[mapguide-commits] r9401 - in sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide: . slate
svn_mapguide at osgeo.org
Thu Jul 26 09:08:49 PDT 2018
Author: jng
Date: 2018-07-26 09:08:49 -0700 (Thu, 26 Jul 2018)
New Revision: 9401
Added:
sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/images/
sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/index.php
sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/slate/index.templ
Add new top-level template entry point (index.php). This accepts the following parameters:
- templateName: The name of the template to load
- any existing parameter supported by the current templates
The purpose of this entry point is to:
- Eliminate the initial roundtrip to get the ApplicationDefinition content
- Be able to safely add any script tags for external services like Google Maps
Instead of calling fusion/templates/mapguide/$TEMPLATE_NAME/index.html?... one would instead call fusion/templates/mapguide/index.php?templateName=$TEMPLATE_NAME&...
A new index.templ is added to the various templates that index.php will plug in all the required placeholders. Currently only slate has this new templates. Subsequent commits will add this new file for the other templates.
A small change as a result of this new entry point is that image assets URLs break because index.php is one level up. A copy of the current image assets have been added up one level to match.
These templates requires the cms_refactor sandbox branch of Fusion to work. It is expected when complete that both sandbox branches will be merged in tandem.
Added: sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/index.php
--- sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/index.php (rev 0)
+++ sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/index.php 2018-07-26 16:08:49 UTC (rev 9401)
@@ -0,0 +1,73 @@
+<?php
+require_once("../../layers/MapGuide/php/Common.php");
+require_once('../../common/php/Utilities.php');
+if (InitializationErrorOccurred())
+ DisplayInitializationErrorHTML();
+ exit;
+$locale = GetDefaultLocale();
+$params = $_GET;
+if (!array_key_exists("template", $params))
+ echo "<p>Missing required parameter: template</p>";
+ exit;
+if (!array_key_exists("ApplicationDefinition", $params))
+ echo "<p>Missing required parameter: ApplicationDefinition</p>";
+ exit;
+$bDebug = (array_key_exists("debug", $params) && $params["debug"] == "1");
+$templateName = strtolower($params["template"]);
+$appDef = $params["ApplicationDefinition"];
+$templatePath = dirname(__FILE__)."/$templateName/index.templ";
+if (!file_exists($templatePath)) {
+ echo "<p>Template ($templateName) not found</p>";
+ exit;
+//Requests to this script can be made from anywhere, so disable XML entity loading to
+//guard against malicious XML
+libxml_disable_entity_loader(true);
+try {
+ $resourceService = $siteConnection->CreateService(MgServiceType::ResourceService);
+ $appDefId = new MgResourceIdentifier($appDef);
+ $content = $resourceService->GetResourceContent($appDefId);
+ $document = new DOMDocument();
+ $document->loadXML($content->ToString());
+ $root = $document->documentElement;
+ $json = '{"' . $root->tagName . '":' . xml2json($root) . '}';
+ $scriptName = "fusionSF-compressed";
+ if ($bDebug) {
+ $scriptName = "fusion";
+ $content = file_get_contents($templatePath);
+ $content = str_replace("%__LIB_BASE__%", "../../lib", $content);
+ $content = str_replace("%__TEMPLATE_BASE__%", "$templateName", $content);
+ $content = str_replace("%__FUSION_SCRIPT__%", $scriptName, $content);
+ $content = str_replace("%__SCRIPTS__%", "<!-- TODO: Inject Google Maps script if required -->", $content);
+ $content = str_replace("%__APPDEF_JSON__%", $json, $content);
+ header("Content-Type: text/html");
+ echo $content;
+} catch (MgException $ex) {
+ $initializationErrorMessage = $ex->GetExceptionMessage();
+ $initializationErrorDetail = $ex->GetDetails();
+ $initializationErrorStackTrace = $ex->GetStackTrace();
\ No newline at end of file
Added: sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/slate/index.templ
--- sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/slate/index.templ (rev 0)
+++ sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/slate/index.templ 2018-07-26 16:08:49 UTC (rev 9401)
@@ -0,0 +1,303 @@
+<!DOCTYPE html>
+<html>
+<head>
+<title>Slate</title>
+<meta http-equiv="Content-type" content="text/html; charset=utf-8" />
+<meta http-equiv="X-UA-Compatible" content="IE=edge" />
+<meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no" />
+%__SCRIPTS__%
+<script type="text/javascript" src="%__LIB_BASE__%/%__FUSION_SCRIPT__%.js"></script>
+<link rel="stylesheet" href="%__LIB_BASE__%/jxLib/themes/delicious/jxtheme.css" type="text/css" media="screen" charset="utf-8" />
+<link rel="stylesheet" href="%__TEMPLATE_BASE__%/slate.css" type="text/css" media="screen" charset="utf-8" />
+<!--[if lte IE 6]>
+<link rel="stylesheet" href="%__TEMPLATE_BASE__%/ie6.css" type="text/css" media="screen" charset="utf-8" />
+<![endif]-->
+<!--[if IE 7]>
+<link rel="stylesheet" href="%__TEMPLATE_BASE__%/ie7.css" type="text/css" media="screen" charset="utf-8" />
+<![endif]-->
+<link rel="stylesheet" href="%__TEMPLATE_BASE__%/icons.css" type="text/css" media="screen" charset="utf-8" />
+<script type="text/javascript">
+var panel1;
+var panel2;
+var panel3;
+var panelman;
+var dOverviewMap;
+var COLLAPSED_SIDEBAR_WIDTH = 8;
+var appDefJson = %__APPDEF_JSON__%;
+window.onload = function() {
+ Fusion.initializeLocale(); //need to call this first if String.Translate is to be used in the onload
+ var main = new Jx.Layout('AppContainer');
+ new Jx.Layout('FileMenuContainer', {height: 24, top: 0, bottom: null});
+ new Jx.Layout('SplitterArea', {left: 2, right: 2, top: 2, bottom: 23});
+ new Jx.Layout('ToolbarContainer', {height: 56, top: 26, bottom: null});
+ new Jx.Layout('Map', {left: 0, right: 0, top: 76, bottom: 0});
+ new Jx.Layout('StatusbarContainer', {height: 21, left: 0, right: 0, top: null, bottom: 0});
+ new Jx.Layout('Statusbar', {height: 21, left: 0, right: 159, top: null, bottom: 0});
+ var splitter = new Jx.Splitter('SplitterArea', {
+ splitInto:2,
+ elements:[$('Sidebar'),$('MapArea')],
+ layout:'horizontal',
+ containerOptions: [{minWidth:COLLAPSED_SIDEBAR_WIDTH, width: 218}],
+ barOptions: [{
+ snap: 'before',
+ snapElement: $('SidebarCollapse'),
+ snapEvents: ['click']
+ panel1 = new Jx.Panel({
+ label: OpenLayers.i18n('legendTitle'),
+ collapse: true,
+ maximize: true,
+ contentId: 'Legend'
+ panel2 = new Jx.Panel({
+ label: OpenLayers.i18n('selectionPanelTitle'),
+ collapse: true,
+ maximize: true,
+ contentId: 'SelectionPanel'
+ panel3 = new Jx.Panel({
+ label: OpenLayers.i18n('taskPaneTitle'),
+ collapse: true,
+ maximize: true,
+ contentId: 'TaskPane'
+ panelman = new Jx.PanelSet({
+ parent: splitter.elements[0],
+ panels: [panel1, panel2, panel3]
+ dOverviewMap = new Jx.Dialog({
+ id: 'dialogNavigator',
+ label: OpenLayers.i18n('ovmapTitle'),
+ modal: false,
+ resize: false,
+ collapse: false,
+ horizontal: 'right -10',
+ vertical: 'bottom -10',
+ width: 200,
+ height: 200
+ dOverviewMap.content.id = 'OverviewMap';
+ main.addEvent('sizeChange', function(){
+ if (dOverviewMap.domObj.getStyle('display') != 'none'){
+ dOverviewMap.show();
+ main.resize();
+ Fusion.registerForEvent(Fusion.Event.FUSION_INITIALIZED, fusionInitialized);
+ Fusion.registerForEvent(Fusion.Event.FUSION_ERROR, fusionError);
+ Fusion.initialize({
+ appDef: appDefJson
+ dOverviewMap.open();
+var showErrorDialog = function(msg) {
+ var errorDialog = new Jx.Dialog({
+ label: "Fusion Error",
+ image: "images/icons/error.png",
+ width: 800,
+ height: 400,
+ modal: true,
+ resize: true,
+ move: true,
+ content: msg
+ errorDialog.show();
+var fusionError = function(eventId, error) {
+ if (error instanceof Fusion.DetailedError) {
+ //Case 1: Session Expiry
+ if (error.message.indexOf("MgSessionExpiredException") >= 0) {
+ var sessionId = Fusion.getQueryParam("Session");
+ var map = Fusion.getMapByIndice(0);
+ //Graceful reload is only possible if session id was not passed in as a query parameter
+ if (sessionId == "") {
+ map.message.error(OpenLayers.i18n('sessionExpired') + ' <a href="javascript:window.location.reload()">' + OpenLayers.i18n("reload") + '</a>');
+ } else {
+ map.message.error(OpenLayers.i18n('sessionExpired'));
+ return;
+ //Default Case: Show a formatted summary of the error
+ var fmtStack = "";
+ for (var i = 0; i < error.stack.length; i++) {
+ var stackFrame = error.stack[i];
+ fmtStack += " - " + (stackFrame.func != "" ? stackFrame.func : "?") + " at " + stackFrame.url + " (line: " + stackFrame.line + ")";
+ fmtStack += "\n";
+ var message = OpenLayers.i18n("detailedErrorTemplateHtml", {
+ name: error.name,
+ source: error.url,
+ message: error.message,
+ stacktrace: fmtStack
+ showErrorDialog(message);
+ console.log('Fusion Error: \n' + message);
+ } else {
+ var errorMessage = error.toString();
+ var readableMessage = '';
+ //Case 1: For dealing with Function: convertXML (fusion.js)
+ // xml2json: function(callback, r, json) {
+ // if (json) {
+ // var o;
+ // eval("o="+r.responseText);
+ // callback(o);
+ // } else {
+ // if (r.status >= 400) {
+ // Fusion.reportError(new Fusion.Error(Fusion.Error.FATAL,
+ // 'xml2json: invalid XML document: ' + r.transport.responseText + " : " + r.request.url));
+ // return;
+ var tagStart = '<h2>';
+ var tagEnd = '</h2>';
+ var indexStart = errorMessage.indexOf(tagStart);
+ var indexEnd = errorMessage.indexOf(tagEnd, tagStart);
+ if (indexStart != -1 && indexEnd != -1) {
+ readableMessage = errorMessage.substring(indexStart + tagStart.length, indexEnd);
+ readableMessage = readableMessage.replace(/\\n/g, '\n');
+ readableMessage = readableMessage.replace(/\\t/g, '\t');
+ readableMessage = readableMessage.replace(/\\'/g, '\'');
+ if (readableMessage != '') {
+ showErrorDialog(readableMessage);
+ else {
+ showErrorDialog('Fusion Error: \n' + errorMessage);
+ console.log('Fusion Error: \n' + errorMessage);
+var fusionInitialized = function() {
+ $('AppContainer').resize({forceResize: true});
+ var mapWidget = Fusion.getMapById('Map');
+ mapWidget.registerForEvent(Fusion.Event.MAP_LOADED, initPanelHandler);
+var isTaskPaneRegistered = false;
+var initPanelHandler = function() {
+ if(isTaskPaneRegistered) return;
+ //register this with MAP_LOADED so that the initial layout will remain
+ Fusion.registerForEvent(Fusion.Event.TASK_PANE_LOADED, showTaskPane);
+ isTaskPaneRegistered = true;
+var showOverviewMap = function() {
+var showSidebarIfCollapsed = function() {
+ if ($("Sidebar").getWidth() <= COLLAPSED_SIDEBAR_WIDTH)
+ $("SidebarCollapse").fireEvent("click");
+var showTaskPane = function() {
+ showSidebarIfCollapsed();
+ panelman.maximizePanel(panel3);
+var showLegend = function() {
+ panelman.maximizePanel(panel1);
+var showSelectionPanel = function() {
+ panelman.maximizePanel(panel2);
+</script>
+<!--style type="text/css">
+body { overflow: hidden }
+#StatusNavigator {
+ position: absolute;
+ right: 139px;
+ padding-top: 2px;
+#pbmg {
+ right: 0px;
+ padding-top: 2px;
+</style-->
+</head>
+<body>
+<div id="AppContainer">
+ <div id="SplitterArea">
+ <div id="Sidebar">
+ <!-- Collapse Sidebar -->
+ <div id="SidebarCollapse">
+ <div id="SidebarCollapseTop"></div>
+ <div id="SidebarCollapseContent">
+ <a id="SidebarCollapseButton" href="#"></a>
+ </div>
+ <div id="SidebarCollapseBottom"></div>
+ </div>
+ </div>
+ <div id="MapArea">
+ <!-- File Menu -->
+ <div id="FileMenuContainer">
+ <div id="FileMenu"></div>
+ <div id="FileMenuLeft"></div>
+ <div id="FileMenuRight"></div>
+ </div>
+ <!-- /File Menu -->
+ <!-- Toolbar -->
+ <div id="ToolbarContainer">
+ <div id="Toolbar"></div>
+ <div id="ToolbarLeft"></div>
+ <div id="ToolbarRight"></div>
+ <!-- I dont know about this one... -->
+ <div id="ToolbarSecondary"></div>
+ <div id="ToolbarSecondaryLeft"></div>
+ <div id="ToolbarSecondaryRight"></div>
+ </div>
+ <!-- /Toolbar -->
+ <div id="Map">
+ <div id="Navigator"></div>
+ </div>
+ </div>
+ </div>
+ <!-- /Collapse Sidebar -->
+ <!--<div id="OverviewMapContent"></div>-->
+ <div id="StatusbarContainer">
+ <div id="Statusbar"></div>
+ <div id="StatusNavigator"></div>
+ <div id="pbmg"><img src="%__TEMPLATE_BASE__%/images/pbmg.png" alt=""></div>
+ </div>
+</div>
+<div id="Maptip"></div>
+</body>
+</html>
More information about the mapguide-commits
