[mapguide-commits] r9573 - sandbox/jng/wfs_hits/Web/src/HttpHandler
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Jul 13 05:02:18 PDT 2019
Author: jng
Date: 2019-07-13 05:02:18 -0700 (Sat, 13 Jul 2019)
New Revision: 9573
   sandbox/jng/wfs_hits/Web/src/HttpHandler/HttpWfsGetFeature.cpp
   sandbox/jng/wfs_hits/Web/src/HttpHandler/ReaderByteSourceImpl.cpp
   sandbox/jng/wfs_hits/Web/src/HttpHandler/WmsMapUtil.cpp
Fix up the expected format of a WFS GetFeatures when resultType=hits.
If format is JSON just return an object with the total.
Also fix an assortment of warnings
Modified: sandbox/jng/wfs_hits/Web/src/HttpHandler/HttpWfsGetFeature.cpp
--- sandbox/jng/wfs_hits/Web/src/HttpHandler/HttpWfsGetFeature.cpp	2019-07-12 14:37:42 UTC (rev 9572)
+++ sandbox/jng/wfs_hits/Web/src/HttpHandler/HttpWfsGetFeature.cpp	2019-07-13 12:02:18 UTC (rev 9573)
@@ -309,20 +309,28 @@
                                 if (sOutputFormat == MgMimeType::Json)
                                     std::string json = "{";
-                                    json += "\"total\": ";
+                                    json += "\"numberOfFeatures\": ";
                                     json += sTotal;
                                     json += "}";
-                                    Ptr<MgByteSource> bs = new MgByteSource((BYTE_ARRAY_IN)json.data(), json.length());
+                                    Ptr<MgByteSource> bs = new MgByteSource((BYTE_ARRAY_IN)json.data(), (INT32)json.length());
                                     bs->SetMimeType(MgMimeType::Json);
                                     resultReader = bs->GetReader();
                                 else
-                                    std::string xml = "<test>";
-                                    xml += "total is: ";
+                                    std::string mbPrefix;
+                                    MgUtil::WideCharToMultiByte(sPrefix, mbPrefix);
+                                    std::string xml = "<?xml version=\"1.0\" encoding=\"utf-8\" ?>\n";
+                                    xml += "<wfs:FeatureCollection xmlns:gml=\"http://www.opengis.net/gml\" xmlns:wfs=\"http://www.opengis.net/wfs\" xmlns:";
+                                    xml += mbPrefix;
+                                    xml += "=\"http://fdo.osgeo.org/schemas/feature/";
+                                    xml += mbPrefix;
+                                    xml += "\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:schemaLocation=\"http://www.opengis.net/gml http://schemas.opengis.net/gml/3.1.1/base/feature.xsd http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd\"";
+                                    xml += " numberOfFeatures=\"";
                                     xml += sTotal;
-                                    xml += "</test>";
-                                    Ptr<MgByteSource> bs = new MgByteSource((BYTE_ARRAY_IN)xml.data(), xml.length());
+                                    xml += "\" />";
+                                    Ptr<MgByteSource> bs = new MgByteSource((BYTE_ARRAY_IN)xml.data(), (INT32)xml.length());
                                     bs->SetMimeType(MgMimeType::Xml);
Modified: sandbox/jng/wfs_hits/Web/src/HttpHandler/ReaderByteSourceImpl.cpp
--- sandbox/jng/wfs_hits/Web/src/HttpHandler/ReaderByteSourceImpl.cpp	2019-07-12 14:37:42 UTC (rev 9572)
+++ sandbox/jng/wfs_hits/Web/src/HttpHandler/ReaderByteSourceImpl.cpp	2019-07-13 12:02:18 UTC (rev 9573)
@@ -166,7 +166,7 @@
-    INT32 maxIndex = m_buf.length() - 1;
+    auto maxIndex = m_buf.length() - 1;
     //We have an internal buffer. Clear this out first
     if (m_bufOffset < maxIndex)
@@ -311,7 +311,7 @@
     while (ret < length)
         m_bufOffset++;
         if (m_bufOffset <= maxIndex)
             buffer[fromIndex + ret] = m_buf[m_bufOffset];
Modified: sandbox/jng/wfs_hits/Web/src/HttpHandler/WmsMapUtil.cpp
--- sandbox/jng/wfs_hits/Web/src/HttpHandler/WmsMapUtil.cpp	2019-07-12 14:37:42 UTC (rev 9572)
+++ sandbox/jng/wfs_hits/Web/src/HttpHandler/WmsMapUtil.cpp	2019-07-13 12:02:18 UTC (rev 9573)
@@ -219,7 +219,7 @@
                         STRING qualifiedName = mgLayer->GetFeatureClassName();
-                        int pos = qualifiedName.find(L":");
+                        auto pos = qualifiedName.find(L":");
                         STRING schemaName = qualifiedName.substr(0,pos);
                         STRING className = qualifiedName.substr(pos+1,qualifiedName.length()-pos-1);
@@ -527,11 +527,11 @@
     // Looking for all <Bounds> elements from layerBounds
     // Example: <Bounds SRS="EPSG:4326" west="-87.74" south="43.68" east="-87.69" north="43.815"/>
     Ptr<MgStringCollection> bounds = new MgStringCollection();
-    int pos = 0;
+    size_t pos = 0;
     while((pos = layerBounds.find(L"<Bounds",pos)) != STRING::npos)
         pos += 7; // pos+7 to the first character after <Bounds
-        int endPos = layerBounds.find(L"/>",pos);
+        auto endPos = layerBounds.find(L"/>",pos);
         bounds->Add(layerBounds.substr(pos,endPos-pos));
@@ -541,8 +541,8 @@
         STRING bound = bounds->GetItem(i);
         //Find SRS value from Bounds element
-        int startPos = bound.find(L"SRS=\"");
-        int endPos = bound.find(L"\"",startPos+5); // pos+5 to the first character after SRS="
+        auto startPos = bound.find(L"SRS=\"");
+        auto endPos = bound.find(L"\"",startPos+5); // pos+5 to the first character after SRS="
         STRING srs = bound.substr(startPos+5,endPos-startPos-5);
         if(MgUtil::ToUpper(srs) == MgUtil::ToUpper(sSrs))
More information about the mapguide-commits mailing list
