[mapguide-commits] r9423 - in trunk/MgDev: . Web/src/HttpHandler
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Dec 14 07:31:15 PST 2018
Author: jng
Date: 2018-12-14 07:31:15 -0800 (Fri, 14 Dec 2018)
New Revision: 9423
   trunk/MgDev/CMakeLists.txt
   trunk/MgDev/Web/src/HttpHandler/CMakeLists.txt
#2786: Revert the CMakeLists.txt changes. These changes are no ready for prime time. The previous commit was only for cmake_bootstrap.sh
Modified: trunk/MgDev/CMakeLists.txt
--- trunk/MgDev/CMakeLists.txt	2018-12-14 15:28:35 UTC (rev 9422)
+++ trunk/MgDev/CMakeLists.txt	2018-12-14 15:31:15 UTC (rev 9423)
@@ -207,146 +207,26 @@
 endif ()
 find_package(Sanitizers)
-######################## Begin Thirdparty Section ###############################
-set(INTERNAL_ACE true)
-set(INTERNAL_JSONCPP true)
-set(INTERNAL_GD true)
-# ACE
-if (NOT INTERNAL_ACE)
-    message(STATUS "Finding ACE (system)")
-    find_package(ACE REQUIRED)
-else (NOT INTERNAL_ACE)
-    message(STATUS "Setting up ACE (internal)")
-    set(ACE_BUILD_BITS 32)
-    set(ACE_DEBUG 0)
-    set(ACE_OPTIMIZE 1)
-    if (CMAKE_BUILD_TYPE MATCHES Debug)
-        set(ACE_DEBUG 1)
-        set(ACE_OPTIMIZE 0)
-    endif (CMAKE_BUILD_TYPE MATCHES Debug)
-    if (MG_CPU EQUAL 64)
-        set(ACE_BUILD_BITS 64)
-    endif (MG_CPU EQUAL 64)
-    set(ACE_SOURCE_DIR ${CMAKE_CURRENT_SOURCE_DIR}/Oem/ACE)
-    set(ACE_WORKING_DIR ${CMAKE_CURRENT_BINARY_DIR}/Oem/ACE)
-    ExternalProject_Add(ACE
-        SOURCE_DIR ${ACE_SOURCE_DIR}
-        BINARY_DIR ${ACE_WORKING_DIR}
-        BUILD_IN_SOURCE 0
-        BUILD_COMMAND env ACE_ROOT=${ACE_WORKING_DIR}/ACE_wrappers make buildbits=${ACE_BUILD_BITS} debug=${ACE_DEBUG} optimize=${ACE_OPTIMIZE}
-endif (NOT INTERNAL_ACE)
-# DbXml
-# HTTPD
-# PHP
-# Tomcat Connector
-# CppUnit
-# ZLib
-if (NOT INTERNAL_ZLIB)
-    message(STATUS "Finding zlib (system)")
-    find_package(GD REQUIRED)
-else (NOT INTERNAL_ZLIB)
-    message(STATUS "Setting up zlib (internal)")
-    set(ZLIB_SOURCE_DIR ${CMAKE_CURRENT_SOURCE_DIR}/Oem/gd/zlib)
-    set(ZLIB_WORKING_DIR ${CMAKE_CURRENT_BINARY_DIR}/Oem/gd/zlib)
-    ExternalProject_Add(zlib
-        SOURCE_DIR ${FREETYPE_SOURCE_DIR}
-        BINARY_DIR ${FREETYPE_WORKING_DIR}
-        BUILD_IN_SOURCE 0
-        CONFIGURE_COMMAND ./configure
-        BUILD_COMMAND make
-endif (NOT INTERNAL_ZLIB)
-# LibPNG
-# Jpeg
-# freetype
-if (NOT INTERNAL_FREETYPE)
-    message(STATUS "Finding freetype (system)")
-else (NOT INTERNAL_FREETYPE)
-    message(STATUS "Setting up freetype (internal)")
-    set(FREETYPE_SOURCE_DIR ${CMAKE_CURRENT_SOURCE_DIR}/Oem/gd/gd)
-    set(FREETYPE_WORKING_DIR ${CMAKE_CURRENT_BINARY_DIR}/Oem/gd/gd)
-    ExternalProject_Add(freetype
-        BUILD_IN_SOURCE 0
-        CONFIGURE_COMMAND ./configure --enable-static --disable-shared --without-fontconfig --enable-silent-rules --with-pic
-endif (NOT INTERNAL_FREETYPE)
-# gd
-if (NOT INTERNAL_GD)
-    message(STATUS "Finding GD (system)")
-else (NOT INTERNAL_GD)
-    message(STATUS "Setting up GD (internal)")
-    set(GD_SOURCE_DIR ${CMAKE_CURRENT_SOURCE_DIR}/Oem/gd/gd)
-    set(GD_WORKING_DIR ${CMAKE_CURRENT_BINARY_DIR}/Oem/gd/gd)
-    ExternalProject_Add(GD
-        SOURCE_DIR ${GD_SOURCE_DIR}
-        BINARY_DIR ${GD_WORKING_DIR}
-        BUILD_IN_SOURCE 0
-endif (NOT INTERNAL_GD)
-# jsoncpp
-if (NOT INTERNAL_JSONCPP)
-    message(STATUS "Finding JsonCpp (system)")
-    find_package (JsonCpp REQUIRED)
-else (NOT INTERNAL_JSONCPP)
-    message(STATUS "Setting up JsonCpp (internal)")
-    set(JSONCPP_SOURCE_DIR ${CMAKE_CURRENT_SOURCE_DIR}/Oem/jsoncpp)
-    set(JSONCPP_WORKING_DIR ${CMAKE_CURRENT_BINARY_DIR}/Oem/jsoncpp)
-    ExternalProject_Add(JsonCpp
-        SOURCE_DIR ${JSONCPP_SOURCE_DIR}
-        BINARY_DIR ${JSONCPP_WORKING_DIR}
-        BUILD_IN_SOURCE 0
-        BUILD_COMMAND scons platform=linux-gcc
-    set(JsonCpp_INCLUDE_DIR ${JSONCPP_WORKING_DIR}/include)
-    set(JsonCpp_LIBRARY lib_json)
-endif (NOT INTERNAL_JSONCPP)
-#find_package(GEOS REQUIRED)
-#find_package(ACE REQUIRED)
-#if (NOT INTERNAL_XERCES)
-#    find_package(XercesC REQUIRED)
-#else (NOT INTERNAL_XERCES)
-#    message(STATUS "Using internal xerces-c")
-#endif (NOT INTERNAL_XERCES)
-#find_package(GD REQUIRED)
-#find_package(Freetype REQUIRED)
-#find_package(JPEG REQUIRED)
-#find_package(PNG REQUIRED)
-#find_package(FDO REQUIRED)
-#find_package(CppUnit REQUIRED)
-#find_package(TCLAP REQUIRED)
-#find_package(LinuxApt REQUIRED)
-#find_package(DbXmlInternal REQUIRED)
-#if (INTERNAL_XERCES)
-#    # This will be the same
-#    set(XERCESC_INCLUDE_DIR "${DBXML_INCLUDE_DIR}")
-#endif (INTERNAL_XERCES)
-######################## End Thirdparty Section ###############################
+find_package(GEOS REQUIRED)
+find_package(ACE REQUIRED)
+if (NOT INTERNAL_XERCES)
+    find_package(XercesC REQUIRED)
+else (NOT INTERNAL_XERCES)
+    message(STATUS "Using internal xerces-c")
+endif (NOT INTERNAL_XERCES)
+find_package(GD REQUIRED)
+find_package(Freetype REQUIRED)
+find_package(JPEG REQUIRED)
+find_package(PNG REQUIRED)
+find_package(FDO REQUIRED)
+find_package(CppUnit REQUIRED)
+find_package(TCLAP REQUIRED)
+find_package(LinuxApt REQUIRED)
+find_package(DbXmlInternal REQUIRED)
+if (INTERNAL_XERCES)
+    # This will be the same
+    set(XERCESC_INCLUDE_DIR "${DBXML_INCLUDE_DIR}")
+endif (INTERNAL_XERCES)
 find_package(Ant REQUIRED)
 # Set internal tool paths
Modified: trunk/MgDev/Web/src/HttpHandler/CMakeLists.txt
--- trunk/MgDev/Web/src/HttpHandler/CMakeLists.txt	2018-12-14 15:28:35 UTC (rev 9422)
+++ trunk/MgDev/Web/src/HttpHandler/CMakeLists.txt	2018-12-14 15:31:15 UTC (rev 9423)
@@ -1,3 +1,5 @@
+find_package (JsonCpp REQUIRED)
 include_directories(${JsonCpp_INCLUDE_DIR}
     ${MG_COMMON_DIR}/MdfModel
     ${MG_COMMON_DIR}/Foundation
More information about the mapguide-commits mailing list
