[mapguide-commits] r9551 - in sandbox/jng/tiling_v3: Doc/samples/ol2samples/hybrid UnitTest/TestData/Samples/Sheboygan UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets
svn_mapguide at osgeo.org
Mon Jun 17 05:14:48 PDT 2019
Author: jng
Date: 2019-06-17 05:14:48 -0700 (Mon, 17 Jun 2019)
New Revision: 9551
Added:
sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_CONTENT.xml
sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml
sandbox/jng/tiling_v3/Doc/samples/ol2samples/hybrid/index.html
sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml
- Add "retina" XYZ sample tile set
- Auto-set retina scale level if present on "hybrid" sample
Modified: sandbox/jng/tiling_v3/Doc/samples/ol2samples/hybrid/index.html
--- sandbox/jng/tiling_v3/Doc/samples/ol2samples/hybrid/index.html 2019-06-17 11:54:46 UTC (rev 9550)
+++ sandbox/jng/tiling_v3/Doc/samples/ol2samples/hybrid/index.html 2019-06-17 12:14:48 UTC (rev 9551)
@@ -177,6 +177,10 @@
var zOrigin = _this.finiteScales.length - 1;
var resolutions = new Array(_this.finiteScales.length);
if (rtMapInfo.RuntimeMap.TileSetProvider == "XYZ") {
+ var retinaScale = 1;
+ if (typeof(rtMapInfo.RuntimeMap.TilePixelRatio) != 'undefined') {
+ retinaScale = rtMapInfo.RuntimeMap.TilePixelRatio;
$("scale-el").hide(); //Not applicable for XYZ
for (var i = 0; i < rtMapInfo.RuntimeMap.Group.length; i++) {
var group = rtMapInfo.RuntimeMap.Group[i];
@@ -192,7 +196,8 @@
html: '<img src="../../localized/PoweredBy_en.gif" title="Powered by MapGuide" />'
- url: getTileUrlTemplate(resourceId, group.Name, true)
+ url: getTileUrlTemplate(resourceId, group.Name, true),
+ tilePixelRatio: retinaScale
Added: sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_CONTENT.xml
--- sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_CONTENT.xml (rev 0)
+++ sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_CONTENT.xml 2019-06-17 12:14:48 UTC (rev 9551)
@@ -0,0 +1,87 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<TileSetDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="TileSetDefinition-3.0.0.xsd">
+ <TileStoreParameters>
+ <TileProvider>XYZ</TileProvider>
+ <Parameter>
+ <Name>TilePath</Name>
+ <Value>%MG_TILE_CACHE_PATH%</Value>
+ </Parameter>
+ <Parameter>
+ <Name>TileFormat</Name>
+ <Value>PNG</Value>
+ </Parameter>
+ <Parameter>
+ <Name>RetinaScale</Name>
+ <Value>2</Value>
+ </Parameter>
+ </TileStoreParameters>
+ <Extents>
+ <MinX>-9769953.6613122653</MinX>
+ <MaxX>-9762220.7994439267</MaxX>
+ <MinY>5417808.8801717851</MinY>
+ <MaxY>5434161.2241863841</MaxY>
+ </Extents>
+ <BaseMapLayerGroup>
+ <Name>Base Layer Group</Name>
+ <Visible>true</Visible>
+ <ShowInLegend>true</ShowInLegend>
+ <ExpandInLegend>true</ExpandInLegend>
+ <LegendLabel>Tiled Layers</LegendLabel>
+ <BaseMapLayer>
+ <Name>Roads</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</ResourceId>
+ <Selectable>false</Selectable>
+ <LegendLabel>Roads</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>Districts</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</ResourceId>
+ <LegendLabel>Districts</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>Buildings</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</ResourceId>
+ <LegendLabel>Buildings</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>Parcels</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</ResourceId>
+ <Selectable>true</Selectable>
+ <LegendLabel>Parcels</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>Islands</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</ResourceId>
+ <LegendLabel>Islands</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>Hydrography</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</ResourceId>
+ <LegendLabel>Hydrography</LegendLabel>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>CityLimits</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</ResourceId>
+ <LegendLabel>CityLimits</LegendLabel>
+ </BaseMapLayer>
+ </BaseMapLayerGroup>
+</TileSetDefinition>
\ No newline at end of file
Added: sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml
--- sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml (rev 0)
+++ sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml 2019-06-17 12:14:48 UTC (rev 9551)
@@ -0,0 +1,6 @@
+<ResourceDocumentHeader xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
+ <Security xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
+ <Inherited>true</Inherited>
+ </Security>
+</ResourceDocumentHeader>
Modified: sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml
--- sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml 2019-06-17 11:54:46 UTC (rev 9550)
+++ sandbox/jng/tiling_v3/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml 2019-06-17 12:14:48 UTC (rev 9551)
@@ -1,2409 +1 @@
-<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
-<ResourcePackageManifest
- xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourcePackageManifest-1.0.0.xsd">
- <Operations>
- <Operation>
- <Name>SETRESOURCE</Name>
- <Version>1.0.0</Version>
- <Parameters>
- <Parameter>
- <Name>HEADER</Name>
- <Value>Library/Samples/Sheboygan/_HEADER.xml</Value>
- <ContentType>text/xml</ContentType>
- </Parameter>
- <Parameter>
- <Name>RESOURCEID</Name>
- <Value>Library://Samples/Sheboygan/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/FlexibleLayouts/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Maps/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Maps/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/MapsTiled/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/MapsTiled/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Symbols/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Watermarks/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/TileSets/_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library://Samples/Sheboygan/TileSets/</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Name>DELETERESOURCE</Name>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>CONTENT</Name>
- <Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Name>SETRESOURCEDATA</Name>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_DATA_symbols.dwf</Value>
- <ContentType>model/vnd.dwf</ContentType>
- </Parameter>
- <Parameter>
- <Name>DATALENGTH</Name>
- <Value>5594</Value>
- </Parameter>
- <Parameter>
- <Name>DATANAME</Name>
- <Value>symbols.dwf</Value>
- </Parameter>
- <Parameter>
- <Name>DATATYPE</Name>
- <Value>File</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_DATA_symbols.dwf</Value>
- </Parameter>
- <Parameter>
- <Value>22760</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_DATA_BuildingOutlines.sdf</Value>
- <ContentType>application/octet-stream</ContentType>
- </Parameter>
- <Parameter>
- <Value>8038400</Value>
- </Parameter>
- <Parameter>
- <Value>BuildingOutlines.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_DATA_CityLimits.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>307200</Value>
- </Parameter>
- <Parameter>
- <Value>CityLimits.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_DATA_HydrographicLines.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>768000</Value>
- </Parameter>
- <Parameter>
- <Value>HydrographicLines.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_DATA_HydrographicPolygons.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>512000</Value>
- </Parameter>
- <Parameter>
- <Value>HydrographicPolygons.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_DATA_Islands.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- <Value>Islands.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_DATA_LandUse.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>1996800</Value>
- </Parameter>
- <Parameter>
- <Value>LandUse.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_DATA_Parcels.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>11929600</Value>
- </Parameter>
- <Parameter>
- <Value>Parcels.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_DATA_Rail.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>870400</Value>
- </Parameter>
- <Parameter>
- <Value>Rail.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_DATA_RoadCenterLines.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>665600</Value>
- </Parameter>
- <Parameter>
- <Value>RoadCenterLines.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_DATA_Soils.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>4556800</Value>
- </Parameter>
- <Parameter>
- <Value>Soils.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_DATA_Trees.sdf</Value>
- </Parameter>
- <Parameter>
- <Value>6656000</Value>
- </Parameter>
- <Parameter>
- <Value>Trees.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Name>DATA</Name>
- <Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_DATA_VotingDistricts.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- <Value>VotingDistricts.sdf</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/SheboyganV26.WebLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Trees.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers/Soils.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Symbols/Rail.SymbolDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Symbols/Trees.SymbolDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library://Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition</Value>
- </Parameter>
- </Parameters>
- </Operation>
- <Operation>
- <Parameters>
- <Parameter>
- <Value>Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_CONTENT.xml</Value>
- </Parameter>
- <Parameter>
- <Value>Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_HEADER.xml</Value>
- </Parameter>
- <Parameter>
- </Parameter>
- </Parameters>
- </Operation>
- </Operations>
-</ResourcePackageManifest>
+<?xml version="1.0" encoding="UTF-8" standalone="no" ?><ResourcePackageManifest xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourcePackageManifest-1.0.0.xsd"><Operations><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/_HEADER.xml</Value><Content
Type>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/MapsTiled/_HEADER.xml</Value><ContentType>
text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/MapsTiled/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/_HEADER.xml</Value><ContentType>text/xml
</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/_HEADER.xml</Value><Content
Type>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Paramet
ers><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><N
ame>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Islands.LayerD
efinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERE
SOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0<
/Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>
Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJspTiled.We
bLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout</Value></Parameter
></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentTyp
e></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboy
gan/Layouts/SheboyganMap.PrintLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Symbols/Bas
icSymbols.SymbolLibrary_DATA_symbols.dwf</Value><ContentType>model/vnd.dwf</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>5594</Value></Parameter><Parameter><Name>DATANAME</Name><Value>symbols.dwf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_HEADER.xml</Valu
e><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_DATA_symbols.dwf</Value><ContentType>model/vnd.dwf</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>22760</Value></Parameter><Parameter><Name>DATANAME</Name><Value>symbols.dwf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Ope
ration><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_DATA_BuildingOutlines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>8038400</Value></Parameter><Parameter><Name>DATANAME</Name><Value>BuildingOutlines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Val
ue>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Paramete
rs><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_DATA_CityLimits.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>CityLimits.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Para
meter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_DATA_HydrographicLines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>768000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>HydrographicLines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Ver
sion><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_DATA_HydrographicPolygons.sdf</Value><ContentType>application/octet-stream</ContentType><
/Parameter><Parameter><Name>DATALENGTH</Name><Value>512000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>HydrographicPolygons.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOUR
CEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_DATA_Islands.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Islands.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Para
meter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_DATA_LandUse.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>1996800</Value></Parameter><Parameter><Name>DATANAME</Name><Value>LandUse.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Va
lue></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_DATA_Parcels.sdf</Value><ContentType>application/octet-s
tream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>11929600</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Parcels.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><V
alue>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_DATA_Rail.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>870400</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Rail.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT<
/Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_DATA_RoadCenterLines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>665600</Value></Parameter><Parameter><Name>DATANAME</Name><Value>RoadCenterLines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Dat
a/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_DATA_Soils.sdf</Value><ContentT
ype>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>4556800</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Soils.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Nam
e>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_DATA_Trees.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>6656000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Trees.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameter
s><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_DATA_VotingDistricts.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>VotingDistricts.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Libr
ary://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/
Sheboygan/Layers/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapText.Water
markDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition
_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition</Value><
/Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganV26.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganV26.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition</Value></Pa
rameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheb
oygan/FlexibleLayouts/Slate.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/She
boygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/
Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Paramete
r><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Vers
ion><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Soils.L
ayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURC
E</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><
Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_CONTENT.xml</Value><ContentT
ype>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Para
meter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Ver
sion><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0
.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Rail.SymbolDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>
Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Rail.SymbolDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Trees.SymbolDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Trees.SymbolDefinition</Value></Parameter></Par
ameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition</Value
></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advance
d/Parcels.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml</Value><
ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Op
eration><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout</Value></Parameter></P
arameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_CONTENT.xml</Value><Con
tentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESO
URCEID</Name><Value>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganUTFGrid.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Par
ameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Versi
on>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/TileSets/SheboyganXYZRetina.TileSetDefinition</Value></Parameter></Parameters></Operation></Operations></ResourcePackageManifest>
\ No newline at end of file
More information about the mapguide-commits
