[mapguide-commits] r9550 - in sandbox/jng/tiling_v3: Doc/samples/ol2samples/hybrid Doc/samples/ol2samples/xyz UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets
svn_mapguide at osgeo.org
Mon Jun 17 04:54:46 PDT 2019
Author: jng
Date: 2019-06-17 04:54:46 -0700 (Mon, 17 Jun 2019)
New Revision: 9550
Added:
sandbox/jng/tiling_v3/Doc/samples/ol2samples/xyz/index_ol.html
sandbox/jng/tiling_v3/Doc/samples/ol2samples/hybrid/index.html
sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml
- Add XYZ sample to verify XYZ tile sets are consumable in ol3+
- Fix up extents of sample XYZ tile set. Its bounds were in LL84 coordinates when it should be WGS84.PseudoMercator coordinates (per RFC 140 errata)
- With this change, we can confirm that the "hybrid" example can now work with XYZ tile sets as well.
Modified: sandbox/jng/tiling_v3/Doc/samples/ol2samples/hybrid/index.html
--- sandbox/jng/tiling_v3/Doc/samples/ol2samples/hybrid/index.html 2019-06-16 14:56:56 UTC (rev 9549)
+++ sandbox/jng/tiling_v3/Doc/samples/ol2samples/hybrid/index.html 2019-06-17 11:54:46 UTC (rev 9550)
@@ -114,6 +114,7 @@
activeMap.destroy();
activeMap = new MapViewModel("#wrap", data, jqXHR.responseText.length);
+ $("#error").html("");
}).error(function (jqXHR, textStatus, errorThrown) {
$("#error").html(jqXHR.responseText);
Added: sandbox/jng/tiling_v3/Doc/samples/ol2samples/xyz/index_ol.html
--- sandbox/jng/tiling_v3/Doc/samples/ol2samples/xyz/index_ol.html (rev 0)
+++ sandbox/jng/tiling_v3/Doc/samples/ol2samples/xyz/index_ol.html 2019-06-17 11:54:46 UTC (rev 9550)
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ <title>Sheboygan map as XYZ</title>
+ <link rel="stylesheet" href="../assets/ol.css" />
+ <style type="text/css">
+ #error { color: red; }
+ #wrap { width: 900; }
+ #map { width: 400; height: 300; float: left; border: 1px solid black; }
+ #main { margin-top: 50px; padding-top: 20px; }
+ </style>
+ <script type="text/javascript" src="../assets/ol-debug.js"></script>
+ <script type="text/javascript" src="../assets/jquery-1.10.2.min.js"></script>
+ <script type="text/javascript">
+ //This sample is assumed to be hosted at http://servername/mapguide/ol2samples/xyz/index_ol.html
+ var mapAgentUrl = "../../mapagent/mapagent.fcgi";
+ $(document).ready(function() {
+ //NOTE: Your map definition can be in any coordinate system as long as it it transformable to LL84
+ //But the ol3 tile layer must remain as EPSG:3857
+ var map = new ol.Map({
+ layers: [
+ new ol.layer.Tile({
+ source: new ol.source.OSM({
+ attributions: [
+ new ol.Attribution({
+ html: 'Tiles © <a href="http://www.openstreetmap.org/">' +
+ 'OpenStreetMap</a>'
+ ol.source.OSM.ATTRIBUTION
+ url: 'http://{a-c}.tile.openstreetmap.org/{z}/{x}/{y}.png'
+ source: new ol.source.XYZ({
+ url: mapAgentUrl + "?OPERATION=GETTILEIMAGE&VERSION=1.2.0&CLIENTAGENT=OpenLayers&USERNAME=Anonymous&MAPDEFINITION=Library://Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition&BASEMAPLAYERGROUPNAME=Base+Layer+Group&TILECOL={y}&TILEROW={x}&SCALEINDEX={z}"
+ renderer: 'canvas',
+ target: document.getElementById('map'),
+ view: new ol.View({
+ center: ol.proj.transform([-87.7302542509315, 43.744459064634], 'EPSG:4326', 'EPSG:3857'),
+ minZoom: 10,
+ maxZoom: 19,
+ zoom: 12
+ </script>
+ </head>
+ <body>
+ <div id="main">
+ <div class="container">
+ <div class="alert alert-info">
+ <p>This example demonstrates a Map Definition being consumed as a <strong>XYZ layer</strong> via the MapGuide REST API with <a href="http://openlayers.org/">OpenLayers 3</a>.</p>
+ <p>An OpenStreetMap layer is included as a backdrop for context</p>
+ <strong>For maximum visual fidelity, your Map Definition should be in WGS84.PseudoMercator</strong>
+ <p>Sample not loading? <a href="../data/load.php">Check that the required resources have been loaded</a></p>
+ </div>
+ <div id="error">
+ </div>
+ <div id="wrap">
+ <div id="map">
+ </div>
+ </div>
+ </div>
+ </div>
+ </body>
+</html>
Modified: sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml
--- sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml 2019-06-16 14:56:56 UTC (rev 9549)
+++ sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml 2019-06-17 11:54:46 UTC (rev 9550)
@@ -12,10 +12,10 @@
</Parameter>
</TileStoreParameters>
<Extents>
- <MinX>-87.79786601383196</MinX>
- <MaxX>-87.66452777186925</MaxX>
- <MinY>43.6868578621819</MinY>
- <MaxY>43.8037962206133</MaxY>
+ <MinX>-9769953.6613122653</MinX>
+ <MaxX>-9762220.7994439267</MaxX>
+ <MinY>5417808.8801717851</MinY>
+ <MaxY>5434161.2241863841</MaxY>
</Extents>
<BaseMapLayerGroup>
<Name>Base Layer Group</Name>
More information about the mapguide-commits
