[mapguide-commits] r9559 - in trunk/MgDev: . Common/MapGuideCommon/Services Common/MapGuideCommon/System Common/Renderers Server/src/Core Server/src/Services/Rendering Server/src/Services/Tile Server/src/UnitTesting
svn_mapguide at osgeo.org
Sat Jun 22 01:42:36 PDT 2019
Author: jng
Date: 2019-06-22 01:42:36 -0700 (Sat, 22 Jun 2019)
New Revision: 9559
Removed:
trunk/MgDev/Common/Renderers/GDFillPatterns.cpp
trunk/MgDev/Common/Renderers/GDFillPatterns.h
trunk/MgDev/Common/Renderers/GDRenderer.cpp
trunk/MgDev/Common/Renderers/GDRenderer.h
trunk/MgDev/Common/Renderers/GDW2DRewriter.cpp
trunk/MgDev/Common/Renderers/GDW2DRewriter.h
trunk/MgDev/Common/Renderers/complex_polygon_gd.cpp
trunk/MgDev/Common/Renderers/complex_polygon_gd.h
trunk/MgDev/
trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.h
trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
trunk/MgDev/Common/Renderers/Renderers.vcxproj
trunk/MgDev/Common/Renderers/Renderers.vcxproj.filters
trunk/MgDev/Server/src/Core/serverconfig.ini
trunk/MgDev/Server/src/Services/Rendering/OpRenderTileFromMetatile.cpp
trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h
trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp
trunk/MgDev/Server/src/Services/Tile/ServerTileService.h
trunk/MgDev/Server/src/Services/Tile/TileCacheDefaultProvider.cpp
trunk/MgDev/Server/src/Services/Tile/TileCacheDefaultProvider.h
trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.cpp
trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.h
trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp
trunk/MgDev/Server/src/UnitTesting/TestTileService.cpp
Implement MapGuide RFC 174. Farewell GD renderer.
Index: trunk/MgDev
--- trunk/MgDev 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev 2019-06-22 08:42:36 UTC (rev 9559)
Property changes on: trunk/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
## -21,6 +21,7 ##
/sandbox/jng/geos34x:8256-8259
/sandbox/jng/ogc:9240-9255
/sandbox/jng/php56x:8975-8985
+/sandbox/jng/remove_gd:9548-9558
/sandbox/jng/rfc155:8872-8884
/sandbox/jng/simplify:8814-9141
/sandbox/jng/tiling:8174-8208
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.cpp 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.cpp 2019-06-22 08:42:36 UTC (rev 9559)
@@ -1407,7 +1407,6 @@
MgByteReader* MgProxyRenderingService::RenderTileFromMetaTile(
MgMap* map,
MgMetatile* metaTile,
- CREFSTRING rendererName,
INT32 subTileX,
INT32 subTileY)
@@ -1415,14 +1414,13 @@
cmd.ExecuteCommand(m_connProp, // Connection
MgCommand::knObject, // Return type expected
MgRenderingServiceOpId::RenderTileFromMetaTile, // Command Code
- 9, // No of arguments
+ 4, // No of arguments
Rendering_Service, // Service Id
- BUILD_VERSION(4,0,0), // Operation version
+ BUILD_VERSION(4,0,0), // Operation version
MgCommand::knObject, map, // Argument#1
MgCommand::knObject, metaTile, // Argument#2
- MgCommand::knString, &rendererName, // Argument#3
- MgCommand::knInt32, subTileX, // Argument#4
- MgCommand::knInt32, subTileY, // Argument#5
+ MgCommand::knInt32, subTileX, // Argument#3
+ MgCommand::knInt32, subTileY, // Argument#4
MgCommand::knNone); // End of arguments
SetWarning(cmd.GetWarningObject());
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.h 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.h 2019-06-22 08:42:36 UTC (rev 9559)
@@ -1233,9 +1233,6 @@
/// \param metaTile
/// Input
/// The meta-tile from which a subtile is being requested for
- /// \param rendererName
- /// Input
- /// The name of the renderer to create for sub-tile slicing
/// \param subTileX
/// Input
/// The x sub-tile coordinate of the meta-tile to request
@@ -1247,7 +1244,7 @@
/// The requested sub-tile
/// \since 4.0
- virtual MgByteReader* RenderTileFromMetaTile(MgMap* map, MgMetatile* metaTile, CREFSTRING rendererName, INT32 subTileX, INT32 subTileY);
+ virtual MgByteReader* RenderTileFromMetaTile(MgMap* map, MgMetatile* metaTile, INT32 subTileX, INT32 subTileY);
protected:
Modified: trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h
--- trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h 2019-06-22 08:42:36 UTC (rev 9559)
@@ -1249,9 +1249,6 @@
/// \param metaTile
/// Input
- /// Input
/// \param subTileX
/// Input
@@ -1263,7 +1260,7 @@
/// \since 4.0
- virtual MgByteReader* RenderTileFromMetaTile(MgMap* map, MgMetatile* metaTile, CREFSTRING rendererName, INT32 subTileX, INT32 subTileY) = 0;
+ virtual MgByteReader* RenderTileFromMetaTile(MgMap* map, MgMetatile* metaTile, INT32 subTileX, INT32 subTileY) = 0;
protected:
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2019-06-22 08:42:36 UTC (rev 9559)
@@ -170,8 +170,6 @@
const STRING MgConfigProperties::DefaultGeneralPropertyWmsDocumentPath = L"Wms/";
const STRING MgConfigProperties::GeneralPropertyWorkerThreadPoolSize = L"WorkerThreadPoolSize"; // for internal use only
const INT32 MgConfigProperties::DefaultGeneralPropertyWorkerThreadPoolSize = 1;
-const STRING MgConfigProperties::GeneralPropertyRenderer = L"Renderer";
-const STRING MgConfigProperties::DefaultGeneralPropertyRenderer = L"GD";
const STRING MgConfigProperties::GeneralPropertyFailoverRetryTime = L"FailoverRetryTime"; // for internal use only
const INT32 MgConfigProperties::DefaultGeneralPropertyFailoverRetryTime = 60;
const STRING MgConfigProperties::GeneralPropertyPreCacheMaps = L"PreCacheMaps";
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2019-06-22 08:42:36 UTC (rev 9559)
@@ -142,10 +142,6 @@
static const STRING GeneralPropertyWmsDocumentPath; /// value("WmsDocumentPath")
static const STRING DefaultGeneralPropertyWmsDocumentPath; /// value("Wms/")
- /// Sets desired image renderer
- static const STRING GeneralPropertyRenderer; /// value("Renderer")
- static const STRING DefaultGeneralPropertyRenderer; /// value("GD")
/// Sets the maps to precache
static const STRING GeneralPropertyPreCacheMaps; /// value("PreCacheMaps")
static const STRING DefaultGeneralPropertyPreCacheMaps; /// value("")
Deleted: trunk/MgDev/Common/Renderers/GDFillPatterns.cpp
--- trunk/MgDev/Common/Renderers/GDFillPatterns.cpp 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Common/Renderers/GDFillPatterns.cpp 2019-06-22 08:42:36 UTC (rev 9559)
@@ -1,3056 +0,0 @@
-// Copyright (C) 2004-2011 by Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-#include "stdafx.h"
-#include "Renderers.h"
-#include "GDFillPatterns.h"
-// All these definitions were taken from Envision 9 code which took them from
-// OnSite 6 code
-// AutoCAD, and World/MapInfo fill pattern definitions. The fill patterns are
-// defined as monochrome bitmaps (i.e., one bit per pixel), with the following
-// properties: rows of bits are byte aligned rows, and the bitmaps are defined
-// bottom-up. The AutoCAD fill pattern definitions were supplied to us by the
-// Actrix SWD team.
-static unsigned char SOLID_BITS[] = {
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff};
-static unsigned char NONE_BITS[] = {
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
-static unsigned char ANGLE_BITS[] = {
- 0xff, 0x00, 0x01, 0x00, 0x01, 0x00, 0x01, 0x00,
- 0x01, 0x00, 0x01, 0x00, 0x01, 0x00, 0x01, 0x00,
- 0x00, 0x00, 0x00, 0x00};
-static unsigned char BOX_BITS[] = {
- 0xc1, 0x3f, 0xf8, 0x01, 0x41, 0x20, 0x08, 0x00,
- 0x41, 0x20, 0x08, 0x00, 0x41, 0x20, 0x08, 0x00,
- 0xc1, 0x3f, 0xf8, 0x01, 0x41, 0x00, 0x00, 0x00,
- 0x41, 0x00, 0x00, 0x00, 0x41, 0x00, 0x00, 0x00,
- 0x41, 0x00, 0x00, 0x00, 0x7f, 0xe0, 0x0f, 0x00,
- 0x41, 0x20, 0x08, 0x00, 0x7f, 0xe0, 0x0f, 0x00,
- 0x41, 0x00, 0x00, 0x00};
-static unsigned char BRASS_BITS[] = {
- 0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00};
-static unsigned char BRICK_BITS[] = {
- 0xff, 0xff, 0x01, 0x01, 0x00, 0x00, 0x01, 0x00,
- 0x00, 0x01, 0x00, 0x00, 0x01, 0x00, 0x00, 0x01,
- 0x00, 0x00, 0x01, 0x00, 0x00, 0x01, 0x00, 0x00,
- 0x01, 0x00, 0x00, 0xff, 0xff, 0x01, 0x00, 0x02,
- 0x00, 0x00, 0x02, 0x00, 0x00, 0x02, 0x00, 0x00,
- 0x02, 0x00, 0x00, 0x02, 0x00, 0x00, 0x02, 0x00,
- 0x00, 0x02, 0x00};
-static unsigned char BRSTONE_BITS[] = {
- 0xff, 0xff, 0xff, 0xff, 0x0f, 0x00, 0x00, 0x00,
- 0x20, 0x01, 0x00, 0x00, 0x00, 0xe0, 0x01, 0x00,
- 0x00, 0x00, 0x20, 0x01, 0x00, 0x00, 0x00, 0xe0,
- 0x01, 0x00, 0x00, 0x00, 0x20, 0x01, 0x00, 0x00,
- 0x00, 0xe0, 0x01, 0x00, 0x00, 0x00, 0x20, 0x01,
- 0x00, 0x00, 0x00, 0xe0, 0x01, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x20, 0x01, 0xff, 0xff, 0xff, 0xff,
- 0x0f, 0x00, 0x48, 0x00, 0x00, 0x00, 0x00, 0x78,
- 0x00, 0x00, 0x00, 0x00, 0x48, 0x00, 0x00, 0x00,
- 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x48, 0x00,
- 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00,
- 0x48, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00,
- 0x00, 0x00, 0x48, 0x00, 0x00, 0x00, 0x00, 0x78,
- 0x00, 0x00, 0x00, 0x00, 0x48, 0x00, 0x00, 0x00};
-static unsigned char CLAY_BITS[] = {
- 0xff, 0xff, 0x0f, 0x00, 0x00, 0x00, 0xff, 0xff,
- 0x0f, 0x00, 0x00, 0x00, 0xff, 0xff, 0x0f, 0x00,
- 0xff, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
-static unsigned char CORK_BITS[] = {
- 0xff, 0xff, 0xff, 0xff, 0x0a, 0x00, 0x00, 0x80,
- 0x05, 0x00, 0x00, 0x40, 0x02, 0x00, 0x00, 0xa0,
- 0x01, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x00,
- 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x50, 0x01, 0x00, 0x00, 0xa8, 0x00,
- 0x00, 0x00, 0x54, 0x00, 0x00, 0x00, 0x2a, 0x00,
- 0xff, 0xff, 0xff, 0xff, 0x00, 0x80, 0x0a, 0x00,
- 0x00, 0x40, 0x05, 0x00, 0x00, 0xa0, 0x02, 0x00,
- 0x00, 0x50, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x50, 0x01, 0x00, 0x00, 0xa8, 0x00, 0x00, 0x00,
- 0x54, 0x00, 0x00, 0x00, 0x2a, 0x00, 0x00, 0x00};
-static unsigned char CROSS_BITS[] = {
- 0x7f, 0x00, 0x00, 0x08, 0x00, 0x00, 0x08, 0x00,
- 0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x80,
- 0x00, 0x00, 0x80, 0x00, 0x00, 0xf0, 0x07, 0x00,
- 0x80, 0x00, 0x00, 0x80, 0x00, 0x00, 0x80, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
- 0x00, 0x00, 0x08, 0x00, 0x00, 0x08, 0x00, 0x00};
-static unsigned char DASH_BITS[] = {
- 0x7f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0xc1, 0x0f, 0x00, 0x00,
-static unsigned char DOLMIT_BITS[] = {
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0x02, 0x00, 0x00, 0x00,
- 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00,
- 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00,
- 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00,
- 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00,
- 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00,
- 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00,
- 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00,
- 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00,
- 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00,
- 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x02,
- 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20,
- 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80,
- 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00,
- 0xff, 0xff, 0xff, 0xff, 0x00, 0x02, 0x00, 0x00,
- 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00,
- 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00,
- 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00,
- 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00,
- 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00,
- 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00,
- 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
- 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00,
- 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00,
- 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00,
- 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00,
- 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0x02, 0x00,
- 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04,
- 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10,
- 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40,
- 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00};
-static unsigned char DOTS_BITS[] = {
- 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
-static unsigned char EARTH_BITS[] = {
- 0xff, 0xff, 0x7f, 0x02, 0x02, 0x02, 0x00, 0x00,
- 0x00, 0x02, 0x02, 0x02, 0x00, 0x00, 0x00, 0x02,
- 0x02, 0x02, 0x00, 0x00, 0x00, 0x02, 0x02, 0x02,
- 0x00, 0x00, 0x00, 0x02, 0x02, 0x02, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x02, 0x02, 0x02, 0xff, 0xff,
- 0x7f, 0x02, 0x02, 0x02, 0x00, 0x00, 0x00, 0x02,
- 0x02, 0x02, 0x08, 0x08, 0x08, 0x02, 0x02, 0x02,
- 0x08, 0x08, 0x08, 0x00, 0x00, 0x00, 0x08, 0x08,
- 0x08, 0x00, 0x00, 0x00, 0x09, 0x08, 0xc8, 0xff,
- 0xff, 0x0f, 0x08, 0x08, 0x08, 0x00, 0x00, 0x00,
- 0x08, 0x00, 0x00, 0x00, 0x08, 0x08, 0x08, 0x00,
- 0x00, 0x00, 0x08, 0x08, 0x08, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x09, 0x08, 0xc8, 0xff, 0xff, 0x0f,
- 0x08, 0x02, 0x02, 0x02, 0x00, 0x00, 0x00, 0x02,
- 0x02, 0x02, 0x00, 0x00, 0x00, 0x02, 0x02, 0x02};
-static unsigned char ESCHER_BITS[] = {
- 0xf9, 0xff, 0xff, 0x3f, 0x12, 0x00, 0x20, 0x00,
- 0x12, 0x00, 0x40, 0x3f, 0x24, 0x00, 0xc0, 0x30,
- 0xe5, 0xff, 0xff, 0x10, 0x89, 0x02, 0x40, 0x08,
- 0x8a, 0x02, 0x40, 0x08, 0x52, 0x04, 0x20, 0x04,
- 0x61, 0x04, 0x20, 0x04, 0x3f, 0x08, 0x10, 0x02,
- 0x42, 0x08, 0x10, 0x22, 0x42, 0x10, 0x08, 0x21,
- 0x84, 0x10, 0x84, 0x10, 0x04, 0x21, 0x84, 0x10,
- 0x08, 0x21, 0x42, 0x08, 0x10, 0x42, 0x42, 0x08,
- 0x10, 0x42, 0x21, 0x04, 0x20, 0x84, 0x21, 0x04,
- 0x20, 0x84, 0x1f, 0x02, 0x40, 0x08, 0x29, 0x02,
- 0x80, 0x10, 0x49, 0x01, 0x80, 0x10, 0x45, 0x01,
- 0xff, 0xa1, 0xf4, 0x3f, 0x80, 0xa1, 0x12, 0x00,
- 0x80, 0x7e, 0x0a, 0x00, 0x40, 0x00, 0x09, 0x00,
- 0x40, 0x00, 0x05, 0x00, 0xff, 0xff, 0xfc, 0x3f,
- 0x40, 0x00, 0x09, 0x00, 0x80, 0x7e, 0x09, 0x00,
- 0x80, 0xa1, 0x12, 0x00, 0xff, 0xa1, 0xf2, 0x3f,
- 0x80, 0x10, 0x45, 0x01, 0x80, 0x10, 0x45, 0x01,
- 0x40, 0x08, 0x29, 0x02, 0x20, 0x84, 0x1f, 0x02,
- 0x20, 0x84, 0x11, 0x04, 0x10, 0x42, 0x21, 0x04,
- 0x10, 0x42, 0x22, 0x08, 0x08, 0x21, 0x42, 0x08,
- 0x04, 0x21, 0x84, 0x10, 0x84, 0x10, 0x84, 0x10,
- 0x42, 0x10, 0x08, 0x21, 0x42, 0x08, 0x10, 0x21,
- 0x3f, 0x08, 0x10, 0x02, 0x21, 0x04, 0x20, 0x02,
- 0x52, 0x04, 0x20, 0x04, 0x4a, 0x02, 0x40, 0x08,
- 0x89, 0x02, 0x40, 0x08, 0xe5, 0xff, 0xff, 0x10,
- 0x24, 0x00, 0xc0, 0x30, 0x12, 0x00, 0x40, 0x3f,
- 0x12, 0x00, 0x20, 0x00};
-static unsigned char FLEX_BITS[] = {
- 0xff, 0x07, 0x00, 0x00, 0x08, 0x00, 0x00, 0x10,
- 0x00, 0x00, 0x04, 0x00, 0x00, 0x08};
-static unsigned char GRASS_BITS[] = {
- 0x01, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00,
- 0x00, 0x08, 0x05, 0x00, 0x00, 0x00, 0x04, 0x09,
- 0x00, 0x00, 0x00, 0x02, 0x01, 0x00, 0x00, 0x00,
- 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x15, 0x00,
- 0x00, 0x00, 0x80, 0x24, 0x00, 0x00, 0x00, 0x00,
- 0x04, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00,
-static unsigned char GRATE_BITS[] = {
- 0xff, 0xff, 0x07, 0x01, 0x00, 0x00, 0x01, 0x00,
- 0x00, 0x01, 0x00, 0x00, 0x01, 0x00, 0x00};
-static unsigned char HEX_BITS[] = {
- 0x7f, 0x00, 0xfc, 0x00, 0x00, 0x80, 0x00, 0x00,
- 0x00, 0x04, 0x80, 0x00, 0x00, 0x00, 0x04, 0x00,
- 0x01, 0x00, 0x00, 0x02, 0x00, 0x01, 0x00, 0x00,
- 0x02, 0x00, 0x02, 0x00, 0x00, 0x01, 0x00, 0x01,
- 0x00, 0x00, 0x02, 0x00, 0x01, 0x00, 0x00, 0x02,
- 0x80, 0x00, 0x00, 0x00, 0x04, 0x80, 0x00, 0x00,
- 0x00, 0x04, 0x7f, 0x00, 0xfc, 0x00, 0x00, 0x00,
- 0x00, 0x02, 0x01, 0x00, 0x00, 0x00, 0x02, 0x01,
- 0x00, 0x00, 0x00, 0x01, 0x02, 0x00, 0x00, 0x00,
- 0x01, 0x02, 0x00, 0x00, 0x80, 0x00, 0x04, 0x00,
- 0x00, 0x00, 0x01, 0x02, 0x00, 0x00, 0x00, 0x01,
- 0x02, 0x00, 0x00, 0x00, 0x02, 0x01, 0x00, 0x00,
- 0x00, 0x02, 0x01, 0x00};
-static unsigned char HONEY_BITS[] = {
- 0x7f, 0x00, 0x00, 0x80, 0x00, 0x02, 0x80, 0x00,
- 0x02, 0x00, 0x01, 0x01, 0x00, 0x01, 0x01, 0x00,
- 0xfe, 0x00, 0x00, 0x01, 0x01, 0x00, 0x01, 0x01,
- 0x80, 0x00, 0x02, 0x80, 0x00, 0x02};
-static unsigned char HOUND_BITS[] = {
- 0xff, 0xff, 0xff, 0xff, 0x3f, 0x10, 0x04, 0x80,
- 0x20, 0x08, 0x04, 0x01, 0x00, 0x08, 0x02, 0x41,
- 0x00, 0x00, 0x82, 0x40, 0x10, 0x00, 0x80, 0x20,
- 0x10, 0x04, 0x00, 0x20, 0x08, 0x04, 0x01, 0x00,
- 0x08, 0x02, 0x41, 0x00, 0x00, 0x82, 0x40, 0x10,
- 0x00, 0x80, 0x20, 0x10, 0x04, 0x00, 0x20, 0x08,
- 0x04, 0x01, 0x00, 0x08, 0x02, 0x41, 0x00, 0x00,
- 0x82, 0x40, 0x10, 0x00, 0x80, 0x20, 0x10, 0x04,
- 0x00, 0x20, 0x08, 0x04, 0x01, 0x00, 0x08, 0x02,
- 0x41, 0x00, 0x00, 0x82, 0x40, 0x10, 0x00, 0x80,
- 0x20, 0x10, 0x04, 0x00, 0x20, 0x08, 0x04, 0x01,
- 0x00, 0x08, 0x02, 0x41, 0x00, 0x00, 0x82, 0x40,
- 0x10, 0x00, 0x80, 0x20, 0x10, 0x04, 0x00, 0x20,
- 0x08, 0x04, 0x01, 0x00, 0x08, 0xfe, 0xff, 0xff,
- 0xff, 0xff, 0x20, 0x08, 0x04, 0x01, 0x00, 0x08,
- 0x02, 0x41, 0x00, 0x00, 0x82, 0x40, 0x10, 0x00,
- 0x80, 0x20, 0x10, 0x04, 0x00, 0x20, 0x08, 0x04,
- 0x01, 0x00, 0x08, 0x02, 0x41, 0x00, 0x00, 0x82,
- 0x40, 0x10, 0x00, 0x80, 0x20, 0x10, 0x04, 0x00,
- 0x00, 0x08, 0x02, 0x41, 0x00, 0xf8, 0xff, 0xff,
- 0xff, 0xff, 0x01, 0x00, 0x08, 0x02, 0x41, 0x00,
- 0x00, 0x82, 0x40, 0x10, 0x00, 0x80, 0x20, 0x10,
- 0x04, 0x00, 0x20, 0x08, 0x04, 0x01, 0x00, 0x08,
- 0x04, 0xff, 0xff, 0xff, 0x03, 0x41, 0x00, 0x00,
- 0x82, 0x40, 0xf0, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0x01, 0x00, 0x08, 0x02,
- 0x08, 0x04, 0x01, 0x00, 0x08, 0x02, 0x41, 0x00,
- 0x20, 0x08, 0x04, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0x0f, 0x82, 0x40, 0x10, 0x04, 0x80, 0xe0,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x41, 0x00,
- 0x00, 0x02, 0x41, 0x10, 0x00, 0x80, 0x40, 0x10,
- 0x04, 0x00, 0x20, 0x10, 0x04, 0x01, 0x00, 0x08,
- 0x04, 0x41, 0x00, 0x00, 0x02, 0x41, 0x10, 0x00,
- 0x80, 0x40, 0x10, 0x04, 0x00, 0x20, 0x10, 0x04,
- 0x01, 0x00, 0x08, 0x04, 0x41, 0x00, 0x00, 0x02,
- 0x41, 0x10, 0x00, 0x80, 0x40, 0x10, 0x04, 0x00,
- 0x20, 0x10, 0x04, 0x01, 0x00, 0x08, 0x04, 0x41,
- 0x00, 0x00, 0x02, 0x41, 0x10, 0x00, 0x80, 0x40,
- 0x10, 0x04, 0x00, 0x20, 0x10, 0x04, 0x01, 0x00,
- 0x08, 0x04, 0x41, 0x00, 0x00, 0x02, 0x41, 0x10,
- 0x00, 0x80, 0x40, 0x10, 0x04, 0x00, 0x20, 0x10,
- 0x04, 0x01, 0x00, 0x08, 0x04, 0x41, 0x00, 0x00,
- 0x02, 0x41, 0x10, 0x00, 0x80, 0x40, 0x10, 0x04,
- 0x00, 0x20, 0x10, 0x04, 0x01, 0x00, 0x08, 0x04,
- 0xff, 0x1f, 0x04, 0x00, 0x20, 0x10, 0x04, 0x81,
- 0xff, 0xff, 0xff, 0x41, 0x00, 0x00, 0x02, 0x41,
- 0x10, 0x00, 0x80, 0x40, 0x10, 0x04, 0x00, 0x20,
- 0x10, 0x04, 0x01, 0x00, 0x08, 0x04, 0x41, 0x00,
- 0x08, 0x04, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x3f, 0x10,
- 0x41, 0x00, 0x00, 0x02, 0x41, 0x10, 0x00, 0x80,
- 0x40, 0x10, 0x04, 0x00, 0x20, 0x10, 0x04, 0x01,
- 0x00, 0x08, 0x04, 0x41, 0x00, 0x00, 0x02, 0x41,
- 0x01, 0x00, 0x08, 0x04, 0x41, 0x00, 0x00, 0xfe,
- 0xff, 0xff, 0xff, 0xff, 0x00, 0x08, 0x04, 0x41,
- 0x04, 0x41, 0x20, 0x00, 0x02, 0x41, 0x10, 0xf8,
- 0xff, 0xff, 0xff, 0xff, 0x41, 0x20, 0x00, 0x00,
- 0x41, 0x10, 0x08, 0x00, 0x40, 0x10, 0x04, 0x02,
- 0x00, 0x10, 0x04, 0x81, 0x00, 0x00, 0x04, 0x41,
- 0x20, 0x00, 0x00, 0x41, 0x10, 0x08, 0x00, 0x40,
- 0x10, 0x04, 0x02, 0x00, 0x10, 0x04, 0x81, 0x00,
- 0x00, 0x04, 0x41, 0x20, 0x00, 0x00, 0x41, 0x10,
- 0x08, 0x00, 0x40, 0x10, 0x04, 0x02, 0x00, 0x10,
- 0x04, 0x81, 0x00, 0x00, 0x04, 0x41, 0x20, 0x00,
- 0x00, 0x41, 0x10, 0x08, 0x00, 0x40, 0x10, 0x04,
- 0x02, 0x00, 0x10, 0x04, 0x81, 0x00, 0x00, 0x04,
- 0x41, 0x20, 0x00, 0x00, 0x41, 0x10, 0x08, 0x00,
- 0x40, 0x10, 0x04, 0x02, 0x00, 0x10, 0x04, 0x81,
- 0x00, 0x00, 0x04, 0xff, 0xff, 0xff, 0x03, 0x41,
- 0x10, 0x08, 0x00, 0x40, 0xf0, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x41, 0x20,
- 0x00, 0x00, 0x41, 0x10, 0x08, 0x00, 0x40, 0x10,
- 0x04, 0x02, 0x00, 0x10, 0x04, 0x81, 0x00, 0x00,
- 0x04, 0x41, 0x20, 0x00, 0x00, 0x41, 0x10, 0x08,
- 0x00, 0x40, 0x10, 0x04, 0x02, 0x00, 0x10, 0x04,
- 0x81, 0x00, 0x00, 0x04, 0x41, 0x20, 0x00, 0x00,
- 0x04, 0x81, 0x00, 0x00, 0x04, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0x0f, 0x00, 0x40, 0x10, 0x04,
- 0x02, 0xe0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0x00, 0x00, 0x04, 0x41, 0x20, 0x00, 0x00, 0x41,
- 0x10, 0x08, 0x00, 0x40, 0x10, 0x04, 0x02, 0x00,
- 0x10, 0x04, 0x81, 0x00, 0x00, 0x04, 0x41, 0x20,
- 0x00, 0x04, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0x1f, 0x04, 0x02, 0x00, 0x10,
- 0x04, 0x81, 0xff, 0xff, 0xff, 0x41, 0x20, 0x00,
- 0x81, 0x00, 0x00, 0x04, 0xff, 0xff, 0xff, 0xff,
- 0x3f, 0x10, 0x04, 0x81, 0x20, 0x00, 0x04, 0x41,
- 0x20, 0x08, 0x00, 0x40, 0x10, 0x08, 0x02, 0x00,
- 0x10, 0x04, 0x82, 0x00, 0x00, 0x04, 0x81, 0x20,
- 0x00, 0x00, 0x41, 0x20, 0x08, 0x00, 0x40, 0x10,
- 0x08, 0x02, 0x00, 0x10, 0x04, 0x82, 0x00, 0x00,
- 0x04, 0x81, 0x20, 0x00, 0x00, 0x41, 0x20, 0x08,
- 0x00, 0x40, 0x10, 0x08, 0x02, 0x00, 0x10, 0x04,
- 0x82, 0x00, 0x00, 0x04, 0x81, 0x20, 0x00, 0x00,
- 0x41, 0x20, 0x08, 0x00, 0x40, 0x10, 0x08, 0x02,
- 0x00, 0x10, 0x04, 0x82, 0x00, 0x00, 0x04, 0x81,
- 0x20, 0x00, 0x00, 0x41, 0x20, 0x08, 0x00, 0x40,
- 0x10, 0x08, 0x02, 0x00, 0x10, 0x04, 0x82, 0x00,
- 0x00, 0x04, 0x81, 0x20, 0x00, 0x00, 0x41, 0x20,
- 0x08, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x20, 0x00,
- 0x00, 0x41, 0x20, 0x08, 0x00, 0x40, 0x10, 0x08,
- 0x02, 0x00, 0x10, 0x04, 0x82, 0x00, 0x00, 0x04,
- 0x81, 0x20, 0x00, 0x00, 0x41, 0x20, 0x08, 0x00,
- 0x40, 0x10, 0x08, 0x02, 0x00, 0x10, 0x04, 0x82,
- 0x00, 0x00, 0x04, 0x81, 0x20, 0x00, 0x00, 0x41,
- 0x10, 0xf8, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0x08, 0x00, 0x40, 0x10, 0x08, 0x02, 0x00, 0x10,
- 0x04, 0x82, 0x00, 0x00, 0x04, 0x81, 0x20, 0x00,
- 0x04, 0x81, 0x20, 0x00, 0x00, 0xff, 0xff, 0xff,
- 0x03, 0x40, 0x10, 0x08, 0x02, 0x00, 0xf0, 0xff,
- 0x00, 0x00, 0x04, 0x81, 0x20, 0x00, 0x00, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0x82, 0x00,
- 0x10, 0x04, 0x82, 0xe0, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0x40, 0x20, 0x08, 0x02, 0x00, 0x10,
- 0x08, 0x82, 0x00, 0x00, 0x04, 0x82, 0x20, 0x00,
- 0x00, 0x81, 0x20, 0x08, 0x00, 0x40, 0x20, 0x08,
- 0x02, 0x00, 0x10, 0x08, 0x82, 0x00, 0x00, 0x04,
- 0x82, 0x20, 0x00, 0x00, 0x81, 0x20, 0x08, 0x00,
- 0x40, 0x20, 0x08, 0x02, 0x00, 0x10, 0x08, 0x82,
- 0x00, 0x00, 0x04, 0x82, 0x20, 0x00, 0x00, 0x81,
- 0x20, 0x08, 0x00, 0x40, 0x20, 0x08, 0x02, 0x00,
- 0x10, 0x08, 0x82, 0x00, 0x00, 0x04, 0x82, 0x20,
- 0x00, 0x00, 0x81, 0x20, 0x08, 0x00, 0x40, 0x20,
- 0x08, 0x02, 0x00, 0x10, 0x08, 0x82, 0x00, 0x00,
- 0x04, 0x82, 0x20, 0x00, 0x00, 0x81, 0x20, 0x08,
- 0x00, 0x40, 0x20, 0x08, 0x02, 0x00, 0x10, 0x08,
- 0x82, 0x00, 0x00, 0x04, 0x82, 0x20, 0x00, 0x00,
- 0x81, 0x20, 0x08, 0x00, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0x1f, 0x04, 0x82,
- 0x20, 0x00, 0x00, 0x81, 0xff, 0xff, 0xff, 0x40,
- 0x20, 0x08, 0x02, 0x00, 0x10, 0x08, 0x82, 0x00,
- 0x00, 0x04, 0x82, 0x20, 0x00, 0x00, 0x81, 0x20,
- 0x08, 0x00, 0x40, 0x20, 0x08, 0x02, 0x00, 0x10,
- 0x00, 0x00, 0x81, 0x20, 0x08, 0x00, 0xff, 0xff,
- 0xff, 0xff, 0x3f, 0x00, 0x00, 0x81, 0x20, 0x08,
- 0x81, 0x20, 0x08, 0x00, 0x40, 0x20, 0x08, 0x02,
- 0x00, 0x10, 0x08, 0x82, 0x00, 0x00, 0x04, 0x82,
- 0x20, 0x00, 0x00, 0x81, 0x20, 0x08, 0x00, 0x40,
- 0x40, 0x20, 0x08, 0xfe, 0xff, 0xff, 0xff, 0xff,
- 0x00, 0x81, 0x20, 0x08, 0x00, 0x41, 0x20, 0x08,
- 0x02, 0x01, 0x10, 0xf8, 0xff, 0xff, 0xff, 0xff,
- 0x00, 0x20, 0x08, 0x02, 0x01, 0x00, 0x08, 0x82,
- 0x40, 0x00, 0x00, 0x82, 0x20, 0x10, 0x00, 0x80,
- 0x20, 0x08, 0x04, 0x00, 0x20, 0x08, 0x02, 0x01,
- 0x00, 0x08, 0x82, 0x40, 0x00, 0x00, 0x82, 0x20,
- 0x10, 0x00, 0x80, 0x20, 0x08, 0x04, 0x00, 0x20,
- 0x08, 0x02, 0x01, 0x00, 0x08, 0x82, 0x40, 0x00,
- 0x00, 0x82, 0x20, 0x10, 0x00, 0x80, 0x20, 0x08,
- 0x04, 0x00, 0x20, 0x08, 0x02, 0x01, 0x00, 0x08,
- 0x82, 0x40, 0x00, 0x00, 0x82, 0x20, 0x10, 0x00,
- 0x80, 0x20, 0x08, 0x04, 0x00, 0x20, 0x08, 0x02,
- 0x01, 0x00, 0x08, 0x82, 0x40, 0x00, 0x00, 0x82,
- 0x20, 0x10, 0x00, 0x80, 0x20, 0x08, 0x04, 0xff,
- 0xff, 0xff, 0x03, 0x01, 0x00, 0x08, 0x82, 0x40,
- 0xf0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0x00, 0x20, 0x08, 0x02, 0x01, 0x00,
- 0x08, 0x82, 0x40, 0x00, 0x00, 0x82, 0x20, 0x10,
- 0x00, 0x80, 0x20, 0x08, 0x04, 0x00, 0x20, 0x08,
- 0x02, 0x01, 0x00, 0x08, 0x82, 0x40, 0x00, 0x00,
- 0x82, 0x20, 0x10, 0x00, 0x80, 0x20, 0x08, 0x04,
- 0x04, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f,
- 0x82, 0x40, 0x00, 0x00, 0x82, 0xe0, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0x00, 0x20, 0x08, 0x02,
- 0x20, 0x10, 0x00, 0x80, 0x20, 0x08, 0x04, 0x00,
- 0x20, 0x08, 0x02, 0x01, 0x00, 0x08, 0x82, 0x40,
- 0x00, 0x00, 0x82, 0x20, 0x10, 0x00, 0x80, 0x20,
- 0x08, 0x04, 0x00, 0x20, 0x08, 0x02, 0x01, 0x00,
- 0x10, 0x00, 0x80, 0x20, 0x08, 0x04, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x1f,
- 0x00, 0x82, 0x20, 0x10, 0x00, 0x80, 0xff, 0xff,
- 0xff, 0x00, 0x20, 0x08, 0x02, 0x01, 0x00, 0x08,
- 0x82, 0x20, 0x10, 0x00, 0x80, 0x20, 0x08, 0x04};
-static unsigned char INSUL_BITS[] = {
- 0xff, 0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00,
- 0x1f, 0x00, 0x00, 0x00};
-static unsigned char MUDST_BITS[] = {
- 0xff, 0x01, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00,
- 0x01, 0x01, 0xff, 0x01, 0x00, 0x00, 0x00, 0x00,
-static unsigned char NET3_BITS[] = {
- 0xff, 0x03, 0x02, 0x02, 0x04, 0x01, 0x04, 0x01,
- 0x88, 0x00, 0x88, 0x00, 0x50, 0x00, 0x20, 0x00,
- 0xff, 0x03, 0x50, 0x00, 0x88, 0x00, 0x88, 0x00,
- 0x04, 0x01, 0x04, 0x01, 0x02, 0x02, 0x01, 0x00};
-static unsigned char PLAST_BITS[] = {
- 0xff, 0xff, 0x00, 0x00, 0xff, 0xff, 0x00, 0x00,
- 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
-static unsigned char PLASTI_BITS[] = {
- 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0x00, 0x00,
-static unsigned char SACNCR_BITS[] = {
- 0x21, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08, 0x00,
- 0x10, 0x00, 0x21, 0x00, 0x40, 0x00, 0x80, 0x00,
- 0x00, 0x01, 0x00, 0x02};
-static unsigned char SQUARE_BITS[] = {
- 0x00, 0x00, 0x00, 0x00, 0xF0, 0x90, 0x90, 0xF0};
-static unsigned char STARS_BITS[] = {
- 0x7f, 0xf0, 0x07, 0x02, 0x00, 0x02, 0x02, 0x00,
- 0x02, 0x04, 0x00, 0x01, 0x04, 0x00, 0x01, 0x08,
- 0x80, 0x00, 0x08, 0x00, 0x01, 0x04, 0x00, 0x01,
- 0x04, 0x00, 0x02, 0x02, 0x00, 0x02, 0x02, 0x00,
- 0x04, 0x7f, 0xf0, 0x07, 0x80, 0x08, 0x00, 0x80,
- 0x08, 0x00, 0x00, 0x05, 0x00, 0x00, 0x05, 0x00,
- 0x00, 0x02, 0x20, 0x00, 0x00, 0x50, 0x00, 0x00,
- 0x50, 0x00, 0x00, 0x88, 0x00, 0x00, 0x88, 0x7f,
- 0xf0, 0x07, 0x20, 0x20, 0x00, 0x20, 0x20, 0x00,
- 0x10, 0x40, 0x00, 0x10, 0x40, 0x00, 0x08, 0x80,
- 0x00, 0x10, 0x80, 0x00, 0x10, 0x40, 0x00, 0x20,
- 0x40, 0x00, 0x20, 0x20, 0x00, 0x40, 0x20, 0x00,
- 0x7f, 0xf0, 0x07, 0x00, 0x00, 0x88, 0x00, 0x00,
- 0x88, 0x00, 0x00, 0x50, 0x00, 0x00, 0x50, 0x00,
- 0x02, 0x20, 0x00, 0x05, 0x00, 0x00, 0x05, 0x00,
- 0x80, 0x08, 0x00, 0x80, 0x08, 0x00};
-static unsigned char STEEL_BITS[] = {
- 0x01, 0x02, 0x02, 0x04, 0x04, 0x08, 0x08, 0x10,
- 0x10, 0x20, 0x21, 0x00, 0x42, 0x00, 0x84, 0x00,
- 0x08, 0x01, 0x10, 0x02, 0x20, 0x04, 0x40, 0x08,
- 0x80, 0x10, 0x00, 0x21};
-static unsigned char SWAMP_BITS[] = {
- 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x7c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0xba, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0xe0, 0x1f, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x80, 0x0f, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x40, 0x17, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00,
-static unsigned char TRANS_BITS[] = {
- 0xff, 0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00};
-static unsigned char TRIANG_BITS[] = {
- 0x01, 0x00, 0x00, 0x02, 0x00, 0x08, 0x02, 0x00,
- 0x08, 0x04, 0x00, 0x04, 0x04, 0x00, 0x04, 0x08,
- 0x00, 0x02, 0x08, 0x00, 0x02, 0x10, 0x00, 0x01,
- 0x10, 0x00, 0x01, 0x3f, 0x80, 0x0f, 0x00, 0x00,
- 0x00, 0x00, 0x0a, 0x00, 0x00, 0x0a, 0x00, 0x00,
- 0x11, 0x00, 0x00, 0x11, 0x00, 0x80, 0x20, 0x00,
- 0x80, 0x20, 0x00, 0x40, 0x40, 0x00, 0x40, 0x40,
- 0x00, 0xe0, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00,
-static unsigned char ZIGZAG_BITS[] = {
- 0xff, 0x01, 0x00, 0x01, 0x00, 0x01, 0x00, 0x01,
- 0x00, 0x01, 0x00, 0x01, 0x00, 0x01, 0x00, 0x01,
- 0x01, 0xff, 0x01, 0x00, 0x01, 0x00, 0x01, 0x00,
- 0x01, 0x00, 0x01, 0x00, 0x01, 0x00, 0x01, 0x00};
-static unsigned char AR_B816_BITS[] = {
- 0xff, 0xff, 0x0f, 0x01, 0x00, 0x00, 0x01, 0x00,
- 0x01, 0x00, 0x00, 0x01, 0x00, 0x00, 0xff, 0xff,
- 0x0f, 0x00, 0x04, 0x00, 0x00, 0x04, 0x00, 0x00,
- 0x04, 0x00, 0x00, 0x04, 0x00, 0x00, 0x04, 0x00,
- 0x00, 0x04, 0x00, 0x00, 0x04, 0x00, 0x00, 0x04,
- 0x00, 0x00, 0x04, 0x00};
-static unsigned char AR_B816C_BITS[] = {
- 0xff, 0xff, 0x0f, 0x00, 0x04, 0x00, 0x00, 0x04,
- 0x00, 0x00, 0x04, 0x00, 0x00, 0x04, 0x00, 0x00,
- 0x00, 0x04, 0x00, 0x00, 0x04, 0x00, 0xff, 0xff,
- 0x0f, 0x01, 0x00, 0x00, 0x01, 0x00, 0x00, 0x01,
- 0x01, 0x00, 0x00, 0x01, 0x00, 0x00, 0x01, 0x00,
- 0x00, 0x01, 0x00, 0x00};
-static unsigned char AR_B88_BITS[] = {
- 0xff, 0x03, 0x01, 0x00, 0x01, 0x00, 0x01, 0x00,
- 0x01, 0x00, 0x01, 0x00, 0xff, 0x03, 0x20, 0x00,
- 0x20, 0x00, 0x20, 0x00, 0x20, 0x00, 0x20, 0x00,
- 0x20, 0x00, 0x20, 0x00, 0x20, 0x00, 0x20, 0x00};
-static unsigned char AR_BRELM_BITS[] = {
- 0xff, 0xff, 0xff, 0xff, 0x07, 0x01, 0x00, 0x00,
- 0x00, 0x04, 0x01, 0x00, 0x00, 0x00, 0x04, 0x01,
- 0x00, 0x00, 0x00, 0x04, 0x01, 0x00, 0x00, 0x00,
- 0x04, 0x01, 0x00, 0x00, 0x00, 0x04, 0x01, 0x00,
- 0x00, 0x00, 0x04, 0x01, 0x00, 0x00, 0x00, 0x04,
- 0x01, 0x00, 0x00, 0x00, 0x04, 0x01, 0x00, 0x00,
- 0x00, 0x04, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0xff, 0xfe, 0xff, 0xfb,
- 0x0f, 0x80, 0x02, 0x00, 0x0a, 0x00, 0x80, 0x02,
- 0x00, 0x0a, 0x00, 0x80, 0x02, 0x00, 0x0a, 0x00,
- 0x80, 0x02, 0x00, 0x0a, 0x00, 0x80, 0x02, 0x00,
- 0x0a, 0x00, 0x80, 0x02, 0x00, 0x0a, 0x00, 0x80,
- 0x02, 0x00, 0x0a, 0x00, 0x80, 0x02, 0x00, 0x0a,
- 0x00, 0x80, 0x02, 0x00, 0x0a, 0x00, 0xff, 0xfe,
- 0xff, 0xfb, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00};
-static unsigned char AR_BRSTD_BITS[] = {
- 0xff, 0xff, 0xff, 0xff, 0x0f, 0x01, 0x00, 0x00,
- 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x01,
- 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00,
- 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00,
- 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00,
- 0x01, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff,
- 0x0f, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x04,
- 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00,
- 0x04, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00};
-static unsigned char AR_CONC_BITS[] = {
- 0x03, 0x00, 0x80, 0x05, 0x10, 0x00, 0x00, 0x0a,
- 0x08, 0x0a, 0x00, 0x03, 0x12, 0x00, 0x00, 0x00,
- 0x4c, 0x00, 0x00, 0x00, 0x2c, 0x00, 0x00, 0x00,
- 0x0e, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x07, 0x00, 0x00, 0x10, 0x00, 0x00, 0x08, 0x00,
- 0x00, 0x00, 0x08, 0x00, 0x28, 0x00, 0x00, 0x00,
- 0x01, 0x00, 0x00, 0x00, 0x01, 0x00, 0x48, 0x02,
- 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x90, 0x04,
- 0x40, 0x10, 0x40, 0x00, 0x00, 0xa0, 0x60, 0x08,
- 0x00, 0x40, 0xd0, 0x00, 0x08, 0x00, 0x00, 0x90,
- 0x00, 0x08, 0xa0, 0x00, 0x00, 0x90, 0x00, 0xe4,
- 0x00, 0x00, 0x00, 0x20, 0x08, 0xa0, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x90, 0x04, 0xe0, 0x00, 0x00,
- 0x00, 0x90, 0x00, 0x60, 0x00, 0x48, 0x00, 0x00,
- 0x02, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04,
- 0x80, 0x30, 0x00, 0x00, 0x00, 0x02, 0x00, 0x82,
- 0x40, 0x00, 0x00, 0x00, 0x40, 0x02, 0x00, 0x00,
- 0x00, 0x11, 0x10, 0x01, 0x80, 0x21, 0x00, 0x02,
- 0x40, 0x02, 0x30, 0x00, 0x02, 0x00, 0x00, 0x00,
- 0x80, 0x03, 0x00, 0x00, 0x0a, 0x80, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x08, 0x89, 0x10, 0x00,
- 0x02, 0x00, 0x01, 0x10, 0x00, 0xd0, 0x00, 0x00,
- 0x10, 0x00, 0x00, 0x00, 0x00, 0x60, 0x02, 0x14,
- 0x00, 0x10, 0x80, 0x00, 0x00, 0x00, 0x00, 0x90,
- 0x00, 0x00, 0x88, 0x08, 0x00, 0x00, 0x00, 0x0e,
- 0x00, 0x18, 0xf0, 0x13, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x04, 0x0c, 0x08, 0x00, 0x00, 0x12,
- 0x00, 0x00, 0x00, 0x05, 0x00, 0x12, 0x00, 0x1c,
- 0x00, 0x00, 0x00, 0x10, 0x00, 0x94, 0x00, 0x00,
- 0x02, 0x00, 0x00, 0x12, 0x40, 0x4d, 0x00, 0x04,
- 0x40, 0x1a, 0x00, 0x0c, 0x00, 0x00, 0x80, 0x00,
- 0x00, 0x0c, 0x00, 0x00, 0x00, 0x40, 0x00, 0x01,
- 0x10, 0x00, 0x08, 0x01, 0x01, 0x90, 0x08, 0x00,
- 0x00, 0x41, 0x10, 0x00, 0x00, 0x70, 0x00, 0x00,
- 0x00, 0x50, 0x04, 0x01, 0x11, 0x00, 0x00, 0x00,
- 0x00, 0x20, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00,
- 0x02, 0x00, 0x00, 0x00, 0x01, 0x20, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x08,
- 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x24,
- 0x02, 0x00, 0x00, 0x01, 0x02, 0x00, 0x20, 0x80,
- 0x00, 0x04, 0x00, 0x20, 0x12, 0x02, 0x00, 0x00,
- 0x21, 0x00, 0x02, 0x80, 0x03, 0x00, 0x00, 0x00,
- 0x82, 0x00, 0x00, 0x41, 0x00, 0x80, 0x42, 0x22,
- 0x05, 0x00, 0x00, 0x02, 0x60, 0x02, 0x80, 0x0b,
- 0x02, 0x20, 0x10, 0x02, 0x80, 0x11, 0x00, 0x00,
- 0x00, 0x00, 0x40, 0x02, 0x80, 0x11, 0x10, 0x00,
- 0x40, 0x01, 0x80, 0x03, 0x00, 0x1e, 0x10, 0x04,
- 0x84, 0x01, 0x00, 0x00, 0x02, 0x00, 0x10, 0x00,
- 0x80, 0x00, 0x19, 0x00, 0x10, 0x00, 0x12, 0x00,
- 0x00, 0x00, 0x13, 0x00, 0x00, 0x40, 0x0d, 0x00,
- 0x04, 0x00, 0x1e, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x40, 0x10, 0x00, 0x00, 0x08,
- 0x00, 0x28, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x02, 0x00, 0x02, 0x20, 0x04,
- 0x00, 0x00, 0x02, 0x21, 0x60, 0x00, 0x00, 0x00,
- 0xa0, 0x20, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00,
- 0x40, 0x00, 0x00, 0x00, 0xd0, 0x00, 0x01, 0x00,
- 0x44, 0x00, 0x40, 0x00, 0x60, 0x00, 0x00, 0x10,
- 0x70, 0x40, 0x08, 0x00, 0x10, 0x00, 0x48, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x48, 0x02, 0x30, 0x00,
- 0x00, 0x00, 0x20, 0x02, 0x30, 0x00, 0x04, 0x00};
-static unsigned char AR_HBONE_BITS[] = {
- 0x01, 0x10, 0x00, 0x02, 0x20, 0x80, 0x04, 0x40,
- 0x40, 0x08, 0x80, 0x20, 0x10, 0x00, 0x11, 0x20,
- 0x00, 0x0a, 0x40, 0x00, 0x04, 0xa0, 0x00, 0x02,
- 0x10, 0x01, 0x01, 0x08, 0x82, 0x00, 0x04, 0x44,
- 0x00, 0x02, 0x28, 0x00};
-static unsigned char AR_PARQ1_BITS[] = {
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f,
- 0x21, 0x84, 0x10, 0x42, 0x00, 0x00, 0x00, 0x00,
- 0x21, 0x84, 0x10, 0xc2, 0xff, 0xff, 0xff, 0x0f,
- 0x01, 0x00, 0x00, 0x40, 0x08, 0x21, 0x84, 0x00,
- 0xff, 0xff, 0xff, 0x7f, 0x08, 0x21, 0x84, 0x00,
- 0x01, 0x00, 0x00, 0x40, 0x08, 0x21, 0x84, 0x00};
-static unsigned char AR_RROOF_BITS[] = {
- 0x00, 0x00, 0xe0, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0x00, 0xf8,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0x3f, 0x00, 0xfe,
- 0xff, 0xff, 0xff, 0x7f, 0x00, 0x80, 0xff, 0xff,
- 0xff, 0x00, 0xfe, 0xff, 0xff, 0xff, 0x7f, 0xfc,
- 0x3f, 0x80, 0xff, 0xff, 0xff, 0xff, 0x1f, 0xfe,
- 0x1f, 0xe0, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0xc0, 0xff, 0xff, 0xff,
- 0xff, 0x07, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0x7f, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff,
- 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0x00, 0xf0,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00,
- 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0xfe, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0x0f, 0x80, 0xff, 0xff, 0xff,
- 0xff, 0x1f, 0x00, 0xe0, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff,
- 0x00, 0x00, 0x00, 0x00, 0xf0, 0xff, 0xff, 0xff,
- 0xff, 0xc7, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0x03, 0xfc, 0xff, 0xff, 0xff,
- 0xff, 0xf1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0x00, 0xfe, 0xff, 0xff, 0xff,
- 0xff, 0x0f, 0x80, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0x0f, 0x00, 0x00, 0xf0, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0x01, 0x00, 0xfc, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0x1f, 0x00, 0xff, 0xff, 0xff,
- 0xff, 0x3f, 0x00, 0xc0, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0x03, 0xe0, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03,
- 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff, 0xff, 0x3f,
- 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0x7f, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0xff, 0xff, 0xff, 0x3f, 0xfe, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0x1f, 0xc0, 0xff,
- 0xff, 0xff, 0xff, 0x0f, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xf0, 0xff,
- 0xff, 0xff, 0xff, 0xc7, 0x00, 0x00, 0x00, 0x00,
- 0x7f, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0x07, 0xc0, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0x00, 0xf0, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
- 0x00, 0xf8, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00,
- 0xff, 0x07, 0x00, 0x00, 0xf8, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0x07, 0xc0, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0xfe,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0x00, 0xff,
- 0xff, 0xff, 0xff, 0x1f, 0x00, 0xe0, 0xff, 0xff,
- 0xff, 0xff, 0xe3, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0x01, 0xfe, 0xff, 0xff,
- 0xff, 0xff, 0xf8, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0x7f, 0x00, 0xff, 0xff, 0xff,
- 0xff, 0x3f, 0xfe, 0xff, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0x01,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0x01, 0x00, 0xfc,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0x1f, 0x00, 0xfe,
- 0x7f, 0x00, 0x00, 0x80, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0x3f, 0x00, 0xfc, 0xff, 0xff,
- 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0x3f, 0x00,
- 0x80, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03,
- 0xe0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0xf8,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0x3f, 0x00, 0xfc,
- 0x00, 0x00, 0x00, 0x00, 0x1f, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xe0,
- 0xff, 0xff, 0xff, 0xff, 0xc7, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0xf8,
- 0xff, 0xff, 0xff, 0xff, 0xe3, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0x03, 0x00, 0x00, 0xfc,
- 0xff, 0xff, 0x7f, 0x00, 0x00, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0x07, 0x80, 0xff, 0xff, 0xff,
- 0xff, 0x0f, 0x00, 0xf0, 0x00, 0x00, 0x00, 0x00,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0xf8, 0xff,
- 0xff, 0xff, 0xff, 0x01, 0x00, 0xfe, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0x0f, 0x00, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0x3f, 0x00, 0x00, 0xc0, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x1f, 0x00,
- 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0x00, 0xff, 0xff, 0xff, 0xff, 0x7f, 0xfc,
- 0x3f, 0xc0, 0xff, 0xff, 0xff, 0xff, 0x1f, 0xff,
- 0x1f, 0x00, 0xc0, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0x01, 0xf0, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff, 0xff, 0x1f,
-static unsigned char AR_RROOF_90_BITS[] = {
- 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x05, 0x92,
- 0x02, 0x28, 0x00, 0x44, 0x04, 0x41, 0xa4, 0x80,
- 0x8a, 0x40, 0x11, 0x05, 0x92, 0x02, 0x28, 0x00,
- 0x44, 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x11,
- 0x05, 0x92, 0x02, 0x28, 0x00, 0x44, 0x04, 0x41,
- 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x05, 0x92, 0x02,
- 0x28, 0x00, 0x44, 0x04, 0x41, 0xa4, 0x80, 0x8a,
- 0x40, 0x11, 0x05, 0x92, 0x02, 0x28, 0x00, 0x04,
- 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x05,
- 0x92, 0x02, 0x28, 0x00, 0x04, 0x04, 0x41, 0xa4,
- 0x80, 0x8a, 0x40, 0x11, 0x05, 0x92, 0x02, 0x28,
- 0x00, 0x04, 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x40,
- 0x11, 0x05, 0x92, 0x02, 0x28, 0x00, 0x44, 0x04,
- 0x28, 0x04, 0x44, 0x04, 0x41, 0xa4, 0x80, 0x8a,
- 0x40, 0x11, 0x04, 0x92, 0x02, 0x28, 0x04, 0x44,
- 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x04,
- 0x92, 0x02, 0x28, 0x04, 0x44, 0x04, 0x41, 0xa4,
- 0x80, 0x8a, 0x40, 0x11, 0x04, 0x92, 0x02, 0x2a,
- 0x04, 0x44, 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x40,
- 0x11, 0x04, 0x90, 0x02, 0x2a, 0x04, 0x44, 0x04,
- 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x04, 0x90,
- 0x02, 0x2a, 0x04, 0x44, 0x04, 0x41, 0xa4, 0x80,
- 0x8a, 0x40, 0x11, 0x04, 0x90, 0x02, 0x2a, 0x04,
- 0x04, 0x90, 0x02, 0x2a, 0x04, 0x44, 0x04, 0x41,
- 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x04, 0x90, 0x02,
- 0x2a, 0x04, 0x44, 0x04, 0x41, 0xa4, 0x80, 0x8a,
- 0x40, 0x11, 0x04, 0x90, 0x02, 0x2a, 0x04, 0x45,
- 0x04, 0x41, 0xa0, 0x80, 0x8a, 0x40, 0x11, 0x04,
- 0x90, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x41, 0xa0,
- 0x80, 0x8a, 0x40, 0x11, 0x04, 0x90, 0x02, 0x2a,
- 0x04, 0x45, 0x04, 0x41, 0xa0, 0x80, 0x8a, 0x40,
- 0x11, 0x04, 0x90, 0x02, 0x2a, 0x04, 0x45, 0x04,
- 0x41, 0xa0, 0x80, 0x8a, 0x40, 0x11, 0x04, 0x90,
- 0x02, 0x22, 0x04, 0x45, 0x04, 0x41, 0xa0, 0x80,
- 0x8a, 0x40, 0x11, 0x04, 0x90, 0x02, 0x22, 0x04,
- 0x45, 0x04, 0x41, 0xa0, 0x80, 0x8a, 0x40, 0x11,
- 0x04, 0x92, 0x02, 0x22, 0x04, 0x45, 0x04, 0x41,
- 0xa0, 0x00, 0x8a, 0x40, 0x11, 0x04, 0x92, 0x02,
- 0x22, 0x04, 0x45, 0x04, 0x41, 0xa0, 0x00, 0x8a,
- 0x40, 0x11, 0x04, 0x92, 0x02, 0x22, 0x04, 0x45,
- 0x04, 0x41, 0xa4, 0x00, 0x8a, 0x40, 0x11, 0x05,
- 0x92, 0x02, 0x22, 0x04, 0x45, 0x04, 0x41, 0xa4,
- 0x00, 0x0a, 0x40, 0x11, 0x05, 0x92, 0x02, 0x22,
- 0x04, 0x45, 0x04, 0x41, 0xa4, 0x00, 0x0a, 0x40,
- 0x11, 0x05, 0x92, 0x02, 0x22, 0x04, 0x45, 0x04,
- 0x41, 0xa4, 0x00, 0x0a, 0x40, 0x11, 0x05, 0x92,
- 0x02, 0x22, 0x04, 0x45, 0x04, 0x41, 0xa4, 0x00,
- 0x02, 0x40, 0x11, 0x05, 0x92, 0x02, 0x22, 0x04,
- 0x45, 0x04, 0x41, 0xa4, 0x00, 0x02, 0x40, 0x11,
- 0x05, 0x92, 0x02, 0x22, 0x04, 0x45, 0x04, 0x41,
- 0xa4, 0x00, 0x02, 0x40, 0x11, 0x05, 0x92, 0x02,
- 0x22, 0x04, 0x45, 0x04, 0x41, 0xa4, 0x00, 0x02,
- 0x40, 0x11, 0x05, 0x92, 0x02, 0x22, 0x04, 0x45,
- 0x04, 0x41, 0xa4, 0x00, 0x02, 0x40, 0x11, 0x05,
- 0x00, 0x02, 0x40, 0x11, 0x05, 0x92, 0x02, 0x22,
- 0x04, 0x45, 0x04, 0x41, 0xa4, 0x00, 0x02, 0x40,
- 0x41, 0xa4, 0x00, 0x02, 0x40, 0x11, 0x05, 0x92,
- 0x82, 0x40, 0x11, 0x05, 0x92, 0x02, 0x22, 0x04,
- 0x45, 0x04, 0x41, 0xa4, 0x00, 0x8a, 0x40, 0x11,
- 0xa4, 0x00, 0x8a, 0x40, 0x11, 0x05, 0x92, 0x02,
- 0x22, 0x04, 0x45, 0x04, 0x41, 0xa4, 0x80, 0x8a,
- 0x04, 0x01, 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x05,
- 0x92, 0x02, 0x22, 0x04, 0x45, 0x04, 0x01, 0xa4,
- 0x80, 0x8a, 0x40, 0x01, 0x05, 0x92, 0x02, 0x22,
- 0x04, 0x45, 0x04, 0x01, 0xa4, 0x80, 0x8a, 0x40,
- 0x01, 0x05, 0x92, 0x02, 0x22, 0x04, 0x41, 0x04,
- 0x01, 0xa4, 0x80, 0x8a, 0x40, 0x01, 0x05, 0x92,
- 0x02, 0x2a, 0x04, 0x41, 0x04, 0x01, 0xa4, 0x80,
- 0x8a, 0x40, 0x01, 0x05, 0x92, 0x02, 0x2a, 0x04,
- 0x41, 0x04, 0x01, 0xa4, 0x80, 0x8a, 0x40, 0x01,
- 0x05, 0x92, 0x02, 0x2a, 0x04, 0x41, 0x00, 0x01,
- 0xa4, 0x80, 0x8a, 0x40, 0x01, 0x05, 0x12, 0x02,
- 0x2a, 0x04, 0x41, 0x00, 0x01, 0xa4, 0x80, 0x8a,
- 0x40, 0x01, 0x05, 0x12, 0x02, 0x2a, 0x04, 0x41,
- 0x00, 0x01, 0xa4, 0x80, 0x8a, 0x40, 0x01, 0x05,
- 0x12, 0x02, 0x2a, 0x04, 0x41, 0x00, 0x01, 0xa4,
- 0x80, 0x8a, 0x40, 0x11, 0x05, 0x12, 0x02, 0x2a,
- 0x04, 0x41, 0x00, 0x01, 0xa4, 0x80, 0x8a, 0x40,
- 0x11, 0x05, 0x12, 0x02, 0x2a, 0x04, 0x41, 0x00,
- 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x05, 0x12,
- 0x02, 0x2a, 0x04, 0x41, 0x00, 0x41, 0xa4, 0x80,
- 0x8a, 0x40, 0x11, 0x05, 0x12, 0x02, 0x2a, 0x04,
- 0x41, 0x00, 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x11,
- 0x05, 0x02, 0x02, 0x2a, 0x04, 0x41, 0x00, 0x41,
- 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x05, 0x02, 0x02,
- 0x2a, 0x04, 0x41, 0x00, 0x41, 0xa4, 0x80, 0x8a,
- 0x40, 0x11, 0x05, 0x02, 0x02, 0x2a, 0x04, 0x41,
- 0x00, 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x05,
- 0x02, 0x02, 0x2a, 0x04, 0x41, 0x04, 0x41, 0xa4,
- 0x80, 0x8a, 0x40, 0x11, 0x05, 0x02, 0x00, 0x2a,
- 0x04, 0x41, 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x40,
- 0x11, 0x05, 0x02, 0x00, 0x2a, 0x04, 0x41, 0x04,
- 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x05, 0x02,
- 0x00, 0x2a, 0x04, 0x45, 0x04, 0x41, 0xa4, 0x80,
- 0x8a, 0x40, 0x11, 0x05, 0x02, 0x00, 0x28, 0x04,
- 0x45, 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x11,
- 0x05, 0x02, 0x00, 0x28, 0x04, 0x45, 0x04, 0x41,
- 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x05, 0x12, 0x00,
- 0x28, 0x04, 0x45, 0x04, 0x41, 0xa0, 0x80, 0x8a,
- 0x40, 0x11, 0x05, 0x12, 0x00, 0x28, 0x04, 0x45,
- 0x04, 0x41, 0xa0, 0x80, 0x8a, 0x40, 0x11, 0x05,
- 0x12, 0x00, 0x28, 0x04, 0x45, 0x04, 0x41, 0xa0,
- 0x80, 0x8a, 0x40, 0x11, 0x05, 0x12, 0x00, 0x28,
- 0x04, 0x45, 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x40,
- 0x11, 0x05, 0x12, 0x00, 0x08, 0x04, 0x45, 0x04,
- 0x00, 0x08, 0x04, 0x45, 0x04, 0x41, 0xa4, 0x80,
- 0x8a, 0x40, 0x11, 0x05, 0x12, 0x00, 0x08, 0x04,
- 0x05, 0x12, 0x00, 0x08, 0x04, 0x45, 0x04, 0x41,
- 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x05, 0x92, 0x00,
- 0x08, 0x04, 0x45, 0x04, 0x41, 0xa4, 0x80, 0x8a,
- 0x40, 0x11, 0x05, 0x92, 0x00, 0x0a, 0x04, 0x45,
- 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x10, 0x05,
- 0x92, 0x00, 0x0a, 0x04, 0x45, 0x04, 0x41, 0xa4,
- 0x80, 0x8a, 0x40, 0x10, 0x05, 0x92, 0x00, 0x0a,
- 0x10, 0x01, 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04,
- 0x41, 0xa4, 0x80, 0x82, 0x40, 0x10, 0x00, 0x92,
- 0x02, 0x2a, 0x04, 0x45, 0x04, 0x41, 0xa4, 0x80,
- 0x82, 0x40, 0x10, 0x00, 0x92, 0x02, 0x2a, 0x04,
- 0x45, 0x04, 0x41, 0xa4, 0x80, 0x82, 0x40, 0x10,
- 0x00, 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x41,
- 0xa4, 0x80, 0x8a, 0x40, 0x10, 0x00, 0x92, 0x02,
- 0x2a, 0x04, 0x05, 0x04, 0x41, 0xa4, 0x80, 0x8a,
- 0x40, 0x10, 0x00, 0x92, 0x02, 0x2a, 0x04, 0x04,
- 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x10, 0x00,
- 0x92, 0x02, 0x2a, 0x04, 0x04, 0x04, 0x41, 0xa4,
- 0x80, 0x8a, 0x40, 0x10, 0x00, 0x92, 0x02, 0x2a,
- 0x04, 0x04, 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x40,
- 0x10, 0x00, 0x92, 0x02, 0x2a, 0x04, 0x04, 0x04,
- 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x10, 0x00, 0x92,
- 0x02, 0x2a, 0x04, 0x04, 0x04, 0x41, 0xa4, 0x80,
- 0x8a, 0x40, 0x10, 0x00, 0x92, 0x02, 0x2a, 0x04,
- 0x04, 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x10,
- 0x00, 0x92, 0x02, 0x2a, 0x04, 0x04, 0x04, 0x41,
- 0xa4, 0x80, 0x8a, 0x40, 0x10, 0x01, 0x92, 0x02,
- 0x2a, 0x04, 0x04, 0x04, 0x41, 0x24, 0x80, 0x8a,
- 0x40, 0x10, 0x01, 0x92, 0x02, 0x2a, 0x04, 0x44,
- 0x04, 0x41, 0x24, 0x80, 0x8a, 0x40, 0x00, 0x01,
- 0x92, 0x02, 0x2a, 0x04, 0x44, 0x04, 0x41, 0x24,
- 0x80, 0x8a, 0x40, 0x01, 0x01, 0x92, 0x02, 0x2a,
- 0x04, 0x44, 0x04, 0x41, 0x24, 0x00, 0x8a, 0x40,
- 0x01, 0x01, 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04,
- 0x41, 0x24, 0x00, 0x8a, 0x40, 0x11, 0x01, 0x92,
- 0x02, 0x2a, 0x04, 0x45, 0x04, 0x41, 0x24, 0x00,
- 0x8a, 0x40, 0x11, 0x01, 0x92, 0x02, 0x2a, 0x04,
- 0x45, 0x04, 0x41, 0x24, 0x00, 0x8a, 0x40, 0x11,
- 0x01, 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x41,
- 0x24, 0x00, 0x8a, 0x40, 0x11, 0x01, 0x92, 0x02,
- 0x2a, 0x04, 0x45, 0x04, 0x41, 0x24, 0x00, 0x8a,
- 0x40, 0x11, 0x01, 0x92, 0x02, 0x2a, 0x04, 0x45,
- 0x04, 0x41, 0x24, 0x00, 0x8a, 0x40, 0x11, 0x01,
- 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x41, 0x24,
- 0x00, 0x8a, 0x40, 0x11, 0x01, 0x92, 0x02, 0x2a,
- 0x04, 0x45, 0x04, 0x41, 0x24, 0x00, 0x8a, 0x40,
- 0x11, 0x05, 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04,
- 0x41, 0x24, 0x00, 0x8a, 0x40, 0x11, 0x05, 0x92,
- 0x8a, 0x40, 0x11, 0x05, 0x82, 0x02, 0x2a, 0x04,
- 0x45, 0x04, 0x41, 0x24, 0x80, 0x8a, 0x00, 0x11,
- 0x05, 0x82, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x41,
- 0x24, 0x80, 0x8a, 0x00, 0x11, 0x05, 0x82, 0x02,
- 0x2a, 0x04, 0x45, 0x04, 0x41, 0x24, 0x80, 0x8a,
- 0x00, 0x11, 0x05, 0x92, 0x02, 0x2a, 0x04, 0x45,
- 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x00, 0x11, 0x05,
- 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x41, 0xa4,
- 0x80, 0x8a, 0x00, 0x11, 0x05, 0x92, 0x02, 0x2a,
- 0x04, 0x45, 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x00,
- 0x41, 0xa4, 0x80, 0x8a, 0x00, 0x11, 0x05, 0x92,
- 0x02, 0x22, 0x00, 0x45, 0x04, 0x41, 0xa4, 0x80,
- 0x8a, 0x00, 0x11, 0x05, 0x92, 0x02, 0x22, 0x00,
- 0x45, 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x00, 0x11,
- 0x05, 0x92, 0x02, 0x22, 0x00, 0x45, 0x04, 0x41,
- 0xa4, 0x80, 0x8a, 0x00, 0x11, 0x05, 0x92, 0x02,
- 0x22, 0x00, 0x41, 0x04, 0x41, 0xa4, 0x80, 0x8a,
- 0x00, 0x11, 0x05, 0x92, 0x02, 0x22, 0x00, 0x41,
- 0x92, 0x02, 0x22, 0x00, 0x41, 0x04, 0x41, 0xa4,
- 0x80, 0x8a, 0x00, 0x11, 0x05, 0x92, 0x02, 0x02,
- 0x00, 0x41, 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x00,
- 0x11, 0x05, 0x92, 0x02, 0x02, 0x00, 0x41, 0x04,
- 0x02, 0x02, 0x00, 0x41, 0x04, 0x41, 0xa4, 0x80,
- 0x41, 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x00, 0x11,
- 0x05, 0x92, 0x02, 0x22, 0x00, 0x41, 0x04, 0x41,
- 0x2a, 0x00, 0x41, 0x04, 0x41, 0xa4, 0x80, 0x8a,
- 0x00, 0x11, 0x05, 0x92, 0x02, 0x2a, 0x00, 0x41,
- 0x92, 0x02, 0x2a, 0x00, 0x41, 0x04, 0x41, 0xa4,
- 0x00, 0x45, 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x00,
- 0x11, 0x05, 0x90, 0x02, 0x2a, 0x00, 0x45, 0x04,
- 0x41, 0xa4, 0x80, 0x8a, 0x00, 0x11, 0x05, 0x90,
- 0x02, 0x2a, 0x00, 0x45, 0x04, 0x41, 0xa4, 0x80,
- 0x8a, 0x00, 0x11, 0x05, 0x90, 0x02, 0x2a, 0x04,
- 0x05, 0x90, 0x00, 0x2a, 0x04, 0x05, 0x04, 0x41,
- 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x05, 0x90, 0x00,
- 0x40, 0x11, 0x05, 0x90, 0x00, 0x2a, 0x04, 0x05,
- 0x90, 0x00, 0x2a, 0x04, 0x45, 0x04, 0x41, 0xa4,
- 0x80, 0x88, 0x40, 0x11, 0x05, 0x90, 0x00, 0x2a,
- 0x04, 0x45, 0x04, 0x41, 0xa4, 0x80, 0x88, 0x40,
- 0x11, 0x05, 0x90, 0x00, 0x2a, 0x04, 0x45, 0x04,
- 0x41, 0xa4, 0x80, 0x88, 0x40, 0x11, 0x05, 0x90,
- 0x88, 0x40, 0x11, 0x05, 0x90, 0x00, 0x2a, 0x04,
- 0x45, 0x04, 0x41, 0xa4, 0x80, 0x88, 0x40, 0x11,
- 0x05, 0x90, 0x00, 0x2a, 0x04, 0x45, 0x04, 0x41,
- 0xa4, 0x80, 0x88, 0x40, 0x11, 0x05, 0x10, 0x00,
- 0x2a, 0x04, 0x45, 0x04, 0x41, 0xa4, 0x80, 0x88,
- 0x40, 0x11, 0x05, 0x10, 0x00, 0x2a, 0x04, 0x45,
- 0x04, 0x41, 0xa4, 0x80, 0x88, 0x40, 0x11, 0x05,
- 0x10, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x41, 0xa4,
- 0x80, 0x08, 0x40, 0x11, 0x05, 0x10, 0x02, 0x2a,
- 0x04, 0x45, 0x04, 0x41, 0xa4, 0x80, 0x08, 0x40,
- 0x11, 0x05, 0x10, 0x02, 0x2a, 0x04, 0x45, 0x04,
- 0x41, 0xa4, 0x80, 0x08, 0x40, 0x11, 0x05, 0x12,
- 0x08, 0x40, 0x10, 0x05, 0x12, 0x02, 0x2a, 0x04,
- 0x45, 0x04, 0x41, 0xa4, 0x80, 0x08, 0x40, 0x10,
- 0x05, 0x12, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x41,
- 0xa0, 0x80, 0x08, 0x40, 0x10, 0x05, 0x12, 0x02,
- 0x2a, 0x04, 0x45, 0x04, 0x41, 0xa0, 0x80, 0x08,
- 0x40, 0x10, 0x05, 0x12, 0x02, 0x2a, 0x04, 0x45,
- 0x04, 0x41, 0xa0, 0x80, 0x08, 0x40, 0x10, 0x05,
- 0x12, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x41, 0xa0,
- 0x80, 0x08, 0x40, 0x10, 0x05, 0x92, 0x02, 0x2a,
- 0x04, 0x45, 0x04, 0x41, 0xa0, 0x80, 0x08, 0x40,
- 0x10, 0x05, 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04,
- 0x41, 0xa0, 0x80, 0x08, 0x40, 0x10, 0x05, 0x92,
- 0x02, 0x2a, 0x04, 0x45, 0x04, 0x41, 0xa0, 0x80,
- 0x08, 0x40, 0x10, 0x05, 0x92, 0x02, 0x2a, 0x04,
- 0x45, 0x04, 0x41, 0xa0, 0x80, 0x08, 0x40, 0x10,
- 0x05, 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x41,
- 0xa4, 0x80, 0x08, 0x40, 0x10, 0x05, 0x92, 0x02,
- 0x2a, 0x04, 0x45, 0x04, 0x41, 0xa4, 0x80, 0x08,
- 0x40, 0x10, 0x05, 0x92, 0x02, 0x2a, 0x04, 0x45,
- 0x04, 0x41, 0xa4, 0x80, 0x08, 0x40, 0x11, 0x05,
- 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x01, 0xa4,
- 0x80, 0x0a, 0x40, 0x11, 0x05, 0x92, 0x02, 0x2a,
- 0x01, 0x24, 0x80, 0x82, 0x40, 0x11, 0x05, 0x92,
- 0x02, 0x2a, 0x04, 0x45, 0x04, 0x01, 0x04, 0x80,
- 0x82, 0x40, 0x11, 0x05, 0x92, 0x02, 0x2a, 0x04,
- 0x45, 0x04, 0x01, 0x04, 0x80, 0x82, 0x40, 0x11,
- 0x05, 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x01,
- 0x04, 0x80, 0x82, 0x40, 0x11, 0x05, 0x92, 0x02,
- 0x2a, 0x04, 0x45, 0x00, 0x01, 0x04, 0x80, 0x82,
- 0x40, 0x11, 0x05, 0x92, 0x02, 0x2a, 0x04, 0x45,
- 0x00, 0x01, 0x04, 0x80, 0x82, 0x40, 0x11, 0x05,
- 0x92, 0x02, 0x2a, 0x04, 0x45, 0x00, 0x01, 0x04,
- 0x80, 0x82, 0x40, 0x11, 0x01, 0x92, 0x02, 0x2a,
- 0x04, 0x45, 0x00, 0x01, 0x04, 0x80, 0x82, 0x40,
- 0x11, 0x01, 0x92, 0x02, 0x2a, 0x04, 0x45, 0x00,
- 0x01, 0x04, 0x80, 0x8a, 0x40, 0x11, 0x01, 0x92,
- 0x02, 0x2a, 0x04, 0x45, 0x00, 0x01, 0x04, 0x80,
- 0x45, 0x00, 0x01, 0x04, 0x80, 0x8a, 0x40, 0x11,
- 0x01, 0x92, 0x02, 0x2a, 0x04, 0x45, 0x00, 0x01,
- 0x04, 0x80, 0x8a, 0x40, 0x11, 0x01, 0x92, 0x02,
- 0x2a, 0x04, 0x45, 0x00, 0x01, 0x84, 0x80, 0x8a,
- 0x40, 0x01, 0x01, 0x92, 0x02, 0x2a, 0x04, 0x45,
- 0x00, 0x01, 0x84, 0x80, 0x8a, 0x40, 0x01, 0x01,
- 0x92, 0x02, 0x2a, 0x04, 0x45, 0x00, 0x41, 0x84,
- 0x04, 0x45, 0x00, 0x41, 0x84, 0x80, 0x8a, 0x40,
- 0x01, 0x01, 0x92, 0x02, 0x2a, 0x04, 0x45, 0x00,
- 0x41, 0x84, 0x80, 0x8a, 0x40, 0x01, 0x01, 0x92,
- 0x02, 0x2a, 0x04, 0x45, 0x00, 0x41, 0x84, 0x80,
- 0x8a, 0x40, 0x01, 0x01, 0x92, 0x02, 0x2a, 0x04,
- 0x45, 0x00, 0x41, 0x84, 0x80, 0x8a, 0x40, 0x01,
- 0x05, 0x92, 0x02, 0x28, 0x04, 0x45, 0x00, 0x41,
- 0x84, 0x80, 0x8a, 0x40, 0x01, 0x05, 0x92, 0x02,
- 0x28, 0x04, 0x45, 0x04, 0x41, 0x84, 0x80, 0x8a,
- 0x40, 0x11, 0x05, 0x92, 0x02, 0x28, 0x00, 0x45,
- 0x04, 0x41, 0x84, 0x80, 0x8a, 0x40, 0x11, 0x05,
- 0x92, 0x02, 0x28, 0x00, 0x45, 0x04, 0x41, 0x84,
- 0x00, 0x45, 0x04, 0x41, 0x84, 0x80, 0x8a, 0x40,
- 0x11, 0x05, 0x92, 0x02, 0x28, 0x00, 0x45, 0x04,
- 0x41, 0x84, 0x80, 0x8a, 0x40, 0x11, 0x05, 0x92,
- 0x02, 0x28, 0x00, 0x45, 0x04, 0x41, 0xa4, 0x80,
- 0x8a, 0x40, 0x11, 0x05, 0x82, 0x02, 0x28, 0x00,
- 0x05, 0x82, 0x02, 0x28, 0x00, 0x45, 0x04, 0x41,
- 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x05, 0x82, 0x02,
- 0x28, 0x00, 0x45, 0x04, 0x41, 0xa4, 0x80, 0x8a,
- 0x40, 0x11, 0x05, 0x82, 0x02, 0x28, 0x00, 0x45,
- 0x04, 0x40, 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x05,
- 0x82, 0x02, 0x28, 0x00, 0x45, 0x04, 0x40, 0xa4,
- 0x80, 0x8a, 0x40, 0x11, 0x05, 0x82, 0x02, 0x28,
- 0x00, 0x45, 0x04, 0x40, 0xa4, 0x80, 0x8a, 0x40,
- 0x11, 0x05, 0x82, 0x02, 0x28, 0x00, 0x45, 0x04,
- 0x40, 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x05, 0x82,
- 0x02, 0x28, 0x04, 0x45, 0x04, 0x40, 0xa4, 0x80,
- 0x8a, 0x40, 0x11, 0x04, 0x92, 0x02, 0x28, 0x04,
- 0x45, 0x04, 0x40, 0xa0, 0x80, 0x8a, 0x00, 0x11,
- 0x04, 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x40,
- 0xa0, 0x80, 0x8a, 0x00, 0x11, 0x04, 0x90, 0x02,
- 0x2a, 0x04, 0x45, 0x04, 0x40, 0xa0, 0x80, 0x8a,
- 0x00, 0x11, 0x04, 0x90, 0x02, 0x2a, 0x04, 0x45,
- 0x04, 0x40, 0xa4, 0x80, 0x8a, 0x00, 0x11, 0x04,
- 0x90, 0x02, 0x0a, 0x04, 0x45, 0x04, 0x40, 0xa4,
- 0x80, 0x8a, 0x00, 0x11, 0x04, 0x90, 0x02, 0x0a,
- 0x04, 0x45, 0x04, 0x40, 0xa4, 0x80, 0x8a, 0x00,
- 0x11, 0x04, 0x90, 0x02, 0x0a, 0x04, 0x45, 0x04,
- 0x40, 0xa4, 0x80, 0x8a, 0x00, 0x11, 0x04, 0x90,
- 0x02, 0x0a, 0x04, 0x45, 0x04, 0x40, 0xa4, 0x80,
- 0x8a, 0x00, 0x11, 0x04, 0x90, 0x02, 0x0a, 0x04,
- 0x45, 0x04, 0x40, 0xa4, 0x80, 0x8a, 0x00, 0x11,
- 0x04, 0x90, 0x02, 0x0a, 0x04, 0x45, 0x04, 0x40,
- 0xa4, 0x80, 0x8a, 0x00, 0x11, 0x04, 0x90, 0x02,
- 0x0a, 0x04, 0x45, 0x04, 0x40, 0xa4, 0x80, 0x8a,
- 0x00, 0x11, 0x04, 0x90, 0x02, 0x0a, 0x04, 0x45,
- 0x04, 0x40, 0xa4, 0x80, 0x8a, 0x40, 0x11, 0x04,
- 0x90, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x40, 0xa4,
- 0x80, 0x82, 0x40, 0x11, 0x04, 0x90, 0x02, 0x2a,
- 0x04, 0x45, 0x04, 0x40, 0xa4, 0x80, 0x82, 0x40,
- 0x11, 0x04, 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04,
- 0x40, 0xa4, 0x00, 0x82, 0x40, 0x11, 0x04, 0x92,
- 0x02, 0x2a, 0x04, 0x45, 0x04, 0x40, 0xa4, 0x00,
- 0x45, 0x04, 0x40, 0xa4, 0x00, 0x0a, 0x40, 0x11,
- 0x05, 0x92, 0x02, 0x2a, 0x04, 0x05, 0x04, 0x40,
- 0xa4, 0x00, 0x0a, 0x40, 0x11, 0x05, 0x92, 0x02,
- 0x2a, 0x04, 0x05, 0x04, 0x40, 0xa4, 0x00, 0x0a,
- 0x40, 0x11, 0x05, 0x92, 0x02, 0x2a, 0x04, 0x05,
- 0x04, 0x41, 0xa4, 0x00, 0x0a, 0x40, 0x11, 0x05,
- 0x92, 0x02, 0x2a, 0x04, 0x05, 0x04, 0x41, 0xa4,
- 0x00, 0x0a, 0x40, 0x11, 0x05, 0x92, 0x02, 0x2a,
- 0x04, 0x05, 0x04, 0x41, 0xa4, 0x00, 0x0a, 0x40,
- 0x11, 0x05, 0x92, 0x02, 0x2a, 0x04, 0x05, 0x04,
- 0x02, 0x2a, 0x04, 0x05, 0x04, 0x41, 0xa4, 0x00,
- 0x0a, 0x40, 0x11, 0x05, 0x92, 0x02, 0x2a, 0x04,
- 0x05, 0x04, 0x41, 0xa4, 0x00, 0x0a, 0x40, 0x11,
- 0xa4, 0x00, 0x0a, 0x40, 0x01, 0x05, 0x92, 0x02,
- 0x2a, 0x04, 0x45, 0x04, 0x41, 0xa4, 0x00, 0x0a,
- 0x40, 0x01, 0x05, 0x92, 0x02, 0x2a, 0x04, 0x45,
- 0x04, 0x41, 0xa4, 0x00, 0x08, 0x40, 0x01, 0x05,
- 0x00, 0x88, 0x40, 0x11, 0x05, 0x92, 0x02, 0x2a,
- 0x04, 0x45, 0x04, 0x41, 0xa4, 0x00, 0x88, 0x40,
- 0x41, 0xa4, 0x80, 0x88, 0x40, 0x11, 0x05, 0x92,
- 0x02, 0x2a, 0x04, 0x45, 0x04, 0x01, 0xa4, 0x80,
- 0x88, 0x40, 0x11, 0x05, 0x92, 0x02, 0x2a, 0x04,
- 0x45, 0x04, 0x01, 0xa4, 0x80, 0x88, 0x40, 0x11,
- 0xa4, 0x80, 0x88, 0x40, 0x11, 0x05, 0x92, 0x02,
- 0x2a, 0x04, 0x45, 0x04, 0x01, 0xa4, 0x80, 0x88,
- 0x40, 0x11, 0x05, 0x92, 0x02, 0x2a, 0x04, 0x41,
- 0x04, 0x01, 0xa4, 0x80, 0x88, 0x40, 0x11, 0x05,
- 0x92, 0x02, 0x2a, 0x04, 0x41, 0x04, 0x01, 0xa4,
- 0x80, 0x88, 0x40, 0x11, 0x05, 0x92, 0x02, 0x2a,
- 0x04, 0x41, 0x00, 0x01, 0xa4, 0x80, 0x88, 0x40,
- 0x11, 0x05, 0x92, 0x02, 0x2a, 0x04, 0x41, 0x00,
- 0x01, 0xa4, 0x80, 0x88, 0x40, 0x11, 0x05, 0x82,
- 0x02, 0x2a, 0x04, 0x41, 0x00, 0x01, 0xa4, 0x80,
- 0x41, 0x00, 0x01, 0xa4, 0x80, 0x8a, 0x40, 0x11,
- 0x05, 0x82, 0x02, 0x2a, 0x04, 0x41, 0x00, 0x01,
- 0x92, 0x02, 0x2a, 0x04, 0x41, 0x00, 0x41, 0xa4,
- 0x80, 0x8a, 0x40, 0x11, 0x05, 0x92, 0x02, 0x2a,
- 0x04, 0x41, 0x00, 0x41, 0xa4, 0x80, 0x8a, 0x40,
- 0x8a, 0x40, 0x11, 0x05, 0x92, 0x02, 0x2a, 0x04,
- 0x05, 0x92, 0x02, 0x2a, 0x04, 0x41, 0x04, 0x41,
- 0x2a, 0x04, 0x41, 0x04, 0x41, 0xa4, 0x80, 0x8a,
- 0x92, 0x00, 0x08, 0x04, 0x45, 0x04, 0x41, 0xa4,
- 0x80, 0x8a, 0x40, 0x11, 0x05, 0x92, 0x00, 0x08,
- 0x11, 0x05, 0x92, 0x00, 0x28, 0x04, 0x45, 0x04,
- 0x00, 0x28, 0x04, 0x45, 0x04, 0x41, 0x84, 0x80,
- 0x8a, 0x40, 0x11, 0x05, 0x92, 0x00, 0x28, 0x04,
- 0x45, 0x04, 0x41, 0x84, 0x80, 0x8a, 0x40, 0x11,
- 0x05, 0x92, 0x00, 0x28, 0x04, 0x45, 0x04, 0x41,
- 0x84, 0x80, 0x8a, 0x40, 0x11, 0x05, 0x92, 0x00,
- 0x40, 0x11, 0x05, 0x92, 0x00, 0x28, 0x04, 0x45,
- 0x92, 0x00, 0x28, 0x04, 0x45, 0x04, 0x41, 0x84,
- 0x80, 0x8a, 0x40, 0x11, 0x05, 0x92, 0x00, 0x28,
- 0x04, 0x45, 0x04, 0x41, 0x84, 0x80, 0x8a, 0x40,
- 0x8a, 0x40, 0x11, 0x05, 0x92, 0x00, 0x2a, 0x04,
- 0x05, 0x04, 0x41, 0x84, 0x80, 0x8a, 0x40, 0x10,
- 0x05, 0x92, 0x00, 0x2a, 0x04, 0x05, 0x04, 0x41,
- 0x84, 0x80, 0x8a, 0x40, 0x10, 0x05, 0x92, 0x02,
- 0x40, 0x10, 0x04, 0x92, 0x02, 0x2a, 0x04, 0x45,
- 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x10, 0x04,
- 0x80, 0x8a, 0x40, 0x10, 0x04, 0x92, 0x02, 0x2a,
- 0x10, 0x04, 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04,
- 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x10, 0x04, 0x92,
- 0x8a, 0x40, 0x10, 0x04, 0x92, 0x02, 0x2a, 0x04,
- 0x45, 0x04, 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x10,
- 0x04, 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x41,
- 0xa4, 0x80, 0x8a, 0x40, 0x10, 0x04, 0x92, 0x02,
- 0x2a, 0x04, 0x45, 0x04, 0x41, 0xa4, 0x80, 0x8a,
- 0x41, 0xa4, 0x80, 0x8a, 0x40, 0x10, 0x05, 0x92,
- 0x02, 0x2a, 0x04, 0x45, 0x04, 0x41, 0x20, 0x80,
- 0x8a, 0x40, 0x10, 0x05, 0x92, 0x02, 0x2a, 0x04,
- 0x45, 0x04, 0x41, 0x20, 0x80, 0x8a, 0x40, 0x11,
- 0x20, 0x00, 0x8a, 0x40, 0x11, 0x05, 0x92, 0x02,
- 0x2a, 0x04, 0x45, 0x04, 0x40, 0x20, 0x00, 0x8a,
- 0x04, 0x40, 0x20, 0x00, 0x8a, 0x40, 0x11, 0x05,
- 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x40, 0x20,
- 0x00, 0x8a, 0x40, 0x11, 0x05, 0x92, 0x02, 0x2a,
- 0x04, 0x45, 0x04, 0x40, 0x20, 0x00, 0x8a, 0x40,
- 0x40, 0x20, 0x00, 0x8a, 0x40, 0x11, 0x05, 0x92,
- 0x02, 0x2a, 0x04, 0x45, 0x04, 0x40, 0x20, 0x00,
- 0x45, 0x04, 0x40, 0x24, 0x00, 0x8a, 0x40, 0x11,
- 0x05, 0x92, 0x02, 0x2a, 0x04, 0x45, 0x04, 0x40,
- 0x24, 0x00, 0x8a, 0x40, 0x11, 0x05, 0x92, 0x02,
- 0x2a, 0x04, 0x45, 0x04, 0x40, 0x24, 0x00, 0x8a,
- 0x40, 0x11, 0x05, 0x92, 0x02, 0x2a, 0x04, 0x44,
- 0x04, 0x40, 0x24, 0x00, 0x8a, 0x40, 0x11, 0x05,
- 0x92, 0x02, 0x2a, 0x04, 0x44, 0x04, 0x40, 0x24,
- 0x00, 0x82, 0x40, 0x11, 0x05, 0x92, 0x02, 0x2a,
- 0x04, 0x44, 0x04, 0x40, 0x24, 0x80, 0x82, 0x40,
- 0x11, 0x05, 0x92, 0x02, 0x2a, 0x04, 0x44, 0x04};
-static unsigned char AR_RSHKE_BITS[] = {
- 0xff, 0x07, 0xfc, 0x7f, 0xf8, 0xff, 0x07, 0x00,
- 0x01, 0xfc, 0x07, 0x40, 0x08, 0x00, 0xfc, 0x01,
- 0x01, 0x04, 0x04, 0x40, 0x08, 0x00, 0x04, 0x00,
- 0x01, 0x04, 0x3f, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0xf0, 0xff, 0xe1, 0xff, 0x1f, 0xf8, 0x3f, 0x00,
- 0x1f, 0x00, 0x21, 0x00, 0xf0, 0x0f, 0xe0, 0x01,
- 0x10, 0x00, 0x21, 0x00, 0x10, 0x08, 0x20, 0x00,
- 0xfc, 0x00, 0x00, 0x00, 0x00, 0x08, 0x20, 0x00,
- 0x87, 0xff, 0x7f, 0xe0, 0xff, 0x80, 0xff, 0x01,
- 0x84, 0x00, 0xc0, 0x3f, 0x80, 0xff, 0x00, 0x00,
- 0x84, 0x00, 0x40, 0x20, 0x80, 0x80, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x20, 0x80, 0xf0, 0x03, 0x00,
- 0xff, 0xc1, 0xff, 0x01, 0xfe, 0x1f, 0xfe, 0x01,
- 0x00, 0x7f, 0x00, 0xff, 0x03, 0x10, 0x02, 0x00,
- 0x00, 0x41, 0x00, 0x01, 0x02, 0x10, 0x02, 0x00,
- 0x00, 0x40, 0x00, 0xc1, 0x0f, 0x00, 0x00, 0x00};
-static unsigned char AR_RSHKE_90_BITS[] = {
- 0x01, 0x00, 0x10, 0x00, 0x00, 0x01, 0x00, 0xe8,
- 0xff, 0xff, 0x01, 0x00, 0x10, 0x00, 0x00, 0x01,
- 0x00, 0x08, 0x00, 0x00, 0x01, 0x00, 0xd0, 0xff,
- 0xff, 0x03, 0x00, 0x08, 0x00, 0x00, 0x01, 0x00,
- 0x10, 0x00, 0x00, 0x02, 0x00, 0x08, 0x00, 0x00,
- 0x01, 0x00, 0x10, 0x00, 0x00, 0xfa, 0xff, 0x1f,
- 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x00, 0x02,
- 0x00, 0x10, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00,
- 0x00, 0x02, 0x00, 0x10, 0x00, 0x00, 0x01, 0x00,
- 0xd0, 0xff, 0xff, 0x03, 0x00, 0x10, 0x00, 0x00,
- 0xfd, 0xff, 0x1f, 0x00, 0x00, 0x01, 0x00, 0x10,
- 0x00, 0x00, 0x01, 0x00, 0x08, 0x00, 0x00, 0x01,
- 0x00, 0x10, 0x00, 0x00, 0x01, 0x00, 0x08, 0x00,
- 0x00, 0x01, 0x00, 0xf0, 0xff, 0xff, 0x00, 0x00,
- 0x08, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x80,
- 0x00, 0x00, 0x08, 0x00, 0x00, 0x01, 0x00, 0x10,
- 0x00, 0x80, 0x00, 0x00, 0x08, 0x00, 0x00, 0x01,
- 0x00, 0x10, 0x00, 0x80, 0xfe, 0xff, 0x1f, 0x00,
- 0x00, 0x01, 0x00, 0x10, 0x00, 0x80, 0x00, 0x00,
- 0x10, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x80,
- 0x00, 0x00, 0x10, 0x00, 0x00, 0xfd, 0xff, 0x3f,
- 0x00, 0x80, 0x00, 0x00, 0x10, 0x00, 0x00, 0x01,
- 0x00, 0x20, 0x00, 0x80, 0x01, 0x00, 0x10, 0x00,
- 0x00, 0x01, 0x00, 0xa0, 0xff, 0xff, 0x01, 0x00,
- 0x10, 0x00, 0x00, 0x01, 0x00, 0x20, 0x00, 0x00,
- 0x01, 0x00, 0x10, 0x00, 0x00, 0x01, 0x00, 0x20,
- 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x00, 0xfd,
- 0xff, 0x3f, 0x00, 0x00, 0x01, 0x00, 0xd0, 0xff,
- 0xff, 0x01, 0x00, 0x10, 0x00, 0x00, 0x01, 0x00,
- 0x10, 0x00, 0x80, 0x00, 0x00, 0x10, 0x00, 0x00,
- 0xff, 0xff, 0x1f, 0x00, 0x80, 0x00, 0x00, 0x10,
- 0x00, 0x00, 0x01, 0x00, 0x08, 0x00, 0x80, 0x00,
- 0x80, 0x00, 0x00, 0x10, 0x00, 0x00, 0x01, 0x00,
- 0x08, 0x00, 0x80, 0x00, 0x00, 0x10, 0x00, 0x00,
- 0x01, 0x00, 0x08, 0x00, 0x80, 0x00, 0x00, 0x10,
- 0x00, 0x00, 0x01, 0x00, 0xe8, 0xff, 0xff, 0x01,
- 0x00, 0x10, 0x00, 0x00, 0x03, 0x00, 0x08, 0x00,
- 0x00, 0x01, 0x00, 0xd0, 0xff, 0xff, 0x02, 0x00,
- 0x08, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x00,
- 0x02, 0x00, 0x08, 0x00, 0x00, 0x01, 0x00, 0x10,
- 0x00, 0x00, 0xfa, 0xff, 0x1f, 0x00, 0x00, 0x01,
- 0x00, 0x10, 0x00, 0x00, 0x02, 0x00, 0x10, 0x00,
- 0x00, 0x01, 0x00, 0x10, 0x00, 0x00, 0x03, 0x00,
- 0x10, 0x00, 0x00, 0x01, 0x00, 0xd0, 0xff, 0xff,
- 0x01, 0x00, 0x10, 0x00, 0x00, 0xfd, 0xff, 0x1f,
- 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x00, 0x01,
- 0x00, 0x08, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00,
- 0x00, 0x01, 0x00, 0x08, 0x00, 0x00, 0x01, 0x00,
- 0xf0, 0xff, 0xff, 0x01, 0x00, 0x08, 0x00, 0x00,
- 0x01, 0x00, 0x10, 0x00, 0x80, 0x00, 0x00, 0x08,
- 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x80, 0x00,
- 0x80, 0x00, 0x00, 0x08, 0x00, 0x00, 0x01, 0x00,
- 0x10, 0x00, 0x80, 0xfe, 0xff, 0x1f, 0x00, 0x00,
- 0xfd, 0xff, 0x3f, 0x00, 0x80, 0x00, 0x00, 0x10,
- 0x00, 0x00, 0x01, 0x00, 0x20, 0x00, 0x80, 0x00,
- 0x00, 0x10, 0x00, 0x00, 0x01, 0x00, 0x20, 0x00,
- 0xa0, 0xff, 0xff, 0x01, 0x00, 0x10, 0x00, 0x00,
- 0x01, 0x00, 0x20, 0x00, 0x00, 0x01, 0x00, 0x10,
- 0x00, 0x00, 0xfd, 0xff, 0x3f, 0x00, 0x00, 0x01,
- 0x00, 0x01, 0x00, 0xd0, 0xff, 0xff, 0x00, 0x00,
- 0x00, 0x00, 0x10, 0x00, 0x00, 0x01, 0x00, 0x10,
- 0x00, 0x80, 0x00, 0x00, 0x10, 0x00, 0x00, 0xff,
- 0xff, 0x1f, 0x00, 0x80, 0x00, 0x00, 0x10, 0x00,
- 0x00, 0x01, 0x00, 0x08, 0x00, 0x80, 0x00, 0x00,
- 0x10, 0x00, 0x00, 0x01, 0x00, 0x08, 0x00, 0x80,
- 0x00, 0x00, 0x10, 0x00, 0x00, 0x01, 0x00, 0x08,
- 0x00, 0x80};
-static unsigned char AR_RSHKE_180_BITS[] = {
- 0x81, 0xff, 0x7f, 0xf8, 0xff, 0x80, 0xff, 0x01,
- 0x00, 0x00, 0xc0, 0x0f, 0x02, 0x08, 0x00, 0x00,
- 0x00, 0x21, 0x00, 0x00, 0x02, 0x08, 0x02, 0x00,
- 0x00, 0x21, 0x00, 0x01, 0x02, 0x08, 0x02, 0x00,
- 0x00, 0x21, 0x00, 0xff, 0x03, 0xf8, 0x03, 0x00,
- 0xff, 0xe1, 0xff, 0x01, 0xfe, 0x0f, 0xfe, 0x01,
- 0x00, 0x3f, 0x04, 0x20, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x04, 0x20, 0x08, 0x00, 0x84, 0x00,
- 0x00, 0x04, 0x04, 0x20, 0x08, 0x00, 0x84, 0x00,
- 0x00, 0xfc, 0x07, 0xe0, 0x0f, 0x00, 0x84, 0x00,
- 0xff, 0x07, 0xfc, 0x3f, 0xf8, 0xff, 0x87, 0x01,
- 0x10, 0x40, 0x00, 0x00, 0x00, 0x00, 0xfc, 0x00,
- 0x10, 0x40, 0x20, 0x00, 0x10, 0x02, 0x00, 0x00,
- 0x10, 0x40, 0x20, 0x00, 0x10, 0x02, 0x20, 0x00,
- 0x1f, 0xc0, 0x3f, 0x00, 0x10, 0x02, 0xe0, 0x01,
- 0xf0, 0x7f, 0xe0, 0xff, 0x1f, 0xfe, 0x3f, 0x00,
- 0x01, 0x00, 0x00, 0x00, 0xf0, 0x83, 0x00, 0x00,
- 0x81, 0x00, 0x40, 0x08, 0x00, 0x80, 0x00, 0x00,
- 0x81, 0x00, 0x40, 0x08, 0x80, 0x80, 0x00, 0x00,
- 0xff, 0x00, 0x40, 0x08, 0x80, 0xff, 0x00, 0x00};
-static unsigned char AR_RSHKE_270_BITS[] = {
- 0xff, 0xff, 0x2f, 0x00, 0x00, 0x01, 0x00, 0x10,
- 0x00, 0x00, 0x02, 0x00, 0x20, 0x00, 0x00, 0x01,
- 0x00, 0x10, 0x00, 0x00, 0x02, 0x00, 0x20, 0x00,
- 0x00, 0x01, 0x00, 0x10, 0x00, 0x00, 0x02, 0x00,
- 0x20, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x00,
- 0x02, 0x00, 0xf0, 0xff, 0xff, 0x01, 0x00, 0x10,
- 0x00, 0x00, 0x02, 0x00, 0x10, 0x00, 0x00, 0x01,
- 0x00, 0x01, 0x00, 0x10, 0x00, 0x00, 0xff, 0xff,
- 0x17, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x00,
- 0x01, 0x00, 0x10, 0x00, 0x00, 0x01, 0x00, 0xf8,
- 0xff, 0x7f, 0x01, 0x00, 0x10, 0x00, 0x00, 0x01,
- 0x00, 0xff, 0xff, 0x0f, 0x00, 0x00, 0x01, 0x00,
- 0x01, 0x00, 0x10, 0x00, 0x00, 0x02, 0x00, 0x08,
- 0x00, 0xf8, 0xff, 0x7f, 0x01, 0x00, 0xf0, 0xff,
- 0xff, 0x02, 0x00, 0x10, 0x00, 0x00, 0x01, 0x00,
- 0x20, 0x00, 0x00, 0x02, 0x00, 0x10, 0x00, 0x00,
- 0x01, 0x00, 0x20, 0x00, 0x00, 0x02, 0x00, 0x10,
- 0x00, 0x00, 0x01, 0x00, 0x20, 0x00, 0x00, 0x02,
- 0x00, 0xff, 0xff, 0x1f, 0x00, 0x00, 0x01, 0x00,
- 0x00, 0x00, 0x01, 0x00, 0xf0, 0xff, 0x7f, 0x01,
- 0x00, 0x10, 0x00, 0x00, 0xff, 0xff, 0x17, 0x00,
- 0x00, 0x00, 0x10, 0x00, 0x00, 0x01, 0x00, 0xf0,
- 0xff, 0xff, 0x00, 0x00, 0x10, 0x00, 0x00, 0x01,
- 0x00, 0x20, 0x00, 0x80, 0x00, 0x00, 0x10, 0x00,
- 0x00, 0x01, 0x00, 0x20, 0x00, 0x80, 0xff, 0xff,
- 0x17, 0x00, 0x00, 0x01, 0x00, 0x20, 0x00, 0x80,
- 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x00, 0xff,
- 0xff, 0x2f, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00,
- 0x00, 0x02, 0x00, 0x20, 0x00, 0x00, 0x01, 0x00,
- 0x10, 0x00, 0x00, 0x02, 0x00, 0x20, 0x00, 0x00,
- 0x01, 0x00, 0x10, 0x00, 0x00, 0x02, 0x00, 0x20,
- 0x00, 0xf0, 0xff, 0xff, 0x01, 0x00, 0x10, 0x00,
- 0x10, 0x00, 0x00, 0xff, 0xff, 0x17, 0x00, 0x00,
- 0x01, 0x00, 0xf8, 0xff, 0x7f, 0x01, 0x00, 0x10,
- 0x0f, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x00,
- 0x00, 0x00, 0x02, 0x00, 0xf8, 0xff, 0x7f, 0x01,
- 0x10, 0x00, 0x00, 0x01, 0x00, 0xf0, 0xff, 0xff,
- 0x02, 0x00, 0x10, 0x00, 0x00, 0x01, 0x00, 0x20,
- 0x00, 0x20, 0x00, 0x00, 0x02, 0x00, 0x10, 0x00,
- 0x00, 0x01, 0x00, 0x20, 0x00, 0x00, 0xff, 0xff,
- 0x1f, 0x00, 0x00, 0x01, 0x00, 0x20, 0x00, 0x00,
- 0x00, 0xf0, 0xff, 0x7f, 0x01, 0x00, 0x10, 0x00,
- 0x80, 0xff, 0xff, 0x17, 0x00, 0x00, 0x01, 0x00,
- 0x01, 0x00, 0x10, 0x00, 0x80, 0x00, 0x00, 0x10,
- 0x00, 0x00, 0x01, 0x00, 0xf0, 0xff, 0xff, 0x00,
- 0x20, 0x00, 0x80, 0xff, 0xff, 0x17, 0x00, 0x00,
- 0x00, 0x00};
-static unsigned char AR_SAND_BITS[] = {
- 0x01, 0x64, 0x00, 0x06, 0x00, 0x02, 0x00, 0x02,
- 0x00, 0x02, 0x00, 0x02, 0x04, 0x10, 0x08, 0x00,
- 0x00, 0x00, 0x01, 0x20, 0x00, 0x04, 0x00, 0x01,
- 0x20, 0x00, 0x00, 0x40, 0x04, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x02, 0x00, 0x00, 0x08, 0x00, 0x80,
- 0x00, 0x00, 0x08, 0x00, 0x00, 0x06, 0x00, 0x48,
- 0x01, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x40, 0x00, 0x10, 0x00, 0x42, 0x42, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80,
- 0x00, 0x80, 0x00, 0xa0, 0x00, 0x90, 0x00, 0x82,
- 0x40, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x90, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x02, 0x00, 0x20, 0x00, 0x08,
- 0x06, 0x00, 0x40, 0x00, 0x00, 0x10, 0x00, 0x00,
- 0x01, 0x00, 0x00, 0x00, 0x00, 0x10, 0x02, 0x00,
- 0x20, 0x00, 0x04, 0x80, 0x00, 0x00, 0x00, 0x00,
- 0x01, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80,
- 0x00, 0xc5, 0x20, 0x00, 0x20, 0x00, 0x20, 0x00,
- 0x20, 0x02, 0x00, 0x00, 0x00, 0x00, 0x06, 0x20,
- 0x01, 0x01, 0x00, 0x08, 0x00, 0x00, 0x01, 0x20,
- 0x10, 0x20, 0x00, 0x20, 0x00, 0x00, 0x40, 0x02,
- 0x00, 0x00, 0x00, 0x00, 0x20, 0x10, 0x00, 0x02,
- 0x40, 0x00, 0x10, 0x00, 0x02, 0x40, 0x00, 0x00,
- 0x00, 0x00, 0x80, 0x08, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x80, 0x00,
- 0x00, 0x14, 0x00, 0x80, 0x01, 0x00, 0x10, 0x00,
- 0x00, 0x01};
-static unsigned char ANSI31_BITS[] = {
- 0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08, 0x00,
- 0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80, 0x00,
- 0x00, 0x01};
-static unsigned char ANSI32_BITS[] = {
- 0x01, 0x02, 0x00, 0x00, 0x02, 0x04, 0x00, 0x00,
- 0x04, 0x08, 0x00, 0x00, 0x08, 0x10, 0x00, 0x00,
- 0x10, 0x20, 0x00, 0x00, 0x20, 0x40, 0x00, 0x00,
- 0x40, 0x80, 0x00, 0x00, 0x80, 0x00, 0x01, 0x00,
- 0x00, 0x01, 0x02, 0x00, 0x00, 0x02, 0x04, 0x00,
- 0x00, 0x04, 0x08, 0x00, 0x00, 0x08, 0x10, 0x00,
- 0x00, 0x10, 0x20, 0x00, 0x00, 0x20, 0x40, 0x00,
- 0x00, 0x40, 0x80, 0x00, 0x00, 0x80, 0x00, 0x01,
- 0x00, 0x00, 0x01, 0x02, 0x00, 0x00, 0x02, 0x04,
- 0x01, 0x00, 0x04, 0x00, 0x02, 0x00, 0x08, 0x00,
- 0x04, 0x00, 0x10, 0x00, 0x08, 0x00, 0x20, 0x00,
- 0x10, 0x00, 0x40, 0x00, 0x20, 0x00, 0x80, 0x00,
- 0x40, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x02,
- 0x00, 0x01, 0x00, 0x04};
-static unsigned char ANSI33_BITS[] = {
- 0x01, 0x02, 0x00, 0x02, 0x04, 0x00, 0x04, 0x08,
- 0x00, 0x08, 0x10, 0x00, 0x10, 0x20, 0x00, 0x20,
- 0x40, 0x00, 0x40, 0x00, 0x00, 0x80, 0x00, 0x01,
- 0x00, 0x01, 0x02, 0x01, 0x02, 0x00, 0x02, 0x04,
- 0x00, 0x04, 0x08, 0x00, 0x08, 0x10, 0x00, 0x10,
- 0x20, 0x00, 0x20, 0x40, 0x00, 0x00, 0x80, 0x00,
- 0x80, 0x00, 0x01, 0x00, 0x01, 0x02};
-static unsigned char ANSI34_BITS[] = {
- 0x01, 0x02, 0x04, 0x08, 0x00, 0x00, 0x00, 0x02,
- 0x04, 0x08, 0x10, 0x00, 0x00, 0x00, 0x04, 0x08,
- 0x10, 0x20, 0x00, 0x00, 0x00, 0x08, 0x10, 0x20,
- 0x40, 0x00, 0x00, 0x00, 0x10, 0x20, 0x40, 0x80,
- 0x00, 0x00, 0x00, 0x20, 0x40, 0x80, 0x00, 0x01,
- 0x00, 0x00, 0x40, 0x80, 0x00, 0x01, 0x02, 0x00,
- 0x00, 0x80, 0x00, 0x01, 0x02, 0x04, 0x00, 0x00,
- 0x00, 0x01, 0x02, 0x04, 0x08, 0x00, 0x00, 0x00,
- 0x02, 0x04, 0x08, 0x10, 0x00, 0x00, 0x00, 0x04,
- 0x08, 0x10, 0x20, 0x00, 0x00, 0x00, 0x08, 0x10,
- 0x20, 0x40, 0x00, 0x00, 0x00, 0x10, 0x20, 0x40,
- 0x80, 0x00, 0x00, 0x00, 0x20, 0x40, 0x80, 0x00,
- 0x01, 0x00, 0x00, 0x40, 0x80, 0x00, 0x01, 0x02,
- 0x00, 0x00, 0x80, 0x00, 0x01, 0x02, 0x04, 0x00,
- 0x00, 0x00, 0x01, 0x02, 0x04, 0x08, 0x00, 0x00,
- 0x00, 0x02, 0x04, 0x08, 0x10, 0x00, 0x00, 0x00,
- 0x04, 0x08, 0x10, 0x20, 0x00, 0x00, 0x00, 0x08,
- 0x10, 0x20, 0x40, 0x00, 0x00, 0x00, 0x10, 0x20,
- 0x40, 0x80, 0x00, 0x00, 0x00, 0x20, 0x40, 0x80,
- 0x00, 0x01, 0x00, 0x00, 0x40, 0x80, 0x00, 0x01,
- 0x02, 0x00, 0x00, 0x80, 0x00, 0x01, 0x02, 0x04,
- 0x00, 0x00, 0x00, 0x01, 0x02, 0x04, 0x08, 0x00,
- 0x00, 0x00, 0x02, 0x04, 0x08, 0x10, 0x00, 0x00,
- 0x00, 0x04, 0x08, 0x10, 0x20, 0x01, 0x00, 0x00,
- 0x08, 0x10, 0x20, 0x00, 0x02, 0x00, 0x00, 0x10,
- 0x20, 0x40, 0x00, 0x04, 0x00, 0x00, 0x20, 0x40,
- 0x80, 0x00, 0x08, 0x00, 0x00, 0x40, 0x80, 0x00,
- 0x01, 0x10, 0x00, 0x00, 0x80, 0x00, 0x01, 0x02,
- 0x20, 0x00, 0x00, 0x00, 0x01, 0x02, 0x04, 0x40,
- 0x00, 0x00, 0x00, 0x02, 0x04, 0x08, 0x80, 0x00,
- 0x00, 0x00, 0x04, 0x08, 0x10, 0x00, 0x01, 0x00,
- 0x00, 0x08, 0x10, 0x20, 0x01, 0x02, 0x00, 0x00,
- 0x10, 0x20, 0x00, 0x02, 0x04, 0x00, 0x00, 0x20,
- 0x40, 0x00, 0x04, 0x08, 0x00, 0x00, 0x40, 0x80,
- 0x00, 0x08, 0x10, 0x00, 0x00, 0x80, 0x00, 0x01,
- 0x10, 0x20, 0x00, 0x00, 0x00, 0x01, 0x02, 0x20,
- 0x40, 0x00, 0x00, 0x00, 0x02, 0x04, 0x40, 0x80,
- 0x00, 0x00, 0x00, 0x04, 0x08, 0x80, 0x00, 0x01,
- 0x00, 0x00, 0x08, 0x10, 0x00, 0x01, 0x02, 0x00,
- 0x00, 0x10, 0x20, 0x01, 0x02, 0x04, 0x00, 0x00,
- 0x20, 0x00, 0x02, 0x04, 0x08, 0x00, 0x00, 0x40,
- 0x00, 0x04, 0x08, 0x10, 0x00, 0x00, 0x80, 0x00,
- 0x08, 0x10, 0x20, 0x00, 0x00, 0x00, 0x01, 0x10,
- 0x20, 0x40, 0x00, 0x00, 0x00, 0x02, 0x20, 0x40,
- 0x80, 0x00, 0x00, 0x00, 0x04, 0x40, 0x80, 0x00,
- 0x01, 0x00, 0x00, 0x08, 0x80, 0x00, 0x01, 0x02,
- 0x00, 0x00, 0x10, 0x00, 0x01, 0x02, 0x04, 0x00,
- 0x00, 0x20};
-static unsigned char ANSI35_BITS[] = {
- 0x01, 0x02, 0x04, 0x08, 0x00, 0x02, 0x04, 0x08,
- 0x10, 0x00, 0x04, 0x08, 0x10, 0x20, 0x00, 0x08,
- 0x10, 0x20, 0x00, 0x00, 0x10, 0x20, 0x40, 0x00,
- 0x00, 0x20, 0x40, 0x80, 0x00, 0x01, 0x40, 0x80,
- 0x00, 0x01, 0x00, 0x80, 0x00, 0x01, 0x02, 0x04,
- 0x00, 0x01, 0x02, 0x04, 0x08, 0x01, 0x02, 0x04,
- 0x08, 0x00, 0x02, 0x04, 0x08, 0x10, 0x00, 0x04,
- 0x08, 0x10, 0x20, 0x00, 0x08, 0x10, 0x00, 0x40,
- 0x00, 0x10, 0x20, 0x00, 0x80, 0x00, 0x20, 0x40,
- 0x80, 0x00, 0x01, 0x40, 0x80, 0x00, 0x00, 0x02,
- 0x80, 0x00, 0x01, 0x02, 0x04, 0x00, 0x01, 0x02,
- 0x04, 0x08, 0x01, 0x02, 0x04, 0x08, 0x00, 0x02,
- 0x04, 0x08, 0x10, 0x00, 0x04, 0x08, 0x10, 0x20,
- 0x00, 0x08, 0x00, 0x20, 0x40, 0x00, 0x10, 0x00,
- 0x40, 0x80, 0x00, 0x20, 0x40, 0x80, 0x00, 0x01,
- 0x40, 0x00, 0x00, 0x01, 0x02, 0x80, 0x00, 0x01,
- 0x02, 0x04, 0x00, 0x01, 0x02, 0x04, 0x08, 0x01,
- 0x02, 0x04, 0x08, 0x00, 0x02, 0x04, 0x08, 0x10,
- 0x00, 0x04, 0x08, 0x10, 0x20, 0x00, 0x00, 0x10,
- 0x20, 0x40, 0x00, 0x00, 0x20, 0x40, 0x80, 0x00,
- 0x20, 0x40, 0x80, 0x00, 0x01, 0x00, 0x80, 0x00,
- 0x01, 0x02, 0x80, 0x00, 0x01, 0x02, 0x04, 0x00,
- 0x01, 0x02, 0x04, 0x08};
-static unsigned char ANSI36_BITS[] = {
- 0x01, 0x00, 0x02, 0x04, 0x04, 0x00, 0x08, 0x10,
- 0x10, 0x20, 0x20, 0x40, 0x40, 0x00, 0x80, 0x00,
- 0x00, 0x01, 0x00, 0x02, 0x02, 0x04, 0x00, 0x08,
- 0x08, 0x00, 0x10, 0x20, 0x20, 0x00};
-static unsigned char ANSI37_BITS[] = {
- 0x01, 0x00, 0x02, 0x01, 0x84, 0x00, 0x48, 0x00,
- 0x30, 0x00, 0x30, 0x00, 0x48, 0x00, 0x84, 0x00,
- 0x02, 0x01};
-static unsigned char ANSI38_BITS[] = {
- 0x01, 0x02, 0x00, 0x02, 0x05, 0x02, 0x84, 0x08,
- 0x01, 0x48, 0x10, 0x00, 0x30, 0x20, 0x00, 0x30,
- 0x40, 0x00, 0x48, 0x80, 0x00, 0x84, 0x00, 0x01,
- 0x00, 0x01, 0x02, 0x01, 0x02, 0x00, 0x02, 0x05,
- 0x00, 0x84, 0x08, 0x03, 0x48, 0x90, 0x00, 0x30,
- 0x60, 0x00, 0x30, 0x60, 0x00, 0x48, 0x90, 0x00,
- 0x84, 0x08, 0x01, 0x02, 0x01, 0x02};
-static unsigned char ACAD_ISO02W100_BITS[] = {
- 0xff, 0xff, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
-static unsigned char ACAD_ISO03W100_BITS[] = {
-static unsigned char ACAD_ISO04W100_BITS[] = {
- 0xff, 0xff, 0xff, 0xff, 0x1f, 0x02, 0x00, 0x00,
-static unsigned char ACAD_ISO05W100_BITS[] = {
- 0xff, 0xff, 0xff, 0xff, 0x1f, 0xc2, 0x00, 0x00,
-static unsigned char ACAD_ISO06W100_BITS[] = {
- 0xff, 0xff, 0xff, 0xff, 0x1f, 0x43, 0x18, 0x00,
-static unsigned char ACAD_ISO07W100_BITS[] = {
- 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
-static unsigned char ACAD_ISO08W100_BITS[] = {
- 0xff, 0xff, 0xff, 0xff, 0x1f, 0xfe, 0x07, 0x00,
-static unsigned char ACAD_ISO09W100_BITS[] = {
- 0xff, 0xff, 0xff, 0xff, 0x1f, 0xfe, 0xc7, 0xff,
-static unsigned char ACAD_ISO10W100_BITS[] = {
- 0xff, 0xff, 0x87, 0x00, 0x00, 0x00, 0x00, 0x00,
-static unsigned char ACAD_ISO11W100_BITS[] = {
- 0xff, 0xff, 0xc7, 0xff, 0xff, 0x61, 0x00, 0x00,
-static unsigned char ACAD_ISO12W100_BITS[] = {
- 0xff, 0xff, 0x87, 0x30, 0x00, 0x00, 0x00, 0x00,
-static unsigned char ACAD_ISO13W100_BITS[] = {
- 0xff, 0xff, 0x87, 0xff, 0xff, 0x63, 0x08, 0x00,
-static unsigned char ACAD_ISO14W100_BITS[] = {
- 0xff, 0xff, 0xc7, 0x10, 0x06, 0x00, 0x00, 0x00,
-static unsigned char ACAD_ISO15W100_BITS[] = {
- 0xff, 0xff, 0x87, 0xff, 0xff, 0x63, 0x0c, 0x01,
-// AutoCAD fill patterns defined as a series of line segments. The first element
-// in each array specifies the number of segments, and subsequent quads of
-// elements specify the line segment endpoints. These arrays were supplied to
-// us by the Actrix SWD team.
-// Removed..... we use bitmaps
-static unsigned char SHAPEFILL12_BITS[] = {0xff, 0xef, 0xff, 0xfe, 0xff, 0xef, 0xff, 0xfe};
-static unsigned char SHAPEFILL13_BITS[] = {0xff, 0xee, 0xff, 0xbb, 0xff, 0xee, 0xff, 0xbb};
-static unsigned char SHAPEFILL14_BITS[] = {0xee, 0xbb, 0xee, 0xbb, 0xee, 0xbb, 0xee, 0xbb};
-static unsigned char SHAPEFILL15_BITS[] = {0xaa, 0x55, 0xaa, 0x55, 0xaa, 0x55, 0xaa, 0x55};
-static unsigned char SHAPEFILL16_BITS[] = {0x44, 0x11, 0x44, 0x11, 0x44, 0x11, 0x44, 0x11};
-static unsigned char SHAPEFILL17_BITS[] = {0x00, 0x44, 0x00, 0x11, 0x00, 0x44, 0x00, 0x11};
-static unsigned char SHAPEFILL18_BITS[] = {0x00, 0x10, 0x00, 0x01, 0x00, 0x10, 0x00, 0x01};
-static unsigned char SHAPEFILL19_BITS[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff};
-static unsigned char SHAPEFILL20_BITS[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff};
-static unsigned char SHAPEFILL21_BITS[] = {0x00, 0x00, 0x00, 0xff, 0x00, 0x00, 0x00, 0xff};
-static unsigned char SHAPEFILL22_BITS[] = {0x00, 0x00, 0xff, 0xff, 0x00, 0x00, 0xff, 0xff};
-static unsigned char SHAPEFILL23_BITS[] = {0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff};
-static unsigned char SHAPEFILL24_BITS[] = {0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01};
-static unsigned char SHAPEFILL25_BITS[] = {0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03};
-static unsigned char SHAPEFILL26_BITS[] = {0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11};
-static unsigned char SHAPEFILL27_BITS[] = {0x33, 0x33, 0x33, 0x33, 0x33, 0x33, 0x33, 0x33};
-static unsigned char SHAPEFILL28_BITS[] = {0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55};
-static unsigned char SHAPEFILL29_BITS[] = {0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80};
-static unsigned char SHAPEFILL30_BITS[] = {0x81, 0x03, 0x06, 0x0c, 0x18, 0x30, 0x60, 0xc0};
-static unsigned char SHAPEFILL31_BITS[] = {0x11, 0x22, 0x44, 0x88, 0x11, 0x22, 0x44, 0x88};
-static unsigned char SHAPEFILL32_BITS[] = {0x99, 0x33, 0x66, 0xcc, 0x99, 0x33, 0x66, 0xcc};
-static unsigned char SHAPEFILL33_BITS[] = {0xee, 0xdd, 0xbb, 0x77, 0xee, 0xdd, 0xbb, 0x77};
-static unsigned char SHAPEFILL34_BITS[] = {0x80, 0x40, 0x20, 0x10, 0x08, 0x04, 0x02, 0x01};
-static unsigned char SHAPEFILL35_BITS[] = {0x81, 0xc0, 0x60, 0x30, 0x18, 0x0c, 0x06, 0x03};
-static unsigned char SHAPEFILL36_BITS[] = {0x88, 0x44, 0x22, 0x11, 0x88, 0x44, 0x22, 0x11};
-static unsigned char SHAPEFILL37_BITS[] = {0x99, 0xcc, 0x66, 0x33, 0x99, 0xcc, 0x66, 0x33};
-static unsigned char SHAPEFILL38_BITS[] = {0x77, 0xbb, 0xdd, 0xee, 0x77, 0xbb, 0xdd, 0xee};
-static unsigned char SHAPEFILL39_BITS[] = {0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0xff};
-static unsigned char SHAPEFILL40_BITS[] = {0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0xff, 0xff};
-static unsigned char SHAPEFILL41_BITS[] = {0x11, 0x11, 0x11, 0xff, 0x11, 0x11, 0x11, 0xff};
-static unsigned char SHAPEFILL42_BITS[] = {0x33, 0x33, 0xff, 0xff, 0x33, 0x33, 0xff, 0xff};
-static unsigned char SHAPEFILL43_BITS[] = {0x55, 0xff, 0x55, 0xff, 0x55, 0xff, 0x55, 0xff};
-static unsigned char SHAPEFILL44_BITS[] = {0x80, 0x41, 0x22, 0x14, 0x08, 0x14, 0x22, 0x41};
-static unsigned char SHAPEFILL45_BITS[] = {0x81, 0xc3, 0x66, 0x3c, 0x18, 0x3c, 0x66, 0xc3};
-static unsigned char SHAPEFILL46_BITS[] = {0x88, 0x55, 0x22, 0x55, 0x88, 0x55, 0x22, 0x55};
-static unsigned char SHAPEFILL47_BITS[] = {0xcc, 0xcc, 0x33, 0x33, 0xcc, 0xcc, 0x33, 0x33};
-static unsigned char SHAPEFILL48_BITS[] = {0xb1, 0x30, 0x03, 0x1b, 0xd8, 0xc0, 0x0c, 0x8d};
-static unsigned char SHAPEFILL49_BITS[] = {0x20, 0x02, 0x10, 0x80, 0x04, 0x40, 0x08, 0x01};
-static unsigned char SHAPEFILL50_BITS[] = {0x00, 0x55, 0x00, 0x55, 0x00, 0x55, 0x00, 0x55};
-static unsigned char SHAPEFILL51_BITS[] = {0x00, 0x10, 0x20, 0x40, 0x00, 0x04, 0x02, 0x01};
-static unsigned char SHAPEFILL52_BITS[] = {0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x01};
-static unsigned char SHAPEFILL53_BITS[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01};
-static unsigned char SHAPEFILL54_BITS[] = {0x80, 0x80, 0x80, 0x41, 0x22, 0x9c, 0x22, 0x41};
-static unsigned char SHAPEFILL55_BITS[] = {0x8e, 0x44, 0xe8, 0xf1, 0xe2, 0x44, 0x2e, 0x1f};
-static unsigned char SHAPEFILL56_BITS[] = {0x20, 0x20, 0x50, 0xaa, 0x02, 0x02, 0x05, 0xaa};
-static unsigned char SHAPEFILL57_BITS[] = {0x40, 0xa0, 0x11, 0x11, 0x11, 0x11, 0x0a, 0x04};
-static unsigned char SHAPEFILL58_BITS[] = {0x0d, 0x0d, 0x0d, 0x0d, 0xfd, 0xfd, 0x00, 0xfd};
-static unsigned char SHAPEFILL59_BITS[] = {0x10, 0x10, 0x10, 0xff, 0x01, 0x01, 0x01, 0xff};
-static unsigned char SHAPEFILL60_BITS[] = {0x00, 0x01, 0x00, 0x11, 0x00, 0x01, 0x00, 0x55};
-static unsigned char SHAPEFILL61_BITS[] = {0x20, 0x40, 0x80, 0x01, 0x83, 0x44, 0x38, 0x10};
-static unsigned char SHAPEFILL62_BITS[] = {0x00, 0x55, 0x00, 0x11, 0x82, 0x44, 0x28, 0x11};
-static unsigned char SHAPEFILL63_BITS[] = {0x00, 0x00, 0x50, 0x20, 0x00, 0x00, 0x05, 0x02};
-static unsigned char SHAPEFILL64_BITS[] = {0x80, 0x80, 0x40, 0x30, 0x0c, 0x12, 0x21, 0xc0};
-static unsigned char SHAPEFILL65_BITS[] = {0xc7, 0x28, 0x10, 0x10, 0x7c, 0x82, 0x01, 0x01};
-static unsigned char SHAPEFILL66_BITS[] = {0x10, 0x20, 0x40, 0xff, 0x55, 0x2a, 0x04, 0x08};
-static unsigned char SHAPEFILL67_BITS[] = {0x1f, 0x1f, 0x19, 0xee, 0xf1, 0xf1, 0x91, 0xee};
-static unsigned char SHAPEFILL68_BITS[] = {0x10, 0x28, 0x54, 0xaa, 0x54, 0x28, 0x10, 0x00};
-static unsigned char SHAPEFILL69_BITS[] = {0x22, 0x49, 0x9c, 0x39, 0x92, 0x44, 0x28, 0x14};
-static unsigned char SHAPEFILL70_BITS[] = {0x00, 0x06, 0x06, 0x06, 0x00, 0x60, 0x60, 0x60};
-static unsigned char SHAPEFILL71_BITS[] = {0x8f, 0x88, 0x88, 0x88, 0xf8, 0x88, 0x88, 0x88};
-// fill pattern definitions (bit patterns and segments)
-struct FillPattern
- int m_width; // width of the pattern in pixels
- int m_height; // height of the pattern in pixels
- unsigned char* m_bits;// pointer to the pixel pattern array
-static FillPattern s_fillPattern[] = {
- { 8, 8, NONE_BITS}, // none
- { 8, 8, SOLID_BITS}, // solid
- { 8, 8, SHAPEFILL14_BITS}, // hatch
- { 8, 8, SHAPEFILL19_BITS}, // horizontal shapefill19
- { 8, 8, SHAPEFILL24_BITS}, // vertical shapefill24
- { 8, 8, SHAPEFILL29_BITS}, // diagonal45 shapefill29
- { 8, 8, SHAPEFILL34_BITS}, // diagonal135 shapefill34
- { 8, 8, SHAPEFILL39_BITS}, // cross shapefill39
- { 8, 8, SHAPEFILL44_BITS}, // diagonalcross shapefill44
- { 10, 10, ANGLE_BITS},
- { 25, 25, BOX_BITS},
- { 10, 13, BRASS_BITS},
- { 17, 17, BRICK_BITS},
- { 36, 24, BRSTONE_BITS},
- { 20, 12, CLAY_BITS},
- { 32, 32, CORK_BITS},
- { 24, 24, CROSS_BITS},
- { 12, 12, DASH_BITS},
- { 96, 96, DOLMIT_BITS},
- { 8, 16, DOTS_BITS},
- { 44, 44, EARTH_BITS},
- { 30, 53, ESCHER_BITS},
- { 20, 10, FLEX_BITS},
- { 36, 36, GRASS_BITS},
- { 19, 5, GRATE_BITS},
- { 35, 20, HEX_BITS},
- { 18, 10, HONEY_BITS},
- {152, 152, HOUND_BITS},
- { 8, 12, INSUL_BITS},
- { 32, 16, MUDST_BITS},
- { 10, 16, NET3_BITS},
- { 16, 16, PLAST_BITS},
- { 16, 16, PLASTI_BITS},
- { 10, 10, SACNCR_BITS},
- { 8, 8, SQUARE_BITS},
- { 24, 42, STARS_BITS},
- { 14, 14, STEEL_BITS},
- { 58, 100, SWAMP_BITS},
- { 8, 8, TRANS_BITS},
- { 20, 36, TRIANG_BITS},
- { 16, 16, ZIGZAG_BITS},
- { 20, 20, AR_B816_BITS},
- { 20, 20, AR_B816C_BITS},
- { 10, 20, AR_B88_BITS},
- { 36, 24, AR_BRELM_BITS},
- { 36, 24, AR_BRSTD_BITS},
- { 64, 64, AR_CONC_BITS},
- { 24, 12, AR_HBONE_BITS},
- { 60, 60, AR_PARQ1_BITS},
- {288, 100, AR_RROOF_BITS},
- {100, 288, AR_RROOF_90_BITS},
- { 57, 80, AR_RSHKE_BITS},
- { 80, 57, AR_RSHKE_90_BITS},
- { 57, 80, AR_RSHKE_180_BITS},
- { 80, 57, AR_RSHKE_270_BITS},
- {100, 18, AR_SAND_BITS},
- { 9, 9, ANSI31_BITS},
- { 27, 27, ANSI32_BITS},
- { 18, 18, ANSI33_BITS},
- { 54, 54, ANSI34_BITS},
- { 36, 36, ANSI35_BITS},
- { 15, 15, ANSI36_BITS},
- { 9, 9, ANSI37_BITS},
- { 18, 18, ANSI38_BITS},
- { 23, 8, ACAD_ISO02W100_BITS},
- { 45, 8, ACAD_ISO03W100_BITS},
- { 46, 8, ACAD_ISO04W100_BITS},
- { 51, 8, ACAD_ISO05W100_BITS},
- { 56, 8, ACAD_ISO06W100_BITS},
- { 5, 8, ACAD_ISO07W100_BITS},
- { 54, 8, ACAD_ISO08W100_BITS},
- { 68, 8, ACAD_ISO09W100_BITS},
- { 28, 8, ACAD_ISO10W100_BITS},
- { 50, 8, ACAD_ISO11W100_BITS},
- { 33, 8, ACAD_ISO12W100_BITS},
- { 56, 8, ACAD_ISO13W100_BITS},
- { 38, 8, ACAD_ISO14W100_BITS},
- { 61, 8, ACAD_ISO15W100_BITS},
- { 8, 8, SHAPEFILL12_BITS},
- { 8, 8, SHAPEFILL13_BITS},
- { 8, 8, SHAPEFILL15_BITS},
- { 8, 8, SHAPEFILL16_BITS},
- { 8, 8, SHAPEFILL17_BITS},
- { 8, 8, SHAPEFILL18_BITS},
- { 8, 8, SHAPEFILL19_BITS}, // duplicates Horizontal hatch
- { 8, 8, SHAPEFILL20_BITS},
- { 8, 8, SHAPEFILL21_BITS},
- { 8, 8, SHAPEFILL22_BITS},
- { 8, 8, SHAPEFILL23_BITS},
- { 8, 8, SHAPEFILL24_BITS}, // duplicates Vertical hatch
- { 8, 8, SHAPEFILL25_BITS},
- { 8, 8, SHAPEFILL26_BITS},
- { 8, 8, SHAPEFILL27_BITS},
- { 8, 8, SHAPEFILL28_BITS},
- { 8, 8, SHAPEFILL29_BITS}, // duplicate Diagonal45 hatch
- { 8, 8, SHAPEFILL30_BITS},
- { 8, 8, SHAPEFILL31_BITS},
- { 8, 8, SHAPEFILL32_BITS},
- { 8, 8, SHAPEFILL33_BITS},
- { 8, 8, SHAPEFILL34_BITS}, // duplicate Diagonal135 hatch
- { 8, 8, SHAPEFILL35_BITS},
- { 8, 8, SHAPEFILL36_BITS},
- { 8, 8, SHAPEFILL37_BITS},
- { 8, 8, SHAPEFILL38_BITS},
- { 8, 8, SHAPEFILL39_BITS}, // duplicate Cross hatch
- { 8, 8, SHAPEFILL40_BITS},
- { 8, 8, SHAPEFILL41_BITS},
- { 8, 8, SHAPEFILL42_BITS},
- { 8, 8, SHAPEFILL43_BITS},
- { 8, 8, SHAPEFILL44_BITS}, // duplicate DiagonalCross hatch
- { 8, 8, SHAPEFILL45_BITS},
- { 8, 8, SHAPEFILL46_BITS},
- { 8, 8, SHAPEFILL47_BITS},
- { 8, 8, SHAPEFILL48_BITS},
- { 8, 8, SHAPEFILL49_BITS},
- { 8, 8, SHAPEFILL50_BITS},
- { 8, 8, SHAPEFILL51_BITS},
- { 8, 8, SHAPEFILL52_BITS},
- { 8, 8, SHAPEFILL53_BITS},
- { 8, 8, SHAPEFILL54_BITS},
- { 8, 8, SHAPEFILL55_BITS},
- { 8, 8, SHAPEFILL56_BITS},
- { 8, 8, SHAPEFILL57_BITS},
- { 8, 8, SHAPEFILL58_BITS},
- { 8, 8, SHAPEFILL59_BITS},
- { 8, 8, SHAPEFILL60_BITS},
- { 8, 8, SHAPEFILL61_BITS},
- { 8, 8, SHAPEFILL62_BITS},
- { 8, 8, SHAPEFILL63_BITS},
- { 8, 8, SHAPEFILL64_BITS},
- { 8, 8, SHAPEFILL65_BITS},
- { 8, 8, SHAPEFILL66_BITS},
- { 8, 8, SHAPEFILL67_BITS},
- { 8, 8, SHAPEFILL68_BITS},
- { 8, 8, SHAPEFILL69_BITS},
- { 8, 8, SHAPEFILL70_BITS},
- { 8, 8, SHAPEFILL71_BITS}
-static wchar_t* fillPatternNames[] = {
- L"None",
- L"Solid",
- L"Square",
- L"Line",
- L"Line_90",
- L"Line_45",
- L"Line_135",
- L"Net",
- L"Net_45",
- L"ANGLE",
- L"BOX",
- L"BRASS",
- L"BRICK",
- L"BRSTONE",
- L"CLAY",
- L"CORK",
- L"CROSS",
- L"DASH",
- L"DOLMIT",
- L"DOTS",
- L"EARTH",
- L"ESCHER",
- L"FLEX",
- L"GRASS",
- L"GRATE",
- L"HEX",
- L"HONEY",
- L"HOUND",
- L"INSUL",
- L"MUDST",
- L"NET3",
- L"PLAST",
- L"PLASTI",
- L"SACNCR",
- L"SQUARE",
- L"STARS",
- L"STEEL",
- L"SWAMP",
- L"TRANS",
- L"TRIANG",
- L"ZIGZAG",
- L"AR_B816",
- L"AR_B816C",
- L"AR_B88",
- L"AR_BRELM",
- L"AR_BRSTD",
- L"AR_CONC",
- L"AR_HBONE",
- L"AR_PARQ1",
- L"AR_RROOF",
- L"AR_RROOF_90",
- L"AR_RSHKE",
- L"AR_RSHKE_90",
- L"AR_RSHKE_180",
- L"AR_RSHKE_270",
- L"AR_SAND",
- L"ANSI31",
- L"ANSI32",
- L"ANSI33",
- L"ANSI34",
- L"ANSI35",
- L"ANSI36",
- L"ANSI37",
- L"ANSI38",
- L"ACAD_ISO02W100",
- L"ACAD_ISO03W100",
- L"ACAD_ISO04W100",
- L"ACAD_ISO05W100",
- L"ACAD_ISO06W100",
- L"ACAD_ISO07W100",
- L"ACAD_ISO08W100",
- L"ACAD_ISO09W100",
- L"ACAD_ISO10W100",
- L"ACAD_ISO11W100",
- L"ACAD_ISO12W100",
- L"ACAD_ISO13W100",
- L"ACAD_ISO14W100",
- L"ACAD_ISO15W100",
- L"ShapeFill12",
- L"ShapeFill13",
- L"ShapeFill14",
- L"ShapeFill15",
- L"ShapeFill16",
- L"ShapeFill17",
- L"ShapeFill18",
- L"ShapeFill19",
- L"ShapeFill20",
- L"ShapeFill21",
- L"ShapeFill22",
- L"ShapeFill23",
- L"ShapeFill24",
- L"ShapeFill25",
- L"ShapeFill26",
- L"ShapeFill27",
- L"ShapeFill28",
- L"ShapeFill29",
- L"ShapeFill30",
- L"ShapeFill31",
- L"ShapeFill32",
- L"ShapeFill33",
- L"ShapeFill34",
- L"ShapeFill35",
- L"ShapeFill36",
- L"ShapeFill37",
- L"ShapeFill38",
- L"ShapeFill39",
- L"ShapeFill40",
- L"ShapeFill41",
- L"ShapeFill42",
- L"ShapeFill43",
- L"ShapeFill44",
- L"ShapeFill45",
- L"ShapeFill46",
- L"ShapeFill47",
- L"ShapeFill48",
- L"ShapeFill49",
- L"ShapeFill50",
- L"ShapeFill51",
- L"ShapeFill52",
- L"ShapeFill53",
- L"ShapeFill54",
- L"ShapeFill55",
- L"ShapeFill56",
- L"ShapeFill57",
- L"ShapeFill58",
- L"ShapeFill59",
- L"ShapeFill60",
- L"ShapeFill61",
- L"ShapeFill62",
- L"ShapeFill63",
- L"ShapeFill64",
- L"ShapeFill65",
- L"ShapeFill66",
- L"ShapeFill67",
- L"ShapeFill68",
- L"ShapeFill69",
- L"ShapeFill70",
- L"ShapeFill71"
-gdImagePtr GDFillPatterns::CreatePatternBitmap(const wchar_t* name, int fgColor, int bgColor)
- int index = 1; //Solid by default
- //find the index
- for (int i=0; i<sizeof(fillPatternNames) / sizeof(wchar_t*); i++)
- if (_wcsicmp(name, fillPatternNames[i]) == 0)
- index = i;
- break;
- FillPattern fp = s_fillPattern[index];
- gdImagePtr ret = gdImageCreateTrueColor(fp.m_width, fp.m_height);
- gdImageAlphaBlending(ret, 0);
- for (int row=0; row<fp.m_height; row++)
- for (int col=0; col < fp.m_width; col++)
- int bytesPerRow = (fp.m_width + 7) / 8;
- int baseIndex = (fp.m_height - row - 1) * bytesPerRow;
- int byteIndex = baseIndex + col / 8;
- int bitIndex = col % 8;
- if ((fp.m_bits[byteIndex] & 0x01 << bitIndex) != 0)
- gdImageSetPixel(ret, col, row, fgColor);
- else
- gdImageSetPixel(ret, col, row, bgColor);
- gdImageAlphaBlending(ret, 1);
- return ret;
Deleted: trunk/MgDev/Common/Renderers/GDFillPatterns.h
--- trunk/MgDev/Common/Renderers/GDFillPatterns.h 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Common/Renderers/GDFillPatterns.h 2019-06-22 08:42:36 UTC (rev 9559)
@@ -1,29 +0,0 @@
-// Copyright (C) 2004-2011 by Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-#ifndef GDFILLPATTERNS_H
-#define GDFILLPATTERNS_H
-#include "gd.h"
-class GDFillPatterns
-public:
- static gdImagePtr CreatePatternBitmap(const wchar_t* name, int fgColor, int bgColor);
-#endif
Deleted: trunk/MgDev/Common/Renderers/GDRenderer.cpp
--- trunk/MgDev/Common/Renderers/GDRenderer.cpp 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Common/Renderers/GDRenderer.cpp 2019-06-22 08:42:36 UTC (rev 9559)
@@ -1,2703 +0,0 @@
-#include "stdafx.h"
-#include "GDRenderer.h"
-#include "LineStyle.h"
-#include "SLDSymbols.h"
-#include "LineStyleDef.h"
-#include "dwfcore/File.h"
-#include "dwfcore/String.h"
-#include "dwfcore/Exception.h"
-#include "dwfcore/MIME.h"
-#include "dwfcore/StreamFileDescriptor.h"
-#include "dwfcore/InputStream.h"
-#include "dwfcore/FileInputStream.h"
-#include "dwfcore/BufferOutputStream.h"
-#include "dwfcore/BufferInputStream.h"
-#include "dwf/Version.h"
-#include "dwf/package/Constants.h"
-#include "dwf/package/Manifest.h"
-#include "dwf/package/EPlotSection.h"
-#include "dwf/package/GlobalSection.h"
-#include "dwf/package/DefinedObject.h"
-#include "dwf/package/writer/PackageWriter.h"
-#include "dwf/package/reader/PackageReader.h"
-//GD headers
-#include "gd.h"
-#include "FontManager.h"
-#include "GDUtils.h"
-#include "GDFillPatterns.h"
-#include "GDW2DRewriter.h"
-#include "DWFRSInputStream.h"
-#include "RSDWFInputStream.h"
-#include "LabelRenderer.h"
-#include "LabelRendererLocal.h"
-#include "complex_polygon_gd.h"
-#include "SymbolTrans.h"
-#include "RenderUtil.h"
-#include "SE_SymbolDefProxies.h"
-using namespace DWFToolkit;
-using namespace DWFCore;
-#define ROUND(x) (int)(floor(x+0.5))
-#define SYMBOL_BITMAP_SIZE 128
-#define SYMBOL_BITMAP_MAX 1024
-// maximum allowed size for images
-#define IMAGE_SIZE_MAX 2048.0*2048.0
-// Dummy class used to automate initialization/uninitialization of GD.
-class CInitGD
-public:
- CInitGD()
- // initialize font cache
- gdFontCacheSetup();
- ~CInitGD()
- // free GD resources
- gdFontCacheShutdown();
-static CInitGD sg_InitGD;
-bool GDRenderer::s_bGeneralizeData = false;
-//default constructor
-GDRenderer::GDRenderer(int width,
- int height,
- RS_Color& bgColor,
- bool requiresClipping,
- bool localOverposting,
- double tileExtentOffset)
-m_width(width),
-m_height(height),
-m_bgcolor(bgColor),
-m_extents(0.0, 0.0, 0.0, 0.0),
-m_wtPointBuffer(NULL),
-m_wtPointLen(0),
-m_symbolManager(NULL),
-m_mapInfo(NULL),
-m_layerInfo(NULL),
-m_featureClassInfo(NULL),
-m_bRequiresClipping(requiresClipping),
-m_bIsSymbolW2D(false),
-m_bHaveViewport(false),
-m_imsym(NULL),
-m_input(NULL),
-m_xformer()
- if (m_width <= 0)
- m_width = 1;
- if (m_height <= 0)
- m_height = 1;
- //set max line width to the screen diagonal
- m_maxLineWidth = (int)(0.5 + sqrt((double)(m_width * m_width + m_height * m_height)));
- gdImagePtr img = gdImageCreateTrueColor(m_width, m_height);
- m_imout = img;
- int bgc = ConvertColor(img, bgColor);
- // initialize the image to the supplied color (temporarily turn
- // off alpha blending so the fill has the supplied alpha)
- gdImageAlphaBlending(img, 0);
- gdImageFilledRectangle(img, 0, 0, gdImageSX(img)-1, gdImageSY(img)-1, bgc);
- gdImageAlphaBlending(img, 1);
- // set any transparent color
- if (bgColor.alpha() != 255)
- gdImageColorTransparent(img, bgc);
- if (!localOverposting)
- m_labeler = new LabelRenderer(this);
- else
- m_labeler = new LabelRendererLocal(this, tileExtentOffset);
- m_polyrasterizer = new complex_polygon_gd();
-GDRenderer::~GDRenderer()
- gdImageDestroy((gdImagePtr)m_imout);
- if (m_imsym)
- gdImageDestroy((gdImagePtr)m_imsym);
- delete [] m_wtPointBuffer;
- delete m_labeler;
- delete m_polyrasterizer;
-void GDRenderer::Save(const RS_String& filename, const RS_String& format)
- Save(filename, format, m_width, m_height);
-void GDRenderer::Save(const RS_String& filename, const RS_String& format, int width, int height)
- //get the in-memory image stream
- auto_ptr<RS_ByteData> data;
- data.reset(Save(format, width, height));
- if (NULL == data.get())
- return;
- //We write to a file to avoid sending a FILE* across DLL
- //boundary, which is not always safe.
- //TODO: take care of this string conversion -- shouldn't matter
- //since it is only a temp file name anyway, and they are ascii
- char mbfilename[1024];
- wcstombs(mbfilename, filename.c_str(), 1024);
- FILE* out = fopen(mbfilename, "wb");
- _ASSERT(out);
- if (out)
- unsigned char* bytes = data->GetBytes();
- unsigned int numBytes = data->GetNumBytes();
- if (fwrite(bytes, 1, numBytes, out) != numBytes)
- _ASSERT(false);
- fclose(out);
-RS_ByteData* GDRenderer::Save(const RS_String& format, int width, int height)
- gdImagePtr im = NULL;
- if (width <= 0)
- width = 1;
- if (height <= 0)
- height = 1;
- //do we need to stretch to non-square pixels?
- if (width != m_width || height != m_height || format == L"PNG8")
- if(format == L"PNG8")
- im = gdImageCreate(width, height);
- else
- im = gdImageCreateTrueColor(width, height);
- int bgc = ConvertColor(im, m_bgcolor);
- // initialize the destination image to the bg color (temporarily turn
- gdImageAlphaBlending(im, 0);
- gdImageFilledRectangle(im, 0, 0, gdImageSX(im)-1, gdImageSY(im)-1, bgc);
- if (m_bgcolor.alpha() != 255)
- gdImageColorTransparent(im, bgc);
- gdImageCopyResized(im, (gdImagePtr)m_imout, 0, 0, 0, 0, width, height, m_width, m_height);
- gdImageAlphaBlending(im, 1);
- else
- im = (gdImagePtr)m_imout;
- // Make output image non-interlaced --- it's a little faster to compress that way.
- gdImageInterlace(im, 0);
- // Make sure the alpha values get saved -- but only if required
- // it is faster not to save them and makes a smaller PNG
- gdImageSaveAlpha(im, 1);
- else
- gdImageSaveAlpha(im, 0);
- //get an in-memory image stream
- int size = 0;
- unsigned char* data = NULL;
- // TODO: Tiff
- if (format == L"GIF") // MgImageFormats::Gif
- data = (unsigned char*)gdImageGifPtr(im, &size);
- else if (format == L"JPG") // MgImageFormats::Jpeg
- data = (unsigned char*)gdImageJpegPtr(im, &size, 75);
-// else if (format == L"TIF") // MgImageFormats::Tiff
-// data = (unsigned char*)gdImageTiffPtr(im, &size);
- else if (format == L"PNG"
- || format == L"PNG8") // MgImageFormats::Png || MgImageFormats::Png8
- data = (unsigned char*)gdImagePngPtr(im, &size);
- else // PNG is the default
- auto_ptr<RS_ByteData> byteData;
- byteData.reset((NULL == data)? NULL : new RS_ByteData(data, size));
- gdFree(data);
- //if we allocated a temporary image to stretch-blit, destroy it
- if (im != m_imout)
- gdImageDestroy(im);
- return byteData.release();
-void GDRenderer::Combine(const RS_String& fileIn1, const RS_String& fileIn2, const RS_String& fileOut)
- char mbfileIn1[1024];
- char mbfileIn2[1024];
- char mbfileOut[1024];
- wcstombs(mbfileIn1, fileIn1.c_str(), 1024);
- wcstombs(mbfileIn2, fileIn2.c_str(), 1024);
- wcstombs(mbfileOut, fileOut.c_str(), 1024);
- // read in the images
- FILE* fIn1 = fopen(mbfileIn1, "rb");
- FILE* fIn2 = fopen(mbfileIn2, "rb");
- gdImagePtr img1 = gdImageCreateFromPng(fIn1);
- gdImagePtr img2 = gdImageCreateFromPng(fIn2);
- fclose(fIn1);
- fclose(fIn2);
- // composite the 2nd image onto the 1st
- gdImageSetTile(img1, img2);
- gdImageFilledRectangle(img1, 0, 0, gdImageSX(img1)-1, gdImageSY(img1)-1, gdTiled);
- gdImageSaveAlpha(img1, 1);
- // save the merged image
- FILE* out = fopen(mbfileOut, "wb");
- gdImagePng(img1, out);
- fclose(out);
- // clean up
- gdImageDestroy(img1);
- gdImageDestroy(img2);
-void GDRenderer::StartMap(RS_MapUIInfo* mapInfo,
- RS_Bounds& extents,
- double mapScale,
- double dpi,
- double metersPerUnit,
- CSysTransformer* /*xformToLL*/)
- m_mapScale = mapScale;
- m_dpi = dpi;
- m_metersPerUnit = metersPerUnit;
- m_extents = extents;
- //compute drawing scale
- //drawing scale is map scale converted to [mapping units] / [pixels]
- double metersPerPixel = METERS_PER_INCH / m_dpi;
- m_drawingScale = m_mapScale * metersPerPixel / m_metersPerUnit;
- //find scale used to convert to pixel coordinates
- //need to take aspect ratios into account
- double arDisplay = (double)m_width / (double)m_height;
- double arMap = m_extents.width() / m_extents.height();
- if (arDisplay > arMap)
- m_scale = (double)m_height / m_extents.height();
- else
- m_scale = (double)m_width / m_extents.width();
- m_invScale = 1.0 / m_scale;
- m_offsetX = m_extents.minx;
- m_offsetY = m_extents.miny;
- m_labeler->StartLabels();
- // remember the map info
- m_mapInfo = mapInfo;
- // make sure that the mapInfo is in sync with the background member variable
- if (m_mapInfo)
- m_mapInfo->bgcolor() = this->m_bgcolor;
- // do it here, since we will need the renderer's map scales, which are computed above
- InitFontEngine(this);
-void GDRenderer::EndMap()
- // turn off selection mode so the labels draw normal
- SetRenderSelectionMode(false);
- // finally draw all the labels
- m_labeler->BlastLabels();
- // clear the map info
- m_mapInfo = NULL;
-void GDRenderer::StartLayer(RS_LayerUIInfo* layerInfo,
- RS_FeatureClassInfo* classInfo)
- // remember the layer/feature info
- m_layerInfo = layerInfo;
- m_featureClassInfo = classInfo;
-void GDRenderer::EndLayer()
- // clear the layer/feature info
- m_layerInfo = NULL;
- m_featureClassInfo = NULL;
-void GDRenderer::StartFeature(RS_FeatureReader* /*feature*/,
- bool /*initialPass*/,
- const RS_String* /*tooltip*/,
- const RS_String* /*url*/,
- const RS_String* /*theme*/,
- double /*zOffset*/,
- double /*zExtrusion*/,
- RS_ElevationType /*zOffsetType*/)
-void GDRenderer::ProcessPolygon(LineBuffer* lb, RS_FillStyle& fill)
- _ASSERT(NULL != lb);
- RS_FillStyle* use_fill = &fill;
- //should we use selection style?
- if (m_bSelectionMode)
- use_fill = &m_selFill;
- if (lb->point_count() == 0)
- return;
- //render any polygon fill
- if (use_fill->color().alpha() != 0)
- _TransformPointsNoClamp(lb);
- int gdc = ConvertColor((gdImagePtr)m_imout, use_fill->color());
- int gdcbg = ConvertColor((gdImagePtr)m_imout, use_fill->background());
- gdImagePtr fillpat = NULL;
- if (wcscmp(use_fill->pattern().c_str(), L"Solid") != 0)
- fillpat = GDFillPatterns::CreatePatternBitmap(use_fill->pattern().c_str(), gdc, gdcbg);
- gdImageSetTile((gdImagePtr)m_imout, fillpat);
- //call the new rasterizer
- m_polyrasterizer->FillPolygon((Point*)m_wtPointBuffer, lb->point_count(), lb->cntrs(), lb->cntr_count(),
- fillpat? gdTiled : gdc, (gdImagePtr)m_imout);
- if (fillpat)
- gdImageSetTile((gdImagePtr)m_imout, NULL);
- gdImageDestroy(fillpat);
- //render any polygon outline
- RS_LineStroke& use_lsym = use_fill->outline();
- if (use_lsym.color().alpha() == 0)
- return;
- LineBuffer* workbuffer = lb;
- std::unique_ptr<LineBuffer> spLB;
- if (s_bGeneralizeData)
- if (workbuffer->point_count() > 6)
- LineBuffer* optbuffer = workbuffer->Optimize(m_drawingScale, m_pPool);
- if (optbuffer)
- workbuffer = optbuffer;
- spLB.reset(workbuffer);
- //apply line style if needed
- if ((wcscmp(use_lsym.style().c_str(), L"Solid") != 0))
- //TODO: we should simplify the math that does all that pixel-based stuff
- LineBuffer* newbuffer = ApplyLineStyle(workbuffer, (wchar_t*)use_lsym.style().c_str(),
- use_lsym.width() * m_dpi / METERS_PER_INCH, // LineStyle works in pixels
- m_drawingScale, // pixels per map unit
- m_dpi); // dpi
- if (newbuffer)
- if (spLB.get())
- LineBufferPool::FreeLineBuffer(m_pPool, spLB.release());
- workbuffer = newbuffer;
- if (workbuffer)
- WritePolylines(workbuffer, use_lsym, true);
- if (spLB.get())
-void GDRenderer::ProcessPolyline(LineBuffer* lb, RS_LineStroke& lsym)
- RS_LineStroke* use_lsym = &lsym;
- //are we drawing a selection?
- use_lsym = &(m_selFill.outline());
- return;
- //render any polyline outline
- if (use_lsym->color().alpha() == 0)
- return;
- if (optbuffer)
- if ((wcscmp(use_lsym->style().c_str(), L"Solid") != 0))
- LineBuffer* newbuffer = ApplyLineStyle(workbuffer, (wchar_t*)use_lsym->style().c_str(),
- use_lsym->width() * m_dpi / METERS_PER_INCH, // LineStyle works in pixels
- m_dpi); // dpi
- if (newbuffer)
- if (spLB.get())
- if (workbuffer)
- WritePolylines(workbuffer, *use_lsym, true);
- if (spLB.get())
-void GDRenderer::ProcessRaster(unsigned char* data,
- int length,
- RS_ImageFormat format,
- int width, int height,
- TransformMesh* /*xformMesh*/)
- // TODO: use xformMesh and call AGGRenderer::DrawScreenRasterTransformed
- double cx = 0.5 * (extents.minx + extents.maxx);
- double cy = 0.5 * (extents.miny + extents.maxy);
- WorldToScreenPoint(cx, cy, cx, cy);
- //pass to the screen space render function
- DrawScreenRaster(data, length, format, width, height, cx, cy, extents.width() * m_scale, extents.height() * m_scale, 0.0);
-void GDRenderer::ProcessMarker(LineBuffer* srclb, RS_MarkerDef& mdef, bool allowOverpost, RS_Bounds* bounds)
- RS_MarkerDef use_mdef = mdef;
- //use the selection style to draw
- use_mdef = RS_MarkerDef(RS_MarkerType_Marker,
- mdef.width(),
- mdef.height(),
- mdef.insx(), mdef.insy(),
- mdef.rotation(),
- mdef.units(),
- SLDType_Square,
- L"", L"",
- m_selFill);
- for (int i=0; i<srclb->point_count(); i++)
- //if marker is processed from here it should be added to the
- //feature W2D, not the labeling W2D -- need the API to reflect that.
- ProcessOneMarker(srclb->x_coord(i), srclb->y_coord(i), use_mdef, allowOverpost, (i==0)? bounds : NULL);
-void GDRenderer::ProcessOneMarker(double x, double y, RS_MarkerDef& mdef, bool allowOverpost, RS_Bounds* bounds)
- RS_InputStream* symbol = NULL;
- //attempt to retrieve the symbol
- if (m_symbolManager && (mdef.type() == RS_MarkerType_W2D))
- // BOGUS:
- // We need to pass in "symbols" as the name of the data for the
- // symbol library resource. This is hardcoded right now.
- // If it ever changes, we will need to update it
- symbol = (RS_InputStream*)m_symbolManager->GetSymbolData(mdef.library().c_str(), L"symbols.dwf");
- //symbol in mapping space units
- double iw = _MeterToMapSize(mdef.units(), mdef.width());
- double ih = _MeterToMapSize(mdef.units(), mdef.height());
- //unrotated symbol bounding box (mapping space)
- RS_Bounds dst(x, y, x+iw, y+ih);
- //convert to pixel size
- iw *= m_scale;
- ih *= m_scale;
- //if it's too big, make it smaller
- //it cannot be too big since we allocate iw * ih * 4 bytes of
- //memory to cache the symbol image -- this code simply truncates
- //the size, ignoring changes in aspect ratio
- const double MAX_SIZE = 4096.0;
- if (iw > MAX_SIZE)
- iw = MAX_SIZE;
- dst.maxx = dst.minx + iw / m_scale;
- if (ih > MAX_SIZE)
- ih = MAX_SIZE;
- dst.maxy = dst.miny + ih / m_scale;
- int devwidth = ROUND(iw);
- int devheight = ROUND(ih);
- //get insertion point
- double refX = mdef.insx();
- double refY = mdef.insy();
- //rotation angle
- double angleRad = mdef.rotation() * M_PI180;
- if (mdef.type() == RS_MarkerType_Font)
- //case where we are using a font symbol
- // TODO: cannot easily check for font symbol repetition
- // since we forward to the labeling logic...
- // check to see if the last symbol we got was the same
-// if ( mdef.type() != m_lastSymbol.type()
-// || mdef.height() != m_lastSymbol.height()
-// || mdef.insx() != m_lastSymbol.insx()
-// || mdef.insy() != m_lastSymbol.insy()
-// || mdef.rotation() != m_lastSymbol.rotation()
-// || mdef.units() != m_lastSymbol.units()
-// || mdef.library() != m_lastSymbol.library()
-// || mdef.name() != m_lastSymbol.name()
-// || mdef.style().color().argb() != m_lastSymbol.style().color().argb()
-// || mdef.fontstyle() != m_lastSymbol.fontstyle())
- m_lastSymbol = mdef;
- //convert font symbol to a simple label
- RS_TextDef tdef(RS_HAlignment_Center, RS_VAlignment_Half);
- RS_FontDef fdef(mdef.library(), mdef.height(), mdef.fontstyle(), mdef.units());
- tdef.font() = fdef;
- tdef.textcolor() = mdef.style().color();
- tdef.rotation() = mdef.rotation();
- //compute placement position for character centerpoint, taking into
- //account the insertion point.
- //TODO: is this way of computing insertion point offset correct, when
- //compared to what SymbolTrans does? Is rotation applied before the symbol
- //is moved to its insertion point or after? Need to check that.
- double posx = dst.minx + (0.5 - refX) * dst.width();
- double posy = dst.miny + (0.5 - refY) * dst.height();
- // transform insertion point into pixel space
- WorldToScreenPoint(posx, posy, posx, posy);
- // draw the character
- RS_TextMetrics tm;
- if (GetTextMetrics(mdef.name(), tdef, tm, false))
- DrawScreenText(tm, tdef, posx, posy, NULL, 0, 0.0);
- else
- //for non-font symbols we will draw into a temporary image
- //which we can reuse if the symbol is not changing from one
- //feature to the next
- //check to see if the last symbol we got was different or if it
- //is not cached yet
- if ( mdef.type() != m_lastSymbol.type()
- || mdef.width() != m_lastSymbol.width()
- || mdef.height() != m_lastSymbol.height()
- || mdef.insx() != m_lastSymbol.insx()
- || mdef.insy() != m_lastSymbol.insy()
- || mdef.rotation() != m_lastSymbol.rotation()
- || mdef.markernum() != m_lastSymbol.markernum()
- || mdef.library() != m_lastSymbol.library()
- || mdef.name() != m_lastSymbol.name()
- || mdef.style().color().argb() != m_lastSymbol.style().color().argb()
- || mdef.style().outline().color().argb() != m_lastSymbol.style().outline().color().argb()
- || mdef.style().background().argb() != m_lastSymbol.style().background().argb()
- || !m_imsym)
- int imsymw = devwidth;
- int imsymh = devheight;
- if (imsymw > SYMBOL_BITMAP_MAX || imsymh > SYMBOL_BITMAP_MAX)
- //symbol will be too big so we will draw it as
- //geometry directly into the map image instead.
- //So we need to destroy the cached symbol image if any
- if (m_imsym)
- m_imsym = NULL;
- else
- //otherwise allocate a second bitmap where
- //we will cache the symbol image for reuse
- //did we cache an image previously, but it was different size?
- if (m_imsym
- && ( gdImageSX((gdImagePtr)m_imsym) != imsymw
- || gdImageSY((gdImagePtr)m_imsym) != imsymh))
- m_imsym = NULL;
- //allocate the symbol image
- if (!m_imsym)
- m_imsym = gdImageCreateTrueColor(imsymw, imsymh);
- if (symbol)
- //case where we are using a W2D symbol from the library
- _ASSERT(mdef.type() == RS_MarkerType_W2D);
- //default bounds of symbol data in W2D
- //for symbols created by MapGuide Studio
- RS_Bounds src(0.0, 0.0, SYMBOL_MAX, SYMBOL_MAX);
- SymbolTrans st = SymbolTrans(src, dst, refX, refY, angleRad);
- if (m_imsym)
- //case where we will cache the symbol image
- //we will use unrotated symbol bounding box
- //since rotation will be done by the image copy
- //also we will use a slight boundary offset
- //hardcoded to 1 pixel so that geometry exactly on the edge
- //draws just inside the image
- RS_Bounds dst1(1.0, 1.0, (double)(imsymw-1), (double)(imsymh-1));
- st = SymbolTrans(src, dst1, 0.0, 0.0, 0.0);
- m_imw2d = m_imsym;
- // initialize the temporary symbol image to a transparent background
- gdImageAlphaBlending((gdImagePtr)m_imsym, 0);
- gdImageFilledRectangle((gdImagePtr)m_imsym, 0, 0, gdImageSX((gdImagePtr)m_imsym)-1, gdImageSY((gdImagePtr)m_imsym)-1, 0x7f000000);
- gdImageAlphaBlending((gdImagePtr)m_imsym, 1);
- else
- //case where we will draw the W2D directly into
- //the destination image because the symbol is too big
- m_imw2d = m_imout;
- //also set flags controlling how W2D are rewritten
- //into the destination DWF
- m_bIsSymbolW2D = true;
- m_mdOverrideColors = mdef;
- //copy symbol W2D into destination
- AddDWFContent(symbol, &st, mdef.name(), RS_String(L""), RS_String(L""));
- //make sure we zero out the W2D symbol flags
- m_bIsSymbolW2D = false;
- m_imw2d = NULL;
- else
- //case where we are using an SLD symbol, and fall-through for other cases
- //determine which SLD symbol we need to draw
- //and pick up its polygon point definition
- RS_F_Point* poly = NULL;
- int npts = 0;
- bool found = true;
- if (mdef.markernum() == SLDType_Square)
- poly = (RS_F_Point*)SLD_SQUARE;
- npts = sizeof(SLD_SQUARE) / (2 * sizeof(double));
- else if (mdef.markernum() == SLDType_Circle)
- poly = (RS_F_Point*)SLD_CIRCLE;
- npts = sizeof(SLD_CIRCLE) / (2 * sizeof(double));
- else if (mdef.markernum() == SLDType_Triangle)
- poly = (RS_F_Point*)SLD_TRIANGLE;
- npts = sizeof(SLD_TRIANGLE) / (2 * sizeof(double));
- else if (mdef.markernum() == SLDType_Star)
- poly = (RS_F_Point*)SLD_STAR;
- npts = sizeof(SLD_STAR) / (2 * sizeof(double));
- else if (mdef.markernum() == SLDType_Cross)
- poly = (RS_F_Point*)SLD_CROSS;
- npts = sizeof(SLD_CROSS) / (2 * sizeof(double));
- else if (mdef.markernum() == SLDType_X)
- poly = (RS_F_Point*)SLD_X;
- npts = sizeof(SLD_X) / (2 * sizeof(double));
- else
- //default or error
- poly = (RS_F_Point*)SLD_ERROR;
- npts = sizeof(SLD_ERROR) / (2 * sizeof(double));
- found = false;
- //fill color
- RS_Color fill = mdef.style().color();
- int gdcfill = ConvertColor((gdImagePtr)m_imout, fill);
- //outline color
- RS_Color outline = mdef.style().outline().color();
- int gdcline = ConvertColor((gdImagePtr)m_imout, outline);
- //see if symbol will be small enough to draw in cached image
- if (m_imsym)
- int superw = imsymw;
- int superh = imsymh;
- //if it is too small, make it bigger
- //so that we get an antialiased effect -- only
- //do this for SLD symbols since DWF symbols are too
- //varied and not all of them look good with smoothing applied
- if (!symbol && superw < SYMBOL_BITMAP_SIZE/2 && superh < SYMBOL_BITMAP_SIZE/2)
- superw = superh = SYMBOL_BITMAP_SIZE;
- gdImagePtr tmp = gdImageCreateTrueColor(superw, superh);
- //transform to coordinates of temporary image where we
- //draw symbol before transfering to the map
- EnsureBufferSize(npts);
- RS_D_Point* pts = m_wtPointBuffer;
- double tempx, tempy;
- for (int i=0; i<npts; i++)
- tempx = poly[i].x;
- tempy = poly[i].y;
- pts[i].x = (int)(tempx * (superw - 10.0) + 5.0);
- pts[i].y = (int)((superh - 10.0) - tempy * (superh - 10.0) + 5.0);
- // initialize the temporary supersampled symbol image to a transparent background
- gdImageAlphaBlending(tmp, 0);
- gdImageFilledRectangle(tmp, 0, 0, gdImageSX(tmp)-1, gdImageSY(tmp)-1, 0x7f000000);
- gdImageAlphaBlending(tmp, 1);
- if (!found)
- //unknown symbol
- RS_Color red(255, 0, 0, 255);
- int line_weight = rs_min(superw, superh) / 17;
- // line_weight cannot be zero
- gdImagePtr brush1 = rs_gdImageThickLineBrush((line_weight > 1)? line_weight : 2, red);
- gdImageSetBrush(tmp, brush1);
- gdImageOpenPolygon(tmp, (gdPointPtr)pts, npts, gdBrushed);
- gdImageSetBrush(tmp, NULL);
- gdImageDestroy(brush1);
- else
- //draw fill
- // TODO: When a filled polygon image is down-sampled, a gray false edge is created.
- // This edge can only be seen when the real edge is not being drawn.
- gdImageFilledPolygon(tmp, (gdPointPtr)pts, npts, gdcfill);
- //draw outline with a thickness set so that when scaled down to
- //th destination image, the outline is still fully visible
- gdImagePtr brush1 = rs_gdImageThickLineBrush((line_weight > 1)? line_weight : 2, outline);
- // initialize the real cached symbol image to a transparent background
- //resample the supersampled temporary image into the cached image
- gdImageCopyResampled((gdImagePtr)m_imsym, tmp, 0, 0, 0, 0, imsymw, imsymh, superw, superh);
- gdImageDestroy(tmp);
- else
- //otherwise symbol was too big and must be drawn as a regular polygon
- //construct transformer
- RS_Bounds src(0.0, 0.0, 1.0, 1.0);
- SymbolTrans trans(src, dst, refX, refY, angleRad);
- //unit square to world
- trans.TransformPoint(tempx, tempy);
- //world to device
- pts[i].x = _TX(tempx);
- pts[i].y = _TY(tempy);
- if (!found)
- //unknown symbol
- int gdcred = ConvertColor((gdImagePtr)m_imout, red);
- gdImageOpenPolygon((gdImagePtr)m_imout, (gdPointPtr)pts, npts, gdcred);
- else
- //draw fill
- gdImageSetAntiAliased((gdImagePtr)m_imout, gdcfill);
- gdImageFilledPolygon((gdImagePtr)m_imout, (gdPointPtr)pts, npts, gdAntiAliased);
- //draw outline
- gdImageSetAntiAliased((gdImagePtr)m_imout, gdcline);
- gdImageOpenPolygon((gdImagePtr)m_imout, (gdPointPtr)pts, npts, gdAntiAliased);
- if (m_imsym)
- //in case we cached a symbol image, draw it to the main
- //map image
- //get the source image size
- int imsymw = gdImageSX((gdImagePtr)m_imsym);
- int imsymh = gdImageSY((gdImagePtr)m_imsym);
- //construct transformer from cached image space
- //to rotated map space -- we need this in order to
- //take into account the insertion point
- RS_Bounds src(0.0, 0.0, imsymw, imsymh);
- //initialize 4 corner points of symbol -- we will
- //destructively transform this array to destination map space
- RS_F_Point b[4];
- b[0].x = 0.0; b[0].y = 0.0;
- b[1].x = imsymw; b[1].y = 0.0;
- b[2].x = imsymw; b[2].y = imsymh;
- b[3].x = 0.0; b[3].y = imsymh;
- for (int i=0; i<4; i++)
- //to world space
- trans.TransformPoint(b[i].x, b[i].y);
- //world to screen space
- WorldToScreenPoint(b[i].x, b[i].y, b[i].x, b[i].y);
- //copy symbol image into destination image
- if (mdef.rotation() == 0.0)
- //upper left point
- int ulx = (int)floor(b[3].x);
- int uly = (int)floor(b[3].y);
- //straight copy without resampling since we are
- //guaranteed for the source image size to equal the
- //symbol pixel size
- gdImageCopy((gdImagePtr)m_imout, (gdImagePtr)m_imsym, ulx, uly, 0, 0, imsymw, imsymh);
- else
- //for rotated copy, we need to scale down the image first
- //allocating an extra image here should not be too much of
- //an overhead since it is usually small
- gdImagePtr tmp = gdImageCreateTrueColor(imsymw+2, imsymh+2);
- //make it transparent
- gdImageFilledRectangle(tmp, 0, 0, imsymw+1, imsymh+1, 0x7f000000);
- gdImageCopy(tmp, (gdImagePtr)m_imsym, 1, 1, 0, 0, imsymw, imsymh);
- //for rotated gd copy, we need the midpoint of
- //the destination bounds
- double mx = floor(0.5 * (b[0].x + b[2].x));
- double my = floor(0.5 * (b[0].y + b[2].y));
- //draw rotated symbol onto final destination image
- gdImageCopyRotated((gdImagePtr)m_imout, tmp, mx, my, 0, 0, imsymw+2, imsymh+2, ROUND(mdef.rotation()));
- if (!allowOverpost)
- //now add an exclusion region to the file so that
- //labels do not overlap the symbol
- //a square that we will transform into the dst bounds
- RS_F_Point box[4];
- box[0].x = 0.0;
- box[0].y = 0.0;
- box[1].x = SYMBOL_MAX;
- box[1].y = 0.0;
- box[2].x = SYMBOL_MAX;
- box[2].y = SYMBOL_MAX;
- box[3].x = 0.0;
- box[3].y = SYMBOL_MAX;
- //construct transformer -- same as the
- //one used for the actual symbol drawables
- SymbolTrans boxtrans(src, dst, refX, refY, angleRad);
- RS_F_Point pts[4];
- tempx = box[i].x;
- tempy = box[i].y;
- boxtrans.TransformPoint(tempx, tempy);
- AddExclusionRegion(pts, 4);
- //set actual (unrotated) bounds with new insertion point if a pointer was passed in
- if (bounds)
- bounds->minx = -refX * mdef.width();
- bounds->maxx = (1.0 - refX) * mdef.width();
- bounds->miny = -refY * mdef.height();
- bounds->maxy = (1.0 - refY) * mdef.height();
-void GDRenderer::ProcessLabelGroup(RS_LabelInfo* labels,
- int nlabels,
- const RS_String& text,
- RS_OverpostType type,
- bool exclude,
- LineBuffer* path,
- double scaleLimit)
- //check if we are rendering a selection -- bail if so
- return;
- //forward it to the label renderer
- m_labeler->ProcessLabelGroup(labels, nlabels, text, type, exclude, path, scaleLimit);
-void GDRenderer::AddExclusionRegion(RS_F_Point* fpts, int npts)
- m_labeler->AddExclusionRegion(fpts, npts);
-void GDRenderer::SetSymbolManager(RS_SymbolManager* manager)
- m_symbolManager = manager;
-RS_MapUIInfo* GDRenderer::GetMapInfo()
- return m_mapInfo;
-RS_LayerUIInfo* GDRenderer::GetLayerInfo()
- return m_layerInfo;
-RS_FeatureClassInfo* GDRenderer::GetFeatureClassInfo()
- return m_featureClassInfo;
-double GDRenderer::GetMapScale()
- return m_mapScale;
-double GDRenderer::GetDrawingScale()
- return m_drawingScale;
-double GDRenderer::GetMetersPerUnit()
- return m_metersPerUnit;
-RS_Bounds& GDRenderer::GetBounds()
- return m_extents;
-double GDRenderer::GetDpi()
- return m_dpi;
-bool GDRenderer::RequiresClipping()
- return m_bRequiresClipping;
-bool GDRenderer::RequiresLabelClipping()
- // always the same value as RequiresClipping
-bool GDRenderer::SupportsZ()
- // Z values in feature geometry are ignored
- return false;
-bool GDRenderer::SupportsTooltips()
- // set to false to disable processing of tooltips
- return false;
-bool GDRenderer::SupportsHyperlinks()
- // set to false to disable processing of hyperlinks
- return false;
-void GDRenderer::WritePolylines(LineBuffer* srclb, RS_LineStroke& stroke, bool aa)
- //apply the stroke first
- int gdc = ConvertColor((gdImagePtr)m_imout, stroke.color());
- gdImageSetAntiAliased((gdImagePtr)m_imout, gdc);
- double thickness = stroke.width();
- //convert thickness to pixels
- int line_weight = (int)(_MeterToMapSize(stroke.units(), fabs(thickness)) * m_scale);
- if (line_weight > m_maxLineWidth)
- line_weight = m_maxLineWidth;
- gdImagePtr brush1 = NULL;
- if (line_weight > 1)
- brush1 = rs_gdImageThickLineBrush(line_weight, stroke.color());
- //draw the lines
- for (int i=0; i<srclb->cntr_count(); i++)
- int cntr_size = srclb->cntr_size(i);
- if (cntr_size > 1)
- _TransformContourPointsNoClamp(srclb, i);
- //draw antialiased only if thickness is single pixel
- if (aa && line_weight <= 1)
- gdImageOpenPolygon((gdImagePtr)m_imout, (gdPointPtr)m_wtPointBuffer, cntr_size, gdAntiAliased);
- else
- gdImageSetBrush((gdImagePtr)m_imout, brush1);
- gdImageOpenPolygon((gdImagePtr)m_imout, (gdPointPtr)m_wtPointBuffer, cntr_size, brush1? gdBrushed : gdc);
- //unset the stroke
- gdImageSetBrush((gdImagePtr)m_imout, NULL);
- if (brush1)
-//transforms an x coordinate from mapping to screen space
-inline int GDRenderer::_TX(double x)
- return (int)floor((x - m_offsetX) * m_scale);
-//transforms a y coordinate from mapping to screen space
-inline int GDRenderer::_TY(double y)
-// return (int)floor(m_height - (y - m_offsetY) * m_scale);
- return m_height + (int)floor((m_offsetY - y) * m_scale); // avoids converting m_height to double
-//transforms an array of input mapping space points into pixel
-//coordinates and places them in the point buffer m_wtPointBuffer
-void GDRenderer::_TransformPointsNoClamp(LineBuffer* plb)
- EnsureBufferSize(plb->point_count());
- int* wpts = (int*)m_wtPointBuffer;
- for (int i=0; i<plb->point_count(); i++)
- *wpts++ = _TX(plb->x_coord(i));
- *wpts++ = _TY(plb->y_coord(i));
-void GDRenderer::_TransformContourPointsNoClamp(LineBuffer* plb, int cntr)
- EnsureBufferSize(plb->cntr_size(cntr));
- int end = plb->contour_end_point(cntr);
- for (int i=plb->contour_start_point(cntr); i<=end; i++)
-void GDRenderer::EnsureBufferSize(int len)
- if (!m_wtPointBuffer)
- m_wtPointLen = len;
- m_wtPointBuffer = new RS_D_Point[m_wtPointLen];
- else if (len > m_wtPointLen)
-//WARNING: caller responsible for deleting resulting line buffer
-LineBuffer* GDRenderer::ApplyLineStyle(LineBuffer* srcLB, wchar_t* lineStyle, double lineWidthPixels, double drawingScale, double dpi)
- // if there are less than two indices then we can't style
- int lenInds = srcLB->point_count();
- if (lenInds < 2)
- return NULL;
- // configure the line style definition to use
- LineStyleDef lineStyleDef;
- LineStyle style = lineStyleDef.FindLineStyle(lineStyle);
- lineStyleDef.SetStyle(style, drawingScale, dpi, lineWidthPixels);
- // the starting pixel run
- int pixelRunInd = 0;
- PixelRun pixelRun = lineStyleDef.m_pixelRuns[pixelRunInd];
- // create the destination line buffer
- LineBuffer* destLB = LineBufferPool::NewLineBuffer(m_pPool, 8);
- std::unique_ptr<LineBuffer> spDestLB(destLB);
- // special code for Fenceline1 style
- int numCapSegs = 0;
- double csCapAng = 0.0, snCapAng = 0.0;
- if (style == LineStyle_FENCELINE1)
- // get the size in screen units of the circular decoration
- double decorSize = lineStyleDef.m_pixelRuns[1].m_decorSize / drawingScale;
- numCapSegs = (int)ceil(M_PI * sqrt(0.5*decorSize));
- // restrict this value to be safe - 64 is enough to handle the
- // case of the decoration filling the whole screen
- if (numCapSegs > 64)
- numCapSegs = 64;
- // angle increment
- double dAngle = 2.0*M_PI / numCapSegs;
- csCapAng = cos(dAngle);
- snCapAng = sin(dAngle);
- // loop over the source buffer's segments
- double walkLen = 0.0;
- double sumdLen = 0.0;
- for (int j=1; j<lenInds; ++j)
- // get the vertex and index arrays from the line
- // buffer - these are inside the loop because they
- // change if the line buffer resizes itself
- // don't style if current segment is empty (a move-to)
- if (srcLB->point_type(j) == (unsigned char)LineBuffer::stMoveTo)
- continue;
- // get the data for the segment
- double p0x, p0y, p1x, p1y;
- srcLB->get_point(j-1, p0x, p0y);
- srcLB->get_point(j , p1x, p1y);
- double dx = p1x - p0x;
- double dy = p1y - p0y;
- // detect a previous move-to
- if (srcLB->point_type(j-1) == (unsigned char)LineBuffer::stMoveTo)
- // reset the distances
- walkLen = 0.0;
- sumdLen = 0.0;
- // reset the pixel run
- pixelRunInd = 0;
- pixelRun = lineStyleDef.m_pixelRuns[pixelRunInd];
- // skip zero-length segments
- if (dx == 0.0 && dy == 0.0)
- continue;
- // get the length and normalized direction
- double lineLen = sqrt(dx*dx + dy*dy);
- double lineInv = 1.0 / lineLen;
- dx *= lineInv;
- dy *= lineInv;
- // traverse this segment (in model units)
- bool doneSeg = false;
- double x0 = p0x;
- double y0 = p0y;
- double x1, y1;
- do
- // f gives the parametric position on the line
- // corresponding to the end of the pixel run
- double f = walkLen - sumdLen + pixelRun.m_nPixels;
- if (f < lineLen)
- // somewhere before the end of the line
- x1 = p0x + f*dx;
- y1 = p0y + f*dy;
- else
- // only go to the end of the line
- x1 = p1x;
- y1 = p1y;
- doneSeg = true;
- // draw any dash
- if (pixelRun.m_isOn && destLB != srcLB)
- destLB->MoveTo(x0, y0);
- destLB->LineTo(x1, y1);
- x0 = x1;
- y0 = y1;
- // draw any decoration
- if (pixelRun.m_decor != Decoration_None)
- double g = walkLen - sumdLen + pixelRun.m_decorOffset;
- if (g >= 0.0 && g < lineLen)
- double dxw = 0.5*pixelRun.m_decorSize*dx;
- double dyw = 0.5*pixelRun.m_decorSize*dy;
- double xd = p0x + g*dx;
- double yd = p0y + g*dy;
- if (pixelRun.m_decor == Decoration_CrossTick)
- destLB->MoveTo(xd - dyw, yd + dxw);
- destLB->LineTo(xd + dyw, yd - dxw);
- else if (pixelRun.m_decor == Decoration_Square)
- double dxyp = dxw + dyw;
- double dxym = dxw - dyw;
- destLB->MoveTo(xd + dxym, yd + dxyp);
- destLB->LineTo(xd - dxyp, yd + dxym);
- destLB->LineTo(xd - dxym, yd - dxyp);
- destLB->LineTo(xd + dxyp, yd - dxym);
- destLB->LineTo(xd + dxym, yd + dxyp);
- else if (pixelRun.m_decor == Decoration_Circle)
- // set the first point
- destLB->MoveTo(xd + dxw, yd + dyw);
- // set the intermediate points
- double xc = dxw;
- double yc = dyw;
- for (int i=1; i<numCapSegs; i++)
- double xt = xc;
- xc = csCapAng*xc - snCapAng*yc;
- yc = snCapAng*xt + csCapAng*yc;
- destLB->LineTo(xd + xc, yd + yc);
- // set the final point
- destLB->LineTo(xd + dxw, yd + dyw);
- if (!doneSeg)
- // update the walk length
- walkLen += pixelRun.m_nPixels;
- // move to the next pixel run
- ++pixelRunInd;
- if (pixelRunInd == lineStyleDef.m_nRuns)
- pixelRunInd = 0;
- while (!doneSeg);
- // update the summed line length
- sumdLen += lineLen;
- return spDestLB.release();
-//scale an input number in meters to a mapping
-//space number given a device or mapping space unit.
-double GDRenderer::_MeterToMapSize(RS_Units unit, double number)
- double scale_factor;
- if (unit == RS_Units_Device) // in meters, fixed size
- scale_factor = m_mapScale / m_metersPerUnit;
- else
- scale_factor = 1.0 / m_metersPerUnit;
- return number * scale_factor;
-void GDRenderer::SetRenderSelectionMode(bool mode)
- SetRenderSelectionMode(mode, 0x0000FFFF);
-void GDRenderer::SetRenderSelectionMode(bool mode, int rgba)
- SE_Renderer::SetRenderSelectionMode(mode, rgba);
- //initialize the selection styles if needed
- if (mode)
- RS_Color selLineColor = RS_Color((rgba & 0xFFFFFF00) | 200);
- RS_Color selFillColor(rgba & 0xFFFFFFFF);
- //For backward compatibility, only do the override if we have a fully opaque alpha component, otherwise respect the value defined
- if (selFillColor.alpha() == 255)
- selFillColor = RS_Color((rgba & 0xFFFFFF00) | 160);
- RS_Color selBgColor(0, 0, 0, 0);
- RS_LineStroke selStroke = RS_LineStroke(selLineColor, 0.001, L"Solid", RS_Units_Device);
- m_selFill = RS_FillStyle(selStroke, selFillColor, selBgColor, L"Solid");
-// Text drawing
-// RS_FontEngine implementation
-void GDRenderer::MeasureString(const RS_String& s,
- double height,
- const RS_Font* font,
- double angleRad,
- RS_F_Point* res, // assumes length equals 4 points
- float* offsets) // assumes length equals length of string
- //gd likes height in points rather than pixels
- height *= 72.0 / m_dpi;
- // The computed height can have roundoff in it, and the rendering code is
- // very sensitive to it. Remove this roundoff by rounding the height to
- // the nearest 1/65536ths of a point.
- height = floor(height * 65536.0 + 0.5) / 65536.0;
- // If the supplied font height is too large GD can't measure it. We'll
- // use a reasonable font height for measuring, and then scale the result.
- double measureHeight = rs_min(5000.0, height);
- double measureScale = height / measureHeight;
- // Do any BIDI conversion. If the offset array is supplied (i.e. for path
- // text) then assume the conversion was already performed on the input string.
- const RS_String* pStrToUse;
- if (offsets)
- pStrToUse = &s;
- else
- const RS_String& sConv = m_bidiConverter.ConvertString(s);
- // ConvertString returns either the converter-owned string or the input
- // string - in either case we can temporarily hold on to the pointer
- pStrToUse = &sConv;
- //convert input to UTF8, which is what GD uses
- size_t len = pStrToUse->length();
- size_t lenbytes = len*4+1;
- char* sutf8 = (char*)alloca(lenbytes);
- DWFString::EncodeUTF8(pStrToUse->c_str(), len * sizeof(wchar_t), sutf8, lenbytes);
- //convert font path to utf8 also
- size_t lenf = font->m_filename.length();
- size_t lenbytesf = lenf * 4 + 1;
- char* futf8 = (char*)alloca(lenbytesf);
- DWFString::EncodeUTF8(font->m_filename.c_str(), lenf * sizeof(wchar_t), futf8, lenbytesf);
- int extent[8];
- gdFTStringExtra extra;
- memset(&extra, 0, sizeof(gdFTStringExtra));
- if (offsets)
- extra.flags |= gdFTEX_XSHOW;
- extra.flags |= gdFTEX_RESOLUTION;
- extra.hdpi = (int)m_dpi;
- extra.vdpi = (int)m_dpi;
- char* err = NULL;
- err = gdImageStringFTEx(NULL, extent, 0, futf8, measureHeight, angleRad, 0, 0, sutf8, &extra);
-#ifdef _DEBUG
- if (err) printf("gd text error : %s\n", err);
-#endif
- //scale the result
- for (int i=0; i<4; ++i)
- res[i].x = measureScale*extent[2*i];
- res[i].y = measureScale*extent[2*i+1];
- if (extra.xshow && offsets)
- //copy over character spacings into result array
- for (size_t i=0; i<len; ++i)
- offsets[i] = (float)(measureScale*extra.xshow[i]);
- //and then release the gd allocated xshow pointer
- gdFree(extra.xshow);
-void GDRenderer::DrawString(const RS_String& s,
- double x,
- double y,
- double /*width*/,
- double height,
- RS_Color& color,
- double angleRad)
- if (font == NULL)
- return;
- // Don't draw the text if height > 16384 pixels, since memory usage in the call
- // to gdImageStringFTEx below starts to get too large. 16394 pixels should be
- // more than enough (e.g. this allows 13" high text on a 1200dpi device).
- if (height > 16384.0)
- return;
- // do BIDI conversion
- size_t len = sConv.length();
- DWFString::EncodeUTF8(sConv.c_str(), len * sizeof(wchar_t), sutf8, lenbytes);
- //draw the string
- int gdc = ConvertColor((gdImagePtr)m_imout, color);
- char* err = NULL;
- err = gdImageStringFTEx((gdImagePtr)m_imout, NULL, gdc, futf8, height, angleRad, ROUND(x), ROUND(y), sutf8, &extra);
-#ifdef _DEBUG
-#endif
-const RS_Font* GDRenderer::FindFont(RS_FontDef& def)
- const RS_Font* pFont = FontManager::Instance()->FindFont(def.name().c_str(),
- (def.style() & RS_FontStyle_Bold) != 0,
- (def.style() & RS_FontStyle_Italic) != 0);
- return pFont;
-// Called when applying a line style on a feature geometry. Line styles can
-// only be applied to linestring and polygon feature geometry types.
-void GDRenderer::ProcessLine(SE_ApplyContext* ctx, SE_RenderLineStyle* style)
- LineBuffer* featGeom = ctx->geometry;
- // if the geometry bounds is less than one sixteenth pixel it is too small to try drawing
-// RS_Bounds bds = featGeom->bounds();
-// if ((bds.width() < 0.25*m_drawingScale) && (bds.height() < 0.25*m_drawingScale))
-// return;
- if (featGeom->point_count() > 6)
- featGeom = featGeom->Optimize(0.5*m_drawingScale, m_pPool);
- if (featGeom != ctx->geometry)
- spLB.reset(featGeom);
- SE_ApplyContext local_ctx = *ctx;
- local_ctx.geometry = featGeom;
- SE_Renderer::ProcessLine(&local_ctx, style);
- // cleanup
- if (spLB.get())
-// Called when applying an area style on a feature geometry. Area styles can
-// can only be applied to polygon feature geometry types.
-void GDRenderer::ProcessArea(SE_ApplyContext* ctx, SE_RenderAreaStyle* style)
- // can't apply an area style to point and linestring geometry types
- switch (featGeom->geom_type())
- case FdoGeometryType_Point:
- case FdoGeometryType_MultiPoint:
- case FdoGeometryType_LineString:
- case FdoGeometryType_MultiLineString:
- case FdoGeometryType_CurveString:
- case FdoGeometryType_MultiCurveString:
- return;
- // if the geometry bounds is less than one quarter pixel, then it is too small to try drawing
-// if ((bds.width() < 0.5*m_drawingScale) && (bds.height() < 0.5*m_drawingScale))
-// return;
- SE_Renderer::ProcessArea(&local_ctx, style);
- // cleanup
- if (spLB.get())
-//// DWF Rewrite and related code
-//Inserts the contents of a given DWF input stream
-//into the current output W2D. The given coord sys
-//transformation is applied and geometry will be clipped
-//to the RS_Bounds context of the DWFRenderer
-void GDRenderer::AddDWFContent(RS_InputStream* in,
- CSysTransformer* xformer,
- const RS_String& section,
- const RS_String& passwd,
- const RS_String& w2dfilter)
- try
- if (in->available() == 0)
- return;
- //go to beginning of stream
- in->seek(SEEK_SET, 0);
- DWFRSInputStream rsin(in);
- DWFPackageReader oReader(rsin, passwd.c_str());
- DWFPackageReader::tPackageInfo tInfo;
- oReader.getPackageInfo(tInfo);
- if (tInfo.eType != DWFPackageReader::eDWFPackage)
- return; //throw exception?
- bool checkSection = (wcslen(section.c_str()) > 0);
- //read the manifest
- DWFManifest& rManifest = oReader.getManifest();
- //now read the sections
- DWFSection* pSection = NULL;
- DWFManifest::SectionIterator* iSection = (&rManifest)->getSections();
- if (iSection)
- for (; iSection->valid(); iSection->next())
- pSection = iSection->get();
- //call this so that the resource data (like transforms and roles) is read in
- pSection->readDescriptor();
- //DWFGlobalSection* pGlobal = dynamic_cast<DWFGlobalSection*>(pSection);
- DWFEPlotSection* pEPlot = dynamic_cast<DWFEPlotSection*>(pSection);
- if (pEPlot)
- if (checkSection)
- //compare name stored in section to user requested
- //section
- //Used for point symbols
- DWFString name = pEPlot->title();
- //skip current section if its name does
- //not match the name of the one we need
- if (name != section.c_str())
- continue;
- // Get the resources for the section
- //first do primary W2D resources
- DWFIterator<DWFResource*>* piResources = pEPlot->findResourcesByRole(DWFXML::kzRole_Graphics2d);
- if (piResources)
- for (; piResources->valid(); piResources->next())
- DWFResource* pResource = piResources->get();
- DWFInputStream* pStream = pResource->getInputStream();
- if (!pStream)
- _DWFCORE_THROW(DWFMemoryException, L"Out of memory");
- RSDWFInputStream rsdwfin(pStream);
- AddW2DContent(&rsdwfin, xformer, w2dfilter);
- DWFCORE_FREE_OBJECT(pStream);
- DWFCORE_FREE_OBJECT(piResources);
- piResources = NULL;
- //then do overlays
- piResources = pEPlot->findResourcesByRole(DWFXML::kzRole_Graphics2dOverlay);
- if (piResources)
- if (!pStream)
- DWFCORE_FREE_OBJECT(iSection);
- catch (DWFException&)
-void GDRenderer::AddW2DContent(RS_InputStream* in, CSysTransformer* xformer, const RS_String& w2dfilter)
- WT_Result result;
- //initialize state variables, which are needed by W2D rewriter callbacks
- m_input = in;
- m_xformer = xformer;
- m_bHaveViewport = false;
- m_bLayerPassesFilter = true;
- m_layerFilter = w2dfilter;
- //set output image if not already set
- if (!m_bIsSymbolW2D)
- WT_File fin;
- fin.set_file_mode(WT_File::/*WT_File_mode::*/File_Read);
- fin.set_stream_user_data(this);
- SetActions(fin);
- fin.open();
- // Do the actual reading.
- do
- result = fin.process_next_object();
- while (result == WT_Result::Success);
- fin.close();
- m_input = NULL;
- //clear the output image if we set it in this function
- m_imw2d = NULL;
-void GDRenderer::SetActions(WT_File& file)
- file.set_stream_open_action (gdr_open);
- file.set_stream_close_action(gdr_close);
- file.set_stream_read_action (gdr_read);
- file.set_stream_seek_action (gdr_seek);
- //file.set_dwf_header_action(gdr_process_dwf_header);
- //file.set_author_action(gdr_process_author);
- //file.set_creator_action(gdr_process_creator);
- //file.set_creation_time_action(gdr_process_created);
- //file.set_modification_time_action(gdr_process_modified);
- //file.set_source_filename_action(gdr_process_sourceFilename);
- //file.set_source_creation_time_action(gdr_process_sourceCreationTime);
- //file.set_source_modification_time_action(gdr_process_sourceModificationTime);
- file.set_units_action(gdr_process_units);
- //file.set_embed_action(gdr_process_embed);
- //file.set_named_view_action(gdr_process_namedView);
- //file.set_view_action(gdr_process_view);
- //file.set_plot_info_action(gdr_process_plotInfo);
- file.set_background_action(gdr_process_background);
- file.set_color_action(gdr_process_color);
- file.set_line_weight_action(gdr_process_lineWeight);
- file.set_line_style_action(gdr_process_lineStyle);
- file.set_layer_action(gdr_process_layer);
- file.set_viewport_action(gdr_process_viewport);
- file.set_visibility_action(gdr_process_visibility);
- file.set_code_page_action(gdr_process_codePage);
- file.set_color_map_action(gdr_process_colorMap);
- //file.set_comments_action(gdr_process_comments);
- file.set_contour_set_action(gdr_process_contourSet);
- //file.set_copyright_action(gdr_process_copyright);
- file.set_dash_pattern_action(gdr_process_dashPattern);
- //file.set_description_action(gdr_process_description);
- file.set_fill_action(gdr_process_fill);
- file.set_filled_ellipse_action(gdr_process_filledEllipse);
- file.set_font_action(gdr_process_font);
- file.set_image_action(gdr_process_image);
- //file.set_keywords_action(gdr_process_keywords);
- file.set_marker_size_action(gdr_process_markerSize);
- file.set_marker_symbol_action(gdr_process_markerSymbol);
- file.set_merge_control_action(gdr_process_mergeControl);
- //file.set_named_view_list_action(gdr_process_namedViewList);
- file.set_origin_action(gdr_process_origin);
- file.set_outline_ellipse_action(gdr_process_outlineEllipse);
- file.set_polygon_action(gdr_process_polygon);
- file.set_polytriangle_action(gdr_process_polytriangle);
- file.set_polymarker_action(gdr_process_polymarker);
- file.set_projection_action(gdr_process_projection);
- //file.set_subject_action(gdr_process_subject);
- //file.set_title_action(gdr_process_title);
- //file.set_unknown_action(gdr_process_unknown);
- //file.set_url_action(gdr_process_url);
- file.set_png_group4_image_action(gdr_process_pngGroup4Image);
- file.set_polyline_action(gdr_process_polyline);
- file.set_text_action(gdr_process_text);
- file.set_inked_area_action(gdr_process_inkedArea);
- //file.set_plot_optimized_action(gdr_process_plotOptimized);
- //file.set_group_begin_action(gdr_process_groupBegin);
- //file.set_group_end_action(gdr_process_groupEnd);
- //file.set_embedded_font_action(gdr_process_embeddedFont);
- //file.set_trusted_font_list_action(gdr_process_trustedFontList);
- //file.set_blockref_action(gdr_process_blockref);
- //file.set_block_meaning_action(gdr_process_blockMeaning);
- //file.set_encryption_action(gdr_process_encryption);
- //file.set_orientation_action(gdr_process_orientation);
- file.set_alignment_action(gdr_process_alignment);
- //file.set_password_action(gdr_process_password);
- //file.set_guid_action(gdr_process_guid);
- //file.set_filetime_action(gdr_process_fileTime);
- //file.set_userdata_action(gdr_process_userData);
- file.set_pen_pattern_action(gdr_process_penPattern);
- file.set_line_pattern_action(gdr_process_linePattern);
- file.set_fill_pattern_action(gdr_process_fillPattern);
- //file.set_signdata_action(gdr_process_DigitalSign);
- file.set_gouraud_polytriangle_action(gdr_process_gouraudPolytriangle);
- file.set_gouraud_polyline_action(gdr_process_gouraudPolyline);
-//Given an array of points in W2D logical coordinates, this function:
-// 1. Transform W2D logical coords into their model space using the
-// W2D file's units structure
-// 2. Apply coordinate system transformation into the destination
-// map's space
-// 3. Optionally clip the resulting point to the user-requested
-// data extent of the destination map
-// 4. Transform clipped points to destination W2D space
-// 5. Return a pointer to an array of W2D points with the
-// total number of output points returned in outNumpts.
-// If the clipping process of a polyline or polygon resulted
-// in a multipolygon or multipolyline, a pointer to a vector
-// containing contour counts will also be returned.
-// *** Both pointers are valid unit the next call to this function. ***
-const RS_D_Point* GDRenderer::ProcessW2DPoints(WT_File& file,
- WT_Logical_Point* srcpts,
- int numpts,
- bool checkInBounds)
- //This transformer may have been modified if a Viewport
- //opcode was encountered in the source W2D. This is needed for
- //support for symbols from ACAD, which do not use the
- //standard W2D extent used by Studio.
- //The function UpdateSymbolTrans does the actual modification and is
- //called by the process_viewport callback.
- SymbolTrans* trans = (SymbolTrans*)m_xformer;
- //Our W2DRewrite component stores the source file Units transform
- //in the source file's desired rendition -- a bit of a hack
- //but we cannot store it in the destination file -- it messes up some scales
- //plus it has a totally different units of its own.
- WT_Matrix xform = file.desired_rendition().drawing_info().units().dwf_to_application_adjoint_transform();
- LineBuffer* lb = LineBufferPool::NewLineBuffer(m_pPool, numpts);
- std::unique_ptr<LineBuffer> spLB(lb);
- lb->Reset();
- // Process the points into mapping space
- WT_Point3D psrc(0.0, 0.0, 0.0);
- WT_Point3D pdst(0.0, 0.0, 0.0);
- for (int i=0; i<numpts; i++)
- psrc.m_x = srcpts[i].m_x;
- psrc.m_y = srcpts[i].m_y;
- //this puts it into model space of the source data
- xform.transform(psrc, pdst);
- //now transform to mapping space of map
- //using the symbol transformer object (if any)
- if (trans)
- trans->TransformPoint(pdst.m_x, pdst.m_y);
- if (i == 0)
- lb->MoveTo(pdst.m_x, pdst.m_y);
- else
- lb->LineTo(pdst.m_x, pdst.m_y);
- // IMPORTANT: Only do this if the data is a DWF layer
- // or a DWF symbol that is too large to draw using a
- // cached bitmap. Regular DWF Symbols will be transformed
- // to the correct mapping space location by the symbol code
- if (!IsSymbolW2D())
- // Clipping. For GD rendering a simple bounds check is enough,
- // the renderer itself will take care of the rest
- if (checkInBounds)
- //check if line buffer is completely outside box
- if ( lb->bounds().minx > m_extents.maxx
- || lb->bounds().miny > m_extents.maxy
- || lb->bounds().maxx < m_extents.minx
- || lb->bounds().maxy < m_extents.miny)
- return NULL;
- if (!IsSymbolW2D() || m_imw2d != m_imsym)
- if (lb->point_count() > 0)
- else
- //for symbols just copy the points to the output array
- //and only invert the y coordinate -- we need to flip y since
- //in gd y goes down and in DWF it goes up
- int count = lb->point_count();
- EnsureBufferSize(count);
- RS_D_Point* wpts = m_wtPointBuffer;
- for (int i=0; i<count; i++)
- wpts[i].x = (int)lb->x_coord(i);
- wpts[i].y = gdImageSY((gdImagePtr)GetW2DTargetImage()) - (int)lb->y_coord(i);
- //free temporary linebuffer
- return m_wtPointBuffer;
-//This function scales a W2D space related value from
-//source W2D space to destination.
-//Since the source W2D file can fit into a small piece of the
-//destination DWF or be much larger, we need to take that
-//scaling into account when carrying over things like line weight,
-//font height, etc. this helper funtion determines and applies
-//that scale
-double GDRenderer::ScaleW2DNumber(WT_File& file, WT_Integer32 number)
- double scale1 = 1.0 / xform(0, 0); //div because we need inverse
- //number is now in source W2D model units
- double dModelSpace = (double)number * scale1;
- double dMapSpace = dModelSpace;
- if (m_xformer)
- //now we need to convert that to a length in destination
- //map units.
- dMapSpace *= m_xformer->GetLinearScale();
- double dDstSpace = dMapSpace;
- //only scale by map scale if we are not a symbol inside a cached image
- dDstSpace *= m_scale;
- return dDstSpace;
-// Fills and returns the point buffer using the supplied line buffer.
-// No transformations are applied.
-const RS_D_Point* GDRenderer::FillPointBuffer(LineBuffer* lb)
- _TransferPoints(lb, NULL);
-void GDRenderer::UpdateSymbolTrans(WT_File& /*file*/, WT_Viewport& viewport)
- _ASSERT(m_xformer);
- RS_Bounds alternate_extent(0.0, 0.0, -1.0, -1.0);
- //If a viewport was defined, the symbol W2D likely came from AutoCAD.
- //In that case, the extent of the data inside the W2D is not the same
- //as what Studio saves (0, 0, SYMBOL_MAX, SYMBOL_MAX), so we need to use
- //a different transformation for that data.
- //IMPORTANT: This will destructively modify the transformer that was passed in.
- //It is ugly, but avoids parsing the W2D twice.
- //The assumption here is that Viewport opcodes define the bounds of the data.
- //This is not necessarily true for all W2D files, but is true for ones coming
- //from ACAD through the Dwg Extract and Transform engine.
- if (viewport.contour() && m_bIsSymbolW2D)
- const WT_Contour_Set* cset = viewport.contour();
- const WT_Logical_Point* pts = cset->points();
- _ASSERT(cset->total_points() == 4);
- if (cset->total_points() == 4)
- alternate_extent.minx = rs_min(pts[0].m_x, pts[2].m_x);
- alternate_extent.maxx = rs_max(pts[0].m_x, pts[2].m_x);
- alternate_extent.miny = rs_min(pts[0].m_y, pts[2].m_y);
- alternate_extent.maxy = rs_max(pts[0].m_y, pts[2].m_y);
- //TODO: we don't do that yet, since DWF layers can have
- //multiple viewports, which mess up this logic -- no single
- //viewport contains the overall extent of the data
- //if it is a DWF layer, also correct for aspect ratio
- //of the destination bounds of the transformer so that
- //we avoid stretching of the layer data.
- //we now assume we know the exact bounds of the data
- //in the w2d
- double arsrc = alternate_extent.width() / alternate_extent.height();
- RS_Bounds dstext = trans.GetSrcBounds();
- double ardst = dstext.width() / dstext.height();
- if (arsrc >= ardst)
- double newhgt2 = 0.5 * dstext.width() / arsrc;
- double oldcy = 0.5 * (dstext.miny + dstext.maxy);
- RS_Bounds newdst(dstext.minx, oldcy - newhgt2, dstext.maxx, oldcy + newhgt2);
- trans.SetDstBounds(newdst);
- else
- double newwid2 = 0.5 * dstext.height() * arsrc;
- double oldcx = 0.5 * (dstext.minx + dstext.maxx);
- RS_Bounds newdst(oldcx - newwid2, dstext.miny, oldcx + newwid2, dstext.maxy);
- //and finally set the source bounds we got from the viewport
- //opcode
- ((SymbolTrans*)m_xformer)->SetSrcBounds(alternate_extent);
- m_bHaveViewport = true;
-//// END of DWF Rewrite and related code
-// SE_Renderer implementation
-void GDRenderer::_TransferPoints(LineBuffer* plb, const SE_Matrix* xform)
- int numpts = plb->point_count();
- EnsureBufferSize(numpts);
- int* pts = (int*)m_wtPointBuffer;
- if (!xform || xform->isIdentity())
- *pts++ = (int)plb->x_coord(i);
- *pts++ = (int)plb->y_coord(i);
- else
- double x, y;
- xform->transform(plb->x_coord(i), plb->y_coord(i), x, y);
- pts[0] = (int)x;
- pts[1] = (int)y;
- pts += 2;
-void GDRenderer::_TransferContourPoints(LineBuffer* plb, int cntr, const SE_Matrix* xform)
- else
- double x, y;
- pts[0] = (int)x;
- pts[1] = (int)y;
- pts += 2;
-//copied from WritePolylines, except it doesn't do to screen transform -- we should refactor
-void GDRenderer::DrawScreenPolyline(LineBuffer* srclb, const SE_Matrix* xform, const SE_LineStroke& lineStroke)
- if ((lineStroke.color & 0xFF000000) == 0)
- return;
- if (srclb->geom_count() == 0)
- return; //if you have no geoms, why do you call us at all?
- unsigned int color = lineStroke.color;
- RS_Color c((color >> 16) & 0xFF, (color >> 8) & 0xFF, color & 0xFF, (color >> 24) & 0xFF);
- int gdc = ConvertColor((gdImagePtr)m_imout, c);
- //line width is always device space and units are meters.
- //so convert to equivalent pixel width
- int line_weight = (int)lineStroke.weight;
- brush1 = rs_gdImageThickLineBrush(line_weight, c);
- //draw the lines
- //convert to integer coords
- _TransferContourPoints(srclb, i, xform);
- if (line_weight <= 1)
- else
- if (brush1)
-void GDRenderer::DrawScreenPolygon(LineBuffer* polygon, const SE_Matrix* xform, unsigned int color)
- if ((color & 0xFF000000) == 0)
- return;
- if (polygon->geom_count() == 0)
- //TODO: do the device space calls need fill pattern support?
- _TransferPoints(polygon, xform);
- int total_cntrs = 0;
- int total_pts = 0;
- for (int i = 0; i < polygon->geom_count(); ++i)
- int cntrs = polygon->geom_size(i);
- int pts = 0;
- for (int j = total_cntrs; j < total_cntrs + cntrs; ++j)
- pts += polygon->cntr_size(j);
- m_polyrasterizer->FillPolygon((Point*)(m_wtPointBuffer + total_pts), pts,
- polygon->cntrs() + total_cntrs, cntrs,
- total_cntrs += cntrs;
- total_pts += pts;
- if (fillpat)
-bool GDRenderer::YPointsUp()
- return false;
-void GDRenderer::GetWorldToScreenTransform(SE_Matrix& xform)
- xform.x0 = m_scale;
- xform.x1 = 0.0;
- xform.x2 = - m_offsetX * m_scale;
- xform.y0 = 0.0;
- xform.y1 = - m_scale;
- xform.y2 = m_height /*- 1*/ + m_offsetY * m_scale;
-void GDRenderer::WorldToScreenPoint(double& inx, double& iny, double& ox, double& oy)
- //TODO: assumes no rotation of the viewport
- ox = (inx - m_offsetX) * m_scale;
- oy = m_height /*- 1*/ - (iny - m_offsetY) * m_scale;
-void GDRenderer::ScreenToWorldPoint(double& inx, double& iny, double& ox, double& oy)
- ox = inx * m_invScale + m_offsetX;
- oy = m_offsetY - (iny /*+ 1.0*/ - m_height) * m_invScale;
-// returns number of pixels per millimeter device
-double GDRenderer::GetScreenUnitsPerMillimeterDevice()
- return m_dpi / MILLIMETERS_PER_INCH;
-// returns number of pixels per millimeter world
-double GDRenderer::GetScreenUnitsPerMillimeterWorld()
- return m_dpi / MILLIMETERS_PER_INCH / m_mapScale;
-// screen units are pixels
-double GDRenderer::GetScreenUnitsPerPixel()
- return 1.0;
-RS_FontEngine* GDRenderer::GetRSFontEngine()
- return this;
-//labeling -- this is the entry API for adding SE labels
-//to the label mananger
-void GDRenderer::ProcessSELabelGroup(SE_LabelInfo* labels,
- int nlabels,
- bool exclude,
- LineBuffer* path)
- //pass labels to the label renderer here
- return;
- m_labeler->ProcessLabelGroup(labels, nlabels, type, exclude, path);
-void GDRenderer::DrawScreenRaster(unsigned char* data, int length,
- RS_ImageFormat format, int native_width, int native_height,
- double x, double y, double w, double h, double angleDeg)
- if (format == RS_ImageFormat_Unknown)
- return;
- // compute the scaled / rotated size
- double rotatedW = w;
- double rotatedH = h;
- if (angleDeg != 0.0)
- double csAbs = fabs(cos(angleDeg * M_PI180));
- double snAbs = fabs(sin(angleDeg * M_PI180));
- rotatedW = csAbs*w + snAbs*h;
- rotatedH = snAbs*w + csAbs*h;
- // don't allow images beyond the maximum size
- if (rotatedW * rotatedH > IMAGE_SIZE_MAX)
- return;
- // get the source image
- gdImagePtr src = NULL;
- if (format == RS_ImageFormat_ABGR)
- if (native_width < 0 || native_height < 0)
- return;
- src = gdImageCreateTrueColor(native_width, native_height);
- //TODO: figure out a way to do this without copying the whole thing
- //in such a lame loop
- //at least here we don't call gdImageSetPixel for every pixel
- for (int j=0; j<native_height; j++)
- for (int i=0; i<native_width; i++)
- int srccol = ((int*)data)[i + j * native_width];
- //compute GD alpha and reverse b and r
- int col = gdImageColorAllocateAlpha(src, srccol & 0xFF,
- (srccol >> 8) & 0XFF,
- (srccol >> 16) & 0xFF,
- 127 - ((srccol >> 24) & 0xFF)/ 2);
- src->tpixels[j][i] = col;
- else if (format == RS_ImageFormat_ARGB)
- return;
- int col = gdImageColorAllocateAlpha(src, (srccol >> 16) & 0xFF,
- srccol & 0xFF,
- else if (format == RS_ImageFormat_PNG)
- //NOTE: native_width and native_height arguments are ignored for PNG
- // since they're encoded in the png data array
- src = gdImageCreateFromPngPtr(length, data);
- else
- throw "Well implement this already!";
- if (ROUND(angleDeg) == 0)
- double w2 = w * 0.5;
- double h2 = h * 0.5;
- int minx = ROUND(x - w2);
- int maxx = ROUND(x + w2);
- int miny = ROUND(y - h2);
- int maxy = ROUND(y + h2);
- gdImageCopyResampled((gdImagePtr)m_imout, src,
- minx, miny, 0, 0,
- maxx-minx, maxy-miny, //TODO: do we need +1?
- gdImageSX(src), gdImageSY(src));
- else
- // scale it if necessary
- if ((int)w != gdImageSX(src) || (int)h != gdImageSY(src))
- gdImagePtr dst = gdImageCreateTrueColor((int)w, (int)h);
- gdImageAlphaBlending(dst, 0);
- gdImageFilledRectangle(dst, 0, 0, gdImageSX(dst)-1, gdImageSY(dst)-1, 0x7f000000);
- gdImageAlphaBlending(dst, 1);
- gdImageCopyResampled(dst, src, 0, 0, 0, 0, gdImageSX(dst), gdImageSY(dst), gdImageSX(src), gdImageSY(src));
- gdImageDestroy(src);
- src = dst;
- gdImageCopyRotated((gdImagePtr)m_imout, src, x, y, 0, 0, gdImageSX(src), gdImageSY(src), ROUND(angleDeg));
- double x, double y, double w, double h, double angleDeg,
- double alpha)
- RenderUtil::DrawScreenRaster(this, data, length, format, native_width, native_height,
- x, y, w, h, angleDeg, alpha);
-void GDRenderer::DrawScreenText(const RS_TextMetrics& tm, RS_TextDef& tdef, double insx, double insy,
- RS_F_Point* path, int npts, double param_position)
- if (path)
- // path text - we need to do BIDI conversion before we process the text
- const RS_String& sConv = m_bidiConverter.ConvertString(tm.text);
- // we cannot modify the cached RS_TextMetrics so we create a local one
- // and use it to layout the path text
- RS_TextMetrics tm_local;
- if (GetTextMetrics(sConv, tdef, tm_local, true))
- // TODO: need computed seglens rather than NULL to make things faster
- if (LayoutPathText(tm_local, (RS_F_Point*)path, npts, NULL, param_position, tdef.valign(), 0.5))
- DrawPathText(tm_local, tdef);
- else
- // block text - check that we have a valid text metrics
- if (tm.font != NULL)
- DrawBlockText(tm, tdef, insx, insy);
Deleted: trunk/MgDev/Common/Renderers/GDRenderer.h
--- trunk/MgDev/Common/Renderers/GDRenderer.h 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Common/Renderers/GDRenderer.h 2019-06-22 08:42:36 UTC (rev 9559)
@@ -1,332 +0,0 @@
-// Copyright (C) 2004-2011 by Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-#ifndef GDRENDERER_H
-#define GDRENDERER_H
-// ignore warnings about exception definitions
-#pragma warning(disable: 4290)
-#include "Renderers.h"
-#include "Renderer.h"
-#include "LineBuffer.h"
-#include "LabelRendererBase.h"
-#include "RS_ByteData.h"
-#include "SE_Renderer.h"
-#include "SE_SymbolManager.h"
-#include "RS_FontEngine.h"
-#include "BIDIConverter.h"
-#include <vector>
-class WT_File;
-class WT_Viewport;
-class WT_Logical_Point;
-struct RS_Font;
-class complex_polygon_gd;
-class TransformMesh;
-class GDRenderer : public SE_Renderer, public RS_FontEngine
- friend class LabelRenderer;
- friend class LabelRendererBase;
- friend class LabelRendererLocal;
-public:
- RENDERERS_API GDRenderer(int width,
- int height,
- RS_Color& bgColor,
- bool requiresClipping,
- bool localOverposting,
- double tileExtentOffset);
- RENDERERS_API virtual ~GDRenderer();
- // Renderer implementation
- RENDERERS_API virtual void StartMap(RS_MapUIInfo* mapInfo,
- double mapScale,
- double dpi,
- CSysTransformer* xformToLL = NULL);
- RENDERERS_API virtual void EndMap();
- RENDERERS_API virtual void StartLayer(RS_LayerUIInfo* layerInfo,
- RS_FeatureClassInfo* classInfo);
- RENDERERS_API virtual void EndLayer();
- RENDERERS_API virtual void StartFeature(RS_FeatureReader* feature,
- bool initialPass,
- const RS_String* tooltip = NULL,
- const RS_String* url = NULL,
- const RS_String* theme = NULL,
- double zOffset = 0.0,
- double zExtrusion = 0.0,
- RS_ElevationType zOffsetType = RS_ElevationType_RelativeToGround);
- RENDERERS_API virtual void ProcessPolygon(LineBuffer* lb, RS_FillStyle& fill);
- RENDERERS_API virtual void ProcessPolyline(LineBuffer* lb, RS_LineStroke& lsym);
- RENDERERS_API virtual void ProcessRaster(unsigned char* data,
- int length,
- int width,
- int height,
- TransformMesh* xformMesh = NULL);
- RENDERERS_API virtual void ProcessMarker(LineBuffer* lb, RS_MarkerDef& mdef, bool allowOverpost, RS_Bounds* bounds = NULL);
- RENDERERS_API virtual void ProcessLabelGroup(RS_LabelInfo* labels,
- int nlabels,
- bool exclude,
- LineBuffer* path,
- double scaleLimit);
- RENDERERS_API virtual void AddDWFContent(RS_InputStream* in,
- const RS_String& w2dfilter);
- RENDERERS_API virtual void SetSymbolManager(RS_SymbolManager* manager);
- virtual RS_MapUIInfo* GetMapInfo();
- virtual RS_LayerUIInfo* GetLayerInfo();
- virtual RS_FeatureClassInfo* GetFeatureClassInfo();
- virtual double GetMapScale();
- virtual double GetDrawingScale();
- virtual double GetMetersPerUnit();
- virtual double GetDpi();
- virtual RS_Bounds& GetBounds();
- virtual bool RequiresClipping();
- virtual bool RequiresLabelClipping();
- virtual bool SupportsZ();
- virtual bool SupportsTooltips();
- virtual bool SupportsHyperlinks();
- // GDRenderer specific
- RENDERERS_API RS_ByteData* Save(const RS_String& format, int width, int height);
- RENDERERS_API void Save(const RS_String& filename, const RS_String& format);
- RENDERERS_API void Save(const RS_String& filename, const RS_String& format, int width, int height);
- void Combine(const RS_String& fileIn1, const RS_String& fileIn2, const RS_String& fileOut);
- // SE_Renderer
- virtual void SetRenderSelectionMode(bool mode);
- virtual void SetRenderSelectionMode(bool mode, int rgba);
- virtual void DrawScreenPolyline(LineBuffer* geom, const SE_Matrix* xform, const SE_LineStroke& lineStroke);
- virtual void DrawScreenPolygon(LineBuffer* geom, const SE_Matrix* xform, unsigned int fill);
- virtual void DrawScreenRaster(unsigned char* data, int length,
- double x, double y, double w, double h, double angleDeg);
- double alpha);
- virtual void DrawScreenText(const RS_TextMetrics& tm, RS_TextDef& tdef, double insx, double insy,
- RS_F_Point* path, int npts, double param_position);
- virtual bool YPointsUp();
- virtual void GetWorldToScreenTransform(SE_Matrix& xform);
- virtual void WorldToScreenPoint(double& inx, double& iny, double& ox, double& oy);
- virtual void ScreenToWorldPoint(double& inx, double& iny, double& ox, double& oy);
- virtual double GetScreenUnitsPerMillimeterDevice();
- virtual double GetScreenUnitsPerMillimeterWorld();
- virtual double GetScreenUnitsPerPixel();
- virtual RS_FontEngine* GetRSFontEngine();
- virtual void ProcessSELabelGroup(SE_LabelInfo* labels,
- int nlabels,
- bool exclude,
- LineBuffer* path = NULL);
- virtual void ProcessLine(SE_ApplyContext* ctx, SE_RenderLineStyle* style);
- virtual void ProcessArea(SE_ApplyContext* ctx, SE_RenderAreaStyle* style);
- virtual void AddExclusionRegion(RS_F_Point* fpts, int npts);
- // RS_FontEngine
- virtual void MeasureString(const RS_String& s,
- double height,
- double angleRad,
- RS_F_Point* res,
- float* offsets);
- virtual void DrawString(const RS_String& s,
- double x,
- double y,
- double width,
- double height,
- RS_Color& color,
- double angleRad);
- virtual const RS_Font* FindFont(RS_FontDef& def);
-private:
- double _MeterToMapSize(RS_Units unit, double number);
- LineBuffer* ApplyLineStyle(LineBuffer* srcLB, wchar_t* lineStyle, double lineWidthPixels, double drawingScale, double dpi);
- void ProcessOneMarker(double x, double y, RS_MarkerDef& mdef, bool allowOverpost, RS_Bounds* bounds = NULL);
- void WritePolylines(LineBuffer* srclb, RS_LineStroke& stroke, bool aa);
- //transformation from mapping to W2D space
- inline int _TX(double x);
- inline int _TY(double y);
- void _TransformPointsNoClamp(LineBuffer* plb);
- void _TransformContourPointsNoClamp(LineBuffer* plb, int cntr);
- void _TransferPoints(LineBuffer* plb, const SE_Matrix* xform);
- void _TransferContourPoints(LineBuffer* plb, int cntr, const SE_Matrix* xform);
- RS_Color m_bgcolor;
- RS_Bounds m_extents;
- double m_metersPerUnit;
- double m_dpi;
- double m_mapScale;
- double m_scale;
- double m_invScale;
- double m_offsetX;
- double m_offsetY;
- int m_width;
- int m_height;
- int m_maxLineWidth;
- double m_drawingScale;
- bool m_bRequiresClipping;
- RS_SymbolManager* m_symbolManager;
- //buffer to hold device space points during conversion from line buffers
- //to W2D drawables
- RS_D_Point* m_wtPointBuffer;
- int m_wtPointLen;
- void EnsureBufferSize(int len);
- void* m_imout;
- void* m_imsym;
- int m_lineColor;
- RS_FillStyle m_selFill;
- LabelRendererBase* m_labeler;
- BIDIConverter m_bidiConverter;
-public:
- RENDERERS_API static bool s_bGeneralizeData;
- // Functions and structures used during insertion of W2Ds
- //TODO: these should be extracted to a friend class that holds
- // all of the W2D rewriting context
-public:
- /*Do not export from DLL*/ void* GetImage() { return m_imout; } //target map image
- /*Do not export from DLL*/ void* GetW2DTargetImage() { return m_imw2d; } //target image for W2D rewriter
- /*Do not export from DLL*/ complex_polygon_gd* GetPolyRasterizer() { return m_polyrasterizer; } //for drawing contour sets
- /*Do not export from DLL*/ bool IsViewportSet() { return m_bHaveViewport; }
- /*Do not export from DLL*/ bool IsSymbolW2D() { return m_bIsSymbolW2D; }
- /*Do not export from DLL*/ void UpdateSymbolTrans(WT_File& file, WT_Viewport& viewport);
- /*Do not export from DLL*/ RS_MarkerDef& GetOverrideColorMarker() { return m_mdOverrideColors; }
- /*Do not export from DLL*/ RS_String& GetLayerFilter() { return m_layerFilter; }
- /*Do not export from DLL*/ bool& LayerPassesFilter() { return m_bLayerPassesFilter; }
- /*Do not export from DLL*/ RS_InputStream* _GetInputStream() { return m_input; }
- /*Do not export from DLL*/ const RS_D_Point* ProcessW2DPoints(WT_File& file,
- int numpts,
- bool checkInBounds);
- /*Do not export from DLL*/ double ScaleW2DNumber(WT_File& file, long number);
- /*Do not export from DLL*/ const RS_D_Point* FillPointBuffer(LineBuffer* lb);
-private:
- void AddW2DContent(RS_InputStream* in, CSysTransformer* xformer, const RS_String& w2dfilter);
- void SetActions(WT_File& file);
- //State variables for when DWFRenderer is used to keep
- //information during DWF rewriting process for symbols
- //and DWF layers
- std::vector<int> m_cntrs;
- RS_InputStream* m_input;
- CSysTransformer* m_xformer;
- bool m_bIsSymbolW2D;
- bool m_bHaveViewport;
- bool m_bLayerPassesFilter;
- RS_String m_layerFilter;
- //target image for W2D rewriter -- equal to either the target map
- //image or to a temporary cached symbol image in case we are
- //processing a symbol from the library
- void* m_imw2d;
- // map/layer/feature info
- RS_MapUIInfo* m_mapInfo;
- RS_LayerUIInfo* m_layerInfo;
- RS_FeatureClassInfo* m_featureClassInfo;
- //storage for override colors
- RS_MarkerDef m_mdOverrideColors;
- //remember id of last symbol
- RS_MarkerDef m_lastSymbol;
- //polygon rasterizer
- complex_polygon_gd* m_polyrasterizer;
-#endif
Deleted: trunk/MgDev/Common/Renderers/GDW2DRewriter.cpp
--- trunk/MgDev/Common/Renderers/GDW2DRewriter.cpp 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Common/Renderers/GDW2DRewriter.cpp 2019-06-22 08:42:36 UTC (rev 9559)
@@ -1,1134 +0,0 @@
-#include "stdafx.h"
-#include "GDRenderer.h"
-#include "GDW2DRewriter.h"
-#include "gd.h"
-#include "GDUtils.h"
-#include "complex_polygon_gd.h"
-#define ROUND(x) (int)(floor(x+0.5))
-// I/O Overloads
-WT_Result gdr_open(WT_File & /*file*/)
- return WT_Result::Success;
-WT_Result gdr_close(WT_File & file)
- file.set_stream_user_data(WD_Null);
-WT_Result gdr_read(WT_File & file, int desired_bytes, int & bytes_read, void * buffer)
- bytes_read = (int)((GDRenderer*)file.stream_user_data())->_GetInputStream()->read(buffer, desired_bytes);
- if (!bytes_read)
- return WT_Result::Unknown_File_Read_Error;
-WT_Result gdr_seek(WT_File & file, int distance, int & amount_seeked)
- off_t prev = 0;
- ((GDRenderer*)file.stream_user_data())->_GetInputStream()->seek(distance, prev);
- amount_seeked = distance;
-// Implementation of Actions....
-WT_Result gdr_process_units(WT_Units & units, WT_File & file)
- GDRenderer* rewriter = (GDRenderer*)file.stream_user_data();
- //do not write the units -- the destination W2D has different units
- //units.serialize(*rewriter->_GetW2D());
- //Instead save the in the desired rendition of the source file
- //so that we can get to them when transforming coordinates for DWF layers
- //Note that for DWF point symbols we do not do that
- if (!rewriter->IsSymbolW2D())
- file.desired_rendition().drawing_info().units() = units;
-WT_Result gdr_process_color(WT_Color & color, WT_File & file)
- //note reversal of r and b
- WT_RGBA32 rgba = color.rgba();
- RS_Color c(rgba.m_rgb.b, rgba.m_rgb.g, rgba.m_rgb.r, rgba.m_rgb.a);
- int gdc = ConvertColor((gdImagePtr)rewriter->GetW2DTargetImage(), c);
- gdImageSetAntiAliased((gdImagePtr)rewriter->GetW2DTargetImage(), gdc);
- file.rendition().color() = color;
-WT_Result gdr_process_lineWeight(WT_Line_Weight & lineWeight, WT_File & file)
- //GDRenderer* rewriter = (GDRenderer*)file.stream_user_data();
- //rescale the line weight
- //int dstWeight = rewriter->ScaleW2DNumber(file, lineWeight.weight_value());
- file.rendition().line_weight() = lineWeight;
-WT_Result gdr_process_viewport(WT_Viewport & viewport, WT_File & file)
- //IMPORTANT: AutoCAD defines a viewport for each view of the
- //drawing displayed in paper space. These views are arranged
- //to fit on the page via several of the viewports.
- //For symbols coming from the import engine, only one viewport
- //is set, corresponding to the extent all the symbol entities.
- //We use this viewport setting in order to determine the extent
- //of the W2D entities in the symbol W2D, since they are not the
- //same as the extent that Studio will use when generating symbol
- //W2Ds (0, 0, SYMBOL_MAX, SYMBOL_MAX).
- //In the case this code is used for DWF layers, things are more complicated
- //as there are often multiple viewports, defining extents for part of the data.
- //We cannot handle this for now
- if (rewriter->IsSymbolW2D() && ! rewriter->IsViewportSet())
- rewriter->UpdateSymbolTrans(file, viewport);
- //(*rewriter->GetW2DTargetImage()).desired_rendition().viewport() = viewport;
-WT_Result gdr_process_colorMap(WT_Color_Map & colorMap, WT_File & file)
- file.rendition().color_map() = colorMap;
-WT_Result gdr_process_contourSet(WT_Contour_Set & contourSet, WT_File & file)
- if (file.rendition().visibility().visible() == WD_False)
- if (!rewriter->LayerPassesFilter())
- WT_RGBA32 rgba = file.rendition().color().rgba();
- RS_Color color = RS_Color(rgba.m_rgb.r, rgba.m_rgb.g, rgba.m_rgb.b, rgba.m_rgb.a);
- //check for override color
- if (rewriter->IsSymbolW2D())
- RS_Color override = rewriter->GetOverrideColorMarker().style().color();
- if (override.argb() != RS_Color::EMPTY_COLOR_ARGB)
- color = override;
- //transform point and draw the contour set
- int numcntrs = contourSet.contours();
- WT_Integer32* cntrcounts = contourSet.counts();
- int totalPts = contourSet.total_points();
- const RS_D_Point* dst_cntr = rewriter->ProcessW2DPoints(file, (WT_Logical_Point*)contourSet.points(), totalPts, true);
- if (dst_cntr)
- if (color.alpha() != 0)
- int gdc = ConvertColor((gdImagePtr)rewriter->GetW2DTargetImage(), color);
- //call the new rasterizer
- rewriter->GetPolyRasterizer()->FillPolygon((Point*)dst_cntr, totalPts, (int*)cntrcounts, numcntrs,
- gdc, (gdImagePtr)rewriter->GetW2DTargetImage());
-WT_Result gdr_process_fill(WT_Fill & fill, WT_File & file)
- file.rendition().fill() = fill;
-WT_Result gdr_process_font(WT_Font & font, WT_File & file)
- /*GDRenderer* rewriter = (GDRenderer*)file.stream_user_data();*/
- file.rendition().font() = font;
-WT_Result gdr_process_gouraudPolyline(WT_Gouraud_Polyline & /*gouraudPolyline*/, WT_File & /*file*/)
- //TODO: if the polyline is clipped, the colors will be wrong
- //WT_Gouraud_Polyline poly2(numpts, dstpts, gouraudPolyline.colors(), true);
- //poly2.serialize(*rewriter->GetW2DTargetImage());
-WT_Result gdr_process_gouraudPolytriangle(WT_Gouraud_Polytriangle & /*gouraudPolytriangle*/, WT_File & /*file*/)
- //TODO: clipping for polytriangles is needed
- //gouraudPolytriangle.serialize(*rewriter->GetW2DTargetImage());
-WT_Result gdr_process_image(WT_Image & image, WT_File & file)
- //transform the bounds
- WT_Logical_Box bounds = image.bounds();
- WT_Logical_Point endpts[4];
- endpts[0].m_x = bounds.m_min.m_x;
- endpts[0].m_y = bounds.m_min.m_y;
- endpts[1].m_x = bounds.m_max.m_x;
- endpts[1].m_y = bounds.m_min.m_y;
- endpts[2].m_x = bounds.m_max.m_x;
- endpts[2].m_y = bounds.m_max.m_y;
- endpts[3].m_x = bounds.m_min.m_x;
- endpts[3].m_y = bounds.m_max.m_y;
- const RS_D_Point* dstpts = rewriter->ProcessW2DPoints(file, endpts, 4, false);
- if (image.format() == WT_Image::RGBA)
- src = gdImageCreateTrueColor(image.columns(), image.rows());
- gdImageAlphaBlending(src, 0);
- for (int j=0; j<image.rows(); j++)
- for (int i=0; i<image.columns(); i++)
- WT_RGBA32 rgba = ((WT_RGBA32*)image.data())[i + j*image.columns()];
- RS_Color rsc(rgba.m_rgb.b, rgba.m_rgb.g, rgba.m_rgb.r, rgba.m_rgb.a);
- int gdc = ConvertColor(src, rsc);
- gdImageSetPixel(src, i, j, gdc);
- gdImageAlphaBlending(src, 1);
- else if (image.format() == WT_Image::RGB)
- WT_RGBA32 rgba;
- const unsigned char* ptr = image.data() + 3*(i + j * image.columns());
- rgba.m_rgb.b = *ptr++;
- rgba.m_rgb.g = *ptr++;
- rgba.m_rgb.r = *ptr++;
- rgba.m_rgb.a = 255;
- RS_Color rsc(rgba.m_rgb.r, rgba.m_rgb.g, rgba.m_rgb.b, rgba.m_rgb.a);
- gdImageSetPixel(src, i, j, ConvertColor(src, rsc));
- else if (image.format() == WT_Image::JPEG)
- src = gdImageCreateFromJpegPtr(image.data_size(), (void*)image.data());
- if (src)
- double angleRad = atan2((double)(dstpts[1].y - dstpts[0].y), (double)(dstpts[1].x - dstpts[0].x));
- int iAngleDeg = ROUND(-angleRad * M_180PI);
- //case of no rotation
- if (iAngleDeg == 0)
- int left = rs_min(dstpts[0].x, dstpts[1].x);
- int top = rs_min(dstpts[1].y, dstpts[2].y);
- int width = dstpts[1].x - dstpts[0].x;
- int height = dstpts[1].y - dstpts[2].y; //y is inverted
- gdImageCopyResampled((gdImagePtr)rewriter->GetW2DTargetImage(), src,
- left, top, //dstX, dstY
- 0, 0, //srcX, srcY
- width, height, //int dstW, int dstH,
- image.columns(), image.rows() //srcW, srcH
- else
- int dx = dstpts[1].x - dstpts[0].x;
- int dy = dstpts[1].y - dstpts[0].y;
- int width = (int)sqrt((double)dx*dx + dy*dy);
- dx = dstpts[2].x - dstpts[1].x;
- dy = dstpts[2].y - dstpts[1].y;
- int height = (int)sqrt((double)dx*dx + dy*dy);
- //see if we need to rescale the original image
- if (width != src->sx || height != src->sy)
- gdImagePtr resized = gdImageCreateTrueColor(width, height);
- gdImageAlphaBlending(resized, 0);
- gdImageFilledRectangle(resized, 0, 0, width-1, height-1, 0x7f000000);
- gdImageAlphaBlending(resized, 1);
- gdImageCopyResampled(resized, src,
- 0, 0, //dstX, dstY
- width, height, //dstW, dstH,
- src->sx, src->sy); //srcW, srcH
- src = resized;
- double midx = 0.5 * (dstpts[0].x + dstpts[2].x);
- double midy = 0.5 * (dstpts[0].y + dstpts[2].y);
- gdImageCopyRotated((gdImagePtr)rewriter->GetW2DTargetImage(),
- src,
- midx, midy, //dstX, dstY
- src->sx, src->sy, //srcW, srcH
- iAngleDeg);
-WT_Result gdr_process_origin(WT_Origin & origin, WT_File & file)
- WT_Logical_Point pt = origin.origin();
- //transform origin into new space
- const RS_D_Point* pts = rewriter->ProcessW2DPoints(file, &pt, 1, false);
- pts = NULL;
- //WT_Origin origin2(pts[0]);
- file.update_current_point (origin.origin());
- //origin2.serialize(*rewriter->GetW2DTargetImage());
-WT_Result gdr_process_filledEllipse(WT_Filled_Ellipse & filledEllipse, WT_File & file)
- //process override color, if any
- if (rewriter->IsSymbolW2D() && rewriter->GetOverrideColorMarker().style().color().argb() != RS_Color::EMPTY_COLOR_ARGB)
- color = override;
- WT_Logical_Point center = filledEllipse.position();
- const RS_D_Point* dstpts = rewriter->ProcessW2DPoints(file, (WT_Logical_Point*)¢er, 1, false);
- //negate because GD is left-handed coords
- double tilt = -filledEllipse.tilt_radian();
- if (tilt == 0.0)
- // case where ellipse is unrotated
- int major = ROUND(rewriter->ScaleW2DNumber(file, filledEllipse.major()));
- int minor = ROUND(rewriter->ScaleW2DNumber(file, filledEllipse.minor()));
- //simple bounds check before we draw
- if ( !(dstpts[0].x + major < 0
- || dstpts[0].x - major > ((gdImagePtr)rewriter->GetW2DTargetImage())->sx
- || dstpts[0].y + minor < 0
- || dstpts[0].x - minor > ((gdImagePtr)rewriter->GetW2DTargetImage())->sy))
- float end = 360.f - filledEllipse.start_degree();
- float start = 360.f - filledEllipse.end_degree();
- //gd does not like negative angles (its sin/cos lookup table doesn't)
- while (start < 0.f)
- start += 360.f;
- end += 360.f;
- gdImageFilledArc((gdImagePtr)rewriter->GetW2DTargetImage(),
- dstpts[0].x, dstpts[0].y,
- major * 2, minor * 2,
- (int)start, (int)end,
- gdc, gdArc);
- else
- // case where ellipse is rotated
- double rcos = cos(tilt);
- double rsin = sin(tilt);
- double major = rewriter->ScaleW2DNumber(file, filledEllipse.major());
- double minor = rewriter->ScaleW2DNumber(file, filledEllipse.minor());
- // the half-width / half-height of the bounding box for the rotated ellipse
- int wid2 = (int)sqrt(major*major*rcos*rcos + minor*minor*rsin*rsin) + 1;
- int hgt2 = (int)sqrt(major*major*rsin*rsin + minor*minor*rcos*rcos) + 1;
- if ( !(dstpts[0].x + wid2 < 0
- || dstpts[0].x - wid2 > ((gdImagePtr)rewriter->GetW2DTargetImage())->sx
- || dstpts[0].y + hgt2 < 0
- || dstpts[0].x - hgt2 > ((gdImagePtr)rewriter->GetW2DTargetImage())->sy))
- double start = -filledEllipse.start_radian();
- double end = -filledEllipse.end_radian();
- // compute start point
- double tx = major * cos(start);
- double ty = minor * sin(start);
- double startX = dstpts[0].x + tx*rcos - ty*rsin;
- double startY = dstpts[0].y + ty*rcos + tx*rsin;
- // use a line buffer to tessellate the arc
- LineBuffer* ell = LineBufferPool::NewLineBuffer(rewriter->GetBufferPool(), 20);
- std::unique_ptr<LineBuffer> spEllLB(ell);
- ell->SetDrawingScale(1.0);
- ell->MoveTo(startX, startY);
- ell->ArcTo(dstpts[0].x, dstpts[0].y, major, minor, start, end, tilt);
- int numpts = ell->point_count();
- const RS_D_Point* dstpts = rewriter->FillPointBuffer(ell);
- LineBufferPool::FreeLineBuffer(rewriter->GetBufferPool(), spEllLB.release());
- gdImageFilledPolygon((gdImagePtr)rewriter->GetW2DTargetImage(),
- (gdPointPtr)dstpts,
- numpts,
- gdc);
-WT_Result gdr_process_outlineEllipse(WT_Outline_Ellipse & outlineEllipse, WT_File & file)
- RS_Color override = rewriter->GetOverrideColorMarker().style().outline().color();
- color = override;
- WT_Logical_Point center = outlineEllipse.position();
- double tilt = -outlineEllipse.tilt_radian();
- if (tilt == 0.0)
- int major = ROUND(rewriter->ScaleW2DNumber(file, outlineEllipse.major()));
- int minor = ROUND(rewriter->ScaleW2DNumber(file, outlineEllipse.minor()));
- float end = 360.f - outlineEllipse.start_degree();
- float start = 360.f - outlineEllipse.end_degree();
- start += 360.f;
- end += 360.f;
- // handle thickness
- //get W2D line weight
- int thick = ROUND(rewriter->ScaleW2DNumber(file, file.rendition().line_weight().weight_value()));
- if (thick > 1)
- brush1 = rs_gdImageThickLineBrush(thick, color);
- gdImageSetBrush((gdImagePtr)rewriter->GetW2DTargetImage(), brush1);
- gdImageArc((gdImagePtr)rewriter->GetW2DTargetImage(),
- brush1 ? gdBrushed : gdc);
- if (brush1)
- gdImageSetBrush((gdImagePtr)rewriter->GetW2DTargetImage(), NULL);
- gdImageDestroy(brush1);
- else
- double major = rewriter->ScaleW2DNumber(file, outlineEllipse.major());
- double minor = rewriter->ScaleW2DNumber(file, outlineEllipse.minor());
- double start = -outlineEllipse.start_radian();
- double end = -outlineEllipse.end_radian();
- if (thick > 1)
- gdImageOpenPolygon((gdImagePtr)rewriter->GetW2DTargetImage(),
- numpts,
- if (brush1)
-WT_Result gdr_process_polygon(WT_Polygon & polygon, WT_File & file)
- color = override;
- //do all necessary transformations
- file, polygon.points(), polygon.count(), true);
- if (dstpts)
- polygon.count(),
- gdc);
-WT_Result gdr_process_polytriangle(WT_Polytriangle & polytriangle, WT_File & file)
- color = override;
- WT_Logical_Point* srcpts = polytriangle.points();
- const RS_D_Point* dstpts = rewriter->ProcessW2DPoints(file, srcpts, polytriangle.count(), true);
- if (dstpts)
- for (int i=2; i < polytriangle.count(); i++)
- (gdPointPtr)(dstpts + i - 2),
- 3,
- gdc);
-WT_Result gdr_process_pngGroup4Image(WT_PNG_Group4_Image & pngGroup4Image, WT_File & file)
- WT_Logical_Box bounds = pngGroup4Image.bounds();
- file, endpts, 4, false);
- gdImagePtr src = gdImageCreateFromPngPtr(pngGroup4Image.data_size(), (void*)pngGroup4Image.data());
- pngGroup4Image.columns(), pngGroup4Image.rows() //srcW, srcH
- else
- src = resized;
- src,
- iAngleDeg);
-WT_Result gdr_process_polyline(WT_Polyline & polyline, WT_File & file)
- //TODO: we have no easy way to determine if a polyline is
- //just a polyline or the outline of a polygon. Since we need to
- //use different override colors in these cases, we will take a guess.
- bool isPossiblyPolygonOutline = false;
- //if the first point and the last point of the polyline are equal,
- //we will treat it as a polygon outline
- if (polyline.count() > 2
- && polyline.points()[0] == polyline.points()[polyline.count() - 1])
- isPossiblyPolygonOutline = true;
- color = override;
- //do all necessary transformations and clipping
- file, polyline.points(), polyline.count(), true);
- if (dstpts)
- if (thick > 1)
- polyline.count(),
- if (brush1)
-WT_Result gdr_process_text(WT_Text & text, WT_File & file)
- //text override color is stored in the bg color of the fill
- //which is otherwise unused
- if (rewriter->IsSymbolW2D() && rewriter->GetOverrideColorMarker().style().background().argb() != RS_Color::EMPTY_COLOR_ARGB)
- RS_Color override = rewriter->GetOverrideColorMarker().style().background();
- color = override;
- WT_Logical_Point pt = text.position();
- const RS_D_Point* dstpts = rewriter->ProcessW2DPoints(file, &pt, 1, true);
- if (dstpts)
- const WT_Font& font = file.rendition().font();
- //rescale font height
- double hgt = 0.75 * rewriter->ScaleW2DNumber(file, font.height().height());
- double angleRad = (double)font.rotation().rotation() * 2.0 * M_PI / 65536.0;
- //match the font
- int style = RS_FontStyle_Regular;
- if (font.style().bold() == WD_True)
- style |= (int)RS_FontStyle_Bold;
- if (font.style().italic() == WD_True)
- style |= (int)RS_FontStyle_Italic;
- if (font.style().underlined() == WD_True)
- style |= (int)RS_FontStyle_Underline;
- wchar_t* uni_name = WT_String::to_wchar(font.font_name().name().length(),
- font.font_name().name().unicode());
- RS_String rs_uni_name = uni_name;
- RS_FontDef fdef(rs_uni_name, hgt, (RS_FontStyle_Mask)style, RS_Units_Model);
- delete [] uni_name;
- const RS_Font* rsfont = rewriter->FindFont(fdef);
- //draw the text
- wchar_t* uni_text = WT_String::to_wchar(text.string().length(), text.string().unicode());
- //width is not used by GDRenderer - can leave at zero
- rewriter->DrawString(uni_text, dstpts[0].x, dstpts[0].y, 0.0, hgt, rsfont, color, angleRad);
- delete [] uni_text;
- //TODO: optionally text position can be specified using
- //a bounds box. This case needs to be handled here too
-WT_Result gdr_process_visibility(WT_Visibility & visibility, WT_File & file)
- file.rendition().visibility() = visibility;
-WT_Result gdr_process_codePage(WT_Code_Page & /*codePage*/, WT_File & /*file*/)
- //(*rewriter->GetW2DTargetImage()).desired_rendition().code_page() = codePage;
-WT_Result gdr_process_plotInfo(WT_Plot_Info & /*plotInfo*/, WT_File & /*file*/)
- //plotInfo.serialize(*rewriter->GetW2DTargetImage());
-WT_Result gdr_process_background(WT_Background & /*background*/, WT_File & /*file*/)
- //background.serialize(*rewriter->GetW2DTargetImage());
-WT_Result gdr_process_polymarker(WT_Polymarker & polymarker, WT_File & file)
- const RS_D_Point* dstpts = rewriter->ProcessW2DPoints(file, polymarker.points(), polymarker.count(), true);
- dstpts = NULL;
- //WT_Polymarker poly2(outpts, dstpts, true);
-WT_Result gdr_process_markerSize(WT_Marker_Size & /*markerSize*/, WT_File & /*file*/)
- //rescale the marker size
- //WT_Integer32 size2 = rewriter->ScaleW2DNumber(file, markerSize.size());
- //(*rewriter->GetW2DTargetImage()).desired_rendition().marker_size() = WT_Marker_Size(size2);
-WT_Result gdr_process_markerSymbol(WT_Marker_Symbol & /*markerSymbol*/, WT_File & /*file*/)
-WT_Result gdr_process_mergeControl(WT_Merge_Control & /*mergeControl*/, WT_File & /*file*/)
-WT_Result gdr_process_projection(WT_Projection & /*projection*/, WT_File & /*file*/)
-WT_Result gdr_process_inkedArea(WT_Inked_Area & /*inkedArea*/, WT_File & /*file*/)
-WT_Result gdr_process_alignment(WT_Alignment & /*alignment*/, WT_File & /*file*/)
-WT_Result gdr_process_penPattern(WT_Pen_Pattern & /*penPattern*/, WT_File & /*file*/)
-WT_Result gdr_process_linePattern(WT_Line_Pattern & /*linePattern*/, WT_File & /*file*/)
-WT_Result gdr_process_fillPattern(WT_Fill_Pattern & /*fillPattern*/, WT_File & /*file*/)
-WT_Result gdr_process_dashPattern(WT_Dash_Pattern & /*dashPattern*/, WT_File & /*file*/)
-WT_Result gdr_process_lineStyle(WT_Line_Style & /*lineStyle*/, WT_File & /*file*/)
-WT_Result gdr_process_layer(WT_Layer & layer, WT_File & file)
- //Most of the time layers are referred to by their integer id only.
- //Only the first time they are identified by name which we need to keep
- //track of.
- //first see if we already have this layer
- WT_Layer* layer2 = file.layer_list().find_layer_from_index(layer.layer_num());
- //if we don't have it in the list, add it
- if (!layer2)
- file.layer_list().add_layer(layer);
- layer2 = &layer;
- wchar_t* name = WT_String::to_wchar(layer2->layer_name().length(), layer2->layer_name().unicode());
- //check if the current layer was requested by looking it up
- //in the W2D layer filter that was passes to the renderer
- RS_String filter = rewriter->GetLayerFilter();
- if (!filter.empty())
- rewriter->LayerPassesFilter() = false;
- wchar_t* strTok = (wchar_t*)alloca(sizeof(wchar_t) * (filter.length() + 1));
- wcscpy(strTok, filter.c_str());
- wchar_t* ptr;
- wchar_t* token = _wcstok(strTok, L",", &ptr);
- while (token)
- if (wcscmp(token, name) == 0)
- rewriter->LayerPassesFilter() = true;
- break;
- token = _wcstok(NULL, L",", &ptr);
- delete [] name;
Deleted: trunk/MgDev/Common/Renderers/GDW2DRewriter.h
--- trunk/MgDev/Common/Renderers/GDW2DRewriter.h 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Common/Renderers/GDW2DRewriter.h 2019-06-22 08:42:36 UTC (rev 9559)
@@ -1,100 +0,0 @@
-#ifndef GDW2DREWRITER_H
-#define GDW2DREWRITER_H
-#include "whiptk/whip_toolkit.h"
-// Standard action routines.
-WT_Result gdr_open(WT_File & file);
-WT_Result gdr_close(WT_File & file);
-WT_Result gdr_read(WT_File & file, int desired_bytes, int &bytes_read, void * buffer);
-WT_Result gdr_seek(WT_File & file, int distance, int &amount_seeked);
-//WT_Result gdr_process_author(WT_Author & author, WT_File & file);
-//WT_Result gdr_process_creator(WT_Creator & creator, WT_File & file);
-//WT_Result gdr_process_created(WT_Creation_Time & created, WT_File & file);
-//WT_Result gdr_process_modified(WT_Modification_Time & modified, WT_File & file);
-//WT_Result gdr_process_sourceFilename(WT_Source_Filename & sourceFilename, WT_File & file);
-//WT_Result gdr_process_sourceCreationTime(WT_Source_Creation_Time & sourceCreated, WT_File & file);
-//WT_Result gdr_process_sourceModificationTime(WT_Source_Modification_Time & sourceModified, WT_File & file);
-WT_Result gdr_process_units(WT_Units & units, WT_File & file);
-//WT_Result gdr_process_embed(WT_Embed & embed, WT_File & file);
-//WT_Result gdr_process_namedView(WT_Named_View & namedView, WT_File & file);
-//WT_Result gdr_process_view(WT_View & view, WT_File & file);
-WT_Result gdr_process_plotInfo(WT_Plot_Info & plotInfo, WT_File & file);
-WT_Result gdr_process_background(WT_Background & background, WT_File & file);
-WT_Result gdr_process_color(WT_Color & color, WT_File & file);
-WT_Result gdr_process_lineWeight(WT_Line_Weight & lineWeight, WT_File & file);
-WT_Result gdr_process_lineStyle(WT_Line_Style & lineStyle, WT_File & file);
-WT_Result gdr_process_linePattern(WT_Line_Pattern & linePattern, WT_File & file);
-WT_Result gdr_process_layer(WT_Layer & layer, WT_File & file);
-WT_Result gdr_process_viewport(WT_Viewport & viewport, WT_File & file);
-WT_Result gdr_process_visibility(WT_Visibility & visibility, WT_File & file);
-WT_Result gdr_process_codePage(WT_Code_Page & codePage, WT_File & file);
-WT_Result gdr_process_colorMap(WT_Color_Map & colorMap, WT_File & file);
-//WT_Result gdr_process_comments(WT_Comments & comments, WT_File & file);
-WT_Result gdr_process_contourSet(WT_Contour_Set & contourSet, WT_File & file);
-//WT_Result gdr_process_copyright(WT_Copyright & copyright, WT_File & file);
-WT_Result gdr_process_dashPattern(WT_Dash_Pattern & dashPattern, WT_File & file);
-//WT_Result gdr_process_description(WT_Description & description, WT_File & file);
-WT_Result gdr_process_fill(WT_Fill & fill, WT_File & file);
-WT_Result gdr_process_filledEllipse(WT_Filled_Ellipse & filledEllipse, WT_File & file);
-WT_Result gdr_process_font(WT_Font & font, WT_File & file);
-WT_Result gdr_process_gouraudPolyline(WT_Gouraud_Polyline & gouraudPolyline, WT_File & file);
-WT_Result gdr_process_gouraudPolytriangle(WT_Gouraud_Polytriangle & gouraudPolytriangle, WT_File & file);
-WT_Result gdr_process_image(WT_Image & image, WT_File & file);
-//WT_Result gdr_process_keywords(WT_Keywords & keywords, WT_File & file);
-WT_Result gdr_process_markerSize(WT_Marker_Size & markerSize, WT_File & file);
-WT_Result gdr_process_markerSymbol(WT_Marker_Symbol & markerSymbol, WT_File & file);
-WT_Result gdr_process_mergeControl(WT_Merge_Control & mergeControl, WT_File & file);
-//WT_Result gdr_process_namedViewList(WT_Named_View_List & namedViewList, WT_File & file);
-WT_Result gdr_process_origin(WT_Origin & origin, WT_File & file);
-WT_Result gdr_process_outlineEllipse(WT_Outline_Ellipse & outlineEllipse, WT_File & file);
-WT_Result gdr_process_polygon(WT_Polygon & polygon, WT_File & file);
-WT_Result gdr_process_polymarker(WT_Polymarker & polymarker, WT_File & file);
-WT_Result gdr_process_polytriangle(WT_Polytriangle & polytriangle, WT_File & file);
-WT_Result gdr_process_projection(WT_Projection & projection, WT_File & file);
-//WT_Result gdr_process_subject(WT_Subject & subject, WT_File & file);
-//WT_Result gdr_process_title(WT_Title & title, WT_File & file);
-//WT_Result gdr_process_unknown(WT_Unknown & unknown, WT_File & file);
-//WT_Result gdr_process_url(WT_URL & url, WT_File & file);
-WT_Result gdr_process_pngGroup4Image(WT_PNG_Group4_Image & pngGroup4Image, WT_File & file);
-WT_Result gdr_process_polyline(WT_Polyline & polyline, WT_File & file);
-WT_Result gdr_process_text(WT_Text & text, WT_File & file);
-WT_Result gdr_process_inkedArea(WT_Inked_Area & inkedArea, WT_File & file);
-//WT_Result gdr_process_plotOptimized(WT_Plot_Optimized & plotOptimized, WT_File & file);
-//WT_Result gdr_process_groupBegin(WT_Group_Begin & groupBegin, WT_File & file);
-//WT_Result gdr_process_groupEnd(WT_Group_End & groupEnd, WT_File & file);
-//WT_Result gdr_process_embeddedFont(WT_Embedded_Font & embeddedFont, WT_File & file);
-//WT_Result gdr_process_trustedFontList(WT_Trusted_Font_List & tustedFontList, WT_File & file);
-//WT_Result gdr_process_blockref(WT_BlockRef & blockref, WT_File & file);
-//WT_Result gdr_process_blockMeaning(WT_Block_Meaning & blockMeaning, WT_File & file);
-//WT_Result gdr_process_encryption(WT_Encryption & encryption, WT_File & file);
-//WT_Result gdr_process_orientation(WT_Orientation & orientation, WT_File & file);
-WT_Result gdr_process_alignment(WT_Alignment & alignment, WT_File & file);
-//WT_Result gdr_process_password(WT_Password & password, WT_File & file);
-//WT_Result gdr_process_guid(WT_Guid & guid, WT_File & file);
-//WT_Result gdr_process_fileTime(WT_FileTime & fileTime, WT_File & file);
-//WT_Result gdr_process_userData(WT_UserData & userData, WT_File & file);
-WT_Result gdr_process_penPattern(WT_Pen_Pattern & penPattern, WT_File & file);
-WT_Result gdr_process_fillPattern(WT_Fill_Pattern & fillPattern, WT_File & file);
-//WT_Result gdr_process_DigitalSign(WT_SignData & digitalSing, WT_File & file);
-//WT_Result gdr_process_dwf_header(WT_DWF_Header & dwf_header, WT_File & file);
-#endif
Modified: trunk/MgDev/Common/Renderers/Renderers.vcxproj
--- trunk/MgDev/Common/Renderers/Renderers.vcxproj 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Common/Renderers/Renderers.vcxproj 2019-06-22 08:42:36 UTC (rev 9559)
@@ -221,11 +221,7 @@
<ClCompile Include="UTFGridContent.cpp" />
<ClCompile Include="UTFGridRenderer.cpp" />
<ClCompile Include="W2DRewriter.cpp" />
- <ClCompile Include="complex_polygon_gd.cpp" />
- <ClCompile Include="GDFillPatterns.cpp" />
- <ClCompile Include="GDRenderer.cpp" />
<ClCompile Include="GDUtils.cpp" />
- <ClCompile Include="GDW2DRewriter.cpp" />
<ClCompile Include="RS_ByteData.cpp" />
<ClCompile Include="ObservationMesh.cpp" />
<ClCompile Include="KmlContent.cpp" />
@@ -274,11 +270,7 @@
<ClInclude Include="W2DRewriter.h" />
<ClInclude Include="whip_fill_library.h" />
<ClInclude Include="whip_hatch_library.h" />
- <ClInclude Include="complex_polygon_gd.h" />
- <ClInclude Include="GDFillPatterns.h" />
- <ClInclude Include="GDRenderer.h" />
<ClInclude Include="GDUtils.h" />
- <ClInclude Include="GDW2DRewriter.h" />
<ClInclude Include="RS_ByteData.h" />
<ClInclude Include="ObservationMesh.h" />
<ClInclude Include="KmlContent.h" />
Modified: trunk/MgDev/Common/Renderers/Renderers.vcxproj.filters
--- trunk/MgDev/Common/Renderers/Renderers.vcxproj.filters 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Common/Renderers/Renderers.vcxproj.filters 2019-06-22 08:42:36 UTC (rev 9559)
@@ -39,21 +39,9 @@
<ClCompile Include="W2DRewriter.cpp">
<Filter>DWFRenderers</Filter>
</ClCompile>
- <ClCompile Include="complex_polygon_gd.cpp">
- <Filter>GDRenderer</Filter>
- </ClCompile>
- <ClCompile Include="GDFillPatterns.cpp">
- </ClCompile>
- <ClCompile Include="GDRenderer.cpp">
- </ClCompile>
<ClCompile Include="GDUtils.cpp">
</ClCompile>
- <ClCompile Include="GDW2DRewriter.cpp">
- </ClCompile>
<ClCompile Include="RS_ByteData.cpp">
</ClCompile>
@@ -152,21 +140,9 @@
<ClInclude Include="whip_hatch_library.h">
</ClInclude>
- <ClInclude Include="complex_polygon_gd.h">
- </ClInclude>
- <ClInclude Include="GDFillPatterns.h">
- </ClInclude>
- <ClInclude Include="GDRenderer.h">
- </ClInclude>
<ClInclude Include="GDUtils.h">
</ClInclude>
- <ClInclude Include="GDW2DRewriter.h">
- </ClInclude>
<ClInclude Include="RS_ByteData.h">
</ClInclude>
Deleted: trunk/MgDev/Common/Renderers/complex_polygon_gd.cpp
--- trunk/MgDev/Common/Renderers/complex_polygon_gd.cpp 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Common/Renderers/complex_polygon_gd.cpp 2019-06-22 08:42:36 UTC (rev 9559)
@@ -1,353 +0,0 @@
-/* Traian 1/2/2007
- Polygon fill routines taken from the Graphics Programming Black Book by M. Abrash.
- I (heavily) modified the code as follows:
- * add support for polygons with multiple contours,
- * do polygon clipping if parts of the polygon are outside of
- the screen,
- * Reduce number of memory allocations by reusing the same
- buffer for egde lists
- * function no longer returns an int
- Original code description follows below.
-/* Color-fills an arbitrarily-shaped polygon described by VertexList.
-If the first and last points in VertexList are not the same, the path
-around the polygon is automatically closed. All vertices are offset
-by (XOffset, YOffset). Returns 1 for success, 0 if memory allocation
-failed.
-If the polygon shape is known in advance, speedier processing may be
-enabled by specifying the shape as follows: "convex" - a rubber band
-stretched around the polygon would touch every vertex in order;
-"nonconvex" - the polygon is not self-intersecting, but need not be
-convex; "complex" - the polygon may be self-intersecting, or, indeed,
-any sort of polygon at all. Complex will work for all polygons; convex
-is fastest. Undefined results will occur if convex is specified for a
-nonconvex or complex polygon.
-Define CONVEX_CODE_LINKED if the fast convex polygon filling code from
-Chapter 21 is linked in. Otherwise, convex polygons are
-handled by the complex polygon filling code.
-Nonconvex is handled as complex in this implementation. See text for a
-discussion of faster nonconvex handling
-Link with L23-4.C and L23-2.C in Small model.
-Tested with Borland C++ 4.02 by Jim Mischel 12/16/94.
-#include <stdlib.h>
-/* Describes a single point (used for a single vertex) */
-struct Point {
- int X; /* X coordinate */
- int Y; /* Y coordinate */
-/* Describes the beginning and ending X coordinates of a single
- horizontal line (used only by fast polygon fill code) */
-struct HLine {
- int XStart; /* X coordinate of leftmost pixel in line */
- int XEnd; /* X coordinate of rightmost pixel in line */
-/* Describes a Length-long series of horizontal lines, all assumed to
- be on contiguous scan lines starting at YStart and proceeding
- downward (used to describe a scan-converted polygon to the
- low-level hardware-dependent drawing code) (used only by fast
- polygon fill code) */
-struct HLineList {
- int Length; /* # of horizontal lines */
- int YStart; /* Y coordinate of topmost line */
- struct HLine * HLinePtr; /* pointer to list of horz lines */
-#define SWAP(a,b) {temp = a; a = b; b = temp;}
-struct EdgeState {
- struct EdgeState *NextEdge;
- int X;
- int StartY;
- int WholePixelXMove;
- int XDirection;
- int ErrorTerm;
- int ErrorTermAdjUp;
- int ErrorTermAdjDown;
- int Count;
-complex_polygon_gd::complex_polygon_gd()
- m_bufEdgeState = NULL;
- m_nBufEdgeState = 0;
-complex_polygon_gd::~complex_polygon_gd()
- delete [] m_bufEdgeState;
-void complex_polygon_gd::FillPolygon(Point * VertexList, int nVerts, int* Contours, int nContours, int Color, gdImagePtr target)
- struct EdgeState *EdgeTableBuffer;
- int CurrentY;
- /* It takes a minimum of 3 vertices to cause any pixels to be
- drawn; reject polygons that are guaranteed to be invisible */
- if (nVerts < 3)
- return;
- /* Get enough memory to store the entire edge table */
- /* TIS -- reuse a buffer owned by the class */
- if (m_nBufEdgeState < (size_t)nVerts)
- m_nBufEdgeState = nVerts;
- m_bufEdgeState = new EdgeState[m_nBufEdgeState];
- EdgeTableBuffer = m_bufEdgeState;
- /* Build the global edge table */
- BuildGET(VertexList, Contours, nContours, EdgeTableBuffer, target->sy - 1);
- if (m_GETPtr) /* true if polygon was not completely clipped out */
- /* Scan down through the polygon edges, one scan line at a time,
- so long as at least one edge remains in either the GET or AET */
- m_AETPtr = NULL; /* initialize the active edge table to empty */
- CurrentY = m_GETPtr->StartY; /* start at the top polygon vertex */
- while (((m_GETPtr != NULL) || (m_AETPtr != NULL))
- && CurrentY != target->sy)
- MoveXSortedToAET(CurrentY); /* update AET for this scan line */
- ScanOutAET(CurrentY, Color, target); /* draw this scan line from AET */
- AdvanceAET(); /* advance AET edges 1 scan line */
- XSortAET(); /* resort on X */
- CurrentY++; /* advance to the next scan line */
-/* Creates a GET in the buffer pointed to by NextFreeEdgeStruc from
-the vertex list. Edge endpoints are flipped, if necessary, to
-guarantee all edges go top to bottom. The GET is sorted primarily
-by ascending Y start coordinate, and secondarily by ascending X
-start coordinate within edges with common Y coordinates */
-void complex_polygon_gd::BuildGET(struct Point * VertexList,
-int* Contours, int nContours, struct EdgeState * NextFreeEdgeStruc, int MaxY)
- int i, StartX, StartY, EndX, EndY, DeltaY, DeltaX, Width, temp, SkipY;
- struct EdgeState *NewEdgePtr;
- struct EdgeState *FollowingEdge, **FollowingEdgeLink;
- struct Point *VertexPtr;
- /* Scan through the vertex list and put all non-0-height edges into
- the GET, sorted by increasing Y start coordinate */
- VertexPtr = VertexList; /* point to the vertex list */
- m_GETPtr = NULL; /* initialize the global edge table to empty */
- int offset = 0;
- for (int j=0; j<nContours; j++)
- for (i = 0; i < Contours[j]; i++) {
- /* Calculate the edge height and width */
- StartX = VertexPtr[offset + i].X;
- StartY = VertexPtr[offset + i].Y;
- /* The edge runs from the current point to the previous one */
- if (i == 0) {
- /* Wrap back around to the end of the list */
- EndX = VertexPtr[offset + Contours[j]-1].X;
- EndY = VertexPtr[offset + Contours[j]-1].Y;
- } else {
- EndX = VertexPtr[offset + i-1].X;
- EndY = VertexPtr[offset + i-1].Y;
- /* Make sure the edge runs top to bottom */
- if (StartY > EndY) {
- SWAP(StartX, EndX);
- SWAP(StartY, EndY);
- /* Skip if this can't ever be an active edge (has 0 height)
- or if the edge doesn't cross the vertical screen
- bounds at all */
- if ((DeltaY = EndY - StartY) != 0
- && (EndY > 0) && (StartY <= MaxY)) {
- /* Allocate space for this edge's info, and fill in the
- structure */
- NewEdgePtr = NextFreeEdgeStruc++;
- NewEdgePtr->XDirection = /* direction in which X moves */
- ((DeltaX = EndX - StartX) > 0) ? 1 : -1;
- Width = abs(DeltaX);
- NewEdgePtr->X = StartX;
- /* clip stuff that's before beginning of screen
- We can't just change StartY -- we also need to
- update the initial conditions for the edge
- rasterizer
- /* find how many rows we have to skip */
- SkipY = (StartY >=0) ? 0 : -StartY;
- StartY += SkipY;
- NewEdgePtr->StartY = StartY;
- NewEdgePtr->Count = DeltaY - SkipY;
- NewEdgePtr->ErrorTermAdjDown = DeltaY;
- /* set initial rasterization conditions */
- if (DeltaX >= 0) /* initial error term going L->R */
- NewEdgePtr->ErrorTerm = 0;
- else /* initial error term going R->L */
- NewEdgePtr->ErrorTerm = -DeltaY + 1;
- if (DeltaY >= Width) { /* Y-major edge */
- NewEdgePtr->WholePixelXMove = 0;
- NewEdgePtr->ErrorTermAdjUp = Width;
- } else { /* X-major edge */
- (Width / DeltaY) * NewEdgePtr->XDirection;
- NewEdgePtr->ErrorTermAdjUp = Width % DeltaY;
- /* update initial conditions only if we have to*/
- if (SkipY != 0) {
- int XMove = (SkipY + 1) * NewEdgePtr->WholePixelXMove;
- int ErrorMove = NewEdgePtr->ErrorTerm + (SkipY + 1) * NewEdgePtr->ErrorTermAdjUp;
- int ErrorDiv = ErrorMove / NewEdgePtr->ErrorTermAdjDown;
- int ErrorMod = ErrorMove % NewEdgePtr->ErrorTermAdjDown;
- NewEdgePtr->X += XMove + ErrorDiv * NewEdgePtr->XDirection;
- StartX = NewEdgePtr->X;
- NewEdgePtr->ErrorTerm = ErrorMod - NewEdgePtr->ErrorTermAdjDown;
- /* Link the new edge into the GET so that the edge list is
- still sorted by Y coordinate, and by X coordinate for all
- edges with the same Y coordinate */
- FollowingEdgeLink = &m_GETPtr;
- for (;;) {
- FollowingEdge = *FollowingEdgeLink;
- if ((FollowingEdge == NULL) ||
- (FollowingEdge->StartY > StartY) ||
- ((FollowingEdge->StartY == StartY) &&
- (FollowingEdge->X >= StartX))) {
- NewEdgePtr->NextEdge = FollowingEdge;
- *FollowingEdgeLink = NewEdgePtr;
- break;
- FollowingEdgeLink = &FollowingEdge->NextEdge;
- offset += Contours[j];
-/* Sorts all edges currently in the active edge table into ascending
-order of current X coordinates */
-void complex_polygon_gd::XSortAET() {
- struct EdgeState *CurrentEdge, **CurrentEdgePtr, *TempEdge;
- int SwapOccurred;
- /* Scan through the AET and swap any adjacent edges for which the
- second edge is at a lower current X coord than the first edge.
- Repeat until no further swapping is needed */
- if (m_AETPtr != NULL) {
- do {
- SwapOccurred = 0;
- CurrentEdgePtr = &m_AETPtr;
- while ((CurrentEdge = *CurrentEdgePtr)->NextEdge != NULL) {
- if (CurrentEdge->X > CurrentEdge->NextEdge->X) {
- /* The second edge has a lower X than the first;
- swap them in the AET */
- TempEdge = CurrentEdge->NextEdge->NextEdge;
- *CurrentEdgePtr = CurrentEdge->NextEdge;
- CurrentEdge->NextEdge->NextEdge = CurrentEdge;
- CurrentEdge->NextEdge = TempEdge;
- SwapOccurred = 1;
- CurrentEdgePtr = &(*CurrentEdgePtr)->NextEdge;
- } while (SwapOccurred != 0);
-/* Advances each edge in the AET by one scan line.
-Removes edges that have been fully scanned. */
-void complex_polygon_gd::AdvanceAET() {
- struct EdgeState *CurrentEdge, **CurrentEdgePtr;
- /* Count down and remove or advance each edge in the AET */
- while ((CurrentEdge = *CurrentEdgePtr) != NULL) {
- /* Count off one scan line for this edge */
- if ((--(CurrentEdge->Count)) == 0) {
- /* This edge is finished, so remove it from the AET */
- } else {
- /* Advance the edge's X coordinate by minimum move */
- CurrentEdge->X += CurrentEdge->WholePixelXMove;
- /* Determine whether it's time for X to advance one extra */
- if ((CurrentEdge->ErrorTerm +=
- CurrentEdge->ErrorTermAdjUp) > 0) {
- CurrentEdge->X += CurrentEdge->XDirection;
- CurrentEdge->ErrorTerm -= CurrentEdge->ErrorTermAdjDown;
- CurrentEdgePtr = &CurrentEdge->NextEdge;
-/* Moves all edges that start at the specified Y coordinate from the
-GET to the AET, maintaining the X sorting of the AET. */
-void complex_polygon_gd::MoveXSortedToAET(int YToMove) {
- struct EdgeState *AETEdge, **AETEdgePtr, *TempEdge;
- int CurrentX;
- /* The GET is Y sorted. Any edges that start at the desired Y
- coordinate will be first in the GET, so we'll move edges from
- the GET to AET until the first edge left in the GET is no longer
- at the desired Y coordinate. Also, the GET is X sorted within
- each Y coordinate, so each successive edge we add to the AET is
- guaranteed to belong later in the AET than the one just added */
- AETEdgePtr = &m_AETPtr;
- while ((m_GETPtr != NULL) && (m_GETPtr->StartY == YToMove)) {
- CurrentX = m_GETPtr->X;
- /* Link the new edge into the AET so that the AET is still
- sorted by X coordinate */
- for (;;) {
- AETEdge = *AETEdgePtr;
- if ((AETEdge == NULL) || (AETEdge->X >= CurrentX)) {
- TempEdge = m_GETPtr->NextEdge;
- *AETEdgePtr = m_GETPtr; /* link the edge into the AET */
- m_GETPtr->NextEdge = AETEdge;
- AETEdgePtr = &m_GETPtr->NextEdge;
- m_GETPtr = TempEdge; /* unlink the edge from the GET */
- break;
- } else {
- AETEdgePtr = &AETEdge->NextEdge;
-/* Fills the scan line described by the current AET at the specified Y
-coordinate in the specified color, using the odd/even fill rule */
-void complex_polygon_gd::ScanOutAET(int YToScan, int Color, gdImagePtr target) {
- int LeftX;
- struct EdgeState *CurrentEdge;
- /* Scan through the AET, drawing line segments as each pair of edge
- crossings is encountered. The nearest pixel on or to the right
- of left edges is drawn, and the nearest pixel to the left of but
- not on right edges is drawn */
- CurrentEdge = m_AETPtr;
- while (CurrentEdge != NULL) {
- LeftX = CurrentEdge->X;
- CurrentEdge = CurrentEdge->NextEdge;
- DrawHorizontalLineSeg(YToScan, LeftX, CurrentEdge->X-1, Color, target);
Deleted: trunk/MgDev/Common/Renderers/complex_polygon_gd.h
--- trunk/MgDev/Common/Renderers/complex_polygon_gd.h 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Common/Renderers/complex_polygon_gd.h 2019-06-22 08:42:36 UTC (rev 9559)
@@ -1,55 +0,0 @@
-#ifndef complex_polygon_gd_H
-#define complex_polygon_gd_H
-#include "gd.h"
-struct EdgeState;
-struct Point;
-public:
- complex_polygon_gd();
- ~complex_polygon_gd();
- void FillPolygon(Point * VertexList, int nVerts, int* Contours, int nContours, int Color, gdImagePtr target);
-private:
- //This is what you want to implement for your own render target
- //for all the rest of the code to work with it
- inline void DrawHorizontalLineSeg(int Y, int StartX, int EndX, int Color, gdImagePtr target)
- if (StartX <= EndX)
- gdImageLine(target, StartX, Y, EndX, Y, Color);
- void BuildGET(Point *, int* Contours, int nContours, EdgeState *, int MaxY);
- void MoveXSortedToAET(int);
- void ScanOutAET(int, int, gdImagePtr);
- void AdvanceAET();
- void XSortAET();
- /* Pointers to global edge table (GET) and active edge table (AET) */
- struct EdgeState *m_GETPtr, *m_AETPtr;
- EdgeState* m_bufEdgeState;
- size_t m_nBufEdgeState;
-#endif
Modified: trunk/MgDev/Server/src/Core/serverconfig.ini
--- trunk/MgDev/Server/src/Core/serverconfig.ini 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Server/src/Core/serverconfig.ini 2019-06-22 08:42:36 UTC (rev 9559)
@@ -76,7 +76,6 @@
# PreCacheMaps The list of maps to precache at server startup.
# Value = Map resource name(s) separated by ","
# Example: Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition
-# Renderer Image renderer to use (GD or AGG)
# ResourcesPath Path where the localization resource files are stored
# SerialNumber The MapGuide Server serial number (not used by MapGuide Open Source)
# 0 <= Length <= 12
@@ -103,7 +102,6 @@
MentorDictionaryPath = ../../../Oem/CsMap/CsMapDev/Dictionaries/
MentorUserDictionaryPath =
PreCacheMaps =
-Renderer = AGG
ResourcesPath = Resources/
SerialNumber =
TcpIpMtu = 1460
Modified: trunk/MgDev/Server/src/Services/Rendering/OpRenderTileFromMetatile.cpp
--- trunk/MgDev/Server/src/Services/Rendering/OpRenderTileFromMetatile.cpp 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Server/src/Services/Rendering/OpRenderTileFromMetatile.cpp 2019-06-22 08:42:36 UTC (rev 9559)
@@ -36,7 +36,7 @@
ACE_ASSERT(m_stream != NULL);
- if (5 == m_packet.m_NumArguments)
+ if (4 == m_packet.m_NumArguments)
Ptr<MgMap> map = (MgMap*)m_stream->GetObject();
Ptr<MgResourceIdentifier> resource = map->GetResourceId();
@@ -44,9 +44,6 @@
Ptr<MgMetatile> metaTile = (MgMetatile*)m_stream->GetObject();
- STRING rendererName;
- m_stream->GetString(rendererName);
INT32 subTileX = 0;
m_stream->GetInt32(subTileX);
@@ -64,10 +61,8 @@
MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
MG_LOG_OPERATION_MESSAGE_ADD_INT32(metaTile->GetMetaTilingFactor());
MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"]");
- MG_LOG_OPERATION_MESSAGE_ADD_STRING(rendererName.c_str());
- MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
MG_LOG_OPERATION_MESSAGE_ADD_INT32(subTileX);
MG_LOG_OPERATION_MESSAGE_ADD_INT32(subTileY);
@@ -75,7 +70,7 @@
Validate();
- Ptr<MgByteReader> tile = m_service->RenderTileFromMetaTile(map, metaTile, rendererName, subTileX, subTileY);
+ Ptr<MgByteReader> tile = m_service->RenderTileFromMetaTile(map, metaTile, subTileX, subTileY);
EndExecution(tile);
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2019-06-22 08:42:36 UTC (rev 9559)
@@ -18,7 +18,6 @@
#include "MapGuideCommon.h"
#include "ServerRenderingService.h"
#include "DefaultStylizer.h"
#include "AGGRenderer.h"
#include "UTFGridRenderer.h"
#include "RSMgSymbolManager.h"
@@ -79,10 +78,6 @@
assert(m_svcDrawing != NULL);
MgConfiguration* pConf = MgConfiguration::GetInstance();
- pConf->GetStringValue(MgConfigProperties::GeneralPropertiesSection,
- MgConfigProperties::GeneralPropertyRenderer,
- m_rendererName,
- MgConfigProperties::DefaultGeneralPropertyRenderer);
pConf->GetIntValue(MgConfigProperties::RenderingServicePropertiesSection,
MgConfigProperties::RenderingServicePropertyRasterGridSize,
@@ -129,7 +124,6 @@
bGeneralizeData,
MgConfigProperties::DefaultRenderingServicePropertyGeneralizeData);
AGGRenderer::s_bGeneralizeData = bGeneralizeData;
- GDRenderer::s_bGeneralizeData = bGeneralizeData;
@@ -465,7 +459,7 @@
// initialize the renderer (set clipping to false so that we label
// the unclipped geometry)
- auto_ptr<SE_Renderer> dr(CreateRenderer(m_rendererName, width, height, bgColor, false, true, tileExtentOffset));
+ std::unique_ptr<AGGRenderer> dr(CreateRenderer(width, height, bgColor, false, true, tileExtentOffset));
// create a temporary collection containing all the layers for the base group
Ptr<MgLayerCollection> layers = map->GetLayers();
@@ -588,7 +582,7 @@
bgColor.alpha() = 0;
- auto_ptr<SE_Renderer> dr(CreateRenderer(m_rendererName, width, height, bgColor, true));
+ std::unique_ptr<AGGRenderer> dr(CreateRenderer(width, height, bgColor, true));
bool bIncludeDynamicLayers = ((options->GetBehavior() & MgRenderingOptions::RenderLayers) == MgRenderingOptions::RenderLayers);
bool bIncludeBaseLayers = ((options->GetBehavior() & MgRenderingOptions::RenderBaseLayers) == MgRenderingOptions::RenderBaseLayers);
@@ -784,7 +778,7 @@
// initialize the renderer with the rendering canvas size - in this
// case it is not necessarily the same size as the requested image
// size due to support for non-square pixels
- auto_ptr<SE_Renderer> dr(CreateRenderer(m_rendererName, drawWidth, drawHeight, bgcolor, false));
+ std::unique_ptr<AGGRenderer> dr(CreateRenderer(drawWidth, drawHeight, bgcolor, false));
// call the internal helper API to do all the stylization overhead work
ret = RenderMapInternal(map, selection, NULL, dr.get(), drawWidth, drawHeight, width, height, format, scale, b, true, bKeepSelection, true, NULL);
@@ -923,7 +917,7 @@
backgroundColor->GetAlpha());
// initialize the appropriate map renderer
- auto_ptr<SE_Renderer> dr(CreateRenderer(m_rendererName, width, height, bgcolor, bClip));
+ std::unique_ptr<AGGRenderer> dr(CreateRenderer(width, height, bgcolor, bClip));
if(NULL != pPRMResult)
@@ -994,7 +988,7 @@
double point_buf[2];
double* point = NULL;
- auto_ptr<SE_Renderer> impRenderer;
+ std::unique_ptr<AGGRenderer> impRenderer;
if (geometry && maxFeatures == 1)
MgPolygon* polygon = dynamic_cast<MgPolygon*>(geometry);
@@ -1028,7 +1022,7 @@
point = point_buf;
RS_Color bgColor; // not used
- impRenderer.reset(CreateRenderer(m_rendererName, 1, 1, bgColor, false));
+ impRenderer.reset(CreateRenderer(1, 1, bgColor, false));
@@ -1137,7 +1131,7 @@
MgByteReader* MgServerRenderingService::RenderMapInternal(MgMap* map,
MgSelection* selection,
MgReadOnlyLayerCollection* roLayers,
- SE_Renderer* dr,
+ AGGRenderer* dr,
INT32 drawWidth,
INT32 drawHeight,
INT32 saveWidth,
@@ -1168,7 +1162,7 @@
- SE_Renderer* dr,
+ AGGRenderer* dr,
INT32 drawWidth,
INT32 drawHeight,
INT32 saveWidth,
@@ -1289,7 +1283,7 @@
MG_THROW() // to skip a faulty tile we need to rethrow the exception which could be thrown in StylizeLayers
- Ptr<MgByteReader> ret = CreateImageFromRenderer(map, dr, saveWidth, saveHeight, format, m_rendererName, pPRMResult);
+ Ptr<MgByteReader> ret = CreateImageFromRenderer(map, dr, saveWidth, saveHeight, format, pPRMResult);
return ret.Detach();
@@ -1325,7 +1319,7 @@
//initialize a renderer
- auto_ptr<Renderer> dr(CreateRenderer(m_rendererName, width, height, bgcolor, false, false, 0.0));
+ std::unique_ptr<AGGRenderer> dr(CreateRenderer(width, height, bgcolor, false, false, 0.0));
RS_Bounds b(0,0,width,height);
@@ -1353,13 +1347,9 @@
dr->EndMap();
// get a byte representation of the image
- auto_ptr<RS_ByteData> data;
+ std::unique_ptr<RS_ByteData> data;
+ data.reset((dr.get())->Save(format, width, height));
- if (wcscmp(m_rendererName.c_str(), L"AGG") == 0)
- data.reset(((AGGRenderer*)dr.get())->Save(format, width, height));
- else
- data.reset(((GDRenderer*)dr.get())->Save(format, width, height));
if (NULL != data.get())
// put this into a byte source
@@ -1556,7 +1546,7 @@
MdfModel::VectorLayerDefinition* vl = NULL;
Ptr<MgResourceLayerDefinitionCacheItem> cacheItem;
- auto_ptr<MdfModel::LayerDefinition> ldf;
+ std::unique_ptr<MdfModel::LayerDefinition> ldf;
Ptr<MgResourceIdentifier> layerResId = layer->GetLayerDefinition();
if (bOnlyVisibleLayers)
@@ -1621,7 +1611,7 @@
// Initialize the reader
- auto_ptr<RSMgFeatureReader> rsrdr;
+ std::unique_ptr<RSMgFeatureReader> rsrdr;
try
@@ -1816,8 +1806,7 @@
-SE_Renderer* MgServerRenderingService::CreateRenderer(CREFSTRING rendererName,
- INT32 width,
+AGGRenderer* MgServerRenderingService::CreateRenderer(INT32 width,
INT32 height,
RS_Color& bgColor,
@@ -1824,20 +1813,13 @@
- SE_Renderer* renderer = NULL;
- if (wcscmp(rendererName.c_str(), L"AGG") == 0)
- renderer = new AGGRenderer(width, height, bgColor, requiresClipping, localOverposting, tileExtentOffset);
- else
- renderer = new GDRenderer(width, height, bgColor, requiresClipping, localOverposting, tileExtentOffset);
+ auto renderer = new AGGRenderer(width, height, bgColor, requiresClipping, localOverposting, tileExtentOffset);
- if (renderer != NULL)
- renderer->SetRasterGridSize(m_rasterGridSize);
- renderer->SetMinRasterGridSize(m_minRasterGridSize);
- renderer->SetRasterGridSizeOverrideRatio(m_rasterGridSizeOverrideRatio);
- renderer->SetMaxRasterImageWidth(m_maxRasterImageWidth);
- renderer->SetMaxRasterImageHeight(m_maxRasterImageHeight);
+ renderer->SetRasterGridSize(m_rasterGridSize);
+ renderer->SetMinRasterGridSize(m_minRasterGridSize);
+ renderer->SetRasterGridSizeOverrideRatio(m_rasterGridSizeOverrideRatio);
+ renderer->SetMaxRasterImageWidth(m_maxRasterImageWidth);
+ renderer->SetMaxRasterImageHeight(m_maxRasterImageHeight);
return renderer;
@@ -1982,13 +1964,13 @@
// 3. Map's watermark usage is not 0, which means watermark usage is WMS and / or Viewer.
WatermarkInstanceCollection watermarkInstances; //Watermark list to render
WatermarkInstanceCollection tempWatermarkInstances; //Used to reverse list
- auto_ptr<WatermarkInstance> tempInstance;
+ std::unique_ptr<WatermarkInstance> tempInstance;
// Get watermark instance in map
Ptr<MgResourceIdentifier> mapId = map->GetMapDefinition();
if (mapId.p)
- auto_ptr<MapDefinition> mdef(MgMapBase::GetMapDefinition(m_svcResource, mapId));
+ std::unique_ptr<MapDefinition> mdef(MgMapBase::GetMapDefinition(m_svcResource, mapId));
WatermarkInstanceCollection* mapWatermarks = mdef->GetWatermarks();
for (int i=mapWatermarks->GetCount()-1; i>=0; i--)
tempWatermarkInstances.Adopt(mapWatermarks->OrphanAt(i));
@@ -2021,7 +2003,7 @@
// Get watermark instance in layer
const int layerCount = layers->GetCount();
- auto_ptr<LayerDefinition> ldf;
+ std::unique_ptr<LayerDefinition> ldf;
for (int i=0; i<layerCount; ++i)
Ptr<MgLayerBase> mapLayer(layers->GetItem(i));
@@ -2456,7 +2438,7 @@
- auto_ptr<SE_Renderer> dr(CreateRenderer(m_rendererName, drawWidth, drawHeight, bgColor, false, true, tileExtentOffset));
+ std::unique_ptr<AGGRenderer> dr(CreateRenderer(drawWidth, drawHeight, bgColor, false, true, tileExtentOffset));
@@ -2492,7 +2474,6 @@
MgByteReader* MgServerRenderingService::RenderTileFromMetaTile(MgMap* map,
MgMetatile* metaTile,
- CREFSTRING rendererName,
INT32 subTileX,
INT32 subTileY)
@@ -2545,9 +2526,9 @@
StylizationUtil::ParseColor(map->GetBackgroundColor(), bgColor);
// Must create renderer under the scaled width/height and not original
- auto_ptr<SE_Renderer> dr(CreateRenderer(rendererName, scaledTileWidth, scaledTileHeight, bgColor, true));
+ std::unique_ptr<AGGRenderer> dr(CreateRenderer(scaledTileWidth, scaledTileHeight, bgColor, true));
RS_ColorVector tileColorPalette;
- if (rendererName == L"AGG" && HasColorMap(origTileFormat))
+ if (HasColorMap(origTileFormat))
MgMappingUtil::ParseColorStrings(&tileColorPalette, map);
@@ -2562,8 +2543,8 @@
unsigned int *framebuf = (unsigned int*)byteBuffer->Bytes();
// allocate subtile buffer to copy new framebuf with changed dimensions
- // place buffer in allocated MgByte auto_ptr object for destruction at end of scope
- auto_ptr<MgByte> subTileBytes(new MgByte((unsigned char*)new unsigned int[scaledTileWidth * scaledTileHeight],
+ // place buffer in allocated MgByte std::unique_ptr object for destruction at end of scope
+ std::unique_ptr<MgByte> subTileBytes(new MgByte((unsigned char*)new unsigned int[scaledTileWidth * scaledTileHeight],
scaledTileWidth * scaledTileHeight * sizeof(int), MgByte::New));
// get the pointer to the internal target buffer
unsigned int* subTileBuf = (unsigned int*)subTileBytes->Bytes();
@@ -2577,7 +2558,7 @@
* scaledTileWidth * metaTileFactor); // use width of metaTile here
// then call the image renderer to convert the framebuffer bitmap into the desired image format
- ret = CreateImageFromRenderer(map, dr.get(), origTileWidth, origTileHeight, origTileFormat, rendererName, NULL, subTileBuf);
+ ret = CreateImageFromRenderer(map, dr.get(), origTileWidth, origTileHeight, origTileFormat, NULL, subTileBuf);
MG_CATCH_AND_THROW(L"MgServerRenderingService.RenderTileFromMetaTile")
@@ -2590,11 +2571,10 @@
MgByteReader* MgServerRenderingService::CreateImageFromRenderer(MgMap* map,
- Renderer* dr,
+ AGGRenderer* dr,
INT32 saveWidth,
INT32 saveHeight,
CREFSTRING format,
ProfileRenderMapResult* pPRMResult,
unsigned int* frameBuffer)
@@ -2627,43 +2607,38 @@
Ptr<MgByteSource> bs;
try
// call the image renderer to create the image
+ if (format == MgImageFormats::Meta) // we dont use the colorPalette here for meta tiling
+ { // as this call only returns the framebuffer
+ data.reset(dr->Save(format, saveWidth, saveHeight, NULL, NULL));
+ // copy the framebuffer into the reader, RenderTileFromMetatile is taking it from there
+ else
- if (format == MgImageFormats::Meta) // we dont use the colorPalette here for meta tiling
- { // as this call only returns the framebuffer
- data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight, NULL, NULL));
- // copy the framebuffer into the reader, RenderTileFromMetatile is taking it from there
+ /// RFC60 code to correct colormaps by UV
+ // We examine the expressions collected from xml definitions of all layers.
+ // The map object has a list from all color entries found in the most recent
+ // layer stylization.
+ // * TODO - currently they are interpreted as ffffffff 32-bit RGBA string values
+ // * adding expresssions and other interpretations should be done in ParseColorStrings
+ // * the color Palette for the renderer is a vector<RS_Color>
+ if (HasColorMap(format))
+ RS_ColorVector tileColorPalette;
+ MgMappingUtil::ParseColorStrings(&tileColorPalette, map);
+ // printf("<<<<<<<<<<<<<<<<<<<<< MgServerRenderingService::ColorPalette->size(): %d\n", tileColorPalette.size());
+ data.reset(dr->Save(format, saveWidth, saveHeight, &tileColorPalette, frameBuffer));
else
- /// RFC60 code to correct colormaps by UV
- // We examine the expressions collected from xml definitions of all layers.
- // The map object has a list from all color entries found in the most recent
- // layer stylization.
- // * TODO - currently they are interpreted as ffffffff 32-bit RGBA string values
- // * adding expresssions and other interpretations should be done in ParseColorStrings
- // * the color Palette for the renderer is a vector<RS_Color>
- if (HasColorMap(format))
- RS_ColorVector tileColorPalette;
- MgMappingUtil::ParseColorStrings(&tileColorPalette, map);
- // printf("<<<<<<<<<<<<<<<<<<<<< MgServerRenderingService::ColorPalette->size(): %d\n", tileColorPalette.size());
- data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight, &tileColorPalette, frameBuffer));
- else
- data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight, NULL, frameBuffer));
+ data.reset(dr->Save(format, saveWidth, saveHeight, NULL, frameBuffer));
- else
- data.reset(((GDRenderer*)dr)->Save(format, saveWidth, saveHeight));
catch (exception e)
@@ -2697,7 +2672,7 @@
pPRMResult->SetCreateImageTime(createImageTime);
pPRMResult->SetImageFormat(format);
- pPRMResult->SetRendererType(rendererName);
+ pPRMResult->SetRendererType(L"AGG"); //NOXLATE
return bs->GetReader();
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h 2019-06-22 08:42:36 UTC (rev 9559)
@@ -22,7 +22,7 @@
struct RS_Bounds;
class RS_Color;
-class SE_Renderer;
+class AGGRenderer;
class Renderer;
class FeatureInfoRenderer;
class MgFeatureInformation;
@@ -286,17 +286,16 @@
double tileExtentOffset,
INT32 metaTilingFactor);
- virtual MgByteReader* RenderTileFromMetaTile(MgMap* map, MgMetatile* metaTile, CREFSTRING rendererName, INT32 subTileX, INT32 subTileY);
+ virtual MgByteReader* RenderTileFromMetaTile(MgMap* map, MgMetatile* metaTile, INT32 subTileX, INT32 subTileY);
private:
static bool HasColorMap(CREFSTRING format);
static MgByteReader* CreateImageFromRenderer(MgMap* map,
- Renderer* dr,
+ AGGRenderer* dr,
INT32 saveWidth,
INT32 saveHeight,
CREFSTRING format,
unsigned int* frameBuffer = NULL);
@@ -322,7 +321,7 @@
MgByteReader* RenderMapInternal(MgMap* map,
- SE_Renderer* dr,
+ AGGRenderer* dr,
INT32 drawWidth,
INT32 drawHeight,
INT32 saveWidth,
@@ -339,7 +338,7 @@
- SE_Renderer* dr,
+ AGGRenderer* dr,
INT32 drawWidth,
INT32 drawHeight,
INT32 saveWidth,
@@ -360,8 +359,7 @@
INT32 layerAttributeFilter,
FeatureInfoRenderer* selRenderer);
- virtual SE_Renderer* CreateRenderer(CREFSTRING rendererName,
- INT32 width,
+ virtual AGGRenderer* CreateRenderer(INT32 width,
INT32 height,
RS_Color& bgColor,
bool requiresClipping,
@@ -405,9 +403,6 @@
Ptr<MgDrawingService> m_svcDrawing;
Ptr<MgCoordinateSystemFactory> m_pCSFactory;
- // this will eventually be removed
- STRING m_rendererName;
INT32 m_rasterGridSize;
INT32 m_minRasterGridSize;
double m_rasterGridSizeOverrideRatio;
Modified: trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp
--- trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2019-06-22 08:42:36 UTC (rev 9559)
@@ -26,12 +26,6 @@
MgServerTileService::MgServerTileService() : MgTileService()
MgTileCacheDefault::Initialize();
- MgConfiguration* pConf = MgConfiguration::GetInstance();
- m_rendererName,
MgServerTileService::~MgServerTileService()
@@ -657,7 +651,7 @@
path = MgTileParameters::tileCachePath;
- cache = new MgTileCacheDefaultProvider(tileSetId, path, width, height, format, bRenderOnly, tileExtentOffset, m_rendererName, metaTileFactor, metaTileLockMethod);
+ cache = new MgTileCacheDefaultProvider(tileSetId, path, width, height, format, bRenderOnly, tileExtentOffset, metaTileFactor, metaTileLockMethod);
else if (provider == MG_TILE_PROVIDER_XYZ)
@@ -707,7 +701,7 @@
- cache = new MgTileCacheXYZProvider(tileSetId, path, format, bRenderOnly, tileExtentOffset, m_rendererName, metaTileFactor, metaTileLockMethod);
+ cache = new MgTileCacheXYZProvider(tileSetId, path, format, bRenderOnly, tileExtentOffset, metaTileFactor, metaTileLockMethod);
else
Modified: trunk/MgDev/Server/src/Services/Tile/ServerTileService.h
--- trunk/MgDev/Server/src/Services/Tile/ServerTileService.h 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Server/src/Services/Tile/ServerTileService.h 2019-06-22 08:42:36 UTC (rev 9559)
@@ -78,8 +78,6 @@
private:
MgTileCache* GetTileCache(MgResourceIdentifier* resource);
MgTileCache* GetTileCache(MgResourceIdentifier* tileSetId, MdfModel::TileSetDefinition* tileset);
#endif
Modified: trunk/MgDev/Server/src/Services/Tile/TileCacheDefaultProvider.cpp
--- trunk/MgDev/Server/src/Services/Tile/TileCacheDefaultProvider.cpp 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Server/src/Services/Tile/TileCacheDefaultProvider.cpp 2019-06-22 08:42:36 UTC (rev 9559)
@@ -28,7 +28,6 @@
CREFSTRING format,
bool bRenderOnly,
INT32 metaTileFactor,
INT32 metaTileLockMethod)
@@ -39,7 +38,6 @@
m_format = format;
m_renderOnly = bRenderOnly;
m_tileExtentOffset = tileExtentOffset;
- m_rendererName = rendererName;
m_metaTileFactor = metaTileFactor;
m_metaTileLockMethod = metaTileLockMethod;
@@ -127,9 +125,6 @@
INT32 tileRow,
INT32 scaleIndex)
- // Must have a renderer name set
- _ASSERT(!m_rendererName.empty());
Ptr<MgByteReader> returnedSubtile;
FILE* lockFile = NULL;
STRING tilePathname, lockPathname;
@@ -340,7 +335,7 @@
for (int x = 0; x < maxX; x++) // columns
// Collect the subtile from the metatile
- Ptr<MgByteReader> img = svcRendering->RenderTileFromMetaTile(map, metaTile, m_rendererName, x, y);
+ Ptr<MgByteReader> img = svcRendering->RenderTileFromMetaTile(map, metaTile, x, y);
#ifdef _DEBUG
INT32 tileLen = img->GetLength();
#endif
Modified: trunk/MgDev/Server/src/Services/Tile/TileCacheDefaultProvider.h
--- trunk/MgDev/Server/src/Services/Tile/TileCacheDefaultProvider.h 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Server/src/Services/Tile/TileCacheDefaultProvider.h 2019-06-22 08:42:36 UTC (rev 9559)
@@ -29,7 +29,6 @@
CREFSTRING format,
bool bRenderOnly,
INT32 metaTileLockMethod);
virtual ~MgTileCacheDefaultProvider();
@@ -75,7 +74,6 @@
STRING m_format;
bool m_renderOnly;
double m_tileExtentOffset;
INT32 m_metaTileFactor;
INT32 m_metaTileLockMethod;
Modified: trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.cpp
--- trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.cpp 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.cpp 2019-06-22 08:42:36 UTC (rev 9559)
@@ -25,7 +25,6 @@
CREFSTRING format,
bool bRenderOnly,
@@ -34,7 +33,6 @@
m_format = format;
@@ -214,9 +212,6 @@
INT32 tileRow,
INT32 scaleIndex)
@@ -422,7 +417,7 @@
// Collect the subtile from the metatile (we flip x/y for XYZ)
#ifdef _DEBUG
#endif
Modified: trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.h
--- trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.h 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Server/src/Services/Tile/TileCacheXYZProvider.h 2019-06-22 08:42:36 UTC (rev 9559)
@@ -27,7 +27,6 @@
CREFSTRING format,
bool bRenderOnly,
virtual ~MgTileCacheXYZProvider();
@@ -79,8 +78,6 @@
#endif
\ No newline at end of file
Modified: trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp 2019-06-22 08:42:36 UTC (rev 9559)
@@ -1740,11 +1740,10 @@
//metaTile->ToFile(L"../UnitTestFiles/RenderTile_Metatile at 4_6.png");
//CPPUNIT_ASSERT(metaTile->IsRewindable());
//metaTile->Rewind();
- STRING rendererName = L"AGG";
- Ptr<MgByteReader> tile4_6 = renderSvc->RenderTileFromMetaTile(map, metaTile, rendererName, 0, 0);
- Ptr<MgByteReader> tile4_7 = renderSvc->RenderTileFromMetaTile(map, metaTile, rendererName, 0, 1);
- Ptr<MgByteReader> tile5_6 = renderSvc->RenderTileFromMetaTile(map, metaTile, rendererName, 1, 0);
- Ptr<MgByteReader> tile5_7 = renderSvc->RenderTileFromMetaTile(map, metaTile, rendererName, 1, 1);
+ Ptr<MgByteReader> tile4_6 = renderSvc->RenderTileFromMetaTile(map, metaTile, 0, 0);
+ Ptr<MgByteReader> tile4_7 = renderSvc->RenderTileFromMetaTile(map, metaTile, 0, 1);
+ Ptr<MgByteReader> tile5_6 = renderSvc->RenderTileFromMetaTile(map, metaTile, 1, 0);
+ Ptr<MgByteReader> tile5_7 = renderSvc->RenderTileFromMetaTile(map, metaTile, 1, 1);
tile4_6->ToFile(GetPath(L"../UnitTestFiles/RenderTile_4_6_Metatiled", imageFormat, extension));
@@ -1785,11 +1784,10 @@
//metaTile->ToFile(L"../UnitTestFiles/RenderTileXYZ_Metatile at 16798_23891_16.png");
- Ptr<MgByteReader> tile_16798_23891 = renderSvc->RenderTileFromMetaTile(map, metaTile, rendererName, 0, 0);
- Ptr<MgByteReader> tile_16799_23891 = renderSvc->RenderTileFromMetaTile(map, metaTile, rendererName, 1, 0);
- Ptr<MgByteReader> tile_16798_23892 = renderSvc->RenderTileFromMetaTile(map, metaTile, rendererName, 0, 1);
- Ptr<MgByteReader> tile_16799_23892 = renderSvc->RenderTileFromMetaTile(map, metaTile, rendererName, 1, 1);
+ Ptr<MgByteReader> tile_16798_23891 = renderSvc->RenderTileFromMetaTile(map, metaTile, 0, 0);
+ Ptr<MgByteReader> tile_16799_23891 = renderSvc->RenderTileFromMetaTile(map, metaTile, 1, 0);
+ Ptr<MgByteReader> tile_16798_23892 = renderSvc->RenderTileFromMetaTile(map, metaTile, 0, 1);
+ Ptr<MgByteReader> tile_16799_23892 = renderSvc->RenderTileFromMetaTile(map, metaTile, 1, 1);
tile_16798_23891->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16798_23891_16_Metatiled", imageFormat, extension));
tile_16799_23891->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_16799_23891_16_Metatiled", imageFormat, extension));
Modified: trunk/MgDev/Server/src/UnitTesting/TestTileService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestTileService.cpp 2019-06-19 16:14:46 UTC (rev 9558)
+++ trunk/MgDev/Server/src/UnitTesting/TestTileService.cpp 2019-06-22 08:42:36 UTC (rev 9559)
@@ -1789,7 +1789,7 @@
for (INT32 y = 0; y < metaTile->GetMetaTilingFactor(); y++)
- Ptr<MgByteReader> img = renderSvc->RenderTileFromMetaTile(map, metaTile, L"AGG", x, y);
+ Ptr<MgByteReader> img = renderSvc->RenderTileFromMetaTile(map, metaTile, x, y);
INT64 tileLen = img->GetLength();
STRING fileName = L"../UnitTestFiles/GetMetatileSingle_Baseline/";
STRING s;
@@ -1868,7 +1868,7 @@
for (INT32 y1 = 0; y1 < mtFactor; y1++)
- Ptr<MgByteReader> img = renderSvc->RenderTileFromMetaTile(map, metaTile, L"AGG", x1, y1);
+ Ptr<MgByteReader> img = renderSvc->RenderTileFromMetaTile(map, metaTile, x1, y1);
STRING fileName = L"../UnitTestFiles/GetMetatileSingleXYZ_Baseline/";
STRING s;
More information about the mapguide-commits
