {number}
+ this.maxDelta_ = -1;
+ * @private
+ * @type {number}
+ this.maxDeltaRevision_ = -1;
+ this.setCoordinates(coordinates, opt_layout);
+ol.inherits(ol.geom.LineString, ol.geom.SimpleGeometry);
+ * Append the passed coordinate to the coordinates of the linestring.
+ * @param {ol.Coordinate} coordinate Coordinate.
+ * @api
+ol.geom.LineString.prototype.appendCoordinate = function(coordinate) {
+ if (!this.flatCoordinates) {
+ this.flatCoordinates = coordinate.slice();
+ } else {
+ ol.array.extend(this.flatCoordinates, coordinate);
+ this.changed();
+ * Make a complete copy of the geometry.
+ * @return {!ol.geom.LineString} Clone.
+ * @override
+ * @api
+ol.geom.LineString.prototype.clone = function() {
+ var lineString = new ol.geom.LineString(null);
+ lineString.setFlatCoordinates(this.layout, this.flatCoordinates.slice());
+ return lineString;
+ * @inheritDoc
+ol.geom.LineString.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
+ if (minSquaredDistance <
+ ol.extent.closestSquaredDistanceXY(this.getExtent(), x, y)) {
+ return minSquaredDistance;
+ if (this.maxDeltaRevision_ != this.getRevision()) {
+ this.maxDelta_ = Math.sqrt(ol.geom.flat.closest.getMaxSquaredDelta(
+ this.flatCoordinates, 0, this.flatCoordinates.length, this.stride, 0));
+ this.maxDeltaRevision_ = this.getRevision();
+ return ol.geom.flat.closest.getClosestPoint(
+ this.maxDelta_, false, x, y, closestPoint, minSquaredDistance);
+ * Iterate over each segment, calling the provided callback.
+ * If the callback returns a truthy value the function returns that
+ * value immediately. Otherwise the function returns `false`.
+ * @param {function(this: S, ol.Coordinate, ol.Coordinate): T} callback Function
+ * called for each segment.
+ * @param {S=} opt_this The object to be used as the value of 'this'
+ * within callback.
+ * @return {T|boolean} Value.
+ * @template T,S
+ * @api
+ol.geom.LineString.prototype.forEachSegment = function(callback, opt_this) {
+ return ol.geom.flat.segments.forEach(this.flatCoordinates, 0,
+ this.flatCoordinates.length, this.stride, callback, opt_this);
+ * Returns the coordinate at `m` using linear interpolation, or `null` if no
+ * such coordinate exists.
+ * `opt_extrapolate` controls extrapolation beyond the range of Ms in the
+ * MultiLineString. If `opt_extrapolate` is `true` then Ms less than the first
+ * M will return the first coordinate and Ms greater than the last M will
+ * return the last coordinate.
+ * @param {boolean=} opt_extrapolate Extrapolate. Default is `false`.
+ * @api
+ol.geom.LineString.prototype.getCoordinateAtM = function(m, opt_extrapolate) {
+ if (this.layout != ol.geom.GeometryLayout.XYM &&
+ this.layout != ol.geom.GeometryLayout.XYZM) {
+ return null;
+ var extrapolate = opt_extrapolate !== undefined ? opt_extrapolate : false;
+ return ol.geom.flat.interpolate.lineStringCoordinateAtM(this.flatCoordinates, 0,
+ this.flatCoordinates.length, this.stride, m, extrapolate);
+ * Return the coordinates of the linestring.
+ * @return {Array.<ol.Coordinate>} Coordinates.
+ * @override
+ * @api
+ol.geom.LineString.prototype.getCoordinates = function() {
+ return ol.geom.flat.inflate.coordinates(
+ this.flatCoordinates, 0, this.flatCoordinates.length, this.stride);
+ * Return the coordinate at the provided fraction along the linestring.
+ * The `fraction` is a number between 0 and 1, where 0 is the start of the
+ * linestring and 1 is the end.
+ * @param {ol.Coordinate=} opt_dest Optional coordinate whose values will
+ * be modified. If not provided, a new coordinate will be returned.
+ * @return {ol.Coordinate} Coordinate of the interpolated point.
+ * @api
+ol.geom.LineString.prototype.getCoordinateAt = function(fraction, opt_dest) {
+ return ol.geom.flat.interpolate.lineString(
+ fraction, opt_dest);
+ * Return the length of the linestring on projected plane.
+ * @return {number} Length (on projected plane).
+ * @api
+ol.geom.LineString.prototype.getLength = function() {
+ return ol.geom.flat.length.lineString(
+ * @return {Array.<number>} Flat midpoint.
+ol.geom.LineString.prototype.getFlatMidpoint = function() {
+ if (this.flatMidpointRevision_ != this.getRevision()) {
+ this.flatMidpoint_ = this.getCoordinateAt(0.5, this.flatMidpoint_);
+ this.flatMidpointRevision_ = this.getRevision();
+ return this.flatMidpoint_;
+ * @inheritDoc
+ol.geom.LineString.prototype.getSimplifiedGeometryInternal = function(squaredTolerance) {
+ var simplifiedFlatCoordinates = [];
+ simplifiedFlatCoordinates.length = ol.geom.flat.simplify.douglasPeucker(
+ squaredTolerance, simplifiedFlatCoordinates, 0);
+ var simplifiedLineString = new ol.geom.LineString(null);
+ simplifiedLineString.setFlatCoordinates(
+ ol.geom.GeometryLayout.XY, simplifiedFlatCoordinates);
+ return simplifiedLineString;
+ * @inheritDoc
+ * @api
+ol.geom.LineString.prototype.getType = function() {
+ return ol.geom.GeometryType.LINE_STRING;
+ * @inheritDoc
+ * @api
+ol.geom.LineString.prototype.intersectsExtent = function(extent) {
+ return ol.geom.flat.intersectsextent.lineString(
+ extent);
+ * Set the coordinates of the linestring.
+ * @override
+ * @api
+ol.geom.LineString.prototype.setCoordinates = function(coordinates, opt_layout) {
+ if (!coordinates) {
+ this.setFlatCoordinates(ol.geom.GeometryLayout.XY, null);
+ } else {
+ this.setLayout(opt_layout, coordinates, 1);
+ this.flatCoordinates = [];
+ this.flatCoordinates.length = ol.geom.flat.deflate.coordinates(
+ this.flatCoordinates, 0, coordinates, this.stride);
+ this.changed();
+ * @param {ol.geom.GeometryLayout} layout Layout.
+ol.geom.LineString.prototype.setFlatCoordinates = function(layout, flatCoordinates) {
+ this.setFlatCoordinatesInternal(layout, flatCoordinates);
+ this.changed();
+goog.provide('ol.geom.MultiLineString');
+goog.require('ol.geom.LineString');
+ * @classdesc
+ * Multi-linestring geometry.
+ * @constructor
+ * @param {Array.<Array.<ol.Coordinate>>} coordinates Coordinates.
+ * @api
+ol.geom.MultiLineString = function(coordinates, opt_layout) {
+ * @type {Array.<number>}
+ * @private
+ this.ends_ = [];
+ * @private
+ * @type {number}
+ * @private
+ * @type {number}
+ol.inherits(ol.geom.MultiLineString, ol.geom.SimpleGeometry);
+ * Append the passed linestring to the multilinestring.
+ * @param {ol.geom.LineString} lineString LineString.
+ * @api
+ol.geom.MultiLineString.prototype.appendLineString = function(lineString) {
+ this.flatCoordinates = lineString.getFlatCoordinates().slice();
+ } else {
+ ol.array.extend(
+ this.flatCoordinates, lineString.getFlatCoordinates().slice());
+ this.ends_.push(this.flatCoordinates.length);
+ this.changed();
+ * @return {!ol.geom.MultiLineString} Clone.
+ * @override
+ * @api
+ol.geom.MultiLineString.prototype.clone = function() {
+ var multiLineString = new ol.geom.MultiLineString(null);
+ multiLineString.setFlatCoordinates(
+ this.layout, this.flatCoordinates.slice(), this.ends_.slice());
+ return multiLineString;
+ * @inheritDoc
+ol.geom.MultiLineString.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
+ this.maxDelta_ = Math.sqrt(ol.geom.flat.closest.getsMaxSquaredDelta(
+ this.flatCoordinates, 0, this.ends_, this.stride, 0));
+ return ol.geom.flat.closest.getsClosestPoint(
+ * `opt_interpolate` controls interpolation between consecutive LineStrings
+ * within the MultiLineString. If `opt_interpolate` is `true` the coordinates
+ * will be linearly interpolated between the last coordinate of one LineString
+ * and the first coordinate of the next LineString. If `opt_interpolate` is
+ * `false` then the function will return `null` for Ms falling between
+ * LineStrings.
+ * @param {boolean=} opt_interpolate Interpolate. Default is `false`.
+ * @api
+ol.geom.MultiLineString.prototype.getCoordinateAtM = function(m, opt_extrapolate, opt_interpolate) {
+ if ((this.layout != ol.geom.GeometryLayout.XYM &&
+ this.layout != ol.geom.GeometryLayout.XYZM) ||
+ this.flatCoordinates.length === 0) {
+ return null;
+ var interpolate = opt_interpolate !== undefined ? opt_interpolate : false;
+ return ol.geom.flat.interpolate.lineStringsCoordinateAtM(this.flatCoordinates, 0,
+ this.ends_, this.stride, m, extrapolate, interpolate);
+ * Return the coordinates of the multilinestring.
+ * @return {Array.<Array.<ol.Coordinate>>} Coordinates.
+ * @override
+ * @api
+ol.geom.MultiLineString.prototype.getCoordinates = function() {
+ return ol.geom.flat.inflate.coordinatess(
+ this.flatCoordinates, 0, this.ends_, this.stride);
+ * @return {Array.<number>} Ends.
+ol.geom.MultiLineString.prototype.getEnds = function() {
+ return this.ends_;
+ * Return the linestring at the specified index.
+ * @param {number} index Index.
+ * @return {ol.geom.LineString} LineString.
+ * @api
+ol.geom.MultiLineString.prototype.getLineString = function(index) {
+ if (index < 0 || this.ends_.length <= index) {
+ return null;
+ index === 0 ? 0 : this.ends_[index - 1], this.ends_[index]));
+ * Return the linestrings of this multilinestring.
+ * @return {Array.<ol.geom.LineString>} LineStrings.
+ * @api
+ol.geom.MultiLineString.prototype.getLineStrings = function() {
+ var flatCoordinates = this.flatCoordinates;
+ var ends = this.ends_;
+ var layout = this.layout;
+ /** @type {Array.<ol.geom.LineString>} */
+ var lineStrings = [];
+ var offset = 0;
+ var i, ii;
+ lineString.setFlatCoordinates(layout, flatCoordinates.slice(offset, end));
+ lineStrings.push(lineString);
+ offset = end;
+ return lineStrings;
+ * @return {Array.<number>} Flat midpoints.
+ol.geom.MultiLineString.prototype.getFlatMidpoints = function() {
+ var midpoints = [];
+ var offset = 0;
+ var stride = this.stride;
+ var i, ii;
+ var midpoint = ol.geom.flat.interpolate.lineString(
+ flatCoordinates, offset, end, stride, 0.5);
+ ol.array.extend(midpoints, midpoint);
+ offset = end;
+ return midpoints;
+ * @inheritDoc
+ol.geom.MultiLineString.prototype.getSimplifiedGeometryInternal = function(squaredTolerance) {
+ var simplifiedEnds = [];
+ simplifiedFlatCoordinates.length = ol.geom.flat.simplify.douglasPeuckers(
+ this.flatCoordinates, 0, this.ends_, this.stride, squaredTolerance,
+ simplifiedFlatCoordinates, 0, simplifiedEnds);
+ var simplifiedMultiLineString = new ol.geom.MultiLineString(null);
+ simplifiedMultiLineString.setFlatCoordinates(
+ ol.geom.GeometryLayout.XY, simplifiedFlatCoordinates, simplifiedEnds);
+ return simplifiedMultiLineString;
+ * @inheritDoc
+ * @api
+ol.geom.MultiLineString.prototype.getType = function() {
+ return ol.geom.GeometryType.MULTI_LINE_STRING;
+ * @inheritDoc
+ * @api
+ol.geom.MultiLineString.prototype.intersectsExtent = function(extent) {
+ return ol.geom.flat.intersectsextent.lineStrings(
+ this.flatCoordinates, 0, this.ends_, this.stride, extent);
+ * Set the coordinates of the multilinestring.
+ * @override
+ * @api
+ol.geom.MultiLineString.prototype.setCoordinates = function(coordinates, opt_layout) {
+ this.setFlatCoordinates(ol.geom.GeometryLayout.XY, null, this.ends_);
+ } else {
+ this.setLayout(opt_layout, coordinates, 2);
+ var ends = ol.geom.flat.deflate.coordinatess(
+ this.flatCoordinates, 0, coordinates, this.stride, this.ends_);
+ this.flatCoordinates.length = ends.length === 0 ? 0 : ends[ends.length - 1];
+ this.changed();
+ol.geom.MultiLineString.prototype.setFlatCoordinates = function(layout, flatCoordinates, ends) {
+ this.ends_ = ends;
+ this.changed();
+ * @param {Array.<ol.geom.LineString>} lineStrings LineStrings.
+ol.geom.MultiLineString.prototype.setLineStrings = function(lineStrings) {
+ var layout = this.getLayout();
+ var flatCoordinates = [];
+ var ends = [];
+ var i, ii;
+ for (i = 0, ii = lineStrings.length; i < ii; ++i) {
+ var lineString = lineStrings[i];
+ if (i === 0) {
+ layout = lineString.getLayout();
+ ol.array.extend(flatCoordinates, lineString.getFlatCoordinates());
+ ends.push(flatCoordinates.length);
+ this.setFlatCoordinates(layout, flatCoordinates, ends);
+goog.provide('ol.geom.MultiPoint');
+goog.require('ol.geom.Point');
+ * @classdesc
+ * Multi-point geometry.
+ * @constructor
+ * @api
+ol.geom.MultiPoint = function(coordinates, opt_layout) {
+ol.inherits(ol.geom.MultiPoint, ol.geom.SimpleGeometry);
+ * Append the passed point to this multipoint.
+ * @param {ol.geom.Point} point Point.
+ * @api
+ol.geom.MultiPoint.prototype.appendPoint = function(point) {
+ this.flatCoordinates = point.getFlatCoordinates().slice();
+ } else {
+ ol.array.extend(this.flatCoordinates, point.getFlatCoordinates());
+ this.changed();
+ * @return {!ol.geom.MultiPoint} Clone.
+ * @override
+ * @api
+ol.geom.MultiPoint.prototype.clone = function() {
+ var multiPoint = new ol.geom.MultiPoint(null);
+ multiPoint.setFlatCoordinates(this.layout, this.flatCoordinates.slice());
+ return multiPoint;
+ * @inheritDoc
+ol.geom.MultiPoint.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
+ var i, ii, j;
+ for (i = 0, ii = flatCoordinates.length; i < ii; i += stride) {
+ var squaredDistance = ol.math.squaredDistance(
+ x, y, flatCoordinates[i], flatCoordinates[i + 1]);
+ if (squaredDistance < minSquaredDistance) {
+ minSquaredDistance = squaredDistance;
+ for (j = 0; j < stride; ++j) {
+ closestPoint[j] = flatCoordinates[i + j];
+ closestPoint.length = stride;
+ * Return the coordinates of the multipoint.
+ * @override
+ * @api
+ol.geom.MultiPoint.prototype.getCoordinates = function() {
+ * Return the point at the specified index.
+ * @return {ol.geom.Point} Point.
+ * @api
+ol.geom.MultiPoint.prototype.getPoint = function(index) {
+ var n = !this.flatCoordinates ?
+ 0 : this.flatCoordinates.length / this.stride;
+ if (index < 0 || n <= index) {
+ return null;
+ var point = new ol.geom.Point(null);
+ point.setFlatCoordinates(this.layout, this.flatCoordinates.slice(
+ index * this.stride, (index + 1) * this.stride));
+ return point;
+ * Return the points of this multipoint.
+ * @return {Array.<ol.geom.Point>} Points.
+ * @api
+ol.geom.MultiPoint.prototype.getPoints = function() {
+ /** @type {Array.<ol.geom.Point>} */
+ var points = [];
+ var i, ii;
+ point.setFlatCoordinates(layout, flatCoordinates.slice(i, i + stride));
+ points.push(point);
+ return points;
+ * @inheritDoc
+ * @api
+ol.geom.MultiPoint.prototype.getType = function() {
+ return ol.geom.GeometryType.MULTI_POINT;
+ * @inheritDoc
+ * @api
+ol.geom.MultiPoint.prototype.intersectsExtent = function(extent) {
+ var i, ii, x, y;
+ x = flatCoordinates[i];
+ y = flatCoordinates[i + 1];
+ if (ol.extent.containsXY(extent, x, y)) {
+ return true;
+ return false;
+ * Set the coordinates of the multipoint.
+ * @override
+ * @api
+ol.geom.MultiPoint.prototype.setCoordinates = function(coordinates, opt_layout) {
+ } else {
+ this.changed();
+ol.geom.MultiPoint.prototype.setFlatCoordinates = function(layout, flatCoordinates) {
+ this.changed();
+goog.provide('ol.geom.flat.center');
+ * @param {Array.<Array.<number>>} endss Endss.
+ * @return {Array.<number>} Flat centers.
+ol.geom.flat.center.linearRingss = function(flatCoordinates, offset, endss, stride) {
+ var flatCenters = [];
+ var i, ii;
+ var extent = ol.extent.createEmpty();
+ for (i = 0, ii = endss.length; i < ii; ++i) {
+ var ends = endss[i];
+ extent = ol.extent.createOrUpdateFromFlatCoordinates(
+ flatCoordinates, offset, ends[0], stride);
+ flatCenters.push((extent[0] + extent[2]) / 2, (extent[1] + extent[3]) / 2);
+ offset = ends[ends.length - 1];
+ return flatCenters;
+goog.provide('ol.geom.MultiPolygon');
+goog.require('ol');
+goog.require('ol.geom.MultiPoint');
+goog.require('ol.geom.Polygon');
+goog.require('ol.geom.flat.area');
+goog.require('ol.geom.flat.center');
+goog.require('ol.geom.flat.contains');
+goog.require('ol.geom.flat.interiorpoint');
+goog.require('ol.geom.flat.orient');
+ * @classdesc
+ * Multi-polygon geometry.
+ * @constructor
+ * @param {Array.<Array.<Array.<ol.Coordinate>>>} coordinates Coordinates.
+ * @api
+ol.geom.MultiPolygon = function(coordinates, opt_layout) {
+ * @type {Array.<Array.<number>>}
+ * @private
+ this.endss_ = [];
+ * @private
+ * @type {number}
+ this.flatInteriorPointsRevision_ = -1;
+ * @private
+ this.flatInteriorPoints_ = null;
+ * @private
+ * @type {number}
+ * @private
+ * @type {number}
+ * @private
+ * @type {number}
+ this.orientedRevision_ = -1;
+ * @private
+ this.orientedFlatCoordinates_ = null;
+ol.inherits(ol.geom.MultiPolygon, ol.geom.SimpleGeometry);
+ * Append the passed polygon to this multipolygon.
+ * @param {ol.geom.Polygon} polygon Polygon.
+ * @api
+ol.geom.MultiPolygon.prototype.appendPolygon = function(polygon) {
+ /** @type {Array.<number>} */
+ var ends;
+ this.flatCoordinates = polygon.getFlatCoordinates().slice();
+ ends = polygon.getEnds().slice();
+ this.endss_.push();
+ } else {
+ var offset = this.flatCoordinates.length;
+ ol.array.extend(this.flatCoordinates, polygon.getFlatCoordinates());
+ var i, ii;
+ ends[i] += offset;
+ this.endss_.push(ends);
+ this.changed();
+ * @return {!ol.geom.MultiPolygon} Clone.
+ * @override
+ * @api
+ol.geom.MultiPolygon.prototype.clone = function() {
+ var multiPolygon = new ol.geom.MultiPolygon(null);
+ var len = this.endss_.length;
+ var newEndss = new Array(len);
+ for (var i = 0; i < len; ++i) {
+ newEndss[i] = this.endss_[i].slice();
+ multiPolygon.setFlatCoordinates(
+ this.layout, this.flatCoordinates.slice(), newEndss);
+ return multiPolygon;
+ * @inheritDoc
+ol.geom.MultiPolygon.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
+ this.maxDelta_ = Math.sqrt(ol.geom.flat.closest.getssMaxSquaredDelta(
+ this.flatCoordinates, 0, this.endss_, this.stride, 0));
+ return ol.geom.flat.closest.getssClosestPoint(
+ this.getOrientedFlatCoordinates(), 0, this.endss_, this.stride,
+ this.maxDelta_, true, x, y, closestPoint, minSquaredDistance);
+ * @inheritDoc
+ol.geom.MultiPolygon.prototype.containsXY = function(x, y) {
+ return ol.geom.flat.contains.linearRingssContainsXY(
+ this.getOrientedFlatCoordinates(), 0, this.endss_, this.stride, x, y);
+ * Return the area of the multipolygon on projected plane.
+ * @return {number} Area (on projected plane).
+ * @api
+ol.geom.MultiPolygon.prototype.getArea = function() {
+ return ol.geom.flat.area.linearRingss(
+ this.getOrientedFlatCoordinates(), 0, this.endss_, this.stride);
+ * Get the coordinate array for this geometry. This array has the structure
+ * of a GeoJSON coordinate array for multi-polygons.
+ * @param {boolean=} opt_right Orient coordinates according to the right-hand
+ * rule (counter-clockwise for exterior and clockwise for interior rings).
+ * If `false`, coordinates will be oriented according to the left-hand rule
+ * (clockwise for exterior and counter-clockwise for interior rings).
+ * By default, coordinate orientation will depend on how the geometry was
+ * constructed.
+ * @return {Array.<Array.<Array.<ol.Coordinate>>>} Coordinates.
+ * @override
+ * @api
+ol.geom.MultiPolygon.prototype.getCoordinates = function(opt_right) {
+ var flatCoordinates;
+ if (opt_right !== undefined) {
+ flatCoordinates = this.getOrientedFlatCoordinates().slice();
+ ol.geom.flat.orient.orientLinearRingss(
+ flatCoordinates, 0, this.endss_, this.stride, opt_right);
+ } else {
+ flatCoordinates = this.flatCoordinates;
+ return ol.geom.flat.inflate.coordinatesss(
+ flatCoordinates, 0, this.endss_, this.stride);
+ * @return {Array.<Array.<number>>} Endss.
+ol.geom.MultiPolygon.prototype.getEndss = function() {
+ return this.endss_;
+ * @return {Array.<number>} Flat interior points.
+ol.geom.MultiPolygon.prototype.getFlatInteriorPoints = function() {
+ if (this.flatInteriorPointsRevision_ != this.getRevision()) {
+ var flatCenters = ol.geom.flat.center.linearRingss(
+ this.flatCoordinates, 0, this.endss_, this.stride);
+ this.flatInteriorPoints_ = ol.geom.flat.interiorpoint.linearRingss(
+ flatCenters);
+ this.flatInteriorPointsRevision_ = this.getRevision();
+ return this.flatInteriorPoints_;
+ * Return the interior points as {@link ol.geom.MultiPoint multipoint}.
+ * @return {ol.geom.MultiPoint} Interior points.
+ * @api
+ol.geom.MultiPolygon.prototype.getInteriorPoints = function() {
+ var interiorPoints = new ol.geom.MultiPoint(null);
+ interiorPoints.setFlatCoordinates(ol.geom.GeometryLayout.XY,
+ this.getFlatInteriorPoints().slice());
+ return interiorPoints;
+ * @return {Array.<number>} Oriented flat coordinates.
+ol.geom.MultiPolygon.prototype.getOrientedFlatCoordinates = function() {
+ if (this.orientedRevision_ != this.getRevision()) {
+ if (ol.geom.flat.orient.linearRingssAreOriented(
+ flatCoordinates, 0, this.endss_, this.stride)) {
+ this.orientedFlatCoordinates_ = flatCoordinates;
+ } else {
+ this.orientedFlatCoordinates_ = flatCoordinates.slice();
+ this.orientedFlatCoordinates_.length =
+ this.orientedFlatCoordinates_, 0, this.endss_, this.stride);
+ this.orientedRevision_ = this.getRevision();
+ return this.orientedFlatCoordinates_;
+ * @inheritDoc
+ol.geom.MultiPolygon.prototype.getSimplifiedGeometryInternal = function(squaredTolerance) {
+ var simplifiedEndss = [];
+ simplifiedFlatCoordinates.length = ol.geom.flat.simplify.quantizess(
+ Math.sqrt(squaredTolerance),
+ simplifiedFlatCoordinates, 0, simplifiedEndss);
+ var simplifiedMultiPolygon = new ol.geom.MultiPolygon(null);
+ simplifiedMultiPolygon.setFlatCoordinates(
+ ol.geom.GeometryLayout.XY, simplifiedFlatCoordinates, simplifiedEndss);
+ return simplifiedMultiPolygon;
+ * Return the polygon at the specified index.
+ * @return {ol.geom.Polygon} Polygon.
+ * @api
+ol.geom.MultiPolygon.prototype.getPolygon = function(index) {
+ if (index < 0 || this.endss_.length <= index) {
+ return null;
+ var offset;
+ if (index === 0) {
+ offset = 0;
+ } else {
+ var prevEnds = this.endss_[index - 1];
+ offset = prevEnds[prevEnds.length - 1];
+ var ends = this.endss_[index].slice();
+ var end = ends[ends.length - 1];
+ if (offset !== 0) {
+ var i, ii;
+ ends[i] -= offset;
+ var polygon = new ol.geom.Polygon(null);
+ polygon.setFlatCoordinates(
+ this.layout, this.flatCoordinates.slice(offset, end), ends);
+ return polygon;
+ * Return the polygons of this multipolygon.
+ * @return {Array.<ol.geom.Polygon>} Polygons.
+ * @api
+ol.geom.MultiPolygon.prototype.getPolygons = function() {
+ var endss = this.endss_;
+ var polygons = [];
+ var offset = 0;
+ var i, ii, j, jj;
+ var ends = endss[i].slice();
+ for (j = 0, jj = ends.length; j < jj; ++j) {
+ ends[j] -= offset;
+ layout, flatCoordinates.slice(offset, end), ends);
+ polygons.push(polygon);
+ offset = end;
+ return polygons;
+ * @inheritDoc
+ * @api
+ol.geom.MultiPolygon.prototype.getType = function() {
+ return ol.geom.GeometryType.MULTI_POLYGON;
+ * @inheritDoc
+ * @api
+ol.geom.MultiPolygon.prototype.intersectsExtent = function(extent) {
+ return ol.geom.flat.intersectsextent.linearRingss(
+ this.getOrientedFlatCoordinates(), 0, this.endss_, this.stride, extent);
+ * Set the coordinates of the multipolygon.
+ * @override
+ * @api
+ol.geom.MultiPolygon.prototype.setCoordinates = function(coordinates, opt_layout) {
+ this.setFlatCoordinates(ol.geom.GeometryLayout.XY, null, this.endss_);
+ } else {
+ this.setLayout(opt_layout, coordinates, 3);
+ var endss = ol.geom.flat.deflate.coordinatesss(
+ this.flatCoordinates, 0, coordinates, this.stride, this.endss_);
+ if (endss.length === 0) {
+ this.flatCoordinates.length = 0;
+ } else {
+ var lastEnds = endss[endss.length - 1];
+ this.flatCoordinates.length = lastEnds.length === 0 ?
+ 0 : lastEnds[lastEnds.length - 1];
+ this.changed();
+ol.geom.MultiPolygon.prototype.setFlatCoordinates = function(layout, flatCoordinates, endss) {
+ this.endss_ = endss;
+ this.changed();
+ * @param {Array.<ol.geom.Polygon>} polygons Polygons.
+ol.geom.MultiPolygon.prototype.setPolygons = function(polygons) {
+ var endss = [];
+ var i, ii, ends;
+ for (i = 0, ii = polygons.length; i < ii; ++i) {
+ var polygon = polygons[i];
+ if (i === 0) {
+ layout = polygon.getLayout();
+ var offset = flatCoordinates.length;
+ ends = polygon.getEnds();
+ var j, jj;
+ ends[j] += offset;
+ ol.array.extend(flatCoordinates, polygon.getFlatCoordinates());
+ endss.push(ends);
+ this.setFlatCoordinates(layout, flatCoordinates, endss);
+goog.provide('ol.format.EsriJSON');
+goog.require('ol.Feature');
+goog.require('ol.asserts');
+goog.require('ol.format.JSONFeature');
+goog.require('ol.geom.GeometryType');
+goog.require('ol.geom.LinearRing');
+goog.require('ol.geom.MultiLineString');
+goog.require('ol.geom.MultiPolygon');
+ * @classdesc
+ * Feature format for reading and writing data in the EsriJSON format.
+ * @constructor
+ * @extends {ol.format.JSONFeature}
+ * @param {olx.format.EsriJSONOptions=} opt_options Options.
+ * @api
+ol.format.EsriJSON = function(opt_options) {
+ var options = opt_options ? opt_options : {};
+ ol.format.JSONFeature.call(this);
+ * Name of the geometry attribute for features.
+ * @type {string|undefined}
+ * @private
+ this.geometryName_ = options.geometryName;
+ol.inherits(ol.format.EsriJSON, ol.format.JSONFeature);
+ * @param {EsriJSONGeometry} object Object.
+ * @private
+ol.format.EsriJSON.readGeometry_ = function(object, opt_options) {
+ if (!object) {
+ return null;
+ /** @type {ol.geom.GeometryType} */
+ var type;
+ if (typeof object.x === 'number' && typeof object.y === 'number') {
+ type = ol.geom.GeometryType.POINT;
+ } else if (object.points) {
+ type = ol.geom.GeometryType.MULTI_POINT;
+ } else if (object.paths) {
+ if (object.paths.length === 1) {
+ type = ol.geom.GeometryType.LINE_STRING;
+ } else {
+ type = ol.geom.GeometryType.MULTI_LINE_STRING;
+ } else if (object.rings) {
+ var layout = ol.format.EsriJSON.getGeometryLayout_(object);
+ var rings = ol.format.EsriJSON.convertRings_(object.rings, layout);
+ object = /** @type {EsriJSONGeometry} */(ol.obj.assign({}, object));
+ if (rings.length === 1) {
+ type = ol.geom.GeometryType.POLYGON;
+ object.rings = rings[0];
+ } else {
+ type = ol.geom.GeometryType.MULTI_POLYGON;
+ object.rings = rings;
+ var geometryReader = ol.format.EsriJSON.GEOMETRY_READERS_[type];
+ return /** @type {ol.geom.Geometry} */ (
+ ol.format.Feature.transformWithOptions(
+ geometryReader(object), false, opt_options));
+ * Determines inner and outer rings.
+ * Checks if any polygons in this array contain any other polygons in this
+ * array. It is used for checking for holes.
+ * Logic inspired by: https://github.com/Esri/terraformer-arcgis-parser
+ * @param {Array.<!Array.<!Array.<number>>>} rings Rings.
+ * @param {ol.geom.GeometryLayout} layout Geometry layout.
+ * @private
+ * @return {Array.<!Array.<!Array.<number>>>} Transformed rings.
+ol.format.EsriJSON.convertRings_ = function(rings, layout) {
+ var flatRing = [];
+ var outerRings = [];
+ var holes = [];
+ var i, ii;
+ for (i = 0, ii = rings.length; i < ii; ++i) {
+ flatRing.length = 0;
+ ol.geom.flat.deflate.coordinates(flatRing, 0, rings[i], layout.length);
+ // is this ring an outer ring? is it clockwise?
+ var clockwise = ol.geom.flat.orient.linearRingIsClockwise(flatRing, 0,
+ flatRing.length, layout.length);
+ if (clockwise) {
+ outerRings.push([rings[i]]);
+ } else {
+ holes.push(rings[i]);
+ while (holes.length) {
+ var hole = holes.shift();
+ var matched = false;
+ // loop over all outer rings and see if they contain our hole.
+ for (i = outerRings.length - 1; i >= 0; i--) {
+ var outerRing = outerRings[i][0];
+ if (ol.extent.containsExtent(new ol.geom.LinearRing(
+ outerRing).getExtent(),
+ new ol.geom.LinearRing(hole).getExtent())) {
+ // the hole is contained push it into our polygon
+ outerRings[i].push(hole);
+ matched = true;
+ break;
+ if (!matched) {
+ // no outer rings contain this hole turn it into and outer
+ // ring (reverse it)
+ outerRings.push([hole.reverse()]);
+ return outerRings;
+ * @private
+ * @return {ol.geom.Geometry} Point.
+ol.format.EsriJSON.readPointGeometry_ = function(object) {
+ var point;
+ if (object.m !== undefined && object.z !== undefined) {
+ point = new ol.geom.Point([object.x, object.y, object.z, object.m],
+ ol.geom.GeometryLayout.XYZM);
+ } else if (object.z !== undefined) {
+ point = new ol.geom.Point([object.x, object.y, object.z],
+ ol.geom.GeometryLayout.XYZ);
+ } else if (object.m !== undefined) {
+ point = new ol.geom.Point([object.x, object.y, object.m],
+ ol.geom.GeometryLayout.XYM);
+ } else {
+ point = new ol.geom.Point([object.x, object.y]);
+ return point;
+ * @private
+ * @return {ol.geom.Geometry} LineString.
+ol.format.EsriJSON.readLineStringGeometry_ = function(object) {
+ return new ol.geom.LineString(object.paths[0], layout);
+ * @private
+ * @return {ol.geom.Geometry} MultiLineString.
+ol.format.EsriJSON.readMultiLineStringGeometry_ = function(object) {
+ return new ol.geom.MultiLineString(object.paths, layout);
+ * @private
+ * @return {ol.geom.GeometryLayout} The geometry layout to use.
+ol.format.EsriJSON.getGeometryLayout_ = function(object) {
+ var layout = ol.geom.GeometryLayout.XY;
+ if (object.hasZ === true && object.hasM === true) {
+ layout = ol.geom.GeometryLayout.XYZM;
+ } else if (object.hasZ === true) {
+ layout = ol.geom.GeometryLayout.XYZ;
+ } else if (object.hasM === true) {
+ layout = ol.geom.GeometryLayout.XYM;
+ return layout;
+ * @private
+ * @return {ol.geom.Geometry} MultiPoint.
+ol.format.EsriJSON.readMultiPointGeometry_ = function(object) {
+ return new ol.geom.MultiPoint(object.points, layout);
+ * @private
+ * @return {ol.geom.Geometry} MultiPolygon.
+ol.format.EsriJSON.readMultiPolygonGeometry_ = function(object) {
+ return new ol.geom.MultiPolygon(
+ /** @type {Array.<Array.<Array.<Array.<number>>>>} */(object.rings),
+ layout);
+ * @private
+ * @return {ol.geom.Geometry} Polygon.
+ol.format.EsriJSON.readPolygonGeometry_ = function(object) {
+ return new ol.geom.Polygon(object.rings, layout);
+ * @private
+ * @return {EsriJSONGeometry} EsriJSON geometry.
+ol.format.EsriJSON.writePointGeometry_ = function(geometry, opt_options) {
+ var coordinates = /** @type {ol.geom.Point} */ (geometry).getCoordinates();
+ var esriJSON;
+ var layout = /** @type {ol.geom.Point} */ (geometry).getLayout();
+ if (layout === ol.geom.GeometryLayout.XYZ) {
+ esriJSON = /** @type {EsriJSONPoint} */ ({
+ x: coordinates[0],
+ y: coordinates[1],
+ z: coordinates[2]
+ } else if (layout === ol.geom.GeometryLayout.XYM) {
+ m: coordinates[2]
+ } else if (layout === ol.geom.GeometryLayout.XYZM) {
+ z: coordinates[2],
+ m: coordinates[3]
+ } else if (layout === ol.geom.GeometryLayout.XY) {
+ y: coordinates[1]
+ } else {
+ ol.asserts.assert(false, 34); // Invalid geometry layout
+ return /** @type {EsriJSONGeometry} */ (esriJSON);
+ * @param {ol.geom.SimpleGeometry} geometry Geometry.
+ * @private
+ * @return {Object} Object with boolean hasZ and hasM keys.
+ol.format.EsriJSON.getHasZM_ = function(geometry) {
+ var layout = geometry.getLayout();
+ return {
+ hasZ: (layout === ol.geom.GeometryLayout.XYZ ||
+ layout === ol.geom.GeometryLayout.XYZM),
+ hasM: (layout === ol.geom.GeometryLayout.XYM ||
+ * @private
+ * @return {EsriJSONPolyline} EsriJSON geometry.
+ol.format.EsriJSON.writeLineStringGeometry_ = function(geometry, opt_options) {
+ var hasZM = ol.format.EsriJSON.getHasZM_(/** @type {ol.geom.LineString} */ (geometry));
+ return /** @type {EsriJSONPolyline} */ ({
+ hasZ: hasZM.hasZ,
+ hasM: hasZM.hasM,
+ paths: [
+ /** @type {ol.geom.LineString} */ (geometry).getCoordinates()
+ * @private
+ * @return {EsriJSONPolygon} EsriJSON geometry.
+ol.format.EsriJSON.writePolygonGeometry_ = function(geometry, opt_options) {
+ // Esri geometries use the left-hand rule
+ var hasZM = ol.format.EsriJSON.getHasZM_(/** @type {ol.geom.Polygon} */ (geometry));
+ return /** @type {EsriJSONPolygon} */ ({
+ hasZ: hasZM.hasZ,
+ hasM: hasZM.hasM,
+ rings: /** @type {ol.geom.Polygon} */ (geometry).getCoordinates(false)
+ * @private
+ol.format.EsriJSON.writeMultiLineStringGeometry_ = function(geometry, opt_options) {
+ var hasZM = ol.format.EsriJSON.getHasZM_(/** @type {ol.geom.MultiLineString} */ (geometry));
+ hasZ: hasZM.hasZ,
+ hasM: hasZM.hasM,
+ paths: /** @type {ol.geom.MultiLineString} */ (geometry).getCoordinates()
+ * @private
+ * @return {EsriJSONMultipoint} EsriJSON geometry.
+ol.format.EsriJSON.writeMultiPointGeometry_ = function(geometry, opt_options) {
+ var hasZM = ol.format.EsriJSON.getHasZM_(/** @type {ol.geom.MultiPoint} */ (geometry));
+ return /** @type {EsriJSONMultipoint} */ ({
+ hasZ: hasZM.hasZ,
+ hasM: hasZM.hasM,
+ points: /** @type {ol.geom.MultiPoint} */ (geometry).getCoordinates()
+ * @private
+ol.format.EsriJSON.writeMultiPolygonGeometry_ = function(geometry,
+ opt_options) {
+ var hasZM = ol.format.EsriJSON.getHasZM_(/** @type {ol.geom.MultiPolygon} */ (geometry));
+ var coordinates = /** @type {ol.geom.MultiPolygon} */ (geometry).getCoordinates(false);
+ var output = [];
+ for (var i = 0; i < coordinates.length; i++) {
+ for (var x = coordinates[i].length - 1; x >= 0; x--) {
+ output.push(coordinates[i][x]);
+ hasZ: hasZM.hasZ,
+ hasM: hasZM.hasM,
+ rings: output
+ * @const
+ * @private
+ * @type {Object.<ol.geom.GeometryType, function(EsriJSONGeometry): ol.geom.Geometry>}
+ol.format.EsriJSON.GEOMETRY_READERS_ = {};
+ol.format.EsriJSON.GEOMETRY_READERS_[ol.geom.GeometryType.POINT] =
+ ol.format.EsriJSON.readPointGeometry_;
+ol.format.EsriJSON.GEOMETRY_READERS_[ol.geom.GeometryType.LINE_STRING] =
+ ol.format.EsriJSON.readLineStringGeometry_;
+ol.format.EsriJSON.GEOMETRY_READERS_[ol.geom.GeometryType.POLYGON] =
+ ol.format.EsriJSON.readPolygonGeometry_;
+ol.format.EsriJSON.GEOMETRY_READERS_[ol.geom.GeometryType.MULTI_POINT] =
+ ol.format.EsriJSON.readMultiPointGeometry_;
+ol.format.EsriJSON.GEOMETRY_READERS_[ol.geom.GeometryType.MULTI_LINE_STRING] =
+ ol.format.EsriJSON.readMultiLineStringGeometry_;
+ol.format.EsriJSON.GEOMETRY_READERS_[ol.geom.GeometryType.MULTI_POLYGON] =
+ ol.format.EsriJSON.readMultiPolygonGeometry_;
+ * @const
+ * @private
+ * @type {Object.<string, function(ol.geom.Geometry, olx.format.WriteOptions=): (EsriJSONGeometry)>}
+ol.format.EsriJSON.GEOMETRY_WRITERS_ = {};
+ol.format.EsriJSON.GEOMETRY_WRITERS_[ol.geom.GeometryType.POINT] =
+ ol.format.EsriJSON.writePointGeometry_;
+ol.format.EsriJSON.GEOMETRY_WRITERS_[ol.geom.GeometryType.LINE_STRING] =
+ ol.format.EsriJSON.writeLineStringGeometry_;
+ol.format.EsriJSON.GEOMETRY_WRITERS_[ol.geom.GeometryType.POLYGON] =
+ ol.format.EsriJSON.writePolygonGeometry_;
+ol.format.EsriJSON.GEOMETRY_WRITERS_[ol.geom.GeometryType.MULTI_POINT] =
+ ol.format.EsriJSON.writeMultiPointGeometry_;
+ol.format.EsriJSON.GEOMETRY_WRITERS_[ol.geom.GeometryType.MULTI_LINE_STRING] =
+ ol.format.EsriJSON.writeMultiLineStringGeometry_;
+ol.format.EsriJSON.GEOMETRY_WRITERS_[ol.geom.GeometryType.MULTI_POLYGON] =
+ ol.format.EsriJSON.writeMultiPolygonGeometry_;
+ * Read a feature from a EsriJSON Feature source. Only works for Feature,
+ * use `readFeatures` to read FeatureCollection source.
+ * @function
+ * @param {ArrayBuffer|Document|Node|Object|string} source Source.
+ * @api
+ol.format.EsriJSON.prototype.readFeature;
+ * Read all features from a EsriJSON source. Works with both Feature and
+ * FeatureCollection sources.
+ * @function
+ * @api
+ol.format.EsriJSON.prototype.readFeatures;
+ * @inheritDoc
+ol.format.EsriJSON.prototype.readFeatureFromObject = function(
+ object, opt_options) {
+ var esriJSONFeature = /** @type {EsriJSONFeature} */ (object);
+ var geometry = ol.format.EsriJSON.readGeometry_(esriJSONFeature.geometry,
+ opt_options);
+ var feature = new ol.Feature();
+ if (this.geometryName_) {
+ feature.setGeometryName(this.geometryName_);
+ feature.setGeometry(geometry);
+ if (opt_options && opt_options.idField &&
+ esriJSONFeature.attributes[opt_options.idField]) {
+ feature.setId(/** @type {number} */(
+ esriJSONFeature.attributes[opt_options.idField]));
+ if (esriJSONFeature.attributes) {
+ feature.setProperties(esriJSONFeature.attributes);
+ return feature;
+ * @inheritDoc
+ol.format.EsriJSON.prototype.readFeaturesFromObject = function(
+ var esriJSONObject = /** @type {EsriJSONObject} */ (object);
+ if (esriJSONObject.features) {
+ var esriJSONFeatureCollection = /** @type {EsriJSONFeatureCollection} */
+ (object);
+ /** @type {Array.<ol.Feature>} */
+ var features = [];
+ var esriJSONFeatures = esriJSONFeatureCollection.features;
+ var i, ii;
+ options.idField = object.objectIdFieldName;
+ for (i = 0, ii = esriJSONFeatures.length; i < ii; ++i) {
+ features.push(this.readFeatureFromObject(esriJSONFeatures[i],
+ options));
+ return features;
+ } else {
+ return [this.readFeatureFromObject(object, options)];
+ * Read a geometry from a EsriJSON source.
+ * @function
+ * @api
+ol.format.EsriJSON.prototype.readGeometry;
+ * @inheritDoc
+ol.format.EsriJSON.prototype.readGeometryFromObject = function(
+ return ol.format.EsriJSON.readGeometry_(
+ /** @type {EsriJSONGeometry} */ (object), opt_options);
+ * Read the projection from a EsriJSON source.
+ * @function
+ * @api
+ol.format.EsriJSON.prototype.readProjection;
+ * @inheritDoc
+ol.format.EsriJSON.prototype.readProjectionFromObject = function(object) {
+ if (esriJSONObject.spatialReference && esriJSONObject.spatialReference.wkid) {
+ var crs = esriJSONObject.spatialReference.wkid;
+ return ol.proj.get('EPSG:' + crs);
+ } else {
+ return null;
+ * @private
+ol.format.EsriJSON.writeGeometry_ = function(geometry, opt_options) {
+ var geometryWriter = ol.format.EsriJSON.GEOMETRY_WRITERS_[geometry.getType()];
+ return geometryWriter(/** @type {ol.geom.Geometry} */ (
+ ol.format.Feature.transformWithOptions(geometry, true, opt_options)),
+ opt_options);
+ * Encode a geometry as a EsriJSON string.
+ * @function
+ * @return {string} EsriJSON.
+ * @api
+ol.format.EsriJSON.prototype.writeGeometry;
+ * Encode a geometry as a EsriJSON object.
+ * @return {EsriJSONGeometry} Object.
+ * @override
+ * @api
+ol.format.EsriJSON.prototype.writeGeometryObject = function(geometry,
+ opt_options) {
+ return ol.format.EsriJSON.writeGeometry_(geometry,
+ this.adaptOptions(opt_options));
+ * Encode a feature as a EsriJSON Feature string.
+ * @function
+ * @api
+ol.format.EsriJSON.prototype.writeFeature;
+ * Encode a feature as a esriJSON Feature object.
+ * @override
+ * @api
+ol.format.EsriJSON.prototype.writeFeatureObject = function(
+ feature, opt_options) {
+ opt_options = this.adaptOptions(opt_options);
+ var object = {};
+ var geometry = feature.getGeometry();
+ if (geometry) {
+ object['geometry'] =
+ ol.format.EsriJSON.writeGeometry_(geometry, opt_options);
+ var properties = feature.getProperties();
+ delete properties[feature.getGeometryName()];
+ if (!ol.obj.isEmpty(properties)) {
+ object['attributes'] = properties;
+ } else {
+ object['attributes'] = {};
+ if (opt_options && opt_options.featureProjection) {
+ object['spatialReference'] = /** @type {EsriJSONCRS} */({
+ wkid: ol.proj.get(
+ opt_options.featureProjection).getCode().split(':').pop()
+ return object;
+ * Encode an array of features as EsriJSON.
+ * @function
+ * @api
+ol.format.EsriJSON.prototype.writeFeatures;
+ * Encode an array of features as a EsriJSON object.
+ * @return {Object} EsriJSON Object.
+ * @override
+ * @api
+ol.format.EsriJSON.prototype.writeFeaturesObject = function(features, opt_options) {
+ var objects = [];
+ var i, ii;
+ for (i = 0, ii = features.length; i < ii; ++i) {
+ objects.push(this.writeFeatureObject(features[i], opt_options));
+ return /** @type {EsriJSONFeatureCollection} */ ({
+ 'features': objects
+goog.provide('ol.format.filter.Filter');
+ * @classdesc
+ * Abstract class; normally only used for creating subclasses and not instantiated in apps.
+ * Base class for WFS GetFeature filters.
+ * @constructor
+ * @param {!string} tagName The XML tag name for this filter.
+ * @struct
+ * @api
+ol.format.filter.Filter = function(tagName) {
+ * @private
+ * @type {!string}
+ this.tagName_ = tagName;
+ * The XML tag name for a filter.
+ * @returns {!string} Name.
+ol.format.filter.Filter.prototype.getTagName = function() {
+ return this.tagName_;
+goog.provide('ol.format.filter.LogicalNary');
+goog.require('ol.format.filter.Filter');
+ * @classdesc
+ * Base class for WFS GetFeature n-ary logical filters.
+ * @constructor
+ * @param {...ol.format.filter.Filter} conditions Conditions.
+ * @extends {ol.format.filter.Filter}
+ol.format.filter.LogicalNary = function(tagName, conditions) {
+ ol.format.filter.Filter.call(this, tagName);
+ * @public
+ * @type {Array.<ol.format.filter.Filter>}
+ this.conditions = Array.prototype.slice.call(arguments, 1);
+ ol.asserts.assert(this.conditions.length >= 2, 57); // At least 2 conditions are required.
+ol.inherits(ol.format.filter.LogicalNary, ol.format.filter.Filter);
+goog.provide('ol.format.filter.And');
+goog.require('ol.format.filter.LogicalNary');
+ * @classdesc
+ * Represents a logical `<And>` operator between two or more filter conditions.
+ * @constructor
+ * @extends {ol.format.filter.LogicalNary}
+ * @api
+ol.format.filter.And = function(conditions) {
+ var params = ['And'].concat(Array.prototype.slice.call(arguments));
+ ol.format.filter.LogicalNary.apply(this, params);
+ol.inherits(ol.format.filter.And, ol.format.filter.LogicalNary);
+goog.provide('ol.format.filter.Bbox');
+ * @classdesc
+ * Represents a `<BBOX>` operator to test whether a geometry-valued property
+ * intersects a fixed bounding box
+ * @constructor
+ * @param {!string} geometryName Geometry name to use.
+ * @param {!ol.Extent} extent Extent.
+ * @param {string=} opt_srsName SRS name. No srsName attribute will be
+ * set on geometries when this is not provided.
+ * @api
+ol.format.filter.Bbox = function(geometryName, extent, opt_srsName) {
+ ol.format.filter.Filter.call(this, 'BBOX');
+ * @public
+ * @type {!string}
+ this.geometryName = geometryName;
+ * @public
+ * @type {ol.Extent}
+ this.extent = extent;
+ * @public
+ this.srsName = opt_srsName;
+ol.inherits(ol.format.filter.Bbox, ol.format.filter.Filter);
+goog.provide('ol.format.filter.Comparison');
+ * @classdesc
+ * Base class for WFS GetFeature property comparison filters.
+ * @constructor
+ * @param {!string} propertyName Name of the context property to compare.
+ * @api
+ol.format.filter.Comparison = function(tagName, propertyName) {
+ * @public
+ * @type {!string}
+ this.propertyName = propertyName;
+ol.inherits(ol.format.filter.Comparison, ol.format.filter.Filter);
+goog.provide('ol.format.filter.ComparisonBinary');
+goog.require('ol.format.filter.Comparison');
+ * @classdesc
+ * Base class for WFS GetFeature property binary comparison filters.
+ * @constructor
+ * @param {!(string|number)} expression The value to compare.
+ * @param {boolean=} opt_matchCase Case-sensitive?
+ * @extends {ol.format.filter.Comparison}
+ * @api
+ol.format.filter.ComparisonBinary = function(
+ tagName, propertyName, expression, opt_matchCase) {
+ ol.format.filter.Comparison.call(this, tagName, propertyName);
+ * @public
+ * @type {!(string|number)}
+ this.expression = expression;
+ * @public
+ * @type {boolean|undefined}
+ this.matchCase = opt_matchCase;
+ol.inherits(ol.format.filter.ComparisonBinary, ol.format.filter.Comparison);
+goog.provide('ol.format.filter.EqualTo');
+goog.require('ol.format.filter.ComparisonBinary');
+ * @classdesc
+ * Represents a `<PropertyIsEqualTo>` comparison operator.
+ * @constructor
+ * @extends {ol.format.filter.ComparisonBinary}
+ * @api
+ol.format.filter.EqualTo = function(propertyName, expression, opt_matchCase) {
+ ol.format.filter.ComparisonBinary.call(this, 'PropertyIsEqualTo', propertyName, expression, opt_matchCase);
+ol.inherits(ol.format.filter.EqualTo, ol.format.filter.ComparisonBinary);
+goog.provide('ol.format.filter.GreaterThan');
+ * @classdesc
+ * Represents a `<PropertyIsGreaterThan>` comparison operator.
+ * @constructor
+ * @param {!number} expression The value to compare.
+ * @api
+ol.format.filter.GreaterThan = function(propertyName, expression) {
+ ol.format.filter.ComparisonBinary.call(this, 'PropertyIsGreaterThan', propertyName, expression);
+ol.inherits(ol.format.filter.GreaterThan, ol.format.filter.ComparisonBinary);
+goog.provide('ol.format.filter.GreaterThanOrEqualTo');
+ * @classdesc
+ * Represents a `<PropertyIsGreaterThanOrEqualTo>` comparison operator.
+ * @constructor
+ * @api
+ol.format.filter.GreaterThanOrEqualTo = function(propertyName, expression) {
+ ol.format.filter.ComparisonBinary.call(this, 'PropertyIsGreaterThanOrEqualTo', propertyName, expression);
+ol.inherits(ol.format.filter.GreaterThanOrEqualTo, ol.format.filter.ComparisonBinary);
+goog.provide('ol.format.filter.Spatial');
+ * @classdesc
+ * Represents a spatial operator to test whether a geometry-valued property
+ * relates to a given geometry.
+ * @constructor
+ * @param {!ol.geom.Geometry} geometry Geometry.
+ * @api
+ol.format.filter.Spatial = function(tagName, geometryName, geometry, opt_srsName) {
+ * @public
+ * @type {!string}
+ this.geometryName = geometryName || 'the_geom';
+ * @public
+ * @type {ol.geom.Geometry}
+ this.geometry = geometry;
+ * @public
+ol.inherits(ol.format.filter.Spatial, ol.format.filter.Filter);
+goog.provide('ol.format.filter.Intersects');
+goog.require('ol.format.filter.Spatial');
+ * @classdesc
+ * Represents a `<Intersects>` operator to test whether a geometry-valued property
+ * intersects a given geometry.
+ * @constructor
+ * @extends {ol.format.filter.Spatial}
+ * @api
+ol.format.filter.Intersects = function(geometryName, geometry, opt_srsName) {
+ ol.format.filter.Spatial.call(this, 'Intersects', geometryName, geometry, opt_srsName);
+ol.inherits(ol.format.filter.Intersects, ol.format.filter.Spatial);
+goog.provide('ol.format.filter.IsBetween');
+ * @classdesc
+ * Represents a `<PropertyIsBetween>` comparison operator.
+ * @constructor
+ * @param {!number} lowerBoundary The lower bound of the range.
+ * @param {!number} upperBoundary The upper bound of the range.
+ * @api
+ol.format.filter.IsBetween = function(propertyName, lowerBoundary, upperBoundary) {
+ ol.format.filter.Comparison.call(this, 'PropertyIsBetween', propertyName);
+ * @public
+ * @type {!number}
+ this.lowerBoundary = lowerBoundary;
+ * @public
+ * @type {!number}
+ this.upperBoundary = upperBoundary;
+ol.inherits(ol.format.filter.IsBetween, ol.format.filter.Comparison);
+goog.provide('ol.format.filter.IsLike');
+ * @classdesc
+ * Represents a `<PropertyIsLike>` comparison operator.
+ * @constructor
+ * @param {!string} pattern Text pattern.
+ * @param {string=} opt_wildCard Pattern character which matches any sequence of
+ * zero or more string characters. Default is '*'.
+ * @param {string=} opt_singleChar pattern character which matches any single
+ * string character. Default is '.'.
+ * @param {string=} opt_escapeChar Escape character which can be used to escape
+ * the pattern characters. Default is '!'.
+ * @api
+ol.format.filter.IsLike = function(propertyName, pattern,
+ opt_wildCard, opt_singleChar, opt_escapeChar, opt_matchCase) {
+ ol.format.filter.Comparison.call(this, 'PropertyIsLike', propertyName);
+ * @public
+ * @type {!string}
+ this.pattern = pattern;
+ * @public
+ * @type {!string}
+ this.wildCard = (opt_wildCard !== undefined) ? opt_wildCard : '*';
+ * @public
+ * @type {!string}
+ this.singleChar = (opt_singleChar !== undefined) ? opt_singleChar : '.';
+ * @public
+ * @type {!string}
+ this.escapeChar = (opt_escapeChar !== undefined) ? opt_escapeChar : '!';
+ * @public
+ol.inherits(ol.format.filter.IsLike, ol.format.filter.Comparison);
+goog.provide('ol.format.filter.IsNull');
+ * @classdesc
+ * Represents a `<PropertyIsNull>` comparison operator.
+ * @constructor
+ * @api
+ol.format.filter.IsNull = function(propertyName) {
+ ol.format.filter.Comparison.call(this, 'PropertyIsNull', propertyName);
+ol.inherits(ol.format.filter.IsNull, ol.format.filter.Comparison);
+goog.provide('ol.format.filter.LessThan');
+ * @classdesc
+ * Represents a `<PropertyIsLessThan>` comparison operator.
+ * @constructor
+ * @api
+ol.format.filter.LessThan = function(propertyName, expression) {
+ ol.format.filter.ComparisonBinary.call(this, 'PropertyIsLessThan', propertyName, expression);
+ol.inherits(ol.format.filter.LessThan, ol.format.filter.ComparisonBinary);
+goog.provide('ol.format.filter.LessThanOrEqualTo');
+ * @classdesc
+ * Represents a `<PropertyIsLessThanOrEqualTo>` comparison operator.
+ * @constructor
+ * @api
+ol.format.filter.LessThanOrEqualTo = function(propertyName, expression) {
+ ol.format.filter.ComparisonBinary.call(this, 'PropertyIsLessThanOrEqualTo', propertyName, expression);
+ol.inherits(ol.format.filter.LessThanOrEqualTo, ol.format.filter.ComparisonBinary);
+goog.provide('ol.format.filter.Not');
+ * @classdesc
+ * Represents a logical `<Not>` operator for a filter condition.
+ * @constructor
+ * @param {!ol.format.filter.Filter} condition Filter condition.
+ * @api
+ol.format.filter.Not = function(condition) {
+ ol.format.filter.Filter.call(this, 'Not');
+ * @public
+ * @type {!ol.format.filter.Filter}
+ this.condition = condition;
+ol.inherits(ol.format.filter.Not, ol.format.filter.Filter);
+goog.provide('ol.format.filter.NotEqualTo');
+ * @classdesc
+ * Represents a `<PropertyIsNotEqualTo>` comparison operator.
+ * @constructor
+ * @api
+ol.format.filter.NotEqualTo = function(propertyName, expression, opt_matchCase) {
+ ol.format.filter.ComparisonBinary.call(this, 'PropertyIsNotEqualTo', propertyName, expression, opt_matchCase);
+ol.inherits(ol.format.filter.NotEqualTo, ol.format.filter.ComparisonBinary);
+goog.provide('ol.format.filter.Or');
+ * @classdesc
+ * Represents a logical `<Or>` operator between two ore more filter conditions.
+ * @constructor
+ * @api
+ol.format.filter.Or = function(conditions) {
+ var params = ['Or'].concat(Array.prototype.slice.call(arguments));
+ol.inherits(ol.format.filter.Or, ol.format.filter.LogicalNary);
+goog.provide('ol.format.filter.Within');
+ * @classdesc
+ * Represents a `<Within>` operator to test whether a geometry-valued property
+ * is within a given geometry.
+ * @constructor
+ * @api
+ol.format.filter.Within = function(geometryName, geometry, opt_srsName) {
+ ol.format.filter.Spatial.call(this, 'Within', geometryName, geometry, opt_srsName);
+ol.inherits(ol.format.filter.Within, ol.format.filter.Spatial);
+goog.provide('ol.format.filter');
+goog.require('ol.format.filter.And');
+goog.require('ol.format.filter.Bbox');
+goog.require('ol.format.filter.EqualTo');
+goog.require('ol.format.filter.GreaterThan');
+goog.require('ol.format.filter.GreaterThanOrEqualTo');
+goog.require('ol.format.filter.Intersects');
+goog.require('ol.format.filter.IsBetween');
+goog.require('ol.format.filter.IsLike');
+goog.require('ol.format.filter.IsNull');
+goog.require('ol.format.filter.LessThan');
+goog.require('ol.format.filter.LessThanOrEqualTo');
+goog.require('ol.format.filter.Not');
+goog.require('ol.format.filter.NotEqualTo');
+goog.require('ol.format.filter.Or');
+goog.require('ol.format.filter.Within');
+ * Create a logical `<And>` operator between two or more filter conditions.
+ * @param {...ol.format.filter.Filter} conditions Filter conditions.
+ * @returns {!ol.format.filter.And} `<And>` operator.
+ * @api
+ol.format.filter.and = function(conditions) {
+ var params = [null].concat(Array.prototype.slice.call(arguments));
+ return new (Function.prototype.bind.apply(ol.format.filter.And, params));
+ * Create a logical `<Or>` operator between two or more filter conditions.
+ * @returns {!ol.format.filter.Or} `<Or>` operator.
+ * @api
+ol.format.filter.or = function(conditions) {
+ return new (Function.prototype.bind.apply(ol.format.filter.Or, params));
+ * @returns {!ol.format.filter.Not} `<Not>` operator.
+ * @api
+ol.format.filter.not = function(condition) {
+ return new ol.format.filter.Not(condition);
+ * Create a `<BBOX>` operator to test whether a geometry-valued property
+ * @returns {!ol.format.filter.Bbox} `<BBOX>` operator.
+ * @api
+ol.format.filter.bbox = function(geometryName, extent, opt_srsName) {
+ return new ol.format.filter.Bbox(geometryName, extent, opt_srsName);
+ * Create a `<Intersects>` operator to test whether a geometry-valued property
+ * @returns {!ol.format.filter.Intersects} `<Intersects>` operator.
+ * @api
+ol.format.filter.intersects = function(geometryName, geometry, opt_srsName) {
+ return new ol.format.filter.Intersects(geometryName, geometry, opt_srsName);
+ * Create a `<Within>` operator to test whether a geometry-valued property
+ * @returns {!ol.format.filter.Within} `<Within>` operator.
+ * @api
+ol.format.filter.within = function(geometryName, geometry, opt_srsName) {
+ return new ol.format.filter.Within(geometryName, geometry, opt_srsName);
+ * Creates a `<PropertyIsEqualTo>` comparison operator.
+ * @returns {!ol.format.filter.EqualTo} `<PropertyIsEqualTo>` operator.
+ * @api
+ol.format.filter.equalTo = function(propertyName, expression, opt_matchCase) {
+ return new ol.format.filter.EqualTo(propertyName, expression, opt_matchCase);
+ * Creates a `<PropertyIsNotEqualTo>` comparison operator.
+ * @returns {!ol.format.filter.NotEqualTo} `<PropertyIsNotEqualTo>` operator.
+ * @api
+ol.format.filter.notEqualTo = function(propertyName, expression, opt_matchCase) {
+ return new ol.format.filter.NotEqualTo(propertyName, expression, opt_matchCase);
+ * Creates a `<PropertyIsLessThan>` comparison operator.
+ * @returns {!ol.format.filter.LessThan} `<PropertyIsLessThan>` operator.
+ * @api
+ol.format.filter.lessThan = function(propertyName, expression) {
+ return new ol.format.filter.LessThan(propertyName, expression);
+ * Creates a `<PropertyIsLessThanOrEqualTo>` comparison operator.
+ * @returns {!ol.format.filter.LessThanOrEqualTo} `<PropertyIsLessThanOrEqualTo>` operator.
+ * @api
+ol.format.filter.lessThanOrEqualTo = function(propertyName, expression) {
+ return new ol.format.filter.LessThanOrEqualTo(propertyName, expression);
+ * Creates a `<PropertyIsGreaterThan>` comparison operator.
+ * @returns {!ol.format.filter.GreaterThan} `<PropertyIsGreaterThan>` operator.
+ * @api
+ol.format.filter.greaterThan = function(propertyName, expression) {
+ return new ol.format.filter.GreaterThan(propertyName, expression);
+ * Creates a `<PropertyIsGreaterThanOrEqualTo>` comparison operator.
+ * @returns {!ol.format.filter.GreaterThanOrEqualTo} `<PropertyIsGreaterThanOrEqualTo>` operator.
+ * @api
+ol.format.filter.greaterThanOrEqualTo = function(propertyName, expression) {
+ return new ol.format.filter.GreaterThanOrEqualTo(propertyName, expression);
+ * Creates a `<PropertyIsNull>` comparison operator to test whether a property value
+ * is null.
+ * @returns {!ol.format.filter.IsNull} `<PropertyIsNull>` operator.
+ * @api
+ol.format.filter.isNull = function(propertyName) {
+ return new ol.format.filter.IsNull(propertyName);
+ * Creates a `<PropertyIsBetween>` comparison operator to test whether an expression
+ * value lies within a range given by a lower and upper bound (inclusive).
+ * @returns {!ol.format.filter.IsBetween} `<PropertyIsBetween>` operator.
+ * @api
+ol.format.filter.between = function(propertyName, lowerBoundary, upperBoundary) {
+ return new ol.format.filter.IsBetween(propertyName, lowerBoundary, upperBoundary);
+ * Represents a `<PropertyIsLike>` comparison operator that matches a string property
+ * value against a text pattern.
+ * @returns {!ol.format.filter.IsLike} `<PropertyIsLike>` operator.
+ * @api
+ol.format.filter.like = function(propertyName, pattern,
+ return new ol.format.filter.IsLike(propertyName, pattern,
+ opt_wildCard, opt_singleChar, opt_escapeChar, opt_matchCase);
+goog.provide('ol.geom.GeometryCollection');
+goog.require('ol.events');
+goog.require('ol.events.EventType');
+goog.require('ol.geom.Geometry');
+goog.require('ol.obj');
+ * @classdesc
+ * An array of {@link ol.geom.Geometry} objects.
+ * @constructor
+ * @extends {ol.geom.Geometry}
+ * @param {Array.<ol.geom.Geometry>=} opt_geometries Geometries.
+ * @api
+ol.geom.GeometryCollection = function(opt_geometries) {
+ ol.geom.Geometry.call(this);
+ * @private
+ * @type {Array.<ol.geom.Geometry>}
+ this.geometries_ = opt_geometries ? opt_geometries : null;
+ this.listenGeometriesChange_();
+ol.inherits(ol.geom.GeometryCollection, ol.geom.Geometry);
+ * @param {Array.<ol.geom.Geometry>} geometries Geometries.
+ * @private
+ * @return {Array.<ol.geom.Geometry>} Cloned geometries.
+ol.geom.GeometryCollection.cloneGeometries_ = function(geometries) {
+ var clonedGeometries = [];
+ var i, ii;
+ for (i = 0, ii = geometries.length; i < ii; ++i) {
+ clonedGeometries.push(geometries[i].clone());
+ return clonedGeometries;
+ * @private
+ol.geom.GeometryCollection.prototype.unlistenGeometriesChange_ = function() {
+ var i, ii;
+ if (!this.geometries_) {
+ return;
+ for (i = 0, ii = this.geometries_.length; i < ii; ++i) {
+ ol.events.unlisten(
+ this.geometries_[i], ol.events.EventType.CHANGE,
+ this.changed, this);
+ * @private
+ol.geom.GeometryCollection.prototype.listenGeometriesChange_ = function() {
+ var i, ii;
+ return;
+ ol.events.listen(
+ * @return {!ol.geom.GeometryCollection} Clone.
+ * @override
+ * @api
+ol.geom.GeometryCollection.prototype.clone = function() {
+ var geometryCollection = new ol.geom.GeometryCollection(null);
+ geometryCollection.setGeometries(this.geometries_);
+ return geometryCollection;
+ * @inheritDoc
+ol.geom.GeometryCollection.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
+ var geometries = this.geometries_;
+ var i, ii;
+ minSquaredDistance = geometries[i].closestPointXY(
+ x, y, closestPoint, minSquaredDistance);
+ * @inheritDoc
+ol.geom.GeometryCollection.prototype.containsXY = function(x, y) {
+ var i, ii;
+ if (geometries[i].containsXY(x, y)) {
+ return true;
+ return false;
+ * @inheritDoc
+ol.geom.GeometryCollection.prototype.computeExtent = function(extent) {
+ ol.extent.createOrUpdateEmpty(extent);
+ for (var i = 0, ii = geometries.length; i < ii; ++i) {
+ ol.extent.extend(extent, geometries[i].getExtent());
+ return extent;
+ * Return the geometries that make up this geometry collection.
+ * @return {Array.<ol.geom.Geometry>} Geometries.
+ * @api
+ol.geom.GeometryCollection.prototype.getGeometries = function() {
+ return ol.geom.GeometryCollection.cloneGeometries_(this.geometries_);
+ol.geom.GeometryCollection.prototype.getGeometriesArray = function() {
+ return this.geometries_;
+ * @inheritDoc
+ol.geom.GeometryCollection.prototype.getSimplifiedGeometry = function(squaredTolerance) {
+ if (this.simplifiedGeometryRevision != this.getRevision()) {
+ ol.obj.clear(this.simplifiedGeometryCache);
+ this.simplifiedGeometryMaxMinSquaredTolerance = 0;
+ this.simplifiedGeometryRevision = this.getRevision();
+ if (squaredTolerance < 0 ||
+ (this.simplifiedGeometryMaxMinSquaredTolerance !== 0 &&
+ squaredTolerance < this.simplifiedGeometryMaxMinSquaredTolerance)) {
+ return this;
+ var key = squaredTolerance.toString();
+ if (this.simplifiedGeometryCache.hasOwnProperty(key)) {
+ return this.simplifiedGeometryCache[key];
+ } else {
+ var simplifiedGeometries = [];
+ var simplified = false;
+ var i, ii;
+ var geometry = geometries[i];
+ var simplifiedGeometry = geometry.getSimplifiedGeometry(squaredTolerance);
+ simplifiedGeometries.push(simplifiedGeometry);
+ if (simplifiedGeometry !== geometry) {
+ simplified = true;
+ if (simplified) {
+ var simplifiedGeometryCollection = new ol.geom.GeometryCollection(null);
+ simplifiedGeometryCollection.setGeometriesArray(simplifiedGeometries);
+ this.simplifiedGeometryCache[key] = simplifiedGeometryCollection;
+ return simplifiedGeometryCollection;
+ } else {
+ this.simplifiedGeometryMaxMinSquaredTolerance = squaredTolerance;
+ return this;
+ * @inheritDoc
+ * @api
+ol.geom.GeometryCollection.prototype.getType = function() {
+ return ol.geom.GeometryType.GEOMETRY_COLLECTION;
+ * @inheritDoc
+ * @api
+ol.geom.GeometryCollection.prototype.intersectsExtent = function(extent) {
+ var i, ii;
+ if (geometries[i].intersectsExtent(extent)) {
+ return true;
+ return false;
+ * @return {boolean} Is empty.
+ol.geom.GeometryCollection.prototype.isEmpty = function() {
+ return this.geometries_.length === 0;
+ * @inheritDoc
+ * @api
+ol.geom.GeometryCollection.prototype.rotate = function(angle, anchor) {
+ geometries[i].rotate(angle, anchor);
+ this.changed();
+ * @inheritDoc
+ * @api
+ol.geom.GeometryCollection.prototype.scale = function(sx, opt_sy, opt_anchor) {
+ var anchor = opt_anchor;
+ if (!anchor) {
+ anchor = ol.extent.getCenter(this.getExtent());
+ geometries[i].scale(sx, opt_sy, anchor);
+ this.changed();
+ * Set the geometries that make up this geometry collection.
+ * @api
+ol.geom.GeometryCollection.prototype.setGeometries = function(geometries) {
+ this.setGeometriesArray(
+ ol.geom.GeometryCollection.cloneGeometries_(geometries));
+ol.geom.GeometryCollection.prototype.setGeometriesArray = function(geometries) {
+ this.unlistenGeometriesChange_();
+ this.geometries_ = geometries;
+ this.changed();
+ * @inheritDoc
+ * @api
+ol.geom.GeometryCollection.prototype.applyTransform = function(transformFn) {
+ var i, ii;
+ geometries[i].applyTransform(transformFn);
+ this.changed();
+ * Translate the geometry.
+ * @param {number} deltaX Delta X.
+ * @param {number} deltaY Delta Y.
+ * @override
+ * @api
+ol.geom.GeometryCollection.prototype.translate = function(deltaX, deltaY) {
+ var i, ii;
+ geometries[i].translate(deltaX, deltaY);
+ this.changed();
+ * @inheritDoc
+ol.geom.GeometryCollection.prototype.disposeInternal = function() {
+ ol.geom.Geometry.prototype.disposeInternal.call(this);
+// TODO: serialize dataProjection as crs member when writing
+// see https://github.com/openlayers/openlayers/issues/2078
+goog.provide('ol.format.GeoJSON');
+goog.require('ol.format.Feature');
+goog.require('ol.geom.GeometryCollection');
+goog.require('ol.proj');
+ * @classdesc
+ * Feature format for reading and writing data in the GeoJSON format.
+ * @constructor
+ * @param {olx.format.GeoJSONOptions=} opt_options Options.
+ * @api
+ol.format.GeoJSON = function(opt_options) {
+ * @inheritDoc
+ this.defaultDataProjection = ol.proj.get(
+ options.defaultDataProjection ?
+ options.defaultDataProjection : 'EPSG:4326');
+ if (options.featureProjection) {
+ this.defaultFeatureProjection = ol.proj.get(options.featureProjection);
+ * @private
+ol.inherits(ol.format.GeoJSON, ol.format.JSONFeature);
+ * @param {GeoJSONGeometry|GeoJSONGeometryCollection} object Object.
+ * @param {olx.format.ReadOptions=} opt_options Read options.
+ * @private
+ * @return {ol.geom.Geometry} Geometry.
+ol.format.GeoJSON.readGeometry_ = function(object, opt_options) {
+ if (!object) {
+ return null;
+ var geometryReader = ol.format.GeoJSON.GEOMETRY_READERS_[object.type];
+ * @param {GeoJSONGeometryCollection} object Object.
+ * @private
+ * @return {ol.geom.GeometryCollection} Geometry collection.
+ol.format.GeoJSON.readGeometryCollectionGeometry_ = function(
+ var geometries = object.geometries.map(
+ * @param {GeoJSONGeometry} geometry Geometry.
+ * @return {ol.geom.Geometry} geometry Geometry.
+ function(geometry) {
+ return ol.format.GeoJSON.readGeometry_(geometry, opt_options);
+ return new ol.geom.GeometryCollection(geometries);
+ * @param {GeoJSONGeometry} object Object.
+ * @private
+ol.format.GeoJSON.readPointGeometry_ = function(object) {
+ return new ol.geom.Point(object.coordinates);
+ * @private
+ol.format.GeoJSON.readLineStringGeometry_ = function(object) {
+ return new ol.geom.LineString(object.coordinates);
+ * @private
+ * @return {ol.geom.MultiLineString} MultiLineString.
+ol.format.GeoJSON.readMultiLineStringGeometry_ = function(object) {
+ return new ol.geom.MultiLineString(object.coordinates);
+ * @private
+ * @return {ol.geom.MultiPoint} MultiPoint.
+ol.format.GeoJSON.readMultiPointGeometry_ = function(object) {
+ return new ol.geom.MultiPoint(object.coordinates);
+ * @private
+ * @return {ol.geom.MultiPolygon} MultiPolygon.
+ol.format.GeoJSON.readMultiPolygonGeometry_ = function(object) {
+ return new ol.geom.MultiPolygon(object.coordinates);
+ * @private
+ol.format.GeoJSON.readPolygonGeometry_ = function(object) {
+ return new ol.geom.Polygon(object.coordinates);
+ * @param {ol.geom.Geometry} geometry Geometry.
+ * @param {olx.format.WriteOptions=} opt_options Write options.
+ * @private
+ * @return {GeoJSONGeometry|GeoJSONGeometryCollection} GeoJSON geometry.
+ol.format.GeoJSON.writeGeometry_ = function(geometry, opt_options) {
+ var geometryWriter = ol.format.GeoJSON.GEOMETRY_WRITERS_[geometry.getType()];
+ opt_options);
+ * @private
+ * @return {GeoJSONGeometryCollection} Empty GeoJSON geometry collection.
+ol.format.GeoJSON.writeEmptyGeometryCollectionGeometry_ = function(geometry) {
+ return /** @type {GeoJSONGeometryCollection} */ ({
+ type: 'GeometryCollection',
+ geometries: []
+ * @param {ol.geom.GeometryCollection} geometry Geometry.
+ * @private
+ * @return {GeoJSONGeometryCollection} GeoJSON geometry collection.
+ol.format.GeoJSON.writeGeometryCollectionGeometry_ = function(
+ geometry, opt_options) {
+ var geometries = geometry.getGeometriesArray().map(function(geometry) {
+ var options = ol.obj.assign({}, opt_options);
+ delete options.featureProjection;
+ return ol.format.GeoJSON.writeGeometry_(geometry, options);
+ geometries: geometries
+ * @param {ol.geom.LineString} geometry Geometry.
+ * @private
+ * @return {GeoJSONGeometry} GeoJSON geometry.
+ol.format.GeoJSON.writeLineStringGeometry_ = function(geometry, opt_options) {
+ return /** @type {GeoJSONGeometry} */ ({
+ type: 'LineString',
+ coordinates: geometry.getCoordinates()
+ * @param {ol.geom.MultiLineString} geometry Geometry.
+ * @private
+ol.format.GeoJSON.writeMultiLineStringGeometry_ = function(geometry, opt_options) {
+ type: 'MultiLineString',
+ * @param {ol.geom.MultiPoint} geometry Geometry.
+ * @private
+ol.format.GeoJSON.writeMultiPointGeometry_ = function(geometry, opt_options) {
+ type: 'MultiPoint',
+ * @param {ol.geom.MultiPolygon} geometry Geometry.
+ * @private
+ol.format.GeoJSON.writeMultiPolygonGeometry_ = function(geometry, opt_options) {
+ var right;
+ if (opt_options) {
+ right = opt_options.rightHanded;
+ type: 'MultiPolygon',
+ coordinates: geometry.getCoordinates(right)
+ * @param {ol.geom.Point} geometry Geometry.
+ * @private
+ol.format.GeoJSON.writePointGeometry_ = function(geometry, opt_options) {
+ type: 'Point',
+ * @param {ol.geom.Polygon} geometry Geometry.
+ * @private
+ol.format.GeoJSON.writePolygonGeometry_ = function(geometry, opt_options) {
+ var right;
+ type: 'Polygon',
+ * @const
+ * @private
+ * @type {Object.<string, function(GeoJSONObject): ol.geom.Geometry>}
+ol.format.GeoJSON.GEOMETRY_READERS_ = {
+ 'Point': ol.format.GeoJSON.readPointGeometry_,
+ 'LineString': ol.format.GeoJSON.readLineStringGeometry_,
+ 'Polygon': ol.format.GeoJSON.readPolygonGeometry_,
+ 'MultiPoint': ol.format.GeoJSON.readMultiPointGeometry_,
+ 'MultiLineString': ol.format.GeoJSON.readMultiLineStringGeometry_,
+ 'MultiPolygon': ol.format.GeoJSON.readMultiPolygonGeometry_,
+ 'GeometryCollection': ol.format.GeoJSON.readGeometryCollectionGeometry_
+ * @const
+ * @private
+ * @type {Object.<string, function(ol.geom.Geometry, olx.format.WriteOptions=): (GeoJSONGeometry|GeoJSONGeometryCollection)>}
+ol.format.GeoJSON.GEOMETRY_WRITERS_ = {
+ 'Point': ol.format.GeoJSON.writePointGeometry_,
+ 'LineString': ol.format.GeoJSON.writeLineStringGeometry_,
+ 'Polygon': ol.format.GeoJSON.writePolygonGeometry_,
+ 'MultiPoint': ol.format.GeoJSON.writeMultiPointGeometry_,
+ 'MultiLineString': ol.format.GeoJSON.writeMultiLineStringGeometry_,
+ 'MultiPolygon': ol.format.GeoJSON.writeMultiPolygonGeometry_,
+ 'GeometryCollection': ol.format.GeoJSON.writeGeometryCollectionGeometry_,
+ 'Circle': ol.format.GeoJSON.writeEmptyGeometryCollectionGeometry_
+ * Read a feature from a GeoJSON Feature source. Only works for Feature or
+ * geometry types. Use {@link ol.format.GeoJSON#readFeatures} to read
+ * FeatureCollection source.
+ * @function
+ * @param {Document|Node|Object|string} source Source.
+ * @return {ol.Feature} Feature.
+ * @api
+ol.format.GeoJSON.prototype.readFeature;
+ * Read all features from a GeoJSON source. Works for all GeoJSON types.
+ * If the source includes only geometries, features will be created with those
+ * geometries.
+ * @function
+ * @return {Array.<ol.Feature>} Features.
+ * @api
+ol.format.GeoJSON.prototype.readFeatures;
+ * @inheritDoc
+ol.format.GeoJSON.prototype.readFeatureFromObject = function(
+ * @type {GeoJSONFeature}
+ var geoJSONFeature = null;
+ if (object.type === 'Feature') {
+ geoJSONFeature = /** @type {GeoJSONFeature} */ (object);
+ } else {
+ geoJSONFeature = /** @type {GeoJSONFeature} */ ({
+ type: 'Feature',
+ geometry: /** @type {GeoJSONGeometry|GeoJSONGeometryCollection} */ (object)
+ var geometry = ol.format.GeoJSON.readGeometry_(geoJSONFeature.geometry, opt_options);
+ if (geoJSONFeature.id !== undefined) {
+ feature.setId(geoJSONFeature.id);
+ if (geoJSONFeature.properties) {
+ feature.setProperties(geoJSONFeature.properties);
+ return feature;
+ * @inheritDoc
+ol.format.GeoJSON.prototype.readFeaturesFromObject = function(
+ var geoJSONObject = /** @type {GeoJSONObject} */ (object);
+ var features = null;
+ if (geoJSONObject.type === 'FeatureCollection') {
+ var geoJSONFeatureCollection = /** @type {GeoJSONFeatureCollection} */
+ (object);
+ features = [];
+ var geoJSONFeatures = geoJSONFeatureCollection.features;
+ var i, ii;
+ for (i = 0, ii = geoJSONFeatures.length; i < ii; ++i) {
+ features.push(this.readFeatureFromObject(geoJSONFeatures[i],
+ opt_options));
+ } else {
+ features = [this.readFeatureFromObject(object, opt_options)];
+ return features;
+ * Read a geometry from a GeoJSON source.
+ * @function
+ * @api
+ol.format.GeoJSON.prototype.readGeometry;
+ * @inheritDoc
+ol.format.GeoJSON.prototype.readGeometryFromObject = function(
+ /** @type {GeoJSONGeometry} */ (object), opt_options);
+ * Read the projection from a GeoJSON source.
+ * @function
+ * @return {ol.proj.Projection} Projection.
+ * @api
+ol.format.GeoJSON.prototype.readProjection;
+ * @inheritDoc
+ol.format.GeoJSON.prototype.readProjectionFromObject = function(object) {
+ var crs = geoJSONObject.crs;
+ var projection;
+ if (crs) {
+ if (crs.type == 'name') {
+ projection = ol.proj.get(crs.properties.name);
+ } else if (crs.type == 'EPSG') {
+ // 'EPSG' is not part of the GeoJSON specification, but is generated by
+ // GeoServer.
+ // TODO: remove this when http://jira.codehaus.org/browse/GEOS-5996
+ // is fixed and widely deployed.
+ projection = ol.proj.get('EPSG:' + crs.properties.code);
+ } else {
+ ol.asserts.assert(false, 36); // Unknown SRS type
+ } else {
+ projection = this.defaultDataProjection;
+ return /** @type {ol.proj.Projection} */ (projection);
+ * Encode a feature as a GeoJSON Feature string.
+ * @function
+ * @param {ol.Feature} feature Feature.
+ * @return {string} GeoJSON.
+ * @override
+ * @api
+ol.format.GeoJSON.prototype.writeFeature;
+ * Encode a feature as a GeoJSON Feature object.
+ * @return {GeoJSONFeature} Object.
+ * @override
+ * @api
+ol.format.GeoJSON.prototype.writeFeatureObject = function(feature, opt_options) {
+ var object = /** @type {GeoJSONFeature} */ ({
+ 'type': 'Feature'
+ var id = feature.getId();
+ if (id !== undefined) {
+ object.id = id;
+ if (geometry) {
+ object.geometry =
+ ol.format.GeoJSON.writeGeometry_(geometry, opt_options);
+ } else {
+ object.geometry = null;
+ object.properties = properties;
+ } else {
+ object.properties = null;
+ return object;
+ * Encode an array of features as GeoJSON.
+ * @function
+ * @param {Array.<ol.Feature>} features Features.
+ * @api
+ol.format.GeoJSON.prototype.writeFeatures;
+ * Encode an array of features as a GeoJSON object.
+ * @return {GeoJSONFeatureCollection} GeoJSON Object.
+ * @override
+ * @api
+ol.format.GeoJSON.prototype.writeFeaturesObject = function(features, opt_options) {
+ var objects = [];
+ var i, ii;
+ return /** @type {GeoJSONFeatureCollection} */ ({
+ type: 'FeatureCollection',
+ features: objects
+ * Encode a geometry as a GeoJSON string.
+ * @function
+ * @api
+ol.format.GeoJSON.prototype.writeGeometry;
+ * Encode a geometry as a GeoJSON object.
+ * @return {GeoJSONGeometry|GeoJSONGeometryCollection} Object.
+ * @override
+ * @api
+ol.format.GeoJSON.prototype.writeGeometryObject = function(geometry,
+ opt_options) {
+goog.provide('ol.format.XMLFeature');
+goog.require('ol.array');
+goog.require('ol.format.FormatType');
+goog.require('ol.xml');
+ * @classdesc
+ * Abstract base class; normally only used for creating subclasses and not
+ * instantiated in apps.
+ * Base class for XML feature formats.
+ * @constructor
+ * @abstract
+ * @extends {ol.format.Feature}
+ol.format.XMLFeature = function() {
+ * @type {XMLSerializer}
+ * @private
+ this.xmlSerializer_ = new XMLSerializer();
+ ol.format.Feature.call(this);
+ol.inherits(ol.format.XMLFeature, ol.format.Feature);
+ * @inheritDoc
+ol.format.XMLFeature.prototype.getType = function() {
+ return ol.format.FormatType.XML;
+ * @inheritDoc
+ol.format.XMLFeature.prototype.readFeature = function(source, opt_options) {
+ if (ol.xml.isDocument(source)) {
+ return this.readFeatureFromDocument(
+ /** @type {Document} */ (source), opt_options);
+ } else if (ol.xml.isNode(source)) {
+ return this.readFeatureFromNode(/** @type {Node} */ (source), opt_options);
+ } else if (typeof source === 'string') {
+ var doc = ol.xml.parse(source);
+ return this.readFeatureFromDocument(doc, opt_options);
+ } else {
+ return null;
+ * @param {Document} doc Document.
+ * @param {olx.format.ReadOptions=} opt_options Options.
+ol.format.XMLFeature.prototype.readFeatureFromDocument = function(
+ doc, opt_options) {
+ var features = this.readFeaturesFromDocument(doc, opt_options);
+ if (features.length > 0) {
+ return features[0];
+ } else {
+ return null;
+ * @param {Node} node Node.
+ol.format.XMLFeature.prototype.readFeatureFromNode = function(node, opt_options) {
+ return null; // not implemented
+ * @inheritDoc
+ol.format.XMLFeature.prototype.readFeatures = function(source, opt_options) {
+ return this.readFeaturesFromDocument(
+ return this.readFeaturesFromNode(/** @type {Node} */ (source), opt_options);
+ return this.readFeaturesFromDocument(doc, opt_options);
+ } else {
+ return [];
+ * @protected
+ol.format.XMLFeature.prototype.readFeaturesFromDocument = function(
+ var n;
+ for (n = doc.firstChild; n; n = n.nextSibling) {
+ if (n.nodeType == Node.ELEMENT_NODE) {
+ ol.array.extend(features, this.readFeaturesFromNode(n, opt_options));
+ return features;
+ * @abstract
+ * @protected
+ol.format.XMLFeature.prototype.readFeaturesFromNode = function(node, opt_options) {};
+ * @inheritDoc
+ol.format.XMLFeature.prototype.readGeometry = function(source, opt_options) {
+ return this.readGeometryFromDocument(
+ return this.readGeometryFromNode(/** @type {Node} */ (source), opt_options);
+ return this.readGeometryFromDocument(doc, opt_options);
+ } else {
+ return null;
+ * @protected
+ol.format.XMLFeature.prototype.readGeometryFromDocument = function(doc, opt_options) {
+ * @protected
+ol.format.XMLFeature.prototype.readGeometryFromNode = function(node, opt_options) {
+ * @inheritDoc
+ol.format.XMLFeature.prototype.readProjection = function(source) {
+ return this.readProjectionFromDocument(/** @type {Document} */ (source));
+ return this.readProjectionFromNode(/** @type {Node} */ (source));
+ return this.readProjectionFromDocument(doc);
+ } else {
+ return null;
+ * @protected
+ol.format.XMLFeature.prototype.readProjectionFromDocument = function(doc) {
+ return this.defaultDataProjection;
+ * @protected
+ol.format.XMLFeature.prototype.readProjectionFromNode = function(node) {
+ * @inheritDoc
+ol.format.XMLFeature.prototype.writeFeature = function(feature, opt_options) {
+ var node = this.writeFeatureNode(feature, opt_options);
+ return this.xmlSerializer_.serializeToString(node);
+ * @param {olx.format.WriteOptions=} opt_options Options.
+ * @protected
+ * @return {Node} Node.
+ol.format.XMLFeature.prototype.writeFeatureNode = function(feature, opt_options) {
+ * @inheritDoc
+ol.format.XMLFeature.prototype.writeFeatures = function(features, opt_options) {
+ var node = this.writeFeaturesNode(features, opt_options);
+ol.format.XMLFeature.prototype.writeFeaturesNode = function(features, opt_options) {
+ * @inheritDoc
+ol.format.XMLFeature.prototype.writeGeometry = function(geometry, opt_options) {
+ var node = this.writeGeometryNode(geometry, opt_options);
+ol.format.XMLFeature.prototype.writeGeometryNode = function(geometry, opt_options) {
+// FIXME Envelopes should not be treated as geometries! readEnvelope_ is part
+// of GEOMETRY_PARSERS_ and methods using GEOMETRY_PARSERS_ do not expect
+// envelopes/extents, only geometries!
+goog.provide('ol.format.GMLBase');
+goog.require('ol');
+goog.require('ol.format.XMLFeature');
+goog.require('ol.geom.GeometryLayout');
+goog.require('ol.geom.LineString');
+goog.require('ol.geom.MultiPoint');
+goog.require('ol.geom.Point');
+goog.require('ol.geom.Polygon');
+ * @classdesc
+ * Feature base format for reading and writing data in the GML format.
+ * This class cannot be instantiated, it contains only base content that
+ * is shared with versioned format classes ol.format.GML2 and
+ * ol.format.GML3.
+ * @constructor
+ * @abstract
+ * @param {olx.format.GMLOptions=} opt_options
+ * Optional configuration object.
+ * @extends {ol.format.XMLFeature}
+ol.format.GMLBase = function(opt_options) {
+ var options = /** @type {olx.format.GMLOptions} */
+ (opt_options ? opt_options : {});
+ * @protected
+ * @type {Array.<string>|string|undefined}
+ this.featureType = options.featureType;
+ * @protected
+ * @type {Object.<string, string>|string|undefined}
+ this.featureNS = options.featureNS;
+ * @protected
+ * @type {string}
+ this.srsName = options.srsName;
+ * @protected
+ * @type {string}
+ this.schemaLocation = '';
+ * @type {Object.<string, Object.<string, Object>>}
+ this.FEATURE_COLLECTION_PARSERS = {};
+ this.FEATURE_COLLECTION_PARSERS[ol.format.GMLBase.GMLNS] = {
+ 'featureMember': ol.xml.makeReplacer(
+ ol.format.GMLBase.prototype.readFeaturesInternal),
+ 'featureMembers': ol.xml.makeReplacer(
+ ol.format.XMLFeature.call(this);
+ol.inherits(ol.format.GMLBase, ol.format.XMLFeature);
+ * @const
+ * @type {string}
+ol.format.GMLBase.GMLNS = 'http://www.opengis.net/gml';
+ * A regular expression that matches if a string only contains whitespace
+ * characters. It will e.g. match `''`, `' '`, `'\n'` etc. The non-breaking
+ * space (0xa0) is explicitly included as IE doesn't include it in its
+ * definition of `\s`.
+ * Information from `goog.string.isEmptyOrWhitespace`: https://github.com/google/closure-library/blob/e877b1e/closure/goog/string/string.js#L156-L160
+ * @const
+ * @type {RegExp}
+ * @private
+ol.format.GMLBase.ONLY_WHITESPACE_RE_ = /^[\s\xa0]*$/;
+ * @param {Array.<*>} objectStack Object stack.
+ * @return {Array.<ol.Feature> | undefined} Features.
+ol.format.GMLBase.prototype.readFeaturesInternal = function(node, objectStack) {
+ var localName = node.localName;
+ if (localName == 'FeatureCollection') {
+ if (node.namespaceURI === 'http://www.opengis.net/wfs') {
+ features = ol.xml.pushParseAndPop([],
+ this.FEATURE_COLLECTION_PARSERS, node,
+ objectStack, this);
+ } else {
+ features = ol.xml.pushParseAndPop(null,
+ } else if (localName == 'featureMembers' || localName == 'featureMember') {
+ var context = objectStack[0];
+ var featureType = context['featureType'];
+ var featureNS = context['featureNS'];
+ var i, ii, prefix = 'p', defaultPrefix = 'p0';
+ if (!featureType && node.childNodes) {
+ featureType = [], featureNS = {};
+ for (i = 0, ii = node.childNodes.length; i < ii; ++i) {
+ var child = node.childNodes[i];
+ if (child.nodeType === 1) {
+ var ft = child.nodeName.split(':').pop();
+ if (featureType.indexOf(ft) === -1) {
+ var key = '';
+ var count = 0;
+ var uri = child.namespaceURI;
+ for (var candidate in featureNS) {
+ if (featureNS[candidate] === uri) {
+ key = candidate;
+ break;
+ ++count;
+ if (!key) {
+ key = prefix + count;
+ featureNS[key] = uri;
+ featureType.push(key + ':' + ft);
+ if (localName != 'featureMember') {
+ // recheck featureType for each featureMember
+ context['featureType'] = featureType;
+ context['featureNS'] = featureNS;
+ if (typeof featureNS === 'string') {
+ var ns = featureNS;
+ featureNS = {};
+ featureNS[defaultPrefix] = ns;
+ var parsersNS = {};
+ var featureTypes = Array.isArray(featureType) ? featureType : [featureType];
+ for (var p in featureNS) {
+ var parsers = {};
+ for (i = 0, ii = featureTypes.length; i < ii; ++i) {
+ var featurePrefix = featureTypes[i].indexOf(':') === -1 ?
+ defaultPrefix : featureTypes[i].split(':')[0];
+ if (featurePrefix === p) {
+ parsers[featureTypes[i].split(':').pop()] =
+ (localName == 'featureMembers') ?
+ ol.xml.makeArrayPusher(this.readFeatureElement, this) :
+ ol.xml.makeReplacer(this.readFeatureElement, this);
+ parsersNS[featureNS[p]] = parsers;
+ if (localName == 'featureMember') {
+ features = ol.xml.pushParseAndPop(undefined, parsersNS, node, objectStack);
+ } else {
+ features = ol.xml.pushParseAndPop([], parsersNS, node, objectStack);
+ if (features === null) {
+ features = [];
+ return features;
+ * @return {ol.geom.Geometry|undefined} Geometry.
+ol.format.GMLBase.prototype.readGeometryElement = function(node, objectStack) {
+ var context = /** @type {Object} */ (objectStack[0]);
+ context['srsName'] = node.firstElementChild.getAttribute('srsName');
+ /** @type {ol.geom.Geometry} */
+ var geometry = ol.xml.pushParseAndPop(null,
+ this.GEOMETRY_PARSERS_, node, objectStack, this);
+ if (geometry) {
+ ol.format.Feature.transformWithOptions(geometry, false, context));
+ } else {
+ return undefined;
+ol.format.GMLBase.prototype.readFeatureElement = function(node, objectStack) {
+ var n;
+ var fid = node.getAttribute('fid') ||
+ ol.xml.getAttributeNS(node, ol.format.GMLBase.GMLNS, 'id');
+ var values = {}, geometryName;
+ for (n = node.firstElementChild; n; n = n.nextElementSibling) {
+ var localName = n.localName;
+ // Assume attribute elements have one child node and that the child
+ // is a text or CDATA node (to be treated as text).
+ // Otherwise assume it is a geometry node.
+ if (n.childNodes.length === 0 ||
+ (n.childNodes.length === 1 &&
+ (n.firstChild.nodeType === 3 || n.firstChild.nodeType === 4))) {
+ var value = ol.xml.getAllTextContent(n, false);
+ if (ol.format.GMLBase.ONLY_WHITESPACE_RE_.test(value)) {
+ value = undefined;
+ values[localName] = value;
+ } else {
+ // boundedBy is an extent and must not be considered as a geometry
+ if (localName !== 'boundedBy') {
+ geometryName = localName;
+ values[localName] = this.readGeometryElement(n, objectStack);
+ var feature = new ol.Feature(values);
+ if (geometryName) {
+ feature.setGeometryName(geometryName);
+ if (fid) {
+ feature.setId(fid);
+ return feature;
+ * @return {ol.geom.Point|undefined} Point.
+ol.format.GMLBase.prototype.readPoint = function(node, objectStack) {
+ var flatCoordinates =
+ this.readFlatCoordinatesFromNode_(node, objectStack);
+ if (flatCoordinates) {
+ var point = new ol.geom.Point(null);
+ point.setFlatCoordinates(ol.geom.GeometryLayout.XYZ, flatCoordinates);
+ return point;
+ * @return {ol.geom.MultiPoint|undefined} MultiPoint.
+ol.format.GMLBase.prototype.readMultiPoint = function(node, objectStack) {
+ /** @type {Array.<Array.<number>>} */
+ var coordinates = ol.xml.pushParseAndPop([],
+ this.MULTIPOINT_PARSERS_, node, objectStack, this);
+ if (coordinates) {
+ return new ol.geom.MultiPoint(coordinates);
+ } else {
+ return undefined;
+ * @return {ol.geom.MultiLineString|undefined} MultiLineString.
+ol.format.GMLBase.prototype.readMultiLineString = function(node, objectStack) {
+ /** @type {Array.<ol.geom.LineString>} */
+ var lineStrings = ol.xml.pushParseAndPop([],
+ this.MULTILINESTRING_PARSERS_, node, objectStack, this);
+ if (lineStrings) {
+ var multiLineString = new ol.geom.MultiLineString(null);
+ multiLineString.setLineStrings(lineStrings);
+ return multiLineString;
+ } else {
+ return undefined;
+ * @return {ol.geom.MultiPolygon|undefined} MultiPolygon.
+ol.format.GMLBase.prototype.readMultiPolygon = function(node, objectStack) {
+ /** @type {Array.<ol.geom.Polygon>} */
+ var polygons = ol.xml.pushParseAndPop([],
+ this.MULTIPOLYGON_PARSERS_, node, objectStack, this);
+ if (polygons) {
+ var multiPolygon = new ol.geom.MultiPolygon(null);
+ multiPolygon.setPolygons(polygons);
+ return multiPolygon;
+ } else {
+ return undefined;
+ * @private
+ol.format.GMLBase.prototype.pointMemberParser_ = function(node, objectStack) {
+ ol.xml.parseNode(this.POINTMEMBER_PARSERS_,
+ node, objectStack, this);
+ * @private
+ol.format.GMLBase.prototype.lineStringMemberParser_ = function(node, objectStack) {
+ ol.xml.parseNode(this.LINESTRINGMEMBER_PARSERS_,
+ * @private
+ol.format.GMLBase.prototype.polygonMemberParser_ = function(node, objectStack) {
+ ol.xml.parseNode(this.POLYGONMEMBER_PARSERS_, node,
+ * @return {ol.geom.LineString|undefined} LineString.
+ol.format.GMLBase.prototype.readLineString = function(node, objectStack) {
+ var lineString = new ol.geom.LineString(null);
+ lineString.setFlatCoordinates(ol.geom.GeometryLayout.XYZ, flatCoordinates);
+ return lineString;
+ } else {
+ return undefined;
+ * @private
+ * @return {Array.<number>|undefined} LinearRing flat coordinates.
+ol.format.GMLBase.prototype.readFlatLinearRing_ = function(node, objectStack) {
+ var ring = ol.xml.pushParseAndPop(null,
+ this.GEOMETRY_FLAT_COORDINATES_PARSERS_, node,
+ if (ring) {
+ return ring;
+ } else {
+ return undefined;
+ * @return {ol.geom.LinearRing|undefined} LinearRing.
+ol.format.GMLBase.prototype.readLinearRing = function(node, objectStack) {
+ var ring = new ol.geom.LinearRing(null);
+ ring.setFlatCoordinates(ol.geom.GeometryLayout.XYZ, flatCoordinates);
+ return ring;
+ } else {
+ return undefined;
+ * @return {ol.geom.Polygon|undefined} Polygon.
+ol.format.GMLBase.prototype.readPolygon = function(node, objectStack) {
+ var flatLinearRings = ol.xml.pushParseAndPop([null],
+ this.FLAT_LINEAR_RINGS_PARSERS_, node, objectStack, this);
+ if (flatLinearRings && flatLinearRings[0]) {
+ var polygon = new ol.geom.Polygon(null);
+ var flatCoordinates = flatLinearRings[0];
+ var ends = [flatCoordinates.length];
+ var i, ii;
+ for (i = 1, ii = flatLinearRings.length; i < ii; ++i) {
+ ol.array.extend(flatCoordinates, flatLinearRings[i]);
+ ends.push(flatCoordinates.length);
+ polygon.setFlatCoordinates(
+ ol.geom.GeometryLayout.XYZ, flatCoordinates, ends);
+ return polygon;
+ } else {
+ return undefined;
+ * @private
+ * @return {Array.<number>} Flat coordinates.
+ol.format.GMLBase.prototype.readFlatCoordinatesFromNode_ = function(node, objectStack) {
+ return ol.xml.pushParseAndPop(null,
+ * @const
+ * @type {Object.<string, Object.<string, ol.XmlParser>>}
+ * @private
+ol.format.GMLBase.prototype.MULTIPOINT_PARSERS_ = {
+ 'http://www.opengis.net/gml': {
+ 'pointMember': ol.xml.makeArrayPusher(
+ ol.format.GMLBase.prototype.pointMemberParser_),
+ 'pointMembers': ol.xml.makeArrayPusher(
+ * @const
+ * @private
+ol.format.GMLBase.prototype.MULTILINESTRING_PARSERS_ = {
+ 'lineStringMember': ol.xml.makeArrayPusher(
+ ol.format.GMLBase.prototype.lineStringMemberParser_),
+ 'lineStringMembers': ol.xml.makeArrayPusher(
+ * @const
+ * @private
+ol.format.GMLBase.prototype.MULTIPOLYGON_PARSERS_ = {
+ 'polygonMember': ol.xml.makeArrayPusher(
+ ol.format.GMLBase.prototype.polygonMemberParser_),
+ 'polygonMembers': ol.xml.makeArrayPusher(
+ * @const
+ * @private
+ol.format.GMLBase.prototype.POINTMEMBER_PARSERS_ = {
+ 'Point': ol.xml.makeArrayPusher(
+ ol.format.GMLBase.prototype.readFlatCoordinatesFromNode_)
+ * @const
+ * @private
+ol.format.GMLBase.prototype.LINESTRINGMEMBER_PARSERS_ = {
+ 'LineString': ol.xml.makeArrayPusher(
+ ol.format.GMLBase.prototype.readLineString)
+ * @const
+ * @private
+ol.format.GMLBase.prototype.POLYGONMEMBER_PARSERS_ = {
+ 'Polygon': ol.xml.makeArrayPusher(
+ ol.format.GMLBase.prototype.readPolygon)
+ * @const
+ * @protected
+ol.format.GMLBase.prototype.RING_PARSERS = {
+ 'LinearRing': ol.xml.makeReplacer(
+ ol.format.GMLBase.prototype.readFlatLinearRing_)
+ * @inheritDoc
+ol.format.GMLBase.prototype.readGeometryFromNode = function(node, opt_options) {
+ var geometry = this.readGeometryElement(node,
+ [this.getReadOptions(node, opt_options ? opt_options : {})]);
+ return geometry ? geometry : null;
+ * Read all features from a GML FeatureCollection.
+ * @function
+ * @api
+ol.format.GMLBase.prototype.readFeatures;
+ * @inheritDoc
+ol.format.GMLBase.prototype.readFeaturesFromNode = function(node, opt_options) {
+ var options = {
+ featureType: this.featureType,
+ featureNS: this.featureNS
+ ol.obj.assign(options, this.getReadOptions(node, opt_options));
+ var features = this.readFeaturesInternal(node, [options]);
+ return features || [];
+ * @inheritDoc
+ol.format.GMLBase.prototype.readProjectionFromNode = function(node) {
+ return ol.proj.get(this.srsName ? this.srsName :
+ node.firstElementChild.getAttribute('srsName'));
+goog.provide('ol.format.XSD');
+goog.require('ol.string');
+ * @const
+ * @type {string}
+ol.format.XSD.NAMESPACE_URI = 'http://www.w3.org/2001/XMLSchema';
+ * @return {boolean|undefined} Boolean.
+ol.format.XSD.readBoolean = function(node) {
+ var s = ol.xml.getAllTextContent(node, false);
+ return ol.format.XSD.readBooleanString(s);
+ * @param {string} string String.
+ol.format.XSD.readBooleanString = function(string) {
+ var m = /^\s*(true|1)|(false|0)\s*$/.exec(string);
+ if (m) {
+ return m[1] !== undefined || false;
+ } else {
+ return undefined;
+ * @return {number|undefined} DateTime in seconds.
+ol.format.XSD.readDateTime = function(node) {
+ var dateTime = Date.parse(s);
+ return isNaN(dateTime) ? undefined : dateTime / 1000;
+ * @return {number|undefined} Decimal.
+ol.format.XSD.readDecimal = function(node) {
+ return ol.format.XSD.readDecimalString(s);
+ol.format.XSD.readDecimalString = function(string) {
+ // FIXME check spec
+ var m = /^\s*([+\-]?\d*\.?\d+(?:e[+\-]?\d+)?)\s*$/i.exec(string);
+ if (m) {
+ return parseFloat(m[1]);
+ } else {
+ return undefined;
+ * @return {number|undefined} Non negative integer.
+ol.format.XSD.readNonNegativeInteger = function(node) {
+ return ol.format.XSD.readNonNegativeIntegerString(s);
+ol.format.XSD.readNonNegativeIntegerString = function(string) {
+ var m = /^\s*(\d+)\s*$/.exec(string);
+ if (m) {
+ return parseInt(m[1], 10);
+ } else {
+ return undefined;
+ * @return {string|undefined} String.
+ol.format.XSD.readString = function(node) {
+ return ol.xml.getAllTextContent(node, false).trim();
+ * @param {Node} node Node to append a TextNode with the boolean to.
+ * @param {boolean} bool Boolean.
+ol.format.XSD.writeBooleanTextNode = function(node, bool) {
+ ol.format.XSD.writeStringTextNode(node, (bool) ? '1' : '0');
+ * @param {Node} node Node to append a CDATA Section with the string to.
+ol.format.XSD.writeCDATASection = function(node, string) {
+ node.appendChild(ol.xml.DOCUMENT.createCDATASection(string));
+ * @param {Node} node Node to append a TextNode with the dateTime to.
+ * @param {number} dateTime DateTime in seconds.
+ol.format.XSD.writeDateTimeTextNode = function(node, dateTime) {
+ var date = new Date(dateTime * 1000);
+ var string = date.getUTCFullYear() + '-' +
+ ol.string.padNumber(date.getUTCMonth() + 1, 2) + '-' +
+ ol.string.padNumber(date.getUTCDate(), 2) + 'T' +
+ ol.string.padNumber(date.getUTCHours(), 2) + ':' +
+ ol.string.padNumber(date.getUTCMinutes(), 2) + ':' +
+ ol.string.padNumber(date.getUTCSeconds(), 2) + 'Z';
+ node.appendChild(ol.xml.DOCUMENT.createTextNode(string));
+ * @param {Node} node Node to append a TextNode with the decimal to.
+ * @param {number} decimal Decimal.
+ol.format.XSD.writeDecimalTextNode = function(node, decimal) {
+ var string = decimal.toPrecision();
+ * @param {number} nonNegativeInteger Non negative integer.
+ol.format.XSD.writeNonNegativeIntegerTextNode = function(node, nonNegativeInteger) {
+ var string = nonNegativeInteger.toString();
+ * @param {Node} node Node to append a TextNode with the string to.
+ol.format.XSD.writeStringTextNode = function(node, string) {
+goog.provide('ol.format.GML3');
+goog.require('ol.extent');
+goog.require('ol.format.GMLBase');
+goog.require('ol.format.XSD');
+goog.require('ol.geom.MultiLineString');
+goog.require('ol.geom.MultiPolygon');
+ * @classdesc
+ * Feature format for reading and writing data in the GML format
+ * version 3.1.1.
+ * Currently only supports GML 3.1.1 Simple Features profile.
+ * @constructor
+ * @extends {ol.format.GMLBase}
+ * @api
+ol.format.GML3 = function(opt_options) {
+ ol.format.GMLBase.call(this, options);
+ * @private
+ * @type {boolean}
+ this.surface_ = options.surface !== undefined ? options.surface : false;
+ * @private
+ * @type {boolean}
+ this.curve_ = options.curve !== undefined ? options.curve : false;
+ * @private
+ * @type {boolean}
+ this.multiCurve_ = options.multiCurve !== undefined ?
+ options.multiCurve : true;
+ * @private
+ * @type {boolean}
+ this.multiSurface_ = options.multiSurface !== undefined ?
+ options.multiSurface : true;
+ * @inheritDoc
+ this.schemaLocation = options.schemaLocation ?
+ options.schemaLocation : ol.format.GML3.schemaLocation_;
+ol.inherits(ol.format.GML3, ol.format.GMLBase);
+ * @const
+ * @type {string}
+ * @private
+ol.format.GML3.schemaLocation_ = ol.format.GMLBase.GMLNS +
+ ' http://schemas.opengis.net/gml/3.1.1/profiles/gmlsfProfile/' +
+ '1.0.0/gmlsf.xsd';
+ * @private
+ol.format.GML3.prototype.readMultiCurve_ = function(node, objectStack) {
+ this.MULTICURVE_PARSERS_, node, objectStack, this);
+ } else {
+ return undefined;
+ * @private
+ol.format.GML3.prototype.readMultiSurface_ = function(node, objectStack) {
+ this.MULTISURFACE_PARSERS_, node, objectStack, this);
+ if (polygons) {
+ } else {
+ return undefined;
+ * @private
+ol.format.GML3.prototype.curveMemberParser_ = function(node, objectStack) {
+ ol.xml.parseNode(this.CURVEMEMBER_PARSERS_, node, objectStack, this);
+ * @private
+ol.format.GML3.prototype.surfaceMemberParser_ = function(node, objectStack) {
+ ol.xml.parseNode(this.SURFACEMEMBER_PARSERS_,
+ * @private
+ * @return {Array.<(Array.<number>)>|undefined} flat coordinates.
+ol.format.GML3.prototype.readPatch_ = function(node, objectStack) {
+ return ol.xml.pushParseAndPop([null],
+ this.PATCHES_PARSERS_, node, objectStack, this);
+ * @private
+ * @return {Array.<number>|undefined} flat coordinates.
+ol.format.GML3.prototype.readSegment_ = function(node, objectStack) {
+ this.SEGMENTS_PARSERS_, node, objectStack, this);
+ * @private
+ol.format.GML3.prototype.readPolygonPatch_ = function(node, objectStack) {
+ * @private
+ol.format.GML3.prototype.readLineStringSegment_ = function(node, objectStack) {
+ * @private
+ol.format.GML3.prototype.interiorParser_ = function(node, objectStack) {
+ /** @type {Array.<number>|undefined} */
+ var flatLinearRing = ol.xml.pushParseAndPop(undefined,
+ this.RING_PARSERS, node, objectStack, this);
+ if (flatLinearRing) {
+ var flatLinearRings = /** @type {Array.<Array.<number>>} */
+ (objectStack[objectStack.length - 1]);
+ flatLinearRings.push(flatLinearRing);
+ * @private
+ol.format.GML3.prototype.exteriorParser_ = function(node, objectStack) {
+ flatLinearRings[0] = flatLinearRing;
+ * @private
+ol.format.GML3.prototype.readSurface_ = function(node, objectStack) {
+ this.SURFACE_PARSERS_, node, objectStack, this);
+ var i, ii;
+ return polygon;
+ } else {
+ return undefined;
+ * @private
+ol.format.GML3.prototype.readCurve_ = function(node, objectStack) {
+ /** @type {Array.<number>} */
+ var flatCoordinates = ol.xml.pushParseAndPop([null],
+ this.CURVE_PARSERS_, node, objectStack, this);
+ } else {
+ return undefined;
+ * @private
+ * @return {ol.Extent|undefined} Envelope.
+ol.format.GML3.prototype.readEnvelope_ = function(node, objectStack) {
+ this.ENVELOPE_PARSERS_, node, objectStack, this);
+ return ol.extent.createOrUpdate(flatCoordinates[1][0],
+ flatCoordinates[1][1], flatCoordinates[2][0],
+ flatCoordinates[2][1]);
+ * @private
+ * @return {Array.<number>|undefined} Flat coordinates.
+ol.format.GML3.prototype.readFlatPos_ = function(node, objectStack) {
+ var re = /^\s*([+\-]?\d*\.?\d+(?:[eE][+\-]?\d+)?)\s*/;
+ var flatCoordinates = [];
+ var m;
+ while ((m = re.exec(s))) {
+ flatCoordinates.push(parseFloat(m[1]));
+ s = s.substr(m[0].length);
+ if (s !== '') {
+ return undefined;
+ var containerSrs = context['srsName'];
+ var axisOrientation = 'enu';
+ if (containerSrs) {
+ var proj = ol.proj.get(containerSrs);
+ axisOrientation = proj.getAxisOrientation();
+ if (axisOrientation === 'neu') {
+ var i, ii;
+ for (i = 0, ii = flatCoordinates.length; i < ii; i += 3) {
+ var y = flatCoordinates[i];
+ var x = flatCoordinates[i + 1];
+ flatCoordinates[i] = x;
+ flatCoordinates[i + 1] = y;
+ var len = flatCoordinates.length;
+ if (len == 2) {
+ flatCoordinates.push(0);
+ if (len === 0) {
+ return undefined;
+ return flatCoordinates;
+ * @private
+ol.format.GML3.prototype.readFlatPosList_ = function(node, objectStack) {
+ var s = ol.xml.getAllTextContent(node, false).replace(/^\s*|\s*$/g, '');
+ var containerDimension = node.parentNode.getAttribute('srsDimension');
+ var coords = s.split(/\s+/);
+ // The "dimension" attribute is from the GML 3.0.1 spec.
+ var dim = 2;
+ if (node.getAttribute('srsDimension')) {
+ dim = ol.format.XSD.readNonNegativeIntegerString(
+ node.getAttribute('srsDimension'));
+ } else if (node.getAttribute('dimension')) {
+ node.getAttribute('dimension'));
+ } else if (containerDimension) {
+ dim = ol.format.XSD.readNonNegativeIntegerString(containerDimension);
+ var x, y, z;
+ for (var i = 0, ii = coords.length; i < ii; i += dim) {
+ x = parseFloat(coords[i]);
+ y = parseFloat(coords[i + 1]);
+ z = (dim === 3) ? parseFloat(coords[i + 2]) : 0;
+ if (axisOrientation.substr(0, 2) === 'en') {
+ flatCoordinates.push(x, y, z);
+ } else {
+ flatCoordinates.push(y, x, z);
+ * @const
+ * @private
+ol.format.GML3.prototype.GEOMETRY_FLAT_COORDINATES_PARSERS_ = {
+ 'pos': ol.xml.makeReplacer(ol.format.GML3.prototype.readFlatPos_),
+ 'posList': ol.xml.makeReplacer(ol.format.GML3.prototype.readFlatPosList_)
+ * @const
+ * @private
+ol.format.GML3.prototype.FLAT_LINEAR_RINGS_PARSERS_ = {
+ 'interior': ol.format.GML3.prototype.interiorParser_,
+ 'exterior': ol.format.GML3.prototype.exteriorParser_
+ * @const
+ * @private
+ol.format.GML3.prototype.GEOMETRY_PARSERS_ = {
+ 'Point': ol.xml.makeReplacer(ol.format.GMLBase.prototype.readPoint),
+ 'MultiPoint': ol.xml.makeReplacer(
+ ol.format.GMLBase.prototype.readMultiPoint),
+ 'LineString': ol.xml.makeReplacer(
+ ol.format.GMLBase.prototype.readLineString),
+ 'MultiLineString': ol.xml.makeReplacer(
+ ol.format.GMLBase.prototype.readMultiLineString),
+ ol.format.GMLBase.prototype.readLinearRing),
+ 'Polygon': ol.xml.makeReplacer(ol.format.GMLBase.prototype.readPolygon),
+ 'MultiPolygon': ol.xml.makeReplacer(
+ ol.format.GMLBase.prototype.readMultiPolygon),
+ 'Surface': ol.xml.makeReplacer(ol.format.GML3.prototype.readSurface_),
+ 'MultiSurface': ol.xml.makeReplacer(
+ ol.format.GML3.prototype.readMultiSurface_),
+ 'Curve': ol.xml.makeReplacer(ol.format.GML3.prototype.readCurve_),
+ 'MultiCurve': ol.xml.makeReplacer(
+ ol.format.GML3.prototype.readMultiCurve_),
+ 'Envelope': ol.xml.makeReplacer(ol.format.GML3.prototype.readEnvelope_)
+ * @const
+ * @private
+ol.format.GML3.prototype.MULTICURVE_PARSERS_ = {
+ 'curveMember': ol.xml.makeArrayPusher(
+ ol.format.GML3.prototype.curveMemberParser_),
+ 'curveMembers': ol.xml.makeArrayPusher(
+ * @const
+ * @private
+ol.format.GML3.prototype.MULTISURFACE_PARSERS_ = {
+ 'surfaceMember': ol.xml.makeArrayPusher(
+ ol.format.GML3.prototype.surfaceMemberParser_),
+ 'surfaceMembers': ol.xml.makeArrayPusher(
+ * @const
+ * @private
+ol.format.GML3.prototype.CURVEMEMBER_PARSERS_ = {
+ 'Curve': ol.xml.makeArrayPusher(ol.format.GML3.prototype.readCurve_)
+ * @const
+ * @private
+ol.format.GML3.prototype.SURFACEMEMBER_PARSERS_ = {
+ 'Polygon': ol.xml.makeArrayPusher(ol.format.GMLBase.prototype.readPolygon),
+ 'Surface': ol.xml.makeArrayPusher(ol.format.GML3.prototype.readSurface_)
+ * @const
+ * @private
+ol.format.GML3.prototype.SURFACE_PARSERS_ = {
+ 'patches': ol.xml.makeReplacer(ol.format.GML3.prototype.readPatch_)
+ * @const
+ * @private
+ol.format.GML3.prototype.CURVE_PARSERS_ = {
+ 'segments': ol.xml.makeReplacer(ol.format.GML3.prototype.readSegment_)
+ * @const
+ * @private
+ol.format.GML3.prototype.ENVELOPE_PARSERS_ = {
+ 'lowerCorner': ol.xml.makeArrayPusher(
+ ol.format.GML3.prototype.readFlatPosList_),
+ 'upperCorner': ol.xml.makeArrayPusher(
+ * @const
+ * @private
+ol.format.GML3.prototype.PATCHES_PARSERS_ = {
+ 'PolygonPatch': ol.xml.makeReplacer(
+ ol.format.GML3.prototype.readPolygonPatch_)
+ * @const
+ * @private
+ol.format.GML3.prototype.SEGMENTS_PARSERS_ = {
+ 'LineStringSegment': ol.xml.makeReplacer(
+ ol.format.GML3.prototype.readLineStringSegment_)
+ * @param {ol.geom.Point} value Point geometry.
+ * @param {Array.<*>} objectStack Node stack.
+ * @private
+ol.format.GML3.prototype.writePos_ = function(node, value, objectStack) {
+ var context = objectStack[objectStack.length - 1];
+ var srsName = context['srsName'];
+ if (srsName) {
+ axisOrientation = ol.proj.get(srsName).getAxisOrientation();
+ var point = value.getCoordinates();
+ var coords;
+ // only 2d for simple features profile
+ coords = (point[0] + ' ' + point[1]);
+ } else {
+ coords = (point[1] + ' ' + point[0]);
+ ol.format.XSD.writeStringTextNode(node, coords);
+ * @param {Array.<number>} point Point geometry.
+ * @param {string=} opt_srsName Optional srsName
+ * @return {string} The coords string.
+ * @private
+ol.format.GML3.prototype.getCoords_ = function(point, opt_srsName) {
+ if (opt_srsName) {
+ axisOrientation = ol.proj.get(opt_srsName).getAxisOrientation();
+ return ((axisOrientation.substr(0, 2) === 'en') ?
+ point[0] + ' ' + point[1] :
+ point[1] + ' ' + point[0]);
+ * @param {ol.geom.LineString|ol.geom.LinearRing} value Geometry.
+ * @private
+ol.format.GML3.prototype.writePosList_ = function(node, value, objectStack) {
+ var points = value.getCoordinates();
+ var len = points.length;
+ var parts = new Array(len);
+ var point;
+ for (var i = 0; i < len; ++i) {
+ point = points[i];
+ parts[i] = this.getCoords_(point, srsName);
+ ol.format.XSD.writeStringTextNode(node, parts.join(' '));
+ * @param {ol.geom.Point} geometry Point geometry.
+ * @private
+ol.format.GML3.prototype.writePoint_ = function(node, geometry, objectStack) {
+ if (srsName) {
+ node.setAttribute('srsName', srsName);
+ var pos = ol.xml.createElementNS(node.namespaceURI, 'pos');
+ node.appendChild(pos);
+ this.writePos_(pos, geometry, objectStack);
+ * @type {Object.<string, Object.<string, ol.XmlSerializer>>}
+ * @private
+ol.format.GML3.ENVELOPE_SERIALIZERS_ = {
+ 'lowerCorner': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
+ 'upperCorner': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode)
+ * @param {ol.Extent} extent Extent.
+ol.format.GML3.prototype.writeEnvelope = function(node, extent, objectStack) {
+ if (srsName) {
+ var keys = ['lowerCorner', 'upperCorner'];
+ var values = [extent[0] + ' ' + extent[1], extent[2] + ' ' + extent[3]];
+ ol.xml.pushSerializeAndPop(/** @type {ol.XmlNodeStackItem} */
+ ({node: node}), ol.format.GML3.ENVELOPE_SERIALIZERS_,
+ ol.xml.OBJECT_PROPERTY_NODE_FACTORY,
+ values,
+ objectStack, keys, this);
+ * @param {ol.geom.LinearRing} geometry LinearRing geometry.
+ * @private
+ol.format.GML3.prototype.writeLinearRing_ = function(node, geometry, objectStack) {
+ if (srsName) {
+ var posList = ol.xml.createElementNS(node.namespaceURI, 'posList');
+ node.appendChild(posList);
+ this.writePosList_(posList, geometry, objectStack);
+ * @param {*} value Value.
+ * @param {string=} opt_nodeName Node name.
+ * @private
+ol.format.GML3.prototype.RING_NODE_FACTORY_ = function(value, objectStack, opt_nodeName) {
+ var parentNode = context.node;
+ var exteriorWritten = context['exteriorWritten'];
+ if (exteriorWritten === undefined) {
+ context['exteriorWritten'] = true;
+ return ol.xml.createElementNS(parentNode.namespaceURI,
+ exteriorWritten !== undefined ? 'interior' : 'exterior');
+ * @param {ol.geom.Polygon} geometry Polygon geometry.
+ * @private
+ol.format.GML3.prototype.writeSurfaceOrPolygon_ = function(node, geometry, objectStack) {
+ if (node.nodeName !== 'PolygonPatch' && srsName) {
+ if (node.nodeName === 'Polygon' || node.nodeName === 'PolygonPatch') {
+ var rings = geometry.getLinearRings();
+ {node: node, srsName: srsName},
+ ol.format.GML3.RING_SERIALIZERS_,
+ this.RING_NODE_FACTORY_,
+ rings, objectStack, undefined, this);
+ } else if (node.nodeName === 'Surface') {
+ var patches = ol.xml.createElementNS(node.namespaceURI, 'patches');
+ node.appendChild(patches);
+ this.writeSurfacePatches_(
+ patches, geometry, objectStack);
+ * @param {ol.geom.LineString} geometry LineString geometry.
+ * @private
+ol.format.GML3.prototype.writeCurveOrLineString_ = function(node, geometry, objectStack) {
+ if (node.nodeName !== 'LineStringSegment' && srsName) {
+ if (node.nodeName === 'LineString' ||
+ node.nodeName === 'LineStringSegment') {
+ } else if (node.nodeName === 'Curve') {
+ var segments = ol.xml.createElementNS(node.namespaceURI, 'segments');
+ node.appendChild(segments);
+ this.writeCurveSegments_(segments,
+ geometry, objectStack);
+ * @param {ol.geom.MultiPolygon} geometry MultiPolygon geometry.
+ * @private
+ol.format.GML3.prototype.writeMultiSurfaceOrPolygon_ = function(node, geometry, objectStack) {
+ var surface = context['surface'];
+ if (srsName) {
+ var polygons = geometry.getPolygons();
+ ol.xml.pushSerializeAndPop({node: node, srsName: srsName, surface: surface},
+ ol.format.GML3.SURFACEORPOLYGONMEMBER_SERIALIZERS_,
+ this.MULTIGEOMETRY_MEMBER_NODE_FACTORY_, polygons,
+ objectStack, undefined, this);
+ * @param {ol.geom.MultiPoint} geometry MultiPoint geometry.
+ * @private
+ol.format.GML3.prototype.writeMultiPoint_ = function(node, geometry,
+ objectStack) {
+ if (srsName) {
+ var points = geometry.getPoints();
+ ol.xml.pushSerializeAndPop({node: node, srsName: srsName},
+ ol.format.GML3.POINTMEMBER_SERIALIZERS_,
+ ol.xml.makeSimpleNodeFactory('pointMember'), points,
+ * @param {ol.geom.MultiLineString} geometry MultiLineString geometry.
+ * @private
+ol.format.GML3.prototype.writeMultiCurveOrLineString_ = function(node, geometry, objectStack) {
+ var curve = context['curve'];
+ if (srsName) {
+ var lines = geometry.getLineStrings();
+ ol.xml.pushSerializeAndPop({node: node, srsName: srsName, curve: curve},
+ ol.format.GML3.LINESTRINGORCURVEMEMBER_SERIALIZERS_,
+ this.MULTIGEOMETRY_MEMBER_NODE_FACTORY_, lines,
+ * @param {ol.geom.LinearRing} ring LinearRing geometry.
+ * @private
+ol.format.GML3.prototype.writeRing_ = function(node, ring, objectStack) {
+ var linearRing = ol.xml.createElementNS(node.namespaceURI, 'LinearRing');
+ node.appendChild(linearRing);
+ this.writeLinearRing_(linearRing, ring, objectStack);
+ * @param {ol.geom.Polygon} polygon Polygon geometry.
+ * @private
+ol.format.GML3.prototype.writeSurfaceOrPolygonMember_ = function(node, polygon, objectStack) {
+ var child = this.GEOMETRY_NODE_FACTORY_(
+ polygon, objectStack);
+ if (child) {
+ node.appendChild(child);
+ this.writeSurfaceOrPolygon_(child, polygon, objectStack);
+ * @param {ol.geom.Point} point Point geometry.
+ * @private
+ol.format.GML3.prototype.writePointMember_ = function(node, point, objectStack) {
+ var child = ol.xml.createElementNS(node.namespaceURI, 'Point');
+ this.writePoint_(child, point, objectStack);
+ * @param {ol.geom.LineString} line LineString geometry.
+ * @private
+ol.format.GML3.prototype.writeLineStringOrCurveMember_ = function(node, line, objectStack) {
+ var child = this.GEOMETRY_NODE_FACTORY_(line, objectStack);
+ if (child) {
+ this.writeCurveOrLineString_(child, line, objectStack);
+ * @private
+ol.format.GML3.prototype.writeSurfacePatches_ = function(node, polygon, objectStack) {
+ var child = ol.xml.createElementNS(node.namespaceURI, 'PolygonPatch');
+ * @private
+ol.format.GML3.prototype.writeCurveSegments_ = function(node, line, objectStack) {
+ 'LineStringSegment');
+ * @param {ol.geom.Geometry|ol.Extent} geometry Geometry.
+ol.format.GML3.prototype.writeGeometryElement = function(node, geometry, objectStack) {
+ var context = /** @type {olx.format.WriteOptions} */ (objectStack[objectStack.length - 1]);
+ var item = ol.obj.assign({}, context);
+ item.node = node;
+ var value;
+ if (Array.isArray(geometry)) {
+ if (context.dataProjection) {
+ value = ol.proj.transformExtent(
+ geometry, context.featureProjection, context.dataProjection);
+ } else {
+ value = geometry;
+ } else {
+ value =
+ ol.format.Feature.transformWithOptions(/** @type {ol.geom.Geometry} */ (geometry), true, context);
+ (item), ol.format.GML3.GEOMETRY_SERIALIZERS_,
+ this.GEOMETRY_NODE_FACTORY_, [value],
+ol.format.GML3.prototype.writeFeatureElement = function(node, feature, objectStack) {
+ var fid = feature.getId();
+ if (fid) {
+ node.setAttribute('fid', fid);
+ var context = /** @type {Object} */ (objectStack[objectStack.length - 1]);
+ var geometryName = feature.getGeometryName();
+ if (!context.serializers) {
+ context.serializers = {};
+ context.serializers[featureNS] = {};
+ var properties = feature.getProperties();
+ var keys = [], values = [];
+ for (var key in properties) {
+ var value = properties[key];
+ if (value !== null) {
+ keys.push(key);
+ values.push(value);
+ if (key == geometryName || value instanceof ol.geom.Geometry) {
+ if (!(key in context.serializers[featureNS])) {
+ context.serializers[featureNS][key] = ol.xml.makeChildAppender(
+ this.writeGeometryElement, this);
+ } else {
+ ol.format.XSD.writeStringTextNode);
+ item.node = node;
+ (item), context.serializers,
+ ol.xml.makeSimpleNodeFactory(undefined, featureNS),
+ values,
+ objectStack, keys);
+ * @private
+ol.format.GML3.prototype.writeFeatureMembers_ = function(node, features, objectStack) {
+ var serializers = {};
+ serializers[featureNS] = {};
+ serializers[featureNS][featureType] = ol.xml.makeChildAppender(
+ this.writeFeatureElement, this);
+ item.node = node;
+ (item),
+ serializers,
+ ol.xml.makeSimpleNodeFactory(featureType, featureNS), features,
+ objectStack);
+ * @private
+ol.format.GML3.SURFACEORPOLYGONMEMBER_SERIALIZERS_ = {
+ 'surfaceMember': ol.xml.makeChildAppender(
+ ol.format.GML3.prototype.writeSurfaceOrPolygonMember_),
+ 'polygonMember': ol.xml.makeChildAppender(
+ * @private
+ol.format.GML3.POINTMEMBER_SERIALIZERS_ = {
+ 'pointMember': ol.xml.makeChildAppender(
+ ol.format.GML3.prototype.writePointMember_)
+ * @private
+ol.format.GML3.LINESTRINGORCURVEMEMBER_SERIALIZERS_ = {
+ 'lineStringMember': ol.xml.makeChildAppender(
+ ol.format.GML3.prototype.writeLineStringOrCurveMember_),
+ 'curveMember': ol.xml.makeChildAppender(
+ * @private
+ol.format.GML3.RING_SERIALIZERS_ = {
+ 'exterior': ol.xml.makeChildAppender(ol.format.GML3.prototype.writeRing_),
+ 'interior': ol.xml.makeChildAppender(ol.format.GML3.prototype.writeRing_)
+ * @private
+ol.format.GML3.GEOMETRY_SERIALIZERS_ = {
+ 'Curve': ol.xml.makeChildAppender(
+ ol.format.GML3.prototype.writeCurveOrLineString_),
+ 'MultiCurve': ol.xml.makeChildAppender(
+ ol.format.GML3.prototype.writeMultiCurveOrLineString_),
+ 'Point': ol.xml.makeChildAppender(ol.format.GML3.prototype.writePoint_),
+ 'MultiPoint': ol.xml.makeChildAppender(
+ ol.format.GML3.prototype.writeMultiPoint_),
+ 'LineString': ol.xml.makeChildAppender(
+ 'MultiLineString': ol.xml.makeChildAppender(
+ 'LinearRing': ol.xml.makeChildAppender(
+ ol.format.GML3.prototype.writeLinearRing_),
+ 'Polygon': ol.xml.makeChildAppender(
+ ol.format.GML3.prototype.writeSurfaceOrPolygon_),
+ 'MultiPolygon': ol.xml.makeChildAppender(
+ ol.format.GML3.prototype.writeMultiSurfaceOrPolygon_),
+ 'Surface': ol.xml.makeChildAppender(
+ 'MultiSurface': ol.xml.makeChildAppender(
+ 'Envelope': ol.xml.makeChildAppender(
+ ol.format.GML3.prototype.writeEnvelope)
+ * @const
+ * @type {Object.<string, string>}
+ * @private
+ol.format.GML3.MULTIGEOMETRY_TO_MEMBER_NODENAME_ = {
+ 'MultiLineString': 'lineStringMember',
+ 'MultiCurve': 'curveMember',
+ 'MultiPolygon': 'polygonMember',
+ 'MultiSurface': 'surfaceMember'
+ * @const
+ * @return {Node|undefined} Node.
+ * @private
+ol.format.GML3.prototype.MULTIGEOMETRY_MEMBER_NODE_FACTORY_ = function(value, objectStack, opt_nodeName) {
+ var parentNode = objectStack[objectStack.length - 1].node;
+ return ol.xml.createElementNS('http://www.opengis.net/gml',
+ ol.format.GML3.MULTIGEOMETRY_TO_MEMBER_NODENAME_[parentNode.nodeName]);
+ * @const
+ * @private
+ol.format.GML3.prototype.GEOMETRY_NODE_FACTORY_ = function(value, objectStack, opt_nodeName) {
+ var multiSurface = context['multiSurface'];
+ var multiCurve = context['multiCurve'];
+ var nodeName;
+ if (!Array.isArray(value)) {
+ nodeName = /** @type {ol.geom.Geometry} */ (value).getType();
+ if (nodeName === 'MultiPolygon' && multiSurface === true) {
+ nodeName = 'MultiSurface';
+ } else if (nodeName === 'Polygon' && surface === true) {
+ nodeName = 'Surface';
+ } else if (nodeName === 'LineString' && curve === true) {
+ nodeName = 'Curve';
+ } else if (nodeName === 'MultiLineString' && multiCurve === true) {
+ nodeName = 'MultiCurve';
+ } else {
+ nodeName = 'Envelope';
+ nodeName);
+ * Encode a geometry in GML 3.1.1 Simple Features.
+ * @override
+ * @api
+ol.format.GML3.prototype.writeGeometryNode = function(geometry, opt_options) {
+ opt_options = this.adaptOptions(opt_options);
+ var geom = ol.xml.createElementNS('http://www.opengis.net/gml', 'geom');
+ var context = {node: geom, srsName: this.srsName,
+ curve: this.curve_, surface: this.surface_,
+ multiSurface: this.multiSurface_, multiCurve: this.multiCurve_};
+ ol.obj.assign(context, opt_options);
+ this.writeGeometryElement(geom, geometry, [context]);
+ return geom;
+ * Encode an array of features in GML 3.1.1 Simple Features.
+ * @function
+ * @return {string} Result.
+ * @api
+ol.format.GML3.prototype.writeFeatures;
+ * Encode an array of features in the GML 3.1.1 format as an XML node.
+ * @override
+ * @api
+ol.format.GML3.prototype.writeFeaturesNode = function(features, opt_options) {
+ var node = ol.xml.createElementNS('http://www.opengis.net/gml',
+ 'featureMembers');
+ ol.xml.setAttributeNS(node, 'http://www.w3.org/2001/XMLSchema-instance',
+ 'xsi:schemaLocation', this.schemaLocation);
+ var context = {
+ srsName: this.srsName,
+ surface: this.surface_,
+ multiCurve: this.multiCurve_,
+ featureNS: this.featureNS,
+ this.writeFeatureMembers_(node, features, [context]);
+ return node;
+goog.provide('ol.format.GML');
+goog.require('ol.format.GML3');
+ * @classdesc
+ * version 3.1.1.
+ * @constructor
+ * @api
+ol.format.GML = ol.format.GML3;
+ * @function
+ * @api
+ol.format.GML.prototype.writeFeatures;
+ * @function
+ * @api
+ol.format.GML.prototype.writeFeaturesNode;
+goog.provide('ol.format.GML2');
+ * @classdesc
+ * Feature format for reading and writing data in the GML format,
+ * version 2.1.2.
+ * @constructor
+ * @param {olx.format.GMLOptions=} opt_options Optional configuration object.
+ * @api
+ol.format.GML2 = function(opt_options) {
+ this.FEATURE_COLLECTION_PARSERS[ol.format.GMLBase.GMLNS][
+ 'featureMember'] =
+ ol.xml.makeArrayPusher(ol.format.GMLBase.prototype.readFeaturesInternal);
+ * @inheritDoc
+ options.schemaLocation : ol.format.GML2.schemaLocation_;
+ol.inherits(ol.format.GML2, ol.format.GMLBase);
+ * @const
+ * @type {string}
+ * @private
+ol.format.GML2.schemaLocation_ = ol.format.GMLBase.GMLNS +
+ ' http://schemas.opengis.net/gml/2.1.2/feature.xsd';
+ * @private
+ol.format.GML2.prototype.readFlatCoordinates_ = function(node, objectStack) {
+ var context = /** @type {ol.XmlNodeStackItem} */ (objectStack[0]);
+ if (proj) {
+ var coordsGroups = s.trim().split(/\s+/);
+ var x, y, z;
+ for (var i = 0, ii = coordsGroups.length; i < ii; i++) {
+ var coords = coordsGroups[i].split(/,+/);
+ x = parseFloat(coords[0]);
+ y = parseFloat(coords[1]);
+ z = (coords.length === 3) ? parseFloat(coords[2]) : 0;
+ } else {
+ * @private
+ol.format.GML2.prototype.readBox_ = function(node, objectStack) {
+ this.BOX_PARSERS_, node, objectStack, this);
+ flatCoordinates[1][1], flatCoordinates[1][3],
+ flatCoordinates[1][4]);
+ * @private
+ol.format.GML2.prototype.innerBoundaryIsParser_ = function(node, objectStack) {
+ * @private
+ol.format.GML2.prototype.outerBoundaryIsParser_ = function(node, objectStack) {
+ * @const
+ * @private
+ol.format.GML2.prototype.GEOMETRY_FLAT_COORDINATES_PARSERS_ = {
+ 'coordinates': ol.xml.makeReplacer(
+ ol.format.GML2.prototype.readFlatCoordinates_)
+ * @const
+ * @private
+ol.format.GML2.prototype.FLAT_LINEAR_RINGS_PARSERS_ = {
+ 'innerBoundaryIs': ol.format.GML2.prototype.innerBoundaryIsParser_,
+ 'outerBoundaryIs': ol.format.GML2.prototype.outerBoundaryIsParser_
+ * @const
+ * @private
+ol.format.GML2.prototype.BOX_PARSERS_ = {
+ 'coordinates': ol.xml.makeArrayPusher(
+ * @const
+ * @private
+ol.format.GML2.prototype.GEOMETRY_PARSERS_ = {
+ 'Box': ol.xml.makeReplacer(ol.format.GML2.prototype.readBox_)
+ * @const
+ * @private
+ol.format.GML2.prototype.GEOMETRY_NODE_FACTORY_ = function(value, objectStack, opt_nodeName) {
+ var nodeName;
+ } else {
+ nodeName);
+ol.format.GML2.prototype.writeFeatureElement = function(node, feature, objectStack) {
+ if (fid) {
+ keys.push(key);
+ } else {
+ item.node = node;
+ values,
+ol.format.GML2.prototype.writeGeometryElement = function(node, geometry, objectStack) {
+ item.node = node;
+ var value;
+ } else {
+ value = geometry;
+ } else {
+ value =
+ (item), ol.format.GML2.GEOMETRY_SERIALIZERS_,
+ * @private
+ol.format.GML2.prototype.writeCurveOrLineString_ = function(node, geometry, objectStack) {
+ var coordinates = this.createCoordinatesNode_(node.namespaceURI);
+ node.appendChild(coordinates);
+ this.writeCoordinates_(coordinates, geometry, objectStack);
+ * @param {string} namespaceURI XML namespace.
+ * @returns {Node} coordinates node.
+ * @private
+ol.format.GML2.prototype.createCoordinatesNode_ = function(namespaceURI) {
+ var coordinates = ol.xml.createElementNS(namespaceURI, 'coordinates');
+ coordinates.setAttribute('decimal', '.');
+ coordinates.setAttribute('cs', ',');
+ coordinates.setAttribute('ts', ' ');
+ return coordinates;
+ * @private
+ol.format.GML2.prototype.writeCoordinates_ = function(node, value, objectStack) {
+ var point;
+ * @private
+ol.format.GML2.prototype.writeCurveSegments_ = function(node, line, objectStack) {
+ * @private
+ol.format.GML2.prototype.writeSurfaceOrPolygon_ = function(node, geometry, objectStack) {
+ ol.format.GML2.RING_SERIALIZERS_,
+ * @private
+ol.format.GML2.prototype.RING_NODE_FACTORY_ = function(value, objectStack, opt_nodeName) {
+ exteriorWritten !== undefined ? 'innerBoundaryIs' : 'outerBoundaryIs');
+ * @private
+ol.format.GML2.prototype.writeSurfacePatches_ = function(node, polygon, objectStack) {
+ * @private
+ol.format.GML2.prototype.writeRing_ = function(node, ring, objectStack) {
+ * @private
+ol.format.GML2.prototype.getCoords_ = function(point, opt_srsName) {
+ point[0] + ',' + point[1] :
+ point[1] + ',' + point[0]);
+ * @private
+ol.format.GML2.prototype.writeMultiCurveOrLineString_ = function(node, geometry, objectStack) {
+ if (srsName) {
+ ol.format.GML2.LINESTRINGORCURVEMEMBER_SERIALIZERS_,
+ * @private
+ol.format.GML2.prototype.writePoint_ = function(node, geometry, objectStack) {
+ if (srsName) {
+ var point = geometry.getCoordinates();
+ var coord = this.getCoords_(point, srsName);
+ ol.format.XSD.writeStringTextNode(coordinates, coord);
+ * @private
+ol.format.GML2.prototype.writeMultiPoint_ = function(node, geometry,
+ objectStack) {
+ if (srsName) {
+ ol.format.GML2.POINTMEMBER_SERIALIZERS_,
+ * @private
+ol.format.GML2.prototype.writePointMember_ = function(node, point, objectStack) {
+ * @private
+ol.format.GML2.prototype.writeLineStringOrCurveMember_ = function(node, line, objectStack) {
+ if (child) {
+ * @private
+ol.format.GML2.prototype.writeLinearRing_ = function(node, geometry, objectStack) {
+ if (srsName) {
+ * @private
+ol.format.GML2.prototype.writeMultiSurfaceOrPolygon_ = function(node, geometry, objectStack) {
+ if (srsName) {
+ ol.format.GML2.SURFACEORPOLYGONMEMBER_SERIALIZERS_,
+ * @private
+ol.format.GML2.prototype.writeSurfaceOrPolygonMember_ = function(node, polygon, objectStack) {
+ if (child) {
+ * @private
+ol.format.GML2.prototype.writeEnvelope = function(node, extent, objectStack) {
+ if (srsName) {
+ ({node: node}), ol.format.GML2.ENVELOPE_SERIALIZERS_,
+ values,
+ * @const
+ * @private
+ol.format.GML2.GEOMETRY_SERIALIZERS_ = {
+ ol.format.GML2.prototype.writeCurveOrLineString_),
+ ol.format.GML2.prototype.writeMultiCurveOrLineString_),
+ 'Point': ol.xml.makeChildAppender(ol.format.GML2.prototype.writePoint_),
+ ol.format.GML2.prototype.writeMultiPoint_),
+ ol.format.GML2.prototype.writeLinearRing_),
+ ol.format.GML2.prototype.writeSurfaceOrPolygon_),
+ ol.format.GML2.prototype.writeMultiSurfaceOrPolygon_),
+ ol.format.GML2.prototype.writeEnvelope)
+ * @private
+ol.format.GML2.RING_SERIALIZERS_ = {
+ 'outerBoundaryIs': ol.xml.makeChildAppender(ol.format.GML2.prototype.writeRing_),
+ 'innerBoundaryIs': ol.xml.makeChildAppender(ol.format.GML2.prototype.writeRing_)
+ * @private
+ol.format.GML2.POINTMEMBER_SERIALIZERS_ = {
+ ol.format.GML2.prototype.writePointMember_)
+ * @private
+ol.format.GML2.LINESTRINGORCURVEMEMBER_SERIALIZERS_ = {
+ ol.format.GML2.prototype.writeLineStringOrCurveMember_),
+ * @const
+ * @private
+ol.format.GML2.prototype.MULTIGEOMETRY_MEMBER_NODE_FACTORY_ = function(value, objectStack, opt_nodeName) {
+ ol.format.GML2.MULTIGEOMETRY_TO_MEMBER_NODENAME_[parentNode.nodeName]);
+ * @const
+ * @private
+ol.format.GML2.MULTIGEOMETRY_TO_MEMBER_NODENAME_ = {
+ * @const
+ * @private
+ol.format.GML2.SURFACEORPOLYGONMEMBER_SERIALIZERS_ = {
+ ol.format.GML2.prototype.writeSurfaceOrPolygonMember_),
+ * @private
+ol.format.GML2.ENVELOPE_SERIALIZERS_ = {
+goog.provide('ol.format.GPX');
+goog.require('ol.Feature');
+goog.require('ol.format.Feature');
+goog.require('ol.proj');
+ * @classdesc
+ * Feature format for reading and writing data in the GPX format.
+ * @constructor
+ * @param {olx.format.GPXOptions=} opt_options Options.
+ * @api
+ol.format.GPX = function(opt_options) {
+ var options = opt_options ? opt_options : {};
+ * @inheritDoc
+ this.defaultDataProjection = ol.proj.get('EPSG:4326');
+ * @type {function(ol.Feature, Node)|undefined}
+ * @private
+ this.readExtensions_ = options.readExtensions;
+ol.inherits(ol.format.GPX, ol.format.XMLFeature);
+ * @const
+ * @private
+ * @type {Array.<string>}
+ol.format.GPX.NAMESPACE_URIS_ = [
+ null,
+ 'http://www.topografix.com/GPX/1/0',
+ 'http://www.topografix.com/GPX/1/1'
+ * @const
+ * @type {string}
+ * @private
+ol.format.GPX.SCHEMA_LOCATION_ = 'http://www.topografix.com/GPX/1/1 ' +
+ 'http://www.topografix.com/GPX/1/1/gpx.xsd';
+ * @param {Array.<number>} flatCoordinates Flat coordinates.
+ * @param {ol.LayoutOptions} layoutOptions Layout options.
+ * @param {Object} values Values.
+ * @private
+ol.format.GPX.appendCoordinate_ = function(flatCoordinates, layoutOptions, node, values) {
+ parseFloat(node.getAttribute('lon')),
+ parseFloat(node.getAttribute('lat')));
+ if ('ele' in values) {
+ flatCoordinates.push(/** @type {number} */ (values['ele']));
+ delete values['ele'];
+ layoutOptions.hasZ = true;
+ } else {
+ if ('time' in values) {
+ flatCoordinates.push(/** @type {number} */ (values['time']));
+ delete values['time'];
+ layoutOptions.hasM = true;
+ } else {
+ * Choose GeometryLayout based on flags in layoutOptions and adjust flatCoordinates
+ * and ends arrays by shrinking them accordingly (removing unused zero entries).
+ * @param {Array.<number>=} ends Ends.
+ * @return {ol.geom.GeometryLayout} Layout.
+ol.format.GPX.applyLayoutOptions_ = function(layoutOptions, flatCoordinates, ends) {
+ var layout = ol.geom.GeometryLayout.XY;
+ var stride = 2;
+ if (layoutOptions.hasZ && layoutOptions.hasM) {
+ layout = ol.geom.GeometryLayout.XYZM;
+ stride = 4;
+ } else if (layoutOptions.hasZ) {
+ layout = ol.geom.GeometryLayout.XYZ;
+ stride = 3;
+ } else if (layoutOptions.hasM) {
+ layout = ol.geom.GeometryLayout.XYM;
+ stride = 3;
+ if (stride !== 4) {
+ var i, ii;
+ for (i = 0, ii = flatCoordinates.length / 4; i < ii; i++) {
+ flatCoordinates[i * stride] = flatCoordinates[i * 4];
+ flatCoordinates[i * stride + 1] = flatCoordinates[i * 4 + 1];
+ if (layoutOptions.hasZ) {
+ flatCoordinates[i * stride + 2] = flatCoordinates[i * 4 + 2];
+ if (layoutOptions.hasM) {
+ flatCoordinates[i * stride + 2] = flatCoordinates[i * 4 + 3];
+ flatCoordinates.length = flatCoordinates.length / 4 * stride;
+ if (ends) {
+ for (i = 0, ii = ends.length; i < ii; i++) {
+ ends[i] = ends[i] / 4 * stride;
+ return layout;
+ * @private
+ol.format.GPX.parseLink_ = function(node, objectStack) {
+ var values = /** @type {Object} */ (objectStack[objectStack.length - 1]);
+ var href = node.getAttribute('href');
+ if (href !== null) {
+ values['link'] = href;
+ ol.xml.parseNode(ol.format.GPX.LINK_PARSERS_, node, objectStack);
+ * @private
+ol.format.GPX.parseExtensions_ = function(node, objectStack) {
+ values['extensionsNode_'] = node;
+ * @private
+ol.format.GPX.parseRtePt_ = function(node, objectStack) {
+ var values = ol.xml.pushParseAndPop(
+ {}, ol.format.GPX.RTEPT_PARSERS_, node, objectStack);
+ if (values) {
+ var rteValues = /** @type {Object} */ (objectStack[objectStack.length - 1]);
+ var flatCoordinates = /** @type {Array.<number>} */
+ (rteValues['flatCoordinates']);
+ var layoutOptions = /** @type {ol.LayoutOptions} */
+ (rteValues['layoutOptions']);
+ ol.format.GPX.appendCoordinate_(flatCoordinates, layoutOptions, node, values);
+ * @private
+ol.format.GPX.parseTrkPt_ = function(node, objectStack) {
+ {}, ol.format.GPX.TRKPT_PARSERS_, node, objectStack);
+ if (values) {
+ var trkValues = /** @type {Object} */ (objectStack[objectStack.length - 1]);
+ (trkValues['flatCoordinates']);
+ (trkValues['layoutOptions']);
+ * @private
+ol.format.GPX.parseTrkSeg_ = function(node, objectStack) {
+ ol.xml.parseNode(ol.format.GPX.TRKSEG_PARSERS_, node, objectStack);
+ (values['flatCoordinates']);
+ var ends = /** @type {Array.<number>} */ (values['ends']);
+ * @private
+ * @return {ol.Feature|undefined} Track.
+ol.format.GPX.readRte_ = function(node, objectStack) {
+ var options = /** @type {olx.format.ReadOptions} */ (objectStack[0]);
+ var values = ol.xml.pushParseAndPop({
+ 'flatCoordinates': [],
+ 'layoutOptions': {}
+ }, ol.format.GPX.RTE_PARSERS_, node, objectStack);
+ if (!values) {
+ return undefined;
+ delete values['flatCoordinates'];
+ var layoutOptions = /** @type {ol.LayoutOptions} */ (values['layoutOptions']);
+ delete values['layoutOptions'];
+ var layout = ol.format.GPX.applyLayoutOptions_(layoutOptions, flatCoordinates);
+ var geometry = new ol.geom.LineString(null);
+ geometry.setFlatCoordinates(layout, flatCoordinates);
+ ol.format.Feature.transformWithOptions(geometry, false, options);
+ var feature = new ol.Feature(geometry);
+ feature.setProperties(values);
+ return feature;
+ * @private
+ol.format.GPX.readTrk_ = function(node, objectStack) {
+ 'ends': [],
+ }, ol.format.GPX.TRK_PARSERS_, node, objectStack);
+ if (!values) {
+ return undefined;
+ delete values['ends'];
+ var layout = ol.format.GPX.applyLayoutOptions_(layoutOptions, flatCoordinates, ends);
+ var geometry = new ol.geom.MultiLineString(null);
+ geometry.setFlatCoordinates(layout, flatCoordinates, ends);
+ return feature;
+ * @private
+ * @return {ol.Feature|undefined} Waypoint.
+ol.format.GPX.readWpt_ = function(node, objectStack) {
+ {}, ol.format.GPX.WPT_PARSERS_, node, objectStack);
+ if (!values) {
+ return undefined;
+ var layoutOptions = /** @type {ol.LayoutOptions} */ ({});
+ var coordinates = ol.format.GPX.appendCoordinate_([], layoutOptions, node, values);
+ var layout = ol.format.GPX.applyLayoutOptions_(layoutOptions, coordinates);
+ var geometry = new ol.geom.Point(coordinates, layout);
+ return feature;
+ * @const
+ * @type {Object.<string, function(Node, Array.<*>): (ol.Feature|undefined)>}
+ * @private
+ol.format.GPX.FEATURE_READER_ = {
+ 'rte': ol.format.GPX.readRte_,
+ 'trk': ol.format.GPX.readTrk_,
+ 'wpt': ol.format.GPX.readWpt_
+ * @const
+ * @private
+ol.format.GPX.GPX_PARSERS_ = ol.xml.makeStructureNS(
+ ol.format.GPX.NAMESPACE_URIS_, {
+ 'rte': ol.xml.makeArrayPusher(ol.format.GPX.readRte_),
+ 'trk': ol.xml.makeArrayPusher(ol.format.GPX.readTrk_),
+ 'wpt': ol.xml.makeArrayPusher(ol.format.GPX.readWpt_)
+ * @const
+ * @private
+ol.format.GPX.LINK_PARSERS_ = ol.xml.makeStructureNS(
+ 'text':
+ ol.xml.makeObjectPropertySetter(ol.format.XSD.readString, 'linkText'),
+ 'type':
+ ol.xml.makeObjectPropertySetter(ol.format.XSD.readString, 'linkType')
+ * @const
+ * @private
+ol.format.GPX.RTE_PARSERS_ = ol.xml.makeStructureNS(
+ 'name': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'cmt': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'desc': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'src': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'link': ol.format.GPX.parseLink_,
+ 'number':
+ ol.xml.makeObjectPropertySetter(ol.format.XSD.readNonNegativeInteger),
+ 'extensions': ol.format.GPX.parseExtensions_,
+ 'type': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'rtept': ol.format.GPX.parseRtePt_
+ * @const
+ * @private
+ol.format.GPX.RTEPT_PARSERS_ = ol.xml.makeStructureNS(
+ 'ele': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'time': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDateTime)
+ * @const
+ * @private
+ol.format.GPX.TRK_PARSERS_ = ol.xml.makeStructureNS(
+ 'number':
+ 'trkseg': ol.format.GPX.parseTrkSeg_
+ * @const
+ * @private
+ol.format.GPX.TRKSEG_PARSERS_ = ol.xml.makeStructureNS(
+ 'trkpt': ol.format.GPX.parseTrkPt_
+ * @const
+ * @private
+ol.format.GPX.TRKPT_PARSERS_ = ol.xml.makeStructureNS(
+ * @const
+ * @private
+ol.format.GPX.WPT_PARSERS_ = ol.xml.makeStructureNS(
+ 'time': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDateTime),
+ 'magvar': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'geoidheight': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'sym': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'fix': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'sat': ol.xml.makeObjectPropertySetter(
+ ol.format.XSD.readNonNegativeInteger),
+ 'hdop': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'vdop': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'pdop': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'ageofdgpsdata':
+ ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'dgpsid':
+ * @param {Array.<ol.Feature>} features List of features.
+ * @private
+ol.format.GPX.prototype.handleReadExtensions_ = function(features) {
+ if (!features) {
+ features = [];
+ for (var i = 0, ii = features.length; i < ii; ++i) {
+ var feature = features[i];
+ if (this.readExtensions_) {
+ var extensionsNode = feature.get('extensionsNode_') || null;
+ this.readExtensions_(feature, extensionsNode);
+ feature.set('extensionsNode_', undefined);
+ * Read the first feature from a GPX source.
+ * Routes (`<rte>`) are converted into LineString geometries, and tracks (`<trk>`)
+ * into MultiLineString. Any properties on route and track waypoints are ignored.
+ * @function
+ * @param {Document|Node|Object|string} source Source.
+ * @param {olx.format.ReadOptions=} opt_options Read options.
+ * @return {ol.Feature} Feature.
+ * @api
+ol.format.GPX.prototype.readFeature;
+ * @inheritDoc
+ol.format.GPX.prototype.readFeatureFromNode = function(node, opt_options) {
+ if (!ol.array.includes(ol.format.GPX.NAMESPACE_URIS_, node.namespaceURI)) {
+ return null;
+ var featureReader = ol.format.GPX.FEATURE_READER_[node.localName];
+ if (!featureReader) {
+ return null;
+ var feature = featureReader(node, [this.getReadOptions(node, opt_options)]);
+ if (!feature) {
+ return null;
+ this.handleReadExtensions_([feature]);
+ return feature;
+ * Read all features from a GPX source.
+ * @function
+ * @return {Array.<ol.Feature>} Features.
+ * @api
+ol.format.GPX.prototype.readFeatures;
+ * @inheritDoc
+ol.format.GPX.prototype.readFeaturesFromNode = function(node, opt_options) {
+ return [];
+ if (node.localName == 'gpx') {
+ /** @type {Array.<ol.Feature>} */
+ var features = ol.xml.pushParseAndPop([], ol.format.GPX.GPX_PARSERS_,
+ node, [this.getReadOptions(node, opt_options)]);
+ if (features) {
+ this.handleReadExtensions_(features);
+ return features;
+ } else {
+ return [];
+ return [];
+ * Read the projection from a GPX source.
+ * @function
+ * @return {ol.proj.Projection} Projection.
+ * @api
+ol.format.GPX.prototype.readProjection;
+ * @param {string} value Value for the link's `href` attribute.
+ * @private
+ol.format.GPX.writeLink_ = function(node, value, objectStack) {
+ node.setAttribute('href', value);
+ var properties = context['properties'];
+ var link = [
+ properties['linkText'],
+ properties['linkType']
+ ol.xml.pushSerializeAndPop(/** @type {ol.XmlNodeStackItem} */ ({node: node}),
+ ol.format.GPX.LINK_SERIALIZERS_, ol.xml.OBJECT_PROPERTY_NODE_FACTORY,
+ link, objectStack, ol.format.GPX.LINK_SEQUENCE_);
+ * @param {ol.Coordinate} coordinate Coordinate.
+ * @private
+ol.format.GPX.writeWptType_ = function(node, coordinate, objectStack) {
+ var namespaceURI = parentNode.namespaceURI;
+ //FIXME Projection handling
+ ol.xml.setAttributeNS(node, null, 'lat', coordinate[1]);
+ ol.xml.setAttributeNS(node, null, 'lon', coordinate[0]);
+ var geometryLayout = context['geometryLayout'];
+ switch (geometryLayout) {
+ case ol.geom.GeometryLayout.XYZM:
+ if (coordinate[3] !== 0) {
+ properties['time'] = coordinate[3];
+ // fall through
+ case ol.geom.GeometryLayout.XYZ:
+ if (coordinate[2] !== 0) {
+ properties['ele'] = coordinate[2];
+ break;
+ case ol.geom.GeometryLayout.XYM:
+ properties['time'] = coordinate[2];
+ break;
+ default:
+ // pass
+ var orderedKeys = (node.nodeName == 'rtept') ?
+ ol.format.GPX.RTEPT_TYPE_SEQUENCE_[namespaceURI] :
+ ol.format.GPX.WPT_TYPE_SEQUENCE_[namespaceURI];
+ var values = ol.xml.makeSequence(properties, orderedKeys);
+ ({node: node, 'properties': properties}),
+ ol.format.GPX.WPT_TYPE_SERIALIZERS_, ol.xml.OBJECT_PROPERTY_NODE_FACTORY,
+ values, objectStack, orderedKeys);
+ * @param {Node} node Node.
+ * @param {ol.Feature} feature Feature.
+ * @private
+ol.format.GPX.writeRte_ = function(node, feature, objectStack) {
+ var options = /** @type {olx.format.WriteOptions} */ (objectStack[0]);
+ var context = {node: node, 'properties': properties};
+ var geometry = feature.getGeometry();
+ if (geometry) {
+ geometry = /** @type {ol.geom.LineString} */
+ (ol.format.Feature.transformWithOptions(geometry, true, options));
+ context['geometryLayout'] = geometry.getLayout();
+ properties['rtept'] = geometry.getCoordinates();
+ var orderedKeys = ol.format.GPX.RTE_SEQUENCE_[parentNode.namespaceURI];
+ ol.xml.pushSerializeAndPop(context,
+ ol.format.GPX.RTE_SERIALIZERS_, ol.xml.OBJECT_PROPERTY_NODE_FACTORY,
+ * @private
+ol.format.GPX.writeTrk_ = function(node, feature, objectStack) {
+ /** @type {ol.XmlNodeStackItem} */
+ if (geometry) {
+ geometry = /** @type {ol.geom.MultiLineString} */
+ properties['trkseg'] = geometry.getLineStrings();
+ var orderedKeys = ol.format.GPX.TRK_SEQUENCE_[parentNode.namespaceURI];
+ ol.format.GPX.TRK_SERIALIZERS_, ol.xml.OBJECT_PROPERTY_NODE_FACTORY,
+ * @param {ol.geom.LineString} lineString LineString.
+ * @private
+ol.format.GPX.writeTrkSeg_ = function(node, lineString, objectStack) {
+ var context = {node: node, 'geometryLayout': lineString.getLayout(),
+ 'properties': {}};
+ ol.format.GPX.TRKSEG_SERIALIZERS_, ol.format.GPX.TRKSEG_NODE_FACTORY_,
+ lineString.getCoordinates(), objectStack);
+ * @private
+ol.format.GPX.writeWpt_ = function(node, feature, objectStack) {
+ context['properties'] = feature.getProperties();
+ if (geometry) {
+ geometry = /** @type {ol.geom.Point} */
+ ol.format.GPX.writeWptType_(node, geometry.getCoordinates(), objectStack);
+ * @const
+ * @private
+ol.format.GPX.LINK_SEQUENCE_ = ['text', 'type'];
+ * @private
+ol.format.GPX.LINK_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'text': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
+ 'type': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode)
+ * @const
+ * @type {Object.<string, Array.<string>>}
+ * @private
+ol.format.GPX.RTE_SEQUENCE_ = ol.xml.makeStructureNS(
+ ol.format.GPX.NAMESPACE_URIS_, [
+ 'name', 'cmt', 'desc', 'src', 'link', 'number', 'type', 'rtept'
+ * @const
+ * @private
+ol.format.GPX.RTE_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'name': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
+ 'cmt': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
+ 'desc': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
+ 'src': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
+ 'link': ol.xml.makeChildAppender(ol.format.GPX.writeLink_),
+ 'number': ol.xml.makeChildAppender(
+ ol.format.XSD.writeNonNegativeIntegerTextNode),
+ 'type': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
+ 'rtept': ol.xml.makeArraySerializer(ol.xml.makeChildAppender(
+ ol.format.GPX.writeWptType_))
+ * @const
+ * @private
+ol.format.GPX.RTEPT_TYPE_SEQUENCE_ = ol.xml.makeStructureNS(
+ 'ele', 'time'
+ * @const
+ * @private
+ol.format.GPX.TRK_SEQUENCE_ = ol.xml.makeStructureNS(
+ 'name', 'cmt', 'desc', 'src', 'link', 'number', 'type', 'trkseg'
+ * @const
+ * @private
+ol.format.GPX.TRK_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'trkseg': ol.xml.makeArraySerializer(ol.xml.makeChildAppender(
+ ol.format.GPX.writeTrkSeg_))
+ * @const
+ * @type {function(*, Array.<*>, string=): (Node|undefined)}
+ * @private
+ol.format.GPX.TRKSEG_NODE_FACTORY_ = ol.xml.makeSimpleNodeFactory('trkpt');
+ * @const
+ * @private
+ol.format.GPX.TRKSEG_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'trkpt': ol.xml.makeChildAppender(ol.format.GPX.writeWptType_)
+ * @const
+ * @private
+ol.format.GPX.WPT_TYPE_SEQUENCE_ = ol.xml.makeStructureNS(
+ 'ele', 'time', 'magvar', 'geoidheight', 'name', 'cmt', 'desc', 'src',
+ 'link', 'sym', 'type', 'fix', 'sat', 'hdop', 'vdop', 'pdop',
+ 'ageofdgpsdata', 'dgpsid'
+ * @private
+ol.format.GPX.WPT_TYPE_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'ele': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
+ 'time': ol.xml.makeChildAppender(ol.format.XSD.writeDateTimeTextNode),
+ 'magvar': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
+ 'geoidheight': ol.xml.makeChildAppender(
+ ol.format.XSD.writeDecimalTextNode),
+ 'sym': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
+ 'fix': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
+ 'sat': ol.xml.makeChildAppender(
+ 'hdop': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
+ 'vdop': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
+ 'pdop': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
+ 'ageofdgpsdata': ol.xml.makeChildAppender(
+ 'dgpsid': ol.xml.makeChildAppender(
+ * @const
+ * @private
+ol.format.GPX.GEOMETRY_TYPE_TO_NODENAME_ = {
+ 'Point': 'wpt',
+ 'LineString': 'rte',
+ 'MultiLineString': 'trk'
+ * @const
+ * @param {Array.<*>} objectStack Object stack.
+ * @private
+ol.format.GPX.GPX_NODE_FACTORY_ = function(value, objectStack, opt_nodeName) {
+ var geometry = /** @type {ol.Feature} */ (value).getGeometry();
+ if (geometry) {
+ var nodeName = ol.format.GPX.GEOMETRY_TYPE_TO_NODENAME_[geometry.getType()];
+ if (nodeName) {
+ return ol.xml.createElementNS(parentNode.namespaceURI, nodeName);
+ * @const
+ * @private
+ol.format.GPX.GPX_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'rte': ol.xml.makeChildAppender(ol.format.GPX.writeRte_),
+ 'trk': ol.xml.makeChildAppender(ol.format.GPX.writeTrk_),
+ 'wpt': ol.xml.makeChildAppender(ol.format.GPX.writeWpt_)
+ * Encode an array of features in the GPX format.
+ * LineString geometries are output as routes (`<rte>`), and MultiLineString
+ * as tracks (`<trk>`).
+ * @function
+ * @param {Array.<ol.Feature>} features Features.
+ * @param {olx.format.WriteOptions=} opt_options Write options.
+ * @api
+ol.format.GPX.prototype.writeFeatures;
+ * Encode an array of features in the GPX format as an XML node.
+ * @param {olx.format.WriteOptions=} opt_options Options.
+ * @return {Node} Node.
+ * @override
+ * @api
+ol.format.GPX.prototype.writeFeaturesNode = function(features, opt_options) {
+ //FIXME Serialize metadata
+ var gpx = ol.xml.createElementNS('http://www.topografix.com/GPX/1/1', 'gpx');
+ var xmlnsUri = 'http://www.w3.org/2000/xmlns/';
+ var xmlSchemaInstanceUri = 'http://www.w3.org/2001/XMLSchema-instance';
+ ol.xml.setAttributeNS(gpx, xmlnsUri, 'xmlns:xsi', xmlSchemaInstanceUri);
+ ol.xml.setAttributeNS(gpx, xmlSchemaInstanceUri, 'xsi:schemaLocation',
+ ol.format.GPX.SCHEMA_LOCATION_);
+ gpx.setAttribute('version', '1.1');
+ gpx.setAttribute('creator', 'OpenLayers');
+ ({node: gpx}), ol.format.GPX.GPX_SERIALIZERS_,
+ ol.format.GPX.GPX_NODE_FACTORY_, features, [opt_options]);
+ return gpx;
+goog.provide('ol.format.IGCZ');
+ * IGC altitude/z. One of 'barometric', 'gps', 'none'.
+ * @enum {string}
+ol.format.IGCZ = {
+ BAROMETRIC: 'barometric',
+ GPS: 'gps',
+ NONE: 'none'
+goog.provide('ol.format.TextFeature');
+goog.require('ol');
+goog.require('ol.format.FormatType');
+ * @classdesc
+ * Abstract base class; normally only used for creating subclasses and not
+ * instantiated in apps.
+ * Base class for text feature formats.
+ * @constructor
+ * @abstract
+ * @extends {ol.format.Feature}
+ol.format.TextFeature = function() {
+ ol.format.Feature.call(this);
+ol.inherits(ol.format.TextFeature, ol.format.Feature);
+ * @private
+ * @return {string} Text.
+ol.format.TextFeature.prototype.getText_ = function(source) {
+ if (typeof source === 'string') {
+ return source;
+ } else {
+ return '';
+ * @inheritDoc
+ol.format.TextFeature.prototype.getType = function() {
+ return ol.format.FormatType.TEXT;
+ * @inheritDoc
+ol.format.TextFeature.prototype.readFeature = function(source, opt_options) {
+ return this.readFeatureFromText(
+ this.getText_(source), this.adaptOptions(opt_options));
+ * @abstract
+ * @param {string} text Text.
+ * @protected
+ol.format.TextFeature.prototype.readFeatureFromText = function(text, opt_options) {};
+ * @inheritDoc
+ol.format.TextFeature.prototype.readFeatures = function(source, opt_options) {
+ return this.readFeaturesFromText(
+ * @abstract
+ * @protected
+ol.format.TextFeature.prototype.readFeaturesFromText = function(text, opt_options) {};
+ * @inheritDoc
+ol.format.TextFeature.prototype.readGeometry = function(source, opt_options) {
+ return this.readGeometryFromText(
+ * @abstract
+ * @protected
+ * @return {ol.geom.Geometry} Geometry.
+ol.format.TextFeature.prototype.readGeometryFromText = function(text, opt_options) {};
+ * @inheritDoc
+ol.format.TextFeature.prototype.readProjection = function(source) {
+ return this.readProjectionFromText(this.getText_(source));
+ * @protected
+ol.format.TextFeature.prototype.readProjectionFromText = function(text) {
+ return this.defaultDataProjection;
+ * @inheritDoc
+ol.format.TextFeature.prototype.writeFeature = function(feature, opt_options) {
+ return this.writeFeatureText(feature, this.adaptOptions(opt_options));
+ * @abstract
+ * @param {ol.Feature} feature Features.
+ * @protected
+ol.format.TextFeature.prototype.writeFeatureText = function(feature, opt_options) {};
+ * @inheritDoc
+ol.format.TextFeature.prototype.writeFeatures = function(
+ features, opt_options) {
+ return this.writeFeaturesText(features, this.adaptOptions(opt_options));
+ * @abstract
+ * @protected
+ol.format.TextFeature.prototype.writeFeaturesText = function(features, opt_options) {};
+ * @inheritDoc
+ol.format.TextFeature.prototype.writeGeometry = function(
+ geometry, opt_options) {
+ return this.writeGeometryText(geometry, this.adaptOptions(opt_options));
+ * @abstract
+ * @param {ol.geom.Geometry} geometry Geometry.
+ * @protected
+ol.format.TextFeature.prototype.writeGeometryText = function(geometry, opt_options) {};
+goog.provide('ol.format.IGC');
+goog.require('ol.format.IGCZ');
+goog.require('ol.format.TextFeature');
+goog.require('ol.geom.GeometryLayout');
+goog.require('ol.geom.LineString');
+ * @classdesc
+ * Feature format for `*.igc` flight recording files.
+ * @constructor
+ * @extends {ol.format.TextFeature}
+ * @param {olx.format.IGCOptions=} opt_options Options.
+ * @api
+ol.format.IGC = function(opt_options) {
+ ol.format.TextFeature.call(this);
+ * @inheritDoc
+ * @private
+ * @type {ol.format.IGCZ}
+ this.altitudeMode_ = options.altitudeMode ?
+ options.altitudeMode : ol.format.IGCZ.NONE;
+ol.inherits(ol.format.IGC, ol.format.TextFeature);
+ * @const
+ * @type {RegExp}
+ * @private
+ol.format.IGC.B_RECORD_RE_ =
+ /^B(\d{2})(\d{2})(\d{2})(\d{2})(\d{5})([NS])(\d{3})(\d{5})([EW])([AV])(\d{5})(\d{5})/;
+ * @const
+ * @type {RegExp}
+ * @private
+ol.format.IGC.H_RECORD_RE_ = /^H.([A-Z]{3}).*?:(.*)/;
+ * @const
+ * @type {RegExp}
+ * @private
+ol.format.IGC.HFDTE_RECORD_RE_ = /^HFDTE(\d{2})(\d{2})(\d{2})/;
+ * A regular expression matching the newline characters `\r\n`, `\r` and `\n`.
+ * @const
+ * @type {RegExp}
+ * @private
+ol.format.IGC.NEWLINE_RE_ = /\r\n|\r|\n/;
+ * Read the feature from the IGC source.
+ * @function
+ * @api
+ol.format.IGC.prototype.readFeature;
+ * @inheritDoc
+ol.format.IGC.prototype.readFeatureFromText = function(text, opt_options) {
+ var altitudeMode = this.altitudeMode_;
+ var lines = text.split(ol.format.IGC.NEWLINE_RE_);
+ /** @type {Object.<string, string>} */
+ var properties = {};
+ var year = 2000;
+ var month = 0;
+ var day = 1;
+ var lastDateTime = -1;
+ var i, ii;
+ for (i = 0, ii = lines.length; i < ii; ++i) {
+ var line = lines[i];
+ var m;
+ if (line.charAt(0) == 'B') {
+ m = ol.format.IGC.B_RECORD_RE_.exec(line);
+ if (m) {
+ var hour = parseInt(m[1], 10);
+ var minute = parseInt(m[2], 10);
+ var second = parseInt(m[3], 10);
+ var y = parseInt(m[4], 10) + parseInt(m[5], 10) / 60000;
+ if (m[6] == 'S') {
+ y = -y;
+ var x = parseInt(m[7], 10) + parseInt(m[8], 10) / 60000;
+ if (m[9] == 'W') {
+ x = -x;
+ flatCoordinates.push(x, y);
+ if (altitudeMode != ol.format.IGCZ.NONE) {
+ var z;
+ if (altitudeMode == ol.format.IGCZ.GPS) {
+ z = parseInt(m[11], 10);
+ } else if (altitudeMode == ol.format.IGCZ.BAROMETRIC) {
+ z = parseInt(m[12], 10);
+ } else {
+ z = 0;
+ flatCoordinates.push(z);
+ var dateTime = Date.UTC(year, month, day, hour, minute, second);
+ // Detect UTC midnight wrap around.
+ if (dateTime < lastDateTime) {
+ dateTime = Date.UTC(year, month, day + 1, hour, minute, second);
+ flatCoordinates.push(dateTime / 1000);
+ lastDateTime = dateTime;
+ } else if (line.charAt(0) == 'H') {
+ m = ol.format.IGC.HFDTE_RECORD_RE_.exec(line);
+ if (m) {
+ day = parseInt(m[1], 10);
+ month = parseInt(m[2], 10) - 1;
+ year = 2000 + parseInt(m[3], 10);
+ } else {
+ m = ol.format.IGC.H_RECORD_RE_.exec(line);
+ if (m) {
+ properties[m[1]] = m[2].trim();
+ if (flatCoordinates.length === 0) {
+ return null;
+ var lineString = new ol.geom.LineString(null);
+ var layout = altitudeMode == ol.format.IGCZ.NONE ?
+ ol.geom.GeometryLayout.XYM : ol.geom.GeometryLayout.XYZM;
+ lineString.setFlatCoordinates(layout, flatCoordinates);
+ var feature = new ol.Feature(ol.format.Feature.transformWithOptions(
+ lineString, false, opt_options));
+ feature.setProperties(properties);
+ return feature;
+ * Read the feature from the source. As IGC sources contain a single
+ * feature, this will return the feature in an array.
+ * @function
+ * @api
+ol.format.IGC.prototype.readFeatures;
+ * @inheritDoc
+ol.format.IGC.prototype.readFeaturesFromText = function(text, opt_options) {
+ var feature = this.readFeatureFromText(text, opt_options);
+ if (feature) {
+ return [feature];
+ } else {
+ return [];
+ * Read the projection from the IGC source.
+ * @function
+ * @api
+ol.format.IGC.prototype.readProjection;
+ * Not implemented.
+ * @inheritDoc
+ol.format.IGC.prototype.writeFeatureText = function(feature, opt_options) {};
+ * @inheritDoc
+ol.format.IGC.prototype.writeFeaturesText = function(features, opt_options) {};
+ * @inheritDoc
+ol.format.IGC.prototype.writeGeometryText = function(geometry, opt_options) {};
+ * @inheritDoc
+ol.format.IGC.prototype.readGeometryFromText = function(text, opt_options) {};
+goog.provide('ol.style.IconAnchorUnits');
+ * Icon anchor units. One of 'fraction', 'pixels'.
+ * @enum {string}
+ol.style.IconAnchorUnits = {
+ FRACTION: 'fraction',
+ PIXELS: 'pixels'
+goog.provide('ol.style.IconImage');
+goog.require('ol.dom');
+goog.require('ol.events');
+goog.require('ol.events.EventTarget');
+goog.require('ol.events.EventType');
+goog.require('ol.ImageState');
+goog.require('ol.style');
+ * @constructor
+ * @param {Image|HTMLCanvasElement} image Image.
+ * @param {string|undefined} src Src.
+ * @param {ol.Size} size Size.
+ * @param {?string} crossOrigin Cross origin.
+ * @param {ol.ImageState} imageState Image state.
+ * @param {ol.Color} color Color.
+ * @extends {ol.events.EventTarget}
+ol.style.IconImage = function(image, src, size, crossOrigin, imageState,
+ color) {
+ ol.events.EventTarget.call(this);
+ * @private
+ * @type {Image|HTMLCanvasElement}
+ this.hitDetectionImage_ = null;
+ * @private
+ this.image_ = !image ? new Image() : image;
+ if (crossOrigin !== null) {
+ this.image_.crossOrigin = crossOrigin;
+ * @private
+ * @type {HTMLCanvasElement}
+ this.canvas_ = color ?
+ /** @type {HTMLCanvasElement} */ (document.createElement('CANVAS')) :
+ null;
+ * @private
+ * @type {ol.Color}
+ this.color_ = color;
+ * @private
+ * @type {Array.<ol.EventsKey>}
+ this.imageListenerKeys_ = null;
+ * @private
+ * @type {ol.ImageState}
+ this.imageState_ = imageState;
+ * @private
+ * @type {ol.Size}
+ this.size_ = size;
+ * @private
+ * @type {string|undefined}
+ this.src_ = src;
+ * @private
+ * @type {boolean}
+ this.tainting_ = false;
+ if (this.imageState_ == ol.ImageState.LOADED) {
+ this.determineTainting_();
+ol.inherits(ol.style.IconImage, ol.events.EventTarget);
+ * @param {string} src Src.
+ * @return {ol.style.IconImage} Icon image.
+ol.style.IconImage.get = function(image, src, size, crossOrigin, imageState,
+ color) {
+ var iconImageCache = ol.style.iconImageCache;
+ var iconImage = iconImageCache.get(src, crossOrigin, color);
+ if (!iconImage) {
+ iconImage = new ol.style.IconImage(
+ image, src, size, crossOrigin, imageState, color);
+ iconImageCache.set(src, crossOrigin, color, iconImage);
+ return iconImage;
+ * @private
+ol.style.IconImage.prototype.determineTainting_ = function() {
+ var context = ol.dom.createCanvasContext2D(1, 1);
+ try {
+ context.drawImage(this.image_, 0, 0);
+ context.getImageData(0, 0, 1, 1);
+ } catch (e) {
+ this.tainting_ = true;
+ * @private
+ol.style.IconImage.prototype.dispatchChangeEvent_ = function() {
+ this.dispatchEvent(ol.events.EventType.CHANGE);
+ * @private
+ol.style.IconImage.prototype.handleImageError_ = function() {
+ this.imageState_ = ol.ImageState.ERROR;
+ this.unlistenImage_();
+ this.dispatchChangeEvent_();
+ * @private
+ol.style.IconImage.prototype.handleImageLoad_ = function() {
+ this.imageState_ = ol.ImageState.LOADED;
+ if (this.size_) {
+ this.image_.width = this.size_[0];
+ this.image_.height = this.size_[1];
+ this.size_ = [this.image_.width, this.image_.height];
+ this.replaceColor_();
+ * @param {number} pixelRatio Pixel ratio.
+ * @return {Image|HTMLCanvasElement} Image or Canvas element.
+ol.style.IconImage.prototype.getImage = function(pixelRatio) {
+ return this.canvas_ ? this.canvas_ : this.image_;
+ * @return {ol.ImageState} Image state.
+ol.style.IconImage.prototype.getImageState = function() {
+ return this.imageState_;
+ * @return {Image|HTMLCanvasElement} Image element.
+ol.style.IconImage.prototype.getHitDetectionImage = function(pixelRatio) {
+ if (!this.hitDetectionImage_) {
+ if (this.tainting_) {
+ var width = this.size_[0];
+ var height = this.size_[1];
+ var context = ol.dom.createCanvasContext2D(width, height);
+ context.fillRect(0, 0, width, height);
+ this.hitDetectionImage_ = context.canvas;
+ } else {
+ this.hitDetectionImage_ = this.image_;
+ return this.hitDetectionImage_;
+ * @return {ol.Size} Image size.
+ol.style.IconImage.prototype.getSize = function() {
+ return this.size_;
+ * @return {string|undefined} Image src.
+ol.style.IconImage.prototype.getSrc = function() {
+ return this.src_;
+ * Load not yet loaded URI.
+ol.style.IconImage.prototype.load = function() {
+ if (this.imageState_ == ol.ImageState.IDLE) {
+ this.imageState_ = ol.ImageState.LOADING;
+ this.imageListenerKeys_ = [
+ ol.events.listenOnce(this.image_, ol.events.EventType.ERROR,
+ this.handleImageError_, this),
+ ol.events.listenOnce(this.image_, ol.events.EventType.LOAD,
+ this.handleImageLoad_, this)
+ try {
+ this.image_.src = this.src_;
+ } catch (e) {
+ this.handleImageError_();
+ * @private
+ol.style.IconImage.prototype.replaceColor_ = function() {
+ if (this.tainting_ || this.color_ === null) {
+ return;
+ this.canvas_.width = this.image_.width;
+ this.canvas_.height = this.image_.height;
+ var ctx = this.canvas_.getContext('2d');
+ ctx.drawImage(this.image_, 0, 0);
+ var imgData = ctx.getImageData(0, 0, this.image_.width, this.image_.height);
+ var data = imgData.data;
+ var r = this.color_[0] / 255.0;
+ var g = this.color_[1] / 255.0;
+ var b = this.color_[2] / 255.0;
+ for (var i = 0, ii = data.length; i < ii; i += 4) {
+ data[i] *= r;
+ data[i + 1] *= g;
+ data[i + 2] *= b;
+ ctx.putImageData(imgData, 0, 0);
+ * Discards event handlers which listen for load completion or errors.
+ * @private
+ol.style.IconImage.prototype.unlistenImage_ = function() {
+ this.imageListenerKeys_.forEach(ol.events.unlistenByKey);
+goog.provide('ol.style.IconOrigin');
+ * Icon origin. One of 'bottom-left', 'bottom-right', 'top-left', 'top-right'.
+ * @enum {string}
+ol.style.IconOrigin = {
+ BOTTOM_LEFT: 'bottom-left',
+ BOTTOM_RIGHT: 'bottom-right',
+ TOP_LEFT: 'top-left',
+ TOP_RIGHT: 'top-right'
+goog.provide('ol.style.Icon');
+goog.require('ol.asserts');
+goog.require('ol.color');
+goog.require('ol.style.IconAnchorUnits');
+goog.require('ol.style.IconImage');
+goog.require('ol.style.IconOrigin');
+goog.require('ol.style.Image');
+ * @classdesc
+ * Set icon style for vector features.
+ * @constructor
+ * @param {olx.style.IconOptions=} opt_options Options.
+ * @extends {ol.style.Image}
+ * @api
+ol.style.Icon = function(opt_options) {
+ var options = opt_options || {};
+ * @private
+ * @type {Array.<number>}
+ this.anchor_ = options.anchor !== undefined ? options.anchor : [0.5, 0.5];
+ * @private
+ this.normalizedAnchor_ = null;
+ * @private
+ * @type {ol.style.IconOrigin}
+ this.anchorOrigin_ = options.anchorOrigin !== undefined ?
+ options.anchorOrigin : ol.style.IconOrigin.TOP_LEFT;
+ * @private
+ * @type {ol.style.IconAnchorUnits}
+ this.anchorXUnits_ = options.anchorXUnits !== undefined ?
+ options.anchorXUnits : ol.style.IconAnchorUnits.FRACTION;
+ * @private
+ this.anchorYUnits_ = options.anchorYUnits !== undefined ?
+ options.anchorYUnits : ol.style.IconAnchorUnits.FRACTION;
+ * @private
+ * @type {?string}
+ this.crossOrigin_ =
+ options.crossOrigin !== undefined ? options.crossOrigin : null;
+ var image = options.img !== undefined ? options.img : null;
+ * @type {ol.Size}
+ var imgSize = options.imgSize !== undefined ? options.imgSize : null;
+ var src = options.src;
+ ol.asserts.assert(!(src !== undefined && image),
+ 4); // `image` and `src` cannot be provided at the same time
+ ol.asserts.assert(!image || (image && imgSize),
+ 5); // `imgSize` must be set when `image` is provided
+ if ((src === undefined || src.length === 0) && image) {
+ src = image.src || ol.getUid(image).toString();
+ ol.asserts.assert(src !== undefined && src.length > 0,
+ 6); // A defined and non-empty `src` or `image` must be provided
+ var imageState = options.src !== undefined ?
+ ol.ImageState.IDLE : ol.ImageState.LOADED;
+ * @private
+ this.color_ = options.color !== undefined ? ol.color.asArray(options.color) :
+ null;
+ * @private
+ * @type {ol.style.IconImage}
+ this.iconImage_ = ol.style.IconImage.get(
+ image, /** @type {string} */ (src), imgSize, this.crossOrigin_, imageState, this.color_);
+ * @private
+ this.offset_ = options.offset !== undefined ? options.offset : [0, 0];
+ * @private
+ this.offsetOrigin_ = options.offsetOrigin !== undefined ?
+ options.offsetOrigin : ol.style.IconOrigin.TOP_LEFT;
+ * @private
+ this.origin_ = null;
+ * @private
+ * @type {ol.Size}
+ this.size_ = options.size !== undefined ? options.size : null;
+ * @type {number}
+ var opacity = options.opacity !== undefined ? options.opacity : 1;
+ * @type {boolean}
+ var rotateWithView = options.rotateWithView !== undefined ?
+ options.rotateWithView : false;
+ * @type {number}
+ var rotation = options.rotation !== undefined ? options.rotation : 0;
+ * @type {number}
+ var scale = options.scale !== undefined ? options.scale : 1;
+ * @type {boolean}
+ var snapToPixel = options.snapToPixel !== undefined ?
+ options.snapToPixel : true;
+ ol.style.Image.call(this, {
+ opacity: opacity,
+ rotation: rotation,
+ scale: scale,
+ snapToPixel: snapToPixel,
+ rotateWithView: rotateWithView
+ol.inherits(ol.style.Icon, ol.style.Image);
+ * Clones the style.
+ * @return {ol.style.Icon} The cloned style.
+ * @api
+ol.style.Icon.prototype.clone = function() {
+ var oldImage = this.getImage(1);
+ var newImage;
+ if (this.iconImage_.getImageState() === ol.ImageState.LOADED) {
+ if (oldImage.tagName.toUpperCase() === 'IMG') {
+ newImage = /** @type {Image} */ (oldImage.cloneNode(true));
+ } else {
+ newImage = /** @type {HTMLCanvasElement} */ (document.createElement('canvas'));
+ var context = newImage.getContext('2d');
+ newImage.width = oldImage.width;
+ newImage.height = oldImage.height;
+ context.drawImage(oldImage, 0, 0);
+ return new ol.style.Icon({
+ anchor: this.anchor_.slice(),
+ anchorOrigin: this.anchorOrigin_,
+ anchorXUnits: this.anchorXUnits_,
+ anchorYUnits: this.anchorYUnits_,
+ crossOrigin: this.crossOrigin_,
+ color: (this.color_ && this.color_.slice) ? this.color_.slice() : this.color_ || undefined,
+ img: newImage ? newImage : undefined,
+ imgSize: newImage ? this.iconImage_.getSize().slice() : undefined,
+ src: newImage ? undefined : this.getSrc(),
+ offset: this.offset_.slice(),
+ offsetOrigin: this.offsetOrigin_,
+ size: this.size_ !== null ? this.size_.slice() : undefined,
+ opacity: this.getOpacity(),
+ scale: this.getScale(),
+ snapToPixel: this.getSnapToPixel(),
+ rotation: this.getRotation(),
+ rotateWithView: this.getRotateWithView()
+ * @inheritDoc
+ * @api
+ol.style.Icon.prototype.getAnchor = function() {
+ if (this.normalizedAnchor_) {
+ return this.normalizedAnchor_;
+ var anchor = this.anchor_;
+ var size = this.getSize();
+ if (this.anchorXUnits_ == ol.style.IconAnchorUnits.FRACTION ||
+ this.anchorYUnits_ == ol.style.IconAnchorUnits.FRACTION) {
+ if (!size) {
+ return null;
+ anchor = this.anchor_.slice();
+ if (this.anchorXUnits_ == ol.style.IconAnchorUnits.FRACTION) {
+ anchor[0] *= size[0];
+ if (this.anchorYUnits_ == ol.style.IconAnchorUnits.FRACTION) {
+ anchor[1] *= size[1];
+ if (this.anchorOrigin_ != ol.style.IconOrigin.TOP_LEFT) {
+ if (!size) {
+ return null;
+ if (anchor === this.anchor_) {
+ if (this.anchorOrigin_ == ol.style.IconOrigin.TOP_RIGHT ||
+ this.anchorOrigin_ == ol.style.IconOrigin.BOTTOM_RIGHT) {
+ anchor[0] = -anchor[0] + size[0];
+ if (this.anchorOrigin_ == ol.style.IconOrigin.BOTTOM_LEFT ||
+ anchor[1] = -anchor[1] + size[1];
+ this.normalizedAnchor_ = anchor;
+ * Get the icon color.
+ * @return {ol.Color} Color.
+ * @api
+ol.style.Icon.prototype.getColor = function() {
+ return this.color_;
+ * Get the image icon.
+ * @override
+ * @api
+ol.style.Icon.prototype.getImage = function(pixelRatio) {
+ return this.iconImage_.getImage(pixelRatio);
+ * @override
+ol.style.Icon.prototype.getImageSize = function() {
+ return this.iconImage_.getSize();
+ * @override
+ol.style.Icon.prototype.getHitDetectionImageSize = function() {
+ return this.getImageSize();
+ * @override
+ol.style.Icon.prototype.getImageState = function() {
+ return this.iconImage_.getImageState();
+ * @override
+ol.style.Icon.prototype.getHitDetectionImage = function(pixelRatio) {
+ return this.iconImage_.getHitDetectionImage(pixelRatio);
+ * @inheritDoc
+ * @api
+ol.style.Icon.prototype.getOrigin = function() {
+ if (this.origin_) {
+ return this.origin_;
+ var offset = this.offset_;
+ if (this.offsetOrigin_ != ol.style.IconOrigin.TOP_LEFT) {
+ var iconImageSize = this.iconImage_.getSize();
+ if (!size || !iconImageSize) {
+ return null;
+ offset = offset.slice();
+ if (this.offsetOrigin_ == ol.style.IconOrigin.TOP_RIGHT ||
+ this.offsetOrigin_ == ol.style.IconOrigin.BOTTOM_RIGHT) {
+ offset[0] = iconImageSize[0] - size[0] - offset[0];
+ if (this.offsetOrigin_ == ol.style.IconOrigin.BOTTOM_LEFT ||
+ offset[1] = iconImageSize[1] - size[1] - offset[1];
+ this.origin_ = offset;
+ * Get the image URL.
+ * @api
+ol.style.Icon.prototype.getSrc = function() {
+ return this.iconImage_.getSrc();
+ * @inheritDoc
+ * @api
+ol.style.Icon.prototype.getSize = function() {
+ return !this.size_ ? this.iconImage_.getSize() : this.size_;
+ * @override
+ol.style.Icon.prototype.listenImageChange = function(listener, thisArg) {
+ return ol.events.listen(this.iconImage_, ol.events.EventType.CHANGE,
+ listener, thisArg);
+ * When rendering a feature with an icon style, the vector renderer will
+ * automatically call this method. However, you might want to call this
+ * method yourself for preloading or other purposes.
+ * @override
+ * @api
+ol.style.Icon.prototype.load = function() {
+ this.iconImage_.load();
+ * @override
+ol.style.Icon.prototype.unlistenImageChange = function(listener, thisArg) {
+ ol.events.unlisten(this.iconImage_, ol.events.EventType.CHANGE,
+goog.provide('ol.style.Text');
+goog.require('ol.style.Fill');
+ * @classdesc
+ * Set text style for vector features.
+ * @constructor
+ * @param {olx.style.TextOptions=} opt_options Options.
+ * @api
+ol.style.Text = function(opt_options) {
+ * @private
+ this.font_ = options.font;
+ * @private
+ * @type {number|undefined}
+ this.rotation_ = options.rotation;
+ * @private
+ * @type {boolean|undefined}
+ this.rotateWithView_ = options.rotateWithView;
+ * @private
+ this.scale_ = options.scale;
+ * @private
+ this.text_ = options.text;
+ * @private
+ this.textAlign_ = options.textAlign;
+ * @private
+ this.textBaseline_ = options.textBaseline;
+ * @private
+ * @type {ol.style.Fill}
+ this.fill_ = options.fill !== undefined ? options.fill :
+ new ol.style.Fill({color: ol.style.Text.DEFAULT_FILL_COLOR_});
+ * @private
+ * @type {ol.style.Stroke}
+ this.stroke_ = options.stroke !== undefined ? options.stroke : null;
+ * @private
+ * @type {number}
+ this.offsetX_ = options.offsetX !== undefined ? options.offsetX : 0;
+ * @private
+ * @type {number}
+ this.offsetY_ = options.offsetY !== undefined ? options.offsetY : 0;
+ * The default fill color to use if no fill was set at construction time; a
+ * blackish `#333`.
+ * @const {string}
+ * @private
+ol.style.Text.DEFAULT_FILL_COLOR_ = '#333';
+ * @return {ol.style.Text} The cloned style.
+ * @api
+ol.style.Text.prototype.clone = function() {
+ return new ol.style.Text({
+ font: this.getFont(),
+ rotateWithView: this.getRotateWithView(),
+ text: this.getText(),
+ textAlign: this.getTextAlign(),
+ textBaseline: this.getTextBaseline(),
+ fill: this.getFill() ? this.getFill().clone() : undefined,
+ stroke: this.getStroke() ? this.getStroke().clone() : undefined,
+ offsetX: this.getOffsetX(),
+ offsetY: this.getOffsetY()
+ * Get the font name.
+ * @return {string|undefined} Font.
+ * @api
+ol.style.Text.prototype.getFont = function() {
+ return this.font_;
+ * Get the x-offset for the text.
+ * @return {number} Horizontal text offset.
+ * @api
+ol.style.Text.prototype.getOffsetX = function() {
+ return this.offsetX_;
+ * Get the y-offset for the text.
+ * @return {number} Vertical text offset.
+ * @api
+ol.style.Text.prototype.getOffsetY = function() {
+ return this.offsetY_;
+ * Get the fill style for the text.
+ * @return {ol.style.Fill} Fill style.
+ * @api
+ol.style.Text.prototype.getFill = function() {
+ return this.fill_;
+ * Determine whether the text rotates with the map.
+ * @return {boolean|undefined} Rotate with map.
+ * @api
+ol.style.Text.prototype.getRotateWithView = function() {
+ return this.rotateWithView_;
+ * Get the text rotation.
+ * @return {number|undefined} Rotation.
+ * @api
+ol.style.Text.prototype.getRotation = function() {
+ return this.rotation_;
+ * Get the text scale.
+ * @return {number|undefined} Scale.
+ * @api
+ol.style.Text.prototype.getScale = function() {
+ return this.scale_;
+ * Get the stroke style for the text.
+ * @return {ol.style.Stroke} Stroke style.
+ * @api
+ol.style.Text.prototype.getStroke = function() {
+ return this.stroke_;
+ * Get the text to be rendered.
+ * @return {string|undefined} Text.
+ * @api
+ol.style.Text.prototype.getText = function() {
+ return this.text_;
+ * Get the text alignment.
+ * @return {string|undefined} Text align.
+ * @api
+ol.style.Text.prototype.getTextAlign = function() {
+ return this.textAlign_;
+ * Get the text baseline.
+ * @return {string|undefined} Text baseline.
+ * @api
+ol.style.Text.prototype.getTextBaseline = function() {
+ return this.textBaseline_;
+ * Set the font.
+ * @param {string|undefined} font Font.
+ * @api
+ol.style.Text.prototype.setFont = function(font) {
+ this.font_ = font;
+ * Set the x offset.
+ * @param {number} offsetX Horizontal text offset.
+ * @api
+ol.style.Text.prototype.setOffsetX = function(offsetX) {
+ this.offsetX_ = offsetX;
+ * Set the y offset.
+ * @param {number} offsetY Vertical text offset.
+ * @api
+ol.style.Text.prototype.setOffsetY = function(offsetY) {
+ this.offsetY_ = offsetY;
+ * Set the fill.
+ * @param {ol.style.Fill} fill Fill style.
+ * @api
+ol.style.Text.prototype.setFill = function(fill) {
+ this.fill_ = fill;
+ * Set the rotation.
+ * @param {number|undefined} rotation Rotation.
+ * @api
+ol.style.Text.prototype.setRotation = function(rotation) {
+ this.rotation_ = rotation;
+ * Set the scale.
+ * @param {number|undefined} scale Scale.
+ * @api
+ol.style.Text.prototype.setScale = function(scale) {
+ this.scale_ = scale;
+ * Set the stroke.
+ * @param {ol.style.Stroke} stroke Stroke style.
+ * @api
+ol.style.Text.prototype.setStroke = function(stroke) {
+ this.stroke_ = stroke;
+ * Set the text.
+ * @param {string|undefined} text Text.
+ * @api
+ol.style.Text.prototype.setText = function(text) {
+ this.text_ = text;
+ * Set the text alignment.
+ * @param {string|undefined} textAlign Text align.
+ * @api
+ol.style.Text.prototype.setTextAlign = function(textAlign) {
+ this.textAlign_ = textAlign;
+ * Set the text baseline.
+ * @param {string|undefined} textBaseline Text baseline.
+ * @api
+ol.style.Text.prototype.setTextBaseline = function(textBaseline) {
+ this.textBaseline_ = textBaseline;
+// FIXME http://earth.google.com/kml/1.0 namespace?
+// FIXME why does node.getAttribute return an unknown type?
+// FIXME serialize arbitrary feature properties
+// FIXME don't parse style if extractStyles is false
+goog.provide('ol.format.KML');
+goog.require('ol.array');
+goog.require('ol.format.XMLFeature');
+goog.require('ol.format.XSD');
+goog.require('ol.geom.GeometryCollection');
+goog.require('ol.geom.GeometryType');
+goog.require('ol.geom.MultiLineString');
+goog.require('ol.geom.MultiPoint');
+goog.require('ol.geom.MultiPolygon');
+goog.require('ol.geom.Point');
+goog.require('ol.geom.Polygon');
+goog.require('ol.math');
+goog.require('ol.style.Icon');
+goog.require('ol.style.Stroke');
+goog.require('ol.style.Style');
+goog.require('ol.style.Text');
+goog.require('ol.xml');
+ * @classdesc
+ * Feature format for reading and writing data in the KML format.
+ * Note that the KML format uses the URL() constructor. Older browsers such as IE
+ * which do not support this will need a URL polyfill to be loaded before use.
+ * @constructor
+ * @extends {ol.format.XMLFeature}
+ * @param {olx.format.KMLOptions=} opt_options Options.
+ * @api
+ol.format.KML = function(opt_options) {
+ ol.format.XMLFeature.call(this);
+ if (!ol.format.KML.DEFAULT_STYLE_ARRAY_) {
+ ol.format.KML.createStyleDefaults_();
+ * @inheritDoc
+ * @private
+ * @type {Array.<ol.style.Style>}
+ this.defaultStyle_ = options.defaultStyle ?
+ options.defaultStyle : ol.format.KML.DEFAULT_STYLE_ARRAY_;
+ * @private
+ * @type {boolean}
+ this.extractStyles_ = options.extractStyles !== undefined ?
+ options.extractStyles : true;
+ * @private
+ * @type {boolean}
+ this.writeStyles_ = options.writeStyles !== undefined ?
+ options.writeStyles : true;
+ * @private
+ * @type {Object.<string, (Array.<ol.style.Style>|string)>}
+ this.sharedStyles_ = {};
+ * @private
+ * @type {boolean}
+ this.showPointNames_ = options.showPointNames !== undefined ?
+ options.showPointNames : true;
+ol.inherits(ol.format.KML, ol.format.XMLFeature);
+ * @const
+ * @private
+ol.format.KML.GX_NAMESPACE_URIS_ = [
+ 'http://www.google.com/kml/ext/2.2'
+ * @const
+ * @private
+ol.format.KML.NAMESPACE_URIS_ = [
+ null,
+ 'http://earth.google.com/kml/2.0',
+ 'http://earth.google.com/kml/2.1',
+ 'http://earth.google.com/kml/2.2',
+ 'http://www.opengis.net/kml/2.2'
+ * @const
+ * @type {string}
+ * @private
+ol.format.KML.SCHEMA_LOCATION_ = 'http://www.opengis.net/kml/2.2 ' +
+ 'https://developers.google.com/kml/schema/kml22gx.xsd';
+ * @return {Array.<ol.style.Style>} Default style.
+ * @private
+ol.format.KML.createStyleDefaults_ = function() {
+ * @const
+ * @private
+ ol.format.KML.DEFAULT_COLOR_ = [255, 255, 255, 1];
+ * @const
+ * @private
+ ol.format.KML.DEFAULT_FILL_STYLE_ = new ol.style.Fill({
+ color: ol.format.KML.DEFAULT_COLOR_
+ * @const
+ * @type {ol.Size}
+ * @private
+ ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_ = [20, 2]; // FIXME maybe [8, 32] ?
+ * @const
+ * @private
+ ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_X_UNITS_ =
+ ol.style.IconAnchorUnits.PIXELS;
+ * @const
+ * @private
+ ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_Y_UNITS_ =
+ * @const
+ * @type {ol.Size}
+ * @private
+ ol.format.KML.DEFAULT_IMAGE_STYLE_SIZE_ = [64, 64];
+ * @const
+ * @type {string}
+ * @private
+ ol.format.KML.DEFAULT_IMAGE_STYLE_SRC_ =
+ 'https://maps.google.com/mapfiles/kml/pushpin/ylw-pushpin.png';
+ * @const
+ * @type {number}
+ * @private
+ ol.format.KML.DEFAULT_IMAGE_SCALE_MULTIPLIER_ = 0.5;
+ * @const
+ * @type {ol.style.Image}
+ * @private
+ ol.format.KML.DEFAULT_IMAGE_STYLE_ = new ol.style.Icon({
+ anchor: ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_,
+ anchorOrigin: ol.style.IconOrigin.BOTTOM_LEFT,
+ anchorXUnits: ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_X_UNITS_,
+ anchorYUnits: ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_Y_UNITS_,
+ crossOrigin: 'anonymous',
+ rotation: 0,
+ scale: ol.format.KML.DEFAULT_IMAGE_SCALE_MULTIPLIER_,
+ size: ol.format.KML.DEFAULT_IMAGE_STYLE_SIZE_,
+ src: ol.format.KML.DEFAULT_IMAGE_STYLE_SRC_
+ * @const
+ * @type {string}
+ * @private
+ ol.format.KML.DEFAULT_NO_IMAGE_STYLE_ = 'NO_IMAGE';
+ * @const
+ * @private
+ ol.format.KML.DEFAULT_STROKE_STYLE_ = new ol.style.Stroke({
+ color: ol.format.KML.DEFAULT_COLOR_,
+ width: 1
+ * @const
+ * @private
+ ol.format.KML.DEFAULT_TEXT_STROKE_STYLE_ = new ol.style.Stroke({
+ color: [51, 51, 51, 1],
+ width: 2
+ * @const
+ * @type {ol.style.Text}
+ * @private
+ ol.format.KML.DEFAULT_TEXT_STYLE_ = new ol.style.Text({
+ font: 'bold 16px Helvetica',
+ fill: ol.format.KML.DEFAULT_FILL_STYLE_,
+ stroke: ol.format.KML.DEFAULT_TEXT_STROKE_STYLE_,
+ scale: 0.8
+ * @const
+ * @type {ol.style.Style}
+ * @private
+ ol.format.KML.DEFAULT_STYLE_ = new ol.style.Style({
+ image: ol.format.KML.DEFAULT_IMAGE_STYLE_,
+ text: ol.format.KML.DEFAULT_TEXT_STYLE_,
+ stroke: ol.format.KML.DEFAULT_STROKE_STYLE_,
+ zIndex: 0
+ * @const
+ * @private
+ ol.format.KML.DEFAULT_STYLE_ARRAY_ = [ol.format.KML.DEFAULT_STYLE_];
+ return ol.format.KML.DEFAULT_STYLE_ARRAY_;
+ * @const
+ * @type {Object.<string, ol.style.IconAnchorUnits>}
+ * @private
+ol.format.KML.ICON_ANCHOR_UNITS_MAP_ = {
+ 'fraction': ol.style.IconAnchorUnits.FRACTION,
+ 'pixels': ol.style.IconAnchorUnits.PIXELS
+ * @param {ol.style.Style|undefined} foundStyle Style.
+ * @param {string} name Name.
+ * @return {ol.style.Style} style Style.
+ * @private
+ol.format.KML.createNameStyleFunction_ = function(foundStyle, name) {
+ var textStyle = null;
+ var textOffset = [0, 0];
+ var textAlign = 'start';
+ if (foundStyle.getImage()) {
+ var imageSize = foundStyle.getImage().getImageSize();
+ if (imageSize === null) {
+ imageSize = ol.format.KML.DEFAULT_IMAGE_STYLE_SIZE_;
+ if (imageSize.length == 2) {
+ var imageScale = foundStyle.getImage().getScale();
+ // Offset the label to be centered to the right of the icon, if there is
+ // one.
+ textOffset[0] = imageScale * imageSize[0] / 2;
+ textOffset[1] = -imageScale * imageSize[1] / 2;
+ textAlign = 'left';
+ if (foundStyle.getText() !== null) {
+ // clone the text style, customizing it with name, alignments and offset.
+ // Note that kml does not support many text options that OpenLayers does (rotation, textBaseline).
+ var foundText = foundStyle.getText();
+ textStyle = foundText.clone();
+ textStyle.setFont(foundText.getFont() || ol.format.KML.DEFAULT_TEXT_STYLE_.getFont());
+ textStyle.setScale(foundText.getScale() || ol.format.KML.DEFAULT_TEXT_STYLE_.getScale());
+ textStyle.setFill(foundText.getFill() || ol.format.KML.DEFAULT_TEXT_STYLE_.getFill());
+ textStyle.setStroke(foundText.getStroke() || ol.format.KML.DEFAULT_TEXT_STROKE_STYLE_);
+ } else {
+ textStyle = ol.format.KML.DEFAULT_TEXT_STYLE_.clone();
+ textStyle.setText(name);
+ textStyle.setOffsetX(textOffset[0]);
+ textStyle.setOffsetY(textOffset[1]);
+ textStyle.setTextAlign(textAlign);
+ var nameStyle = new ol.style.Style({
+ text: textStyle
+ return nameStyle;
+ * @param {Array.<ol.style.Style>|undefined} style Style.
+ * @param {string} styleUrl Style URL.
+ * @param {Array.<ol.style.Style>} defaultStyle Default style.
+ * @param {Object.<string, (Array.<ol.style.Style>|string)>} sharedStyles Shared
+ * styles.
+ * @param {boolean|undefined} showPointNames true to show names for point
+ * placemarks.
+ * @return {ol.FeatureStyleFunction} Feature style function.
+ * @private
+ol.format.KML.createFeatureStyleFunction_ = function(style, styleUrl,
+ defaultStyle, sharedStyles, showPointNames) {
+ return (
+ * @param {number} resolution Resolution.
+ * @return {Array.<ol.style.Style>} Style.
+ * @this {ol.Feature}
+ function(resolution) {
+ var drawName = showPointNames;
+ /** @type {ol.style.Style|undefined} */
+ var nameStyle;
+ var name = '';
+ if (drawName) {
+ if (this.getGeometry()) {
+ drawName = (this.getGeometry().getType() ===
+ ol.geom.GeometryType.POINT);
+ if (drawName) {
+ name = /** @type {string} */ (this.get('name'));
+ drawName = drawName && name;
+ if (style) {
+ if (drawName) {
+ nameStyle = ol.format.KML.createNameStyleFunction_(style[0],
+ name);
+ return style.concat(nameStyle);
+ return style;
+ if (styleUrl) {
+ var foundStyle = ol.format.KML.findStyle_(styleUrl, defaultStyle,
+ sharedStyles);
+ if (drawName) {
+ nameStyle = ol.format.KML.createNameStyleFunction_(foundStyle[0],
+ name);
+ return foundStyle.concat(nameStyle);
+ return foundStyle;
+ if (drawName) {
+ nameStyle = ol.format.KML.createNameStyleFunction_(defaultStyle[0],
+ name);
+ return defaultStyle.concat(nameStyle);
+ return defaultStyle;
+ * @param {Array.<ol.style.Style>|string|undefined} styleValue Style value.
+ * Shared styles.
+ * @private
+ol.format.KML.findStyle_ = function(styleValue, defaultStyle, sharedStyles) {
+ if (Array.isArray(styleValue)) {
+ return styleValue;
+ } else if (typeof styleValue === 'string') {
+ // KML files in the wild occasionally forget the leading `#` on styleUrls
+ // defined in the same document. Add a leading `#` if it enables to find
+ // a style.
+ if (!(styleValue in sharedStyles) && ('#' + styleValue in sharedStyles)) {
+ styleValue = '#' + styleValue;
+ return ol.format.KML.findStyle_(
+ sharedStyles[styleValue], defaultStyle, sharedStyles);
+ } else {
+ * @private
+ * @return {ol.Color|undefined} Color.
+ol.format.KML.readColor_ = function(node) {
+ var s = ol.xml.getAllTextContent(node, false);
+ // The KML specification states that colors should not include a leading `#`
+ // but we tolerate them.
+ var m = /^\s*#?\s*([0-9A-Fa-f]{8})\s*$/.exec(s);
+ if (m) {
+ var hexColor = m[1];
+ return [
+ parseInt(hexColor.substr(6, 2), 16),
+ parseInt(hexColor.substr(4, 2), 16),
+ parseInt(hexColor.substr(2, 2), 16),
+ parseInt(hexColor.substr(0, 2), 16) / 255
+ } else {
+ return undefined;
+ * @private
+ * @return {Array.<number>|undefined} Flat coordinates.
+ol.format.KML.readFlatCoordinates_ = function(node) {
+ var flatCoordinates = [];
+ // The KML specification states that coordinate tuples should not include
+ // spaces, but we tolerate them.
+ var re =
+ /^\s*([+\-]?\d*\.?\d+(?:e[+\-]?\d+)?)\s*,\s*([+\-]?\d*\.?\d+(?:e[+\-]?\d+)?)(?:\s*,\s*([+\-]?\d*\.?\d+(?:e[+\-]?\d+)?))?\s*/i;
+ var m;
+ while ((m = re.exec(s))) {
+ var x = parseFloat(m[1]);
+ var y = parseFloat(m[2]);
+ var z = m[3] ? parseFloat(m[3]) : 0;
+ flatCoordinates.push(x, y, z);
+ s = s.substr(m[0].length);
+ if (s !== '') {
+ return undefined;
+ return flatCoordinates;
+ * @private
+ * @return {string} URI.
+ol.format.KML.readURI_ = function(node) {
+ var s = ol.xml.getAllTextContent(node, false).trim();
+ if (node.baseURI) {
+ var url = new URL(s, node.baseURI);
+ return url.href;
+ } else {
+ return s;
+ * @private
+ * @return {ol.KMLVec2_} Vec2.
+ol.format.KML.readVec2_ = function(node) {
+ var xunits = node.getAttribute('xunits');
+ var yunits = node.getAttribute('yunits');
+ return {
+ x: parseFloat(node.getAttribute('x')),
+ xunits: ol.format.KML.ICON_ANCHOR_UNITS_MAP_[xunits],
+ y: parseFloat(node.getAttribute('y')),
+ yunits: ol.format.KML.ICON_ANCHOR_UNITS_MAP_[yunits]
+ * @private
+ol.format.KML.readScale_ = function(node) {
+ return ol.format.XSD.readDecimal(node);
+ * @private
+ * @return {Array.<ol.style.Style>|string|undefined} StyleMap.
+ol.format.KML.readStyleMapValue_ = function(node, objectStack) {
+ return ol.xml.pushParseAndPop(undefined,
+ ol.format.KML.STYLE_MAP_PARSERS_, node, objectStack);
+ * @private
+ol.format.KML.IconStyleParser_ = function(node, objectStack) {
+ // FIXME refreshMode
+ // FIXME refreshInterval
+ // FIXME viewRefreshTime
+ // FIXME viewBoundScale
+ // FIXME viewFormat
+ // FIXME httpQuery
+ var object = ol.xml.pushParseAndPop(
+ {}, ol.format.KML.ICON_STYLE_PARSERS_, node, objectStack);
+ if (!object) {
+ return;
+ var styleObject = /** @type {Object} */ (objectStack[objectStack.length - 1]);
+ var IconObject = 'Icon' in object ? object['Icon'] : {};
+ var drawIcon = (!('Icon' in object) || Object.keys(IconObject).length > 0);
+ var src;
+ var href = /** @type {string|undefined} */
+ (IconObject['href']);
+ if (href) {
+ src = href;
+ } else if (drawIcon) {
+ src = ol.format.KML.DEFAULT_IMAGE_STYLE_SRC_;
+ var anchor, anchorXUnits, anchorYUnits;
+ var hotSpot = /** @type {ol.KMLVec2_|undefined} */
+ (object['hotSpot']);
+ if (hotSpot) {
+ anchor = [hotSpot.x, hotSpot.y];
+ anchorXUnits = hotSpot.xunits;
+ anchorYUnits = hotSpot.yunits;
+ } else if (src === ol.format.KML.DEFAULT_IMAGE_STYLE_SRC_) {
+ anchor = ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_;
+ anchorXUnits = ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_X_UNITS_;
+ anchorYUnits = ol.format.KML.DEFAULT_IMAGE_STYLE_ANCHOR_Y_UNITS_;
+ } else if (/^http:\/\/maps\.(?:google|gstatic)\.com\//.test(src)) {
+ anchor = [0.5, 0];
+ anchorXUnits = ol.style.IconAnchorUnits.FRACTION;
+ anchorYUnits = ol.style.IconAnchorUnits.FRACTION;
+ var offset;
+ var x = /** @type {number|undefined} */
+ (IconObject['x']);
+ var y = /** @type {number|undefined} */
+ (IconObject['y']);
+ if (x !== undefined && y !== undefined) {
+ offset = [x, y];
+ var size;
+ var w = /** @type {number|undefined} */
+ (IconObject['w']);
+ var h = /** @type {number|undefined} */
+ (IconObject['h']);
+ if (w !== undefined && h !== undefined) {
+ size = [w, h];
+ var rotation;
+ var heading = /** @type {number} */
+ (object['heading']);
+ if (heading !== undefined) {
+ rotation = ol.math.toRadians(heading);
+ var scale = /** @type {number|undefined} */
+ (object['scale']);
+ if (drawIcon) {
+ if (src == ol.format.KML.DEFAULT_IMAGE_STYLE_SRC_) {
+ size = ol.format.KML.DEFAULT_IMAGE_STYLE_SIZE_;
+ if (scale === undefined) {
+ scale = ol.format.KML.DEFAULT_IMAGE_SCALE_MULTIPLIER_;
+ var imageStyle = new ol.style.Icon({
+ anchor: anchor,
+ anchorXUnits: anchorXUnits,
+ anchorYUnits: anchorYUnits,
+ crossOrigin: 'anonymous', // FIXME should this be configurable?
+ offset: offset,
+ offsetOrigin: ol.style.IconOrigin.BOTTOM_LEFT,
+ scale: scale,
+ size: size,
+ src: src
+ styleObject['imageStyle'] = imageStyle;
+ } else {
+ // handle the case when we explicitly want to draw no icon.
+ styleObject['imageStyle'] = ol.format.KML.DEFAULT_NO_IMAGE_STYLE_;
+ * @private
+ol.format.KML.LabelStyleParser_ = function(node, objectStack) {
+ // FIXME colorMode
+ {}, ol.format.KML.LABEL_STYLE_PARSERS_, node, objectStack);
+ if (!object) {
+ return;
+ var styleObject = objectStack[objectStack.length - 1];
+ var textStyle = new ol.style.Text({
+ fill: new ol.style.Fill({
+ color: /** @type {ol.Color} */
+ ('color' in object ? object['color'] : ol.format.KML.DEFAULT_COLOR_)
+ scale: /** @type {number|undefined} */
+ (object['scale'])
+ styleObject['textStyle'] = textStyle;
+ * @private
+ol.format.KML.LineStyleParser_ = function(node, objectStack) {
+ // FIXME gx:outerColor
+ // FIXME gx:outerWidth
+ // FIXME gx:physicalWidth
+ // FIXME gx:labelVisibility
+ {}, ol.format.KML.LINE_STYLE_PARSERS_, node, objectStack);
+ if (!object) {
+ return;
+ var strokeStyle = new ol.style.Stroke({
+ ('color' in object ? object['color'] : ol.format.KML.DEFAULT_COLOR_),
+ width: /** @type {number} */ ('width' in object ? object['width'] : 1)
+ styleObject['strokeStyle'] = strokeStyle;
+ * @private
+ol.format.KML.PolyStyleParser_ = function(node, objectStack) {
+ {}, ol.format.KML.POLY_STYLE_PARSERS_, node, objectStack);
+ if (!object) {
+ return;
+ var fillStyle = new ol.style.Fill({
+ styleObject['fillStyle'] = fillStyle;
+ var fill = /** @type {boolean|undefined} */ (object['fill']);
+ if (fill !== undefined) {
+ styleObject['fill'] = fill;
+ var outline =
+ /** @type {boolean|undefined} */ (object['outline']);
+ if (outline !== undefined) {
+ styleObject['outline'] = outline;
+ * @private
+ * @return {Array.<number>} LinearRing flat coordinates.
+ol.format.KML.readFlatLinearRing_ = function(node, objectStack) {
+ return ol.xml.pushParseAndPop(null,
+ ol.format.KML.FLAT_LINEAR_RING_PARSERS_, node, objectStack);
+ * @private
+ol.format.KML.gxCoordParser_ = function(node, objectStack) {
+ var gxTrackObject = /** @type {ol.KMLGxTrackObject_} */
+ (objectStack[objectStack.length - 1]);
+ var flatCoordinates = gxTrackObject.flatCoordinates;
+ var re =
+ /^\s*([+\-]?\d+(?:\.\d*)?(?:e[+\-]?\d*)?)\s+([+\-]?\d+(?:\.\d*)?(?:e[+\-]?\d*)?)\s+([+\-]?\d+(?:\.\d*)?(?:e[+\-]?\d*)?)\s*$/i;
+ var m = re.exec(s);
+ if (m) {
+ var z = parseFloat(m[3]);
+ flatCoordinates.push(x, y, z, 0);
+ } else {
+ flatCoordinates.push(0, 0, 0, 0);
+ * @private
+ * @return {ol.geom.MultiLineString|undefined} MultiLineString.
+ol.format.KML.readGxMultiTrack_ = function(node, objectStack) {
+ var lineStrings = ol.xml.pushParseAndPop([],
+ ol.format.KML.GX_MULTITRACK_GEOMETRY_PARSERS_, node, objectStack);
+ if (!lineStrings) {
+ return undefined;
+ var multiLineString = new ol.geom.MultiLineString(null);
+ multiLineString.setLineStrings(lineStrings);
+ return multiLineString;
+ * @private
+ * @return {ol.geom.LineString|undefined} LineString.
+ol.format.KML.readGxTrack_ = function(node, objectStack) {
+ var gxTrackObject = ol.xml.pushParseAndPop(
+ /** @type {ol.KMLGxTrackObject_} */ ({
+ flatCoordinates: [],
+ whens: []
+ }), ol.format.KML.GX_TRACK_PARSERS_, node, objectStack);
+ if (!gxTrackObject) {
+ return undefined;
+ var whens = gxTrackObject.whens;
+ var i, ii;
+ for (i = 0, ii = Math.min(flatCoordinates.length, whens.length); i < ii;
+ ++i) {
+ flatCoordinates[4 * i + 3] = whens[i];
+ lineString.setFlatCoordinates(ol.geom.GeometryLayout.XYZM, flatCoordinates);
+ return lineString;
+ * @private
+ * @return {Object} Icon object.
+ol.format.KML.readIcon_ = function(node, objectStack) {
+ var iconObject = ol.xml.pushParseAndPop(
+ {}, ol.format.KML.ICON_PARSERS_, node, objectStack);
+ if (iconObject) {
+ return iconObject;
+ } else {
+ return null;
+ * @private
+ * @return {Array.<number>} Flat coordinates.
+ol.format.KML.readFlatCoordinatesFromNode_ = function(node, objectStack) {
+ ol.format.KML.GEOMETRY_FLAT_COORDINATES_PARSERS_, node, objectStack);
+ * @private
+ol.format.KML.readLineString_ = function(node, objectStack) {
+ var properties = ol.xml.pushParseAndPop({},
+ ol.format.KML.EXTRUDE_AND_ALTITUDE_MODE_PARSERS_, node,
+ objectStack);
+ ol.format.KML.readFlatCoordinatesFromNode_(node, objectStack);
+ if (flatCoordinates) {
+ lineString.setFlatCoordinates(ol.geom.GeometryLayout.XYZ, flatCoordinates);
+ lineString.setProperties(properties);
+ } else {
+ return undefined;
+ * @private
+ * @return {ol.geom.Polygon|undefined} Polygon.
+ol.format.KML.readLinearRing_ = function(node, objectStack) {
+ objectStack);
+ var polygon = new ol.geom.Polygon(null);
+ polygon.setFlatCoordinates(ol.geom.GeometryLayout.XYZ, flatCoordinates,
+ [flatCoordinates.length]);
+ polygon.setProperties(properties);
+ return polygon;
+ } else {
+ return undefined;
+ * @private
+ol.format.KML.readMultiGeometry_ = function(node, objectStack) {
+ var geometries = ol.xml.pushParseAndPop([],
+ ol.format.KML.MULTI_GEOMETRY_PARSERS_, node, objectStack);
+ if (!geometries) {
+ return null;
+ if (geometries.length === 0) {
+ return new ol.geom.GeometryCollection(geometries);
+ /** @type {ol.geom.Geometry} */
+ var multiGeometry;
+ var homogeneous = true;
+ var type = geometries[0].getType();
+ var geometry, i, ii;
+ for (i = 1, ii = geometries.length; i < ii; ++i) {
+ geometry = geometries[i];
+ if (geometry.getType() != type) {
+ homogeneous = false;
+ break;
+ if (homogeneous) {
+ var layout;
+ var flatCoordinates;
+ if (type == ol.geom.GeometryType.POINT) {
+ var point = geometries[0];
+ layout = point.getLayout();
+ flatCoordinates = point.getFlatCoordinates();
+ ol.array.extend(flatCoordinates, geometry.getFlatCoordinates());
+ multiGeometry = new ol.geom.MultiPoint(null);
+ multiGeometry.setFlatCoordinates(layout, flatCoordinates);
+ ol.format.KML.setCommonGeometryProperties_(multiGeometry, geometries);
+ } else if (type == ol.geom.GeometryType.LINE_STRING) {
+ multiGeometry = new ol.geom.MultiLineString(null);
+ multiGeometry.setLineStrings(geometries);
+ } else if (type == ol.geom.GeometryType.POLYGON) {
+ multiGeometry = new ol.geom.MultiPolygon(null);
+ multiGeometry.setPolygons(geometries);
+ } else if (type == ol.geom.GeometryType.GEOMETRY_COLLECTION) {
+ multiGeometry = new ol.geom.GeometryCollection(geometries);
+ } else {
+ ol.asserts.assert(false, 37); // Unknown geometry type found
+ } else {
+ return /** @type {ol.geom.Geometry} */ (multiGeometry);
+ * @private
+ * @return {ol.geom.Point|undefined} Point.
+ol.format.KML.readPoint_ = function(node, objectStack) {
+ objectStack);
+ var point = new ol.geom.Point(null);
+ point.setFlatCoordinates(ol.geom.GeometryLayout.XYZ, flatCoordinates);
+ point.setProperties(properties);
+ return point;
+ } else {
+ return undefined;
+ * @private
+ol.format.KML.readPolygon_ = function(node, objectStack) {
+ var properties = ol.xml.pushParseAndPop(/** @type {Object<string,*>} */ ({}),
+ objectStack);
+ var flatLinearRings = ol.xml.pushParseAndPop([null],
+ ol.format.KML.FLAT_LINEAR_RINGS_PARSERS_, node, objectStack);
+ if (flatLinearRings && flatLinearRings[0]) {
+ var flatCoordinates = flatLinearRings[0];
+ var ends = [flatCoordinates.length];
+ var i, ii;
+ for (i = 1, ii = flatLinearRings.length; i < ii; ++i) {
+ ol.array.extend(flatCoordinates, flatLinearRings[i]);
+ ends.push(flatCoordinates.length);
+ ol.geom.GeometryLayout.XYZ, flatCoordinates, ends);
+ return polygon;
+ } else {
+ return undefined;
+ * @private
+ol.format.KML.readStyle_ = function(node, objectStack) {
+ var styleObject = ol.xml.pushParseAndPop(
+ {}, ol.format.KML.STYLE_PARSERS_, node, objectStack);
+ if (!styleObject) {
+ return null;
+ var fillStyle = /** @type {ol.style.Fill} */
+ ('fillStyle' in styleObject ?
+ styleObject['fillStyle'] : ol.format.KML.DEFAULT_FILL_STYLE_);
+ var fill = /** @type {boolean|undefined} */ (styleObject['fill']);
+ if (fill !== undefined && !fill) {
+ fillStyle = null;
+ var imageStyle = /** @type {ol.style.Image} */
+ ('imageStyle' in styleObject ?
+ styleObject['imageStyle'] : ol.format.KML.DEFAULT_IMAGE_STYLE_);
+ if (imageStyle == ol.format.KML.DEFAULT_NO_IMAGE_STYLE_) {
+ imageStyle = undefined;
+ var textStyle = /** @type {ol.style.Text} */
+ ('textStyle' in styleObject ?
+ styleObject['textStyle'] : ol.format.KML.DEFAULT_TEXT_STYLE_);
+ var strokeStyle = /** @type {ol.style.Stroke} */
+ ('strokeStyle' in styleObject ?
+ styleObject['strokeStyle'] : ol.format.KML.DEFAULT_STROKE_STYLE_);
+ var outline = /** @type {boolean|undefined} */
+ (styleObject['outline']);
+ if (outline !== undefined && !outline) {
+ strokeStyle = null;
+ return [new ol.style.Style({
+ fill: fillStyle,
+ image: imageStyle,
+ stroke: strokeStyle,
+ text: textStyle,
+ zIndex: undefined // FIXME
+ * Reads an array of geometries and creates arrays for common geometry
+ * properties. Then sets them to the multi geometry.
+ * @param {ol.geom.MultiPoint|ol.geom.MultiLineString|ol.geom.MultiPolygon}
+ * multiGeometry A multi-geometry.
+ * @param {Array.<ol.geom.Geometry>} geometries List of geometries.
+ * @private
+ol.format.KML.setCommonGeometryProperties_ = function(multiGeometry,
+ geometries) {
+ var ii = geometries.length;
+ var extrudes = new Array(geometries.length);
+ var altitudeModes = new Array(geometries.length);
+ var geometry, i, hasExtrude, hasAltitudeMode;
+ hasExtrude = hasAltitudeMode = false;
+ for (i = 0; i < ii; ++i) {
+ extrudes[i] = geometry.get('extrude');
+ altitudeModes[i] = geometry.get('altitudeMode');
+ hasExtrude = hasExtrude || extrudes[i] !== undefined;
+ hasAltitudeMode = hasAltitudeMode || altitudeModes[i];
+ if (hasExtrude) {
+ multiGeometry.set('extrude', extrudes);
+ if (hasAltitudeMode) {
+ multiGeometry.set('altitudeMode', altitudeModes);
+ * @private
+ol.format.KML.DataParser_ = function(node, objectStack) {
+ var name = node.getAttribute('name');
+ ol.xml.parseNode(ol.format.KML.DATA_PARSERS_, node, objectStack);
+ var featureObject =
+ /** @type {Object} */ (objectStack[objectStack.length - 1]);
+ if (name !== null) {
+ featureObject[name] = featureObject.value;
+ } else if (featureObject.displayName !== null) {
+ featureObject[featureObject.displayName] = featureObject.value;
+ * @private
+ol.format.KML.ExtendedDataParser_ = function(node, objectStack) {
+ ol.xml.parseNode(ol.format.KML.EXTENDED_DATA_PARSERS_, node, objectStack);
+ * @private
+ol.format.KML.RegionParser_ = function(node, objectStack) {
+ ol.xml.parseNode(ol.format.KML.REGION_PARSERS_, node, objectStack);
+ * @private
+ol.format.KML.PairDataParser_ = function(node, objectStack) {
+ var pairObject = ol.xml.pushParseAndPop(
+ {}, ol.format.KML.PAIR_PARSERS_, node, objectStack);
+ if (!pairObject) {
+ return;
+ var key = /** @type {string|undefined} */
+ (pairObject['key']);
+ if (key && key == 'normal') {
+ var styleUrl = /** @type {string|undefined} */
+ (pairObject['styleUrl']);
+ if (styleUrl) {
+ objectStack[objectStack.length - 1] = styleUrl;
+ var Style = /** @type {ol.style.Style} */
+ (pairObject['Style']);
+ if (Style) {
+ objectStack[objectStack.length - 1] = Style;
+ * @private
+ol.format.KML.PlacemarkStyleMapParser_ = function(node, objectStack) {
+ var styleMapValue = ol.format.KML.readStyleMapValue_(node, objectStack);
+ if (!styleMapValue) {
+ return;
+ var placemarkObject = objectStack[objectStack.length - 1];
+ if (Array.isArray(styleMapValue)) {
+ placemarkObject['Style'] = styleMapValue;
+ } else if (typeof styleMapValue === 'string') {
+ placemarkObject['styleUrl'] = styleMapValue;
+ } else {
+ ol.asserts.assert(false, 38); // `styleMapValue` has an unknown type
+ * @private
+ol.format.KML.SchemaDataParser_ = function(node, objectStack) {
+ ol.xml.parseNode(ol.format.KML.SCHEMA_DATA_PARSERS_, node, objectStack);
+ * @private
+ol.format.KML.SimpleDataParser_ = function(node, objectStack) {
+ var data = ol.format.XSD.readString(node);
+ featureObject[name] = data;
+ * @private
+ol.format.KML.LatLonAltBoxParser_ = function(node, objectStack) {
+ var object = ol.xml.pushParseAndPop({}, ol.format.KML.LAT_LON_ALT_BOX_PARSERS_, node, objectStack);
+ if (!object) {
+ return;
+ var regionObject = /** @type {Object} */ (objectStack[objectStack.length - 1]);
+ var extent = [
+ parseFloat(object['west']),
+ parseFloat(object['south']),
+ parseFloat(object['east']),
+ parseFloat(object['north'])
+ regionObject['extent'] = extent;
+ regionObject['altitudeMode'] = object['altitudeMode'];
+ regionObject['minAltitude'] = parseFloat(object['minAltitude']);
+ regionObject['maxAltitude'] = parseFloat(object['maxAltitude']);
+ * @private
+ol.format.KML.LodParser_ = function(node, objectStack) {
+ var object = ol.xml.pushParseAndPop({}, ol.format.KML.LOD_PARSERS_, node, objectStack);
+ if (!object) {
+ return;
+ var lodObject = /** @type {Object} */ (objectStack[objectStack.length - 1]);
+ lodObject['minLodPixels'] = parseFloat(object['minLodPixels']);
+ lodObject['maxLodPixels'] = parseFloat(object['maxLodPixels']);
+ lodObject['minFadeExtent'] = parseFloat(object['minFadeExtent']);
+ lodObject['maxFadeExtent'] = parseFloat(object['maxFadeExtent']);
+ * @private
+ol.format.KML.innerBoundaryIsParser_ = function(node, objectStack) {
+ /** @type {Array.<number>|undefined} */
+ var flatLinearRing = ol.xml.pushParseAndPop(undefined,
+ ol.format.KML.INNER_BOUNDARY_IS_PARSERS_, node, objectStack);
+ if (flatLinearRing) {
+ var flatLinearRings = /** @type {Array.<Array.<number>>} */
+ flatLinearRings.push(flatLinearRing);
+ * @param {Node} node Node.
+ * @private
+ol.format.KML.outerBoundaryIsParser_ = function(node, objectStack) {
+ ol.format.KML.OUTER_BOUNDARY_IS_PARSERS_, node, objectStack);
+ flatLinearRings[0] = flatLinearRing;
+ * @private
+ol.format.KML.LinkParser_ = function(node, objectStack) {
+ ol.xml.parseNode(ol.format.KML.LINK_PARSERS_, node, objectStack);
+ * @private
+ol.format.KML.whenParser_ = function(node, objectStack) {
+ var when = Date.parse(s);
+ whens.push(isNaN(when) ? 0 : when);
+ * @const
+ * @type {Object.<string, Object.<string, ol.XmlParser>>}
+ * @private
+ol.format.KML.DATA_PARSERS_ = ol.xml.makeStructureNS(
+ ol.format.KML.NAMESPACE_URIS_, {
+ 'displayName': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'value': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString)
+ * @const
+ * @private
+ol.format.KML.EXTENDED_DATA_PARSERS_ = ol.xml.makeStructureNS(
+ 'Data': ol.format.KML.DataParser_,
+ 'SchemaData': ol.format.KML.SchemaDataParser_
+ * @const
+ * @private
+ol.format.KML.REGION_PARSERS_ = ol.xml.makeStructureNS(
+ 'LatLonAltBox': ol.format.KML.LatLonAltBoxParser_,
+ 'Lod': ol.format.KML.LodParser_
+ * @const
+ * @private
+ol.format.KML.LAT_LON_ALT_BOX_PARSERS_ = ol.xml.makeStructureNS(
+ 'altitudeMode': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'minAltitude': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'maxAltitude': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'north': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'south': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'east': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'west': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal)
+ * @const
+ * @private
+ol.format.KML.LOD_PARSERS_ = ol.xml.makeStructureNS(
+ 'minLodPixels': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'maxLodPixels': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'minFadeExtent': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'maxFadeExtent': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal)
+ * @const
+ * @private
+ol.format.KML.EXTRUDE_AND_ALTITUDE_MODE_PARSERS_ = ol.xml.makeStructureNS(
+ 'extrude': ol.xml.makeObjectPropertySetter(ol.format.XSD.readBoolean),
+ * @const
+ * @private
+ol.format.KML.FLAT_LINEAR_RING_PARSERS_ = ol.xml.makeStructureNS(
+ 'coordinates': ol.xml.makeReplacer(ol.format.KML.readFlatCoordinates_)
+ * @const
+ * @private
+ol.format.KML.FLAT_LINEAR_RINGS_PARSERS_ = ol.xml.makeStructureNS(
+ 'innerBoundaryIs': ol.format.KML.innerBoundaryIsParser_,
+ 'outerBoundaryIs': ol.format.KML.outerBoundaryIsParser_
+ * @const
+ * @private
+ol.format.KML.GX_TRACK_PARSERS_ = ol.xml.makeStructureNS(
+ 'when': ol.format.KML.whenParser_
+ }, ol.xml.makeStructureNS(
+ ol.format.KML.GX_NAMESPACE_URIS_, {
+ 'coord': ol.format.KML.gxCoordParser_
+ * @const
+ * @private
+ol.format.KML.GEOMETRY_FLAT_COORDINATES_PARSERS_ = ol.xml.makeStructureNS(
+ * @const
+ * @private
+ol.format.KML.ICON_PARSERS_ = ol.xml.makeStructureNS(
+ 'href': ol.xml.makeObjectPropertySetter(ol.format.KML.readURI_)
+ 'x': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'y': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'w': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'h': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal)
+ * @const
+ * @private
+ol.format.KML.ICON_STYLE_PARSERS_ = ol.xml.makeStructureNS(
+ 'Icon': ol.xml.makeObjectPropertySetter(ol.format.KML.readIcon_),
+ 'heading': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal),
+ 'hotSpot': ol.xml.makeObjectPropertySetter(ol.format.KML.readVec2_),
+ 'scale': ol.xml.makeObjectPropertySetter(ol.format.KML.readScale_)
+ * @const
+ * @private
+ol.format.KML.INNER_BOUNDARY_IS_PARSERS_ = ol.xml.makeStructureNS(
+ 'LinearRing': ol.xml.makeReplacer(ol.format.KML.readFlatLinearRing_)
+ * @const
+ * @private
+ol.format.KML.LABEL_STYLE_PARSERS_ = ol.xml.makeStructureNS(
+ 'color': ol.xml.makeObjectPropertySetter(ol.format.KML.readColor_),
+ * @const
+ * @private
+ol.format.KML.LINE_STYLE_PARSERS_ = ol.xml.makeStructureNS(
+ 'width': ol.xml.makeObjectPropertySetter(ol.format.XSD.readDecimal)
+ * @const
+ * @private
+ol.format.KML.MULTI_GEOMETRY_PARSERS_ = ol.xml.makeStructureNS(
+ 'LineString': ol.xml.makeArrayPusher(ol.format.KML.readLineString_),
+ 'LinearRing': ol.xml.makeArrayPusher(ol.format.KML.readLinearRing_),
+ 'MultiGeometry': ol.xml.makeArrayPusher(ol.format.KML.readMultiGeometry_),
+ 'Point': ol.xml.makeArrayPusher(ol.format.KML.readPoint_),
+ 'Polygon': ol.xml.makeArrayPusher(ol.format.KML.readPolygon_)
+ * @const
+ * @private
+ol.format.KML.GX_MULTITRACK_GEOMETRY_PARSERS_ = ol.xml.makeStructureNS(
+ 'Track': ol.xml.makeArrayPusher(ol.format.KML.readGxTrack_)
+ * @const
+ * @private
+ol.format.KML.NETWORK_LINK_PARSERS_ = ol.xml.makeStructureNS(
+ 'ExtendedData': ol.format.KML.ExtendedDataParser_,
+ 'Region': ol.format.KML.RegionParser_,
+ 'Link': ol.format.KML.LinkParser_,
+ 'address': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'description': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'name': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'open': ol.xml.makeObjectPropertySetter(ol.format.XSD.readBoolean),
+ 'phoneNumber': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'visibility': ol.xml.makeObjectPropertySetter(ol.format.XSD.readBoolean)
+ * @const
+ * @private
+ol.format.KML.LINK_PARSERS_ = ol.xml.makeStructureNS(
+ * @const
+ * @private
+ol.format.KML.OUTER_BOUNDARY_IS_PARSERS_ = ol.xml.makeStructureNS(
+ * @const
+ * @private
+ol.format.KML.PAIR_PARSERS_ = ol.xml.makeStructureNS(
+ 'Style': ol.xml.makeObjectPropertySetter(ol.format.KML.readStyle_),
+ 'key': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'styleUrl': ol.xml.makeObjectPropertySetter(ol.format.KML.readURI_)
+ * @const
+ * @private
+ol.format.KML.PLACEMARK_PARSERS_ = ol.xml.makeStructureNS(
+ 'MultiGeometry': ol.xml.makeObjectPropertySetter(
+ ol.format.KML.readMultiGeometry_, 'geometry'),
+ 'LineString': ol.xml.makeObjectPropertySetter(
+ ol.format.KML.readLineString_, 'geometry'),
+ 'LinearRing': ol.xml.makeObjectPropertySetter(
+ ol.format.KML.readLinearRing_, 'geometry'),
+ 'Point': ol.xml.makeObjectPropertySetter(
+ ol.format.KML.readPoint_, 'geometry'),
+ 'Polygon': ol.xml.makeObjectPropertySetter(
+ ol.format.KML.readPolygon_, 'geometry'),
+ 'StyleMap': ol.format.KML.PlacemarkStyleMapParser_,
+ 'styleUrl': ol.xml.makeObjectPropertySetter(ol.format.KML.readURI_),
+ 'MultiTrack': ol.xml.makeObjectPropertySetter(
+ ol.format.KML.readGxMultiTrack_, 'geometry'),
+ 'Track': ol.xml.makeObjectPropertySetter(
+ ol.format.KML.readGxTrack_, 'geometry')
+ * @const
+ * @private
+ol.format.KML.POLY_STYLE_PARSERS_ = ol.xml.makeStructureNS(
+ 'fill': ol.xml.makeObjectPropertySetter(ol.format.XSD.readBoolean),
+ 'outline': ol.xml.makeObjectPropertySetter(ol.format.XSD.readBoolean)
+ * @const
+ * @private
+ol.format.KML.SCHEMA_DATA_PARSERS_ = ol.xml.makeStructureNS(
+ 'SimpleData': ol.format.KML.SimpleDataParser_
+ * @const
+ * @private
+ol.format.KML.STYLE_PARSERS_ = ol.xml.makeStructureNS(
+ 'IconStyle': ol.format.KML.IconStyleParser_,
+ 'LabelStyle': ol.format.KML.LabelStyleParser_,
+ 'LineStyle': ol.format.KML.LineStyleParser_,
+ 'PolyStyle': ol.format.KML.PolyStyleParser_
+ * @const
+ * @private
+ol.format.KML.STYLE_MAP_PARSERS_ = ol.xml.makeStructureNS(
+ 'Pair': ol.format.KML.PairDataParser_
+ * @param {Array.<*>} objectStack Object stack.
+ * @private
+ * @return {Array.<ol.Feature>|undefined} Features.
+ol.format.KML.prototype.readDocumentOrFolder_ = function(node, objectStack) {
+ // FIXME use scope somehow
+ var parsersNS = ol.xml.makeStructureNS(
+ 'Document': ol.xml.makeArrayExtender(this.readDocumentOrFolder_, this),
+ 'Folder': ol.xml.makeArrayExtender(this.readDocumentOrFolder_, this),
+ 'Placemark': ol.xml.makeArrayPusher(this.readPlacemark_, this),
+ 'Style': this.readSharedStyle_.bind(this),
+ 'StyleMap': this.readSharedStyleMap_.bind(this)
+ /** @type {Array.<ol.Feature>} */
+ var features = ol.xml.pushParseAndPop([], parsersNS, node, objectStack, this);
+ if (features) {
+ return features;
+ } else {
+ return undefined;
+ * @private
+ * @return {ol.Feature|undefined} Feature.
+ol.format.KML.prototype.readPlacemark_ = function(node, objectStack) {
+ var object = ol.xml.pushParseAndPop({'geometry': null},
+ ol.format.KML.PLACEMARK_PARSERS_, node, objectStack);
+ if (!object) {
+ return undefined;
+ var feature = new ol.Feature();
+ var id = node.getAttribute('id');
+ if (id !== null) {
+ feature.setId(id);
+ var options = /** @type {olx.format.ReadOptions} */ (objectStack[0]);
+ var geometry = object['geometry'];
+ if (geometry) {
+ ol.format.Feature.transformWithOptions(geometry, false, options);
+ feature.setGeometry(geometry);
+ delete object['geometry'];
+ if (this.extractStyles_) {
+ var style = object['Style'];
+ var styleUrl = object['styleUrl'];
+ var styleFunction = ol.format.KML.createFeatureStyleFunction_(
+ style, styleUrl, this.defaultStyle_, this.sharedStyles_,
+ this.showPointNames_);
+ feature.setStyle(styleFunction);
+ delete object['Style'];
+ // we do not remove the styleUrl property from the object, so it
+ // gets stored on feature when setProperties is called
+ feature.setProperties(object);
+ return feature;
+ * @private
+ol.format.KML.prototype.readSharedStyle_ = function(node, objectStack) {
+ var style = ol.format.KML.readStyle_(node, objectStack);
+ if (style) {
+ var styleUri;
+ var url = new URL('#' + id, node.baseURI);
+ styleUri = url.href;
+ } else {
+ styleUri = '#' + id;
+ this.sharedStyles_[styleUri] = style;
+ * @private
+ol.format.KML.prototype.readSharedStyleMap_ = function(node, objectStack) {
+ if (id === null) {
+ return;
+ return;
+ var styleUri;
+ } else {
+ this.sharedStyles_[styleUri] = styleMapValue;
+ * Read the first feature from a KML source. MultiGeometries are converted into
+ * GeometryCollections if they are a mix of geometry types, and into MultiPoint/
+ * MultiLineString/MultiPolygon if they are all of the same type.
+ * @function
+ * @param {Document|Node|Object|string} source Source.
+ * @param {olx.format.ReadOptions=} opt_options Read options.
+ * @return {ol.Feature} Feature.
+ * @api
+ol.format.KML.prototype.readFeature;
+ * @inheritDoc
+ol.format.KML.prototype.readFeatureFromNode = function(node, opt_options) {
+ if (!ol.array.includes(ol.format.KML.NAMESPACE_URIS_, node.namespaceURI)) {
+ return null;
+ var feature = this.readPlacemark_(
+ node, [this.getReadOptions(node, opt_options)]);
+ if (feature) {
+ return feature;
+ } else {
+ return null;
+ * Read all features from a KML source. MultiGeometries are converted into
+ * @function
+ * @return {Array.<ol.Feature>} Features.
+ * @api
+ol.format.KML.prototype.readFeatures;
+ * @inheritDoc
+ol.format.KML.prototype.readFeaturesFromNode = function(node, opt_options) {
+ return [];
+ var features;
+ var localName = node.localName;
+ if (localName == 'Document' || localName == 'Folder') {
+ features = this.readDocumentOrFolder_(
+ if (features) {
+ return features;
+ } else {
+ return [];
+ } else if (localName == 'Placemark') {
+ if (feature) {
+ return [feature];
+ } else {
+ return [];
+ } else if (localName == 'kml') {
+ features = [];
+ var n;
+ for (n = node.firstElementChild; n; n = n.nextElementSibling) {
+ var fs = this.readFeaturesFromNode(n, opt_options);
+ if (fs) {
+ ol.array.extend(features, fs);
+ return features;
+ } else {
+ return [];
+ * Read the name of the KML.
+ * @param {Document|Node|string} source Souce.
+ * @return {string|undefined} Name.
+ * @api
+ol.format.KML.prototype.readName = function(source) {
+ if (ol.xml.isDocument(source)) {
+ return this.readNameFromDocument(/** @type {Document} */ (source));
+ } else if (ol.xml.isNode(source)) {
+ return this.readNameFromNode(/** @type {Node} */ (source));
+ } else if (typeof source === 'string') {
+ var doc = ol.xml.parse(source);
+ return this.readNameFromDocument(doc);
+ } else {
+ return undefined;
+ * @param {Document} doc Document.
+ol.format.KML.prototype.readNameFromDocument = function(doc) {
+ var n;
+ for (n = doc.firstChild; n; n = n.nextSibling) {
+ if (n.nodeType == Node.ELEMENT_NODE) {
+ var name = this.readNameFromNode(n);
+ if (name) {
+ return name;
+ return undefined;
+ol.format.KML.prototype.readNameFromNode = function(node) {
+ var n;
+ if (ol.array.includes(ol.format.KML.NAMESPACE_URIS_, n.namespaceURI) &&
+ n.localName == 'name') {
+ return ol.format.XSD.readString(n);
+ var localName = n.localName;
+ (localName == 'Document' ||
+ localName == 'Folder' ||
+ localName == 'Placemark' ||
+ localName == 'kml')) {
+ if (name) {
+ return name;
+ return undefined;
+ * Read the network links of the KML.
+ * @param {Document|Node|string} source Source.
+ * @return {Array.<Object>} Network links.
+ * @api
+ol.format.KML.prototype.readNetworkLinks = function(source) {
+ var networkLinks = [];
+ ol.array.extend(networkLinks, this.readNetworkLinksFromDocument(
+ /** @type {Document} */ (source)));
+ ol.array.extend(networkLinks, this.readNetworkLinksFromNode(
+ /** @type {Node} */ (source)));
+ ol.array.extend(networkLinks, this.readNetworkLinksFromDocument(doc));
+ return networkLinks;
+ol.format.KML.prototype.readNetworkLinksFromDocument = function(doc) {
+ var n, networkLinks = [];
+ ol.array.extend(networkLinks, this.readNetworkLinksFromNode(n));
+ol.format.KML.prototype.readNetworkLinksFromNode = function(node) {
+ n.localName == 'NetworkLink') {
+ var obj = ol.xml.pushParseAndPop({}, ol.format.KML.NETWORK_LINK_PARSERS_,
+ n, []);
+ networkLinks.push(obj);
+ * Read the regions of the KML.
+ * @return {Array.<Object>} Regions.
+ * @api
+ol.format.KML.prototype.readRegion = function(source) {
+ var regions = [];
+ ol.array.extend(regions, this.readRegionFromDocument(
+ ol.array.extend(regions, this.readRegionFromNode(
+ ol.array.extend(regions, this.readRegionFromDocument(doc));
+ return regions;
+ * @return {Array.<Object>} Region.
+ol.format.KML.prototype.readRegionFromDocument = function(doc) {
+ var n, regions = [];
+ ol.array.extend(regions, this.readRegionFromNode(n));
+ return regions;
+ * @api
+ol.format.KML.prototype.readRegionFromNode = function(node) {
+ n.localName == 'Region') {
+ var obj = ol.xml.pushParseAndPop({}, ol.format.KML.REGION_PARSERS_,
+ n, []);
+ regions.push(obj);
+ return regions;
+ * Read the projection from a KML source.
+ * @function
+ * @return {ol.proj.Projection} Projection.
+ * @api
+ol.format.KML.prototype.readProjection;
+ * @param {Node} node Node to append a TextNode with the color to.
+ * @param {ol.Color|string} color Color.
+ * @private
+ol.format.KML.writeColorTextNode_ = function(node, color) {
+ var rgba = ol.color.asArray(color);
+ var opacity = (rgba.length == 4) ? rgba[3] : 1;
+ var abgr = [opacity * 255, rgba[2], rgba[1], rgba[0]];
+ var i;
+ for (i = 0; i < 4; ++i) {
+ var hex = parseInt(abgr[i], 10).toString(16);
+ abgr[i] = (hex.length == 1) ? '0' + hex : hex;
+ ol.format.XSD.writeStringTextNode(node, abgr.join(''));
+ * @param {Node} node Node to append a TextNode with the coordinates to.
+ * @param {Array.<number>} coordinates Coordinates.
+ * @private
+ol.format.KML.writeCoordinatesTextNode_ = function(node, coordinates, objectStack) {
+ var context = objectStack[objectStack.length - 1];
+ var layout = context['layout'];
+ var stride = context['stride'];
+ var dimension;
+ if (layout == ol.geom.GeometryLayout.XY ||
+ layout == ol.geom.GeometryLayout.XYM) {
+ dimension = 2;
+ } else if (layout == ol.geom.GeometryLayout.XYZ ||
+ layout == ol.geom.GeometryLayout.XYZM) {
+ dimension = 3;
+ } else {
+ ol.asserts.assert(false, 34); // Invalid geometry layout
+ var d, i;
+ var ii = coordinates.length;
+ var text = '';
+ if (ii > 0) {
+ text += coordinates[0];
+ for (d = 1; d < dimension; ++d) {
+ text += ',' + coordinates[d];
+ for (i = stride; i < ii; i += stride) {
+ text += ' ' + coordinates[i];
+ text += ',' + coordinates[i + d];
+ ol.format.XSD.writeStringTextNode(node, text);
+ * @param {{name: *, value: *}} pair Name value pair.
+ * @private
+ol.format.KML.writeDataNode_ = function(node, pair, objectStack) {
+ node.setAttribute('name', pair.name);
+ var /** @type {ol.XmlNodeStackItem} */ context = {node: node};
+ var value = pair.value;
+ if (typeof value == 'object') {
+ if (value !== null && value.displayName) {
+ ol.xml.pushSerializeAndPop(context, ol.format.KML.EXTENDEDDATA_NODE_SERIALIZERS_,
+ ol.xml.OBJECT_PROPERTY_NODE_FACTORY, [value.displayName], objectStack, ['displayName']);
+ if (value !== null && value.value) {
+ ol.xml.OBJECT_PROPERTY_NODE_FACTORY, [value.value], objectStack, ['value']);
+ } else {
+ ol.xml.OBJECT_PROPERTY_NODE_FACTORY, [value], objectStack, ['value']);
+ * @param {Node} node Node to append a TextNode with the name to.
+ * @param {string} name DisplayName.
+ * @private
+ol.format.KML.writeDataNodeName_ = function(node, name) {
+ ol.format.XSD.writeCDATASection(node, name);
+ * @param {Node} node Node to append a CDATA Section with the value to.
+ * @param {string} value Value.
+ * @private
+ol.format.KML.writeDataNodeValue_ = function(node, value) {
+ ol.format.XSD.writeStringTextNode(node, value);
+ * @param {Array.<ol.Feature>} features Features.
+ * @this {ol.format.KML}
+ * @private
+ol.format.KML.writeDocument_ = function(node, features, objectStack) {
+ ol.xml.pushSerializeAndPop(context, ol.format.KML.DOCUMENT_SERIALIZERS_,
+ ol.format.KML.DOCUMENT_NODE_FACTORY_, features, objectStack, undefined,
+ this);
+ * @param {{names: Array<string>, values: (Array<*>)}} namesAndValues Names and values.
+ * @private
+ol.format.KML.writeExtendedData_ = function(node, namesAndValues, objectStack) {
+ var names = namesAndValues.names, values = namesAndValues.values;
+ var length = names.length;
+ for (var i = 0; i < length; i++) {
+ ol.format.KML.DATA_NODE_FACTORY_, [{name: names[i], value: values[i]}], objectStack);
+ * @param {Object} icon Icon object.
+ * @private
+ol.format.KML.writeIcon_ = function(node, icon, objectStack) {
+ var parentNode = objectStack[objectStack.length - 1].node;
+ var orderedKeys = ol.format.KML.ICON_SEQUENCE_[parentNode.namespaceURI];
+ var values = ol.xml.makeSequence(icon, orderedKeys);
+ ol.format.KML.ICON_SERIALIZERS_, ol.xml.OBJECT_PROPERTY_NODE_FACTORY,
+ values, objectStack, orderedKeys);
+ orderedKeys =
+ ol.format.KML.ICON_SEQUENCE_[ol.format.KML.GX_NAMESPACE_URIS_[0]];
+ values = ol.xml.makeSequence(icon, orderedKeys);
+ ol.xml.pushSerializeAndPop(context, ol.format.KML.ICON_SERIALIZERS_,
+ ol.format.KML.GX_NODE_FACTORY_, values, objectStack, orderedKeys);
+ * @param {ol.style.Icon} style Icon style.
+ * @private
+ol.format.KML.writeIconStyle_ = function(node, style, objectStack) {
+ var properties = {};
+ var src = style.getSrc();
+ var size = style.getSize();
+ var iconImageSize = style.getImageSize();
+ var iconProperties = {
+ 'href': src
+ if (size) {
+ iconProperties['w'] = size[0];
+ iconProperties['h'] = size[1];
+ var anchor = style.getAnchor(); // top-left
+ var origin = style.getOrigin(); // top-left
+ if (origin && iconImageSize && origin[0] !== 0 && origin[1] !== size[1]) {
+ iconProperties['x'] = origin[0];
+ iconProperties['y'] = iconImageSize[1] - (origin[1] + size[1]);
+ if (anchor && anchor[0] !== 0 && anchor[1] !== size[1]) {
+ var /** @type {ol.KMLVec2_} */ hotSpot = {
+ x: anchor[0],
+ xunits: ol.style.IconAnchorUnits.PIXELS,
+ y: size[1] - anchor[1],
+ yunits: ol.style.IconAnchorUnits.PIXELS
+ properties['hotSpot'] = hotSpot;
+ properties['Icon'] = iconProperties;
+ var scale = style.getScale();
+ if (scale !== 1) {
+ properties['scale'] = scale;
+ var rotation = style.getRotation();
+ if (rotation !== 0) {
+ properties['heading'] = rotation; // 0-360
+ var orderedKeys = ol.format.KML.ICON_STYLE_SEQUENCE_[parentNode.namespaceURI];
+ var values = ol.xml.makeSequence(properties, orderedKeys);
+ ol.xml.pushSerializeAndPop(context, ol.format.KML.ICON_STYLE_SERIALIZERS_,
+ ol.xml.OBJECT_PROPERTY_NODE_FACTORY, values, objectStack, orderedKeys);
+ * @param {ol.style.Text} style style.
+ * @private
+ol.format.KML.writeLabelStyle_ = function(node, style, objectStack) {
+ var fill = style.getFill();
+ if (fill) {
+ properties['color'] = fill.getColor();
+ if (scale && scale !== 1) {
+ var orderedKeys =
+ ol.format.KML.LABEL_STYLE_SEQUENCE_[parentNode.namespaceURI];
+ ol.xml.pushSerializeAndPop(context, ol.format.KML.LABEL_STYLE_SERIALIZERS_,
+ * @param {ol.style.Stroke} style style.
+ * @private
+ol.format.KML.writeLineStyle_ = function(node, style, objectStack) {
+ 'color': style.getColor(),
+ 'width': style.getWidth()
+ var orderedKeys = ol.format.KML.LINE_STYLE_SEQUENCE_[parentNode.namespaceURI];
+ ol.xml.pushSerializeAndPop(context, ol.format.KML.LINE_STYLE_SERIALIZERS_,
+ * @param {ol.geom.Geometry} geometry Geometry.
+ * @private
+ol.format.KML.writeMultiGeometry_ = function(node, geometry, objectStack) {
+ /** @type {ol.XmlNodeStackItem} */
+ var context = {node: node};
+ var type = geometry.getType();
+ /** @type {Array.<ol.geom.Geometry>} */
+ var geometries;
+ /** @type {function(*, Array.<*>, string=): (Node|undefined)} */
+ var factory;
+ if (type == ol.geom.GeometryType.GEOMETRY_COLLECTION) {
+ geometries = /** @type {ol.geom.GeometryCollection} */ (geometry).getGeometries();
+ factory = ol.format.KML.GEOMETRY_NODE_FACTORY_;
+ } else if (type == ol.geom.GeometryType.MULTI_POINT) {
+ geometries = /** @type {ol.geom.MultiPoint} */ (geometry).getPoints();
+ factory = ol.format.KML.POINT_NODE_FACTORY_;
+ } else if (type == ol.geom.GeometryType.MULTI_LINE_STRING) {
+ geometries =
+ (/** @type {ol.geom.MultiLineString} */ (geometry)).getLineStrings();
+ factory = ol.format.KML.LINE_STRING_NODE_FACTORY_;
+ } else if (type == ol.geom.GeometryType.MULTI_POLYGON) {
+ geometries =
+ (/** @type {ol.geom.MultiPolygon} */ (geometry)).getPolygons();
+ factory = ol.format.KML.POLYGON_NODE_FACTORY_;
+ } else {
+ ol.asserts.assert(false, 39); // Unknown geometry type
+ ol.format.KML.MULTI_GEOMETRY_SERIALIZERS_, factory,
+ geometries, objectStack);
+ * @param {ol.geom.LinearRing} linearRing Linear ring.
+ * @private
+ol.format.KML.writeBoundaryIs_ = function(node, linearRing, objectStack) {
+ ol.format.KML.BOUNDARY_IS_SERIALIZERS_,
+ ol.format.KML.LINEAR_RING_NODE_FACTORY_, [linearRing], objectStack);
+ * FIXME currently we do serialize arbitrary/custom feature properties
+ * (ExtendedData).
+ * @param {ol.Feature} feature Feature.
+ * @private
+ol.format.KML.writePlacemark_ = function(node, feature, objectStack) {
+ // set id
+ if (feature.getId()) {
+ node.setAttribute('id', feature.getId());
+ // serialize properties (properties unknown to KML are not serialized)
+ var properties = feature.getProperties();
+ // don't export these to ExtendedData
+ var filter = {'address': 1, 'description': 1, 'name': 1, 'open': 1,
+ 'phoneNumber': 1, 'styleUrl': 1, 'visibility': 1};
+ filter[feature.getGeometryName()] = 1;
+ var keys = Object.keys(properties || {}).sort().filter(function(v) {
+ return !filter[v];
+ if (keys.length > 0) {
+ var sequence = ol.xml.makeSequence(properties, keys);
+ var namesAndValues = {names: keys, values: sequence};
+ ol.xml.pushSerializeAndPop(context, ol.format.KML.PLACEMARK_SERIALIZERS_,
+ ol.format.KML.EXTENDEDDATA_NODE_FACTORY_, [namesAndValues], objectStack);
+ var styleFunction = feature.getStyleFunction();
+ if (styleFunction) {
+ // FIXME the styles returned by the style function are supposed to be
+ // resolution-independent here
+ var styles = styleFunction.call(feature, 0);
+ if (styles) {
+ var style = Array.isArray(styles) ? styles[0] : styles;
+ if (this.writeStyles_) {
+ properties['Style'] = style;
+ var textStyle = style.getText();
+ if (textStyle) {
+ properties['name'] = textStyle.getText();
+ var orderedKeys = ol.format.KML.PLACEMARK_SEQUENCE_[parentNode.namespaceURI];
+ // serialize geometry
+ var options = /** @type {olx.format.WriteOptions} */ (objectStack[0]);
+ var geometry = feature.getGeometry();
+ if (geometry) {
+ geometry =
+ ol.format.Feature.transformWithOptions(geometry, true, options);
+ ol.format.KML.GEOMETRY_NODE_FACTORY_, [geometry], objectStack);
+ * @param {ol.geom.SimpleGeometry} geometry Geometry.
+ * @private
+ol.format.KML.writePrimitiveGeometry_ = function(node, geometry, objectStack) {
+ var flatCoordinates = geometry.getFlatCoordinates();
+ context['layout'] = geometry.getLayout();
+ context['stride'] = geometry.getStride();
+ ol.format.KML.PRIMITIVE_GEOMETRY_SERIALIZERS_,
+ ol.format.KML.COORDINATES_NODE_FACTORY_,
+ [flatCoordinates], objectStack);
+ * @param {ol.geom.Polygon} polygon Polygon.
+ * @private
+ol.format.KML.writePolygon_ = function(node, polygon, objectStack) {
+ var linearRings = polygon.getLinearRings();
+ var outerRing = linearRings.shift();
+ // inner rings
+ ol.format.KML.POLYGON_SERIALIZERS_,
+ ol.format.KML.INNER_BOUNDARY_NODE_FACTORY_,
+ linearRings, objectStack);
+ // outer ring
+ ol.format.KML.OUTER_BOUNDARY_NODE_FACTORY_,
+ [outerRing], objectStack);
+ * @param {ol.style.Fill} style Style.
+ * @private
+ol.format.KML.writePolyStyle_ = function(node, style, objectStack) {
+ ol.xml.pushSerializeAndPop(context, ol.format.KML.POLY_STYLE_SERIALIZERS_,
+ ol.format.KML.COLOR_NODE_FACTORY_, [style.getColor()], objectStack);
+ * @param {Node} node Node to append a TextNode with the scale to.
+ * @private
+ol.format.KML.writeScaleTextNode_ = function(node, scale) {
+ // the Math is to remove any excess decimals created by float arithmetic
+ ol.format.XSD.writeDecimalTextNode(node,
+ Math.round(scale * 1e6) / 1e6);
+ * @param {ol.style.Style} style Style.
+ * @private
+ol.format.KML.writeStyle_ = function(node, style, objectStack) {
+ var fillStyle = style.getFill();
+ var strokeStyle = style.getStroke();
+ var imageStyle = style.getImage();
+ if (imageStyle instanceof ol.style.Icon) {
+ properties['IconStyle'] = imageStyle;
+ if (textStyle) {
+ properties['LabelStyle'] = textStyle;
+ if (strokeStyle) {
+ properties['LineStyle'] = strokeStyle;
+ if (fillStyle) {
+ properties['PolyStyle'] = fillStyle;
+ var orderedKeys = ol.format.KML.STYLE_SEQUENCE_[parentNode.namespaceURI];
+ ol.xml.pushSerializeAndPop(context, ol.format.KML.STYLE_SERIALIZERS_,
+ * @param {Node} node Node to append a TextNode with the Vec2 to.
+ * @param {ol.KMLVec2_} vec2 Vec2.
+ * @private
+ol.format.KML.writeVec2_ = function(node, vec2) {
+ node.setAttribute('x', vec2.x);
+ node.setAttribute('y', vec2.y);
+ node.setAttribute('xunits', vec2.xunits);
+ node.setAttribute('yunits', vec2.yunits);
+ * @const
+ * @type {Object.<string, Array.<string>>}
+ * @private
+ol.format.KML.KML_SEQUENCE_ = ol.xml.makeStructureNS(
+ ol.format.KML.NAMESPACE_URIS_, [
+ 'Document', 'Placemark'
+ * @const
+ * @type {Object.<string, Object.<string, ol.XmlSerializer>>}
+ * @private
+ol.format.KML.KML_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'Document': ol.xml.makeChildAppender(ol.format.KML.writeDocument_),
+ 'Placemark': ol.xml.makeChildAppender(ol.format.KML.writePlacemark_)
+ * @const
+ * @private
+ol.format.KML.DOCUMENT_SERIALIZERS_ = ol.xml.makeStructureNS(
+ * @const
+ * @private
+ol.format.KML.EXTENDEDDATA_NODE_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'Data': ol.xml.makeChildAppender(ol.format.KML.writeDataNode_),
+ 'value': ol.xml.makeChildAppender(ol.format.KML.writeDataNodeValue_),
+ 'displayName': ol.xml.makeChildAppender(ol.format.KML.writeDataNodeName_)
+ * @const
+ * @type {Object.<string, string>}
+ * @private
+ol.format.KML.GEOMETRY_TYPE_TO_NODENAME_ = {
+ 'Point': 'Point',
+ 'LineString': 'LineString',
+ 'LinearRing': 'LinearRing',
+ 'Polygon': 'Polygon',
+ 'MultiPoint': 'MultiGeometry',
+ 'MultiLineString': 'MultiGeometry',
+ 'MultiPolygon': 'MultiGeometry',
+ 'GeometryCollection': 'MultiGeometry'
+ * @const
+ * @private
+ol.format.KML.ICON_SEQUENCE_ = ol.xml.makeStructureNS(
+ 'href'
+ ol.xml.makeStructureNS(ol.format.KML.GX_NAMESPACE_URIS_, [
+ 'x', 'y', 'w', 'h'
+ * @const
+ * @private
+ol.format.KML.ICON_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'href': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode)
+ 'x': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
+ 'y': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
+ 'w': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
+ 'h': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode)
+ * @const
+ * @private
+ol.format.KML.ICON_STYLE_SEQUENCE_ = ol.xml.makeStructureNS(
+ 'scale', 'heading', 'Icon', 'hotSpot'
+ * @const
+ * @private
+ol.format.KML.ICON_STYLE_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'Icon': ol.xml.makeChildAppender(ol.format.KML.writeIcon_),
+ 'heading': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode),
+ 'hotSpot': ol.xml.makeChildAppender(ol.format.KML.writeVec2_),
+ 'scale': ol.xml.makeChildAppender(ol.format.KML.writeScaleTextNode_)
+ * @const
+ * @private
+ol.format.KML.LABEL_STYLE_SEQUENCE_ = ol.xml.makeStructureNS(
+ 'color', 'scale'
+ * @const
+ * @private
+ol.format.KML.LABEL_STYLE_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'color': ol.xml.makeChildAppender(ol.format.KML.writeColorTextNode_),
+ * @const
+ * @private
+ol.format.KML.LINE_STYLE_SEQUENCE_ = ol.xml.makeStructureNS(
+ 'color', 'width'
+ * @const
+ * @private
+ol.format.KML.LINE_STYLE_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'width': ol.xml.makeChildAppender(ol.format.XSD.writeDecimalTextNode)
+ * @const
+ * @private
+ol.format.KML.BOUNDARY_IS_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'LinearRing': ol.xml.makeChildAppender(
+ ol.format.KML.writePrimitiveGeometry_)
+ * @const
+ * @private
+ol.format.KML.MULTI_GEOMETRY_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'LineString': ol.xml.makeChildAppender(
+ ol.format.KML.writePrimitiveGeometry_),
+ 'Point': ol.xml.makeChildAppender(
+ 'Polygon': ol.xml.makeChildAppender(ol.format.KML.writePolygon_),
+ 'GeometryCollection': ol.xml.makeChildAppender(
+ ol.format.KML.writeMultiGeometry_)
+ * @const
+ * @private
+ol.format.KML.PLACEMARK_SEQUENCE_ = ol.xml.makeStructureNS(
+ 'name', 'open', 'visibility', 'address', 'phoneNumber', 'description',
+ 'styleUrl', 'Style'
+ * @const
+ * @private
+ol.format.KML.PLACEMARK_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'ExtendedData': ol.xml.makeChildAppender(
+ ol.format.KML.writeExtendedData_),
+ 'MultiGeometry': ol.xml.makeChildAppender(
+ ol.format.KML.writeMultiGeometry_),
+ 'Style': ol.xml.makeChildAppender(ol.format.KML.writeStyle_),
+ 'address': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
+ 'description': ol.xml.makeChildAppender(
+ ol.format.XSD.writeStringTextNode),
+ 'name': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
+ 'open': ol.xml.makeChildAppender(ol.format.XSD.writeBooleanTextNode),
+ 'phoneNumber': ol.xml.makeChildAppender(
+ 'styleUrl': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode),
+ 'visibility': ol.xml.makeChildAppender(
+ ol.format.XSD.writeBooleanTextNode)
+ * @const
+ * @private
+ol.format.KML.PRIMITIVE_GEOMETRY_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'coordinates': ol.xml.makeChildAppender(
+ ol.format.KML.writeCoordinatesTextNode_)
+ * @const
+ * @private
+ol.format.KML.POLYGON_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'outerBoundaryIs': ol.xml.makeChildAppender(
+ ol.format.KML.writeBoundaryIs_),
+ 'innerBoundaryIs': ol.xml.makeChildAppender(
+ * @const
+ * @private
+ol.format.KML.POLY_STYLE_SERIALIZERS_ = ol.xml.makeStructureNS(
+ * @const
+ * @private
+ol.format.KML.STYLE_SEQUENCE_ = ol.xml.makeStructureNS(
+ 'IconStyle', 'LabelStyle', 'LineStyle', 'PolyStyle'
+ * @const
+ * @private
+ol.format.KML.STYLE_SERIALIZERS_ = ol.xml.makeStructureNS(
+ 'IconStyle': ol.xml.makeChildAppender(ol.format.KML.writeIconStyle_),
+ 'LabelStyle': ol.xml.makeChildAppender(ol.format.KML.writeLabelStyle_),
+ 'LineStyle': ol.xml.makeChildAppender(ol.format.KML.writeLineStyle_),
+ 'PolyStyle': ol.xml.makeChildAppender(ol.format.KML.writePolyStyle_)
+ * @const
+ * @param {*} value Value.
+ * @param {string=} opt_nodeName Node name.
+ * @return {Node|undefined} Node.
+ * @private
+ol.format.KML.GX_NODE_FACTORY_ = function(value, objectStack, opt_nodeName) {
+ return ol.xml.createElementNS(ol.format.KML.GX_NAMESPACE_URIS_[0],
+ 'gx:' + opt_nodeName);
+ * @const
+ * @private
+ol.format.KML.DOCUMENT_NODE_FACTORY_ = function(value, objectStack,
+ opt_nodeName) {
+ return ol.xml.createElementNS(parentNode.namespaceURI, 'Placemark');
+ * @const
+ * @private
+ol.format.KML.GEOMETRY_NODE_FACTORY_ = function(value, objectStack,
+ opt_nodeName) {
+ if (value) {
+ ol.format.KML.GEOMETRY_TYPE_TO_NODENAME_[/** @type {ol.geom.Geometry} */ (value).getType()]);
+ * A factory for creating coordinates nodes.
+ * @const
+ * @type {function(*, Array.<*>, string=): (Node|undefined)}
+ * @private
+ol.format.KML.COLOR_NODE_FACTORY_ = ol.xml.makeSimpleNodeFactory('color');
+ * @const
+ * @private
+ol.format.KML.COORDINATES_NODE_FACTORY_ =
+ ol.xml.makeSimpleNodeFactory('coordinates');
+ * A factory for creating Data nodes.
+ * @const
+ * @type {function(*, Array.<*>): (Node|undefined)}
+ * @private
+ol.format.KML.DATA_NODE_FACTORY_ =
+ ol.xml.makeSimpleNodeFactory('Data');
+ * A factory for creating ExtendedData nodes.
+ * @const
+ * @private
+ol.format.KML.EXTENDEDDATA_NODE_FACTORY_ =
+ ol.xml.makeSimpleNodeFactory('ExtendedData');
+ * A factory for creating innerBoundaryIs nodes.
+ * @const
+ * @private
+ol.format.KML.INNER_BOUNDARY_NODE_FACTORY_ =
+ ol.xml.makeSimpleNodeFactory('innerBoundaryIs');
+ * A factory for creating Point nodes.
+ * @const
+ * @private
+ol.format.KML.POINT_NODE_FACTORY_ =
+ ol.xml.makeSimpleNodeFactory('Point');
+ * A factory for creating LineString nodes.
+ * @const
+ * @private
+ol.format.KML.LINE_STRING_NODE_FACTORY_ =
+ ol.xml.makeSimpleNodeFactory('LineString');
+ * A factory for creating LinearRing nodes.
+ * @const
+ * @private
+ol.format.KML.LINEAR_RING_NODE_FACTORY_ =
+ ol.xml.makeSimpleNodeFactory('LinearRing');
+ * A factory for creating Polygon nodes.
+ * @const
+ * @private
+ol.format.KML.POLYGON_NODE_FACTORY_ =
+ ol.xml.makeSimpleNodeFactory('Polygon');
+ * A factory for creating outerBoundaryIs nodes.
+ * @const
+ * @private
+ol.format.KML.OUTER_BOUNDARY_NODE_FACTORY_ =
+ ol.xml.makeSimpleNodeFactory('outerBoundaryIs');
+ * Encode an array of features in the KML format. GeometryCollections, MultiPoints,
+ * MultiLineStrings, and MultiPolygons are output as MultiGeometries.
+ * @function
+ * @param {olx.format.WriteOptions=} opt_options Options.
+ * @return {string} Result.
+ * @api
+ol.format.KML.prototype.writeFeatures;
+ * Encode an array of features in the KML format as an XML node. GeometryCollections,
+ * MultiPoints, MultiLineStrings, and MultiPolygons are output as MultiGeometries.
+ * @return {Node} Node.
+ * @override
+ * @api
+ol.format.KML.prototype.writeFeaturesNode = function(features, opt_options) {
+ opt_options = this.adaptOptions(opt_options);
+ var kml = ol.xml.createElementNS(ol.format.KML.NAMESPACE_URIS_[4], 'kml');
+ var xmlnsUri = 'http://www.w3.org/2000/xmlns/';
+ var xmlSchemaInstanceUri = 'http://www.w3.org/2001/XMLSchema-instance';
+ ol.xml.setAttributeNS(kml, xmlnsUri, 'xmlns:gx',
+ ol.format.KML.GX_NAMESPACE_URIS_[0]);
+ ol.xml.setAttributeNS(kml, xmlnsUri, 'xmlns:xsi', xmlSchemaInstanceUri);
+ ol.xml.setAttributeNS(kml, xmlSchemaInstanceUri, 'xsi:schemaLocation',
+ ol.format.KML.SCHEMA_LOCATION_);
+ var /** @type {ol.XmlNodeStackItem} */ context = {node: kml};
+ if (features.length > 1) {
+ properties['Document'] = features;
+ } else if (features.length == 1) {
+ properties['Placemark'] = features[0];
+ var orderedKeys = ol.format.KML.KML_SEQUENCE_[kml.namespaceURI];
+ ol.xml.pushSerializeAndPop(context, ol.format.KML.KML_SERIALIZERS_,
+ ol.xml.OBJECT_PROPERTY_NODE_FACTORY, values, [opt_options], orderedKeys,
+ this);
+ return kml;
+goog.provide('ol.ext.pbf');
+/** @typedef {function(*)} */
+ol.ext.pbf;
+(function() {
+var exports = {};
+var module = {exports: exports};
+var define;
+ * @fileoverview
+ * @suppress {accessControls, ambiguousFunctionDecl, checkDebuggerStatement, checkRegExp, checkTypes, checkVars, const, constantProperty, deprecated, duplicate, es5Strict, fileoverviewTags, missingProperties, nonStandardJsDocs, strictModuleDepCheck, suspiciousCode, undefinedNames, undefinedVars, unknownDefines, unusedLocalVariables, uselessCode, visibility}
+(function(f){if(typeof exports==="object"&&typeof module!=="undefined"){module.exports=f()}else if(typeof define==="function"&&define.amd){define([],f)}else{var g;if(typeof window!=="undefined"){g=window}else if(typeof global!=="undefined"){g=global}else if(typeof self!=="undefined"){g=self}else{g=this}g.pbf = f()}})(function(){var define,module,exports;return (function e(t,n,r){function s(o,u){if(!n[o]){if(!t[o]){var a=typeof require=="function"&&require;if(!u&&a)return a(o,!0);if(i)return i(o,!0);var f=new Error("Cannot find module '"+o+"'");throw f.code="MODULE_NOT_FOUND",f}var l=n[o]={exports:{}};t[o][0].call(l.exports,function(e){var n=t[o][1][e];return s(n?n:e)},l,l.exports,e,t,n,r)}return n[o].exports}var i=typeof require=="function"&&require;for(var o=0;o<r.length;o++)s(r[o]);return s})({1:[function(_dereq_,module,exports){
+exports.read = function (buffer, offset, isLE, mLen, nBytes) {
+ var e, m
+ var eLen = nBytes * 8 - mLen - 1
+ var eMax = (1 << eLen) - 1
+ var eBias = eMax >> 1
+ var nBits = -7
+ var i = isLE ? (nBytes - 1) : 0
+ var d = isLE ? -1 : 1
+ var s = buffer[offset + i]
+ i += d
+ e = s & ((1 << (-nBits)) - 1)
+ s >>= (-nBits)
+ nBits += eLen
+ for (; nBits > 0; e = e * 256 + buffer[offset + i], i += d, nBits -= 8) {}
+ m = e & ((1 << (-nBits)) - 1)
+ e >>= (-nBits)
+ nBits += mLen
+ for (; nBits > 0; m = m * 256 + buffer[offset + i], i += d, nBits -= 8) {}
+ if (e === 0) {
+ e = 1 - eBias
+ } else if (e === eMax) {
+ return m ? NaN : ((s ? -1 : 1) * Infinity)
+ } else {
+ m = m + Math.pow(2, mLen)
+ e = e - eBias
+ return (s ? -1 : 1) * m * Math.pow(2, e - mLen)
+exports.write = function (buffer, value, offset, isLE, mLen, nBytes) {
+ var e, m, c
+ var rt = (mLen === 23 ? Math.pow(2, -24) - Math.pow(2, -77) : 0)
+ var i = isLE ? 0 : (nBytes - 1)
+ var d = isLE ? 1 : -1
+ var s = value < 0 || (value === 0 && 1 / value < 0) ? 1 : 0
+ value = Math.abs(value)
+ if (isNaN(value) || value === Infinity) {
+ m = isNaN(value) ? 1 : 0
+ e = eMax
+ } else {
+ e = Math.floor(Math.log(value) / Math.LN2)
+ if (value * (c = Math.pow(2, -e)) < 1) {
+ e--
+ c *= 2
+ if (e + eBias >= 1) {
+ value += rt / c
+ } else {
+ value += rt * Math.pow(2, 1 - eBias)
+ if (value * c >= 2) {
+ e++
+ c /= 2
+ if (e + eBias >= eMax) {
+ m = 0
+ e = eMax
+ } else if (e + eBias >= 1) {
+ m = (value * c - 1) * Math.pow(2, mLen)
+ e = e + eBias
+ } else {
+ m = value * Math.pow(2, eBias - 1) * Math.pow(2, mLen)
+ e = 0
+ for (; mLen >= 8; buffer[offset + i] = m & 0xff, i += d, m /= 256, mLen -= 8) {}
+ e = (e << mLen) | m
+ eLen += mLen
+ for (; eLen > 0; buffer[offset + i] = e & 0xff, i += d, e /= 256, eLen -= 8) {}
+ buffer[offset + i - d] |= s * 128
+},{}],2:[function(_dereq_,module,exports){
+'use strict';
+module.exports = Pbf;
+var ieee754 = _dereq_('ieee754');
+function Pbf(buf) {
+ this.buf = ArrayBuffer.isView && ArrayBuffer.isView(buf) ? buf : new Uint8Array(buf || 0);
+ this.pos = 0;
+ this.type = 0;
+ this.length = this.buf.length;
+Pbf.Varint = 0; // varint: int32, int64, uint32, uint64, sint32, sint64, bool, enum
+Pbf.Fixed64 = 1; // 64-bit: double, fixed64, sfixed64
+Pbf.Bytes = 2; // length-delimited: string, bytes, embedded messages, packed repeated fields
+Pbf.Fixed32 = 5; // 32-bit: float, fixed32, sfixed32
+var SHIFT_LEFT_32 = (1 << 16) * (1 << 16),
+ SHIFT_RIGHT_32 = 1 / SHIFT_LEFT_32;
+Pbf.prototype = {
+ destroy: function() {
+ this.buf = null;
+ // === READING =================================================================
+ readFields: function(readField, result, end) {
+ end = end || this.length;
+ while (this.pos < end) {
+ var val = this.readVarint(),
+ tag = val >> 3,
+ startPos = this.pos;
+ this.type = val & 0x7;
+ readField(tag, result, this);
+ if (this.pos === startPos) this.skip(val);
+ return result;
+ readMessage: function(readField, result) {
+ return this.readFields(readField, result, this.readVarint() + this.pos);
+ readFixed32: function() {
+ var val = readUInt32(this.buf, this.pos);
+ this.pos += 4;
+ return val;
+ readSFixed32: function() {
+ var val = readInt32(this.buf, this.pos);
+ this.pos += 4;
+ return val;
+ // 64-bit int handling is based on github.com/dpw/node-buffer-more-ints (MIT-licensed)
+ readFixed64: function() {
+ var val = readUInt32(this.buf, this.pos) + readUInt32(this.buf, this.pos + 4) * SHIFT_LEFT_32;
+ this.pos += 8;
+ return val;
+ readSFixed64: function() {
+ var val = readUInt32(this.buf, this.pos) + readInt32(this.buf, this.pos + 4) * SHIFT_LEFT_32;
+ this.pos += 8;
+ return val;
+ readFloat: function() {
+ var val = ieee754.read(this.buf, this.pos, true, 23, 4);
+ this.pos += 4;
+ return val;
+ readDouble: function() {
+ var val = ieee754.read(this.buf, this.pos, true, 52, 8);
+ this.pos += 8;
+ return val;
+ readVarint: function(isSigned) {
+ var buf = this.buf,
+ val, b;
+ b = buf[this.pos++]; val = b & 0x7f; if (b < 0x80) return val;
+ b = buf[this.pos++]; val |= (b & 0x7f) << 7; if (b < 0x80) return val;
+ b = buf[this.pos++]; val |= (b & 0x7f) << 14; if (b < 0x80) return val;
+ b = buf[this.pos++]; val |= (b & 0x7f) << 21; if (b < 0x80) return val;
+ b = buf[this.pos]; val |= (b & 0x0f) << 28;
+ return readVarintRemainder(val, isSigned, this);
+ readVarint64: function() { // for compatibility with v2.0.1
+ return this.readVarint(true);
+ readSVarint: function() {
+ var num = this.readVarint();
+ return num % 2 === 1 ? (num + 1) / -2 : num / 2; // zigzag encoding
+ readBoolean: function() {
+ return Boolean(this.readVarint());
+ readString: function() {
+ var end = this.readVarint() + this.pos,
+ str = readUtf8(this.buf, this.pos, end);
+ this.pos = end;
+ return str;
+ readBytes: function() {
+ buffer = this.buf.subarray(this.pos, end);
+ this.pos = end;
+ return buffer;
+ // verbose for performance reasons; doesn't affect gzipped size
+ readPackedVarint: function(arr, isSigned) {
+ var end = readPackedEnd(this);
+ arr = arr || [];
+ while (this.pos < end) arr.push(this.readVarint(isSigned));
+ return arr;
+ readPackedSVarint: function(arr) {
+ arr = arr || [];
+ while (this.pos < end) arr.push(this.readSVarint());
+ return arr;
+ readPackedBoolean: function(arr) {
+ arr = arr || [];
+ while (this.pos < end) arr.push(this.readBoolean());
+ return arr;
+ readPackedFloat: function(arr) {
+ arr = arr || [];
+ while (this.pos < end) arr.push(this.readFloat());
+ return arr;
+ readPackedDouble: function(arr) {
+ arr = arr || [];
+ while (this.pos < end) arr.push(this.readDouble());
+ return arr;
+ readPackedFixed32: function(arr) {
+ arr = arr || [];
+ while (this.pos < end) arr.push(this.readFixed32());
+ return arr;
+ readPackedSFixed32: function(arr) {
+ arr = arr || [];
+ while (this.pos < end) arr.push(this.readSFixed32());
+ return arr;
+ readPackedFixed64: function(arr) {
+ arr = arr || [];
+ while (this.pos < end) arr.push(this.readFixed64());
+ return arr;
+ readPackedSFixed64: function(arr) {
+ arr = arr || [];
+ while (this.pos < end) arr.push(this.readSFixed64());
+ return arr;
+ skip: function(val) {
+ var type = val & 0x7;
+ if (type === Pbf.Varint) while (this.buf[this.pos++] > 0x7f) {}
+ else if (type === Pbf.Bytes) this.pos = this.readVarint() + this.pos;
+ else if (type === Pbf.Fixed32) this.pos += 4;
+ else if (type === Pbf.Fixed64) this.pos += 8;
+ else throw new Error('Unimplemented type: ' + type);
+ // === WRITING =================================================================
+ writeTag: function(tag, type) {
+ this.writeVarint((tag << 3) | type);
+ realloc: function(min) {
+ var length = this.length || 16;
+ while (length < this.pos + min) length *= 2;
+ if (length !== this.length) {
+ var buf = new Uint8Array(length);
+ buf.set(this.buf);
+ this.buf = buf;
+ this.length = length;
+ finish: function() {
+ this.length = this.pos;
+ this.pos = 0;
+ return this.buf.subarray(0, this.length);
+ writeFixed32: function(val) {
+ this.realloc(4);
+ writeInt32(this.buf, val, this.pos);
+ this.pos += 4;
+ writeSFixed32: function(val) {
+ this.realloc(4);
+ this.pos += 4;
+ writeFixed64: function(val) {
+ this.realloc(8);
+ writeInt32(this.buf, val & -1, this.pos);
+ writeInt32(this.buf, Math.floor(val * SHIFT_RIGHT_32), this.pos + 4);
+ this.pos += 8;
+ writeSFixed64: function(val) {
+ this.realloc(8);
+ this.pos += 8;
+ writeVarint: function(val) {
+ val = +val || 0;
+ if (val > 0xfffffff || val < 0) {
+ writeBigVarint(val, this);
+ return;
+ this.realloc(4);
+ this.buf[this.pos++] = val & 0x7f | (val > 0x7f ? 0x80 : 0); if (val <= 0x7f) return;
+ this.buf[this.pos++] = ((val >>>= 7) & 0x7f) | (val > 0x7f ? 0x80 : 0); if (val <= 0x7f) return;
+ this.buf[this.pos++] = (val >>> 7) & 0x7f;
+ writeSVarint: function(val) {
+ this.writeVarint(val < 0 ? -val * 2 - 1 : val * 2);
+ writeBoolean: function(val) {
+ this.writeVarint(Boolean(val));
+ writeString: function(str) {
+ str = String(str);
+ this.realloc(str.length * 4);
+ this.pos++; // reserve 1 byte for short string length
+ var startPos = this.pos;
+ // write the string directly to the buffer and see how much was written
+ this.pos = writeUtf8(this.buf, str, this.pos);
+ var len = this.pos - startPos;
+ if (len >= 0x80) makeRoomForExtraLength(startPos, len, this);
+ // finally, write the message length in the reserved place and restore the position
+ this.pos = startPos - 1;
+ this.writeVarint(len);
+ this.pos += len;
+ writeFloat: function(val) {
+ this.realloc(4);
+ ieee754.write(this.buf, val, this.pos, true, 23, 4);
+ this.pos += 4;
+ writeDouble: function(val) {
+ this.realloc(8);
+ ieee754.write(this.buf, val, this.pos, true, 52, 8);
+ this.pos += 8;
+ writeBytes: function(buffer) {
+ var len = buffer.length;
+ this.realloc(len);
+ for (var i = 0; i < len; i++) this.buf[this.pos++] = buffer[i];
+ writeRawMessage: function(fn, obj) {
+ this.pos++; // reserve 1 byte for short message length
+ // write the message directly to the buffer and see how much was written
+ fn(obj, this);
+ this.pos += len;
+ writeMessage: function(tag, fn, obj) {
+ this.writeTag(tag, Pbf.Bytes);
+ this.writeRawMessage(fn, obj);
+ writePackedVarint: function(tag, arr) { this.writeMessage(tag, writePackedVarint, arr); },
+ writePackedSVarint: function(tag, arr) { this.writeMessage(tag, writePackedSVarint, arr); },
+ writePackedBoolean: function(tag, arr) { this.writeMessage(tag, writePackedBoolean, arr); },
+ writePackedFloat: function(tag, arr) { this.writeMessage(tag, writePackedFloat, arr); },
+ writePackedDouble: function(tag, arr) { this.writeMessage(tag, writePackedDouble, arr); },
+ writePackedFixed32: function(tag, arr) { this.writeMessage(tag, writePackedFixed32, arr); },
+ writePackedSFixed32: function(tag, arr) { this.writeMessage(tag, writePackedSFixed32, arr); },
+ writePackedFixed64: function(tag, arr) { this.writeMessage(tag, writePackedFixed64, arr); },
+ writePackedSFixed64: function(tag, arr) { this.writeMessage(tag, writePackedSFixed64, arr); },
+ writeBytesField: function(tag, buffer) {
+ this.writeBytes(buffer);
+ writeFixed32Field: function(tag, val) {
+ this.writeTag(tag, Pbf.Fixed32);
+ this.writeFixed32(val);
+ writeSFixed32Field: function(tag, val) {
+ this.writeSFixed32(val);
+ writeFixed64Field: function(tag, val) {
+ this.writeTag(tag, Pbf.Fixed64);
+ this.writeFixed64(val);
+ writeSFixed64Field: function(tag, val) {
+ this.writeSFixed64(val);
+ writeVarintField: function(tag, val) {
+ this.writeTag(tag, Pbf.Varint);
+ this.writeVarint(val);
+ writeSVarintField: function(tag, val) {
+ this.writeSVarint(val);
+ writeStringField: function(tag, str) {
+ this.writeString(str);
+ writeFloatField: function(tag, val) {
+ this.writeFloat(val);
+ writeDoubleField: function(tag, val) {
+ this.writeDouble(val);
+ writeBooleanField: function(tag, val) {
+ this.writeVarintField(tag, Boolean(val));
+function readVarintRemainder(l, s, p) {
+ var buf = p.buf,
+ h, b;
+ b = buf[p.pos++]; h = (b & 0x70) >> 4; if (b < 0x80) return toNum(l, h, s);
+ b = buf[p.pos++]; h |= (b & 0x7f) << 3; if (b < 0x80) return toNum(l, h, s);
+ b = buf[p.pos++]; h |= (b & 0x7f) << 10; if (b < 0x80) return toNum(l, h, s);
+ b = buf[p.pos++]; h |= (b & 0x7f) << 17; if (b < 0x80) return toNum(l, h, s);
+ b = buf[p.pos++]; h |= (b & 0x7f) << 24; if (b < 0x80) return toNum(l, h, s);
+ b = buf[p.pos++]; h |= (b & 0x01) << 31; if (b < 0x80) return toNum(l, h, s);
+ throw new Error('Expected varint not more than 10 bytes');
+function readPackedEnd(pbf) {
+ return pbf.type === Pbf.Bytes ?
+ pbf.readVarint() + pbf.pos : pbf.pos + 1;
+function toNum(low, high, isSigned) {
+ if (isSigned) {
+ return high * 0x100000000 + (low >>> 0);
+ return ((high >>> 0) * 0x100000000) + (low >>> 0);
+function writeBigVarint(val, pbf) {
+ var low, high;
+ if (val >= 0) {
+ low = (val % 0x100000000) | 0;
+ high = (val / 0x100000000) | 0;
+ } else {
+ low = ~(-val % 0x100000000);
+ high = ~(-val / 0x100000000);
+ if (low ^ 0xffffffff) {
+ low = (low + 1) | 0;
+ } else {
+ low = 0;
+ high = (high + 1) | 0;
+ if (val >= 0x10000000000000000 || val < -0x10000000000000000) {
+ throw new Error('Given varint doesn\'t fit into 10 bytes');
+ pbf.realloc(10);
+ writeBigVarintLow(low, high, pbf);
+ writeBigVarintHigh(high, pbf);
+function writeBigVarintLow(low, high, pbf) {
+ pbf.buf[pbf.pos++] = low & 0x7f | 0x80; low >>>= 7;
+ pbf.buf[pbf.pos] = low & 0x7f;
+function writeBigVarintHigh(high, pbf) {
+ var lsb = (high & 0x07) << 4;
+ pbf.buf[pbf.pos++] |= lsb | ((high >>>= 3) ? 0x80 : 0); if (!high) return;
+ pbf.buf[pbf.pos++] = high & 0x7f | ((high >>>= 7) ? 0x80 : 0); if (!high) return;
+ pbf.buf[pbf.pos++] = high & 0x7f;
+function makeRoomForExtraLength(startPos, len, pbf) {
+ var extraLen =
+ len <= 0x3fff ? 1 :
+ len <= 0x1fffff ? 2 :
+ len <= 0xfffffff ? 3 : Math.ceil(Math.log(len) / (Math.LN2 * 7));
+ // if 1 byte isn't enough for encoding message length, shift the data to the right
+ pbf.realloc(extraLen);
+ for (var i = pbf.pos - 1; i >= startPos; i--) pbf.buf[i + extraLen] = pbf.buf[i];
+function writePackedVarint(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeVarint(arr[i]); }
+function writePackedSVarint(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeSVarint(arr[i]); }
+function writePackedFloat(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeFloat(arr[i]); }
+function writePackedDouble(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeDouble(arr[i]); }
+function writePackedBoolean(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeBoolean(arr[i]); }
+function writePackedFixed32(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeFixed32(arr[i]); }
+function writePackedSFixed32(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeSFixed32(arr[i]); }
+function writePackedFixed64(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeFixed64(arr[i]); }
+function writePackedSFixed64(arr, pbf) { for (var i = 0; i < arr.length; i++) pbf.writeSFixed64(arr[i]); }
+// Buffer code below from https://github.com/feross/buffer, MIT-licensed
+function readUInt32(buf, pos) {
+ return ((buf[pos]) |
+ (buf[pos + 1] << 8) |
+ (buf[pos + 2] << 16)) +
+ (buf[pos + 3] * 0x1000000);
+function writeInt32(buf, val, pos) {
+ buf[pos] = val;
+ buf[pos + 1] = (val >>> 8);
+ buf[pos + 2] = (val >>> 16);
+ buf[pos + 3] = (val >>> 24);
+function readInt32(buf, pos) {
+ (buf[pos + 3] << 24);
+function readUtf8(buf, pos, end) {
+ var str = '';
+ var i = pos;
+ while (i < end) {
+ var b0 = buf[i];
+ var c = null; // codepoint
+ var bytesPerSequence =
+ b0 > 0xEF ? 4 :
+ b0 > 0xDF ? 3 :
+ b0 > 0xBF ? 2 : 1;
+ if (i + bytesPerSequence > end) break;
+ var b1, b2, b3;
+ if (bytesPerSequence === 1) {
+ if (b0 < 0x80) {
+ c = b0;
+ } else if (bytesPerSequence === 2) {
+ b1 = buf[i + 1];
+ if ((b1 & 0xC0) === 0x80) {
+ c = (b0 & 0x1F) << 0x6 | (b1 & 0x3F);
+ if (c <= 0x7F) {
+ c = null;
+ } else if (bytesPerSequence === 3) {
+ b1 = buf[i + 1];
+ b2 = buf[i + 2];
+ if ((b1 & 0xC0) === 0x80 && (b2 & 0xC0) === 0x80) {
+ c = (b0 & 0xF) << 0xC | (b1 & 0x3F) << 0x6 | (b2 & 0x3F);
+ if (c <= 0x7FF || (c >= 0xD800 && c <= 0xDFFF)) {
+ c = null;
+ } else if (bytesPerSequence === 4) {
+ b1 = buf[i + 1];
+ b2 = buf[i + 2];
+ b3 = buf[i + 3];
+ if ((b1 & 0xC0) === 0x80 && (b2 & 0xC0) === 0x80 && (b3 & 0xC0) === 0x80) {
+ c = (b0 & 0xF) << 0x12 | (b1 & 0x3F) << 0xC | (b2 & 0x3F) << 0x6 | (b3 & 0x3F);
+ if (c <= 0xFFFF || c >= 0x110000) {
+ c = null;
+ if (c === null) {
+ c = 0xFFFD;
+ bytesPerSequence = 1;
+ } else if (c > 0xFFFF) {
+ c -= 0x10000;
+ str += String.fromCharCode(c >>> 10 & 0x3FF | 0xD800);
+ c = 0xDC00 | c & 0x3FF;
+ str += String.fromCharCode(c);
+ i += bytesPerSequence;
+ return str;
+function writeUtf8(buf, str, pos) {
+ for (var i = 0, c, lead; i < str.length; i++) {
+ c = str.charCodeAt(i); // code point
+ if (c > 0xD7FF && c < 0xE000) {
+ if (lead) {
+ if (c < 0xDC00) {
+ buf[pos++] = 0xEF;
+ buf[pos++] = 0xBF;
+ buf[pos++] = 0xBD;
+ lead = c;
+ continue;
+ } else {
+ c = lead - 0xD800 << 10 | c - 0xDC00 | 0x10000;
+ lead = null;
+ } else {
+ if (c > 0xDBFF || (i + 1 === str.length)) {
+ } else {
+ lead = c;
+ continue;
+ } else if (lead) {
+ lead = null;
+ if (c < 0x80) {
+ buf[pos++] = c;
+ } else {
+ if (c < 0x800) {
+ buf[pos++] = c >> 0x6 | 0xC0;
+ } else {
+ if (c < 0x10000) {
+ buf[pos++] = c >> 0xC | 0xE0;
+ } else {
+ buf[pos++] = c >> 0x12 | 0xF0;
+ buf[pos++] = c >> 0xC & 0x3F | 0x80;
+ buf[pos++] = c >> 0x6 & 0x3F | 0x80;
+ buf[pos++] = c & 0x3F | 0x80;
+ return pos;
+},{"ieee754":1}]},{},[2])(2)
+ol.ext.pbf = module.exports;
+goog.provide('ol.ext.vectortile');
+ol.ext.vectortile;
+(function() {
+var exports = {};
+var define;
+ * @fileoverview
+(function(f){if(typeof exports==="object"&&typeof module!=="undefined"){module.exports=f()}else if(typeof define==="function"&&define.amd){define([],f)}else{var g;if(typeof window!=="undefined"){g=window}else if(typeof global!=="undefined"){g=global}else if(typeof self!=="undefined"){g=self}else{g=this}g.vectortile = f()}})(function(){var define,module,exports;return (function e(t,n,r){function s(o,u){if(!n[o]){if(!t[o]){var a=typeof require=="function"&&require;if(!u&&a)return a(o,!0);if(i)return i(o,!0);var f=new Error("Cannot find module '"+o+"'");throw f.code="MODULE_NOT_FOUND",f}var l=n[o]={exports:{}};t[o][0].call(l.exports,function(e){var n=t[o][1][e];return s(n?n:e)},l,l.exports,e,t,n,r)}return n[o].exports}var i=typeof require=="function"&&require;for(var o=0;o<r.length;o++)s(r[o]);return s})({1:[function(_dereq_,module,exports){
+'use strict';
+module.exports = Point;
+function Point(x, y) {
+ this.x = x;
+ this.y = y;
+Point.prototype = {
+ clone: function() { return new Point(this.x, this.y); },
+ add: function(p) { return this.clone()._add(p); },
+ sub: function(p) { return this.clone()._sub(p); },
+ mult: function(k) { return this.clone()._mult(k); },
+ div: function(k) { return this.clone()._div(k); },
+ rotate: function(a) { return this.clone()._rotate(a); },
+ matMult: function(m) { return this.clone()._matMult(m); },
+ unit: function() { return this.clone()._unit(); },
+ perp: function() { return this.clone()._perp(); },
+ round: function() { return this.clone()._round(); },
+ mag: function() {
+ return Math.sqrt(this.x * this.x + this.y * this.y);
+ equals: function(p) {
+ return this.x === p.x &&
+ this.y === p.y;
+ dist: function(p) {
+ return Math.sqrt(this.distSqr(p));
+ distSqr: function(p) {
+ var dx = p.x - this.x,
+ dy = p.y - this.y;
+ return dx * dx + dy * dy;
+ angle: function() {
+ return Math.atan2(this.y, this.x);
+ angleTo: function(b) {
+ return Math.atan2(this.y - b.y, this.x - b.x);
+ angleWith: function(b) {
+ return this.angleWithSep(b.x, b.y);
+ // Find the angle of the two vectors, solving the formula for the cross product a x b = |a||b|sin(θ) for θ.
+ angleWithSep: function(x, y) {
+ this.x * y - this.y * x,
+ this.x * x + this.y * y);
+ _matMult: function(m) {
+ var x = m[0] * this.x + m[1] * this.y,
+ y = m[2] * this.x + m[3] * this.y;
+ this.x = x;
+ this.y = y;
+ return this;
+ _add: function(p) {
+ this.x += p.x;
+ this.y += p.y;
+ return this;
+ _sub: function(p) {
+ this.x -= p.x;
+ this.y -= p.y;
+ return this;
+ _mult: function(k) {
+ this.x *= k;
+ this.y *= k;
+ return this;
+ _div: function(k) {
+ this.x /= k;
+ this.y /= k;
+ return this;
+ _unit: function() {
+ this._div(this.mag());
+ return this;
+ _perp: function() {
+ var y = this.y;
+ this.y = this.x;
+ this.x = -y;
+ return this;
+ _rotate: function(angle) {
+ var cos = Math.cos(angle),
+ sin = Math.sin(angle),
+ x = cos * this.x - sin * this.y,
+ y = sin * this.x + cos * this.y;
+ this.x = x;
+ this.y = y;
+ return this;
+ _round: function() {
+ this.x = Math.round(this.x);
+ this.y = Math.round(this.y);
+ return this;
+// constructs Point from an array if necessary
+Point.convert = function (a) {
+ if (a instanceof Point) {
+ return a;
+ if (Array.isArray(a)) {
+ return new Point(a[0], a[1]);
+ return a;
+module.exports.VectorTile = _dereq_('./lib/vectortile.js');
+module.exports.VectorTileFeature = _dereq_('./lib/vectortilefeature.js');
+module.exports.VectorTileLayer = _dereq_('./lib/vectortilelayer.js');
+},{"./lib/vectortile.js":3,"./lib/vectortilefeature.js":4,"./lib/vectortilelayer.js":5}],3:[function(_dereq_,module,exports){
+'use strict';
+var VectorTileLayer = _dereq_('./vectortilelayer');
+module.exports = VectorTile;
+function VectorTile(pbf, end) {
+ this.layers = pbf.readFields(readTile, {}, end);
+function readTile(tag, layers, pbf) {
+ if (tag === 3) {
+ var layer = new VectorTileLayer(pbf, pbf.readVarint() + pbf.pos);
+ if (layer.length) layers[layer.name] = layer;
+},{"./vectortilelayer":5}],4:[function(_dereq_,module,exports){
+'use strict';
+var Point = _dereq_('point-geometry');
+module.exports = VectorTileFeature;
+function VectorTileFeature(pbf, end, extent, keys, values) {
+ // Public
+ this.properties = {};
+ this.extent = extent;
+ this.type = 0;
+ // Private
+ this._pbf = pbf;
+ this._geometry = -1;
+ this._keys = keys;
+ this._values = values;
+ pbf.readFields(readFeature, this, end);
+function readFeature(tag, feature, pbf) {
+ if (tag == 1) feature.id = pbf.readVarint();
+ else if (tag == 2) readTag(pbf, feature);
+ else if (tag == 3) feature.type = pbf.readVarint();
+ else if (tag == 4) feature._geometry = pbf.pos;
+function readTag(pbf, feature) {
+ var end = pbf.readVarint() + pbf.pos;
+ while (pbf.pos < end) {
+ var key = feature._keys[pbf.readVarint()],
+ value = feature._values[pbf.readVarint()];
+ feature.properties[key] = value;
+VectorTileFeature.types = ['Unknown', 'Point', 'LineString', 'Polygon'];
+VectorTileFeature.prototype.loadGeometry = function() {
+ var pbf = this._pbf;
+ pbf.pos = this._geometry;
+ var end = pbf.readVarint() + pbf.pos,
+ cmd = 1,
+ length = 0,
+ x = 0,
+ y = 0,
+ lines = [],
+ line;
+ if (!length) {
+ var cmdLen = pbf.readVarint();
+ cmd = cmdLen & 0x7;
+ length = cmdLen >> 3;
+ length--;
+ if (cmd === 1 || cmd === 2) {
+ x += pbf.readSVarint();
+ y += pbf.readSVarint();
+ if (cmd === 1) { // moveTo
+ if (line) lines.push(line);
+ line = [];
+ line.push(new Point(x, y));
+ } else if (cmd === 7) {
+ // Workaround for https://github.com/mapbox/mapnik-vector-tile/issues/90
+ if (line) {
+ line.push(line[0].clone()); // closePolygon
+ } else {
+ throw new Error('unknown command ' + cmd);
+ return lines;
+VectorTileFeature.prototype.bbox = function() {
+ cmd = 1,
+ length = 0,
+ x = 0,
+ y = 0,
+ x1 = Infinity,
+ x2 = -Infinity,
+ y1 = Infinity,
+ y2 = -Infinity;
+ if (!length) {
+ length--;
+ if (x < x1) x1 = x;
+ if (x > x2) x2 = x;
+ if (y < y1) y1 = y;
+ if (y > y2) y2 = y;
+ } else if (cmd !== 7) {
+ return [x1, y1, x2, y2];
+VectorTileFeature.prototype.toGeoJSON = function(x, y, z) {
+ var size = this.extent * Math.pow(2, z),
+ x0 = this.extent * x,
+ y0 = this.extent * y,
+ coords = this.loadGeometry(),
+ type = VectorTileFeature.types[this.type],
+ i, j;
+ function project(line) {
+ for (var j = 0; j < line.length; j++) {
+ var p = line[j], y2 = 180 - (p.y + y0) * 360 / size;
+ line[j] = [
+ (p.x + x0) * 360 / size - 180,
+ 360 / Math.PI * Math.atan(Math.exp(y2 * Math.PI / 180)) - 90
+ switch (this.type) {
+ case 1:
+ var points = [];
+ for (i = 0; i < coords.length; i++) {
+ points[i] = coords[i][0];
+ coords = points;
+ project(coords);
+ break;
+ case 2:
+ project(coords[i]);
+ break;
+ case 3:
+ coords = classifyRings(coords);
+ for (j = 0; j < coords[i].length; j++) {
+ project(coords[i][j]);
+ break;
+ if (coords.length === 1) {
+ coords = coords[0];
+ } else {
+ type = 'Multi' + type;
+ var result = {
+ type: "Feature",
+ geometry: {
+ type: type,
+ coordinates: coords
+ properties: this.properties
+ if ('id' in this) {
+ result.id = this.id;
+ return result;
+// classifies an array of rings into polygons with outer rings and holes
+function classifyRings(rings) {
+ var len = rings.length;
+ if (len <= 1) return [rings];
+ var polygons = [],
+ polygon,
+ ccw;
+ for (var i = 0; i < len; i++) {
+ var area = signedArea(rings[i]);
+ if (area === 0) continue;
+ if (ccw === undefined) ccw = area < 0;
+ if (ccw === area < 0) {
+ if (polygon) polygons.push(polygon);
+ polygon = [rings[i]];
+ } else {
+ polygon.push(rings[i]);
+ return polygons;
+function signedArea(ring) {
+ var sum = 0;
+ for (var i = 0, len = ring.length, j = len - 1, p1, p2; i < len; j = i++) {
+ p1 = ring[i];
+ p2 = ring[j];
+ sum += (p2.x - p1.x) * (p1.y + p2.y);
+ return sum;
+},{"point-geometry":1}],5:[function(_dereq_,module,exports){
+'use strict';
+var VectorTileFeature = _dereq_('./vectortilefeature.js');
+module.exports = VectorTileLayer;
+function VectorTileLayer(pbf, end) {
+ // Public
+ this.version = 1;
+ this.name = null;
+ this.extent = 4096;
+ this.length = 0;
+ // Private
+ this._pbf = pbf;
+ this._keys = [];
+ this._values = [];
+ this._features = [];
+ pbf.readFields(readLayer, this, end);
+ this.length = this._features.length;
+function readLayer(tag, layer, pbf) {
+ if (tag === 15) layer.version = pbf.readVarint();
+ else if (tag === 1) layer.name = pbf.readString();
+ else if (tag === 5) layer.extent = pbf.readVarint();
+ else if (tag === 2) layer._features.push(pbf.pos);
+ else if (tag === 3) layer._keys.push(pbf.readString());
+ else if (tag === 4) layer._values.push(readValueMessage(pbf));
+function readValueMessage(pbf) {
+ var value = null,
+ end = pbf.readVarint() + pbf.pos;
+ var tag = pbf.readVarint() >> 3;
+ value = tag === 1 ? pbf.readString() :
+ tag === 2 ? pbf.readFloat() :
+ tag === 3 ? pbf.readDouble() :
+ tag === 4 ? pbf.readVarint64() :
+ tag === 5 ? pbf.readVarint() :
+ tag === 6 ? pbf.readSVarint() :
+ tag === 7 ? pbf.readBoolean() : null;
+ return value;
+// return feature `i` from this layer as a `VectorTileFeature`
+VectorTileLayer.prototype.feature = function(i) {
+ if (i < 0 || i >= this._features.length) throw new Error('feature index out of bounds');
+ this._pbf.pos = this._features[i];
+ var end = this._pbf.readVarint() + this._pbf.pos;
+ return new VectorTileFeature(this._pbf, end, this.extent, this._keys, this._values);
+},{"./vectortilefeature.js":4}]},{},[2])(2)
+ol.ext.vectortile = module.exports;
+goog.provide('ol.render.Feature');
+goog.require('ol');
+goog.require('ol.extent');
+goog.require('ol.geom.GeometryType');
+ * Lightweight, read-only, {@link ol.Feature} and {@link ol.geom.Geometry} like
+ * structure, optimized for rendering and styling. Geometry access through the
+ * API is limited to getting the type and extent of the geometry.
+ * @constructor
+ * @param {ol.geom.GeometryType} type Geometry type.
+ * @param {Array.<number>} flatCoordinates Flat coordinates. These always need
+ * to be right-handed for polygons.
+ * @param {Array.<number>|Array.<Array.<number>>} ends Ends or Endss.
+ * @param {Object.<string, *>} properties Properties.
+ol.render.Feature = function(type, flatCoordinates, ends, properties) {
+ * @private
+ * @type {ol.Extent|undefined}
+ this.extent_;
+ * @private
+ * @type {ol.geom.GeometryType}
+ this.type_ = type;
+ * @private
+ * @type {Array.<number>}
+ this.flatCoordinates_ = flatCoordinates;
+ * @private
+ * @type {Array.<number>|Array.<Array.<number>>}
+ this.ends_ = ends;
+ * @private
+ * @type {Object.<string, *>}
+ this.properties_ = properties;
+ * Get a feature property by its key.
+ * @param {string} key Key
+ * @return {*} Value for the requested key.
+ * @api
+ol.render.Feature.prototype.get = function(key) {
+ return this.properties_[key];
+ * @return {Array.<number>|Array.<Array.<number>>} Ends or endss.
+ol.render.Feature.prototype.getEnds = function() {
+ return this.ends_;
+ * Get the extent of this feature's geometry.
+ * @return {ol.Extent} Extent.
+ * @api
+ol.render.Feature.prototype.getExtent = function() {
+ if (!this.extent_) {
+ this.extent_ = this.type_ === ol.geom.GeometryType.POINT ?
+ ol.extent.createOrUpdateFromCoordinate(this.flatCoordinates_) :
+ ol.extent.createOrUpdateFromFlatCoordinates(
+ this.flatCoordinates_, 0, this.flatCoordinates_.length, 2);
+ return this.extent_;
+ * @return {Array.<number>} Flat coordinates.
+ol.render.Feature.prototype.getOrientedFlatCoordinates = function() {
+ return this.flatCoordinates_;
+ol.render.Feature.prototype.getFlatCoordinates =
+ ol.render.Feature.prototype.getOrientedFlatCoordinates;
+ * Get the feature for working with its geometry.
+ * @return {ol.render.Feature} Feature.
+ * @api
+ol.render.Feature.prototype.getGeometry = function() {
+ return this;
+ * Get the feature properties.
+ * @return {Object.<string, *>} Feature properties.
+ * @api
+ol.render.Feature.prototype.getProperties = function() {
+ return this.properties_;
+ol.render.Feature.prototype.getSimplifiedGeometry =
+ ol.render.Feature.prototype.getGeometry;
+ * @return {number} Stride.
+ol.render.Feature.prototype.getStride = function() {
+ return 2;
+ * @return {undefined}
+ol.render.Feature.prototype.getStyleFunction = ol.nullFunction;
+ * Get the type of this feature's geometry.
+ * @return {ol.geom.GeometryType} Geometry type.
+ * @api
+ol.render.Feature.prototype.getType = function() {
+ return this.type_;
+//FIXME Implement projection handling
+goog.provide('ol.format.MVT');
+goog.require('ol.ext.pbf');
+goog.require('ol.ext.vectortile');
+goog.require('ol.format.Feature');
+goog.require('ol.format.FormatType');
+goog.require('ol.geom.GeometryLayout');
+goog.require('ol.geom.LineString');
+goog.require('ol.geom.MultiLineString');
+goog.require('ol.geom.MultiPoint');
+goog.require('ol.geom.Point');
+goog.require('ol.geom.Polygon');
+goog.require('ol.proj.Projection');
+goog.require('ol.proj.Units');
+goog.require('ol.render.Feature');
+ * @classdesc
+ * Feature format for reading data in the Mapbox MVT format.
+ * @constructor
+ * @extends {ol.format.Feature}
+ * @param {olx.format.MVTOptions=} opt_options Options.
+ * @api
+ol.format.MVT = function(opt_options) {
+ ol.format.Feature.call(this);
+ var options = opt_options ? opt_options : {};
+ * @type {ol.proj.Projection}
+ this.defaultDataProjection = new ol.proj.Projection({
+ code: '',
+ units: ol.proj.Units.TILE_PIXELS
+ * @private
+ * @type {function((ol.geom.Geometry|Object.<string, *>)=)|
+ * function(ol.geom.GeometryType,Array.<number>,
+ * (Array.<number>|Array.<Array.<number>>),Object.<string, *>)}
+ this.featureClass_ = options.featureClass ?
+ options.featureClass : ol.render.Feature;
+ * @private
+ * @type {string|undefined}
+ this.geometryName_ = options.geometryName;
+ * @private
+ * @type {string}
+ this.layerName_ = options.layerName ? options.layerName : 'layer';
+ * @private
+ * @type {Array.<string>}
+ this.layers_ = options.layers ? options.layers : null;
+ol.inherits(ol.format.MVT, ol.format.Feature);
+ * @inheritDoc
+ol.format.MVT.prototype.getType = function() {
+ return ol.format.FormatType.ARRAY_BUFFER;
+ * @private
+ * @param {Object} rawFeature Raw Mapbox feature.
+ * @param {string} layer Layer.
+ol.format.MVT.prototype.readFeature_ = function(
+ rawFeature, layer, opt_options) {
+ var feature = new this.featureClass_();
+ var id = rawFeature.id;
+ var values = rawFeature.properties;
+ values[this.layerName_] = layer;
+ if (this.geometryName_) {
+ feature.setGeometryName(this.geometryName_);
+ var geometry = ol.format.Feature.transformWithOptions(
+ ol.format.MVT.readGeometry_(rawFeature), false,
+ this.adaptOptions(opt_options));
+ feature.setId(id);
+ feature.setProperties(values);
+ return feature;
+ * @private
+ol.format.MVT.prototype.readRenderFeature_ = function(rawFeature, layer) {
+ var coords = rawFeature.loadGeometry();
+ var ends = [];
+ var flatCoordinates = [];
+ ol.format.MVT.calculateFlatCoordinates_(coords, flatCoordinates, ends);
+ var type = rawFeature.type;
+ /** @type {ol.geom.GeometryType} */
+ var geometryType;
+ if (type === 1) {
+ geometryType = coords.length === 1 ?
+ ol.geom.GeometryType.POINT : ol.geom.GeometryType.MULTI_POINT;
+ } else if (type === 2) {
+ geometryType = ol.geom.GeometryType.LINE_STRING;
+ } else {
+ geometryType = ol.geom.GeometryType.MULTI_LINE_STRING;
+ } else if (type === 3) {
+ geometryType = ol.geom.GeometryType.POLYGON;
+ return new this.featureClass_(geometryType, flatCoordinates, ends, values);
+ * @inheritDoc
+ * @api
+ol.format.MVT.prototype.readFeatures = function(source, opt_options) {
+ var layers = this.layers_;
+ var pbf = new ol.ext.pbf(/** @type {ArrayBuffer} */ (source));
+ var tile = new ol.ext.vectortile.VectorTile(pbf);
+ var features = [];
+ var featureClass = this.featureClass_;
+ var layer, feature;
+ for (var name in tile.layers) {
+ if (layers && layers.indexOf(name) == -1) {
+ continue;
+ layer = tile.layers[name];
+ for (var i = 0, ii = layer.length; i < ii; ++i) {
+ if (featureClass === ol.render.Feature) {
+ feature = this.readRenderFeature_(layer.feature(i), name);
+ } else {
+ feature = this.readFeature_(layer.feature(i), name, opt_options);
+ features.push(feature);
+ return features;
+ * @inheritDoc
+ * @api
+ol.format.MVT.prototype.readProjection = function(source) {
+ return this.defaultDataProjection;
+ * Sets the layers that features will be read from.
+ * @param {Array.<string>} layers Layers.
+ * @api
+ol.format.MVT.prototype.setLayers = function(layers) {
+ this.layers_ = layers;
+ * @private
+ * @param {Object} coords Raw feature coordinates.
+ * @param {Array.<number>} flatCoordinates Flat coordinates to be populated by
+ * this function.
+ * @param {Array.<number>} ends Ends to be populated by this function.
+ol.format.MVT.calculateFlatCoordinates_ = function(
+ coords, flatCoordinates, ends) {
+ var end = 0;
+ for (var i = 0, ii = coords.length; i < ii; ++i) {
+ var line = coords[i];
+ var j, jj;
+ for (j = 0, jj = line.length; j < jj; ++j) {
+ var coord = line[j];
+ // Non-tilespace coords can be calculated here when a TileGrid and
+ // TileCoord are known.
+ flatCoordinates.push(coord.x, coord.y);
+ end += 2 * j;
+ ends.push(end);
+ * @private
+ * @return {ol.geom.Geometry} Geometry.
+ol.format.MVT.readGeometry_ = function(rawFeature) {
+ if (type === 0) {
+ return null;
+ var ends = [];
+ var geom;
+ if (type === 1) {
+ geom = coords.length === 1 ?
+ new ol.geom.Point(null) : new ol.geom.MultiPoint(null);
+ geom = new ol.geom.LineString(null);
+ } else {
+ geom = new ol.geom.MultiLineString(null);
+ geom = new ol.geom.Polygon(null);
+ geom.setFlatCoordinates(ol.geom.GeometryLayout.XY, flatCoordinates,
+ ends);
+ return geom;
+ * Not implemented.
+ * @override
+ol.format.MVT.prototype.readFeature = function() {};
+ * @override
+ol.format.MVT.prototype.readGeometry = function() {};
+ * @override
+ol.format.MVT.prototype.writeFeature = function() {};
+ * @override
+ol.format.MVT.prototype.writeGeometry = function() {};
+ * @override
+ol.format.MVT.prototype.writeFeatures = function() {};
+// FIXME add typedef for stack state objects
+goog.provide('ol.format.OSMXML');
+goog.require('ol.array');
+goog.require('ol.Feature');
+goog.require('ol.format.XMLFeature');
+goog.require('ol.obj');
+goog.require('ol.proj');
+goog.require('ol.xml');
+ * @classdesc
+ * [OSMXML format](http://wiki.openstreetmap.org/wiki/OSM_XML).
+ * @constructor
+ * @extends {ol.format.XMLFeature}
+ * @api
+ol.format.OSMXML = function() {
+ ol.format.XMLFeature.call(this);
+ * @inheritDoc
+ this.defaultDataProjection = ol.proj.get('EPSG:4326');
+ol.inherits(ol.format.OSMXML, ol.format.XMLFeature);
+ * @param {Node} node Node.
+ * @param {Array.<*>} objectStack Object stack.
+ * @private
+ol.format.OSMXML.readNode_ = function(node, objectStack) {
+ var options = /** @type {olx.format.ReadOptions} */ (objectStack[0]);
+ var state = /** @type {Object} */ (objectStack[objectStack.length - 1]);
+ var id = node.getAttribute('id');
+ /** @type {ol.Coordinate} */
+ var coordinates = [
+ parseFloat(node.getAttribute('lon')),
+ parseFloat(node.getAttribute('lat'))
+ state.nodes[id] = coordinates;
+ var values = ol.xml.pushParseAndPop({
+ tags: {}
+ }, ol.format.OSMXML.NODE_PARSERS_, node, objectStack);
+ if (!ol.obj.isEmpty(values.tags)) {
+ var geometry = new ol.geom.Point(coordinates);
+ ol.format.Feature.transformWithOptions(geometry, false, options);
+ var feature = new ol.Feature(geometry);
+ feature.setProperties(values.tags);
+ state.features.push(feature);
+ * @private
+ol.format.OSMXML.readWay_ = function(node, objectStack) {
+ ndrefs: [],
+ tags: {}
+ }, ol.format.OSMXML.WAY_PARSERS_, node, objectStack);
+ /** @type {Array.<number>} */
+ for (var i = 0, ii = values.ndrefs.length; i < ii; i++) {
+ var point = state.nodes[values.ndrefs[i]];
+ ol.array.extend(flatCoordinates, point);
+ var geometry;
+ if (values.ndrefs[0] == values.ndrefs[values.ndrefs.length - 1]) {
+ // closed way
+ geometry = new ol.geom.Polygon(null);
+ geometry.setFlatCoordinates(ol.geom.GeometryLayout.XY, flatCoordinates,
+ [flatCoordinates.length]);
+ } else {
+ geometry = new ol.geom.LineString(null);
+ geometry.setFlatCoordinates(ol.geom.GeometryLayout.XY, flatCoordinates);
+ * @private
+ol.format.OSMXML.readNd_ = function(node, objectStack) {
+ var values = /** @type {Object} */ (objectStack[objectStack.length - 1]);
+ values.ndrefs.push(node.getAttribute('ref'));
+ * @private
+ol.format.OSMXML.readTag_ = function(node, objectStack) {
+ values.tags[node.getAttribute('k')] = node.getAttribute('v');
+ * @const
+ * @private
+ol.format.OSMXML.NAMESPACE_URIS_ = [
+ null
+ * @const
+ * @type {Object.<string, Object.<string, ol.XmlParser>>}
+ * @private
+ol.format.OSMXML.WAY_PARSERS_ = ol.xml.makeStructureNS(
+ ol.format.OSMXML.NAMESPACE_URIS_, {
+ 'nd': ol.format.OSMXML.readNd_,
+ 'tag': ol.format.OSMXML.readTag_
+ * @const
+ * @private
+ol.format.OSMXML.PARSERS_ = ol.xml.makeStructureNS(
+ 'node': ol.format.OSMXML.readNode_,
+ 'way': ol.format.OSMXML.readWay_
+ * @const
+ * @private
+ol.format.OSMXML.NODE_PARSERS_ = ol.xml.makeStructureNS(
+ * Read all features from an OSM source.
+ * @function
+ * @param {Document|Node|Object|string} source Source.
+ * @param {olx.format.ReadOptions=} opt_options Read options.
+ * @return {Array.<ol.Feature>} Features.
+ * @api
+ol.format.OSMXML.prototype.readFeatures;
+ * @inheritDoc
+ol.format.OSMXML.prototype.readFeaturesFromNode = function(node, opt_options) {
+ var options = this.getReadOptions(node, opt_options);
+ if (node.localName == 'osm') {
+ var state = ol.xml.pushParseAndPop({
+ nodes: {},
+ features: []
+ }, ol.format.OSMXML.PARSERS_, node, [options]);
+ if (state.features) {
+ return state.features;
+ return [];
+ * Read the projection from an OSM source.
+ * @function
+ * @return {ol.proj.Projection} Projection.
+ * @api
+ol.format.OSMXML.prototype.readProjection;
+ * @inheritDoc
+ol.format.OSMXML.prototype.writeFeatureNode = function(feature, opt_options) {};
+ * @inheritDoc
+ol.format.OSMXML.prototype.writeFeaturesNode = function(features, opt_options) {};
+ * @inheritDoc
+ol.format.OSMXML.prototype.writeGeometryNode = function(geometry, opt_options) {};
+goog.provide('ol.format.XLink');
+ * @const
+ * @type {string}
+ol.format.XLink.NAMESPACE_URI = 'http://www.w3.org/1999/xlink';
+ * @return {boolean|undefined} Boolean.
+ol.format.XLink.readHref = function(node) {
+ return node.getAttributeNS(ol.format.XLink.NAMESPACE_URI, 'href');
+goog.provide('ol.format.XML');
+ * @classdesc
+ * Generic format for reading non-feature XML data
+ * @constructor
+ * @abstract
+ * @struct
+ol.format.XML = function() {
+ * @param {Document|Node|string} source Source.
+ * @return {Object} The parsed result.
+ol.format.XML.prototype.read = function(source) {
+ if (ol.xml.isDocument(source)) {
+ return this.readFromDocument(/** @type {Document} */ (source));
+ } else if (ol.xml.isNode(source)) {
+ return this.readFromNode(/** @type {Node} */ (source));
+ } else if (typeof source === 'string') {
+ var doc = ol.xml.parse(source);
+ return this.readFromDocument(doc);
+ } else {
+ return null;
+ * @abstract
+ * @param {Document} doc Document.
+ * @return {Object} Object
+ol.format.XML.prototype.readFromDocument = function(doc) {};
+ * @abstract
+ol.format.XML.prototype.readFromNode = function(node) {};
+goog.provide('ol.format.OWS');
+goog.require('ol.format.XLink');
+goog.require('ol.format.XML');
+goog.require('ol.format.XSD');
+ * @constructor
+ * @extends {ol.format.XML}
+ol.format.OWS = function() {
+ ol.format.XML.call(this);
+ol.inherits(ol.format.OWS, ol.format.XML);
+ * @inheritDoc
+ol.format.OWS.prototype.readFromDocument = function(doc) {
+ for (var n = doc.firstChild; n; n = n.nextSibling) {
+ if (n.nodeType == Node.ELEMENT_NODE) {
+ return this.readFromNode(n);
+ return null;
+ * @inheritDoc
+ol.format.OWS.prototype.readFromNode = function(node) {
+ var owsObject = ol.xml.pushParseAndPop({},
+ ol.format.OWS.PARSERS_, node, []);
+ return owsObject ? owsObject : null;
+ * @private
+ * @return {Object|undefined} The address.
+ol.format.OWS.readAddress_ = function(node, objectStack) {
+ return ol.xml.pushParseAndPop({},
+ ol.format.OWS.ADDRESS_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} The values.
+ol.format.OWS.readAllowedValues_ = function(node, objectStack) {
+ ol.format.OWS.ALLOWED_VALUES_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} The constraint.
+ol.format.OWS.readConstraint_ = function(node, objectStack) {
+ var name = node.getAttribute('name');
+ if (!name) {
+ return undefined;
+ return ol.xml.pushParseAndPop({'name': name},
+ ol.format.OWS.CONSTRAINT_PARSERS_, node,
+ objectStack);
+ * @private
+ * @return {Object|undefined} The contact info.
+ol.format.OWS.readContactInfo_ = function(node, objectStack) {
+ ol.format.OWS.CONTACT_INFO_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} The DCP.
+ol.format.OWS.readDcp_ = function(node, objectStack) {
+ ol.format.OWS.DCP_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} The GET object.
+ol.format.OWS.readGet_ = function(node, objectStack) {
+ var href = ol.format.XLink.readHref(node);
+ if (!href) {
+ return undefined;
+ return ol.xml.pushParseAndPop({'href': href},
+ ol.format.OWS.REQUEST_METHOD_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} The HTTP object.
+ol.format.OWS.readHttp_ = function(node, objectStack) {
+ return ol.xml.pushParseAndPop({}, ol.format.OWS.HTTP_PARSERS_,
+ node, objectStack);
+ * @private
+ * @return {Object|undefined} The operation.
+ol.format.OWS.readOperation_ = function(node, objectStack) {
+ var value = ol.xml.pushParseAndPop({},
+ ol.format.OWS.OPERATION_PARSERS_, node, objectStack);
+ if (!value) {
+ return undefined;
+ var object = /** @type {Object} */
+ (objectStack[objectStack.length - 1]);
+ object[name] = value;
+ * @private
+ * @return {Object|undefined} The operations metadata.
+ol.format.OWS.readOperationsMetadata_ = function(node,
+ objectStack) {
+ ol.format.OWS.OPERATIONS_METADATA_PARSERS_, node,
+ objectStack);
+ * @private
+ * @return {Object|undefined} The phone.
+ol.format.OWS.readPhone_ = function(node, objectStack) {
+ ol.format.OWS.PHONE_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} The service identification.
+ol.format.OWS.readServiceIdentification_ = function(node,
+ objectStack) {
+ {}, ol.format.OWS.SERVICE_IDENTIFICATION_PARSERS_, node,
+ objectStack);
+ * @private
+ * @return {Object|undefined} The service contact.
+ol.format.OWS.readServiceContact_ = function(node, objectStack) {
+ {}, ol.format.OWS.SERVICE_CONTACT_PARSERS_, node,
+ objectStack);
+ * @private
+ * @return {Object|undefined} The service provider.
+ol.format.OWS.readServiceProvider_ = function(node, objectStack) {
+ {}, ol.format.OWS.SERVICE_PROVIDER_PARSERS_, node,
+ objectStack);
+ * @private
+ * @return {string|undefined} The value.
+ol.format.OWS.readValue_ = function(node, objectStack) {
+ return ol.format.XSD.readString(node);
+ * @const
+ * @private
+ol.format.OWS.NAMESPACE_URIS_ = [
+ null,
+ 'http://www.opengis.net/ows/1.1'
+ * @const
+ * @private
+ol.format.OWS.PARSERS_ = ol.xml.makeStructureNS(
+ ol.format.OWS.NAMESPACE_URIS_, {
+ 'ServiceIdentification': ol.xml.makeObjectPropertySetter(
+ ol.format.OWS.readServiceIdentification_),
+ 'ServiceProvider': ol.xml.makeObjectPropertySetter(
+ ol.format.OWS.readServiceProvider_),
+ 'OperationsMetadata': ol.xml.makeObjectPropertySetter(
+ ol.format.OWS.readOperationsMetadata_)
+ * @const
+ * @private
+ol.format.OWS.ADDRESS_PARSERS_ = ol.xml.makeStructureNS(
+ 'DeliveryPoint': ol.xml.makeObjectPropertySetter(
+ ol.format.XSD.readString),
+ 'City': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'AdministrativeArea': ol.xml.makeObjectPropertySetter(
+ 'PostalCode': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'Country': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'ElectronicMailAddress': ol.xml.makeObjectPropertySetter(
+ * @const
+ * @private
+ol.format.OWS.ALLOWED_VALUES_PARSERS_ = ol.xml.makeStructureNS(
+ 'Value': ol.xml.makeObjectPropertyPusher(ol.format.OWS.readValue_)
+ * @const
+ * @private
+ol.format.OWS.CONSTRAINT_PARSERS_ = ol.xml.makeStructureNS(
+ 'AllowedValues': ol.xml.makeObjectPropertySetter(
+ ol.format.OWS.readAllowedValues_)
+ * @const
+ * @private
+ol.format.OWS.CONTACT_INFO_PARSERS_ = ol.xml.makeStructureNS(
+ 'Phone': ol.xml.makeObjectPropertySetter(ol.format.OWS.readPhone_),
+ 'Address': ol.xml.makeObjectPropertySetter(ol.format.OWS.readAddress_)
+ * @const
+ * @private
+ol.format.OWS.DCP_PARSERS_ = ol.xml.makeStructureNS(
+ 'HTTP': ol.xml.makeObjectPropertySetter(ol.format.OWS.readHttp_)
+ * @const
+ * @private
+ol.format.OWS.HTTP_PARSERS_ = ol.xml.makeStructureNS(
+ 'Get': ol.xml.makeObjectPropertyPusher(ol.format.OWS.readGet_),
+ 'Post': undefined // TODO
+ * @const
+ * @private
+ol.format.OWS.OPERATION_PARSERS_ = ol.xml.makeStructureNS(
+ 'DCP': ol.xml.makeObjectPropertySetter(ol.format.OWS.readDcp_)
+ * @const
+ * @private
+ol.format.OWS.OPERATIONS_METADATA_PARSERS_ = ol.xml.makeStructureNS(
+ 'Operation': ol.format.OWS.readOperation_
+ * @const
+ * @private
+ol.format.OWS.PHONE_PARSERS_ = ol.xml.makeStructureNS(
+ 'Voice': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'Facsimile': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString)
+ * @const
+ * @private
+ol.format.OWS.REQUEST_METHOD_PARSERS_ = ol.xml.makeStructureNS(
+ 'Constraint': ol.xml.makeObjectPropertyPusher(
+ ol.format.OWS.readConstraint_)
+ * @const
+ * @private
+ol.format.OWS.SERVICE_CONTACT_PARSERS_ =
+ 'IndividualName': ol.xml.makeObjectPropertySetter(
+ 'PositionName': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'ContactInfo': ol.xml.makeObjectPropertySetter(
+ ol.format.OWS.readContactInfo_)
+ * @const
+ * @private
+ol.format.OWS.SERVICE_IDENTIFICATION_PARSERS_ =
+ 'Title': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'ServiceTypeVersion': ol.xml.makeObjectPropertySetter(
+ 'ServiceType': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString)
+ * @const
+ * @private
+ol.format.OWS.SERVICE_PROVIDER_PARSERS_ =
+ 'ProviderName': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'ProviderSite': ol.xml.makeObjectPropertySetter(ol.format.XLink.readHref),
+ 'ServiceContact': ol.xml.makeObjectPropertySetter(
+ ol.format.OWS.readServiceContact_)
+goog.provide('ol.geom.flat.flip');
+ * @param {number} offset Offset.
+ * @param {number} end End.
+ * @param {number} stride Stride.
+ * @param {Array.<number>=} opt_dest Destination.
+ * @param {number=} opt_destOffset Destination offset.
+ol.geom.flat.flip.flipXY = function(flatCoordinates, offset, end, stride, opt_dest, opt_destOffset) {
+ var dest, destOffset;
+ if (opt_dest !== undefined) {
+ dest = opt_dest;
+ destOffset = opt_destOffset !== undefined ? opt_destOffset : 0;
+ } else {
+ dest = [];
+ destOffset = 0;
+ var j = offset;
+ while (j < end) {
+ var x = flatCoordinates[j++];
+ dest[destOffset++] = flatCoordinates[j++];
+ dest[destOffset++] = x;
+ for (var k = 2; k < stride; ++k) {
+ dest.length = destOffset;
+ return dest;
+goog.provide('ol.format.Polyline');
+goog.require('ol.asserts');
+goog.require('ol.format.TextFeature');
+goog.require('ol.geom.SimpleGeometry');
+goog.require('ol.geom.flat.flip');
+goog.require('ol.geom.flat.inflate');
+ * @classdesc
+ * Feature format for reading and writing data in the Encoded
+ * Polyline Algorithm Format.
+ * @constructor
+ * @extends {ol.format.TextFeature}
+ * @param {olx.format.PolylineOptions=} opt_options
+ * Optional configuration object.
+ * @api
+ol.format.Polyline = function(opt_options) {
+ ol.format.TextFeature.call(this);
+ * @inheritDoc
+ * @private
+ * @type {number}
+ this.factor_ = options.factor ? options.factor : 1e5;
+ * @private
+ * @type {ol.geom.GeometryLayout}
+ this.geometryLayout_ = options.geometryLayout ?
+ options.geometryLayout : ol.geom.GeometryLayout.XY;
+ol.inherits(ol.format.Polyline, ol.format.TextFeature);
+ * Encode a list of n-dimensional points and return an encoded string
+ * Attention: This function will modify the passed array!
+ * @param {Array.<number>} numbers A list of n-dimensional points.
+ * @param {number} stride The number of dimension of the points in the list.
+ * @param {number=} opt_factor The factor by which the numbers will be
+ * multiplied. The remaining decimal places will get rounded away.
+ * Default is `1e5`.
+ * @return {string} The encoded string.
+ * @api
+ol.format.Polyline.encodeDeltas = function(numbers, stride, opt_factor) {
+ var factor = opt_factor ? opt_factor : 1e5;
+ var d;
+ var lastNumbers = new Array(stride);
+ for (d = 0; d < stride; ++d) {
+ lastNumbers[d] = 0;
+ var i, ii;
+ for (i = 0, ii = numbers.length; i < ii;) {
+ for (d = 0; d < stride; ++d, ++i) {
+ var num = numbers[i];
+ var delta = num - lastNumbers[d];
+ lastNumbers[d] = num;
+ numbers[i] = delta;
+ return ol.format.Polyline.encodeFloats(numbers, factor);
+ * Decode a list of n-dimensional points from an encoded string
+ * @param {string} encoded An encoded string.
+ * encoded string.
+ * @param {number=} opt_factor The factor by which the resulting numbers will
+ * be divided. Default is `1e5`.
+ * @return {Array.<number>} A list of n-dimensional points.
+ * @api
+ol.format.Polyline.decodeDeltas = function(encoded, stride, opt_factor) {
+ var d;
+ var numbers = ol.format.Polyline.decodeFloats(encoded, factor);
+ var i, ii;
+ lastNumbers[d] += numbers[i];
+ numbers[i] = lastNumbers[d];
+ return numbers;
+ * Encode a list of floating point numbers and return an encoded string
+ * @param {Array.<number>} numbers A list of floating point numbers.
+ * @api
+ol.format.Polyline.encodeFloats = function(numbers, opt_factor) {
+ var i, ii;
+ for (i = 0, ii = numbers.length; i < ii; ++i) {
+ numbers[i] = Math.round(numbers[i] * factor);
+ return ol.format.Polyline.encodeSignedIntegers(numbers);
+ * Decode a list of floating point numbers from an encoded string
+ * @param {number=} opt_factor The factor by which the result will be divided.
+ * @return {Array.<number>} A list of floating point numbers.
+ * @api
+ol.format.Polyline.decodeFloats = function(encoded, opt_factor) {
+ var numbers = ol.format.Polyline.decodeSignedIntegers(encoded);
+ var i, ii;
+ numbers[i] /= factor;
+ return numbers;
+ * Encode a list of signed integers and return an encoded string
+ * @param {Array.<number>} numbers A list of signed integers.
+ol.format.Polyline.encodeSignedIntegers = function(numbers) {
+ var i, ii;
+ numbers[i] = (num < 0) ? ~(num << 1) : (num << 1);
+ return ol.format.Polyline.encodeUnsignedIntegers(numbers);
+ * Decode a list of signed integers from an encoded string
+ * @return {Array.<number>} A list of signed integers.
+ol.format.Polyline.decodeSignedIntegers = function(encoded) {
+ var numbers = ol.format.Polyline.decodeUnsignedIntegers(encoded);
+ var i, ii;
+ numbers[i] = (num & 1) ? ~(num >> 1) : (num >> 1);
+ return numbers;
+ * Encode a list of unsigned integers and return an encoded string
+ * @param {Array.<number>} numbers A list of unsigned integers.
+ol.format.Polyline.encodeUnsignedIntegers = function(numbers) {
+ var encoded = '';
+ var i, ii;
+ encoded += ol.format.Polyline.encodeUnsignedInteger(numbers[i]);
+ return encoded;
+ * Decode a list of unsigned integers from an encoded string
+ * @return {Array.<number>} A list of unsigned integers.
+ol.format.Polyline.decodeUnsignedIntegers = function(encoded) {
+ var numbers = [];
+ var current = 0;
+ var shift = 0;
+ var i, ii;
+ for (i = 0, ii = encoded.length; i < ii; ++i) {
+ var b = encoded.charCodeAt(i) - 63;
+ current |= (b & 0x1f) << shift;
+ if (b < 0x20) {
+ numbers.push(current);
+ current = 0;
+ shift = 0;
+ } else {
+ shift += 5;
+ return numbers;
+ * Encode one single unsigned integer and return an encoded string
+ * @param {number} num Unsigned integer that should be encoded.
+ol.format.Polyline.encodeUnsignedInteger = function(num) {
+ var value, encoded = '';
+ while (num >= 0x20) {
+ value = (0x20 | (num & 0x1f)) + 63;
+ encoded += String.fromCharCode(value);
+ num >>= 5;
+ value = num + 63;
+ return encoded;
+ * Read the feature from the Polyline source. The coordinates are assumed to be
+ * in two dimensions and in latitude, longitude order.
+ * @function
+ * @return {ol.Feature} Feature.
+ * @api
+ol.format.Polyline.prototype.readFeature;
+ * @inheritDoc
+ol.format.Polyline.prototype.readFeatureFromText = function(text, opt_options) {
+ var geometry = this.readGeometryFromText(text, opt_options);
+ return new ol.Feature(geometry);
+ * Read the feature from the source. As Polyline sources contain a single
+ * feature, this will return the feature in an array.
+ * @function
+ * @api
+ol.format.Polyline.prototype.readFeatures;
+ * @inheritDoc
+ol.format.Polyline.prototype.readFeaturesFromText = function(text, opt_options) {
+ var feature = this.readFeatureFromText(text, opt_options);
+ return [feature];
+ * Read the geometry from the source.
+ * @function
+ * @api
+ol.format.Polyline.prototype.readGeometry;
+ * @inheritDoc
+ol.format.Polyline.prototype.readGeometryFromText = function(text, opt_options) {
+ var stride = ol.geom.SimpleGeometry.getStrideForLayout(this.geometryLayout_);
+ var flatCoordinates = ol.format.Polyline.decodeDeltas(
+ text, stride, this.factor_);
+ ol.geom.flat.flip.flipXY(
+ flatCoordinates, 0, flatCoordinates.length, stride, flatCoordinates);
+ var coordinates = ol.geom.flat.inflate.coordinates(
+ flatCoordinates, 0, flatCoordinates.length, stride);
+ return /** @type {ol.geom.Geometry} */ (
+ new ol.geom.LineString(coordinates, this.geometryLayout_), false,
+ this.adaptOptions(opt_options)));
+ * Read the projection from a Polyline source.
+ * @function
+ * @api
+ol.format.Polyline.prototype.readProjection;
+ * @inheritDoc
+ol.format.Polyline.prototype.writeFeatureText = function(feature, opt_options) {
+ var geometry = feature.getGeometry();
+ if (geometry) {
+ return this.writeGeometryText(geometry, opt_options);
+ } else {
+ ol.asserts.assert(false, 40); // Expected `feature` to have a geometry
+ return '';
+ * @inheritDoc
+ol.format.Polyline.prototype.writeFeaturesText = function(features, opt_options) {
+ return this.writeFeatureText(features[0], opt_options);
+ * Write a single geometry in Polyline format.
+ * @function
+ * @param {ol.geom.Geometry} geometry Geometry.
+ * @param {olx.format.WriteOptions=} opt_options Write options.
+ * @return {string} Geometry.
+ * @api
+ol.format.Polyline.prototype.writeGeometry;
+ * @inheritDoc
+ol.format.Polyline.prototype.writeGeometryText = function(geometry, opt_options) {
+ geometry = /** @type {ol.geom.LineString} */
+ (ol.format.Feature.transformWithOptions(
+ geometry, true, this.adaptOptions(opt_options)));
+ var flatCoordinates = geometry.getFlatCoordinates();
+ var stride = geometry.getStride();
+ return ol.format.Polyline.encodeDeltas(flatCoordinates, stride, this.factor_);
+goog.provide('ol.format.TopoJSON');
+goog.require('ol.format.JSONFeature');
+goog.require('ol.geom.MultiPolygon');
+ * @classdesc
+ * Feature format for reading data in the TopoJSON format.
+ * @constructor
+ * @extends {ol.format.JSONFeature}
+ * @param {olx.format.TopoJSONOptions=} opt_options Options.
+ * @api
+ol.format.TopoJSON = function(opt_options) {
+ ol.format.JSONFeature.call(this);
+ * @inheritDoc
+ options.defaultDataProjection ?
+ options.defaultDataProjection : 'EPSG:4326');
+ol.inherits(ol.format.TopoJSON, ol.format.JSONFeature);
+ * Concatenate arcs into a coordinate array.
+ * @param {Array.<number>} indices Indices of arcs to concatenate. Negative
+ * values indicate arcs need to be reversed.
+ * @param {Array.<Array.<ol.Coordinate>>} arcs Array of arcs (already
+ * transformed).
+ * @return {Array.<ol.Coordinate>} Coordinates array.
+ * @private
+ol.format.TopoJSON.concatenateArcs_ = function(indices, arcs) {
+ /** @type {Array.<ol.Coordinate>} */
+ var coordinates = [];
+ var index, arc;
+ var i, ii;
+ var j, jj;
+ for (i = 0, ii = indices.length; i < ii; ++i) {
+ index = indices[i];
+ if (i > 0) {
+ // splicing together arcs, discard last point
+ coordinates.pop();
+ if (index >= 0) {
+ // forward arc
+ arc = arcs[index];
+ } else {
+ // reverse arc
+ arc = arcs[~index].slice().reverse();
+ coordinates.push.apply(coordinates, arc);
+ // provide fresh copies of coordinate arrays
+ for (j = 0, jj = coordinates.length; j < jj; ++j) {
+ coordinates[j] = coordinates[j].slice();
+ return coordinates;
+ * Create a point from a TopoJSON geometry object.
+ * @param {TopoJSONGeometry} object TopoJSON object.
+ * @param {Array.<number>} scale Scale for each dimension.
+ * @param {Array.<number>} translate Translation for each dimension.
+ * @return {ol.geom.Point} Geometry.
+ * @private
+ol.format.TopoJSON.readPointGeometry_ = function(object, scale, translate) {
+ var coordinates = object.coordinates;
+ if (scale && translate) {
+ ol.format.TopoJSON.transformVertex_(coordinates, scale, translate);
+ return new ol.geom.Point(coordinates);
+ * Create a multi-point from a TopoJSON geometry object.
+ * @return {ol.geom.MultiPoint} Geometry.
+ * @private
+ol.format.TopoJSON.readMultiPointGeometry_ = function(object, scale,
+ translate) {
+ var i, ii;
+ for (i = 0, ii = coordinates.length; i < ii; ++i) {
+ ol.format.TopoJSON.transformVertex_(coordinates[i], scale, translate);
+ return new ol.geom.MultiPoint(coordinates);
+ * Create a linestring from a TopoJSON geometry object.
+ * @param {Array.<Array.<ol.Coordinate>>} arcs Array of arcs.
+ * @return {ol.geom.LineString} Geometry.
+ * @private
+ol.format.TopoJSON.readLineStringGeometry_ = function(object, arcs) {
+ var coordinates = ol.format.TopoJSON.concatenateArcs_(object.arcs, arcs);
+ return new ol.geom.LineString(coordinates);
+ * Create a multi-linestring from a TopoJSON geometry object.
+ * @return {ol.geom.MultiLineString} Geometry.
+ * @private
+ol.format.TopoJSON.readMultiLineStringGeometry_ = function(object, arcs) {
+ var i, ii;
+ for (i = 0, ii = object.arcs.length; i < ii; ++i) {
+ coordinates[i] = ol.format.TopoJSON.concatenateArcs_(object.arcs[i], arcs);
+ return new ol.geom.MultiLineString(coordinates);
+ * Create a polygon from a TopoJSON geometry object.
+ * @return {ol.geom.Polygon} Geometry.
+ * @private
+ol.format.TopoJSON.readPolygonGeometry_ = function(object, arcs) {
+ var i, ii;
+ return new ol.geom.Polygon(coordinates);
+ * Create a multi-polygon from a TopoJSON geometry object.
+ * @return {ol.geom.MultiPolygon} Geometry.
+ * @private
+ol.format.TopoJSON.readMultiPolygonGeometry_ = function(object, arcs) {
+ var polyArray, ringCoords, j, jj;
+ var i, ii;
+ // for each polygon
+ polyArray = object.arcs[i];
+ ringCoords = [];
+ for (j = 0, jj = polyArray.length; j < jj; ++j) {
+ // for each ring
+ ringCoords[j] = ol.format.TopoJSON.concatenateArcs_(polyArray[j], arcs);
+ coordinates[i] = ringCoords;
+ return new ol.geom.MultiPolygon(coordinates);
+ * Create features from a TopoJSON GeometryCollection object.
+ * @param {TopoJSONGeometryCollection} collection TopoJSON Geometry
+ * object.
+ * @return {Array.<ol.Feature>} Array of features.
+ * @private
+ol.format.TopoJSON.readFeaturesFromGeometryCollection_ = function(
+ collection, arcs, scale, translate, opt_options) {
+ var geometries = collection.geometries;
+ var i, ii;
+ for (i = 0, ii = geometries.length; i < ii; ++i) {
+ features[i] = ol.format.TopoJSON.readFeatureFromGeometry_(
+ geometries[i], arcs, scale, translate, opt_options);
+ return features;
+ * Create a feature from a TopoJSON geometry object.
+ * @param {TopoJSONGeometry} object TopoJSON geometry object.
+ * @private
+ol.format.TopoJSON.readFeatureFromGeometry_ = function(object, arcs,
+ scale, translate, opt_options) {
+ var geometry;
+ var type = object.type;
+ var geometryReader = ol.format.TopoJSON.GEOMETRY_READERS_[type];
+ if ((type === 'Point') || (type === 'MultiPoint')) {
+ geometry = geometryReader(object, scale, translate);
+ } else {
+ geometry = geometryReader(object, arcs);
+ var feature = new ol.Feature();
+ feature.setGeometry(/** @type {ol.geom.Geometry} */ (
+ ol.format.Feature.transformWithOptions(geometry, false, opt_options)));
+ if (object.id !== undefined) {
+ feature.setId(object.id);
+ if (object.properties) {
+ feature.setProperties(object.properties);
+ return feature;
+ * Read all features from a TopoJSON source.
+ * @function
+ * @api
+ol.format.TopoJSON.prototype.readFeatures;
+ * @inheritDoc
+ol.format.TopoJSON.prototype.readFeaturesFromObject = function(
+ object, opt_options) {
+ if (object.type == 'Topology') {
+ var topoJSONTopology = /** @type {TopoJSONTopology} */ (object);
+ var transform, scale = null, translate = null;
+ if (topoJSONTopology.transform) {
+ transform = topoJSONTopology.transform;
+ scale = transform.scale;
+ translate = transform.translate;
+ var arcs = topoJSONTopology.arcs;
+ if (transform) {
+ ol.format.TopoJSON.transformArcs_(arcs, scale, translate);
+ /** @type {Array.<ol.Feature>} */
+ var topoJSONFeatures = ol.obj.getValues(topoJSONTopology.objects);
+ var i, ii;
+ var feature;
+ for (i = 0, ii = topoJSONFeatures.length; i < ii; ++i) {
+ if (topoJSONFeatures[i].type === 'GeometryCollection') {
+ feature = /** @type {TopoJSONGeometryCollection} */
+ (topoJSONFeatures[i]);
+ features.push.apply(features,
+ ol.format.TopoJSON.readFeaturesFromGeometryCollection_(
+ feature, arcs, scale, translate, opt_options));
+ } else {
+ feature = /** @type {TopoJSONGeometry} */
+ features.push(ol.format.TopoJSON.readFeatureFromGeometry_(
+ return features;
+ } else {
+ return [];
+ * Apply a linear transform to array of arcs. The provided array of arcs is
+ * modified in place.
+ * @private
+ol.format.TopoJSON.transformArcs_ = function(arcs, scale, translate) {
+ var i, ii;
+ for (i = 0, ii = arcs.length; i < ii; ++i) {
+ ol.format.TopoJSON.transformArc_(arcs[i], scale, translate);
+ * Apply a linear transform to an arc. The provided arc is modified in place.
+ * @param {Array.<ol.Coordinate>} arc Arc.
+ * @private
+ol.format.TopoJSON.transformArc_ = function(arc, scale, translate) {
+ var x = 0;
+ var y = 0;
+ var vertex;
+ var i, ii;
+ for (i = 0, ii = arc.length; i < ii; ++i) {
+ vertex = arc[i];
+ x += vertex[0];
+ y += vertex[1];
+ vertex[0] = x;
+ vertex[1] = y;
+ ol.format.TopoJSON.transformVertex_(vertex, scale, translate);
+ * Apply a linear transform to a vertex. The provided vertex is modified in
+ * place.
+ * @param {ol.Coordinate} vertex Vertex.
+ * @private
+ol.format.TopoJSON.transformVertex_ = function(vertex, scale, translate) {
+ vertex[0] = vertex[0] * scale[0] + translate[0];
+ vertex[1] = vertex[1] * scale[1] + translate[1];
+ * Read the projection from a TopoJSON source.
+ * @param {Document|Node|Object|string} object Source.
+ * @override
+ * @api
+ol.format.TopoJSON.prototype.readProjection;
+ * @inheritDoc
+ol.format.TopoJSON.prototype.readProjectionFromObject = function(object) {
+ * @const
+ * @private
+ * @type {Object.<string, function(TopoJSONGeometry, Array, ...Array): ol.geom.Geometry>}
+ol.format.TopoJSON.GEOMETRY_READERS_ = {
+ 'Point': ol.format.TopoJSON.readPointGeometry_,
+ 'LineString': ol.format.TopoJSON.readLineStringGeometry_,
+ 'Polygon': ol.format.TopoJSON.readPolygonGeometry_,
+ 'MultiPoint': ol.format.TopoJSON.readMultiPointGeometry_,
+ 'MultiLineString': ol.format.TopoJSON.readMultiLineStringGeometry_,
+ 'MultiPolygon': ol.format.TopoJSON.readMultiPolygonGeometry_
+ * @inheritDoc
+ol.format.TopoJSON.prototype.writeFeatureObject = function(feature, opt_options) {};
+ * @inheritDoc
+ol.format.TopoJSON.prototype.writeFeaturesObject = function(features, opt_options) {};
+ * @inheritDoc
+ol.format.TopoJSON.prototype.writeGeometryObject = function(geometry, opt_options) {};
+ * @override
+ol.format.TopoJSON.prototype.readGeometryFromObject = function() {};
+ * @override
+ol.format.TopoJSON.prototype.readFeatureFromObject = function() {};
+goog.provide('ol.format.WFS');
+goog.require('ol.format.GML2');
+goog.require('ol.format.GML3');
+goog.require('ol.format.GMLBase');
+goog.require('ol.format.filter');
+goog.require('ol.geom.Geometry');
+ * @classdesc
+ * Feature format for reading and writing data in the WFS format.
+ * By default, supports WFS version 1.1.0. You can pass a GML format
+ * as option if you want to read a WFS that contains GML2 (WFS 1.0.0).
+ * Also see {@link ol.format.GMLBase} which is used by this format.
+ * @constructor
+ * @param {olx.format.WFSOptions=} opt_options
+ * @api
+ol.format.WFS = function(opt_options) {
+ * @private
+ * @type {Array.<string>|string|undefined}
+ this.featureType_ = options.featureType;
+ * @private
+ * @type {Object.<string, string>|string|undefined}
+ this.featureNS_ = options.featureNS;
+ * @private
+ * @type {ol.format.GMLBase}
+ this.gmlFormat_ = options.gmlFormat ?
+ options.gmlFormat : new ol.format.GML3();
+ * @private
+ * @type {string}
+ this.schemaLocation_ = options.schemaLocation ?
+ options.schemaLocation :
+ ol.format.WFS.SCHEMA_LOCATIONS[ol.format.WFS.DEFAULT_VERSION];
+ol.inherits(ol.format.WFS, ol.format.XMLFeature);
+ * @const
+ * @type {string}
+ol.format.WFS.FEATURE_PREFIX = 'feature';
+ * @const
+ * @type {string}
+ol.format.WFS.XMLNS = 'http://www.w3.org/2000/xmlns/';
+ * @const
+ * @type {string}
+ol.format.WFS.OGCNS = 'http://www.opengis.net/ogc';
+ * @const
+ * @type {string}
+ol.format.WFS.WFSNS = 'http://www.opengis.net/wfs';
+ * @const
+ * @type {Object.<string, string>}
+ol.format.WFS.SCHEMA_LOCATIONS = {
+ '1.1.0': 'http://www.opengis.net/wfs ' +
+ 'http://schemas.opengis.net/wfs/1.1.0/wfs.xsd',
+ '1.0.0': 'http://www.opengis.net/wfs ' +
+ 'http://schemas.opengis.net/wfs/1.0.0/wfs.xsd'
+ * @const
+ * @type {string}
+ol.format.WFS.DEFAULT_VERSION = '1.1.0';
+ * Read all features from a WFS FeatureCollection.
+ * @function
+ * @api
+ol.format.WFS.prototype.readFeatures;
+ * @inheritDoc
+ol.format.WFS.prototype.readFeaturesFromNode = function(node, opt_options) {
+ var context = /** @type {ol.XmlNodeStackItem} */ ({
+ 'featureType': this.featureType_,
+ 'featureNS': this.featureNS_
+ ol.obj.assign(context, this.getReadOptions(node,
+ opt_options ? opt_options : {}));
+ var objectStack = [context];
+ this.gmlFormat_.FEATURE_COLLECTION_PARSERS[ol.format.GMLBase.GMLNS][
+ 'featureMember'] =
+ ol.xml.makeArrayPusher(ol.format.GMLBase.prototype.readFeaturesInternal);
+ var features = ol.xml.pushParseAndPop([],
+ this.gmlFormat_.FEATURE_COLLECTION_PARSERS, node,
+ objectStack, this.gmlFormat_);
+ if (!features) {
+ features = [];
+ return features;
+ * Read transaction response of the source.
+ * @return {ol.WFSTransactionResponse|undefined} Transaction response.
+ * @api
+ol.format.WFS.prototype.readTransactionResponse = function(source) {
+ return this.readTransactionResponseFromDocument(
+ /** @type {Document} */ (source));
+ return this.readTransactionResponseFromNode(/** @type {Node} */ (source));
+ return this.readTransactionResponseFromDocument(doc);
+ } else {
+ return undefined;
+ * Read feature collection metadata of the source.
+ * @return {ol.WFSFeatureCollectionMetadata|undefined}
+ * FeatureCollection metadata.
+ * @api
+ol.format.WFS.prototype.readFeatureCollectionMetadata = function(source) {
+ return this.readFeatureCollectionMetadataFromDocument(
+ return this.readFeatureCollectionMetadataFromNode(
+ /** @type {Node} */ (source));
+ return this.readFeatureCollectionMetadataFromDocument(doc);
+ } else {
+ return undefined;
+ol.format.WFS.prototype.readFeatureCollectionMetadataFromDocument = function(doc) {
+ return this.readFeatureCollectionMetadataFromNode(n);
+ return undefined;
+ * @const
+ * @private
+ol.format.WFS.FEATURE_COLLECTION_PARSERS_ = {
+ 'http://www.opengis.net/gml': {
+ 'boundedBy': ol.xml.makeObjectPropertySetter(
+ ol.format.GMLBase.prototype.readGeometryElement, 'bounds')
+ol.format.WFS.prototype.readFeatureCollectionMetadataFromNode = function(node) {
+ var result = {};
+ var value = ol.format.XSD.readNonNegativeIntegerString(
+ node.getAttribute('numberOfFeatures'));
+ result['numberOfFeatures'] = value;
+ /** @type {ol.WFSFeatureCollectionMetadata} */ (result),
+ ol.format.WFS.FEATURE_COLLECTION_PARSERS_, node, [], this.gmlFormat_);
+ * @const
+ * @private
+ol.format.WFS.TRANSACTION_SUMMARY_PARSERS_ = {
+ 'http://www.opengis.net/wfs': {
+ 'totalInserted': ol.xml.makeObjectPropertySetter(
+ ol.format.XSD.readNonNegativeInteger),
+ 'totalUpdated': ol.xml.makeObjectPropertySetter(
+ 'totalDeleted': ol.xml.makeObjectPropertySetter(
+ * @return {Object|undefined} Transaction Summary.
+ * @private
+ol.format.WFS.readTransactionSummary_ = function(node, objectStack) {
+ {}, ol.format.WFS.TRANSACTION_SUMMARY_PARSERS_, node, objectStack);
+ * @const
+ * @private
+ol.format.WFS.OGC_FID_PARSERS_ = {
+ 'http://www.opengis.net/ogc': {
+ 'FeatureId': ol.xml.makeArrayPusher(function(node, objectStack) {
+ return node.getAttribute('fid');
+ * @private
+ol.format.WFS.fidParser_ = function(node, objectStack) {
+ ol.xml.parseNode(ol.format.WFS.OGC_FID_PARSERS_, node, objectStack);
+ * @const
+ * @private
+ol.format.WFS.INSERT_RESULTS_PARSERS_ = {
+ 'Feature': ol.format.WFS.fidParser_
+ * @return {Array.<string>|undefined} Insert results.
+ * @private
+ol.format.WFS.readInsertResults_ = function(node, objectStack) {
+ [], ol.format.WFS.INSERT_RESULTS_PARSERS_, node, objectStack);
+ * @const
+ * @private
+ol.format.WFS.TRANSACTION_RESPONSE_PARSERS_ = {
+ 'TransactionSummary': ol.xml.makeObjectPropertySetter(
+ ol.format.WFS.readTransactionSummary_, 'transactionSummary'),
+ 'InsertResults': ol.xml.makeObjectPropertySetter(
+ ol.format.WFS.readInsertResults_, 'insertIds')
+ol.format.WFS.prototype.readTransactionResponseFromDocument = function(doc) {
+ return this.readTransactionResponseFromNode(n);
+ return undefined;
+ol.format.WFS.prototype.readTransactionResponseFromNode = function(node) {
+ /** @type {ol.WFSTransactionResponse} */({}),
+ ol.format.WFS.TRANSACTION_RESPONSE_PARSERS_, node, []);
+ * @type {Object.<string, Object.<string, ol.XmlSerializer>>}
+ * @private
+ol.format.WFS.QUERY_SERIALIZERS_ = {
+ 'PropertyName': ol.xml.makeChildAppender(ol.format.XSD.writeStringTextNode)
+ * @param {ol.Feature} feature Feature.
+ * @param {Array.<*>} objectStack Node stack.
+ * @private
+ol.format.WFS.writeFeature_ = function(node, feature, objectStack) {
+ var context = objectStack[objectStack.length - 1];
+ var featureType = context['featureType'];
+ var featureNS = context['featureNS'];
+ var gmlVersion = context['gmlVersion'];
+ var child = ol.xml.createElementNS(featureNS, featureType);
+ node.appendChild(child);
+ if (gmlVersion === 2) {
+ ol.format.GML2.prototype.writeFeatureElement(child, feature, objectStack);
+ } else {
+ ol.format.GML3.prototype.writeFeatureElement(child, feature, objectStack);
+ * @param {number|string} fid Feature identifier.
+ * @private
+ol.format.WFS.writeOgcFidFilter_ = function(node, fid, objectStack) {
+ var filter = ol.xml.createElementNS(ol.format.WFS.OGCNS, 'Filter');
+ var child = ol.xml.createElementNS(ol.format.WFS.OGCNS, 'FeatureId');
+ filter.appendChild(child);
+ child.setAttribute('fid', fid);
+ node.appendChild(filter);
+ * @private
+ol.format.WFS.writeDelete_ = function(node, feature, objectStack) {
+ ol.asserts.assert(feature.getId() !== undefined, 26); // Features must have an id set
+ var featurePrefix = context['featurePrefix'];
+ featurePrefix = featurePrefix ? featurePrefix :
+ ol.format.WFS.FEATURE_PREFIX;
+ node.setAttribute('typeName', featurePrefix + ':' + featureType);
+ ol.xml.setAttributeNS(node, ol.format.WFS.XMLNS, 'xmlns:' + featurePrefix,
+ featureNS);
+ var fid = feature.getId();
+ if (fid !== undefined) {
+ ol.format.WFS.writeOgcFidFilter_(node, fid, objectStack);
+ * @private
+ol.format.WFS.writeUpdate_ = function(node, feature, objectStack) {
+ ol.asserts.assert(feature.getId() !== undefined, 27); // Features must have an id set
+ featureNS);
+ var keys = feature.getKeys();
+ var values = [];
+ for (var i = 0, ii = keys.length; i < ii; i++) {
+ var value = feature.get(keys[i]);
+ if (value !== undefined) {
+ values.push({name: keys[i], value: value});
+ ol.xml.pushSerializeAndPop(/** @type {ol.XmlNodeStackItem} */ (
+ {'gmlVersion': context['gmlVersion'], node: node,
+ 'srsName': context['srsName']}),
+ ol.format.WFS.TRANSACTION_SERIALIZERS_,
+ ol.xml.makeSimpleNodeFactory('Property'), values,
+ objectStack);
+ * @param {Object} pair Property name and value.
+ * @private
+ol.format.WFS.writeProperty_ = function(node, pair, objectStack) {
+ var name = ol.xml.createElementNS(ol.format.WFS.WFSNS, 'Name');
+ node.appendChild(name);
+ ol.format.XSD.writeStringTextNode(name, pair.name);
+ if (pair.value !== undefined && pair.value !== null) {
+ var value = ol.xml.createElementNS(ol.format.WFS.WFSNS, 'Value');
+ node.appendChild(value);
+ if (pair.value instanceof ol.geom.Geometry) {
+ ol.format.GML2.prototype.writeGeometryElement(value,
+ pair.value, objectStack);
+ } else {
+ ol.format.GML3.prototype.writeGeometryElement(value,
+ } else {
+ ol.format.XSD.writeStringTextNode(value, pair.value);
+ * @param {{vendorId: string, safeToIgnore: boolean, value: string}}
+ * nativeElement The native element.
+ * @private
+ol.format.WFS.writeNative_ = function(node, nativeElement, objectStack) {
+ if (nativeElement.vendorId) {
+ node.setAttribute('vendorId', nativeElement.vendorId);
+ if (nativeElement.safeToIgnore !== undefined) {
+ node.setAttribute('safeToIgnore', nativeElement.safeToIgnore);
+ if (nativeElement.value !== undefined) {
+ ol.format.XSD.writeStringTextNode(node, nativeElement.value);
+ * @private
+ol.format.WFS.TRANSACTION_SERIALIZERS_ = {
+ 'Insert': ol.xml.makeChildAppender(ol.format.WFS.writeFeature_),
+ 'Update': ol.xml.makeChildAppender(ol.format.WFS.writeUpdate_),
+ 'Delete': ol.xml.makeChildAppender(ol.format.WFS.writeDelete_),
+ 'Property': ol.xml.makeChildAppender(ol.format.WFS.writeProperty_),
+ 'Native': ol.xml.makeChildAppender(ol.format.WFS.writeNative_)
+ * @param {string} featureType Feature type.
+ * @private
+ol.format.WFS.writeQuery_ = function(node, featureType, objectStack) {
+ var context = /** @type {Object} */ (objectStack[objectStack.length - 1]);
+ var propertyNames = context['propertyNames'];
+ var srsName = context['srsName'];
+ var prefix = featurePrefix ? featurePrefix + ':' : '';
+ node.setAttribute('typeName', prefix + featureType);
+ if (srsName) {
+ node.setAttribute('srsName', srsName);
+ if (featureNS) {
+ featureNS);
+ var item = /** @type {ol.XmlNodeStackItem} */ (ol.obj.assign({}, context));
+ item.node = node;
+ ol.xml.pushSerializeAndPop(item,
+ ol.format.WFS.QUERY_SERIALIZERS_,
+ ol.xml.makeSimpleNodeFactory('PropertyName'), propertyNames,
+ objectStack);
+ var filter = context['filter'];
+ if (filter) {
+ var child = ol.xml.createElementNS(ol.format.WFS.OGCNS, 'Filter');
+ ol.format.WFS.writeFilterCondition_(child, filter, objectStack);
+ * @param {ol.format.filter.Filter} filter Filter.
+ * @private
+ol.format.WFS.writeFilterCondition_ = function(node, filter, objectStack) {
+ /** @type {ol.XmlNodeStackItem} */
+ var item = {node: node};
+ ol.format.WFS.GETFEATURE_SERIALIZERS_,
+ ol.xml.makeSimpleNodeFactory(filter.getTagName()),
+ [filter], objectStack);
+ * @param {ol.format.filter.Bbox} filter Filter.
+ * @private
+ol.format.WFS.writeBboxFilter_ = function(node, filter, objectStack) {
+ context['srsName'] = filter.srsName;
+ ol.format.WFS.writeOgcPropertyName_(node, filter.geometryName);
+ ol.format.GML3.prototype.writeGeometryElement(node, filter.extent, objectStack);
+ * @param {ol.format.filter.Intersects} filter Filter.
+ * @private
+ol.format.WFS.writeIntersectsFilter_ = function(node, filter, objectStack) {
+ ol.format.GML3.prototype.writeGeometryElement(node, filter.geometry, objectStack);
+ * @param {ol.format.filter.Within} filter Filter.
+ * @private
+ol.format.WFS.writeWithinFilter_ = function(node, filter, objectStack) {
+ * @param {ol.format.filter.LogicalNary} filter Filter.
+ * @private
+ol.format.WFS.writeLogicalFilter_ = function(node, filter, objectStack) {
+ filter.conditions.forEach(function(condition) {
+ ol.xml.makeSimpleNodeFactory(condition.getTagName()),
+ [condition], objectStack);
+ * @param {ol.format.filter.Not} filter Filter.
+ * @private
+ol.format.WFS.writeNotFilter_ = function(node, filter, objectStack) {
+ var condition = filter.condition;
+ * @param {ol.format.filter.ComparisonBinary} filter Filter.
+ * @private
+ol.format.WFS.writeComparisonFilter_ = function(node, filter, objectStack) {
+ if (filter.matchCase !== undefined) {
+ node.setAttribute('matchCase', filter.matchCase.toString());
+ ol.format.WFS.writeOgcPropertyName_(node, filter.propertyName);
+ ol.format.WFS.writeOgcLiteral_(node, '' + filter.expression);
+ * @param {ol.format.filter.IsNull} filter Filter.
+ * @private
+ol.format.WFS.writeIsNullFilter_ = function(node, filter, objectStack) {
+ * @param {ol.format.filter.IsBetween} filter Filter.
+ * @private
+ol.format.WFS.writeIsBetweenFilter_ = function(node, filter, objectStack) {
+ var lowerBoundary = ol.xml.createElementNS(ol.format.WFS.OGCNS, 'LowerBoundary');
+ node.appendChild(lowerBoundary);
+ ol.format.WFS.writeOgcLiteral_(lowerBoundary, '' + filter.lowerBoundary);
+ var upperBoundary = ol.xml.createElementNS(ol.format.WFS.OGCNS, 'UpperBoundary');
+ node.appendChild(upperBoundary);
+ ol.format.WFS.writeOgcLiteral_(upperBoundary, '' + filter.upperBoundary);
+ * @param {ol.format.filter.IsLike} filter Filter.
+ * @private
+ol.format.WFS.writeIsLikeFilter_ = function(node, filter, objectStack) {
+ node.setAttribute('wildCard', filter.wildCard);
+ node.setAttribute('singleChar', filter.singleChar);
+ node.setAttribute('escapeChar', filter.escapeChar);
+ ol.format.WFS.writeOgcLiteral_(node, '' + filter.pattern);
+ * @param {string} tagName Tag name.
+ * @param {string} value Value.
+ * @private
+ol.format.WFS.writeOgcExpression_ = function(tagName, node, value) {
+ var property = ol.xml.createElementNS(ol.format.WFS.OGCNS, tagName);
+ ol.format.XSD.writeStringTextNode(property, value);
+ node.appendChild(property);
+ * @param {string} value PropertyName value.
+ * @private
+ol.format.WFS.writeOgcPropertyName_ = function(node, value) {
+ ol.format.WFS.writeOgcExpression_('PropertyName', node, value);
+ * @private
+ol.format.WFS.writeOgcLiteral_ = function(node, value) {
+ ol.format.WFS.writeOgcExpression_('Literal', node, value);
+ * @private
+ol.format.WFS.GETFEATURE_SERIALIZERS_ = {
+ 'Query': ol.xml.makeChildAppender(ol.format.WFS.writeQuery_)
+ 'And': ol.xml.makeChildAppender(ol.format.WFS.writeLogicalFilter_),
+ 'Or': ol.xml.makeChildAppender(ol.format.WFS.writeLogicalFilter_),
+ 'Not': ol.xml.makeChildAppender(ol.format.WFS.writeNotFilter_),
+ 'BBOX': ol.xml.makeChildAppender(ol.format.WFS.writeBboxFilter_),
+ 'Intersects': ol.xml.makeChildAppender(ol.format.WFS.writeIntersectsFilter_),
+ 'Within': ol.xml.makeChildAppender(ol.format.WFS.writeWithinFilter_),
+ 'PropertyIsEqualTo': ol.xml.makeChildAppender(ol.format.WFS.writeComparisonFilter_),
+ 'PropertyIsNotEqualTo': ol.xml.makeChildAppender(ol.format.WFS.writeComparisonFilter_),
+ 'PropertyIsLessThan': ol.xml.makeChildAppender(ol.format.WFS.writeComparisonFilter_),
+ 'PropertyIsLessThanOrEqualTo': ol.xml.makeChildAppender(ol.format.WFS.writeComparisonFilter_),
+ 'PropertyIsGreaterThan': ol.xml.makeChildAppender(ol.format.WFS.writeComparisonFilter_),
+ 'PropertyIsGreaterThanOrEqualTo': ol.xml.makeChildAppender(ol.format.WFS.writeComparisonFilter_),
+ 'PropertyIsNull': ol.xml.makeChildAppender(ol.format.WFS.writeIsNullFilter_),
+ 'PropertyIsBetween': ol.xml.makeChildAppender(ol.format.WFS.writeIsBetweenFilter_),
+ 'PropertyIsLike': ol.xml.makeChildAppender(ol.format.WFS.writeIsLikeFilter_)
+ * Encode filter as WFS `Filter` and return the Node.
+ * @return {Node} Result.
+ * @api
+ol.format.WFS.writeFilter = function(filter) {
+ ol.format.WFS.writeFilterCondition_(child, filter, []);
+ return child;
+ * @param {Array.<string>} featureTypes Feature types.
+ * @private
+ol.format.WFS.writeGetFeature_ = function(node, featureTypes, objectStack) {
+ item.node = node;
+ ol.xml.makeSimpleNodeFactory('Query'), featureTypes,
+ objectStack);
+ * Encode format as WFS `GetFeature` and return the Node.
+ * @param {olx.format.WFSWriteGetFeatureOptions} options Options.
+ * @api
+ol.format.WFS.prototype.writeGetFeature = function(options) {
+ var node = ol.xml.createElementNS(ol.format.WFS.WFSNS, 'GetFeature');
+ node.setAttribute('service', 'WFS');
+ node.setAttribute('version', '1.1.0');
+ var filter;
+ if (options) {
+ if (options.handle) {
+ node.setAttribute('handle', options.handle);
+ if (options.outputFormat) {
+ node.setAttribute('outputFormat', options.outputFormat);
+ if (options.maxFeatures !== undefined) {
+ node.setAttribute('maxFeatures', options.maxFeatures);
+ if (options.resultType) {
+ node.setAttribute('resultType', options.resultType);
+ if (options.startIndex !== undefined) {
+ node.setAttribute('startIndex', options.startIndex);
+ if (options.count !== undefined) {
+ node.setAttribute('count', options.count);
+ filter = options.filter;
+ if (options.bbox) {
+ ol.asserts.assert(options.geometryName,
+ 12); // `options.geometryName` must also be provided when `options.bbox` is set
+ var bbox = ol.format.filter.bbox(
+ /** @type {string} */ (options.geometryName), options.bbox, options.srsName);
+ if (filter) {
+ // if bbox and filter are both set, combine the two into a single filter
+ filter = ol.format.filter.and(filter, bbox);
+ } else {
+ filter = bbox;
+ ol.xml.setAttributeNS(node, 'http://www.w3.org/2001/XMLSchema-instance',
+ 'xsi:schemaLocation', this.schemaLocation_);
+ var context = {
+ node: node,
+ 'srsName': options.srsName,
+ 'featureNS': options.featureNS ? options.featureNS : this.featureNS_,
+ 'featurePrefix': options.featurePrefix,
+ 'geometryName': options.geometryName,
+ 'filter': filter,
+ 'propertyNames': options.propertyNames ? options.propertyNames : []
+ ol.asserts.assert(Array.isArray(options.featureTypes),
+ 11); // `options.featureTypes` should be an Array
+ ol.format.WFS.writeGetFeature_(node, /** @type {!Array.<string>} */ (options.featureTypes), [context]);
+ return node;
+ * Encode format as WFS `Transaction` and return the Node.
+ * @param {Array.<ol.Feature>} inserts The features to insert.
+ * @param {Array.<ol.Feature>} updates The features to update.
+ * @param {Array.<ol.Feature>} deletes The features to delete.
+ * @param {olx.format.WFSWriteTransactionOptions} options Write options.
+ * @api
+ol.format.WFS.prototype.writeTransaction = function(inserts, updates, deletes,
+ options) {
+ var objectStack = [];
+ var node = ol.xml.createElementNS(ol.format.WFS.WFSNS, 'Transaction');
+ var version = options.version ?
+ options.version : ol.format.WFS.DEFAULT_VERSION;
+ var gmlVersion = version === '1.0.0' ? 2 : 3;
+ node.setAttribute('version', version);
+ var baseObj;
+ var obj;
+ if (options) {
+ baseObj = options.gmlOptions ? options.gmlOptions : {};
+ var schemaLocation = ol.format.WFS.SCHEMA_LOCATIONS[version];
+ 'xsi:schemaLocation', schemaLocation);
+ if (inserts) {
+ obj = {node: node, 'featureNS': options.featureNS,
+ 'featureType': options.featureType, 'featurePrefix': options.featurePrefix,
+ 'gmlVersion': gmlVersion, 'srsName': options.srsName};
+ ol.obj.assign(obj, baseObj);
+ ol.xml.pushSerializeAndPop(obj,
+ ol.xml.makeSimpleNodeFactory('Insert'), inserts,
+ objectStack);
+ if (updates) {
+ ol.xml.makeSimpleNodeFactory('Update'), updates,
+ objectStack);
+ if (deletes) {
+ ol.xml.pushSerializeAndPop({node: node, 'featureNS': options.featureNS,
+ 'gmlVersion': gmlVersion, 'srsName': options.srsName},
+ ol.xml.makeSimpleNodeFactory('Delete'), deletes,
+ objectStack);
+ if (options.nativeElements) {
+ ol.xml.makeSimpleNodeFactory('Native'), options.nativeElements,
+ objectStack);
+ return node;
+ * Read the projection from a WFS source.
+ * @function
+ * @return {?ol.proj.Projection} Projection.
+ * @api
+ol.format.WFS.prototype.readProjection;
+ * @inheritDoc
+ol.format.WFS.prototype.readProjectionFromDocument = function(doc) {
+ return this.readProjectionFromNode(n);
+ return null;
+ * @inheritDoc
+ol.format.WFS.prototype.readProjectionFromNode = function(node) {
+ if (node.firstElementChild &&
+ node.firstElementChild.firstElementChild) {
+ node = node.firstElementChild.firstElementChild;
+ for (var n = node.firstElementChild; n; n = n.nextElementSibling) {
+ if (!(n.childNodes.length === 0 ||
+ (n.childNodes.length === 1 &&
+ n.firstChild.nodeType === 3))) {
+ var objectStack = [{}];
+ this.gmlFormat_.readGeometryElement(n, objectStack);
+ return ol.proj.get(objectStack.pop().srsName);
+ return null;
+goog.provide('ol.format.WKT');
+goog.require('ol.geom.GeometryCollection');
+ * @classdesc
+ * Geometry format for reading and writing data in the `WellKnownText` (WKT)
+ * format.
+ * @constructor
+ * @param {olx.format.WKTOptions=} opt_options Options.
+ * @api
+ol.format.WKT = function(opt_options) {
+ * Split GeometryCollection into multiple features.
+ * @type {boolean}
+ * @private
+ this.splitCollection_ = options.splitCollection !== undefined ?
+ options.splitCollection : false;
+ol.inherits(ol.format.WKT, ol.format.TextFeature);
+ * @const
+ * @type {string}
+ol.format.WKT.EMPTY = 'EMPTY';
+ * @const
+ * @type {string}
+ol.format.WKT.Z = 'Z';
+ * @const
+ * @type {string}
+ol.format.WKT.M = 'M';
+ * @const
+ * @type {string}
+ol.format.WKT.ZM = 'ZM';
+ * @param {ol.geom.Point} geom Point geometry.
+ * @return {string} Coordinates part of Point as WKT.
+ * @private
+ol.format.WKT.encodePointGeometry_ = function(geom) {
+ var coordinates = geom.getCoordinates();
+ if (coordinates.length === 0) {
+ return '';
+ return coordinates.join(' ');
+ * @param {ol.geom.MultiPoint} geom MultiPoint geometry.
+ * @return {string} Coordinates part of MultiPoint as WKT.
+ * @private
+ol.format.WKT.encodeMultiPointGeometry_ = function(geom) {
+ var array = [];
+ var components = geom.getPoints();
+ for (var i = 0, ii = components.length; i < ii; ++i) {
+ array.push('(' + ol.format.WKT.encodePointGeometry_(components[i]) + ')');
+ return array.join(',');
+ * @param {ol.geom.GeometryCollection} geom GeometryCollection geometry.
+ * @return {string} Coordinates part of GeometryCollection as WKT.
+ * @private
+ol.format.WKT.encodeGeometryCollectionGeometry_ = function(geom) {
+ var array = [];
+ var geoms = geom.getGeometries();
+ for (var i = 0, ii = geoms.length; i < ii; ++i) {
+ array.push(ol.format.WKT.encode_(geoms[i]));
+ * @param {ol.geom.LineString|ol.geom.LinearRing} geom LineString geometry.
+ * @return {string} Coordinates part of LineString as WKT.
+ * @private
+ol.format.WKT.encodeLineStringGeometry_ = function(geom) {
+ var array = [];
+ for (var i = 0, ii = coordinates.length; i < ii; ++i) {
+ array.push(coordinates[i].join(' '));
+ * @param {ol.geom.MultiLineString} geom MultiLineString geometry.
+ * @return {string} Coordinates part of MultiLineString as WKT.
+ * @private
+ol.format.WKT.encodeMultiLineStringGeometry_ = function(geom) {
+ var array = [];
+ var components = geom.getLineStrings();
+ array.push('(' + ol.format.WKT.encodeLineStringGeometry_(
+ components[i]) + ')');
+ * @param {ol.geom.Polygon} geom Polygon geometry.
+ * @return {string} Coordinates part of Polygon as WKT.
+ * @private
+ol.format.WKT.encodePolygonGeometry_ = function(geom) {
+ var array = [];
+ var rings = geom.getLinearRings();
+ for (var i = 0, ii = rings.length; i < ii; ++i) {
+ rings[i]) + ')');
+ * @param {ol.geom.MultiPolygon} geom MultiPolygon geometry.
+ * @return {string} Coordinates part of MultiPolygon as WKT.
+ * @private
+ol.format.WKT.encodeMultiPolygonGeometry_ = function(geom) {
+ var array = [];
+ var components = geom.getPolygons();
+ array.push('(' + ol.format.WKT.encodePolygonGeometry_(
+ * @param {ol.geom.SimpleGeometry} geom SimpleGeometry geometry.
+ * @return {string} Potential dimensional information for WKT type.
+ * @private
+ol.format.WKT.encodeGeometryLayout_ = function(geom) {
+ var layout = geom.getLayout();
+ var dimInfo = '';
+ if (layout === ol.geom.GeometryLayout.XYZ || layout === ol.geom.GeometryLayout.XYZM) {
+ dimInfo += ol.format.WKT.Z;
+ if (layout === ol.geom.GeometryLayout.XYM || layout === ol.geom.GeometryLayout.XYZM) {
+ dimInfo += ol.format.WKT.M;
+ return dimInfo;
+ * Encode a geometry as WKT.
+ * @param {ol.geom.Geometry} geom The geometry to encode.
+ * @return {string} WKT string for the geometry.
+ * @private
+ol.format.WKT.encode_ = function(geom) {
+ var type = geom.getType();
+ var geometryEncoder = ol.format.WKT.GeometryEncoder_[type];
+ var enc = geometryEncoder(geom);
+ type = type.toUpperCase();
+ if (geom instanceof ol.geom.SimpleGeometry) {
+ var dimInfo = ol.format.WKT.encodeGeometryLayout_(geom);
+ if (dimInfo.length > 0) {
+ type += ' ' + dimInfo;
+ if (enc.length === 0) {
+ return type + ' ' + ol.format.WKT.EMPTY;
+ return type + '(' + enc + ')';
+ * @const
+ * @type {Object.<string, function(ol.geom.Geometry): string>}
+ * @private
+ol.format.WKT.GeometryEncoder_ = {
+ 'Point': ol.format.WKT.encodePointGeometry_,
+ 'LineString': ol.format.WKT.encodeLineStringGeometry_,
+ 'Polygon': ol.format.WKT.encodePolygonGeometry_,
+ 'MultiPoint': ol.format.WKT.encodeMultiPointGeometry_,
+ 'MultiLineString': ol.format.WKT.encodeMultiLineStringGeometry_,
+ 'MultiPolygon': ol.format.WKT.encodeMultiPolygonGeometry_,
+ 'GeometryCollection': ol.format.WKT.encodeGeometryCollectionGeometry_
+ * Parse a WKT string.
+ * @param {string} wkt WKT string.
+ * @return {ol.geom.Geometry|undefined}
+ * The geometry created.
+ * @private
+ol.format.WKT.prototype.parse_ = function(wkt) {
+ var lexer = new ol.format.WKT.Lexer(wkt);
+ var parser = new ol.format.WKT.Parser(lexer);
+ return parser.parse();
+ * Read a feature from a WKT source.
+ * @function
+ * @api
+ol.format.WKT.prototype.readFeature;
+ * @inheritDoc
+ol.format.WKT.prototype.readFeatureFromText = function(text, opt_options) {
+ var geom = this.readGeometryFromText(text, opt_options);
+ if (geom) {
+ feature.setGeometry(geom);
+ return feature;
+ return null;
+ * Read all features from a WKT source.
+ * @function
+ * @api
+ol.format.WKT.prototype.readFeatures;
+ * @inheritDoc
+ol.format.WKT.prototype.readFeaturesFromText = function(text, opt_options) {
+ var geometries = [];
+ if (this.splitCollection_ &&
+ geometry.getType() == ol.geom.GeometryType.GEOMETRY_COLLECTION) {
+ geometries = (/** @type {ol.geom.GeometryCollection} */ (geometry))
+ .getGeometriesArray();
+ } else {
+ geometries = [geometry];
+ var feature, features = [];
+ for (var i = 0, ii = geometries.length; i < ii; ++i) {
+ feature = new ol.Feature();
+ feature.setGeometry(geometries[i]);
+ return features;
+ * Read a single geometry from a WKT source.
+ * @function
+ * @api
+ol.format.WKT.prototype.readGeometry;
+ * @inheritDoc
+ol.format.WKT.prototype.readGeometryFromText = function(text, opt_options) {
+ var geometry = this.parse_(text);
+ if (geometry) {
+ ol.format.Feature.transformWithOptions(geometry, false, opt_options));
+ } else {
+ return null;
+ * Encode a feature as a WKT string.
+ * @function
+ * @return {string} WKT string.
+ * @api
+ol.format.WKT.prototype.writeFeature;
+ * @inheritDoc
+ol.format.WKT.prototype.writeFeatureText = function(feature, opt_options) {
+ if (geometry) {
+ return '';
+ * Encode an array of features as a WKT string.
+ * @function
+ * @param {Array.<ol.Feature>} features Features.
+ * @api
+ol.format.WKT.prototype.writeFeatures;
+ * @inheritDoc
+ol.format.WKT.prototype.writeFeaturesText = function(features, opt_options) {
+ if (features.length == 1) {
+ for (var i = 0, ii = features.length; i < ii; ++i) {
+ geometries.push(features[i].getGeometry());
+ var collection = new ol.geom.GeometryCollection(geometries);
+ return this.writeGeometryText(collection, opt_options);
+ * Write a single geometry as a WKT string.
+ * @function
+ * @api
+ol.format.WKT.prototype.writeGeometry;
+ * @inheritDoc
+ol.format.WKT.prototype.writeGeometryText = function(geometry, opt_options) {
+ return ol.format.WKT.encode_(/** @type {ol.geom.Geometry} */ (
+ ol.format.Feature.transformWithOptions(geometry, true, opt_options)));
+ * @const
+ * @enum {number}
+ * @private
+ol.format.WKT.TokenType_ = {
+ TEXT: 1,
+ LEFT_PAREN: 2,
+ RIGHT_PAREN: 3,
+ NUMBER: 4,
+ COMMA: 5,
+ EOF: 6
+ * Class to tokenize a WKT string.
+ * @constructor
+ * @protected
+ol.format.WKT.Lexer = function(wkt) {
+ * @type {string}
+ this.wkt = wkt;
+ * @type {number}
+ * @private
+ this.index_ = -1;
+ * @param {string} c Character.
+ * @return {boolean} Whether the character is alphabetic.
+ * @private
+ol.format.WKT.Lexer.prototype.isAlpha_ = function(c) {
+ return c >= 'a' && c <= 'z' || c >= 'A' && c <= 'Z';
+ * @param {boolean=} opt_decimal Whether the string number
+ * contains a dot, i.e. is a decimal number.
+ * @return {boolean} Whether the character is numeric.
+ * @private
+ol.format.WKT.Lexer.prototype.isNumeric_ = function(c, opt_decimal) {
+ var decimal = opt_decimal !== undefined ? opt_decimal : false;
+ return c >= '0' && c <= '9' || c == '.' && !decimal;
+ * @return {boolean} Whether the character is whitespace.
+ * @private
+ol.format.WKT.Lexer.prototype.isWhiteSpace_ = function(c) {
+ return c == ' ' || c == '\t' || c == '\r' || c == '\n';
+ * @return {string} Next string character.
+ * @private
+ol.format.WKT.Lexer.prototype.nextChar_ = function() {
+ return this.wkt.charAt(++this.index_);
+ * Fetch and return the next token.
+ * @return {!ol.WKTToken} Next string token.
+ol.format.WKT.Lexer.prototype.nextToken = function() {
+ var c = this.nextChar_();
+ var token = {position: this.index_, value: c};
+ if (c == '(') {
+ token.type = ol.format.WKT.TokenType_.LEFT_PAREN;
+ } else if (c == ',') {
+ token.type = ol.format.WKT.TokenType_.COMMA;
+ } else if (c == ')') {
+ token.type = ol.format.WKT.TokenType_.RIGHT_PAREN;
+ } else if (this.isNumeric_(c) || c == '-') {
+ token.type = ol.format.WKT.TokenType_.NUMBER;
+ token.value = this.readNumber_();
+ } else if (this.isAlpha_(c)) {
+ token.type = ol.format.WKT.TokenType_.TEXT;
+ token.value = this.readText_();
+ } else if (this.isWhiteSpace_(c)) {
+ return this.nextToken();
+ } else if (c === '') {
+ token.type = ol.format.WKT.TokenType_.EOF;
+ } else {
+ throw new Error('Unexpected character: ' + c);
+ return token;
+ * @return {number} Numeric token value.
+ * @private
+ol.format.WKT.Lexer.prototype.readNumber_ = function() {
+ var c, index = this.index_;
+ var decimal = false;
+ var scientificNotation = false;
+ do {
+ if (c == '.') {
+ decimal = true;
+ } else if (c == 'e' || c == 'E') {
+ scientificNotation = true;
+ c = this.nextChar_();
+ } while (
+ this.isNumeric_(c, decimal) ||
+ // if we haven't detected a scientific number before, 'e' or 'E'
+ // hint that we should continue to read
+ !scientificNotation && (c == 'e' || c == 'E') ||
+ // once we know that we have a scientific number, both '-' and '+'
+ // are allowed
+ scientificNotation && (c == '-' || c == '+')
+ return parseFloat(this.wkt.substring(index, this.index_--));
+ * @return {string} String token value.
+ * @private
+ol.format.WKT.Lexer.prototype.readText_ = function() {
+ do {
+ } while (this.isAlpha_(c));
+ return this.wkt.substring(index, this.index_--).toUpperCase();
+ * Class to parse the tokens from the WKT string.
+ * @param {ol.format.WKT.Lexer} lexer The lexer.
+ * @constructor
+ * @protected
+ol.format.WKT.Parser = function(lexer) {
+ * @type {ol.format.WKT.Lexer}
+ * @private
+ this.lexer_ = lexer;
+ * @type {ol.WKTToken}
+ * @private
+ this.token_;
+ * @private
+ this.layout_ = ol.geom.GeometryLayout.XY;
+ * Fetch the next token form the lexer and replace the active token.
+ * @private
+ol.format.WKT.Parser.prototype.consume_ = function() {
+ this.token_ = this.lexer_.nextToken();
+ * Tests if the given type matches the type of the current token.
+ * @param {ol.format.WKT.TokenType_} type Token type.
+ * @return {boolean} Whether the token matches the given type.
+ol.format.WKT.Parser.prototype.isTokenType = function(type) {
+ var isMatch = this.token_.type == type;
+ return isMatch;
+ * If the given type matches the current token, consume it.
+ol.format.WKT.Parser.prototype.match = function(type) {
+ var isMatch = this.isTokenType(type);
+ if (isMatch) {
+ this.consume_();
+ return isMatch;
+ * Try to parse the tokens provided by the lexer.
+ * @return {ol.geom.Geometry} The geometry.
+ol.format.WKT.Parser.prototype.parse = function() {
+ this.consume_();
+ var geometry = this.parseGeometry_();
+ return geometry;
+ * Try to parse the dimensional info.
+ * @return {ol.geom.GeometryLayout} The layout.
+ * @private
+ol.format.WKT.Parser.prototype.parseGeometryLayout_ = function() {
+ var layout = ol.geom.GeometryLayout.XY;
+ var dimToken = this.token_;
+ if (this.isTokenType(ol.format.WKT.TokenType_.TEXT)) {
+ var dimInfo = dimToken.value;
+ if (dimInfo === ol.format.WKT.Z) {
+ layout = ol.geom.GeometryLayout.XYZ;
+ } else if (dimInfo === ol.format.WKT.M) {
+ layout = ol.geom.GeometryLayout.XYM;
+ } else if (dimInfo === ol.format.WKT.ZM) {
+ layout = ol.geom.GeometryLayout.XYZM;
+ if (layout !== ol.geom.GeometryLayout.XY) {
+ this.consume_();
+ return layout;
+ * @return {!ol.geom.Geometry} The geometry.
+ * @private
+ol.format.WKT.Parser.prototype.parseGeometry_ = function() {
+ var token = this.token_;
+ if (this.match(ol.format.WKT.TokenType_.TEXT)) {
+ var geomType = token.value;
+ this.layout_ = this.parseGeometryLayout_();
+ if (geomType == ol.geom.GeometryType.GEOMETRY_COLLECTION.toUpperCase()) {
+ var geometries = this.parseGeometryCollectionText_();
+ return new ol.geom.GeometryCollection(geometries);
+ } else {
+ var parser = ol.format.WKT.Parser.GeometryParser_[geomType];
+ var ctor = ol.format.WKT.Parser.GeometryConstructor_[geomType];
+ if (!parser || !ctor) {
+ throw new Error('Invalid geometry type: ' + geomType);
+ var coordinates = parser.call(this);
+ return new ctor(coordinates, this.layout_);
+ throw new Error(this.formatErrorMessage_());
+ * @return {!Array.<ol.geom.Geometry>} A collection of geometries.
+ * @private
+ol.format.WKT.Parser.prototype.parseGeometryCollectionText_ = function() {
+ if (this.match(ol.format.WKT.TokenType_.LEFT_PAREN)) {
+ do {
+ geometries.push(this.parseGeometry_());
+ } while (this.match(ol.format.WKT.TokenType_.COMMA));
+ if (this.match(ol.format.WKT.TokenType_.RIGHT_PAREN)) {
+ return geometries;
+ } else if (this.isEmptyGeometry_()) {
+ return [];
+ * @return {Array.<number>} All values in a point.
+ * @private
+ol.format.WKT.Parser.prototype.parsePointText_ = function() {
+ var coordinates = this.parsePoint_();
+ return null;
+ * @return {!Array.<!Array.<number>>} All points in a linestring.
+ * @private
+ol.format.WKT.Parser.prototype.parseLineStringText_ = function() {
+ var coordinates = this.parsePointList_();
+ return [];
+ * @return {!Array.<!Array.<number>>} All points in a polygon.
+ * @private
+ol.format.WKT.Parser.prototype.parsePolygonText_ = function() {
+ var coordinates = this.parseLineStringTextList_();
+ return [];
+ * @return {!Array.<!Array.<number>>} All points in a multipoint.
+ * @private
+ol.format.WKT.Parser.prototype.parseMultiPointText_ = function() {
+ var coordinates;
+ if (this.token_.type == ol.format.WKT.TokenType_.LEFT_PAREN) {
+ coordinates = this.parsePointTextList_();
+ } else {
+ coordinates = this.parsePointList_();
+ return [];
+ * @return {!Array.<!Array.<number>>} All linestring points
+ * in a multilinestring.
+ * @private
+ol.format.WKT.Parser.prototype.parseMultiLineStringText_ = function() {
+ return [];
+ * @return {!Array.<!Array.<number>>} All polygon points in a multipolygon.
+ * @private
+ol.format.WKT.Parser.prototype.parseMultiPolygonText_ = function() {
+ var coordinates = this.parsePolygonTextList_();
+ return [];
+ * @return {!Array.<number>} A point.
+ * @private
+ol.format.WKT.Parser.prototype.parsePoint_ = function() {
+ var dimensions = this.layout_.length;
+ for (var i = 0; i < dimensions; ++i) {
+ if (this.match(ol.format.WKT.TokenType_.NUMBER)) {
+ coordinates.push(token.value);
+ } else {
+ break;
+ if (coordinates.length == dimensions) {
+ * @return {!Array.<!Array.<number>>} An array of points.
+ * @private
+ol.format.WKT.Parser.prototype.parsePointList_ = function() {
+ var coordinates = [this.parsePoint_()];
+ while (this.match(ol.format.WKT.TokenType_.COMMA)) {
+ coordinates.push(this.parsePoint_());
+ * @private
+ol.format.WKT.Parser.prototype.parsePointTextList_ = function() {
+ var coordinates = [this.parsePointText_()];
+ coordinates.push(this.parsePointText_());
+ * @private
+ol.format.WKT.Parser.prototype.parseLineStringTextList_ = function() {
+ var coordinates = [this.parseLineStringText_()];
+ coordinates.push(this.parseLineStringText_());
+ * @private
+ol.format.WKT.Parser.prototype.parsePolygonTextList_ = function() {
+ var coordinates = [this.parsePolygonText_()];
+ coordinates.push(this.parsePolygonText_());
+ * @return {boolean} Whether the token implies an empty geometry.
+ * @private
+ol.format.WKT.Parser.prototype.isEmptyGeometry_ = function() {
+ var isEmpty = this.isTokenType(ol.format.WKT.TokenType_.TEXT) &&
+ this.token_.value == ol.format.WKT.EMPTY;
+ if (isEmpty) {
+ this.consume_();
+ return isEmpty;
+ * Create an error message for an unexpected token error.
+ * @return {string} Error message.
+ * @private
+ol.format.WKT.Parser.prototype.formatErrorMessage_ = function() {
+ return 'Unexpected `' + this.token_.value + '` at position ' +
+ this.token_.position + ' in `' + this.lexer_.wkt + '`';
+ * @enum {function (new:ol.geom.Geometry, Array, ol.geom.GeometryLayout)}
+ * @private
+ol.format.WKT.Parser.GeometryConstructor_ = {
+ 'POINT': ol.geom.Point,
+ 'LINESTRING': ol.geom.LineString,
+ 'POLYGON': ol.geom.Polygon,
+ 'MULTIPOINT': ol.geom.MultiPoint,
+ 'MULTILINESTRING': ol.geom.MultiLineString,
+ 'MULTIPOLYGON': ol.geom.MultiPolygon
+ * @enum {(function(): Array)}
+ * @private
+ol.format.WKT.Parser.GeometryParser_ = {
+ 'POINT': ol.format.WKT.Parser.prototype.parsePointText_,
+ 'LINESTRING': ol.format.WKT.Parser.prototype.parseLineStringText_,
+ 'POLYGON': ol.format.WKT.Parser.prototype.parsePolygonText_,
+ 'MULTIPOINT': ol.format.WKT.Parser.prototype.parseMultiPointText_,
+ 'MULTILINESTRING': ol.format.WKT.Parser.prototype.parseMultiLineStringText_,
+ 'MULTIPOLYGON': ol.format.WKT.Parser.prototype.parseMultiPolygonText_
+goog.provide('ol.format.WMSCapabilities');
+goog.require('ol');
+goog.require('ol.format.XLink');
+goog.require('ol.format.XML');
+goog.require('ol.format.XSD');
+goog.require('ol.xml');
+ * @classdesc
+ * Format for reading WMS capabilities data
+ * @constructor
+ * @extends {ol.format.XML}
+ * @api
+ol.format.WMSCapabilities = function() {
+ ol.format.XML.call(this);
+ * @type {string|undefined}
+ this.version = undefined;
+ol.inherits(ol.format.WMSCapabilities, ol.format.XML);
+ * Read a WMS capabilities document.
+ * @function
+ * @param {Document|Node|string} source The XML source.
+ * @return {Object} An object representing the WMS capabilities.
+ * @api
+ol.format.WMSCapabilities.prototype.read;
+ * @inheritDoc
+ol.format.WMSCapabilities.prototype.readFromDocument = function(doc) {
+ for (var n = doc.firstChild; n; n = n.nextSibling) {
+ if (n.nodeType == Node.ELEMENT_NODE) {
+ return this.readFromNode(n);
+ return null;
+ * @inheritDoc
+ol.format.WMSCapabilities.prototype.readFromNode = function(node) {
+ this.version = node.getAttribute('version').trim();
+ var wmsCapabilityObject = ol.xml.pushParseAndPop({
+ 'version': this.version
+ }, ol.format.WMSCapabilities.PARSERS_, node, []);
+ return wmsCapabilityObject ? wmsCapabilityObject : null;
+ * @private
+ * @param {Node} node Node.
+ * @param {Array.<*>} objectStack Object stack.
+ * @return {Object|undefined} Attribution object.
+ol.format.WMSCapabilities.readAttribution_ = function(node, objectStack) {
+ return ol.xml.pushParseAndPop(
+ {}, ol.format.WMSCapabilities.ATTRIBUTION_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object} Bounding box object.
+ol.format.WMSCapabilities.readBoundingBox_ = function(node, objectStack) {
+ var extent = [
+ ol.format.XSD.readDecimalString(node.getAttribute('minx')),
+ ol.format.XSD.readDecimalString(node.getAttribute('miny')),
+ ol.format.XSD.readDecimalString(node.getAttribute('maxx')),
+ ol.format.XSD.readDecimalString(node.getAttribute('maxy'))
+ var resolutions = [
+ ol.format.XSD.readDecimalString(node.getAttribute('resx')),
+ ol.format.XSD.readDecimalString(node.getAttribute('resy'))
+ return {
+ 'crs': node.getAttribute('CRS'),
+ 'extent': extent,
+ 'res': resolutions
+ * @private
+ * @return {ol.Extent|undefined} Bounding box object.
+ol.format.WMSCapabilities.readEXGeographicBoundingBox_ = function(node, objectStack) {
+ var geographicBoundingBox = ol.xml.pushParseAndPop(
+ ol.format.WMSCapabilities.EX_GEOGRAPHIC_BOUNDING_BOX_PARSERS_,
+ node, objectStack);
+ if (!geographicBoundingBox) {
+ return undefined;
+ var westBoundLongitude = /** @type {number|undefined} */
+ (geographicBoundingBox['westBoundLongitude']);
+ var southBoundLatitude = /** @type {number|undefined} */
+ (geographicBoundingBox['southBoundLatitude']);
+ var eastBoundLongitude = /** @type {number|undefined} */
+ (geographicBoundingBox['eastBoundLongitude']);
+ var northBoundLatitude = /** @type {number|undefined} */
+ (geographicBoundingBox['northBoundLatitude']);
+ if (westBoundLongitude === undefined || southBoundLatitude === undefined ||
+ eastBoundLongitude === undefined || northBoundLatitude === undefined) {
+ return undefined;
+ return [
+ westBoundLongitude, southBoundLatitude,
+ eastBoundLongitude, northBoundLatitude
+ * @private
+ * @return {Object|undefined} Capability object.
+ol.format.WMSCapabilities.readCapability_ = function(node, objectStack) {
+ {}, ol.format.WMSCapabilities.CAPABILITY_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} Service object.
+ol.format.WMSCapabilities.readService_ = function(node, objectStack) {
+ {}, ol.format.WMSCapabilities.SERVICE_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} Contact information object.
+ol.format.WMSCapabilities.readContactInformation_ = function(node, objectStack) {
+ {}, ol.format.WMSCapabilities.CONTACT_INFORMATION_PARSERS_,
+ * @private
+ * @return {Object|undefined} Contact person object.
+ol.format.WMSCapabilities.readContactPersonPrimary_ = function(node, objectStack) {
+ {}, ol.format.WMSCapabilities.CONTACT_PERSON_PARSERS_,
+ * @private
+ * @return {Object|undefined} Contact address object.
+ol.format.WMSCapabilities.readContactAddress_ = function(node, objectStack) {
+ {}, ol.format.WMSCapabilities.CONTACT_ADDRESS_PARSERS_,
+ * @private
+ * @return {Array.<string>|undefined} Format array.
+ol.format.WMSCapabilities.readException_ = function(node, objectStack) {
+ [], ol.format.WMSCapabilities.EXCEPTION_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} Layer object.
+ol.format.WMSCapabilities.readCapabilityLayer_ = function(node, objectStack) {
+ {}, ol.format.WMSCapabilities.LAYER_PARSERS_, node, objectStack);
+ * @private
+ol.format.WMSCapabilities.readLayer_ = function(node, objectStack) {
+ var parentLayerObject = /** @type {Object.<string,*>} */
+ (objectStack[objectStack.length - 1]);
+ var layerObject = ol.xml.pushParseAndPop(
+ if (!layerObject) {
+ return undefined;
+ var queryable =
+ ol.format.XSD.readBooleanString(node.getAttribute('queryable'));
+ if (queryable === undefined) {
+ queryable = parentLayerObject['queryable'];
+ layerObject['queryable'] = queryable !== undefined ? queryable : false;
+ var cascaded = ol.format.XSD.readNonNegativeIntegerString(
+ node.getAttribute('cascaded'));
+ if (cascaded === undefined) {
+ cascaded = parentLayerObject['cascaded'];
+ layerObject['cascaded'] = cascaded;
+ var opaque = ol.format.XSD.readBooleanString(node.getAttribute('opaque'));
+ if (opaque === undefined) {
+ opaque = parentLayerObject['opaque'];
+ layerObject['opaque'] = opaque !== undefined ? opaque : false;
+ var noSubsets =
+ ol.format.XSD.readBooleanString(node.getAttribute('noSubsets'));
+ if (noSubsets === undefined) {
+ noSubsets = parentLayerObject['noSubsets'];
+ layerObject['noSubsets'] = noSubsets !== undefined ? noSubsets : false;
+ var fixedWidth =
+ ol.format.XSD.readDecimalString(node.getAttribute('fixedWidth'));
+ if (!fixedWidth) {
+ fixedWidth = parentLayerObject['fixedWidth'];
+ layerObject['fixedWidth'] = fixedWidth;
+ var fixedHeight =
+ ol.format.XSD.readDecimalString(node.getAttribute('fixedHeight'));
+ if (!fixedHeight) {
+ fixedHeight = parentLayerObject['fixedHeight'];
+ layerObject['fixedHeight'] = fixedHeight;
+ // See 7.2.4.8
+ var addKeys = ['Style', 'CRS', 'AuthorityURL'];
+ addKeys.forEach(function(key) {
+ if (key in parentLayerObject) {
+ var childValue = layerObject[key] || [];
+ layerObject[key] = childValue.concat(parentLayerObject[key]);
+ var replaceKeys = ['EX_GeographicBoundingBox', 'BoundingBox', 'Dimension',
+ 'Attribution', 'MinScaleDenominator', 'MaxScaleDenominator'];
+ replaceKeys.forEach(function(key) {
+ if (!(key in layerObject)) {
+ var parentValue = parentLayerObject[key];
+ layerObject[key] = parentValue;
+ return layerObject;
+ * @private
+ * @return {Object} Dimension object.
+ol.format.WMSCapabilities.readDimension_ = function(node, objectStack) {
+ var dimensionObject = {
+ 'name': node.getAttribute('name'),
+ 'units': node.getAttribute('units'),
+ 'unitSymbol': node.getAttribute('unitSymbol'),
+ 'default': node.getAttribute('default'),
+ 'multipleValues': ol.format.XSD.readBooleanString(
+ node.getAttribute('multipleValues')),
+ 'nearestValue': ol.format.XSD.readBooleanString(
+ node.getAttribute('nearestValue')),
+ 'current': ol.format.XSD.readBooleanString(node.getAttribute('current')),
+ 'values': ol.format.XSD.readString(node)
+ return dimensionObject;
+ * @private
+ * @return {Object|undefined} Online resource object.
+ol.format.WMSCapabilities.readFormatOnlineresource_ = function(node, objectStack) {
+ {}, ol.format.WMSCapabilities.FORMAT_ONLINERESOURCE_PARSERS_,
+ * @private
+ * @return {Object|undefined} Request object.
+ol.format.WMSCapabilities.readRequest_ = function(node, objectStack) {
+ {}, ol.format.WMSCapabilities.REQUEST_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} DCP type object.
+ol.format.WMSCapabilities.readDCPType_ = function(node, objectStack) {
+ {}, ol.format.WMSCapabilities.DCPTYPE_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} HTTP object.
+ol.format.WMSCapabilities.readHTTP_ = function(node, objectStack) {
+ {}, ol.format.WMSCapabilities.HTTP_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} Operation type object.
+ol.format.WMSCapabilities.readOperationType_ = function(node, objectStack) {
+ {}, ol.format.WMSCapabilities.OPERATIONTYPE_PARSERS_, node, objectStack);
+ * @private
+ol.format.WMSCapabilities.readSizedFormatOnlineresource_ = function(node, objectStack) {
+ var formatOnlineresource =
+ ol.format.WMSCapabilities.readFormatOnlineresource_(node, objectStack);
+ if (formatOnlineresource) {
+ var size = [
+ ol.format.XSD.readNonNegativeIntegerString(node.getAttribute('width')),
+ ol.format.XSD.readNonNegativeIntegerString(node.getAttribute('height'))
+ formatOnlineresource['size'] = size;
+ return formatOnlineresource;
+ return undefined;
+ * @private
+ * @return {Object|undefined} Authority URL object.
+ol.format.WMSCapabilities.readAuthorityURL_ = function(node, objectStack) {
+ var authorityObject =
+ if (authorityObject) {
+ authorityObject['name'] = node.getAttribute('name');
+ return authorityObject;
+ return undefined;
+ * @private
+ * @return {Object|undefined} Metadata URL object.
+ol.format.WMSCapabilities.readMetadataURL_ = function(node, objectStack) {
+ var metadataObject =
+ if (metadataObject) {
+ metadataObject['type'] = node.getAttribute('type');
+ return metadataObject;
+ return undefined;
+ * @private
+ * @return {Object|undefined} Style object.
+ol.format.WMSCapabilities.readStyle_ = function(node, objectStack) {
+ {}, ol.format.WMSCapabilities.STYLE_PARSERS_, node, objectStack);
+ * @private
+ * @return {Array.<string>|undefined} Keyword list.
+ol.format.WMSCapabilities.readKeywordList_ = function(node, objectStack) {
+ [], ol.format.WMSCapabilities.KEYWORDLIST_PARSERS_, node, objectStack);
+ * @const
+ * @private
+ * @type {Array.<string>}
+ol.format.WMSCapabilities.NAMESPACE_URIS_ = [
+ null,
+ 'http://www.opengis.net/wms'
+ * @const
+ * @type {Object.<string, Object.<string, ol.XmlParser>>}
+ * @private
+ol.format.WMSCapabilities.PARSERS_ = ol.xml.makeStructureNS(
+ ol.format.WMSCapabilities.NAMESPACE_URIS_, {
+ 'Service': ol.xml.makeObjectPropertySetter(
+ ol.format.WMSCapabilities.readService_),
+ 'Capability': ol.xml.makeObjectPropertySetter(
+ ol.format.WMSCapabilities.readCapability_)
+ * @const
+ * @private
+ol.format.WMSCapabilities.CAPABILITY_PARSERS_ = ol.xml.makeStructureNS(
+ 'Request': ol.xml.makeObjectPropertySetter(
+ ol.format.WMSCapabilities.readRequest_),
+ 'Exception': ol.xml.makeObjectPropertySetter(
+ ol.format.WMSCapabilities.readException_),
+ 'Layer': ol.xml.makeObjectPropertySetter(
+ ol.format.WMSCapabilities.readCapabilityLayer_)
+ * @const
+ * @private
+ol.format.WMSCapabilities.SERVICE_PARSERS_ = ol.xml.makeStructureNS(
+ 'Name': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'Title': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'Abstract': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'KeywordList': ol.xml.makeObjectPropertySetter(
+ ol.format.WMSCapabilities.readKeywordList_),
+ 'OnlineResource': ol.xml.makeObjectPropertySetter(
+ ol.format.XLink.readHref),
+ 'ContactInformation': ol.xml.makeObjectPropertySetter(
+ ol.format.WMSCapabilities.readContactInformation_),
+ 'Fees': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'AccessConstraints': ol.xml.makeObjectPropertySetter(
+ ol.format.XSD.readString),
+ 'LayerLimit': ol.xml.makeObjectPropertySetter(
+ 'MaxWidth': ol.xml.makeObjectPropertySetter(
+ 'MaxHeight': ol.xml.makeObjectPropertySetter(
+ * @const
+ * @private
+ol.format.WMSCapabilities.CONTACT_INFORMATION_PARSERS_ = ol.xml.makeStructureNS(
+ 'ContactPersonPrimary': ol.xml.makeObjectPropertySetter(
+ ol.format.WMSCapabilities.readContactPersonPrimary_),
+ 'ContactPosition': ol.xml.makeObjectPropertySetter(
+ 'ContactAddress': ol.xml.makeObjectPropertySetter(
+ ol.format.WMSCapabilities.readContactAddress_),
+ 'ContactVoiceTelephone': ol.xml.makeObjectPropertySetter(
+ 'ContactFacsimileTelephone': ol.xml.makeObjectPropertySetter(
+ 'ContactElectronicMailAddress': ol.xml.makeObjectPropertySetter(
+ * @const
+ * @private
+ol.format.WMSCapabilities.CONTACT_PERSON_PARSERS_ = ol.xml.makeStructureNS(
+ 'ContactPerson': ol.xml.makeObjectPropertySetter(
+ 'ContactOrganization': ol.xml.makeObjectPropertySetter(
+ * @const
+ * @private
+ol.format.WMSCapabilities.CONTACT_ADDRESS_PARSERS_ = ol.xml.makeStructureNS(
+ 'AddressType': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'Address': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'City': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'StateOrProvince': ol.xml.makeObjectPropertySetter(
+ 'PostCode': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ 'Country': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString)
+ * @const
+ * @private
+ol.format.WMSCapabilities.EXCEPTION_PARSERS_ = ol.xml.makeStructureNS(
+ 'Format': ol.xml.makeArrayPusher(ol.format.XSD.readString)
+ * @const
+ * @private
+ol.format.WMSCapabilities.LAYER_PARSERS_ = ol.xml.makeStructureNS(
+ 'CRS': ol.xml.makeObjectPropertyPusher(ol.format.XSD.readString),
+ 'EX_GeographicBoundingBox': ol.xml.makeObjectPropertySetter(
+ ol.format.WMSCapabilities.readEXGeographicBoundingBox_),
+ 'BoundingBox': ol.xml.makeObjectPropertyPusher(
+ ol.format.WMSCapabilities.readBoundingBox_),
+ 'Dimension': ol.xml.makeObjectPropertyPusher(
+ ol.format.WMSCapabilities.readDimension_),
+ 'Attribution': ol.xml.makeObjectPropertySetter(
+ ol.format.WMSCapabilities.readAttribution_),
+ 'AuthorityURL': ol.xml.makeObjectPropertyPusher(
+ ol.format.WMSCapabilities.readAuthorityURL_),
+ 'Identifier': ol.xml.makeObjectPropertyPusher(ol.format.XSD.readString),
+ 'MetadataURL': ol.xml.makeObjectPropertyPusher(
+ ol.format.WMSCapabilities.readMetadataURL_),
+ 'DataURL': ol.xml.makeObjectPropertyPusher(
+ ol.format.WMSCapabilities.readFormatOnlineresource_),
+ 'FeatureListURL': ol.xml.makeObjectPropertyPusher(
+ 'Style': ol.xml.makeObjectPropertyPusher(
+ ol.format.WMSCapabilities.readStyle_),
+ 'MinScaleDenominator': ol.xml.makeObjectPropertySetter(
+ ol.format.XSD.readDecimal),
+ 'MaxScaleDenominator': ol.xml.makeObjectPropertySetter(
+ 'Layer': ol.xml.makeObjectPropertyPusher(
+ ol.format.WMSCapabilities.readLayer_)
+ * @const
+ * @private
+ol.format.WMSCapabilities.ATTRIBUTION_PARSERS_ = ol.xml.makeStructureNS(
+ 'LogoURL': ol.xml.makeObjectPropertySetter(
+ ol.format.WMSCapabilities.readSizedFormatOnlineresource_)
+ * @const
+ * @private
+ol.format.WMSCapabilities.EX_GEOGRAPHIC_BOUNDING_BOX_PARSERS_ =
+ ol.xml.makeStructureNS(ol.format.WMSCapabilities.NAMESPACE_URIS_, {
+ 'westBoundLongitude': ol.xml.makeObjectPropertySetter(
+ 'eastBoundLongitude': ol.xml.makeObjectPropertySetter(
+ 'southBoundLatitude': ol.xml.makeObjectPropertySetter(
+ 'northBoundLatitude': ol.xml.makeObjectPropertySetter(
+ * @const
+ * @private
+ol.format.WMSCapabilities.REQUEST_PARSERS_ = ol.xml.makeStructureNS(
+ 'GetCapabilities': ol.xml.makeObjectPropertySetter(
+ ol.format.WMSCapabilities.readOperationType_),
+ 'GetMap': ol.xml.makeObjectPropertySetter(
+ 'GetFeatureInfo': ol.xml.makeObjectPropertySetter(
+ * @const
+ * @private
+ol.format.WMSCapabilities.OPERATIONTYPE_PARSERS_ = ol.xml.makeStructureNS(
+ 'Format': ol.xml.makeObjectPropertyPusher(ol.format.XSD.readString),
+ 'DCPType': ol.xml.makeObjectPropertyPusher(
+ ol.format.WMSCapabilities.readDCPType_)
+ * @const
+ * @private
+ol.format.WMSCapabilities.DCPTYPE_PARSERS_ = ol.xml.makeStructureNS(
+ 'HTTP': ol.xml.makeObjectPropertySetter(
+ ol.format.WMSCapabilities.readHTTP_)
+ * @const
+ * @private
+ol.format.WMSCapabilities.HTTP_PARSERS_ = ol.xml.makeStructureNS(
+ 'Get': ol.xml.makeObjectPropertySetter(
+ 'Post': ol.xml.makeObjectPropertySetter(
+ * @const
+ * @private
+ol.format.WMSCapabilities.STYLE_PARSERS_ = ol.xml.makeStructureNS(
+ 'LegendURL': ol.xml.makeObjectPropertyPusher(
+ ol.format.WMSCapabilities.readSizedFormatOnlineresource_),
+ 'StyleSheetURL': ol.xml.makeObjectPropertySetter(
+ 'StyleURL': ol.xml.makeObjectPropertySetter(
+ * @const
+ * @private
+ol.format.WMSCapabilities.FORMAT_ONLINERESOURCE_PARSERS_ =
+ 'Format': ol.xml.makeObjectPropertySetter(ol.format.XSD.readString),
+ * @const
+ * @private
+ol.format.WMSCapabilities.KEYWORDLIST_PARSERS_ = ol.xml.makeStructureNS(
+ 'Keyword': ol.xml.makeArrayPusher(ol.format.XSD.readString)
+goog.provide('ol.format.WMSGetFeatureInfo');
+goog.require('ol.array');
+goog.require('ol.format.XMLFeature');
+goog.require('ol.obj');
+ * @classdesc
+ * Format for reading WMSGetFeatureInfo format. It uses
+ * {@link ol.format.GML2} to read features.
+ * @constructor
+ * @extends {ol.format.XMLFeature}
+ * @param {olx.format.WMSGetFeatureInfoOptions=} opt_options Options.
+ * @api
+ol.format.WMSGetFeatureInfo = function(opt_options) {
+ var options = opt_options ? opt_options : {};
+ * @private
+ * @type {string}
+ this.featureNS_ = 'http://mapserver.gis.umn.edu/mapserver';
+ * @private
+ * @type {ol.format.GML2}
+ this.gmlFormat_ = new ol.format.GML2();
+ * @private
+ this.layers_ = options.layers ? options.layers : null;
+ ol.format.XMLFeature.call(this);
+ol.inherits(ol.format.WMSGetFeatureInfo, ol.format.XMLFeature);
+ * @const
+ * @type {string}
+ * @private
+ol.format.WMSGetFeatureInfo.featureIdentifier_ = '_feature';
+ * @const
+ * @type {string}
+ * @private
+ol.format.WMSGetFeatureInfo.layerIdentifier_ = '_layer';
+ * @return {Array.<ol.Feature>} Features.
+ * @private
+ol.format.WMSGetFeatureInfo.prototype.readFeatures_ = function(node, objectStack) {
+ node.setAttribute('namespaceURI', this.featureNS_);
+ var localName = node.localName;
+ var features = [];
+ if (node.childNodes.length === 0) {
+ return features;
+ if (localName == 'msGMLOutput') {
+ for (var i = 0, ii = node.childNodes.length; i < ii; i++) {
+ var layer = node.childNodes[i];
+ if (layer.nodeType !== Node.ELEMENT_NODE) {
+ continue;
+ var context = objectStack[0];
+ var toRemove = ol.format.WMSGetFeatureInfo.layerIdentifier_;
+ var layerName = layer.localName.replace(toRemove, '');
+ if (this.layers_ && !ol.array.includes(this.layers_, layerName)) {
+ continue;
+ var featureType = layerName +
+ ol.format.WMSGetFeatureInfo.featureIdentifier_;
+ context['featureType'] = featureType;
+ context['featureNS'] = this.featureNS_;
+ var parsers = {};
+ parsers[featureType] = ol.xml.makeArrayPusher(
+ this.gmlFormat_.readFeatureElement, this.gmlFormat_);
+ var parsersNS = ol.xml.makeStructureNS(
+ [context['featureNS'], null], parsers);
+ layer.setAttribute('namespaceURI', this.featureNS_);
+ var layerFeatures = ol.xml.pushParseAndPop(
+ [], parsersNS, layer, objectStack, this.gmlFormat_);
+ if (layerFeatures) {
+ ol.array.extend(features, layerFeatures);
+ if (localName == 'FeatureCollection') {
+ var gmlFeatures = ol.xml.pushParseAndPop([],
+ [{}], this.gmlFormat_);
+ if (gmlFeatures) {
+ features = gmlFeatures;
+ return features;
+ * Read all features from a WMSGetFeatureInfo response.
+ * @function
+ * @param {Document|Node|Object|string} source Source.
+ * @param {olx.format.ReadOptions=} opt_options Options.
+ * @api
+ol.format.WMSGetFeatureInfo.prototype.readFeatures;
+ * @inheritDoc
+ol.format.WMSGetFeatureInfo.prototype.readFeaturesFromNode = function(node, opt_options) {
+ var options = {};
+ if (opt_options) {
+ ol.obj.assign(options, this.getReadOptions(node, opt_options));
+ return this.readFeatures_(node, [options]);
+ * Not implemented.
+ * @inheritDoc
+ol.format.WMSGetFeatureInfo.prototype.writeFeatureNode = function(feature, opt_options) {};
+ * @inheritDoc
+ol.format.WMSGetFeatureInfo.prototype.writeFeaturesNode = function(features, opt_options) {};
+ * @inheritDoc
+ol.format.WMSGetFeatureInfo.prototype.writeGeometryNode = function(geometry, opt_options) {};
+goog.provide('ol.format.WMTSCapabilities');
+goog.require('ol.extent');
+goog.require('ol.format.OWS');
+ * @classdesc
+ * Format for reading WMTS capabilities data.
+ * @constructor
+ * @api
+ol.format.WMTSCapabilities = function() {
+ * @type {ol.format.OWS}
+ * @private
+ this.owsParser_ = new ol.format.OWS();
+ol.inherits(ol.format.WMTSCapabilities, ol.format.XML);
+ * Read a WMTS capabilities document.
+ * @function
+ * @return {Object} An object representing the WMTS capabilities.
+ * @api
+ol.format.WMTSCapabilities.prototype.read;
+ * @inheritDoc
+ol.format.WMTSCapabilities.prototype.readFromDocument = function(doc) {
+ return null;
+ * @inheritDoc
+ol.format.WMTSCapabilities.prototype.readFromNode = function(node) {
+ var version = node.getAttribute('version').trim();
+ var WMTSCapabilityObject = this.owsParser_.readFromNode(node);
+ if (!WMTSCapabilityObject) {
+ return null;
+ WMTSCapabilityObject['version'] = version;
+ WMTSCapabilityObject = ol.xml.pushParseAndPop(WMTSCapabilityObject,
+ ol.format.WMTSCapabilities.PARSERS_, node, []);
+ return WMTSCapabilityObject ? WMTSCapabilityObject : null;
+ * @private
+ol.format.WMTSCapabilities.readContents_ = function(node, objectStack) {
+ return ol.xml.pushParseAndPop({},
+ ol.format.WMTSCapabilities.CONTENTS_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} Layers object.
+ol.format.WMTSCapabilities.readLayer_ = function(node, objectStack) {
+ ol.format.WMTSCapabilities.LAYER_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} Tile Matrix Set object.
+ol.format.WMTSCapabilities.readTileMatrixSet_ = function(node, objectStack) {
+ ol.format.WMTSCapabilities.TMS_PARSERS_, node, objectStack);
+ * @private
+ol.format.WMTSCapabilities.readStyle_ = function(node, objectStack) {
+ var style = ol.xml.pushParseAndPop({},
+ ol.format.WMTSCapabilities.STYLE_PARSERS_, node, objectStack);
+ if (!style) {
+ return undefined;
+ var isDefault = node.getAttribute('isDefault') === 'true';
+ style['isDefault'] = isDefault;
+ return style;
+ * @private
+ * @return {Object|undefined} Tile Matrix Set Link object.
+ol.format.WMTSCapabilities.readTileMatrixSetLink_ = function(node,
+ objectStack) {
+ ol.format.WMTSCapabilities.TMS_LINKS_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} Dimension object.
+ol.format.WMTSCapabilities.readDimensions_ = function(node, objectStack) {
+ ol.format.WMTSCapabilities.DIMENSION_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} Resource URL object.
+ol.format.WMTSCapabilities.readResourceUrl_ = function(node, objectStack) {
+ var format = node.getAttribute('format');
+ var template = node.getAttribute('template');
+ var resourceType = node.getAttribute('resourceType');
+ var resource = {};
+ if (format) {
+ resource['format'] = format;
+ if (template) {
+ resource['template'] = template;
+ if (resourceType) {
+ resource['resourceType'] = resourceType;
+ return resource;
+ * @private
+ * @return {Object|undefined} WGS84 BBox object.
+ol.format.WMTSCapabilities.readWgs84BoundingBox_ = function(node, objectStack) {
+ var coordinates = ol.xml.pushParseAndPop([],
+ ol.format.WMTSCapabilities.WGS84_BBOX_READERS_, node, objectStack);
+ if (coordinates.length != 2) {
+ return undefined;
+ return ol.extent.boundingExtent(coordinates);
+ * @private
+ * @return {Object|undefined} Legend object.
+ol.format.WMTSCapabilities.readLegendUrl_ = function(node, objectStack) {
+ var legend = {};
+ legend['format'] = node.getAttribute('format');
+ legend['href'] = ol.format.XLink.readHref(node);
+ return legend;
+ * @private
+ * @return {Object|undefined} Coordinates object.
+ol.format.WMTSCapabilities.readCoordinates_ = function(node, objectStack) {
+ var coordinates = ol.format.XSD.readString(node).split(' ');
+ if (!coordinates || coordinates.length != 2) {
+ return undefined;
+ var x = +coordinates[0];
+ var y = +coordinates[1];
+ if (isNaN(x) || isNaN(y)) {
+ return undefined;
+ return [x, y];
+ * @private
+ * @return {Object|undefined} TileMatrix object.
+ol.format.WMTSCapabilities.readTileMatrix_ = function(node, objectStack) {
+ ol.format.WMTSCapabilities.TM_PARSERS_, node, objectStack);
+ * @private
+ * @return {Object|undefined} TileMatrixSetLimits Object.
+ol.format.WMTSCapabilities.readTileMatrixLimitsList_ = function(node,
+ objectStack) {
+ return ol.xml.pushParseAndPop([],
+ ol.format.WMTSCapabilities.TMS_LIMITS_LIST_PARSERS_, node,
+ objectStack);
+ * @private
+ * @return {Object|undefined} TileMatrixLimits Array.
+ol.format.WMTSCapabilities.readTileMatrixLimits_ = function(node, objectStack) {
+ ol.format.WMTSCapabilities.TMS_LIMITS_PARSERS_, node, objectStack);
+ * @const
+ * @private
+ol.format.WMTSCapabilities.NAMESPACE_URIS_ = [
+ null,
+ 'http://www.opengis.net/wmts/1.0'
+ * @const
+ * @private
+ol.format.WMTSCapabilities.OWS_NAMESPACE_URIS_ = [
+ null,
+ 'http://www.opengis.net/ows/1.1'
+ * @const
+ * @private
+ol.format.WMTSCapabilities.PARSERS_ = ol.xml.makeStructureNS(
+ ol.format.WMTSCapabilities.NAMESPACE_URIS_, {
+ 'Contents': ol.xml.makeObjectPropertySetter(
+ ol.format.WMTSCapabilities.readContents_)
+ * @const
+ * @private
+ol.format.WMTSCapabilities.CONTENTS_PARSERS_ = ol.xml.makeStructureNS(
+ ol.format.WMTSCapabilities.readLayer_),
+ 'TileMatrixSet': ol.xml.makeObjectPropertyPusher(
+ ol.format.WMTSCapabilities.readTileMatrixSet_)
+ * @const
+ * @private
+ol.format.WMTSCapabilities.LAYER_PARSERS_ = ol.xml.makeStructureNS(
+ ol.format.WMTSCapabilities.readStyle_),
+ 'TileMatrixSetLink': ol.xml.makeObjectPropertyPusher(
+ ol.format.WMTSCapabilities.readTileMatrixSetLink_),
+ ol.format.WMTSCapabilities.readDimensions_),
+ 'ResourceURL': ol.xml.makeObjectPropertyPusher(
+ ol.format.WMTSCapabilities.readResourceUrl_)
+ }, ol.xml.makeStructureNS(ol.format.WMTSCapabilities.OWS_NAMESPACE_URIS_, {
+ 'WGS84BoundingBox': ol.xml.makeObjectPropertySetter(
+ ol.format.WMTSCapabilities.readWgs84BoundingBox_),
+ 'Identifier': ol.xml.makeObjectPropertySetter(
+ * @const
+ * @private
+ol.format.WMTSCapabilities.STYLE_PARSERS_ = ol.xml.makeStructureNS(
+ ol.format.WMTSCapabilities.readLegendUrl_)
+ * @const
+ * @private
+ol.format.WMTSCapabilities.TMS_LINKS_PARSERS_ = ol.xml.makeStructureNS(
+ 'TileMatrixSet': ol.xml.makeObjectPropertySetter(
+ 'TileMatrixSetLimits': ol.xml.makeObjectPropertySetter(
+ ol.format.WMTSCapabilities.readTileMatrixLimitsList_)
+ * @const
+ * @private
+ol.format.WMTSCapabilities.TMS_LIMITS_LIST_PARSERS_ = ol.xml.makeStructureNS(
+ 'TileMatrixLimits': ol.xml.makeArrayPusher(
+ ol.format.WMTSCapabilities.readTileMatrixLimits_)
+ * @const
+ * @private
+ol.format.WMTSCapabilities.TMS_LIMITS_PARSERS_ = ol.xml.makeStructureNS(
+ 'TileMatrix': ol.xml.makeObjectPropertySetter(
+ 'MinTileRow': ol.xml.makeObjectPropertySetter(
+ ol.format.XSD.readNonNegativeInteger),
+ 'MaxTileRow': ol.xml.makeObjectPropertySetter(
+ 'MinTileCol': ol.xml.makeObjectPropertySetter(
+ 'MaxTileCol': ol.xml.makeObjectPropertySetter(
+ * @const
+ * @private
+ol.format.WMTSCapabilities.DIMENSION_PARSERS_ = ol.xml.makeStructureNS(
+ 'Default': ol.xml.makeObjectPropertySetter(
+ 'Value': ol.xml.makeObjectPropertyPusher(
+ * @const
+ * @private
+ol.format.WMTSCapabilities.WGS84_BBOX_READERS_ = ol.xml.makeStructureNS(
+ ol.format.WMTSCapabilities.OWS_NAMESPACE_URIS_, {
+ 'LowerCorner': ol.xml.makeArrayPusher(
+ ol.format.WMTSCapabilities.readCoordinates_),
+ 'UpperCorner': ol.xml.makeArrayPusher(
+ * @const
+ * @private
+ol.format.WMTSCapabilities.TMS_PARSERS_ = ol.xml.makeStructureNS(
+ 'WellKnownScaleSet': ol.xml.makeObjectPropertySetter(
+ 'TileMatrix': ol.xml.makeObjectPropertyPusher(
+ ol.format.WMTSCapabilities.readTileMatrix_)
+ 'SupportedCRS': ol.xml.makeObjectPropertySetter(
+ * @const
+ * @private
+ol.format.WMTSCapabilities.TM_PARSERS_ = ol.xml.makeStructureNS(
+ 'TopLeftCorner': ol.xml.makeObjectPropertySetter(
+ 'ScaleDenominator': ol.xml.makeObjectPropertySetter(
+ 'TileWidth': ol.xml.makeObjectPropertySetter(
+ 'TileHeight': ol.xml.makeObjectPropertySetter(
+ 'MatrixWidth': ol.xml.makeObjectPropertySetter(
+ 'MatrixHeight': ol.xml.makeObjectPropertySetter(
+goog.provide('ol.GeolocationProperty');
+ * @enum {string}
+ol.GeolocationProperty = {
+ ACCURACY: 'accuracy',
+ ACCURACY_GEOMETRY: 'accuracyGeometry',
+ ALTITUDE: 'altitude',
+ ALTITUDE_ACCURACY: 'altitudeAccuracy',
+ HEADING: 'heading',
+ POSITION: 'position',
+ PROJECTION: 'projection',
+ SPEED: 'speed',
+ TRACKING: 'tracking',
+ TRACKING_OPTIONS: 'trackingOptions'
+// FIXME handle geolocation not supported
+goog.provide('ol.Geolocation');
+goog.require('ol.Object');
+goog.require('ol.GeolocationProperty');
+goog.require('ol.events');
+goog.require('ol.events.EventType');
+goog.require('ol.geom.Polygon');
+goog.require('ol.has');
+goog.require('ol.math');
+goog.require('ol.proj');
+goog.require('ol.sphere.WGS84');
+ * @classdesc
+ * Helper class for providing HTML5 Geolocation capabilities.
+ * The [Geolocation API](http://www.w3.org/TR/geolocation-API/)
+ * is used to locate a user's position.
+ * To get notified of position changes, register a listener for the generic
+ * `change` event on your instance of `ol.Geolocation`.
+ * Example:
+ * var geolocation = new ol.Geolocation({
+ * // take the projection to use from the map's view
+ * projection: view.getProjection()
+ * // listen to changes in position
+ * geolocation.on('change', function(evt) {
+ * window.console.log(geolocation.getPosition());
+ * @fires error
+ * @constructor
+ * @extends {ol.Object}
+ * @param {olx.GeolocationOptions=} opt_options Options.
+ * @api
+ol.Geolocation = function(opt_options) {
+ ol.Object.call(this);
+ var options = opt_options || {};
+ * The unprojected (EPSG:4326) device position.
+ * @private
+ * @type {ol.Coordinate}
+ this.position_ = null;
+ * @private
+ * @type {ol.TransformFunction}
+ this.transform_ = ol.proj.identityTransform;
+ * @private
+ * @type {number|undefined}
+ this.watchId_ = undefined;
+ ol.events.listen(
+ this, ol.Object.getChangeEventType(ol.GeolocationProperty.PROJECTION),
+ this.handleProjectionChanged_, this);
+ ol.events.listen(
+ this, ol.Object.getChangeEventType(ol.GeolocationProperty.TRACKING),
+ this.handleTrackingChanged_, this);
+ if (options.projection !== undefined) {
+ this.setProjection(ol.proj.get(options.projection));
+ if (options.trackingOptions !== undefined) {
+ this.setTrackingOptions(options.trackingOptions);
+ this.setTracking(options.tracking !== undefined ? options.tracking : false);
+ol.inherits(ol.Geolocation, ol.Object);
+ * @inheritDoc
+ol.Geolocation.prototype.disposeInternal = function() {
+ this.setTracking(false);
+ ol.Object.prototype.disposeInternal.call(this);
+ * @private
+ol.Geolocation.prototype.handleProjectionChanged_ = function() {
+ var projection = this.getProjection();
+ if (projection) {
+ this.transform_ = ol.proj.getTransformFromProjections(
+ ol.proj.get('EPSG:4326'), projection);
+ if (this.position_) {
+ this.set(
+ ol.GeolocationProperty.POSITION, this.transform_(this.position_));
+ * @private
+ol.Geolocation.prototype.handleTrackingChanged_ = function() {
+ if (ol.has.GEOLOCATION) {
+ var tracking = this.getTracking();
+ if (tracking && this.watchId_ === undefined) {
+ this.watchId_ = navigator.geolocation.watchPosition(
+ this.positionChange_.bind(this),
+ this.positionError_.bind(this),
+ this.getTrackingOptions());
+ } else if (!tracking && this.watchId_ !== undefined) {
+ navigator.geolocation.clearWatch(this.watchId_);
+ * @private
+ * @param {GeolocationPosition} position position event.
+ol.Geolocation.prototype.positionChange_ = function(position) {
+ var coords = position.coords;
+ this.set(ol.GeolocationProperty.ACCURACY, coords.accuracy);
+ this.set(ol.GeolocationProperty.ALTITUDE,
+ coords.altitude === null ? undefined : coords.altitude);
+ this.set(ol.GeolocationProperty.ALTITUDE_ACCURACY,
+ coords.altitudeAccuracy === null ?
+ undefined : coords.altitudeAccuracy);
+ this.set(ol.GeolocationProperty.HEADING, coords.heading === null ?
+ undefined : ol.math.toRadians(coords.heading));
+ if (!this.position_) {
+ this.position_ = [coords.longitude, coords.latitude];
+ } else {
+ this.position_[0] = coords.longitude;
+ this.position_[1] = coords.latitude;
+ var projectedPosition = this.transform_(this.position_);
+ this.set(ol.GeolocationProperty.POSITION, projectedPosition);
+ this.set(ol.GeolocationProperty.SPEED,
+ coords.speed === null ? undefined : coords.speed);
+ var geometry = ol.geom.Polygon.circular(
+ ol.sphere.WGS84, this.position_, coords.accuracy);
+ geometry.applyTransform(this.transform_);
+ this.set(ol.GeolocationProperty.ACCURACY_GEOMETRY, geometry);
+ this.changed();
+ * Triggered when the Geolocation returns an error.
+ * @event error
+ * @api
+ * @private
+ * @param {GeolocationPositionError} error error object.
+ol.Geolocation.prototype.positionError_ = function(error) {
+ error.type = ol.events.EventType.ERROR;
+ this.dispatchEvent(/** @type {{type: string, target: undefined}} */ (error));
+ * Get the accuracy of the position in meters.
+ * @return {number|undefined} The accuracy of the position measurement in
+ * meters.
+ * @observable
+ * @api
+ol.Geolocation.prototype.getAccuracy = function() {
+ return /** @type {number|undefined} */ (
+ this.get(ol.GeolocationProperty.ACCURACY));
+ * Get a geometry of the position accuracy.
+ * @return {?ol.geom.Polygon} A geometry of the position accuracy.
+ * @observable
+ * @api
+ol.Geolocation.prototype.getAccuracyGeometry = function() {
+ return /** @type {?ol.geom.Polygon} */ (
+ this.get(ol.GeolocationProperty.ACCURACY_GEOMETRY) || null);
+ * Get the altitude associated with the position.
+ * @return {number|undefined} The altitude of the position in meters above mean
+ * sea level.
+ * @observable
+ * @api
+ol.Geolocation.prototype.getAltitude = function() {
+ this.get(ol.GeolocationProperty.ALTITUDE));
+ * Get the altitude accuracy of the position.
+ * @return {number|undefined} The accuracy of the altitude measurement in
+ * meters.
+ * @observable
+ * @api
+ol.Geolocation.prototype.getAltitudeAccuracy = function() {
+ this.get(ol.GeolocationProperty.ALTITUDE_ACCURACY));
+ * Get the heading as radians clockwise from North.
+ * @return {number|undefined} The heading of the device in radians from north.
+ * @observable
+ * @api
+ol.Geolocation.prototype.getHeading = function() {
+ this.get(ol.GeolocationProperty.HEADING));
+ * Get the position of the device.
+ * @return {ol.Coordinate|undefined} The current position of the device reported
+ * in the current projection.
+ * @observable
+ * @api
+ol.Geolocation.prototype.getPosition = function() {
+ return /** @type {ol.Coordinate|undefined} */ (
+ this.get(ol.GeolocationProperty.POSITION));
+ * Get the projection associated with the position.
+ * @return {ol.proj.Projection|undefined} The projection the position is
+ * reported in.
+ * @observable
+ * @api
+ol.Geolocation.prototype.getProjection = function() {
+ return /** @type {ol.proj.Projection|undefined} */ (
+ this.get(ol.GeolocationProperty.PROJECTION));
+ * Get the speed in meters per second.
+ * @return {number|undefined} The instantaneous speed of the device in meters
+ * per second.
+ * @observable
+ * @api
+ol.Geolocation.prototype.getSpeed = function() {
+ this.get(ol.GeolocationProperty.SPEED));
+ * Determine if the device location is being tracked.
+ * @return {boolean} The device location is being tracked.
+ * @observable
+ * @api
+ol.Geolocation.prototype.getTracking = function() {
+ return /** @type {boolean} */ (
+ this.get(ol.GeolocationProperty.TRACKING));
+ * Get the tracking options.
+ * @see http://www.w3.org/TR/geolocation-API/#position-options
+ * @return {GeolocationPositionOptions|undefined} PositionOptions as defined by
+ * the [HTML5 Geolocation spec
+ * ](http://www.w3.org/TR/geolocation-API/#position_options_interface).
+ * @observable
+ * @api
+ol.Geolocation.prototype.getTrackingOptions = function() {
+ return /** @type {GeolocationPositionOptions|undefined} */ (
+ this.get(ol.GeolocationProperty.TRACKING_OPTIONS));
+ * Set the projection to use for transforming the coordinates.
+ * @param {ol.proj.Projection} projection The projection the position is
+ * reported in.
+ * @observable
+ * @api
+ol.Geolocation.prototype.setProjection = function(projection) {
+ this.set(ol.GeolocationProperty.PROJECTION, projection);
+ * Enable or disable tracking.
+ * @param {boolean} tracking Enable tracking.
+ * @observable
+ * @api
+ol.Geolocation.prototype.setTracking = function(tracking) {
+ this.set(ol.GeolocationProperty.TRACKING, tracking);
+ * Set the tracking options.
+ * @param {GeolocationPositionOptions} options PositionOptions as defined by the
+ * [HTML5 Geolocation spec
+ * @observable
+ * @api
+ol.Geolocation.prototype.setTrackingOptions = function(options) {
+ this.set(ol.GeolocationProperty.TRACKING_OPTIONS, options);
+goog.provide('ol.geom.Circle');
+goog.require('ol.geom.GeometryLayout');
+goog.require('ol.geom.GeometryType');
+goog.require('ol.geom.SimpleGeometry');
+goog.require('ol.geom.flat.deflate');
+ * @classdesc
+ * Circle geometry.
+ * @constructor
+ * @extends {ol.geom.SimpleGeometry}
+ * @param {ol.Coordinate} center Center.
+ * @param {number=} opt_radius Radius.
+ * @param {ol.geom.GeometryLayout=} opt_layout Layout.
+ * @api
+ol.geom.Circle = function(center, opt_radius, opt_layout) {
+ ol.geom.SimpleGeometry.call(this);
+ var radius = opt_radius ? opt_radius : 0;
+ this.setCenterAndRadius(center, radius, opt_layout);
+ol.inherits(ol.geom.Circle, ol.geom.SimpleGeometry);
+ * Make a complete copy of the geometry.
+ * @return {!ol.geom.Circle} Clone.
+ * @override
+ * @api
+ol.geom.Circle.prototype.clone = function() {
+ var circle = new ol.geom.Circle(null);
+ circle.setFlatCoordinates(this.layout, this.flatCoordinates.slice());
+ return circle;
+ * @inheritDoc
+ol.geom.Circle.prototype.closestPointXY = function(x, y, closestPoint, minSquaredDistance) {
+ var flatCoordinates = this.flatCoordinates;
+ var dx = x - flatCoordinates[0];
+ var dy = y - flatCoordinates[1];
+ var squaredDistance = dx * dx + dy * dy;
+ if (squaredDistance < minSquaredDistance) {
+ var i;
+ if (squaredDistance === 0) {
+ for (i = 0; i < this.stride; ++i) {
+ closestPoint[i] = flatCoordinates[i];
+ } else {
+ var delta = this.getRadius() / Math.sqrt(squaredDistance);
+ closestPoint[0] = flatCoordinates[0] + delta * dx;
+ closestPoint[1] = flatCoordinates[1] + delta * dy;
+ for (i = 2; i < this.stride; ++i) {
+ closestPoint.length = this.stride;
+ return squaredDistance;
+ } else {
+ return minSquaredDistance;
+ * @inheritDoc
+ol.geom.Circle.prototype.containsXY = function(x, y) {
+ return dx * dx + dy * dy <= this.getRadiusSquared_();
+ * Return the center of the circle as {@link ol.Coordinate coordinate}.
+ * @return {ol.Coordinate} Center.
+ * @api
+ol.geom.Circle.prototype.getCenter = function() {
+ return this.flatCoordinates.slice(0, this.stride);
+ * @inheritDoc
+ol.geom.Circle.prototype.computeExtent = function(extent) {
+ var radius = flatCoordinates[this.stride] - flatCoordinates[0];
+ return ol.extent.createOrUpdate(
+ flatCoordinates[0] - radius, flatCoordinates[1] - radius,
+ flatCoordinates[0] + radius, flatCoordinates[1] + radius,
+ extent);
+ * Return the radius of the circle.
+ * @return {number} Radius.
+ * @api
+ol.geom.Circle.prototype.getRadius = function() {
+ return Math.sqrt(this.getRadiusSquared_());
+ * @private
+ * @return {number} Radius squared.
+ol.geom.Circle.prototype.getRadiusSquared_ = function() {
+ var dx = this.flatCoordinates[this.stride] - this.flatCoordinates[0];
+ var dy = this.flatCoordinates[this.stride + 1] - this.flatCoordinates[1];
+ return dx * dx + dy * dy;
+ * @inheritDoc
+ * @api
+ol.geom.Circle.prototype.getType = function() {
+ return ol.geom.GeometryType.CIRCLE;
+ * @inheritDoc
+ * @api
+ol.geom.Circle.prototype.intersectsExtent = function(extent) {
+ var circleExtent = this.getExtent();
+ if (ol.extent.intersects(extent, circleExtent)) {
+ var center = this.getCenter();
+ if (extent[0] <= center[0] && extent[2] >= center[0]) {
+ return true;
+ if (extent[1] <= center[1] && extent[3] >= center[1]) {
+ return true;
+ return ol.extent.forEachCorner(extent, this.intersectsCoordinate, this);
+ return false;
+ * Set the center of the circle as {@link ol.Coordinate coordinate}.
+ * @api
+ol.geom.Circle.prototype.setCenter = function(center) {
+ var stride = this.stride;
+ var radius = this.flatCoordinates[stride] - this.flatCoordinates[0];
+ var flatCoordinates = center.slice();
+ flatCoordinates[stride] = flatCoordinates[0] + radius;
+ var i;
+ for (i = 1; i < stride; ++i) {
+ flatCoordinates[stride + i] = center[i];
+ this.setFlatCoordinates(this.layout, flatCoordinates);
+ * Set the center (as {@link ol.Coordinate coordinate}) and the radius (as
+ * number) of the circle.
+ * @param {number} radius Radius.
+ * @api
+ol.geom.Circle.prototype.setCenterAndRadius = function(center, radius, opt_layout) {
+ if (!center) {
+ this.setFlatCoordinates(ol.geom.GeometryLayout.XY, null);
+ } else {
+ this.setLayout(opt_layout, center, 0);
+ if (!this.flatCoordinates) {
+ this.flatCoordinates = [];
+ /** @type {Array.<number>} */
+ var offset = ol.geom.flat.deflate.coordinate(
+ flatCoordinates, 0, center, this.stride);
+ flatCoordinates[offset++] = flatCoordinates[0] + radius;
+ var i, ii;
+ for (i = 1, ii = this.stride; i < ii; ++i) {
+ flatCoordinates[offset++] = flatCoordinates[i];
+ flatCoordinates.length = offset;
+ this.changed();
+ * @inheritDoc
+ol.geom.Circle.prototype.getCoordinates = function() {};
+ * @inheritDoc
+ol.geom.Circle.prototype.setCoordinates = function(coordinates, opt_layout) {};
+ * @param {ol.geom.GeometryLayout} layout Layout.
+ * @param {Array.<number>} flatCoordinates Flat coordinates.
+ol.geom.Circle.prototype.setFlatCoordinates = function(layout, flatCoordinates) {
+ this.setFlatCoordinatesInternal(layout, flatCoordinates);
+ this.changed();
+ * Set the radius of the circle. The radius is in the units of the projection.
+ * @api
+ol.geom.Circle.prototype.setRadius = function(radius) {
+ this.flatCoordinates[this.stride] = this.flatCoordinates[0] + radius;
+ this.changed();
+ * Transform each coordinate of the circle from one coordinate reference system
+ * to another. The geometry is modified in place.
+ * If you do not want the geometry modified in place, first clone() it and
+ * then use this function on the clone.
+ * Internally a circle is currently represented by two points: the center of
+ * the circle `[cx, cy]`, and the point to the right of the circle
+ * `[cx + r, cy]`. This `transform` function just transforms these two points.
+ * So the resulting geometry is also a circle, and that circle does not
+ * correspond to the shape that would be obtained by transforming every point
+ * of the original circle.
+ * @param {ol.ProjectionLike} source The current projection. Can be a
+ * string identifier or a {@link ol.proj.Projection} object.
+ * @param {ol.ProjectionLike} destination The desired projection. Can be a
+ * @return {ol.geom.Circle} This geometry. Note that original geometry is
+ * modified in place.
+ * @function
+ * @api
+ol.geom.Circle.prototype.transform;
+goog.provide('ol.geom.flat.geodesic');
+ * @private
+ * @param {function(number): ol.Coordinate} interpolate Interpolate function.
+ * @param {ol.TransformFunction} transform Transform from longitude/latitude to
+ * projected coordinates.
+ * @param {number} squaredTolerance Squared tolerance.
+ * @return {Array.<number>} Flat coordinates.
+ol.geom.flat.geodesic.line_ = function(interpolate, transform, squaredTolerance) {
+ // FIXME reduce garbage generation
+ // FIXME optimize stack operations
+ var flatCoordinates = [];
+ var geoA = interpolate(0);
+ var geoB = interpolate(1);
+ var a = transform(geoA);
+ var b = transform(geoB);
+ /** @type {Array.<ol.Coordinate>} */
+ var geoStack = [geoB, geoA];
+ var stack = [b, a];
+ var fractionStack = [1, 0];
+ /** @type {Object.<string, boolean>} */
+ var fractions = {};
+ var maxIterations = 1e5;
+ var geoM, m, fracA, fracB, fracM, key;
+ while (--maxIterations > 0 && fractionStack.length > 0) {
+ // Pop the a coordinate off the stack
+ fracA = fractionStack.pop();
+ geoA = geoStack.pop();
+ a = stack.pop();
+ // Add the a coordinate if it has not been added yet
+ key = fracA.toString();
+ if (!(key in fractions)) {
+ flatCoordinates.push(a[0], a[1]);
+ fractions[key] = true;
+ // Pop the b coordinate off the stack
+ fracB = fractionStack.pop();
+ geoB = geoStack.pop();
+ b = stack.pop();
+ // Find the m point between the a and b coordinates
+ fracM = (fracA + fracB) / 2;
+ geoM = interpolate(fracM);
+ m = transform(geoM);
+ if (ol.math.squaredSegmentDistance(m[0], m[1], a[0], a[1],
+ b[0], b[1]) < squaredTolerance) {
+ // If the m point is sufficiently close to the straight line, then we
+ // discard it. Just use the b coordinate and move on to the next line
+ // segment.
+ flatCoordinates.push(b[0], b[1]);
+ key = fracB.toString();
+ } else {
+ // Otherwise, we need to subdivide the current line segment. Split it
+ // into two and push the two line segments onto the stack.
+ fractionStack.push(fracB, fracM, fracM, fracA);
+ stack.push(b, m, m, a);
+ geoStack.push(geoB, geoM, geoM, geoA);
+ return flatCoordinates;
+* Generate a great-circle arcs between two lat/lon points.
+* @param {number} lon1 Longitude 1 in degrees.
+* @param {number} lat1 Latitude 1 in degrees.
+* @param {number} lon2 Longitude 2 in degrees.
+* @param {number} lat2 Latitude 2 in degrees.
+ * @param {ol.proj.Projection} projection Projection.
+* @param {number} squaredTolerance Squared tolerance.
+* @return {Array.<number>} Flat coordinates.
+ol.geom.flat.geodesic.greatCircleArc = function(
+ lon1, lat1, lon2, lat2, projection, squaredTolerance) {
+ var geoProjection = ol.proj.get('EPSG:4326');
+ var cosLat1 = Math.cos(ol.math.toRadians(lat1));
+ var sinLat1 = Math.sin(ol.math.toRadians(lat1));
+ var cosLat2 = Math.cos(ol.math.toRadians(lat2));
+ var sinLat2 = Math.sin(ol.math.toRadians(lat2));
+ var cosDeltaLon = Math.cos(ol.math.toRadians(lon2 - lon1));
+ var sinDeltaLon = Math.sin(ol.math.toRadians(lon2 - lon1));
+ var d = sinLat1 * sinLat2 + cosLat1 * cosLat2 * cosDeltaLon;
+ return ol.geom.flat.geodesic.line_(
+ * @param {number} frac Fraction.
+ * @return {ol.Coordinate} Coordinate.
+ function(frac) {
+ if (1 <= d) {
+ return [lon2, lat2];
+ var D = frac * Math.acos(d);
+ var cosD = Math.cos(D);
+ var sinD = Math.sin(D);
+ var y = sinDeltaLon * cosLat2;
+ var x = cosLat1 * sinLat2 - sinLat1 * cosLat2 * cosDeltaLon;
+ var theta = Math.atan2(y, x);
+ var lat = Math.asin(sinLat1 * cosD + cosLat1 * sinD * Math.cos(theta));
+ var lon = ol.math.toRadians(lon1) +
+ Math.atan2(Math.sin(theta) * sinD * cosLat1,
+ cosD - sinLat1 * Math.sin(lat));
+ return [ol.math.toDegrees(lon), ol.math.toDegrees(lat)];
+ }, ol.proj.getTransform(geoProjection, projection), squaredTolerance);
+ * Generate a meridian (line at constant longitude).
+ * @param {number} lon Longitude.
+ * @param {number} lat1 Latitude 1.
+ * @param {number} lat2 Latitude 2.
+ol.geom.flat.geodesic.meridian = function(lon, lat1, lat2, projection, squaredTolerance) {
+ var epsg4326Projection = ol.proj.get('EPSG:4326');
+ function(frac) {
+ return [lon, lat1 + ((lat2 - lat1) * frac)];
+ ol.proj.getTransform(epsg4326Projection, projection), squaredTolerance);
+ * Generate a parallel (line at constant latitude).
+ * @param {number} lat Latitude.
+ * @param {number} lon1 Longitude 1.
+ * @param {number} lon2 Longitude 2.
+ol.geom.flat.geodesic.parallel = function(lat, lon1, lon2, projection, squaredTolerance) {
+ function(frac) {
+ return [lon1 + ((lon2 - lon1) * frac), lat];
+goog.provide('ol.Graticule');
+goog.require('ol.geom.LineString');
+goog.require('ol.geom.flat.geodesic');
+goog.require('ol.render.EventType');
+goog.require('ol.style.Stroke');
+ * Render a grid for a coordinate system on a map.
+ * @constructor
+ * @param {olx.GraticuleOptions=} opt_options Options.
+ * @api
+ol.Graticule = function(opt_options) {
+ * @type {ol.Map}
+ * @private
+ this.map_ = null;
+ * @type {ol.proj.Projection}
+ * @private
+ this.projection_ = null;
+ * @type {number}
+ * @private
+ this.maxLat_ = Infinity;
+ * @type {number}
+ * @private
+ this.maxLon_ = Infinity;
+ * @type {number}
+ * @private
+ this.minLat_ = -Infinity;
+ * @type {number}
+ * @private
+ this.minLon_ = -Infinity;
+ * @type {number}
+ * @private
+ this.maxLatP_ = Infinity;
+ * @type {number}
+ * @private
+ this.maxLonP_ = Infinity;
+ * @type {number}
+ * @private
+ this.minLatP_ = -Infinity;
+ * @type {number}
+ * @private
+ this.minLonP_ = -Infinity;
+ * @type {number}
+ * @private
+ this.targetSize_ = options.targetSize !== undefined ?
+ options.targetSize : 100;
+ * @type {number}
+ * @private
+ this.maxLines_ = options.maxLines !== undefined ? options.maxLines : 100;
+ * @type {Array.<ol.geom.LineString>}
+ * @private
+ this.meridians_ = [];
+ * @private
+ this.parallels_ = [];
+ * @type {ol.style.Stroke}
+ * @private
+ this.strokeStyle_ = options.strokeStyle !== undefined ?
+ options.strokeStyle : ol.Graticule.DEFAULT_STROKE_STYLE_;
+ * @type {ol.TransformFunction|undefined}
+ * @private
+ this.fromLonLatTransform_ = undefined;
+ * @private
+ this.toLonLatTransform_ = undefined;
+ * @private
+ this.projectionCenterLonLat_ = null;
+ this.setMap(options.map !== undefined ? options.map : null);
+ * @private
+ * @const
+ol.Graticule.DEFAULT_STROKE_STYLE_ = new ol.style.Stroke({
+ color: 'rgba(0,0,0,0.2)'
+ * TODO can be configurable
+ * @type {Array.<number>}
+ * @private
+ol.Graticule.intervals_ = [90, 45, 30, 20, 10, 5, 2, 1, 0.5, 0.2, 0.1, 0.05,
+ 0.01, 0.005, 0.002, 0.001];
+ * @param {number} minLat Minimal latitude.
+ * @param {number} maxLat Maximal latitude.
+ * @param {ol.Extent} extent Extent.
+ * @param {number} index Index.
+ * @return {number} Index.
+ * @private
+ol.Graticule.prototype.addMeridian_ = function(lon, minLat, maxLat, squaredTolerance, extent, index) {
+ var lineString = this.getMeridian_(lon, minLat, maxLat,
+ squaredTolerance, index);
+ if (ol.extent.intersects(lineString.getExtent(), extent)) {
+ this.meridians_[index++] = lineString;
+ return index;
+ * @param {number} minLon Minimal longitude.
+ * @param {number} maxLon Maximal longitude.
+ * @private
+ol.Graticule.prototype.addParallel_ = function(lat, minLon, maxLon, squaredTolerance, extent, index) {
+ var lineString = this.getParallel_(lat, minLon, maxLon, squaredTolerance,
+ index);
+ this.parallels_[index++] = lineString;
+ return index;
+ * @param {number} resolution Resolution.
+ * @private
+ol.Graticule.prototype.createGraticule_ = function(extent, center, resolution, squaredTolerance) {
+ var interval = this.getInterval_(resolution);
+ if (interval == -1) {
+ this.meridians_.length = this.parallels_.length = 0;
+ return;
+ var centerLonLat = this.toLonLatTransform_(center);
+ var centerLon = centerLonLat[0];
+ var centerLat = centerLonLat[1];
+ var maxLines = this.maxLines_;
+ var cnt, idx, lat, lon;
+ var validExtent = [
+ Math.max(extent[0], this.minLonP_),
+ Math.max(extent[1], this.minLatP_),
+ Math.min(extent[2], this.maxLonP_),
+ Math.min(extent[3], this.maxLatP_)
+ validExtent = ol.proj.transformExtent(validExtent, this.projection_,
+ 'EPSG:4326');
+ var maxLat = validExtent[3];
+ var maxLon = validExtent[2];
+ var minLat = validExtent[1];
+ var minLon = validExtent[0];
+ // Create meridians
+ centerLon = Math.floor(centerLon / interval) * interval;
+ lon = ol.math.clamp(centerLon, this.minLon_, this.maxLon_);
+ idx = this.addMeridian_(lon, minLat, maxLat, squaredTolerance, extent, 0);
+ cnt = 0;
+ while (lon != this.minLon_ && cnt++ < maxLines) {
+ lon = Math.max(lon - interval, this.minLon_);
+ idx = this.addMeridian_(lon, minLat, maxLat, squaredTolerance, extent, idx);
+ cnt = 0;
+ while (lon != this.maxLon_ && cnt++ < maxLines) {
+ lon = Math.min(lon + interval, this.maxLon_);
+ this.meridians_.length = idx;
+ // Create parallels
+ centerLat = Math.floor(centerLat / interval) * interval;
+ lat = ol.math.clamp(centerLat, this.minLat_, this.maxLat_);
+ idx = this.addParallel_(lat, minLon, maxLon, squaredTolerance, extent, 0);
+ cnt = 0;
+ while (lat != this.minLat_ && cnt++ < maxLines) {
+ lat = Math.max(lat - interval, this.minLat_);
+ idx = this.addParallel_(lat, minLon, maxLon, squaredTolerance, extent, idx);
+ cnt = 0;
+ while (lat != this.maxLat_ && cnt++ < maxLines) {
+ lat = Math.min(lat + interval, this.maxLat_);
+ this.parallels_.length = idx;
+ * @return {number} The interval in degrees.
+ * @private
+ol.Graticule.prototype.getInterval_ = function(resolution) {
+ var centerLon = this.projectionCenterLonLat_[0];
+ var centerLat = this.projectionCenterLonLat_[1];
+ var interval = -1;
+ var i, ii, delta, dist;
+ var target = Math.pow(this.targetSize_ * resolution, 2);
+ /** @type {Array.<number>} **/
+ var p1 = [];
+ var p2 = [];
+ for (i = 0, ii = ol.Graticule.intervals_.length; i < ii; ++i) {
+ delta = ol.Graticule.intervals_[i] / 2;
+ p1[0] = centerLon - delta;
+ p1[1] = centerLat - delta;
+ p2[0] = centerLon + delta;
+ p2[1] = centerLat + delta;
+ this.fromLonLatTransform_(p1, p1);
+ this.fromLonLatTransform_(p2, p2);
+ dist = Math.pow(p2[0] - p1[0], 2) + Math.pow(p2[1] - p1[1], 2);
+ if (dist <= target) {
+ break;
+ interval = ol.Graticule.intervals_[i];
+ return interval;
+ * Get the map associated with this graticule.
+ * @return {ol.Map} The map.
+ * @api
+ol.Graticule.prototype.getMap = function() {
+ return this.map_;
+ * @return {ol.geom.LineString} The meridian line string.
+ * @private
+ol.Graticule.prototype.getMeridian_ = function(lon, minLat, maxLat,
+ squaredTolerance, index) {
+ var flatCoordinates = ol.geom.flat.geodesic.meridian(lon,
+ minLat, maxLat, this.projection_, squaredTolerance);
+ var lineString = this.meridians_[index] !== undefined ?
+ this.meridians_[index] : new ol.geom.LineString(null);
+ lineString.setFlatCoordinates(ol.geom.GeometryLayout.XY, flatCoordinates);
+ return lineString;
+ * Get the list of meridians. Meridians are lines of equal longitude.
+ * @return {Array.<ol.geom.LineString>} The meridians.
+ * @api
+ol.Graticule.prototype.getMeridians = function() {
+ return this.meridians_;
+ * @return {ol.geom.LineString} The parallel line string.
+ * @private
+ol.Graticule.prototype.getParallel_ = function(lat, minLon, maxLon,
+ var flatCoordinates = ol.geom.flat.geodesic.parallel(lat,
+ this.minLon_, this.maxLon_, this.projection_, squaredTolerance);
+ var lineString = this.parallels_[index] !== undefined ?
+ this.parallels_[index] : new ol.geom.LineString(null);
+ * Get the list of parallels. Pallels are lines of equal latitude.
+ * @return {Array.<ol.geom.LineString>} The parallels.
+ * @api
+ol.Graticule.prototype.getParallels = function() {
+ return this.parallels_;
+ * @param {ol.render.Event} e Event.
+ * @private
+ol.Graticule.prototype.handlePostCompose_ = function(e) {
+ var vectorContext = e.vectorContext;
+ var frameState = e.frameState;
+ var extent = frameState.extent;
+ var viewState = frameState.viewState;
+ var center = viewState.center;
+ var projection = viewState.projection;
+ var resolution = viewState.resolution;
+ var pixelRatio = frameState.pixelRatio;
+ var squaredTolerance =
+ resolution * resolution / (4 * pixelRatio * pixelRatio);
+ var updateProjectionInfo = !this.projection_ ||
+ !ol.proj.equivalent(this.projection_, projection);
+ if (updateProjectionInfo) {
+ this.updateProjectionInfo_(projection);
+ //Fix the extent if wrapped.
+ //(note: this is the same extent as vectorContext.extent_)
+ var offsetX = 0;
+ if (projection.canWrapX()) {
+ var projectionExtent = projection.getExtent();
+ var worldWidth = ol.extent.getWidth(projectionExtent);
+ var x = frameState.focus[0];
+ if (x < projectionExtent[0] || x > projectionExtent[2]) {
+ var worldsAway = Math.ceil((projectionExtent[0] - x) / worldWidth);
+ offsetX = worldWidth * worldsAway;
+ extent = [
+ extent[0] + offsetX, extent[1],
+ extent[2] + offsetX, extent[3]
+ this.createGraticule_(extent, center, resolution, squaredTolerance);
+ // Draw the lines
+ vectorContext.setFillStrokeStyle(null, this.strokeStyle_);
+ var i, l, line;
+ for (i = 0, l = this.meridians_.length; i < l; ++i) {
+ line = this.meridians_[i];
+ vectorContext.drawLineString(line, null);
+ for (i = 0, l = this.parallels_.length; i < l; ++i) {
+ line = this.parallels_[i];
+ * @private
+ol.Graticule.prototype.updateProjectionInfo_ = function(projection) {
+ var extent = projection.getExtent();
+ var worldExtent = projection.getWorldExtent();
+ var worldExtentP = ol.proj.transformExtent(worldExtent,
+ epsg4326Projection, projection);
+ var maxLat = worldExtent[3];
+ var maxLon = worldExtent[2];
+ var minLat = worldExtent[1];
+ var minLon = worldExtent[0];
+ var maxLatP = worldExtentP[3];
+ var maxLonP = worldExtentP[2];
+ var minLatP = worldExtentP[1];
+ var minLonP = worldExtentP[0];
+ this.maxLat_ = maxLat;
+ this.maxLon_ = maxLon;
+ this.minLat_ = minLat;
+ this.minLon_ = minLon;
+ this.maxLatP_ = maxLatP;
+ this.maxLonP_ = maxLonP;
+ this.minLatP_ = minLatP;
+ this.minLonP_ = minLonP;
+ this.fromLonLatTransform_ = ol.proj.getTransform(
+ this.toLonLatTransform_ = ol.proj.getTransform(
+ projection, epsg4326Projection);
+ this.projectionCenterLonLat_ = this.toLonLatTransform_(
+ ol.extent.getCenter(extent));
+ this.projection_ = projection;
+ * Set the map for this graticule. The graticule will be rendered on the
+ * provided map.
+ * @param {ol.Map} map Map.
+ * @api
+ol.Graticule.prototype.setMap = function(map) {
+ if (this.map_) {
+ this.map_.un(ol.render.EventType.POSTCOMPOSE,
+ this.handlePostCompose_, this);
+ this.map_.render();
+ if (map) {
+ map.on(ol.render.EventType.POSTCOMPOSE,
+ map.render();
+ this.map_ = map;
+goog.provide('ol.ImageBase');
+goog.require('ol.events.EventTarget');
+ * @constructor
+ * @abstract
+ * @extends {ol.events.EventTarget}
+ * @param {number|undefined} resolution Resolution.
+ * @param {number} pixelRatio Pixel ratio.
+ * @param {ol.ImageState} state State.
+ * @param {Array.<ol.Attribution>} attributions Attributions.
+ol.ImageBase = function(extent, resolution, pixelRatio, state, attributions) {
+ ol.events.EventTarget.call(this);
+ * @private
+ * @type {Array.<ol.Attribution>}
+ this.attributions_ = attributions;
+ * @protected
+ * @type {ol.Extent}
+ this.extent = extent;
+ * @private
+ * @type {number}
+ this.pixelRatio_ = pixelRatio;
+ * @protected
+ this.resolution = resolution;
+ * @protected
+ * @type {ol.ImageState}
+ this.state = state;
+ol.inherits(ol.ImageBase, ol.events.EventTarget);
+ * @protected
+ol.ImageBase.prototype.changed = function() {
+ this.dispatchEvent(ol.events.EventType.CHANGE);
+ * @return {Array.<ol.Attribution>} Attributions.
+ol.ImageBase.prototype.getAttributions = function() {
+ return this.attributions_;
+ * @return {ol.Extent} Extent.
+ol.ImageBase.prototype.getExtent = function() {
+ return this.extent;
+ * @abstract
+ * @param {Object=} opt_context Object.
+ * @return {HTMLCanvasElement|Image|HTMLVideoElement} Image.
+ol.ImageBase.prototype.getImage = function(opt_context) {};
+ * @return {number} PixelRatio.
+ol.ImageBase.prototype.getPixelRatio = function() {
+ return this.pixelRatio_;
+ * @return {number} Resolution.
+ol.ImageBase.prototype.getResolution = function() {
+ return /** @type {number} */ (this.resolution);
+ * @return {ol.ImageState} State.
+ol.ImageBase.prototype.getState = function() {
+ return this.state;
+ * Load not yet loaded URI.
+ * @abstract
+ol.ImageBase.prototype.load = function() {};
+goog.provide('ol.Image');
+goog.require('ol.ImageBase');
+goog.require('ol.ImageState');
+ * @constructor
+ * @extends {ol.ImageBase}
+ * @param {string} src Image source URI.
+ * @param {?string} crossOrigin Cross origin.
+ * @param {ol.ImageLoadFunctionType} imageLoadFunction Image load function.
+ol.Image = function(extent, resolution, pixelRatio, attributions, src,
+ crossOrigin, imageLoadFunction) {
+ ol.ImageBase.call(this, extent, resolution, pixelRatio, ol.ImageState.IDLE,
+ attributions);
+ * @private
+ * @type {string}
+ this.src_ = src;
+ * @private
+ * @type {HTMLCanvasElement|Image|HTMLVideoElement}
+ this.image_ = new Image();
+ if (crossOrigin !== null) {
+ this.image_.crossOrigin = crossOrigin;
+ * @private
+ * @type {Object.<number, (HTMLCanvasElement|Image|HTMLVideoElement)>}
+ this.imageByContext_ = {};
+ * @private
+ * @type {Array.<ol.EventsKey>}
+ this.imageListenerKeys_ = null;
+ * @protected
+ this.state = ol.ImageState.IDLE;
+ * @private
+ * @type {ol.ImageLoadFunctionType}
+ this.imageLoadFunction_ = imageLoadFunction;
+ol.inherits(ol.Image, ol.ImageBase);
+ * @inheritDoc
+ * @api
+ol.Image.prototype.getImage = function(opt_context) {
+ if (opt_context !== undefined) {
+ var image;
+ var key = ol.getUid(opt_context);
+ if (key in this.imageByContext_) {
+ return this.imageByContext_[key];
+ } else if (ol.obj.isEmpty(this.imageByContext_)) {
+ image = this.image_;
+ } else {
+ image = /** @type {Image} */ (this.image_.cloneNode(false));
+ this.imageByContext_[key] = image;
+ return image;
+ } else {
+ return this.image_;
+ * Tracks loading or read errors.
+ * @private
+ol.Image.prototype.handleImageError_ = function() {
+ this.state = ol.ImageState.ERROR;
+ this.unlistenImage_();
+ this.changed();
+ * Tracks successful image load.
+ * @private
+ol.Image.prototype.handleImageLoad_ = function() {
+ if (this.resolution === undefined) {
+ this.resolution = ol.extent.getHeight(this.extent) / this.image_.height;
+ this.state = ol.ImageState.LOADED;
+ this.changed();
+ * Load the image or retry if loading previously failed.
+ * Loading is taken care of by the tile queue, and calling this method is
+ * only needed for preloading or for reloading in case of an error.
+ * @override
+ * @api
+ol.Image.prototype.load = function() {
+ if (this.state == ol.ImageState.IDLE || this.state == ol.ImageState.ERROR) {
+ this.state = ol.ImageState.LOADING;
+ this.changed();
+ this.imageListenerKeys_ = [
+ ol.events.listenOnce(this.image_, ol.events.EventType.ERROR,
+ this.handleImageError_, this),
+ ol.events.listenOnce(this.image_, ol.events.EventType.LOAD,
+ this.handleImageLoad_, this)
+ this.imageLoadFunction_(this, this.src_);
+ * @param {HTMLCanvasElement|Image|HTMLVideoElement} image Image.
+ol.Image.prototype.setImage = function(image) {
+ this.image_ = image;
+ * Discards event handlers which listen for load completion or errors.
+ * @private
+ol.Image.prototype.unlistenImage_ = function() {
+ this.imageListenerKeys_.forEach(ol.events.unlistenByKey);
+goog.provide('ol.ImageCanvas');
+goog.require('ol');
+ * @constructor
+ * @param {HTMLCanvasElement} canvas Canvas.
+ * @param {ol.ImageCanvasLoader=} opt_loader Optional loader function to
+ * support asynchronous canvas drawing.
+ol.ImageCanvas = function(extent, resolution, pixelRatio, attributions,
+ canvas, opt_loader) {
+ * Optional canvas loader function.
+ * @type {?ol.ImageCanvasLoader}
+ * @private
+ this.loader_ = opt_loader !== undefined ? opt_loader : null;
+ var state = opt_loader !== undefined ?
+ ol.ImageState.IDLE : ol.ImageState.LOADED;
+ ol.ImageBase.call(this, extent, resolution, pixelRatio, state, attributions);
+ * @private
+ * @type {HTMLCanvasElement}
+ this.canvas_ = canvas;
+ * @private
+ * @type {Error}
+ this.error_ = null;
+ol.inherits(ol.ImageCanvas, ol.ImageBase);
+ * Get any error associated with asynchronous rendering.
+ * @return {Error} Any error that occurred during rendering.
+ol.ImageCanvas.prototype.getError = function() {
+ return this.error_;
+ * Handle async drawing complete.
+ * @param {Error} err Any error during drawing.
+ * @private
+ol.ImageCanvas.prototype.handleLoad_ = function(err) {
+ if (err) {
+ this.error_ = err;
+ } else {
+ this.changed();
+ * @inheritDoc
+ol.ImageCanvas.prototype.load = function() {
+ if (this.state == ol.ImageState.IDLE) {
+ this.changed();
+ this.loader_(this.handleLoad_.bind(this));
+ * @inheritDoc
+ol.ImageCanvas.prototype.getImage = function(opt_context) {
+ return this.canvas_;
+goog.provide('ol.Tile');
+goog.require('ol.TileState');
+ * @classdesc
+ * Base class for tiles.
+ * @constructor
+ * @abstract
+ * @param {ol.TileCoord} tileCoord Tile coordinate.
+ * @param {ol.TileState} state State.
+ol.Tile = function(tileCoord, state) {
+ * @type {ol.TileCoord}
+ this.tileCoord = tileCoord;
+ * @protected
+ * @type {ol.TileState}
+ * An "interim" tile for this tile. The interim tile may be used while this
+ * one is loading, for "smooth" transitions when changing params/dimensions
+ * on the source.
+ * @type {ol.Tile}
+ this.interimTile = null;
+ * A key assigned to the tile. This is used by the tile source to determine
+ * if this tile can effectively be used, or if a new tile should be created
+ * and this one be used as an interim tile for this new tile.
+ * @type {string}
+ this.key = '';
+ol.inherits(ol.Tile, ol.events.EventTarget);
+ * @protected
+ol.Tile.prototype.changed = function() {
+ * Get the HTML image element for this tile (may be a Canvas, Image, or Video).
+ * @abstract
+ * @return {HTMLCanvasElement|HTMLImageElement|HTMLVideoElement} Image.
+ol.Tile.prototype.getImage = function() {};
+ * @return {string} Key.
+ol.Tile.prototype.getKey = function() {
+ return this.key + '/' + this.tileCoord;
+ * Get the interim tile most suitable for rendering using the chain of interim
+ * tiles. This corresponds to the most recent tile that has been loaded, if no
+ * such tile exists, the original tile is returned.
+ * @return {!ol.Tile} Best tile for rendering.
+ol.Tile.prototype.getInterimTile = function() {
+ if (!this.interimTile) {
+ //empty chain
+ return this;
+ var tile = this.interimTile;
+ // find the first loaded tile and return it. Since the chain is sorted in
+ // decreasing order of creation time, there is no need to search the remainder
+ // of the list (all those tiles correspond to older requests and will be
+ // cleaned up by refreshInterimChain)
+ do {
+ if (tile.getState() == ol.TileState.LOADED) {
+ return tile;
+ tile = tile.interimTile;
+ } while (tile);
+ // we can not find a better tile
+ return this;
+ * Goes through the chain of interim tiles and discards sections of the chain
+ * that are no longer relevant.
+ol.Tile.prototype.refreshInterimChain = function() {
+ return;
+ var prev = this;
+ do {
+ //we have a loaded tile, we can discard the rest of the list
+ //we would could abort any LOADING tile request
+ //older than this tile (i.e. any LOADING tile following this entry in the chain)
+ tile.interimTile = null;
+ break;
+ } else if (tile.getState() == ol.TileState.LOADING) {
+ //keep this LOADING tile any loaded tiles later in the chain are
+ //older than this tile, so we're still interested in the request
+ prev = tile;
+ } else if (tile.getState() == ol.TileState.IDLE) {
+ //the head of the list is the most current tile, we don't need
+ //to start any other requests for this chain
+ prev.interimTile = tile.interimTile;
+ } else {
+ prev = tile;
+ tile = prev.interimTile;
+ } while (tile);
+ * Get the tile coordinate for this tile.
+ * @return {ol.TileCoord} The tile coordinate.
+ * @api
+ol.Tile.prototype.getTileCoord = function() {
+ return this.tileCoord;
+ * @return {ol.TileState} State.
+ol.Tile.prototype.getState = function() {
+ * @abstract
+ * @api
+ol.Tile.prototype.load = function() {};
+goog.provide('ol.ImageTile');
+goog.require('ol.Tile');
+ * @constructor
+ * @extends {ol.Tile}
+ * @param {ol.TileLoadFunctionType} tileLoadFunction Tile load function.
+ol.ImageTile = function(tileCoord, state, src, crossOrigin, tileLoadFunction) {
+ ol.Tile.call(this, tileCoord, state);
+ * Image URI
+ * @private
+ * @type {string}
+ this.src_ = src;
+ * @private
+ * @type {Image}
+ * @private
+ * @private
+ * @type {ol.TileLoadFunctionType}
+ this.tileLoadFunction_ = tileLoadFunction;
+ol.inherits(ol.ImageTile, ol.Tile);
+ * @inheritDoc
+ol.ImageTile.prototype.disposeInternal = function() {
+ if (this.state == ol.TileState.LOADING) {
+ if (this.interimTile) {
+ this.interimTile.dispose();
+ this.state = ol.TileState.ABORT;
+ this.changed();
+ ol.Tile.prototype.disposeInternal.call(this);
+ * Get the image element for this tile.
+ * @inheritDoc
+ * @api
+ol.ImageTile.prototype.getImage = function() {
+ * @inheritDoc
+ol.ImageTile.prototype.getKey = function() {
+ return this.src_;
+ * @private
+ol.ImageTile.prototype.handleImageError_ = function() {
+ this.state = ol.TileState.ERROR;
+ this.changed();
+ * @private
+ol.ImageTile.prototype.handleImageLoad_ = function() {
+ if (this.image_.naturalWidth && this.image_.naturalHeight) {
+ this.state = ol.TileState.LOADED;
+ } else {
+ this.state = ol.TileState.EMPTY;
+ this.changed();
+ * @inheritDoc
+ * @api
+ol.ImageTile.prototype.load = function() {
+ if (this.state == ol.TileState.IDLE || this.state == ol.TileState.ERROR) {
+ this.state = ol.TileState.LOADING;
+ this.changed();
+ this.tileLoadFunction_(this, this.src_);
+ * @private
+ol.ImageTile.prototype.unlistenImage_ = function() {
+// FIXME should handle all geo-referenced data, not just vector data
+goog.provide('ol.interaction.DragAndDrop');
+goog.require('ol.functions');
+goog.require('ol.events.Event');
+goog.require('ol.interaction.Interaction');
+ * @classdesc
+ * Handles input of vector data by drag and drop.
+ * @constructor
+ * @extends {ol.interaction.Interaction}
+ * @fires ol.interaction.DragAndDrop.Event
+ * @param {olx.interaction.DragAndDropOptions=} opt_options Options.
+ * @api
+ol.interaction.DragAndDrop = function(opt_options) {
+ ol.interaction.Interaction.call(this, {
+ handleEvent: ol.interaction.DragAndDrop.handleEvent
+ * @private
+ * @type {Array.<function(new: ol.format.Feature)>}
+ this.formatConstructors_ = options.formatConstructors ?
+ options.formatConstructors : [];
+ * @private
+ this.projection_ = options.projection ?
+ ol.proj.get(options.projection) : null;
+ * @private
+ this.dropListenKeys_ = null;
+ * @private
+ * @type {Element}
+ this.target = options.target ? options.target : null;
+ol.inherits(ol.interaction.DragAndDrop, ol.interaction.Interaction);
+ * @param {Event} event Event.
+ * @this {ol.interaction.DragAndDrop}
+ * @private
+ol.interaction.DragAndDrop.handleDrop_ = function(event) {
+ var files = event.dataTransfer.files;
+ var i, ii, file;
+ for (i = 0, ii = files.length; i < ii; ++i) {
+ file = files.item(i);
+ var reader = new FileReader();
+ reader.addEventListener(ol.events.EventType.LOAD,
+ this.handleResult_.bind(this, file));
+ reader.readAsText(file);
+ * @private
+ol.interaction.DragAndDrop.handleStop_ = function(event) {
+ event.stopPropagation();
+ event.preventDefault();
+ event.dataTransfer.dropEffect = 'copy';
+ * @param {File} file File.
+ * @param {Event} event Load event.
+ * @private
+ol.interaction.DragAndDrop.prototype.handleResult_ = function(file, event) {
+ var result = event.target.result;
+ var map = this.getMap();
+ var projection = this.projection_;
+ if (!projection) {
+ var view = map.getView();
+ projection = view.getProjection();
+ var formatConstructors = this.formatConstructors_;
+ var i, ii;
+ for (i = 0, ii = formatConstructors.length; i < ii; ++i) {
+ * Avoid "cannot instantiate abstract class" error.
+ * @type {Function}
+ var formatConstructor = formatConstructors[i];
+ * @type {ol.format.Feature}
+ var format = new formatConstructor();
+ features = this.tryReadFeatures_(format, result, {
+ featureProjection: projection
+ if (features && features.length > 0) {
+ break;
+ new ol.interaction.DragAndDrop.Event(
+ ol.interaction.DragAndDrop.EventType_.ADD_FEATURES, file,
+ features, projection));
+ * Handles the {@link ol.MapBrowserEvent map browser event} unconditionally and
+ * neither prevents the browser default nor stops event propagation.
+ * @param {ol.MapBrowserEvent} mapBrowserEvent Map browser event.
+ * @return {boolean} `false` to stop event propagation.
+ * @api
+ol.interaction.DragAndDrop.handleEvent = ol.functions.TRUE;
+ * @inheritDoc
+ol.interaction.DragAndDrop.prototype.setMap = function(map) {
+ if (this.dropListenKeys_) {
+ this.dropListenKeys_.forEach(ol.events.unlistenByKey);
+ ol.interaction.Interaction.prototype.setMap.call(this, map);
+ if (map) {
+ var dropArea = this.target ? this.target : map.getViewport();
+ this.dropListenKeys_ = [
+ ol.events.listen(dropArea, ol.events.EventType.DROP,
+ ol.interaction.DragAndDrop.handleDrop_, this),
+ ol.events.listen(dropArea, ol.events.EventType.DRAGENTER,
+ ol.interaction.DragAndDrop.handleStop_, this),
+ ol.events.listen(dropArea, ol.events.EventType.DRAGOVER,
+ * @param {ol.format.Feature} format Format.
+ * @param {string} text Text.
+ * @param {olx.format.ReadOptions} options Read options.
+ * @private
+ol.interaction.DragAndDrop.prototype.tryReadFeatures_ = function(format, text, options) {
+ try {
+ return format.readFeatures(text, options);
+ } catch (e) {
+ return null;
+ * @enum {string}
+ * @private
+ol.interaction.DragAndDrop.EventType_ = {
+ * Triggered when features are added
+ * @event ol.interaction.DragAndDrop.Event#addfeatures
+ * @api
+ ADD_FEATURES: 'addfeatures'
+ * @classdesc
+ * Events emitted by {@link ol.interaction.DragAndDrop} instances are instances
+ * of this type.
+ * @constructor
+ * @extends {ol.events.Event}
+ * @implements {oli.interaction.DragAndDropEvent}
+ * @param {ol.interaction.DragAndDrop.EventType_} type Type.
+ * @param {Array.<ol.Feature>=} opt_features Features.
+ * @param {ol.proj.Projection=} opt_projection Projection.
+ol.interaction.DragAndDrop.Event = function(type, file, opt_features, opt_projection) {
+ ol.events.Event.call(this, type);
+ * The features parsed from dropped data.
+ * @type {Array.<ol.Feature>|undefined}
+ * @api
+ this.features = opt_features;
+ * The dropped file.
+ * @type {File}
+ * @api
+ this.file = file;
+ * The feature projection.
+ * @type {ol.proj.Projection|undefined}
+ * @api
+ this.projection = opt_projection;
+ol.inherits(ol.interaction.DragAndDrop.Event, ol.events.Event);
+goog.provide('ol.interaction.DragRotateAndZoom');
+goog.require('ol.ViewHint');
+goog.require('ol.events.condition');
+goog.require('ol.interaction.Pointer');
+ * @classdesc
+ * Allows the user to zoom and rotate the map by clicking and dragging
+ * on the map. By default, this interaction is limited to when the shift
+ * key is held down.
+ * This interaction is only supported for mouse devices.
+ * And this interaction is not included in the default interactions.
+ * @constructor
+ * @extends {ol.interaction.Pointer}
+ * @param {olx.interaction.DragRotateAndZoomOptions=} opt_options Options.
+ * @api
+ol.interaction.DragRotateAndZoom = function(opt_options) {
+ ol.interaction.Pointer.call(this, {
+ handleDownEvent: ol.interaction.DragRotateAndZoom.handleDownEvent_,
+ handleDragEvent: ol.interaction.DragRotateAndZoom.handleDragEvent_,
+ handleUpEvent: ol.interaction.DragRotateAndZoom.handleUpEvent_
+ * @private
+ * @type {ol.EventsConditionType}
+ this.condition_ = options.condition ?
+ options.condition : ol.events.condition.shiftKeyOnly;
+ * @private
+ this.lastAngle_ = undefined;
+ * @private
+ this.lastMagnitude_ = undefined;
+ * @private
+ * @type {number}
+ this.lastScaleDelta_ = 0;
+ * @private
+ * @type {number}
+ this.duration_ = options.duration !== undefined ? options.duration : 400;
+ol.inherits(ol.interaction.DragRotateAndZoom, ol.interaction.Pointer);
+ * @param {ol.MapBrowserPointerEvent} mapBrowserEvent Event.
+ * @this {ol.interaction.DragRotateAndZoom}
+ * @private
+ol.interaction.DragRotateAndZoom.handleDragEvent_ = function(mapBrowserEvent) {
+ if (!ol.events.condition.mouseOnly(mapBrowserEvent)) {
+ return;
+ var map = mapBrowserEvent.map;
+ var size = map.getSize();
+ var offset = mapBrowserEvent.pixel;
+ var deltaX = offset[0] - size[0] / 2;
+ var deltaY = size[1] / 2 - offset[1];
+ var theta = Math.atan2(deltaY, deltaX);
+ var magnitude = Math.sqrt(deltaX * deltaX + deltaY * deltaY);
+ if (this.lastAngle_ !== undefined) {
+ var angleDelta = theta - this.lastAngle_;
+ ol.interaction.Interaction.rotateWithoutConstraints(
+ view, view.getRotation() - angleDelta);
+ this.lastAngle_ = theta;
+ if (this.lastMagnitude_ !== undefined) {
+ var resolution = this.lastMagnitude_ * (view.getResolution() / magnitude);
+ ol.interaction.Interaction.zoomWithoutConstraints(view, resolution);
+ this.lastScaleDelta_ = this.lastMagnitude_ / magnitude;
+ this.lastMagnitude_ = magnitude;
+ * @return {boolean} Stop drag sequence?
+ * @private
+ol.interaction.DragRotateAndZoom.handleUpEvent_ = function(mapBrowserEvent) {
+ return true;
+ view.setHint(ol.ViewHint.INTERACTING, -1);
+ var direction = this.lastScaleDelta_ - 1;
+ ol.interaction.Interaction.rotate(view, view.getRotation());
+ ol.interaction.Interaction.zoom(view, view.getResolution(),
+ undefined, this.duration_, direction);
+ return false;
+ * @return {boolean} Start drag sequence?
+ * @private
+ol.interaction.DragRotateAndZoom.handleDownEvent_ = function(mapBrowserEvent) {
+ return false;
+ if (this.condition_(mapBrowserEvent)) {
+ mapBrowserEvent.map.getView().setHint(ol.ViewHint.INTERACTING, 1);
+ return true;
+ } else {
+ return false;
+goog.provide('ol.interaction.DrawEventType');
+ * @enum {string}
+ol.interaction.DrawEventType = {
+ * Triggered upon feature draw start
+ * @event ol.interaction.Draw.Event#drawstart
+ * @api
+ DRAWSTART: 'drawstart',
+ * Triggered upon feature draw end
+ * @event ol.interaction.Draw.Event#drawend
+ * @api
+ DRAWEND: 'drawend'
+goog.provide('ol.render.canvas.Instruction');
+ * @enum {number}
+ol.render.canvas.Instruction = {
+ BEGIN_GEOMETRY: 0,
+ BEGIN_PATH: 1,
+ CIRCLE: 2,
+ CLOSE_PATH: 3,
+ DRAW_IMAGE: 4,
+ DRAW_TEXT: 5,
+ END_GEOMETRY: 6,
+ FILL: 7,
+ MOVE_TO_LINE_TO: 8,
+ SET_FILL_STYLE: 9,
+ SET_STROKE_STYLE: 10,
+ SET_TEXT_STYLE: 11,
+ STROKE: 12
+goog.provide('ol.render.canvas.Replay');
+goog.require('ol.array');
+goog.require('ol.extent.Relationship');
+goog.require('ol.geom.flat.transform');
+goog.require('ol.obj');
+goog.require('ol.render.VectorContext');
+goog.require('ol.render.canvas.Instruction');
+goog.require('ol.transform');
+ * @constructor
+ * @extends {ol.render.VectorContext}
+ * @param {number} tolerance Tolerance.
+ * @param {ol.Extent} maxExtent Maximum extent.
+ * @param {boolean} overlaps The replay can have overlapping geometries.
+ * @struct
+ol.render.canvas.Replay = function(tolerance, maxExtent, resolution, overlaps) {
+ ol.render.VectorContext.call(this);
+ * @protected
+ * @type {number}
+ this.tolerance = tolerance;
+ * @protected
+ * @const
+ this.maxExtent = maxExtent;
+ * @protected
+ * @type {boolean}
+ this.overlaps = overlaps;
+ * @protected
+ * @type {number}
+ this.maxLineWidth = 0;
+ * @protected
+ * @const
+ * @type {number}
+ * @private
+ this.fillOrigin_;
+ * @private
+ * @type {Array.<*>}
+ this.beginGeometryInstruction1_ = null;
+ * @private
+ this.beginGeometryInstruction2_ = null;
+ * @protected
+ this.instructions = [];
+ * @protected
+ this.coordinates = [];
+ * @private
+ * @type {!ol.Transform}
+ this.renderedTransform_ = ol.transform.create();
+ * @protected
+ this.hitDetectionInstructions = [];
+ * @private
+ this.pixelCoordinates_ = null;
+ * @private
+ this.tmpLocalTransform_ = ol.transform.create();
+ * @private
+ this.resetTransform_ = ol.transform.create();
+ol.inherits(ol.render.canvas.Replay, ol.render.VectorContext);
+ * @param {number} offset Offset.
+ * @param {number} end End.
+ * @param {number} stride Stride.
+ * @param {boolean} closed Last input coordinate equals first.
+ * @param {boolean} skipFirst Skip first coordinate.
+ * @protected
+ * @return {number} My end.
+ol.render.canvas.Replay.prototype.appendFlatCoordinates = function(flatCoordinates, offset, end, stride, closed, skipFirst) {
+ var myEnd = this.coordinates.length;
+ var extent = this.getBufferedMaxExtent();
+ if (skipFirst) {
+ offset += stride;
+ var lastCoord = [flatCoordinates[offset], flatCoordinates[offset + 1]];
+ var nextCoord = [NaN, NaN];
+ var skipped = true;
+ var i, lastRel, nextRel;
+ for (i = offset + stride; i < end; i += stride) {
+ nextCoord[0] = flatCoordinates[i];
+ nextCoord[1] = flatCoordinates[i + 1];
+ nextRel = ol.extent.coordinateRelationship(extent, nextCoord);
+ if (nextRel !== lastRel) {
+ if (skipped) {
+ this.coordinates[myEnd++] = lastCoord[0];
+ this.coordinates[myEnd++] = lastCoord[1];
+ this.coordinates[myEnd++] = nextCoord[0];
+ this.coordinates[myEnd++] = nextCoord[1];
+ skipped = false;
+ } else if (nextRel === ol.extent.Relationship.INTERSECTING) {
+ skipped = false;
+ } else {
+ skipped = true;
+ lastCoord[0] = nextCoord[0];
+ lastCoord[1] = nextCoord[1];
+ lastRel = nextRel;
+ // Last coordinate equals first or only one point to append:
+ if ((closed && skipped) || i === offset + stride) {
+ return myEnd;
+ * @protected
+ * @param {ol.geom.Geometry|ol.render.Feature} geometry Geometry.
+ * @param {ol.Feature|ol.render.Feature} feature Feature.
+ol.render.canvas.Replay.prototype.beginGeometry = function(geometry, feature) {
+ [ol.render.canvas.Instruction.BEGIN_GEOMETRY, feature, 0];
+ this.instructions.push(this.beginGeometryInstruction1_);
+ this.hitDetectionInstructions.push(this.beginGeometryInstruction2_);
+ * @private
+ * @param {CanvasRenderingContext2D} context Context.
+ * @param {number} rotation Rotation.
+ol.render.canvas.Replay.prototype.fill_ = function(context, rotation) {
+ if (this.fillOrigin_) {
+ var origin = ol.transform.apply(this.renderedTransform_, this.fillOrigin_.slice());
+ context.translate(origin[0], origin[1]);
+ context.rotate(rotation);
+ context.fill();
+ context.setTransform.apply(context, this.resetTransform_);
+ * @private
+ * @param {ol.Transform} transform Transform.
+ * @param {number} viewRotation View rotation.
+ * @param {Object.<string, boolean>} skippedFeaturesHash Ids of features
+ * to skip.
+ * @param {Array.<*>} instructions Instructions array.
+ * @param {function((ol.Feature|ol.render.Feature)): T|undefined}
+ * featureCallback Feature callback.
+ * @param {ol.Extent=} opt_hitExtent Only check features that intersect this
+ * extent.
+ * @return {T|undefined} Callback result.
+ * @template T
+ol.render.canvas.Replay.prototype.replay_ = function(
+ context, pixelRatio, transform, viewRotation, skippedFeaturesHash,
+ instructions, featureCallback, opt_hitExtent) {
+ var pixelCoordinates;
+ if (this.pixelCoordinates_ && ol.array.equals(transform, this.renderedTransform_)) {
+ pixelCoordinates = this.pixelCoordinates_;
+ } else {
+ if (!this.pixelCoordinates_) {
+ this.pixelCoordinates_ = [];
+ pixelCoordinates = ol.geom.flat.transform.transform2D(
+ this.coordinates, 0, this.coordinates.length, 2,
+ transform, this.pixelCoordinates_);
+ ol.transform.setFromArray(this.renderedTransform_, transform);
+ var skipFeatures = !ol.obj.isEmpty(skippedFeaturesHash);
+ var i = 0; // instruction index
+ var ii = instructions.length; // end of instructions
+ var d = 0; // data index
+ var dd; // end of per-instruction data
+ var localTransform = this.tmpLocalTransform_;
+ var resetTransform = this.resetTransform_;
+ var prevX, prevY, roundX, roundY;
+ var pendingFill = 0;
+ var pendingStroke = 0;
+ // When the batch size gets too big, performance decreases. 200 is a good
+ // balance between batch size and number of fill/stroke instructions.
+ var batchSize =
+ this.instructions != instructions || this.overlaps ? 0 : 200;
+ while (i < ii) {
+ var instruction = instructions[i];
+ var type = /** @type {ol.render.canvas.Instruction} */ (instruction[0]);
+ var feature, fill, stroke, text, x, y;
+ switch (type) {
+ case ol.render.canvas.Instruction.BEGIN_GEOMETRY:
+ feature = /** @type {ol.Feature|ol.render.Feature} */ (instruction[1]);
+ if ((skipFeatures &&
+ skippedFeaturesHash[ol.getUid(feature).toString()]) ||
+ !feature.getGeometry()) {
+ i = /** @type {number} */ (instruction[2]);
+ } else if (opt_hitExtent !== undefined && !ol.extent.intersects(
+ opt_hitExtent, feature.getGeometry().getExtent())) {
+ i = /** @type {number} */ (instruction[2]) + 1;
+ } else {
+ ++i;
+ break;
+ case ol.render.canvas.Instruction.BEGIN_PATH:
+ if (pendingFill > batchSize) {
+ this.fill_(context, viewRotation);
+ pendingFill = 0;
+ if (pendingStroke > batchSize) {
+ context.stroke();
+ pendingStroke = 0;
+ if (!pendingFill && !pendingStroke) {
+ context.beginPath();
+ prevX = prevY = NaN;
+ ++i;
+ break;
+ case ol.render.canvas.Instruction.CIRCLE:
+ d = /** @type {number} */ (instruction[1]);
+ var x1 = pixelCoordinates[d];
+ var y1 = pixelCoordinates[d + 1];
+ var x2 = pixelCoordinates[d + 2];
+ var y2 = pixelCoordinates[d + 3];
+ var dx = x2 - x1;
+ var dy = y2 - y1;
+ var r = Math.sqrt(dx * dx + dy * dy);
+ context.moveTo(x1 + r, y1);
+ context.arc(x1, y1, r, 0, 2 * Math.PI, true);
+ ++i;
+ break;
+ case ol.render.canvas.Instruction.CLOSE_PATH:
+ context.closePath();
+ ++i;
+ break;
+ case ol.render.canvas.Instruction.DRAW_IMAGE:
+ dd = /** @type {number} */ (instruction[2]);
+ var image = /** @type {HTMLCanvasElement|HTMLVideoElement|Image} */
+ (instruction[3]);
+ // Remaining arguments in DRAW_IMAGE are in alphabetical order
+ var anchorX = /** @type {number} */ (instruction[4]) * pixelRatio;
+ var anchorY = /** @type {number} */ (instruction[5]) * pixelRatio;
+ var height = /** @type {number} */ (instruction[6]);
+ var opacity = /** @type {number} */ (instruction[7]);
+ var originX = /** @type {number} */ (instruction[8]);
+ var originY = /** @type {number} */ (instruction[9]);
+ var rotateWithView = /** @type {boolean} */ (instruction[10]);
+ var rotation = /** @type {number} */ (instruction[11]);
+ var scale = /** @type {number} */ (instruction[12]);
+ var snapToPixel = /** @type {boolean} */ (instruction[13]);
+ var width = /** @type {number} */ (instruction[14]);
+ if (rotateWithView) {
+ rotation += viewRotation;
+ for (; d < dd; d += 2) {
+ x = pixelCoordinates[d] - anchorX;
+ y = pixelCoordinates[d + 1] - anchorY;
+ if (snapToPixel) {
+ x = Math.round(x);
+ y = Math.round(y);
+ if (scale != 1 || rotation !== 0) {
+ var centerX = x + anchorX;
+ var centerY = y + anchorY;
+ ol.transform.compose(localTransform,
+ centerX, centerY, scale, scale, rotation, -centerX, -centerY);
+ context.setTransform.apply(context, localTransform);
+ var alpha = context.globalAlpha;
+ if (opacity != 1) {
+ context.globalAlpha = alpha * opacity;
+ var w = (width + originX > image.width) ? image.width - originX : width;
+ var h = (height + originY > image.height) ? image.height - originY : height;
+ context.drawImage(image, originX, originY, w, h,
+ x, y, w * pixelRatio, h * pixelRatio);
+ context.globalAlpha = alpha;
+ context.setTransform.apply(context, resetTransform);
+ ++i;
+ break;
+ case ol.render.canvas.Instruction.DRAW_TEXT:
+ text = /** @type {string} */ (instruction[3]);
+ var offsetX = /** @type {number} */ (instruction[4]) * pixelRatio;
+ var offsetY = /** @type {number} */ (instruction[5]) * pixelRatio;
+ rotation = /** @type {number} */ (instruction[6]);
+ scale = /** @type {number} */ (instruction[7]) * pixelRatio;
+ fill = /** @type {boolean} */ (instruction[8]);
+ stroke = /** @type {boolean} */ (instruction[9]);
+ rotateWithView = /** @type {boolean} */ (instruction[10]);
+ x = pixelCoordinates[d] + offsetX;
+ y = pixelCoordinates[d + 1] + offsetY;
+ ol.transform.compose(localTransform, x, y, scale, scale, rotation, -x, -y);
+ // Support multiple lines separated by \n
+ var lines = text.split('\n');
+ var numLines = lines.length;
+ var fontSize, lineY;
+ if (numLines > 1) {
+ // Estimate line height using width of capital M, and add padding
+ fontSize = Math.round(context.measureText('M').width * 1.5);
+ lineY = y - (((numLines - 1) / 2) * fontSize);
+ } else {
+ // No need to calculate line height/offset for a single line
+ fontSize = 0;
+ lineY = y;
+ for (var lineIndex = 0; lineIndex < numLines; lineIndex++) {
+ var line = lines[lineIndex];
+ if (stroke) {
+ context.strokeText(line, x, lineY);
+ if (fill) {
+ context.fillText(line, x, lineY);
+ // Move next line down by fontSize px
+ lineY = lineY + fontSize;
+ ++i;
+ break;
+ case ol.render.canvas.Instruction.END_GEOMETRY:
+ if (featureCallback !== undefined) {
+ feature =
+ /** @type {ol.Feature|ol.render.Feature} */ (instruction[1]);
+ var result = featureCallback(feature);
+ if (result) {
+ return result;
+ ++i;
+ break;
+ case ol.render.canvas.Instruction.FILL:
+ if (batchSize) {
+ pendingFill++;
+ } else {
+ ++i;
+ break;
+ case ol.render.canvas.Instruction.MOVE_TO_LINE_TO:
+ x = pixelCoordinates[d];
+ y = pixelCoordinates[d + 1];
+ roundX = (x + 0.5) | 0;
+ roundY = (y + 0.5) | 0;
+ if (roundX !== prevX || roundY !== prevY) {
+ context.moveTo(x, y);
+ prevX = roundX;
+ prevY = roundY;
+ for (d += 2; d < dd; d += 2) {
+ if (d == dd - 2 || roundX !== prevX || roundY !== prevY) {
+ context.lineTo(x, y);
+ prevX = roundX;
+ prevY = roundY;
+ ++i;
+ break;
+ case ol.render.canvas.Instruction.SET_FILL_STYLE:
+ this.fillOrigin_ = instruction[2];
+ if (pendingFill) {
+ pendingFill = 0;
+ if (pendingStroke) {
+ context.stroke();
+ context.fillStyle = /** @type {ol.ColorLike} */ (instruction[1]);
+ ++i;
+ break;
+ case ol.render.canvas.Instruction.SET_STROKE_STYLE:
+ var usePixelRatio = instruction[8] !== undefined ?
+ instruction[8] : true;
+ var renderedPixelRatio = instruction[9];
+ var lineWidth = /** @type {number} */ (instruction[2]);
+ context.stroke();
+ context.strokeStyle = /** @type {ol.ColorLike} */ (instruction[1]);
+ context.lineWidth = usePixelRatio ? lineWidth * pixelRatio : lineWidth;
+ context.lineCap = /** @type {string} */ (instruction[3]);
+ context.lineJoin = /** @type {string} */ (instruction[4]);
+ context.miterLimit = /** @type {number} */ (instruction[5]);
+ if (ol.has.CANVAS_LINE_DASH) {
+ var lineDash = /** @type {Array.<number>} */ (instruction[6]);
+ var lineDashOffset = /** @type {number} */ (instruction[7]);
+ if (usePixelRatio && pixelRatio !== renderedPixelRatio) {
+ lineDash = lineDash.map(function(dash) {
+ return dash * pixelRatio / renderedPixelRatio;
+ lineDashOffset *= pixelRatio / renderedPixelRatio;
+ instruction[6] = lineDash;
+ instruction[7] = lineDashOffset;
+ instruction[9] = pixelRatio;
+ context.lineDashOffset = lineDashOffset;
+ context.setLineDash(lineDash);
+ ++i;
+ break;
+ case ol.render.canvas.Instruction.SET_TEXT_STYLE:
+ context.font = /** @type {string} */ (instruction[1]);
+ context.textAlign = /** @type {string} */ (instruction[2]);
+ context.textBaseline = /** @type {string} */ (instruction[3]);
+ ++i;
+ break;
+ case ol.render.canvas.Instruction.STROKE:
+ if (batchSize) {
+ pendingStroke++;
+ } else {
+ context.stroke();
+ ++i;
+ break;
+ default:
+ ++i; // consume the instruction anyway, to avoid an infinite loop
+ break;
+ context.stroke();
+ return undefined;
+ * to skip.
+ol.render.canvas.Replay.prototype.replay = function(
+ context, pixelRatio, transform, viewRotation, skippedFeaturesHash) {
+ var instructions = this.instructions;
+ this.replay_(context, pixelRatio, transform, viewRotation,
+ skippedFeaturesHash, instructions, undefined, undefined);
+ * to skip.
+ * @param {function((ol.Feature|ol.render.Feature)): T=} opt_featureCallback
+ * Feature callback.
+ * extent.
+ * @template T
+ol.render.canvas.Replay.prototype.replayHitDetection = function(
+ context, transform, viewRotation, skippedFeaturesHash,
+ opt_featureCallback, opt_hitExtent) {
+ var instructions = this.hitDetectionInstructions;
+ return this.replay_(context, 1, transform, viewRotation,
+ skippedFeaturesHash, instructions, opt_featureCallback, opt_hitExtent);
+ * Reverse the hit detection instructions.
+ol.render.canvas.Replay.prototype.reverseHitDetectionInstructions = function() {
+ var hitDetectionInstructions = this.hitDetectionInstructions;
+ // step 1 - reverse array
+ hitDetectionInstructions.reverse();
+ // step 2 - reverse instructions within geometry blocks
+ var i;
+ var n = hitDetectionInstructions.length;
+ var instruction;
+ var type;
+ var begin = -1;
+ for (i = 0; i < n; ++i) {
+ instruction = hitDetectionInstructions[i];
+ type = /** @type {ol.render.canvas.Instruction} */ (instruction[0]);
+ if (type == ol.render.canvas.Instruction.END_GEOMETRY) {
+ begin = i;
+ } else if (type == ol.render.canvas.Instruction.BEGIN_GEOMETRY) {
+ instruction[2] = i;
+ ol.array.reverseSubArray(this.hitDetectionInstructions, begin, i);
+ begin = -1;
+ol.render.canvas.Replay.prototype.endGeometry = function(geometry, feature) {
+ this.beginGeometryInstruction1_[2] = this.instructions.length;
+ this.beginGeometryInstruction2_[2] = this.hitDetectionInstructions.length;
+ var endGeometryInstruction =
+ [ol.render.canvas.Instruction.END_GEOMETRY, feature];
+ this.instructions.push(endGeometryInstruction);
+ this.hitDetectionInstructions.push(endGeometryInstruction);
+ * FIXME empty description for jsdoc
+ol.render.canvas.Replay.prototype.finish = ol.nullFunction;
+ * Get the buffered rendering extent. Rendering will be clipped to the extent
+ * provided to the constructor. To account for symbolizers that may intersect
+ * this extent, we calculate a buffered extent (e.g. based on stroke width).
+ * @return {ol.Extent} The buffered rendering extent.
+ * @protected
+ol.render.canvas.Replay.prototype.getBufferedMaxExtent = function() {
+ return this.maxExtent;
+goog.provide('ol.render.canvas.ImageReplay');
+goog.require('ol.render.canvas.Replay');
+ * @constructor
+ * @extends {ol.render.canvas.Replay}
+ * @struct
+ol.render.canvas.ImageReplay = function(tolerance, maxExtent, resolution, overlaps) {
+ ol.render.canvas.Replay.call(this, tolerance, maxExtent, resolution, overlaps);
+ * @private
+ * @type {HTMLCanvasElement|HTMLVideoElement|Image}
+ this.hitDetectionImage_ = null;
+ * @private
+ this.image_ = null;
+ * @private
+ * @type {number|undefined}
+ this.anchorX_ = undefined;
+ * @private
+ this.anchorY_ = undefined;
+ * @private
+ this.height_ = undefined;
+ * @private
+ this.opacity_ = undefined;
+ * @private
+ this.originX_ = undefined;
+ * @private
+ this.originY_ = undefined;
+ * @private
+ * @type {boolean|undefined}
+ this.rotateWithView_ = undefined;
+ * @private
+ this.rotation_ = undefined;
+ * @private
+ this.scale_ = undefined;
+ * @private
+ this.snapToPixel_ = undefined;
+ * @private
+ this.width_ = undefined;
+ol.inherits(ol.render.canvas.ImageReplay, ol.render.canvas.Replay);
+ * @private
+ol.render.canvas.ImageReplay.prototype.drawCoordinates_ = function(flatCoordinates, offset, end, stride) {
+ return this.appendFlatCoordinates(
+ flatCoordinates, offset, end, stride, false, false);
+ * @inheritDoc
+ol.render.canvas.ImageReplay.prototype.drawPoint = function(pointGeometry, feature) {
+ if (!this.image_) {
+ return;
+ this.beginGeometry(pointGeometry, feature);
+ var flatCoordinates = pointGeometry.getFlatCoordinates();
+ var stride = pointGeometry.getStride();
+ var myBegin = this.coordinates.length;
+ var myEnd = this.drawCoordinates_(
+ flatCoordinates, 0, flatCoordinates.length, stride);
+ this.instructions.push([
+ ol.render.canvas.Instruction.DRAW_IMAGE, myBegin, myEnd, this.image_,
+ // Remaining arguments to DRAW_IMAGE are in alphabetical order
+ this.anchorX_, this.anchorY_, this.height_, this.opacity_,
+ this.originX_, this.originY_, this.rotateWithView_, this.rotation_,
+ this.scale_, this.snapToPixel_, this.width_
+ this.hitDetectionInstructions.push([
+ this.hitDetectionImage_,
+ this.endGeometry(pointGeometry, feature);
+ * @inheritDoc
+ol.render.canvas.ImageReplay.prototype.drawMultiPoint = function(multiPointGeometry, feature) {
+ return;
+ this.beginGeometry(multiPointGeometry, feature);
+ var flatCoordinates = multiPointGeometry.getFlatCoordinates();
+ var stride = multiPointGeometry.getStride();
+ this.endGeometry(multiPointGeometry, feature);
+ * @inheritDoc
+ol.render.canvas.ImageReplay.prototype.finish = function() {
+ this.reverseHitDetectionInstructions();
+ // FIXME this doesn't really protect us against further calls to draw*Geometry
+ * @inheritDoc
+ol.render.canvas.ImageReplay.prototype.setImageStyle = function(imageStyle) {
+ var anchor = imageStyle.getAnchor();
+ var size = imageStyle.getSize();
+ var hitDetectionImage = imageStyle.getHitDetectionImage(1);
+ var image = imageStyle.getImage(1);
+ var origin = imageStyle.getOrigin();
+ this.anchorX_ = anchor[0];
+ this.anchorY_ = anchor[1];
+ this.hitDetectionImage_ = hitDetectionImage;
+ this.height_ = size[1];
+ this.opacity_ = imageStyle.getOpacity();
+ this.originX_ = origin[0];
+ this.originY_ = origin[1];
+ this.rotateWithView_ = imageStyle.getRotateWithView();
+ this.rotation_ = imageStyle.getRotation();
+ this.scale_ = imageStyle.getScale();
+ this.snapToPixel_ = imageStyle.getSnapToPixel();
+ this.width_ = size[0];
+goog.provide('ol.render.canvas.LineStringReplay');
+goog.require('ol.colorlike');
+goog.require('ol.extent');
+goog.require('ol.render.canvas');
+ * @constructor
+ * @struct
+ol.render.canvas.LineStringReplay = function(tolerance, maxExtent, resolution, overlaps) {
+ * @private
+ this.bufferedMaxExtent_ = null;
+ * @private
+ * @type {{currentStrokeStyle: (ol.ColorLike|undefined),
+ * currentLineCap: (string|undefined),
+ * currentLineDash: Array.<number>,
+ * currentLineDashOffset: (number|undefined),
+ * currentLineJoin: (string|undefined),
+ * currentLineWidth: (number|undefined),
+ * currentMiterLimit: (number|undefined),
+ * lastStroke: number,
+ * strokeStyle: (ol.ColorLike|undefined),
+ * lineCap: (string|undefined),
+ * lineDash: Array.<number>,
+ * lineDashOffset: (number|undefined),
+ * lineJoin: (string|undefined),
+ * lineWidth: (number|undefined),
+ * miterLimit: (number|undefined)}|null}
+ this.state_ = {
+ currentStrokeStyle: undefined,
+ currentLineCap: undefined,
+ currentLineDash: null,
+ currentLineDashOffset: undefined,
+ currentLineJoin: undefined,
+ currentLineWidth: undefined,
+ currentMiterLimit: undefined,
+ lastStroke: 0,
+ strokeStyle: undefined,
+ lineCap: undefined,
+ lineDash: null,
+ lineDashOffset: undefined,
+ lineJoin: undefined,
+ lineWidth: undefined,
+ miterLimit: undefined
+ol.inherits(ol.render.canvas.LineStringReplay, ol.render.canvas.Replay);
+ * @private
+ * @return {number} end.
+ol.render.canvas.LineStringReplay.prototype.drawFlatCoordinates_ = function(flatCoordinates, offset, end, stride) {
+ var myEnd = this.appendFlatCoordinates(
+ var moveToLineToInstruction =
+ [ol.render.canvas.Instruction.MOVE_TO_LINE_TO, myBegin, myEnd];
+ this.instructions.push(moveToLineToInstruction);
+ this.hitDetectionInstructions.push(moveToLineToInstruction);
+ return end;
+ * @inheritDoc
+ol.render.canvas.LineStringReplay.prototype.getBufferedMaxExtent = function() {
+ if (!this.bufferedMaxExtent_) {
+ this.bufferedMaxExtent_ = ol.extent.clone(this.maxExtent);
+ if (this.maxLineWidth > 0) {
+ var width = this.resolution * (this.maxLineWidth + 1) / 2;
+ ol.extent.buffer(this.bufferedMaxExtent_, width, this.bufferedMaxExtent_);
+ return this.bufferedMaxExtent_;
+ * @private
+ol.render.canvas.LineStringReplay.prototype.setStrokeStyle_ = function() {
+ var state = this.state_;
+ var strokeStyle = state.strokeStyle;
+ var lineCap = state.lineCap;
+ var lineDash = state.lineDash;
+ var lineDashOffset = state.lineDashOffset;
+ var lineJoin = state.lineJoin;
+ var lineWidth = state.lineWidth;
+ var miterLimit = state.miterLimit;
+ if (state.currentStrokeStyle != strokeStyle ||
+ state.currentLineCap != lineCap ||
+ !ol.array.equals(state.currentLineDash, lineDash) ||
+ state.currentLineDashOffset != lineDashOffset ||
+ state.currentLineJoin != lineJoin ||
+ state.currentLineWidth != lineWidth ||
+ state.currentMiterLimit != miterLimit) {
+ if (state.lastStroke != this.coordinates.length) {
+ this.instructions.push([ol.render.canvas.Instruction.STROKE]);
+ state.lastStroke = this.coordinates.length;
+ ol.render.canvas.Instruction.SET_STROKE_STYLE,
+ strokeStyle, lineWidth, lineCap, lineJoin, miterLimit, lineDash, lineDashOffset, true, 1
+ ol.render.canvas.Instruction.BEGIN_PATH
+ state.currentStrokeStyle = strokeStyle;
+ state.currentLineCap = lineCap;
+ state.currentLineDash = lineDash;
+ state.currentLineDashOffset = lineDashOffset;
+ state.currentLineJoin = lineJoin;
+ state.currentLineWidth = lineWidth;
+ state.currentMiterLimit = miterLimit;
+ * @inheritDoc
+ol.render.canvas.LineStringReplay.prototype.drawLineString = function(lineStringGeometry, feature) {
+ if (strokeStyle === undefined || lineWidth === undefined) {
+ return;
+ this.setStrokeStyle_();
+ this.beginGeometry(lineStringGeometry, feature);
+ state.strokeStyle, state.lineWidth, state.lineCap, state.lineJoin,
+ state.miterLimit, state.lineDash, state.lineDashOffset, true, 1
+ var flatCoordinates = lineStringGeometry.getFlatCoordinates();
+ var stride = lineStringGeometry.getStride();
+ this.drawFlatCoordinates_(flatCoordinates, 0, flatCoordinates.length, stride);
+ this.hitDetectionInstructions.push([ol.render.canvas.Instruction.STROKE]);
+ this.endGeometry(lineStringGeometry, feature);
+ * @inheritDoc
+ol.render.canvas.LineStringReplay.prototype.drawMultiLineString = function(multiLineStringGeometry, feature) {
+ return;
+ this.beginGeometry(multiLineStringGeometry, feature);
+ var ends = multiLineStringGeometry.getEnds();
+ var flatCoordinates = multiLineStringGeometry.getFlatCoordinates();
+ var stride = multiLineStringGeometry.getStride();
+ var offset = 0;
+ var i, ii;
+ for (i = 0, ii = ends.length; i < ii; ++i) {
+ offset = this.drawFlatCoordinates_(
+ flatCoordinates, offset, ends[i], stride);
+ this.endGeometry(multiLineStringGeometry, feature);
+ * @inheritDoc
+ol.render.canvas.LineStringReplay.prototype.finish = function() {
+ this.state_ = null;
+ * @inheritDoc
+ol.render.canvas.LineStringReplay.prototype.setFillStrokeStyle = function(fillStyle, strokeStyle) {
+ var strokeStyleColor = strokeStyle.getColor();
+ this.state_.strokeStyle = ol.colorlike.asColorLike(strokeStyleColor ?
+ strokeStyleColor : ol.render.canvas.defaultStrokeStyle);
+ var strokeStyleLineCap = strokeStyle.getLineCap();
+ this.state_.lineCap = strokeStyleLineCap !== undefined ?
+ strokeStyleLineCap : ol.render.canvas.defaultLineCap;
+ var strokeStyleLineDash = strokeStyle.getLineDash();
+ this.state_.lineDash = strokeStyleLineDash ?
+ strokeStyleLineDash : ol.render.canvas.defaultLineDash;
+ var strokeStyleLineDashOffset = strokeStyle.getLineDashOffset();
+ this.state_.lineDashOffset = strokeStyleLineDashOffset ?
+ strokeStyleLineDashOffset : ol.render.canvas.defaultLineDashOffset;
+ var strokeStyleLineJoin = strokeStyle.getLineJoin();
+ this.state_.lineJoin = strokeStyleLineJoin !== undefined ?
+ strokeStyleLineJoin : ol.render.canvas.defaultLineJoin;
+ var strokeStyleWidth = strokeStyle.getWidth();
+ this.state_.lineWidth = strokeStyleWidth !== undefined ?
+ strokeStyleWidth : ol.render.canvas.defaultLineWidth;
+ var strokeStyleMiterLimit = strokeStyle.getMiterLimit();
+ this.state_.miterLimit = strokeStyleMiterLimit !== undefined ?
+ strokeStyleMiterLimit : ol.render.canvas.defaultMiterLimit;
+ if (this.state_.lineWidth > this.maxLineWidth) {
+ this.maxLineWidth = this.state_.lineWidth;
+ // invalidate the buffered max extent cache
+goog.provide('ol.render.canvas.PolygonReplay');
+goog.require('ol.color');
+goog.require('ol.geom.flat.simplify');
+ * @constructor
+ * @struct
+ol.render.canvas.PolygonReplay = function(tolerance, maxExtent, resolution, overlaps) {
+ * @private
+ * @private
+ * @type {{currentFillStyle: (ol.ColorLike|undefined),
+ * currentStrokeStyle: (ol.ColorLike|undefined),
+ * fillStyle: (ol.ColorLike|undefined),
+ this.state_ = {
+ currentFillStyle: undefined,
+ fillStyle: undefined,
+ lineDash: null,
+ol.inherits(ol.render.canvas.PolygonReplay, ol.render.canvas.Replay);
+ * @param {Array.<number>} flatCoordinates Flat coordinates.
+ * @param {Array.<number>} ends Ends.
+ * @private
+ * @return {number} End.
+ol.render.canvas.PolygonReplay.prototype.drawFlatCoordinatess_ = function(flatCoordinates, offset, ends, stride) {
+ var fill = state.fillStyle !== undefined;
+ var stroke = state.strokeStyle != undefined;
+ var numEnds = ends.length;
+ var beginPathInstruction = [ol.render.canvas.Instruction.BEGIN_PATH];
+ this.instructions.push(beginPathInstruction);
+ this.hitDetectionInstructions.push(beginPathInstruction);
+ for (var i = 0; i < numEnds; ++i) {
+ var end = ends[i];
+ flatCoordinates, offset, end, stride, true, !stroke);
+ if (stroke) {
+ // Performance optimization: only call closePath() when we have a stroke.
+ // Otherwise the ring is closed already (see appendFlatCoordinates above).
+ var closePathInstruction = [ol.render.canvas.Instruction.CLOSE_PATH];
+ this.instructions.push(closePathInstruction);
+ this.hitDetectionInstructions.push(closePathInstruction);
+ offset = end;
+ var fillInstruction = [ol.render.canvas.Instruction.FILL];
+ this.hitDetectionInstructions.push(fillInstruction);
+ if (fill) {
+ this.instructions.push(fillInstruction);
+ if (stroke) {
+ var strokeInstruction = [ol.render.canvas.Instruction.STROKE];
+ this.instructions.push(strokeInstruction);
+ this.hitDetectionInstructions.push(strokeInstruction);
+ return offset;
+ * @inheritDoc
+ol.render.canvas.PolygonReplay.prototype.drawCircle = function(circleGeometry, feature) {
+ var fillStyle = state.fillStyle;
+ if (fillStyle === undefined && strokeStyle === undefined) {
+ return;
+ this.setFillStrokeStyles_(circleGeometry);
+ this.beginGeometry(circleGeometry, feature);
+ // always fill the circle for hit detection
+ ol.render.canvas.Instruction.SET_FILL_STYLE,
+ ol.color.asString(ol.render.canvas.defaultFillStyle)
+ if (state.strokeStyle !== undefined) {
+ var flatCoordinates = circleGeometry.getFlatCoordinates();
+ var stride = circleGeometry.getStride();
+ this.appendFlatCoordinates(
+ flatCoordinates, 0, flatCoordinates.length, stride, false, false);
+ var circleInstruction = [ol.render.canvas.Instruction.CIRCLE, myBegin];
+ this.instructions.push(beginPathInstruction, circleInstruction);
+ this.hitDetectionInstructions.push(beginPathInstruction, circleInstruction);
+ if (state.fillStyle !== undefined) {
+ this.endGeometry(circleGeometry, feature);
+ * @inheritDoc
+ol.render.canvas.PolygonReplay.prototype.drawPolygon = function(polygonGeometry, feature) {
+ this.setFillStrokeStyles_(polygonGeometry);
+ this.beginGeometry(polygonGeometry, feature);
+ // always fill the polygon for hit detection
+ ol.color.asString(ol.render.canvas.defaultFillStyle)]
+ var ends = polygonGeometry.getEnds();
+ var flatCoordinates = polygonGeometry.getOrientedFlatCoordinates();
+ var stride = polygonGeometry.getStride();
+ this.drawFlatCoordinatess_(flatCoordinates, 0, ends, stride);
+ this.endGeometry(polygonGeometry, feature);
+ * @inheritDoc
+ol.render.canvas.PolygonReplay.prototype.drawMultiPolygon = function(multiPolygonGeometry, feature) {
+ return;
+ this.setFillStrokeStyles_(multiPolygonGeometry);
+ this.beginGeometry(multiPolygonGeometry, feature);
+ // always fill the multi-polygon for hit detection
+ var endss = multiPolygonGeometry.getEndss();
+ var flatCoordinates = multiPolygonGeometry.getOrientedFlatCoordinates();
+ var stride = multiPolygonGeometry.getStride();
+ var offset = 0;
+ var i, ii;
+ for (i = 0, ii = endss.length; i < ii; ++i) {
+ offset = this.drawFlatCoordinatess_(
+ flatCoordinates, offset, endss[i], stride);
+ this.endGeometry(multiPolygonGeometry, feature);
+ * @inheritDoc
+ol.render.canvas.PolygonReplay.prototype.finish = function() {
+ // We want to preserve topology when drawing polygons. Polygons are
+ // simplified using quantization and point elimination. However, we might
+ // have received a mix of quantized and non-quantized geometries, so ensure
+ // that all are quantized by quantizing all coordinates in the batch.
+ var tolerance = this.tolerance;
+ if (tolerance !== 0) {
+ var coordinates = this.coordinates;
+ var i, ii;
+ for (i = 0, ii = coordinates.length; i < ii; ++i) {
+ coordinates[i] = ol.geom.flat.simplify.snap(coordinates[i], tolerance);
+ * @inheritDoc
+ol.render.canvas.PolygonReplay.prototype.getBufferedMaxExtent = function() {
+ * @inheritDoc
+ol.render.canvas.PolygonReplay.prototype.setFillStrokeStyle = function(fillStyle, strokeStyle) {
+ if (fillStyle) {
+ var fillStyleColor = fillStyle.getColor();
+ state.fillStyle = ol.colorlike.asColorLike(fillStyleColor ?
+ fillStyleColor : ol.render.canvas.defaultFillStyle);
+ } else {
+ state.fillStyle = undefined;
+ if (strokeStyle) {
+ state.strokeStyle = ol.colorlike.asColorLike(strokeStyleColor ?
+ state.lineCap = strokeStyleLineCap !== undefined ?
+ state.lineDash = strokeStyleLineDash ?
+ strokeStyleLineDash.slice() : ol.render.canvas.defaultLineDash;
+ state.lineDashOffset = strokeStyleLineDashOffset ?
+ state.lineJoin = strokeStyleLineJoin !== undefined ?
+ state.lineWidth = strokeStyleWidth !== undefined ?
+ state.miterLimit = strokeStyleMiterLimit !== undefined ?
+ if (state.lineWidth > this.maxLineWidth) {
+ this.maxLineWidth = state.lineWidth;
+ } else {
+ state.strokeStyle = undefined;
+ state.lineCap = undefined;
+ state.lineDash = null;
+ state.lineDashOffset = undefined;
+ state.lineJoin = undefined;
+ state.lineWidth = undefined;
+ state.miterLimit = undefined;
+ * @private
+ol.render.canvas.PolygonReplay.prototype.setFillStrokeStyles_ = function(geometry) {
+ if (fillStyle !== undefined && (typeof fillStyle !== 'string' || state.currentFillStyle != fillStyle)) {
+ var fillInstruction = [ol.render.canvas.Instruction.SET_FILL_STYLE, fillStyle];
+ if (typeof fillStyle !== 'string') {
+ var fillExtent = geometry.getExtent();
+ fillInstruction.push([fillExtent[0], fillExtent[3]]);
+ state.currentFillStyle = state.fillStyle;
+ if (strokeStyle !== undefined) {
+goog.provide('ol.render.canvas.TextReplay');
+ * @constructor
+ * @struct
+ol.render.canvas.TextReplay = function(tolerance, maxExtent, resolution, overlaps) {
+ * @private
+ * @type {?ol.CanvasFillState}
+ this.replayFillState_ = null;
+ * @private
+ * @type {?ol.CanvasStrokeState}
+ this.replayStrokeState_ = null;
+ * @private
+ * @type {?ol.CanvasTextState}
+ this.replayTextState_ = null;
+ * @private
+ * @type {string}
+ this.text_ = '';
+ * @private
+ * @type {number}
+ this.textOffsetX_ = 0;
+ * @private
+ * @type {number}
+ this.textOffsetY_ = 0;
+ * @private
+ this.textRotateWithView_ = undefined;
+ * @private
+ * @type {number}
+ this.textRotation_ = 0;
+ * @private
+ * @type {number}
+ this.textScale_ = 0;
+ * @private
+ this.textFillState_ = null;
+ * @private
+ this.textStrokeState_ = null;
+ * @private
+ this.textState_ = null;
+ol.inherits(ol.render.canvas.TextReplay, ol.render.canvas.Replay);
+ * @inheritDoc
+ol.render.canvas.TextReplay.prototype.drawText = function(flatCoordinates, offset, end, stride, geometry, feature) {
+ if (this.text_ === '' || !this.textState_ ||
+ (!this.textFillState_ && !this.textStrokeState_)) {
+ return;
+ if (this.textFillState_) {
+ this.setReplayFillState_(this.textFillState_);
+ if (this.textStrokeState_) {
+ this.setReplayStrokeState_(this.textStrokeState_);
+ this.setReplayTextState_(this.textState_);
+ this.beginGeometry(geometry, feature);
+ var myEnd =
+ this.appendFlatCoordinates(flatCoordinates, offset, end, stride, false, false);
+ var fill = !!this.textFillState_;
+ var stroke = !!this.textStrokeState_;
+ var drawTextInstruction = [
+ ol.render.canvas.Instruction.DRAW_TEXT, myBegin, myEnd, this.text_,
+ this.textOffsetX_, this.textOffsetY_, this.textRotation_, this.textScale_,
+ fill, stroke, this.textRotateWithView_];
+ this.instructions.push(drawTextInstruction);
+ this.hitDetectionInstructions.push(drawTextInstruction);
+ this.endGeometry(geometry, feature);
+ * @param {ol.CanvasFillState} fillState Fill state.
+ * @private
+ol.render.canvas.TextReplay.prototype.setReplayFillState_ = function(fillState) {
+ var replayFillState = this.replayFillState_;
+ if (replayFillState &&
+ replayFillState.fillStyle == fillState.fillStyle) {
+ return;
+ var setFillStyleInstruction =
+ [ol.render.canvas.Instruction.SET_FILL_STYLE, fillState.fillStyle];
+ this.instructions.push(setFillStyleInstruction);
+ this.hitDetectionInstructions.push(setFillStyleInstruction);
+ if (!replayFillState) {
+ this.replayFillState_ = {
+ fillStyle: fillState.fillStyle
+ } else {
+ replayFillState.fillStyle = fillState.fillStyle;
+ * @param {ol.CanvasStrokeState} strokeState Stroke state.
+ * @private
+ol.render.canvas.TextReplay.prototype.setReplayStrokeState_ = function(strokeState) {
+ var replayStrokeState = this.replayStrokeState_;
+ if (replayStrokeState &&
+ replayStrokeState.lineCap == strokeState.lineCap &&
+ replayStrokeState.lineDash == strokeState.lineDash &&
+ replayStrokeState.lineDashOffset == strokeState.lineDashOffset &&
+ replayStrokeState.lineJoin == strokeState.lineJoin &&
+ replayStrokeState.lineWidth == strokeState.lineWidth &&
+ replayStrokeState.miterLimit == strokeState.miterLimit &&
+ replayStrokeState.strokeStyle == strokeState.strokeStyle) {
+ return;
+ var setStrokeStyleInstruction = [
+ ol.render.canvas.Instruction.SET_STROKE_STYLE, strokeState.strokeStyle,
+ strokeState.lineWidth, strokeState.lineCap, strokeState.lineJoin,
+ strokeState.miterLimit, strokeState.lineDash, strokeState.lineDashOffset, false, 1
+ this.instructions.push(setStrokeStyleInstruction);
+ this.hitDetectionInstructions.push(setStrokeStyleInstruction);
+ if (!replayStrokeState) {
+ this.replayStrokeState_ = {
+ lineCap: strokeState.lineCap,
+ lineDash: strokeState.lineDash,
+ lineDashOffset: strokeState.lineDashOffset,
+ lineJoin: strokeState.lineJoin,
+ lineWidth: strokeState.lineWidth,
+ miterLimit: strokeState.miterLimit,
+ strokeStyle: strokeState.strokeStyle
+ } else {
+ replayStrokeState.lineCap = strokeState.lineCap;
+ replayStrokeState.lineDash = strokeState.lineDash;
+ replayStrokeState.lineDashOffset = strokeState.lineDashOffset;
+ replayStrokeState.lineJoin = strokeState.lineJoin;
+ replayStrokeState.lineWidth = strokeState.lineWidth;
+ replayStrokeState.miterLimit = strokeState.miterLimit;
+ replayStrokeState.strokeStyle = strokeState.strokeStyle;
+ * @param {ol.CanvasTextState} textState Text state.
+ * @private
+ol.render.canvas.TextReplay.prototype.setReplayTextState_ = function(textState) {
+ var replayTextState = this.replayTextState_;
+ if (replayTextState &&
+ replayTextState.font == textState.font &&
+ replayTextState.textAlign == textState.textAlign &&
+ replayTextState.textBaseline == textState.textBaseline) {
+ return;
+ var setTextStyleInstruction = [ol.render.canvas.Instruction.SET_TEXT_STYLE,
+ textState.font, textState.textAlign, textState.textBaseline];
+ this.instructions.push(setTextStyleInstruction);
+ this.hitDetectionInstructions.push(setTextStyleInstruction);
+ if (!replayTextState) {
+ this.replayTextState_ = {
+ font: textState.font,
+ textAlign: textState.textAlign,
+ textBaseline: textState.textBaseline
+ } else {
+ replayTextState.font = textState.font;
+ replayTextState.textAlign = textState.textAlign;
+ replayTextState.textBaseline = textState.textBaseline;
+ * @inheritDoc
+ol.render.canvas.TextReplay.prototype.setTextStyle = function(textStyle) {
+ if (!textStyle) {
+ this.text_ = '';
+ } else {
+ var textFillStyle = textStyle.getFill();
+ if (!textFillStyle) {
+ } else {
+ var textFillStyleColor = textFillStyle.getColor();
+ var fillStyle = ol.colorlike.asColorLike(textFillStyleColor ?
+ textFillStyleColor : ol.render.canvas.defaultFillStyle);
+ if (!this.textFillState_) {
+ this.textFillState_ = {
+ fillStyle: fillStyle
+ } else {
+ var textFillState = this.textFillState_;
+ textFillState.fillStyle = fillStyle;
+ var textStrokeStyle = textStyle.getStroke();
+ if (!textStrokeStyle) {
+ } else {
+ var textStrokeStyleColor = textStrokeStyle.getColor();
+ var textStrokeStyleLineCap = textStrokeStyle.getLineCap();
+ var textStrokeStyleLineDash = textStrokeStyle.getLineDash();
+ var textStrokeStyleLineDashOffset = textStrokeStyle.getLineDashOffset();
+ var textStrokeStyleLineJoin = textStrokeStyle.getLineJoin();
+ var textStrokeStyleWidth = textStrokeStyle.getWidth();
+ var textStrokeStyleMiterLimit = textStrokeStyle.getMiterLimit();
+ var lineCap = textStrokeStyleLineCap !== undefined ?
+ textStrokeStyleLineCap : ol.render.canvas.defaultLineCap;
+ var lineDash = textStrokeStyleLineDash ?
+ textStrokeStyleLineDash.slice() : ol.render.canvas.defaultLineDash;
+ var lineDashOffset = textStrokeStyleLineDashOffset !== undefined ?
+ textStrokeStyleLineDashOffset : ol.render.canvas.defaultLineDashOffset;
+ var lineJoin = textStrokeStyleLineJoin !== undefined ?
+ textStrokeStyleLineJoin : ol.render.canvas.defaultLineJoin;
+ var lineWidth = textStrokeStyleWidth !== undefined ?
+ textStrokeStyleWidth : ol.render.canvas.defaultLineWidth;
+ var miterLimit = textStrokeStyleMiterLimit !== undefined ?
+ textStrokeStyleMiterLimit : ol.render.canvas.defaultMiterLimit;
+ var strokeStyle = ol.colorlike.asColorLike(textStrokeStyleColor ?
+ textStrokeStyleColor : ol.render.canvas.defaultStrokeStyle);
+ if (!this.textStrokeState_) {
+ this.textStrokeState_ = {
+ lineCap: lineCap,
+ lineDash: lineDash,
+ lineDashOffset: lineDashOffset,
+ lineJoin: lineJoin,
+ lineWidth: lineWidth,
+ miterLimit: miterLimit,
+ strokeStyle: strokeStyle
+ } else {
+ var textStrokeState = this.textStrokeState_;
+ textStrokeState.lineCap = lineCap;
+ textStrokeState.lineDash = lineDash;
+ textStrokeState.lineDashOffset = lineDashOffset;
+ textStrokeState.lineJoin = lineJoin;
+ textStrokeState.lineWidth = lineWidth;
+ textStrokeState.miterLimit = miterLimit;
+ textStrokeState.strokeStyle = strokeStyle;
+ var textFont = textStyle.getFont();
+ var textOffsetX = textStyle.getOffsetX();
+ var textOffsetY = textStyle.getOffsetY();
+ var textRotateWithView = textStyle.getRotateWithView();
+ var textRotation = textStyle.getRotation();
+ var textScale = textStyle.getScale();
+ var textText = textStyle.getText();
+ var textTextAlign = textStyle.getTextAlign();
+ var textTextBaseline = textStyle.getTextBaseline();
+ var font = textFont !== undefined ?
+ textFont : ol.render.canvas.defaultFont;
+ var textAlign = textTextAlign !== undefined ?
+ textTextAlign : ol.render.canvas.defaultTextAlign;
+ var textBaseline = textTextBaseline !== undefined ?
+ textTextBaseline : ol.render.canvas.defaultTextBaseline;
+ if (!this.textState_) {
+ this.textState_ = {
+ font: font,
+ textAlign: textAlign,
+ textBaseline: textBaseline
+ } else {
+ var textState = this.textState_;
+ textState.font = font;
+ textState.textAlign = textAlign;
+ textState.textBaseline = textBaseline;
+ this.text_ = textText !== undefined ? textText : '';
+ this.textOffsetX_ = textOffsetX !== undefined ? textOffsetX : 0;
+ this.textOffsetY_ = textOffsetY !== undefined ? textOffsetY : 0;
+ this.textRotateWithView_ = textRotateWithView !== undefined ? textRotateWithView : false;
+ this.textRotation_ = textRotation !== undefined ? textRotation : 0;
+ this.textScale_ = textScale !== undefined ? textScale : 1;
+goog.provide('ol.render.canvas.ReplayGroup');
+goog.require('ol.dom');
+goog.require('ol.render.ReplayGroup');
+goog.require('ol.render.canvas.ImageReplay');
+goog.require('ol.render.canvas.LineStringReplay');
+goog.require('ol.render.canvas.PolygonReplay');
+goog.require('ol.render.canvas.TextReplay');
+goog.require('ol.render.replay');
+ * @constructor
+ * @extends {ol.render.ReplayGroup}
+ * @param {ol.Extent} maxExtent Max extent.
+ * @param {number} resolution Resolution.
+ * @param {boolean} overlaps The replay group can have overlapping geometries.
+ * @param {number=} opt_renderBuffer Optional rendering buffer.
+ * @struct
+ol.render.canvas.ReplayGroup = function(
+ tolerance, maxExtent, resolution, overlaps, opt_renderBuffer) {
+ ol.render.ReplayGroup.call(this);
+ * @private
+ * @type {number}
+ this.tolerance_ = tolerance;
+ * @private
+ * @type {ol.Extent}
+ this.maxExtent_ = maxExtent;
+ * @private
+ * @type {boolean}
+ this.overlaps_ = overlaps;
+ * @private
+ * @type {number}
+ this.resolution_ = resolution;
+ * @private
+ this.renderBuffer_ = opt_renderBuffer;
+ * @private
+ * @type {!Object.<string,
+ * Object.<ol.render.ReplayType, ol.render.canvas.Replay>>}
+ this.replaysByZIndex_ = {};
+ * @private
+ * @type {CanvasRenderingContext2D}
+ this.hitDetectionContext_ = ol.dom.createCanvasContext2D(1, 1);
+ * @private
+ * @type {ol.Transform}
+ this.hitDetectionTransform_ = ol.transform.create();
+ol.inherits(ol.render.canvas.ReplayGroup, ol.render.ReplayGroup);
+ * This cache is used for storing calculated pixel circles for increasing performance.
+ * It is a static property to allow each Replaygroup to access it.
+ * @type {Object.<number, Array.<Array.<(boolean|undefined)>>>}
+ * @private
+ol.render.canvas.ReplayGroup.circleArrayCache_ = {
+ 0: [[true]]
+ * This method fills a row in the array from the given coordinate to the
+ * middle with `true`.
+ * @param {Array.<Array.<(boolean|undefined)>>} array The array that will be altered.
+ * @param {number} x X coordinate.
+ * @param {number} y Y coordinate.
+ * @private
+ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_ = function(array, x, y) {
+ var i;
+ var radius = Math.floor(array.length / 2);
+ if (x >= radius) {
+ for (i = radius; i < x; i++) {
+ array[i][y] = true;
+ } else if (x < radius) {
+ for (i = x + 1; i < radius; i++) {
+ * This methods creates a circle inside a fitting array. Points inside the
+ * circle are marked by true, points on the outside are undefined.
+ * It uses the midpoint circle algorithm.
+ * A cache is used to increase performance.
+ * @param {number} radius Radius.
+ * @returns {Array.<Array.<(boolean|undefined)>>} An array with marked circle points.
+ * @private
+ol.render.canvas.ReplayGroup.getCircleArray_ = function(radius) {
+ if (ol.render.canvas.ReplayGroup.circleArrayCache_[radius] !== undefined) {
+ return ol.render.canvas.ReplayGroup.circleArrayCache_[radius];
+ var arraySize = radius * 2 + 1;
+ var arr = new Array(arraySize);
+ for (var i = 0; i < arraySize; i++) {
+ arr[i] = new Array(arraySize);
+ var x = radius;
+ var y = 0;
+ var error = 0;
+ while (x >= y) {
+ ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_(arr, radius + x, radius + y);
+ ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_(arr, radius + y, radius + x);
+ ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_(arr, radius - y, radius + x);
+ ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_(arr, radius - x, radius + y);
+ ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_(arr, radius - x, radius - y);
+ ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_(arr, radius - y, radius - x);
+ ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_(arr, radius + y, radius - x);
+ ol.render.canvas.ReplayGroup.fillCircleArrayRowToMiddle_(arr, radius + x, radius - y);
+ y++;
+ error += 1 + 2 * y;
+ if (2 * (error - x) + 1 > 0) {
+ x -= 1;
+ error += 1 - 2 * x;
+ ol.render.canvas.ReplayGroup.circleArrayCache_[radius] = arr;
+ return arr;
+ol.render.canvas.ReplayGroup.prototype.finish = function() {
+ var zKey;
+ for (zKey in this.replaysByZIndex_) {
+ var replays = this.replaysByZIndex_[zKey];
+ var replayKey;
+ for (replayKey in replays) {
+ replays[replayKey].finish();
+ * @param {ol.Coordinate} coordinate Coordinate.
+ * @param {number} hitTolerance Hit tolerance in pixels.
+ * to skip.
+ * @param {function((ol.Feature|ol.render.Feature)): T} callback Feature
+ * callback.
+ * @template T
+ol.render.canvas.ReplayGroup.prototype.forEachFeatureAtCoordinate = function(
+ coordinate, resolution, rotation, hitTolerance, skippedFeaturesHash, callback) {
+ hitTolerance = Math.round(hitTolerance);
+ var contextSize = hitTolerance * 2 + 1;
+ var transform = ol.transform.compose(this.hitDetectionTransform_,
+ hitTolerance + 0.5, hitTolerance + 0.5,
+ 1 / resolution, -1 / resolution,
+ -rotation,
+ -coordinate[0], -coordinate[1]);
+ var context = this.hitDetectionContext_;
+ if (context.canvas.width !== contextSize || context.canvas.height !== contextSize) {
+ context.canvas.width = contextSize;
+ context.canvas.height = contextSize;
+ } else {
+ context.clearRect(0, 0, contextSize, contextSize);
+ var hitExtent;
+ if (this.renderBuffer_ !== undefined) {
+ hitExtent = ol.extent.createEmpty();
+ ol.extent.extendCoordinate(hitExtent, coordinate);
+ ol.extent.buffer(hitExtent, resolution * (this.renderBuffer_ + hitTolerance), hitExtent);
+ var mask = ol.render.canvas.ReplayGroup.getCircleArray_(hitTolerance);
+ return this.replayHitDetection_(context, transform, rotation,
+ * @return {?} Callback result.
+ function(feature) {
+ var imageData = context.getImageData(0, 0, contextSize, contextSize).data;
+ for (var i = 0; i < contextSize; i++) {
+ for (var j = 0; j < contextSize; j++) {
+ if (mask[i][j]) {
+ if (imageData[(j * contextSize + i) * 4 + 3] > 0) {
+ var result = callback(feature);
+ if (result) {
+ return result;
+ } else {
+ return undefined;
+ }, hitExtent);
+ * @return {Array.<number>} Clip coordinates.
+ol.render.canvas.ReplayGroup.prototype.getClipCoords = function(transform) {
+ var maxExtent = this.maxExtent_;
+ var minX = maxExtent[0];
+ var minY = maxExtent[1];
+ var maxX = maxExtent[2];
+ var maxY = maxExtent[3];
+ var flatClipCoords = [minX, minY, minX, maxY, maxX, maxY, maxX, minY];
+ ol.geom.flat.transform.transform2D(
+ flatClipCoords, 0, 8, 2, transform, flatClipCoords);
+ return flatClipCoords;
+ * @inheritDoc
+ol.render.canvas.ReplayGroup.prototype.getReplay = function(zIndex, replayType) {
+ var zIndexKey = zIndex !== undefined ? zIndex.toString() : '0';
+ var replays = this.replaysByZIndex_[zIndexKey];
+ if (replays === undefined) {
+ replays = {};
+ this.replaysByZIndex_[zIndexKey] = replays;
+ var replay = replays[replayType];
+ if (replay === undefined) {
+ var Constructor = ol.render.canvas.ReplayGroup.BATCH_CONSTRUCTORS_[replayType];
+ replay = new Constructor(this.tolerance_, this.maxExtent_,
+ this.resolution_, this.overlaps_);
+ replays[replayType] = replay;
+ return replay;
+ * @inheritDoc
+ol.render.canvas.ReplayGroup.prototype.isEmpty = function() {
+ return ol.obj.isEmpty(this.replaysByZIndex_);
+ * @param {number} pixelRatio Pixel ratio.
+ * to skip.
+ * @param {Array.<ol.render.ReplayType>=} opt_replayTypes Ordered replay types
+ * to replay. Default is {@link ol.render.replay.ORDER}
+ol.render.canvas.ReplayGroup.prototype.replay = function(context, pixelRatio,
+ transform, viewRotation, skippedFeaturesHash, opt_replayTypes) {
+ /** @type {Array.<number>} */
+ var zs = Object.keys(this.replaysByZIndex_).map(Number);
+ zs.sort(ol.array.numberSafeCompareFunction);
+ // setup clipping so that the parts of over-simplified geometries are not
+ // visible outside the current extent when panning
+ var flatClipCoords = this.getClipCoords(transform);
+ context.save();
+ context.moveTo(flatClipCoords[0], flatClipCoords[1]);
+ context.lineTo(flatClipCoords[2], flatClipCoords[3]);
+ context.lineTo(flatClipCoords[4], flatClipCoords[5]);
+ context.lineTo(flatClipCoords[6], flatClipCoords[7]);
+ context.clip();
+ var replayTypes = opt_replayTypes ? opt_replayTypes : ol.render.replay.ORDER;
+ var i, ii, j, jj, replays, replay;
+ for (i = 0, ii = zs.length; i < ii; ++i) {
+ replays = this.replaysByZIndex_[zs[i].toString()];
+ for (j = 0, jj = replayTypes.length; j < jj; ++j) {
+ replay = replays[replayTypes[j]];
+ if (replay !== undefined) {
+ replay.replay(context, pixelRatio, transform, viewRotation,
+ skippedFeaturesHash);
+ context.restore();
+ * @private
+ * to skip.
+ * @param {function((ol.Feature|ol.render.Feature)): T} featureCallback
+ * extent.
+ * @template T
+ol.render.canvas.ReplayGroup.prototype.replayHitDetection_ = function(
+ featureCallback, opt_hitExtent) {
+ zs.sort(function(a, b) {
+ return b - a;
+ var i, ii, j, replays, replay, result;
+ for (j = ol.render.replay.ORDER.length - 1; j >= 0; --j) {
+ replay = replays[ol.render.replay.ORDER[j]];
+ result = replay.replayHitDetection(context, transform, viewRotation,
+ skippedFeaturesHash, featureCallback, opt_hitExtent);
+ if (result) {
+ return result;
+ return undefined;
+ * @const
+ * @private
+ * @type {Object.<ol.render.ReplayType,
+ * function(new: ol.render.canvas.Replay, number, ol.Extent,
+ * number, boolean)>}
+ol.render.canvas.ReplayGroup.BATCH_CONSTRUCTORS_ = {
+ 'Circle': ol.render.canvas.PolygonReplay,
+ 'Image': ol.render.canvas.ImageReplay,
+ 'LineString': ol.render.canvas.LineStringReplay,
+ 'Polygon': ol.render.canvas.PolygonReplay,
+ 'Text': ol.render.canvas.TextReplay
+goog.provide('ol.renderer.Layer');
+goog.require('ol');
+goog.require('ol.ImageState');
+goog.require('ol.Observable');
+goog.require('ol.TileState');
+goog.require('ol.asserts');
+goog.require('ol.events');
+goog.require('ol.events.EventType');
+goog.require('ol.source.State');
+ * @constructor
+ * @extends {ol.Observable}
+ * @param {ol.layer.Layer} layer Layer.
+ * @struct
+ol.renderer.Layer = function(layer) {
+ ol.Observable.call(this);
+ * @private
+ * @type {ol.layer.Layer}
+ this.layer_ = layer;
+ol.inherits(ol.renderer.Layer, ol.Observable);
+ * @param {olx.FrameState} frameState Frame state.
+ * @param {function(this: S, (ol.Feature|ol.render.Feature), ol.layer.Layer): T}
+ * callback Feature callback.
+ * @param {S} thisArg Value to use as `this` when executing `callback`.
+ * @template S,T
+ol.renderer.Layer.prototype.forEachFeatureAtCoordinate = ol.nullFunction;
+ * @return {boolean} Is there a feature at the given coordinate?
+ol.renderer.Layer.prototype.hasFeatureAtCoordinate = ol.functions.FALSE;
+ * Create a function that adds loaded tiles to the tile lookup.
+ * @param {ol.source.Tile} source Tile source.
+ * @param {ol.proj.Projection} projection Projection of the tiles.
+ * @param {Object.<number, Object.<string, ol.Tile>>} tiles Lookup of loaded
+ * tiles by zoom level.
+ * @return {function(number, ol.TileRange):boolean} A function that can be
+ * called with a zoom level and a tile range to add loaded tiles to the
+ * lookup.
+ * @protected
+ol.renderer.Layer.prototype.createLoadedTileFinder = function(source, projection, tiles) {
+ return (
+ * @param {number} zoom Zoom level.
+ * @param {ol.TileRange} tileRange Tile range.
+ * @return {boolean} The tile range is fully loaded.
+ function(zoom, tileRange) {
+ function callback(tile) {
+ if (!tiles[zoom]) {
+ tiles[zoom] = {};
+ tiles[zoom][tile.tileCoord.toString()] = tile;
+ return source.forEachLoadedTile(projection, zoom, tileRange, callback);
+ * @return {ol.layer.Layer} Layer.
+ol.renderer.Layer.prototype.getLayer = function() {
+ return this.layer_;
+ * Handle changes in image state.
+ * @param {ol.events.Event} event Image change event.
+ * @private
+ol.renderer.Layer.prototype.handleImageChange_ = function(event) {
+ var image = /** @type {ol.Image} */ (event.target);
+ if (image.getState() === ol.ImageState.LOADED) {
+ this.renderIfReadyAndVisible();
+ * Load the image if not already loaded, and register the image change
+ * listener if needed.
+ * @param {ol.ImageBase} image Image.
+ * @return {boolean} `true` if the image is already loaded, `false`
+ * otherwise.
+ * @protected
+ol.renderer.Layer.prototype.loadImage = function(image) {
+ var imageState = image.getState();
+ if (imageState != ol.ImageState.LOADED &&
+ imageState != ol.ImageState.ERROR) {
+ ol.events.listen(image, ol.events.EventType.CHANGE,
+ this.handleImageChange_, this);
+ if (imageState == ol.ImageState.IDLE) {
+ image.load();
+ imageState = image.getState();
+ return imageState == ol.ImageState.LOADED;
+ * @protected
+ol.renderer.Layer.prototype.renderIfReadyAndVisible = function() {
+ var layer = this.getLayer();
+ if (layer.getVisible() && layer.getSourceState() == ol.source.State.READY) {
+ this.changed();
+ * @param {ol.source.Tile} tileSource Tile source.
+ * @protected
+ol.renderer.Layer.prototype.scheduleExpireCache = function(frameState, tileSource) {
+ if (tileSource.canExpireCache()) {
+ * @param {ol.Map} map Map.
+ var postRenderFunction = function(tileSource, map, frameState) {
+ var tileSourceKey = ol.getUid(tileSource).toString();
+ tileSource.expireCache(frameState.viewState.projection,
+ frameState.usedTiles[tileSourceKey]);
+ }.bind(null, tileSource);
+ frameState.postRenderFunctions.push(
+ /** @type {ol.PostRenderFunction} */ (postRenderFunction)
+ * @param {Object.<string, ol.Attribution>} attributionsSet Attributions
+ * set (target).
+ * @param {Array.<ol.Attribution>} attributions Attributions (source).
+ * @protected
+ol.renderer.Layer.prototype.updateAttributions = function(attributionsSet, attributions) {
+ if (attributions) {
+ var attribution, i, ii;
+ for (i = 0, ii = attributions.length; i < ii; ++i) {
+ attribution = attributions[i];
+ attributionsSet[ol.getUid(attribution).toString()] = attribution;
+ * @param {ol.source.Source} source Source.
+ * @protected
+ol.renderer.Layer.prototype.updateLogos = function(frameState, source) {
+ var logo = source.getLogo();
+ if (logo !== undefined) {
+ if (typeof logo === 'string') {
+ frameState.logos[logo] = '';
+ } else if (logo) {
+ ol.asserts.assert(typeof logo.href == 'string', 44); // `logo.href` should be a string.
+ ol.asserts.assert(typeof logo.src == 'string', 45); // `logo.src` should be a string.
+ frameState.logos[logo.src] = logo.href;
+ * @param {Object.<string, Object.<string, ol.TileRange>>} usedTiles Used tiles.
+ * @param {number} z Z.
+ * @protected
+ol.renderer.Layer.prototype.updateUsedTiles = function(usedTiles, tileSource, z, tileRange) {
+ // FIXME should we use tilesToDrawByZ instead?
+ var zKey = z.toString();
+ if (tileSourceKey in usedTiles) {
+ if (zKey in usedTiles[tileSourceKey]) {
+ usedTiles[tileSourceKey][zKey].extend(tileRange);
+ } else {
+ usedTiles[tileSourceKey][zKey] = tileRange;
+ } else {
+ usedTiles[tileSourceKey] = {};
+ * Manage tile pyramid.
+ * This function performs a number of functions related to the tiles at the
+ * current zoom and lower zoom levels:
+ * - registers idle tiles in frameState.wantedTiles so that they are not
+ * discarded by the tile queue
+ * - enqueues missing tiles
+ * @param {ol.tilegrid.TileGrid} tileGrid Tile grid.
+ * @param {ol.proj.Projection} projection Projection.
+ * @param {ol.Extent} extent Extent.
+ * @param {number} currentZ Current Z.
+ * @param {number} preload Load low resolution tiles up to 'preload' levels.
+ * @param {function(this: T, ol.Tile)=} opt_tileCallback Tile callback.
+ * @param {T=} opt_this Object to use as `this` in `opt_tileCallback`.
+ * @protected
+ * @template T
+ol.renderer.Layer.prototype.manageTilePyramid = function(
+ frameState, tileSource, tileGrid, pixelRatio, projection, extent,
+ currentZ, preload, opt_tileCallback, opt_this) {
+ if (!(tileSourceKey in frameState.wantedTiles)) {
+ frameState.wantedTiles[tileSourceKey] = {};
+ var wantedTiles = frameState.wantedTiles[tileSourceKey];
+ var tileQueue = frameState.tileQueue;
+ var minZoom = tileGrid.getMinZoom();
+ var tile, tileRange, tileResolution, x, y, z;
+ for (z = currentZ; z >= minZoom; --z) {
+ tileRange = tileGrid.getTileRangeForExtentAndZ(extent, z, tileRange);
+ tileResolution = tileGrid.getResolution(z);
+ for (x = tileRange.minX; x <= tileRange.maxX; ++x) {
+ for (y = tileRange.minY; y <= tileRange.maxY; ++y) {
+ if (currentZ - z <= preload) {
+ tile = tileSource.getTile(z, x, y, pixelRatio, projection);
+ if (tile.getState() == ol.TileState.IDLE) {
+ wantedTiles[tile.getKey()] = true;
+ if (!tileQueue.isKeyQueued(tile.getKey())) {
+ tileQueue.enqueue([tile, tileSourceKey,
+ tileGrid.getTileCoordCenter(tile.tileCoord), tileResolution]);
+ if (opt_tileCallback !== undefined) {
+ opt_tileCallback.call(opt_this, tile);
+ } else {
+ tileSource.useTile(z, x, y, projection);
+goog.provide('ol.renderer.canvas.Layer');
+goog.require('ol.functions');
+goog.require('ol.render.Event');
+goog.require('ol.render.EventType');
+goog.require('ol.render.canvas.Immediate');
+goog.require('ol.renderer.Layer');
+ * @constructor
+ * @abstract
+ * @extends {ol.renderer.Layer}
+ol.renderer.canvas.Layer = function(layer) {
+ ol.renderer.Layer.call(this, layer);
+ * @protected
+ * @type {number}
+ this.renderedResolution;
+ * @private
+ this.transform_ = ol.transform.create();
+ol.inherits(ol.renderer.canvas.Layer, ol.renderer.Layer);
+ * @param {ol.Extent} extent Clip extent.
+ * @protected
+ol.renderer.canvas.Layer.prototype.clip = function(context, frameState, extent) {
+ var pixelRatio = frameState.pixelRatio;
+ var width = frameState.size[0] * pixelRatio;
+ var height = frameState.size[1] * pixelRatio;
+ var rotation = frameState.viewState.rotation;
+ var topLeft = ol.extent.getTopLeft(/** @type {ol.Extent} */ (extent));
+ var topRight = ol.extent.getTopRight(/** @type {ol.Extent} */ (extent));
+ var bottomRight = ol.extent.getBottomRight(/** @type {ol.Extent} */ (extent));
+ var bottomLeft = ol.extent.getBottomLeft(/** @type {ol.Extent} */ (extent));
+ ol.transform.apply(frameState.coordinateToPixelTransform, topLeft);
+ ol.transform.apply(frameState.coordinateToPixelTransform, topRight);
+ ol.transform.apply(frameState.coordinateToPixelTransform, bottomRight);
+ ol.transform.apply(frameState.coordinateToPixelTransform, bottomLeft);
+ context.save();
+ ol.render.canvas.rotateAtOffset(context, -rotation, width / 2, height / 2);
+ context.moveTo(topLeft[0] * pixelRatio, topLeft[1] * pixelRatio);
+ context.lineTo(topRight[0] * pixelRatio, topRight[1] * pixelRatio);
+ context.lineTo(bottomRight[0] * pixelRatio, bottomRight[1] * pixelRatio);
+ context.lineTo(bottomLeft[0] * pixelRatio, bottomLeft[1] * pixelRatio);
+ context.clip();
+ ol.render.canvas.rotateAtOffset(context, rotation, width / 2, height / 2);
+ * @param {ol.render.EventType} type Event type.
+ * @param {ol.Transform=} opt_transform Transform.
+ * @private
+ol.renderer.canvas.Layer.prototype.dispatchComposeEvent_ = function(type, context, frameState, opt_transform) {
+ if (layer.hasListener(type)) {
+ var width = frameState.size[0] * frameState.pixelRatio;
+ var height = frameState.size[1] * frameState.pixelRatio;
+ var transform = opt_transform !== undefined ?
+ opt_transform : this.getTransform(frameState, 0);
+ var render = new ol.render.canvas.Immediate(
+ context, frameState.pixelRatio, frameState.extent, transform,
+ frameState.viewState.rotation);
+ var composeEvent = new ol.render.Event(type, render, frameState,
+ context, null);
+ layer.dispatchEvent(composeEvent);
+ * @param {olx.FrameState} frameState FrameState.
+ * @param {function(this: S, ol.layer.Layer, (Uint8ClampedArray|Uint8Array)): T} callback Layer
+ * callback.
+ * @template S,T,U
+ol.renderer.canvas.Layer.prototype.forEachLayerAtCoordinate = function(coordinate, frameState, callback, thisArg) {
+ var hasFeature = this.forEachFeatureAtCoordinate(
+ coordinate, frameState, 0, ol.functions.TRUE, this);
+ if (hasFeature) {
+ return callback.call(thisArg, this.getLayer(), null);
+ } else {
+ return undefined;
+ * @param {ol.LayerState} layerState Layer state.
+ * @protected
+ol.renderer.canvas.Layer.prototype.postCompose = function(context, frameState, layerState, opt_transform) {
+ this.dispatchComposeEvent_(ol.render.EventType.POSTCOMPOSE, context,
+ frameState, opt_transform);
+ * @protected
+ol.renderer.canvas.Layer.prototype.preCompose = function(context, frameState, opt_transform) {
+ this.dispatchComposeEvent_(ol.render.EventType.PRECOMPOSE, context,
+ * @protected
+ol.renderer.canvas.Layer.prototype.dispatchRenderEvent = function(context, frameState, opt_transform) {
+ this.dispatchComposeEvent_(ol.render.EventType.RENDER, context,
+ * @param {number} offsetX Offset on the x-axis in view coordinates.
+ * @protected
+ * @return {!ol.Transform} Transform.
+ol.renderer.canvas.Layer.prototype.getTransform = function(frameState, offsetX) {
+ var viewState = frameState.viewState;
+ var dx1 = pixelRatio * frameState.size[0] / 2;
+ var dy1 = pixelRatio * frameState.size[1] / 2;
+ var sx = pixelRatio / viewState.resolution;
+ var sy = -sx;
+ var angle = -viewState.rotation;
+ var dx2 = -viewState.center[0] + offsetX;
+ var dy2 = -viewState.center[1];
+ return ol.transform.compose(this.transform_, dx1, dy1, sx, sy, angle, dx2, dy2);
+ * @abstract
+ol.renderer.canvas.Layer.prototype.composeFrame = function(frameState, layerState, context) {};
+ * @abstract
+ * @return {boolean} whether composeFrame should be called.
+ol.renderer.canvas.Layer.prototype.prepareFrame = function(frameState, layerState) {};
+goog.provide('ol.renderer.vector');
+goog.require('ol.render.ReplayType');
+ * @param {ol.Feature|ol.render.Feature} feature1 Feature 1.
+ * @param {ol.Feature|ol.render.Feature} feature2 Feature 2.
+ * @return {number} Order.
+ol.renderer.vector.defaultOrder = function(feature1, feature2) {
+ return ol.getUid(feature1) - ol.getUid(feature2);
+ * @return {number} Squared pixel tolerance.
+ol.renderer.vector.getSquaredTolerance = function(resolution, pixelRatio) {
+ var tolerance = ol.renderer.vector.getTolerance(resolution, pixelRatio);
+ return tolerance * tolerance;
+ * @return {number} Pixel tolerance.
+ol.renderer.vector.getTolerance = function(resolution, pixelRatio) {
+ return ol.SIMPLIFY_TOLERANCE * resolution / pixelRatio;
+ * @param {ol.render.ReplayGroup} replayGroup Replay group.
+ * @param {ol.geom.Circle} geometry Geometry.
+ * @param {ol.style.Style} style Style.
+ * @param {ol.Feature} feature Feature.
+ * @private
+ol.renderer.vector.renderCircleGeometry_ = function(replayGroup, geometry, style, feature) {
+ var fillStyle = style.getFill();
+ var strokeStyle = style.getStroke();
+ if (fillStyle || strokeStyle) {
+ var circleReplay = replayGroup.getReplay(
+ style.getZIndex(), ol.render.ReplayType.CIRCLE);
+ circleReplay.setFillStrokeStyle(fillStyle, strokeStyle);
+ circleReplay.drawCircle(geometry, feature);
+ var textStyle = style.getText();
+ if (textStyle) {
+ var textReplay = replayGroup.getReplay(
+ style.getZIndex(), ol.render.ReplayType.TEXT);
+ textReplay.setTextStyle(textStyle);
+ textReplay.drawText(geometry.getCenter(), 0, 2, 2, geometry, feature);
+ * @param {ol.Feature|ol.render.Feature} feature Feature.
+ * @param {number} squaredTolerance Squared tolerance.
+ * @param {function(this: T, ol.events.Event)} listener Listener function.
+ * @param {T} thisArg Value to use as `this` when executing `listener`.
+ * @return {boolean} `true` if style is loading.
+ * @template T
+ol.renderer.vector.renderFeature = function(
+ replayGroup, feature, style, squaredTolerance, listener, thisArg) {
+ var loading = false;
+ var imageStyle, imageState;
+ imageStyle = style.getImage();
+ if (imageStyle) {
+ imageState = imageStyle.getImageState();
+ if (imageState == ol.ImageState.LOADED ||
+ imageState == ol.ImageState.ERROR) {
+ imageStyle.unlistenImageChange(listener, thisArg);
+ } else {
+ imageStyle.load();
+ imageStyle.listenImageChange(listener, thisArg);
+ loading = true;
+ ol.renderer.vector.renderFeature_(replayGroup, feature, style,
+ squaredTolerance);
+ return loading;
+ * @private
+ol.renderer.vector.renderFeature_ = function(
+ replayGroup, feature, style, squaredTolerance) {
+ var geometry = style.getGeometryFunction()(feature);
+ if (!geometry) {
+ return;
+ var simplifiedGeometry = geometry.getSimplifiedGeometry(squaredTolerance);
+ var geometryRenderer =
+ ol.renderer.vector.GEOMETRY_RENDERERS_[simplifiedGeometry.getType()];
+ geometryRenderer(replayGroup, simplifiedGeometry, style, feature);
+ * @param {ol.geom.GeometryCollection} geometry Geometry.
+ * @private
+ol.renderer.vector.renderGeometryCollectionGeometry_ = function(replayGroup, geometry, style, feature) {
+ var geometries = geometry.getGeometriesArray();
+ var i, ii;
+ for (i = 0, ii = geometries.length; i < ii; ++i) {
+ ol.renderer.vector.GEOMETRY_RENDERERS_[geometries[i].getType()];
+ geometryRenderer(replayGroup, geometries[i], style, feature);
+ * @param {ol.geom.LineString|ol.render.Feature} geometry Geometry.
+ * @private
+ol.renderer.vector.renderLineStringGeometry_ = function(replayGroup, geometry, style, feature) {
+ var lineStringReplay = replayGroup.getReplay(
+ style.getZIndex(), ol.render.ReplayType.LINE_STRING);
+ lineStringReplay.setFillStrokeStyle(null, strokeStyle);
+ lineStringReplay.drawLineString(geometry, feature);
+ if (textStyle) {
+ textReplay.drawText(geometry.getFlatMidpoint(), 0, 2, 2, geometry, feature);
+ * @param {ol.geom.MultiLineString|ol.render.Feature} geometry Geometry.
+ * @private
+ol.renderer.vector.renderMultiLineStringGeometry_ = function(replayGroup, geometry, style, feature) {
+ lineStringReplay.drawMultiLineString(geometry, feature);
+ if (textStyle) {
+ var flatMidpointCoordinates = geometry.getFlatMidpoints();
+ textReplay.drawText(flatMidpointCoordinates, 0,
+ flatMidpointCoordinates.length, 2, geometry, feature);
+ * @param {ol.geom.MultiPolygon} geometry Geometry.
+ * @private
+ol.renderer.vector.renderMultiPolygonGeometry_ = function(replayGroup, geometry, style, feature) {
+ if (strokeStyle || fillStyle) {
+ var polygonReplay = replayGroup.getReplay(
+ style.getZIndex(), ol.render.ReplayType.POLYGON);
+ polygonReplay.setFillStrokeStyle(fillStyle, strokeStyle);
+ polygonReplay.drawMultiPolygon(geometry, feature);
+ if (textStyle) {
+ var flatInteriorPointCoordinates = geometry.getFlatInteriorPoints();
+ textReplay.drawText(flatInteriorPointCoordinates, 0,
+ flatInteriorPointCoordinates.length, 2, geometry, feature);
+ * @param {ol.geom.Point|ol.render.Feature} geometry Geometry.
+ * @private
+ol.renderer.vector.renderPointGeometry_ = function(replayGroup, geometry, style, feature) {
+ var imageStyle = style.getImage();
+ if (imageStyle) {
+ if (imageStyle.getImageState() != ol.ImageState.LOADED) {
+ return;
+ var imageReplay = replayGroup.getReplay(
+ style.getZIndex(), ol.render.ReplayType.IMAGE);
+ imageReplay.setImageStyle(imageStyle);
+ imageReplay.drawPoint(geometry, feature);
+ if (textStyle) {
+ textReplay.drawText(geometry.getFlatCoordinates(), 0, 2, 2, geometry,
+ feature);
+ * @param {ol.geom.MultiPoint|ol.render.Feature} geometry Geometry.
+ * @private
+ol.renderer.vector.renderMultiPointGeometry_ = function(replayGroup, geometry, style, feature) {
+ if (imageStyle) {
+ return;
+ imageReplay.drawMultiPoint(geometry, feature);
+ if (textStyle) {
+ var flatCoordinates = geometry.getFlatCoordinates();
+ textReplay.drawText(flatCoordinates, 0, flatCoordinates.length,
+ geometry.getStride(), geometry, feature);
+ * @param {ol.geom.Polygon|ol.render.Feature} geometry Geometry.
+ * @private
+ol.renderer.vector.renderPolygonGeometry_ = function(replayGroup, geometry, style, feature) {
+ polygonReplay.drawPolygon(geometry, feature);
+ if (textStyle) {
+ geometry.getFlatInteriorPoint(), 0, 2, 2, geometry, feature);
+ * @const
+ * @private
+ * @type {Object.<ol.geom.GeometryType,
+ * function(ol.render.ReplayGroup, ol.geom.Geometry,
+ * ol.style.Style, Object)>}
+ol.renderer.vector.GEOMETRY_RENDERERS_ = {
+ 'Point': ol.renderer.vector.renderPointGeometry_,
+ 'LineString': ol.renderer.vector.renderLineStringGeometry_,
+ 'Polygon': ol.renderer.vector.renderPolygonGeometry_,
+ 'MultiPoint': ol.renderer.vector.renderMultiPointGeometry_,
+ 'MultiLineString': ol.renderer.vector.renderMultiLineStringGeometry_,
+ 'MultiPolygon': ol.renderer.vector.renderMultiPolygonGeometry_,
+ 'GeometryCollection': ol.renderer.vector.renderGeometryCollectionGeometry_,
+ 'Circle': ol.renderer.vector.renderCircleGeometry_
+goog.provide('ol.renderer.canvas.VectorLayer');
+goog.require('ol.ViewHint');
+goog.require('ol.render.canvas.ReplayGroup');
+goog.require('ol.renderer.canvas.Layer');
+goog.require('ol.renderer.vector');
+ * @constructor
+ * @extends {ol.renderer.canvas.Layer}
+ * @param {ol.layer.Vector} vectorLayer Vector layer.
+ol.renderer.canvas.VectorLayer = function(vectorLayer) {
+ ol.renderer.canvas.Layer.call(this, vectorLayer);
+ * @private
+ * @type {boolean}
+ this.dirty_ = false;
+ * @private
+ * @type {number}
+ this.renderedRevision_ = -1;
+ * @private
+ * @type {number}
+ this.renderedResolution_ = NaN;
+ * @private
+ this.renderedExtent_ = ol.extent.createEmpty();
+ * @private
+ * @type {function(ol.Feature, ol.Feature): number|null}
+ this.renderedRenderOrder_ = null;
+ * @private
+ * @type {ol.render.canvas.ReplayGroup}
+ this.replayGroup_ = null;
+ * @private
+ this.context_ = ol.dom.createCanvasContext2D();
+ol.inherits(ol.renderer.canvas.VectorLayer, ol.renderer.canvas.Layer);
+ * @inheritDoc
+ol.renderer.canvas.VectorLayer.prototype.composeFrame = function(frameState, layerState, context) {
+ var extent = frameState.extent;
+ var skippedFeatureUids = layerState.managed ?
+ frameState.skippedFeatureUids : {};
+ var projection = viewState.projection;
+ var rotation = viewState.rotation;
+ var projectionExtent = projection.getExtent();
+ var vectorSource = /** @type {ol.source.Vector} */ (this.getLayer().getSource());
+ var transform = this.getTransform(frameState, 0);
+ this.preCompose(context, frameState, transform);
+ // clipped rendering if layer extent is set
+ var clipExtent = layerState.extent;
+ var clipped = clipExtent !== undefined;
+ if (clipped) {
+ this.clip(context, frameState, /** @type {ol.Extent} */ (clipExtent));
+ var replayGroup = this.replayGroup_;
+ if (replayGroup && !replayGroup.isEmpty()) {
+ var drawOffsetX = 0;
+ var drawOffsetY = 0;
+ var replayContext;
+ if (layer.hasListener(ol.render.EventType.RENDER)) {
+ var drawWidth = context.canvas.width;
+ var drawHeight = context.canvas.height;
+ if (rotation) {
+ var drawSize = Math.round(Math.sqrt(drawWidth * drawWidth + drawHeight * drawHeight));
+ drawOffsetX = (drawSize - drawWidth) / 2;
+ drawOffsetY = (drawSize - drawHeight) / 2;
+ drawWidth = drawHeight = drawSize;
+ // resize and clear
+ this.context_.canvas.width = drawWidth;
+ this.context_.canvas.height = drawHeight;
+ replayContext = this.context_;
+ } else {
+ replayContext = context;
+ // for performance reasons, context.save / context.restore is not used
+ // to save and restore the transformation matrix and the opacity.
+ // see http://jsperf.com/context-save-restore-versus-variable
+ var alpha = replayContext.globalAlpha;
+ replayContext.globalAlpha = layerState.opacity;
+ if (replayContext != context) {
+ replayContext.translate(drawOffsetX, drawOffsetY);
+ ol.render.canvas.rotateAtOffset(replayContext, -rotation,
+ width / 2, height / 2);
+ replayGroup.replay(replayContext, pixelRatio, transform, rotation,
+ skippedFeatureUids);
+ if (vectorSource.getWrapX() && projection.canWrapX() &&
+ !ol.extent.containsExtent(projectionExtent, extent)) {
+ var startX = extent[0];
+ var worldWidth = ol.extent.getWidth(projectionExtent);
+ var world = 0;
+ var offsetX;
+ while (startX < projectionExtent[0]) {
+ --world;
+ offsetX = worldWidth * world;
+ transform = this.getTransform(frameState, offsetX);
+ startX += worldWidth;
+ world = 0;
+ startX = extent[2];
+ while (startX > projectionExtent[2]) {
+ ++world;
+ startX -= worldWidth;
+ // restore original transform for render and compose events
+ transform = this.getTransform(frameState, 0);
+ ol.render.canvas.rotateAtOffset(replayContext, rotation,
+ this.dispatchRenderEvent(replayContext, frameState, transform);
+ context.drawImage(replayContext.canvas, -drawOffsetX, -drawOffsetY);
+ replayContext.translate(-drawOffsetX, -drawOffsetY);
+ replayContext.globalAlpha = alpha;
+ if (clipped) {
+ this.postCompose(context, frameState, layerState, transform);
+ * @inheritDoc
+ol.renderer.canvas.VectorLayer.prototype.forEachFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, callback, thisArg) {
+ if (!this.replayGroup_) {
+ return undefined;
+ } else {
+ var resolution = frameState.viewState.resolution;
+ /** @type {Object.<string, boolean>} */
+ var features = {};
+ return this.replayGroup_.forEachFeatureAtCoordinate(coordinate, resolution,
+ rotation, hitTolerance, {},
+ var key = ol.getUid(feature).toString();
+ if (!(key in features)) {
+ features[key] = true;
+ return callback.call(thisArg, feature, layer);
+ * Handle changes in image style state.
+ * @param {ol.events.Event} event Image style change event.
+ * @private
+ol.renderer.canvas.VectorLayer.prototype.handleStyleImageChange_ = function(event) {
+ * @inheritDoc
+ol.renderer.canvas.VectorLayer.prototype.prepareFrame = function(frameState, layerState) {
+ var vectorLayer = /** @type {ol.layer.Vector} */ (this.getLayer());
+ var vectorSource = vectorLayer.getSource();
+ this.updateAttributions(
+ frameState.attributions, vectorSource.getAttributions());
+ this.updateLogos(frameState, vectorSource);
+ var animating = frameState.viewHints[ol.ViewHint.ANIMATING];
+ var interacting = frameState.viewHints[ol.ViewHint.INTERACTING];
+ var updateWhileAnimating = vectorLayer.getUpdateWhileAnimating();
+ var updateWhileInteracting = vectorLayer.getUpdateWhileInteracting();
+ if (!this.dirty_ && (!updateWhileAnimating && animating) ||
+ (!updateWhileInteracting && interacting)) {
+ return true;
+ var frameStateExtent = frameState.extent;
+ var resolution = viewState.resolution;
+ var vectorLayerRevision = vectorLayer.getRevision();
+ var vectorLayerRenderBuffer = vectorLayer.getRenderBuffer();
+ var vectorLayerRenderOrder = vectorLayer.getRenderOrder();
+ if (vectorLayerRenderOrder === undefined) {
+ vectorLayerRenderOrder = ol.renderer.vector.defaultOrder;
+ var extent = ol.extent.buffer(frameStateExtent,
+ vectorLayerRenderBuffer * resolution);
+ var projectionExtent = viewState.projection.getExtent();
+ if (vectorSource.getWrapX() && viewState.projection.canWrapX() &&
+ !ol.extent.containsExtent(projectionExtent, frameState.extent)) {
+ // For the replay group, we need an extent that intersects the real world
+ // (-180° to +180°). To support geometries in a coordinate range from -540°
+ // to +540°, we add at least 1 world width on each side of the projection
+ // extent. If the viewport is wider than the world, we need to add half of
+ // the viewport width to make sure we cover the whole viewport.
+ var buffer = Math.max(ol.extent.getWidth(extent) / 2, worldWidth);
+ extent[0] = projectionExtent[0] - buffer;
+ extent[2] = projectionExtent[2] + buffer;
+ this.renderedResolution_ == resolution &&
+ this.renderedRevision_ == vectorLayerRevision &&
+ this.renderedRenderOrder_ == vectorLayerRenderOrder &&
+ ol.extent.containsExtent(this.renderedExtent_, extent)) {
+ return true;
+ var replayGroup =
+ new ol.render.canvas.ReplayGroup(
+ ol.renderer.vector.getTolerance(resolution, pixelRatio), extent,
+ resolution, vectorSource.getOverlaps(), vectorLayer.getRenderBuffer());
+ vectorSource.loadFeatures(extent, resolution, projection);
+ * @this {ol.renderer.canvas.VectorLayer}
+ var renderFeature = function(feature) {
+ var styles;
+ var styleFunction = feature.getStyleFunction();
+ if (styleFunction) {
+ styles = styleFunction.call(feature, resolution);
+ } else {
+ styleFunction = vectorLayer.getStyleFunction();
+ styles = styleFunction(feature, resolution);
+ if (styles) {
+ var dirty = this.renderFeature(
+ feature, resolution, pixelRatio, styles, replayGroup);
+ this.dirty_ = this.dirty_ || dirty;
+ if (vectorLayerRenderOrder) {
+ /** @type {Array.<ol.Feature>} */
+ var features = [];
+ vectorSource.forEachFeatureInExtent(extent,
+ features.push(feature);
+ }, this);
+ features.sort(vectorLayerRenderOrder);
+ features.forEach(renderFeature, this);
+ } else {
+ vectorSource.forEachFeatureInExtent(extent, renderFeature, this);
+ replayGroup.finish();
+ this.renderedResolution_ = resolution;
+ this.renderedRevision_ = vectorLayerRevision;
+ this.renderedRenderOrder_ = vectorLayerRenderOrder;
+ this.renderedExtent_ = extent;
+ this.replayGroup_ = replayGroup;
+ return true;
+ * @param {(ol.style.Style|Array.<ol.style.Style>)} styles The style or array of
+ * styles.
+ * @param {ol.render.canvas.ReplayGroup} replayGroup Replay group.
+ * @return {boolean} `true` if an image is loading.
+ol.renderer.canvas.VectorLayer.prototype.renderFeature = function(feature, resolution, pixelRatio, styles, replayGroup) {
+ if (!styles) {
+ return false;
+ if (Array.isArray(styles)) {
+ for (var i = 0, ii = styles.length; i < ii; ++i) {
+ loading = ol.renderer.vector.renderFeature(
+ replayGroup, feature, styles[i],
+ ol.renderer.vector.getSquaredTolerance(resolution, pixelRatio),
+ this.handleStyleImageChange_, this) || loading;
+ } else {
+ replayGroup, feature, styles,
+ return loading;
+// This file is automatically generated, do not edit
+goog.provide('ol.renderer.webgl.defaultmapshader');
+goog.require('ol.webgl.Fragment');
+goog.require('ol.webgl.Vertex');
+if (ol.ENABLE_WEBGL) {
+ * @constructor
+ * @extends {ol.webgl.Fragment}
+ * @struct
+ ol.renderer.webgl.defaultmapshader.Fragment = function() {
+ ol.webgl.Fragment.call(this, ol.renderer.webgl.defaultmapshader.Fragment.SOURCE);
+ ol.inherits(ol.renderer.webgl.defaultmapshader.Fragment, ol.webgl.Fragment);
+ * @const
+ * @type {string}
+ ol.renderer.webgl.defaultmapshader.Fragment.DEBUG_SOURCE = 'precision mediump float;\nvarying vec2 v_texCoord;\n\n\nuniform float u_opacity;\nuniform sampler2D u_texture;\n\nvoid main(void) {\n vec4 texColor = texture2D(u_texture, v_texCoord);\n gl_FragColor.rgb = texColor.rgb;\n gl_FragColor.a = texColor.a * u_opacity;\n}\n';
+ * @const
+ * @type {string}
+ ol.renderer.webgl.defaultmapshader.Fragment.OPTIMIZED_SOURCE = 'precision mediump float;varying vec2 a;uniform float f;uniform sampler2D g;void main(void){vec4 texColor=texture2D(g,a);gl_FragColor.rgb=texColor.rgb;gl_FragColor.a=texColor.a*f;}';
+ * @const
+ * @type {string}
+ ol.renderer.webgl.defaultmapshader.Fragment.SOURCE = ol.DEBUG_WEBGL ?
+ ol.renderer.webgl.defaultmapshader.Fragment.DEBUG_SOURCE :
+ ol.renderer.webgl.defaultmapshader.Fragment.OPTIMIZED_SOURCE;
+ ol.renderer.webgl.defaultmapshader.fragment = new ol.renderer.webgl.defaultmapshader.Fragment();
+ * @constructor
+ * @extends {ol.webgl.Vertex}
+ * @struct
+ ol.renderer.webgl.defaultmapshader.Vertex = function() {
+ ol.webgl.Vertex.call(this, ol.renderer.webgl.defaultmapshader.Vertex.SOURCE);
+ ol.inherits(ol.renderer.webgl.defaultmapshader.Vertex, ol.webgl.Vertex);
+ * @const
+ * @type {string}
+ ol.renderer.webgl.defaultmapshader.Vertex.DEBUG_SOURCE = 'varying vec2 v_texCoord;\n\n\nattribute vec2 a_position;\nattribute vec2 a_texCoord;\n\nuniform mat4 u_texCoordMatrix;\nuniform mat4 u_projectionMatrix;\n\nvoid main(void) {\n gl_Position = u_projectionMatrix * vec4(a_position, 0., 1.);\n v_texCoord = (u_texCoordMatrix * vec4(a_texCoord, 0., 1.)).st;\n}\n\n\n';
+ * @const
+ * @type {string}
+ ol.renderer.webgl.defaultmapshader.Vertex.OPTIMIZED_SOURCE = 'varying vec2 a;attribute vec2 b;attribute vec2 c;uniform mat4 d;uniform mat4 e;void main(void){gl_Position=e*vec4(b,0.,1.);a=(d*vec4(c,0.,1.)).st;}';
+ * @const
+ * @type {string}
+ ol.renderer.webgl.defaultmapshader.Vertex.SOURCE = ol.DEBUG_WEBGL ?
+ ol.renderer.webgl.defaultmapshader.Vertex.DEBUG_SOURCE :
+ ol.renderer.webgl.defaultmapshader.Vertex.OPTIMIZED_SOURCE;
+ ol.renderer.webgl.defaultmapshader.vertex = new ol.renderer.webgl.defaultmapshader.Vertex();
+ * @constructor
+ * @param {WebGLRenderingContext} gl GL.
+ * @param {WebGLProgram} program Program.
+ * @struct
+ ol.renderer.webgl.defaultmapshader.Locations = function(gl, program) {
+ * @type {WebGLUniformLocation}
+ this.u_opacity = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_opacity' : 'f');
+ this.u_projectionMatrix = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_projectionMatrix' : 'e');
+ this.u_texCoordMatrix = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_texCoordMatrix' : 'd');
+ this.u_texture = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_texture' : 'g');
+ * @type {number}
+ this.a_position = gl.getAttribLocation(
+ program, ol.DEBUG_WEBGL ? 'a_position' : 'b');
+ * @type {number}
+ this.a_texCoord = gl.getAttribLocation(
+ program, ol.DEBUG_WEBGL ? 'a_texCoord' : 'c');
+goog.provide('ol.renderer.webgl.Layer');
+goog.require('ol.render.webgl.Immediate');
+goog.require('ol.renderer.webgl.defaultmapshader');
+goog.require('ol.transform');
+goog.require('ol.vec.Mat4');
+goog.require('ol.webgl');
+goog.require('ol.webgl.Buffer');
+goog.require('ol.webgl.Context');
+ * @constructor
+ * @abstract
+ * @param {ol.renderer.webgl.Map} mapRenderer Map renderer.
+ ol.renderer.webgl.Layer = function(mapRenderer, layer) {
+ * @protected
+ * @type {ol.renderer.webgl.Map}
+ this.mapRenderer = mapRenderer;
+ * @private
+ * @type {ol.webgl.Buffer}
+ this.arrayBuffer_ = new ol.webgl.Buffer([
+ -1, -1, 0, 0,
+ 1, -1, 1, 0,
+ -1, 1, 0, 1,
+ 1, 1, 1, 1
+ * @protected
+ * @type {WebGLTexture}
+ this.texture = null;
+ * @protected
+ * @type {WebGLFramebuffer}
+ this.framebuffer = null;
+ * @protected
+ * @type {number|undefined}
+ this.framebufferDimension = undefined;
+ * @protected
+ this.texCoordMatrix = ol.transform.create();
+ * @protected
+ this.projectionMatrix = ol.transform.create();
+ * @type {Array.<number>}
+ * @private
+ this.tmpMat4_ = ol.vec.Mat4.create();
+ * @private
+ * @type {ol.renderer.webgl.defaultmapshader.Locations}
+ this.defaultLocations_ = null;
+ ol.inherits(ol.renderer.webgl.Layer, ol.renderer.Layer);
+ * @param {number} framebufferDimension Framebuffer dimension.
+ * @protected
+ ol.renderer.webgl.Layer.prototype.bindFramebuffer = function(frameState, framebufferDimension) {
+ var gl = this.mapRenderer.getGL();
+ if (this.framebufferDimension === undefined ||
+ this.framebufferDimension != framebufferDimension) {
+ * @param {WebGLFramebuffer} framebuffer Framebuffer.
+ * @param {WebGLTexture} texture Texture.
+ var postRenderFunction = function(gl, framebuffer, texture) {
+ if (!gl.isContextLost()) {
+ gl.deleteFramebuffer(framebuffer);
+ gl.deleteTexture(texture);
+ }.bind(null, gl, this.framebuffer, this.texture);
+ var texture = ol.webgl.Context.createEmptyTexture(
+ gl, framebufferDimension, framebufferDimension);
+ var framebuffer = gl.createFramebuffer();
+ gl.bindFramebuffer(ol.webgl.FRAMEBUFFER, framebuffer);
+ gl.framebufferTexture2D(ol.webgl.FRAMEBUFFER,
+ ol.webgl.COLOR_ATTACHMENT0, ol.webgl.TEXTURE_2D, texture, 0);
+ this.texture = texture;
+ this.framebuffer = framebuffer;
+ this.framebufferDimension = framebufferDimension;
+ } else {
+ gl.bindFramebuffer(ol.webgl.FRAMEBUFFER, this.framebuffer);
+ * @param {ol.webgl.Context} context Context.
+ ol.renderer.webgl.Layer.prototype.composeFrame = function(frameState, layerState, context) {
+ ol.render.EventType.PRECOMPOSE, context, frameState);
+ context.bindBuffer(ol.webgl.ARRAY_BUFFER, this.arrayBuffer_);
+ var gl = context.getGL();
+ var fragmentShader = ol.renderer.webgl.defaultmapshader.fragment;
+ var vertexShader = ol.renderer.webgl.defaultmapshader.vertex;
+ var program = context.getProgram(fragmentShader, vertexShader);
+ var locations;
+ if (!this.defaultLocations_) {
+ locations =
+ new ol.renderer.webgl.defaultmapshader.Locations(gl, program);
+ this.defaultLocations_ = locations;
+ } else {
+ locations = this.defaultLocations_;
+ if (context.useProgram(program)) {
+ gl.enableVertexAttribArray(locations.a_position);
+ gl.vertexAttribPointer(
+ locations.a_position, 2, ol.webgl.FLOAT, false, 16, 0);
+ gl.enableVertexAttribArray(locations.a_texCoord);
+ locations.a_texCoord, 2, ol.webgl.FLOAT, false, 16, 8);
+ gl.uniform1i(locations.u_texture, 0);
+ gl.uniformMatrix4fv(locations.u_texCoordMatrix, false,
+ ol.vec.Mat4.fromTransform(this.tmpMat4_, this.getTexCoordMatrix()));
+ gl.uniformMatrix4fv(locations.u_projectionMatrix, false,
+ ol.vec.Mat4.fromTransform(this.tmpMat4_, this.getProjectionMatrix()));
+ gl.uniform1f(locations.u_opacity, layerState.opacity);
+ gl.bindTexture(ol.webgl.TEXTURE_2D, this.getTexture());
+ gl.drawArrays(ol.webgl.TRIANGLE_STRIP, 0, 4);
+ ol.render.EventType.POSTCOMPOSE, context, frameState);
+ * @param {ol.webgl.Context} context WebGL context.
+ * @private
+ ol.renderer.webgl.Layer.prototype.dispatchComposeEvent_ = function(type, context, frameState) {
+ var center = viewState.center;
+ var size = frameState.size;
+ var render = new ol.render.webgl.Immediate(
+ context, center, resolution, rotation, size, extent, pixelRatio);
+ type, render, frameState, null, context);
+ * @return {!ol.Transform} Matrix.
+ ol.renderer.webgl.Layer.prototype.getTexCoordMatrix = function() {
+ return this.texCoordMatrix;
+ * @return {WebGLTexture} Texture.
+ ol.renderer.webgl.Layer.prototype.getTexture = function() {
+ return this.texture;
+ ol.renderer.webgl.Layer.prototype.getProjectionMatrix = function() {
+ return this.projectionMatrix;
+ * Handle webglcontextlost.
+ ol.renderer.webgl.Layer.prototype.handleWebGLContextLost = function() {
+ * @abstract
+ ol.renderer.webgl.Layer.prototype.prepareFrame = function(frameState, layerState, context) {};
+ * @abstract
+ * @param {ol.Pixel} pixel Pixel.
+ * callback.
+ * @return {T|undefined} Callback result.
+ * @template S,T,U
+ ol.renderer.webgl.Layer.prototype.forEachLayerAtPixel = function(pixel, frameState, callback, thisArg) {};
+goog.provide('ol.renderer.webgl.VectorLayer');
+goog.require('ol.extent');
+goog.require('ol.render.webgl.ReplayGroup');
+goog.require('ol.renderer.webgl.Layer');
+ * @constructor
+ * @extends {ol.renderer.webgl.Layer}
+ ol.renderer.webgl.VectorLayer = function(mapRenderer, vectorLayer) {
+ ol.renderer.webgl.Layer.call(this, mapRenderer, vectorLayer);
+ * @private
+ * @type {boolean}
+ * @private
+ * @type {number}
+ * @private
+ * @type {number}
+ * @private
+ * @private
+ * @private
+ * @type {ol.render.webgl.ReplayGroup}
+ * The last layer state.
+ * @private
+ * @type {?ol.LayerState}
+ this.layerState_ = null;
+ ol.inherits(ol.renderer.webgl.VectorLayer, ol.renderer.webgl.Layer);
+ * @inheritDoc
+ ol.renderer.webgl.VectorLayer.prototype.composeFrame = function(frameState, layerState, context) {
+ this.layerState_ = layerState;
+ gl.enable(gl.SCISSOR_TEST);
+ gl.scissor(0, 0, size[0] * pixelRatio, size[1] * pixelRatio);
+ replayGroup.replay(context,
+ viewState.center, viewState.resolution, viewState.rotation,
+ size, pixelRatio, layerState.opacity,
+ layerState.managed ? frameState.skippedFeatureUids : {});
+ gl.disable(gl.SCISSOR_TEST);
+ * @inheritDoc
+ ol.renderer.webgl.VectorLayer.prototype.disposeInternal = function() {
+ if (replayGroup) {
+ var context = this.mapRenderer.getContext();
+ replayGroup.getDeleteResourcesFunction(context)();
+ ol.renderer.webgl.Layer.prototype.disposeInternal.call(this);
+ * @inheritDoc
+ ol.renderer.webgl.VectorLayer.prototype.forEachFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, callback, thisArg) {
+ if (!this.replayGroup_ || !this.layerState_) {
+ return undefined;
+ } else {
+ var layerState = this.layerState_;
+ context, viewState.center, viewState.resolution, viewState.rotation,
+ frameState.size, frameState.pixelRatio, layerState.opacity,
+ * @inheritDoc
+ ol.renderer.webgl.VectorLayer.prototype.hasFeatureAtCoordinate = function(coordinate, frameState) {
+ return false;
+ } else {
+ return this.replayGroup_.hasFeatureAtCoordinate(coordinate,
+ frameState.skippedFeatureUids);
+ * @inheritDoc
+ ol.renderer.webgl.VectorLayer.prototype.forEachLayerAtPixel = function(pixel, frameState, callback, thisArg) {
+ var coordinate = ol.transform.apply(
+ frameState.pixelToCoordinateTransform, pixel.slice());
+ var hasFeature = this.hasFeatureAtCoordinate(coordinate, frameState);
+ if (hasFeature) {
+ } else {
+ return undefined;
+ * @private
+ ol.renderer.webgl.VectorLayer.prototype.handleStyleImageChange_ = function(event) {
+ * @inheritDoc
+ ol.renderer.webgl.VectorLayer.prototype.prepareFrame = function(frameState, layerState, context) {
+ return true;
+ return true;
+ if (this.replayGroup_) {
+ this.replayGroup_.getDeleteResourcesFunction(context));
+ var replayGroup = new ol.render.webgl.ReplayGroup(
+ extent, vectorLayer.getRenderBuffer());
+ * @this {ol.renderer.webgl.VectorLayer}
+ var styles;
+ } else {
+ if (styles) {
+ }, this);
+ } else {
+ replayGroup.finish(context);
+ return true;
+ * styles.
+ * @param {ol.render.webgl.ReplayGroup} replayGroup Replay group.
+ ol.renderer.webgl.VectorLayer.prototype.renderFeature = function(feature, resolution, pixelRatio, styles, replayGroup) {
+ if (!styles) {
+ return false;
+ for (var i = styles.length - 1, ii = 0; i >= ii; --i) {
+ } else {
+ return loading;
+goog.provide('ol.layer.Vector');
+goog.require('ol.layer.Layer');
+goog.require('ol.obj');
+goog.require('ol.renderer.Type');
+goog.require('ol.renderer.canvas.VectorLayer');
+goog.require('ol.renderer.webgl.VectorLayer');
+goog.require('ol.style.Style');
+ * @classdesc
+ * Vector data that is rendered client-side.
+ * Note that any property set in the options is set as a {@link ol.Object}
+ * property on the layer object; for example, setting `title: 'My Title'` in the
+ * options means that `title` is observable, and has get/set accessors.
+ * @constructor
+ * @extends {ol.layer.Layer}
+ * @fires ol.render.Event
+ * @param {olx.layer.VectorOptions=} opt_options Options.
+ * @api
+ol.layer.Vector = function(opt_options) {
+ var options = opt_options ?
+ opt_options : /** @type {olx.layer.VectorOptions} */ ({});
+ var baseOptions = ol.obj.assign({}, options);
+ delete baseOptions.style;
+ delete baseOptions.renderBuffer;
+ delete baseOptions.updateWhileAnimating;
+ delete baseOptions.updateWhileInteracting;
+ ol.layer.Layer.call(this, /** @type {olx.layer.LayerOptions} */ (baseOptions));
+ * @type {number}
+ * @private
+ this.renderBuffer_ = options.renderBuffer !== undefined ?
+ options.renderBuffer : 100;
+ * User provided style.
+ * @type {ol.style.Style|Array.<ol.style.Style>|ol.StyleFunction}
+ * @private
+ this.style_ = null;
+ * Style function for use within the library.
+ * @type {ol.StyleFunction|undefined}
+ * @private
+ this.styleFunction_ = undefined;
+ this.setStyle(options.style);
+ * @type {boolean}
+ * @private
+ this.updateWhileAnimating_ = options.updateWhileAnimating !== undefined ?
+ options.updateWhileAnimating : false;
+ * @type {boolean}
+ * @private
+ this.updateWhileInteracting_ = options.updateWhileInteracting !== undefined ?
+ options.updateWhileInteracting : false;
+ol.inherits(ol.layer.Vector, ol.layer.Layer);
+ * @inheritDoc
+ol.layer.Vector.prototype.createRenderer = function(mapRenderer) {
+ var renderer = null;
+ var type = mapRenderer.getType();
+ if (ol.ENABLE_CANVAS && type === ol.renderer.Type.CANVAS) {
+ renderer = new ol.renderer.canvas.VectorLayer(this);
+ } else if (ol.ENABLE_WEBGL && type === ol.renderer.Type.WEBGL) {
+ renderer = new ol.renderer.webgl.VectorLayer(/** @type {ol.renderer.webgl.Map} */ (mapRenderer), this);
+ return renderer;
+ * @return {number|undefined} Render buffer.
+ol.layer.Vector.prototype.getRenderBuffer = function() {
+ return this.renderBuffer_;
+ * @return {function(ol.Feature, ol.Feature): number|null|undefined} Render
+ * order.
+ol.layer.Vector.prototype.getRenderOrder = function() {
+ return /** @type {ol.RenderOrderFunction|null|undefined} */ (
+ this.get(ol.layer.Vector.Property_.RENDER_ORDER));
+ * Return the associated {@link ol.source.Vector vectorsource} of the layer.
+ * @function
+ * @return {ol.source.Vector} Source.
+ * @api
+ol.layer.Vector.prototype.getSource;
+ * Get the style for features. This returns whatever was passed to the `style`
+ * option at construction or to the `setStyle` method.
+ * @return {ol.style.Style|Array.<ol.style.Style>|ol.StyleFunction}
+ * Layer style.
+ * @api
+ol.layer.Vector.prototype.getStyle = function() {
+ return this.style_;
+ * Get the style function.
+ * @return {ol.StyleFunction|undefined} Layer style function.
+ * @api
+ol.layer.Vector.prototype.getStyleFunction = function() {
+ return this.styleFunction_;
+ * @return {boolean} Whether the rendered layer should be updated while
+ * animating.
+ol.layer.Vector.prototype.getUpdateWhileAnimating = function() {
+ return this.updateWhileAnimating_;
+ * interacting.
+ol.layer.Vector.prototype.getUpdateWhileInteracting = function() {
+ return this.updateWhileInteracting_;
+ * @param {ol.RenderOrderFunction|null|undefined} renderOrder
+ * Render order.
+ol.layer.Vector.prototype.setRenderOrder = function(renderOrder) {
+ this.set(ol.layer.Vector.Property_.RENDER_ORDER, renderOrder);
+ * Set the style for features. This can be a single style object, an array
+ * of styles, or a function that takes a feature and resolution and returns
+ * an array of styles. If it is `undefined` the default style is used. If
+ * it is `null` the layer has no style (a `null` style), so only features
+ * that have their own styles will be rendered in the layer. See
+ * {@link ol.style} for information on the default style.
+ * @param {ol.style.Style|Array.<ol.style.Style>|ol.StyleFunction|null|undefined}
+ * style Layer style.
+ * @api
+ol.layer.Vector.prototype.setStyle = function(style) {
+ this.style_ = style !== undefined ? style : ol.style.Style.defaultFunction;
+ this.styleFunction_ = style === null ?
+ undefined : ol.style.Style.createFunction(this.style_);
+ this.changed();
+ * @enum {string}
+ * @private
+ol.layer.Vector.Property_ = {
+ RENDER_ORDER: 'renderOrder'
+goog.provide('ol.loadingstrategy');
+ * Strategy function for loading all features with a single request.
+ * @return {Array.<ol.Extent>} Extents.
+ * @api
+ol.loadingstrategy.all = function(extent, resolution) {
+ return [[-Infinity, -Infinity, Infinity, Infinity]];
+ * Strategy function for loading features based on the view's extent and
+ * resolution.
+ * @api
+ol.loadingstrategy.bbox = function(extent, resolution) {
+ return [extent];
+ * Creates a strategy function for loading features based on a tile grid.
+ * @return {function(ol.Extent, number): Array.<ol.Extent>} Loading strategy.
+ * @api
+ol.loadingstrategy.tile = function(tileGrid) {
+ return (
+ function(extent, resolution) {
+ var z = tileGrid.getZForResolution(resolution);
+ var tileRange = tileGrid.getTileRangeForExtentAndZ(extent, z);
+ /** @type {Array.<ol.Extent>} */
+ var extents = [];
+ /** @type {ol.TileCoord} */
+ var tileCoord = [z, 0, 0];
+ for (tileCoord[1] = tileRange.minX; tileCoord[1] <= tileRange.maxX;
+ ++tileCoord[1]) {
+ for (tileCoord[2] = tileRange.minY; tileCoord[2] <= tileRange.maxY;
+ ++tileCoord[2]) {
+ extents.push(tileGrid.getTileCoordExtent(tileCoord));
+ return extents;
+goog.provide('ol.source.Source');
+goog.require('ol.Attribution');
+goog.require('ol.Object');
+goog.require('ol.proj');
+ * @classdesc
+ * Abstract base class; normally only used for creating subclasses and not
+ * instantiated in apps.
+ * Base class for {@link ol.layer.Layer} sources.
+ * A generic `change` event is triggered when the state of the source changes.
+ * @constructor
+ * @abstract
+ * @extends {ol.Object}
+ * @param {ol.SourceSourceOptions} options Source options.
+ * @api
+ol.source.Source = function(options) {
+ ol.Object.call(this);
+ * @private
+ * @type {ol.proj.Projection}
+ this.projection_ = ol.proj.get(options.projection);
+ * @private
+ * @type {Array.<ol.Attribution>}
+ this.attributions_ = ol.source.Source.toAttributionsArray_(options.attributions);
+ * @private
+ * @type {string|olx.LogoOptions|undefined}
+ this.logo_ = options.logo;
+ * @private
+ * @type {ol.source.State}
+ this.state_ = options.state !== undefined ?
+ options.state : ol.source.State.READY;
+ * @private
+ * @type {boolean}
+ this.wrapX_ = options.wrapX !== undefined ? options.wrapX : false;
+ol.inherits(ol.source.Source, ol.Object);
+ * Turns various ways of defining an attribution to an array of `ol.Attributions`.
+ * @param {ol.AttributionLike|undefined}
+ * attributionLike The attributions as string, array of strings,
+ * `ol.Attribution`, array of `ol.Attribution` or undefined.
+ * @return {Array.<ol.Attribution>} The array of `ol.Attribution` or null if
+ * `undefined` was given.
+ol.source.Source.toAttributionsArray_ = function(attributionLike) {
+ if (typeof attributionLike === 'string') {
+ return [new ol.Attribution({html: attributionLike})];
+ } else if (attributionLike instanceof ol.Attribution) {
+ return [attributionLike];
+ } else if (Array.isArray(attributionLike)) {
+ var len = attributionLike.length;
+ var attributions = new Array(len);
+ for (var i = 0; i < len; i++) {
+ var item = attributionLike[i];
+ if (typeof item === 'string') {
+ attributions[i] = new ol.Attribution({html: item});
+ } else {
+ attributions[i] = item;
+ return attributions;
+ } else {
+ return null;
+ * @param {number} rotation Rotation.
+ * @param {Object.<string, boolean>} skippedFeatureUids Skipped feature uids.
+ * callback.
+ * @template T
+ol.source.Source.prototype.forEachFeatureAtCoordinate = ol.nullFunction;
+ * Get the attributions of the source.
+ * @return {Array.<ol.Attribution>} Attributions.
+ * @api
+ol.source.Source.prototype.getAttributions = function() {
+ return this.attributions_;
+ * Get the logo of the source.
+ * @return {string|olx.LogoOptions|undefined} Logo.
+ * @api
+ol.source.Source.prototype.getLogo = function() {
+ return this.logo_;
+ * Get the projection of the source.
+ * @return {ol.proj.Projection} Projection.
+ * @api
+ol.source.Source.prototype.getProjection = function() {
+ return this.projection_;
+ * @abstract
+ * @return {Array.<number>|undefined} Resolutions.
+ol.source.Source.prototype.getResolutions = function() {};
+ * Get the state of the source, see {@link ol.source.State} for possible states.
+ * @return {ol.source.State} State.
+ * @api
+ol.source.Source.prototype.getState = function() {
+ return this.state_;
+ * @return {boolean|undefined} Wrap X.
+ol.source.Source.prototype.getWrapX = function() {
+ return this.wrapX_;
+ * Refreshes the source and finally dispatches a 'change' event.
+ * @api
+ol.source.Source.prototype.refresh = function() {
+ this.changed();
+ * Set the attributions of the source.
+ * @param {ol.AttributionLike|undefined} attributions Attributions.
+ * Can be passed as `string`, `Array<string>`, `{@link ol.Attribution}`,
+ * `Array<{@link ol.Attribution}>` or `undefined`.
+ * @api
+ol.source.Source.prototype.setAttributions = function(attributions) {
+ this.attributions_ = ol.source.Source.toAttributionsArray_(attributions);
+ this.changed();
+ * Set the logo of the source.
+ * @param {string|olx.LogoOptions|undefined} logo Logo.
+ol.source.Source.prototype.setLogo = function(logo) {
+ this.logo_ = logo;
+ * Set the state of the source.
+ * @param {ol.source.State} state State.
+ * @protected
+ol.source.Source.prototype.setState = function(state) {
+ this.state_ = state;
+ this.changed();
+goog.provide('ol.source.VectorEventType');
+ * @enum {string}
+ol.source.VectorEventType = {
+ * Triggered when a feature is added to the source.
+ * @event ol.source.Vector.Event#addfeature
+ * @api
+ ADDFEATURE: 'addfeature',
+ * Triggered when a feature is updated.
+ * @event ol.source.Vector.Event#changefeature
+ * @api
+ CHANGEFEATURE: 'changefeature',
+ * Triggered when the clear method is called on the source.
+ * @event ol.source.Vector.Event#clear
+ * @api
+ CLEAR: 'clear',
+ * Triggered when a feature is removed from the source.
+ * See {@link ol.source.Vector#clear source.clear()} for exceptions.
+ * @event ol.source.Vector.Event#removefeature
+ * @api
+ REMOVEFEATURE: 'removefeature'
+// FIXME bulk feature upload - suppress events
+// FIXME make change-detection more refined (notably, geometry hint)
+goog.provide('ol.source.Vector');
+goog.require('ol.Collection');
+goog.require('ol.CollectionEventType');
+goog.require('ol.ObjectEventType');
+goog.require('ol.array');
+goog.require('ol.events.Event');
+goog.require('ol.featureloader');
+goog.require('ol.loadingstrategy');
+goog.require('ol.source.Source');
+goog.require('ol.source.VectorEventType');
+goog.require('ol.structs.RBush');
+ * @classdesc
+ * Provides a source of features for vector layers. Vector features provided
+ * by this source are suitable for editing. See {@link ol.source.VectorTile} for
+ * vector data that is optimized for rendering.
+ * @constructor
+ * @extends {ol.source.Source}
+ * @fires ol.source.Vector.Event
+ * @param {olx.source.VectorOptions=} opt_options Vector source options.
+ * @api
+ol.source.Vector = function(opt_options) {
+ var options = opt_options || {};
+ ol.source.Source.call(this, {
+ attributions: options.attributions,
+ logo: options.logo,
+ projection: undefined,
+ state: ol.source.State.READY,
+ wrapX: options.wrapX !== undefined ? options.wrapX : true
+ * @private
+ * @type {ol.FeatureLoader}
+ this.loader_ = ol.nullFunction;
+ * @private
+ * @type {ol.format.Feature|undefined}
+ this.format_ = options.format;
+ * @private
+ * @type {boolean}
+ this.overlaps_ = options.overlaps == undefined ? true : options.overlaps;
+ * @private
+ * @type {string|ol.FeatureUrlFunction|undefined}
+ this.url_ = options.url;
+ if (options.loader !== undefined) {
+ this.loader_ = options.loader;
+ } else if (this.url_ !== undefined) {
+ ol.asserts.assert(this.format_, 7); // `format` must be set when `url` is set
+ // create a XHR feature loader for "url" and "format"
+ this.loader_ = ol.featureloader.xhr(this.url_, /** @type {ol.format.Feature} */ (this.format_));
+ * @private
+ * @type {ol.LoadingStrategy}
+ this.strategy_ = options.strategy !== undefined ? options.strategy :
+ ol.loadingstrategy.all;
+ var useSpatialIndex =
+ options.useSpatialIndex !== undefined ? options.useSpatialIndex : true;
+ * @private
+ * @type {ol.structs.RBush.<ol.Feature>}
+ this.featuresRtree_ = useSpatialIndex ? new ol.structs.RBush() : null;
+ * @private
+ * @type {ol.structs.RBush.<{extent: ol.Extent}>}
+ this.loadedExtentsRtree_ = new ol.structs.RBush();
+ * @private
+ * @type {Object.<string, ol.Feature>}
+ this.nullGeometryFeatures_ = {};
+ * A lookup of features by id (the return from feature.getId()).
+ * @private
+ this.idIndex_ = {};
+ * A lookup of features without id (keyed by ol.getUid(feature)).
+ * @private
+ this.undefIdIndex_ = {};
+ * @private
+ * @type {Object.<string, Array.<ol.EventsKey>>}
+ this.featureChangeKeys_ = {};
+ * @private
+ * @type {ol.Collection.<ol.Feature>}
+ this.featuresCollection_ = null;
+ var collection, features;
+ if (options.features instanceof ol.Collection) {
+ collection = options.features;
+ features = collection.getArray();
+ } else if (Array.isArray(options.features)) {
+ features = options.features;
+ if (!useSpatialIndex && collection === undefined) {
+ collection = new ol.Collection(features);
+ if (features !== undefined) {
+ this.addFeaturesInternal(features);
+ if (collection !== undefined) {
+ this.bindFeaturesCollection_(collection);
+ol.inherits(ol.source.Vector, ol.source.Source);
+ * Add a single feature to the source. If you want to add a batch of features
+ * at once, call {@link ol.source.Vector#addFeatures source.addFeatures()}
+ * instead.
+ * @param {ol.Feature} feature Feature to add.
+ * @api
+ol.source.Vector.prototype.addFeature = function(feature) {
+ this.addFeatureInternal(feature);
+ this.changed();
+ * Add a feature without firing a `change` event.
+ * @protected
+ol.source.Vector.prototype.addFeatureInternal = function(feature) {
+ var featureKey = ol.getUid(feature).toString();
+ if (!this.addToIndex_(featureKey, feature)) {
+ return;
+ this.setupChangeEvents_(featureKey, feature);
+ var geometry = feature.getGeometry();
+ if (geometry) {
+ var extent = geometry.getExtent();
+ if (this.featuresRtree_) {
+ this.featuresRtree_.insert(extent, feature);
+ } else {
+ this.nullGeometryFeatures_[featureKey] = feature;
+ this.dispatchEvent(
+ new ol.source.Vector.Event(ol.source.VectorEventType.ADDFEATURE, feature));
+ * @param {string} featureKey Unique identifier for the feature.
+ * @param {ol.Feature} feature The feature.
+ * @private
+ol.source.Vector.prototype.setupChangeEvents_ = function(featureKey, feature) {
+ this.featureChangeKeys_[featureKey] = [
+ ol.events.listen(feature, ol.events.EventType.CHANGE,
+ this.handleFeatureChange_, this),
+ ol.events.listen(feature, ol.ObjectEventType.PROPERTYCHANGE,
+ * @return {boolean} The feature is "valid", in the sense that it is also a
+ * candidate for insertion into the Rtree.
+ * @private
+ol.source.Vector.prototype.addToIndex_ = function(featureKey, feature) {
+ var valid = true;
+ var id = feature.getId();
+ if (id !== undefined) {
+ if (!(id.toString() in this.idIndex_)) {
+ this.idIndex_[id.toString()] = feature;
+ } else {
+ valid = false;
+ } else {
+ ol.asserts.assert(!(featureKey in this.undefIdIndex_),
+ 30); // The passed `feature` was already added to the source
+ this.undefIdIndex_[featureKey] = feature;
+ return valid;
+ * Add a batch of features to the source.
+ * @param {Array.<ol.Feature>} features Features to add.
+ * @api
+ol.source.Vector.prototype.addFeatures = function(features) {
+ this.changed();
+ * Add features without firing a `change` event.
+ * @param {Array.<ol.Feature>} features Features.
+ * @protected
+ol.source.Vector.prototype.addFeaturesInternal = function(features) {
+ var featureKey, i, length, feature;
+ var extents = [];
+ var newFeatures = [];
+ var geometryFeatures = [];
+ for (i = 0, length = features.length; i < length; i++) {
+ feature = features[i];
+ featureKey = ol.getUid(feature).toString();
+ if (this.addToIndex_(featureKey, feature)) {
+ newFeatures.push(feature);
+ for (i = 0, length = newFeatures.length; i < length; i++) {
+ feature = newFeatures[i];
+ if (geometry) {
+ extents.push(extent);
+ geometryFeatures.push(feature);
+ } else {
+ this.featuresRtree_.load(extents, geometryFeatures);
+ this.dispatchEvent(new ol.source.Vector.Event(
+ ol.source.VectorEventType.ADDFEATURE, newFeatures[i]));
+ * @param {!ol.Collection.<ol.Feature>} collection Collection.
+ * @private
+ol.source.Vector.prototype.bindFeaturesCollection_ = function(collection) {
+ var modifyingCollection = false;
+ ol.events.listen(this, ol.source.VectorEventType.ADDFEATURE,
+ function(evt) {
+ if (!modifyingCollection) {
+ modifyingCollection = true;
+ collection.push(evt.feature);
+ modifyingCollection = false;
+ ol.events.listen(this, ol.source.VectorEventType.REMOVEFEATURE,
+ function(evt) {
+ collection.remove(evt.feature);
+ ol.events.listen(collection, ol.CollectionEventType.ADD,
+ function(evt) {
+ this.addFeature(/** @type {ol.Feature} */ (evt.element));
+ }, this);
+ ol.events.listen(collection, ol.CollectionEventType.REMOVE,
+ function(evt) {
+ this.removeFeature(/** @type {ol.Feature} */ (evt.element));
+ }, this);
+ this.featuresCollection_ = collection;
+ * Remove all features from the source.
+ * @param {boolean=} opt_fast Skip dispatching of {@link removefeature} events.
+ * @api
+ol.source.Vector.prototype.clear = function(opt_fast) {
+ if (opt_fast) {
+ for (var featureId in this.featureChangeKeys_) {
+ var keys = this.featureChangeKeys_[featureId];
+ keys.forEach(ol.events.unlistenByKey);
+ if (!this.featuresCollection_) {
+ } else {
+ this.featuresRtree_.forEach(this.removeFeatureInternal, this);
+ for (var id in this.nullGeometryFeatures_) {
+ this.removeFeatureInternal(this.nullGeometryFeatures_[id]);
+ if (this.featuresCollection_) {
+ this.featuresCollection_.clear();
+ this.featuresRtree_.clear();
+ this.loadedExtentsRtree_.clear();
+ var clearEvent = new ol.source.Vector.Event(ol.source.VectorEventType.CLEAR);
+ this.dispatchEvent(clearEvent);
+ this.changed();
+ * Iterate through all features on the source, calling the provided callback
+ * with each one. If the callback returns any "truthy" value, iteration will
+ * stop and the function will return the same value.
+ * @param {function(this: T, ol.Feature): S} callback Called with each feature
+ * on the source. Return a truthy value to stop iteration.
+ * @param {T=} opt_this The object to use as `this` in the callback.
+ * @return {S|undefined} The return value from the last call to the callback.
+ * @template T,S
+ * @api
+ol.source.Vector.prototype.forEachFeature = function(callback, opt_this) {
+ return this.featuresRtree_.forEach(callback, opt_this);
+ } else if (this.featuresCollection_) {
+ return this.featuresCollection_.forEach(callback, opt_this);
+ * Iterate through all features whose geometries contain the provided
+ * coordinate, calling the callback with each feature. If the callback returns
+ * a "truthy" value, iteration will stop and the function will return the same
+ * value.
+ * @param {ol.Coordinate} coordinate Coordinate.
+ * whose goemetry contains the provided coordinate.
+ * @template T,S
+ol.source.Vector.prototype.forEachFeatureAtCoordinateDirect = function(coordinate, callback, opt_this) {
+ var extent = [coordinate[0], coordinate[1], coordinate[0], coordinate[1]];
+ return this.forEachFeatureInExtent(extent, function(feature) {
+ if (geometry.intersectsCoordinate(coordinate)) {
+ return callback.call(opt_this, feature);
+ } else {
+ return undefined;
+ * Iterate through all features whose bounding box intersects the provided
+ * extent (note that the feature's geometry may not intersect the extent),
+ * calling the callback with each feature. If the callback returns a "truthy"
+ * value, iteration will stop and the function will return the same value.
+ * If you are interested in features whose geometry intersects an extent, call
+ * the {@link ol.source.Vector#forEachFeatureIntersectingExtent
+ * source.forEachFeatureIntersectingExtent()} method instead.
+ * When `useSpatialIndex` is set to false, this method will loop through all
+ * features, equivalent to {@link ol.source.Vector#forEachFeature}.
+ * whose bounding box intersects the provided extent.
+ * @template T,S
+ * @api
+ol.source.Vector.prototype.forEachFeatureInExtent = function(extent, callback, opt_this) {
+ return this.featuresRtree_.forEachInExtent(extent, callback, opt_this);
+ * Iterate through all features whose geometry intersects the provided extent,
+ * If you only want to test for bounding box intersection, call the
+ * {@link ol.source.Vector#forEachFeatureInExtent
+ * source.forEachFeatureInExtent()} method instead.
+ * whose geometry intersects the provided extent.
+ * @template T,S
+ * @api
+ol.source.Vector.prototype.forEachFeatureIntersectingExtent = function(extent, callback, opt_this) {
+ * @template S
+ function(feature) {
+ if (geometry.intersectsExtent(extent)) {
+ var result = callback.call(opt_this, feature);
+ if (result) {
+ return result;
+ * Get the features collection associated with this source. Will be `null`
+ * unless the source was configured with `useSpatialIndex` set to `false`, or
+ * with an {@link ol.Collection} as `features`.
+ * @return {ol.Collection.<ol.Feature>} The collection of features.
+ * @api
+ol.source.Vector.prototype.getFeaturesCollection = function() {
+ return this.featuresCollection_;
+ * Get all features on the source in random order.
+ * @return {Array.<ol.Feature>} Features.
+ * @api
+ol.source.Vector.prototype.getFeatures = function() {
+ var features;
+ features = this.featuresCollection_.getArray();
+ } else if (this.featuresRtree_) {
+ features = this.featuresRtree_.getAll();
+ if (!ol.obj.isEmpty(this.nullGeometryFeatures_)) {
+ ol.array.extend(
+ features, ol.obj.getValues(this.nullGeometryFeatures_));
+ return /** @type {Array.<ol.Feature>} */ (features);
+ * Get all features whose geometry intersects the provided coordinate.
+ * @api
+ol.source.Vector.prototype.getFeaturesAtCoordinate = function(coordinate) {
+ this.forEachFeatureAtCoordinateDirect(coordinate, function(feature) {
+ return features;
+ * Get all features in the provided extent. Note that this returns an array of
+ * all features intersecting the given extent in random order (so it may include
+ * features whose geometries do not intersect the extent).
+ * This method is not available when the source is configured with
+ * `useSpatialIndex` set to `false`.
+ * @api
+ol.source.Vector.prototype.getFeaturesInExtent = function(extent) {
+ return this.featuresRtree_.getInExtent(extent);
+ * Get the closest feature to the provided coordinate.
+ * @param {function(ol.Feature):boolean=} opt_filter Feature filter function.
+ * The filter function will receive one argument, the {@link ol.Feature feature}
+ * and it should return a boolean value. By default, no filtering is made.
+ * @return {ol.Feature} Closest feature.
+ * @api
+ol.source.Vector.prototype.getClosestFeatureToCoordinate = function(coordinate, opt_filter) {
+ // Find the closest feature using branch and bound. We start searching an
+ // infinite extent, and find the distance from the first feature found. This
+ // becomes the closest feature. We then compute a smaller extent which any
+ // closer feature must intersect. We continue searching with this smaller
+ // extent, trying to find a closer feature. Every time we find a closer
+ // feature, we update the extent being searched so that any even closer
+ // feature must intersect it. We continue until we run out of features.
+ var x = coordinate[0];
+ var y = coordinate[1];
+ var closestFeature = null;
+ var closestPoint = [NaN, NaN];
+ var minSquaredDistance = Infinity;
+ var extent = [-Infinity, -Infinity, Infinity, Infinity];
+ var filter = opt_filter ? opt_filter : ol.functions.TRUE;
+ this.featuresRtree_.forEachInExtent(extent,
+ if (filter(feature)) {
+ var previousMinSquaredDistance = minSquaredDistance;
+ minSquaredDistance = geometry.closestPointXY(
+ x, y, closestPoint, minSquaredDistance);
+ if (minSquaredDistance < previousMinSquaredDistance) {
+ closestFeature = feature;
+ // This is sneaky. Reduce the extent that it is currently being
+ // searched while the R-Tree traversal using this same extent object
+ // is still in progress. This is safe because the new extent is
+ // strictly contained by the old extent.
+ var minDistance = Math.sqrt(minSquaredDistance);
+ extent[0] = x - minDistance;
+ extent[1] = y - minDistance;
+ extent[2] = x + minDistance;
+ extent[3] = y + minDistance;
+ return closestFeature;
+ * Get the extent of the features currently in the source.
+ * @param {ol.Extent=} opt_extent Destination extent. If provided, no new extent
+ * will be created. Instead, that extent's coordinates will be overwritten.
+ * @return {!ol.Extent} Extent.
+ * @api
+ol.source.Vector.prototype.getExtent = function(opt_extent) {
+ return this.featuresRtree_.getExtent(opt_extent);
+ * Get a feature by its identifier (the value returned by feature.getId()).
+ * Note that the index treats string and numeric identifiers as the same. So
+ * `source.getFeatureById(2)` will return a feature with id `'2'` or `2`.
+ * @param {string|number} id Feature identifier.
+ * @return {ol.Feature} The feature (or `null` if not found).
+ * @api
+ol.source.Vector.prototype.getFeatureById = function(id) {
+ var feature = this.idIndex_[id.toString()];
+ return feature !== undefined ? feature : null;
+ * Get the format associated with this source.
+ * @return {ol.format.Feature|undefined} The feature format.
+ * @api
+ol.source.Vector.prototype.getFormat = function() {
+ return this.format_;
+ * @return {boolean} The source can have overlapping geometries.
+ol.source.Vector.prototype.getOverlaps = function() {
+ return this.overlaps_;
+ * @override
+ol.source.Vector.prototype.getResolutions = function() {};
+ * Get the url associated with this source.
+ * @return {string|ol.FeatureUrlFunction|undefined} The url.
+ * @api
+ol.source.Vector.prototype.getUrl = function() {
+ return this.url_;
+ * @param {ol.events.Event} event Event.
+ * @private
+ol.source.Vector.prototype.handleFeatureChange_ = function(event) {
+ var feature = /** @type {ol.Feature} */ (event.target);
+ if (!geometry) {
+ if (!(featureKey in this.nullGeometryFeatures_)) {
+ this.featuresRtree_.remove(feature);
+ } else {
+ if (featureKey in this.nullGeometryFeatures_) {
+ delete this.nullGeometryFeatures_[featureKey];
+ } else {
+ this.featuresRtree_.update(extent, feature);
+ var sid = id.toString();
+ if (featureKey in this.undefIdIndex_) {
+ delete this.undefIdIndex_[featureKey];
+ this.idIndex_[sid] = feature;
+ } else {
+ if (this.idIndex_[sid] !== feature) {
+ this.removeFromIdIndex_(feature);
+ } else {
+ if (!(featureKey in this.undefIdIndex_)) {
+ this.changed();
+ ol.source.VectorEventType.CHANGEFEATURE, feature));
+ * @return {boolean} Is empty.
+ol.source.Vector.prototype.isEmpty = function() {
+ return this.featuresRtree_.isEmpty() &&
+ ol.obj.isEmpty(this.nullGeometryFeatures_);
+ * @param {ol.Extent} extent Extent.
+ * @param {number} resolution Resolution.
+ * @param {ol.proj.Projection} projection Projection.
+ol.source.Vector.prototype.loadFeatures = function(
+ extent, resolution, projection) {
+ var loadedExtentsRtree = this.loadedExtentsRtree_;
+ var extentsToLoad = this.strategy_(extent, resolution);
+ var i, ii;
+ for (i = 0, ii = extentsToLoad.length; i < ii; ++i) {
+ var extentToLoad = extentsToLoad[i];
+ var alreadyLoaded = loadedExtentsRtree.forEachInExtent(extentToLoad,
+ * @param {{extent: ol.Extent}} object Object.
+ * @return {boolean} Contains.
+ function(object) {
+ return ol.extent.containsExtent(object.extent, extentToLoad);
+ if (!alreadyLoaded) {
+ this.loader_.call(this, extentToLoad, resolution, projection);
+ loadedExtentsRtree.insert(extentToLoad, {extent: extentToLoad.slice()});
+ * Remove a single feature from the source. If you want to remove all features
+ * at once, use the {@link ol.source.Vector#clear source.clear()} method
+ * instead.
+ * @param {ol.Feature} feature Feature to remove.
+ * @api
+ol.source.Vector.prototype.removeFeature = function(feature) {
+ } else {
+ this.removeFeatureInternal(feature);
+ this.changed();
+ * Remove feature without firing a `change` event.
+ * @protected
+ol.source.Vector.prototype.removeFeatureInternal = function(feature) {
+ this.featureChangeKeys_[featureKey].forEach(ol.events.unlistenByKey);
+ delete this.featureChangeKeys_[featureKey];
+ delete this.idIndex_[id.toString()];
+ } else {
+ ol.source.VectorEventType.REMOVEFEATURE, feature));
+ * Remove a feature from the id index. Called internally when the feature id
+ * may have changed.
+ * @return {boolean} Removed the feature from the index.
+ * @private
+ol.source.Vector.prototype.removeFromIdIndex_ = function(feature) {
+ var removed = false;
+ for (var id in this.idIndex_) {
+ if (this.idIndex_[id] === feature) {
+ delete this.idIndex_[id];
+ removed = true;
+ break;
+ return removed;
+ * @classdesc
+ * Events emitted by {@link ol.source.Vector} instances are instances of this
+ * type.
+ * @constructor
+ * @extends {ol.events.Event}
+ * @implements {oli.source.Vector.Event}
+ * @param {string} type Type.
+ * @param {ol.Feature=} opt_feature Feature.
+ol.source.Vector.Event = function(type, opt_feature) {
+ ol.events.Event.call(this, type);
+ * The feature being added or removed.
+ * @type {ol.Feature|undefined}
+ * @api
+ this.feature = opt_feature;
+ol.inherits(ol.source.Vector.Event, ol.events.Event);
+goog.provide('ol.interaction.Draw');
+goog.require('ol');
+goog.require('ol.Feature');
+goog.require('ol.MapBrowserEventType');
+goog.require('ol.coordinate');
+goog.require('ol.events');
+goog.require('ol.events.condition');
+goog.require('ol.functions');
+goog.require('ol.geom.Circle');
+goog.require('ol.geom.GeometryType');
+goog.require('ol.geom.LineString');
+goog.require('ol.geom.MultiLineString');
+goog.require('ol.geom.MultiPoint');
+goog.require('ol.geom.MultiPolygon');
+goog.require('ol.geom.Point');
+goog.require('ol.geom.Polygon');
+goog.require('ol.interaction.DrawEventType');
+goog.require('ol.interaction.Pointer');
+goog.require('ol.interaction.Property');
+goog.require('ol.layer.Vector');
+goog.require('ol.source.Vector');
+ * @classdesc
+ * Interaction for drawing feature geometries.
+ * @constructor
+ * @extends {ol.interaction.Pointer}
+ * @fires ol.interaction.Draw.Event
+ * @param {olx.interaction.DrawOptions} options Options.
+ * @api
+ol.interaction.Draw = function(options) {
+ ol.interaction.Pointer.call(this, {
+ handleDownEvent: ol.interaction.Draw.handleDownEvent_,
+ handleEvent: ol.interaction.Draw.handleEvent,
+ handleUpEvent: ol.interaction.Draw.handleUpEvent_
+ * @type {boolean}
+ * @private
+ this.shouldHandle_ = false;
+ * @type {ol.Pixel}
+ * @private
+ this.downPx_ = null;
+ * @type {boolean}
+ * @private
+ this.freehand_ = false;
+ * Target source for drawn features.
+ * @type {ol.source.Vector}
+ * @private
+ this.source_ = options.source ? options.source : null;
+ * Target collection for drawn features.
+ * @private
+ this.features_ = options.features ? options.features : null;
+ * Pixel distance for snapping.
+ * @type {number}
+ * @private
+ this.snapTolerance_ = options.snapTolerance ? options.snapTolerance : 12;
+ * Geometry type.
+ * @type {ol.geom.GeometryType}
+ * @private
+ this.type_ = options.type;
+ * Drawing mode (derived from geometry type.
+ * @type {ol.interaction.Draw.Mode_}
+ * @private
+ this.mode_ = ol.interaction.Draw.getMode_(this.type_);
+ * The number of points that must be drawn before a polygon ring or line
+ * string can be finished. The default is 3 for polygon rings and 2 for
+ * line strings.
+ * @type {number}
+ * @private
+ this.minPoints_ = options.minPoints ?
+ options.minPoints :
+ (this.mode_ === ol.interaction.Draw.Mode_.POLYGON ? 3 : 2);
+ * The number of points that can be drawn before a polygon ring or line string
+ * is finished. The default is no restriction.
+ * @type {number}
+ * @private
+ this.maxPoints_ = options.maxPoints ? options.maxPoints : Infinity;
+ * A function to decide if a potential finish coordinate is permissable
+ * @private
+ * @type {ol.EventsConditionType}
+ this.finishCondition_ = options.finishCondition ? options.finishCondition : ol.functions.TRUE;
+ var geometryFunction = options.geometryFunction;
+ if (!geometryFunction) {
+ if (this.type_ === ol.geom.GeometryType.CIRCLE) {
+ * @param {ol.Coordinate|Array.<ol.Coordinate>|Array.<Array.<ol.Coordinate>>} coordinates
+ * The coordinates.
+ * @param {ol.geom.SimpleGeometry=} opt_geometry Optional geometry.
+ * @return {ol.geom.SimpleGeometry} A geometry.
+ geometryFunction = function(coordinates, opt_geometry) {
+ var circle = opt_geometry ? /** @type {ol.geom.Circle} */ (opt_geometry) :
+ new ol.geom.Circle([NaN, NaN]);
+ var squaredLength = ol.coordinate.squaredDistance(
+ coordinates[0], coordinates[1]);
+ circle.setCenterAndRadius(coordinates[0], Math.sqrt(squaredLength));
+ return circle;
+ } else {
+ var Constructor;
+ var mode = this.mode_;
+ if (mode === ol.interaction.Draw.Mode_.POINT) {
+ Constructor = ol.geom.Point;
+ } else if (mode === ol.interaction.Draw.Mode_.LINE_STRING) {
+ Constructor = ol.geom.LineString;
+ } else if (mode === ol.interaction.Draw.Mode_.POLYGON) {
+ Constructor = ol.geom.Polygon;
+ var geometry = opt_geometry;
+ if (geometry) {
+ if (mode === ol.interaction.Draw.Mode_.POLYGON) {
+ geometry.setCoordinates([coordinates[0].concat([coordinates[0][0]])]);
+ } else {
+ geometry.setCoordinates(coordinates);
+ } else {
+ geometry = new Constructor(coordinates);
+ return geometry;
+ * @type {ol.DrawGeometryFunctionType}
+ * @private
+ this.geometryFunction_ = geometryFunction;
+ * Finish coordinate for the feature (first point for polygons, last point for
+ * linestrings).
+ * @type {ol.Coordinate}
+ * @private
+ this.finishCoordinate_ = null;
+ * Sketch feature.
+ * @type {ol.Feature}
+ * @private
+ this.sketchFeature_ = null;
+ * Sketch point.
+ * @private
+ this.sketchPoint_ = null;
+ * Sketch coordinates. Used when drawing a line or polygon.
+ * @type {ol.Coordinate|Array.<ol.Coordinate>|Array.<Array.<ol.Coordinate>>}
+ * @private
+ this.sketchCoords_ = null;
+ * Sketch line. Used when drawing polygon.
+ * @private
+ this.sketchLine_ = null;
+ * Sketch line coordinates. Used when drawing a polygon or circle.
+ * @type {Array.<ol.Coordinate>}
+ * @private
+ this.sketchLineCoords_ = null;
+ * Squared tolerance for handling up events. If the squared distance
+ * between a down and up event is greater than this tolerance, up events
+ * will not be handled.
+ * @type {number}
+ * @private
+ this.squaredClickTolerance_ = options.clickTolerance ?
+ options.clickTolerance * options.clickTolerance : 36;
+ * Draw overlay where our sketch features are drawn.
+ * @type {ol.layer.Vector}
+ * @private
+ this.overlay_ = new ol.layer.Vector({
+ source: new ol.source.Vector({
+ useSpatialIndex: false,
+ wrapX: options.wrapX ? options.wrapX : false
+ style: options.style ? options.style :
+ ol.interaction.Draw.getDefaultStyleFunction()
+ * Name of the geometry attribute for newly created features.
+ * @type {string|undefined}
+ * @private
+ this.geometryName_ = options.geometryName;
+ * @private
+ this.condition_ = options.condition ?
+ options.condition : ol.events.condition.noModifierKeys;
+ * @private
+ this.freehandCondition_;
+ if (options.freehand) {
+ this.freehandCondition_ = ol.events.condition.always;
+ } else {
+ this.freehandCondition_ = options.freehandCondition ?
+ options.freehandCondition : ol.events.condition.shiftKeyOnly;
+ ol.Object.getChangeEventType(ol.interaction.Property.ACTIVE),
+ this.updateState_, this);
+ol.inherits(ol.interaction.Draw, ol.interaction.Pointer);
+ * @return {ol.StyleFunction} Styles.
+ol.interaction.Draw.getDefaultStyleFunction = function() {
+ var styles = ol.style.Style.createDefaultEditing();
+ return function(feature, resolution) {
+ return styles[feature.getGeometry().getType()];
+ * @inheritDoc
+ol.interaction.Draw.prototype.setMap = function(map) {
+ ol.interaction.Pointer.prototype.setMap.call(this, map);
+ this.updateState_();
+ * Handles the {@link ol.MapBrowserEvent map browser event} and may actually
+ * draw or finish the drawing.
+ * @param {ol.MapBrowserEvent} event Map browser event.
+ * @return {boolean} `false` to stop event propagation.
+ * @this {ol.interaction.Draw}
+ * @api
+ol.interaction.Draw.handleEvent = function(event) {
+ this.freehand_ = this.mode_ !== ol.interaction.Draw.Mode_.POINT && this.freehandCondition_(event);
+ var pass = !this.freehand_;
+ if (this.freehand_ &&
+ event.type === ol.MapBrowserEventType.POINTERDRAG && this.sketchFeature_ !== null) {
+ this.addToDrawing_(event);
+ pass = false;
+ } else if (event.type ===
+ ol.MapBrowserEventType.POINTERMOVE) {
+ pass = this.handlePointerMove_(event);
+ } else if (event.type === ol.MapBrowserEventType.DBLCLICK) {
+ pass = false;
+ return ol.interaction.Pointer.handleEvent.call(this, event) && pass;
+ * @param {ol.MapBrowserPointerEvent} event Event.
+ * @return {boolean} Start drag sequence?
+ * @private
+ol.interaction.Draw.handleDownEvent_ = function(event) {
+ this.shouldHandle_ = !this.freehand_;
+ if (this.freehand_) {
+ this.downPx_ = event.pixel;
+ if (!this.finishCoordinate_) {
+ this.startDrawing_(event);
+ return true;
+ } else if (this.condition_(event)) {
+ return true;
+ } else {
+ return false;
+ * @return {boolean} Stop drag sequence?
+ * @private
+ol.interaction.Draw.handleUpEvent_ = function(event) {
+ var pass = true;
+ this.handlePointerMove_(event);
+ var circleMode = this.mode_ === ol.interaction.Draw.Mode_.CIRCLE;
+ if (this.shouldHandle_) {
+ if (this.mode_ === ol.interaction.Draw.Mode_.POINT) {
+ this.finishDrawing();
+ } else if (this.freehand_ || circleMode) {
+ } else if (this.atFinish_(event)) {
+ if (this.finishCondition_(event)) {
+ } else {
+ pass = false;
+ } else if (this.freehand_) {
+ this.abortDrawing_();
+ return pass;
+ * Handle move events.
+ * @param {ol.MapBrowserEvent} event A move event.
+ * @return {boolean} Pass the event to other interactions.
+ * @private
+ol.interaction.Draw.prototype.handlePointerMove_ = function(event) {
+ if (this.downPx_ &&
+ ((!this.freehand_ && this.shouldHandle_) ||
+ (this.freehand_ && !this.shouldHandle_))) {
+ var downPx = this.downPx_;
+ var clickPx = event.pixel;
+ var dx = downPx[0] - clickPx[0];
+ var dy = downPx[1] - clickPx[1];
+ var squaredDistance = dx * dx + dy * dy;
+ this.shouldHandle_ = this.freehand_ ?
+ squaredDistance > this.squaredClickTolerance_ :
+ squaredDistance <= this.squaredClickTolerance_;
+ if (this.finishCoordinate_) {
+ this.modifyDrawing_(event);
+ } else {
+ this.createOrUpdateSketchPoint_(event);
+ return true;
+ * Determine if an event is within the snapping tolerance of the start coord.
+ * @param {ol.MapBrowserEvent} event Event.
+ * @return {boolean} The event is within the snapping tolerance of the start.
+ * @private
+ol.interaction.Draw.prototype.atFinish_ = function(event) {
+ var at = false;
+ if (this.sketchFeature_) {
+ var potentiallyDone = false;
+ var potentiallyFinishCoordinates = [this.finishCoordinate_];
+ if (this.mode_ === ol.interaction.Draw.Mode_.LINE_STRING) {
+ potentiallyDone = this.sketchCoords_.length > this.minPoints_;
+ } else if (this.mode_ === ol.interaction.Draw.Mode_.POLYGON) {
+ potentiallyDone = this.sketchCoords_[0].length >
+ this.minPoints_;
+ potentiallyFinishCoordinates = [this.sketchCoords_[0][0],
+ this.sketchCoords_[0][this.sketchCoords_[0].length - 2]];
+ if (potentiallyDone) {
+ var map = event.map;
+ for (var i = 0, ii = potentiallyFinishCoordinates.length; i < ii; i++) {
+ var finishCoordinate = potentiallyFinishCoordinates[i];
+ var finishPixel = map.getPixelFromCoordinate(finishCoordinate);
+ var pixel = event.pixel;
+ var dx = pixel[0] - finishPixel[0];
+ var dy = pixel[1] - finishPixel[1];
+ var snapTolerance = this.freehand_ ? 1 : this.snapTolerance_;
+ at = Math.sqrt(dx * dx + dy * dy) <= snapTolerance;
+ if (at) {
+ this.finishCoordinate_ = finishCoordinate;
+ break;
+ return at;
+ * @private
+ol.interaction.Draw.prototype.createOrUpdateSketchPoint_ = function(event) {
+ var coordinates = event.coordinate.slice();
+ if (!this.sketchPoint_) {
+ this.sketchPoint_ = new ol.Feature(new ol.geom.Point(coordinates));
+ this.updateSketchFeatures_();
+ } else {
+ var sketchPointGeom = /** @type {ol.geom.Point} */ (this.sketchPoint_.getGeometry());
+ sketchPointGeom.setCoordinates(coordinates);
+ * Start the drawing.
+ * @private
+ol.interaction.Draw.prototype.startDrawing_ = function(event) {
+ var start = event.coordinate;
+ this.finishCoordinate_ = start;
+ this.sketchCoords_ = start.slice();
+ this.sketchCoords_ = [[start.slice(), start.slice()]];
+ this.sketchLineCoords_ = this.sketchCoords_[0];
+ } else {
+ this.sketchCoords_ = [start.slice(), start.slice()];
+ if (this.mode_ === ol.interaction.Draw.Mode_.CIRCLE) {
+ this.sketchLineCoords_ = this.sketchCoords_;
+ if (this.sketchLineCoords_) {
+ this.sketchLine_ = new ol.Feature(
+ new ol.geom.LineString(this.sketchLineCoords_));
+ var geometry = this.geometryFunction_(this.sketchCoords_);
+ this.sketchFeature_ = new ol.Feature();
+ if (this.geometryName_) {
+ this.sketchFeature_.setGeometryName(this.geometryName_);
+ this.sketchFeature_.setGeometry(geometry);
+ this.dispatchEvent(new ol.interaction.Draw.Event(
+ ol.interaction.DrawEventType.DRAWSTART, this.sketchFeature_));
+ * Modify the drawing.
+ * @private
+ol.interaction.Draw.prototype.modifyDrawing_ = function(event) {
+ var coordinate = event.coordinate;
+ var geometry = /** @type {ol.geom.SimpleGeometry} */ (this.sketchFeature_.getGeometry());
+ var coordinates, last;
+ last = this.sketchCoords_;
+ coordinates = this.sketchCoords_[0];
+ last = coordinates[coordinates.length - 1];
+ if (this.atFinish_(event)) {
+ // snap to finish
+ coordinate = this.finishCoordinate_.slice();
+ } else {
+ coordinates = this.sketchCoords_;
+ last[0] = coordinate[0];
+ last[1] = coordinate[1];
+ this.geometryFunction_(
+ /** @type {!ol.Coordinate|!Array.<ol.Coordinate>|!Array.<Array.<ol.Coordinate>>} */ (this.sketchCoords_),
+ geometry);
+ if (this.sketchPoint_) {
+ sketchPointGeom.setCoordinates(coordinate);
+ var sketchLineGeom;
+ if (geometry instanceof ol.geom.Polygon &&
+ this.mode_ !== ol.interaction.Draw.Mode_.POLYGON) {
+ if (!this.sketchLine_) {
+ this.sketchLine_ = new ol.Feature(new ol.geom.LineString(null));
+ var ring = geometry.getLinearRing(0);
+ sketchLineGeom = /** @type {ol.geom.LineString} */ (this.sketchLine_.getGeometry());
+ sketchLineGeom.setFlatCoordinates(
+ ring.getLayout(), ring.getFlatCoordinates());
+ } else if (this.sketchLineCoords_) {
+ sketchLineGeom.setCoordinates(this.sketchLineCoords_);
+ * Add a new coordinate to the drawing.
+ * @private
+ol.interaction.Draw.prototype.addToDrawing_ = function(event) {
+ var done;
+ var coordinates;
+ this.finishCoordinate_ = coordinate.slice();
+ if (coordinates.length >= this.maxPoints_) {
+ coordinates.pop();
+ } else {
+ done = true;
+ coordinates.push(coordinate.slice());
+ this.geometryFunction_(coordinates, geometry);
+ } else {
+ done = true;
+ if (done) {
+ this.finishCoordinate_ = coordinates[0];
+ this.geometryFunction_(this.sketchCoords_, geometry);
+ if (done) {
+ * Remove last point of the feature currently being drawn.
+ * @api
+ol.interaction.Draw.prototype.removeLastPoint = function() {
+ if (!this.sketchFeature_) {
+ return;
+ var coordinates, sketchLineGeom;
+ coordinates.splice(-2, 1);
+ if (coordinates.length >= 2) {
+ this.finishCoordinate_ = coordinates[coordinates.length - 2].slice();
+ sketchLineGeom.setCoordinates(coordinates);
+ if (coordinates.length === 0) {
+ * Stop drawing and add the sketch feature to the target layer.
+ * The {@link ol.interaction.DrawEventType.DRAWEND} event is dispatched before
+ * inserting the feature.
+ * @api
+ol.interaction.Draw.prototype.finishDrawing = function() {
+ var sketchFeature = this.abortDrawing_();
+ var coordinates = this.sketchCoords_;
+ var geometry = /** @type {ol.geom.SimpleGeometry} */ (sketchFeature.getGeometry());
+ // remove the redundant last point
+ // remove the redundant last point in ring
+ coordinates[0].pop();
+ coordinates = geometry.getCoordinates();
+ // cast multi-part geometries
+ if (this.type_ === ol.geom.GeometryType.MULTI_POINT) {
+ sketchFeature.setGeometry(new ol.geom.MultiPoint([coordinates]));
+ } else if (this.type_ === ol.geom.GeometryType.MULTI_LINE_STRING) {
+ sketchFeature.setGeometry(new ol.geom.MultiLineString([coordinates]));
+ } else if (this.type_ === ol.geom.GeometryType.MULTI_POLYGON) {
+ sketchFeature.setGeometry(new ol.geom.MultiPolygon([coordinates]));
+ // First dispatch event to allow full set up of feature
+ ol.interaction.DrawEventType.DRAWEND, sketchFeature));
+ // Then insert feature
+ if (this.features_) {
+ this.features_.push(sketchFeature);
+ if (this.source_) {
+ this.source_.addFeature(sketchFeature);
+ * Stop drawing without adding the sketch feature to the target layer.
+ * @return {ol.Feature} The sketch feature (or null if none).
+ * @private
+ol.interaction.Draw.prototype.abortDrawing_ = function() {
+ var sketchFeature = this.sketchFeature_;
+ if (sketchFeature) {
+ this.overlay_.getSource().clear(true);
+ return sketchFeature;
+ * Extend an existing geometry by adding additional points. This only works
+ * on features with `LineString` geometries, where the interaction will
+ * extend lines by adding points to the end of the coordinates array.
+ * @param {!ol.Feature} feature Feature to be extended.
+ * @api
+ol.interaction.Draw.prototype.extend = function(feature) {
+ var lineString = /** @type {ol.geom.LineString} */ (geometry);
+ this.sketchFeature_ = feature;
+ this.sketchCoords_ = lineString.getCoordinates();
+ var last = this.sketchCoords_[this.sketchCoords_.length - 1];
+ this.finishCoordinate_ = last.slice();
+ this.sketchCoords_.push(last.slice());
+ * @inheritDoc
+ol.interaction.Draw.prototype.shouldStopEvent = ol.functions.FALSE;
+ * Redraw the sketch features.
+ * @private
+ol.interaction.Draw.prototype.updateSketchFeatures_ = function() {
+ var sketchFeatures = [];
+ sketchFeatures.push(this.sketchFeature_);
+ if (this.sketchLine_) {
+ sketchFeatures.push(this.sketchLine_);
+ sketchFeatures.push(this.sketchPoint_);
+ var overlaySource = this.overlay_.getSource();
+ overlaySource.clear(true);
+ overlaySource.addFeatures(sketchFeatures);
+ * @private
+ol.interaction.Draw.prototype.updateState_ = function() {
+ var map = this.getMap();
+ var active = this.getActive();
+ if (!map || !active) {
+ this.overlay_.setMap(active ? map : null);
+ * Create a `geometryFunction` for `type: 'Circle'` that will create a regular
+ * polygon with a user specified number of sides and start angle instead of an
+ * `ol.geom.Circle` geometry.
+ * @param {number=} opt_sides Number of sides of the regular polygon. Default is
+ * 32.
+ * @param {number=} opt_angle Angle of the first point in radians. 0 means East.
+ * Default is the angle defined by the heading from the center of the
+ * regular polygon to the current pointer position.
+ * @return {ol.DrawGeometryFunctionType} Function that draws a
+ * polygon.
+ * @api
+ol.interaction.Draw.createRegularPolygon = function(opt_sides, opt_angle) {
+ return (
+ function(coordinates, opt_geometry) {
+ var center = coordinates[0];
+ var end = coordinates[1];
+ var radius = Math.sqrt(
+ ol.coordinate.squaredDistance(center, end));
+ var geometry = opt_geometry ? /** @type {ol.geom.Polygon} */ (opt_geometry) :
+ ol.geom.Polygon.fromCircle(new ol.geom.Circle(center), opt_sides);
+ var angle = opt_angle ? opt_angle :
+ Math.atan((end[1] - center[1]) / (end[0] - center[0]));
+ ol.geom.Polygon.makeRegular(geometry, center, radius, angle);
+ return geometry;
+ * Create a `geometryFunction` that will create a box-shaped polygon (aligned
+ * with the coordinate system axes). Use this with the draw interaction and
+ * `type: 'Circle'` to return a box instead of a circle geometry.
+ * @return {ol.DrawGeometryFunctionType} Function that draws a box-shaped polygon.
+ * @api
+ol.interaction.Draw.createBox = function() {
+ return (
+ var extent = ol.extent.boundingExtent(coordinates);
+ var geometry = opt_geometry || new ol.geom.Polygon(null);
+ geometry.setCoordinates([[
+ ol.extent.getBottomLeft(extent),
+ ol.extent.getBottomRight(extent),
+ ol.extent.getTopRight(extent),
+ ol.extent.getTopLeft(extent),
+ return geometry;
+ * Get the drawing mode. The mode for mult-part geometries is the same as for
+ * their single-part cousins.
+ * @param {ol.geom.GeometryType} type Geometry type.
+ * @return {ol.interaction.Draw.Mode_} Drawing mode.
+ * @private
+ol.interaction.Draw.getMode_ = function(type) {
+ var mode;
+ if (type === ol.geom.GeometryType.POINT ||
+ type === ol.geom.GeometryType.MULTI_POINT) {
+ mode = ol.interaction.Draw.Mode_.POINT;
+ } else if (type === ol.geom.GeometryType.LINE_STRING ||
+ type === ol.geom.GeometryType.MULTI_LINE_STRING) {
+ mode = ol.interaction.Draw.Mode_.LINE_STRING;
+ } else if (type === ol.geom.GeometryType.POLYGON ||
+ type === ol.geom.GeometryType.MULTI_POLYGON) {
+ mode = ol.interaction.Draw.Mode_.POLYGON;
+ } else if (type === ol.geom.GeometryType.CIRCLE) {
+ mode = ol.interaction.Draw.Mode_.CIRCLE;
+ return /** @type {!ol.interaction.Draw.Mode_} */ (mode);
+ * Draw mode. This collapses multi-part geometry types with their single-part
+ * cousins.
+ * @enum {string}
+ * @private
+ol.interaction.Draw.Mode_ = {
+ POINT: 'Point',
+ LINE_STRING: 'LineString',
+ POLYGON: 'Polygon',
+ CIRCLE: 'Circle'
+ * @classdesc
+ * Events emitted by {@link ol.interaction.Draw} instances are instances of
+ * this type.
+ * @constructor
+ * @implements {oli.DrawEvent}
+ * @param {ol.interaction.DrawEventType} type Type.
+ * @param {ol.Feature} feature The feature drawn.
+ol.interaction.Draw.Event = function(type, feature) {
+ * The feature being drawn.
+ * @api
+ this.feature = feature;
+ol.inherits(ol.interaction.Draw.Event, ol.events.Event);
+goog.provide('ol.interaction.Extent');
+goog.require('ol.MapBrowserPointerEvent');
+ * @classdesc
+ * Allows the user to draw a vector box by clicking and dragging on the map.
+ * Once drawn, the vector box can be modified by dragging its vertices or edges.
+ * This interaction is only supported for mouse devices.
+ * @constructor
+ * @fires ol.interaction.Extent.Event
+ * @param {olx.interaction.ExtentOptions=} opt_options Options.
+ * @api
+ol.interaction.Extent = function(opt_options) {
+ * Extent of the drawn box
+ * @type {ol.Extent}
+ * @private
+ this.extent_ = null;
+ * Handler for pointer move events
+ * @type {function (ol.Coordinate): ol.Extent|null}
+ * @private
+ this.pointerHandler_ = null;
+ * Pixel threshold to snap to extent
+ * @type {number}
+ * @private
+ this.pixelTolerance_ = 10;
+ * Is the pointer snapped to an extent vertex
+ * @type {boolean}
+ * @private
+ this.snappedToVertex_ = false;
+ * Feature for displaying the visible extent
+ * @private
+ this.extentFeature_ = null;
+ * Feature for displaying the visible pointer
+ * @private
+ this.vertexFeature_ = null;
+ if (!opt_options) {
+ opt_options = {};
+ if (opt_options.extent) {
+ this.setExtent(opt_options.extent);
+ /* Inherit ol.interaction.Pointer */
+ handleDownEvent: ol.interaction.Extent.handleDownEvent_,
+ handleDragEvent: ol.interaction.Extent.handleDragEvent_,
+ handleEvent: ol.interaction.Extent.handleEvent_,
+ handleUpEvent: ol.interaction.Extent.handleUpEvent_
+ * Layer for the extentFeature
+ * @private
+ this.extentOverlay_ = new ol.layer.Vector({
+ wrapX: !!opt_options.wrapX
+ style: opt_options.boxStyle ? opt_options.boxStyle : ol.interaction.Extent.getDefaultExtentStyleFunction_(),
+ updateWhileAnimating: true,
+ updateWhileInteracting: true
+ * Layer for the vertexFeature
+ * @private
+ this.vertexOverlay_ = new ol.layer.Vector({
+ style: opt_options.pointerStyle ? opt_options.pointerStyle : ol.interaction.Extent.getDefaultPointerStyleFunction_(),
+ol.inherits(ol.interaction.Extent, ol.interaction.Pointer);
+ * @param {ol.MapBrowserEvent} mapBrowserEvent Event.
+ * @return {boolean} Propagate event?
+ * @this {ol.interaction.Extent}
+ * @private
+ol.interaction.Extent.handleEvent_ = function(mapBrowserEvent) {
+ if (!(mapBrowserEvent instanceof ol.MapBrowserPointerEvent)) {
+ return true;
+ //display pointer (if not dragging)
+ if (mapBrowserEvent.type == ol.MapBrowserEventType.POINTERMOVE && !this.handlingDownUpSequence) {
+ this.handlePointerMove_(mapBrowserEvent);
+ //call pointer to determine up/down/drag
+ ol.interaction.Pointer.handleEvent.call(this, mapBrowserEvent);
+ //return false to stop propagation
+ return false;
+ * @param {ol.MapBrowserPointerEvent} mapBrowserEvent Event.
+ * @return {boolean} Event handled?
+ * @private
+ol.interaction.Extent.handleDownEvent_ = function(mapBrowserEvent) {
+ var pixel = mapBrowserEvent.pixel;
+ var map = mapBrowserEvent.map;
+ var extent = this.getExtent();
+ var vertex = this.snapToVertex_(pixel, map);
+ //find the extent corner opposite the passed corner
+ var getOpposingPoint = function(point) {
+ var x_ = null;
+ var y_ = null;
+ if (point[0] == extent[0]) {
+ x_ = extent[2];
+ } else if (point[0] == extent[2]) {
+ x_ = extent[0];
+ if (point[1] == extent[1]) {
+ y_ = extent[3];
+ } else if (point[1] == extent[3]) {
+ y_ = extent[1];
+ if (x_ !== null && y_ !== null) {
+ return [x_, y_];
+ return null;
+ if (vertex && extent) {
+ var x = (vertex[0] == extent[0] || vertex[0] == extent[2]) ? vertex[0] : null;
+ var y = (vertex[1] == extent[1] || vertex[1] == extent[3]) ? vertex[1] : null;
+ //snap to point
+ if (x !== null && y !== null) {
+ this.pointerHandler_ = ol.interaction.Extent.getPointHandler_(getOpposingPoint(vertex));
+ //snap to edge
+ } else if (x !== null) {
+ this.pointerHandler_ = ol.interaction.Extent.getEdgeHandler_(
+ getOpposingPoint([x, extent[1]]),
+ getOpposingPoint([x, extent[3]])
+ } else if (y !== null) {
+ getOpposingPoint([extent[0], y]),
+ getOpposingPoint([extent[2], y])
+ //no snap - new bbox
+ } else {
+ vertex = map.getCoordinateFromPixel(pixel);
+ this.setExtent([vertex[0], vertex[1], vertex[0], vertex[1]]);
+ this.pointerHandler_ = ol.interaction.Extent.getPointHandler_(vertex);
+ return true; //event handled; start downup sequence
+ * @private
+ol.interaction.Extent.handleDragEvent_ = function(mapBrowserEvent) {
+ if (this.pointerHandler_) {
+ var pixelCoordinate = mapBrowserEvent.coordinate;
+ this.setExtent(this.pointerHandler_(pixelCoordinate));
+ this.createOrUpdatePointerFeature_(pixelCoordinate);
+ return true;
+ * @private
+ol.interaction.Extent.handleUpEvent_ = function(mapBrowserEvent) {
+ //If bbox is zero area, set to null;
+ if (!extent || ol.extent.getArea(extent) === 0) {
+ this.setExtent(null);
+ return false; //Stop handling downup sequence
+ * Returns the default style for the drawn bbox
+ * @return {ol.StyleFunction} Default Extent style
+ * @private
+ol.interaction.Extent.getDefaultExtentStyleFunction_ = function() {
+ var style = ol.style.Style.createDefaultEditing();
+ return style[ol.geom.GeometryType.POLYGON];
+ * Returns the default style for the pointer
+ * @return {ol.StyleFunction} Default pointer style
+ * @private
+ol.interaction.Extent.getDefaultPointerStyleFunction_ = function() {
+ return style[ol.geom.GeometryType.POINT];
+ * @param {ol.Coordinate} fixedPoint corner that will be unchanged in the new extent
+ * @returns {function (ol.Coordinate): ol.Extent} event handler
+ * @private
+ol.interaction.Extent.getPointHandler_ = function(fixedPoint) {
+ return function(point) {
+ return ol.extent.boundingExtent([fixedPoint, point]);
+ * @param {ol.Coordinate} fixedP1 first corner that will be unchanged in the new extent
+ * @param {ol.Coordinate} fixedP2 second corner that will be unchanged in the new extent
+ * @returns {function (ol.Coordinate): ol.Extent|null} event handler
+ * @private
+ol.interaction.Extent.getEdgeHandler_ = function(fixedP1, fixedP2) {
+ if (fixedP1[0] == fixedP2[0]) {
+ return ol.extent.boundingExtent([fixedP1, [point[0], fixedP2[1]]]);
+ } else if (fixedP1[1] == fixedP2[1]) {
+ return ol.extent.boundingExtent([fixedP1, [fixedP2[0], point[1]]]);
+ } else {
+ return null;
+ * @param {ol.Extent} extent extent
+ * @returns {Array<Array<ol.Coordinate>>} extent line segments
+ * @private
+ol.interaction.Extent.getSegments_ = function(extent) {
+ return [
+ [[extent[0], extent[1]], [extent[0], extent[3]]],
+ [[extent[0], extent[3]], [extent[2], extent[3]]],
+ [[extent[2], extent[3]], [extent[2], extent[1]]],
+ [[extent[2], extent[1]], [extent[0], extent[1]]]
+ * @param {ol.Pixel} pixel cursor location
+ * @param {ol.Map} map map
+ * @returns {ol.Coordinate|null} snapped vertex on extent
+ * @private
+ol.interaction.Extent.prototype.snapToVertex_ = function(pixel, map) {
+ var pixelCoordinate = map.getCoordinateFromPixel(pixel);
+ var sortByDistance = function(a, b) {
+ return ol.coordinate.squaredDistanceToSegment(pixelCoordinate, a) -
+ ol.coordinate.squaredDistanceToSegment(pixelCoordinate, b);
+ if (extent) {
+ //convert extents to line segments and find the segment closest to pixelCoordinate
+ var segments = ol.interaction.Extent.getSegments_(extent);
+ segments.sort(sortByDistance);
+ var closestSegment = segments[0];
+ var vertex = (ol.coordinate.closestOnSegment(pixelCoordinate,
+ closestSegment));
+ var vertexPixel = map.getPixelFromCoordinate(vertex);
+ //if the distance is within tolerance, snap to the segment
+ if (ol.coordinate.distance(pixel, vertexPixel) <= this.pixelTolerance_) {
+ //test if we should further snap to a vertex
+ var pixel1 = map.getPixelFromCoordinate(closestSegment[0]);
+ var pixel2 = map.getPixelFromCoordinate(closestSegment[1]);
+ var squaredDist1 = ol.coordinate.squaredDistance(vertexPixel, pixel1);
+ var squaredDist2 = ol.coordinate.squaredDistance(vertexPixel, pixel2);
+ var dist = Math.sqrt(Math.min(squaredDist1, squaredDist2));
+ this.snappedToVertex_ = dist <= this.pixelTolerance_;
+ if (this.snappedToVertex_) {
+ vertex = squaredDist1 > squaredDist2 ?
+ closestSegment[1] : closestSegment[0];
+ return vertex;
+ return null;
+ * @param {ol.MapBrowserEvent} mapBrowserEvent pointer move event
+ * @private
+ol.interaction.Extent.prototype.handlePointerMove_ = function(mapBrowserEvent) {
+ if (!vertex) {
+ this.createOrUpdatePointerFeature_(vertex);
+ * @returns {ol.Feature} extent as featrue
+ * @private
+ol.interaction.Extent.prototype.createOrUpdateExtentFeature_ = function(extent) {
+ var extentFeature = this.extentFeature_;
+ if (!extentFeature) {
+ if (!extent) {
+ extentFeature = new ol.Feature({});
+ } else {
+ extentFeature = new ol.Feature(ol.geom.Polygon.fromExtent(extent));
+ this.extentFeature_ = extentFeature;
+ this.extentOverlay_.getSource().addFeature(extentFeature);
+ } else {
+ if (!extent) {
+ extentFeature.setGeometry(undefined);
+ } else {
+ extentFeature.setGeometry(ol.geom.Polygon.fromExtent(extent));
+ return extentFeature;
+ * @param {ol.Coordinate} vertex location of feature
+ * @returns {ol.Feature} vertex as feature
+ * @private
+ol.interaction.Extent.prototype.createOrUpdatePointerFeature_ = function(vertex) {
+ var vertexFeature = this.vertexFeature_;
+ if (!vertexFeature) {
+ vertexFeature = new ol.Feature(new ol.geom.Point(vertex));
+ this.vertexFeature_ = vertexFeature;
+ this.vertexOverlay_.getSource().addFeature(vertexFeature);
+ } else {
+ var geometry = /** @type {ol.geom.Point} */ (vertexFeature.getGeometry());
+ geometry.setCoordinates(vertex);
+ return vertexFeature;
+ * @inheritDoc
+ol.interaction.Extent.prototype.setMap = function(map) {
+ this.extentOverlay_.setMap(map);
+ this.vertexOverlay_.setMap(map);
+ * Returns the current drawn extent in the view projection
+ * @return {ol.Extent} Drawn extent in the view projection.
+ * @api
+ol.interaction.Extent.prototype.getExtent = function() {
+ return this.extent_;
+ * Manually sets the drawn extent, using the view projection.
+ * @api
+ol.interaction.Extent.prototype.setExtent = function(extent) {
+ //Null extent means no bbox
+ this.extent_ = extent ? extent : null;
+ this.createOrUpdateExtentFeature_(extent);
+ this.dispatchEvent(new ol.interaction.Extent.Event(this.extent_));
+ * @classdesc
+ * Events emitted by {@link ol.interaction.Extent} instances are instances of
+ * this type.
+ * @constructor
+ * @param {ol.Extent} extent the new extent
+ol.interaction.Extent.Event = function(extent) {
+ ol.events.Event.call(this, ol.interaction.Extent.EventType_.EXTENTCHANGED);
+ * The current extent.
+ * @api
+ this.extent_ = extent;
+ol.inherits(ol.interaction.Extent.Event, ol.events.Event);
+ * @enum {string}
+ * @private
+ol.interaction.Extent.EventType_ = {
+ * Triggered after the extent is changed
+ * @event ol.interaction.Extent.Event
+ * @api
+ EXTENTCHANGED: 'extentchanged'
+goog.provide('ol.interaction.ModifyEventType');
+ * @enum {string}
+ol.interaction.ModifyEventType = {
+ * Triggered upon feature modification start
+ * @event ol.interaction.Modify.Event#modifystart
+ * @api
+ MODIFYSTART: 'modifystart',
+ * Triggered upon feature modification end
+ * @event ol.interaction.Modify.Event#modifyend
+ * @api
+ MODIFYEND: 'modifyend'
+goog.provide('ol.interaction.Modify');
+goog.require('ol.ViewHint');
+goog.require('ol.events.EventType');
+goog.require('ol.extent');
+goog.require('ol.interaction.ModifyEventType');
+goog.require('ol.style.Style');
+ * @classdesc
+ * Interaction for modifying feature geometries.
+ * @constructor
+ * @param {olx.interaction.ModifyOptions} options Options.
+ * @fires ol.interaction.Modify.Event
+ * @api
+ol.interaction.Modify = function(options) {
+ handleDownEvent: ol.interaction.Modify.handleDownEvent_,
+ handleDragEvent: ol.interaction.Modify.handleDragEvent_,
+ handleEvent: ol.interaction.Modify.handleEvent,
+ handleUpEvent: ol.interaction.Modify.handleUpEvent_
+ * @private
+ options.condition : ol.events.condition.primaryAction;
+ * @private
+ * @param {ol.MapBrowserEvent} mapBrowserEvent Browser event.
+ * @return {boolean} Combined condition result.
+ this.defaultDeleteCondition_ = function(mapBrowserEvent) {
+ return ol.events.condition.noModifierKeys(mapBrowserEvent) &&
+ ol.events.condition.singleClick(mapBrowserEvent);
+ * @private
+ this.deleteCondition_ = options.deleteCondition ?
+ options.deleteCondition : this.defaultDeleteCondition_;
+ * Editing vertex.
+ * @private
+ * Segments intersecting {@link this.vertexFeature_} by segment uid.
+ * @type {Object.<string, boolean>}
+ * @private
+ this.vertexSegments_ = null;
+ * @private
+ this.lastPixel_ = [0, 0];
+ * Tracks if the next `singleclick` event should be ignored to prevent
+ * accidental deletion right after vertex creation.
+ * @type {boolean}
+ * @private
+ this.ignoreNextSingleClick_ = false;
+ * @type {boolean}
+ * @private
+ this.modified_ = false;
+ * Segment RTree for each layer
+ * @type {ol.structs.RBush.<ol.ModifySegmentDataType>}
+ * @private
+ this.rBush_ = new ol.structs.RBush();
+ * @type {number}
+ * @private
+ this.pixelTolerance_ = options.pixelTolerance !== undefined ?
+ options.pixelTolerance : 10;
+ * @type {boolean}
+ * @private
+ * Indicate whether the interaction is currently changing a feature's
+ * coordinates.
+ * @type {boolean}
+ * @private
+ this.changingFeature_ = false;
+ * @type {Array}
+ * @private
+ this.dragSegments_ = [];
+ * Draw overlay where sketch features are drawn.
+ * @private
+ wrapX: !!options.wrapX
+ ol.interaction.Modify.getDefaultStyleFunction(),
+ * @const
+ * @private
+ * @type {Object.<string, function(ol.Feature, ol.geom.Geometry)>}
+ this.SEGMENT_WRITERS_ = {
+ 'Point': this.writePointGeometry_,
+ 'LineString': this.writeLineStringGeometry_,
+ 'LinearRing': this.writeLineStringGeometry_,
+ 'Polygon': this.writePolygonGeometry_,
+ 'MultiPoint': this.writeMultiPointGeometry_,
+ 'MultiLineString': this.writeMultiLineStringGeometry_,
+ 'MultiPolygon': this.writeMultiPolygonGeometry_,
+ 'Circle': this.writeCircleGeometry_,
+ 'GeometryCollection': this.writeGeometryCollectionGeometry_
+ * @private
+ this.features_ = options.features;
+ this.features_.forEach(this.addFeature_, this);
+ ol.events.listen(this.features_, ol.CollectionEventType.ADD,
+ this.handleFeatureAdd_, this);
+ ol.events.listen(this.features_, ol.CollectionEventType.REMOVE,
+ this.handleFeatureRemove_, this);
+ * @type {ol.MapBrowserPointerEvent}
+ * @private
+ this.lastPointerEvent_ = null;
+ol.inherits(ol.interaction.Modify, ol.interaction.Pointer);
+ * @define {number} The segment index assigned to a circle's center when
+ * breaking up a cicrle into ModifySegmentDataType segments.
+ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CENTER_INDEX = 0;
+ * @define {number} The segment index assigned to a circle's circumference when
+ * breaking up a circle into ModifySegmentDataType segments.
+ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CIRCUMFERENCE_INDEX = 1;
+ * @param {ol.Feature} feature Feature.
+ * @private
+ol.interaction.Modify.prototype.addFeature_ = function(feature) {
+ if (geometry && geometry.getType() in this.SEGMENT_WRITERS_) {
+ this.SEGMENT_WRITERS_[geometry.getType()].call(this, feature, geometry);
+ if (map && map.isRendered() && this.getActive()) {
+ this.handlePointerAtPixel_(this.lastPixel_, map);
+ this.handleFeatureChange_, this);
+ * @param {ol.MapBrowserPointerEvent} evt Map browser event
+ * @private
+ol.interaction.Modify.prototype.willModifyFeatures_ = function(evt) {
+ if (!this.modified_) {
+ this.modified_ = true;
+ this.dispatchEvent(new ol.interaction.Modify.Event(
+ ol.interaction.ModifyEventType.MODIFYSTART, this.features_, evt));
+ * @private
+ol.interaction.Modify.prototype.removeFeature_ = function(feature) {
+ this.removeFeatureSegmentData_(feature);
+ // Remove the vertex feature if the collection of canditate features
+ // is empty.
+ if (this.vertexFeature_ && this.features_.getLength() === 0) {
+ this.overlay_.getSource().removeFeature(this.vertexFeature_);
+ ol.events.unlisten(feature, ol.events.EventType.CHANGE,
+ * @private
+ol.interaction.Modify.prototype.removeFeatureSegmentData_ = function(feature) {
+ var rBush = this.rBush_;
+ var /** @type {Array.<ol.ModifySegmentDataType>} */ nodesToRemove = [];
+ rBush.forEach(
+ * @param {ol.ModifySegmentDataType} node RTree node.
+ function(node) {
+ if (feature === node.feature) {
+ nodesToRemove.push(node);
+ for (var i = nodesToRemove.length - 1; i >= 0; --i) {
+ rBush.remove(nodesToRemove[i]);
+ * @inheritDoc
+ol.interaction.Modify.prototype.setActive = function(active) {
+ if (this.vertexFeature_ && !active) {
+ ol.interaction.Pointer.prototype.setActive.call(this, active);
+ * @inheritDoc
+ol.interaction.Modify.prototype.setMap = function(map) {
+ this.overlay_.setMap(map);
+ * @param {ol.Collection.Event} evt Event.
+ * @private
+ol.interaction.Modify.prototype.handleFeatureAdd_ = function(evt) {
+ this.addFeature_(/** @type {ol.Feature} */ (evt.element));
+ * @param {ol.events.Event} evt Event.
+ * @private
+ol.interaction.Modify.prototype.handleFeatureChange_ = function(evt) {
+ if (!this.changingFeature_) {
+ var feature = /** @type {ol.Feature} */ (evt.target);
+ this.removeFeature_(feature);
+ this.addFeature_(feature);
+ * @private
+ol.interaction.Modify.prototype.handleFeatureRemove_ = function(evt) {
+ var feature = /** @type {ol.Feature} */ (evt.element);
+ * @param {ol.geom.Point} geometry Geometry.
+ * @private
+ol.interaction.Modify.prototype.writePointGeometry_ = function(feature, geometry) {
+ var coordinates = geometry.getCoordinates();
+ var segmentData = /** @type {ol.ModifySegmentDataType} */ ({
+ feature: feature,
+ geometry: geometry,
+ segment: [coordinates, coordinates]
+ this.rBush_.insert(geometry.getExtent(), segmentData);
+ * @param {ol.geom.MultiPoint} geometry Geometry.
+ * @private
+ol.interaction.Modify.prototype.writeMultiPointGeometry_ = function(feature, geometry) {
+ var points = geometry.getCoordinates();
+ var coordinates, i, ii, segmentData;
+ for (i = 0, ii = points.length; i < ii; ++i) {
+ coordinates = points[i];
+ segmentData = /** @type {ol.ModifySegmentDataType} */ ({
+ feature: feature,
+ depth: [i],
+ index: i,
+ * @param {ol.geom.LineString} geometry Geometry.
+ * @private
+ol.interaction.Modify.prototype.writeLineStringGeometry_ = function(feature, geometry) {
+ var i, ii, segment, segmentData;
+ for (i = 0, ii = coordinates.length - 1; i < ii; ++i) {
+ segment = coordinates.slice(i, i + 2);
+ feature: feature,
+ index: i,
+ segment: segment
+ this.rBush_.insert(ol.extent.boundingExtent(segment), segmentData);
+ * @param {ol.geom.MultiLineString} geometry Geometry.
+ * @private
+ol.interaction.Modify.prototype.writeMultiLineStringGeometry_ = function(feature, geometry) {
+ var lines = geometry.getCoordinates();
+ var coordinates, i, ii, j, jj, segment, segmentData;
+ for (j = 0, jj = lines.length; j < jj; ++j) {
+ coordinates = lines[j];
+ feature: feature,
+ depth: [j],
+ index: i,
+ segment: segment
+ * @param {ol.geom.Polygon} geometry Geometry.
+ * @private
+ol.interaction.Modify.prototype.writePolygonGeometry_ = function(feature, geometry) {
+ var rings = geometry.getCoordinates();
+ for (j = 0, jj = rings.length; j < jj; ++j) {
+ coordinates = rings[j];
+ feature: feature,
+ depth: [j],
+ index: i,
+ segment: segment
+ * @param {ol.geom.MultiPolygon} geometry Geometry.
+ * @private
+ol.interaction.Modify.prototype.writeMultiPolygonGeometry_ = function(feature, geometry) {
+ var polygons = geometry.getCoordinates();
+ var coordinates, i, ii, j, jj, k, kk, rings, segment, segmentData;
+ for (k = 0, kk = polygons.length; k < kk; ++k) {
+ rings = polygons[k];
+ feature: feature,
+ depth: [j, k],
+ index: i,
+ segment: segment
+ * We convert a circle into two segments. The segment at index
+ * {@link ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CENTER_INDEX} is the
+ * circle's center (a point). The segment at index
+ * {@link ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CIRCUMFERENCE_INDEX} is
+ * the circumference, and is not a line segment.
+ * @param {ol.geom.Circle} geometry Geometry.
+ * @private
+ol.interaction.Modify.prototype.writeCircleGeometry_ = function(feature, geometry) {
+ var coordinates = geometry.getCenter();
+ var centerSegmentData = /** @type {ol.ModifySegmentDataType} */ ({
+ feature: feature,
+ index: ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CENTER_INDEX,
+ var circumferenceSegmentData = /** @type {ol.ModifySegmentDataType} */ ({
+ feature: feature,
+ index: ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CIRCUMFERENCE_INDEX,
+ var featureSegments = [centerSegmentData, circumferenceSegmentData];
+ centerSegmentData.featureSegments = circumferenceSegmentData.featureSegments = featureSegments;
+ this.rBush_.insert(ol.extent.createOrUpdateFromCoordinate(coordinates), centerSegmentData);
+ this.rBush_.insert(geometry.getExtent(), circumferenceSegmentData);
+ * @param {ol.geom.GeometryCollection} geometry Geometry.
+ * @private
+ol.interaction.Modify.prototype.writeGeometryCollectionGeometry_ = function(feature, geometry) {
+ var i, geometries = geometry.getGeometriesArray();
+ for (i = 0; i < geometries.length; ++i) {
+ this.SEGMENT_WRITERS_[geometries[i].getType()].call(
+ this, feature, geometries[i]);
+ * @param {ol.Coordinate} coordinates Coordinates.
+ * @return {ol.Feature} Vertex feature.
+ * @private
+ol.interaction.Modify.prototype.createOrUpdateVertexFeature_ = function(coordinates) {
+ vertexFeature = new ol.Feature(new ol.geom.Point(coordinates));
+ this.overlay_.getSource().addFeature(vertexFeature);
+ } else {
+ * @param {ol.ModifySegmentDataType} a The first segment data.
+ * @param {ol.ModifySegmentDataType} b The second segment data.
+ * @return {number} The difference in indexes.
+ * @private
+ol.interaction.Modify.compareIndexes_ = function(a, b) {
+ return a.index - b.index;
+ * @param {ol.MapBrowserPointerEvent} evt Event.
+ * @this {ol.interaction.Modify}
+ * @private
+ol.interaction.Modify.handleDownEvent_ = function(evt) {
+ if (!this.condition_(evt)) {
+ return false;
+ this.handlePointerAtPixel_(evt.pixel, evt.map);
+ var pixelCoordinate = evt.map.getCoordinateFromPixel(evt.pixel);
+ this.dragSegments_.length = 0;
+ if (vertexFeature) {
+ var insertVertices = [];
+ var vertex = geometry.getCoordinates();
+ var vertexExtent = ol.extent.boundingExtent([vertex]);
+ var segmentDataMatches = this.rBush_.getInExtent(vertexExtent);
+ var componentSegments = {};
+ segmentDataMatches.sort(ol.interaction.Modify.compareIndexes_);
+ for (var i = 0, ii = segmentDataMatches.length; i < ii; ++i) {
+ var segmentDataMatch = segmentDataMatches[i];
+ var segment = segmentDataMatch.segment;
+ var uid = ol.getUid(segmentDataMatch.feature);
+ var depth = segmentDataMatch.depth;
+ if (depth) {
+ uid += '-' + depth.join('-'); // separate feature components
+ if (!componentSegments[uid]) {
+ componentSegments[uid] = new Array(2);
+ if (segmentDataMatch.geometry.getType() === ol.geom.GeometryType.CIRCLE &&
+ segmentDataMatch.index === ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CIRCUMFERENCE_INDEX) {
+ var closestVertex = ol.interaction.Modify.closestOnSegmentData_(pixelCoordinate, segmentDataMatch);
+ if (ol.coordinate.equals(closestVertex, vertex) && !componentSegments[uid][0]) {
+ this.dragSegments_.push([segmentDataMatch, 0]);
+ componentSegments[uid][0] = segmentDataMatch;
+ } else if (ol.coordinate.equals(segment[0], vertex) &&
+ !componentSegments[uid][0]) {
+ } else if (ol.coordinate.equals(segment[1], vertex) &&
+ !componentSegments[uid][1]) {
+ // prevent dragging closed linestrings by the connecting node
+ if ((segmentDataMatch.geometry.getType() ===
+ ol.geom.GeometryType.LINE_STRING ||
+ segmentDataMatch.geometry.getType() ===
+ ol.geom.GeometryType.MULTI_LINE_STRING) &&
+ componentSegments[uid][0] &&
+ componentSegments[uid][0].index === 0) {
+ continue;
+ this.dragSegments_.push([segmentDataMatch, 1]);
+ componentSegments[uid][1] = segmentDataMatch;
+ } else if (ol.getUid(segment) in this.vertexSegments_ &&
+ (!componentSegments[uid][0] && !componentSegments[uid][1])) {
+ insertVertices.push([segmentDataMatch, vertex]);
+ if (insertVertices.length) {
+ this.willModifyFeatures_(evt);
+ for (var j = insertVertices.length - 1; j >= 0; --j) {
+ this.insertVertex_.apply(this, insertVertices[j]);
+ return !!this.vertexFeature_;
+ * @private
+ol.interaction.Modify.handleDragEvent_ = function(evt) {
+ var vertex = evt.coordinate;
+ for (var i = 0, ii = this.dragSegments_.length; i < ii; ++i) {
+ var dragSegment = this.dragSegments_[i];
+ var segmentData = dragSegment[0];
+ var depth = segmentData.depth;
+ var geometry = segmentData.geometry;
+ var coordinates;
+ var segment = segmentData.segment;
+ var index = dragSegment[1];
+ while (vertex.length < geometry.getStride()) {
+ vertex.push(segment[index][vertex.length]);
+ switch (geometry.getType()) {
+ case ol.geom.GeometryType.POINT:
+ coordinates = vertex;
+ segment[0] = segment[1] = vertex;
+ break;
+ case ol.geom.GeometryType.MULTI_POINT:
+ coordinates[segmentData.index] = vertex;
+ break;
+ case ol.geom.GeometryType.LINE_STRING:
+ coordinates[segmentData.index + index] = vertex;
+ segment[index] = vertex;
+ break;
+ case ol.geom.GeometryType.MULTI_LINE_STRING:
+ coordinates[depth[0]][segmentData.index + index] = vertex;
+ break;
+ case ol.geom.GeometryType.POLYGON:
+ break;
+ case ol.geom.GeometryType.MULTI_POLYGON:
+ coordinates[depth[1]][depth[0]][segmentData.index + index] = vertex;
+ break;
+ case ol.geom.GeometryType.CIRCLE:
+ if (segmentData.index === ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CENTER_INDEX) {
+ this.changingFeature_ = true;
+ geometry.setCenter(vertex);
+ } else { // We're dragging the circle's circumference:
+ geometry.setRadius(ol.coordinate.distance(geometry.getCenter(), vertex));
+ break;
+ default:
+ // pass
+ if (coordinates) {
+ this.setGeometryCoordinates_(geometry, coordinates);
+ this.createOrUpdateVertexFeature_(vertex);
+ * @private
+ol.interaction.Modify.handleUpEvent_ = function(evt) {
+ var segmentData;
+ var geometry;
+ for (var i = this.dragSegments_.length - 1; i >= 0; --i) {
+ segmentData = this.dragSegments_[i][0];
+ geometry = segmentData.geometry;
+ if (geometry.getType() === ol.geom.GeometryType.CIRCLE) {
+ // Update a circle object in the R* bush:
+ var centerSegmentData = segmentData.featureSegments[0];
+ var circumferenceSegmentData = segmentData.featureSegments[1];
+ centerSegmentData.segment[0] = centerSegmentData.segment[1] = coordinates;
+ circumferenceSegmentData.segment[0] = circumferenceSegmentData.segment[1] = coordinates;
+ this.rBush_.update(ol.extent.createOrUpdateFromCoordinate(coordinates), centerSegmentData);
+ this.rBush_.update(geometry.getExtent(), circumferenceSegmentData);
+ } else {
+ this.rBush_.update(ol.extent.boundingExtent(segmentData.segment),
+ segmentData);
+ if (this.modified_) {
+ ol.interaction.ModifyEventType.MODIFYEND, this.features_, evt));
+ return false;
+ * Handles the {@link ol.MapBrowserEvent map browser event} and may modify the
+ * geometry.
+ * @param {ol.MapBrowserEvent} mapBrowserEvent Map browser event.
+ * @api
+ol.interaction.Modify.handleEvent = function(mapBrowserEvent) {
+ return true;
+ this.lastPointerEvent_ = mapBrowserEvent;
+ var handled;
+ if (!mapBrowserEvent.map.getView().getHints()[ol.ViewHint.INTERACTING] &&
+ mapBrowserEvent.type == ol.MapBrowserEventType.POINTERMOVE &&
+ !this.handlingDownUpSequence) {
+ if (this.vertexFeature_ && this.deleteCondition_(mapBrowserEvent)) {
+ if (mapBrowserEvent.type != ol.MapBrowserEventType.SINGLECLICK ||
+ !this.ignoreNextSingleClick_) {
+ handled = this.removePoint();
+ } else {
+ handled = true;
+ if (mapBrowserEvent.type == ol.MapBrowserEventType.SINGLECLICK) {
+ return ol.interaction.Pointer.handleEvent.call(this, mapBrowserEvent) &&
+ !handled;
+ * @param {ol.MapBrowserEvent} evt Event.
+ * @private
+ol.interaction.Modify.prototype.handlePointerMove_ = function(evt) {
+ this.lastPixel_ = evt.pixel;
+ * @param {ol.Pixel} pixel Pixel
+ * @param {ol.Map} map Map.
+ * @private
+ol.interaction.Modify.prototype.handlePointerAtPixel_ = function(pixel, map) {
+ return ol.interaction.Modify.pointDistanceToSegmentDataSquared_(pixelCoordinate, a) -
+ ol.interaction.Modify.pointDistanceToSegmentDataSquared_(pixelCoordinate, b);
+ var box = ol.extent.buffer(
+ ol.extent.createOrUpdateFromCoordinate(pixelCoordinate),
+ map.getView().getResolution() * this.pixelTolerance_);
+ var nodes = rBush.getInExtent(box);
+ if (nodes.length > 0) {
+ nodes.sort(sortByDistance);
+ var node = nodes[0];
+ var closestSegment = node.segment;
+ var vertex = ol.interaction.Modify.closestOnSegmentData_(pixelCoordinate, node);
+ var dist = ol.coordinate.distance(pixel, vertexPixel);
+ if (dist <= this.pixelTolerance_) {
+ var vertexSegments = {};
+ if (node.geometry.getType() === ol.geom.GeometryType.CIRCLE &&
+ node.index === ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CIRCUMFERENCE_INDEX) {
+ this.snappedToVertex_ = true;
+ } else {
+ dist = Math.sqrt(Math.min(squaredDist1, squaredDist2));
+ var segment;
+ for (var i = 1, ii = nodes.length; i < ii; ++i) {
+ segment = nodes[i].segment;
+ if ((ol.coordinate.equals(closestSegment[0], segment[0]) &&
+ ol.coordinate.equals(closestSegment[1], segment[1]) ||
+ (ol.coordinate.equals(closestSegment[0], segment[1]) &&
+ ol.coordinate.equals(closestSegment[1], segment[0])))) {
+ vertexSegments[ol.getUid(segment)] = true;
+ } else {
+ break;
+ vertexSegments[ol.getUid(closestSegment)] = true;
+ this.vertexSegments_ = vertexSegments;
+ return;
+ if (this.vertexFeature_) {
+ * Returns the distance from a point to a line segment.
+ * @param {ol.Coordinate} pointCoordinates The coordinates of the point from
+ * which to calculate the distance.
+ * @param {ol.ModifySegmentDataType} segmentData The object describing the line
+ * segment we are calculating the distance to.
+ * @return {number} The square of the distance between a point and a line segment.
+ol.interaction.Modify.pointDistanceToSegmentDataSquared_ = function(pointCoordinates, segmentData) {
+ var circleGeometry = /** @type {ol.geom.Circle} */ (geometry);
+ if (segmentData.index === ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CIRCUMFERENCE_INDEX) {
+ var distanceToCenterSquared =
+ ol.coordinate.squaredDistance(circleGeometry.getCenter(), pointCoordinates);
+ var distanceToCircumference =
+ Math.sqrt(distanceToCenterSquared) - circleGeometry.getRadius();
+ return distanceToCircumference * distanceToCircumference;
+ return ol.coordinate.squaredDistanceToSegment(pointCoordinates, segmentData.segment);
+ * Returns the point closest to a given line segment.
+ * @param {ol.Coordinate} pointCoordinates The point to which a closest point
+ * should be found.
+ * segment which should contain the closest point.
+ * @return {ol.Coordinate} The point closest to the specified line segment.
+ol.interaction.Modify.closestOnSegmentData_ = function(pointCoordinates, segmentData) {
+ if (geometry.getType() === ol.geom.GeometryType.CIRCLE &&
+ segmentData.index === ol.interaction.Modify.MODIFY_SEGMENT_CIRCLE_CIRCUMFERENCE_INDEX) {
+ return geometry.getClosestPoint(pointCoordinates);
+ return ol.coordinate.closestOnSegment(pointCoordinates, segmentData.segment);
+ * @param {ol.ModifySegmentDataType} segmentData Segment data.
+ * @param {ol.Coordinate} vertex Vertex.
+ * @private
+ol.interaction.Modify.prototype.insertVertex_ = function(segmentData, vertex) {
+ var feature = segmentData.feature;
+ var index = /** @type {number} */ (segmentData.index);
+ var coordinates;
+ vertex.push(0);
+ coordinates[depth[0]].splice(index + 1, 0, vertex);
+ break;
+ break;
+ coordinates[depth[1]][depth[0]].splice(index + 1, 0, vertex);
+ break;
+ coordinates.splice(index + 1, 0, vertex);
+ break;
+ default:
+ return;
+ var rTree = this.rBush_;
+ rTree.remove(segmentData);
+ this.updateSegmentIndices_(geometry, index, depth, 1);
+ var newSegmentData = /** @type {ol.ModifySegmentDataType} */ ({
+ segment: [segment[0], vertex],
+ feature: feature,
+ depth: depth,
+ index: index
+ rTree.insert(ol.extent.boundingExtent(newSegmentData.segment),
+ newSegmentData);
+ this.dragSegments_.push([newSegmentData, 1]);
+ var newSegmentData2 = /** @type {ol.ModifySegmentDataType} */ ({
+ segment: [vertex, segment[1]],
+ feature: feature,
+ depth: depth,
+ index: index + 1
+ rTree.insert(ol.extent.boundingExtent(newSegmentData2.segment),
+ newSegmentData2);
+ this.dragSegments_.push([newSegmentData2, 0]);
+ this.ignoreNextSingleClick_ = true;
+ * Removes the vertex currently being pointed.
+ * @return {boolean} True when a vertex was removed.
+ * @api
+ol.interaction.Modify.prototype.removePoint = function() {
+ if (this.lastPointerEvent_ && this.lastPointerEvent_.type != ol.MapBrowserEventType.POINTERDRAG) {
+ var evt = this.lastPointerEvent_;
+ this.removeVertex_();
+ return true;
+ return false;
+ * Removes a vertex from all matching features.
+ * @private
+ol.interaction.Modify.prototype.removeVertex_ = function() {
+ var dragSegments = this.dragSegments_;
+ var segmentsByFeature = {};
+ var deleted = false;
+ var component, coordinates, dragSegment, geometry, i, index, left;
+ var newIndex, right, segmentData, uid;
+ for (i = dragSegments.length - 1; i >= 0; --i) {
+ dragSegment = dragSegments[i];
+ segmentData = dragSegment[0];
+ uid = ol.getUid(segmentData.feature);
+ if (segmentData.depth) {
+ // separate feature components
+ uid += '-' + segmentData.depth.join('-');
+ if (!(uid in segmentsByFeature)) {
+ segmentsByFeature[uid] = {};
+ if (dragSegment[1] === 0) {
+ segmentsByFeature[uid].right = segmentData;
+ segmentsByFeature[uid].index = segmentData.index;
+ } else if (dragSegment[1] == 1) {
+ segmentsByFeature[uid].left = segmentData;
+ segmentsByFeature[uid].index = segmentData.index + 1;
+ for (uid in segmentsByFeature) {
+ right = segmentsByFeature[uid].right;
+ left = segmentsByFeature[uid].left;
+ index = segmentsByFeature[uid].index;
+ newIndex = index - 1;
+ if (left !== undefined) {
+ segmentData = left;
+ } else {
+ segmentData = right;
+ if (newIndex < 0) {
+ newIndex = 0;
+ component = coordinates;
+ deleted = false;
+ if (coordinates[segmentData.depth[0]].length > 2) {
+ coordinates[segmentData.depth[0]].splice(index, 1);
+ deleted = true;
+ break;
+ if (coordinates.length > 2) {
+ coordinates.splice(index, 1);
+ deleted = true;
+ break;
+ component = component[segmentData.depth[1]];
+ /* falls through */
+ component = component[segmentData.depth[0]];
+ if (component.length > 4) {
+ if (index == component.length - 1) {
+ index = 0;
+ component.splice(index, 1);
+ deleted = true;
+ if (index === 0) {
+ // close the ring again
+ component.pop();
+ component.push(component[0]);
+ newIndex = component.length - 1;
+ break;
+ default:
+ // pass
+ if (deleted) {
+ var segments = [];
+ this.rBush_.remove(left);
+ segments.push(left.segment[0]);
+ if (right !== undefined) {
+ this.rBush_.remove(right);
+ segments.push(right.segment[1]);
+ if (left !== undefined && right !== undefined) {
+ depth: segmentData.depth,
+ feature: segmentData.feature,
+ geometry: segmentData.geometry,
+ index: newIndex,
+ segment: segments
+ this.rBush_.insert(ol.extent.boundingExtent(newSegmentData.segment),
+ newSegmentData);
+ this.updateSegmentIndices_(geometry, index, segmentData.depth, -1);
+ dragSegments.length = 0;
+ return deleted;
+ * @param {ol.geom.SimpleGeometry} geometry Geometry.
+ * @param {Array} coordinates Coordinates.
+ * @private
+ol.interaction.Modify.prototype.setGeometryCoordinates_ = function(geometry, coordinates) {
+ * @param {number} index Index.
+ * @param {Array.<number>|undefined} depth Depth.
+ * @param {number} delta Delta (1 or -1).
+ * @private
+ol.interaction.Modify.prototype.updateSegmentIndices_ = function(
+ geometry, index, depth, delta) {
+ this.rBush_.forEachInExtent(geometry.getExtent(), function(segmentDataMatch) {
+ if (segmentDataMatch.geometry === geometry &&
+ (depth === undefined || segmentDataMatch.depth === undefined ||
+ ol.array.equals(segmentDataMatch.depth, depth)) &&
+ segmentDataMatch.index > index) {
+ segmentDataMatch.index += delta;
+ol.interaction.Modify.getDefaultStyleFunction = function() {
+ * @classdesc
+ * Events emitted by {@link ol.interaction.Modify} instances are instances of
+ * this type.
+ * @constructor
+ * @implements {oli.ModifyEvent}
+ * @param {ol.interaction.ModifyEventType} type Type.
+ * @param {ol.Collection.<ol.Feature>} features The features modified.
+ * @param {ol.MapBrowserPointerEvent} mapBrowserPointerEvent Associated
+ * {@link ol.MapBrowserPointerEvent}.
+ol.interaction.Modify.Event = function(type, features, mapBrowserPointerEvent) {
+ * The features being modified.
+ * @type {ol.Collection.<ol.Feature>}
+ * @api
+ this.features = features;
+ * Associated {@link ol.MapBrowserEvent}.
+ * @type {ol.MapBrowserEvent}
+ * @api
+ this.mapBrowserEvent = mapBrowserPointerEvent;
+ol.inherits(ol.interaction.Modify.Event, ol.events.Event);
+goog.provide('ol.interaction.Select');
+goog.require('ol.CollectionEventType');
+goog.require('ol.array');
+goog.require('ol.events.Event');
+goog.require('ol.interaction.Interaction');
+goog.require('ol.obj');
+ * @classdesc
+ * Interaction for selecting vector features. By default, selected features are
+ * styled differently, so this interaction can be used for visual highlighting,
+ * as well as selecting features for other actions, such as modification or
+ * output. There are three ways of controlling which features are selected:
+ * using the browser event as defined by the `condition` and optionally the
+ * `toggle`, `add`/`remove`, and `multi` options; a `layers` filter; and a
+ * further feature filter using the `filter` option.
+ * Selected features are added to an internal unmanaged layer.
+ * @constructor
+ * @extends {ol.interaction.Interaction}
+ * @param {olx.interaction.SelectOptions=} opt_options Options.
+ * @fires ol.interaction.Select.Event
+ * @api
+ol.interaction.Select = function(opt_options) {
+ ol.interaction.Interaction.call(this, {
+ handleEvent: ol.interaction.Select.handleEvent
+ var options = opt_options ? opt_options : {};
+ * @private
+ options.condition : ol.events.condition.singleClick;
+ * @private
+ this.addCondition_ = options.addCondition ?
+ options.addCondition : ol.events.condition.never;
+ * @private
+ this.removeCondition_ = options.removeCondition ?
+ options.removeCondition : ol.events.condition.never;
+ * @private
+ this.toggleCondition_ = options.toggleCondition ?
+ options.toggleCondition : ol.events.condition.shiftKeyOnly;
+ * @private
+ * @type {boolean}
+ this.multi_ = options.multi ? options.multi : false;
+ * @private
+ * @type {ol.SelectFilterFunction}
+ this.filter_ = options.filter ? options.filter :
+ ol.functions.TRUE;
+ * @private
+ * @type {number}
+ this.hitTolerance_ = options.hitTolerance ? options.hitTolerance : 0;
+ var featureOverlay = new ol.layer.Vector({
+ features: options.features,
+ ol.interaction.Select.getDefaultStyleFunction(),
+ * @private
+ this.featureOverlay_ = featureOverlay;
+ /** @type {function(ol.layer.Layer): boolean} */
+ var layerFilter;
+ if (options.layers) {
+ if (typeof options.layers === 'function') {
+ layerFilter = options.layers;
+ } else {
+ var layers = options.layers;
+ layerFilter = function(layer) {
+ return ol.array.includes(layers, layer);
+ } else {
+ layerFilter = ol.functions.TRUE;
+ * @private
+ * @type {function(ol.layer.Layer): boolean}
+ this.layerFilter_ = layerFilter;
+ * An association between selected feature (key)
+ * and layer (value)
+ * @private
+ * @type {Object.<number, ol.layer.Layer>}
+ this.featureLayerAssociation_ = {};
+ var features = this.featureOverlay_.getSource().getFeaturesCollection();
+ ol.events.listen(features, ol.CollectionEventType.ADD,
+ this.addFeature_, this);
+ ol.events.listen(features, ol.CollectionEventType.REMOVE,
+ this.removeFeature_, this);
+ol.inherits(ol.interaction.Select, ol.interaction.Interaction);
+ * @param {ol.Feature|ol.render.Feature} feature Feature.
+ * @param {ol.layer.Layer} layer Layer.
+ * @private
+ol.interaction.Select.prototype.addFeatureLayerAssociation_ = function(feature, layer) {
+ var key = ol.getUid(feature);
+ this.featureLayerAssociation_[key] = layer;
+ * Get the selected features.
+ * @return {ol.Collection.<ol.Feature>} Features collection.
+ * @api
+ol.interaction.Select.prototype.getFeatures = function() {
+ return this.featureOverlay_.getSource().getFeaturesCollection();
+ * Returns the Hit-detection tolerance.
+ * @returns {number} Hit tolerance in pixels.
+ * @api
+ol.interaction.Select.prototype.getHitTolerance = function() {
+ return this.hitTolerance_;
+ * Returns the associated {@link ol.layer.Vector vectorlayer} of
+ * the (last) selected feature. Note that this will not work with any
+ * programmatic method like pushing features to
+ * {@link ol.interaction.Select#getFeatures collection}.
+ * @return {ol.layer.Vector} Layer.
+ * @api
+ol.interaction.Select.prototype.getLayer = function(feature) {
+ return /** @type {ol.layer.Vector} */ (this.featureLayerAssociation_[key]);
+ * Handles the {@link ol.MapBrowserEvent map browser event} and may change the
+ * selected state of features.
+ * @this {ol.interaction.Select}
+ * @api
+ol.interaction.Select.handleEvent = function(mapBrowserEvent) {
+ if (!this.condition_(mapBrowserEvent)) {
+ return true;
+ var add = this.addCondition_(mapBrowserEvent);
+ var remove = this.removeCondition_(mapBrowserEvent);
+ var toggle = this.toggleCondition_(mapBrowserEvent);
+ var set = !add && !remove && !toggle;
+ var deselected = [];
+ var selected = [];
+ if (set) {
+ // Replace the currently selected feature(s) with the feature(s) at the
+ // pixel, or clear the selected feature(s) if there is no feature at
+ // the pixel.
+ ol.obj.clear(this.featureLayerAssociation_);
+ map.forEachFeatureAtPixel(mapBrowserEvent.pixel,
+ * @return {boolean|undefined} Continue to iterate over the features.
+ function(feature, layer) {
+ if (this.filter_(feature, layer)) {
+ selected.push(feature);
+ this.addFeatureLayerAssociation_(feature, layer);
+ return !this.multi_;
+ }).bind(this), {
+ layerFilter: this.layerFilter_,
+ hitTolerance: this.hitTolerance_
+ var i;
+ for (i = features.getLength() - 1; i >= 0; --i) {
+ var feature = features.item(i);
+ var index = selected.indexOf(feature);
+ if (index > -1) {
+ // feature is already selected
+ selected.splice(index, 1);
+ } else {
+ features.remove(feature);
+ deselected.push(feature);
+ if (selected.length !== 0) {
+ features.extend(selected);
+ } else {
+ // Modify the currently selected feature(s).
+ if ((add || toggle) &&
+ !ol.array.includes(features.getArray(), feature)) {
+ } else if ((remove || toggle) &&
+ ol.array.includes(features.getArray(), feature)) {
+ this.removeFeatureLayerAssociation_(feature);
+ }).bind(this), {
+ var j;
+ for (j = deselected.length - 1; j >= 0; --j) {
+ features.remove(deselected[j]);
+ if (selected.length > 0 || deselected.length > 0) {
+ new ol.interaction.Select.Event(ol.interaction.Select.EventType_.SELECT,
+ selected, deselected, mapBrowserEvent));
+ return ol.events.condition.pointerMove(mapBrowserEvent);
+ * Hit-detection tolerance. Pixels inside the radius around the given position
+ * will be checked for features. This only works for the canvas renderer and
+ * not for WebGL.
+ * @param {number} hitTolerance Hit tolerance in pixels.
+ * @api
+ol.interaction.Select.prototype.setHitTolerance = function(hitTolerance) {
+ this.hitTolerance_ = hitTolerance;
+ * Remove the interaction from its current map, if any, and attach it to a new
+ * map, if any. Pass `null` to just remove the interaction from the current map.
+ * @override
+ * @api
+ol.interaction.Select.prototype.setMap = function(map) {
+ var currentMap = this.getMap();
+ var selectedFeatures =
+ this.featureOverlay_.getSource().getFeaturesCollection();
+ if (currentMap) {
+ selectedFeatures.forEach(currentMap.unskipFeature, currentMap);
+ ol.interaction.Interaction.prototype.setMap.call(this, map);
+ this.featureOverlay_.setMap(map);
+ if (map) {
+ selectedFeatures.forEach(map.skipFeature, map);
+ol.interaction.Select.getDefaultStyleFunction = function() {
+ ol.array.extend(styles[ol.geom.GeometryType.POLYGON],
+ styles[ol.geom.GeometryType.LINE_STRING]);
+ ol.array.extend(styles[ol.geom.GeometryType.GEOMETRY_COLLECTION],
+ if (!feature.getGeometry()) {
+ return null;
+ * @private
+ol.interaction.Select.prototype.addFeature_ = function(evt) {
+ if (map) {
+ map.skipFeature(/** @type {ol.Feature} */ (evt.element));
+ * @private
+ol.interaction.Select.prototype.removeFeature_ = function(evt) {
+ if (map) {
+ map.unskipFeature(/** @type {ol.Feature} */ (evt.element));
+ * @private
+ol.interaction.Select.prototype.removeFeatureLayerAssociation_ = function(feature) {
+ delete this.featureLayerAssociation_[key];
+ * @classdesc
+ * Events emitted by {@link ol.interaction.Select} instances are instances of
+ * this type.
+ * @param {ol.interaction.Select.EventType_} type The event type.
+ * @param {Array.<ol.Feature>} selected Selected features.
+ * @param {Array.<ol.Feature>} deselected Deselected features.
+ * @param {ol.MapBrowserEvent} mapBrowserEvent Associated
+ * {@link ol.MapBrowserEvent}.
+ * @implements {oli.SelectEvent}
+ * @extends {ol.events.Event}
+ * @constructor
+ol.interaction.Select.Event = function(type, selected, deselected, mapBrowserEvent) {
+ ol.events.Event.call(this, type);
+ * Selected features array.
+ * @type {Array.<ol.Feature>}
+ * @api
+ this.selected = selected;
+ * Deselected features array.
+ * @api
+ this.deselected = deselected;
+ * @api
+ this.mapBrowserEvent = mapBrowserEvent;
+ol.inherits(ol.interaction.Select.Event, ol.events.Event);
+ * @enum {string}
+ * @private
+ol.interaction.Select.EventType_ = {
+ * Triggered when feature(s) has been (de)selected.
+ * @event ol.interaction.Select.Event#select
+ * @api
+ SELECT: 'select'
+goog.provide('ol.interaction.Snap');
+goog.require('ol');
+goog.require('ol.Collection');
+goog.require('ol.coordinate');
+goog.require('ol.events');
+goog.require('ol.functions');
+goog.require('ol.interaction.Pointer');
+goog.require('ol.source.Vector');
+goog.require('ol.source.VectorEventType');
+goog.require('ol.structs.RBush');
+ * @classdesc
+ * Handles snapping of vector features while modifying or drawing them. The
+ * features can come from a {@link ol.source.Vector} or {@link ol.Collection}
+ * Any interaction object that allows the user to interact
+ * with the features using the mouse can benefit from the snapping, as long
+ * as it is added before.
+ * The snap interaction modifies map browser event `coordinate` and `pixel`
+ * properties to force the snap to occur to any interaction that them.
+ * Example:
+ * var snap = new ol.interaction.Snap({
+ * source: source
+ * @constructor
+ * @extends {ol.interaction.Pointer}
+ * @param {olx.interaction.SnapOptions=} opt_options Options.
+ * @api
+ol.interaction.Snap = function(opt_options) {
+ ol.interaction.Pointer.call(this, {
+ handleEvent: ol.interaction.Snap.handleEvent_,
+ handleDownEvent: ol.functions.TRUE,
+ handleUpEvent: ol.interaction.Snap.handleUpEvent_
+ * @type {ol.source.Vector}
+ * @private
+ this.source_ = options.source ? options.source : null;
+ * @private
+ * @type {boolean}
+ this.vertex_ = options.vertex !== undefined ? options.vertex : true;
+ * @private
+ * @type {boolean}
+ this.edge_ = options.edge !== undefined ? options.edge : true;
+ * @private
+ this.features_ = options.features ? options.features : null;
+ * @type {Array.<ol.EventsKey>}
+ * @private
+ this.featuresListenerKeys_ = [];
+ * @type {Object.<number, ol.EventsKey>}
+ * @private
+ this.featureChangeListenerKeys_ = {};
+ * Extents are preserved so indexed segment can be quickly removed
+ * when its feature geometry changes
+ * @type {Object.<number, ol.Extent>}
+ * @private
+ this.indexedFeaturesExtents_ = {};
+ * If a feature geometry changes while a pointer drag|move event occurs, the
+ * feature doesn't get updated right away. It will be at the next 'pointerup'
+ * event fired.
+ * @type {Object.<number, ol.Feature>}
+ * @private
+ this.pendingFeatures_ = {};
+ * Used for distance sorting in sortByDistance_
+ * @type {ol.Coordinate}
+ * @private
+ this.pixelCoordinate_ = null;
+ * @type {number}
+ * @private
+ * @type {function(ol.SnapSegmentDataType, ol.SnapSegmentDataType): number}
+ * @private
+ this.sortByDistance_ = ol.interaction.Snap.sortByDistance.bind(this);
+ * @type {ol.structs.RBush.<ol.SnapSegmentDataType>}
+ * @private
+ * @const
+ * @private
+ol.inherits(ol.interaction.Snap, ol.interaction.Pointer);
+ * Add a feature to the collection of features that we may snap to.
+ * @param {boolean=} opt_listen Whether to listen to the feature change or not
+ * Defaults to `true`.
+ * @api
+ol.interaction.Snap.prototype.addFeature = function(feature, opt_listen) {
+ var listen = opt_listen !== undefined ? opt_listen : true;
+ var feature_uid = ol.getUid(feature);
+ var geometry = feature.getGeometry();
+ if (geometry) {
+ var segmentWriter = this.SEGMENT_WRITERS_[geometry.getType()];
+ if (segmentWriter) {
+ this.indexedFeaturesExtents_[feature_uid] = geometry.getExtent(
+ ol.extent.createEmpty());
+ segmentWriter.call(this, feature, geometry);
+ if (listen) {
+ this.featureChangeListenerKeys_[feature_uid] = ol.events.listen(
+ feature,
+ ol.events.EventType.CHANGE,
+ * @private
+ol.interaction.Snap.prototype.forEachFeatureAdd_ = function(feature) {
+ this.addFeature(feature);
+ * @private
+ol.interaction.Snap.prototype.forEachFeatureRemove_ = function(feature) {
+ this.removeFeature(feature);
+ * @return {ol.Collection.<ol.Feature>|Array.<ol.Feature>} Features.
+ * @private
+ol.interaction.Snap.prototype.getFeatures_ = function() {
+ var features;
+ features = this.features_;
+ } else if (this.source_) {
+ features = this.source_.getFeatures();
+ return /** @type {!Array.<ol.Feature>|!ol.Collection.<ol.Feature>} */ (features);
+ * @param {ol.source.Vector.Event|ol.Collection.Event} evt Event.
+ * @private
+ol.interaction.Snap.prototype.handleFeatureAdd_ = function(evt) {
+ var feature;
+ if (evt instanceof ol.source.Vector.Event) {
+ feature = evt.feature;
+ } else if (evt instanceof ol.Collection.Event) {
+ feature = evt.element;
+ this.addFeature(/** @type {ol.Feature} */ (feature));
+ * @private
+ol.interaction.Snap.prototype.handleFeatureRemove_ = function(evt) {
+ var feature;
+ this.removeFeature(/** @type {ol.Feature} */ (feature));
+ * @private
+ol.interaction.Snap.prototype.handleFeatureChange_ = function(evt) {
+ if (this.handlingDownUpSequence) {
+ var uid = ol.getUid(feature);
+ if (!(uid in this.pendingFeatures_)) {
+ this.pendingFeatures_[uid] = feature;
+ } else {
+ this.updateFeature_(feature);
+ * Remove a feature from the collection of features that we may snap to.
+ * @param {boolean=} opt_unlisten Whether to unlisten to the feature change
+ * or not. Defaults to `true`.
+ * @api
+ol.interaction.Snap.prototype.removeFeature = function(feature, opt_unlisten) {
+ var unlisten = opt_unlisten !== undefined ? opt_unlisten : true;
+ var extent = this.indexedFeaturesExtents_[feature_uid];
+ if (extent) {
+ var i, nodesToRemove = [];
+ rBush.forEachInExtent(extent, function(node) {
+ for (i = nodesToRemove.length - 1; i >= 0; --i) {
+ if (unlisten) {
+ ol.events.unlistenByKey(this.featureChangeListenerKeys_[feature_uid]);
+ delete this.featureChangeListenerKeys_[feature_uid];
+ * @inheritDoc
+ol.interaction.Snap.prototype.setMap = function(map) {
+ var keys = this.featuresListenerKeys_;
+ var features = this.getFeatures_();
+ if (currentMap) {
+ keys.forEach(ol.events.unlistenByKey);
+ keys.length = 0;
+ features.forEach(this.forEachFeatureRemove_, this);
+ ol.interaction.Pointer.prototype.setMap.call(this, map);
+ if (map) {
+ keys.push(
+ this.handleFeatureAdd_, this),
+ keys.push(
+ ol.events.listen(this.source_, ol.source.VectorEventType.ADDFEATURE,
+ ol.events.listen(this.source_, ol.source.VectorEventType.REMOVEFEATURE,
+ features.forEach(this.forEachFeatureAdd_, this);
+ * @inheritDoc
+ol.interaction.Snap.prototype.shouldStopEvent = ol.functions.FALSE;
+ * @param {ol.Coordinate} pixelCoordinate Coordinate
+ * @return {ol.SnapResultType} Snap result
+ol.interaction.Snap.prototype.snapTo = function(pixel, pixelCoordinate, map) {
+ var lowerLeft = map.getCoordinateFromPixel(
+ [pixel[0] - this.pixelTolerance_, pixel[1] + this.pixelTolerance_]);
+ var upperRight = map.getCoordinateFromPixel(
+ [pixel[0] + this.pixelTolerance_, pixel[1] - this.pixelTolerance_]);
+ var box = ol.extent.boundingExtent([lowerLeft, upperRight]);
+ var segments = this.rBush_.getInExtent(box);
+ var snappedToVertex = false;
+ var snapped = false;
+ var vertex = null;
+ var vertexPixel = null;
+ var dist, pixel1, pixel2, squaredDist1, squaredDist2;
+ if (segments.length > 0) {
+ this.pixelCoordinate_ = pixelCoordinate;
+ segments.sort(this.sortByDistance_);
+ var closestSegment = segments[0].segment;
+ if (this.vertex_ && !this.edge_) {
+ pixel1 = map.getPixelFromCoordinate(closestSegment[0]);
+ pixel2 = map.getPixelFromCoordinate(closestSegment[1]);
+ squaredDist1 = ol.coordinate.squaredDistance(pixel, pixel1);
+ squaredDist2 = ol.coordinate.squaredDistance(pixel, pixel2);
+ snappedToVertex = dist <= this.pixelTolerance_;
+ if (snappedToVertex) {
+ snapped = true;
+ vertexPixel = map.getPixelFromCoordinate(vertex);
+ } else if (this.edge_) {
+ vertex = (ol.coordinate.closestOnSegment(pixelCoordinate,
+ closestSegment));
+ snapped = true;
+ if (this.vertex_) {
+ squaredDist1 = ol.coordinate.squaredDistance(vertexPixel, pixel1);
+ squaredDist2 = ol.coordinate.squaredDistance(vertexPixel, pixel2);
+ if (snapped) {
+ vertexPixel = [Math.round(vertexPixel[0]), Math.round(vertexPixel[1])];
+ return /** @type {ol.SnapResultType} */ ({
+ snapped: snapped,
+ vertex: vertex,
+ vertexPixel: vertexPixel
+ * @private
+ol.interaction.Snap.prototype.updateFeature_ = function(feature) {
+ this.removeFeature(feature, false);
+ this.addFeature(feature, false);
+ * @private
+ol.interaction.Snap.prototype.writeGeometryCollectionGeometry_ = function(feature, geometry) {
+ * @private
+ol.interaction.Snap.prototype.writeLineStringGeometry_ = function(feature, geometry) {
+ segmentData = /** @type {ol.SnapSegmentDataType} */ ({
+ feature: feature,
+ segment: segment
+ * @private
+ol.interaction.Snap.prototype.writeMultiLineStringGeometry_ = function(feature, geometry) {
+ feature: feature,
+ segment: segment
+ * @private
+ol.interaction.Snap.prototype.writeMultiPointGeometry_ = function(feature, geometry) {
+ feature: feature,
+ * @private
+ol.interaction.Snap.prototype.writeMultiPolygonGeometry_ = function(feature, geometry) {
+ feature: feature,
+ segment: segment
+ * @private
+ol.interaction.Snap.prototype.writePointGeometry_ = function(feature, geometry) {
+ var segmentData = /** @type {ol.SnapSegmentDataType} */ ({
+ feature: feature,
+ * @private
+ol.interaction.Snap.prototype.writePolygonGeometry_ = function(feature, geometry) {
+ feature: feature,
+ segment: segment
+ * Handle all pointer events events.
+ * @param {ol.MapBrowserEvent} evt A move event.
+ * @return {boolean} Pass the event to other interactions.
+ * @this {ol.interaction.Snap}
+ * @private
+ol.interaction.Snap.handleEvent_ = function(evt) {
+ var result = this.snapTo(evt.pixel, evt.coordinate, evt.map);
+ if (result.snapped) {
+ evt.coordinate = result.vertex.slice(0, 2);
+ evt.pixel = result.vertexPixel;
+ return ol.interaction.Pointer.handleEvent.call(this, evt);
+ * @return {boolean} Stop drag sequence?
+ * @private
+ol.interaction.Snap.handleUpEvent_ = function(evt) {
+ var featuresToUpdate = ol.obj.getValues(this.pendingFeatures_);
+ if (featuresToUpdate.length) {
+ featuresToUpdate.forEach(this.updateFeature_, this);
+ return false;
+ * Sort segments by distance, helper function
+ * @param {ol.SnapSegmentDataType} a The first segment data.
+ * @param {ol.SnapSegmentDataType} b The second segment data.
+ * @return {number} The difference in distance.
+ol.interaction.Snap.sortByDistance = function(a, b) {
+ this.pixelCoordinate_, a.segment) -
+ this.pixelCoordinate_, b.segment);
+goog.provide('ol.interaction.TranslateEventType');
+ * @enum {string}
+ol.interaction.TranslateEventType = {
+ * Triggered upon feature translation start.
+ * @event ol.interaction.Translate.Event#translatestart
+ * @api
+ TRANSLATESTART: 'translatestart',
+ * Triggered upon feature translation.
+ * @event ol.interaction.Translate.Event#translating
+ * @api
+ TRANSLATING: 'translating',
+ * Triggered upon feature translation end.
+ * @event ol.interaction.Translate.Event#translateend
+ * @api
+ TRANSLATEEND: 'translateend'
+goog.provide('ol.interaction.Translate');
+goog.require('ol.interaction.TranslateEventType');
+ * @classdesc
+ * Interaction for translating (moving) features.
+ * @constructor
+ * @fires ol.interaction.Translate.Event
+ * @param {olx.interaction.TranslateOptions=} opt_options Options.
+ * @api
+ol.interaction.Translate = function(opt_options) {
+ handleDownEvent: ol.interaction.Translate.handleDownEvent_,
+ handleDragEvent: ol.interaction.Translate.handleDragEvent_,
+ handleMoveEvent: ol.interaction.Translate.handleMoveEvent_,
+ handleUpEvent: ol.interaction.Translate.handleUpEvent_
+ * @type {string|undefined}
+ * @private
+ this.previousCursor_ = undefined;
+ * The last position we translated to.
+ * @private
+ this.lastCoordinate_ = null;
+ * @private
+ this.features_ = options.features !== undefined ? options.features : null;
+ var layerFilter;
+ } else {
+ } else {
+ * @private
+ * @private
+ * @type {number}
+ * @type {ol.Feature}
+ * @private
+ this.lastFeature_ = null;
+ ol.events.listen(this,
+ ol.Object.getChangeEventType(ol.interaction.Property.ACTIVE),
+ this.handleActiveChanged_, this);
+ol.inherits(ol.interaction.Translate, ol.interaction.Pointer);
+ * @param {ol.MapBrowserPointerEvent} event Event.
+ * @return {boolean} Start drag sequence?
+ * @this {ol.interaction.Translate}
+ * @private
+ol.interaction.Translate.handleDownEvent_ = function(event) {
+ this.lastFeature_ = this.featuresAtPixel_(event.pixel, event.map);
+ if (!this.lastCoordinate_ && this.lastFeature_) {
+ this.lastCoordinate_ = event.coordinate;
+ ol.interaction.Translate.handleMoveEvent_.call(this, event);
+ var features = this.features_ || new ol.Collection([this.lastFeature_]);
+ new ol.interaction.Translate.Event(
+ ol.interaction.TranslateEventType.TRANSLATESTART, features,
+ event.coordinate));
+ return true;
+ return false;
+ * @private
+ol.interaction.Translate.handleUpEvent_ = function(event) {
+ if (this.lastCoordinate_) {
+ ol.interaction.TranslateEventType.TRANSLATEEND, features,
+ return true;
+ return false;
+ * @private
+ol.interaction.Translate.handleDragEvent_ = function(event) {
+ var newCoordinate = event.coordinate;
+ var deltaX = newCoordinate[0] - this.lastCoordinate_[0];
+ var deltaY = newCoordinate[1] - this.lastCoordinate_[1];
+ features.forEach(function(feature) {
+ var geom = feature.getGeometry();
+ geom.translate(deltaX, deltaY);
+ feature.setGeometry(geom);
+ this.lastCoordinate_ = newCoordinate;
+ ol.interaction.TranslateEventType.TRANSLATING, features,
+ newCoordinate));
+ * @param {ol.MapBrowserEvent} event Event.
+ * @private
+ol.interaction.Translate.handleMoveEvent_ = function(event) {
+ var elem = event.map.getTargetElement();
+ // Change the cursor to grab/grabbing if hovering any of the features managed
+ // by the interaction
+ if (this.featuresAtPixel_(event.pixel, event.map)) {
+ this.previousCursor_ = this.previousCursor_ !== undefined ?
+ this.previousCursor_ : elem.style.cursor;
+ // WebKit browsers don't support the grab icons without a prefix
+ elem.style.cursor = this.lastCoordinate_ ?
+ '-webkit-grabbing' : '-webkit-grab';
+ // Thankfully, attempting to set the standard ones will silently fail,
+ // keeping the prefixed icons
+ elem.style.cursor = this.lastCoordinate_ ? 'grabbing' : 'grab';
+ } else if (this.previousCursor_ !== undefined) {
+ elem.style.cursor = this.previousCursor_;
+ * Tests to see if the given coordinates intersects any of our selected
+ * features.
+ * @param {ol.Pixel} pixel Pixel coordinate to test for intersection.
+ * @param {ol.Map} map Map to test the intersection on.
+ * @return {ol.Feature} Returns the feature found at the specified pixel
+ * coordinates.
+ * @private
+ol.interaction.Translate.prototype.featuresAtPixel_ = function(pixel, map) {
+ return map.forEachFeatureAtPixel(pixel,
+ function(feature) {
+ if (!this.features_ ||
+ ol.array.includes(this.features_.getArray(), feature)) {
+ return feature;
+ }.bind(this), {
+ * @api
+ol.interaction.Translate.prototype.getHitTolerance = function() {
+ * not for WebGL.
+ * @api
+ol.interaction.Translate.prototype.setHitTolerance = function(hitTolerance) {
+ * @inheritDoc
+ol.interaction.Translate.prototype.setMap = function(map) {
+ var oldMap = this.getMap();
+ this.updateState_(oldMap);
+ * @private
+ol.interaction.Translate.prototype.handleActiveChanged_ = function() {
+ this.updateState_(null);
+ * @param {ol.Map} oldMap Old map.
+ * @private
+ol.interaction.Translate.prototype.updateState_ = function(oldMap) {
+ var map = this.getMap();
+ var active = this.getActive();
+ if ((!map || !active) && this.previousCursor_ !== undefined) {
+ if (!map) {
+ map = oldMap;
+ var elem = map.getTargetElement();
+ * @classdesc
+ * Events emitted by {@link ol.interaction.Translate} instances are instances of
+ * this type.
+ * @constructor
+ * @implements {oli.interaction.TranslateEvent}
+ * @param {ol.interaction.TranslateEventType} type Type.
+ * @param {ol.Collection.<ol.Feature>} features The features translated.
+ * @param {ol.Coordinate} coordinate The event coordinate.
+ol.interaction.Translate.Event = function(type, features, coordinate) {
+ * The features being translated.
+ * @api
+ * The coordinate of the drag event.
+ * @const
+ * @api
+ this.coordinate = coordinate;
+ol.inherits(ol.interaction.Translate.Event, ol.events.Event);
+goog.provide('ol.layer.Heatmap');
+goog.require('ol.Object');
+goog.require('ol.dom');
+goog.require('ol.layer.Vector');
+goog.require('ol.math');
+goog.require('ol.render.EventType');
+goog.require('ol.style.Icon');
+ * @classdesc
+ * Layer for rendering vector data as a heatmap.
+ * Note that any property set in the options is set as a {@link ol.Object}
+ * property on the layer object; for example, setting `title: 'My Title'` in the
+ * options means that `title` is observable, and has get/set accessors.
+ * @constructor
+ * @extends {ol.layer.Vector}
+ * @fires ol.render.Event
+ * @param {olx.layer.HeatmapOptions=} opt_options Options.
+ * @api
+ol.layer.Heatmap = function(opt_options) {
+ var baseOptions = ol.obj.assign({}, options);
+ delete baseOptions.gradient;
+ delete baseOptions.radius;
+ delete baseOptions.blur;
+ delete baseOptions.shadow;
+ delete baseOptions.weight;
+ ol.layer.Vector.call(this, /** @type {olx.layer.VectorOptions} */ (baseOptions));
+ * @private
+ * @type {Uint8ClampedArray}
+ this.gradient_ = null;
+ * @private
+ * @type {number}
+ this.shadow_ = options.shadow !== undefined ? options.shadow : 250;
+ * @private
+ this.circleImage_ = undefined;
+ * @private
+ * @type {Array.<Array.<ol.style.Style>>}
+ this.styleCache_ = null;
+ ol.Object.getChangeEventType(ol.layer.Heatmap.Property_.GRADIENT),
+ this.handleGradientChanged_, this);
+ this.setGradient(options.gradient ?
+ options.gradient : ol.layer.Heatmap.DEFAULT_GRADIENT);
+ this.setBlur(options.blur !== undefined ? options.blur : 15);
+ this.setRadius(options.radius !== undefined ? options.radius : 8);
+ ol.Object.getChangeEventType(ol.layer.Heatmap.Property_.BLUR),
+ this.handleStyleChanged_, this);
+ ol.Object.getChangeEventType(ol.layer.Heatmap.Property_.RADIUS),
+ this.handleStyleChanged_();
+ var weight = options.weight ? options.weight : 'weight';
+ var weightFunction;
+ if (typeof weight === 'string') {
+ weightFunction = function(feature) {
+ return feature.get(weight);
+ } else {
+ weightFunction = weight;
+ this.setStyle(function(feature, resolution) {
+ var weight = weightFunction(feature);
+ var opacity = weight !== undefined ? ol.math.clamp(weight, 0, 1) : 1;
+ // cast to 8 bits
+ var index = (255 * opacity) | 0;
+ var style = this.styleCache_[index];
+ if (!style) {
+ style = [
+ new ol.style.Style({
+ image: new ol.style.Icon({
+ opacity: opacity,
+ src: this.circleImage_
+ this.styleCache_[index] = style;
+ return style;
+ }.bind(this));
+ // For performance reasons, don't sort the features before rendering.
+ // The render order is not relevant for a heatmap representation.
+ this.setRenderOrder(null);
+ ol.events.listen(this, ol.render.EventType.RENDER, this.handleRender_, this);
+ol.inherits(ol.layer.Heatmap, ol.layer.Vector);
+ * @const
+ * @type {Array.<string>}
+ol.layer.Heatmap.DEFAULT_GRADIENT = ['#00f', '#0ff', '#0f0', '#ff0', '#f00'];
+ * @param {Array.<string>} colors A list of colored.
+ * @return {Uint8ClampedArray} An array.
+ * @private
+ol.layer.Heatmap.createGradient_ = function(colors) {
+ var width = 1;
+ var height = 256;
+ var context = ol.dom.createCanvasContext2D(width, height);
+ var gradient = context.createLinearGradient(0, 0, width, height);
+ var step = 1 / (colors.length - 1);
+ for (var i = 0, ii = colors.length; i < ii; ++i) {
+ gradient.addColorStop(i * step, colors[i]);
+ context.fillStyle = gradient;
+ context.fillRect(0, 0, width, height);
+ return context.getImageData(0, 0, width, height).data;
+ * @return {string} Data URL for a circle.
+ * @private
+ol.layer.Heatmap.prototype.createCircle_ = function() {
+ var radius = this.getRadius();
+ var blur = this.getBlur();
+ var halfSize = radius + blur + 1;
+ var size = 2 * halfSize;
+ var context = ol.dom.createCanvasContext2D(size, size);
+ context.shadowOffsetX = context.shadowOffsetY = this.shadow_;
+ context.shadowBlur = blur;
+ context.shadowColor = '#000';
+ context.beginPath();
+ var center = halfSize - this.shadow_;
+ context.arc(center, center, radius, 0, Math.PI * 2, true);
+ context.fill();
+ return context.canvas.toDataURL();
+ * Return the blur size in pixels.
+ * @return {number} Blur size in pixels.
+ * @api
+ * @observable
+ol.layer.Heatmap.prototype.getBlur = function() {
+ return /** @type {number} */ (this.get(ol.layer.Heatmap.Property_.BLUR));
+ * Return the gradient colors as array of strings.
+ * @return {Array.<string>} Colors.
+ * @api
+ * @observable
+ol.layer.Heatmap.prototype.getGradient = function() {
+ return /** @type {Array.<string>} */ (
+ this.get(ol.layer.Heatmap.Property_.GRADIENT));
+ * Return the size of the radius in pixels.
+ * @return {number} Radius size in pixel.
+ * @api
+ * @observable
+ol.layer.Heatmap.prototype.getRadius = function() {
+ return /** @type {number} */ (this.get(ol.layer.Heatmap.Property_.RADIUS));
+ * @private
+ol.layer.Heatmap.prototype.handleGradientChanged_ = function() {
+ this.gradient_ = ol.layer.Heatmap.createGradient_(this.getGradient());
+ * @private
+ol.layer.Heatmap.prototype.handleStyleChanged_ = function() {
+ this.circleImage_ = this.createCircle_();
+ this.styleCache_ = new Array(256);
+ this.changed();
+ * @param {ol.render.Event} event Post compose event
+ * @private
+ol.layer.Heatmap.prototype.handleRender_ = function(event) {
+ var context = event.context;
+ var canvas = context.canvas;
+ var image = context.getImageData(0, 0, canvas.width, canvas.height);
+ var view8 = image.data;
+ var i, ii, alpha;
+ for (i = 0, ii = view8.length; i < ii; i += 4) {
+ alpha = view8[i + 3] * 4;
+ if (alpha) {
+ view8[i] = this.gradient_[alpha];
+ view8[i + 1] = this.gradient_[alpha + 1];
+ view8[i + 2] = this.gradient_[alpha + 2];
+ context.putImageData(image, 0, 0);
+ * Set the blur size in pixels.
+ * @param {number} blur Blur size in pixels.
+ * @api
+ * @observable
+ol.layer.Heatmap.prototype.setBlur = function(blur) {
+ this.set(ol.layer.Heatmap.Property_.BLUR, blur);
+ * Set the gradient colors as array of strings.
+ * @param {Array.<string>} colors Gradient.
+ * @api
+ * @observable
+ol.layer.Heatmap.prototype.setGradient = function(colors) {
+ this.set(ol.layer.Heatmap.Property_.GRADIENT, colors);
+ * Set the size of the radius in pixels.
+ * @param {number} radius Radius size in pixel.
+ * @api
+ * @observable
+ol.layer.Heatmap.prototype.setRadius = function(radius) {
+ this.set(ol.layer.Heatmap.Property_.RADIUS, radius);
+ * @enum {string}
+ * @private
+ol.layer.Heatmap.Property_ = {
+ BLUR: 'blur',
+ GRADIENT: 'gradient',
+ RADIUS: 'radius'
+goog.provide('ol.renderer.canvas.IntermediateCanvas');
+goog.require('ol.renderer.canvas.Layer');
+goog.require('ol.transform');
+ * @constructor
+ * @abstract
+ * @extends {ol.renderer.canvas.Layer}
+ol.renderer.canvas.IntermediateCanvas = function(layer) {
+ ol.renderer.canvas.Layer.call(this, layer);
+ * @protected
+ * @type {ol.Transform}
+ this.coordinateToCanvasPixelTransform = ol.transform.create();
+ * @private
+ * @type {CanvasRenderingContext2D}
+ this.hitCanvasContext_ = null;
+ol.inherits(ol.renderer.canvas.IntermediateCanvas, ol.renderer.canvas.Layer);
+ * @inheritDoc
+ol.renderer.canvas.IntermediateCanvas.prototype.composeFrame = function(frameState, layerState, context) {
+ this.preCompose(context, frameState);
+ var image = this.getImage();
+ if (image) {
+ // clipped rendering if layer extent is set
+ var extent = layerState.extent;
+ var clipped = extent !== undefined &&
+ !ol.extent.containsExtent(extent, frameState.extent) &&
+ ol.extent.intersects(extent, frameState.extent);
+ if (clipped) {
+ this.clip(context, frameState, /** @type {ol.Extent} */ (extent));
+ var imageTransform = this.getImageTransform();
+ // for performance reasons, context.save / context.restore is not used
+ // to save and restore the transformation matrix and the opacity.
+ // see http://jsperf.com/context-save-restore-versus-variable
+ var alpha = context.globalAlpha;
+ context.globalAlpha = layerState.opacity;
+ // for performance reasons, context.setTransform is only used
+ // when the view is rotated. see http://jsperf.com/canvas-transform
+ var dx = imageTransform[4];
+ var dy = imageTransform[5];
+ var dw = image.width * imageTransform[0];
+ var dh = image.height * imageTransform[3];
+ context.drawImage(image, 0, 0, +image.width, +image.height,
+ Math.round(dx), Math.round(dy), Math.round(dw), Math.round(dh));
+ context.globalAlpha = alpha;
+ if (clipped) {
+ context.restore();
+ this.postCompose(context, frameState, layerState);
+ * @abstract
+ * @return {HTMLCanvasElement|HTMLVideoElement|Image} Canvas.
+ol.renderer.canvas.IntermediateCanvas.prototype.getImage = function() {};
+ * @abstract
+ * @return {!ol.Transform} Image transform.
+ol.renderer.canvas.IntermediateCanvas.prototype.getImageTransform = function() {};
+ * @inheritDoc
+ol.renderer.canvas.IntermediateCanvas.prototype.forEachFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, callback, thisArg) {
+ var layer = this.getLayer();
+ var source = layer.getSource();
+ var resolution = frameState.viewState.resolution;
+ var rotation = frameState.viewState.rotation;
+ var skippedFeatureUids = frameState.skippedFeatureUids;
+ return source.forEachFeatureAtCoordinate(
+ coordinate, resolution, rotation, hitTolerance, skippedFeatureUids,
+ * @return {?} Callback result.
+ return callback.call(thisArg, feature, layer);
+ * @inheritDoc
+ol.renderer.canvas.IntermediateCanvas.prototype.forEachLayerAtCoordinate = function(coordinate, frameState, callback, thisArg) {
+ if (!this.getImage()) {
+ return undefined;
+ if (this.getLayer().getSource().forEachFeatureAtCoordinate !== ol.nullFunction) {
+ // for ImageVector sources use the original hit-detection logic,
+ // so that for example also transparent polygons are detected
+ return ol.renderer.canvas.Layer.prototype.forEachLayerAtCoordinate.apply(this, arguments);
+ } else {
+ var pixel = ol.transform.apply(this.coordinateToCanvasPixelTransform, coordinate.slice());
+ ol.coordinate.scale(pixel, frameState.viewState.resolution / this.renderedResolution);
+ if (!this.hitCanvasContext_) {
+ this.hitCanvasContext_ = ol.dom.createCanvasContext2D(1, 1);
+ this.hitCanvasContext_.clearRect(0, 0, 1, 1);
+ this.hitCanvasContext_.drawImage(this.getImage(), pixel[0], pixel[1], 1, 1, 0, 0, 1, 1);
+ var imageData = this.hitCanvasContext_.getImageData(0, 0, 1, 1).data;
+ if (imageData[3] > 0) {
+ return callback.call(thisArg, this.getLayer(), imageData);
+ } else {
+ return undefined;
+goog.provide('ol.renderer.canvas.ImageLayer');
+goog.require('ol.ViewHint');
+goog.require('ol.extent');
+goog.require('ol.renderer.canvas.IntermediateCanvas');
+ * @constructor
+ * @extends {ol.renderer.canvas.IntermediateCanvas}
+ * @param {ol.layer.Image} imageLayer Single image layer.
+ol.renderer.canvas.ImageLayer = function(imageLayer) {
+ ol.renderer.canvas.IntermediateCanvas.call(this, imageLayer);
+ * @private
+ * @type {?ol.ImageBase}
+ this.image_ = null;
+ * @private
+ this.imageTransform_ = ol.transform.create();
+ol.inherits(ol.renderer.canvas.ImageLayer, ol.renderer.canvas.IntermediateCanvas);
+ * @inheritDoc
+ol.renderer.canvas.ImageLayer.prototype.getImage = function() {
+ return !this.image_ ? null : this.image_.getImage();
+ * @inheritDoc
+ol.renderer.canvas.ImageLayer.prototype.getImageTransform = function() {
+ return this.imageTransform_;
+ * @inheritDoc
+ol.renderer.canvas.ImageLayer.prototype.prepareFrame = function(frameState, layerState) {
+ var pixelRatio = frameState.pixelRatio;
+ var size = frameState.size;
+ var viewState = frameState.viewState;
+ var viewCenter = viewState.center;
+ var viewResolution = viewState.resolution;
+ var image;
+ var imageLayer = /** @type {ol.layer.Image} */ (this.getLayer());
+ var imageSource = imageLayer.getSource();
+ var hints = frameState.viewHints;
+ var renderedExtent = frameState.extent;
+ if (layerState.extent !== undefined) {
+ renderedExtent = ol.extent.getIntersection(
+ renderedExtent, layerState.extent);
+ if (!hints[ol.ViewHint.ANIMATING] && !hints[ol.ViewHint.INTERACTING] &&
+ !ol.extent.isEmpty(renderedExtent)) {
+ var projection = viewState.projection;
+ if (!ol.ENABLE_RASTER_REPROJECTION) {
+ var sourceProjection = imageSource.getProjection();
+ if (sourceProjection) {
+ projection = sourceProjection;
+ image = imageSource.getImage(
+ renderedExtent, viewResolution, pixelRatio, projection);
+ if (image) {
+ var loaded = this.loadImage(image);
+ if (loaded) {
+ this.image_ = image;
+ if (this.image_) {
+ image = this.image_;
+ var imageExtent = image.getExtent();
+ var imageResolution = image.getResolution();
+ var imagePixelRatio = image.getPixelRatio();
+ var scale = pixelRatio * imageResolution /
+ (viewResolution * imagePixelRatio);
+ var transform = ol.transform.compose(this.imageTransform_,
+ pixelRatio * size[0] / 2, pixelRatio * size[1] / 2,
+ scale, scale,
+ 0,
+ imagePixelRatio * (imageExtent[0] - viewCenter[0]) / imageResolution,
+ imagePixelRatio * (viewCenter[1] - imageExtent[3]) / imageResolution);
+ ol.transform.compose(this.coordinateToCanvasPixelTransform,
+ pixelRatio * size[0] / 2 - transform[4], pixelRatio * size[1] / 2 - transform[5],
+ pixelRatio / viewResolution, -pixelRatio / viewResolution,
+ 0,
+ -viewCenter[0], -viewCenter[1]);
+ this.updateAttributions(frameState.attributions, image.getAttributions());
+ this.updateLogos(frameState, imageSource);
+ this.renderedResolution = viewResolution * pixelRatio / imagePixelRatio;
+ return !!this.image_;
+goog.provide('ol.reproj');
+goog.require('ol.proj');
+ * Calculates ideal resolution to use from the source in order to achieve
+ * pixel mapping as close as possible to 1:1 during reprojection.
+ * The resolution is calculated regardless of what resolutions
+ * are actually available in the dataset (TileGrid, Image, ...).
+ * @param {ol.proj.Projection} sourceProj Source projection.
+ * @param {ol.proj.Projection} targetProj Target projection.
+ * @param {ol.Coordinate} targetCenter Target center.
+ * @param {number} targetResolution Target resolution.
+ * @return {number} The best resolution to use. Can be +-Infinity, NaN or 0.
+ol.reproj.calculateSourceResolution = function(sourceProj, targetProj,
+ targetCenter, targetResolution) {
+ var sourceCenter = ol.proj.transform(targetCenter, targetProj, sourceProj);
+ // calculate the ideal resolution of the source data
+ var sourceResolution =
+ ol.proj.getPointResolution(targetProj, targetResolution, targetCenter);
+ var targetMetersPerUnit = targetProj.getMetersPerUnit();
+ if (targetMetersPerUnit !== undefined) {
+ sourceResolution *= targetMetersPerUnit;
+ var sourceMetersPerUnit = sourceProj.getMetersPerUnit();
+ if (sourceMetersPerUnit !== undefined) {
+ sourceResolution /= sourceMetersPerUnit;
+ // Based on the projection properties, the point resolution at the specified
+ // coordinates may be slightly different. We need to reverse-compensate this
+ // in order to achieve optimal results.
+ var compensationFactor =
+ ol.proj.getPointResolution(sourceProj, sourceResolution, sourceCenter) /
+ sourceResolution;
+ if (isFinite(compensationFactor) && compensationFactor > 0) {
+ sourceResolution /= compensationFactor;
+ return sourceResolution;
+ * Enlarge the clipping triangle point by 1 pixel to ensure the edges overlap
+ * in order to mask gaps caused by antialiasing.
+ * @param {number} centroidX Centroid of the triangle (x coordinate in pixels).
+ * @param {number} centroidY Centroid of the triangle (y coordinate in pixels).
+ * @param {number} x X coordinate of the point (in pixels).
+ * @param {number} y Y coordinate of the point (in pixels).
+ * @return {ol.Coordinate} New point 1 px farther from the centroid.
+ * @private
+ol.reproj.enlargeClipPoint_ = function(centroidX, centroidY, x, y) {
+ var dX = x - centroidX, dY = y - centroidY;
+ var distance = Math.sqrt(dX * dX + dY * dY);
+ return [Math.round(x + dX / distance), Math.round(y + dY / distance)];
+ * Renders the source data into new canvas based on the triangulation.
+ * @param {number} width Width of the canvas.
+ * @param {number} height Height of the canvas.
+ * @param {number} pixelRatio Pixel ratio.
+ * @param {number} sourceResolution Source resolution.
+ * @param {ol.Extent} sourceExtent Extent of the data source.
+ * @param {ol.Extent} targetExtent Target extent.
+ * @param {ol.reproj.Triangulation} triangulation Calculated triangulation.
+ * @param {Array.<{extent: ol.Extent,
+ * image: (HTMLCanvasElement|Image|HTMLVideoElement)}>} sources
+ * Array of sources.
+ * @param {number} gutter Gutter of the sources.
+ * @param {boolean=} opt_renderEdges Render reprojection edges.
+ * @return {HTMLCanvasElement} Canvas with reprojected data.
+ol.reproj.render = function(width, height, pixelRatio,
+ sourceResolution, sourceExtent, targetResolution, targetExtent,
+ triangulation, sources, gutter, opt_renderEdges) {
+ var context = ol.dom.createCanvasContext2D(Math.round(pixelRatio * width),
+ Math.round(pixelRatio * height));
+ if (sources.length === 0) {
+ return context.canvas;
+ context.scale(pixelRatio, pixelRatio);
+ var sourceDataExtent = ol.extent.createEmpty();
+ sources.forEach(function(src, i, arr) {
+ ol.extent.extend(sourceDataExtent, src.extent);
+ var canvasWidthInUnits = ol.extent.getWidth(sourceDataExtent);
+ var canvasHeightInUnits = ol.extent.getHeight(sourceDataExtent);
+ var stitchContext = ol.dom.createCanvasContext2D(
+ Math.round(pixelRatio * canvasWidthInUnits / sourceResolution),
+ Math.round(pixelRatio * canvasHeightInUnits / sourceResolution));
+ var stitchScale = pixelRatio / sourceResolution;
+ var xPos = src.extent[0] - sourceDataExtent[0];
+ var yPos = -(src.extent[3] - sourceDataExtent[3]);
+ var srcWidth = ol.extent.getWidth(src.extent);
+ var srcHeight = ol.extent.getHeight(src.extent);
+ stitchContext.drawImage(
+ src.image,
+ gutter, gutter,
+ src.image.width - 2 * gutter, src.image.height - 2 * gutter,
+ xPos * stitchScale, yPos * stitchScale,
+ srcWidth * stitchScale, srcHeight * stitchScale);
+ var targetTopLeft = ol.extent.getTopLeft(targetExtent);
+ triangulation.getTriangles().forEach(function(triangle, i, arr) {
+ /* Calculate affine transform (src -> dst)
+ * Resulting matrix can be used to transform coordinate
+ * from `sourceProjection` to destination pixels.
+ * To optimize number of context calls and increase numerical stability,
+ * we also do the following operations:
+ * trans(-topLeftExtentCorner), scale(1 / targetResolution), scale(1, -1)
+ * here before solving the linear system so [ui, vi] are pixel coordinates.
+ * Src points: xi, yi
+ * Dst points: ui, vi
+ * Affine coefficients: aij
+ * | x0 y0 1 0 0 0 | |a00| |u0|
+ * | x1 y1 1 0 0 0 | |a01| |u1|
+ * | x2 y2 1 0 0 0 | x |a02| = |u2|
+ * | 0 0 0 x0 y0 1 | |a10| |v0|
+ * | 0 0 0 x1 y1 1 | |a11| |v1|
+ * | 0 0 0 x2 y2 1 | |a12| |v2|
+ var source = triangle.source, target = triangle.target;
+ var x0 = source[0][0], y0 = source[0][1],
+ x1 = source[1][0], y1 = source[1][1],
+ x2 = source[2][0], y2 = source[2][1];
+ var u0 = (target[0][0] - targetTopLeft[0]) / targetResolution,
+ v0 = -(target[0][1] - targetTopLeft[1]) / targetResolution;
+ var u1 = (target[1][0] - targetTopLeft[0]) / targetResolution,
+ v1 = -(target[1][1] - targetTopLeft[1]) / targetResolution;
+ var u2 = (target[2][0] - targetTopLeft[0]) / targetResolution,
+ v2 = -(target[2][1] - targetTopLeft[1]) / targetResolution;
+ // Shift all the source points to improve numerical stability
+ // of all the subsequent calculations. The [x0, y0] is used here.
+ // This is also used to simplify the linear system.
+ var sourceNumericalShiftX = x0, sourceNumericalShiftY = y0;
+ x0 = 0;
+ y0 = 0;
+ x1 -= sourceNumericalShiftX;
+ y1 -= sourceNumericalShiftY;
+ x2 -= sourceNumericalShiftX;
+ y2 -= sourceNumericalShiftY;
+ var augmentedMatrix = [
+ [x1, y1, 0, 0, u1 - u0],
+ [x2, y2, 0, 0, u2 - u0],
+ [0, 0, x1, y1, v1 - v0],
+ [0, 0, x2, y2, v2 - v0]
+ var affineCoefs = ol.math.solveLinearSystem(augmentedMatrix);
+ if (!affineCoefs) {
+ return;
+ context.save();
+ var centroidX = (u0 + u1 + u2) / 3, centroidY = (v0 + v1 + v2) / 3;
+ var p0 = ol.reproj.enlargeClipPoint_(centroidX, centroidY, u0, v0);
+ var p1 = ol.reproj.enlargeClipPoint_(centroidX, centroidY, u1, v1);
+ var p2 = ol.reproj.enlargeClipPoint_(centroidX, centroidY, u2, v2);
+ context.moveTo(p1[0], p1[1]);
+ context.lineTo(p0[0], p0[1]);
+ context.lineTo(p2[0], p2[1]);
+ context.clip();
+ context.transform(
+ affineCoefs[0], affineCoefs[2], affineCoefs[1], affineCoefs[3], u0, v0);
+ context.translate(sourceDataExtent[0] - sourceNumericalShiftX,
+ sourceDataExtent[3] - sourceNumericalShiftY);
+ context.scale(sourceResolution / pixelRatio,
+ -sourceResolution / pixelRatio);
+ context.drawImage(stitchContext.canvas, 0, 0);
+ if (opt_renderEdges) {
+ context.save();
+ context.strokeStyle = 'black';
+ context.lineWidth = 1;
+ var target = triangle.target;
+ context.moveTo(u1, v1);
+ context.lineTo(u0, v0);
+ context.lineTo(u2, v2);
+ context.closePath();
+ context.stroke();
+goog.provide('ol.reproj.Triangulation');
+ * @classdesc
+ * Class containing triangulation of the given target extent.
+ * Used for determining source data and the reprojection itself.
+ * @param {ol.Extent} targetExtent Target extent to triangulate.
+ * @param {ol.Extent} maxSourceExtent Maximal source extent that can be used.
+ * @param {number} errorThreshold Acceptable error (in source units).
+ * @constructor
+ol.reproj.Triangulation = function(sourceProj, targetProj, targetExtent,
+ maxSourceExtent, errorThreshold) {
+ * @type {ol.proj.Projection}
+ * @private
+ this.sourceProj_ = sourceProj;
+ * @private
+ this.targetProj_ = targetProj;
+ /** @type {!Object.<string, ol.Coordinate>} */
+ var transformInvCache = {};
+ var transformInv = ol.proj.getTransform(this.targetProj_, this.sourceProj_);
+ * @param {ol.Coordinate} c A coordinate.
+ * @return {ol.Coordinate} Transformed coordinate.
+ * @private
+ this.transformInv_ = function(c) {
+ var key = c[0] + '/' + c[1];
+ if (!transformInvCache[key]) {
+ transformInvCache[key] = transformInv(c);
+ return transformInvCache[key];
+ * @type {ol.Extent}
+ * @private
+ this.maxSourceExtent_ = maxSourceExtent;
+ * @type {number}
+ * @private
+ this.errorThresholdSquared_ = errorThreshold * errorThreshold;
+ * @type {Array.<ol.ReprojTriangle>}
+ * @private
+ this.triangles_ = [];
+ * Indicates that the triangulation crosses edge of the source projection.
+ * @type {boolean}
+ * @private
+ this.wrapsXInSource_ = false;
+ * @type {boolean}
+ * @private
+ this.canWrapXInSource_ = this.sourceProj_.canWrapX() &&
+ !!maxSourceExtent &&
+ !!this.sourceProj_.getExtent() &&
+ (ol.extent.getWidth(maxSourceExtent) ==
+ ol.extent.getWidth(this.sourceProj_.getExtent()));
+ * @type {?number}
+ * @private
+ this.sourceWorldWidth_ = this.sourceProj_.getExtent() ?
+ ol.extent.getWidth(this.sourceProj_.getExtent()) : null;
+ * @type {?number}
+ * @private
+ this.targetWorldWidth_ = this.targetProj_.getExtent() ?
+ ol.extent.getWidth(this.targetProj_.getExtent()) : null;
+ var destinationTopLeft = ol.extent.getTopLeft(targetExtent);
+ var destinationTopRight = ol.extent.getTopRight(targetExtent);
+ var destinationBottomRight = ol.extent.getBottomRight(targetExtent);
+ var destinationBottomLeft = ol.extent.getBottomLeft(targetExtent);
+ var sourceTopLeft = this.transformInv_(destinationTopLeft);
+ var sourceTopRight = this.transformInv_(destinationTopRight);
+ var sourceBottomRight = this.transformInv_(destinationBottomRight);
+ var sourceBottomLeft = this.transformInv_(destinationBottomLeft);
+ this.addQuad_(
+ destinationTopLeft, destinationTopRight,
+ destinationBottomRight, destinationBottomLeft,
+ sourceTopLeft, sourceTopRight, sourceBottomRight, sourceBottomLeft,
+ ol.RASTER_REPROJECTION_MAX_SUBDIVISION);
+ if (this.wrapsXInSource_) {
+ var leftBound = Infinity;
+ this.triangles_.forEach(function(triangle, i, arr) {
+ leftBound = Math.min(leftBound,
+ triangle.source[0][0], triangle.source[1][0], triangle.source[2][0]);
+ // Shift triangles to be as close to `leftBound` as possible
+ // (if the distance is more than `worldWidth / 2` it can be closer.
+ this.triangles_.forEach(function(triangle) {
+ if (Math.max(triangle.source[0][0], triangle.source[1][0],
+ triangle.source[2][0]) - leftBound > this.sourceWorldWidth_ / 2) {
+ var newTriangle = [[triangle.source[0][0], triangle.source[0][1]],
+ [triangle.source[1][0], triangle.source[1][1]],
+ [triangle.source[2][0], triangle.source[2][1]]];
+ if ((newTriangle[0][0] - leftBound) > this.sourceWorldWidth_ / 2) {
+ newTriangle[0][0] -= this.sourceWorldWidth_;
+ if ((newTriangle[1][0] - leftBound) > this.sourceWorldWidth_ / 2) {
+ newTriangle[1][0] -= this.sourceWorldWidth_;
+ if ((newTriangle[2][0] - leftBound) > this.sourceWorldWidth_ / 2) {
+ newTriangle[2][0] -= this.sourceWorldWidth_;
+ // Rarely (if the extent contains both the dateline and prime meridian)
+ // the shift can in turn break some triangles.
+ // Detect this here and don't shift in such cases.
+ var minX = Math.min(
+ newTriangle[0][0], newTriangle[1][0], newTriangle[2][0]);
+ var maxX = Math.max(
+ if ((maxX - minX) < this.sourceWorldWidth_ / 2) {
+ triangle.source = newTriangle;
+ }, this);
+ transformInvCache = {};
+ * Adds triangle to the triangulation.
+ * @param {ol.Coordinate} a The target a coordinate.
+ * @param {ol.Coordinate} b The target b coordinate.
+ * @param {ol.Coordinate} c The target c coordinate.
+ * @param {ol.Coordinate} aSrc The source a coordinate.
+ * @param {ol.Coordinate} bSrc The source b coordinate.
+ * @param {ol.Coordinate} cSrc The source c coordinate.
+ * @private
+ol.reproj.Triangulation.prototype.addTriangle_ = function(a, b, c,
+ aSrc, bSrc, cSrc) {
+ this.triangles_.push({
+ source: [aSrc, bSrc, cSrc],
+ target: [a, b, c]
+ * Adds quad (points in clock-wise order) to the triangulation
+ * (and reprojects the vertices) if valid.
+ * Performs quad subdivision if needed to increase precision.
+ * @param {ol.Coordinate} d The target d coordinate.
+ * @param {ol.Coordinate} dSrc The source d coordinate.
+ * @param {number} maxSubdivision Maximal allowed subdivision of the quad.
+ * @private
+ol.reproj.Triangulation.prototype.addQuad_ = function(a, b, c, d,
+ aSrc, bSrc, cSrc, dSrc, maxSubdivision) {
+ var sourceQuadExtent = ol.extent.boundingExtent([aSrc, bSrc, cSrc, dSrc]);
+ var sourceCoverageX = this.sourceWorldWidth_ ?
+ ol.extent.getWidth(sourceQuadExtent) / this.sourceWorldWidth_ : null;
+ var sourceWorldWidth = /** @type {number} */ (this.sourceWorldWidth_);
+ // when the quad is wrapped in the source projection
+ // it covers most of the projection extent, but not fully
+ var wrapsX = this.sourceProj_.canWrapX() &&
+ sourceCoverageX > 0.5 && sourceCoverageX < 1;
+ var needsSubdivision = false;
+ if (maxSubdivision > 0) {
+ if (this.targetProj_.isGlobal() && this.targetWorldWidth_) {
+ var targetQuadExtent = ol.extent.boundingExtent([a, b, c, d]);
+ var targetCoverageX =
+ ol.extent.getWidth(targetQuadExtent) / this.targetWorldWidth_;
+ needsSubdivision |=
+ targetCoverageX > ol.RASTER_REPROJECTION_MAX_TRIANGLE_WIDTH;
+ if (!wrapsX && this.sourceProj_.isGlobal() && sourceCoverageX) {
+ sourceCoverageX > ol.RASTER_REPROJECTION_MAX_TRIANGLE_WIDTH;
+ if (!needsSubdivision && this.maxSourceExtent_) {
+ if (!ol.extent.intersects(sourceQuadExtent, this.maxSourceExtent_)) {
+ // whole quad outside source projection extent -> ignore
+ return;
+ if (!needsSubdivision) {
+ if (!isFinite(aSrc[0]) || !isFinite(aSrc[1]) ||
+ !isFinite(bSrc[0]) || !isFinite(bSrc[1]) ||
+ !isFinite(cSrc[0]) || !isFinite(cSrc[1]) ||
+ !isFinite(dSrc[0]) || !isFinite(dSrc[1])) {
+ needsSubdivision = true;
+ } else {
+ return;
+ var center = [(a[0] + c[0]) / 2, (a[1] + c[1]) / 2];
+ var centerSrc = this.transformInv_(center);
+ var dx;
+ if (wrapsX) {
+ var centerSrcEstimX =
+ (ol.math.modulo(aSrc[0], sourceWorldWidth) +
+ ol.math.modulo(cSrc[0], sourceWorldWidth)) / 2;
+ dx = centerSrcEstimX -
+ ol.math.modulo(centerSrc[0], sourceWorldWidth);
+ } else {
+ dx = (aSrc[0] + cSrc[0]) / 2 - centerSrc[0];
+ var dy = (aSrc[1] + cSrc[1]) / 2 - centerSrc[1];
+ var centerSrcErrorSquared = dx * dx + dy * dy;
+ needsSubdivision = centerSrcErrorSquared > this.errorThresholdSquared_;
+ if (needsSubdivision) {
+ if (Math.abs(a[0] - c[0]) <= Math.abs(a[1] - c[1])) {
+ // split horizontally (top & bottom)
+ var bc = [(b[0] + c[0]) / 2, (b[1] + c[1]) / 2];
+ var bcSrc = this.transformInv_(bc);
+ var da = [(d[0] + a[0]) / 2, (d[1] + a[1]) / 2];
+ var daSrc = this.transformInv_(da);
+ this.addQuad_(
+ a, b, bc, da, aSrc, bSrc, bcSrc, daSrc, maxSubdivision - 1);
+ this.addQuad_(
+ da, bc, c, d, daSrc, bcSrc, cSrc, dSrc, maxSubdivision - 1);
+ } else {
+ // split vertically (left & right)
+ var ab = [(a[0] + b[0]) / 2, (a[1] + b[1]) / 2];
+ var abSrc = this.transformInv_(ab);
+ var cd = [(c[0] + d[0]) / 2, (c[1] + d[1]) / 2];
+ var cdSrc = this.transformInv_(cd);
+ this.addQuad_(
+ a, ab, cd, d, aSrc, abSrc, cdSrc, dSrc, maxSubdivision - 1);
+ this.addQuad_(
+ ab, b, c, cd, abSrc, bSrc, cSrc, cdSrc, maxSubdivision - 1);
+ return;
+ if (wrapsX) {
+ if (!this.canWrapXInSource_) {
+ return;
+ this.wrapsXInSource_ = true;
+ this.addTriangle_(a, c, d, aSrc, cSrc, dSrc);
+ this.addTriangle_(a, b, c, aSrc, bSrc, cSrc);
+ * Calculates extent of the 'source' coordinates from all the triangles.
+ * @return {ol.Extent} Calculated extent.
+ol.reproj.Triangulation.prototype.calculateSourceExtent = function() {
+ var extent = ol.extent.createEmpty();
+ var src = triangle.source;
+ ol.extent.extendCoordinate(extent, src[0]);
+ ol.extent.extendCoordinate(extent, src[1]);
+ ol.extent.extendCoordinate(extent, src[2]);
+ return extent;
+ * @return {Array.<ol.ReprojTriangle>} Array of the calculated triangles.
+ol.reproj.Triangulation.prototype.getTriangles = function() {
+ return this.triangles_;
+goog.provide('ol.reproj.Image');
+goog.require('ol.ImageBase');
+goog.require('ol.ImageState');
+goog.require('ol.events.EventType');
+goog.require('ol.reproj');
+goog.require('ol.reproj.Triangulation');
+ * @classdesc
+ * Class encapsulating single reprojected image.
+ * See {@link ol.source.Image}.
+ * @constructor
+ * @extends {ol.ImageBase}
+ * @param {ol.proj.Projection} sourceProj Source projection (of the data).
+ * @param {ol.ReprojImageFunctionType} getImageFunction
+ * Function returning source images (extent, resolution, pixelRatio).
+ol.reproj.Image = function(sourceProj, targetProj,
+ targetExtent, targetResolution, pixelRatio, getImageFunction) {
+ * @private
+ * @private
+ this.maxSourceExtent_ = sourceProj.getExtent();
+ var maxTargetExtent = targetProj.getExtent();
+ var limitedTargetExtent = maxTargetExtent ?
+ ol.extent.getIntersection(targetExtent, maxTargetExtent) : targetExtent;
+ var targetCenter = ol.extent.getCenter(limitedTargetExtent);
+ var sourceResolution = ol.reproj.calculateSourceResolution(
+ sourceProj, targetProj, targetCenter, targetResolution);
+ var errorThresholdInPixels = ol.DEFAULT_RASTER_REPROJECTION_ERROR_THRESHOLD;
+ * @private
+ * @type {!ol.reproj.Triangulation}
+ this.triangulation_ = new ol.reproj.Triangulation(
+ sourceProj, targetProj, limitedTargetExtent, this.maxSourceExtent_,
+ sourceResolution * errorThresholdInPixels);
+ * @private
+ * @type {number}
+ this.targetResolution_ = targetResolution;
+ * @private
+ this.targetExtent_ = targetExtent;
+ var sourceExtent = this.triangulation_.calculateSourceExtent();
+ * @private
+ * @type {ol.ImageBase}
+ this.sourceImage_ =
+ getImageFunction(sourceExtent, sourceResolution, pixelRatio);
+ * @private
+ * @type {number}
+ this.sourcePixelRatio_ =
+ this.sourceImage_ ? this.sourceImage_.getPixelRatio() : 1;
+ * @private
+ * @type {HTMLCanvasElement}
+ this.canvas_ = null;
+ * @private
+ * @type {?ol.EventsKey}
+ this.sourceListenerKey_ = null;
+ var state = ol.ImageState.LOADED;
+ var attributions = [];
+ if (this.sourceImage_) {
+ state = ol.ImageState.IDLE;
+ attributions = this.sourceImage_.getAttributions();
+ ol.ImageBase.call(this, targetExtent, targetResolution, this.sourcePixelRatio_,
+ state, attributions);
+ol.inherits(ol.reproj.Image, ol.ImageBase);
+ * @inheritDoc
+ol.reproj.Image.prototype.disposeInternal = function() {
+ if (this.state == ol.ImageState.LOADING) {
+ this.unlistenSource_();
+ ol.ImageBase.prototype.disposeInternal.call(this);
+ * @inheritDoc
+ol.reproj.Image.prototype.getImage = function(opt_context) {
+ return this.canvas_;
+ * @return {ol.proj.Projection} Projection.
+ol.reproj.Image.prototype.getProjection = function() {
+ return this.targetProj_;
+ * @private
+ol.reproj.Image.prototype.reproject_ = function() {
+ var sourceState = this.sourceImage_.getState();
+ if (sourceState == ol.ImageState.LOADED) {
+ var width = ol.extent.getWidth(this.targetExtent_) / this.targetResolution_;
+ var height =
+ ol.extent.getHeight(this.targetExtent_) / this.targetResolution_;
+ this.canvas_ = ol.reproj.render(width, height, this.sourcePixelRatio_,
+ this.sourceImage_.getResolution(), this.maxSourceExtent_,
+ this.targetResolution_, this.targetExtent_, this.triangulation_, [{
+ extent: this.sourceImage_.getExtent(),
+ image: this.sourceImage_.getImage()
+ }], 0);
+ this.state = sourceState;
+ this.changed();
+ * @inheritDoc
+ol.reproj.Image.prototype.load = function() {
+ if (this.state == ol.ImageState.IDLE) {
+ this.state = ol.ImageState.LOADING;
+ this.changed();
+ if (sourceState == ol.ImageState.LOADED ||
+ sourceState == ol.ImageState.ERROR) {
+ this.reproject_();
+ } else {
+ this.sourceListenerKey_ = ol.events.listen(this.sourceImage_,
+ ol.events.EventType.CHANGE, function(e) {
+ }, this);
+ this.sourceImage_.load();
+ * @private
+ol.reproj.Image.prototype.unlistenSource_ = function() {
+ ol.events.unlistenByKey(/** @type {!ol.EventsKey} */ (this.sourceListenerKey_));
+goog.provide('ol.source.Image');
+goog.require('ol.reproj.Image');
+goog.require('ol.source.Source');
+ * @classdesc
+ * Abstract base class; normally only used for creating subclasses and not
+ * instantiated in apps.
+ * Base class for sources providing a single image.
+ * @constructor
+ * @abstract
+ * @extends {ol.source.Source}
+ * @param {ol.SourceImageOptions} options Single image source options.
+ * @api
+ol.source.Image = function(options) {
+ ol.source.Source.call(this, {
+ attributions: options.attributions,
+ extent: options.extent,
+ logo: options.logo,
+ projection: options.projection,
+ state: options.state
+ * @private
+ * @type {Array.<number>}
+ this.resolutions_ = options.resolutions !== undefined ?
+ options.resolutions : null;
+ * @private
+ * @type {ol.reproj.Image}
+ this.reprojectedImage_ = null;
+ * @private
+ * @type {number}
+ this.reprojectedRevision_ = 0;
+ol.inherits(ol.source.Image, ol.source.Source);
+ * @return {Array.<number>} Resolutions.
+ * @override
+ol.source.Image.prototype.getResolutions = function() {
+ return this.resolutions_;
+ * @protected
+ * @param {number} resolution Resolution.
+ * @return {number} Resolution.
+ol.source.Image.prototype.findNearestResolution = function(resolution) {
+ if (this.resolutions_) {
+ var idx = ol.array.linearFindNearest(this.resolutions_, resolution, 0);
+ resolution = this.resolutions_[idx];
+ return resolution;
+ * @param {ol.Extent} extent Extent.
+ * @param {ol.proj.Projection} projection Projection.
+ * @return {ol.ImageBase} Single image.
+ol.source.Image.prototype.getImage = function(extent, resolution, pixelRatio, projection) {
+ var sourceProjection = this.getProjection();
+ if (!ol.ENABLE_RASTER_REPROJECTION ||
+ !sourceProjection ||
+ !projection ||
+ ol.proj.equivalent(sourceProjection, projection)) {
+ return this.getImageInternal(extent, resolution, pixelRatio, projection);
+ } else {
+ if (this.reprojectedImage_) {
+ if (this.reprojectedRevision_ == this.getRevision() &&
+ this.reprojectedImage_.getProjection(), projection) &&
+ this.reprojectedImage_.getResolution() == resolution &&
+ this.reprojectedImage_.getPixelRatio() == pixelRatio &&
+ ol.extent.equals(this.reprojectedImage_.getExtent(), extent)) {
+ return this.reprojectedImage_;
+ this.reprojectedImage_.dispose();
+ this.reprojectedImage_ = new ol.reproj.Image(
+ sourceProjection, projection, extent, resolution, pixelRatio,
+ function(extent, resolution, pixelRatio) {
+ pixelRatio, sourceProjection);
+ }.bind(this));
+ this.reprojectedRevision_ = this.getRevision();
+ * @abstract
+ * @protected
+ol.source.Image.prototype.getImageInternal = function(extent, resolution, pixelRatio, projection) {};
+ * Handle image change events.
+ * @param {ol.events.Event} event Event.
+ * @protected
+ol.source.Image.prototype.handleImageChange = function(event) {
+ var image = /** @type {ol.Image} */ (event.target);
+ switch (image.getState()) {
+ case ol.ImageState.LOADING:
+ this.dispatchEvent(
+ new ol.source.Image.Event(ol.source.Image.EventType_.IMAGELOADSTART,
+ image));
+ break;
+ case ol.ImageState.LOADED:
+ new ol.source.Image.Event(ol.source.Image.EventType_.IMAGELOADEND,
+ image));
+ break;
+ case ol.ImageState.ERROR:
+ new ol.source.Image.Event(ol.source.Image.EventType_.IMAGELOADERROR,
+ image));
+ break;
+ default:
+ // pass
+ * Default image load function for image sources that use ol.Image image
+ * instances.
+ * @param {ol.Image} image Image.
+ * @param {string} src Source.
+ol.source.Image.defaultImageLoadFunction = function(image, src) {
+ image.getImage().src = src;
+ * @classdesc
+ * Events emitted by {@link ol.source.Image} instances are instances of this
+ * type.
+ * @constructor
+ * @implements {oli.source.ImageEvent}
+ * @param {string} type Type.
+ * @param {ol.Image} image The image.
+ol.source.Image.Event = function(type, image) {
+ * The image related to the event.
+ * @type {ol.Image}
+ * @api
+ this.image = image;
+ol.inherits(ol.source.Image.Event, ol.events.Event);
+ * @enum {string}
+ * @private
+ol.source.Image.EventType_ = {
+ * Triggered when an image starts loading.
+ * @event ol.source.Image.Event#imageloadstart
+ * @api
+ IMAGELOADSTART: 'imageloadstart',
+ * Triggered when an image finishes loading.
+ * @event ol.source.Image.Event#imageloadend
+ * @api
+ IMAGELOADEND: 'imageloadend',
+ * Triggered if image loading results in an error.
+ * @event ol.source.Image.Event#imageloaderror
+ * @api
+ IMAGELOADERROR: 'imageloaderror'
+goog.provide('ol.source.ImageCanvas');
+goog.require('ol.ImageCanvas');
+goog.require('ol.source.Image');
+ * @classdesc
+ * Base class for image sources where a canvas element is the image.
+ * @constructor
+ * @extends {ol.source.Image}
+ * @param {olx.source.ImageCanvasOptions} options Constructor options.
+ * @api
+ol.source.ImageCanvas = function(options) {
+ ol.source.Image.call(this, {
+ resolutions: options.resolutions,
+ * @private
+ * @type {ol.CanvasFunctionType}
+ this.canvasFunction_ = options.canvasFunction;
+ * @private
+ * @type {ol.ImageCanvas}
+ * @private
+ * @type {number}
+ this.renderedRevision_ = 0;
+ * @private
+ * @type {number}
+ this.ratio_ = options.ratio !== undefined ?
+ options.ratio : 1.5;
+ol.inherits(ol.source.ImageCanvas, ol.source.Image);
+ * @inheritDoc
+ol.source.ImageCanvas.prototype.getImageInternal = function(extent, resolution, pixelRatio, projection) {
+ resolution = this.findNearestResolution(resolution);
+ var canvas = this.canvas_;
+ if (canvas &&
+ this.renderedRevision_ == this.getRevision() &&
+ canvas.getResolution() == resolution &&
+ canvas.getPixelRatio() == pixelRatio &&
+ ol.extent.containsExtent(canvas.getExtent(), extent)) {
+ return canvas;
+ extent = extent.slice();
+ ol.extent.scaleFromCenter(extent, this.ratio_);
+ var width = ol.extent.getWidth(extent) / resolution;
+ var height = ol.extent.getHeight(extent) / resolution;
+ var size = [width * pixelRatio, height * pixelRatio];
+ var canvasElement = this.canvasFunction_(
+ extent, resolution, pixelRatio, size, projection);
+ if (canvasElement) {
+ canvas = new ol.ImageCanvas(extent, resolution, pixelRatio,
+ this.getAttributions(), canvasElement);
+ this.canvas_ = canvas;
+ this.renderedRevision_ = this.getRevision();
+ return canvas;
+goog.provide('ol.source.ImageVector');
+goog.require('ol.render.canvas.ReplayGroup');
+goog.require('ol.renderer.vector');
+goog.require('ol.source.ImageCanvas');
+goog.require('ol.style.Style');
+ * @classdesc
+ * An image source whose images are canvas elements into which vector features
+ * read from a vector source (`ol.source.Vector`) are drawn. An
+ * `ol.source.ImageVector` object is to be used as the `source` of an image
+ * layer (`ol.layer.Image`). Image layers are rotated, scaled, and translated,
+ * as opposed to being re-rendered, during animations and interactions. So, like
+ * any other image layer, an image layer configured with an
+ * `ol.source.ImageVector` will exhibit this behaviour. This is in contrast to a
+ * vector layer, where vector features are re-drawn during animations and
+ * interactions.
+ * @constructor
+ * @extends {ol.source.ImageCanvas}
+ * @param {olx.source.ImageVectorOptions} options Options.
+ * @api
+ol.source.ImageVector = function(options) {
+ * @private
+ this.source_ = options.source;
+ * @private
+ this.transform_ = ol.transform.create();
+ * @private
+ this.canvasContext_ = ol.dom.createCanvasContext2D();
+ * @private
+ * @type {ol.Size}
+ this.canvasSize_ = [0, 0];
+ * @private
+ * @type {number}
+ this.renderBuffer_ = options.renderBuffer == undefined ? 100 : options.renderBuffer;
+ * @private
+ * @type {ol.render.canvas.ReplayGroup}
+ this.replayGroup_ = null;
+ ol.source.ImageCanvas.call(this, {
+ canvasFunction: this.canvasFunctionInternal_.bind(this),
+ ratio: options.ratio,
+ state: this.source_.getState()
+ * User provided style.
+ * @type {ol.style.Style|Array.<ol.style.Style>|ol.StyleFunction}
+ * @private
+ this.style_ = null;
+ * Style function for use within the library.
+ * @type {ol.StyleFunction|undefined}
+ * @private
+ this.styleFunction_ = undefined;
+ this.setStyle(options.style);
+ ol.events.listen(this.source_, ol.events.EventType.CHANGE,
+ this.handleSourceChange_, this);
+ol.inherits(ol.source.ImageVector, ol.source.ImageCanvas);
+ * @param {ol.Size} size Size.
+ * @param {ol.proj.Projection} projection Projection;
+ * @return {HTMLCanvasElement} Canvas element.
+ * @private
+ol.source.ImageVector.prototype.canvasFunctionInternal_ = function(extent, resolution, pixelRatio, size, projection) {
+ var replayGroup = new ol.render.canvas.ReplayGroup(
+ ol.renderer.vector.getTolerance(resolution, pixelRatio), extent,
+ resolution, this.source_.getOverlaps(), this.renderBuffer_);
+ this.source_.loadFeatures(extent, resolution, projection);
+ var loading = false;
+ this.source_.forEachFeatureInExtent(extent,
+ * @param {ol.Feature} feature Feature.
+ loading = loading ||
+ this.renderFeature_(feature, resolution, pixelRatio, replayGroup);
+ }, this);
+ replayGroup.finish();
+ if (loading) {
+ return null;
+ if (this.canvasSize_[0] != size[0] || this.canvasSize_[1] != size[1]) {
+ this.canvasContext_.canvas.width = size[0];
+ this.canvasContext_.canvas.height = size[1];
+ this.canvasSize_[0] = size[0];
+ this.canvasSize_[1] = size[1];
+ } else {
+ this.canvasContext_.clearRect(0, 0, size[0], size[1]);
+ var transform = this.getTransform_(ol.extent.getCenter(extent),
+ resolution, pixelRatio, size);
+ replayGroup.replay(this.canvasContext_, pixelRatio, transform, 0, {});
+ this.replayGroup_ = replayGroup;
+ return this.canvasContext_.canvas;
+ * @inheritDoc
+ol.source.ImageVector.prototype.forEachFeatureAtCoordinate = function(
+ coordinate, resolution, rotation, hitTolerance, skippedFeatureUids, callback) {
+ if (!this.replayGroup_) {
+ return undefined;
+ } else {
+ /** @type {Object.<string, boolean>} */
+ var features = {};
+ return this.replayGroup_.forEachFeatureAtCoordinate(
+ coordinate, resolution, 0, hitTolerance, skippedFeatureUids,
+ * @param {ol.Feature|ol.render.Feature} feature Feature.
+ var key = ol.getUid(feature).toString();
+ if (!(key in features)) {
+ features[key] = true;
+ return callback(feature);
+ * Get a reference to the wrapped source.
+ * @return {ol.source.Vector} Source.
+ * @api
+ol.source.ImageVector.prototype.getSource = function() {
+ return this.source_;
+ * Get the style for features. This returns whatever was passed to the `style`
+ * option at construction or to the `setStyle` method.
+ * @return {ol.style.Style|Array.<ol.style.Style>|ol.StyleFunction}
+ * Layer style.
+ * @api
+ol.source.ImageVector.prototype.getStyle = function() {
+ return this.style_;
+ * Get the style function.
+ * @return {ol.StyleFunction|undefined} Layer style function.
+ * @api
+ol.source.ImageVector.prototype.getStyleFunction = function() {
+ return this.styleFunction_;
+ * @param {ol.Coordinate} center Center.
+ * @return {!ol.Transform} Transform.
+ * @private
+ol.source.ImageVector.prototype.getTransform_ = function(center, resolution, pixelRatio, size) {
+ var dx1 = size[0] / 2;
+ var dy1 = size[1] / 2;
+ var sx = pixelRatio / resolution;
+ var sy = -sx;
+ var dx2 = -center[0];
+ var dy2 = -center[1];
+ return ol.transform.compose(this.transform_, dx1, dy1, sx, sy, 0, dx2, dy2);
+ * Handle changes in image style state.
+ * @param {ol.events.Event} event Image style change event.
+ * @private
+ol.source.ImageVector.prototype.handleImageChange_ = function(event) {
+ this.changed();
+ * @private
+ol.source.ImageVector.prototype.handleSourceChange_ = function() {
+ // setState will trigger a CHANGE event, so we always rely
+ // change events by calling setState.
+ this.setState(this.source_.getState());
+ * @param {ol.render.canvas.ReplayGroup} replayGroup Replay group.
+ * @return {boolean} `true` if an image is loading.
+ * @private
+ol.source.ImageVector.prototype.renderFeature_ = function(feature, resolution, pixelRatio, replayGroup) {
+ var styles;
+ var styleFunction = feature.getStyleFunction();
+ if (styleFunction) {
+ styles = styleFunction.call(feature, resolution);
+ } else if (this.styleFunction_) {
+ styles = this.styleFunction_(feature, resolution);
+ if (!styles) {
+ return false;
+ var i, ii, loading = false;
+ if (!Array.isArray(styles)) {
+ styles = [styles];
+ for (i = 0, ii = styles.length; i < ii; ++i) {
+ loading = ol.renderer.vector.renderFeature(
+ replayGroup, feature, styles[i],
+ ol.renderer.vector.getSquaredTolerance(resolution, pixelRatio),
+ this.handleImageChange_, this) || loading;
+ return loading;
+ * Set the style for features. This can be a single style object, an array
+ * of styles, or a function that takes a feature and resolution and returns
+ * an array of styles. If it is `undefined` the default style is used. If
+ * it is `null` the layer has no style (a `null` style), so only features
+ * that have their own styles will be rendered in the layer. See
+ * {@link ol.style} for information on the default style.
+ * @param {ol.style.Style|Array.<ol.style.Style>|ol.StyleFunction|undefined}
+ * style Layer style.
+ * @api
+ol.source.ImageVector.prototype.setStyle = function(style) {
+ this.style_ = style !== undefined ? style : ol.style.Style.defaultFunction;
+ this.styleFunction_ = !style ?
+ undefined : ol.style.Style.createFunction(this.style_);
+ this.changed();
+goog.provide('ol.renderer.webgl.ImageLayer');
+goog.require('ol');
+goog.require('ol.functions');
+goog.require('ol.renderer.webgl.Layer');
+goog.require('ol.source.ImageVector');
+goog.require('ol.webgl');
+goog.require('ol.webgl.Context');
+if (ol.ENABLE_WEBGL) {
+ * @constructor
+ * @extends {ol.renderer.webgl.Layer}
+ * @param {ol.renderer.webgl.Map} mapRenderer Map renderer.
+ * @param {ol.layer.Image} imageLayer Tile layer.
+ ol.renderer.webgl.ImageLayer = function(mapRenderer, imageLayer) {
+ ol.renderer.webgl.Layer.call(this, mapRenderer, imageLayer);
+ * The last rendered image.
+ * @private
+ * @private
+ * @private
+ * @type {?ol.Transform}
+ this.hitTransformationMatrix_ = null;
+ ol.inherits(ol.renderer.webgl.ImageLayer, ol.renderer.webgl.Layer);
+ * @param {ol.ImageBase} image Image.
+ * @private
+ * @return {WebGLTexture} Texture.
+ ol.renderer.webgl.ImageLayer.prototype.createTexture_ = function(image) {
+ // We meet the conditions to work with non-power of two textures.
+ // http://www.khronos.org/webgl/wiki/WebGL_and_OpenGL_Differences#Non-Power_of_Two_Texture_Support
+ // http://learningwebgl.com/blog/?p=2101
+ var imageElement = image.getImage();
+ var gl = this.mapRenderer.getGL();
+ return ol.webgl.Context.createTexture(
+ gl, imageElement, ol.webgl.CLAMP_TO_EDGE, ol.webgl.CLAMP_TO_EDGE);
+ * @inheritDoc
+ ol.renderer.webgl.ImageLayer.prototype.forEachFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, callback, thisArg) {
+ * @inheritDoc
+ ol.renderer.webgl.ImageLayer.prototype.prepareFrame = function(frameState, layerState, context) {
+ var viewRotation = viewState.rotation;
+ var image = this.image_;
+ var texture = this.texture;
+ var image_ = imageSource.getImage(renderedExtent, viewResolution,
+ pixelRatio, projection);
+ if (image_) {
+ var loaded = this.loadImage(image_);
+ if (loaded) {
+ image = image_;
+ texture = this.createTexture_(image_);
+ if (this.texture) {
+ * @param {WebGLRenderingContext} gl GL.
+ * @param {WebGLTexture} texture Texture.
+ var postRenderFunction = function(gl, texture) {
+ if (!gl.isContextLost()) {
+ gl.deleteTexture(texture);
+ }.bind(null, gl, this.texture);
+ frameState.postRenderFunctions.push(
+ /** @type {ol.PostRenderFunction} */ (postRenderFunction)
+ if (image) {
+ var canvas = this.mapRenderer.getContext().getCanvas();
+ this.updateProjectionMatrix_(canvas.width, canvas.height,
+ pixelRatio, viewCenter, viewResolution, viewRotation,
+ image.getExtent());
+ // Translate and scale to flip the Y coord.
+ var texCoordMatrix = this.texCoordMatrix;
+ ol.transform.reset(texCoordMatrix);
+ ol.transform.scale(texCoordMatrix, 1, -1);
+ ol.transform.translate(texCoordMatrix, 0, -1);
+ this.texture = texture;
+ return !!image;
+ * @param {number} canvasWidth Canvas width.
+ * @param {number} canvasHeight Canvas height.
+ * @param {ol.Coordinate} viewCenter View center.
+ * @param {number} viewResolution View resolution.
+ * @param {number} viewRotation View rotation.
+ * @param {ol.Extent} imageExtent Image extent.
+ * @private
+ ol.renderer.webgl.ImageLayer.prototype.updateProjectionMatrix_ = function(canvasWidth, canvasHeight, pixelRatio,
+ viewCenter, viewResolution, viewRotation, imageExtent) {
+ var canvasExtentWidth = canvasWidth * viewResolution;
+ var canvasExtentHeight = canvasHeight * viewResolution;
+ var projectionMatrix = this.projectionMatrix;
+ ol.transform.reset(projectionMatrix);
+ ol.transform.scale(projectionMatrix,
+ pixelRatio * 2 / canvasExtentWidth,
+ pixelRatio * 2 / canvasExtentHeight);
+ ol.transform.rotate(projectionMatrix, -viewRotation);
+ ol.transform.translate(projectionMatrix,
+ imageExtent[0] - viewCenter[0],
+ imageExtent[1] - viewCenter[1]);
+ (imageExtent[2] - imageExtent[0]) / 2,
+ (imageExtent[3] - imageExtent[1]) / 2);
+ ol.transform.translate(projectionMatrix, 1, 1);
+ * @inheritDoc
+ ol.renderer.webgl.ImageLayer.prototype.hasFeatureAtCoordinate = function(coordinate, frameState) {
+ var hasFeature = this.forEachFeatureAtCoordinate(
+ coordinate, frameState, 0, ol.functions.TRUE, this);
+ return hasFeature !== undefined;
+ * @inheritDoc
+ ol.renderer.webgl.ImageLayer.prototype.forEachLayerAtPixel = function(pixel, frameState, callback, thisArg) {
+ if (!this.image_ || !this.image_.getImage()) {
+ return undefined;
+ if (this.getLayer().getSource() instanceof ol.source.ImageVector) {
+ var coordinate = ol.transform.apply(
+ frameState.pixelToCoordinateTransform, pixel.slice());
+ if (hasFeature) {
+ return callback.call(thisArg, this.getLayer(), null);
+ } else {
+ return undefined;
+ } else {
+ var imageSize =
+ [this.image_.getImage().width, this.image_.getImage().height];
+ if (!this.hitTransformationMatrix_) {
+ this.hitTransformationMatrix_ = this.getHitTransformationMatrix_(
+ frameState.size, imageSize);
+ var pixelOnFrameBuffer = ol.transform.apply(
+ this.hitTransformationMatrix_, pixel.slice());
+ if (pixelOnFrameBuffer[0] < 0 || pixelOnFrameBuffer[0] > imageSize[0] ||
+ pixelOnFrameBuffer[1] < 0 || pixelOnFrameBuffer[1] > imageSize[1]) {
+ // outside the image, no need to check
+ return undefined;
+ this.hitCanvasContext_.drawImage(this.image_.getImage(),
+ pixelOnFrameBuffer[0], pixelOnFrameBuffer[1], 1, 1, 0, 0, 1, 1);
+ } else {
+ return undefined;
+ * The transformation matrix to get the pixel on the image for a
+ * pixel on the map.
+ * @param {ol.Size} mapSize The map size.
+ * @param {ol.Size} imageSize The image size.
+ * @return {ol.Transform} The transformation matrix.
+ * @private
+ ol.renderer.webgl.ImageLayer.prototype.getHitTransformationMatrix_ = function(mapSize, imageSize) {
+ // the first matrix takes a map pixel, flips the y-axis and scales to
+ // a range between -1 ... 1
+ var mapCoordTransform = ol.transform.create();
+ ol.transform.translate(mapCoordTransform, -1, -1);
+ ol.transform.scale(mapCoordTransform, 2 / mapSize[0], 2 / mapSize[1]);
+ ol.transform.translate(mapCoordTransform, 0, mapSize[1]);
+ ol.transform.scale(mapCoordTransform, 1, -1);
+ // the second matrix is the inverse of the projection matrix used in the
+ // shader for drawing
+ var projectionMatrixInv = ol.transform.invert(this.projectionMatrix.slice());
+ // the third matrix scales to the image dimensions and flips the y-axis again
+ var transform = ol.transform.create();
+ ol.transform.translate(transform, 0, imageSize[1]);
+ ol.transform.scale(transform, 1, -1);
+ ol.transform.scale(transform, imageSize[0] / 2, imageSize[1] / 2);
+ ol.transform.translate(transform, 1, 1);
+ ol.transform.multiply(transform, projectionMatrixInv);
+ ol.transform.multiply(transform, mapCoordTransform);
+ return transform;
+goog.provide('ol.layer.Image');
+goog.require('ol.layer.Layer');
+goog.require('ol.renderer.Type');
+goog.require('ol.renderer.canvas.ImageLayer');
+goog.require('ol.renderer.webgl.ImageLayer');
+ * @classdesc
+ * Server-rendered images that are available for arbitrary extents and
+ * resolutions.
+ * @constructor
+ * @extends {ol.layer.Layer}
+ * @param {olx.layer.ImageOptions=} opt_options Layer options.
+ * @api
+ol.layer.Image = function(opt_options) {
+ var options = opt_options ? opt_options : {};
+ ol.layer.Layer.call(this, /** @type {olx.layer.LayerOptions} */ (options));
+ol.inherits(ol.layer.Image, ol.layer.Layer);
+ * @inheritDoc
+ol.layer.Image.prototype.createRenderer = function(mapRenderer) {
+ var renderer = null;
+ var type = mapRenderer.getType();
+ if (ol.ENABLE_CANVAS && type === ol.renderer.Type.CANVAS) {
+ renderer = new ol.renderer.canvas.ImageLayer(this);
+ } else if (ol.ENABLE_WEBGL && type === ol.renderer.Type.WEBGL) {
+ renderer = new ol.renderer.webgl.ImageLayer(/** @type {ol.renderer.webgl.Map} */ (mapRenderer), this);
+ return renderer;
+ * Return the associated {@link ol.source.Image source} of the image layer.
+ * @function
+ * @return {ol.source.Image} Source.
+ * @api
+ol.layer.Image.prototype.getSource;
+goog.provide('ol.layer.TileProperty');
+ * @enum {string}
+ol.layer.TileProperty = {
+ PRELOAD: 'preload',
+ USE_INTERIM_TILES_ON_ERROR: 'useInterimTilesOnError'
+// FIXME find correct globalCompositeOperation
+goog.provide('ol.renderer.canvas.TileLayer');
+goog.require('ol.TileRange');
+goog.require('ol.TileState');
+goog.require('ol.array');
+ * @constructor
+ * @param {ol.layer.Tile|ol.layer.VectorTile} tileLayer Tile layer.
+ol.renderer.canvas.TileLayer = function(tileLayer) {
+ ol.renderer.canvas.IntermediateCanvas.call(this, tileLayer);
+ * @protected
+ this.context = this.context === null ? null : ol.dom.createCanvasContext2D();
+ * @private
+ * @type {number}
+ this.oversampling_;
+ * @private
+ this.renderedExtent_ = null;
+ * @protected
+ * @type {number}
+ this.renderedRevision;
+ * @protected
+ * @type {!Array.<ol.Tile>}
+ this.renderedTiles = [];
+ * @protected
+ this.tmpExtent = ol.extent.createEmpty();
+ * @private
+ * @type {ol.TileRange}
+ this.tmpTileRange_ = new ol.TileRange(0, 0, 0, 0);
+ * @private
+ * @protected
+ * @type {number}
+ this.zDirection = 0;
+ol.inherits(ol.renderer.canvas.TileLayer, ol.renderer.canvas.IntermediateCanvas);
+ * @private
+ * @param {ol.Tile} tile Tile.
+ * @return {boolean} Tile is drawable.
+ol.renderer.canvas.TileLayer.prototype.isDrawableTile_ = function(tile) {
+ var tileState = tile.getState();
+ var useInterimTilesOnError = this.getLayer().getUseInterimTilesOnError();
+ return tileState == ol.TileState.LOADED ||
+ tileState == ol.TileState.EMPTY ||
+ tileState == ol.TileState.ERROR && !useInterimTilesOnError;
+ * @inheritDoc
+ol.renderer.canvas.TileLayer.prototype.prepareFrame = function(frameState, layerState) {
+ var tileLayer = this.getLayer();
+ var tileSource = /** @type {ol.source.Tile} */ (tileLayer.getSource());
+ var sourceRevision = tileSource.getRevision();
+ var tileGrid = tileSource.getTileGridForProjection(projection);
+ var z = tileGrid.getZForResolution(viewResolution, this.zDirection);
+ var tileResolution = tileGrid.getResolution(z);
+ var oversampling = Math.round(viewResolution / tileResolution) || 1;
+ var extent = frameState.extent;
+ extent = ol.extent.getIntersection(extent, layerState.extent);
+ if (ol.extent.isEmpty(extent)) {
+ // Return false to prevent the rendering of the layer.
+ return false;
+ var tileRange = tileGrid.getTileRangeForExtentAndResolution(
+ extent, tileResolution);
+ var imageExtent = tileGrid.getTileRangeExtent(z, tileRange);
+ var tilePixelRatio = tileSource.getTilePixelRatio(pixelRatio);
+ * @type {Object.<number, Object.<string, ol.Tile>>}
+ var tilesToDrawByZ = {};
+ tilesToDrawByZ[z] = {};
+ var findLoadedTiles = this.createLoadedTileFinder(
+ tileSource, projection, tilesToDrawByZ);
+ var tmpExtent = this.tmpExtent;
+ var tmpTileRange = this.tmpTileRange_;
+ var newTiles = false;
+ var tile, x, y;
+ for (x = tileRange.minX; x <= tileRange.maxX; ++x) {
+ for (y = tileRange.minY; y <= tileRange.maxY; ++y) {
+ tile = tileSource.getTile(z, x, y, pixelRatio, projection);
+ if (!this.isDrawableTile_(tile)) {
+ tile = tile.getInterimTile();
+ if (this.isDrawableTile_(tile)) {
+ if (tile.getState() == ol.TileState.LOADED) {
+ tilesToDrawByZ[z][tile.tileCoord.toString()] = tile;
+ if (!newTiles && this.renderedTiles.indexOf(tile) == -1) {
+ newTiles = true;
+ continue;
+ var fullyLoaded = tileGrid.forEachTileCoordParentTileRange(
+ tile.tileCoord, findLoadedTiles, null, tmpTileRange, tmpExtent);
+ if (!fullyLoaded) {
+ var childTileRange = tileGrid.getTileCoordChildTileRange(
+ tile.tileCoord, tmpTileRange, tmpExtent);
+ if (childTileRange) {
+ findLoadedTiles(z + 1, childTileRange);
+ if (!(this.renderedResolution && Date.now() - frameState.time > 16 &&
+ (hints[ol.ViewHint.ANIMATING] || hints[ol.ViewHint.INTERACTING])) &&
+ (newTiles || !(this.renderedExtent_ &&
+ ol.extent.containsExtent(this.renderedExtent_, extent)) ||
+ this.renderedRevision != sourceRevision) ||
+ oversampling != this.oversampling_) {
+ var context = this.context;
+ if (context) {
+ var tilePixelSize = tileSource.getTilePixelSize(z, pixelRatio, projection);
+ var width = Math.round(tileRange.getWidth() * tilePixelSize[0] / oversampling);
+ var height = Math.round(tileRange.getHeight() * tilePixelSize[1] / oversampling);
+ if (canvas.width != width || canvas.height != height) {
+ this.oversampling_ = oversampling;
+ canvas.width = width;
+ canvas.height = height;
+ } else {
+ context.clearRect(0, 0, width, height);
+ oversampling = this.oversampling_;
+ this.renderedTiles.length = 0;
+ /** @type {Array.<number>} */
+ var zs = Object.keys(tilesToDrawByZ).map(Number);
+ zs.sort(ol.array.numberSafeCompareFunction);
+ var currentResolution, currentScale, currentTilePixelSize, currentZ, i, ii;
+ var tileExtent, tileGutter, tilesToDraw, w, h;
+ for (i = 0, ii = zs.length; i < ii; ++i) {
+ currentZ = zs[i];
+ currentTilePixelSize = tileSource.getTilePixelSize(currentZ, pixelRatio, projection);
+ currentResolution = tileGrid.getResolution(currentZ);
+ currentScale = currentResolution / tileResolution;
+ tileGutter = tilePixelRatio * tileSource.getGutter(projection);
+ tilesToDraw = tilesToDrawByZ[currentZ];
+ for (var tileCoordKey in tilesToDraw) {
+ tile = tilesToDraw[tileCoordKey];
+ tileExtent = tileGrid.getTileCoordExtent(tile.getTileCoord(), tmpExtent);
+ x = (tileExtent[0] - imageExtent[0]) / tileResolution * tilePixelRatio / oversampling;
+ y = (imageExtent[3] - tileExtent[3]) / tileResolution * tilePixelRatio / oversampling;
+ w = currentTilePixelSize[0] * currentScale / oversampling;
+ h = currentTilePixelSize[1] * currentScale / oversampling;
+ this.drawTileImage(tile, frameState, layerState, x, y, w, h, tileGutter);
+ this.renderedTiles.push(tile);
+ this.renderedRevision = sourceRevision;
+ this.renderedResolution = tileResolution * pixelRatio / tilePixelRatio * oversampling;
+ this.renderedExtent_ = imageExtent;
+ var scale = this.renderedResolution / viewResolution;
+ scale, scale,
+ 0,
+ (this.renderedExtent_[0] - viewCenter[0]) / this.renderedResolution * pixelRatio,
+ (viewCenter[1] - this.renderedExtent_[3]) / this.renderedResolution * pixelRatio);
+ 0,
+ this.updateUsedTiles(frameState.usedTiles, tileSource, z, tileRange);
+ this.manageTilePyramid(frameState, tileSource, tileGrid, pixelRatio,
+ projection, extent, z, tileLayer.getPreload());
+ this.scheduleExpireCache(frameState, tileSource);
+ this.updateLogos(frameState, tileSource);
+ return this.renderedTiles.length > 0;
+ * @param {olx.FrameState} frameState Frame state.
+ * @param {ol.LayerState} layerState Layer state.
+ * @param {number} x Left of the tile.
+ * @param {number} y Top of the tile.
+ * @param {number} w Width of the tile.
+ * @param {number} h Height of the tile.
+ * @param {number} gutter Tile gutter.
+ol.renderer.canvas.TileLayer.prototype.drawTileImage = function(tile, frameState, layerState, x, y, w, h, gutter) {
+ if (!this.getLayer().getSource().getOpaque(frameState.viewState.projection)) {
+ this.context.clearRect(x, y, w, h);
+ var image = tile.getImage();
+ if (image) {
+ this.context.drawImage(image, gutter, gutter,
+ image.width - 2 * gutter, image.height - 2 * gutter, x, y, w, h);
+ * @inheritDoc
+ol.renderer.canvas.TileLayer.prototype.getImage = function() {
+ return context ? context.canvas : null;
+ * @function
+ * @return {ol.layer.Tile|ol.layer.VectorTile}
+ol.renderer.canvas.TileLayer.prototype.getLayer;
+ * @inheritDoc
+ol.renderer.canvas.TileLayer.prototype.getImageTransform = function() {
+// This file is automatically generated, do not edit
+goog.provide('ol.renderer.webgl.tilelayershader');
+goog.require('ol.webgl.Fragment');
+goog.require('ol.webgl.Vertex');
+ * @constructor
+ * @extends {ol.webgl.Fragment}
+ * @struct
+ ol.renderer.webgl.tilelayershader.Fragment = function() {
+ ol.webgl.Fragment.call(this, ol.renderer.webgl.tilelayershader.Fragment.SOURCE);
+ ol.inherits(ol.renderer.webgl.tilelayershader.Fragment, ol.webgl.Fragment);
+ * @const
+ * @type {string}
+ ol.renderer.webgl.tilelayershader.Fragment.DEBUG_SOURCE = 'precision mediump float;\nvarying vec2 v_texCoord;\n\n\nuniform sampler2D u_texture;\n\nvoid main(void) {\n gl_FragColor = texture2D(u_texture, v_texCoord);\n}\n';
+ * @const
+ * @type {string}
+ ol.renderer.webgl.tilelayershader.Fragment.OPTIMIZED_SOURCE = 'precision mediump float;varying vec2 a;uniform sampler2D e;void main(void){gl_FragColor=texture2D(e,a);}';
+ * @const
+ * @type {string}
+ ol.renderer.webgl.tilelayershader.Fragment.SOURCE = ol.DEBUG_WEBGL ?
+ ol.renderer.webgl.tilelayershader.Fragment.DEBUG_SOURCE :
+ ol.renderer.webgl.tilelayershader.Fragment.OPTIMIZED_SOURCE;
+ ol.renderer.webgl.tilelayershader.fragment = new ol.renderer.webgl.tilelayershader.Fragment();
+ * @constructor
+ * @extends {ol.webgl.Vertex}
+ * @struct
+ ol.renderer.webgl.tilelayershader.Vertex = function() {
+ ol.webgl.Vertex.call(this, ol.renderer.webgl.tilelayershader.Vertex.SOURCE);
+ ol.inherits(ol.renderer.webgl.tilelayershader.Vertex, ol.webgl.Vertex);
+ * @const
+ * @type {string}
+ ol.renderer.webgl.tilelayershader.Vertex.DEBUG_SOURCE = 'varying vec2 v_texCoord;\n\n\nattribute vec2 a_position;\nattribute vec2 a_texCoord;\nuniform vec4 u_tileOffset;\n\nvoid main(void) {\n gl_Position = vec4(a_position * u_tileOffset.xy + u_tileOffset.zw, 0., 1.);\n v_texCoord = a_texCoord;\n}\n\n\n';
+ * @const
+ * @type {string}
+ ol.renderer.webgl.tilelayershader.Vertex.OPTIMIZED_SOURCE = 'varying vec2 a;attribute vec2 b;attribute vec2 c;uniform vec4 d;void main(void){gl_Position=vec4(b*d.xy+d.zw,0.,1.);a=c;}';
+ * @const
+ * @type {string}
+ ol.renderer.webgl.tilelayershader.Vertex.SOURCE = ol.DEBUG_WEBGL ?
+ ol.renderer.webgl.tilelayershader.Vertex.DEBUG_SOURCE :
+ ol.renderer.webgl.tilelayershader.Vertex.OPTIMIZED_SOURCE;
+ ol.renderer.webgl.tilelayershader.vertex = new ol.renderer.webgl.tilelayershader.Vertex();
+ * @constructor
+ * @param {WebGLProgram} program Program.
+ * @struct
+ ol.renderer.webgl.tilelayershader.Locations = function(gl, program) {
+ * @type {WebGLUniformLocation}
+ this.u_texture = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_texture' : 'e');
+ this.u_tileOffset = gl.getUniformLocation(
+ program, ol.DEBUG_WEBGL ? 'u_tileOffset' : 'd');
+ * @type {number}
+ this.a_position = gl.getAttribLocation(
+ program, ol.DEBUG_WEBGL ? 'a_position' : 'b');
+ * @type {number}
+ this.a_texCoord = gl.getAttribLocation(
+ program, ol.DEBUG_WEBGL ? 'a_texCoord' : 'c');
+// FIXME large resolutions lead to too large framebuffers :-(
+// FIXME animated shaders! check in redraw
+goog.provide('ol.renderer.webgl.TileLayer');
+goog.require('ol.math');
+goog.require('ol.renderer.webgl.tilelayershader');
+goog.require('ol.size');
+goog.require('ol.webgl.Buffer');
+ * @constructor
+ * @param {ol.layer.Tile} tileLayer Tile layer.
+ ol.renderer.webgl.TileLayer = function(mapRenderer, tileLayer) {
+ ol.renderer.webgl.Layer.call(this, mapRenderer, tileLayer);
+ * @private
+ * @type {ol.webgl.Fragment}
+ this.fragmentShader_ = ol.renderer.webgl.tilelayershader.fragment;
+ * @private
+ * @type {ol.webgl.Vertex}
+ this.vertexShader_ = ol.renderer.webgl.tilelayershader.vertex;
+ * @private
+ * @type {ol.renderer.webgl.tilelayershader.Locations}
+ this.locations_ = null;
+ * @private
+ * @type {ol.webgl.Buffer}
+ this.renderArrayBuffer_ = new ol.webgl.Buffer([
+ 0, 0, 0, 1,
+ 1, 0, 1, 1,
+ 0, 1, 0, 0,
+ 1, 1, 1, 0
+ * @private
+ this.renderedTileRange_ = null;
+ * @private
+ this.renderedFramebufferExtent_ = null;
+ * @private
+ * @type {number}
+ this.renderedRevision_ = -1;
+ * @private
+ * @type {ol.Size}
+ this.tmpSize_ = [0, 0];
+ ol.inherits(ol.renderer.webgl.TileLayer, ol.renderer.webgl.Layer);
+ * @inheritDoc
+ ol.renderer.webgl.TileLayer.prototype.disposeInternal = function() {
+ var context = this.mapRenderer.getContext();
+ context.deleteBuffer(this.renderArrayBuffer_);
+ ol.renderer.webgl.Layer.prototype.disposeInternal.call(this);
+ * @inheritDoc
+ ol.renderer.webgl.TileLayer.prototype.createLoadedTileFinder = function(source, projection, tiles) {
+ var mapRenderer = this.mapRenderer;
+ return (
+ * @param {number} zoom Zoom level.
+ * @param {ol.TileRange} tileRange Tile range.
+ * @return {boolean} The tile range is fully loaded.
+ function(zoom, tileRange) {
+ function callback(tile) {
+ var loaded = mapRenderer.isTileTextureLoaded(tile);
+ if (loaded) {
+ if (!tiles[zoom]) {
+ tiles[zoom] = {};
+ tiles[zoom][tile.tileCoord.toString()] = tile;
+ return loaded;
+ return source.forEachLoadedTile(projection, zoom, tileRange, callback);
+ * @inheritDoc
+ ol.renderer.webgl.TileLayer.prototype.handleWebGLContextLost = function() {
+ ol.renderer.webgl.Layer.prototype.handleWebGLContextLost.call(this);
+ * @inheritDoc
+ ol.renderer.webgl.TileLayer.prototype.prepareFrame = function(frameState, layerState, context) {
+ var gl = context.getGL();
+ var tileLayer = /** @type {ol.layer.Tile} */ (this.getLayer());
+ var tileSource = tileLayer.getSource();
+ var z = tileGrid.getZForResolution(viewState.resolution);
+ tileSource.getTilePixelSize(z, frameState.pixelRatio, projection);
+ var pixelRatio = tilePixelSize[0] /
+ ol.size.toSize(tileGrid.getTileSize(z), this.tmpSize_)[0];
+ var tilePixelResolution = tileResolution / pixelRatio;
+ var tileGutter = tileSource.getTilePixelRatio(pixelRatio) * tileSource.getGutter(projection);
+ var center = viewState.center;
+ var framebufferExtent;
+ if (this.renderedTileRange_ &&
+ this.renderedTileRange_.equals(tileRange) &&
+ this.renderedRevision_ == tileSource.getRevision()) {
+ framebufferExtent = this.renderedFramebufferExtent_;
+ } else {
+ var tileRangeSize = tileRange.getSize();
+ var maxDimension = Math.max(
+ tileRangeSize[0] * tilePixelSize[0],
+ tileRangeSize[1] * tilePixelSize[1]);
+ var framebufferDimension = ol.math.roundUpToPowerOfTwo(maxDimension);
+ var framebufferExtentDimension = tilePixelResolution * framebufferDimension;
+ var origin = tileGrid.getOrigin(z);
+ var minX = origin[0] +
+ tileRange.minX * tilePixelSize[0] * tilePixelResolution;
+ var minY = origin[1] +
+ tileRange.minY * tilePixelSize[1] * tilePixelResolution;
+ framebufferExtent = [
+ minX, minY,
+ minX + framebufferExtentDimension, minY + framebufferExtentDimension
+ this.bindFramebuffer(frameState, framebufferDimension);
+ gl.viewport(0, 0, framebufferDimension, framebufferDimension);
+ gl.clearColor(0, 0, 0, 0);
+ gl.clear(ol.webgl.COLOR_BUFFER_BIT);
+ gl.disable(ol.webgl.BLEND);
+ var program = context.getProgram(this.fragmentShader_, this.vertexShader_);
+ context.useProgram(program);
+ if (!this.locations_) {
+ this.locations_ =
+ new ol.renderer.webgl.tilelayershader.Locations(gl, program);
+ context.bindBuffer(ol.webgl.ARRAY_BUFFER, this.renderArrayBuffer_);
+ gl.enableVertexAttribArray(this.locations_.a_position);
+ gl.vertexAttribPointer(
+ this.locations_.a_position, 2, ol.webgl.FLOAT, false, 16, 0);
+ gl.enableVertexAttribArray(this.locations_.a_texCoord);
+ this.locations_.a_texCoord, 2, ol.webgl.FLOAT, false, 16, 8);
+ gl.uniform1i(this.locations_.u_texture, 0);
+ var useInterimTilesOnError = tileLayer.getUseInterimTilesOnError();
+ var allTilesLoaded = true;
+ var tmpExtent = ol.extent.createEmpty();
+ var tmpTileRange = new ol.TileRange(0, 0, 0, 0);
+ var childTileRange, drawable, fullyLoaded, tile, tileState;
+ var x, y, tileExtent;
+ // ignore tiles outside layer extent
+ tileExtent = tileGrid.getTileCoordExtent(tile.tileCoord, tmpExtent);
+ if (!ol.extent.intersects(tileExtent, layerState.extent)) {
+ continue;
+ tileState = tile.getState();
+ drawable = tileState == ol.TileState.LOADED ||
+ if (!drawable) {
+ if (tileState == ol.TileState.LOADED) {
+ if (mapRenderer.isTileTextureLoaded(tile)) {
+ continue;
+ } else if (tileState == ol.TileState.EMPTY ||
+ (tileState == ol.TileState.ERROR &&
+ !useInterimTilesOnError)) {
+ continue;
+ allTilesLoaded = false;
+ fullyLoaded = tileGrid.forEachTileCoordParentTileRange(
+ childTileRange = tileGrid.getTileCoordChildTileRange(
+ var u_tileOffset = new Float32Array(4);
+ var i, ii, tileKey, tilesToDraw;
+ tilesToDraw = tilesToDrawByZ[zs[i]];
+ for (tileKey in tilesToDraw) {
+ tile = tilesToDraw[tileKey];
+ u_tileOffset[0] = 2 * (tileExtent[2] - tileExtent[0]) /
+ framebufferExtentDimension;
+ u_tileOffset[1] = 2 * (tileExtent[3] - tileExtent[1]) /
+ u_tileOffset[2] = 2 * (tileExtent[0] - framebufferExtent[0]) /
+ framebufferExtentDimension - 1;
+ u_tileOffset[3] = 2 * (tileExtent[1] - framebufferExtent[1]) /
+ gl.uniform4fv(this.locations_.u_tileOffset, u_tileOffset);
+ mapRenderer.bindTileTexture(tile, tilePixelSize,
+ tileGutter * pixelRatio, ol.webgl.LINEAR, ol.webgl.LINEAR);
+ gl.drawArrays(ol.webgl.TRIANGLE_STRIP, 0, 4);
+ if (allTilesLoaded) {
+ this.renderedTileRange_ = tileRange;
+ this.renderedFramebufferExtent_ = framebufferExtent;
+ this.renderedRevision_ = tileSource.getRevision();
+ } else {
+ frameState.animate = true;
+ var tileTextureQueue = mapRenderer.getTileTextureQueue();
+ frameState, tileSource, tileGrid, pixelRatio, projection, extent, z,
+ tileLayer.getPreload(),
+ function(tile) {
+ if (tile.getState() == ol.TileState.LOADED &&
+ !mapRenderer.isTileTextureLoaded(tile) &&
+ !tileTextureQueue.isKeyQueued(tile.getKey())) {
+ tileTextureQueue.enqueue([
+ tile,
+ tileGrid.getTileCoordCenter(tile.tileCoord),
+ tileGrid.getResolution(tile.tileCoord[0]),
+ tilePixelSize, tileGutter * pixelRatio
+ }, this);
+ (Math.round(center[0] / tileResolution) * tileResolution - framebufferExtent[0]) /
+ (framebufferExtent[2] - framebufferExtent[0]),
+ (Math.round(center[1] / tileResolution) * tileResolution - framebufferExtent[1]) /
+ (framebufferExtent[3] - framebufferExtent[1]));
+ if (viewState.rotation !== 0) {
+ ol.transform.rotate(texCoordMatrix, viewState.rotation);
+ frameState.size[0] * viewState.resolution /
+ frameState.size[1] * viewState.resolution /
+ ol.transform.translate(texCoordMatrix, -0.5, -0.5);
+ return true;
+ * @inheritDoc
+ ol.renderer.webgl.TileLayer.prototype.forEachLayerAtPixel = function(pixel, frameState, callback, thisArg) {
+ if (!this.framebuffer) {
+ return undefined;
+ var pixelOnMapScaled = [
+ pixel[0] / frameState.size[0],
+ (frameState.size[1] - pixel[1]) / frameState.size[1]];
+ var pixelOnFrameBufferScaled = ol.transform.apply(
+ this.texCoordMatrix, pixelOnMapScaled.slice());
+ var pixelOnFrameBuffer = [
+ pixelOnFrameBufferScaled[0] * this.framebufferDimension,
+ pixelOnFrameBufferScaled[1] * this.framebufferDimension];
+ var gl = this.mapRenderer.getContext().getGL();
+ gl.bindFramebuffer(gl.FRAMEBUFFER, this.framebuffer);
+ var imageData = new Uint8Array(4);
+ gl.readPixels(pixelOnFrameBuffer[0], pixelOnFrameBuffer[1], 1, 1,
+ gl.RGBA, gl.UNSIGNED_BYTE, imageData);
+ if (imageData[3] > 0) {
+ return callback.call(thisArg, this.getLayer(), imageData);
+ } else {
+ return undefined;
+goog.provide('ol.layer.Tile');
+goog.require('ol.layer.TileProperty');
+goog.require('ol.obj');
+goog.require('ol.renderer.canvas.TileLayer');
+goog.require('ol.renderer.webgl.TileLayer');
+ * @classdesc
+ * For layer sources that provide pre-rendered, tiled images in grids that are
+ * organized by zoom levels for specific resolutions.
+ * Note that any property set in the options is set as a {@link ol.Object}
+ * property on the layer object; for example, setting `title: 'My Title'` in the
+ * options means that `title` is observable, and has get/set accessors.
+ * @constructor
+ * @fires ol.render.Event
+ * @param {olx.layer.TileOptions=} opt_options Tile layer options.
+ * @api
+ol.layer.Tile = function(opt_options) {
+ var baseOptions = ol.obj.assign({}, options);
+ delete baseOptions.preload;
+ delete baseOptions.useInterimTilesOnError;
+ ol.layer.Layer.call(this, /** @type {olx.layer.LayerOptions} */ (baseOptions));
+ this.setPreload(options.preload !== undefined ? options.preload : 0);
+ this.setUseInterimTilesOnError(options.useInterimTilesOnError !== undefined ?
+ options.useInterimTilesOnError : true);
+ol.inherits(ol.layer.Tile, ol.layer.Layer);
+ * @inheritDoc
+ol.layer.Tile.prototype.createRenderer = function(mapRenderer) {
+ renderer = new ol.renderer.canvas.TileLayer(this);
+ renderer = new ol.renderer.webgl.TileLayer(/** @type {ol.renderer.webgl.Map} */ (mapRenderer), this);
+ return renderer;
+ * Return the level as number to which we will preload tiles up to.
+ * @return {number} The level to preload tiles up to.
+ * @observable
+ * @api
+ol.layer.Tile.prototype.getPreload = function() {
+ return /** @type {number} */ (this.get(ol.layer.TileProperty.PRELOAD));
+ * Return the associated {@link ol.source.Tile tilesource} of the layer.
+ * @function
+ * @return {ol.source.Tile} Source.
+ * @api
+ol.layer.Tile.prototype.getSource;
+ * Set the level as number to which we will preload tiles up to.
+ * @param {number} preload The level to preload tiles up to.
+ * @observable
+ * @api
+ol.layer.Tile.prototype.setPreload = function(preload) {
+ this.set(ol.layer.TileProperty.PRELOAD, preload);
+ * Whether we use interim tiles on error.
+ * @return {boolean} Use interim tiles on error.
+ * @observable
+ * @api
+ol.layer.Tile.prototype.getUseInterimTilesOnError = function() {
+ return /** @type {boolean} */ (
+ this.get(ol.layer.TileProperty.USE_INTERIM_TILES_ON_ERROR));
+ * Set whether we use interim tiles on error.
+ * @param {boolean} useInterimTilesOnError Use interim tiles on error.
+ * @observable
+ * @api
+ol.layer.Tile.prototype.setUseInterimTilesOnError = function(useInterimTilesOnError) {
+ this.set(
+ ol.layer.TileProperty.USE_INTERIM_TILES_ON_ERROR, useInterimTilesOnError);
+goog.provide('ol.layer.VectorTileRenderType');
+ * @enum {string}
+ * Render mode for vector tiles:
+ * * `'image'`: Vector tiles are rendered as images. Great performance, but
+ * point symbols and texts are always rotated with the view and pixels are
+ * scaled during zoom animations.
+ * * `'hybrid'`: Polygon and line elements are rendered as images, so pixels
+ * are scaled during zoom animations. Point symbols and texts are accurately
+ * rendered as vectors and can stay upright on rotated views.
+ * * `'vector'`: Vector tiles are rendered as vectors. Most accurate rendering
+ * even during animations, but slower performance than the other options.
+ * @api
+ol.layer.VectorTileRenderType = {
+ IMAGE: 'image',
+ HYBRID: 'hybrid',
+ VECTOR: 'vector'
+goog.provide('ol.renderer.canvas.VectorTileLayer');
+goog.require('ol.dom');
+goog.require('ol.extent');
+goog.require('ol.proj');
+goog.require('ol.proj.Units');
+goog.require('ol.layer.VectorTileRenderType');
+goog.require('ol.render.ReplayType');
+goog.require('ol.render.canvas');
+goog.require('ol.render.replay');
+goog.require('ol.transform');
+ * @constructor
+ * @extends {ol.renderer.canvas.TileLayer}
+ * @param {ol.layer.VectorTile} layer VectorTile layer.
+ol.renderer.canvas.VectorTileLayer = function(layer) {
+ this.context = null;
+ ol.renderer.canvas.TileLayer.call(this, layer);
+ * @private
+ * @type {boolean}
+ this.dirty_ = false;
+ * @private
+ * @type {number}
+ this.renderedLayerRevision_;
+ * @private
+ * @type {ol.Transform}
+ this.tmpTransform_ = ol.transform.create();
+ // Use lower resolution for pure vector rendering. Closest resolution otherwise.
+ this.zDirection =
+ layer.getRenderMode() == ol.layer.VectorTileRenderType.VECTOR ? 1 : 0;
+ol.inherits(ol.renderer.canvas.VectorTileLayer, ol.renderer.canvas.TileLayer);
+ * @const
+ * @type {!Object.<string, Array.<ol.render.ReplayType>>}
+ol.renderer.canvas.VectorTileLayer.IMAGE_REPLAYS = {
+ 'image': ol.render.replay.ORDER,
+ 'hybrid': [ol.render.ReplayType.POLYGON, ol.render.ReplayType.LINE_STRING]
+ * @const
+ol.renderer.canvas.VectorTileLayer.VECTOR_REPLAYS = {
+ 'hybrid': [ol.render.ReplayType.IMAGE, ol.render.ReplayType.TEXT],
+ 'vector': ol.render.replay.ORDER
+ * @inheritDoc
+ol.renderer.canvas.VectorTileLayer.prototype.prepareFrame = function(frameState, layerState) {
+ var layer = this.getLayer();
+ var layerRevision = layer.getRevision();
+ if (this.renderedLayerRevision_ != layerRevision) {
+ var renderMode = layer.getRenderMode();
+ if (!this.context && renderMode != ol.layer.VectorTileRenderType.VECTOR) {
+ this.context = ol.dom.createCanvasContext2D();
+ if (this.context && renderMode == ol.layer.VectorTileRenderType.VECTOR) {
+ this.renderedLayerRevision_ = layerRevision;
+ return ol.renderer.canvas.TileLayer.prototype.prepareFrame.apply(this, arguments);
+ * @param {ol.VectorTile} tile Tile.
+ * @private
+ol.renderer.canvas.VectorTileLayer.prototype.createReplayGroup_ = function(tile,
+ frameState) {
+ var pixelRatio = frameState.pixelRatio;
+ var projection = frameState.viewState.projection;
+ var revision = layer.getRevision();
+ var renderOrder = layer.getRenderOrder() || null;
+ var replayState = tile.getReplayState();
+ if (!replayState.dirty && replayState.renderedRevision == revision &&
+ replayState.renderedRenderOrder == renderOrder) {
+ return;
+ replayState.replayGroup = null;
+ replayState.dirty = false;
+ var source = /** @type {ol.source.VectorTile} */ (layer.getSource());
+ var tileGrid = source.getTileGrid();
+ var tileCoord = tile.tileCoord;
+ var tileProjection = tile.getProjection();
+ var resolution = tileGrid.getResolution(tileCoord[0]);
+ var extent, reproject, tileResolution;
+ if (tileProjection.getUnits() == ol.proj.Units.TILE_PIXELS) {
+ var tilePixelRatio = tileResolution = source.getTilePixelRatio();
+ var tileSize = ol.size.toSize(tileGrid.getTileSize(tileCoord[0]));
+ extent = [0, 0, tileSize[0] * tilePixelRatio, tileSize[1] * tilePixelRatio];
+ } else {
+ tileResolution = resolution;
+ extent = tileGrid.getTileCoordExtent(tileCoord);
+ if (!ol.proj.equivalent(projection, tileProjection)) {
+ reproject = true;
+ tile.setProjection(projection);
+ var replayGroup = new ol.render.canvas.ReplayGroup(0, extent,
+ tileResolution, source.getOverlaps(), layer.getRenderBuffer());
+ var squaredTolerance = ol.renderer.vector.getSquaredTolerance(
+ tileResolution, pixelRatio);
+ * @this {ol.renderer.canvas.VectorTileLayer}
+ function renderFeature(feature) {
+ var styles;
+ styles = styleFunction.call(/** @type {ol.Feature} */ (feature), resolution);
+ } else {
+ styleFunction = layer.getStyleFunction();
+ styles = styleFunction(feature, resolution);
+ if (styles) {
+ var dirty = this.renderFeature(feature, squaredTolerance, styles,
+ replayGroup);
+ this.dirty_ = this.dirty_ || dirty;
+ replayState.dirty = replayState.dirty || dirty;
+ var features = tile.getFeatures();
+ if (renderOrder && renderOrder !== replayState.renderedRenderOrder) {
+ features.sort(renderOrder);
+ var feature;
+ for (var i = 0, ii = features.length; i < ii; ++i) {
+ feature = features[i];
+ if (reproject) {
+ feature.getGeometry().transform(tileProjection, projection);
+ renderFeature.call(this, feature);
+ replayState.renderedRevision = revision;
+ replayState.renderedRenderOrder = renderOrder;
+ replayState.replayGroup = replayGroup;
+ replayState.resolution = NaN;
+ * @inheritDoc
+ol.renderer.canvas.VectorTileLayer.prototype.drawTileImage = function(
+ tile, frameState, layerState, x, y, w, h, gutter) {
+ var vectorTile = /** @type {ol.VectorTile} */ (tile);
+ this.createReplayGroup_(vectorTile, frameState);
+ if (this.context) {
+ this.renderTileImage_(vectorTile, frameState, layerState);
+ ol.renderer.canvas.TileLayer.prototype.drawTileImage.apply(this, arguments);
+ * @inheritDoc
+ol.renderer.canvas.VectorTileLayer.prototype.forEachFeatureAtCoordinate = function(coordinate, frameState, hitTolerance, callback, thisArg) {
+ var resolution = frameState.viewState.resolution;
+ var rotation = frameState.viewState.rotation;
+ hitTolerance = hitTolerance == undefined ? 0 : hitTolerance;
+ /** @type {Array.<ol.VectorTile>} */
+ var replayables = this.renderedTiles;
+ var found, tileSpaceCoordinate;
+ var i, ii, origin, replayGroup;
+ var tile, tileCoord, tileExtent, tilePixelRatio, tileResolution;
+ for (i = 0, ii = replayables.length; i < ii; ++i) {
+ tile = replayables[i];
+ tileCoord = tile.tileCoord;
+ tileExten
