[mapguide-commits] r9422 - in trunk/MgDev: . Web/src/HttpHandler
svn_mapguide at osgeo.org
Fri Dec 14 07:28:35 PST 2018
Author: jng
Date: 2018-12-14 07:28:35 -0800 (Fri, 14 Dec 2018)
New Revision: 9422
trunk/MgDev/CMakeLists.txt
trunk/MgDev/Web/src/HttpHandler/CMakeLists.txt
trunk/MgDev/cmake_bootstrap.sh
#2786: Update cmake_bootstrap.sh to effectively be build_oem.sh with support for building all the internal thirdparty libs if required
Modified: trunk/MgDev/CMakeLists.txt
--- trunk/MgDev/CMakeLists.txt 2018-12-10 14:54:00 UTC (rev 9421)
+++ trunk/MgDev/CMakeLists.txt 2018-12-14 15:28:35 UTC (rev 9422)
@@ -207,26 +207,146 @@
endif ()
find_package(Sanitizers)
-find_package(GEOS REQUIRED)
-find_package(ACE REQUIRED)
-if (NOT INTERNAL_XERCES)
- find_package(XercesC REQUIRED)
-else (NOT INTERNAL_XERCES)
- message(STATUS "Using internal xerces-c")
-endif (NOT INTERNAL_XERCES)
-find_package(GD REQUIRED)
-find_package(Freetype REQUIRED)
-find_package(JPEG REQUIRED)
-find_package(PNG REQUIRED)
-find_package(FDO REQUIRED)
-find_package(CppUnit REQUIRED)
-find_package(TCLAP REQUIRED)
-find_package(LinuxApt REQUIRED)
-find_package(DbXmlInternal REQUIRED)
-if (INTERNAL_XERCES)
- # This will be the same
- set(XERCESC_INCLUDE_DIR "${DBXML_INCLUDE_DIR}")
-endif (INTERNAL_XERCES)
+######################## Begin Thirdparty Section ###############################
+set(INTERNAL_ACE true)
+set(INTERNAL_JSONCPP true)
+set(INTERNAL_GD true)
+# ACE
+if (NOT INTERNAL_ACE)
+ message(STATUS "Finding ACE (system)")
+ find_package(ACE REQUIRED)
+else (NOT INTERNAL_ACE)
+ message(STATUS "Setting up ACE (internal)")
+ set(ACE_BUILD_BITS 32)
+ set(ACE_DEBUG 0)
+ set(ACE_OPTIMIZE 1)
+ if (CMAKE_BUILD_TYPE MATCHES Debug)
+ set(ACE_DEBUG 1)
+ set(ACE_OPTIMIZE 0)
+ endif (CMAKE_BUILD_TYPE MATCHES Debug)
+ if (MG_CPU EQUAL 64)
+ set(ACE_BUILD_BITS 64)
+ endif (MG_CPU EQUAL 64)
+ set(ACE_SOURCE_DIR ${CMAKE_CURRENT_SOURCE_DIR}/Oem/ACE)
+ set(ACE_WORKING_DIR ${CMAKE_CURRENT_BINARY_DIR}/Oem/ACE)
+ ExternalProject_Add(ACE
+ SOURCE_DIR ${ACE_SOURCE_DIR}
+ BINARY_DIR ${ACE_WORKING_DIR}
+ BUILD_IN_SOURCE 0
+ BUILD_COMMAND env ACE_ROOT=${ACE_WORKING_DIR}/ACE_wrappers make buildbits=${ACE_BUILD_BITS} debug=${ACE_DEBUG} optimize=${ACE_OPTIMIZE}
+endif (NOT INTERNAL_ACE)
+# DbXml
+# HTTPD
+# PHP
+# Tomcat Connector
+# CppUnit
+# ZLib
+if (NOT INTERNAL_ZLIB)
+ message(STATUS "Finding zlib (system)")
+ find_package(GD REQUIRED)
+else (NOT INTERNAL_ZLIB)
+ message(STATUS "Setting up zlib (internal)")
+ set(ZLIB_SOURCE_DIR ${CMAKE_CURRENT_SOURCE_DIR}/Oem/gd/zlib)
+ set(ZLIB_WORKING_DIR ${CMAKE_CURRENT_BINARY_DIR}/Oem/gd/zlib)
+ ExternalProject_Add(zlib
+ SOURCE_DIR ${FREETYPE_SOURCE_DIR}
+ BINARY_DIR ${FREETYPE_WORKING_DIR}
+ BUILD_IN_SOURCE 0
+ CONFIGURE_COMMAND ./configure
+ BUILD_COMMAND make
+endif (NOT INTERNAL_ZLIB)
+# LibPNG
+# Jpeg
+# freetype
+if (NOT INTERNAL_FREETYPE)
+ message(STATUS "Finding freetype (system)")
+else (NOT INTERNAL_FREETYPE)
+ message(STATUS "Setting up freetype (internal)")
+ set(FREETYPE_SOURCE_DIR ${CMAKE_CURRENT_SOURCE_DIR}/Oem/gd/gd)
+ set(FREETYPE_WORKING_DIR ${CMAKE_CURRENT_BINARY_DIR}/Oem/gd/gd)
+ ExternalProject_Add(freetype
+ BUILD_IN_SOURCE 0
+ CONFIGURE_COMMAND ./configure --enable-static --disable-shared --without-fontconfig --enable-silent-rules --with-pic
+endif (NOT INTERNAL_FREETYPE)
+# gd
+if (NOT INTERNAL_GD)
+ message(STATUS "Finding GD (system)")
+else (NOT INTERNAL_GD)
+ message(STATUS "Setting up GD (internal)")
+ set(GD_SOURCE_DIR ${CMAKE_CURRENT_SOURCE_DIR}/Oem/gd/gd)
+ set(GD_WORKING_DIR ${CMAKE_CURRENT_BINARY_DIR}/Oem/gd/gd)
+ ExternalProject_Add(GD
+ SOURCE_DIR ${GD_SOURCE_DIR}
+ BINARY_DIR ${GD_WORKING_DIR}
+ BUILD_IN_SOURCE 0
+endif (NOT INTERNAL_GD)
+# jsoncpp
+if (NOT INTERNAL_JSONCPP)
+ message(STATUS "Finding JsonCpp (system)")
+ find_package (JsonCpp REQUIRED)
+else (NOT INTERNAL_JSONCPP)
+ message(STATUS "Setting up JsonCpp (internal)")
+ set(JSONCPP_SOURCE_DIR ${CMAKE_CURRENT_SOURCE_DIR}/Oem/jsoncpp)
+ set(JSONCPP_WORKING_DIR ${CMAKE_CURRENT_BINARY_DIR}/Oem/jsoncpp)
+ ExternalProject_Add(JsonCpp
+ SOURCE_DIR ${JSONCPP_SOURCE_DIR}
+ BINARY_DIR ${JSONCPP_WORKING_DIR}
+ BUILD_IN_SOURCE 0
+ BUILD_COMMAND scons platform=linux-gcc
+ set(JsonCpp_INCLUDE_DIR ${JSONCPP_WORKING_DIR}/include)
+ set(JsonCpp_LIBRARY lib_json)
+endif (NOT INTERNAL_JSONCPP)
+#find_package(GEOS REQUIRED)
+#find_package(ACE REQUIRED)
+#if (NOT INTERNAL_XERCES)
+# find_package(XercesC REQUIRED)
+#else (NOT INTERNAL_XERCES)
+# message(STATUS "Using internal xerces-c")
+#endif (NOT INTERNAL_XERCES)
+#find_package(GD REQUIRED)
+#find_package(Freetype REQUIRED)
+#find_package(JPEG REQUIRED)
+#find_package(PNG REQUIRED)
+#find_package(FDO REQUIRED)
+#find_package(CppUnit REQUIRED)
+#find_package(TCLAP REQUIRED)
+#find_package(LinuxApt REQUIRED)
+#find_package(DbXmlInternal REQUIRED)
+#if (INTERNAL_XERCES)
+# # This will be the same
+# set(XERCESC_INCLUDE_DIR "${DBXML_INCLUDE_DIR}")
+#endif (INTERNAL_XERCES)
+######################## End Thirdparty Section ###############################
find_package(Ant REQUIRED)
# Set internal tool paths
Modified: trunk/MgDev/Web/src/HttpHandler/CMakeLists.txt
--- trunk/MgDev/Web/src/HttpHandler/CMakeLists.txt 2018-12-10 14:54:00 UTC (rev 9421)
+++ trunk/MgDev/Web/src/HttpHandler/CMakeLists.txt 2018-12-14 15:28:35 UTC (rev 9422)
@@ -1,5 +1,3 @@
-find_package (JsonCpp REQUIRED)
include_directories(${JsonCpp_INCLUDE_DIR}
${MG_COMMON_DIR}/MdfModel
${MG_COMMON_DIR}/Foundation
Modified: trunk/MgDev/cmake_bootstrap.sh
--- trunk/MgDev/cmake_bootstrap.sh 2018-12-10 14:54:00 UTC (rev 9421)
+++ trunk/MgDev/cmake_bootstrap.sh 2018-12-14 15:28:35 UTC (rev 9422)
@@ -2,6 +2,15 @@
MG_INST_PREFIX=/usr/local/mapguideopensource-3.3.0
OEM_WORK_DIR=~/mapguide_oem_build
+INTERNAL_ACE=0
+INTERNAL_CPPUNIT=0
+INTERNAL_ZLIB=0
+INTERNAL_LIBPNG=0
+INTERNAL_JPEG=0
+INTERNAL_FREETYPE=0
+INTERNAL_GD=0
+INTERNAL_JSON=0
+INTERNAL_GEOS=0
BUILD_CPU=32
BUILD_CONFIG=Release
HAVE_SYSTEM_XERCES=0
@@ -24,6 +33,41 @@
BUILD_CONFIG=$2
shift
+ --with-all-internal)
+ INTERNAL_ACE=1
+ INTERNAL_CPPUNIT=1
+ INTERNAL_ZLIB=1
+ INTERNAL_LIBPNG=1
+ INTERNAL_JPEG=1
+ INTERNAL_FREETYPE=1
+ INTERNAL_GD=1
+ INTERNAL_JSON=1
+ INTERNAL_GEOS=1
+ --with-internal-ace)
+ INTERNAL_ACE=1
+ --with-internal-cppunit)
+ --with-internal-zlib)
+ INTERNAL_ZLIB=1
+ --with-internal-jpeg)
+ INTERNAL_JPEG=1
+ --with-internal-freetype)
+ --with-internal-gd)
+ INTERNAL_GD=1
+ --with-internal-json)
+ INTERNAL_JSON=1
+ --with-internal-geos)
+ INTERNAL_GEOS=1
--have-system-xerces)
HAVE_SYSTEM_XERCES=1
@@ -39,6 +83,16 @@
echo " --config [Release(default)|Debug]"
echo " --have-system-xerces [Use system-installed xerces]"
echo " --help [Display usage]"
+ echo " --with-internal-ace [Build/Use internal ACE]"
+ echo " --with-internal-cppunit [Build/Use internal CppUnit]"
+ echo " --with-internal-zlib [Build/Use internal zlib]"
+ echo " --with-internal-jpeg [Build/Use internal jpeg]"
+ echo " --with-internal-freetype [Build/Use internal freetype]"
+ echo " --with-internal-gd [Build/Use internal GD]"
+ echo " --with-internal-json [Build/Use internal JsonCpp]"
+ echo " --with-internal-geos [Build/Use internal GEOS]"
+ echo " --with-all-internal [Build/Use all internal libs]"
+ echo " --with-ccache [Use ccache]"
exit
esac
@@ -74,6 +128,15 @@
echo "Using system xerces: $HAVE_SYSTEM_XERCES"
echo "OEM Working Directory is: $OEM_WORK_DIR"
echo "Using ccache: $USE_CCACHE"
+echo "INTERNAL_ACE = $INTERNAL_ACE"
+echo "INTERNAL_CPPUNIT = $INTERNAL_CPPUNIT"
+echo "INTERNAL_ZLIB = $INTERNAL_ZLIB"
+echo "INTERNAL_LIBPNG = $INTERNAL_LIBPNG"
+echo "INTERNAL_JPEG = $INTERNAL_JPEG"
+echo "INTERNAL_FREETYPE = $INTERNAL_FREETYPE"
+echo "INTERNAL_GD = $INTERNAL_GD"
+echo "INTERNAL_JSON = $INTERNAL_JSON"
+echo "INTERNAL_GEOS = $INTERNAL_GEOS"
if [ "$USE_CCACHE" = "1" ]; then
export CC="ccache gcc"
@@ -87,6 +150,133 @@
echo "Created OEM working dir at: $OEM_WORK_DIR"
fi
+OEM_INSTALL_STAGE="${OEM_WORK_DIR}/install"
+mkdir -p "$OEM_INSTALL_STAGE"
+if [ "$INTERNAL_ACE" = "1" ]; then
+ echo "Building ACE (internal)"
+ cp -Rf "${SOURCE_DIR}/Oem/ACE" "${OEM_WORK_DIR}/ACE"
+ ace_buildbits=32
+ ace_debug=0
+ ace_optimize=1
+ if [ $BUILD_CONFIG = "Debug" ]; then
+ ace_debug=1
+ ace_optimize=0
+ chmod +x bin/*.sh
+ fi
+ if [ $BUILD_CPU -eq 64 ]; then
+ ace_buildbits=64
+ fi
+ cd "${OEM_WORK_DIR}/ACE/ACE_wrappers" || exit
+ ACE_PATH="${PWD}"
+ cd ace || exit
+ env ACE_ROOT="${ACE_PATH}" make buildbits=$ace_buildbits debug=$ace_debug optimize=$ace_optimize
+ check_build
+fi
+if [ "$INTERNAL_CPPUNIT" = "1" ]; then
+ echo "Building CppUnit (internal)"
+ cp -Rf "${SOURCE_DIR}/Oem/CppUnit-1.9.14" "${OEM_WORK_DIR}/CppUnit"
+ cd "${OEM_WORK_DIR}/CppUnit" || exit
+ # Force regen of configure to cover our bases
+ aclocal -I config
+ libtoolize --copy --force
+ autoconf
+ automake --add-missing --copy --force-missing
+ # -ldl is to prevent undefined reference to dlsym/dlopen/dlclose
+ sh ./configure --enable-silent-rules --prefix="${MG_INST_PREFIX}" LDFLAGS="-ldl"
+ make && make install
+ check_build
+fi
+mkdir -p "${OEM_WORK_DIR}/gd"
+if [ "$INTERNAL_ZLIB" = "1" ]; then
+ echo "Building zlib (internal)"
+ cp -Rf "${SOURCE_DIR}/Oem/gd/zlib" "${OEM_WORK_DIR}/gd/zlib"
+ cd "${OEM_WORK_DIR}/gd/zlib" || exit
+ sh ./configure --prefix="${OEM_INSTALL_STAGE}/zlib"
+ check_build
+fi
+if [ "$INTERNAL_LIBPNG" = "1" ]; then
+ echo "Building libpng (internal)"
+ cp -Rf "${SOURCE_DIR}/Oem/gd/lpng" "${OEM_WORK_DIR}/gd/lpng"
+ cd "${OEM_WORK_DIR}/gd/lpng" || exit
+ # Need to ensure these directories exist first for our custom prefix to work
+ mkdir -p "${OEM_INSTALL_STAGE}/libpng"
+ mkdir -p "${OEM_INSTALL_STAGE}/libpng/usr/local"
+ cp scripts/makefile.std makefile
+ #Inject -fPIC to CFLAGS for 64-bit
+ sed 's/^CFLAGS=/CFLAGS= -fPIC -m64 /g' makefile > makefile64
+ make -fmakefile64 DESTDIR="${OEM_INSTALL_STAGE}/libpng"
+ make -fmakefile64 DESTDIR="${OEM_INSTALL_STAGE}/libpng" install
+ check_build
+ else
+ make && make DESTDIR="${OEM_INSTALL_STAGE}/libpng" install
+ check_build
+ fi
+fi
+if [ "$INTERNAL_JPEG" = "1" ]; then
+ echo "Building libjpeg (internal)"
+ cp -Rf "${SOURCE_DIR}/Oem/gd/jpeg" "${OEM_WORK_DIR}/gd/jpeg"
+ cd "${OEM_WORK_DIR}/gd/jpeg" || exit
+ mkdir -p "${OEM_INSTALL_STAGE}/libjpeg/bin"
+ mkdir -p "${OEM_INSTALL_STAGE}/libjpeg/man/man1"
+ # A jconfig.h that is not modifed by ./configure will trip up make, so nuke it first
+ rm -f jconfig.h
+ sh ./configure --enable-static --disable-shared --prefix="${OEM_INSTALL_STAGE}/libjpeg"
+ #--with-pic does nothing (probably ancient configure script), so do some sed trickery
+ #to inject this flag. Know a better way? Enlighten us :)
+ sed 's/^CFLAGS=/CFLAGS= -fPIC -m64 /g' Makefile > Makefile64
+ make -fMakefile64
+ check_build
+ make -fMakefile64 install
+ check_build
+ else
+ make
+ check_build
+ make install
+ check_build
+ fi
+ # Make some symlinks so that PHP can work with this
+ ln -s "${OEM_WORK_DIR}/gd/jpeg" "${OEM_INSTALL_STAGE}/libjpeg/include"
+ ln -s "${OEM_WORK_DIR}/gd/jpeg/.libs" "${OEM_INSTALL_STAGE}/libjpeg/lib"
+fi
+if [ "$INTERNAL_FREETYPE" = "1" ]; then
+ echo "Building freetype (internal)"
+ cp -Rf "${SOURCE_DIR}/Oem/gd/freetype" "${OEM_WORK_DIR}/gd/freetype"
+ cd "${OEM_WORK_DIR}/gd/freetype" || exit
+ sh ./configure --enable-static --disable-shared --with-pic --prefix="${OEM_INSTALL_STAGE}/freetype"
+ else
+ sh ./configure --enable-static --disable-shared --prefix="${OEM_INSTALL_STAGE}/freetype"
+ fi
+ check_build
+fi
+if [ "$INTERNAL_GD" = "1" ]; then
+ echo "Building GD (internal)"
+ cp -Rf "${SOURCE_DIR}/Oem/gd/gd" "${OEM_WORK_DIR}/gd/gd"
+ cd "${OEM_WORK_DIR}/gd/gd" || exit
+ sh ./configure --enable-static --disable-shared --without-fontconfig --enable-silent-rules --with-pic --prefix="${OEM_INSTALL_STAGE}/gd"
+ else
+ sh ./configure --enable-static --disable-shared --without-fontconfig --enable-silent-rules --prefix="${OEM_INSTALL_STAGE}/gd"
+ fi
+ check_build
+fi
+if [ "$INTERNAL_JSON" = "1" ]; then
+ echo "Building JsonCpp (internal)"
+ cp -Rf "${SOURCE_DIR}/Oem/jsoncpp" "${OEM_WORK_DIR}/jsoncpp"
+ cd "${OEM_WORK_DIR}/jsoncpp" || exit
+ # Use system scons
+ scons platform=linux-gcc
+ check_build
+fi
echo "Checking if we need to build DBXML"
# Basically perform the same checks as FindDbXml.cmake
HAS_DBXML_HEADERS=0
@@ -113,7 +303,7 @@
# (Re)build DBXML if any of the above is false
if test $HAS_DBXML_HEADERS -eq 0 -o $HAS_DBCXX_LIB -eq 0 -o $HAS_DBXML_LIB -eq 0 -o $HAS_XQILLA_LIB -eq 0; then
echo "Re-building DBXML (${BUILD_CONFIG})"
- cp -Rf Oem/dbxml "${OEM_WORK_DIR}/dbxml"
+ cp -Rf "${SOURCE_DIR}/Oem/dbxml" "${OEM_WORK_DIR}/dbxml"
cd "${OEM_WORK_DIR}/dbxml" || exit
if test $HAVE_SYSTEM_XERCES -eq 1; then
echo "Building DBXML with system-installed xerces. Please wait"
@@ -202,14 +392,34 @@
cd "$SOURCE_DIR/Oem/LinuxApt" || exit
echo "Extracting PHP tarball"
tar -jxf php-${PHP_VER}.tar.bz2 -C "${LA_WORKDIR}"
+ echo "Configuring PHP"
+ PHP_JPEG_DIR=/usr/lib
+ PHP_PNG_DIR=/usr/lib
+ PHP_FREETYPE_DIR=/usr/lib
+ PHP_ZLIB_DIR=/usr/lib
+ if [ "$INTERNAL_JPEG" = "1" ]; then
+ PHP_JPEG_DIR="$OEM_WORK_DIR/install/libjpeg"
+ fi
+ if [ "$INTERNAL_LIBPNG" = "1" ]; then
+ PHP_PNG_DIR="$OEM_WORK_DIR/install/libpng/usr/local"
+ fi
+ if [ "$INTERNAL_FREETYPE" = "1" ]; then
+ PHP_FREETYPE_DIR="$OEM_WORK_DIR/install/freetype"
+ fi
+ if [ "$INTERNAL_ZLIB" = "1" ]; then
+ PHP_ZLIB_DIR="$OEM_WORK_DIR/install/zlib"
+ fi
cd "${PHP_WORKDIR}" || exit
- echo "Configuring PHP"
- ./configure --prefix="${MG_INSTALL_WEB_PREFIX}/php" --with-apxs2="${MG_INSTALL_WEB_PREFIX}/apache2/bin/apxs" --with-openssl --with-curl --enable-xml --enable-wddx --enable-shared --with-zlib --enable-zip --enable-mbstring=all --with-xsl=/usr/lib --with-gd --with-png-dir=/usr/lib --with-jpeg-dir=/usr/lib --with-freetype-dir=/usr/lib 2>&1 | tee "$OEM_WORK_DIR/configure_php.log"
+ # TODO: Patch out the use of meta_ccld so ccache can work: https://bugs.php.net/bug.php?id=75940
+ # if/when we finally move to PHP 7, this patch is already applied
+ ./configure --prefix="${MG_INSTALL_WEB_PREFIX}/php" --with-apxs2="${MG_INSTALL_WEB_PREFIX}/apache2/bin/apxs" --with-openssl --with-curl --enable-xml --enable-wddx --enable-shared --with-zlib-dir="$PHP_ZLIB_DIR" --enable-zip --enable-mbstring=all --with-xsl=/usr/lib --with-gd --with-png-dir="$PHP_PNG_DIR" --with-jpeg-dir="$PHP_JPEG_DIR" --with-freetype-dir="$PHP_FREETYPE_DIR" 2>&1 | tee "$OEM_WORK_DIR/configure_php.log"
check_build
echo "Building PHP. Please wait"
make 2>&1 | tee "$OEM_WORK_DIR/make_php.log"
check_build
fi
echo "Installing PHP"
make install 2>&1 | tee "$OEM_WORK_DIR/make_install_php.log"
@@ -244,6 +454,15 @@
echo "export HTTPD_PORT=$HTTPD_PORT"
echo "export TOMCAT_PORT=$TOMCAT_PORT"
echo "export HAVE_SYSTEM_XERCES=$HAVE_SYSTEM_XERCES"
+ echo "export INTERNAL_ACE=$INTERNAL_ACE"
+ echo "export INTERNAL_CPPUNIT=$INTERNAL_CPPUNIT"
+ echo "export INTERNAL_ZLIB=$INTERNAL_ZLIB"
+ echo "export INTERNAL_LIBPNG=$INTERNAL_LIBPNG"
+ echo "export INTERNAL_JPEG=$INTERNAL_JPEG"
+ echo "export INTERNAL_FREETYPE=$INTERNAL_FREETYPE"
+ echo "export INTERNAL_GD=$INTERNAL_GD"
+ echo "export INTERNAL_JSON=$INTERNAL_JSON"
+ echo "export INTERNAL_GEOS=$INTERNAL_GEOS"
} > "$OEM_WORK_DIR/env_vars.sh"
chmod +x "$OEM_WORK_DIR/env_vars.sh"
More information about the mapguide-commits
