[mapguide-commits] r9402 - in sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide: . aqua limegold maroon slate turquoiseyellow
svn_mapguide at osgeo.org
Thu Jul 26 09:23:27 PDT 2018
Author: jng
Date: 2018-07-26 09:23:26 -0700 (Thu, 26 Jul 2018)
New Revision: 9402
Added:
sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/aqua/index.templ
sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/limegold/index.templ
sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/maroon/index.templ
sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/turquoiseyellow/index.templ
sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/aqua.xml
sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/limegold.xml
sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/maroon.xml
sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/slate.xml
sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/slate/index.templ
sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/turquoiseyellow.xml
Add the index.templ for the remaining templates. Also update template metadata files so that they refer to the new unified template.
This may subtly break our authoring tools (like Maestro) that probably assume the template URL does not already have query string parameters (and blindly tack on "?" and their specific parameters afterwards), so they will need to be updated to not assume this anymore.
Added: sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/aqua/index.templ
--- sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/aqua/index.templ (rev 0)
+++ sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/aqua/index.templ 2018-07-26 16:23:26 UTC (rev 9402)
@@ -0,0 +1,268 @@
+<!DOCTYPE html>
+<html>
+<head>
+<title>Aqua</title>
+<meta http-equiv="Content-type" content="text/html; charset=utf-8" />
+<meta http-equiv="X-UA-Compatible" content="IE=edge" />
+<meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no" />
+%__SCRIPTS__%
+<script type="text/javascript" src="%__LIB_BASE__%/%__FUSION_SCRIPT__%.js"></script>
+<link rel="stylesheet" href="%__LIB_BASE__%/jxLib/themes/delicious/jxtheme.css" type="text/css" media="screen" charset="utf-8" />
+<link rel="stylesheet" href="%__TEMPLATE_BASE__%/aqua.css" type="text/css" media="screen" charset="utf-8" />
+<!--[if lte IE 6]>
+<link rel="stylesheet" href="%__TEMPLATE_BASE__%/ie6.css" type="text/css" media="screen" charset="utf-8" />
+<![endif]-->
+<!--[if IE 7]>
+<link rel="stylesheet" href="%__TEMPLATE_BASE__%/ie7.css" type="text/css" media="screen" charset="utf-8" />
+<![endif]-->
+<link rel="stylesheet" href="%__TEMPLATE_BASE__%/icons.css" type="text/css" media="screen" charset="utf-8" />
+<script type="text/javascript">
+var dOverviewMap;
+var dTasks;
+var dLegend;
+var appDefJson = %__APPDEF_JSON__%;
+window.onload = function() {
+ Fusion.initializeLocale(); //need to call this first if String.Translate is to be used in the onload
+ var main = new Jx.Layout('AppContainer');
+ new Jx.Layout('FileMenu', {height: 34, bottom: null});
+ new Jx.Layout('Toolbar', {height: 25, top: 34, bottom: null});
+ new Jx.Layout('ToolbarVertical', {width: 25, right: null, top: 59, bottom: 21});
+ new Jx.Layout('Map', {left: 25, right: 0, top: 59, bottom: 21});
+ new Jx.Layout('StatusbarContainer', {height: 21, top: null, bottom: 0});
+ new Jx.Layout('Statusbar', {height: 21, right: 159, top: null, bottom: 0});
+ dOverviewMap = new Jx.Dialog({
+ id: 'dialogOverviewMap',
+ label: OpenLayers.i18n('ovmapTitle'),
+ modal: false,
+ resize: false,
+ horizontal: 'right -10',
+ vertical: 'bottom -10',
+ width: 300,
+ height: 300,
+ contentId: 'OverviewMap'
+ dOverviewMap.open();
+ dLegend = new Jx.Dialog({
+ id: 'dialogLegend',
+ label: OpenLayers.i18n('legendTitle'),
+ modal: false,
+ resize: true,
+ vertical: '10 top',
+ width: 300,
+ height: 400,
+ contentId: 'Legend'
+ dTasks = new Jx.Dialog({
+ id: 'dialogTasks',
+ label: OpenLayers.i18n('taskPaneTitle'),
+ modal: false,
+ resize: true,
+ horizontal: '50 left',
+ width: 400,
+ height: 400,
+ contentId: 'TaskPane'
+ dSelection = new Jx.Dialog({
+ id: 'dialogSelection',
+ label: OpenLayers.i18n('selectionPanelTitle'),
+ modal: false,
+ resize: true,
+ width: 400,
+ height: 400,
+ contentId: 'SelectionPanel'
+ main.addEvent('sizeChange', function(){
+ if (dOverviewMap.domObj.getStyle('display') != 'none'){
+ dOverviewMap.show();
+ if (dLegend.domObj.getStyle('display') != 'none'){
+ dLegend.show();
+ if (dTasks.domObj.getStyle('display') != 'none'){
+ dTasks.show();
+ if (dSelection.domObj.getStyle('display') != 'none'){
+ dSelection.show();
+ main.resize();
+ Fusion.registerForEvent(Fusion.Event.FUSION_INITIALIZED, fusionInitialized);
+ Fusion.registerForEvent(Fusion.Event.FUSION_ERROR, fusionError);
+ Fusion.initialize({
+ appDef: appDefJson
+var showErrorDialog = function(msg) {
+ var errorDialog = new Jx.Dialog({
+ label: "Fusion Error",
+ image: "images/icons/error.png",
+ width: 800,
+ height: 400,
+ modal: true,
+ resize: true,
+ move: true,
+ content: msg
+ errorDialog.show();
+var fusionError = function(eventId, error) {
+ if (error instanceof Fusion.DetailedError) {
+ //Case 1: Session Expiry
+ if (error.message.indexOf("MgSessionExpiredException") >= 0) {
+ var sessionId = Fusion.getQueryParam("Session");
+ var map = Fusion.getMapByIndice(0);
+ //Graceful reload is only possible if session id was not passed in as a query parameter
+ if (sessionId == "") {
+ map.message.error(OpenLayers.i18n('sessionExpired') + ' <a href="javascript:window.location.reload()">' + OpenLayers.i18n("reload") + '</a>');
+ } else {
+ map.message.error(OpenLayers.i18n('sessionExpired'));
+ return;
+ //Default Case: Show a formatted summary of the error
+ var fmtStack = "";
+ for (var i = 0; i < error.stack.length; i++) {
+ var stackFrame = error.stack[i];
+ fmtStack += " - " + (stackFrame.func != "" ? stackFrame.func : "?") + " at " + stackFrame.url + " (line: " + stackFrame.line + ")";
+ fmtStack += "\n";
+ var message = OpenLayers.i18n("detailedErrorTemplateHtml", {
+ name: error.name,
+ source: error.url,
+ message: error.message,
+ stacktrace: fmtStack
+ showErrorDialog(message);
+ console.log('Fusion Error: \n' + message);
+ } else {
+ var errorMessage = error.toString();
+ var readableMessage = '';
+ //Case 1: For dealing with Function: convertXML (fusion.js)
+ // xml2json: function(callback, r, json) {
+ // if (json) {
+ // var o;
+ // eval("o="+r.responseText);
+ // callback(o);
+ // } else {
+ // if (r.status >= 400) {
+ // Fusion.reportError(new Fusion.Error(Fusion.Error.FATAL,
+ // 'xml2json: invalid XML document: ' + r.transport.responseText + " : " + r.request.url));
+ // return;
+ var tagStart = '<h2>';
+ var tagEnd = '</h2>';
+ var indexStart = errorMessage.indexOf(tagStart);
+ var indexEnd = errorMessage.indexOf(tagEnd, tagStart);
+ if (indexStart != -1 && indexEnd != -1) {
+ readableMessage = errorMessage.substring(indexStart + tagStart.length, indexEnd);
+ readableMessage = readableMessage.replace(/\\n/g, '\n');
+ readableMessage = readableMessage.replace(/\\t/g, '\t');
+ readableMessage = readableMessage.replace(/\\'/g, '\'');
+ if (readableMessage != '') {
+ showErrorDialog(readableMessage);
+ else {
+ showErrorDialog('Fusion Error: \n' + errorMessage);
+ console.log('Fusion Error: \n' + errorMessage);
+var fusionInitialized = function() {
+ $('AppContainer').resize({forceResize: true});
+ $('AppContainer').style.visibility = 'visible';
+ var mapWidget = Fusion.getMapById('Map');
+ mapWidget.registerForEvent(Fusion.Event.MAP_LOADED, initPanelHandler);
+var isTaskPaneRegistered = false;
+var initPanelHandler = function() {
+ if(isTaskPaneRegistered) return;
+ //register this with MAP_LOADED so that the initial layout will remain
+ Fusion.registerForEvent(Fusion.Event.TASK_PANE_LOADED, showTaskPane);
+ isTaskPaneRegistered = true;
+var showOverviewMap = function() {
+var showTaskPane = function() {
+ dTasks.open();
+var showLegend = function() {
+ dLegend.open();
+var showSelectionPanel = function() {
+ dSelection.open();
+</script>
+</head>
+<body>
+<div id="AppContainer" style="visibility: hidden;">
+ <div id="Map">
+ <div id="Navigator"></div>
+ </div>
+ <!-- File Menu -->
+ <div id="FileMenu"></div>
+ <!-- /File Menu -->
+ <!-- Toolbar -->
+ <div id="Toolbar"></div>
+ <!-- /Toolbar -->
+ <!-- Toolbar Vertical -->
+ <div id="ToolbarVertical"></div>
+ <!-- /Toolbar Vertical -->
+ <div id="StatusbarContainer">
+ <div id="Statusbar"></div>
+ <div id="StatusOverviewMap"></div>
+ <div id="pbmg"><img src="images/pbmg.png" alt=""></div>
+ </div>
+ <div id="Maptip"></div>
+</div>
+<div id="TaskPane"></div>
+<div id="OverviewMap"></div>
+<div id="Legend"></div>
+<div id="SelectionPanel"></div>
+</body>
+</html>
Modified: sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/aqua.xml
--- sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/aqua.xml 2018-07-26 16:08:49 UTC (rev 9401)
+++ sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/aqua.xml 2018-07-26 16:23:26 UTC (rev 9402)
@@ -1,6 +1,6 @@
<TemplateInfo>
<Name>Aqua</Name>
-<LocationUrl>fusion/templates/mapguide/aqua/index.html</LocationUrl>
+<LocationUrl>fusion/templates/mapguide/index.php?template=aqua</LocationUrl>
<Description>Aqua template</Description>
<PreviewImageUrl>fusion/templates/mapguide/aqua/preview.png</PreviewImageUrl>
Added: sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/limegold/index.templ
--- sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/limegold/index.templ (rev 0)
+++ sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/limegold/index.templ 2018-07-26 16:23:26 UTC (rev 9402)
@@ -0,0 +1,266 @@
+<!DOCTYPE html>
+<html>
+<head>
+<title>LimeGold</title>
+%__SCRIPTS__%
+<link rel="stylesheet" href="%__TEMPLATE_BASE__%/limegold.css" type="text/css" media="screen" charset="utf-8" />
+<!--[if lte IE 6]>
+<![endif]-->
+<!--[if IE 7]>
+<![endif]-->
+var tab1;
+var tab2;
+var tab3;
+var tabbox1;
+var COLLAPSED_SIDEBAR_WIDTH = 8;
+ new Jx.Layout('Toolbar', {height: 24, top: 34, bottom: null});
+ new Jx.Layout('ToolbarSecondary', {height: 24, top: 58, bottom: null});
+ new Jx.Layout('SplitterArea', {left: 0, right: 0, top: 82, bottom: 21});
+ new Jx.Layout('Statusbar', {height: 21, right: 141, top: null});
+ new Jx.Layout('Map');
+ var splitter = new Jx.Splitter('SplitterArea', {
+ splitInto:2,
+ elements:[$('Main'),$('Sidebar')],
+ layout:'horizontal',
+ containerOptions: [{},{minWidth:COLLAPSED_SIDEBAR_WIDTH, width: 214}],
+ barOptions: [{
+ snap: 'after',
+ snapElement: $('SidebarCollapse'),
+ snapEvents: ['click']
+ var splitter2 = new Jx.Splitter('Sidebar', {
+ splitInto:2,
+ elements:[$('Info'),$('Bottom')],
+ layout:'vertical',
+ {height: 214, minHeight: 214, maxHeight: 214}
+ /* create dynamic content */
+ tabbox1 = new Jx.TabBox({parent: splitter2.elements[0]});
+ tab1 = new Jx.Tab({
+ tab2 = new Jx.Tab({
+ tab3 = new Jx.Tab({
+ tabbox1.add(tab1, tab2, tab3);
+ var tabbox2 = new Jx.TabBox({parent: splitter2.elements[1]});
+ var tab4 = new Jx.Tab({
+ contentId: 'OverviewMap'});
+ tabbox2.add(tab4);
+ main.resize();
+ width: 800,
+ height: 400,
+ modal: true,
+ resize: true,
+ move: true,
+ content: msg
+ } else {
+ return;
+ fmtStack += "\n";
+ name: error.name,
+ } else {
+ // if (json) {
+ // var o;
+ // callback(o);
+ // } else {
+ // return;
+ else {
+ //Fusion.getWidgetById('ToolbarSecondary').checkPosition();
+ showSidebarIfCollapsed();
+var showSidebarIfCollapsed = function() {
+ if ($("Sidebar").getWidth() <= COLLAPSED_SIDEBAR_WIDTH)
+ $("SidebarCollapse").fireEvent("click");
+ tab1.setActive(true);
+ tab2.setActive(true);
+ tab3.setActive(true);
+</script>
+</head>
+<body>
+<div id="AppContainer">
+ <div id="ToolbarSecondary"></div>
+ <div id="SplitterArea">
+ <div id="Sidebar">
+ <div id="Info"></div>
+ <div id="Bottom"></div>
+ <!-- Collapse Sidebar -->
+ <div id="SidebarCollapse">
+ <div id="SidebarCollapseTop"></div>
+ <div id="SidebarCollapseContent">
+ <a id="SidebarCollapseButton" href="#"></a>
+ </div>
+ <div id="SidebarCollapseBottom"></div>
+ </div>
+ </div>
+ <div id="Main">
+ <div id="Map">
+ </div>
+ </div>
+ </div>
+ </div>
+</div>
+<div id="Maptip"></div>
+</body>
+</html>
Modified: sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/limegold.xml
--- sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/limegold.xml 2018-07-26 16:08:49 UTC (rev 9401)
+++ sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/limegold.xml 2018-07-26 16:23:26 UTC (rev 9402)
@@ -1,6 +1,6 @@
<TemplateInfo>
<Name>LimeGold</Name>
-<LocationUrl>fusion/templates/mapguide/limegold/index.html</LocationUrl>
+<LocationUrl>fusion/templates/mapguide/index.php?template=limegold</LocationUrl>
<Description>Lime-Gold template</Description>
<PreviewImageUrl>fusion/templates/mapguide/limegold/preview.png</PreviewImageUrl>
Added: sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/maroon/index.templ
--- sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/maroon/index.templ (rev 0)
+++ sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/maroon/index.templ 2018-07-26 16:23:26 UTC (rev 9402)
@@ -0,0 +1,281 @@
+<!DOCTYPE html>
+<html>
+<head>
+<title>Maroon</title>
+%__SCRIPTS__%
+<link rel="stylesheet" href="%__TEMPLATE_BASE__%/maroon.css" type="text/css" media="screen" charset="utf-8" />
+<!--[if lte IE 6]>
+<![endif]-->
+<!--[if IE 7]>
+<![endif]-->
+var panel1;
+var panel2;
+var panel3;
+var panel4;
+var panelman;
+ left: 5,
+ right: 5,
+ top: 5,
+ height: 25
+ left: 5,
+ right: 5,
+ top: 30,
+ height: 24
+ left: 5,
+ width: 28,
+ top: 54,
+ bottom: 21
+ left: 33,
+ top: 54,
+ right: 5,
+ bottom: 22
+ new Jx.Layout('MapArea');
+ height: 22,
+ bottom: 0,
+ top: null
+ right: 159
+ splitInto:2,
+ elements:[$('MapArea'),$('Sidebar')],
+ containerOptions: [{},{minWidth:COLLAPSED_SIDEBAR_WIDTH, width: 218}],
+ barOptions: [
+ snap: 'after',
+ panel1 = new Jx.Panel({
+ collapse: true,
+ maximize: true,
+ contentId: 'Legend'});
+ panel1.content.id = 'Legend';
+ panel2 = new Jx.Panel({
+ collapse: true,
+ maximize: true,
+ contentId: 'SelectionPanel'});
+ panel3 = new Jx.Panel({
+ collapse: true,
+ maximize: true,
+ contentId: 'TaskPane'});
+ panel4 = new Jx.Panel({
+ collapse: true,
+ maximize: true,
+ panelman = new Jx.PanelSet({parent: splitter.elements[1], panels: [panel1, panel2, panel3, panel4]});
+ main.resize();
+ width: 800,
+ height: 400,
+ modal: true,
+ resize: true,
+ move: true,
+ content: msg
+ } else {
+ return;
+ fmtStack += "\n";
+ name: error.name,
+ } else {
+ // if (json) {
+ // var o;
+ // callback(o);
+ // } else {
+ // return;
+ else {
+ if ($("Sidebar").getWidth() <= (COLLAPSED_SIDEBAR_WIDTH + 1)) //Template-specific
+ panelman.maximizePanel(panel4);
+ panelman.maximizePanel(panel3);
+ panelman.maximizePanel(panel1);
+ panelman.maximizePanel(panel2);
+</script>
+</head>
+<body>
+ <div id="MapArea">
+ <div id="Map"></div>
+ </div>
+ </div>
+ </div>
+ </div>
+ <div id="pbmg"><img src="images/pbmg.gif" alt=""></div>
+ </div>
+</div>
+</body>
+</html>
Modified: sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/maroon.xml
--- sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/maroon.xml 2018-07-26 16:08:49 UTC (rev 9401)
+++ sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/maroon.xml 2018-07-26 16:23:26 UTC (rev 9402)
@@ -1,6 +1,6 @@
<TemplateInfo>
<Name>Maroon</Name>
-<LocationUrl>fusion/templates/mapguide/maroon/index.html</LocationUrl>
+<LocationUrl>fusion/templates/mapguide/index.php?template=maroon</LocationUrl>
<Description>Maroon template</Description>
<PreviewImageUrl>fusion/templates/mapguide/maroon/preview.png</PreviewImageUrl>
Modified: sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/slate/index.templ
--- sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/slate/index.templ 2018-07-26 16:08:49 UTC (rev 9401)
+++ sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/slate/index.templ 2018-07-26 16:23:26 UTC (rev 9402)
@@ -23,7 +23,6 @@
var panelman;
var dOverviewMap;
@@ -96,7 +95,6 @@
Fusion.initialize({
appDef: appDefJson
Modified: sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/slate.xml
--- sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/slate.xml 2018-07-26 16:08:49 UTC (rev 9401)
+++ sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/slate.xml 2018-07-26 16:23:26 UTC (rev 9402)
@@ -1,6 +1,6 @@
<TemplateInfo>
<Name>Slate</Name>
-<LocationUrl>fusion/templates/mapguide/slate/index.html</LocationUrl>
+<LocationUrl>fusion/templates/mapguide/index.php?template=slate</LocationUrl>
<Description>Slate template</Description>
<PreviewImageUrl>fusion/templates/mapguide/slate/preview.png</PreviewImageUrl>
Added: sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/turquoiseyellow/index.templ
--- sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/turquoiseyellow/index.templ (rev 0)
+++ sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/turquoiseyellow/index.templ 2018-07-26 16:23:26 UTC (rev 9402)
@@ -0,0 +1,242 @@
+<!DOCTYPE html>
+<html>
+<head>
+<title>TurquoiseYellow</title>
+%__SCRIPTS__%
+<link rel="stylesheet" href="%__TEMPLATE_BASE__%/turquoiseyellow.css" type="text/css" media="screen" charset="utf-8" />
+<!--[if lte IE 6]>
+<![endif]-->
+<!--[if IE 7]>
+<![endif]-->
+var tab1;
+var tab2;
+var tab3;
+var tabbox1;
+ new Jx.Layout('SplitterArea', {left: 3, right: 3, bottom: 24});
+ new Jx.Layout('StatusbarContainer', {height: 21, top: null});
+ new Jx.Layout('MapArea', {top: 62});
+ new Jx.Layout('ToolbarVertical', {width: 28, right: null});
+ new Jx.Layout('Map', {left: 28});
+ {splitInto:2,
+ elements:[$('Sidebar'),$('Main')],
+ containerOptions: [{minWidth: 50, width: 214}, {}],
+ snappers: [$('SidebarCollapse'),null]});
+ {splitInto:2,
+ containerOptions: [{}, {height: 214}]});
+ main.resize();
+ width: 800,
+ height: 400,
+ modal: true,
+ resize: true,
+ move: true,
+ content: msg
+ } else {
+ return;
+ fmtStack += "\n";
+ name: error.name,
+ } else {
+ // if (json) {
+ // var o;
+ // callback(o);
+ // } else {
+ // return;
+ else {
+</script>
+</head>
+<body>
+ Start App Container
+ Wraps entire application
+ </div>
+ <div id="Main">
+ <div id="Map">
+ </div>
+ </div>
+ </div>
+ </div>
+ </div>
+</div>
+</body>
+</html>
Modified: sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/turquoiseyellow.xml
--- sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/turquoiseyellow.xml 2018-07-26 16:08:49 UTC (rev 9401)
+++ sandbox/jng/fusion_entrypoint_refactor/Oem/fusionMG/templates/mapguide/turquoiseyellow.xml 2018-07-26 16:23:26 UTC (rev 9402)
@@ -1,6 +1,6 @@
<TemplateInfo>
<Name>TurquoiseYellow</Name>
-<LocationUrl>fusion/templates/mapguide/turquoiseyellow/index.html</LocationUrl>
+<LocationUrl>fusion/templates/mapguide/index.php?template=turquoiseyellow</LocationUrl>
<Description>Turquoise-Yellow template</Description>
<PreviewImageUrl>fusion/templates/mapguide/turquoiseyellow/preview.png</PreviewImageUrl>
More information about the mapguide-commits
