[mapguide-commits] r9492 - in sandbox/jng/tiling_v2/Server/src: Services/Rendering Services/Tile UnitTesting
svn_mapguide at osgeo.org
Mon Apr 22 21:04:25 PDT 2019
Author: jng
Date: 2019-04-22 21:04:25 -0700 (Mon, 22 Apr 2019)
New Revision: 9492
sandbox/jng/tiling_v2/Server/src/Services/Rendering/OpRenderTile.cpp
sandbox/jng/tiling_v2/Server/src/Services/Rendering/ServerRenderingService.cpp
sandbox/jng/tiling_v2/Server/src/Services/Rendering/ServerRenderingService.h
sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheDefaultProvider.cpp
sandbox/jng/tiling_v2/Server/src/UnitTesting/TestRenderingService.cpp
sandbox/jng/tiling_v2/Server/src/UnitTesting/TestRenderingService.h
Port across the core metatile rendering primitives from RFC90 sandbox. Add unit test to dump out rendered sub-metatiles to compare against original rendered tiles at the same coordinates.
Modified: sandbox/jng/tiling_v2/Server/src/Services/Rendering/OpRenderTile.cpp
--- sandbox/jng/tiling_v2/Server/src/Services/Rendering/OpRenderTile.cpp 2019-04-15 11:39:50 UTC (rev 9491)
+++ sandbox/jng/tiling_v2/Server/src/Services/Rendering/OpRenderTile.cpp 2019-04-23 04:04:25 UTC (rev 9492)
@@ -148,7 +148,7 @@
EndExecution(byteReader);
- else if (9 == m_packet.m_NumArguments)
+ else if (10 == m_packet.m_NumArguments)
Ptr<MgMap> map = (MgMap*)m_stream->GetObject();
Ptr<MgResourceIdentifier> resource = map->GetResourceId();
@@ -178,6 +178,9 @@
double tileExtentOffset = 0.0;
m_stream->GetDouble(tileExtentOffset);
+ INT32 metaTileFactor = 0;
+ m_stream->GetInt32(metaTileFactor);
BeginExecution();
MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
@@ -198,12 +201,14 @@
MG_LOG_OPERATION_MESSAGE_ADD_STRING(tileImageFormat.c_str());
MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
MG_LOG_OPERATION_MESSAGE_ADD_DOUBLE(tileExtentOffset);
+ MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(metaTileFactor);
MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
Validate();
Ptr<MgByteReader> byteReader =
- m_service->RenderTile(map, baseMapLayerGroupName, tileCol, tileRow, tileWidth, tileHeight, tileDpi, tileImageFormat, tileExtentOffset);
+ m_service->RenderTile(map, baseMapLayerGroupName, tileCol, tileRow, tileWidth, tileHeight, tileDpi, tileImageFormat, tileExtentOffset, metaTileFactor);
Modified: sandbox/jng/tiling_v2/Server/src/Services/Rendering/ServerRenderingService.cpp
--- sandbox/jng/tiling_v2/Server/src/Services/Rendering/ServerRenderingService.cpp 2019-04-15 11:39:50 UTC (rev 9491)
+++ sandbox/jng/tiling_v2/Server/src/Services/Rendering/ServerRenderingService.cpp 2019-04-23 04:04:25 UTC (rev 9492)
@@ -191,7 +191,7 @@
MG_TRY()
- ret = RenderTile(map, baseMapLayerGroupName, tileColumn, tileRow, tileWidth, tileHeight, tileDpi, tileImageFormat, tileExtentOffset);
+ ret = RenderTile(map, baseMapLayerGroupName, tileColumn, tileRow, tileWidth, tileHeight, tileDpi, tileImageFormat, tileExtentOffset, 0 /* MT factor = 1 -> render at original size */);
MG_CATCH_AND_THROW(L"MgServerRenderingService.RenderTile")
@@ -535,7 +535,63 @@
return ret.Detach();
+// gets called with a bitmap in the bytereader to be split up into metatile^2 images
+MgByteReader* MgServerRenderingService::RenderTileFromMetaTile(MgMap* map, MgByteReader* metaTileBitMap, CREFSTRING origTileFormat,
+ INT32 origTileWidth, INT32 origTileHeight,
+ INT32 metaTileFactor, INT32 subTileX, INT32 subTileY)
+ MgByteSource* bs = metaTileBitMap->GetByteSource();
+ // upcast to bytesource Impl to access bytearray member
+ ByteSourceMemoryImpl* source = dynamic_cast<ByteSourceMemoryImpl*>(bs->GetSourceImpl());
+ assert(source);
+ assert(bs->GetMimeType() == MgMimeType::Meta);
+ int size = (int)source->GetLength();
+ // some checking: the complete meta tile of 32b pixels should be in the framebuffer handed over
+ int expectedSize = 4 * (metaTileFactor * origTileWidth)
+ * (metaTileFactor * origTileHeight);
+ assert(size == expectedSize);
+ // use the map's background color, but always make it fully transparent
+ RS_Color bgColor;
+ StylizationUtil::ParseColor(map->GetBackgroundColor(), bgColor);
+ bgColor.alpha() = 0;
+ auto_ptr<SE_Renderer> dr(CreateRenderer(origTileWidth, origTileHeight, bgColor, true));
+ RS_ColorVector tileColorPalette;
+ if (m_rendererName == L"AGG" && hasColorMap(origTileFormat))
+ MgMappingUtil::ParseColorStrings(&tileColorPalette, map);
+ // now copy tile from meta framebuffer to new one...
+ // use unsigned int pointer arithmetic for pixels!
+ //MgByte* byteBuffer = source->Bytes(); // here we access the bytearray inside the bytesource
+ MgByte* byteBuffer = source->BytesNoAddRef();
+ assert(size == byteBuffer->GetLength()); // double check the buffer size
+ // get pointer to the framebuffer containing the metatile
+ unsigned int *framebuf = (unsigned int*)byteBuffer->Bytes();
+ // allocate subtile buffer to copy new framebuf with changed dimensions
+ // place buffer in allocated MgByte auto_ptr object for destruction at end of scope
+ auto_ptr<MgByte> subTileBytes(new MgByte((unsigned char*)new unsigned int[origTileWidth * origTileHeight],
+ origTileWidth * origTileHeight * sizeof(int), MgByte::New));
+ // get the pointer to the internal target buffer
+ unsigned int* subTileBuf = (unsigned int*)subTileBytes->Bytes();
+ for (int y = 0; y < origTileHeight; y++) // rows
+ for (int x = 0; x < origTileWidth; x++) // columns innerloop
+ { // this copies the 32bit pixels from the meta tile framebuffer to the subtile framebuffer
+ *(subTileBuf + x
+ + y * origTileWidth) // target address in subtile
+ = *(framebuf + (x + (subTileX * origTileWidth)) // X address in meta tile
+ + (y + (subTileY * origTileHeight)) // Y address in meta tile
+ * origTileWidth * metaTileFactor); // use width of metaTile here
+ // then call the image renderer to convert the framebuffer bitmap into the desired image format
+ return CreateImage(map, dr.get(), origTileWidth, origTileHeight, origTileFormat, NULL, subTileBuf);
// default arg bKeepSelection = true
MgByteReader* MgServerRenderingService::RenderDynamicOverlay(MgMap* map,
@@ -2299,7 +2355,8 @@
INT32 saveWidth,
INT32 saveHeight,
CREFSTRING format,
- ProfileRenderMapResult* pPRMResult)
+ ProfileRenderMapResult* pPRMResult,
+ unsigned int* frameBuffer)
if(NULL != pPRMResult)
@@ -2338,24 +2395,32 @@
// call the image renderer to create the image
if (wcscmp(m_rendererName.c_str(), L"AGG") == 0)
- /// RFC60 code to correct colormaps by UV
- // We examine the expressions collected from xml definitions of all layers.
- // The map object has a list from all color entries found in the most recent
- // layer stylization.
- // * TODO - currently they are interpreted as ffffffff 32-bit RGBA string values
- // * adding expresssions and other interpretations should be done in ParseColorStrings
- // * the color Palette for the renderer is a vector<RS_Color>
- if (hasColorMap(format))
+ if (format == MgImageFormats::Meta) // we dont use the colorPalette here for meta tiling
+ { // as this call only returns the framebuffer
+ data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight, NULL, NULL));
+ // copy the framebuffer into the reader, RenderTileFromMetatile is taking it from there
+ else
- RS_ColorVector tileColorPalette;
- MgMappingUtil::ParseColorStrings(&tileColorPalette, map);
-// printf("<<<<<<<<<<<<<<<<<<<<< MgServerRenderingService::ColorPalette->size(): %d\n", tileColorPalette.size());
- data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight, &tileColorPalette));
+ /// RFC60 code to correct colormaps by UV
+ // We examine the expressions collected from xml definitions of all layers.
+ // The map object has a list from all color entries found in the most recent
+ // layer stylization.
+ // * TODO - currently they are interpreted as ffffffff 32-bit RGBA string values
+ // * adding expresssions and other interpretations should be done in ParseColorStrings
+ // * the color Palette for the renderer is a vector<RS_Color>
+ if (hasColorMap(format))
+ // printf("<<<<<<<<<<<<<<<<<<<<< MgServerRenderingService::ColorPalette->size(): %d\n", tileColorPalette.size());
+ data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight, &tileColorPalette, frameBuffer));
+ else
+ data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight, NULL, frameBuffer));
- else
- data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight, NULL));
else
data.reset(((GDRenderer*)dr)->Save(format, saveWidth, saveHeight));
@@ -2379,6 +2444,8 @@
bs->SetMimeType(MgMimeType::Png);
else if (format == MgImageFormats::Tiff)
bs->SetMimeType(MgMimeType::Tiff);
+ else if (format == MgImageFormats::Meta) // add a mimetype for our metatile
+ bs->SetMimeType(MgMimeType::Meta);
else
throw new MgNullReferenceException(L"MgServerRenderingService.CreateImage", __LINE__, __WFILE__, NULL, L"MgNoDataFromRenderer", NULL);
@@ -2404,7 +2471,8 @@
INT32 tileHeight,
INT32 tileDpi,
CREFSTRING tileImageFormat,
- double tileExtentOffset)
+ double tileExtentOffset,
+ INT32 metaTileFactor)
Ptr<MgByteReader> ret;
@@ -2445,27 +2513,14 @@
// upper left corner of the map extent
- Ptr<MgEnvelope> mapExtent = map->GetMapExtent();
- Ptr<MgCoordinate> pt00 = mapExtent->GetLowerLeftCoordinate();
- Ptr<MgCoordinate> pt11 = mapExtent->GetUpperRightCoordinate();
- double mapMinX = rs_min(pt00->GetX(), pt11->GetX());
- double mapMaxX = rs_max(pt00->GetX(), pt11->GetX());
- double mapMinY = rs_min(pt00->GetY(), pt11->GetY());
- double mapMaxY = rs_max(pt00->GetY(), pt11->GetY());
+ double tileMinX, tileMaxX, tileMinY, tileMaxY;
+ map->GetTileCoords(std::max(metaTileFactor, 1), tileColumn, tileRow, tileDpi, tileWidth, tileHeight, tileMinX, tileMaxX, tileMinY, tileMaxY);
- double metersPerUnit = map->GetMetersPerUnit();
- double metersPerPixel = METERS_PER_INCH / tileDpi;
- double tileWidthMCS = (double)tileWidth * metersPerPixel * scale / metersPerUnit;
- double tileHeightMCS = (double)tileHeight * metersPerPixel * scale / metersPerUnit;
- double tileMinX = mapMinX + (double)(tileColumn ) * tileWidthMCS; // left edge
- double tileMaxX = mapMinX + (double)(tileColumn+1) * tileWidthMCS; // right edge
- double tileMinY = mapMaxY - (double)(tileRow +1) * tileHeightMCS; // bottom edge
- double tileMaxY = mapMaxY - (double)(tileRow ) * tileHeightMCS; // top edge
// make the call to render the tile
- ret = RenderTileInternal(map, baseGroup, scaleIndex, tileWidth, tileHeight, scale,
- tileMinX, tileMaxX, tileMinY, tileMaxY, tileImageFormat,
+ ret = RenderTileInternal(map, baseGroup, scaleIndex,
+ tileWidth * std::max(metaTileFactor, 1), tileHeight * std::max(metaTileFactor, 1),
+ scale, tileMinX, tileMaxX, tileMinY, tileMaxY,
+ (metaTileFactor > 1 ? MgImageFormats::Meta : tileImageFormat),
tileExtentOffset);
Modified: sandbox/jng/tiling_v2/Server/src/Services/Rendering/ServerRenderingService.h
--- sandbox/jng/tiling_v2/Server/src/Services/Rendering/ServerRenderingService.h 2019-04-15 11:39:50 UTC (rev 9491)
+++ sandbox/jng/tiling_v2/Server/src/Services/Rendering/ServerRenderingService.h 2019-04-23 04:04:25 UTC (rev 9492)
@@ -64,7 +64,8 @@
INT32 tileHeight,
INT32 tileDpi,
- double tileExtentOffset);
+ INT32 metaTileFactor);
virtual MgByteReader* RenderTileXYZ(MgMap* map,
CREFSTRING baseMapLayerGroupName,
@@ -262,6 +263,10 @@
bool bIncludeFeatureBBOX,
bool bIncludeGeometry);
+ MgByteReader* RenderTileFromMetaTile(MgMap* map, MgByteReader* metaTileBitMap, CREFSTRING origTileFormat,
+ INT32 metaTileFactor, INT32 subTileX, INT32 subTileY);
private:
static void ComputeXYZTileExtents(MgMap* map, INT32 x, INT32 y, INT32 z, RS_Bounds& extent);
// used for tile generation
@@ -363,7 +368,8 @@
INT32 saveWidth,
INT32 saveHeight,
CREFSTRING format,
- ProfileRenderMapResult* pPRMResult);
+ unsigned int* frameBuffer = NULL);
// member data
Ptr<MgFeatureService> m_svcFeature;
Modified: sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheDefaultProvider.cpp
--- sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheDefaultProvider.cpp 2019-04-15 11:39:50 UTC (rev 9491)
+++ sandbox/jng/tiling_v2/Server/src/Services/Tile/TileCacheDefaultProvider.cpp 2019-04-23 04:04:25 UTC (rev 9492)
@@ -65,7 +65,7 @@
if (svcRendering != NULL)
// generate the tile
- img = svcRendering->RenderTile(map, baseMapLayerGroupName, tileColumn, tileRow, GetDefaultTileSizeX(), GetDefaultTileSizeY(), map->GetDisplayDpi(), GetTileFormat(), m_tileExtentOffset);
+ img = svcRendering->RenderTile(map, baseMapLayerGroupName, tileColumn, tileRow, GetDefaultTileSizeX(), GetDefaultTileSizeY(), map->GetDisplayDpi(), GetTileFormat(), m_tileExtentOffset, 0);
// cache the tile
if (!m_renderOnly)
Modified: sandbox/jng/tiling_v2/Server/src/UnitTesting/TestRenderingService.cpp
--- sandbox/jng/tiling_v2/Server/src/UnitTesting/TestRenderingService.cpp 2019-04-15 11:39:50 UTC (rev 9491)
+++ sandbox/jng/tiling_v2/Server/src/UnitTesting/TestRenderingService.cpp 2019-04-23 04:04:25 UTC (rev 9492)
@@ -24,6 +24,9 @@
//#include "GDRenderer.h"
//#include "AGGRenderer.h"
#include "FoundationDefs.h"
+#include "SE_Renderer.h"
+#include "ServerRenderingService.h"
const STRING TEST_LOCALE = L"en";
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION(TestRenderingService, "TestRenderingService");
@@ -1737,6 +1740,43 @@
+void TestRenderingService::TestCase_RenderMetatile()
+ try
+ Ptr<MgMap> map = CreateTestTiledMap();
+ map->SetViewScale(12500.0);
+ //This should be a server impl
+ MgServerRenderingService* renderSvc = dynamic_cast<MgServerRenderingService*>(m_svcRendering.p);
+ CPPUNIT_ASSERT(NULL != renderSvc);
+ // Render a 2x2 metatile which should cover the same tiles as the baseline test.
+ INT32 metaTileFactor = 2;
+ Ptr<MgByteReader> metaTile = renderSvc->RenderTile(map, L"BaseLayers", 4, 6, MgTileParameters::tileWidth, MgTileParameters::tileHeight, MgTileParameters::tileDPI, MgImageFormats::Png, MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset, metaTileFactor);
+ //metaTile->ToFile(L"../UnitTestFiles/RenderTile_Metatile at 4_6.png");
+ //CPPUNIT_ASSERT(metaTile->IsRewindable());
+ //metaTile->Rewind();
+ Ptr<MgByteReader> tile4_6 = renderSvc->RenderTileFromMetaTile(map, metaTile, MgImageFormats::Png, MgTileParameters::tileWidth, MgTileParameters::tileHeight, 2, 0, 0);
+ Ptr<MgByteReader> tile4_7 = renderSvc->RenderTileFromMetaTile(map, metaTile, MgImageFormats::Png, MgTileParameters::tileWidth, MgTileParameters::tileHeight, 2, 0, 1);
+ Ptr<MgByteReader> tile5_6 = renderSvc->RenderTileFromMetaTile(map, metaTile, MgImageFormats::Png, MgTileParameters::tileWidth, MgTileParameters::tileHeight, 2, 1, 0);
+ Ptr<MgByteReader> tile5_7 = renderSvc->RenderTileFromMetaTile(map, metaTile, MgImageFormats::Png, MgTileParameters::tileWidth, MgTileParameters::tileHeight, 2, 1, 1);
+ tile4_6->ToFile(L"../UnitTestFiles/RenderTile_4_6_Metatiled.png");
+ tile4_7->ToFile(L"../UnitTestFiles/RenderTile_4_7_Metatiled.png");
+ tile5_6->ToFile(L"../UnitTestFiles/RenderTile_5_6_Metatiled.png");
+ tile5_7->ToFile(L"../UnitTestFiles/RenderTile_5_7_Metatiled.png");
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
void TestRenderingService::TestCase_RenderTile(CREFSTRING imageFormat, CREFSTRING extension)
try
Modified: sandbox/jng/tiling_v2/Server/src/UnitTesting/TestRenderingService.h
--- sandbox/jng/tiling_v2/Server/src/UnitTesting/TestRenderingService.h 2019-04-15 11:39:50 UTC (rev 9491)
+++ sandbox/jng/tiling_v2/Server/src/UnitTesting/TestRenderingService.h 2019-04-23 04:04:25 UTC (rev 9492)
@@ -26,7 +26,8 @@
CPPUNIT_TEST(TestStart); // This must be the very first unit test
CPPUNIT_TEST(TestCase_RenderTileBaseline);
+ CPPUNIT_TEST(TestCase_RenderMetatile);
CPPUNIT_TEST(TestCase_StylizationFunctionsPNG);
CPPUNIT_TEST(TestCase_SymbologyPointsPNG);
@@ -145,7 +146,6 @@
CPPUNIT_TEST(TestCase_RenderTileXYZ_JPG);
CPPUNIT_TEST(TestCase_QueryFeatures);
//CPPUNIT_TEST(TestCase_RendererPerformance);
CPPUNIT_TEST(TestEnd); // This must be the very last unit test
@@ -162,6 +162,7 @@
void TestCase_QueryFeatures();
void TestCase_RenderTileBaseline();
+ void TestCase_RenderMetatile();
void TestCase_RenderTile(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_RenderTileXYZ(CREFSTRING imageFormat, CREFSTRING extension);
More information about the mapguide-commits
