[mapguide-commits] r9491 - in sandbox/jng/tiling_v2: Common/MapGuideCommon/Services Server/src/Services/Rendering Server/src/Services/Tile
svn_mapguide at osgeo.org
Mon Apr 15 04:39:50 PDT 2019
Author: jng
Date: 2019-04-15 04:39:50 -0700 (Mon, 15 Apr 2019)
New Revision: 9491
sandbox/jng/tiling_v2/Common/MapGuideCommon/Services/ProxyRenderingService.cpp
sandbox/jng/tiling_v2/Common/MapGuideCommon/Services/ProxyRenderingService.h
sandbox/jng/tiling_v2/Common/MapGuideCommon/Services/RenderingService.h
sandbox/jng/tiling_v2/Common/MapGuideCommon/Services/TileDefs.h
sandbox/jng/tiling_v2/Server/src/Services/Rendering/OpRenderTile.cpp
sandbox/jng/tiling_v2/Server/src/Services/Rendering/OpRenderTileXYZ.cpp
sandbox/jng/tiling_v2/Server/src/Services/Rendering/ServerRenderingService.cpp
sandbox/jng/tiling_v2/Server/src/Services/Rendering/ServerRenderingService.h
sandbox/jng/tiling_v2/Server/src/Services/Tile/ServerTileService.cpp
sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheDefaultProvider.cpp
sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheDefaultProvider.h
sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheXYZProvider.cpp
sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheXYZProvider.h
Add new overloads of RenderTile and RenderTileXYZ to take tile extent offset as a parameter
Modified: sandbox/jng/tiling_v2/Common/MapGuideCommon/Services/ProxyRenderingService.cpp
--- sandbox/jng/tiling_v2/Common/MapGuideCommon/Services/ProxyRenderingService.cpp 2019-03-29 10:18:34 UTC (rev 9490)
+++ sandbox/jng/tiling_v2/Common/MapGuideCommon/Services/ProxyRenderingService.cpp 2019-04-15 11:39:50 UTC (rev 9491)
@@ -139,6 +139,40 @@
return (MgByteReader*)cmd.GetReturnValue().val.m_obj;
+MgByteReader* MgProxyRenderingService::RenderTile(
+ MgMap* map,
+ CREFSTRING baseMapLayerGroupName,
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 tileWidth,
+ INT32 tileHeight,
+ INT32 tileDpi,
+ CREFSTRING tileImageFormat,
+ double tileExtentOffset)
+ MgCommand cmd;
+ cmd.ExecuteCommand(m_connProp, // Connection
+ MgCommand::knObject, // Return type expected
+ MgRenderingServiceOpId::RenderTile2, // Command Code
+ 9, // No of arguments
+ Rendering_Service, // Service Id
+ BUILD_VERSION(3, 3, 0), // Operation version
+ MgCommand::knObject, map, // Argument#1
+ MgCommand::knString, &baseMapLayerGroupName, // Argument#2
+ MgCommand::knInt32, tileColumn, // Argument#3
+ MgCommand::knInt32, tileRow, // Argument#4
+ MgCommand::knInt32, tileWidth, // Argument#5
+ MgCommand::knInt32, tileHeight, // Argument#6
+ MgCommand::knInt32, tileDpi, // Argument#7
+ MgCommand::knString, &tileImageFormat, // Argument#8
+ MgCommand::knDouble, tileExtentOffset, // Argument#9
+ MgCommand::knNone); // End of arguments
+ SetWarning(cmd.GetWarningObject());
+ return (MgByteReader*)cmd.GetReturnValue().val.m_obj;
MgByteReader* MgProxyRenderingService::RenderTileXYZ(MgMap* map,
INT32 x,
@@ -193,6 +227,37 @@
+MgByteReader* MgProxyRenderingService::RenderTileXYZ(MgMap* map,
+ INT32 x,
+ INT32 y,
+ INT32 z,
+ INT32 dpi,
+ MgCommand cmd;
+ MgRenderingServiceOpId::RenderTileXYZ2, // Command Code
+ 8, // No of arguments
+ MgCommand::knInt32, x, // Argument#3
+ MgCommand::knInt32, y, // Argument#4
+ MgCommand::knInt32, z, // Argument#5
+ MgCommand::knInt32, dpi, // Argument#6
+ MgCommand::knString, &tileImageFormat, // Argument#7
+ MgCommand::knDouble, tileExtentOffset, // Argument#8
MgByteReader * MgProxyRenderingService::RenderTileUTFGrid(MgMap * map, CREFSTRING baseMapLayerGroupName, INT32 x, INT32 y, INT32 z, INT32 dpi)
MgCommand cmd;
Modified: sandbox/jng/tiling_v2/Common/MapGuideCommon/Services/ProxyRenderingService.h
--- sandbox/jng/tiling_v2/Common/MapGuideCommon/Services/ProxyRenderingService.h 2019-03-29 10:18:34 UTC (rev 9490)
+++ sandbox/jng/tiling_v2/Common/MapGuideCommon/Services/ProxyRenderingService.h 2019-04-15 11:39:50 UTC (rev 9491)
@@ -107,6 +107,60 @@
/// \brief
+ /// Returns the specified base map tile for the given map.
+ /// \remarks
+ /// This method only renders the given tile. No tile caching is performed
+ /// by this method. To render and cache the tile, use the
+ /// \link MgTileService::GetTile GetTile \endlink method instead. However,
+ /// using that method will use default tile width/height/dpi/format specified
+ /// in your MapGuide Server configuration
+ /// \param map
+ /// Input
+ /// map object containing current state of map.
+ /// \param baseMapLayerGroupName
+ /// Input
+ /// Specifies the name of the baseMapLayerGroup for which to render the tile.
+ /// \param tileColumn
+ /// Input
+ /// Specifies the column index of the tile to return.
+ /// \param tileRow
+ /// Input
+ /// Specifies the row index of the tile to return.
+ /// \param tileWidth
+ /// Input
+ /// Specifies the width of the tile to return.
+ /// \param tileHeight
+ /// Input
+ /// Specifies the height of the tile to return.
+ /// \param tileDpi
+ /// Input
+ /// Specifies the dpi the tile to return.
+ /// \param tileImageFormat
+ /// Input
+ /// Specifies the image format of the tile. See \link MgImageFormats \endlink
+ /// \param tileExtentOffset
+ /// Specifies the ratio by which the tile to be rendered should be "buffered out". The tile will be rendered at the specified width
+ /// multiplied by the given ration, which will be cropped back to the original requested size after rendering. This is to improve
+ /// label placement on rendered tiles by giving extra "breathing space" to label placement algorithms.
+ /// \return
+ /// A byte reader containing the rendered tile image.
+ virtual MgByteReader* RenderTile(
+ MgMap* map,
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 tileWidth,
+ INT32 tileHeight,
+ INT32 tileDpi,
+ double tileExtentOffset);
+ /// \brief
/// Returns the specified map tile for the given map. Tile structure is
/// based on the XYZ tiling scheme used by Google Maps, OpenStreetMap, and
/// others
@@ -179,6 +233,51 @@
/// \brief
+ /// Returns the specified map tile for the given map. Tile structure is
+ /// based on the XYZ tiling scheme used by Google Maps, OpenStreetMap, and
+ /// others
+ /// \param map
+ /// Input
+ /// Input
+ /// \param x
+ /// Input
+ /// \param y
+ /// Input
+ /// \param z
+ /// Input
+ /// Specifies the zoom level of the tile to return.
+ /// \param dpi
+ /// Input
+ /// Specifies the dpi of the tile to return.
+ /// Input
+ /// Specifies the image format of the tile to return.
+ /// \return
+ virtual MgByteReader* RenderTileXYZ(
+ MgMap* map,
+ INT32 x,
+ INT32 y,
+ INT32 z,
+ INT32 dpi,
+ /// \brief
/// Returns the specified UTFGrid tile for the given map. Tile structure is
/// others
Modified: sandbox/jng/tiling_v2/Common/MapGuideCommon/Services/RenderingService.h
--- sandbox/jng/tiling_v2/Common/MapGuideCommon/Services/RenderingService.h 2019-03-29 10:18:34 UTC (rev 9490)
+++ sandbox/jng/tiling_v2/Common/MapGuideCommon/Services/RenderingService.h 2019-04-15 11:39:50 UTC (rev 9491)
@@ -121,6 +121,60 @@
/// \brief
+ /// \remarks
+ /// \param map
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// \return
+ MgMap* map,
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 tileWidth,
+ INT32 tileHeight,
+ INT32 tileDpi,
+ double tileExtentOffset) = 0;
+ /// \brief
/// others
@@ -194,6 +248,51 @@
/// \brief
+ /// others
+ /// \param map
+ /// Input
+ /// Input
+ /// \param x
+ /// Input
+ /// \param y
+ /// Input
+ /// \param z
+ /// Input
+ /// \param dpi
+ /// Input
+ /// Input
+ /// \return
+ MgMap* map,
+ INT32 x,
+ INT32 y,
+ INT32 z,
+ INT32 dpi,
+ /// \brief
/// others
Modified: sandbox/jng/tiling_v2/Common/MapGuideCommon/Services/TileDefs.h
--- sandbox/jng/tiling_v2/Common/MapGuideCommon/Services/TileDefs.h 2019-03-29 10:18:34 UTC (rev 9490)
+++ sandbox/jng/tiling_v2/Common/MapGuideCommon/Services/TileDefs.h 2019-04-15 11:39:50 UTC (rev 9491)
@@ -66,5 +66,6 @@
#define MG_TILE_PROVIDER_COMMON_PARAM_RENDERONLY L"RenderOnly"
#define MG_TILE_PROVIDER_COMMON_PARAM_COORDINATESYSTEM L"CoordinateSystem"
#define MG_TILE_PROVIDER_COMMON_PARAM_FINITESCALELIST L"FiniteScaleList"
+#define MG_TILE_PROVIDER_COMMON_PARAM_TILEEXTENTOFFSET L"TileExtentOffset"
#endif
Modified: sandbox/jng/tiling_v2/Server/src/Services/Rendering/OpRenderTile.cpp
--- sandbox/jng/tiling_v2/Server/src/Services/Rendering/OpRenderTile.cpp 2019-03-29 10:18:34 UTC (rev 9490)
+++ sandbox/jng/tiling_v2/Server/src/Services/Rendering/OpRenderTile.cpp 2019-04-15 11:39:50 UTC (rev 9491)
@@ -148,6 +148,65 @@
EndExecution(byteReader);
+ else if (9 == m_packet.m_NumArguments)
+ Ptr<MgMap> map = (MgMap*)m_stream->GetObject();
+ Ptr<MgResourceIdentifier> resource = map->GetResourceId();
+ map->SetDelayedLoadResourceService(m_resourceService);
+ STRING baseMapLayerGroupName;
+ m_stream->GetString(baseMapLayerGroupName);
+ INT32 tileCol = 0;
+ m_stream->GetInt32(tileCol);
+ INT32 tileRow = 0;
+ m_stream->GetInt32(tileRow);
+ INT32 tileWidth = 0;
+ m_stream->GetInt32(tileWidth);
+ INT32 tileHeight = 0;
+ m_stream->GetInt32(tileHeight);
+ INT32 tileDpi = 0;
+ m_stream->GetInt32(tileDpi);
+ STRING tileImageFormat;
+ m_stream->GetString(tileImageFormat);
+ double tileExtentOffset = 0.0;
+ m_stream->GetDouble(tileExtentOffset);
+ BeginExecution();
+ MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING((NULL == resource) ? L"MgResourceIdentifier" : resource->ToString().c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(baseMapLayerGroupName.c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(tileCol);
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(tileRow);
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(tileWidth);
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(tileHeight);
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(tileDpi);
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(tileImageFormat.c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_DOUBLE(tileExtentOffset);
+ MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
+ Validate();
+ Ptr<MgByteReader> byteReader =
+ m_service->RenderTile(map, baseMapLayerGroupName, tileCol, tileRow, tileWidth, tileHeight, tileDpi, tileImageFormat, tileExtentOffset);
+ EndExecution(byteReader);
else
Modified: sandbox/jng/tiling_v2/Server/src/Services/Rendering/OpRenderTileXYZ.cpp
--- sandbox/jng/tiling_v2/Server/src/Services/Rendering/OpRenderTileXYZ.cpp 2019-03-29 10:18:34 UTC (rev 9490)
+++ sandbox/jng/tiling_v2/Server/src/Services/Rendering/OpRenderTileXYZ.cpp 2019-04-15 11:39:50 UTC (rev 9491)
@@ -146,6 +146,59 @@
+ else if (8 == m_packet.m_NumArguments)
+ INT32 x = 0;
+ m_stream->GetInt32(x);
+ INT32 y = 0;
+ m_stream->GetInt32(y);
+ INT32 z = 0;
+ m_stream->GetInt32(z);
+ BeginExecution();
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(x);
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(y);
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(z);
+ Validate();
+ Ptr<MgByteReader> byteReader = m_service->RenderTileXYZ(map, baseMapLayerGroupName, x, y, z, tileDpi, tileImageFormat, tileExtentOffset);
else
Modified: sandbox/jng/tiling_v2/Server/src/Services/Rendering/ServerRenderingService.cpp
--- sandbox/jng/tiling_v2/Server/src/Services/Rendering/ServerRenderingService.cpp 2019-03-29 10:18:34 UTC (rev 9490)
+++ sandbox/jng/tiling_v2/Server/src/Services/Rendering/ServerRenderingService.cpp 2019-04-15 11:39:50 UTC (rev 9491)
@@ -179,65 +179,20 @@
Ptr<MgByteReader> ret;
+ // the label renderer needs to know the tile extent offset parameter
+ MgConfiguration* pConf = MgConfiguration::GetInstance();
+ pConf->GetDoubleValue(MgConfigProperties::RenderingServicePropertiesSection,
+ MgConfigProperties::RenderingServicePropertyTileExtentOffset,
+ tileExtentOffset,
+ MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset);
+ if (tileExtentOffset < 0.0)
+ tileExtentOffset = MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset;
MG_TRY()
- CHECKARGUMENTNULL(map, L"MgServerRenderingService.RenderTile");
- CHECKARGUMENTEMPTYSTRING(baseMapLayerGroupName, L"MgServerRenderingService.RenderTile");
+ ret = RenderTile(map, baseMapLayerGroupName, tileColumn, tileRow, tileWidth, tileHeight, tileDpi, tileImageFormat, tileExtentOffset);
- // find the finite display scale closest to the requested map scale
- double scale = map->GetViewScale();
- INT32 scaleIndex = map->FindNearestFiniteDisplayScaleIndex(scale);
- // if we don't find a nearest scale then something is wrong with the map
- if (scaleIndex < 0)
- throw new MgInvalidMapDefinitionException(L"MgServerRenderingService.RenderTile", __LINE__, __WFILE__, NULL, L"", NULL);
- // get the layer group associated with the name
- Ptr<MgLayerGroupCollection> layerGroups = map->GetLayerGroups();
- Ptr<MgLayerGroup> baseGroup = layerGroups->GetItem(baseMapLayerGroupName);
- if (baseGroup == NULL)
- MgStringCollection arguments;
- arguments.Add(L"2");
- arguments.Add(baseMapLayerGroupName);
- throw new MgInvalidArgumentException(L"MgServerRenderingService.RenderTile",
- __LINE__, __WFILE__, &arguments, L"MgMapLayerGroupNameNotFound", NULL);
- // get the scale at which to render the tile
- scale = map->GetFiniteDisplayScaleAt(scaleIndex);
- // ensure the tile DPI is set on the map
- map->SetDisplayDpi(tileDpi);
- // the upper left corner of tile (0,0) corresponds to the
- // upper left corner of the map extent
- Ptr<MgEnvelope> mapExtent = map->GetMapExtent();
- Ptr<MgCoordinate> pt00 = mapExtent->GetLowerLeftCoordinate();
- Ptr<MgCoordinate> pt11 = mapExtent->GetUpperRightCoordinate();
- double mapMinX = rs_min(pt00->GetX(), pt11->GetX());
- double mapMaxX = rs_max(pt00->GetX(), pt11->GetX());
- double mapMinY = rs_min(pt00->GetY(), pt11->GetY());
- double mapMaxY = rs_max(pt00->GetY(), pt11->GetY());
- double metersPerUnit = map->GetMetersPerUnit();
- double metersPerPixel = METERS_PER_INCH / tileDpi;
- double tileWidthMCS = (double)tileWidth * metersPerPixel * scale / metersPerUnit;
- double tileHeightMCS = (double)tileHeight * metersPerPixel * scale / metersPerUnit;
- double tileMinX = mapMinX + (double)(tileColumn ) * tileWidthMCS; // left edge
- double tileMaxX = mapMinX + (double)(tileColumn+1) * tileWidthMCS; // right edge
- double tileMinY = mapMaxY - (double)(tileRow +1) * tileHeightMCS; // bottom edge
- double tileMaxY = mapMaxY - (double)(tileRow ) * tileHeightMCS; // top edge
- // make the call to render the tile
- ret = RenderTile(map, baseGroup, scaleIndex, tileWidth, tileHeight, scale,
- tileMinX, tileMaxX, tileMinY, tileMaxY, tileImageFormat);
MG_CATCH_AND_THROW(L"MgServerRenderingService.RenderTile")
return ret.Detach();
@@ -312,123 +267,20 @@
- MG_TRY()
- CHECKARGUMENTNULL(map, L"MgServerRenderingService.RenderTileXYZ");
- CHECKARGUMENTEMPTYSTRING(baseMapLayerGroupName, L"MgServerRenderingService.RenderTileXYZ");
- throw new MgInvalidArgumentException(L"MgServerRenderingService.RenderTileXYZ",
- //Set the dpi
- map->SetDisplayDpi(dpi);
- int width = XYZ_TILE_WIDTH;
- int height = XYZ_TILE_HEIGHT;
- // Inlining same logic from RenderTile() overload below as we want the same logic, but we want to pass scale
- // instead of scale index
- RS_Bounds extent;
- ComputeXYZTileExtents(map, x, y, z, extent);
- // use the map's background color, but always make it fully transparent
- RS_Color bgColor;
- StylizationUtil::ParseColor(map->GetBackgroundColor(), bgColor);
- bgColor.alpha() = 0;
- MgConfigProperties::RenderingServicePropertyTileExtentOffset,
- tileExtentOffset,
- MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset);
+ tileExtentOffset,
- // Image scaling logic ripped verbatim from RenderMap() overload that takes MgEnvelope
- // If we need to scale the image (because of request for non-square
- // pixels) we will need to draw at one image size and then save at
- // another scaled size. Here we will compute the correct map scale
- // and render size for a requested extent and image size.
- double screenAR = (double)width / (double)height;
- double mapAR = extent.width() / extent.height();
- int drawWidth = width;
- int drawHeight = height;
- double scale = 0.0;
+ MG_TRY()
- if (mapAR >= screenAR)
- scale = extent.width() * map->GetMetersPerUnit() / METERS_PER_INCH * (double)dpi / (double)width;
+ ret = RenderTileXYZ(map, baseMapLayerGroupName, x, y, z, dpi, tileImageFormat, tileExtentOffset);
- // we based map scale on the image width, so adjust rendering
- // height to match the map aspect ratio
- drawHeight = (int)(width / mapAR);
- // ignore small perturbations in order to avoid rescaling the
- // end image in cases where the rescaling of width is less than
- // a pixel or so
- if (abs(drawHeight - height) <= 1)
- drawHeight = height;
- else
- scale = extent.height() * map->GetMetersPerUnit() / METERS_PER_INCH * (double)dpi / (double)height;
- // we based map scale on the image height, so adjust rendering
- drawWidth = (int)(height * mapAR);
- // ignore small perturbations, in order to avoid rescaling the
- // a pixel or so
- if (abs(drawWidth - width) <= 1)
- drawWidth = width;
- //printf("XYZ(%d, %d, %d) -> [%f, %f] [%f, %f] at %f -- (w: %d, h: %d, mpu: %f)\n", x, y, z, mcsMinX, mcsMinY, mcsMaxX, mcsMaxY, scale, width, height, map->GetMetersPerUnit());
- // sanity check - number of image pixels cannot exceed MAX_PIXELS
- if (drawWidth * drawHeight > MAX_PIXELS)
- throw new MgOutOfRangeException(L"MgServerRenderingService.RenderMap", __LINE__, __WFILE__, NULL, L"MgInvalidImageSizeTooBig", NULL);
- // initialize the renderer (set clipping to false so that we label
- // the unclipped geometry)
- auto_ptr<SE_Renderer> dr(CreateRenderer(drawWidth, drawHeight, bgColor, false, true, tileExtentOffset));
- // create a temporary collection containing all the layers for the base group
- Ptr<MgLayerCollection> layers = map->GetLayers();
- Ptr<MgReadOnlyLayerCollection> roLayers = new MgReadOnlyLayerCollection();
- for (int i=0; i<layers->GetCount(); i++)
- Ptr<MgLayerBase> layer = layers->GetItem(i);
- Ptr<MgLayerGroup> parentGroup = layer->GetGroup();
- if (parentGroup == baseGroup)
- roLayers->Add(layer);
- // of course the group has to also be visible
- bool groupVisible = baseGroup->GetVisible();
- baseGroup->SetVisible(true);
- // call the internal helper API to do all the stylization overhead work
- ret = RenderMapInternal(map, NULL, roLayers, dr.get(), drawWidth, drawHeight, width, height, tileImageFormat, scale, extent, true, true, false, NULL);
- // restore the base group's visibility
- baseGroup->SetVisible(groupVisible);
MG_CATCH_AND_THROW(L"MgServerRenderingService.RenderTileXYZ")
@@ -626,17 +478,18 @@
/// render a map using all layers from the baseGroup
-MgByteReader* MgServerRenderingService::RenderTile(MgMap* map,
- MgLayerGroup* baseGroup,
- INT32 scaleIndex,
- INT32 width,
- INT32 height,
- double scale,
- double mcsMinX,
- double mcsMaxX,
- double mcsMinY,
- double mcsMaxY,
- CREFSTRING format)
+MgByteReader* MgServerRenderingService::RenderTileInternal(MgMap* map,
+ MgLayerGroup* baseGroup,
+ INT32 scaleIndex,
+ INT32 width,
+ INT32 height,
+ double scale,
+ double mcsMinX,
+ double mcsMaxX,
+ double mcsMinY,
+ double mcsMaxY,
+ CREFSTRING format,
@@ -652,16 +505,6 @@
- // the label renderer needs to know the tile extent offset parameter
- double tileExtentOffset = 0.0;
- MgConfiguration* pConf = MgConfiguration::GetInstance();
- pConf->GetDoubleValue(MgConfigProperties::RenderingServicePropertiesSection,
- tileExtentOffset,
- if (tileExtentOffset < 0.0)
- tileExtentOffset = MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset;
auto_ptr<SE_Renderer> dr(CreateRenderer(width, height, bgColor, false, true, tileExtentOffset));
@@ -2552,3 +2395,203 @@
return bs->GetReader();
+MgByteReader* MgServerRenderingService::RenderTile(MgMap* map,
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 tileWidth,
+ INT32 tileHeight,
+ INT32 tileDpi,
+ Ptr<MgByteReader> ret;
+ MG_TRY()
+ CHECKARGUMENTNULL(map, L"MgServerRenderingService.RenderTile");
+ CHECKARGUMENTEMPTYSTRING(baseMapLayerGroupName, L"MgServerRenderingService.RenderTile");
+ // find the finite display scale closest to the requested map scale
+ double scale = map->GetViewScale();
+ INT32 scaleIndex = map->FindNearestFiniteDisplayScaleIndex(scale);
+ // if we don't find a nearest scale then something is wrong with the map
+ if (scaleIndex < 0)
+ throw new MgInvalidMapDefinitionException(L"MgServerRenderingService.RenderTile", __LINE__, __WFILE__, NULL, L"", NULL);
+ // get the layer group associated with the name
+ Ptr<MgLayerGroupCollection> layerGroups = map->GetLayerGroups();
+ Ptr<MgLayerGroup> baseGroup = layerGroups->GetItem(baseMapLayerGroupName);
+ if (baseGroup == NULL)
+ MgStringCollection arguments;
+ arguments.Add(L"2");
+ arguments.Add(baseMapLayerGroupName);
+ throw new MgInvalidArgumentException(L"MgServerRenderingService.RenderTile",
+ __LINE__, __WFILE__, &arguments, L"MgMapLayerGroupNameNotFound", NULL);
+ // get the scale at which to render the tile
+ scale = map->GetFiniteDisplayScaleAt(scaleIndex);
+ // ensure the tile DPI is set on the map
+ map->SetDisplayDpi(tileDpi);
+ // the upper left corner of tile (0,0) corresponds to the
+ // upper left corner of the map extent
+ Ptr<MgEnvelope> mapExtent = map->GetMapExtent();
+ Ptr<MgCoordinate> pt00 = mapExtent->GetLowerLeftCoordinate();
+ Ptr<MgCoordinate> pt11 = mapExtent->GetUpperRightCoordinate();
+ double mapMinX = rs_min(pt00->GetX(), pt11->GetX());
+ double mapMaxX = rs_max(pt00->GetX(), pt11->GetX());
+ double mapMinY = rs_min(pt00->GetY(), pt11->GetY());
+ double mapMaxY = rs_max(pt00->GetY(), pt11->GetY());
+ double metersPerUnit = map->GetMetersPerUnit();
+ double metersPerPixel = METERS_PER_INCH / tileDpi;
+ double tileWidthMCS = (double)tileWidth * metersPerPixel * scale / metersPerUnit;
+ double tileHeightMCS = (double)tileHeight * metersPerPixel * scale / metersPerUnit;
+ double tileMinX = mapMinX + (double)(tileColumn ) * tileWidthMCS; // left edge
+ double tileMaxX = mapMinX + (double)(tileColumn+1) * tileWidthMCS; // right edge
+ double tileMinY = mapMaxY - (double)(tileRow +1) * tileHeightMCS; // bottom edge
+ double tileMaxY = mapMaxY - (double)(tileRow ) * tileHeightMCS; // top edge
+ // make the call to render the tile
+ ret = RenderTileInternal(map, baseGroup, scaleIndex, tileWidth, tileHeight, scale,
+ tileMinX, tileMaxX, tileMinY, tileMaxY, tileImageFormat,
+ tileExtentOffset);
+ MG_CATCH_AND_THROW(L"MgServerRenderingService.RenderTile")
+ return ret.Detach();
+MgByteReader* MgServerRenderingService::RenderTileXYZ(MgMap* map,
+ INT32 x,
+ INT32 y,
+ INT32 z,
+ INT32 dpi,
+ MG_TRY()
+ CHECKARGUMENTNULL(map, L"MgServerRenderingService.RenderTileXYZ");
+ CHECKARGUMENTEMPTYSTRING(baseMapLayerGroupName, L"MgServerRenderingService.RenderTileXYZ");
+ throw new MgInvalidArgumentException(L"MgServerRenderingService.RenderTileXYZ",
+ //Set the dpi
+ map->SetDisplayDpi(dpi);
+ int width = XYZ_TILE_WIDTH;
+ int height = XYZ_TILE_HEIGHT;
+ // Inlining same logic from RenderTile() overload below as we want the same logic, but we want to pass scale
+ // instead of scale index
+ RS_Bounds extent;
+ ComputeXYZTileExtents(map, x, y, z, extent);
+ // use the map's background color, but always make it fully transparent
+ RS_Color bgColor;
+ StylizationUtil::ParseColor(map->GetBackgroundColor(), bgColor);
+ bgColor.alpha() = 0;
+ // Image scaling logic ripped verbatim from RenderMap() overload that takes MgEnvelope
+ // If we need to scale the image (because of request for non-square
+ // pixels) we will need to draw at one image size and then save at
+ // another scaled size. Here we will compute the correct map scale
+ // and render size for a requested extent and image size.
+ double screenAR = (double)width / (double)height;
+ double mapAR = extent.width() / extent.height();
+ int drawWidth = width;
+ int drawHeight = height;
+ double scale = 0.0;
+ if (mapAR >= screenAR)
+ scale = extent.width() * map->GetMetersPerUnit() / METERS_PER_INCH * (double)dpi / (double)width;
+ // we based map scale on the image width, so adjust rendering
+ // height to match the map aspect ratio
+ drawHeight = (int)(width / mapAR);
+ // ignore small perturbations in order to avoid rescaling the
+ // end image in cases where the rescaling of width is less than
+ // a pixel or so
+ if (abs(drawHeight - height) <= 1)
+ drawHeight = height;
+ else
+ scale = extent.height() * map->GetMetersPerUnit() / METERS_PER_INCH * (double)dpi / (double)height;
+ // we based map scale on the image height, so adjust rendering
+ drawWidth = (int)(height * mapAR);
+ // ignore small perturbations, in order to avoid rescaling the
+ // a pixel or so
+ if (abs(drawWidth - width) <= 1)
+ drawWidth = width;
+ //printf("XYZ(%d, %d, %d) -> [%f, %f] [%f, %f] at %f -- (w: %d, h: %d, mpu: %f)\n", x, y, z, mcsMinX, mcsMinY, mcsMaxX, mcsMaxY, scale, width, height, map->GetMetersPerUnit());
+ // sanity check - number of image pixels cannot exceed MAX_PIXELS
+ if (drawWidth * drawHeight > MAX_PIXELS)
+ throw new MgOutOfRangeException(L"MgServerRenderingService.RenderMap", __LINE__, __WFILE__, NULL, L"MgInvalidImageSizeTooBig", NULL);
+ // initialize the renderer (set clipping to false so that we label
+ // the unclipped geometry)
+ auto_ptr<SE_Renderer> dr(CreateRenderer(drawWidth, drawHeight, bgColor, false, true, tileExtentOffset));
+ // create a temporary collection containing all the layers for the base group
+ Ptr<MgLayerCollection> layers = map->GetLayers();
+ Ptr<MgReadOnlyLayerCollection> roLayers = new MgReadOnlyLayerCollection();
+ for (int i=0; i<layers->GetCount(); i++)
+ Ptr<MgLayerBase> layer = layers->GetItem(i);
+ Ptr<MgLayerGroup> parentGroup = layer->GetGroup();
+ if (parentGroup == baseGroup)
+ roLayers->Add(layer);
+ // of course the group has to also be visible
+ bool groupVisible = baseGroup->GetVisible();
+ baseGroup->SetVisible(true);
+ // call the internal helper API to do all the stylization overhead work
+ ret = RenderMapInternal(map, NULL, roLayers, dr.get(), drawWidth, drawHeight, width, height, tileImageFormat, scale, extent, true, true, false, NULL);
+ // restore the base group's visibility
+ baseGroup->SetVisible(groupVisible);
+ MG_CATCH_AND_THROW(L"MgServerRenderingService.RenderTileXYZ")
\ No newline at end of file
Modified: sandbox/jng/tiling_v2/Server/src/Services/Rendering/ServerRenderingService.h
--- sandbox/jng/tiling_v2/Server/src/Services/Rendering/ServerRenderingService.h 2019-03-29 10:18:34 UTC (rev 9490)
+++ sandbox/jng/tiling_v2/Server/src/Services/Rendering/ServerRenderingService.h 2019-04-15 11:39:50 UTC (rev 9491)
@@ -56,6 +56,16 @@
INT32 tileDpi,
CREFSTRING tileImageFormat);
+ virtual MgByteReader* RenderTile(MgMap* map,
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 tileWidth,
+ INT32 tileHeight,
+ INT32 tileDpi,
virtual MgByteReader* RenderTileXYZ(MgMap* map,
INT32 x,
@@ -70,6 +80,15 @@
INT32 dpi,
+ virtual MgByteReader* RenderTileXYZ(MgMap* map,
+ INT32 x,
+ INT32 y,
+ INT32 z,
+ INT32 dpi,
virtual MgByteReader* RenderTileUTFGrid(MgMap* map,
INT32 x,
@@ -246,17 +265,18 @@
private:
static void ComputeXYZTileExtents(MgMap* map, INT32 x, INT32 y, INT32 z, RS_Bounds& extent);
// used for tile generation
- MgByteReader* RenderTile(MgMap* map,
- INT32 scaleIndex,
- INT32 width,
- INT32 height,
- double scale,
- double mcsMinX,
- double mcsMaxX,
- double mcsMinY,
- double mcsMaxY,
- CREFSTRING format);
+ MgByteReader* RenderTileInternal(MgMap* map,
+ INT32 scaleIndex,
+ INT32 width,
+ INT32 height,
+ double scale,
+ double mcsMinX,
+ double mcsMaxX,
+ double mcsMinY,
+ double mcsMaxY,
// helper used by other methods
MgByteReader* RenderMapInternal(MgMap* map,
Modified: sandbox/jng/tiling_v2/Server/src/Services/Tile/ServerTileService.cpp
--- sandbox/jng/tiling_v2/Server/src/Services/Tile/ServerTileService.cpp 2019-03-29 10:18:34 UTC (rev 9490)
+++ sandbox/jng/tiling_v2/Server/src/Services/Tile/ServerTileService.cpp 2019-04-15 11:39:50 UTC (rev 9491)
@@ -313,6 +313,22 @@
xml.append("<DefaultValue></DefaultValue>\n");
xml.append("</ConnectionProperty>\n");
+ //Property: TileExtentOffset
+ xml.append("<ConnectionProperty Enumerable=\"false\" Protected=\"false\" Required=\"true\">\n");
+ xml.append("<Name>");
+ std::string mbTileExtentOffset;
+ MgUtil::WideCharToMultiByte(MG_TILE_PROVIDER_COMMON_PARAM_TILEEXTENTOFFSET, mbTileExtentOffset);
+ xml.append(mbTileExtentOffset);
+ xml.append("</Name>\n");
+ xml.append("<LocalizedName>");
+ std::string mbLocTileExtentOffset;
+ STRING wLocTileExtentOffset = MgUtil::GetResourceMessage(MgResources::TileService, L"MgTileProvider_Common_Property_TileExtentOffset_LocalizedName");
+ MgUtil::WideCharToMultiByte(wLocTileExtentOffset, mbLocTileExtentOffset);
+ xml.append(mbLocTileExtentOffset);
+ xml.append("</LocalizedName>\n");
+ xml.append("<DefaultValue></DefaultValue>\n");
+ xml.append("</ConnectionProperty>\n");
xml.append("</ConnectionProperties>\n");
xml.append("</TileProvider>\n");
@@ -397,6 +413,23 @@
xml.append("<DefaultValue>false</DefaultValue>\n");
@@ -503,6 +536,7 @@
MdfModel::NameStringPairCollection* parameters = tilesetParams->GetParameters();
INT32 width = 300;
INT32 height = 300;
+ double tileExtentOffset = MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset;
STRING format = L"PNG";
STRING path;
bool bRenderOnly = false;
@@ -529,6 +563,14 @@
bRenderOnly = MgUtil::StringToBoolean(pair->GetValue());
+ else if (pair->GetName() == MG_TILE_PROVIDER_COMMON_PARAM_TILEEXTENTOFFSET)
+ tileExtentOffset = MgUtil::StringToDouble(pair->GetValue());
//If we find the cache path substitution tag, replace it with the default path from the configuration
@@ -537,12 +579,13 @@
path = MgTileParameters::tileCachePath;
- cache = new MgTileCacheDefaultProvider(tileSetId, path, width, height, format, bRenderOnly);
+ cache = new MgTileCacheDefaultProvider(tileSetId, path, width, height, format, bRenderOnly, tileExtentOffset);
else if (provider == MG_TILE_PROVIDER_XYZ)
STRING path;
for (INT32 i = 0; i < parameters->GetCount(); i++)
@@ -560,6 +603,14 @@
@@ -568,7 +619,7 @@
- cache = new MgTileCacheXYZProvider(tileSetId, path, format, bRenderOnly);
+ cache = new MgTileCacheXYZProvider(tileSetId, path, format, bRenderOnly, tileExtentOffset);
else
Modified: sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheDefaultProvider.cpp
--- sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheDefaultProvider.cpp 2019-03-29 10:18:34 UTC (rev 9490)
+++ sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheDefaultProvider.cpp 2019-04-15 11:39:50 UTC (rev 9491)
@@ -18,7 +18,7 @@
#include "MapGuideCommon.h"
#include "TileCacheDefaultProvider.h"
-MgTileCacheDefaultProvider::MgTileCacheDefaultProvider(MgResourceIdentifier* tileSetId, CREFSTRING path, INT32 tileWidth, INT32 tileHeight, CREFSTRING format, bool bRenderOnly)
+MgTileCacheDefaultProvider::MgTileCacheDefaultProvider(MgResourceIdentifier* tileSetId, CREFSTRING path, INT32 tileWidth, INT32 tileHeight, CREFSTRING format, bool bRenderOnly, double tileExtentOffset)
m_tilesetId = SAFE_ADDREF(tileSetId);
m_path = path;
@@ -26,6 +26,7 @@
m_tileHeight = tileHeight;
m_format = format;
m_renderOnly = bRenderOnly;
+ m_tileExtentOffset = tileExtentOffset;
MgTileCacheDefaultProvider::~MgTileCacheDefaultProvider()
@@ -64,7 +65,7 @@
if (svcRendering != NULL)
// generate the tile
- img = svcRendering->RenderTile(map, baseMapLayerGroupName, tileColumn, tileRow, GetDefaultTileSizeX(), GetDefaultTileSizeY(), map->GetDisplayDpi(), GetTileFormat());
+ img = svcRendering->RenderTile(map, baseMapLayerGroupName, tileColumn, tileRow, GetDefaultTileSizeX(), GetDefaultTileSizeY(), map->GetDisplayDpi(), GetTileFormat(), m_tileExtentOffset);
// cache the tile
if (!m_renderOnly)
Modified: sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheDefaultProvider.h
--- sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheDefaultProvider.h 2019-03-29 10:18:34 UTC (rev 9490)
+++ sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheDefaultProvider.h 2019-04-15 11:39:50 UTC (rev 9491)
@@ -22,7 +22,7 @@
class MG_SERVER_TILE_API MgTileCacheDefaultProvider : public MgTileCacheDefault
public:
- MgTileCacheDefaultProvider(MgResourceIdentifier* tileSetId, CREFSTRING path, INT32 tileWidth, INT32 tileHeight, CREFSTRING format, bool bRenderOnly);
+ MgTileCacheDefaultProvider(MgResourceIdentifier* tileSetId, CREFSTRING path, INT32 tileWidth, INT32 tileHeight, CREFSTRING format, bool bRenderOnly, double tileExtentOffset);
virtual ~MgTileCacheDefaultProvider();
virtual MgByteReader* GetTile(CREFSTRING baseMapLayerGroupName,
@@ -53,6 +53,7 @@
INT32 m_tileHeight;
STRING m_format;
bool m_renderOnly;
+ double m_tileExtentOffset;
#endif
Modified: sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheXYZProvider.cpp
--- sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheXYZProvider.cpp 2019-03-29 10:18:34 UTC (rev 9490)
+++ sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheXYZProvider.cpp 2019-04-15 11:39:50 UTC (rev 9491)
@@ -18,12 +18,13 @@
#include "TileCacheXYZProvider.h"
-MgTileCacheXYZProvider::MgTileCacheXYZProvider(MgResourceIdentifier* tileSetId, CREFSTRING path, CREFSTRING format, bool bRenderOnly)
+MgTileCacheXYZProvider::MgTileCacheXYZProvider(MgResourceIdentifier* tileSetId, CREFSTRING path, CREFSTRING format, bool bRenderOnly, double tileExtentOffset)
m_path = path;
m_format = format;
MgTileCacheXYZProvider::~MgTileCacheXYZProvider()
@@ -70,7 +71,7 @@
else //Assume it must be image-based at this point
- img = svcRendering->RenderTileXYZ(map, baseMapLayerGroupName, tileRow, tileColumn, scaleIndex, map->GetDisplayDpi(), m_format);
+ img = svcRendering->RenderTileXYZ(map, baseMapLayerGroupName, tileRow, tileColumn, scaleIndex, map->GetDisplayDpi(), m_format, m_tileExtentOffset);
// cache the tile
if (!m_renderOnly)
Modified: sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheXYZProvider.h
--- sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheXYZProvider.h 2019-03-29 10:18:34 UTC (rev 9490)
+++ sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheXYZProvider.h 2019-04-15 11:39:50 UTC (rev 9491)
@@ -22,7 +22,7 @@
class MG_SERVER_TILE_API MgTileCacheXYZProvider : public MgTileCacheDefault
public:
- MgTileCacheXYZProvider(MgResourceIdentifier* tileSetId, CREFSTRING path, CREFSTRING format, bool bRenderOnly);
+ MgTileCacheXYZProvider(MgResourceIdentifier* tileSetId, CREFSTRING path, CREFSTRING format, bool bRenderOnly, double tileExtentOffset);
virtual ~MgTileCacheXYZProvider();
@@ -57,6 +57,7 @@
STRING m_path;
STRING m_format;
bool m_renderOnly;
#endif
More information about the mapguide-commits
