[mapguide-commits] r9572 - sandbox/jng/wfs_hits/Web/src/HttpHandler
svn_mapguide at osgeo.org
Fri Jul 12 07:37:43 PDT 2019
Author: jng
Date: 2019-07-12 07:37:42 -0700 (Fri, 12 Jul 2019)
New Revision: 9572
sandbox/jng/wfs_hits/Web/src/HttpHandler/HttpResourceStrings.cpp
sandbox/jng/wfs_hits/Web/src/HttpHandler/HttpResourceStrings.h
sandbox/jng/wfs_hits/Web/src/HttpHandler/HttpWfsGetFeature.cpp
sandbox/jng/wfs_hits/Web/src/HttpHandler/WfsGetFeatureParams.cpp
sandbox/jng/wfs_hits/Web/src/HttpHandler/WfsGetFeatureParams.h
Initial attempt to support reusltType=hits for WFS. The response format is currently not the expected WFS response. We just want to see the placeholder response first with resultType=hits. We fix the response format to the expected WFS response format afterwards.
Modified: sandbox/jng/wfs_hits/Web/src/HttpHandler/HttpResourceStrings.cpp
--- sandbox/jng/wfs_hits/Web/src/HttpHandler/HttpResourceStrings.cpp 2019-07-12 13:47:29 UTC (rev 9571)
+++ sandbox/jng/wfs_hits/Web/src/HttpHandler/HttpResourceStrings.cpp 2019-07-12 14:37:42 UTC (rev 9572)
@@ -326,6 +326,7 @@
const STRING MgHttpResourceStrings::reqWfsBbox = L"BBOX";
const STRING MgHttpResourceStrings::reqWfsOutputFormat = L"OUTPUTFORMAT";
const STRING MgHttpResourceStrings::reqWfsSortBy = L"SORTBY";
+const STRING MgHttpResourceStrings::reqWfsResultType = L"RESULTTYPE";
// Web Application Parameters
const STRING MgHttpResourceStrings::reqFormat = L"FORMAT";
Modified: sandbox/jng/wfs_hits/Web/src/HttpHandler/HttpResourceStrings.h
--- sandbox/jng/wfs_hits/Web/src/HttpHandler/HttpResourceStrings.h 2019-07-12 13:47:29 UTC (rev 9571)
+++ sandbox/jng/wfs_hits/Web/src/HttpHandler/HttpResourceStrings.h 2019-07-12 14:37:42 UTC (rev 9572)
@@ -237,6 +237,7 @@
static const STRING reqWfsBbox;
static const STRING reqWfsOutputFormat;
static const STRING reqWfsSortBy;
+ static const STRING reqWfsResultType;
// PREDEFINED WEB APPLICATION REQUEST PARAMETERS
static const STRING reqFormat;
Modified: sandbox/jng/wfs_hits/Web/src/HttpHandler/HttpWfsGetFeature.cpp
--- sandbox/jng/wfs_hits/Web/src/HttpHandler/HttpWfsGetFeature.cpp 2019-07-12 13:47:29 UTC (rev 9571)
+++ sandbox/jng/wfs_hits/Web/src/HttpHandler/HttpWfsGetFeature.cpp 2019-07-12 14:37:42 UTC (rev 9572)
@@ -300,41 +300,71 @@
numFeaturesToRetrieve = limit;
- // Call the C++ API
- // NOTE: I updated the maxFeatures value from numFeaturesToRetrieve to numFeaturesToRetrieve-1
- // Because the MgServerFdoFeatureReader in MapGuide server uses -1 to mark empty, while MgWfsFeatures
- // in MapGuide web tier uses 0
- //For GeoJSON, use the new GetWfsReader API
- if (sOutputFormat == MgMimeType::Json)
+ // Is this hit mode? If so, just request the raw total
+ if (m_getFeatureParams->IsHitMode())
- // NOTE: This API doesn't accept WFS version, format and XML namepaces because these are GML-isms baked into the GetWfsFeature API itself, making
- // it unsuitable for non-GML output, hence the need for this new GetWfsReader API
- Ptr<MgFeatureReader> fr = featureService->GetWfsReader(featureSourceId, ((sSchemaHash.size() == 0) ? sClass : sSchemaHash + _(":") + sClass),
- requiredProperties, m_getFeatureParams->GetSrs(), filter, sSortCriteria);
- //MgByteSource owns this and will clean it up when done
- MgReaderByteSourceImpl* bsImpl = new MgReaderByteSourceImpl(fr, MgMimeType::Json, true, false, -1, NULL);
- bsImpl->SetMaxFeatures(numFeaturesToRetrieve - 1);
- Ptr<MgByteSource> bs = new MgByteSource(bsImpl);
- resultReader = bs->GetReader();
+ INT32 total = featureService->GetWfsFeatureTotal(featureSourceId, ((sSchemaHash.size() == 0) ? sClass : sSchemaHash + _(":") + sClass), sSortCriteria, numFeaturesToRetrieve);
+ std::string sTotal;
+ MgUtil::Int32ToString(total, sTotal);
+ if (sOutputFormat == MgMimeType::Json)
+ std::string json = "{";
+ json += "\"total\": ";
+ json += sTotal;
+ json += "}";
+ Ptr<MgByteSource> bs = new MgByteSource((BYTE_ARRAY_IN)json.data(), json.length());
+ bs->SetMimeType(MgMimeType::Json);
+ resultReader = bs->GetReader();
+ else
+ std::string xml = "<test>";
+ xml += "total is: ";
+ xml += sTotal;
+ xml += "</test>";
+ Ptr<MgByteSource> bs = new MgByteSource((BYTE_ARRAY_IN)xml.data(), xml.length());
+ bs->SetMimeType(MgMimeType::Xml);
- else
+ else
// Call the C++ API
- resultReader = featureService->GetWfsFeature(featureSourceId, ((sSchemaHash.size() == 0) ? sClass : sSchemaHash + _(":") + sClass),
- requiredProperties, m_getFeatureParams->GetSrs(), filter, numFeaturesToRetrieve - 1, sVersion, sOutputFormat, sSortCriteria, sPrefix, oFeatureTypes.GetNamespaceUrl());
- // Store the MgByteReader directly for retrieval
- // DO NOT PASS THROUGH OGC XML TEMPLATE PROCESSING CODE!
- // DO NOT PASS GO!
- // DO NOT COLLECT MEMORY SPIKES NEEDLESSLY BUFFERING XML TEMPLATE CONTENT AS A RESULT!
- // This *is* already the WFS GetFeature response. There is nothing to post-process through the XML templates!
+ //For GeoJSON, use the new GetWfsReader API
+ // NOTE: This API doesn't accept WFS version, format and XML namepaces because these are GML-isms baked into the GetWfsFeature API itself, making
+ // it unsuitable for non-GML output, hence the need for this new GetWfsReader API
+ Ptr<MgFeatureReader> fr = featureService->GetWfsReader(featureSourceId, ((sSchemaHash.size() == 0) ? sClass : sSchemaHash + _(":") + sClass),
+ requiredProperties, m_getFeatureParams->GetSrs(), filter, sSortCriteria);
+ //MgByteSource owns this and will clean it up when done
+ MgReaderByteSourceImpl* bsImpl = new MgReaderByteSourceImpl(fr, MgMimeType::Json, true, false, -1, NULL);
+ bsImpl->SetMaxFeatures(numFeaturesToRetrieve - 1);
+ Ptr<MgByteSource> bs = new MgByteSource(bsImpl);
+ else
+ // Call the C++ API
+ // NOTE: I updated the maxFeatures value from numFeaturesToRetrieve to numFeaturesToRetrieve-1
+ // Because the MgServerFdoFeatureReader in MapGuide server uses -1 to mark empty, while MgWfsFeatures
+ // in MapGuide web tier uses 0
+ resultReader = featureService->GetWfsFeature(featureSourceId, ((sSchemaHash.size() == 0) ? sClass : sSchemaHash + _(":") + sClass),
+ requiredProperties, m_getFeatureParams->GetSrs(), filter, numFeaturesToRetrieve - 1, sVersion, sOutputFormat, sSortCriteria, sPrefix, oFeatureTypes.GetNamespaceUrl());
+ // Store the MgByteReader directly for retrieval
+ // DO NOT PASS THROUGH OGC XML TEMPLATE PROCESSING CODE!
+ // DO NOT PASS GO!
+ // DO NOT COLLECT MEMORY SPIKES NEEDLESSLY BUFFERING XML TEMPLATE CONTENT AS A RESULT!
+ // This *is* already the WFS GetFeature response. There is nothing to post-process through the XML templates!
else //Cannot resolve feature source from feature type name
Modified: sandbox/jng/wfs_hits/Web/src/HttpHandler/WfsGetFeatureParams.cpp
--- sandbox/jng/wfs_hits/Web/src/HttpHandler/WfsGetFeatureParams.cpp 2019-07-12 13:47:29 UTC (rev 9571)
+++ sandbox/jng/wfs_hits/Web/src/HttpHandler/WfsGetFeatureParams.cpp 2019-07-12 14:37:42 UTC (rev 9572)
@@ -37,6 +37,7 @@
, m_filterStrings(new MgStringCollection())
, m_featureTypeList(new MgStringCollection())
, m_pNamespaces(new MgXmlNamespaceManager())
+, m_hitMode(false)
// Get the required properties
@@ -105,6 +106,12 @@
// Get the sortby property name
m_sortCriteria = GetRequestParameter(oServer,MgHttpResourceStrings::reqWfsSortBy);
+ // Try to set hit mode flag (only if WFS version != 1.0.0 as it was only introduced from 1.1.0 onwards)
+ if (m_version != L"1.0.0")
+ STRING resultType = GetRequestParameter(oServer, MgHttpResourceStrings::reqWfsResultType);
+ m_hitMode = (resultType == L"hits");
WfsGetFeatureParams::~WfsGetFeatureParams()
@@ -609,3 +616,8 @@
+bool WfsGetFeatureParams::IsHitMode()
+ return m_hitMode;
\ No newline at end of file
Modified: sandbox/jng/wfs_hits/Web/src/HttpHandler/WfsGetFeatureParams.h
--- sandbox/jng/wfs_hits/Web/src/HttpHandler/WfsGetFeatureParams.h 2019-07-12 13:47:29 UTC (rev 9571)
+++ sandbox/jng/wfs_hits/Web/src/HttpHandler/WfsGetFeatureParams.h 2019-07-12 14:37:42 UTC (rev 9572)
@@ -68,6 +68,14 @@
~WfsGetFeatureParams();
/// <summary>
+ /// Gets whether the query is only asking for hits (ie. A total feature count)
+ /// </summary>
+ /// <returns>
+ /// True if the query is asking for hits. False otherwise
+ /// </returns>
+ bool IsHitMode();
+ /// <summary>
/// Retrieves the filter strings for the request
/// </summary>
/// <returns>
@@ -183,6 +191,7 @@
STRING m_outputFormat;
STRING m_version;
STRING m_sortCriteria;
+ bool m_hitMode;
#endif // _FS_WFS_GET_FEATURE_PARAMS_H
More information about the mapguide-commits
